AM69A: Not able to run custom ONXX model for object detection on on Eagle AI studio
Part Number: AM69A
I have been trying to run custom ONXX model on eagle ai studio for object detection. Below steps I followed-
Model analyzer -> selected AM69A - 32 TOPS -> selected custom model onnx runtime
Then I downloaded the pre trained model from this link https://github.com/onnx/models/tree/main/vision/object_detection_segmentation/mask-rcnn (Mask R-CNN R-50-FPN) and tried to run.
Each time I am trying to compile the model, the kernel is getting dead and in some cases, it is giving bad malloc error. This happens when I am using custom onnx model only. So far I am not able to compile and run any single onnx custom model. I have 3 models.
Mask RCNN, yolact (resnet50) and yolact (resnet18).
Even I tried the simple onxx code to check the model -
import onnx
import os
# Preprocessing: load the ONNX model
#model_path = os.path.join("resources", "single_relu.onnx")
onnx_model = onnx.load('path to uploaded model')
print("The model is:\n{}".format(onnx_model))
# Check the model
try:
    onnx.checker.check_model(onnx_model)
except onnx.checker.ValidationError as e:
    print("The model is invalid: %s" % e)
else:
    print("The model is valid!")
Here also the kernel keeps getting disconnected and dead. I tried 1 more custom model onnx based but got the same issue. I have to do log out and login to make it work again. Restarting EVM or kernel is not fixing this issue.
Please let me know why is it happening.
  • Hi Akhilesh,
    I tried to compile "mask_rcnn_R_50_FPN_1" and I saw in notebooks/logs error message "Could not find const or initializer of layer 2170 !!!" (attached log for your reference)
    I am not familiar with this model, but maybe this could give you a hint.
    One thing we recommend is to run models in ARM only, to confirm they run OK. I tried to run it, I used vseg-onnx notebook as a baseline, as I saw in github this is a segmentation model, but you could use either as only postprocessing and visualization would change. Anyhow, it didn't work for me. Attached notebook used. Could you try to run it on ARM only? to discard any possible mistake from my side. Let me know your results.
    tidl_tools_path                                 = /home/root/notebooks/tidl_tools
    artifacts_folder                                = custom-artifacts/onnx/mask_rcnn_R_50_FPN_1x.onnx
    tidl_tensor_bits                                = 8
    debug_level                                     = 1
    num_tidl_subgraphs                              = 16
    tidl_denylist                                   =
    tidl_denylist_layer_name                        =
    tidl_denylist_layer_type                         =
    tidl_allowlist_layer_name                        =
    model_type                                      =
    tidl_calibration_accuracy_level                 = 7
    tidl_calibration_options:num_frames_calibration = 4
    tidl_calibration_options:bias_calibration_iterations = 3
    mixed_precision_factor = -1.000000
    model_group_id = 0
    power_of_2_quantization                         = 2
    enable_high_resolution_optimization             = 0
    pre_batchnorm_fold                              = 1
    add_data_convert_ops                          = 0
    output_feature_16bit_names_list                 =
    m_params_16bit_names_list                       =
    reserved_compile_constraints_flag               = 1601
    ti_internal_reserved_1                          =
    WARNING : 'meta_layers_names_list' is not provided - running OD post processing in ARM mode
    Number of OD backbone nodes = 0
    Size of odBackboneNodeIds = 0
    Only float and INT64 tensor is supported
    Could not find const or initializer of layer 2178 !!!
    Layer 0 -- layer name -- 0
     Input dims size = 3     dims --- 3   0   0
    Layer 0 --- op type -  Unsqueeze,   Number of input dims 3  !=  4 .. not supported by TIDL
    Layer 1 -- layer name -- 2
     Input dims size = 4     dims --- 1   3   0   0
    Supported TIDL layer type ---            Conv -- 2
    Layer 2 -- layer name -- 7
     Input dims size = 4     dims --- 1   64   0   0
    Supported TIDL layer type ---            Relu -- 7
    Layer 3 -- layer name -- 8
    Supported TIDL layer type ---         MaxPool -- 8
    Layer 4 -- layer name -- 30
    Supported TIDL layer type ---            Conv -- 30
    Layer 5 -- layer name -- 10
    Supported TIDL layer type ---            Conv -- 10
    Layer 6 -- layer name -- 15
    Supported TIDL layer type ---            Relu -- 15
    Layer 7 -- layer name -- 17
    Supported TIDL layer type ---            Conv -- 17
    Layer 8 -- layer name -- 22
    Supported TIDL layer type ---            Relu -- 22
    Layer 9 -- layer name -- 24
    Supported TIDL layer type ---            Conv -- 24
    Layer 10 -- layer name -- 35
     Input dims size = 4     dims --- 1   256   0   0
    Supported TIDL layer type ---             Add -- 35
    Layer 11 -- layer name -- 36
    Supported TIDL layer type ---            Relu -- 36
    Layer 12 -- layer name -- 38
    Supported TIDL layer type ---            Conv -- 38
    Layer 13 -- layer name -- 43
    Supported TIDL layer type ---            Relu -- 43
    Layer 14 -- layer name -- 45
    Supported TIDL layer type ---            Conv -- 45
    Layer 15 -- layer name -- 50
    Supported TIDL layer type ---            Relu -- 50
    Layer 16 -- layer name -- 52
    Supported TIDL layer type ---            Conv -- 52
    Layer 17 -- layer name -- 57
    Supported TIDL layer type ---             Add -- 57
    Layer 18 -- layer name -- 58
    Supported TIDL layer type ---            Relu -- 58
    Layer 19 -- layer name -- 60
    Supported TIDL layer type ---            Conv -- 60
    Layer 20 -- layer name -- 65
    Supported TIDL layer type ---            Relu -- 65
    Layer 21 -- layer name -- 67
    Supported TIDL layer type ---            Conv -- 67
    Layer 22 -- layer name -- 72
    Supported TIDL layer type ---            Relu -- 72
    Layer 23 -- layer name -- 74
    Supported TIDL layer type ---            Conv -- 74
    Layer 24 -- layer name -- 79
    Supported TIDL layer type ---             Add -- 79
    Layer 25 -- layer name -- 80
    Supported TIDL layer type ---            Relu -- 80
    Layer 26 -- layer name -- 102
    Supported TIDL layer type ---            Conv -- 102
    Layer 27 -- layer name -- 82
    Supported TIDL layer type ---            Conv -- 82
    Layer 28 -- layer name -- 87
     Input dims size = 4     dims --- 1   128   0   0
    Supported TIDL layer type ---            Relu -- 87
    Layer 29 -- layer name -- 89
    Supported TIDL layer type ---            Conv -- 89
    Layer 30 -- layer name -- 94
    Supported TIDL layer type ---            Relu -- 94
    Layer 31 -- layer name -- 96
    Supported TIDL layer type ---            Conv -- 96
    Layer 32 -- layer name -- 107
     Input dims size = 4     dims --- 1   512   0   0
    Supported TIDL layer type ---             Add -- 107
    Layer 33 -- layer name -- 108
    Supported TIDL layer type ---            Relu -- 108
    Layer 34 -- layer name -- 110
    Supported TIDL layer type ---            Conv -- 110
    Layer 35 -- layer name -- 115
    Supported TIDL layer type ---            Relu -- 115
    Layer 36 -- layer name -- 117
    Supported TIDL layer type ---            Conv -- 117
    Layer 37 -- layer name -- 122
    Supported TIDL layer type ---            Relu -- 122
    Layer 38 -- layer name -- 124
    Supported TIDL layer type ---            Conv -- 124
    Layer 39 -- layer name -- 129
    Supported TIDL layer type ---             Add -- 129
    Layer 40 -- layer name -- 130
    Supported TIDL layer type ---            Relu -- 130
    Layer 41 -- layer name -- 132
    Supported TIDL layer type ---            Conv -- 132
    Layer 42 -- layer name -- 137
    Supported TIDL layer type ---            Relu -- 137
    Layer 43 -- layer name -- 139
    Supported TIDL layer type ---            Conv -- 139
    Layer 44 -- layer name -- 144
    Supported TIDL layer type ---            Relu -- 144
    Layer 45 -- layer name -- 146
    Supported TIDL layer type ---            Conv -- 146
    Layer 46 -- layer name -- 151
    Supported TIDL layer type ---             Add -- 151
    Layer 47 -- layer name -- 152
    Supported TIDL layer type ---            Relu -- 152
    Layer 48 -- layer name -- 154
    Supported TIDL layer type ---            Conv -- 154
    Layer 49 -- layer name -- 159
    Supported TIDL layer type ---            Relu -- 159
    Layer 50 -- layer name -- 161
    Supported TIDL layer type ---            Conv -- 161
    Layer 51 -- layer name -- 166
    Supported TIDL layer type ---            Relu -- 166
    Layer 52 -- layer name -- 168
    Supported TIDL layer type ---            Conv -- 168
    Layer 53 -- layer name -- 173
    Supported TIDL layer type ---             Add -- 173
    Layer 54 -- layer name -- 174
    Supported TIDL layer type ---            Relu -- 174
    Layer 55 -- layer name -- 196
    Supported TIDL layer type ---            Conv -- 196
    Layer 56 -- layer name -- 176
    Supported TIDL layer type ---            Conv -- 176
    Layer 57 -- layer name -- 181
    Supported TIDL layer type ---            Relu -- 181
    Layer 58 -- layer name -- 183
    Supported TIDL layer type ---            Conv -- 183
    Layer 59 -- layer name -- 188
    Supported TIDL layer type ---            Relu -- 188
    Layer 60 -- layer name -- 190
    Supported TIDL layer type ---            Conv -- 190
    Layer 61 -- layer name -- 201
     Input dims size = 4     dims --- 1   1024   0   0
    Supported TIDL layer type ---             Add -- 201
    Layer 62 -- layer name -- 202
    Supported TIDL layer type ---            Relu -- 202
    Layer 63 -- layer name -- 204
    Supported TIDL layer type ---            Conv -- 204
    Layer 64 -- layer name -- 209
    Supported TIDL layer type ---            Relu -- 209
    Layer 65 -- layer name -- 211
    Supported TIDL layer type ---            Conv -- 211
    Layer 66 -- layer name -- 216
    Supported TIDL layer type ---            Relu -- 216
    Layer 67 -- layer name -- 218
    Supported TIDL layer type ---            Conv -- 218
    Layer 68 -- layer name -- 223
    Supported TIDL layer type ---             Add -- 223
    Layer 69 -- layer name -- 224
    Supported TIDL layer type ---            Relu -- 224
    Layer 70 -- layer name -- 226
    Supported TIDL layer type ---            Conv -- 226
    Layer 71 -- layer name -- 231
    Supported TIDL layer type ---            Relu -- 231
    Layer 72 -- layer name -- 233
    Supported TIDL layer type ---            Conv -- 233
    Layer 73 -- layer name -- 238
    Supported TIDL layer type ---            Relu -- 238
    Layer 74 -- layer name -- 240
    Supported TIDL layer type ---            Conv -- 240
    Layer 75 -- layer name -- 245
    Supported TIDL layer type ---             Add -- 245
    Layer 76 -- layer name -- 246
    Supported TIDL layer type ---            Relu -- 246
    Layer 77 -- layer name -- 248
    Supported TIDL layer type ---            Conv -- 248
    Layer 78 -- layer name -- 253
    Supported TIDL layer type ---            Relu -- 253
    Layer 79 -- layer name -- 255
    Supported TIDL layer type ---            Conv -- 255
    Layer 80 -- layer name -- 260
    Supported TIDL layer type ---            Relu -- 260
    Layer 81 -- layer name -- 262
    Supported TIDL layer type ---            Conv -- 262
    Layer 82 -- layer name -- 267
    Supported TIDL layer type ---             Add -- 267
    Layer 83 -- layer name -- 268
    Supported TIDL layer type ---            Relu -- 268
    Layer 84 -- layer name -- 270
    Supported TIDL layer type ---            Conv -- 270
    Layer 85 -- layer name -- 275
    Supported TIDL layer type ---            Relu -- 275
    Layer 86 -- layer name -- 277
    Supported TIDL layer type ---            Conv -- 277
    Layer 87 -- layer name -- 282
    Supported TIDL layer type ---            Relu -- 282
    Layer 88 -- layer name -- 284
    Supported TIDL layer type ---            Conv -- 284
    Layer 89 -- layer name -- 289
    Supported TIDL layer type ---             Add -- 289
    Layer 90 -- layer name -- 290
    Supported TIDL layer type ---            Relu -- 290
    Layer 91 -- layer name -- 292
    Supported TIDL layer type ---            Conv -- 292
    Layer 92 -- layer name -- 297
    Supported TIDL layer type ---            Relu -- 297
    Layer 93 -- layer name -- 299
    Supported TIDL layer type ---            Conv -- 299
    Layer 94 -- layer name -- 304
    Supported TIDL layer type ---            Relu -- 304
    L
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/vseg_2D00_onnx_2D00_cat.ipynb
    Thank you,
    Paula
    Thanks for reply. I check the same and found the same issue. Let's ignore this model.
    I tried to run one more model which is a custom model with resnet18 backbone. This model also I am not able to compile. This is an instance segmentation model, yolact github.com/.../yolact
    I am attaching the logs. It says unsupported TIDL layers for some of the ops. Does this mean TI framework has not supported these operations yet? like transpose, padding?
    artifacts_folder                                = custom-artifacts/yolact_resnet18_54_400000.onnx
    debug_level                                     = 1
    tidl_denylist                                   = MaxPool
    model_type                                      =
    model_group_id = 0
     ****** WARNING : Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options******
    Supported TIDL layer type ---            Conv -- Conv_16
    Supported TIDL layer type ---            Relu -- Relu_17
    Op type 'MaxPool'  added to unsupported nodes as specified in deny list
    Supported TIDL layer type ---            Conv -- Conv_19
    Supported TIDL layer type ---            Relu -- Relu_20
    Supported TIDL layer type ---            Conv -- Conv_21
    Supported TIDL layer type ---             Add -- Add_22
    Supported TIDL layer type ---            Relu -- Relu_23
    Supported TIDL layer type ---            Conv -- Conv_24
    Supported TIDL layer type ---            Relu -- Relu_25
    Supported TIDL layer type ---            Conv -- Conv_26
    Supported TIDL layer type ---             Add -- Add_27
    Supported TIDL layer type ---            Relu -- Relu_28
    Supported TIDL layer type ---            Conv -- Conv_32
    Supported TIDL layer type ---            Conv -- Conv_29
    Supported TIDL layer type ---            Relu -- Relu_30
    Supported TIDL layer type ---            Conv -- Conv_31
    Supported TIDL layer type ---             Add -- Add_33
    Supported TIDL layer type ---            Relu -- Relu_34
    Supported TIDL layer type ---            Conv -- Conv_35
    Supported TIDL layer type ---            Relu -- Relu_36
    Supported TIDL layer type ---            Conv -- Conv_37
    Supported TIDL layer type ---             Add -- Add_38
    Supported TIDL layer type ---            Relu -- Relu_39
    Supported TIDL layer type ---            Conv -- Conv_43
    Supported TIDL layer type ---            Conv -- Conv_40
    Supported TIDL layer type ---            Relu -- Relu_41
    Supported TIDL layer type ---            Conv -- Conv_42
    Supported TIDL layer type ---             Add -- Add_44
    Supported TIDL layer type ---            Relu -- Relu_45
    Supported TIDL layer type ---            Conv -- Conv_46
    Supported TIDL layer type ---            Relu -- Relu_47
    Supported TIDL layer type ---            Conv -- Conv_48
    Supported TIDL layer type ---             Add -- Add_49
    Supported TIDL layer type ---            Relu -- Relu_50
    Supported TIDL layer type ---            Conv -- Conv_54
    Supported TIDL layer type ---            Conv -- Conv_51
    Supported TIDL layer type ---            Relu -- Relu_52
    Supported TIDL layer type ---            Conv -- Conv_53
    Supported TIDL layer type ---             Add -- Add_55
    Supported TIDL layer type ---            Relu -- Relu_56
    Supported TIDL layer type ---            Conv -- Conv_57
    Supported TIDL layer type ---            Relu -- Relu_58
    Supported TIDL layer type ---            Conv -- Conv_59
    Supported TIDL layer type ---             Add -- Add_60
    Supported TIDL layer type ---            Relu -- Relu_61
    Supported TIDL layer type ---            Conv -- Conv_62
    Supported TIDL layer type ---            Conv -- Conv_75
    Supported TIDL layer type ---            Relu -- Relu_76
    Supported TIDL layer type ---            Conv -- Conv_81
    Supported TIDL layer type ---            Conv -- Conv_82
    Supported TIDL layer type ---            Conv -- Conv_175
    Supported TIDL layer type ---            Relu -- Relu_176
    Supported TIDL layer type ---            Conv -- Conv_180
    Unsupported (TIDL check) TIDL layer type ---       Transpose
    Supported TIDL layer type ---         Reshape -- Reshape_182
    Supported TIDL layer type ---            Conv -- Conv_164
    Supported TIDL layer type ---            Relu -- Relu_165
    Supported TIDL layer type ---            Conv -- Conv_169
    Supported TIDL layer type ---         Reshape -- Reshape_171
    Supported TIDL layer type ---            Conv -- Conv_153
    Supported TIDL layer type ---            Relu -- Relu_154
    Supported TIDL layer type ---            Conv -- Conv_158
    Supported TIDL layer type ---         Reshape -- Reshape_160
    Supported TIDL layer type ---            Conv -- Conv_67
    Error : Unsupported Opset for Resize OP
    Resize layer delegated to ARM -- 'Resize_63'
    Unsupported (TIDL check) TIDL layer type ---          Resize
    ERROR : Opset 13 pad is not supported
    Unsupported (TIDL check) TIDL layer type ---             Pad
    Unsupported (TIDL check) TIDL layer type ---     AveragePool
    Supported TIDL layer type ---             Add -- Add_68
    Supported TIDL layer type ---            Conv -- Conv_77
    Supported TIDL layer type ---            Relu -- Relu_78
    Supported TIDL layer type ---            Conv -- Conv_124
    Supported TIDL layer type ---            Relu -- Relu_125
    Supported TIDL layer type ---            Conv -- Conv_135
    Supported TIDL layer type ---         Reshape -- Reshape_143
    Supported TIDL layer type ---            Conv -- Conv_73
    Resize layer delegated to ARM -- 'Resize_69'
    Supported TIDL layer type ---             Add -- Add_74
    Supported TIDL layer type ---            Conv -- Conv_79
    Supported TIDL layer type ---            Relu -- Relu_80
    Supported TIDL layer type ---            Conv -- Conv_95
    Supported TIDL layer type ---            Relu -- Relu_96
    Supported TIDL layer type ---            Conv -- Conv_106
    Supported TIDL layer type ---         Reshape -- Reshape_114
    Supported TIDL layer type ---          Concat -- Concat_187
    Supported TIDL layer type ---         Softmax -- Softmax_190
    Supported TIDL layer type ---            Conv -- Conv_183
    Supported TIDL layer type ---         Reshape -- Reshape_185
    Supported TIDL layer type ---            Conv -- Conv_172
    Supported TIDL layer type ---         Reshape -- Reshape_174
    Supported TIDL layer type ---            Conv -- Conv_161
    Supported TIDL layer type ---         Reshape -- Reshape_163
    Supported TIDL layer type ---            Conv -- Conv_144
    Supported TIDL layer type ---         Reshape -- Reshape_152
    Supported TIDL layer type ---            Conv -- Conv_115
    Supported TIDL layer type ---         Reshape -- Reshape_123
    Supported TIDL layer type ---          Concat -- Concat_188
    Supported TIDL layer type ---            T
    Let me know about unsupported TIDL layers.
    Any recommendations on instance segmentation model? Because I checked the TI model zoo, it does not have any instance seg models.
    Akhilesh Gangwar
  • Also, I am not able to run yolov5s and yolov5l as well. Kernel is getting dead. This is the device log-
    Internal Error: do_recv() expected MSG_ID 5005, got 0!
    Stack trace:
      [bt] (0) /usr/lib/libti_inference_client.so(StackTrace[abi:cxx11](unsigned long, unsigned long)+0x1ed) [0x7f5d7fca505d]
      [bt] (1) /usr/lib/libti_inference_client.so(send_once(unsigned int, void*, int, progressbar*, progressbar*)+0x838) [0x7f5d7fca4ac8]
      [bt] (2) /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so(+0x8074c) [0x7f5d7ff3774c]
      [bt] (3) /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so(+0x80aa9) [0x7f5d7ff37aa9]
      [bt] (4) /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so(+0x880ef) [0x7f5d7ff3f0ef]
      [bt] (5) /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so(+0xa5a67) [0x7f5d7ff5ca67]
      [bt] (6) /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so(+0x74433) [0x7f5d7ff2b433]
      [bt] (7) /usr/bin/python3(_PyCFunction_FastCallDict+0x35c) [0x566b0c]
      [bt] (8) /usr/bin/python3() [0x594741]
      [bt] (9) /usr/bin/python3() [0x549ea5]
      [bt] (10) /usr/bin/python3() [0x5513f1]
      [bt] (11) /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so(+0x767a7) [0x7f5d7ff2d7a7]
      [bt] (12) /usr/bin/python3(_PyObject_FastCallKeywords+0x19c) [0x5a9b9c]
      [bt] (13) /usr/bin/python3() [0x50a2c3]
      [bt] (14) /usr/bin/python3(_PyEval_EvalFrameDefault+0x444) [0x50bcb4]
      [bt] (15) /usr/bin/python3() [0x509459]
    Akhilesh
  • Hi Akhilesh,
    From logs I see "Maxpool" is in "deny_list" could you please delete this from "compile_options". It is there just as an example.
    Also, one option to avoid creation of a lot of subgraphs, which are probably causing the crash, is to use TIDL's meta-architecture in order to replace postprocessing nodes with an OD layer supported by TI.
    edgeai-tidl-tools/docs/tidl_fsg_od_meta_arch.md at master · TexasInstruments/edgeai-tidl-tools · GitHub
    Training video, with some additional details: Process This: Efficient human pose estimation using the YOLO-Pose model and TI processors | Video | TI.com Video is for YoloP
    The main idea is to replace unsupported layers by an OD layer and, be able to offload most (or all) of the model to TIDL.
    In Model Analyzer notebooks/prebuilt-models/8bits you can untar and check OD models to get prototex examples
    Thank you,
    Paula
  • Hi Paula,
    I am able to run yolov5 provided by TI model zoo as a custom model. I am trying one instance segmentation model and getting some undefined behavior.
    Sometimes I am able to compile the model and can see the input and output details. Other times I am getting error while compiling the model itself.
    error -
    RuntimeException                          Traceback (most recent call last)
    <ipython-input-16-5cc78ed11a7d> in <module>
    ----> 1 sess = rt.InferenceSession(onnx_model_path ,providers=EP_list, provider_options=[compile_options, {}], sess_options=so)
    /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py in __init__(self, path_or_bytes, sess_options, providers, provider_options)
        281
        282         try:
    --> 283             self._create_inference_session(providers, provider_options)
        284         except RuntimeError:
        285             if self._enable_fallback:
    /usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py in _create_inference_session(self, providers, provider_options)
        313
        314         # initialize the C++ InferenceSession
    --> 315         sess.initialize_session(providers, provider_options)
        316
        317         self._sess = sess
    RuntimeException: [ONNXRuntimeError] : 6 : RUNTIME_EXCEPTION : Exception during initialization: basic_string::_M_create
    I checked the logs. There are some unsupported operators as well.
    5, 256
     87,          Concat, 4, 1, 250, 257
     88,            Conv, 3, 1, 257, 258
     89,            Relu, 1, 1, 258, 259
     90,            Conv, 3, 1, 259, 260
     91,            Relu, 1, 1, 260, 261
     92,            Conv, 3, 1, 261, 262
     93,            Relu, 1, 1, 262, 263
     94,            Conv, 3, 1, 263, 264
     95,            Relu, 1, 1, 264, 265
     96,            Conv, 3, 1, 259, 266
     97,            Relu, 1, 1, 266, 267
     98,          Concat, 2, 1, 265, 268
     99,            Conv, 3, 1, 268, 269
    100,            Relu, 1, 1, 269, 270
    101,            Conv, 3, 1, 270, 271
    102,            Relu, 1, 1, 271, 272
    103,          Resize, 3, 1, 272, 277
    104,          Concat, 2, 1, 277, 278
    105,            Conv, 3, 1, 278, 279
    106,            Relu, 1, 1, 279, 280
    107,            Conv, 3, 1, 280, 281
    108,            Relu, 1, 1, 281, 282
    109,            Conv, 3, 1, 282, 283
    110,            Relu, 1, 1, 283, 284
    111,            Conv, 3, 1, 278, 285
    112,            Relu, 1, 1, 285, 286
    113,          Concat, 2, 1, 284, 287
    114,            Conv, 3, 1, 287, 288
    115,            Relu, 1, 1, 288, 289
    116,            Conv, 3, 1, 289, 290
    117,            Relu, 1, 1, 290, 291
    118,          Resize, 3, 1, 291, 296
    119,          Concat, 2, 1, 296, 297
    120,            Conv, 3, 1, 297, 298
    121,            Relu, 1, 1, 298, 299
    122,            Conv, 3, 1, 299, 300
    123,            Relu, 1, 1, 300, 301
    124,            Conv, 3, 1, 301, 302
    125,            Relu, 1, 1, 302, 303
    126,            Conv, 3, 1, 297, 304
    127,            Relu, 1, 1, 304, 305
    128,          Concat, 2, 1, 303, 306
    129,            Conv, 3, 1, 306, 307
    130,            Relu, 1, 1, 307, 308
    131,            Conv, 3, 1, 308, 309
    132,            Relu, 1, 1, 309, 310
    133,          Resize, 3, 1, 310, 315
    134,          Concat, 2, 1, 315, 316
    135,            Conv, 3, 1, 316, 317
    136,            Relu, 1, 1, 317, 318
    137,            Conv, 3, 1, 318, 319
    138,            Relu, 1, 1, 319, 320
    139,            Conv, 3, 1, 320, 321
    140,            Relu, 1, 1, 321, 322
    141,            Conv, 3, 1, 316, 323
    142,            Relu, 1, 1, 323, 324
    143,          Concat, 2, 1, 322, 325
    144,            Conv, 3, 1, 325, 326
    145,            Relu, 1, 1, 326, 327
    146,            Conv, 3, 1, 327, 370
    147,            Conv, 3, 1, 327, 328
    148,            Relu, 1, 1, 328, 329
    149,          Concat, 2, 1, 329, 330
    150,            Conv, 3, 1, 330, 331
    151,            Relu, 1, 1, 331, 332
    152,            Conv, 3, 1, 332, 333
    153,            Relu, 1, 1, 333, 334
    154,            Conv, 3, 1, 334, 335
    155,            Relu, 1, 1, 335, 336
    156,            Conv, 3, 1, 330, 337
    157,            Relu, 1, 1, 337, 338
    158,          Concat, 2, 1, 336, 339
    159,            Conv, 3, 1, 339, 340
    160,            Relu, 1, 1, 340, 341
    161,            Conv, 3, 1, 341, 680
    162,            Conv, 3, 1, 341, 342
    163,            Relu, 1, 1, 342, 343
    164,          Concat, 2, 1, 343, 344
    165,            Conv, 3, 1, 344, 345
    166,            Relu, 1, 1, 345, 346
    167,            Conv, 3, 1, 346, 347
    168,            Relu, 1, 1, 347, 348
    169,            Conv, 3, 1, 348, 349
    170,            Relu, 1, 1, 349, 350
    171,            Conv, 3, 1, 344, 351
    172,            Relu, 1, 1, 351, 352
    173,          Concat, 2, 1, 350, 353
    174,            Conv, 3, 1, 353, 354
    175,            Relu, 1, 1, 354, 355
    176,            Conv, 3, 1, 355, 990
    177,            Conv, 3, 1, 355, 356
    178,            Relu, 1, 1, 356, 357
    179,          Concat, 2, 1, 357, 358
    180,            Conv, 3, 1, 358, 359
    181,            Relu, 1, 1, 359, 360
    182,            Conv, 3, 1, 360, 361
    183,            Relu, 1, 1, 361, 362
    184,            Conv, 3, 1, 362, 363
    185,            Relu, 1, 1, 363, 364
    186,            Conv, 3, 1, 358, 365
    187,            Relu, 1, 1, 365, 366
    188,          Concat, 2, 1, 364, 367
    189,            Conv, 3, 1, 367, 368
    190,            Relu, 1, 1, 368, 369
    191,            Conv, 3, 1, 369, 1300
    Input tensor name -  images
    Output tensor name - 1300
    Output tensor name - 990
    Output tensor name - 680
    Output tensor name - 370
    artifacts_folder                                = custom-artifacts/onnx/yolact_resnet18_54_400000.onnx
    debug_level                                     = 1
    tidl_denylist                                   =
    model_type                                      =
    tidl_calibration_options:num_frames_calibration = 5
    model_group_id = 0
    Supported TIDL layer type ---         MaxPool -- MaxPool_18
    Unsupported (TIDL check) TIDL layer type ---            Tanh
    Supported TIDL layer type ---            Conv -- Conv_177
    Supported TIDL layer type ---         Reshape -- Reshape_179
    Supported TIDL layer type ---            Conv -- Conv_166
    Supported TIDL layer type ---         Reshape -- Reshape_168
    Supported TIDL layer type ---            Conv -- Conv_155
    Supported TIDL layer type ---         Reshape -- Reshape_157
    Supported TIDL layer type ---            Conv -- Conv_126
    Supported TIDL layer type ---         Reshape -- Reshape_134
    Supported TIDL layer type ---            Conv -- Conv_97
    Supported TIDL layer type ---         Reshape -- Reshape_105
    Supported TIDL layer type ---          Concat -- Concat_186
    Supported TIDL layer type ---            Conv -- Conv_83
    Supported TIDL layer type ---            Relu -- Relu_84
    Supported TIDL layer type ---            Conv -- Conv_85
    Supported TIDL layer type ---            Relu -- Relu_86
    Supported TIDL layer type ---            Conv -- Conv_87
    Supported TIDL layer type ---            Relu -- Relu_88
    Resize layer delegated to ARM -- 'Resize_89'
    Supported TIDL layer type ---            Conv -- Conv_90
    Supported TIDL layer type ---            Relu -- Relu_91
    Supported TIDL layer type ---            Conv -- Conv_92
    Supported TIDL layer type ---            Relu -- Relu_93
    Preliminary subgraphs created = 20
    *** WARNING : Number of subgraphs generated > max_num_subgraphs provided in options - additional subgraphs are delegated to ARM ***
    Final number of subgraphs created are : 16, - Offloaded Nodes - 99, Total Nodes - 137
    TIDL ALLOWLISTING LAYER CHECK -- [TIDL_TransposeLayer]  should be removed in import process. If not, this model will not work!
    TIDL ALLOWLISTING LAYER CHECK -- TIDL_PoolingLayer '': kernel size 2x2 with stride 1x1 not supported
    TIDL ALLOWLISTING LAYER CHECK -- [TIDL_TanhLayer]  should be removed in import process. This activation type is not supported now !!!
    Running runtimes graphviz - /home/root/notebooks/tidl_tools/tidl_graphVisualiser_runtimes.out custom-artifacts/onnx/yolact_resnet18_54_400000.onnx/allowedNode.txt custom-artifacts/onnx/yolact_resnet18_54_400000.onnx/tempDir/graphvizInfo.txt custom-artifacts/onnx/yolact_resnet18_54_400000.onnx/tempDir/runtimes_visualization.svg
    *** In TIDL_createStateImportFunc ***
    Compute on node : TIDLExecutionProvider_TIDL_0_0
      0,            Conv, 3, 1, input.1, input.4
      1,            Relu, 1, 1, input.4, onnx::MaxPool_159
      2,         MaxPool, 1, 1, onnx::MaxPool_159, input.8
      3,            Conv, 3, 1, input.8, input.16
      4,            Relu, 1, 1, input.16, onnx::Conv_163
      5,            Conv, 3, 1, onnx::Conv_163, onnx::Add_496
      6,             Add, 2, 1, onnx::Add_496, onnx::Relu_166
      7,            Relu, 1, 1, onnx::Relu_166, input.24
      8,            Conv, 3, 1, input.24, input.32
      9,            Relu, 1, 1, input.32, onnx::Conv_170
     10,            Conv, 3, 1, onnx::Conv_170, onnx::Add_502
     11,             Add, 2, 1, onnx::Add_502, onnx::Relu_173
     12,            Relu, 1, 1, onnx::Relu_173, input.40
     13,            Conv, 3, 1, input.40, input.48
     14,            Relu, 1, 1, input.48, onnx::Conv_177
     15,            Conv, 3, 1, onnx::Conv_177, onnx::Add_508
     16,            Conv, 3, 1, input.40, onnx::Add_511
     17,             Add, 2, 1, onnx::Add_508, onnx::Relu_182
     18,            Relu, 1, 1, onnx::Relu_182, input.60
     19,            Conv, 3, 1, input.60, input.68
     20,            Relu, 1, 1, input.68, onnx::Conv_186
     21,            Conv, 3, 1, onnx::Conv_186, onnx::Add_517
     22,             Add, 2, 1, onnx::Add_517, onnx::Relu_189
     23,            Relu, 1, 1, onnx::Relu_189, input.76
     24,            Conv, 3, 1, input.76, input.84
     25,            Relu, 1, 1, input.84, onnx::Conv_193
     26,            Conv, 3, 1, onnx::Conv_193, onnx::Add_523
     27,            Conv, 3, 1, input.76, onnx::Add_526
     28,             Add, 2, 1, onnx::Add_523, onnx::Relu_198
     29,            Relu, 1, 1, onnx::Relu_198, input.96
     30,            Conv, 3, 1, input.96, input.104
     31,            Relu, 1, 1, input.104, onnx::Conv_202
     32,            Conv, 3, 1, onnx::Conv_202, onnx::Add_532
     33,             Add, 2, 1, onnx::Add_532, onnx::Relu_205
     34,            Relu, 1, 1, onnx::Relu_205, input.112
     35,            Conv, 3, 1, input.112, input.120
     36,            Relu, 1, 1, input.120, onnx::Conv_209
     37,            Conv, 3, 1, onnx::Conv_209, onnx::Add_538
     38,            Conv, 3, 1, input.112, onnx::Add_541
     39,             Add, 2, 1, onnx::Add_538, onnx::Relu_214
     40,            Relu, 1, 1, onnx::Relu_214, input.132
     41,            Conv, 3, 1, input.132, input.140
     42,            Relu, 1, 1, input.140, onnx::Conv_218
     43,            Conv, 3, 1, onnx::Conv_218, onnx::Add_547
     44,             Add, 2, 1, onnx::Add_547, onnx::Relu_221
     45,            Relu, 1, 1, onnx::Relu_221, input.148
     46,            Conv, 3, 1, input.148, x
     47,            Conv, 3, 1, x, onnx::Relu_244
     48,            Relu, 1, 1, onnx::Relu_244, onnx::Conv_245
     49,            Conv, 3, 1, onnx::Conv_245, input.156
     50,            Conv, 3, 1, input.156, input.160
     51,            Conv, 3, 1, input.160, input.200
     52,            Relu, 1, 1, input.200, onnx::Conv_445
     53,            Conv, 3, 1, onnx::Conv_445, onnx::Transpose_446
     54,            Conv, 3, 1, onnx::Conv_445, onnx::Transpose_459
    Input tensor name -  input.1
    Output tensor name - input.76
    Output tensor name - input.112
    Output tensor name - x
    Output tensor name - onnx::Conv_245
    Output tensor name - input.156
    Output tensor name - onnx::Conv_445
    Output tensor name - onnx::Transpose_459
    Output tensor name - onnx::Transpose_446
    Compute on node : TIDLExecutionProvider_TIDL_1_1
      0,            Conv, 3, 1, input.156, input.196
      1,            Relu, 1, 1, input.196, onnx::Conv_404
      2,            Conv, 3, 1, onnx::Conv_404, onnx::Transpose_418
      3,         Reshape, 2, 1, onnx::Reshape_460, onnx::Concat_471
    Input tensor name -  onnx::Reshape_460
    Input tensor name -  input.156
    Output tensor name - onnx::Concat_471
    Output tensor name - onnx::Conv_404
    Output tensor name - onnx::Transpose_418
    Compute on node : TIDLExecutionProvider_TIDL_2_2
      0,            Conv, 3, 1, onnx::Conv_245, input.192
      1,            Relu, 1, 1, input.192, onnx::Conv_363
      2,            Conv, 3, 1, onnx::Conv_363, onnx::Transpose_377
      3,         Reshape, 2, 1, onnx::Reshape_419, onnx::Concat_430
    Input tensor name -  onnx::Reshape_419
    Input tensor name -  onnx::Conv_245
    Output tensor name - onnx::Concat_430
    Output tensor name - onnx::Conv_363
    Output tensor name - onnx::Transpose_377
    Compute on node : TIDLExecutionProvider_TIDL_3_3
      0,            Conv, 3, 1, input.112, onnx::Add_232
      1,         Reshape, 2, 1, onnx::Reshape_378, onnx::Concat_389
    Input tensor name -  onnx::Reshape_378
    Input tensor name -  input.112
    Output tensor name - onnx::Concat_389
    Output tensor name - onnx::Add_232
    Compute on node : TIDLExecutionProvider_TIDL_4_4
      0,             Add, 2, 1, onnx::Add_231, x.3
      1,            Conv, 3, 1, x.3, onnx::Relu_246
      2,            Relu, 1, 1, onnx::Relu_246, onnx::Conv_247
      3,            Conv, 3, 1, onnx::Conv_247, input.188
      4,            Relu, 1, 1, input.188, onnx::Conv_316
      5,            Conv, 3, 1, onnx::Conv_316, onnx::Transpose_332
    Input tensor name -  onnx::Add_231
    Input tensor name -  onnx::Add_232
    Output tensor name - x.3
    Output tensor name - onnx::Conv_316
    Output tensor name - onnx::Transpose_332
    Compute on node : TIDLExecutionProvider_TIDL_5_5
      0,            Conv, 3, 1, input.76, onnx::Add_242
      1,         Reshape, 2, 1, onnx::Reshape_333, onnx::Concat_346
    Input tensor name -  onnx::Reshape_333
    Input tensor name -  input.76
    Output tensor name - onnx::Concat_346
    Output tensor name - onnx::Add_242
    Compute on node : TIDLExecutionProvider_TIDL_6_6
      0,             Add, 2, 1, onnx::Add_241, input.152
      1,            Conv, 3, 1, input.152, onnx::Relu_248
      2,            Relu, 1, 1, onnx::Relu_248, onnx::Conv_249
      3,            Conv, 3, 1, onnx::Conv_249, input.184
      4,            Relu, 1, 1, input.184, onnx::Conv_269
      5,            Conv, 3, 1, onnx::Conv_269, onnx::Transpose_285
    Input tensor name -  onnx::Add_241
    Input tensor name -  onnx::Add_242
    Output tensor name - onnx::Conv_249
    Output tensor name - onnx::Conv_269
    Output tensor name - onnx::Transpose_285
    Compute on node : TIDLExecutionProvider_TIDL_7_7
      0,            Conv, 3, 1, onnx::Conv_445, onnx::Transpose_472
      1,         Reshape, 2, 1, onnx::Reshape_286, onnx::Concat_299
      2,          Concat, 5, 1, onnx::Concat_299, onnx::Softmax_486
      3,         Softmax, 1, 1, onnx::Softmax_486, 489
    Input tensor name -  onnx::Reshape_286
    Input tensor name -  onnx::Concat_346
    Input tensor name -  onnx::Concat_389
    Input tensor name -  onnx::Concat_430
    Input tensor name -  onnx::Concat_471
    Input tensor name -  onnx::Conv_445
    Output tensor name - 489
    Output tensor name - onnx::Transpose_472
    Compute on node : TIDLExecutionProvider_TIDL_8_8
      0,            Conv, 3, 1, onnx::Conv_404, onnx::Transpose_431
      1,         Reshape, 2, 1, onnx::Reshape_473, onnx::Concat_484
    Input tensor name -  onnx::Reshape_473
    Input tensor name -  onnx::Conv_404
    Output tensor name - onnx::Concat_484
    Output tensor name - onnx::Transpose_431
    Compute on node : TIDLExecutionProvider_TIDL_9_9
      0,            Conv, 3, 1, onnx::Conv_363, onnx::Transpose_390
      1,         Reshape, 2, 1, onnx::Reshape_432, onnx::Concat_443
    Input tensor name -  onnx::Reshape_432
    The logs actually interrupted and gave the error.
    I have also seen that sometimes the kernel is dead too.
    Let me know what do you think of above logs and erros.
    Akhilesh
  • Also, when I am trying on tvm for custom model, the example you people has given is for resnet18. Here also I am seeing some issues.
    For TVM-
    I am getting this error
    curl_easy_perform: Peer certificate cannot be authenticated with given CA certificates (from logs).
    For ONXX-
    kernel is getting dead and got the same error -
    Let me know how are you people able to cop up with these issues.
  • Hi Akhilesh, Curl error seems a communication error, maybe it was a hiccup in the communication between the container's server and the EVM farm. Could you try again and let me know if the error persists? if so, can you share the TVM model or the other model so I can reproduce it?.
    thank you,
    Paula
  • Hi Paula,
    Curl error exists for multiple time I tried. It was always there.
    For TVM -
    I was using onnx model for instance segmentation. I was able to compile the model using tvm but during runtime, I am getting this error -
    DLRError                                  Traceback (most recent call last)
    <ipython-input-16-41f189c6abd0> in <module>
          2 #Running inference several times to get an stable performance output
          3 for i in range(2):
    ----> 4     res = model.run({input_name : preprocess_for_onnx_resnet18v2('sample-images/elephant.bmp')})
    /usr/local/lib/python3.6/dist-packages/dlr/api.py in run(self, input_values)
        117         except Exception as ex:
        118             self.neo_logger.exception("error in running inference {} {}".format(self._impl.__class__.__name__, ex))
    --> 119             raise ex
        120
        121     def get_input_names(self):
        114         """
        115         try:
    --> 116             return self._impl.run(input_values)
    /usr/local/lib/python3.6/dist-packages/dlr/dlr_model.py in run(self, input_values)
        449                              "or a np.ndarray/generic (representing treelite models)")
        450         # run model
    --> 451         self._run()
        452         # get output
        453         for i in range(self.num_outputs):
    /usr/local/lib/python3.6/dist-packages/dlr/dlr_model.py in _run(self)
        331     def _run(self):
        332         """A light wrapper to call run in the DLR backend."""
    --> 333         self._check_call(self._lib.RunDLRModel(byref(self.handle)))
        334         if self.backend == "relayvm":
        335             self._lazy_init_output_shape()
    /usr/local/lib/python3.6/dist-packages/dlr/dlr_model.py in _check_call(self, ret)
        158         """
        159         if ret != 0:
    --> 160             raise DLRError(self._lib.DLRGetLastError().decode('ascii'))
        161
        162     def get_input_names(self):
    DLRError:
    It took around 35-40 minutes to compile the model. I am attaching the compiled logs too.
    For ONXX -
    The same instance segmentation model when I am trying to compile gives me this error -
    Exception during initialization: std::bad_alloc
    Please find the model, compiled logs for tvm and notebook in this zip.
    notebooks.zip
  • hi Akhilesh, In the cloud, I was able to reproduce the errors you posted for attached "yolact_resnet18_54_400000.onnx". I tried ARM only and didn't work for me either, I am wondering if you were able to run it in ARM only OK as a sanity check. Please let me know.
    Also, I would recommend you to start testing using edgeai-tidl-tools (https://github.com/TexasInstruments/edgeai-tidl-tools) so you can compile and run inference in host emulation using your local setup instead of the cloud. This could give you more debugging freedom as you will have all the scripts running locally. Also, edgeai-tidl-tools is using latest PSDK9.0, in the cloud we are one release behind for now (soon to be updated).
    thank you,
    Paula
  • Hi Akhilesh, I did a quick try using edgeai-tidl-tools. I am getting unsupported Opset error for Resize. We currently support Opset vesions 10 and 11 but those resize layer are 13. Could be possible for you to change them?.
    Those unsupported layers are delegated to ARM, as mentioned in below log, which is creating more subgraphs and probably some other issue gets uncovered. If we can get those layers to run in TIDL we would only have one graph, which is more ideal.
    Running_Model :  yolact_resnet18_54_400000
    Running shape inference on model ../../../models/public/yolact_resnet18_54_400000.onnx
    thank you,
    Paula
  • " We currently support Opset visions 10 and 11 but those resize layer are 13 "
    Something interesting happened. I did change opset from 13 to 10 and tried to compile the onnx model for tvm. I was successfully able to compile and run the model. I did not visualize the outputs but checked the shapes of the output and those are expected. Then I ran the benchmarking function and checked the FPS and all.
    I thought just by changing the opset to 10 works but by the next time I tried to recompile and run, I am still able to compile but while running, I am getting error.
    While executing this line -
    model = DLRmodel(output_dir, 'cpu')
    I got this error -
    <ipython-input-55-a370abb07017> in <module>
          1 # use deployed artifacts from the compiled model
    ----> 2 model = DLRModel(output_dir, 'cpu')
    /usr/local/lib/python3.6/dist-packages/dlr/api.py in __init__(self, model_path, dev_type, dev_id, error_log_file, use_default_dlr)
         90         except Exception as ex:
         91             self.neo_logger.exception("error in DLRModel instantiation {}".format(ex))
    ---> 92             raise ex
         93
         94     def run(self, input_values):
         87             if dev_id is None:
         88                 dev_id = 0
    ---> 89             self._impl = DLRModelImpl(model_path, dev_type, dev_id, error_log_file, use_default_dlr)
    /usr/local/lib/python3.6/dist-packages/dlr/dlr_model.py in __init__(self, model_path, dev_type, dev_id, error_log_file, use_default_dlr)
         80                                         c_char_p(model_path.encode()),
         81                                         c_int(device_table[dev_type]),
    ---> 82                                         c_int(dev_id)))
         83
         84         self.backend = self._parse_backend()
        158         """
        159         if ret != 0:
        161
    DLRError:
    Only 1 time I am able to run. This was happening on cloud.
    I'll setup everything locally and will update you again.
    I don't understand this behavior of executing everything sometimes and another time getting errors.
    Akhilesh
  • Hi Akhilesh, no sure. if you onnxrt instead of tvm does it works OK?
    thank you,
    Paula
  • Hi Paula,
    Using onnxrt, I am not even able to compile the model. The kernel is getting dead. Let me setup local environment and will see if the same error comes there as well.
    Akhilesh
  • Hi Paula,
    I am trying to setup things locally as you mentioned and following the below link - https://github.com/TexasInstruments/edgeai-tidl-tools
    I have setup the docker and built it. When I am trying to run the ./setup.sh script, I was getting protobuf compiler not found error and then I installed it separately and ran again the script.sh. Everything ran smoothly without any error.
    Now I am trying to run and compile the examples by running -
    cmake ../examples && make -j && cd ..
    But I am getting some linking errors. Attaching the error logs. Please let me know.
    Device - am69a
    Akhilesh
    root@b9da96a9c641:/home/root/build# cmake ../examples && make -j && cd ..
    -- The C compiler identification is GNU 11.4.0
    -- The CXX compiler identification is GNU 11.4.0
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Check for working C compiler: /usr/bin/cc - skipped
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Check for working CXX compiler: /usr/bin/c++ - skipped
    -- Detecting CXX compile features
    -- Detecting CXX compile features - done
    -- Detected processor: x86_64
    -- TARGET_DEVICE setting to: am69a
    -- TARGET_CPU not specicfied using x86
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai_tidl_examples
    -- setting TENSORFLOW_INSTALL_DIR path:/home/root/tidl_tools/osrt_deps/tflite_2.8_x86_u22/
    -- setting DLR_INSTALL_DIR path:/home/root/tidl_tools/osrt_deps/dlr_1.10.0_x86_u22/
    -- setting OPENCV_INSTALL_DIR path:/home/root/tidl_tools/osrt_deps/opencv_4.2.0_x86_u22/
    -- Compiling for x86 with am69a config
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tfl_main
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tfl_priority_scheduling
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = ort_priority_scheduling
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = tidlrt_clasification
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = dlr_main
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = ort_main
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/root/build
    [  7%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/utility_functs.cpp.o
    [  7%] Building CXX object osrt_cpp/pre_process/CMakeFiles/pre_process.dir/pre_process.cpp.o
    [ 11%] Building CXX object osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/src/print_utils.cpp.o
    [ 14%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/model_info.cpp.o
    [ 18%] Building CXX object osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/src/arg_parsing.cpp.o
    [ 22%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/ti_logger.cpp.o
    [ 25%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/edgeai_classnames.cpp.o
    [ 29%] Building CXX object osrt_cpp/post_process/CMakeFiles/post_process.dir/post_process.cpp.o
    [ 33%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/arg_parsing.cpp.o
    [ 37%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/pbPlots.cpp.o
    [ 40%] Building CXX object osrt_cpp/utils/CMakeFiles/utils.dir/src/supportLib.cpp.o
    g++: warning: /bin/sh:: linker input file unused because linking not done
    g++: error: /bin/sh:: linker input file not found: No such file or directory
    g++: warning: 1:: linker input file unused because linking not done
    g++: error: 1:: linker input file not found: No such file or directory
    g++: warning: pkg-config:: linker input file unused because linking not done
    g++: error: pkg-config:: linker input file not found: No such file or directory
    g++: warning: not: linker input file unused because linking not done
    g++: error: not: linker input file not found: No such file or directory
    g++: warning: found: linker input file unused because linking not done
    g++: error: found: linker input file not found: No such file or directory
    make[2]: *** [osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/build.make:76: osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/src/arg_parsing.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/src/arg_parsing.cpp.o'
    make[2]: *** Waiting for unfinished jobs....
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:160: osrt_cpp/utils/CMakeFiles/utils.dir/src/supportLib.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/supportLib.cpp.o'
    make[2]: *** [osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/build.make:90: osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/src/print_utils.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/src/print_utils.cpp.o'
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:76: osrt_cpp/utils/CMakeFiles/utils.dir/src/utility_functs.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/utility_functs.cpp.o'
    make[1]: *** [CMakeFiles/Makefile2:425: osrt_cpp/advanced_examples/utils/CMakeFiles/utils_adv.dir/all] Error 2
    make[1]: *** Waiting for unfinished jobs....
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:132: osrt_cpp/utils/CMakeFiles/utils.dir/src/arg_parsing.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/arg_parsing.cpp.o'
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:118: osrt_cpp/utils/CMakeFiles/utils.dir/src/ti_logger.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/ti_logger.cpp.o'
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:104: osrt_cpp/utils/CMakeFiles/utils.dir/src/edgeai_classnames.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/edgeai_classnames.cpp.o'
    make[2]: *** [osrt_cpp/pre_process/CMakeFiles/pre_process.dir/build.make:76: osrt_cpp/pre_process/CMakeFiles/pre_process.dir/pre_process.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/pre_process/CMakeFiles/pre_process.dir/pre_process.cpp.o'
    make[1]: *** [CMakeFiles/Makefile2:286: osrt_cpp/pre_process/CMakeFiles/pre_process.dir/all] Error 2
    make[2]: *** [osrt_cpp/post_process/CMakeFiles/post_process.dir/build.make:76: osrt_cpp/post_process/CMakeFiles/post_process.dir/post_process.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/post_process/CMakeFiles/post_process.dir/post_process.cpp.o'
    make[1]: *** [CMakeFiles/Makefile2:260: osrt_cpp/post_process/CMakeFiles/post_process.dir/all] Error 2
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:90: osrt_cpp/utils/CMakeFiles/utils.dir/src/model_info.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/model_info.cpp.o'
    make[2]: *** [osrt_cpp/utils/CMakeFiles/utils.dir/build.make:146: osrt_cpp/utils/CMakeFiles/utils.dir/src/pbPlots.cpp.o] Error 1
    make[2]: *** Deleting file 'osrt_cpp/utils/CMakeFiles/utils.dir/src/pbPlots.cpp.o'
    make[1]: *** [CMakeFiles/Makefile2:312: osrt_cpp/utils/CMakeFiles/utils.dir/all] Error 2
    make: *** [Makefile:136: all] Error 2
  • Hi Akhilesh, I am not too familiar with current c model examples from edgeai-tidl-tools. Could you instead try python examples?
    Run: python3 onnxrt_ep.py
    Probably you are working in a docker container. If so, and you exit it, you need to run again ""source ./setup.sh"
    if you container is still running, or using another setup in which you already run "source ./setup.sh" then you only need to do:
    export SOC=am69a
    export TIDL_TOOLS_PATH=$(pwd)/tidl_tools
    export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$TIDL_TOOLS_PATH
    export ARM64_GCC_PATH=$(pwd)/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu
    In order to add your model, please check https://github.com/TexasInstruments/edgeai-tidl-tools/blob/master/examples/osrt_python/model_configs.py
    Something like this needs to be added (please correct it if wrong):
        'yolact_resnet18_54_400000' : {
            'model_path' : os.path.join(models_base_path, 'yolact_resnet18_54_400000.onnx'),
            'mean': [123.675, 116.28, 103.53],
            'scale' : [0.017125, 0.017507, 0.017429],
            'num_images' : numImages,
            'num_classes': 19,
            'session_name' : 'onnxrt' ,
            'model_type': 'seg'
    And then you can use it inside onnxrt_ep.py by changing models list to test. Ex:models = ['yolact_resnet18_54_400000']
    Also, could you share your modified model (opset 10)?
    thank you,
    Paula
  • Sure. Let me try python examples. Attaching yolact onnxyolact_resnet18_54_400000opset10.zip model with opest10
  • Hi Paula
    I setup the docker based system and able to compile the same model as well. I ran the code with compile option -d that says Disable offload to TIDL. I am not sure whether I have fully understood this or not. Is it running model on PC or on ARM of emulated hardware?
    When I tried to run without any compile option, this supposed to run on emulated device using TIDL but I got this error -
    python3: src/workload_ref_exec.c:107: int32_t WorkloadRefExec_getIndexFromDataId(int32_t, int32_t*, int32_t): Assertion `arrIdx != WORKLOAD_REF_BUF_NOT_FOUND' failed.
    Aborted (core dumped)
    Am I not supposed to run the part that has to be run on device in this emulated env? I thought since we are emulating the hardware itself, I could have able to run.
    The next part I have doubt over is the operator. I saw in the document that Pooling has been validated for the following kernel sizes: 3x3,2x2,1x1, with a maximum stride of 2.
    I am getting unsupported ops for average pooling with kernel 2 and stride 1. Not sure why.
    Akhilesh
  • Hi Akhilesh, I was able to reproduce it. Let me check why we are denying in alllowlist below two layers and come back to you
    69 AveragePool_65 AveragePool outputAdjNodes 1 70 inputAdjNodes 1 68 additionalOutput 0 diagInfo TIDL ALLOWLISTING LAYER CHECK -- TIDL_PoolingLayer '': kernel size 2x2 with stride 1x1 not supported
    81 AveragePool_70 AveragePool outputAdjNodes 1 82 inputAdjNodes 1 80 additionalOutput 0 diagInfo TIDL ALLOWLISTING LAYER CHECK -- TIDL_PoolingLayer '': kernel size 2x2 with stride 1x1 not supported
    thank you,
    Paula
  • Hi Paula, when I am running the model using TIDL artifacts, I am getting runtime issues.
    This is the logs I got using gdb.
    root@50a41c466951:/home/root/edgeai-tidl-tools/examples/osrt_python/ort# gdb --args python3 onnxrt_ep.py
    GNU gdb (Ubuntu 12.1-0ubuntu1~22.04) 12.1
    Copyright (C) 2022 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    Type "show copying" and "show warranty" for details.
    This GDB was configured as "x86_64-linux-gnu".
    Type "show configuration" for configuration details.
    For bug reporting instructions, please see:
    <https://www.gnu.org/software/gdb/bugs/>.
    Find the GDB manual and other documentation resources online at:
        <http://www.gnu.org/software/gdb/documentation/>.
    For help, type "help".
    Type "apropos word" to search for commands related to "word"...
    Reading symbols from python3...
    (No debugging symbols found in python3)
    (gdb) run
    Starting program: /usr/bin/python3 onnxrt_ep.py
    warning: Error disabling address space randomization: Operation not permitted
    [Thread debugging using libthread_db enabled]
    Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
    [New Thread 0x7f318e3ff640 (LWP 1946)]
    [New Thread 0x7f318dbfe640 (LWP 1947)]
    [New Thread 0x7f318b3fd640 (LWP 1948)]
    [New Thread 0x7f3188bfc640 (LWP 1949)]
    [New Thread 0x7f31863fb640 (LWP 1950)]
    [New Thread 0x7f3181bfa640 (LWP 1951)]
    [New Thread 0x7f317f3f9640 (LWP 1952)]
    [New Thread 0x7f317cbf8640 (LWP 1953)]
    [New Thread 0x7f317a3f7640 (LWP 1954)]
    [New Thread 0x7f3177bf6640 (LWP 1955)]
    [New Thread 0x7f31753f5640 (LWP 1956)]
    [New Thread 0x7f3172bf4640 (LWP 1957)]
    [New Thread 0x7f31723f3640 (LWP 1958)]
    [New Thread 0x7f316dbf2640 (LWP 1959)]
    [New Thread 0x7f316d3f1640 (LWP 1960)]
    args,  Namespace(compile=False, disable_offload=False, run_model_zoo=False, models=[])
    Available execution providers :  ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
    Running_Model :  yolact_resnet18_54_400000_opset10_noAvgPool
    platform.machine() :  x86_64
    model config :  {'model_path': '../../../models/akhilesh/yolact_resnet18_54_400000_opset10_noAvgPool.onnx', 'mean': [123.675, 116.28, 103.53], 'scale': [0.017125, 0.017507, 0.017429], 'num_images': 3, 'num_classes': 81, 'session_name': 'onnxrt', 'model_type': 'seg'}
    ***** executing model *****
    [New Thread 0x7f315c20a640 (LWP 1961)]
    [New Thread 0x7f315ba09640 (LWP 1962)]
    [New Thread 0x7f315b208640 (LWP 1963)]
    [New Thread 0x7f315aa07640 (LWP 1964)]
    [New Thread 0x7f315a206640 (LWP 1965)]
    [New Thread 0x7f3159a05640 (LWP 1966)]
    [New Thread 0x7f3159204640 (LWP 1967)]
    libtidl_onnxrt_EP loaded 0x564292e93d30
    Final number of subgraphs created are : 3, - Offloaded Nodes - 133, Total Nodes - 135
    The soft limit is 2048
    The hard limit is 2048
    MEM: Init ... !!!
    MEM: Init ... Done !!!
     0.0s:  VX_ZONE_INIT:Enabled
     0.5s:  VX_ZONE_ERROR:Enabled
     0.7s:  VX_ZONE_WARNING:Enabled
    [New Thread 0x7f31589f2640 (LWP 1968)]
    [New Thread 0x7f313a95e640 (LWP 1969)]
    [New Thread 0x7f313a15d640 (LWP 1970)]
    [New Thread 0x7f313995c640 (LWP 1971)]
    [New Thread 0x7f313915b640 (LWP 1972)]
    [New Thread 0x7f3122ff2640 (LWP 1973)]
    [New Thread 0x7f31227f1640 (LWP 1974)]
    [New Thread 0x7f3121ff0640 (LWP 1975)]
    [New Thread 0x7f31217ef640 (LWP 1976)]
    [New Thread 0x7f3120fee640 (LWP 1977)]
    [New Thread 0x7f31207ed640 (LWP 1978)]
    [New Thread 0x7f311ffec640 (LWP 1979)]
    [New Thread 0x7f311f7eb640 (LWP 1980)]
    [New Thread 0x7f311efea640 (LWP 1981)]
    [New Thread 0x7f311e7e9640 (LWP 1982)]
    [New Thread 0x7f311dfe8640 (LWP 1983)]
    [New Thread 0x7f311d7e7640 (LWP 1984)]
    [New Thread 0x7f311cfe6640 (LWP 1985)]
    [New Thread 0x7f311c7e5640 (LWP 1986)]
    [New Thread 0x7f311bfe4640 (LWP 1987)]
    [New Thread 0x7f311b7e3640 (LWP 1988)]
    [New Thread 0x7f311afe2640 (LWP 1989)]
    [New Thread 0x7f311a7e1640 (LWP 1990)]
    [New Thread 0x7f3119fe0640 (LWP 1991)]
    [New Thread 0x7f31197df640 (LWP 1992)]
    [New Thread 0x7f3118fde640 (LWP 1993)]
    [New Thread 0x7f31187dd640 (LWP 1994)]
    [New Thread 0x7f3117fdc640 (LWP 1995)]
    [New Thread 0x7f31177db640 (LWP 1996)]
    [New Thread 0x7f3116fda640 (LWP 1997)]
    [New Thread 0x7f31167d9640 (LWP 1998)]
    [New Thread 0x7f3115fd8640 (LWP 1999)]
    [New Thread 0x7f31157d7640 (LWP 2000)]
    [New Thread 0x7f3114fd6640 (LWP 2001)]
    [New Thread 0x7f31147d5640 (LWP 2002)]
    [New Thread 0x7f3113fd4640 (LWP 2003)]
    [New Thread 0x7f31137d3640 (LWP 2004)]
    [New Thread 0x7f3112fd2640 (LWP 2005)]
    [New Thread 0x7f31127d1640 (LWP 2006)]
    [New Thread 0x7f3111fd0640 (LWP 2007)]
    [New Thread 0x7f31117cf640 (LWP 2008)]
    [New Thread 0x7f3110fce640 (LWP 2009)]
    [New Thread 0x7f31107cd640 (LWP 2010)]
    [New Thread 0x7f310ffcc640 (LWP 2011)]
    [New Thread 0x7f310f7cb640 (LWP 2012)]
    [New Thread 0x7f310efca640 (LWP 2013)]
    [New Thread 0x7f310e7c9640 (LWP 2014)]
    [New Thread 0x7f310dfc8640 (LWP 2015)]
    [New Thread 0x7f310d7c7640 (LWP 2016)]
    [New Thread 0x7f310cfc6640 (LWP 2017)]
    [New Thread 0x7f310c7c5640 (LWP 2018)]
    [New Thread 0x7f310bfc4640 (LWP 2019)]
    [New Thread 0x7f310b7c3640 (LWP 2020)]
    [New Thread 0x7f310afc2640 (LWP 2021)]
    [New Thread 0x7f310a7c1640 (LWP 2022)]
    [New Thread 0x7f3109fc0640 (LWP 2023)]
    [New Thread 0x7f31097bf640 (LWP 2024)]
    [New Thread 0x7f3108fbe640 (LWP 2025)]
    [New Thread 0x7f31087bd640 (LWP 2026)]
    [New Thread 0x7f3107fbc640 (LWP 2027)]
    [New Thread 0x7f31077bb640 (LWP 2028)]
    [New Thread 0x7f3106fba640 (LWP 2029)]
    [New Thread 0x7f31067b9640 (LWP 2030)]
    [New Thread 0x7f3105fb8640 (LWP 2031)]
    [New Thread 0x7f31057b7640 (LWP 2032)]
    [New Thread 0x7f3104fb6640 (LWP 2033)]
    [New Thread 0x7f31047b5640 (LWP 2034)]
    [New Thread 0x7f3103fb4640 (LWP 2035)]
    [New Thread 0x7f31037b3640 (LWP 2036)]
    [New Thread 0x7f3102fb2640 (LWP 2037)]
    [New Thread 0x7f31027b1640 (LWP 2038)]
    [New Thread 0x7f3101fb0640 (LWP 2039)]
    [New Thread 0x7f31017af640 (LWP 2040)]
    [New Thread 0x7f3100fae640 (LWP 2041)]
    [New Thread 0x7f31007ad640 (LWP 2042)]
     0.5446s:  VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
    created session for model.
    height, width, channel, batch, floating_model:  550 550 3 1 True
    running session for the model
    input image shape :  (1, 3, 550, 550)
    Thread 24 "python3" received signal SIGABRT, Aborted.
    [Switching to Thread 0x7f31589f2640 (LWP 1968)]
    __pthread_kill_implementation (no_tid=0, signo=6, threadid=139849916950080) at ./nptl/pthread_kill.c:44
    44      ./nptl/pthread_kill.c: No such file or directory.
    (gdb) bt
    #0  __pthread_kill_implementation (no_tid=0, signo=6, threadid=139849916950080) at ./nptl/pthread_kill.c:44
    #1  __pthread_kill_internal (signo=6, threadid=139849916950080) at ./nptl/pthread_kill.c:78
    #2  __GI___pthread_kill (threadid=139849916950080, signo=signo@entry=6) at ./nptl/pthread_kill.c:89
    #3  0x00007f31929a8476 in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
    #4  0x00007f319298e7f3 in __GI_abort () at ./stdlib/abort.c:79
    #5  0x00007f319298e71b in __assert_fail_base (fmt=0x7f3192b43150 "%s%s%s:%u: %s%sAssertion `%s' failed.\n%n",
        assertion=0x7f312c909280 "arrIdx != WORKLOAD_REF_BUF_NOT_FOUND",
        file=0x7f312c9092fd "src/workload_ref_exec.c", line=107, function=<optimized out>) at ./assert/assert.c:92
    #6  0x00007f319299fe96 in __GI___assert_fail (assertion=0x7f312c909280 "arrIdx != WORKLOAD_REF_BUF_NOT_FOUND",
        function=0x7f312c909238 "int32_t WorkloadRefExec_getIndexFromDataId(int32_t, int32_t*, int32_t)")
        at ./assert/assert.c:101
    #7  0x00007f312bf530ef in WorkloadRefExec_getPtrsFromWorkload(TIDL_NetworkCommonParams*, sWorkloadUnit_t*, sTIDL_AlgLayer_t*, sTIDL_Layer_t*, void**, void**) () from /home/root/edgeai-tidl-tools/tidl_tools/libvx_tidl_rt.so
    #8  0x00007f312bf53c67 in WorkloadRefExec_Process(TIDL_Obj*, TIDL_NetworkCommonParams*, sWorkloadUnit_t*, sTIDL_AlgLayer_t*, sTIDL_Layer_t*, void**, void**, int, int, int*) ()
    #9  0x00007f312bef3046 in TIDL_process(IVISION_Obj*, IVISION_BufDescList*, IVISION_BufDescList*, IVISION_InArgs*, IVISION_OutArgs*) () from /home/root/edgeai-tidl-tools/tidl_tools/libvx_tidl_rt.so
    #10 0x00007f312bee2f0a in tivxKernelTIDLProcess () from /home/root/edgeai-tidl-tools/tidl_tools/libvx_tidl_rt.so
    #11 0x00007f312becfa71 in ownTargetKernelExecute () from /home/root/edgeai-tidl-tools/tidl_tools/libvx_tidl_rt.so
    #12 0x00007f312bece23f in ownTargetNodeDescNodeExecuteTargetKernel ()
    #13 0x00007f312bece7cf in ownTargetNodeDescNodeExecute ()
    #14 0x00007f312becec0c in ownTargetTaskMain () from /home/root/edgeai-tidl-tools/tidl_tools/libvx_tidl_rt.so
    #15 0x00007f312bedef5c in tivxTaskMain () from /home/root/edgeai-tidl-tools/tidl_tools/libvx_tidl_rt.so
    #16 0x00007f31929faac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
    #17 0x00007f3192a8bbf4 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:100
    (gdb)
    Did you look into 3 subgraphs and why average pooling is not in support list?
    I even tried to change average pooling to maxpooling and got the same issue. I also can not see any other operator that is not supported.
    Akhilesh
  • Hi Akhilesh, I got the same "WORKLOAD_REF_BUF_NOT_FOUND" error during runtime. I requested help from a colleague w.r.t average pooling not being supported. He will reply back to you. Please wait for few days as there are some Holidays.
    thank you,
    Paula
  • Sure Paula.
    I also checked if I was putting average pooling or max pooling in the deny list of compile option. That's not the case. We don't have anything in the deny list. I am using the compile options given in common_utils.py .
    Akhilesh
  • Hi Paula, any update on this?
    Akhilesh
