AM6442: Watchdog Timer Issue on SR2.0 Silicon
Part Number: AM6442
Other Parts Discussed in Thread: SK-AM64B
The watchdog timer is working correctly on SR1.0 silicon but is no longer able to reset the board after switching to SR2.0 silicon.
Log below showing the device not resetting at the end of the watchdog countdown. Is there anything different needed for SR2.0 silicon for the watchdog timer?
Log:
bash-5.0# ./runltp -P am64xx-sk -f ddt/wdt_test -s WDT_S_FUNC_GETSTATUS
INFO: creating /usr/srvroot/shared/TI/opt/ltp/results directory
INFO: Filtering testscenarios based on am64xx-sk capabilities
Checking for required user/group ids
'nobody' user id and group found.
'bin' user id and group found.
'daemon' user id and group found.
Users group found.
Sys group found.
Required users/groups exist.
If some fields are empty or look unusual you may have an old version.
Compare to the current minimal requirements in Documentation/Changes.
/etc/os-release
ID=****
NAME="****-Linux"
VERSION="1.0 (****)"
VERSION_ID=1.0
PRETTY_NAME="****"
DISTRO_CODENAME="****"
uname:
Linux **** 5.10.140-**** #1 SMP PREEMPT Fri Sep 23 14:11:59 UTC 2022 aarch64 GNU/Linux
/proc/cmdline
console=ttyS2,115200n8 bootmedium=QSPI serverip= msocsbootver= fwup=active upstatus=complete bootsrc= earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:512k(qspi.tiboot3),2m(qspi.tispl),13824k(qspi.u-boot),84m(qspi.fit-img),64k(qspi.ver) root=PARTUUID= rw rootfstype=ext4 rootwait
Gnu C
Clang
util-linux             2.35.1
mount                  linux 2.35.1 (libmount 2.35.1: btrfs, namespaces, assert, debug)
modutils               26
/usr/srvroot/shared/TI/opt/ltp/ver_linux: line 94: ldd: command not found
Linux C Library        r..    1 root     root           199 Sep 11 18:58 alltests
Linux C Library        .    1 root     root          1823 Sep 11 18:58 alltests.orig
Linux C Library        drwxr.xr.x   42 root     root           840 Sep 11 18:58 platform
/usr/srvroot/shared/TI/opt/ltp/ver_linux: line 98: ldd: command not found
Procps                 '--version'
Net-tools              1.60
iproute2               binary.
iputils                'V'
ethtool                4.0
Kbd                    2.2.0
Sh-utils               --v
Modules Loaded         gpio_mon nf_conntrack_tftp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_multiport xt_tcpudp ip6table_filter ip6_tables iptable_filter ip_tables x_tables irq_pruss_intc pru_rproc icss_iep crct10dif_ce rti_wdt sa2ul sha512_generic authenc pruss sch_fq_codel ipv6
free reports:
              total        used        free      shared  buff/cache   available
Mem:        1944600      208196     1453304       49992      283100     1459664
Swap:             0           0           0
cpuinfo:
Architecture:                    aarch64
CPU op-mode(s):                  32-bit, 64-bit
Byte Order:                      Little Endian
CPU(s):                          2
On-line CPU(s) list:             0,1
Thread(s) per core:              1
Core(s) per socket:              2
Socket(s):                       1
Vendor ID:                       ARM
Model:                           4
Model name:                      Cortex-A53
Stepping:                        r0p4
BogoMIPS:                        400.00
L1d cache:                       64 KiB
L1i cache:                       64 KiB
L2 cache:                        256 KiB
Vulnerability Itlb multihit:     Not affected
Vulnerability L1tf:              Not affected
Vulnerability Mds:               Not affected
Vulnerability Meltdown:          Not affected
Vulnerability Mmio stale data:   Not affected
Vulnerability Retbleed:          Not affected
Vulnerability Spec store bypass: Not affected
Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
Vulnerability Spectre v2:        Not affected
Vulnerability Srbds:             Not affected
Vulnerability Tsx async abort:   Not affected
Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpui
                                 d
AppArmor disabled
SELinux mode: unknown
no big block device was specified on commandline.
Tests which require a big block device are disabled.
You can specify it with option -z
COMMAND:    /usr/srvroot/shared/TI/opt/ltp/bin/ltp-pan   -e -S   -a 2038     -n 2038 -p -f /tmp/ltp-XXXXSs6ZNu/alltests -l /tmp/tmp.dbPGXa  -C /usr/srvroot/shared/TI/opt/ltp/output/LTP_RUN_ON-tmp.dbPGXa.failed -T /usr/srvroot/shared/TI/opt/ltp/output/LTP_RUN_ON-tmp.dbPGXa.tconf
INFO: Restricted to WDT_S_FUNC_GETSTATUS
LOG File: /tmp/tmp.dbPGXa
FAILED COMMAND File: /usr/srvroot/shared/TI/opt/ltp/output/LTP_RUN_ON-tmp.dbPGXa.failed
TCONF COMMAND File: /usr/srvroot/shared/TI/opt/ltp/output/LTP_RUN_ON-tmp.dbPGXa.tconf
Running tests.......
<<<test_start>>>
tag=WDT_S_FUNC_GETSTATUS stime=1694458705
cmdline="source 'common.sh'; do_cmd install_modules.sh 'wdt' ; DEV_NODE=`get_devnode.sh "wdt"` || die "error getting devnode for wdt"; do_cmd wdt_tests -device $DEV_NODE -ioctl getstatus"
contacts=""
analysis=exit
<<<test_output>>>
incrementing stop
|TRACE LOG|Inside do_cmd:CMD=install_modules.sh wdt|
|TRACE LOG|Inside do_cmd:CMD=wdt_tests -device /dev/watchdog1 -ioctl getstatus|
|TEST START|wdt_tests|
|TRACE LOG|******** WDT Testcase  parameters  ******** |
|TRACE LOG|Device         : /dev/watchdog1|
|TRACE LOG|Loop Count     : 1|
|TRACE LOG|Operation      : Ioctl|
|TRACE LOG|Ioctl Name     : WDIOC_GETSTATUS|
|TRACE LOG|Ioctl Arg      : 0 |
|TRACE LOG| ************* End of Test params ************* |
|TRACE LOG|STATUS VALUE : 32768
Status Is : |
|TRACE LOG|Keep Alive Ping Reply|
|TEST RESULT|PASS|wdt_tests|
|TEST END|wdt_tests|
|TRACE LOG|EVM will be rebooted after 60 seconds|
|TRACE LOG|59 seconds remaining before reboot|
|TRACE LOG|58 seconds remaining before reboot|
|TRACE LOG|57 seconds remaining before reboot|
|TRACE LOG|56 seconds remaining before reboot|
|TRACE LOG|55 seconds remaining before reboot|
|TRACE LOG|54 seconds remaining before reboot|
|TRACE LOG|53 seconds remaining before reboot|
|TRACE LOG|52 seconds remaining before reboot|
|TRACE LOG|51 seconds remaining before reboot|
|TRACE LOG|50 seconds remaining before reboot|
|TRACE LOG|49 seconds remaining before reboot|
|TRACE LOG|48 seconds remaining before reboot|
|TRACE LOG|47 seconds remaining before reboot|
|TRACE LOG|46 seconds remaining before reboot|
|TRACE LOG|45 seconds remaining before reboot|
|TRACE LOG|44 seconds remaining before reboot|
|TRACE LOG|43 seconds remaining before reboot|
|TRACE LOG|42 seconds remaining before reboot|
|TRACE LOG|41 seconds remaining before reboot|
|TRACE LOG|40 seconds remaining before reboot|
|TRACE LOG|39 seconds remaining before reboot|
|TRACE LOG|38 seconds remaining before reboot|
|TRACE LOG|37 seconds remaining before reboot|
|TRACE LOG|36 seconds remaining before reboot|
|TRACE LOG|35 seconds remaining before reboot|
|TRACE LOG|34 seconds remaining before reboot|
|TRACE LOG|33 seconds remaining before reboot|
|TRACE LOG|32 seconds remaining before reboot|
|TRACE LOG|31 seconds remaining before reboot|
|TRACE LOG|30 seconds remaining before reboot|
|TRACE LOG|29 seconds remaining before reboot|
|TRACE LOG|28 seconds remaining before reboot|
|TRACE LOG|27 seconds remaining before reboot|
|TRACE LOG|26 seconds remaining before reboot|
|TRACE LOG|25 seconds remaining before reboot|
|TRACE LOG|24 seconds remaining before reboot|
|TRACE LOG|23 seconds remaining before reboot|
|TRACE LOG|22 seconds remaining before reboot|
|TRACE LOG|21 seconds remaining before reboot|
|TRACE LOG|20 seconds remaining before reboot|
|TRACE LOG|19 seconds remaining before reboot|
|TRACE LOG|18 seconds remaining before reboot|
|TRACE LOG|17 seconds remaining before reboot|
|TRACE LOG|16 seconds remaining before reboot|
|TRACE LOG|15 seconds remaining before reboot|
|TRACE LOG|14 seconds remaining before reboot|
|TRACE LOG|13 seconds remaining before reboot|
|TRACE LOG|12 seconds remaining before reboot|
|TRACE LOG|11 seconds remaining before reboot|
|TRACE LOG|10 seconds remaining before reboot|
|TRACE LOG|9 seconds remaining before reboot|
|TRACE LOG|8 seconds remaining before reboot|
|TRACE LOG|7 seconds remaining before reboot|
|TRACE LOG|6 seconds remaining before reboot|
|TRACE LOG|5 seconds remaining before reboot|
|TRACE LOG|4 seconds remaining before reboot|
|TRACE LOG|3 seconds remaining before reboot|
|TRACE LOG|2 seconds remaining before reboot|
|TRACE LOG|1 seconds remaining before reboot|
|TRACE LOG|0 seconds remaining before reboot|
|TRACE LOG|-1 seconds remaining before reboot|
|TRACE LOG|-2 seconds remaining before reboot|
|TRACE LOG|-3 seconds remaining before reboot|
|TRACE LOG|-4 seconds remaining before reboot|
|TRACE LOG|-5 seconds remaining before reboot|
|TRACE LOG|-6 seconds remaining before reboot|
|TRACE LOG|-7 seconds remaining before reboot|
|TRACE LOG|-8 seconds remaining before reboot|
|TRACE LOG|-9 seconds remaining before reboot|
|TRACE LOG|-10 seconds remaining before reboot|
|TRACE LOG|-11 seconds remaining before reboot|
|TRACE LOG|-12 seconds remaining before reboot|
|TRACE LOG|-13 seconds remaining before reboot|
|TRACE LOG|-14 seconds remaining before reboot
  • Hello Jason,
    I'm attaching a log file I captured with SDK 8.6 on SK-AM64B (SR2.0 HS-FS).
    It looks "RTI_WDT => ESM => SoC RESET" works.
    -Hong
    U-Boot SPL 2021.01-g2ee8efd654 (Feb 23 2023 - 22:21:41 +0000)
    EEPROM not available at 80, trying to read at 81
    Resetting on cold boot to workaround ErrataID:i2331
    resetting ...
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    SPL initial stack usage: 13424 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 15:41:21, Jan 24 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Feb 21 18:20:15 UTC 2023 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-g2ee8efd654 (Feb 23 2023 - 22:21:31 +0000)
    U-Boot 2021.01-g2ee8efd654 (Feb 23 2023 - 22:21:31 +0000)
    SoC:   AM64X SR2.0 HS-FS
    Model: Texas Instruments AM642 SK
    Board: AM64B-SKEVM rev A
    DRAM:  2 GiB
    NAND:  0 MiB
    MMC:   mmc@fa00000: 1
    Loading Environment from FAT... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 MAC addresses don't match:
    Address in ROM is		34:08:e1:80:af:36
    Address in environment is	70:ff:76:1e:bc:2b
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  2  0
    => md.l 0x43000030 1
    43000030: 00000243                               C...
    => md.l 0x43018170 3
    43018170: 000200ff 00000000 00010000             ............
    => md.l 0x04518170 3
    04518170: 00000fff 00000001 00010000             ............
    => boot
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    1490 bytes read in 3 ms (484.4 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 3 ms (0 Bytes/s)
    Already setup.
    19147264 bytes read in 801 ms (22.8 MiB/s)
    54920 bytes read in 6 ms (8.7 MiB/s)
       Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.10.168-g2c23e6c538 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon Feb 27 14:16:24 UTC 2023
    [    0.000000] Machine model: Texas Instruments AM642 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
    [    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=2d3e2dcc-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1398792K/2097152K available (11200K kernel code, 1162K rwdata, 4308K rodata, 1920K init, 431K bss, 174072K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000006] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008593] Console: colour dummy device 80x25
    [    0.013191] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023868] pid_max: default: 32768 minimum: 301
    [    0.028697] LSM: Security Framework initializing
    [    0.033489] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041067] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051090] rcu: Hierarchical SRCU implementation.
    [    0.056357] Platform MSI: msi-controller@1820000 domain created
    [    0.062777] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.072085] EFI services will not be available.
    [    0.077021] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.090629] Detected VIPT I-cache on CPU1
    [    0.090674] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.090690] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.090761] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.090897] smp: Brought up 1 node, 2 CPUs
    [    0.120284] SMP: Total of 2 processors activated.
    [    0.125097] CPU features: detected: 32-bit EL0 Support
    [    0.130372] CPU features: detected: CRC32 instructions
    [    0.143975] CPU: All CPU(s) started at EL2
    [    0.148182] alternatives: patching kernel code
    [    0.154025] devtmpfs: initialized
    [    0.165973] KASLR disabled due to lack of seed
    [    0.170790] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.180770] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.205651] pinctrl core: initialized pinctrl subsystem
    [    0.211740] DMI not present or invalid.
    [    0.216484] NET: Registered protocol family 16
    [    0.222960] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.230370] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.238469] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.247271] thermal_sys: Registered thermal governor 'step_wise'
    [    0.247280] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.253916] cpuidle: using governor menu
    [    0.264898] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.271912] ASID allocator initialised with 65536 entries
    [    0.306193] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.313078] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.319928] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.326775] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.335023] cryptd: max_cpu_qlen set to 1000
    [    0.343087] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
    [    0.352347] vcc_3v3_sys: supplied by vusb_main5v0
    [    0.358839] iommu: Default domain type: Translated
    [    0.364289] SCSI subsystem initialized
    [    0.368958] mc: Linux media interface: v0.10
    [    0.373364] videodev: Linux video capture interface: v2.00
    [    0.379085] pps_core: LinuxPPS API ver. 1 registered
    [    0.384158] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.393504] PTP clock support registered
    [    0.397544] EDAC MC: Ver: 3.0.0
    [    0.401687] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.408631] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.415460] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.423011] FPGA manager framework
    [    0.426660] Advanced Linux Sound Architecture Driver Initialized.
    [    0.434093] clocksource: Switched to clocksource arch_sys_counter
    [    0.440620] VFS: Disk quotas dquot_6.6.0
    [    0.444709] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.458288] NET: Registered protocol family 2
    [    0.463053] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.472063] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.480910] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.489149] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.496925] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.503883] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.510786] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.518307] NET: Registered protocol family 1
    [    0.523403] RPC: Registered named UNIX socket transport module.
    [    0.529498] RPC: Registered udp transport module.
    [    0.534346] RPC: Registered tcp transport module.
    [    0.539154] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.545746] NET: Registered protocol family 44
    [    0.550312] PCI: CLS 0 bytes, default 64
    [    0.555171] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.568196] Initialise system trusted keyrings
    [    0.573161] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.584242] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.591137] NFS: Registering the id_resolver key type
    [    0.596391] Key type id_resolver registered
    [    0.600681] Key type id_legacy registered
    [    0.604862] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.611715] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.619520] 9p: Installing v9fs 9p2000 file system support
    [    0.668258] Key type asymmetric registered
    [    0.672470] Asymmetric key parser 'x509' registered
    [    0.677531] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.685102] io scheduler mq-deadline registered
    [    0.689736] io scheduler kyber registered
    [    0.696326] pinctrl-single 4084000.pinctrl: 33 pins, size 132
    [    0.702822] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.709773] pinctrl-single a40000.timesync-router: 512 pins, size 2048
    [    0.726510] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.749860] brd: module loaded
    [    0.761635] loop: module loaded
    [    0.765977] megasas: 07.714.04.00-rc1
    [    0.774390] tun: Universal TUN/TAP device driver, 1.6
    [    0.780336] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.786770] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.792891] sky2: driver version 1.30
    [    0.797995] VFIO - User Level meta-driver version: 0.3
    [    0.804605] i2c /dev entries driver
    [    0.809814] sdhci: Secure Digital Host Controller Interface driver
    [    0.816163] sdhci: Copyright(c) Pierre Ossman
    [    0.821382] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.828707] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.835378] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.843771] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.848374] optee: revision 3.20 (8e74d476)
    [    0.865072] optee: dynamic shared memory is enabled
    [    0.874821] optee: initialized driver
    [    0.881343] NET: Registered protocol family 17
    [    0.886138] 9pnet: Installing 9P2000 support
    [    0.890611] Key type dns_resolver registered
    [    0.895521] Loading compiled-in X.509 certificates
    [    0.920197] ti-sci 44043000.dmsc: lpm region is required for suspend but not provided.
    [    0.928447] ti-sci 44043000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    [    0.984033] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
    [    0.990521] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [    1.000395] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.007897] pca953x 1-0070: supply vcc not found, using dummy regulator
    [    1.014897] pca953x 1-0070: using no AI
    [    1.043114] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.050397] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.056614] ti-sci-intr bus@f4000:bus@4000000:interrupt-controller1: Interrupt Router 5 domain created
    [    1.066378] ti-sci-intr bus@f4000:interrupt-controller0: Interrupt Router 3 domain created
    [    1.075202] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.097743] ti-udma 485c0100.dma-controller: Number of rings: 68
    [    1.105461] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    1.115767] ti-udma 485c0000.dma-controller: Number of rings: 288
    [    1.130556] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    1.141684] printk: console [ttyS2] disabled
    [    1.146157] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 16, base_baud = 3000000) is a 8250
    [    1.154925] printk: console [ttyS2] enabled
    [    1.163372] printk: bootconsole [ns16550a0] disabled
    [    1.174875] omap8250 2840000.serial: PM domain pd:155 will not be powered off
    [    1.182457] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 17, base_baud = 3000000) is a 8250
    [    1.191154] serial serial0: tty port ttyS6 registered
    [    1.200903] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.205931] 7 cmdlinepart partitions found on MTD device fc40000.spi.0
    [    1.212456] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.217853] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    1.224723] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    1.231320] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    1.238010] 0x000000700000-0x000000740000 : "ospi.env"
    [    1.244439] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    1.251501] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.258266] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.283117] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.330096] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.340450] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.348567] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.356781] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    1.369687] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    1.376820] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.383542] pps pps0: new PPS source ptp0
    [    1.387966] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.398698] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    1.409722] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.418923] k3-j72xx-soc-thermal b00000.temperature-sensor: invalid resource
    [    1.426050] k3-j72xx-soc-thermal: probe of b00000.temperature-sensor failed with error -22
    [    1.439146] gpio-478 (btuart_rts_sel): hogged as output/high
    [    1.452577] vdd_mmc1: supplied by vcc_3v3_sys
    [    1.458353] wlan_en: supplied by com8_ls_en
    [    1.467490] mmc1: CQHCI version 5.10
    [    1.468487] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
    [    1.474428] mmc0: CQHCI version 5.10
    [    1.490898] ALSA device list:
    [    1.493894]   No soundcards found.
    [    1.523620] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.523653] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.540515] Waiting for root device PARTUUID=2d3e2dcc-02...
    [    1.549584] sdhci-am654 fa10000.mmc: card claims to support voltages below defined range
    [    1.569008] mmc0: new SDIO card at address 0001
    [    1.606168] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    1.613672] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    1.623756]  mmcblk1: p1 p2
    [    1.842823] EXT4-fs (mmcblk1p2): 1 orphan inode deleted
    [    1.848169] EXT4-fs (mmcblk1p2): recovery complete
    [    1.863915] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.872136] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.884588] devtmpfs: mounted
    [    1.888991] Freeing unused kernel memory: 1920K
    [    1.893658] Run /sbin/init as init process
    [    2.060095] systemd[1]: System time before build time, advancing clock.
    [    2.122722] NET: Registered protocol family 10
    [    2.128553] Segment Routing with IPv6
    [    2.166768] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    2.188919] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    2.242153] systemd[1]: Set hostname to <am64xx-evm>.
    [    2.591561] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    2.607253] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    2.652626] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
    [    2.697911] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ? /run/docker.sock; please update the unit file accordingly.
    [    2.853930] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.865495] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    2.886454] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.895481] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    2.918345] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.927321] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    2.952677] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    2.974800] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password �ts to Console Directory Watch.
    [    2.998699] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R�uests to Wall Directory Watch.
    [    3.022661] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.038429] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.058409] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.074444] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.114062] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.138575] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.171113] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.194829] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.222880] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.231942] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.255208] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.271373] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.295298] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.318932] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.348746] systemd[1]: Mounting Huge Pages File System...
    [    3.372565] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.400595] systemd[1]: Mounting Kernel Debug File System...
    [    3.430638] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.453397] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st�odes for the current kernel...
    [    3.484587] systemd[1]: Starting RPC Bind...
    [    3.502762] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.520939] systemd[1]: Starting Journal Service...
    [    3.547689] systemd[1]: Starting Load Kernel Modules...
    [    3.568757] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.588262] cryptodev: loading out-of-tree module taints kernel.
    [    3.605012] systemd[1]: Starting udev Coldplug all Devices...
    [    3.618329] cryptodev: driver 1.10 loaded.
    [    3.640786] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.666571] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [    3.683249] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta� nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage    3.862492] random: systemd-journal: uninitialized urandom read (16 bytes read)
    0m...
    [    3.882682] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.891049] systemd-journald[168]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
    [    3.910734] random: systemd-journal: uninitialized urandom read (16 bytes read)
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Coldplug all Devices.
             Starting udev Wait for Complete Device Initialization...
    [  OK  ] Started Create Volatile Files and Directories.
    [  OK  ] Started udev Kernel Device Manager.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    5.034201] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.169893] random: crng init done
    [    5.173495] random: 64 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    5.428020] Bluetooth: Core ver 2.22
    [    5.454539] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [    5.484003] NET: Registered protocol family 31
    [    5.490846] Bluetooth: HCI device and connection manager initialized
    [    5.501215] Bluetooth: HCI socket layer initialized
    [    5.508318] Bluetooth: L2CAP socket layer initialized
    [    5.513983] Bluetooth: SCO socket layer initialized
    [    5.525804] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    5.544306] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    5.570540] Bluetooth: HCI UART driver ver 2.3
    [    5.575111] Bluetooth: HCI UART protocol H4 registered
    [    5.583365] Bluetooth: HCI UART protocol LL registered
    [    5.589560] Bluetooth: HCI UART protocol Broadcom registered
    [    5.597737] remoteproc remoteproc0: 5000000.m4fss is available
    [    5.599450] Bluetooth: HCI UART protocol QCA registered
    [    5.619285] remoteproc remoteproc0: powering up 5000000.m4fss
    [    5.625347] remoteproc remoteproc0: Booting fw image am64-mcu-m4f0_0-fw, size 86084
    [    5.635522]  remoteproc0#vdev0buffer: assigned reserved memory node m4f-dma-memory@a4000000
    [    5.645250]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    5.653268] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
    [    5.684558] Bluetooth: hci0: change remote baud rate command in firmware
    [    5.707158] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.712910] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.721343] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    5.803046] platform 78000000.r5f: configured R5F for remoteproc mode
    [    5.857321] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    5.879462] remoteproc remoteproc1: 78000000.r5f is available
    [    5.894295] platform 78200000.r5f: configured R5F for remoteproc mode
    [    5.908891] remoteproc remoteproc1: powering up 78000000.r5f
    [    5.914916] remoteproc remoteproc1: Booting fw image am64-main-r5f0_0-fw, size 86352
    [    5.941278] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [    5.942207]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    5.960185] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.966192]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    5.974663] remoteproc remoteproc1: remote processor 78000000.r5f is now up
    [    5.986301] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    5.999765] remoteproc remoteproc2: 78200000.r5f is available
    [    6.013433] remoteproc remoteproc2: powering up 78200000.r5f
    [    6.019391] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
    [    6.029983] platform 78400000.r5f: configured R5F for remoteproc mode
    [    6.037773]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
    [    6.047096] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.056559]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    6.063021] remoteproc remoteproc2: remote processor 78200000.r5f is now up
    [    6.070334] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    6.106568] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    6.121851] remoteproc remoteproc3: 78400000.r5f is available
    [    6.143549] remoteproc remoteproc3: powering up 78400000.r5f
    [    6.149520] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
    [    6.163355] platform 78600000.r5f: configured R5F for remoteproc mode
    [    6.170101]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    6.180940] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.189081]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    6.197925] remoteproc remoteproc3: remote processor 78400000.r5f is now up
    [    6.206760] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    6.243751] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    6.259250] remoteproc remoteproc4: 78600000.r5f is available
    [    6.272621] remoteproc remoteproc4: powering up 78600000.r5f
    [    6.278481] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
    [    6.290854]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    6.300100] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    6.309117]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    6.315410] remoteproc remoteproc4: remote processor 78600000.r5f is now up
    [    6.326305] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Listening on Load/Save RF �itch Status /dev/rfkill Watch.
    [    7.948166] remoteproc remoteproc5: 30034000.pru is available
             Starting Load/Save RF Kill Switch Status...
    [    7.979929] remoteproc remoteproc6: 30004000.rtu is available
    [    7.999201] remoteproc remoteproc7: 3000a000.txpru is available
    [    8.018028] remoteproc remoteproc8: 30038000.pru is available
    [    8.041697] remoteproc remoteproc9: 30006000.rtu is available
    [    8.050561] remoteproc remoteproc10: 3000c000.txpru is available
    [    8.078536] remoteproc remoteproc11: 300b4000.pru is available
    [    8.094930] remoteproc remoteproc12: 30084000.rtu is available
    [    8.103693] remoteproc remoteproc13: 3008a000.txpru is available
    [    8.120634] remoteproc remoteproc14: 300b8000.pru is available
    [    8.134506] remoteproc remoteproc15: 30086000.rtu is available
    [    8.142873] remoteproc remoteproc16: 3008c000.txpru is available
    [  OK  ] Started Load/Save RF Kill Switch Status.
    [    8.384397] usbcore: registered new interface driver usbfs
    [    8.400779] usbcore: registered new interface driver hub
    [    8.410682] usbcore: registered new device driver usb
    [    8.479747] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.517712] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.581548] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    8.589405] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    8.604636] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [    8.614306] xhci-hcd xhci-hcd.1.auto: irq 533, io mem 0x0f410000
    [    8.620808] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    8.626452] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    8.634596] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    [    8.641585] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    8.650014] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    8.657409] usb usb1: Product: xHCI Host Controller
    [    8.662371] usb usb1: Manufacturer: Linux 5.10.168-g2c23e6c538 xhci-hcd
    [    8.669120] usb usb1: SerialNumber: xhci-hcd.1.auto
    [    8.676093] hub 1-0:1.0: USB hub found
    [    8.680280] hub 1-0:1.0: 1 port detected
    [    8.687095] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    8.695901] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    8.704708] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    8.712531] usb usb2: Product: xHCI Host Controller
    [    8.717847] usb usb2: Manufacturer: Linux 5.10.168-g2c23e6c538 xhci-hcd
    [    8.724964] usb usb2: SerialNumber: xhci-hcd.1.auto
    [    8.731969] hub 2-0:1.0: USB hub found
    [    8.736088] hub 2-0:1.0: 1 port detected
    [    8.757932] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Timer service to update the IP on OLED each 10s.
    [    9.122760] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [  OK  ] Started Daily Cleanup of Temporary [    9.136703] wlcore: loaded
    Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
             Starting Bluetooth service...
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Matrix GUI...
             Starting startwlanap...
             Starting startwlansta...
             Starting System Logger Daemon "default" instance...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting telnetd.service...
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started startwlanap.
    [  OK  ] Started startwlansta.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started Matrix GUI.
    [  OK  ] Started telnetd.service.
    [  OK  ] Reached target Network (Pre).
    [    9.930448] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
             Starting LSB: Expand Rootfs of boot device...
             Starting syslog.service...
             Starting Network Service...
    [  OK  ] Started Bluetooth service.
    [  OK  ] Reached target Bluetooth.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
             Starting Hostname Service...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started syslog.service.
    [  OK  ] Started LSB: Expand Rootfs of boot device.
    [   11.070454] startwlansta.sh[580]: Wi-Fi user configuration file missing, exit
    [   11.286789] wlcore: using inverted interrupt logic: 2
    [   11.432968] wlcore: PHY firmware version: Rev 8.2.0.0.245
    [   11.609840] wlcore: firmware booted (Rev 8.9.0.0.86)
    [   11.768588] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [  OK  ] Started Login Service.
    [   12.003876] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Hostname Service.
    [   12.191843] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   12.245583] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   12.266676] startwlanap.sh[653]: adding wlan1 interface
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma�ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Vsftpd ftp daemon.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Permit User Sessions.
    [   12.606641] startwlanap.sh[656]: Configuration file: /usr/share/wl18xx/hostapd.conf
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service'[   12.845515] wlcore: down
     for details.
    [   12.832997] startwlanap.sh[656]: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   12.907018] startwlanap.sh[656]: Using interface wlan1 with hwaddr 6c:79:b8:fa:dd:0b and ssid "AM64xSK-AP_b8fadd"
    [   13.123322] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
    [   13.069260] startwlanap.sh[656]: wlan1: interface state COUNTRY_UPDATE->ENABLED
    [   13.070446] startwlanap.sh[656]: wlan1: AP-ENABLED
    [  OK  ] Started Simple Network Man�ement Protocol (SNMP) Daemon..
    [   13.878152] Bluetooth: hci0: command 0xfd06 tx timeout
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	gstreamer1.0-libav
    	gzip
    	hidapi
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libreadline8
    	libunistring2
    	m4
    	make
    	nettle
    	parted
    	tar
    	which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am64xx-evm ttyS2
    Arago 2021.09 am64xx-evm ttyS2
    am64xx-evm login: root
    root@am64xx-evm:~# cd /opt/ltp
    root@am64xx-evm:/opt/ltp# ./runltp -P am64xx-sk -f ddt/wdt_test -s WDT_S_FUNC_GETSTATUS
    INFO: creating /opt/ltp/results directory
    awk: cmd. line:1: warning: regexp escape sequence `\&' is not a known regexp operator
    Users group found.
    Sys group found.
    /etc/os-release
    ID=arago
    NAME="Arago"
    VERSION="2021.09"
    VERSION_ID=2021.09
    PRETTY_NAME="Arago 2021.09"
    uname:
    Linux am64xx-evm 5.10.168-g2c23e6c538 #1 SMP PREEMPT Mon Feb 27 14:16:24 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
    /proc/cmdline
    Gnu C                  gcc (GCC) 9.2.1 20191025
    Clang
    Gnu make               4.3
    util-linux             2.35.1
    modutils               26
    e2fsprogs              1.45.7
    Linux C Library        > libc.2.30
    Dynamic linker (ldd)   2.30
    Linux C++ Library      6..
    Procps                 3.3.16
    Net-tools              1.60
    iproute2               iproute2-5.10.0
    iputils                'V'
    ethtool                5.10
    Kbd                    2.2.0
    Sh-utils               8.31
    Modules Loaded         af_alg iptable_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip_tables x_tables wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd cdns3 udc_core roles cfg80211 rpmsg_char libarc4 usbcore usb_common irq_pruss_intc icss_iep pru_rproc crct10dif_ce wlcore_sdio rti_wdt ti_k3_r5_remoteproc cdns3_ti virtio_rpmsg_bus hci_uart btqca btbcm ti_k3_m4_remoteproc bluetooth ecdh_generic sa2ul ecc rfkill sha512_generic authenc pruss gpio_tpic2810 optee_rng rng_core sch_fq_codel cryptodev ipv6
    free reports:
    Mem:        1925000       70204     1761404        9792       93392     1775192
    Swap:             0           0           0
    cpuinfo:
    CPU(s):                          2
    On-line CPU(s) [   58.154992] LTP: starting WDT_S_FUNC_GETSTATUS (source 'common.sh'; do_cmd install_modules.sh 'wdt' ; DEV_NODE=`get_devnode.sh "wdt"` || die "error getting devnode for wdt"; do_cmd wdt_tests -device $DEV_NODE -ioctl getstatus)
    list:             0,1
    Socket(s):                       1
    Vendor ID:                       ARM
    Model:                           4
    Stepping:                        r0p4
    BogoMIPS:                        400.00
    L1d cache:                       64 KiB
    L1i cache:                       64 KiB
    L2 cache:                        256 KiB
    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
    AppArmor disabled
    COMMAND:    /opt/ltp/bin/ltp-pan   -e -S   -a 845     -n 845 -p -f /tmp/ltp-iVQOuWcz0M/alltests -l /tmp/tmp.DWRtMbsqUp  -C /opt/ltp/output/LTP_RUN_ON-tmp.DWRtMbsqUp.failed -T /opt/ltp/output/LTP_RUN_ON-tmp.DWRtMbsqUp.tconf
    LOG File: /tmp/tmp.DWRtMbsqUp
    FAILED COMMAND File: /opt/ltp/output/LTP_RUN_ON-tmp.DWRtMbsqUp.failed
    TCONF COMMAND File: /opt/ltp/output/LTP_RUN_ON-tmp.DWRtMbsqUp.tconf
    <<<test_start>>>
    tag=WDT_S_FUNC_GETSTATUS stime=1677504371
    contacts=""
    analysis=exit
    <<<test_output>>>
    incrementing stop
    |TRACE LOG|Inside do_cmd:CMD=wdt_tests -device /dev/watchdog -ioctl getstatus|
    |TRACE LOG|Device         : /dev/watchdog|
    Status Is : |
    |TEST END|wdt_tests|
    I/TC:
    DRAM:  2 GiB
    NAND:  0 MiB
    MMC:   mmc@fa00000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    43018170: 000200ff 00000000 c0010000             ............
    04518170: 00000fff 00000001 c0010000             ............
  • I’ve verified CTRLMMR_MCU_RST_CTRL register on SR1 and SR2 boards and I can see a difference in the values.
    I changed the CTRLMMR_MCU_RST_CTRL register value to 0x00000FFF using devmem tools, watcdoing is working fine.
    Also noticed that not able to modify the CTRLMMR_MCU_RST_CTRL value in R5 enable_mcu_esm_reset().
    #define CTRLMMR_MCU_RST_CTRL                    0x04518170
    #if defined(CONFIG_ESM_K3)
    static void enable_mcu_esm_reset(void)
    /* Set CTRLMMR_MCU_RST_CTRL:MCU_ESM_ERROR_RST_EN_Z to '0' (low active) */
    u32 stat = readl(CTRLMMR_MCU_RST_CTRL);
    stat &= 0xFFFDFFFF;
    writel(stat, CTRLMMR_MCU_RST_CTRL);
    #endif
    Log:
    enable_mcu_esm_reset is called
    Read back after write
    Read back after write 20fff
    SR2:
    root@rscm-hs-sr2-m4010:/usr/srvroot/shared# ./devmem2 0x04518170
    /dev/mem opened.
    Memory mapped at address 0xffff80d89000.
    Read at address  0x04518170 (0xffff80d89170): 0x00020FFF
    SR1:
    Register dump:
    root@rscm-m4010:/usr/srvroot/shared# ./devmem2 0x04518170
    /dev/mem opened.
    Memory mapped at address 0xffff9f410000.
    Read at address  0x04518170 (0xffff9f418170): 0x00000FFF
  • Hello Nagaraj,
    For your reference, I tested previously on firing off AM64x RTI_WDT @u-boot level with Linux SDK 8.2 on AM64x GP EVM
    Can we run similar test @u-boot on your customer board?
    1. cmds @u-boot to fire off main domain RTI_WDT RTI0 starts to count-down
    => mw.l 0xe0000a4 0xa 1
    => mw.l 0xe000090 0xA98559DA 1
    The log for ~1 seconds RTI_WDT timeout (am64_8.2_wdt_esm_uboot_1.txt)
    2. Another log to configure ~12 seconds RTI_WDT timeout (am64_8.2_wdt_esm_uboot_12s.txt)
    => mw.l 0x43009008 0x68EF3490 1
    => mw.l 0x4300900C 0xD172BC5A 1
    => mw.l 0x43008380 0x3 1
    => mw.l 0xe000094 0x23 1
    3. CTRLMMR registers on RST_CTRL/RST_STAT/RST_SRC for main domain and mcu domain are captured
    in the attached two logs => “SOC Reset Caused by MCU ESM Error”, “Reset Caused by Main ESM Error”
    -Hong
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 30 2022 - 16:29:38 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    SPL initial stack usage: 13392 bytes
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 16:24:35, Mar 30 2022
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 30 2022 - 16:28:20 +0000)
    U-Boot 2021.01-g44a87e3ab8 (Mar 30 2022 - 16:28:20 +0000)
    SoC:   AM64X SR1.0
    Model: Texas Instruments AM642 EVM
    Board: AM64-GPEVM rev E2
    DRAM:  2 GiB
    NAND:  0 MiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    43018170: 000200ff 00000000 00000000             ............
    04518170: 00000fff 00000001 00000000             ............
    => md.l 0xe000000 0x40
    0e000000: 00000000 00000000 00000000 00000000    ................
    0e000010: 00000000 00000000 00000000 00000000    ................
    0e000020: 00000000 00000000 00000000 00000000    ................
    0e000030: 00000000 00000000 00000000 00000000    ................
    0e000040: 00000000 00000000 00000000 00000000    ................
    0e000050: 00000000 00000000 00000000 00000000    ................
    0e000060: 00000000 00000000 00000000 00000000    ................
    0e000070: 00000000 00000000 00000000 00000000    ................
    0e000080: 00000000 00000000 00000000 00000000    ................
    0e000090: 5312aced 00000fff 00000000 0000a35c    ...S........\...
    0e0000a0: 01ffffff 00000005 00000005 05050505    ................
    0e0000b0: 00000000 00000000 00000000 00000000    ................
    0e0000c0: 00000000 00000000 00000000 00000000    ................
    0e0000d0: 00000000 00000000 00000000 00000000    ................
    0e0000e0: 00000000 00000000 00000000 00000000    ................
    0e0000f0: 00000000 00000000 00000000 00000000    ................
    SoC:   AM64X SR1.0
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    43018170: 000200ff 00000000 c0000000             ............
    04518170: 00000fff 00000001 c0000000             ............
    SoC:   AM64X SR1.0
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    SoC:   AM64X SR1.0
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Hit any key to stop autoboot:  2  1  0
  • Please find the attached test results. Our board did not fire off the AM64x RTI_WDT.
  • Hello Nagaraj,
    I just tested AM64x SR2.0 (HS-FS) with SDK 8.6 on AM64x EVM.
    RTI_WDT works @u-boot as shown from the attached log.
    Do we make HW changes on your customer board on RESET circuitry from SR1.0 to SR2.0 SoC?
    -Hong
    resetting ...
    I/TC:
    Board: AM64-GPEVM rev C
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    I/TC:
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
  • Hi Hong,
     Let me clarify the problem, we are setting CTRLMMR_MCU_RST_CTRL:MCU_ESM_ERROR_RST_EN_Z to '0' (low active) to enable watchdog (MCU ESM reset). Default value is 0x00020FFF and during R5 boot we are modifying bit#17 to enable MCU_ESM_ERROR_RST_EN_Z bit. This is not working in SR2 silicon. We can be able to modify this register in SR1. Please refer following code.
    Note: This value can be modified from A53 or from Linux using devmem tool in SR2. Please let me know if you have any questions.
    Also please refer following 3 u-boot commit for more information.
    7f67536f37430e66eb870c94fad747b927d2a380
    5eabe81f76c4497fc4294254d16713cb91b78bed
    6cec2c6356df00cac72d249c5fe06e5322e46cff
    Nagaraj S
  • Hello Nagaraj,
    The log I captured and shared yesterday was on SR 2.0 HS-FS => RTI_WDT timeout => MCU ESM => WarmReset works
    I took a closer look at your non-working log => SR2.0 HS-SE on your board.
    I tested on SR2.0 HS-SE this morning, and did reproduce the same issue as observed on your board.
    - am64_8.6_rti_wdt_1s_SE_KO.log: the non-working log I captured on SR2.0 HS-SE.
    It looks like there's timing constraints on accessing CTRLMMR_MCU_RST_CTRL @0x04518170 by the function enable_mcu_esm_reset() after POR
    git.ti.com/gitweb
    I created a WA patch, where enable_mcu_esm_reset() is moved after DDR configurations in R5-SPL.
    - am64_8.6_rti_wdt_1s_SE_OK.log: the working log I captured on SR2.0 HS-SE with the attached patch.
    Please test with the WA patch on your board.
    -Hong
    U-Boot SPL 2021.01-g2ee8efd654 (Feb 27 2023 - 13:50:03 +0000)
    resetting ...
    NOTICE:  BL31: Built : 13:45:56, Feb 27 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Mon Feb 27 13:46:53 UTC 2023 aarch64
    U-Boot SPL 2021.01-g2ee8efd654 (Feb 27 2023 - 13:48:24 +0000)
    U-Boot 2021.01-g2ee8efd654 (Feb 27 2023 - 13:48:24 +0000)
    SoC:   AM64X SR2.0 HS-SE
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    04518170: 00020fff 00000001 00010000             ............
    04518170: 00020fff 00000001 c0010000             ............
    U-Boot SPL 2021.01-00004-gb53b96e-dirty (Sep 22 2023 - 11:23:31 -0500)
    resetting ...
    I/TC:
    U-Boot SPL 2021.01-00004-gb53b96e-dirty (Sep 22 2023 - 11:23:18 -0500)
    U-Boot 2021.01-00004-gb53b96e-dirty (Sep 22 2023 - 11:23:18 -0500)
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    I/TC:
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/am64x_5F00_rti_5F00_wdt_5F00_esm.patch
  • Hi Hong,
    Thank you! WDT is working fine with this patch (am64x_rti_wdt_esm.patch).
    /dev/mem opened.
    Memory mapped at address 0xffff8b966000.
    Read at address 0x04518170 (0xffff8b966170): 0x00000FFF
    Nagaraj S
  • Hello Nagaraj,
    thanks for testing the patch. let's close the e2e.
    -Hong
  • Hi Hong,
    Is this official patch? if so, I'll apply this patch to our U-boot.
    Nagaraj S
  • Hello Nagaraj,
    The patch moves mcu esm configurations after DDR configuration in R5-SPL so I don't think any side effect to use it.
    I'll create a internal CR to track the issue, and keep you posted for any update...
    -Hong
