Hi, TI Experts,
We successfully boot from an SD card made with the TI prebuilt image, but when we try to boot with our self-compiled image, there is no log output. We found that the issue is related to the 'tiboot3.bin' file. When we replace it with the TI prebuilt 'tiboot3.bin,' it works.
Our compilation process involves running 'make uboot -j4,' followed by copying 'u-boot_build/a5/tiboot3.bin.' Can you provide us with some suggestions for troubleshooting this issue?
tiboot3 ok: tiboot3-ok.bin.txt
tiboot3 ng: tiboot3-ng.bin.txt
ok log:
U-Boot SPL 2021.01-ga169f42610 (Aug 30 2022 - 11:58:37 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
SPL initial stack usage: 13472 bytes
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.6(release):v2.7-rc0-dirty
NOTICE: BL31: Built : 11:58:46, Aug 30 2022
I/TC:
I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 11:59:08 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01 (Sep 13 2023 - 11:30:25 +0800)
U-Boot 2021.01 (Sep 13 2023 - 11:30:25 +0800)
SoC: J721S2 SR1.0 GP
Model: Texas Instruments J721S2 EVM
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
Board: J721S2X-PM1-SOM rev E2
DRAM: 16 GiB
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from MMC... OK
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
484 bytes read in 6 ms (78.1 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
Failed to load '.psdk_setup'
## Resetting to default environment
Saving Environment to MMC... Writing to MMC(0)... OK
1 bytes written in 31 ms (0 Bytes/s)
resetting ...
I/TC:
DRAM: 16 GiB
Flash: 0 Bytes
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
Running uenvcmd ...
1 bytes read in 6 ms (0 Bytes/s)
Already setup.
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
916616 bytes read in 29 ms (30.1 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 916616 bytes: Success!
301996 bytes read in 15 ms (19.2 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 301996 bytes: Success!
86668 bytes read in 12 ms (6.9 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 86668 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 86668 bytes: Success!
14422024 bytes read in 316 ms (43.5 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 14422024 bytes: Success!
9887672 bytes read in 219 ms (43.1 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 9887672 bytes: Success!
18520576 bytes read in 402 ms (43.9 MiB/s)
72078 bytes read in 9 ms (7.6 MiB/s)
9642 bytes read in 8 ms (1.1 MiB/s)
Loading Device Tree to 000000008feeb000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.120-g95b90aa828 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Aug 30 12:01:32 UTC 2022
[ 0.000000] Machine model: Texas Instruments J721S2 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 111 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000da000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@da000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 736 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffefff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b0ffffff]
[ 0.000000] node 0: [mem 0x00000000b1000000-0x00000000b1ffffff]
[ 0.000000] node 0: [mem 0x00000000b2000000-0x00000000b9ffffff]
[ 0.000000] node 0: [mem 0x00000000ba000000-0x00000000d9ffffff]
[ 0.000000] node 0: [mem 0x00000000da000000-0x00000000ddffffff]
[ 0.000000] node 0: [mem 0x00000000de000000-0x00000000ffffefff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008adffffff]
[ 0.000000] node 0: [mem 0x00000008ae000000-0x0000000bffffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff]
[ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 512 MiB at 0x00000000dfc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128766
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=3b6e2d6a-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[ 0.000000] Memory: 14073092K/16777208K available (10880K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 2179828K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8ae800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008ae030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008ae040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008374] Console: colour dummy device 80x25
[ 0.012940] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023612] pid_max: default: 32768 minimum: 301
[ 0.028377] LSM: Security Framework initializing
[ 0.033192] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.041019] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.050106] rcu: Hierarchical SRCU implementation.
[ 0.055173] Platform MSI: msi-controller@1820000 domain created
[ 0.061369] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070663] EFI services will not be available.
[ 0.075411] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.088499] Detected PIPT I-cache on CPU1
[ 0.088523] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.088536] GICv3: CPU1: using allocated LPI pending table @0x00000008ae050000
[ 0.088576] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.088637] smp: Brought up 1 node, 2 CPUs
[ 0.117982] SMP: Total of 2 processors activated.
[ 0.122787] CPU features: detected: 32-bit EL0 Support
[ 0.128045] CPU features: detected: CRC32 instructions
[ 0.142636] CPU: All CPU(s) started at EL2
[ 0.146842] alternatives: patching kernel code
[ 0.151932] devtmpfs: initialized
[ 0.159135] KASLR disabled due to lack of seed
[ 0.163792] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.173758] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.186614] pinctrl core: initialized pinctrl subsystem
[ 0.192291] DMI not present or invalid.
[ 0.196551] NET: Registered protocol family 16
[ 0.201912] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.209601] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.218140] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.226563] thermal_sys: Registered thermal governor 'step_wise'
[ 0.226566] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.233169] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.246815] ASID allocator initialised with 65536 entries
[ 0.264753] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.271612] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.278462] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.285310] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.292836] cryptd: max_cpu_qlen set to 1000
[ 0.298903] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
[ 0.307982] vsys_3v3: supplied by evm_12v0
[ 0.312390] vsys_5v0: supplied by evm_12v0
[ 0.317186] iommu: Default domain type: Translated
[ 0.322371] SCSI subsystem initialized
[ 0.326455] mc: Linux media interface: v0.10
[ 0.330836] videodev: Linux video capture interface: v2.00
[ 0.336471] pps_core: LinuxPPS API ver. 1 registered
[ 0.341545] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.350883] PTP clock support registered
[ 0.354901] EDAC MC: Ver: 3.0.0
[ 0.358680] FPGA manager framework
[ 0.362210] Advanced Linux Sound Architecture Driver Initialized.
[ 0.368871] clocksource: Switched to clocksource arch_sys_counter
[ 0.375221] VFS: Disk quotas dquot_6.6.0
[ 0.379260] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.388970] Carveout Heap: Exported 512 MiB at 0x00000000ba000000
[ 0.395264] NET: Registered protocol family 2
[ 0.400549] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.411625] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.420546] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.429239] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.437302] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.444221] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.451322] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.458959] NET: Registered protocol family 1
[ 0.463749] RPC: Registered named UNIX socket transport module.
[ 0.469821] RPC: Registered udp transport module.
[ 0.474626] RPC: Registered tcp transport module.
[ 0.479428] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.486015] PCI: CLS 0 bytes, default 64
[ 0.490408] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.500963] Initialise system trusted keyrings
[ 0.505591] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 0.513852] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.520093] NFS: Registering the id_resolver key type
[ 0.525272] Key type id_resolver registered
[ 0.529542] Key type id_legacy registered
[ 0.533661] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.540510] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.548159] 9p: Installing v9fs 9p2000 file system support
[ 0.573214] Key type asymmetric registered
[ 0.577403] Asymmetric key parser 'x509' registered
[ 0.582404] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.589963] io scheduler mq-deadline registered
[ 0.594588] io scheduler kyber registered
[ 0.599943] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.606070] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.614219] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.620501] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.628384] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.640845] brd: module loaded
[ 0.647483] loop: module loaded
[ 0.651132] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[ 0.659065] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.120-g95b90aa828 #1
[ 0.666353] Hardware name: Texas Instruments J721S2 EVM (DT)
[ 0.672132] Call trace:
[ 0.674635] dump_backtrace+0x0/0x1a0
[ 0.678372] show_stack+0x18/0x68
[ 0.681756] dump_stack+0xd0/0x12c
[ 0.685226] sysfs_warn_dup+0x60/0x80
[ 0.688960] sysfs_create_dir_ns+0xe0/0xf8
[ 0.693142] kobject_add_internal+0x98/0x288
[ 0.697499] kobject_add+0x94/0x100
[ 0.701058] device_add+0xe0/0x740
[ 0.704528] platform_device_add+0x100/0x238
[ 0.708886] platform_device_register_full+0xcc/0x150
[ 0.714046] dma_buf_phys_init+0x6c/0x9c
[ 0.718048] do_one_initcall+0x54/0x1b8
[ 0.721962] kernel_init_freeable+0x220/0x2a0
[ 0.726411] kernel_init+0x14/0x114
[ 0.729969] ret_from_fork+0x10/0x34
[ 0.733643] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[ 0.746907] megasas: 07.714.04.00-rc1
[ 0.752468] tun: Universal TUN/TAP device driver, 1.6
[ 0.757932] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.764340] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.770414] sky2: driver version 1.30
[ 0.774712] VFIO - User Level meta-driver version: 0.3
[ 0.780499] i2c /dev entries driver
[ 0.784724] sdhci: Secure Digital Host Controller Interface driver
[ 0.791051] sdhci: Copyright(c) Pierre Ossman
[ 0.795775] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.802061] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.808398] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.815636] optee: probing for conduit method.
[ 0.820204] optee: revision 3.17 (15a746d2)
[ 0.820352] optee: dynamic shared memory is enabled
E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8af63d000
[ 0.835165] optee: initialized driver
[ 0.840135] NET: Registered protocol family 17
[ 0.844761] 9pnet: Installing 9P2000 support
[ 0.849171] Key type dns_resolver registered
[ 0.853647] Loading compiled-in X.509 certificates
[ 0.862407] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.868755] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.876879] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
[ 0.907981] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.914142] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.920220] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.926662] pca953x 3-0021: supply vcc not found, using dummy regulator
[ 0.933491] pca953x 3-0021: using no AI
[ 0.961419] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.968230] pca953x 3-0020: using no AI
[ 0.972846] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.979650] pca953x 3-0022: using AI
[ 0.983975] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.990368] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
[ 0.998954] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
[ 1.008297] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
[ 1.016909] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
[ 1.025505] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.033174] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.041453] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.049730] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.058556] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.064768] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
[ 1.074652] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.081412] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.090299] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
[ 1.100464] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.107223] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.114910] omap8250 40a00000.serial: failed to get alias
[ 1.121012] printk: console [ttyS2] disabled
[ 1.125412] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 25, base_baud = 3000000) is a 8250
[ 1.134157] printk: console [ttyS2] enabled
[ 1.142593] printk: bootconsole [ns16550a0] disabled
[ 1.155201] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.200873] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.210072] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.218377] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.232263] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
[ 1.342058] gpio-mux mux-controller0: 2-way mux-controller registered
[ 1.342276] mmc0: CQHCI version 5.10
[ 1.352344] gpio-mux mux-controller1: 2-way mux-controller registered
[ 1.362412] vdd_mmc1: supplied by vsys_3v3
[ 1.367653] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 1.374480] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 1.381296] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 1.388095] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 1.391538] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.402183] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.409673] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.417754] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.425834] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.434315] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.440463] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.450392] ti-udma 31150000.dma-controller: Channels: 48 (tchan: 24, rchan: 24, gp-rflow: 16)
[ 1.462687] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.467665] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 1.474268] Creating 7 MTD partitions on "47040000.spi.0":
[ 1.479741] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.485805] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.491397] mmc0: Command Queue Engine enabled
[ 1.491613] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.495849] mmc0: new HS400 MMC card at address 0001
[ 1.501662] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.506515] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.511777] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.515978] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 1.522038] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.527610] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 1.533343] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.544558] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 1.560679] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 1.567135] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.612878] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.622050] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.630357] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.643799] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 1.650615] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.657831] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.664206] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
[ 1.674724] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.674887] mmc1: CQHCI version 5.10
[ 1.682230] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.693866] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.701952] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.710478] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.716696] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.724181] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 1.724188] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.739795] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.747936] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.756419] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.762537] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.770082] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.778218] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.786312] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.794791] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.800620] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
[ 1.808496] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
[ 1.820544] ALSA device list:
[ 1.823519] No soundcards found.
[ 1.827202] Waiting for root device PARTUUID=3b6e2d6a-02...
[ 1.864671] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.871612] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 1.881227] mmcblk1: p1 p2
[ 1.885467] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.892956] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.901041] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.909125] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.917609] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.969047] EXT4-fs (mmcblk1p2): recovery complete
[ 1.980531] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.988643] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 2.002904] devtmpfs: mounted
[ 2.006597] Freeing unused kernel memory: 1792K
[ 2.011241] Run /sbin/init as init process
[ 2.208068] systemd[1]: System time before build time, advancing clock.
[ 2.262264] NET: Registered protocol family 10
[ 2.267275] Segment Routing with IPv6
[ 2.296755] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 2.318519] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 2.364459] systemd[1]: Set hostname to <j721s2-evm>.
[ 2.562378] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock �� /run/docker.sock; please update the unit file accordingly.
[ 2.636276] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.643068] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.655398] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.665595] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 2.684980] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.692403] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 2.712966] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.720301] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 2.741114] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password ��ts to Console Directory Watch.
[ 2.765032] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R��uests to Wall Directory Watch.
[ 2.789026] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 2.804952] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 2.824934] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 2.840936] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 2.862649] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 2.885002] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 2.910140] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 2.933123] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 2.968243] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.976671] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 2.997280] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.017288] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.041196] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.061103] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.083604] systemd[1]: Mounting Huge Pages File System...
[ 3.107554] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.131471] systemd[1]: Mounting Kernel Debug File System...
[ 3.158910] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 3.183679] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st��odes for the current kernel...
[ 3.211386] systemd[1]: Starting Start psplash boot splash screen...
[ 3.237209] systemd[1]: Starting RPC Bind...
[ 3.253113] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.265410] systemd[1]: Starting Journal Service...
[ 3.291197] systemd[1]: Starting Load Kernel Modules...
[ 3.310487] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel.
[0m...
[ 3.332703] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 3.333367] cryptodev: driver 1.10 loaded.
[ 3.345080] systemd[1]: Starting udev Coldplug all Devices...
[ 3.364272] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 3.377381] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta�� nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star��progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 3.594136] systemd-journald[153]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started udev Coldplug all Devices.
[ 3.729546] urandom_read_iter: 47 callbacks suppressed
[ 3.729550] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Reached target Local File Systems (Pre).
[ 3.756995] random: systemd: uninitialized urandom read (16 bytes read)
Mounting /media/ram...
[ 3.770435] random: systemd-journal: uninitialized urandom read (16 bytes read)
Mounting /var/volatile...
Starting udev Wait for Complete Device Initialization...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ 4.245629] CAN device driver interface
[ 4.257037] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 4.265864] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 4.276167] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.287935] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.301078] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.310137] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 4.320652] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 4.336303] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.353014] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.369212] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.478740] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 4.514839] wave5: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.562282] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 4.570517] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 4.579752] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.591704] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.600407] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.645504] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 4.656959] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 4.672924] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.688044] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.701145] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.744006] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 4.751894] remoteproc remoteproc0: 64800000.dsp is available
[ 4.757703] remoteproc remoteproc0: attaching to 64800000.dsp
[ 4.763506] remoteproc remoteproc0: unsupported resource 65538
[ 4.766002] vdec 4210000.video-codec: sram daddr: 0x70020000, size: 0x1f800
[ 4.769626] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 4.783185] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 4.794511] PVR_K: 179: Read BVNC 36.53.104.796 from HW device registers
[ 4.796701] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 4.801365] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 4.834470] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 4.840724] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 4.848231] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 4.856318] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.864432] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.873126] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.883305] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[ 4.892307] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 4.900336] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 4.909233] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
[ 4.918952] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.927078] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.935649] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.942341] PVR_K: 179: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ 5.013562] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[ 5.020828] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 5.027949] remoteproc remoteproc1: 65800000.dsp is available
[ 5.093102] remoteproc remoteproc1: attaching to 65800000.dsp
[ 5.114802] vdec 4210000.video-codec: enum product_id : 00000000
[ 5.129028] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[ 5.162687] remoteproc remoteproc1: unsupported resource 65538
[ 5.169787] vdec 4210000.video-codec: fw_version : 00000000(r240897)
[ 5.177746] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 5.185337] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 5.194265] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 5.202887] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 5.212942] j721e-pcie 2910000.pcie: Failed to init phy
[ 5.222907] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 5.266900] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 5.268512] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[ 5.275595] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 5.292943] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 5.301103] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 5.313079] j721e-pcie 2910000.pcie: Failed to init phy
[ 5.321790] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 5.537099] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
[ 5.541085] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.622392] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 5.624133] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 5.656988] platform 41000000.r5f: configured R5F for IPC-only mode
[ 5.677051] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 5.680885] random: crng init done
[ 5.689572] random: 21 urandom warning(s) missed due to ratelimiting
[ 5.697413] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 5.697624] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 5.703757] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 5.703770] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 5.727310] remoteproc remoteproc2: 41000000.r5f is available
[ 5.732932] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 5.741778] j721e-pcie 2910000.pcie: Failed to init phy
[ 5.755389] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 5.758700] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
[ 5.761427] remoteproc remoteproc2: attaching to 41000000.r5f
[ 5.774696] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 5.784751] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 5.794734] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 5.801287] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 5.801486] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 5.823319] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[ 5.830952] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 5.839188] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 5.847386] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 5.856081] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[ 5.872650] j721e-pcie 2910000.pcie: Failed to init phy
[ 5.878728] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 5.888565] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 5.897542] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 5.913361] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 5.929611] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 5.940772] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 5.947140] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 5.960586] j721e-pcie 2910000.pcie: Failed to init phy
[ 5.971526] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 5.982478] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 5.992868] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 6.001856] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 6.011762] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 6.021629] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 6.027266] j721e-pcie 2910000.pcie: Failed to init phy
[ 6.044306] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
[ 6.064252] m_can_platform 40568000.can: m_can device registered (irq=21, version=32)
[ 6.085021] m_can_platform 2731000.can: m_can device registered (irq=33, version=32)
[ 6.103617] m_can_platform 2751000.can: m_can device registered (irq=35, version=32)
[ 6.124395] m_can_platform 26a1000.can: m_can device registered (irq=37, version=32)
[ 6.137799] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 6.150282] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 6.164972] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 6.180328] remoteproc remoteproc3: 5c00000.r5f is available
[ 6.186145] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 6.196622] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 6.208740] j721e-pcie 2910000.pcie: Failed to init phy
[ 6.235579] remoteproc remoteproc3: attaching to 5c00000.r5f
[ 6.275870] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 6.351230] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 6.440403] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 6.449261] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 6.499156] remoteproc3#vdev0buffer: registered virtio3 (type 7)
[ 6.505408] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 6.513585] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 6.521126] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 6.536914] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 6.545042] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 6.565206] j721e-pcie 2910000.pcie: Failed to init phy
[ 6.581638] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
[ 6.596703] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 6.641546] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 6.679113] remoteproc remoteproc4: 5d00000.r5f is available
[ 6.693815] remoteproc remoteproc4: attaching to 5d00000.r5f
[ 6.704703] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 6.774969] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 6.885396] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 6.894174] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 6.901407] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 6.913026] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.924911] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 6.934763] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.945798] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ 6.952824] remoteproc4#vdev0buffer: registered virtio4 (type 7)
[ 6.957008] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.959134] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 6.970512] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 6.979717] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 6.987270] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.003074] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.014939] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.029095] j721e-pcie 2910000.pcie: Failed to init phy
[ 7.061116] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
[ 7.111983] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 7.121520] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.129112] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.145486] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.147760] platform 5e00000.r5f: configured R5F for IPC-only mode
[ 7.158410] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.173358] j721e-pcie 2910000.pcie: Failed to init phy
[ 7.207814] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 7.224125] remoteproc remoteproc5: 5e00000.r5f is available
[ 7.292623] remoteproc remoteproc5: attaching to 5e00000.r5f
[ 7.332855] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[ 7.344653] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached
[ 7.395433] platform 5f00000.r5f: configured R5F for IPC-only mode
[ 7.407115] usbcore: registered new interface driver usbfs
[ 7.421699] usbcore: registered new interface driver hub
[ 7.452999] usbcore: registered new device driver usb
[ 7.459558] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 7.498824] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 7.507020] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.514534] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.519426] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 7.532927] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.541100] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.555294] j721e-pcie 2910000.pcie: Failed to init phy
[ 7.563115] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 7.573816] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.581353] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.596942] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.606375] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.616975] j721e-pcie 2910000.pcie: Failed to init phy
[ 7.629928] remoteproc remoteproc6: 5f00000.r5f is available
[ 7.640551] remoteproc remoteproc6: attaching to 5f00000.r5f
[ 7.649874] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 7.650093] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[ 7.659736] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.665874] remoteproc remoteproc6: remote processor 5f00000.r5f is now attached
[ 7.676922] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.693166] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.708314] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.724412] j721e-pcie 2910000.pcie: Failed to init phy
[ 7.737599] cdns-mhdp8546 a000000.dp-bridge: no PHY configured
[ 7.749413] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 7.760944] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 7.772939] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 7.784938] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 7.798619] j721e-pcie 2910000.pcie: Failed to init phy
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Found device /dev/mmcblk1p1.
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Telephony service...
Starting rc.pvr.service...
Starting Login Service...
[ OK ] Started TEE Supplicant.
[ OK ] Started Reboot and dump vmcore via kexec.
E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8b1522000
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Reached target Network (Pre).
Starting Network Service...
[ OK ] Started Telephony service.
[ 8.568415] Bluetooth: Core ver 2.22
[ 8.572236] NET: Registered protocol family 31
[ 8.579258] Bluetooth: HCI device and connection manager initialized
[ 8.589701] Bluetooth: HCI socket layer initialized
[ 8.597380] Bluetooth: L2CAP socket layer initialized
[ 8.605603] Bluetooth: SCO socket layer initialized
[ OK ] Started File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ OK ] Listening on Load/Save RF ��itch Status /dev/rfkill Watch.
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Mounted /run/media/mmcblk1p1.
[ OK ] Started Login Service.
[ OK ] Started Network Service.
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ 8.942576] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 8.988432] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma��ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Simple Network Man��ement Protocol (SNMP) Daemon..
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav-dev
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libidn2-0
libidn2-dev
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring-dev
libunistring2
m4-dev
m4
make
nettle-dev
nettle
parted
python3-rfc3987
python3-strict-rfc3339
tar
which
zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started weston.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
[ 12.109360] PVR_K: 1002: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[ 12.139989] PVR_K: 1002: Shader binary image 'rgx.sh.36.53.104.796' loaded
[ 13.491574] PVR_K:(Error): 7: RGXSafetyEventHandler: Safety Watchdog Trigger ! [358]
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j721s2-evm ttyS2
Arago 2021.09 j721s2-evm ttyS2
j721s2-evm login:
uboot build log:
Building U-boot for A72
Building U-boot for R5
make -j 4 -C /home/yihao/work/local/work/work/tda4/test/board-support/u-boot-* CROSS_COMPILE=/home/yihao/work/local/work/work/tda4/test/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-none-linux-gnu- \
j721s2_evm_a72_defconfig O=/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/a72
make -j 4 -C /home/yihao/work/local/work/work/tda4/test/board-support/u-boot-* CROSS_COMPILE=/home/yihao/work/local/work/work/tda4/test/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-none-linux-gnueabihf- \
j721s2_evm_r5_config O=/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/r5
make[1]: warning: -jN forced in submake: disabling jobserver mode.
make[1]: Entering directory '/home/yihao/work/local/work/work/tda4/test/board-support/u-boot-2021.01+gitAUTOINC+62a9e51344-g62a9e51344'
make[2]: Entering directory '/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/a72'
make[2]: Entering directory '/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/r5'
GEN ./Makefile
GEN ./Makefile
# configuration written to .config
make[2]: Leaving directory '/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/r5'
make[1]: Leaving directory '/home/yihao/work/local/work/work/tda4/test/board-support/u-boot-2021.01+gitAUTOINC+62a9e51344-g62a9e51344'
make[2]: Leaving directory '/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/a72'
CONFIG_MKIMAGE_DTC_PATH=/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/a72/scripts/dtc/dtc \
ATF=/home/yihao/work/local/work/work/tda4/test/board-support/prebuilt-images/bl31.bin TEE=/home/yihao/work/local/work/work/tda4/test/board-support/prebuilt-images/bl32.bin DM=/home/yihao/work/local/work/work/tda4/test/board-support/prebuilt-images/ipc_echo_testb_mcu1_0_release_strip.xer5f \
GEN ./Makefile
GEN ./Makefile
scripts/kconfig/conf --syncconfig Kconfig
CFG u-boot.cfg
CFG spl/u-boot.cfg
GEN include/autoconf.mk.dep
GEN spl/include/autoconf.mk
CFG u-boot.cfg
CFG spl/u-boot.cfg
GEN ./Makefile
CFGCHK u-boot.cfg
UPD include/generated/timestamp_autogenerated.h
===================== WARNING ======================
This board does not use CONFIG_DM_ETH (Driver Model
for Ethernet drivers). Please update the board to use
CONFIG_DM_ETH before the v2020.07 release. Failure to
GEN ./Makefile
update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
CFGCHK u-boot.cfg
Using /home/yihao/work/local/work/work/tda4/test/board-support/u-boot-2021.01+gitAUTOINC+62a9e51344-g62a9e51344 as source for U-Boot
HOSTCC tools/mkenvimage.o
HOSTCC tools/fit_image.o
HOSTCC tools/image-host.o
HOSTCC tools/dumpimage.o
HOSTCC tools/mkimage.o
HOSTLD tools/mkenvimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
CC arch/arm/cpu/armv8/fwcall.o
LD arch/arm/cpu/armv8/built-in.o
CC cmd/version.o
CC common/main.o
LD cmd/built-in.o
LD common/built-in.o
CC drivers/fastboot/fb_getvar.o
CC cmd/version.o
CC common/main.o
LD drivers/fastboot/built-in.o
LD cmd/built-in.o
LD drivers/built-in.o
CC lib/smbios.o
CC lib/display_options.o
CC lib/smbios.o
LD lib/built-in.o
LD u-boot
LD lib/built-in.o
LD u-boot
OBJCOPY u-boot-nodtb.bin
OBJCOPY u-boot.srec
SYM u-boot.sym
OBJCOPY u-boot.srec
RELOC u-boot-nodtb.bin
SYM u-boot.sym
DTC arch/arm/dts/k3-am68-sk-base-board.dtb
DTC arch/arm/dts/k3-am68-sk-r5-base-board.dtb
DTC arch/arm/dts/k3-j721s2-common-proc-board.dtb
SECURE u-boot-nodtb.bin_HS
DTC arch/arm/dts/k3-j721s2-r5-common-proc-board.dtb
SHIPPED dts/dt.dtb
FDTGREP dts/dt-spl.dtb
SHIPPED dts/dt.dtb
MKIMAGE u-boot.img
SECURE arch/arm/dts/k3-j721s2-r5-common-proc-board.dtb_HS
MKIMAGE fit-dtb.blob
MKIMAGE u-boot.img
SECURE arch/arm/dts/k3-j721s2-common-proc-board.dtb_HS
SECURE arch/arm/dts/k3-am68-sk-base-board.dtb_HS
COPY u-boot.dtb
MKIMAGE u-boot-dtb.img
COPY u-boot.dtb
MKIMAGE u-boot.img_HS
CAT u-boot-fit-dtb.bin
COPY u-boot.bin
COPY u-boot.bin
MKITS u-boot-spl-k3_HS.its
CC spl/arch/arm/cpu/armv8/fwcall.o
LD spl/arch/arm/cpu/armv8/built-in.o
CC spl/common/spl/spl.o
FDTGREP spl/dts/k3-am68-sk-r5-base-board.dtb
SHIPPED dts/dt.dtb
CC spl/lib/display_options.o
LD spl/common/spl/built-in.o
FDTGREP spl/dts/k3-j721s2-common-proc-board.dtb
FDTGREP spl/dts/k3-am68-sk-base-board.dtb
LD spl/lib/built-in.o
SECURE spl/dts/k3-j721s2-common-proc-board.dtb_HS
SHIPPED dts/dt.dtb
SECURE spl/dts/k3-am68-sk-base-board.dtb_HS
MKIMAGE spl/u-boot-spl.multidtb.fit
FDTGREP spl/dts/k3-j721s2-r5-common-proc-board.dtb
LD spl/u-boot-spl
LD spl/u-boot-spl
SYM spl/u-boot-spl.sym
OBJCOPY spl/u-boot-spl-nodtb.bin
SECURE spl/u-boot-spl-nodtb.bin_HS
CAT spl/u-boot-spl-dtb.bin
COPY spl/u-boot-spl.bin
MKIMAGE tispl.bin_HS
MKIMAGE tispl.bin
FIT description: Configuration to load ATF and SPL
Created: Thu Sep 14 11:47:15 2023
Image 0 (atf)
Description: ARM Trusted Firmware
Type: Firmware
Compression: uncompressed
Data Size: 43968 Bytes = 42.94 KiB = 0.04 MiB
Architecture: AArch64
OS: ARM Trusted Firmware
Load Address: 0x70000000
Image 1 (tee)
Description: OPTEE
Type: Trusted Execution Environment Image
Data Size: 428160 Bytes = 418.12 KiB = 0.41 MiB
Image 2 (dm)
Description: DM binary
Type: Firmware
Data Size: 236844 Bytes = 231.29 KiB = 0.23 MiB
Architecture: Unknown Architecture
OS: Unknown OS
Load Address: 0x89000000
Image 3 (spl)
Description: SPL (64-bit)
Type: Standalone Program
Data Size: 257273 Bytes = 251.24 KiB = 0.25 MiB
Load Address: 0x80080000
Entry Point: 0x80080000
Image 4 (k3-j721s2-common-proc-board.dtb)
Description: k3-j721s2-common-proc-board
Type: Flat Device Tree
Data Size: 11714 Bytes = 11.44 KiB = 0.01 MiB
Architecture: ARM
Image 5 (k3-am68-sk-base-board.dtb)
Description: k3-am68-sk-base-board
Data Size: 9791 Bytes = 9.56 KiB = 0.01 MiB
Architecture: ARM
Default Configuration: 'k3-j721s2-common-proc-board.dtb'
Configuration 0 (k3-j721s2-common-proc-board.dtb)
Kernel: unavailable
Firmware: atf
FDT: k3-j721s2-common-proc-board.dtb
Loadables: tee
dm
spl
Configuration 1 (k3-am68-sk-base-board.dtb)
Kernel: unavailable
Firmware: atf
FDT: k3-am68-sk-base-board.dtb
Loadables: tee
dm
spl
Image 0 (atf)
Type: Firmware
Image 1 (tee)
Description: OPTEE
Image 2 (dm)
Type: Firmware
OS: Unknown OS
Image 3 (spl)
Architecture: ARM
Architecture: ARM
Kernel: unavailable
Firmware: atf
Loadables: tee
dm
spl
Kernel: unavailable
Firmware: atf
Loadables: tee
dm
spl
/home/yihao/work/local/work/work/tda4/test/board-support/u-boot-2021.01+gitAUTOINC+62a9e51344-g62a9e51344/tools/k3_gen_x509_cert.sh -c 16 -b spl/u-boot-spl.bin \
-o tiboot3.bin -l 0x41c00000 -r 1 -k /home/yihao/work/local/work/work/tda4/test/board-support/core-secdev-k3/keys/custMpk.pem
SWRV = 1
make sysfw-image
make[1]: Entering directory '/home/yihao/work/local/work/work/tda4/test'
Building SYSFW Image
make -j 4 -C /home/yihao/work/local/work/work/tda4/test/board-support/k3-image-gen-* \
SBL=/home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/r5/spl/u-boot-spl.bin SYSFW_DIR=/home/yihao/work/local/work/work/tda4/test/board-support/prebuilt-images SCIFS="fs" SOC=j721s2 SOC_TYPE=gp CONFIG=evm CROSS_COMPILE=/home/yihao/work/local/work/work/tda4/test/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-none-linux-gnueabihf-
make[2]: Entering directory '/home/yihao/work/local/work/work/tda4/test'
make[2]: warning: -jN forced in submake: disabling jobserver mode.
./scripts/gen_x509_combined_cert.sh -b /home/yihao/work/local/work/work/tda4/test/board-support/u-boot_build/r5/spl/u-boot-spl.bin -l 0x41c00000 -s /home/yihao/work/local/work/work/tda4/test/board-support/prebuilt-images/ti-fs-firmware-j721s2-gp.bin -m 0x40000 -c "" -d out/soc/j721s2/evm/combined-tifs-cfg.bin -n 0x67000 -t out/soc/j721s2/evm/combined-dm-cfg.bin -y 0x41c80000 -k ti-degenerate-key.pem -r 1 -o tiboot3-j721s2-gp-evm.bin
Certificate being generated :
SUCCESS: Image tiboot3-j721s2-gp-evm.bin generated.
make[2]: Leaving directory '/home/yihao/work/local/work/work/tda4/test/board-support/k3-image-gen-2022.01'
make[1]: Leaving directory '/home/yihao/work/local/work/work/tda4/test'
prebuilt image we metioned: dr-download.ti.com/.../ti-processor-sdk-rtos-j721s2-evm-08_04_00_06-prebuilt.tar.gz
SDK version:
RTOS: 08.04.00.06 link: www.ti.com/.../08.04.00.06
LINUX: 08.04.00.13 link: https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-J721S2/08.04.00.13
