PROCESSOR-SDK-J721E: TIDL-RT test cases
Part Number: PROCESSOR-SDK-J721E
I am using PROCESSOR-SDK-RTOS-J721E downloaded from dr-download.ti.com/.../ti-processor-sdk-rtos-j721e-evm-08_06_01_03.tar.gz.
I want to run TIDL-RT test cases in Linux to verify TIDL-RT.
My Questions are:
1. Can TIDL-RT test cases run in TI Linux? how to build TIDL-RT test cases in Linux? The TIDL-RT test cases are located in tidl_j784s4_08_06_00_10/arm-tidl/rt/test/srctidl_tb.c.
2. I have ported TIDLRT APIs on other OS (not Linux) which are running on A72 CPUs not C7x CPUS. I try to port TIDLRT test cases to verify TIDLRT APIs can work well. But I always get the following errors:
In file included from /workspace/xxx/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/tidl_j784s4_08_06_00_10/ti_dl/algo/src/tidl_preEmption.c:70:
In file included from /workspace/xxx/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/tidl_j784s4_08_06_00_10/ti_dl/algo/inc/tidl_alg_int.h:88:
In file included from /workspace/xxx/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/mmalib_cnn.h:26:
In file included from /workspace/xxx/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX.h:25:
In file included from /workspace/xxx/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/mmalib_02_06_02_00/ti/mmalib/src/cnn_c7xmma/MMALIB_CNN_convolve_col_smallNo_ixX_ixX_oxX/../../common/MMALIB_types.h:35:
In file included from /workspace/xxx/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/ti-cgt-c7000_3.1.0.LTS/include/c7x.h:81:
/workspace/blan/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/ti-cgt-c7000_3.1.0.LTS/include/c7x_cr.h:74:17: error: unknown type name '__cregister'; did you mean '__register_t'?
extern volatile __cregister unsigned long __CPUID;
                __register_t
The file ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/ti-cgt-c7000_3.1.0.LTS/include/c7x_cr.h should be used for free RTOS for C7xx cpus.
Does this mean TIDLRT test cases can run on A72 CPUs?
    Thank you for posting question, we will get back to you on this.
    I did not quite follow the question. Do you want to validate TIDL RT APIs standalone on A72 without C7x ? Can you help me with some more details on application you are trying to target?
    Anand
  • I want to validate TIDL RT APIs can run on A72 on TI tda_4vh board, so I try to port TIDL RT test cases located in tidl_j784s4_08_06_00_10/arm-tidl/rt/test/srctidl_tb.c. But I always get the following errors:
                    __register_t
