AM623: AM623 CPU1: failed in unknown state : 0x0
Part Number: AM623
Other Parts Discussed in Thread: AM625
Device: AM623 GP
Installer: ti-processor-sdk-linux-am62xx-evm-09.00.00.03-Linux-x86-Install.bin — 6664936 K
SD card image: tisdk-debian-bookworm-am62xx-evm.wic.xz — 1955030 K
boot message:
U-Boot SPL 2023.04 (Aug 25 2023 - 11:35:38 +0800)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE:  BL31: Built : 00:42:57, Jan 13 2023
U-Boot SPL 2023.04 (Aug 25 2023 - 11:35:46 +0800)
SPL initial stack usage: 1856 bytes
Error (-2): cannot determine file size
U-Boot 2023.04 (Aug 25 2023 - 11:35:46 +0800)
SoC:   AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 80, trying to read at 81
Reading on-board EEPROM at 0x51 failed -1
DRAM:  2 GiB
Core:  71 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   Could not get PHY for ethernet@8000000port@1: addr 0
am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
## Error: "main_cpsw0_qsgmii_phyinit" not defined
20593152 bytes read in 237 ms (82.9 MiB/s)
57500 bytes read in 19 ms (2.9 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
   Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.33 (andrew@andrew-GENESYS-CML5) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #2 SMP PREEMPT Fri Aug 18 09:31:36 CST 2023
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
[    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[    0.000000]   node   0: [mem 0x00000000fffca000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=a0ea9fb9-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1838092K/2097152K available (12480K kernel code, 1294K rwdata, 4044K rodata, 2176K init, 498K bss, 127988K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008545] Console: colour dummy device 80x25
[    0.013138] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023822] pid_max: default: 32768 minimum: 301
[    0.028596] LSM: Security Framework initializing
[    0.033452] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.041037] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.050861] cblist_init_generic: Setting adjustable number of callback queues.
[    0.058328] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.064629] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.071028] rcu: Hierarchical SRCU implementation.
[    0.075935] rcu:     Max phase no-delay instances is 1000.
[    0.081541] Platform MSI: msi-controller@1820000 domain created
[    0.087856] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.097701] EFI services will not be available.
[    0.102634] smp: Bringing up secondary CPUs ...
[    5.134753] CPU1: failed to come online
[    5.138676] CPU1: failed in unknown state : 0x0
[   10.262839] CPU2: failed to come online
[   10.266763] CPU2: failed in unknown state : 0x0
[   15.390936] CPU3: failed to come online
[   15.394860] CPU3: failed in unknown state : 0x0
[   15.399556] smp: Brought up 1 node, 1 CPU
[   15.403670] SMP: Total of 1 processors activated.
[   15.408495] CPU features: detected: 32-bit EL0 Support
[   15.413756] CPU features: detected: CRC32 instructions
[   15.419082] CPU: All CPU(s) started at EL2
[   15.423269] alternatives: applying system-wide alternatives
[   15.430743] devtmpfs: initialized
[   15.442332] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[   15.452353] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
SoC:   AM62X SR1.0 GP
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
No ethernet found.
Starting kernel ...
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008544] Console: colour dummy device 80x25
[    0.023820] pid_max: default: 32768 minimum: 301
[    0.028593] LSM: Security Framework initializing
[    0.033448] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.041034] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.050860] cblist_init_generic: Setting adjustable number of callback queues.
[    0.058319] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.064620] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.071016] rcu: Hierarchical SRCU implementation.
[    0.075923] rcu:     Max phase no-delay instances is 1000.
[    0.081527] Platform MSI: msi-controller@1820000 domain created
[    0.087839] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.097680] EFI services will not be available.
[    0.102613] smp: Bringing up secondary CPUs ...
[    5.134729] CPU1: failed to come online
[    5.138652] CPU1: failed in unknown state : 0x0
[   10.262815] CPU2: failed to come online
[   10.266736] CPU2: failed in unknown state : 0x0
[   15.390900] CPU3: failed to come online
[   15.394823] CPU3: failed in unknown state : 0x0
[   15.399520] smp: Brought up 1 node, 1 CPU
[   15.403635] SMP: Total of 1 processors activated.
[   15.408460] CPU features: detected: 32-bit EL0 Support
[   15.413721] CPU features: detected: CRC32 instructions
[   15.419048] CPU: All CPU(s) started at EL2
[   15.423235] alternatives: applying system-wide alternatives
[   15.430790] devtmpfs: initialized
[   15.442368] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[   15.452388] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
SoC:   AM62X SR1.0 GP
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
No ethernet found.
20593152 bytes read in 238 ms (82.5 MiB/s)
57500 bytes read in 18 ms (3 MiB/s)
Starting kernel ...
Other than not booting normally, I see "Model: Texas Instruments AM625 SK" and "CPU1: failed in unknown state : 0x0".
SoC:   AM62X SR1.0 GP
DRAM:  2 GiB
I can use the same SD card to boot the AM625 board, please provide the operation steps to boot the AM623 board.
Andrew
