AM5728: Power Management example applications compilation
Part Number: AM5728
I am looking for executable binary for power management examples 'cpuidle' and 'systemconfig' for SoC=AM572x that can be loaded and
freely run in CCS. For the following two makes, neither pm_cpuidle_testapp is generated nor pm_baremental_systemconfig_testapp is
generated.
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build$ make pm_cpuidle_testapp -s BOARD=evmAM572x idkAM572x CORE=mpu1_0 mcu1_0 mcu1_1 mcu2_0 mcu2_1 c66xdsp_1 c66xdsp_2 mpu1_1 BUILD_PROFILE=release debug OS=linux
Nothing to be done for am572x pm_cpuidle_testapp
No rule to make target 'idkAM572x', 'mcu1_0', 'mcu1_1', 'mcu2_0', 'mcu2_1', 'c66xdsp_1', 'c66xdsp_2', 'mpu1_1', 'debug'
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build$ make pm_baremetal_systemconfig_testapp -s BOARD=evmAM572x idkAM572x CORE=mpu1_0 mcu1_0 mcu1_1 mcu2_0 mcu2_1 c66xdsp_1 c66xdsp_2 mpu1_1 BUILD_PROFILE=release debug OS=linux
Nothing to be done for am572x pm_baremetal_systemconfig_testapp
What exactly needs to be done in order to get pm_cpuidle_testapp and pm_baremetal_systemconfig_testapp (based on main_prcm.c) for AM572x that
can be freely run in CCS 12.4? What are the expected results when freely running them in CCS? Whether the binary output be available in the
following locations or at some other locations? If multiple binary outputs are generatted, what are the differences between them and whether
they all can be loaded in CCS and freely run in the target board similar to evmAM572x or idkAM572x?
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/evmAM572x
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_baremetal_systemconfig_testapp/bin/evmAM572x
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/c66/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/m4/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/evmAM572x/a15/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/evmAM572x/c66/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/evmAM572x/m4/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/a15/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/c66/release
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/m4/release
For 'pmrtos', though the makefile generates the binary outputs, I am having the following problems.
Can anyone address them in order to solve the problems faced?
I have tried to load the generated binaries for pm rtos into CCS. The initial state of the
cores were A15_0, DSP1, IPU_1 were disconnected. Initially A15_0 was tried to connect,
A15_0 went to suspended state. Then run the GEL: Scripts–>AM572x MULTICORE
Initialization–>AM572x_MULTICORE_EnableAllCores. Then DSP1 was tried to connect. DSP1 also
went to disconnected state. Then DSP_1 was loaded with pm_rtos.ae66 file. CCS gave the
following error message in the pop-up window.
"Load Program Failed: Encountered a problem loading file:
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/c66/release/pm_rtos.ae66"
Could not determine target type of file"
Then DSP_1 is put into free running mode.
Then IPU1_c0 was tried to connect. IPU1_c0 also went to suspended state. Then IPU1_c0 was loaded
with pm_rtos.aem4. CCS gave the following error message in the pop-up window.
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/m4/release/pm_rtos.aem4"
Then IP1_C0 is put into free running mode.
Below given is the CCS log.
CortexA15_0: GEL Output: --->>> AM572x GP EVM <<<---
CortexA15_0: GEL Output: --->>> AM572x Target Connect Sequence Begins ... <<<---
CortexA15_0: GEL: Error while executing OnTargetConnect(): Target failed to read 0x4A0025F4
       at (*((unsigned int*) 0x4A0025F4)&0xFFF) [AM572x_startup_common.gel:69]
       at AM57xx_EVM_Initialization(0) [gpevm_am572x.gel:54]
       at OnTargetConnect()
CortexA15_0: GEL Output: --->>> Mapping TIMER suspend sources to default cores <<<<<<----
CortexA15_0: GEL Output: --->>> IPU1SS Initialization is in progress ... <<<---
AM572x_MULTICORE_EnableAllCores() cannot be evaluated.
Target failed to read 0x4AE06514
       at (*((unsigned int*) ((cpu_num==1) ? (((0x4AE00000+0x6000)+0x500)+0x14) : (((0x4AE00000+0x6000)+0x700)+0x214)))&0x4) [AM572x_multicore_reset.gel:312]
       at IPUSSClkEnable(1) [AM572x_multicore_reset.gel:274]
       at IPU1SSClkEnable_API() [AM572x_multicore_reset.gel:247]
       at AM572x_MULTICORE_EnableAllCores()C66xx_DSP1: GEL: Encountered a problem loading file: /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/c66/release/pm_rtos.ae66 Could not determine target type of file
Cortex_M4_IPU1_C0: GEL: Encountered a problem loading file: /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/m4/release/pm_rtos.aem4 Could not determine target type of file
When should ~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib
/am572x/a15/release/pm_rtos.aa15fg be loaded onto A15_0? This file also gives the error
"Could not determine target type of file" when tried to load in A15_0 through CCS.
The following executables gets loaded into A15_0 and free runs too. What are the expected
results for the following binary?
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/bin/evmAM572x/pm_rtos_testapp_a15_0_release.xa15fg
The following executables (contents are different from above mentioned files, but with the same file
name) present in the following locations too. When should these following executables be used?
How are they different from the above files? What are the expected results for the following files?
Even the following files are popping up the error message "Could not determine target type of file"
when tried to load into A15_0, DSP1 and IPU1_0 through CCS.
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/evmAM572x/a15/release/ti.board.aa15fg
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/evmAM572x/c66/release/ti.board.ae66
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/evmAM572x/c5/release/ti.board.aem4
generated.
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/a15/release/ti.board.aa15fg
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/c66/release/ti.board.ae66
~/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/c5/release/ti.board.aem4
Thanks.
Rishi.
Thanks.
Rishi.
  • Hi Rishi,
    Can you please share the exact commands that you are running to build these examples and also please share the location from where you are building this?
    Parth
  • Hi Parth,
    The exact command is given below.
    make allcores pm_hal pm_hal_optimized pm_lib pm_lib_optimized pm_rtos pm_example_utils pm_baremetal_systemconfig_testapp pm_cpuidle_testapp pm_rtos_testapp BOARD=evmAM572x idkAM572x BUILD_PROFILE=release debug OS=linux COMP=pm
    The two locations from where builds are made are given below along with its associated PDK_INSTALL_PATH and XDC_INSTALL_PATH.
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build
        PDK_INSTALL_PATH = /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages
        XDC_INSTALL_PATH = /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_55_02_22_core
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build
        PDK_INSTALL_PATH = /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages
        XDC_INSTALL_PATH = /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/xdctools_3_55_02_22_core
    Rishi.
  • Hi Rishi,
    By default pm cpu idle test in not enabled for AM57x boards.
    Parth
  • Hi Parth,
    I noticed that the following folder was not present.
    I created the following folder with the latest xdctools available and set the XDC_INSTALL_PATH pointing to it.
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_62_00_08_core
    Also, the naming for cores is different in AM572x compared to other SoCs.  So, I ran the make once
    again under Processor SDK Linux as well as Processor SDK RTOS.  The results of running the build
    commands are captured in the following files.  The first line in these files contain the make command and the location from where it was executed.  Also, please note that due to size limitation, the first file
    (rtos_build1.txt) is split into five parts (rtos_build1_1through5.txt) due to size limitation of file insertion.
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build$ make all pm_baremetal_systemconfig_testapp pm_cpuidle_testapp pm_rtos_testapp BOARD=evmAM572x idkAM572x CORE=a15_0 ipu1_0 c66x BUILD_PROFILE=release debug OS=linux COMP=pm
    # PDK 08.01.00.09
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_hal
    make[1]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -f/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal/makefile.mk
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal'
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_vm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_vm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_vm.oa15fg prcm/pmhal_vm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_vmdata.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_vmdata.oa15fg prcm/V0/hw_pmhal_vmdata.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_data.oa15fg prcm/V0/hw_pmhal_data.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_data_names.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_data_names.oa15fg prcm/V0/hw_pmhal_data_names.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_pmic.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_pmic.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_pmic.oa15fg prcm/pmhal_pmic.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_pmicComm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_pmicComm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_pmicComm.oa15fg prcm/pmhal_pmicComm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_i2cComm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_i2cComm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_i2cComm.oa15fg prcm/pmhal_i2cComm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_mm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_mm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_mm.oa15fg prcm/pmhal_mm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_prm_int.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_prm_int.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_prm_int.oa15fg prcm/pmhal_prm_int.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_bgap.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_bgap.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_bgap.oa15fg prcm/pmhal_bgap.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_bgap_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_bgap_data.oa15fg prcm/V0/hw_pmhal_bgap_data.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_pdm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_pdm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_pdm.oa15fg prcm/pmhal_pdm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_rm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_rm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_rm.oa15fg prcm/pmhal_rm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_sd.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_sd.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_sd.oa15fg prcm/pmhal_sd.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_cm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_cm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_cm.oa15fg prcm/pmhal_cm.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_bgap_common_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_bgap_common_data.oa15fg prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_prmdata.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_prmdata.oa15fg prcm/V0/hw_pmhal_prmdata.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pm_utils.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pm_utils.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pm_utils.oa15fg prcm/pm_utils.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_clocktree_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_clocktree_data.oa15fg prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_prcm_stats.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_prcm_stats.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_prcm_stats.oa15fg prcm/pmhal_prcm_stats.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_clocktree.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_clocktree.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_clocktree.oa15fg prcm/pmhal_clocktree.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/pmhal_videopll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_videopll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_videopll.oa15fg prcm/V0/pmhal_videopll.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_videopll_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_videopll_data.oa15fg prcm/V0/hw_pmhal_videopll_data.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/hw_pmhal_ina226data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_ina226data.oa15fg prcm/V0/hw_pmhal_ina226data.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_ina226.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_ina226.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_ina226.oa15fg prcm/pmhal_ina226.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_tps659037.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_tps659037.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_tps659037.oa15fg prcm/pmhal_tps659037.c
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_mpu_lprm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_mpu_lprm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_mpu_lprm.oa15fg prcm/pmhal_mpu_lprm.c
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release
    # Archiving am572x:a15_0:release:pm_hal into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_hal.aa15fg ...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-ar cr /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_hal.aa15fg   /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_vm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_vmdata.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_data_names.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_pmic.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_pmicComm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_i2cComm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_mm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_prm_int.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_bgap.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_bgap_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_pdm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_rm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_sd.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_cm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_bgap_common_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_prmdata.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pm_utils.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_clocktree_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_prcm_stats.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_clocktree.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_videopll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_videopll_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/hw_pmhal_ina226data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_ina226.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_tps659037.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_mpu_lprm.oa15fg
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal'
    make[1]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_hal_optimized
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -f/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal/makefile_optimized.mk
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_vm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_vm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_vm.oa15fg prcm/pmhal_vm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_vmdata.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_vmdata.oa15fg prcm/V0/hw_pmhal_vmdata.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_data.oa15fg prcm/V0/hw_pmhal_data.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_data_names.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_data_names.oa15fg prcm/V0/hw_pmhal_data_names.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_pmic.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_pmic.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_pmic.oa15fg prcm/pmhal_pmic.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_pmicComm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_pmicComm.oa15fg prcm/pmhal_pmicComm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_i2cComm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_i2cComm.oa15fg prcm/pmhal_i2cComm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_mm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_mm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_mm.oa15fg prcm/pmhal_mm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_prm_int.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_prm_int.oa15fg prcm/pmhal_prm_int.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_bgap.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_bgap.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_bgap.oa15fg prcm/pmhal_bgap.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_bgap_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_bgap_data.oa15fg prcm/V0/hw_pmhal_bgap_data.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_pdm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_pdm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_pdm.oa15fg prcm/pmhal_pdm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_rm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_rm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_rm.oa15fg prcm/pmhal_rm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_sd.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_sd.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_sd.oa15fg prcm/pmhal_sd.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_cm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_cm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_cm.oa15fg prcm/pmhal_cm.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_bgap_common_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_bgap_common_data.oa15fg prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_prmdata.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_prmdata.oa15fg prcm/V0/hw_pmhal_prmdata.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pm_utils.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pm_utils.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pm_utils.oa15fg prcm/pm_utils.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_clocktree_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_clocktree_data.oa15fg prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_prcm_stats.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_prcm_stats.oa15fg prcm/pmhal_prcm_stats.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_clocktree.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_clocktree.oa15fg prcm/pmhal_clocktree.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_videopll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_videopll.oa15fg prcm/V0/pmhal_videopll.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_videopll_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_videopll_data.oa15fg prcm/V0/hw_pmhal_videopll_data.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/hw_pmhal_ina226data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_ina226data.oa15fg prcm/V0/hw_pmhal_ina226data.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_ina226.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_ina226.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_ina226.oa15fg prcm/pmhal_ina226.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_tps659037.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_tps659037.oa15fg prcm/pmhal_tps659037.c
    # Compiling am572x:a15_0:release:pm_hal_optimized: prcm/pmhal_mpu_lprm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/little/.deps/pmhal_mpu_lprm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_mpu_lprm.oa15fg prcm/pmhal_mpu_lprm.c
    # Archiving am572x:a15_0:release:pm_hal_optimized into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_hal_optimized.aa15fg ...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-ar cr /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_hal_optimized.aa15fg   /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_vm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_vmdata.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_data_names.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_pmic.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_pmicComm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_i2cComm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_mm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_prm_int.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_bgap.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_bgap_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_pdm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_rm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_sd.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_cm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_bgap_common_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_prmdata.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pm_utils.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_clocktree_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_prcm_stats.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_clocktree.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_videopll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_videopll_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/hw_pmhal_ina226data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_ina226.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_tps659037.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmhal/optimized/obj/am572x/a15/release/pmhal_mpu_lprm.oa15fg
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_lib
    make[1]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -f/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib/makefile.mk
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib'
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_lib: prcm/pmlib_cpuidle_utils_a15host.asm
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -c -x assembler-with-cpp -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x          -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_cpuidle_utils_a15host.oa15fg prcm/pmlib_cpuidle_utils_a15host.asm
    # Compiling am572x:a15_0:release:pm_lib: prcm/pmlib_sysconfig.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_sysconfig.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_sysconfig.oa15fg prcm/pmlib_sysconfig.c
    # Compiling am572x:a15_0:release:pm_lib: prcm/pmlib_clkrate.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_clkrate.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_clkrate.oa15fg prcm/pmlib_clkrate.c
    # Compiling am572x:a15_0:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_boardconfig.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_boardconfig.oa15fg prcm/V0/pmlib_boardconfig.c
    # Compiling am572x:a15_0:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_videopll_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_videopll_data.oa15fg prcm/V0/pmlib_videopll_data.c
    # Compiling am572x:a15_0:release:pm_lib: prcm/pmlib_videopll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_videopll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_videopll.oa15fg prcm/pmlib_videopll.c
    # Compiling am572x:a15_0:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_clk_rate_data_tda2xx.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_clk_rate_data_tda2xx.oa15fg prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling am572x:a15_0:release:pm_lib: prcm/pmlib_cpuidle_a15host.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/little/.deps/pmlib_cpuidle_a15host.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_cpuidle_a15host.oa15fg prcm/pmlib_cpuidle_a15host.c
    # Archiving am572x:a15_0:release:pm_lib into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_lib.aa15fg ...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-ar cr /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_lib.aa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_cpuidle_utils_a15host.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_sysconfig.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_clkrate.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_boardconfig.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_videopll_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_videopll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_clk_rate_data_tda2xx.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/obj/am572x/a15/release/pmlib_cpuidle_a15host.oa15fg
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib'
    make[1]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_lib_optimized
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -f/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib/makefile_optimized.mk
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_utils_a15host.asm
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -c -x assembler-with-cpp -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x          -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_cpuidle_utils_a15host.oa15fg prcm/pmlib_cpuidle_utils_a15host.asm
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_sysconfig.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_sysconfig.oa15fg prcm/pmlib_sysconfig.c
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_clkrate.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_clkrate.oa15fg prcm/pmlib_clkrate.c
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_boardconfig.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_boardconfig.oa15fg prcm/V0/pmlib_boardconfig.c
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_videopll_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_videopll_data.oa15fg prcm/V0/pmlib_videopll_data.c
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/pmlib_videopll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_videopll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_videopll.oa15fg prcm/pmlib_videopll.c
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_clk_rate_data_tda2xx.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_clk_rate_data_tda2xx.oa15fg prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling am572x:a15_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_a15host.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/little/.deps/pmlib_cpuidle_a15host.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0  -DPM_OPTIMIZE    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_cpuidle_a15host.oa15fg prcm/pmlib_cpuidle_a15host.c
    # Archiving am572x:a15_0:release:pm_lib_optimized into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_lib_optimized.aa15fg ...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-ar cr /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_lib_optimized.aa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_cpuidle_utils_a15host.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_sysconfig.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_clkrate.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_boardconfig.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_videopll_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_videopll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_clk_rate_data_tda2xx.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/src/pmlib/optimized/obj/am572x/a15/release/pmlib_cpuidle_a15host.oa15fg
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_rtos
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm -fmakefile.mk
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm'
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/pmlib_cpuidle_utils_a15host.asm
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -c -x assembler-with-cpp -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x          -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_cpuidle_utils_a15host.oa15fg src/pmlib/prcm/pmlib_cpuidle_utils_a15host.asm
    # Compiling am572x:a15_0:release:pm_rtos: src/pmrtos/common/List.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/List.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/List.oa15fg src/pmrtos/common/List.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmrtos/prcm/PowerDevice.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/PowerDevice.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerDevice.oa15fg src/pmrtos/prcm/PowerDevice.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmrtos/prcm/PowerDevice_tirtos.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/PowerDevice_tirtos.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerDevice_tirtos.oa15fg src/pmrtos/prcm/PowerDevice_tirtos.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmrtos/prcm/V0/PowerPRCM_deviceInit.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/PowerPRCM_deviceInit.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerPRCM_deviceInit.oa15fg src/pmrtos/prcm/V0/PowerPRCM_deviceInit.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmrtos/prcm/V0/PowerPRCM_dpll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/PowerPRCM_dpll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerPRCM_dpll.oa15fg src/pmrtos/prcm/V0/PowerPRCM_dpll.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_vm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_vm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_vm.oa15fg src/pmhal/prcm/pmhal_vm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_vmdata.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_vmdata.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_vmdata.oa15fg src/pmhal/prcm/V0/hw_pmhal_vmdata.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_data.oa15fg src/pmhal/prcm/V0/hw_pmhal_data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_data_names.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_data_names.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_data_names.oa15fg src/pmhal/prcm/V0/hw_pmhal_data_names.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_pmic.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_pmic.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_pmic.oa15fg src/pmhal/prcm/pmhal_pmic.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_pmicComm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_pmicComm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_pmicComm.oa15fg src/pmhal/prcm/pmhal_pmicComm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_i2cComm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_i2cComm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_i2cComm.oa15fg src/pmhal/prcm/pmhal_i2cComm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_mm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_mm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_mm.oa15fg src/pmhal/prcm/pmhal_mm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_prm_int.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_prm_int.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_prm_int.oa15fg src/pmhal/prcm/pmhal_prm_int.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_bgap.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_bgap.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_bgap.oa15fg src/pmhal/prcm/pmhal_bgap.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_bgap_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_bgap_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_bgap_data.oa15fg src/pmhal/prcm/V0/hw_pmhal_bgap_data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_pdm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_pdm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_pdm.oa15fg src/pmhal/prcm/pmhal_pdm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_rm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_rm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_rm.oa15fg src/pmhal/prcm/pmhal_rm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_sd.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_sd.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_sd.oa15fg src/pmhal/prcm/pmhal_sd.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_cm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_cm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_cm.oa15fg src/pmhal/prcm/pmhal_cm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/common/hw_pmhal_bgap_common_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_bgap_common_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_bgap_common_data.oa15fg src/pmhal/prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_prmdata.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_prmdata.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_prmdata.oa15fg src/pmhal/prcm/V0/hw_pmhal_prmdata.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pm_utils.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pm_utils.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pm_utils.oa15fg src/pmhal/prcm/pm_utils.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_clocktree_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_clocktree_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_clocktree_data.oa15fg src/pmhal/prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_prcm_stats.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_prcm_stats.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_prcm_stats.oa15fg src/pmhal/prcm/pmhal_prcm_stats.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_clocktree.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_clocktree.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_clocktree.oa15fg src/pmhal/prcm/pmhal_clocktree.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/pmhal_videopll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_videopll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_videopll.oa15fg src/pmhal/prcm/V0/pmhal_videopll.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_videopll_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_videopll_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_videopll_data.oa15fg src/pmhal/prcm/V0/hw_pmhal_videopll_data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/V0/hw_pmhal_ina226data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/hw_pmhal_ina226data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_ina226data.oa15fg src/pmhal/prcm/V0/hw_pmhal_ina226data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_ina226.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_ina226.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_ina226.oa15fg src/pmhal/prcm/pmhal_ina226.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_tps659037.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_tps659037.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_tps659037.oa15fg src/pmhal/prcm/pmhal_tps659037.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/pmlib_sysconfig.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_sysconfig.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_sysconfig.oa15fg src/pmlib/prcm/pmlib_sysconfig.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/pmlib_clkrate.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_clkrate.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_clkrate.oa15fg src/pmlib/prcm/pmlib_clkrate.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/V0/pmlib_boardconfig.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_boardconfig.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_boardconfig.oa15fg src/pmlib/prcm/V0/pmlib_boardconfig.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/V0/pmlib_videopll_data.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_videopll_data.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_videopll_data.oa15fg src/pmlib/prcm/V0/pmlib_videopll_data.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/pmlib_videopll.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_videopll.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_videopll.oa15fg src/pmlib/prcm/pmlib_videopll.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/V0/pmlib_clk_rate_data_tda2xx.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_clk_rate_data_tda2xx.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_clk_rate_data_tda2xx.oa15fg src/pmlib/prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmhal/prcm/pmhal_mpu_lprm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmhal_mpu_lprm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_mpu_lprm.oa15fg src/pmhal/prcm/pmhal_mpu_lprm.c
    # Compiling am572x:a15_0:release:pm_rtos: src/pmlib/prcm/pmlib_cpuidle_a15host.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/little/.deps/pmlib_cpuidle_a15host.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc/pmrtos/prcm -Isrc/pmrtos/common -Isrc/pmrtos/prcm/V0 -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -Iprcm -Isrc/pmlib/prcm -Iprcm/V0 -Isrc/pmlib/prcm/V0 -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include/prcm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_cpuidle_a15host.oa15fg src/pmlib/prcm/pmlib_cpuidle_a15host.c
    # Archiving am572x:a15_0:release:pm_rtos into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_rtos.aa15fg ...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-ar cr /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_rtos.aa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_cpuidle_utils_a15host.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/List.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerDevice.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerDevice_tirtos.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerPRCM_deviceInit.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/PowerPRCM_dpll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_vm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_vmdata.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_data_names.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_pmic.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_pmicComm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_i2cComm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_mm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_prm_int.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_bgap.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_bgap_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_pdm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_rm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_sd.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_cm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_bgap_common_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_prmdata.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pm_utils.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_clocktree_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_prcm_stats.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_clocktree.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_videopll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_videopll_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/hw_pmhal_ina226data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_ina226.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_tps659037.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_sysconfig.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_clkrate.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_boardconfig.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_videopll_data.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_videopll.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_clk_rate_data_tda2xx.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmhal_mpu_lprm.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/obj/am572x/a15/release/pmlib_cpuidle_a15host.oa15fg
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm'
    make[1]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_example_utils
    make[1]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils'
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_example_utils: app_utils.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/little/.deps/app_utils.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/app_utils.oa15fg app_utils.c
    # Compiling am572x:a15_0:release:pm_example_utils: uartStdio.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/little/.deps/uartStdio.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0    -DSOC_AM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/uartStdio.oa15fg uartStdio.c
    # Archiving am572x:a15_0:release:pm_example_utils into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_example_utils.aa15fg ...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-ar cr /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/a15/release/pm_example_utils.aa15fg   /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/app_utils.oa15fg  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/ti/drv/pm/examples/utils/obj/am572x/a15/release/uartStdio.oa15fg
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils'
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile all_apps_core
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_baremetal_systemconfig_testapp
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    Nothing to be done for am572x pm_baremetal_systemconfig_testapp
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build'
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_arp32_cpuidle_testapp
    Nothing to be done for am572x pm_arp32_cpuidle_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_baremetal_clkrate_testapp
    Nothing to be done for am572x pm_baremetal_clkrate_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_baremetal_voltage_read_testapp
    Nothing to be done for am572x pm_baremetal_voltage_read_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_cpuidle_testapp
    Nothing to be done for am572x pm_cpuidle_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_baremetal_junction_temp_testapp
    Nothing to be done for am572x pm_baremetal_junction_temp_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_ina226_testapp
    Nothing to be done for am572x pm_ina226_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_core_loading_testapp
    Nothing to be done for am572x pm_core_loading_testapp
    make -f /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile pm_rtos_testapp
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos  xdc_configuro
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    # Invoking configuro...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/xdctools_3_55_02_22_core/xs xdc.tools.configuro --generationOnly -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro -t gnu.targets.arm.A15F -p "ti.platforms.evmAM572X" \
                   -r release -b /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/am572x/config_am572x_a15.bld --ol /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/linker_mod.cmd /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos/pm_a15.cfg
    making package.mak (because of package.bld) ...
    generating interfaces for package configuro (because package/package.xdc.inc is older than package.xdc) ...
    configuring pm_a15.xa15fg from package/cfg/pm_a15_pa15fg.cfg ...
    generating custom ti.sysbios library makefile ...
    Starting build of library sources ...
    making /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/package/cfg/pm_a15_pa15fg.src/sysbios/sysbios.aa15fg ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm_gnu.asm ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/TaskSupport_asm_gnu.asm ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/a15/Cache_asm_gnu.asm ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/a15/Mmu_asm_gnu.asm ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/timers/dmtimer/Timer_asm_gnu.sv7A ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/gic/Hwi_asm_gnu.asm ...
    asma15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/exc/Exception_asm_gnu.asm ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/BIOS.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/IntrinsicsSupport.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/TaskSupport.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Clock.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Idle.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Intrinsics.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Event.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Queue.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Semaphore.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Swi.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/knl/Task.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/heaps/HeapBuf.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/heaps/HeapMem.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/utils/Load.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/utils/Load_CPU.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/hal/Core.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/hal/Hwi.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/hal/Hwi_stack.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/hal/Hwi_startup.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/hal/TimerNull.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/syncs/SyncSem.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/gates/GateHwi.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/gates/GateTask.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/gates/GateMutexPri.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/gates/GateMutex.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/a15/Core.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/a15/Cache.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/a15/Mmu.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/shared/vayu/IntXbar.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/shared/vayu/TimerSupport.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/timers/dmtimer/Timer.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/timers/dmtimer/TimestampProvider.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/rts/gnu/ReentSupport.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/gic/Hwi.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/family/arm/exc/Exception.c ...
    cla15fg /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/ti/sysbios/xdcruntime/GateThreadSupport.c ...
    ara15fg arm_IntrinsicsSupport_asm_gnu.o arm_TaskSupport_asm_gnu.o a15_Cache_asm_gnu.o a15_Mmu_asm_gnu.o dmtimer_Timer_asm_gnu.o gic_Hwi_asm_gnu.o exc_Exception_asm_gnu.o _BIOS.o arm_IntrinsicsSupport.o arm_TaskSupport.o knl_Clock.o knl_Idle.o knl_Intrinsics.o knl_Event.o knl_Queue.o knl_Semaphore.o knl_Swi.o knl_Task.o heaps_HeapBuf.o heaps_HeapMem.o utils_Load.o utils_Load_CPU.o hal_Cache.o hal_Core.o hal_Hwi.o hal_Hwi_stack.o hal_Hwi_startup.o hal_TimerNull.o syncs_SyncSem.o gates_GateHwi.o gates_GateTask.o gates_GateMutexPri.o gates_GateMutex.o a15_Core.o a15_Cache.o a15_Mmu.o vayu_IntXbar.o vayu_TimerSupport.o dmtimer_Timer.o dmtimer_TimestampProvider.o gnu_ReentSupport.o gic_Hwi.o exc_Exception.o xdcruntime_GateThreadSupport.o ...
    Build of libraries done.
    # Configuro done!
    make /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/linker_mod.cmd
    make[4]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    make[4]: '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/linker_mod.cmd' is up to date.
    make[4]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/bin/evmAM572x
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/little/.deps
    make  csl pm_rtos pm_example_utils osal_tirtos   uart i2c board
    make[4]: Nothing to be done for 'csl'.
    make[4]: Nothing to be done for 'pm_rtos'.
    make[4]: Nothing to be done for 'pm_example_utils'.
    make[4]: Nothing to be done for 'osal_tirtos'.
    make[4]: Nothing to be done for 'uart'.
    make[4]: Nothing to be done for 'i2c'.
    make[4]: Nothing to be done for 'board'.
    make  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/bin/evmAM572x/pm_rtos_testapp_a15_0_release.xa15fg
    # Compiling evmAM572x:am572x:a15_0:release:pm_rtos_testapp: src/pm_main_prcm.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/little/.deps/pm_main_prcm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0    -DSOC_AM572x -DevmAM572x=evmAM572x -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=A15F -Dxdc_bld__profile_release -Dxdc_cfg__header__='/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/package/cfg/pm_a15_pa15fg.h' -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages/gnu/targets/arm/libs/install-native/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Isrc -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/bios_6_76_03_01/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/xdctools_3_55_02_22_core/packages -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/pm_main_prcm.oa15fg src/pm_main_prcm.c
    make[4]: *** No rule to make target '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl/lib/am572x/a15/release/ti.csl.aa15fg', needed by '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/bin/evmAM572x/pm_rtos_testapp_a15_0_release.xa15fg'.  Stop.
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/common.mk:401: recipe for target 'a15_0' failed
    make[3]: *** [a15_0] Error 2
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile:339: recipe for target 'pm_rtos_testapp' failed
    make[2]: *** [pm_rtos_testapp] Error 2
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makefile:108: recipe for target 'pm_rtos_testapp_has_dep' failed
    make[1]: *** [pm_rtos_testapp_has_dep] Error 2
    makefile:126: recipe for target 'all_apps' failed
    make: *** [all_apps] Error 2
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build$ make allcores pm_baremetal_systemconfig_testapp pm_cpuidle_testapp pm_rtos_testapp BOARD=evmAM572x idkAM572x BUILD_PROFILE=release debug OS=linux COMP=pm
    make: 'allcores' is up to date.
    make[1]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    make[2]: '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/linker_mod.cmd' is up to date.
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    make[1]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/pmrtos'
    make[2]: Nothing to be done for 'csl'.
    make[2]: Nothing to be done for 'pm_rtos'.
    make[2]: Nothing to be done for 'pm_example_utils'.
    make[2]: Nothing to be done for 'osal_tirtos'.
    make[2]: Nothing to be done for 'uart'.
    make[2]: Nothing to be done for 'i2c'.
    make[2]: Nothing to be done for 'board'.
    make[2]: *** No rule to make target '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl/lib/am572x/a15/release/ti.csl.aa15fg', needed by '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_rtos_testapp/bin/evmAM572x/pm_rtos_testapp_a15_0_release.xa15fg'.  Stop.
    make[1]: *** [a15_0] Error 2
    make: *** [pm_rtos_testapp] Error 2
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build$ make all pm_baremetal_systemconfig_testapp pm_cpuidle_testapp pm_rtos_testapp BOARD=evmAM572x idkAM572x CORE=a15_0 ipu1_0 c66x BUILD_PROFILE=release debug OS=linux COMP=pm
    # PDK MM.NN.PP.BB
    make -f /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build/makefile pm_hal
    make[1]: Entering directory '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build'
    make -C /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/src/pmhal -f/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/src/pmhal/makefile.mk
    make[2]: Entering directory '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/src/pmhal'
    /bin/mkdir -p /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release
    /bin/mkdir -p /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps
    # Compiling am572x:a15_0:release:pm_hal: prcm/pmhal_vm.c
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/little/.deps/pmhal_vm.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0     -DSOC_AM572x -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -Iprcm -Iprcm/common -Isrc/pmhal/prcm -Isrc/pmhal/prcm/common -Iprcm/V0 -Isrc/pmhal/prcm/V0 -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/csl -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/src/pmhal -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/include -I/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/include/prcm -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_vm.oa15fg prcm/pmhal_vm.c
    make[2]: /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc: Command not found
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build/makerules/rules_a15.mk:142: recipe for target '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_vm.oa15fg' failed
    make[2]: *** [/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/ti/drv/pm/src/pmhal/obj/am572x/a15/release/pmhal_vm.oa15fg] Error 127
    make[2]: Leaving directory '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/src/pmhal'
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build/makefile:358: recipe for target 'pm_hal' failed
    make[1]: *** [pm_hal] Error 2
    make[1]: Leaving directory '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build'
    makefile:116: recipe for target 'pm_hal_has_dep' failed
    make: *** [pm_hal_has_dep] Error 2
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build$ make allcores pm_baremetal_systemconfig_testapp pm_cpuidle_testapp pm_rtos_testapp BOARD=evmAM572x idkAM572x BUILD_PROFILE=release debug OS=linux COMP=pm
    make -C /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/examples/pmrtos  xdc_configuro
    make[1]: Entering directory '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/examples/pmrtos'
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_62_00_08_core/xs xdc.tools.configuro --generationOnly -o /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro -t gnu.targets.arm.A15F -p "ti.platforms.evmAM572X" \
                   -r release -b /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build/am572x/config_am572x_a15.bld --ol /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/linker_mod.cmd /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/examples/pmrtos/pm_a15.cfg
    js: "/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_62_00_08_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: Error: Can't find the platform package 'ti.platforms.evmAM572X'.  TI platforms are no longer shipped as part of XDCtools (/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_62_00_08_core).  Please ensure you are either using a pre-3.30 version of XDCtools or you have added a product that includes your platform support along the path '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/bios_6_76_03_01/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_62_00_08_core/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/edma3_lld_2_12_05_30E/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ndk_3_61_01_01/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ns_2_60_01_06;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ipc_3_50_04_08/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/uia_2_30_01_02/packages;/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/xdctools_3_62_00_08_core/packages'.  Check that this path names a directory containing the necessary platform support and that the platform name is properly spelled.
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/build/makerules/rules_a15.mk:284: recipe for target '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/package/cfg/pm_a15_pa15fg.c' failed
    make[1]: *** [/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/binary/pm_rtos_testapp/obj/evmAM572x/a15_0/release/configuro/package/cfg/pm_a15_pa15fg.c] Error 1
    make[1]: Leaving directory '/home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/examples/pmrtos'
    makefile:358: recipe for target 'pm_rtos_testapp' failed
    Please note that the following errors are observed for four builds made.
    rtos_build1:
    rtos_build2:
    linux_build3:
    linux_build4:
    Also, I noticed in line number 10 of makefiles present in the following directories as "APP_NAME = pm_cpuidle_app"
    /home/rishi/ti-processor-sdk-linux-am57xx-evm-08_02_01_00/linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/ti/ti-pdk-tree/packages/ti/drv/pm/examples/cpuidle
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/cpuidle
    Should the APP_NAME in these files to be set to 'pm_cpuidle_testapp'?
    Thanks.
    Rishi.
  • Hi Parth,
    Thanks for your response.
    What should be done to enable the pm cpu idle test and generate the executable binary
    for the cores a15_0, ipu1_0, and c66x?
    What about generation of executable binary for pm system config test for the cores a15_0,
    ipu1_0, and c66x?
    Why are the generated binaries (except pm_rtos_testapp_a15_0_release.xa15fg) for pm_rtos are not loadable in the CCS (i.e. CCS giving error "Could not determine target type of file")?  How can the pm_rtos test binaries be generated for the cores ipu1_0 and c66x that are loadable and freely runnable in CCS?
    Rishi.
    Please refer to the patch in the thread https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1216888/am5716-am5716/4622841#4622841
    With this you should be able to build the cpu_idle test.
    Parth
  • Hi Parth,
    Attached are the two updated files that I used to build pm_cpuidle_testapp.
    I ran the following command first.
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/$ source pdksetupenv.sh
    Then, I gave the following command.
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build$ make BOARD=idkAM572x CORE=a15_0 pm_cpuidle_testapp
    I got the following errors.
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/cpuidle  xdc_configuro
    make[1]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/cpuidle'
    make /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_a15.cmd
    make[2]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/cpuidle'
    make[2]: '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_a15.cmd' is up to date.
    make[2]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/cpuidle'
    make[1]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/cpuidle'
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/a15_0/release
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/a15_0/release/little/.deps
    /bin/mkdir -p /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/a15_0/release/configuro
    make  csl osal_nonos i2c uart board pm_hal pm_lib pm_example_utils csl_init
    make[2]: Nothing to be done for 'osal_nonos'.
    make[2]: Nothing to be done for 'pm_hal'.
    make[2]: Nothing to be done for 'pm_lib'.
    make[2]: Nothing to be done for 'csl_init'.
    make  /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_a15_0_release.xa15fg
    # Compiling idkAM572x:am572x:a15_0:release:pm_cpuidle_testapp: main_a15.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc -MD -MF /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/a15_0/release/little/.deps/main_a15.P -DMAKEFILE_BUILD -Wimplicit -Wall -Wunused -Wunknown-pragmas -ffunction-sections -fdata-sections -c -mcpu=cortex-a15 -g -mfpu=neon -mfloat-abi=hard -mabi=aapcs -mapcs-frame -mno-unaligned-access -D__ARMv7 -Werror -O2 -s -DNDEBUG  -DBUILD_A15_0    -DSOC_AM572x -DidkAM572x=idkAM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/gcc-arm-none-eabi-7-2018-q2-update/arm-none-eabi/include/newlib-nano -I. -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils -I/apps/apps_nonbam/inc -I/ -I/common   -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/a15_0/release/main_a15.oa15fg main_a15.c
    make[2]: *** No rule to make target '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl/lib/am572x/a15/release/ti.csl.aa15fg', needed by '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_a15_0_release.xa15fg'.  Stop.
    makefile:339: recipe for target 'pm_cpuidle_testapp' failed
    make: *** [pm_cpuidle_testapp] Error 2
    Apologies for delay in response. Looks like there are some dependencies missing. Can you please try building with the DISABLE_RECURSE_DEPS=no
    Parth
  • Hi Parth,
    Thanks for your response.  Now, we are able to build pm_cpuidle_testapp for a15_0 with DISABLE_RECURSE_DEPS=no and the following executable is obtained.
    But, we got the following errors for DSP and M4 compilations.  How do we resolve these errors for building pm_cpuidle_testapp for DSP and M4?
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/make pm_cpuidle_testapp BOARD=idkAM572x CORE=c66x DISABLE_RECURSE_DEPS=no
    make /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_dsp.cmd
    make[2]: '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_dsp.cmd' is up to date.
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl -fmakefile.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl'
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/rules_66.mk:187: target 'package/all/cslr_pwmss.h' given more than once in the same rule
    make[3]: Nothing to be done for 'all'.
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal -f build/makefile_nonos.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/i2c -f build/makefile.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/i2c'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/i2c'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/uart -f build/makefile.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/uart'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/uart'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board -f build/makefile.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal -f/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal/makefile.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmhal'
    make -C /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib -f/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib/makefile.mk
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/src/pmlib'
    make[3]: Entering directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils'
    make[3]: Leaving directory '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils'
    make /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_c66x_release.xe66
    # Linking into /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_c66x_release.xe66...
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/ti-cgt-c6000_8.3.2/bin/lnk6x --emit_warnings_as_errors --warn_sections -q -e=_c_int00 --silicon_version=6600 -c -x /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/c66x/release/main_c66x.oe66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_dsp.cmd -o /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_c66x_release.xe66 -m /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_c66x_release.xe66.map -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/csl/lib/am572x/c66/release/ti.csl.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/i2c/lib/am572x/c66/release/ti.drv.i2c.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/uart/lib/am572x/c66/release/ti.drv.uart.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/board/lib/idkAM572x/c66/release/ti.board.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/c66/release/pm_hal.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/c66/release/pm_lib.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/lib/am572x/c66/release/pm_example_utils.ae66 -l/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/ti-cgt-c6000_8.3.2/lib/libc.a
    "/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_dsp.cmd", line 27: error:
    no matching section
    error: creating output section "BOARD_IO_DELAY_DATA" without a SECTIONS
    specification
    error: creating output section "BOARD_IO_DELAY_CODE" without a SECTIONS
    specification
    undefined first referenced
    symbol in file
    CSL_dint /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<EventCombinerP_nonos.oe66>
    CSL_intcClose /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcGlobalEnable /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcGlobalNmiEnable /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcHwControl /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcInit /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcInterruptDisable /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcInterruptEnable /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcOpen /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_intcPlugEventHandler /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<Arch_util.oe66>
    CSL_rint /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/osal/lib/nonos/am572x/c66/release/ti.osal.ae66<EventCombinerP_nonos.oe66>
    error: unresolved symbols remain
    error: errors encountered during linking;
    .xe66" not built
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/rules_66.mk:249: recipe for target '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_c66x_release.xe66' failed
    make[2]: *** [/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_c66x_release.xe66] Error 1
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/common.mk:401: recipe for target 'c66x' failed
    make[1]: *** [c66x] Error 2
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/make pm_cpuidle_testapp BOARD=idkAM572x CORE=ipu1_0 DISABLE_RECURSE_DEPS=no
    make /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_m4.cmd
    make[2]: '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/lnk_m4.cmd' is up to date.
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/rules_ti_cgt_arm.mk:198: target 'package/all/cslr_pwmss.h' given more than once in the same rule
    make /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/bin/idkAM572x/pm_cpuidle_testapp_ipu1_0_release.xem4
    # Compiling idkAM572x:am572x:ipu1_0:release:pm_cpuidle_testapp: main_ipu.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/ti-cgt-arm_18.12.5.LTS/bin/armcl -ppd=/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release/little/.deps/main_ipu.P -g -ms -DMAKEFILE_BUILD -c -qq -pdsw225 --endian=little -mv7M4 --abi=eabi -eo.oem4 -ea.sem4 --symdebug:dwarf --embed_inline_assembly --float_support=vfplib --emit_warnings_as_errors -ms -O4 -op0 -os --optimize_with_debug --inline_recursion_limit=20 -DBUILD_IPU1_0 -DBUILD_IPU1 -DSOC_AM572x -DidkAM572x=idkAM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/ti-cgt-arm_18.12.5.LTS/include -I. -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils -fr=/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release -fs=/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release -fc main_ipu.c
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/ti-cgt-arm_18.12.5.LTS/bin/armcl -g -ms -DMAKEFILE_BUILD -c -qq -pdsw225 --endian=little -mv7M4 --abi=eabi -eo.oem4 -ea.sem4 --symdebug:dwarf --embed_inline_assembly --float_support=vfplib --emit_warnings_as_errors -ms -O4 -op0 -os --optimize_with_debug --inline_recursion_limit=20 -DBUILD_IPU1_0 -DBUILD_IPU1 -DSOC_AM572x -DidkAM572x=idkAM572x -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/ti-cgt-arm_18.12.5.LTS/include -I. -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages -I/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/drv/pm/examples/utils -fr=/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release -fs=/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release -fc main_ipu.c
    "main_ipu.c", line 116: error: identifier "SOC_IPU1_UNICACHE_MMU_CONF_REGS_BASE" is undefined
    1 error detected in the compilation of "main_ipu.c".
    >> Compilation failure
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/rules_ti_cgt_arm.mk:185: recipe for target '/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release/main_ipu.oem4' failed
    make[2]: *** [/home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/binary/pm_cpuidle_testapp/obj/idkAM572x/ipu1_0/release/main_ipu.oem4] Error 1
    /home/rishi/processor_sdk_rtos_am57xx_08_01_00_09/pdk_am57xx_1_0_19/packages/ti/build/makerules/common.mk:401: recipe for target 'ipu1_0' failed
    make[1]: *** [ipu1_0] Error 2
    Rishi.
  • Hi Rishi,
    Apologies for long silence on this.
    Is this issue still open?
    Parth
  • Hi Parth,
    This power management issue is still open. We would like this issue to be resolved ASAP and hence we are
    awaiting your response.
    Basically we would like to see DSP1 & 2 put into on-core active, on-core inactive, and off dynamically by itself
    or by a15_0. We would like to see a15_0 putting a15_1 and m4 (all cores) into on-core active and off dynamically.
    How can sleeping a15_1 be woken up by 1) UART and 2) Timer?
    We would like to see changes in the current drawn by AM5728 for these power saving modes and the
    corresponding power and clock status register changes viewed through a15_0 running linux.
    Is it possible to turn off a15_0 also? In which case, can a15_1 monitor and control power/clock modes of a15_0 or
    only a15_0 can turn off by itself? If a15_0 is turned off, what are the possible ways that it can be turned ON?
    Thanks.
    Rishi.
    Did your build issue resolved? Would you please confirm if you are using PROCESSOR-SDK-LINUX-AM57X or PROCESSOR-SDK-RTOS-AM57X?
    Karthik
