Part Number: TDA4VM
Hello Champs,
Customer is using the TDA4VM EVM board, the PSDK is 08-06-010-03 and device-tree is k3-j721e-common-proc-board.dts,He doesn't change the dts, it stuck at below.
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 11:24:40, May 30 2023
ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue May 30 11:24:46 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue May 30 11:26:02 UTC 2023
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000adffffff]
[ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[ 0.000000] Memory: 3271292K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 398724K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008396] Console: colour dummy device 80x25
[ 0.012963] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023633] pid_max: default: 32768 minimum: 301
[ 0.028390] LSM: Security Framework initializing
[ 0.033146] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040724] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049583] rcu: Hierarchical SRCU implementation.
[ 0.054660] Platform MSI: msi-controller@1820000 domain created
[ 0.060911] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070215] EFI services will not be available.
[ 0.074938] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.093927] Detected PIPT I-cache on CPU1
[ 0.093951] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.093963] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
[ 0.093995] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.094045] smp: Brought up 1 node, 2 CPUs
[ 0.123390] SMP: Total of 2 processors activated.
[ 0.128195] CPU features: detected: 32-bit EL0 Support
[ 0.133450] CPU features: detected: CRC32 instructions
[ 0.147668] CPU: All CPU(s) started at EL2
[ 0.151862] alternatives: patching kernel code
[ 0.156960] devtmpfs: initialized
[ 0.165948] KASLR disabled due to lack of seed
[ 0.170599] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.180563] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.194030] pinctrl core: initialized pinctrl subsystem
[ 0.199692] DMI not present or invalid.
[ 0.203943] NET: Registered protocol family 16
[ 0.209179] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.216500] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.224568] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.232880] thermal_sys: Registered thermal governor 'step_wise'
[ 0.232882] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.239480] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.253116] ASID allocator initialised with 32768 entries
[ 0.277761] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.284617] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.291463] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.298308] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.305777] cryptd: max_cpu_qlen set to 1000
[ 0.311922] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[ 0.320751] vsys_3v3: supplied by evm_12v0
[ 0.325117] vsys_5v0: supplied by evm_12v0
[ 0.329885] iommu: Default domain type: Translated
[ 0.335063] SCSI subsystem initialized
[ 0.339232] mc: Linux media interface: v0.10
[ 0.343608] videodev: Linux video capture interface: v2.00
[ 0.349244] pps_core: LinuxPPS API ver. 1 registered
[ 0.354315] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.363652] PTP clock support registered
[ 0.367674] EDAC MC: Ver: 3.0.0
[ 0.371486] FPGA manager framework
[ 0.374994] Advanced Linux Sound Architecture Driver Initialized.
[ 0.381585] clocksource: Switched to clocksource arch_sys_counter
[ 0.387911] VFS: Disk quotas dquot_6.6.0
[ 0.391942] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.401550] NET: Registered protocol family 2
[ 0.406301] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.414896] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.423655] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.431857] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.439674] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.446481] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.453377] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.460775] NET: Registered protocol family 1
[ 0.465501] RPC: Registered named UNIX socket transport module.
[ 0.471564] RPC: Registered udp transport module.
[ 0.476368] RPC: Registered tcp transport module.
[ 0.481171] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.487753] NET: Registered protocol family 44
[ 0.492299] PCI: CLS 0 bytes, default 64
[ 0.496678] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.507124] Initialise system trusted keyrings
[ 0.511751] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.519904] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.526173] NFS: Registering the id_resolver key type
[ 0.531361] Key type id_resolver registered
[ 0.535631] Key type id_legacy registered
[ 0.539752] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.546601] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.554240] 9p: Installing v9fs 9p2000 file system support
[ 0.579312] Key type asymmetric registered
[ 0.583499] Asymmetric key parser 'x509' registered
[ 0.588497] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.596056] io scheduler mq-deadline registered
[ 0.600681] io scheduler kyber registered
[ 0.606459] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.612651] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.621802] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.628226] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.636218] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.642641] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.650587] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.657005] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.664935] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.671260] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.679212] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.685538] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.695297] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.703616] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.711911] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.719003] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.727585] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.740890] brd: module loaded
[ 0.747482] loop: module loaded
[ 0.751233] megasas: 07.714.04.00-rc1
[ 0.757069] tun: Universal TUN/TAP device driver, 1.6
[ 0.762548] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.768957] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.775031] sky2: driver version 1.30
[ 0.779406] VFIO - User Level meta-driver version: 0.3
[ 0.785202] i2c /dev entries driver
[ 0.789730] sdhci: Secure Digital Host Controller Interface driver
[ 0.796050] sdhci: Copyright(c) Pierre Ossman
[ 0.800716] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.807141] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.813500] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.820914] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.825477] optee: revision 3.20 (8e74d476)
[ 0.841884] optee: dynamic shared memory is enabled
[ 0.851344] optee: initialized driver
[ 0.856576] NET: Registered protocol family 17
[ 0.861201] 9pnet: Installing 9P2000 support
[ 0.865604] Key type dns_resolver registered
[ 0.870056] Loading compiled-in X.509 certificates
[ 0.883922] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[ 0.937996] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.945701] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.951776] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.958195] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.964653] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.971474] pca953x 3-0020: using no AI
[ 0.998472] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 1.005279] pca953x 3-0022: using AI
[ 1.009556] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 1.015534] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 1.021775] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 1.028270] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.034748] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.044654] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.050993] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 1.057826] pca953x 6-0020: using no AI
[ 1.086272] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 1.092378] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.098341] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 1.104594] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 1.111414] pca953x 9-0020: using no AI
[ 1.137917] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 1.144395] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.154365] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.163156] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.172987] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.194282] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.201956] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.210233] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.218509] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.234140] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.240555] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.246161] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.255852] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.262906] pci 0000:00:00.0: [104c:b00d] type 00 class 0x060400
[ 2.269045] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.278915] pci 0000:00:00.0: ignoring class 0x060400 (doesn't match header type 00)
[ 2.286890] pci 0000:00:00.0: supports D1
[ 2.290984] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.296871] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 2.303899] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 2.313896] pci 0000:00:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x2 link at 0000:00:00.0 (capable of 31.506 Gb/s with 16.0 GT/s PCIe x2 link)
[ 2.331697] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.339371] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.347651] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.355927] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.464912] cdns-sierra-phy 5010000.serdes: Timeout waiting for PHY status ready
[ 2.472476] phy phy-5010000.serdes.11: phy poweron failed --> -110
[ 2.478792] j721e-pcie 2910000.pcie: Failed to init phy
[ 2.484161] j721e-pcie: probe of 2910000.pcie failed with error -110
[ 2.490993] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 2.498660] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 2.506937] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 2.515213] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
Shine
