TDA4VM: unable to mount file system,Waiting for root device PARTUUID
Part Number: TDA4VM
Hi,experts
     we can't start the customized board using sdcard, the sd card can start on TDA4VM  EVM board. The log shows that Linux is waiting for the root device to mount.  we disable emmc but it doesn't word, so is it some error on sdcard?
    Can you analyze the problem and give some suggestions?
    Best regards
U-Boot SPL 2021.01 (Aug 31 2023 - 21:01:58 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE:  BL31: Built : 22:56:45, Mar  3 2023
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Fri Mar  3 22:59:24 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01 (Aug 31 2023 - 21:01:16 +0800)
U-Boot 2021.01 (Aug 31 2023 - 21:01:16 +0800)
SoC:   J721E SR1.1 GP
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
cdns,sierra serdes@5000000: PHY not found 0x7364 vs 0x0
Sierra init failed:-22
Net:   Could not get PHY for ethernet@46000000port@1: addr 0
am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed
No ethernet found.
ota_init
bootfirst=0, trycount=1, bootpart=1:2
 normal boot
Saving Environment to FAT... OK
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
574 bytes read in 8 ms (69.3 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19079680 bytes read in 793 ms (22.9 MiB/s)
111819 bytes read in 13 ms (8.2 MiB/s)
   Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.162 (wx@wx-virtual-machine) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Aug 31 20:42:46 CST 2023
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=def429f2-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3271300K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 398716K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008401] Console: colour dummy device 80x25
[    0.012963] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023633] pid_max: default: 32768 minimum: 301
[    0.028388] LSM: Security Framework initializing
[    0.033141] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040715] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049533] rcu: Hierarchical SRCU implementation.
[    0.054597] Platform MSI: msi-controller@1820000 domain created
[    0.060833] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070133] EFI services will not be available.
[    0.074849] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.088087] Detected PIPT I-cache on CPU1
[    0.088112] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.088123] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
[    0.088157] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.088205] smp: Brought up 1 node, 2 CPUs
[    0.117551] SMP: Total of 2 processors activated.
[    0.122356] CPU features: detected: 32-bit EL0 Support
[    0.127610] CPU features: detected: CRC32 instructions
[    0.141621] CPU: All CPU(s) started at EL2
[    0.145814] alternatives: patching kernel code
[    0.150832] devtmpfs: initialized
[    0.159731] KASLR disabled due to lack of seed
[    0.164376] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.174339] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.187204] pinctrl core: initialized pinctrl subsystem
[    0.192849] DMI not present or invalid.
[    0.197090] NET: Registered protocol family 16
[    0.202289] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.209591] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.217642] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.225947] thermal_sys: Registered thermal governor 'step_wise'
[    0.225949] thermal_sys: Registered thermal governor 'power_allocator'
[    0.232527] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.246161] ASID allocator initialised with 65536 entries
[    0.270667] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.277523] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.284369] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.291214] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.298668] cryptd: max_cpu_qlen set to 1000
[    0.304756] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.313575] vsys_3v3: supplied by evm_12v0
[    0.317932] vsys_5v0: supplied by evm_12v0
[    0.322674] iommu: Default domain type: Translated
[    0.327836] SCSI subsystem initialized
[    0.331992] mc: Linux media interface: v0.10
[    0.336370] videodev: Linux video capture interface: v2.00
[    0.342006] pps_core: LinuxPPS API ver. 1 registered
[    0.347077] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.356413] PTP clock support registered
[    0.360434] EDAC MC: Ver: 3.0.0
[    0.364217] FPGA manager framework
[    0.367728] Advanced Linux Sound Architecture Driver Initialized.
[    0.374322] clocksource: Switched to clocksource arch_sys_counter
[    0.380645] VFS: Disk quotas dquot_6.6.0
[    0.384677] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.394225] NET: Registered protocol family 2
[    0.398956] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.407531] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.416286] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.424486] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.432284] TCP: Hash tables configured (established 32768 bind 32768)
[    0.439080] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.445975] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.453372] NET: Registered protocol family 1
[    0.458080] RPC: Registered named UNIX socket transport module.
[    0.464144] RPC: Registered udp transport module.
[    0.468948] RPC: Registered tcp transport module.
[    0.473751] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.480332] NET: Registered protocol family 44
[    0.484878] PCI: CLS 0 bytes, default 64
[    0.489241] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.499633] Initialise system trusted keyrings
[    0.504257] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.512358] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.518612] NFS: Registering the id_resolver key type
[    0.523801] Key type id_resolver registered
[    0.528073] Key type id_legacy registered
[    0.532192] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.539040] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.546675] 9p: Installing v9fs 9p2000 file system support
[    0.572302] Key type asymmetric registered
[    0.576489] Asymmetric key parser 'x509' registered
[    0.581489] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.589048] io scheduler mq-deadline registered
[    0.593674] io scheduler kyber registered
[    0.599403] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.605584] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.614524] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.620949] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[    0.628929] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.635350] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[    0.643286] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.649704] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[    0.657633] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.663960] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[    0.671910] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.678233] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[    0.687915] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.696160] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.704370] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.711404] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.719821] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.732931] brd: module loaded
[    0.739368] loop: module loaded
[    0.743088] megasas: 07.714.04.00-rc1
[    0.748842] tun: Universal TUN/TAP device driver, 1.6
[    0.754299] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.760710] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.766786] sky2: driver version 1.30
[    0.771126] VFIO - User Level meta-driver version: 0.3
[    0.776896] i2c /dev entries driver
[    0.781382] sdhci: Secure Digital Host Controller Interface driver
[    0.787704] sdhci: Copyright(c) Pierre Ossman
[    0.792365] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.798765] ledtrig-cpu: registered to indicate activity on CPUs
[    0.805110] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.812480] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.817043] optee: revision 3.20 (8e74d476)
[    0.833441] optee: dynamic shared memory is enabled
[    0.842901] optee: initialized driver
[    0.848032] NET: Registered protocol family 17
[    0.852652] 9pnet: Installing 9P2000 support
[    0.857050] Key type dns_resolver registered
[    0.861506] Loading compiled-in X.509 certificates
[    0.874576] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[    0.936032] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.943807] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.949883] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.956184] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.962499] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.969315] pca953x 3-0020: using no AI
[    0.994449] pca953x 3-0020: failed writing register
[    0.999488] pca953x: probe of 3-0020 failed with error -121
[    1.005410] pca953x 3-0022: supply vcc not found, using dummy regulator
[    1.012216] pca953x 3-0022: using AI
[    1.016008] pca953x 3-0022: failed writing register
[    1.021033] pca953x: probe of 3-0022 failed with error -121
[    1.026766] omap_i2c 2000000.i2c: bus 3 rev0.12 at 100 kHz
[    1.033065] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
[    1.041178] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[    1.047388] pca953x 6-0020: supply vcc not found, using dummy regulator
[    1.054202] pca953x 6-0020: using no AI
[    1.078452] pca953x 6-0020: failed writing register
[    1.083485] pca953x: probe of 6-0020 failed with error -121
[    1.089471] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
[    1.095529] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.101500] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    1.107636] pca953x 9-0020: supply vcc not found, using dummy regulator
[    1.114447] pca953x 9-0020: using no AI
[    1.142450] pca953x 9-0020: failed writing register
[    1.147480] pca953x: probe of 9-0020 failed with error -121
[    1.153225] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
[    1.159677] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.169651] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.178465] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.188333] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.200708] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
[    1.219563] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.229452] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.236212] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.245200] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.255354] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.262113] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.270085] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    1.279477] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[    1.288222] printk: console [ttyS2] enabled
[    1.296658] printk: bootconsole [ns16550a0] disabled
[    1.307130] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[    1.316071] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[    1.326831] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.337341] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.347499] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.357738] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.368857] scsi host0: ufshcd
[    1.377953] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.422331] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.430253] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.436977] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.449818] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.457025] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.463326] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    1.473639] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.582998] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.595408] pca953x 4-0020: supply vcc not found, using dummy regulator
[    1.602074] pca953x 4-0020: using no AI
[    1.626453] pca953x 4-0020: failed writing register
[    1.631377] pca953x: probe of 4-0020 failed with error -121
[    1.637320] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.644156] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.650986] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.657806] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.664609] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.675139] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.685732] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.700386] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
[    1.705625] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    1.712224] Creating 8 MTD partitions on "47040000.spi.0":
[    1.717695] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.723646] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.729317] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.735099] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.740618] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    1.746314] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    1.752444] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.758218] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.767153] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
[    1.773378] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.797252] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    1.802731] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    1.807769] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    1.814021] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    1.818331] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.820458] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    1.828386] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.834933] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    1.841651] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.848209] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    1.848211] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    1.861047] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.867297] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    1.871810] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.879012] cdns-ufshcd 4e84000.ufs: last intr at 1705812 us, last intr status=0x404
[    1.879014] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    1.887541] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    1.893073] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    1.893076] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    1.893080] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    1.902170] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.908263] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    1.908265] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    1.908270] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    1.918959] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.926261] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    1.955565] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    1.957071] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    1.969459] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    1.974950] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    1.974953] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    1.974960] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    1.974964] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    1.982772] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    1.988517] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    1.994905] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    2.002063] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.008414] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    2.014729] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.014731] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.014736] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.014739] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.021112] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    2.027415] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.035736] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.041036] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.041038] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.041040] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.041042] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.041045] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1706934 us
[    2.041049] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.063258] ALSA device list:
[    2.068304] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.068306] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.068308] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.068310] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    2.165425]   No soundcards found.
[    2.169048] Waiting for root device PARTUUID=def429f2-02...
[   33.846331] tlv71033: disabling
  • Hi
    After analyzing the logs in linux i am net seeing any probe logs related to emmc or SD
    in the kernel command line root device is passed as PARTUUID=def429f2-02  that is why it is waiting for the root device
    Have you made proper changes in the dtsi ?
    Diwakar
        we compare it with TDA4VM  EVM sdcad boot log,  it is the same as it. EVM's log as follows:
    root@j7-evm:~#
    U-Boot SPL 2021.01-g15769936a5 (Dec 20 2021 - 17:09:03 +0000)
    Board: J721EX-PM2-SOM rev A
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 16:34:52, Dec 20 2021
    U-Boot SPL 2021.01-g15769936a5 (Dec 20 2021 - 16:36:05 +0000)
    Detected: J7X-BASE-CPB rev A
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-g15769936a5 (Dec 20 2021 - 16:36:05 +0000)
    SoC:   J721E SR2.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    eth0: ethernet@46000000
    0 bytes read in 1 ms (0 Bytes/s)
    19270144 bytes read in 805 ms (22.8 MiB/s)
    100196 bytes read in 13 ms (7.3 MiB/s)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Linux version 5.10.65-gdcc6bedb2c (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon Dec 20 16:38:26 UTC 2021
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=94abe6d6-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] Memory: 3339136K/4194304K available (10880K kernel code, 1346K rwdata, 4288K rodata, 1856K init, 757K bss, 330880K reserved, 524288K cma-reserved)
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.008352] Console: colour dummy device 80x25
    [    0.012912] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023582] pid_max: default: 32768 minimum: 301
    [    0.028329] LSM: Security Framework initializing
    [    0.033073] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040638] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049585] rcu: Hierarchical SRCU implementation.
    [    0.054634] Platform MSI: msi-controller@1820000 domain created
    [    0.060868] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070161] EFI services will not be available.
    [    0.074909] smp: Bringing up secondary CPUs ...
    [    0.080139] Detected PIPT I-cache on CPU1
    [    0.080163] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080174] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080206] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080260] smp: Brought up 1 node, 2 CPUs
    [    0.109604] SMP: Total of 2 processors activated.
    [    0.114408] CPU features: detected: 32-bit EL0 Support
    [    0.119661] CPU features: detected: CRC32 instructions
    [    0.133370] CPU: All CPU(s) started at EL2
    [    0.137565] alternatives: patching kernel code
    [    0.142551] devtmpfs: initialized
    [    0.150718] KASLR disabled due to lack of seed
    [    0.155370] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165333] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.172994] pinctrl core: initialized pinctrl subsystem
    [    0.178569] DMI not present or invalid.
    [    0.182780] NET: Registered protocol family 16
    [    0.190201] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197502] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205506] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.213808] thermal_sys: Registered thermal governor 'step_wise'
    [    0.213810] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220227] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.233867] ASID allocator initialised with 65536 entries
    [    0.256789] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.263646] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.270404] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.278188] cryptd: max_cpu_qlen set to 1000
    [    0.284226] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.293019] vsys_3v3: supplied by evm_12v0
    [    0.297396] vsys_5v0: supplied by evm_12v0
    [    0.302093] iommu: Default domain type: Translated
    [    0.307212] SCSI subsystem initialized
    [    0.311319] mc: Linux media interface: v0.10
    [    0.315734] videodev: Linux video capture interface: v2.00
    [    0.321363] pps_core: LinuxPPS API ver. 1 registered
    [    0.326433] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.335770] PTP clock support registered
    [    0.339790] EDAC MC: Ver: 3.0.0
    [    0.343540] FPGA manager framework
    [    0.347051] Advanced Linux Sound Architecture Driver Initialized.
    [    0.353640] clocksource: Switched to clocksource arch_sys_counter
    [    0.360058] VFS: Disk quotas dquot_6.6.0
    [    0.364102] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.373725] NET: Registered protocol family 2
    [    0.378301] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.386886] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.395667] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.403861] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.411665] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.418410] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.425301] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.432693] NET: Registered protocol family 1
    [    0.437375] RPC: Registered named UNIX socket transport module.
    [    0.443436] RPC: Registered udp transport module.
    [    0.448240] RPC: Registered tcp transport module.
    [    0.453043] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.459627] PCI: CLS 0 bytes, default 64
    [    0.464002] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.474230] Initialise system trusted keyrings
    [    0.478843] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.487118] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.493327] NFS: Registering the id_resolver key type
    [    0.498544] Key type id_resolver registered
    [    0.502817] Key type id_legacy registered
    [    0.506934] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.513783] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.521419] 9p: Installing v9fs 9p2000 file system support
    [    0.546482] Key type asymmetric registered
    [    0.550667] Asymmetric key parser 'x509' registered
    [    0.555663] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.563221] io scheduler mq-deadline registered
    [    0.567846] io scheduler kyber registered
    [    0.573110] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.579279] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.587741] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.594017] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.601857] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.609913] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.618870] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.627681] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.635397] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.648250] brd: module loaded
    [    0.654132] loop: module loaded
    [    0.657974] megasas: 07.714.04.00-rc1
    [    0.663019] libphy: Fixed MDIO Bus: probed
    [    0.667655] tun: Universal TUN/TAP device driver, 1.6
    [    0.673070] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.679480] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.685553] sky2: driver version 1.30
    [    0.689817] VFIO - User Level meta-driver version: 0.3
    [    0.695504] i2c /dev entries driver
    [    0.699692] sdhci: Secure Digital Host Controller Interface driver
    [    0.706008] sdhci: Copyright(c) Pierre Ossman
    [    0.710697] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.717043] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.723341] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.730462] optee: probing for conduit method.
    [    0.735019] optee: revision 3.12 (3d47a131)
    [    0.735257] optee: initialized driver
    [    0.744551] NET: Registered protocol family 17
    [    0.749162] 9pnet: Installing 9P2000 support
    [    0.753550] Key type dns_resolver registered
    [    0.757990] Loading compiled-in X.509 certificates
    [    0.767203] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.773535] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.781619] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.812021] random: fast init done
    [    0.846052] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.853665] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.859724] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.865794] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.872205] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.879014] pca953x 3-0020: using no AI
    [    0.906446] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.913250] pca953x 3-0022: using AI
    [    0.917515] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.923490] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.929734] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.936227] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.942682] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.952768] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.959053] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.965864] pca953x 6-0020: using no AI
    [    0.994321] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.000368] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.006319] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.012553] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.019366] pca953x 9-0020: using no AI
    [    1.045964] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.052363] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.062337] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.071145] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.080987] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.101522] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
    [    1.109230] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.116895] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.125170] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.133445] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.143794] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.150222] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    2.155827] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.165517] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.172563] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.178703] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.188571] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.198460] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.208419] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.218387] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.228347] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.238331] pci 0000:00:00.0: supports D1
    [    2.242424] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.248296] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.259923] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.268109] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.278072] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.288030] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.299508] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.306276] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.311543] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.317862] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.325528] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.333803] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.342095] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.352236] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.358645] pci_bus 0001:00: root bus resource [bus 00-0f]
    [    3.364251] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    3.374124] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.381168] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.387366] pci 0001:00:00.0: supports D1
    [    3.391459] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.398945] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.408718] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
    [    3.415484] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.420756] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
    [    3.427072] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.434739] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.443014] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.451298] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.459835] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.466244] pci_bus 0002:00: root bus resource [bus 00-0f]
    [    4.471849] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.481095] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    4.491869] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.498066] pci 0002:00:00.0: supports D1
    [    4.502160] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.509651] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.519345] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
    [    4.526116] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.531372] pcieport 0002:00:00.0: PME: Signaling with IRQ 67
    [    4.538112] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    4.547988] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.554746] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.563737] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    4.573888] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.580646] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.588600] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.597978] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.606721] printk: console [ttyS2] enabled
    [    4.615158] printk: bootconsole [ns16550a0] disabled
    [    4.625598] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.634518] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.645106] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    4.655616] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    4.665767] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    4.676004] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    4.686865] scsi host0: ufshcd
    [    4.708727] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    4.729646] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.737293] libphy: 46000f00.mdio: probed
    [    4.742614] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.750916] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.764855] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    4.773738] mmc0: CQHCI version 5.10
    [    4.773977] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.786758] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    4.789360] vdd_mmc1: supplied by vsys_3v3
    [    4.802504] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    4.803274] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    4.820289] pca953x 4-0020: using no AI
    [    4.824155] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.832584] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    4.840485] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.841223] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.855744] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.855878] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.869883] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.876789] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    4.883656] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    4.893893] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    4.904398] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    4.919111] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    4.924347] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    4.930953] Creating 8 MTD partitions on "47040000.spi.0":
    [    4.936439] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    4.942387] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    4.948080] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    4.953957] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    4.959503] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    4.965197] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    4.971342] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    4.977169] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    4.985939] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    4.994871] mmc0: Command Queue Engine enabled
    [    4.999314] mmc0: new HS200 MMC card at address 0001
    [    5.004546] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.009169] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.015180] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.021159] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    5.029669]  mmcblk0: p1 p2
    [    5.032517] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.040431] libphy: 46000f00.mdio: probed
    [    5.046123] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    5.054433] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    5.068048] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    5.075039] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    5.082252] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.088544] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    5.098827] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.104944] mmc1: CQHCI version 5.10
    [    5.112856] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    5.120103] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    5.128326] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    5.135653] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    5.142957] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    5.150262] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    5.158317] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.178603] ALSA device list:
    [    5.181563]   No soundcards found.
    [    6.166332] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.174084] Waiting for root device PARTUUID=94abe6d6-02...
    [    6.231914] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    6.238735] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    6.248453]  mmcblk1: p1 p2
    [    6.298942] EXT4-fs (mmcblk1p2): recovery complete
    [    6.304584] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.312688] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.325528] devtmpfs: mounted
    [    6.328781] Freeing unused kernel memory: 1856K
    [    6.333330] Run /sbin/init as init process
    [    6.507977] systemd[1]: System time before build time, advancing clock.
    [    6.562776] NET: Registered protocol family 10
    [    6.567642] Segment Routing with IPv6
    [    6.592221] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    6.613983] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    6.656383] systemd[1]: Set hostname to <j7-evm>.
    [    6.841267] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    6.908877] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.915610] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    6.927985] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    6.937899] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    6.957715] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.964964] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    6.985708] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.992915] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    7.013829] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    7.037749] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    7.061746] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.077699] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.097686] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.113692] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.137311] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.157718] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.181741] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.201819] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.235858] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.244208] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.265920] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.281956] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.305869] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.325803] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    7.348261] systemd[1]: Mounting Huge Pages File System...
    [    7.367815] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.391829] systemd[1]: Mounting Kernel Debug File System...
    [    7.415160] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.432162] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    7.460506] systemd[1]: Starting Start psplash boot splash screen...
    [    7.485506] systemd[1]: Starting RPC Bind...
    [    7.501813] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.513508] systemd[1]: Starting Journal Service...
    [    7.541895] systemd[1]: Starting Load Kernel Modules...
    [    7.558170] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    7.565178] cryptodev: loading out-of-tree module taints kernel.
             Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
    [0m...
    [    7.584040] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    7.592544] systemd[1]: Starting udev Coldplug all Devices...
    [    7.620146] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    7.642063] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    7.866819] systemd-journald[174]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    8.336183] CAN device driver interface
    [    8.478205] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.526501] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.550646] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.568254] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.577939] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.620235] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    8.634204] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.655457] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.666362] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.694767] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    8.704531] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.720443] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.738908] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.746185] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    8.756481] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    8.769924] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.784792] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.796232] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.806812] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.850353] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    8.905675] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    8.958573] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    9.030517] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    9.042333] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.054230] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    9.064010] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    9.070191] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144332
    [    9.080840] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    9.088962] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [    9.097168] PVR_K:  199: Read BVNC 22.104.208.318 from HW device registers
    [    9.105447] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.112756]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [    9.121788] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.127308]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    9.128549] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.133398] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [    9.141480] PVR_K:  199: RGX Device registered with BVNC 22.104.208.318
    [    9.154755] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    9.162590] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.196095] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    9.264342] remoteproc remoteproc2: 4d81800000.dsp is available
    [    9.326929] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [    9.337695] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    9.342802] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    9.345981] remoteproc remoteproc1: 41000000.r5f is available
    [    9.357988] remoteproc remoteproc2: powering up 4d81800000.dsp
    [    9.363920] remoteproc remoteproc2: Booting fw image j7-c66_1-fw, size 144332
    [    9.376369] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [    9.389877]  remoteproc2#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [    9.393814] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
    [    9.403234] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.416635]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [    9.422757] remoteproc remoteproc2: remote processor 4d81800000.dsp is now up
    [    9.433227] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    9.436783] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.452779] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.501782] remoteproc remoteproc1: attaching to 41000000.r5f
    [    9.538130] remoteproc remoteproc3: 64800000.dsp is available
    [    9.585844] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.715228]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.743302] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.760936]  remoteproc1#vdev0buffer: registered virtio2 (type 7)
    [    9.776588] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.780442] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    9.818772] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    9.864472] remoteproc remoteproc3: powering up 64800000.dsp
    [    9.870177] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489000
    [    9.879422] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.880050] remoteproc remoteproc3: unsupported resource 65538
    [    9.894609] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [    9.904412]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [    9.904799] remoteproc remoteproc4: 5c00000.r5f is available
    [    9.913054] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    9.926574] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.928450]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    9.935279] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    9.945417] remoteproc remoteproc3: remote processor 64800000.dsp is now up
    [   10.034857] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.037981] remoteproc remoteproc4: powering up 5c00000.r5f
    [   10.048465] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
    [   10.062001]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.074797] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.080379]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   10.092734] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [   10.140015] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.264890] remoteproc remoteproc5: 5d00000.r5f is available
    [   10.341786] remoteproc remoteproc5: powering up 5d00000.r5f
    [   10.347463] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 97676
    [   10.355697] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   10.363326]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.372017] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   10.381776]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   10.385659] random: crng init done
    [   10.387878] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [   10.391249] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [   10.434543] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.498575] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.510029] remoteproc remoteproc6: 5e00000.r5f is available
    [   10.536920] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   10.546082] remoteproc remoteproc6: powering up 5e00000.r5f
    [   10.551725] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 97676
    [   10.563837]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.576873] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   10.582475]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   10.591181] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.593299] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   10.651551] remoteproc remoteproc7: 5f00000.r5f is available
    [   10.661003] remoteproc remoteproc7: powering up 5f00000.r5f
    [   10.666676] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 97676
    [   10.678900]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.687600] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   10.695132]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   10.701948] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   10.709235] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.747254] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   10.764566] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   10.782156] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [   10.801524] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [   10.819505] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.845230] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [   10.862949] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [   10.870120] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [   10.932288] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   11.349493] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [   11.408371] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [   11.416171] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [   11.428783] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
    [   11.439622] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [   11.450325] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  4/Nov/2021 SHA:9fe47caa
    [   11.574556] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [   11.607103] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   11.617282] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
    [   11.639421] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [   11.723563] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [   11.762734] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [   11.775139] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
    [   11.798014] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [   11.848260] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   11.856572] usbcore: registered new interface driver usbfs
    [   11.864086] remoteproc remoteproc8: b034000.pru is available
    [   11.943657] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   11.950811] remoteproc remoteproc9: b004000.rtu is available
    [   11.978116] usbcore: registered new interface driver hub
    [   12.034355] remoteproc remoteproc10: b00a000.txpru is available
    [   12.040824] usbcore: registered new device driver usb
    [  OK  ] Found device /dev/mmcblk0p2.
             Starting File System Check on /dev/mmcblk0p2...
    [   12.083428] remoteproc remoteproc11: b038000.pru is available
    [   12.118461] remoteproc remoteproc12: b006000.rtu is available
    [  OK  ] Found device /dev/mmcblk0p1.[   12.124979] remoteproc remoteproc13: b00c000.txpru is available
             Starting File System Check on /dev/mmcblk0p1   12.140758] remoteproc remoteproc14: b134000.pru is available
    0m...
    [   12.149879] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   12.179232] remoteproc remoteproc15: b104000.rtu is available
    [   12.187489] remoteproc remoteproc16: b10a000.txpru is available
    [   12.195965] remoteproc remoteproc17: b138000.pru is available
    [   12.202030] remoteproc remoteproc18: b106000.rtu is available
    [  OK  ] Started File System Check on /dev/mmcblk0p2.
             Mounting /run/media/mmcblk0p2   12.217931] remoteproc remoteproc19: b10c000.txpru is available
    0m...
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Started File System Check on /dev/m[   12.250202] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    mcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Mounted /run/media/mmcblk0p2.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Created slice system-weston.slice.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   12.900362] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.905962] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.914130] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   12.923568] xhci-hcd xhci-hcd.2.auto: irq 663, io mem 0x06410000
    [   12.929737] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.938012] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.945232] usb usb1: Product: xHCI Host Controller
    [   12.950105] usb usb1: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [   12.956627] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   12.961794] hub 1-0:1.0: USB hub found
    [   12.965558] hub 1-0:1.0: 1 port detected
    [   12.969701] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.975190] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.982847] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   12.989404] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.997557] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   13.005810] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.013019] usb usb2: Product: xHCI Host Controller
    [   13.017891] usb usb2: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [   13.024407] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   13.029506] hub 2-0:1.0: USB hub found
    [   13.034866] hub 2-0:1.0: 1 port detected
    [   13.225658] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   13.377923] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   13.386085] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   13.393208] usb 1-1: SerialNumber: 69010069A119
    [   13.398219] hub 1-1:1.0: USB hub found
    [   13.402003] hub 1-1:1.0: 4 ports detected
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlan...
             Starting Login Service...
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Started Telephony service.
    [   13.998527] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   14.036479] Bluetooth: Core ver 2.22
    [   14.043906] NET: Registered protocol family 31
    [   14.051620] Bluetooth: HCI device and connection manager initialized
    [   14.063759] Bluetooth: HCI socket layer initialized
    [   14.070330] Bluetooth: L2CAP socket layer initialized
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [   14.093157] Bluetooth: SCO socket layer initialized
    [  OK  ] Listening on Load/Save RF …itch S[   14.098895] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    tatus /dev/rfkill Watch.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started Login Service.
    [   14.313893] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [   14.356160] Intel(R) Wireless WiFi driver for Linux
    [   14.552299] PVR_K:  1083: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   14.675575] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [   14.770565] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
             Starting Synchronize System and HW clocks...
             Starting Weston Wayland Compositor...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avah[   14.832464] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Created slice User Slice of UID 0.
             Starting User Runtime Directory /run/user/0...
    [  OK  ] Started User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [  OK  ] Started User Manager for UID 0.
    [  OK  ] Started Session c1 of user root.
    [   15.448046] startwlan.sh[1034]: Starting WLAN AP setup
    [   15.458361] startwlan.sh[1139]: Starting WLAN AP se
    [   15.458817] startwlan.sh[1140]: Starting WLAN AP se
    [   15.477505] startwlan.sh[1140]: ddin
    [   15.478250] startwlan.sh[1142]: ddin
    [   15.511879] startwlan.sh[1142]: ommand failed: No such file or directory (
    [   15.512529] startwlan.sh[1143]: ommand failed: No such file or directory (
    [   15.552491] startwlan.sh[1143]: onfiguratioCould not read interface wlp1s0 flags: No such device
    [   15.552683] startwlan.sh[1143]: nl80211: Driver does not support authentication/association or connect commands
    [   15.552751] startwlan.sh[1143]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
    [   15.572568] startwlan.sh[1143]: Could not read interface wlp1s0 flags: No such device
    [   15.572748] startwlan.sh[1143]: nl80211 driver initialization failed.
    [   15.572817] startwlan.sh[1143]: wlp1s0: interface state UNINITIALIZED->DISABLED
    [   15.572876] startwlan.sh[1143]: wlp1s0: AP-DISABLED
    [   15.572936] startwlan.sh[1143]: wlp1s0: CTRL-EVENT-TERMINATING
    [   15.572995] startwlan.sh[1143]: hostapd_free_hapd_data: Interface wlp1s0 wasn't started
    [   16.504730] startwlan.sh[1298]: SIOCSIFADDR: No such device
    [   16.524267] startwlan.sh[1298]: wlp1s0: ERROR while getting interface flags: No such device
    [   16.540269] startwlan.sh[1298]: SIOCSIFNETMASK: No such device
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gstreamer1.0-libav-dev
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline8
    	libunistring-dev
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	python3-rfc3987
    	python3-strict-rfc3339
    	tar
    	which
    	zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [   16.556295] startwlan.sh[1298]: wlp1s0: ERROR while getting interface flags: No such device
    [  OK  ] Started startwlan.
    [   17.681809] startwlan.sh[1345]: iperf3: error - unable to start listener for connections: Cannot assign requested address
    [   17.696145] startwlan.sh[1345]: iperf3: exiting
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root
    Last login: Mon Dec 20 16:27:19 UTC 2021
    We confirm that in dts we disable  sdhci0 and sdhci2.
    &main_sdhci0 {
    	/* eMMC
    	non-removable;
    	ti,driver-strength-ohm = <50>;
    	disable-wp;*/
    	status = "disabled";
    &main_sdhci1 {
    	/* SD/MMC */
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vdd_sd_dv_alt>;
    	pinctrl-names = "default";
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    &main_sdhci2 {
    	/* Unused */
    so can you tell us how to modify it? Thinks
  • HI
    If you see the TI EVM logs the emmc and SD is getting mounted
    Trying to boot from MMC2
    MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
    mmc1 is current device
    SD/MMC found on device 1
    Importing environment from mmc1 ...
    Can you share me the DTB file which you are using ?
    Diwakar
  • Hi, experts
        Thinks for you support. we comfire that emmc and sdcard in correct location(emmc->mmc0, sdcard->mmc1, and boot by sd card), but it doesn' mount. the logs as follows:
    U-Boot SPL 2021.01 (Aug 31 2023 - 15:24:48 +0800)
    Model: Texas Instruments K3 J721E SoC
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed 1
    Board: J721EX-PM1-SOM rev E2
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 22:56:45, Mar  3 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Fri Mar  3 22:59:24 UTC 2023 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01 (Aug 31 2023 - 15:24:39 +0800)
    U-Boot 2021.01 (Aug 31 2023 - 15:24:39 +0800)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    Loading Environment from FAT... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    cdns,sierra serdes@5000000: PHY not found 0x7364 vs 0x0
    Sierra init failed:-22
    Net:   Could not get PHY for ethernet@46000000port@1: addr 0
    am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed
    No ethernet found.
    ota_init
    bootfirst=0, trycount=2, bootpart=1:2
     normal boot
    Saving Environment to FAT... OK
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    Failed to load 'boot.scr'
    574 bytes read in 8 ms (69.3 KiB/s)
    Loaded env from uEnv.txt
    19079680 bytes read in 792 ms (23 MiB/s)
    112170 bytes read in 13 ms (8.2 MiB/s)
       Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.162 (wx@wx-virtual-machine) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Thu Aug 31 15:14:46 CST 2023
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=b024fe8a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3271300K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 398716K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008414] Console: colour dummy device 80x25
    [    0.012975] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023646] pid_max: default: 32768 minimum: 301
    [    0.028400] LSM: Security Framework initializing
    [    0.033153] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040728] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049549] rcu: Hierarchical SRCU implementation.
    [    0.054613] Platform MSI: msi-controller@1820000 domain created
    [    0.060854] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070159] EFI services will not be available.
    [    0.074876] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.088096] Detected PIPT I-cache on CPU1
    [    0.088120] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088131] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.088164] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088212] smp: Brought up 1 node, 2 CPUs
    [    0.117557] SMP: Total of 2 processors activated.
    [    0.122361] CPU features: detected: 32-bit EL0 Support
    [    0.127616] CPU features: detected: CRC32 instructions
    [    0.141655] CPU: All CPU(s) started at EL2
    [    0.145850] alternatives: patching kernel code
    [    0.150865] devtmpfs: initialized
    [    0.159780] KASLR disabled due to lack of seed
    [    0.164424] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.174389] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.187245] pinctrl core: initialized pinctrl subsystem
    [    0.192894] DMI not present or invalid.
    [    0.197153] NET: Registered protocol family 16
    [    0.202347] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.209650] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.217700] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.226001] thermal_sys: Registered thermal governor 'step_wise'
    [    0.226003] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.232578] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.246214] ASID allocator initialised with 65536 entries
    [    0.271987] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.278843] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.285689] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.292535] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.299989] cryptd: max_cpu_qlen set to 1000
    [    0.306082] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.314908] vsys_3v3: supplied by evm_12v0
    [    0.319265] vsys_5v0: supplied by evm_12v0
    [    0.324008] iommu: Default domain type: Translated
    [    0.329174] SCSI subsystem initialized
    [    0.333338] mc: Linux media interface: v0.10
    [    0.337715] videodev: Linux video capture interface: v2.00
    [    0.343352] pps_core: LinuxPPS API ver. 1 registered
    [    0.348422] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.357759] PTP clock support registered
    [    0.361780] EDAC MC: Ver: 3.0.0
    [    0.365599] FPGA manager framework
    [    0.369105] Advanced Linux Sound Architecture Driver Initialized.
    [    0.375692] clocksource: Switched to clocksource arch_sys_counter
    [    0.382013] VFS: Disk quotas dquot_6.6.0
    [    0.386043] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.395618] NET: Registered protocol family 2
    [    0.400354] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.408933] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.417690] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.425891] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.433682] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.440478] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.447371] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.454767] NET: Registered protocol family 1
    [    0.459478] RPC: Registered named UNIX socket transport module.
    [    0.465541] RPC: Registered udp transport module.
    [    0.470345] RPC: Registered tcp transport module.
    [    0.475148] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.481729] NET: Registered protocol family 44
    [    0.486273] PCI: CLS 0 bytes, default 64
    [    0.490642] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.501037] Initialise system trusted keyrings
    [    0.505659] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.513766] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.520019] NFS: Registering the id_resolver key type
    [    0.525209] Key type id_resolver registered
    [    0.529480] Key type id_legacy registered
    [    0.533600] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.540448] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.548085] 9p: Installing v9fs 9p2000 file system support
    [    0.573861] Key type asymmetric registered
    [    0.578047] Asymmetric key parser 'x509' registered
    [    0.583046] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.590605] io scheduler mq-deadline registered
    [    0.595231] io scheduler kyber registered
    [    0.600988] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.607178] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.616280] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.622705] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.630691] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.637112] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.645050] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.651467] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.659395] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.665720] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.673668] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.680000] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.689715] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.697986] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.706187] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.713222] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.721638] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.734820] brd: module loaded
    [    0.741257] loop: module loaded
    [    0.744985] megasas: 07.714.04.00-rc1
    [    0.750787] tun: Universal TUN/TAP device driver, 1.6
    [    0.756255] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.762665] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.768739] sky2: driver version 1.30
    [    0.773112] VFIO - User Level meta-driver version: 0.3
    [    0.778898] i2c /dev entries driver
    [    0.783418] sdhci: Secure Digital Host Controller Interface driver
    [    0.789757] sdhci: Copyright(c) Pierre Ossman
    [    0.794425] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.800861] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.807211] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.814592] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.819155] optee: revision 3.20 (8e74d476)
    [    0.835555] optee: dynamic shared memory is enabled
    [    0.845014] optee: initialized driver
    [    0.850197] NET: Registered protocol family 17
    [    0.854819] 9pnet: Installing 9P2000 support
    [    0.859215] Key type dns_resolver registered
    [    0.863667] Loading compiled-in X.509 certificates
    [    0.877382] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.941368] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.949165] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.955254] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.961694] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.968189] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.975004] pca953x 3-0020: using no AI
    [    0.999820] pca953x 3-0020: failed writing register
    [    1.004858] pca953x: probe of 3-0020 failed with error -121
    [    1.010934] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.017732] pca953x 3-0022: using AI
    [    1.021516] pca953x 3-0022: failed writing register
    [    1.026539] pca953x: probe of 3-0022 failed with error -121
    [    1.032273] omap_i2c 2000000.i2c: bus 3 rev0.12 at 100 kHz
    [    1.038726] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
    [    1.048986] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    [    1.055334] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    1.062152] pca953x 6-0020: using no AI
    [    1.087822] pca953x 6-0020: failed writing register
    [    1.092857] pca953x: probe of 6-0020 failed with error -121
    [    1.098974] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
    [    1.105046] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.111049] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.117358] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.124179] pca953x 9-0020: using no AI
    [    1.151821] pca953x 9-0020: failed writing register
    [    1.156855] pca953x: probe of 9-0020 failed with error -121
    [    1.162598] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
    [    1.169068] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.179048] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.187863] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.197736] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.210310] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
    [    1.229071] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.236752] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.245031] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.253309] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.262206] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.269885] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.278165] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.286443] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.295252] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.302937] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.311214] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.319492] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.328753] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.338633] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.345392] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.354378] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.364531] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.371291] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.379257] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    1.388655] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    1.397401] printk: console [ttyS2] enabled
    [    1.405837] printk: bootconsole [ns16550a0] disabled
    [    1.416289] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    1.425243] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    1.435991] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    1.446502] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    1.456663] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    1.466902] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    1.478022] scsi host0: ufshcd
    [    1.487082] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.531697] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.539618] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    1.546340] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.559184] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.566390] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.572690] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.583037] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.692756] mmc0: CQHCI version 5.10
    [    1.692799] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.708677] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    1.715343] pca953x 4-0020: using no AI
    [    1.732236] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.739820] pca953x 4-0020: failed writing register
    [    1.744808] pca953x: probe of 4-0020 failed with error -121
    [    1.750825] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.757670] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.764601] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.771535] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.778395] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.788780] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.796276] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.804375] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.812461] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.821159] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.828662] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.836746] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.844826] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.853418] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.860913] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.868998] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.877085] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.886268] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.896913] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.911632] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    1.916911] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.917980] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.923530] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.929017] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.934482] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.939518] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.945474] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.951246] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.957005] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.962966] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.968796] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.975214] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.980707] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.986935] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.992603] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    1.998568] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    2.004678] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.008820] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    2.014580] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.022365] cdns-ufshcd 4e84000.ufs: last intr at 1829171 us, last intr status=0x404
    [    2.031285] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    2.035838] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    2.042072] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    2.048354] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    2.063981] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    2.069991] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    2.076254] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    2.082343] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    2.088434] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    2.100605] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.108281] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    2.108580] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    2.114634] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    2.121354] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    2.127650] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    2.140491] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.146737] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    2.153938] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.160273] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    2.166549] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    2.172517] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    2.182843] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.187791] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    2.195964] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    2.200565] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    2.212636] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    2.215043] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.219167] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    2.226507] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.232963] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    2.240918] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.246184] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    2.254340] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.259577] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    2.268306] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.273106] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    2.273108] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    2.273110] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    2.273112] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    2.280609] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.285883] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1830293 us
    [    2.291291] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.297442] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    2.297444] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    2.297469] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    2.303028] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.311076] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    2.311078] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    2.363192] mmc0: Command Queue Engine enabled
    [    2.363314] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.367634] mmc0: new HS200 MMC card at address 0001
    [    2.367925] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    [    2.375130] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.380162] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    [    2.384595] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.392768] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    [    2.398586] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.406743] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
    [    2.421346] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.435624] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.443735] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.451822] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.460737] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.468239] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.476325] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.484413] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.493073] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.500574] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.508663] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.516747] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.526282] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.533790] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.541872] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.549952] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.558437] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    2.565733] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    2.574124] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    2.581448] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    2.588758] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.596065] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    2.604441] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.611641] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.619139] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.627230] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.635317] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.644249] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.651750] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.659836] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.667922] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.689694] ALSA device list:
    [    2.691185] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.692667]   No soundcards found.
    [    2.703556] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.711639] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.719721] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.728187] Waiting for root device PARTUUID=b024fe8a-02...
  • Hi
    The latest logs shows that the emmc is getting detected but not seeing any logs related to that have you disabled SD card
    One more thing is that are you able to get the both emmc and SD in uboot
    help share the output of the bellow command (halt at UBOOT and then the below command),
    mmc list
    mmc dev 0
    mmc info
    mmc part
    mmc dev 1
    mmc info
    mmc part
  • Hi,Thinks
        the logs as fellows:
    U-Boot SPL 2021.01 (Sep 01 2023 - 11:52:43 +0800)
    Reading on-board EEPROM at 0x51 failed -1
    I/TC:
    U-Boot SPL 2021.01 (Sep 01 2023 - 11:52:33 +0800)
    U-Boot 2021.01 (Sep 01 2023 - 11:52:33 +0800)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    No ethernet found.
    ota_init
    bootfirst=0, trycount=1, bootpart=1:2
     normal boot
    19079680 bytes read in 797 ms (22.8 MiB/s)
    111990 bytes read in 13 ms (8.2 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Mar 3 23:00:40 UTC 2023
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=d9273407-02 rw rootfstype=ext4 rootwait
    [    0.008415] Console: colour dummy device 80x25
    [    0.028401] LSM: Security Framework initializing
    [    0.033155] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040730] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049538] rcu: Hierarchical SRCU implementation.
    [    0.054599] Platform MSI: msi-controller@1820000 domain created
    [    0.060840] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070148] EFI services will not be available.
    [    0.074869] smp: Bringing up secondary CPUs ...
    [    0.088106] Detected PIPT I-cache on CPU1
    [    0.088130] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088141] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.088174] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088221] smp: Brought up 1 node, 2 CPUs
    [    0.117566] SMP: Total of 2 processors activated.
    [    0.122371] CPU features: detected: 32-bit EL0 Support
    [    0.127625] CPU features: detected: CRC32 instructions
    [    0.141580] CPU: All CPU(s) started at EL2
    [    0.145773] alternatives: patching kernel code
    [    0.150783] devtmpfs: initialized
    [    0.159710] KASLR disabled due to lack of seed
    [    0.164356] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.174320] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.187200] pinctrl core: initialized pinctrl subsystem
    [    0.192848] DMI not present or invalid.
    [    0.197090] NET: Registered protocol family 16
    [    0.202280] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.209582] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.217630] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.225930] thermal_sys: Registered thermal governor 'step_wise'
    [    0.225932] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.232502] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.246136] ASID allocator initialised with 65536 entries
    [    0.271851] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.278707] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.285558] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.292430] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.299900] cryptd: max_cpu_qlen set to 1000
    [    0.305951] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.314778] vsys_3v3: supplied by evm_12v0
    [    0.319151] vsys_5v0: supplied by evm_12v0
    [    0.323922] iommu: Default domain type: Translated
    [    0.329111] SCSI subsystem initialized
    [    0.333263] mc: Linux media interface: v0.10
    [    0.337637] videodev: Linux video capture interface: v2.00
    [    0.343267] pps_core: LinuxPPS API ver. 1 registered
    [    0.348340] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.357679] PTP clock support registered
    [    0.361696] EDAC MC: Ver: 3.0.0
    [    0.365507] FPGA manager framework
    [    0.369021] Advanced Linux Sound Architecture Driver Initialized.
    [    0.375608] clocksource: Switched to clocksource arch_sys_counter
    [    0.381929] VFS: Disk quotas dquot_6.6.0
    [    0.385961] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.395469] NET: Registered protocol family 2
    [    0.400200] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.408771] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.417526] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.425723] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.433510] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.440302] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.447199] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.454598] NET: Registered protocol family 1
    [    0.459313] RPC: Registered named UNIX socket transport module.
    [    0.465375] RPC: Registered udp transport module.
    [    0.470179] RPC: Registered tcp transport module.
    [    0.474982] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.481564] NET: Registered protocol family 44
    [    0.486108] PCI: CLS 0 bytes, default 64
    [    0.490482] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.500874] Initialise system trusted keyrings
    [    0.505486] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.513576] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.519843] NFS: Registering the id_resolver key type
    [    0.525033] Key type id_resolver registered
    [    0.529307] Key type id_legacy registered
    [    0.533428] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.540278] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.547922] 9p: Installing v9fs 9p2000 file system support
    [    0.572914] Key type asymmetric registered
    [    0.577100] Asymmetric key parser 'x509' registered
    [    0.582098] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.589657] io scheduler mq-deadline registered
    [    0.594282] io scheduler kyber registered
    [    0.600076] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.606255] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.615354] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.621795] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.629772] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.636192] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.644134] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.650552] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.658481] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.664806] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.672754] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.679080] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.688829] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.697117] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.705330] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.712362] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.720818] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.734004] brd: module loaded
    [    0.740435] loop: module loaded
    [    0.744166] megasas: 07.714.04.00-rc1
    [    0.749969] tun: Universal TUN/TAP device driver, 1.6
    [    0.755444] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.761853] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.767929] sky2: driver version 1.30
    [    0.772293] VFIO - User Level meta-driver version: 0.3
    [    0.778077] i2c /dev entries driver
    [    0.782608] sdhci: Secure Digital Host Controller Interface driver
    [    0.788933] sdhci: Copyright(c) Pierre Ossman
    [    0.793611] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.800057] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.806414] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.813812] optee: probing for conduit method.
    [    0.818375] optee: revision 3.20 (8e74d476)
    [    0.834772] optee: dynamic shared memory is enabled
    [    0.844233] optee: initialized driver
    [    0.849420] NET: Registered protocol family 17
    [    0.854038] 9pnet: Installing 9P2000 support
    [    0.858431] Key type dns_resolver registered
    [    0.862882] Loading compiled-in X.509 certificates
    [    0.876683] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.940491] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.948300] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.954390] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.960836] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.967330] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.974152] pca953x 3-0020: using no AI
    [    0.999653] pca953x 3-0020: failed writing register
    [    1.004691] pca953x: probe of 3-0020 failed with error -121
    [    1.010763] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.017561] pca953x 3-0022: using AI
    [    1.021264] pca953x 3-0022: failed writing register
    [    1.026289] pca953x: probe of 3-0022 failed with error -121
    [    1.032025] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.038482] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.048684] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.055024] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    1.061843] pca953x 6-0020: using no AI
    [    1.087655] pca953x 6-0020: failed writing register
    [    1.092691] pca953x: probe of 6-0020 failed with error -121
    [    1.098806] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.104866] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.110885] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.117192] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.124007] pca953x 9-0020: using no AI
    [    1.151936] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.158412] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.168395] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.177208] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.187088] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.199709] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
    [    1.218263] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.225965] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.234243] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.242521] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.251422] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.259110] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.267388] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.275669] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.284492] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.292171] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.300447] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.308724] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.317993] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.327871] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.334630] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.343639] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.353779] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.360543] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.368508] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    1.377900] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    1.386648] printk: console [ttyS2] enabled
    [    1.395085] printk: bootconsole [ns16550a0] disabled
    [    1.405548] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    1.414489] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    1.425255] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    1.435769] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    1.445924] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    1.456163] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    1.467329] scsi host0: ufshcd
    [    1.476372] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.519612] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.527537] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    1.534259] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.547056] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.554262] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.560555] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.570913] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.680614] mmc0: CQHCI version 5.10
    [    1.680681] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.696583] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    1.703262] pca953x 4-0020: using no AI
    [    1.720152] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.727653] pca953x 4-0020: failed writing register
    [    1.732651] pca953x: probe of 4-0020 failed with error -121
    [    1.738675] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.745520] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.752458] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.759395] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.766256] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.776678] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.784172] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.792275] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.800362] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.809075] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.816575] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.824660] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.832741] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.841346] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.848849] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.856940] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.865027] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.874219] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.884854] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.899631] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    1.904890] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.905966] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.911508] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.916977] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.922450] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.927499] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.933437] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.939211] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.944878] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.950932] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.956772] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.963172] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.968723] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.974900] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.980581] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    1.986544] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    1.992652] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.996789] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    2.002542] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.010330] cdns-ufshcd 4e84000.ufs: last intr at 1801243 us, last intr status=0x404
    [    2.019235] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    2.023789] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    2.030036] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    2.036311] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    2.051934] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    2.057939] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    2.064206] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    2.070296] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    2.076387] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    2.088559] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.096236] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    2.096547] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    2.102601] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    2.109322] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    2.115616] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    2.128409] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.134703] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    2.141904] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.148239] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    2.154499] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    2.160483] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    2.170824] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.175758] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    2.183938] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    2.188528] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    2.200603] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    2.202933] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.207131] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    2.214474] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.220935] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    2.228890] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.234153] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    2.242309] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.247546] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    2.256314] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.261075] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    2.261077] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    2.261079] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    2.261089] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    2.268578] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.273851] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1802362 us
    [    2.279259] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.285410] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    2.285436] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    2.290998] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.299043] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    2.299045] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    2.299047] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    2.351170] mmc0: Command Queue Engine enabled
    [    2.351293] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.355612] mmc0: new HS200 MMC card at address 0001
    [    2.355907] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    [    2.363110] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.368139] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    [    2.372573] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.380756] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    [    2.386563] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.394726] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
    [    2.409322] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.423594] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.431703] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.439789] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.448702] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.456203] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.464289] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.472377] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.481042] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.488543] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.496632] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.504716] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.514268] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.521779] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.529860] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.537940] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.546428] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    2.553728] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    2.562101] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    2.569429] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    2.576735] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.584046] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    2.592417] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.599617] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.607103] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.615202] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.623290] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.632225] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.639728] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.647814] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.655901] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.677760] ALSA device list:
    [    2.679279] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.680732]   No soundcards found.
    [    2.691626] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.699709] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.707808] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.716276] Waiting for root device PARTUUID=d9273407-02...
    [   33.859620] tlv71033: disabling
    command log:
    => mmc list
    sdhci@4f80000: 0
    sdhci@4fb0000: 1 (SD)
    => mmcdev 0
    Unknown command 'mmcdev' - try 'help'
    => mmc dev 0
    mmc0(part 0) is current device
    => mmc part
    ## Unknown partition table type 0
    => mmc info
    Device: sdhci@4f80000
    Manufacturer ID: 13
    OEM: 14e
    Bus Speed: 200000000
    Mode: HS200 (200MHz)
    Rd Block Len: 512
    MMC version 5.1
    High Capacity: Yes
    Capacity: 29.6 GiB
    Bus Width: 8-bit
    Erase Group Size: 512 KiB
    HC WP Group Size: 8 MiB
    User Capacity: 29.6 GiB WRREL
    Boot Capacity: 31.5 MiB ENH
    RPMB Capacity: 4 MiB ENH
    Boot area 0 is not write protected
    Boot area 1 is not write protected
    => mmc part
    => mmc dev 1
    mmc1 is current device
    => mmc info
    Device: sdhci@4fb0000
    Manufacturer ID: 3
    OEM: 5344
    Bus Speed: 50000000
    Mode: SD High Speed (50MHz)
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 59.5 GiB
    Bus Width: 4-bit
    Erase Group Size: 512 Bytes
    => mmc part
    Partition Map for MMC device 1  --   Partition Type: DOS
    Part	Start Sector	Num Sectors	UUID		Type
      1	2048      	126976    	d9273407-01	0c Boot
      2	129024    	124606464 	d9273407-02	83
  • HI
    As you can see from UBOOT logs you are able to get the SD as well emmc both
    => mmc info
    Manufacturer ID: 13
    OEM: 14e
    Rd Block Len: 512
    MMC version 5.1
    High Capacity: Yes
    Capacity: 29.6 GiB
    Bus Width: 8-bit
    => mmc info
    Manufacturer ID: 3
    OEM: 5344
    Bus Speed: 50000000
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 59.5 GiB
    Bus Width: 4-bit
    have you disabled SD in linux ?Also the partuid is correct just that your sd is not getting probed because of that you are seeing issue
    Diwakar
  • Hi, experts
         Thinks for your support. we add "printk(KERN_INFO "Waiting for mount_root\n");" in API prepare_namespace() in linux/init/do_mounts.c, as fellows
     * Prepare the namespace - decide what/where to mount, load ramdisks, etc.
    void __init prepare_namespace(void)
    	if (root_delay) {
    		printk(KERN_INFO "Waiting %d sec before mounting root device...\n",
    		       root_delay);
    		ssleep(root_delay);
    	 * wait for the known devices to complete their probing
    	 * Note: this is a potential source of long boot delays.
    	 * For example, it is not atypical to wait 5 seconds here
    	 * for the touchpad of a laptop to initialize.
    	wait_for_device_probe();
    	md_run_setup();
    	if (saved_root_name[0]) {
    		root_device_name = saved_root_name;
    		if (!strncmp(root_device_name, "mtd", 3) ||
    		    !strncmp(root_device_name, "ubi", 3)) {
    			mount_block_root(root_device_name, root_mountflags);
    			goto out;
    		ROOT_DEV = name_to_dev_t(root_device_name);
    		if (strncmp(root_device_name, "/dev/", 5) == 0)
    			root_device_name += 5;
    	if (initrd_load())
    		goto out;
    	/* wait for any asynchronous scanning to complete */
    	if ((ROOT_DEV == 0) && root_wait) {
    		printk(KERN_INFO "Waiting for root device %s...\n",
    			saved_root_name);
    		while (driver_probe_done() != 0 ||
    			(ROOT_DEV = name_to_dev_t(saved_root_name)) == 0)
    			msleep(5);
    		async_synchronize_full();
    	mount_root();
    out:
    	devtmpfs_mount();
    	init_mount(".", "/", NULL, MS_MOVE, NULL);
    	init_chroot(".");
            printk(KERN_INFO "prepare_namespace end\n");
    In my opinion, if mount error, it will print "Waiting for mount_root".  In our logs, it doesn't go there.
    So i think our eeror occurt in here. is it correct?
    			msleep(5);
  • HI
    If you see your Kernel command line
    You are specifying that your root device is with PARTUUID=d9273407-02 but as your SD card is not getting detected in Linux
    this part UID is not preset and its waiting for the root device to come up.
    In order to solve this issue first you need to fix your SD card probe issue
    Diwakar
  • Hi,Thinks
          we don't disabled sdcard.
    &main_sdhci0 {
    	/* eMMC*/
    	non-removable;
    	ti,driver-strength-ohm = <50>;
    	disable-wp;
    &main_sdhci1 {
    	/* SD/MMC */
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vdd_sd_dv_alt>;
    	pinctrl-names = "default";
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    &main_sdhci2 {
    	/* Unused */
    	status = "disabled";
    We modify gpio in vdd_mmc1, and keep pulling this  gpio up. Would that be a problem?
    vdd_mmc1: fixedregulator-sd {
    		compatible = "regulator-fixed";
    		regulator-name = "vdd_mmc1";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-boot-on;
    		enable-active-high;
    		vin-supply = <&vsys_3v3>;
    		gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
  • Hi
    Can you keep the same as of UBOOT as it is working there.
    Diwakar
  • Hi,experts
          Thinks for your support.  We compare  dts of uboot with kernel's dts. It is the same about vdd_mmc1.  Is there any other reason to affect this ?
    dts of uboot in /board-support/u-boot-2021.01+gitAUTOINC+62a9e51344-g62a9e51344/arch/arm/dts/k3-j721e-common-proc-board.dts as fellows:
    // SPDX-License-Identifier: GPL-2.0
     * Copyright (C) 2019 Texas Instruments Incorporated - https://www.ti.com/
    /dts-v1/;
    #include "k3-j721e-som-p0.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/input/input.h>
    #include <dt-bindings/net/ti-dp83867.h>
    #include <dt-bindings/phy/phy-cadence.h>
    	chosen {
    		stdout-path = "serial2:115200n8";
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    	gpio_keys: gpio-keys {
    		compatible = "gpio-keys";
    		autorepeat;
    		pinctrl-0 = <&sw10_button_pins_default &sw11_button_pins_default>;
    		sw10: sw10 {
    			label = "GPIO Key USER1";
    			linux,code = <BTN_0>;
    			gpios = <&main_gpio0 0 GPIO_ACTIVE_LOW>;
    		sw11: sw11 {
    			label = "GPIO Key USER2";
    			linux,code = <BTN_1>;
    			gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
    	evm_12v0: fixedregulator-evm12v0 {
    		/* main supply */
    		regulator-name = "evm_12v0";
    		regulator-min-microvolt = <12000000>;
    		regulator-max-microvolt = <12000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vsys_3v3: fixedregulator-vsys3v3 {
    		/* Output of LMS140 */
    		regulator-name = "vsys_3v3";
    		vin-supply = <&evm_12v0>;
    		regulator-boot-on;
    	vsys_5v0: fixedregulator-vsys5v0 {
    		/* Output of LM5140 */
    		regulator-name = "vsys_5v0";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-boot-on;
    		regulator-boot-on;
    		enable-active-high;
    	vdd_sd_dv_alt: gpio-regulator-TLV71033 {
    		compatible = "regulator-gpio";
    		pinctrl-0 = <&vdd_sd_dv_alt_pins_default>;
    		regulator-name = "tlv71033";
    		regulator-min-microvolt = <1800000>;
    		regulator-boot-on;
    		vin-supply = <&vsys_5v0>;
    		gpios = <&main_gpio0 117 GPIO_ACTIVE_HIGH>;
    		states = <1800000 0x0>,
    			 <3300000 0x1>;
    	sound0: sound@0 {
    		compatible = "ti,j721e-cpb-audio";
    		model = "j721e-cpb";
    		ti,cpb-mcasp = <&mcasp10>;
    		ti,cpb-codec = <&pcm3168a_1>;
    		clocks = <&k3_clks 184 1>,
    			 <&k3_clks 184 2>, <&k3_clks 184 4>,
    			 <&k3_clks 157 371>,
    			 <&k3_clks 157 400>, <&k3_clks 157 401>;
    		clock-names = "cpb-mcasp-auxclk",
    			      "cpb-mcasp-auxclk-48000", "cpb-mcasp-auxclk-44100",
    			      "cpb-codec-scki",
    			      "cpb-codec-scki-48000", "cpb-codec-scki-44100";
    &main_pmx0 {
    	sw10_button_pins_default: sw10-button-pins-default {
    		pinctrl-single,pins = <
    			J721E_IOPAD(0x0, PIN_INPUT, 7) /* (AC18) EXTINTn.GPIO0_0 */
    	main_mmc1_pins_default: main-mmc1-pins-default {
    			J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */
    			J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */
    			J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
    			J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */
    			J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
    			J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */
    			J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */
    			J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */
    			J721E_IOPAD(0x25c, PIN_INPUT, 0) /* (R28) MMC1_SDWP */
    	vdd_sd_dv_alt_pins_default: vdd-sd-dv-alt-pins-default {
    			J721E_IOPAD(0x1d8, PIN_INPUT, 7) /* (W4) SPI1_CS1.GPIO0_117 */
    	main_usbss0_pins_default: main-usbss0-pins-default {
    			J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */
    			J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */
    	main_usbss1_pins_default: main-usbss1-pins-default {
    			J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */
    	main_i2c1_exp4_pins_default: main-i2c1-exp4-pins-default {
    			J721E_IOPAD(0x230, PIN_INPUT, 7) /* (U2) ECAP0_IN_APWM_OUT.GPIO1_11 */
    	main_i2c0_pins_default: main-i2c0-pins-default {
    			J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */
    			J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */
    	main_i2c1_pins_default: main-i2c1-pins-default {
    			J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
    			J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
    	main_i2c3_pins_default: main-i2c3-pins-default {
    			J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */
    			J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */
    	main_i2c6_pins_default: main-i2c6-pins-default {
    			J721E_IOPAD(0x1d0, PIN_INPUT_PULLUP, 2) /* (AA3) SPI0_D1.I2C6_SCL */
    			J721E_IOPAD(0x1e4, PIN_INPUT_PULLUP, 2) /* (Y2) SPI1_D1.I2C6_SDA */
    	mcasp10_pins_default: mcasp10-pins-default {
    			J721E_IOPAD(0x158, PIN_OUTPUT_PULLDOWN, 12) /* (U23) RGMII5_TX_CTL.MCASP10_ACLKX */
    			J721E_IOPAD(0x15c, PIN_OUTPUT_PULLDOWN, 12) /* (U26) RGMII5_RX_CTL.MCASP10_AFSX */
    			J721E_IOPAD(0x160, PIN_OUTPUT_PULLDOWN, 12) /* (V28) RGMII5_TD3.MCASP10_AXR0 */
    			J721E_IOPAD(0x164, PIN_OUTPUT_PULLDOWN, 12) /* (V29) RGMII5_TD2.MCASP10_AXR1 */
    			J721E_IOPAD(0x170, PIN_OUTPUT_PULLDOWN, 12) /* (U29) RGMII5_TXC.MCASP10_AXR2 */
    			J721E_IOPAD(0x174, PIN_OUTPUT_PULLDOWN, 12) /* (U25) RGMII5_RXC.MCASP10_AXR3 */
    			J721E_IOPAD(0x198, PIN_INPUT_PULLDOWN, 12) /* (V25) RGMII6_TD1.MCASP10_AXR4 */
    			J721E_IOPAD(0x19c, PIN_INPUT_PULLDOWN, 12) /* (W27) RGMII6_TD0.MCASP10_AXR5 */
    			J721E_IOPAD(0x1a0, PIN_INPUT_PULLDOWN, 12) /* (W29) RGMII6_TXC.MCASP10_AXR6 */
    	audi_ext_refclk2_pins_default: audi-ext-refclk2-pins-default {
    			J721E_IOPAD(0x1a4, PIN_OUTPUT, 3) /* (W26) RGMII6_RXC.AUDIO_EXT_REFCLK2 */
    &wkup_pmx0 {
    	sw11_button_pins_default: sw11-button-pins-default {
    			J721E_WKUP_IOPAD(0xcc, PIN_INPUT, 7) /* (G28) WKUP_GPIO0_7 */
    	wkup_gpio_pins_default: wkup-gpio-pins-default {
    			J721E_WKUP_IOPAD(0xd0, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_8 */
    	mcu_fss0_ospi1_pins_default: mcu-fss0-ospi1-pins-default {
    			J721E_WKUP_IOPAD(0x34, PIN_OUTPUT, 0) /* (F22) MCU_OSPI1_CLK */
    			J721E_WKUP_IOPAD(0x50, PIN_OUTPUT, 0) /* (C22) MCU_OSPI1_CSn0 */
    			J721E_WKUP_IOPAD(0x40, PIN_INPUT, 0) /* (D22) MCU_OSPI1_D0 */
    			J721E_WKUP_IOPAD(0x44, PIN_INPUT, 0) /* (G22) MCU_OSPI1_D1 */
    			J721E_WKUP_IOPAD(0x48, PIN_INPUT, 0) /* (D23) MCU_OSPI1_D2 */
    			J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 0) /* (C23) MCU_OSPI1_D3 */
    			J721E_WKUP_IOPAD(0x3c, PIN_INPUT, 0) /* (B23) MCU_OSPI1_DQS */
    			J721E_WKUP_IOPAD(0x38, PIN_INPUT, 0) /* (A23) MCU_OSPI1_LBCLKO */
    	mcu_cpsw_pins_default: mcu-cpsw-pins-default {
    			J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
    			J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
    			J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
    			J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
    			J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
    			J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
    			J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
    			J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
    			J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
    			J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
    			J721E_WKUP_IOPAD(0x0070, PIN_INPUT, 0) /* MCU_RGMII1_TXC */
    			J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
    	mcu_mdio_pins_default: mcu-mdio1-pins-default {
    			J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* MCU_MDIO0_MDC */
    			J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_MDIO0_MDIO */
    &wkup_uart0 {
    	/* Wakeup UART is used by System firmware */
    	status = "reserved";
    &main_uart0 {
    	power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
    &main_uart3 {
    	/* UART not brought out */
    &main_uart5 {
    &main_uart6 {
    &main_uart7 {
    &main_uart8 {
    &main_uart9 {
    &main_gpio2 {
    &main_gpio3 {
    &main_gpio4 {
    &main_gpio5 {
    &main_gpio6 {
    &main_gpio7 {
    &wkup_gpio1 {
    &main_sdhci0 {
    	/* eMMC */
    	non-removable;
    	disable-wp;
    &main_sdhci1 {
    	/* SD/MMC */
    	disable-wp;
    &main_sdhci2 {
    	/* Unused */
    &usb_serdes_mux {
    	idle-states = <1>, <0>; /* USB0 to SERDES3, USB1 to SERDES1 */
    &serdes_ln_ctrl {
    	idle-states = <J721E_SERDES0_LANE0_PCIE0_LANE0>, <J721E_SERDES0_LANE1_QSGMII_LANE2>,
    		      <J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>,
    		      <J721E_SERDES2_LANE0_PCIE2_LANE0>, <J721E_SERDES2_LANE1_PCIE2_LANE1>,
    		      <J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>,
    		      <J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>,
    		      <J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>;
    &serdes_wiz3 {
    	typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
    	typec-dir-debounce-ms = <700>;	/* TUSB321, tCCB_DEFAULT 133 ms */
    &serdes3 {
    	serdes3_usb_link: link@0 {
    		reg = <0>;
    		cdns,num-lanes = <2>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_USB3>;
    		resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
    &usbss0 {
    	pinctrl-0 = <&main_usbss0_pins_default>;
    	ti,vbus-divider;
    &usb0 {
    	dr_mode = "otg";
    	maximum-speed = "super-speed";
    	phys = <&serdes3_usb_link>;
    	phy-names = "cdns3,usb3-phy";
    &wkup_gpio0 {
    	pinctrl-0 = <&wkup_gpio_pins_default>;
    &usbss1 {
    	pinctrl-0 = <&main_usbss1_pins_default>;
    	ti,usb2-only;
    &usb1 {
    	dr_mode = "host";
    	maximum-speed = "high-speed";
    &ospi1 {
    	pinctrl-0 = <&mcu_fss0_ospi1_pins_default>;
    	flash@0{
    		compatible = "jedec,spi-nor";
    		reg = <0x0>;
    		spi-tx-bus-width = <1>;
    		spi-rx-bus-width = <4>;
    		spi-max-frequency = <40000000>;
    		cdns,tshsl-ns = <60>;
    		cdns,tsd2d-ns = <60>;
    		cdns,tchsh-ns = <60>;
    		cdns,tslch-ns = <60>;
    		cdns,read-delay = <2>;
    		#address-cells = <1>;
    		#size-cells = <1>;
    &tscadc0 {
    	adc {
    		ti,adc-channels = <0 1 2 3 4 5 6 7>;
    &tscadc1 {
    	adc {
    &main_i2c0 {
    	pinctrl-0 = <&main_i2c0_pins_default>;
    	clock-frequency = <100000>;
    	exp1: gpio@20 {
    		compatible = "ti,tca6416";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	exp2: gpio@22 {
    		compatible = "ti,tca6424";
    		reg = <0x22>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		p09-hog {
    			/* P11 - MCASP/TRACE_MUX_S0 */
    			gpio-hog;
    			gpios = <9 GPIO_ACTIVE_HIGH>;
    			output-low;
    			line-name = "MCASP/TRACE_MUX_S0";
    		p10-hog {
    			/* P12 - MCASP/TRACE_MUX_S1 */
    			gpio-hog;
    			gpios = <10 GPIO_ACTIVE_HIGH>;
    			output-high;
    			line-name = "MCASP/TRACE_MUX_S1";
    &main_i2c1 {
    	pinctrl-0 = <&main_i2c1_pins_default>;
    	exp4: gpio@20 {
    		compatible = "ti,tca6408";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		pinctrl-0 = <&main_i2c1_exp4_pins_default>;
    		interrupt-parent = <&main_gpio1>;
    		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    &k3_clks {
    	/* Confiure AUDIO_EXT_REFCLK2 pin as output */
    	pinctrl-0 = <&audi_ext_refclk2_pins_default>;
    &main_i2c3 {
    	pinctrl-0 = <&main_i2c3_pins_default>;
    	exp3: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	pcm3168a_1: audio-codec@44 {
    		compatible = "ti,pcm3168a";
    		reg = <0x44>;
    		#sound-dai-cells = <1>;
    		reset-gpios = <&exp3 0 GPIO_ACTIVE_LOW>;
    		/* C_AUDIO_REFCLK2 -> RGMII6_RXC (W26) */
    		clocks = <&k3_clks 157 371>;
    		clock-names = "scki";
    		/* HSDIV3_16FFT_MAIN_4_HSDIVOUT2_CLK -> REFCLK2 */
    		assigned-clocks = <&k3_clks 157 371>;
    		assigned-clock-parents = <&k3_clks 157 400>;
    		assigned-clock-rates = <24576000>; /* for 48KHz */
    		VDD1-supply = <&vsys_3v3>;
    		VDD2-supply = <&vsys_3v3>;
    		VCCAD1-supply = <&vsys_5v0>;
    		VCCAD2-supply = <&vsys_5v0>;
    		VCCDA1-supply = <&vsys_5v0>;
    		VCCDA2-supply = <&vsys_5v0>;
    &main_i2c6 {
    	pinctrl-0 = <&main_i2c6_pins_default>;
    	exp5: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    &mcu_cpsw {
    	pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>;
    &davinci_mdio {
    	phy0: ethernet-phy@0 {
    		reg = <0>;
    		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
    		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
    &cpsw_port1 {
    	phy-mode = "rgmii-rxid";
    	phy-handle = <&phy0>;
    &dss {
    	 * These clock assignments are chosen to enable the following outputs:
    	 * VP0 - DisplayPort SST
    	 * VP1 - DPI0
    	 * VP2 - DSI
    	 * VP3 - DPI1
    	assigned-clocks = <&k3_clks 152 1>,
    			  <&k3_clks 152 4>,
    			  <&k3_clks 152 9>,
    			  <&k3_clks 152 13>;
    	assigned-clock-parents = <&k3_clks 152 2>,	/* PLL16_HSDIV0 */
    				 <&k3_clks 152 6>,	/* PLL19_HSDIV0 */
    				 <&k3_clks 152 11>,	/* PLL18_HSDIV0 */
    				 <&k3_clks 152 18>;	/* PLL23_HSDIV0 */
    &mcasp0 {
    &mcasp1 {
    &mcasp2 {
    &mcasp3 {
    &mcasp4 {
    &mcasp5 {
    &mcasp6 {
    &mcasp7 {
    &mcasp8 {
    &mcasp9 {
    &mcasp10 {
    	#sound-dai-cells = <0>;
    	pinctrl-0 = <&mcasp10_pins_default>;
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	auxclk-fs-ratio = <256>;
    	serial-dir = <	/* 0: INACTIVE, 1: TX, 2: RX */
    		1 1 1 1
    		2 2 2 0
    	tx-num-evt = <0>;
    	rx-num-evt = <0>;
    &mcasp11 {
    &wiz0_pll1_refclk {
    	assigned-clocks = <&wiz0_pll1_refclk>;
    	assigned-clock-parents = <&dummy_cmn_refclk1>;
    &wiz0_refclk_dig {
    	assigned-clocks = <&wiz0_refclk_dig>;
    &serdes0 {
    	assigned-clocks = <&serdes0 CDNS_SIERRA_PLL_CMNLC>, <&serdes0 CDNS_SIERRA_PLL_CMNLC1>;
    	assigned-clock-parents = <&wiz0_pll1_refclk>, <&wiz0_pll1_refclk>;
    	serdes0_pcie_link: phy@0 {
    		reg = <0>;
    		cdns,num-lanes = <1>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_PCIE>;
    		resets = <&serdes_wiz0 1>;
    	serdes0_qsgmii_link: phy@1 {
    		reg = <1>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_QSGMII>;
    		resets = <&serdes_wiz0 2>;
    &serdes1 {
    	serdes1_pcie_link: link@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
    &serdes2 {
    	serdes2_pcie_link: link@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
    &pcie0_rc {
    	reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes0_pcie_link>;
    	phy-names = "pcie-phy";
    	num-lanes = <1>;
    &pcie1_rc {
    	reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes1_pcie_link>;
    	num-lanes = <2>;
    &pcie2_rc {
    	reset-gpios = <&exp2 20 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes2_pcie_link>;
    	num-lanes = <2>;
    &pcie0_ep {
    	num-lanes = <1>;
    &pcie1_ep {
    	num-lanes = <2>;
    &pcie2_ep {
    	num-lanes = <2>;
    &pcie3_rc {
    &pcie3_ep {
    &dss {
    dts of kernel in ./board-support/linux-5.10.162+gitAUTOINC+76b3e88d56-g76b3e88d56/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts:
    /dts-v1/;
    	chosen {
            aliases{
                   soc_i2c0 = &main_i2c0;
                   soc_i2c1 = &main_i2c1;
                   soc_i2c3 = &main_i2c3;
                   soc_i2c6 = &main_i2c6;
    		autorepeat;
    		sw10: sw10 {
    		sw11: sw11 {
    		/* main supply */
    		regulator-boot-on;
    		regulator-boot-on;
    		regulator-boot-on;
    		regulator-boot-on;
    		enable-active-high;
    		regulator-boot-on;
    			 <3300000 0x1>;
    	/*sound0: sound@0 {
    			 <&k3_clks 157 371>,
    			      "cpb-codec-scki",
    	cpsw9g_virt_mac: main_r5fss_cpsw9g_virt_mac0 {
    		compatible = "ti,j721e-cpsw-virt-mac";
    		dma-coherent;
    		ti,psil-base = <0x4a00>;
    		ti,remote-name = "mpu_1_0_ethswitch-device-0";
    		dmas = <&main_udmap 0xca00>,
    		       <&main_udmap 0xca01>,
    		       <&main_udmap 0xca02>,
    		       <&main_udmap 0xca03>,
    		       <&main_udmap 0xca04>,
    		       <&main_udmap 0xca05>,
    		       <&main_udmap 0xca06>,
    		       <&main_udmap 0xca07>,
    		       <&main_udmap 0x4a00>;
    		dma-names = "tx0", "tx1", "tx2", "tx3",
    			    "tx4", "tx5", "tx6", "tx7",
    			    "rx";
    		virt_emac_port {
    			ti,label = "virt-port";
    			/* local-mac-address = [0 0 0 0 0 0]; */
    	cpsw9g_virt_maconly: main-r5fss-cpsw9g-virt-mac1 {
    		dma-coherent;
    		ti,remote-name = "mpu_1_0_ethmac-device-1";
    			    "rx";
    		virt_emac_port {
    	transceiver1: can-phy0 {
    		compatible = "ti,tcan1043";
    		#phy-cells = <0>;
    		max-bitrate = <5000000>;
    		pinctrl-0 = <&mcu_mcan0_gpio_pins_default>;
    		standby-gpios = <&wkup_gpio0 54 GPIO_ACTIVE_LOW>;
    		enable-gpios = <&wkup_gpio0 0 GPIO_ACTIVE_HIGH>;
    	transceiver2: can-phy1 {
    		compatible = "ti,tcan1042";
    		#phy-cells = <0>;
    		pinctrl-0 = <&mcu_mcan1_gpio_pins_default>;
    		standby-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_HIGH>;
    	transceiver3: can-phy2 {
    		#phy-cells = <0>;
    		standby-gpios = <&exp2 7 GPIO_ACTIVE_LOW>;
    		enable-gpios = <&exp2 6 GPIO_ACTIVE_HIGH>;
    	transceiver4: can-phy3 {
    		#phy-cells = <0>;
    		pinctrl-0 = <&main_mcan2_gpio_pins_default>;
    		standby-gpios = <&main_gpio0 127 GPIO_ACTIVE_HIGH>;
    	dp_pwr_3v3: fixedregulator-dp-prw {
    		regulator-name = "dp-pwr";
    		gpio = <&exp4 0 0>;	/* P0 - DP0_PWR_SW_EN */
    		enable-active-high;
    		/* Always on for now, until dp-connector driver can handle this */
    	dp0: connector {
    		compatible = "dp-connector";
    		label = "DP0";
    		type = "full-size";
    		dp-pwr-supply = <&dp_pwr_3v3>;
    		port {
    			dp_connector_in: endpoint {
    				remote-endpoint = <&dp0_out>;
    &main_pmx0 {
    	dp0_pins_default: dp0-pins-default {
    			J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
    	main_i2c2_pins_default: main-i2c2-pins-default {
    			J721E_IOPAD(0x1c8, PIN_INPUT_PULLUP, 2) /* (AB5) SPI0_CLK.I2C2_SCL */
    			J721E_IOPAD(0x1cc, PIN_INPUT_PULLUP, 2) /* (AA1) SPI0_D0.I2C2_SDA */
    	main_mcan0_pins_default: main-mcan0-pins-default {
    			J721E_IOPAD(0x208, PIN_INPUT, 0) /* (W5) MCAN0_RX */
    			J721E_IOPAD(0x20c, PIN_OUTPUT, 0) /* (W6) MCAN0_TX */
    	main_mcan2_pins_default: main-mcan2-pins-default {
    			J721E_IOPAD(0x01f0, PIN_INPUT, 3) /* (AC2) MCAN2_RX.GPIO0_123 */
    			J721E_IOPAD(0x01f4, PIN_OUTPUT, 3) /* (AB1) MCAN2_TX.GPIO0_124 */
    	main_mcan2_gpio_pins_default: main-mcan2-gpio-pins-default {
    			J721E_IOPAD(0x200, PIN_INPUT, 7) /* (AC4) UART1_CTSn.GPIO0_127 */
    &wkup_pmx0 {
    			J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */
    	mcu_mcan0_pins_default: mcu-mcan0-pins-default {
    			J721E_WKUP_IOPAD(0xac, PIN_INPUT, 0) /* (C29) MCU_MCAN0_RX */
    			J721E_WKUP_IOPAD(0xa8, PIN_OUTPUT, 0) /* (D29) MCU_MCAN0_TX */
    	mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default {
    			J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 7) /* (F26) WKUP_GPIO0_0 */
    			J721E_WKUP_IOPAD(0x98, PIN_INPUT, 7) /* (E28) MCU_SPI0_D1.WKUP_GPIO0_54 */
    	mcu_mcan1_pins_default: mcu-mcan1-pins-default {
    			J721E_WKUP_IOPAD(0xc4, PIN_INPUT, 0) /* (G24) WKUP_GPIO0_5.MCU_MCAN1_RX */
    			J721E_WKUP_IOPAD(0xc0, PIN_OUTPUT, 0) /* (G25) WKUP_GPIO0_4.MCU_MCAN1_TX */
    	mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-pins-default {
    			J721E_WKUP_IOPAD(0xb8, PIN_INPUT, 7) /* (F28) WKUP_GPIO0_2 */
    &wkup_uart0 {
    &main_uart0 {
    &main_uart3 {
    &main_uart5 {
    &main_uart6 {
    &main_uart7 {
    &main_uart8 {
    &main_uart9 {
    &main_gpio2 {
    &main_gpio3 {
    &main_gpio4 {
    &main_gpio5 {
    &main_gpio6 {
    &main_gpio7 {
    &wkup_gpio1 {
    &main_sdhci0 {
    	/* eMMC*/
    	non-removable;
    	disable-wp;
    &main_sdhci1 {
    	/* SD/MMC */
    	disable-wp;
    &main_sdhci2 {
    	/* Unused */
    &usb_serdes_mux {
    &serdes_ln_ctrl {
    &serdes_wiz3 {
    &serdes3 {
    	serdes3_usb_link: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    &usbss0 {
    	ti,vbus-divider;
    &usb0 {
    	dr_mode = "otg";
    &usbss1 {
    	ti,usb2-only;
    &usb1 {
    	dr_mode = "host";
    &ospi1 {
    	flash@0{
    		reg = <0x0>;
    		#size-cells = <1>;
    &tscadc0 {
    	adc {
    &tscadc1 {
    	adc {
    &main_i2c0 {
    	exp1: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	exp2: gpio@22 {
    		reg = <0x22>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		p08-hog {
    			/* P10 - PM_I2C_CTRL_OE */
    			gpio-hog;
    			gpios = <8 GPIO_ACTIVE_HIGH>;
    			output-high;
    			line-name = "CTRL_PM_I2C_OE";
    		p09-hog {
    			gpio-hog;
    			output-low;
    		p10-hog {
    			gpio-hog;
    			output-high;
    &main_i2c1 {
    	exp4: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    &main_i2c2 {
    	pinctrl-0 = <&main_i2c2_pins_default>;
    	ina226@40 {
    		compatible = "ti,ina226";
    		reg = <0x40>;
    		shunt-resistor = <10000>;
    	ina226@41 {
    		reg = <0x41>;
    	ina226@42 {
    		reg = <0x42>;
    	ina226@43 {
    		reg = <0x43>;
    	ina226@44 {
    		reg = <0x44>;
    	ina226@45 {
    		reg = <0x45>;
    		shunt-resistor = <5000>;
    	ina226@46 {
    		reg = <0x46>;
    	ina226@47 {
    		reg = <0x47>;
    	ina226@48 {
    		reg = <0x48>;
    	ina226@49 {
    		reg = <0x49>;
    	ina226@4a {
    		reg = <0x4a>;
    	ina226@4b {
    		reg = <0x4b>;
    	ina226@4c {
    		reg = <0x4c>;
    	ina226@4d {
    		reg = <0x4d>;
    	ina226@4e {
    		reg = <0x4e>;
    	ina226@4f {
    		reg = <0x4f>;
    &k3_clks {
    &main_i2c3 {
    	exp3: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		reg = <0x44>;
    &main_i2c6 {
    	exp5: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    &mcu_cpsw {
    &davinci_mdio {
    		reg = <0>;
    &cpsw_port1 {
    &dss {
    	 * VP1 - DPI0
    	 * VP2 - DSI
    	 * VP3 - DPI1
    			  <&k3_clks 152 4>,
    			  <&k3_clks 152 9>,
    			  <&k3_clks 152 13>;
    &dss_ports {
    	port@0 {
    		reg = <0>;
    		dpi0_out: endpoint {
    			remote-endpoint = <&dp0_in>;
    &mhdp {
    	pinctrl-0 = <&dp0_pins_default>;
    &dp0_ports {
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dp0_in: endpoint {
    			remote-endpoint = <&dpi0_out>;
    	port@4 {
    		reg = <4>;
    		dp0_out: endpoint {
    			remote-endpoint = <&dp_connector_in>;
    &mcasp0 {
    &mcasp1 {
    &mcasp2 {
    &mcasp3 {
    &mcasp4 {
    &mcasp5 {
    &mcasp6 {
    &mcasp7 {
    &mcasp8 {
    &mcasp9 {
    &mcasp10 {
    	tdm-slots = <2>;
    		1 1 1 1
    		2 2 2 0
    	tx-num-evt = <0>;
    	rx-num-evt = <0>;
    &mcasp11 {
    &cmn_refclk1 {
    	clock-frequency = <100000000>;
    &wiz0_pll1_refclk {
    	assigned-clock-parents = <&cmn_refclk1>;
    &wiz0_refclk_dig {
    &wiz1_pll1_refclk {
    	assigned-clocks = <&wiz1_pll1_refclk>;
    &wiz1_refclk_dig {
    	assigned-clocks = <&wiz1_refclk_dig>;
    &wiz2_pll1_refclk {
    	assigned-clocks = <&wiz2_pll1_refclk>;
    &wiz2_refclk_dig {
    	assigned-clocks = <&wiz2_refclk_dig>;
    &cmn_refclk1 {
    &serdes0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		reg = <1>;
    		#phy-cells = <0>;
    &serdes1 {
    	assigned-clocks = <&serdes1 CDNS_SIERRA_PLL_CMNLC>;
    	assigned-clock-parents = <&wiz1_pll1_refclk>;
    	serdes1_pcie_link: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    &serdes2 {
    	assigned-clocks = <&serdes2 CDNS_SIERRA_PLL_CMNLC>;
    	assigned-clock-parents = <&wiz2_pll1_refclk>;
    	serdes2_pcie_link: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    &cpsw0 {
    	 * Disable cpsw0 since cpsw9g_virt_mac is the default Ethernet
    	 * controller. cpsw0 is enabled with overlay for native
    	 * Ethernet driver support.
    &pcie0_rc {
    	num-lanes = <1>;
    &pcie1_rc {
    	num-lanes = <2>;
    &pcie2_rc {
    	num-lanes = <2>;
    &pcie0_ep {
    	num-lanes = <1>;
    &pcie1_ep {
    	num-lanes = <2>;
    &pcie2_ep {
    	num-lanes = <2>;
    &pcie3_rc {
    &pcie3_ep {
    /* uart2 assigned to cpsw9g eth-switch fw running on remote CPU core */
    &main_uart2 {
    &mcu_mcan0 {
    	pinctrl-0 = <&mcu_mcan0_pins_default>;
    	phys = <&transceiver1>;
    &mcu_mcan1 {
    	pinctrl-0 = <&mcu_mcan1_pins_default>;
    	phys = <&transceiver2>;
    &main_mcan0 {
    	pinctrl-0 = <&main_mcan0_pins_default>;
    	phys = <&transceiver3>;
    &main_mcan1 {
    &main_mcan2 {
    	pinctrl-0 = <&main_mcan2_pins_default>;
    	phys = <&transceiver4>;
    &main_mcan3 {
    &main_mcan4 {
    &main_mcan5 {
    &main_mcan6 {
    &main_mcan7 {
    &main_mcan8 {
    &main_mcan9 {
    &main_mcan10 {
    &main_mcan11 {
    &main_mcan12 {
    &main_mcan13 {
    &csi0_port0 {
    &csi0_port1 {
    &csi0_port2 {
    &csi0_port3 {
    &csi0_port4 {
    &main_spi4 {
    &mcu_spi0 {
    &mcu_spi1 {
    &mcu_spi2 {
    &main_ehrpwm0 {
    &main_ehrpwm1 {
    &main_ehrpwm2 {
    &main_ehrpwm3 {
    &main_ehrpwm4 {
    &main_ehrpwm5 {
    &wkup_i2c0 {
    	status = "okay";
    	tps6594x: tps6594x@48 {
    		compatible = "ti,tps6594x";
    		reg = <0x48>;
    		ti,system-power-controller;
    		rtc {
    			compatible = "ti,tps6594x-rtc";
    		gpio {
    			compatible = "ti,tps6594x-gpio";
  • Hi
    Can you share a DTB also for both to see if any parameter is getting overwritten.
    Diwakar
    kernel's dtb in rootfs/boot/k3-j721e-common-proc-board.dtb
    k3-j721e-common-proc-board.rar
    dtb of u-boot, Here is result of make uboot  in cammand "make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- j721e_evm_a72_defconfig O=out/a72"
    a72.zip
  • HI Davied
    Thanks for providing the DTB have not seen anything unusual
    Can you add a logs in the driver to see if the probe is getting called or not for the SD
    as far as the compatible property matches with the driver compatible property the probe should get called but i am not seeing any logs related to SD ,so can you add logs in the driver.
    Diwakar
  • Also Davied
    Can you try setting the default environment variable and see if its booting
    in UBOOT run below command
    => env default -a
    ## Resetting to default environment
    => boot
    Diwakar
  • Hi, experts
         Thinks for your support, we have solved this problem by modified vdd_mmc1.
        Best regards
