AM3356: ethernet phy DP83TC813R support in kernel 4.19
Part Number: AM3356
Other Parts Discussed in Thread: DP83TC811
Hi, Exports.
I'm Katsuyama.
We are planning to use DP83TC813R as ethernet phy.
Kernel Version is 4.19.
SDK Version is 06_03_00_106.
Is there a device driver for DP83TC813R.
Or, "dp83t811.c" in driver/net/phy directory supports it?
Best regards.
  • Hello Katsuyama,
    I would assume that dp83tc811.c would apply to DP83TC813R. However, I am sending your thread over to the PHY team to comment.
    Nick
  • Hi Katsuyama,
    Here is the most up to date DP83TC813 driver: redacted
    David
  • Hi, Nick and David.
    Thanks to your responses.
    I'm afraid to say, I can't access the URL "https://bitbucket.itg.ti.com/" .
    But, I  found "dp83tc812.c" in "">www.ti.com/.../ETHERNET-SW" .
    So, I compiled it, then I got following errors.
    Does it support kernel 4.19?
      CC      drivers/net/phy/dp83tc812.o
    drivers/net/phy/dp83tc812.c:517:3: error: implicit declaration of function 'PHY_ID_MATCH_EXACT' [-Werror=implicit-function-declaration]
       PHY_ID_MATCH_EXACT(_id),   \
    drivers/net/phy/dp83tc812.c:534:2: note: in expansion of macro 'DP83812_PHY_DRIVER'
      DP83812_PHY_DRIVER(DP83TC812_CS1_0_PHY_ID, "TI DP83TC812CS1.0"),
    drivers/net/phy/dp83tc812.c:517:3: warning: initialization of 'const char *' from 'int' makes pointer from integer without a cast [-Wint-conversion]
    drivers/net/phy/dp83tc812.c:517:3: note: (near initialization for 'dp83812_driver[0].mdiodrv.driver.name')
    drivers/net/phy/dp83tc812.c:517:3: error: initializer element is not constant
    drivers/net/phy/dp83tc812.c:533:45: warning: missing braces around initializer [-Wmissing-braces]
     static struct phy_driver dp83812_driver[] = {
    drivers/net/phy/dp83tc812.c:535:2: note: in expansion of macro 'DP83812_PHY_DRIVER'
      DP83812_PHY_DRIVER(DP83TC812_CS2_0_PHY_ID, "TI DP83TC812CS2.0"),
    drivers/net/phy/dp83tc812.c:517:3: note: (near initialization for 'dp83812_driver[1].mdiodrv.driver.name')
    Thanks.
  • Hi Takeharu,
    My apologies. Can you please try the attached?
    David
    // SPDX-License-Identifier: GPL-2.0
     * Driver for the Texas Instruments DP83TC812 PHY
     * Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
    #include <linux/ethtool.h>
    #include <linux/etherdevice.h>
    #include <linux/kernel.h>
    #include <linux/mii.h>
    #include <linux/module.h>
    #include <linux/of.h>
    #include <linux/phy.h>
    #include <linux/netdevice.h>
    #define DP83TC812_CS1_0_PHY_ID	0x2000a270
    #define DP83TC812_CS2_0_PHY_ID	0x2000a271
    #define DP83TC813_CS2_0_PHY_ID	0x2000a211
    #define DP83TC814_CS2_0_PHY_ID	0x2000a261
    #define DP83812_DEVADDR		0x1f
    #define DP83812_DEVADDR_MMD1	0x1
    #define DP83812_STRAP		0x45d
    #define MII_DP83812_SGMII_CTRL	0x608
    #define SGMII_CONFIG_VAL	0x027B
    #define MII_DP83812_RGMII_CTRL	0x600
    #define MII_DP83812_INT_STAT1	0x12
    #define MII_DP83812_INT_STAT2	0x13
    #define MII_DP83812_INT_STAT3	0x18
    #define MII_DP83812_RESET_CTRL	0x1f
    #define DP83812_HW_RESET	BIT(15)
    #define DP83812_SW_RESET	BIT(14)
    /* INT_STAT1 bits */
    #define DP83812_RX_ERR_CNT_HALF_FULL_INT_EN	BIT(0)
    #define DP83812_TX_ERR_CNT_HALF_FULL_INT_EN	BIT(1)
    #define DP83812_MS_TRAIN_DONE_INT_EN		BIT(2)
    #define DP83812_ESD_EVENT_INT_EN		BIT(3)
    #define DP83812_LINK_STAT_INT_EN		BIT(5)
    #define DP83812_ENERGY_DET_INT_EN		BIT(6)
    #define DP83812_LINK_QUAL_INT_EN		BIT(7)
    /* INT_STAT2 bits */
    #define DP83812_JABBER_INT_EN		BIT(0)
    #define DP83812_POL_INT_EN		BIT(1)
    #define DP83812_SLEEP_MODE_INT_EN	BIT(2)
    #define DP83812_OVERTEMP_INT_EN		BIT(3)
    #define DP83812_FIFO_INT_EN		BIT(4)
    #define DP83812_PAGE_RXD_INT_EN		BIT(5)
    #define DP83812_OVERVOLTAGE_INT_EN	BIT(6)
    #define DP83812_UNDERVOLTAGE_INT_EN	BIT(7)
    /* INT_STAT3 bits */
    #define DP83812_LPS_INT_EN		BIT(0)
    #define DP83812_WUP_INT_EN		BIT(1)
    #define DP83812_WAKE_REQ_INT_EN		BIT(2)
    #define DP83811_NO_FRAME_INT_EN		BIT(3)
    #define DP83811_POR_DONE_INT_EN		BIT(4)
    #define DP83812_SLEEP_FAIL_INT_EN	BIT(5)
    /* RGMII_CTRL bits */
    #define DP83812_RGMII_EN		BIT(3)
    /* SGMII CTRL bits */
    #define DP83812_SGMII_AUTO_NEG_EN	BIT(0)
    #define DP83812_SGMII_EN		BIT(9)
    /* Strap bits */
    #define DP83812_MASTER_MODE	BIT(9)
    #define DP83812_RGMII_IS_EN	BIT(7)
    /* RGMII ID CTRL */
    #define DP83812_RGMII_ID_CTRL	0x602
    #define DP83812_RX_CLK_SHIFT	BIT(1)
    #define DP83812_TX_CLK_SHIFT	BIT(0)
    enum dp83812_chip_type {
    	DP83812_CS1 = 0,
    	DP83812_CS2,
    	DP83813_CS2,
    	DP83814_CS2,
    struct dp83812_init_reg {
    	int	reg;
    	int	val;
    static const struct dp83812_init_reg dp83812_master_cs1_0_init[] = {
    	{0x523, 0x0001},
    	{0x800, 0xf864},
    	{0x803, 0x1552},
    	{0x804, 0x1a66},
    	{0x805, 0x1f7b},
    	{0x81f, 0x2a88},
    	{0x825, 0x40e5},
    	{0x82b, 0x7f3f},
    	{0x830, 0x0543},
    	{0x836, 0x5008},
    	{0x83a, 0x08e0},
    	{0x83b, 0x0845},
    	{0x83e, 0x0445},
    	{0x855, 0x9b9a},
    	{0x85f, 0x2010},
    	{0x860, 0x6040},
    	{0x86c, 0x1333},
    	{0x86b, 0x3e10},
    	{0x872, 0x88c0},
    	{0x873, 0x0003},
    	{0x879, 0x000f},
    	{0x87b, 0x0070},
    	{0x87c, 0x003f},
    	{0x89e, 0x00aa},
    	{0x523, 0x0000},
    static const struct dp83812_init_reg dp83812_master_cs2_0_init[] = {
    	{0x523, 0x0001},
    	{0x81C, 0x0fe2},
    	{0x872, 0x0300},
    	{0x879, 0x0f00},
    	{0x806, 0x2952},
    	{0x807, 0x3361},
    	{0x808, 0x3D7B},
    	{0x83E, 0x045F},
    	{0x834, 0x8000},
    	{0x862, 0x00E8},
    	{0x896, 0x32CB},
    	{0x03E, 0x0009},
    	{0x01f, 0x4000},
    	{0x523, 0x0000},
    static const struct dp83812_init_reg dp83812_slave_cs1_0_init[] = {
    	{0x523, 0x0001},
    	{0x803, 0x1b52},
    	{0x804, 0x216c},
    	{0x805, 0x277b},
    	{0x827, 0x3000},
    	{0x830, 0x0543},
    	{0x83a, 0x0020},
    	{0x83c, 0x0001},
    	{0x855, 0x9b9a},
    	{0x85f, 0x2010},
    	{0x860, 0x6040},
    	{0x86c, 0x0333},
    	{0x872, 0x88c0},
    	{0x873, 0x0021},
    	{0x879, 0x000f},
    	{0x87b, 0x0070},
    	{0x87c, 0x0002},
    	{0x897, 0x003f},
    	{0x89e, 0x00a2},
    	{0x510, 0x000f},
    	{0x523, 0x0000},
    static const struct dp83812_init_reg dp83812_slave_cs2_0_init[] = {
    	{0x523, 0x0001},
    	{0x873, 0x0821},
    	{0x896, 0x22ff},
    	{0x89E, 0x0000},
    	{0x01f, 0x4000},
    	{0x523, 0x0000},
    struct dp83812_private {
    	int chip;
    	bool is_master;
    	bool is_rgmii;
    	bool is_sgmii;
    static int dp83812_read_straps(struct phy_device *phydev)
    	struct dp83812_private *dp83812 = phydev->priv;
    	int strap;
    	strap = phy_read_mmd(phydev, DP83812_DEVADDR, DP83812_STRAP);
    	if (strap < 0)
    		return strap;
    	printk("%s: Strap is 0x%X\n", __func__, strap);
    	if (strap & DP83812_MASTER_MODE)
    		dp83812->is_master = true;
    	if (strap & DP83812_RGMII_IS_EN)
    		dp83812->is_rgmii = true;
    	return 0;
    static int dp83812_reset(struct phy_device *phydev, bool hw_reset)
    	int ret;
    	if (hw_reset)
    		ret = phy_write_mmd(phydev, DP83812_DEVADDR, MII_DP83812_RESET_CTRL,
    				DP83812_HW_RESET);
    	else
    				DP83812_SW_RESET);
    	if (ret)
    		return ret;
    	mdelay(100);
    	return 0;
    static int dp83812_phy_reset(struct phy_device *phydev)
    	int err;
    	int ret;
    	err = phy_write_mmd(phydev, DP83812_DEVADDR, MII_DP83812_RESET_CTRL, DP83812_HW_RESET);
    	if (err < 0)
    		return err;
    	ret = dp83812_read_straps(phydev);
    	if (ret)
    		return ret;
    	return 0;
    static int dp83812_write_seq(struct phy_device *phydev, const struct
    				dp83812_init_reg *init_data, int size)
    	int ret;
    	int i;
    	for (i = 0; i < size; i++) {
    		ret = phy_write_mmd(phydev, DP83812_DEVADDR, init_data[i].reg,
    					init_data[i].val);
    	if (ret)
    		return ret;
    	return 0;
    static int dp83812_chip_init(struct phy_device *phydev)
    	int ret;
    	ret = dp83812_reset(phydev, true);
    	if (ret)
    		return ret;
    	phydev->autoneg = AUTONEG_DISABLE;
    	phydev->speed = SPEED_100;
    	phydev->duplex = DUPLEX_FULL;
    	linkmode_set_bit(ETHTOOL_LINK_MODE_100baseT_Full_BIT,
    		 phydev->supported);
    	if (dp83812->is_master)
    		ret = phy_write_mmd(phydev, DP83812_DEVADDR_MMD1, 0x0834, 0xc001);
    		// ret = phy_write_mmd(phydev, DP83812_DEVADDR, 0x0834, 0xc001);
    	else
    		ret = phy_write_mmd(phydev, DP83812_DEVADDR_MMD1, 0x0834, 0x8001);
    		// ret = phy_write_mmd(phydev, DP83812_DEVADDR, 0x0834, 0x8001);
    	switch (dp83812->chip) {
    	case DP83812_CS1:
    			ret = dp83812_write_seq(phydev,
    						dp83812_master_cs1_0_init,
    						ARRAY_SIZE(dp83812_master_cs1_0_init));
    		else
    						dp83812_slave_cs1_0_init,
    						ARRAY_SIZE(dp83812_slave_cs1_0_init));
    	break;
    	case DP83812_CS2:
    						dp83812_master_cs2_0_init,
    						ARRAY_SIZE(dp83812_master_cs2_0_init));
    		else
    						dp83812_slave_cs2_0_init,
    						ARRAY_SIZE(dp83812_slave_cs2_0_init));
    	break;
    	case DP83813_CS2:
    		else
    	break;
    	case DP83814_CS2:
    		else
    	break;
    	default:
    		return -EINVAL;
    	if (ret)
    		return ret;
    	mdelay(10);
    	// phy_write_mmd(phydev, DP83812_DEVADDR, 0x523, 0x00);
    	/* Do a soft reset to restart the PHY with updated values */
    	return dp83812_reset(phydev, false);
    static int dp83812_config_init(struct phy_device *phydev)
    	struct device *dev = &phydev->mdio.dev;
    	s32 rx_int_delay;
    	s32 tx_int_delay;
    	int rgmii_delay;
    	int value, ret;
    	ret = dp83812_chip_init(phydev);
    	if (ret)
    		return ret;
    	if (phy_interface_is_rgmii(phydev)) {
    		rx_int_delay = phy_get_internal_delay(phydev, dev, NULL, 0,
    						      true);
    		if (rx_int_delay <= 0)
    			rgmii_delay = 0;
    		else
    			rgmii_delay = DP83812_RX_CLK_SHIFT;
    		tx_int_delay = phy_get_internal_delay(phydev, dev, NULL, 0,
    						      false);
    		if (tx_int_delay <= 0)
    			rgmii_delay &= ~DP83812_TX_CLK_SHIFT;
    		else
    			rgmii_delay |= DP83812_TX_CLK_SHIFT;
    		if (rgmii_delay) {
    			ret = phy_set_bits_mmd(phydev, DP83812_DEVADDR_MMD1,
    					       DP83812_RGMII_ID_CTRL,
    					       rgmii_delay);
    			if (ret)
    				return ret;
    	if (phydev->interface == PHY_INTERFACE_MODE_SGMII) {
    		value = phy_read(phydev, MII_DP83812_SGMII_CTRL);
    		ret = phy_write_mmd(phydev, DP83812_DEVADDR, MII_DP83812_SGMII_CTRL,
    				SGMII_CONFIG_VAL);
    	if (ret < 0)
    		return ret;
    	return 0;
    static int dp83812_ack_interrupt(struct phy_device *phydev)
    	int err;
    	err = phy_read(phydev, MII_DP83812_INT_STAT1);
    	if (err < 0)
    		return err;
    	err = phy_read(phydev, MII_DP83812_INT_STAT2);
    	if (err < 0)
    		return err;
    	err = phy_read(phydev, MII_DP83812_INT_STAT3);
    	if (err < 0)
    		return err;
    	return 0;
    static int dp83812_config_intr(struct phy_device *phydev)
    	int misr_status, err;
    	if (phydev->interrupts == PHY_INTERRUPT_ENABLED) {
    		misr_status = phy_read(phydev, MII_DP83812_INT_STAT1);
    		if (misr_status < 0)
    			return misr_status;
    		misr_status |= (DP83812_ESD_EVENT_INT_EN |
    				DP83812_LINK_STAT_INT_EN |
    				DP83812_ENERGY_DET_INT_EN |
    				DP83812_LINK_QUAL_INT_EN);
    		err = phy_write(phydev, MII_DP83812_INT_STAT1, misr_status);
    		if (err < 0)
    			return err;
    		misr_status = phy_read(phydev, MII_DP83812_INT_STAT2);
    			return misr_status;
    		misr_status |= (DP83812_SLEEP_MODE_INT_EN |
    				DP83812_OVERTEMP_INT_EN |
    				DP83812_OVERVOLTAGE_INT_EN |
    				DP83812_UNDERVOLTAGE_INT_EN);
    		err = phy_write(phydev, MII_DP83812_INT_STAT2, misr_status);
    		if (err < 0)
    			return err;
    		misr_status = phy_read(phydev, MII_DP83812_INT_STAT3);
    			return misr_status;
    		misr_status |= (DP83812_LPS_INT_EN |
    				DP83812_WAKE_REQ_INT_EN |
    				DP83811_NO_FRAME_INT_EN |
    				DP83811_POR_DONE_INT_EN);
    		err = phy_write(phydev, MII_DP83812_INT_STAT3, misr_status);
    	} else {
    		err = phy_write(phydev, MII_DP83812_INT_STAT1, 0);
    		if (err < 0)
    			return err;
    		err = phy_write(phydev, MII_DP83812_INT_STAT2, 0);
    		if (err < 0)
    			return err;
    		err = phy_write(phydev, MII_DP83812_INT_STAT3, 0);
    	return err;
    #if 0
    static irqreturn_t dp83812_handle_interrupt(struct phy_device *phydev)
    	bool trigger_machine = false;
    	int irq_status;
    	/* The INT_STAT registers 1, 2 and 3 are holding the interrupt status
    	 * in the upper half (15:8), while the lower half (7:0) is used for
    	 * controlling the interrupt enable state of those individual interrupt
    	 * sources. To determine the possible interrupt sources, just read the
    	 * INT_STAT* register and use it directly to know which interrupts have
    	 * been enabled previously or not.
    	irq_status = phy_read(phydev, MII_DP83812_INT_STAT1);
    	if (irq_status < 0) {
    		phy_error(phydev);
    		return IRQ_NONE;
    	if (irq_status & ((irq_status & GENMASK(7, 0)) << 8))
    		trigger_machine = true;
    	irq_status = phy_read(phydev, MII_DP83812_INT_STAT2);
    		phy_error(phydev);
    		return IRQ_NONE;
    	irq_status = phy_read(phydev, MII_DP83812_INT_STAT3);
    		phy_error(phydev);
    		return IRQ_NONE;
    	if (!trigger_machine)
    		return IRQ_NONE;
    	phy_trigger_machine(phydev);
    	return IRQ_HANDLED;
    #endif
    static int dp83812_config_aneg(struct phy_device *phydev)
    	int value, ret;
    				SGMII_CONFIG_VAL);
    		if (ret < 0)
    			return ret;
    	return genphy_config_aneg(phydev);
    static int dp83812_probe(struct phy_device *phydev)
    	struct dp83812_private *dp83812;
    	int ret;
    	dp83812 = devm_kzalloc(&phydev->mdio.dev, sizeof(*dp83812), GFP_KERNEL);
    	if (!dp83812)
    		return -ENOMEM;
    	phydev->priv = dp83812;
    	if (ret)
    		return ret;
    	switch (phydev->phy_id) {
    	case DP83TC812_CS1_0_PHY_ID:
    		dp83812->chip = DP83812_CS1;
    	break;
    	case DP83TC812_CS2_0_PHY_ID:
    		dp83812->chip = DP83812_CS2;
    	break;
    	case DP83TC813_CS2_0_PHY_ID:
    		dp83812->chip = DP83813_CS2;
    		break;
    	case DP83TC814_CS2_0_PHY_ID:
    		dp83812->chip = DP83814_CS2;
    	break;
    	default:
    	return -EINVAL;
    /* vikram : above code added to switch between different phy ids */
    	return dp83812_config_init(phydev);
    #define DP83812_PHY_DRIVER(_id, _name)				\
    		.name           = (_name),			\
    		.probe          = dp83812_probe,		\
    		/* PHY_BASIC_FEATURES */			\
    		.soft_reset     = dp83812_phy_reset,		\
    		.config_init    = dp83812_config_init,		\
    		.config_aneg = dp83812_config_aneg,		\
    		.ack_interrupt = dp83812_ack_interrupt,		\
    /*if 0								\
    		.handle_interrupt = dp83812_handle_interrupt,	\
    #endif	*/							\
    		.config_intr = dp83812_config_intr,		\
    		.suspend = genphy_suspend,			\
    		.resume = genphy_resume,			\
    	DP83812_PHY_DRIVER(DP83TC813_CS2_0_PHY_ID, "TI DP83TC813CS2.0"),
    	DP83812_PHY_DRIVER(DP83TC814_CS2_0_PHY_ID, "TI DP83TC814CS2.0"),
    module_phy_driver(dp83812_driver);
    static struct mdio_device_id __maybe_unused dp83812_tbl[] = {
    	{ PHY_ID_MATCH_EXACT(DP83TC812_CS1_0_PHY_ID) },
    	{ PHY_ID_MATCH_EXACT(DP83TC812_CS2_0_PHY_ID) },
    	{ PHY_ID_MATCH_EXACT(DP83TC813_CS2_0_PHY_ID) },
    	{ PHY_ID_MATCH_EXACT(DP83TC814_CS2_0_PHY_ID) },
    MODULE_DEVICE_TABLE(mdio, dp83812_tbl);
    MODULE_DESCRIPTION("Texas Instruments DP83TC812 PHY driver");
    MODULE_AUTHOR("Hari Nagalla <hnagalla@ti.com");
    MODULE_LICENSE("GPL");
  • Hi, David
    I'm afraid to say, they are completely same this one and  the one in "">www.ti.com/.../ETHERNET-SW" .
    I work on the same team as David. He is OoO due to the Labor Day Holiday. Please expect a delay in his next correspondence.
    Sincerely,
    Gerome
  • Hi Takeharu,
    The driver which I shared as a text file has only been tested on Linux 5.10 and later. We recommend to use the latest kernel. Can you try again with Linux 5.10 or later and let me know the result?
    David
  • I'm sorry to be late for response.
    We can't chage kernel version from 4.19 to 5.10.
    So, We gave up to use DP83TC813.
    Thank you for your responses.
    Katsuyama.
