Other Parts Discussed in Thread: CCSTUDIO
I converted my project from release to debug, but project is building without errors in release mode and I am getting some errors in Debug mode and the error are mentioned below:
--------------------------- MTL32_015.pjt - Debug ---------------------------
[Linking...] "C:\CCStudio_v3.1\C5500\cgtools\bin\cl55" -@"Debug.lkf"
<Linking>
>> error: linking files for incompatible targets (library
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'addd.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'cmpd.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'divli.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'exit.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fixdi.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fixdli.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fixdul.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fltid.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fltlid.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fltud.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'fltuld.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'llmpy.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'memcpy.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'mpyd.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'negd.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member '_lock.obj')
'D:\Prashant\Codes\MTL32Code\DSP\rts55x.lib', member 'frcmpyd.obj')
>> Compilation failure
Build Complete,
18 Errors, 0 Warnings, 0 Remarks.
Please help me in solving this problem.
Thanks & Regards,
Prashant.
