Part Number: TDA4VM-Q1
Dear expert,
Need your help to check how to enable or disable the GPU FBCDC ? Thanks.
Fredy Zhang
Dear expert,
Fredy Zhang
Hello Fredy,
Framebuffer Compression / Decompression is enabled by default in the GPU driver. You can disable it by using the AppHint "DisableFBCDC" as an AppHint.
To apply AppHints to the driver, you can create a file called /etc/powervr.ini. If you want the selection to apply to all applications you run, you can place it under the default section, otherwise you can create a section for the particular app you are running. Please see below for an example on how to set the apphint:
/etc/powervr.ini:
[default] DisableFBCDC=1 [gles2test1] DisableFBCDC=0
In this example, we disable FBCDC for all applications except for gles2test1.
Please let me know if you have further questions.
Erick
