Device: AM62x SKEVM PROC114E3
Installer: ti-processor-sdk-linux-am62xx-evm-09.00.00.03-Linux-x86-Install.bin — 6664936 K
SD card image: tisdk-debian-bookworm-am62xx-evm.wic.xz — 1955030 K
I used the method mentioned in this thread on the default code to create a boot sd card, but a Failed to start ssh.service error appeared.
U-Boot SPL 2023.04 (Sep 19 2023 - 17:03:44 +0800)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 00:42:57, Jan 13 2023
U-Boot SPL 2023.04 (Sep 19 2023 - 17:03:52 +0800)
SPL initial stack usage: 1856 bytes
Error (-2): cannot determine file size
U-Boot 2023.04 (Sep 19 2023 - 17:03:52 +0800)
SoC: AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 80, trying to read at 81
Board: AM62-SKEVM rev E3
DRAM: 2 GiB
Core: 71 devices, 31 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
## Error: "main_cpsw0_qsgmii_phyinit" not defined
20593152 bytes read in 230 ms (85.4 MiB/s)
57500 bytes read in 16 ms (3.4 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.33 (root@andrew-GENESYS-CML5) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Tue Sep 19 15:49:00 CST 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=a0ea9fb9-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1838092K/2097152K available (12480K kernel code, 1294K rwdata, 4040K rodata, 2176K init, 498K bss, 127988K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008544] Console: colour dummy device 80x25
[ 0.013138] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023820] pid_max: default: 32768 minimum: 301
[ 0.028593] LSM: Security Framework initializing
[ 0.033448] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.041033] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.050864] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.058327] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.064632] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.071034] rcu: Hierarchical SRCU implementation.
[ 0.075941] rcu: Max phase no-delay instances is 1000.
[ 0.081551] Platform MSI: msi-controller@1820000 domain created
[ 0.087870] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.097707] EFI services will not be available.
[ 0.102639] smp: Bringing up secondary CPUs ...
[ 0.107956] Detected VIPT I-cache on CPU1
[ 0.108074] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.108093] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[ 0.108151] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.108875] Detected VIPT I-cache on CPU2
[ 0.108955] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.108968] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
[ 0.109004] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.109651] Detected VIPT I-cache on CPU3
[ 0.109731] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.109744] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
[ 0.109776] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.109850] smp: Brought up 1 node, 4 CPUs
[ 0.189583] SMP: Total of 4 processors activated.
[ 0.194397] CPU features: detected: 32-bit EL0 Support
[ 0.199671] CPU features: detected: CRC32 instructions
[ 0.204994] CPU: All CPU(s) started at EL2
[ 0.209192] alternatives: applying system-wide alternatives
[ 0.216797] devtmpfs: initialized
[ 0.228379] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.238381] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.249946] pinctrl core: initialized pinctrl subsystem
[ 0.255939] DMI not present or invalid.
[ 0.260514] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.267791] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.275356] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.283473] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.291662] audit: initializing netlink subsys (disabled)
[ 0.297370] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[ 0.297853] thermal_sys: Registered thermal governor 'step_wise'
[ 0.305302] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.311491] cpuidle: using governor menu
[ 0.322362] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.329397] ASID allocator initialised with 65536 entries
[ 0.345760] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.356997] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.367944] KASLR disabled due to lack of seed
[ 0.379704] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.386677] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.393088] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.400028] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.406436] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.413374] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.419782] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.426721] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.434926] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.445023] iommu: Default domain type: Translated
[ 0.450083] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.456788] SCSI subsystem initialized
[ 0.461004] usbcore: registered new interface driver usbfs
[ 0.466660] usbcore: registered new interface driver hub
[ 0.472152] usbcore: registered new device driver usb
[ 0.477887] pps_core: LinuxPPS API ver. 1 registered
[ 0.482969] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.492321] PTP clock support registered
[ 0.496452] EDAC MC: Ver: 3.0.0
[ 0.500606] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.507746] FPGA manager framework
[ 0.511328] Advanced Linux Sound Architecture Driver Initialized.
[ 0.518588] clocksource: Switched to clocksource arch_sys_counter
[ 0.525087] VFS: Disk quotas dquot_6.6.0
[ 0.529143] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.542158] NET: Registered PF_INET protocol family
[ 0.547460] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.556711] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.565521] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.573458] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.581661] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.589655] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.596576] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.603501] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.611051] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.617319] RPC: Registered named UNIX socket transport module.
[ 0.623396] RPC: Registered udp transport module.
[ 0.628207] RPC: Registered tcp transport module.
[ 0.633015] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.639606] NET: Registered PF_XDP protocol family
[ 0.644519] PCI: CLS 0 bytes, default 64
[ 0.649352] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.659448] Initialise system trusted keyrings
[ 0.664277] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.676731] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.683443] NFS: Registering the id_resolver key type
[ 0.688691] Key type id_resolver registered
[ 0.692968] Key type id_legacy registered
[ 0.697134] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.703990] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.711754] 9p: Installing v9fs 9p2000 file system support
[ 0.753350] Key type asymmetric registered
[ 0.757540] Asymmetric key parser 'x509' registered
[ 0.762597] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.770326] io scheduler mq-deadline registered
[ 0.774966] io scheduler kyber registered
[ 0.782317] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.788895] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.795704] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.809344] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.824238] loop: module loaded
[ 0.828791] megasas: 07.719.03.00-rc1
[ 0.836668] tun: Universal TUN/TAP device driver, 1.6
[ 0.842627] thunder_xcv, ver 1.0
[ 0.845958] thunder_bgx, ver 1.0
[ 0.849287] nicpf, ver 1.0
[ 0.852475] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.859866] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.865358] hclge is initializing
[ 0.868773] e1000: Intel(R) PRO/1000 Network Driver
[ 0.873761] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.879672] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.884748] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.890833] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.896354] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.902077] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.908486] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.914682] sky2: driver version 1.30
[ 0.919156] VFIO - User Level meta-driver version: 0.3
[ 0.925246] usbcore: registered new interface driver usb-storage
[ 0.932188] i2c_dev: i2c /dev entries driver
[ 0.938805] sdhci: Secure Digital Host Controller Interface driver
[ 0.945163] sdhci: Copyright(c) Pierre Ossman
[ 0.950115] Synopsys Designware Multimedia Card Interface Driver
[ 0.956705] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.963558] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.969912] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.976882] usbcore: registered new interface driver usbhid
[ 0.982587] usbhid: USB HID core driver
[ 0.987839] optee: probing for conduit method.
[ 0.992447] optee: revision 3.20 (8e74d476)
[ 0.992772] optee: dynamic shared memory is enabled
[ 1.002305] optee: initialized driver
[ 1.007909] Initializing XFRM netlink socket
[ 1.012343] NET: Registered PF_PACKET protocol family
[ 1.017660] 9pnet: Installing 9P2000 support
[ 1.022204] Key type dns_resolver registered
[ 1.027068] registered taskstats version 1
[ 1.031294] Loading compiled-in X.509 certificates
[ 1.045120] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
[ 1.108715] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.116293] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.123387] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.129365] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.137721] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.146954] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.156892] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.165098] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.176261] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.186320] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.196630] printk: console [ttyS2] disabled
[ 1.201090] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3000000) is a 8250
[ 1.209989] printk: console [ttyS2] enabled
[ 1.218447] printk: bootconsole [ns16550a0] disabled
[ 1.231555] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.236646] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.243605] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.248998] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.255719] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.262232] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.268716] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.274939] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.281743] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.288305] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.296676] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.342613] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.352494] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.360606] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.368730] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.381586] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.388712] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.395226] pps pps0: new PPS source ptp0
[ 1.399531] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.410017] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.421425] mmc0: CQHCI version 5.10
[ 1.427919] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.434678] pca953x 1-0022: using AI
[ 1.466507] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.468254] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.482305] mmc2: CQHCI version 5.10
[ 1.482316] mmc1: CQHCI version 5.10
[ 1.495585] ALSA device list:
[ 1.498615] No soundcards found.
[ 1.515999] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.530766] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.538674] Waiting for root device PARTUUID=a0ea9fb9-02...
[ 1.563251] mmc0: Command Queue Engine enabled
[ 1.567731] mmc0: new HS200 MMC card at address 0001
[ 1.570270] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 1.573603] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.580295] mmcblk1: mmc1:59b4 USDU1 14.9 GiB
[ 1.585747] mmcblk0: p1 p2
[ 1.590464] mmcblk1: p1 p2
[ 1.591833] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.600060] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.605987] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 1.795588] EXT4-fs (mmcblk1p2): recovery complete
[ 1.801139] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.809762] VFS: Mounted root (ext4 filesystem) on device 179:34.
[ 1.818698] devtmpfs: mounted
[ 1.823132] Freeing unused kernel memory: 2176K
[ 1.827763] Run /sbin/init as init process
[ 2.053277] systemd[1]: System time before build time, advancing clock.
[ 2.110265] NET: Registered PF_INET6 protocol family
[ 2.117029] Segment Routing with IPv6
[ 2.120798] In-situ OAM (IOAM) with IPv6
[ 2.171003] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.184583] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.202872] systemd[1]: systemd 252.6-1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 2.234864] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 12 (bookworm)!
[ 2.252825] systemd[1]: Hostname set to <am62xx>.
[ 2.491392] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.506059] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.526170] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.540702] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.557369] systemd[1]: Configuration file /etc/systemd/system/weston.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.571787] systemd[1]: Configuration file /etc/systemd/system/weston.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.589690] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.603901] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.620731] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.635020] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.651390] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.665584] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.681734] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.696002] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.714806] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.730388] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.749020] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.764809] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.786162] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.801504] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.820187] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.834717] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.851409] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.866026] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.882925] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.897974] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.915571] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.929839] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.947604] systemd[1]: Configuration file /lib/systemd/system/systemd-pcrphase-initrd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.963450] systemd[1]: Configuration file /lib/systemd/system/systemd-pcrphase-initrd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 2.982457] systemd[1]: Configuration file /lib/systemd/system/systemd-sysext.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.997526] systemd[1]: Configuration file /lib/systemd/system/systemd-sysext.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.015546] systemd[1]: Configuration file /lib/systemd/system/cryptsetup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.030166] systemd[1]: Configuration file /lib/systemd/system/cryptsetup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.046954] systemd[1]: Configuration file /lib/systemd/system/cryptsetup-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.061912] systemd[1]: Configuration file /lib/systemd/system/cryptsetup-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.079236] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.094453] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.112612] systemd[1]: Configuration file /lib/systemd/system/initrd-usr-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.127496] systemd[1]: Configuration file /lib/systemd/system/initrd-usr-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.145004] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.160309] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.179475] systemd[1]: Configuration file /lib/systemd/system/remote-veritysetup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.194795] systemd[1]: Configuration file /lib/systemd/system/remote-veritysetup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.212579] systemd[1]: Configuration file /lib/systemd/system/veritysetup-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.227643] systemd[1]: Configuration file /lib/systemd/system/veritysetup-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.245005] systemd[1]: Configuration file /lib/systemd/system/veritysetup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.259701] systemd[1]: Configuration file /lib/systemd/system/veritysetup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.276301] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.291166] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.308568] systemd[1]: Configuration file /lib/systemd/system/remote-cryptsetup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.323783] systemd[1]: Configuration file /lib/systemd/system/remote-cryptsetup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.341332] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.356567] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.376401] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.390691] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.407850] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.423516] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.442061] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.457893] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.477240] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.491780] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.508765] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.523727] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.542477] systemd[1]: Configuration file /lib/systemd/system/systemd-repart.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.557549] systemd[1]: Configuration file /lib/systemd/system/systemd-repart.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.575629] systemd[1]: Configuration file /lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.590253] systemd[1]: Configuration file /lib/systemd/system/modprobe@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.608126] systemd[1]: Configuration file /lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.622757] systemd[1]: Configuration file /lib/systemd/system/modprobe@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.639247] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.655235] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.674798] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.690280] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.708645] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.724214] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.742715] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.758189] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.776447] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.792017] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.810508] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.825477] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.844563] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.859801] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.877985] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.893398] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.911815] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.926607] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.943982] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.959284] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.977535] systemd[1]: Configuration file /lib/systemd/system/systemd-fsckd.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.992415] systemd[1]: Configuration file /lib/systemd/system/systemd-fsckd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.010066] systemd[1]: Configuration file /lib/systemd/system/systemd-fsckd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.025040] systemd[1]: Configuration file /lib/systemd/system/systemd-fsckd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.042684] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.058077] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.076325] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.090794] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.107455] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.121898] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.139825] systemd[1]: Configuration file /lib/systemd/system/man-db.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.154032] systemd[1]: Configuration file /lib/systemd/system/man-db.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.176813] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.191382] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.208353] systemd[1]: Configuration file /lib/systemd/system/man-db.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.222724] systemd[1]: Configuration file /lib/systemd/system/man-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.239830] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.255601] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.274458] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.288922] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.305560] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.320190] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.337403] systemd[1]: Configuration file /lib/systemd/system/fstrim.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.351603] systemd[1]: Configuration file /lib/systemd/system/fstrim.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.368058] systemd[1]: Configuration file /lib/systemd/system/fstrim.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.382435] systemd[1]: Configuration file /lib/systemd/system/fstrim.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.400008] systemd[1]: Configuration file /lib/systemd/system/e2scrub_all.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.414648] systemd[1]: Configuration file /lib/systemd/system/e2scrub_all.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.431592] systemd[1]: Configuration file /lib/systemd/system/e2scrub_all.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.446411] systemd[1]: Configuration file /lib/systemd/system/e2scrub_all.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.463388] systemd[1]: Configuration file /lib/systemd/system/dpkg-db-backup.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.478278] systemd[1]: Configuration file /lib/systemd/system/dpkg-db-backup.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.495890] systemd[1]: Configuration file /lib/systemd/system/dpkg-db-backup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.510947] systemd[1]: Configuration file /lib/systemd/system/dpkg-db-backup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.528654] systemd[1]: Configuration file /lib/systemd/system/apt-daily.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.543100] systemd[1]: Configuration file /lib/systemd/system/apt-daily.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.560183] systemd[1]: Configuration file /lib/systemd/system/apt-daily.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.574825] systemd[1]: Configuration file /lib/systemd/system/apt-daily.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.592125] systemd[1]: Configuration file /lib/systemd/system/NetworkManager.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.607207] systemd[1]: Configuration file /lib/systemd/system/NetworkManager.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.624913] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.639115] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.655497] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.670216] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.687277] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.702495] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.722085] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.737159] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.755141] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.770707] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.789428] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.804572] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.822188] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.837150] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.855475] systemd[1]: Configuration file /lib/systemd/system/networking.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.870195] systemd[1]: Configuration file /lib/systemd/system/networking.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.887622] systemd[1]: Configuration file /lib/systemd/system/ifupdown-pre.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.902517] systemd[1]: Configuration file /lib/systemd/system/ifupdown-pre.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.919887] systemd[1]: Configuration file /lib/systemd/system/NetworkManager-wait-online.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.935976] systemd[1]: Configuration file /lib/systemd/system/NetworkManager-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.955207] systemd[1]: Configuration file /lib/systemd/system/network.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.969561] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.985966] systemd[1]: Configuration file /lib/systemd/system/apt-daily-upgrade.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.001098] systemd[1]: Configuration file /lib/systemd/system/apt-daily-upgrade.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.019231] systemd[1]: Configuration file /lib/systemd/system/apt-daily-upgrade.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.034544] systemd[1]: Configuration file /lib/systemd/system/apt-daily-upgrade.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.052814] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.067192] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.085068] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.100179] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.117941] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.133126] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.150705] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.165055] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.185759] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.201284] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.220193] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.236325] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.256175] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.271485] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.291758] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.307263] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.326084] systemd[1]: Configuration file /lib/systemd/system/first-boot-complete.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.341498] systemd[1]: Configuration file /lib/systemd/system/first-boot-complete.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.359544] systemd[1]: Configuration file /lib/systemd/system/systemd-pstore.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.374590] systemd[1]: Configuration file /lib/systemd/system/systemd-pstore.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.392560] systemd[1]: Configuration file /lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.407193] systemd[1]: Configuration file /lib/systemd/system/modprobe@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.423725] systemd[1]: Configuration file /lib/systemd/system/systemd-pcrphase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.438937] systemd[1]: Configuration file /lib/systemd/system/systemd-pcrphase.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.456865] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.471398] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.488309] systemd[1]: Configuration file /lib/systemd/system/systemd-pcrphase-sysinit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.504223] systemd[1]: Configuration file /lib/systemd/system/systemd-pcrphase-sysinit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.523111] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.539108] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.558356] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.574017] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.592690] systemd[1]: Configuration file /lib/systemd/system/systemd-firstboot.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.608004] systemd[1]: Configuration file /lib/systemd/system/systemd-firstboot.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.626249] systemd[1]: Configuration file /lib/systemd/system/systemd-binfmt.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.641308] systemd[1]: Configuration file /lib/systemd/system/systemd-binfmt.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.659220] systemd[1]: Configuration file /lib/systemd/system/proc-sys-fs-binfmt_misc.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.674876] systemd[1]: Configuration file /lib/systemd/system/proc-sys-fs-binfmt_misc.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ OK ] Created slice system-getty.slice - Slice /system/getty.
[ OK ] Created slice system-modpr…lice - Slice /system/modprobe.
[ OK ] Created slice system-seria… - Slice /system/serial-getty.
[ OK ] Created slice user.slice - User and Session Slice.
[ OK ] Started systemd-ask-passwo…quests to Console Directory Watch.
[ OK ] Started systemd-ask-passwo… Requests to Wall Directory Watch.
[ OK ] Reached target cryptsetup.…get - Local Encrypted Volumes.
[ OK ] Reached target integrityse…Local Integrity Protected Volumes.
[ OK ] Reached target paths.target - Path Units.
[ OK ] Reached target remote-fs.target - Remote File Systems.
[ OK ] Reached target slices.target - Slice Units.
[ OK ] Reached target swap.target - Swaps.
[ OK ] Reached target veritysetup… - Local Verity Protected Volumes.
[ OK ] Listening on systemd-initc… initctl Compatibility Named Pipe.
[ OK ] Listening on systemd-journ…socket - Journal Audit Socket.
[ OK ] Listening on systemd-journ…t - Journal Socket (/dev/log).
[ OK ] Listening on systemd-journald.socket - Journal Socket.
[ OK ] Listening on systemd-udevd….socket - udev Control Socket.
[ OK ] Listening on systemd-udevd…l.socket - udev Kernel Socket.
Mounting dev-hugepages.mount - Huge Pages File System...
Mounting dev-mqueue.mount▒▒POSIX Message Queue File System...
Mounting sys-kernel-debug.… - Kernel Debug File System...
Starting kmod-static-nodes…ate List of Static Device Nodes...
Starting modprobe@configfs…m - Load Kernel Module configfs...
Starting modprobe@dm_mod.s…[0m - Load Kernel Module dm_mod...
Starting modprobe@drm.service - Load Kerne[ 6.318651] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
l Module drm...
Starting modprobe@efi_psto…- Load Kernel Module efi_pstore...
Starting modprobe@fuse.ser…e - Load Kernel Module fuse...
[ 6.397322] fuse: init (API version 7.37)
Starting modprobe@loop.ser…e - Load Kernel Module loop...
Starting systemd-journald.service - Journal Service...
Starting systemd-modules-l…rvice - Load Kernel Modules...
Starting systemd-remount-f…nt Root and Kernel File Systems...
Starting systemd-udev-trig…[0m - Coldplug All udev Devices...
[ 6.526000] systemd-journald[173]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.540738] systemd-journald[173]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ OK ] Mounted dev-hugepages.mount - Huge Pages File System.
[ OK ] Mounted dev-mqueue.mount▒▒- POSIX Message Queue File System.
[ OK ] Mounted sys-kernel-debug.m…nt - Kernel Debug File System.
[ OK ] Finished kmod-static-nodes…reate List of Static Device Nodes.
[ OK ] Started systemd-journald.service - Journal Service.
[ OK ] Finished modprobe@configfs…[0m - Load Kernel Module configfs.
[ OK ] Finished modprobe@dm_mod.s…e - Load Kernel Module dm_mod.
[ OK ] Finished modprobe@drm.service - Load Kernel Module drm.
[ OK ] Finished modprobe@efi_psto…m - Load Kernel Module efi_pstore.
[ OK ] Finished modprobe@fuse.service - Load Kernel Module fuse.
[ OK ] Finished modprobe@loop.service - Load Kernel Module loop.
[ OK ] Finished systemd-modules-l…service - Load Kernel Modules.
[ OK ] Finished systemd-remount-f…ount Root and Kernel File Systems.
Mounting sys-fs-fuse-conne… - FUSE Control File System...
Mounting sys-kernel-config…ernel Configuration File System...
Starting systemd-journal-f…h Journal to Persistent Storage...
Starting systemd-random-se…ice - Load/Save Random Seed...
[ 6.899859] systemd-journald[173]: Received client request to flush runtime journal.
[ 6.911996] systemd-journald[173]: File /var/log/journal/61e3cf19309f4a3a80b3ea3558380ffb/system.journal corrupted or uncleanly shut down, renaming and replacing.
Starting systemd-sysctl.se…ce - Apply Kernel Variables...
Starting systemd-sysusers.…rvice - Create System Users...
[ OK ] Mounted sys-fs-fuse-connec…nt - FUSE Control File System.
[ OK ] Mounted sys-kernel-config.… Kernel Configuration File System.
[ OK ] Finished systemd-udev-trig…e - Coldplug All udev Devices.
Starting ifupdown-pre.serv…ynchronize boot up for ifupdown...
[ OK ] Finished systemd-journal-f…ush Journal to Persistent Storage.
[ OK ] Finished systemd-sysctl.service - Apply Kernel Variables.
[ OK ] Finished ifupdown-pre.serv… synchronize boot up for ifupdown.
[ OK ] Finished systemd-sysusers.service - Create System Users.
Starting systemd-tmpfiles-…ate Static Device Nodes in /dev...
[ OK ] Finished systemd-tmpfiles-…reate Static Device Nodes in /dev.
[ OK ] Reached target local-fs-pr…reparation for Local File Systems.
[ OK ] Reached target local-fs.target - Local File Systems.
Starting networking.service - Raise network interfaces...
Starting systemd-binfmt.se…et Up Additional Binary Formats...
Starting systemd-tmpfiles-… Volatile Files and Directories...
Starting systemd-udevd.ser…ger for Device Events and Files...
[FAILED] Failed to start systemd-bi… Set Up Additional Binary Formats.
See 'systemctl status systemd-binfmt.service' for details.
[ OK ] Finished systemd-tmpfiles-…te Volatile Files and Directories.
Starting systemd-timesyncd… - Network Time Synchronization...
Starting systemd-update-ut…rd System Boot/Shutdown in UTMP...
[ 7.830635] random: crng init done
[ OK ] Started systemd-udevd.serv…nager for Device Events and Files.
[ OK ] Finished systemd-random-se…rvice - Load/Save Random Seed.
[ OK ] Finished networking.service - Raise network interfaces.
[ OK ] Finished systemd-update-ut…cord System Boot/Shutdown in UTMP.
[ OK ] Found device dev-ttyS2.device - /dev/ttyS2.
[ 8.166977] systemd-journald[173]: Oldest entry in /var/log/journal/61e3cf19309f4a3a80b3ea3558380ffb/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[ OK ] Started systemd-timesyncd.…0m - N[ 8.199109] systemd-journald[173]: /var/log/journal/61e3cf19309f4a3a80b3ea3558380ffb/system.journal: Journal header limits reached or header out-of-date, rotating.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Started systemd-tmpfiles-c… Cleanup of Temporary Directories.
[ OK ] Reached target time-set.target - System Time Set.
[ OK ] Started apt-daily.timer - Daily apt download activities.
[ 8.580132] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[ OK ] Started apt-daily-upgrade.… apt u[ 8.591638] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
pgrade and clean activities.
[ 8.602806] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[ OK ] Started dpkg-db-backup.tim… Daily[ 8.616117] remoteproc remoteproc0: 5000000.m4fss is available
dpkg database backup timer.
[ 8.629056] mc: Linux media interface: v0.10
[ 8.629901] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ OK ] Started e2scrub_all.timer▒▒etadat[ 8.645113] remoteproc remoteproc0: powering up 5000000.m4fss
a Check for All Filesystems.
[ 8.656765] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ OK ] Started fstrim.timer - Discard [ 8.669661] remoteproc remoteproc0: request_firmware failed: -2
[ 8.680164] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
unused blocks once a week.
[ 8.681346] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 8.686356] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:14 UTC (14)
[ 8.701489] systemd-journald[173]: Time jumped backwards, rotating.
[ 8.703754] platform 78000000.r5f: configured R5F for IPC-only mode
[ 8.704796] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[ 8.705527] remoteproc remoteproc1: 78000000.r5f is available
[ 8.705669] remoteproc remoteproc1: attaching to 78000000.r5f
[ 8.706484] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 8.706504] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9da00000
[ 8.706625] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[ 8.706632] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[ 8.722765] videodev: Linux video capture interface: v2.00
[ OK ] Started logrotate.timer - Daily rotation of log files.
[ OK ] Started man-db.timer - Daily man-db regeneration.
[ OK ] Reached target timers.target - Timer Units.
[ OK ] Listening on dbus.socket▒▒- D-Bus System Message Bus Socket.
[ OK ] Listening on weston.socket - Weston socket.
[ OK ] Reached target sockets.target - Socket Units.
[ OK ] Reached target basic.target - Basic System.
[ 9.007736] remoteproc remoteproc2: 30074000.pru is available
[ 9.017068] remoteproc remoteproc3: 30078000.pru is available
[ 9.017885] sii902x 1-003b: supply iovcc not found, using dummy regulator
[ OK ] Started cron.service -…kgroun[ 9.033898] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
d program processing daemon.
[ 9.057319] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[ 9.057679] i2c i2c-1: Added multiplexed i2c bus 3
[ 9.071324] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 9.072656] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
Starting dbus.service - D-Bus System Messa[ 9.087174] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
ge Bus...
[ 9.087678] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 9.108697] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
Starting e2scrub_reap.serv…e ext4 Metadata Check Snapshots...
[ 9.155918] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: new channel: 0x400 -> 0xd!
[ 9.164635] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 1 (src: 0xd)
[ 9.173140] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 2 (src: 0xd)
[ 9.181759] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 3 (src: 0xd)
[ 9.190409] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 4 (src: 0xd)
[ 9.193460] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 9.198874] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 5 (src: 0xd)
[ 9.210975] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 9.212698] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 6 (src: 0xd)
[ 9.220537] xhci-hcd xhci-hcd.2.auto: USB3 root hub has no ports
[ 9.231802] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 7 (src: 0xd)
[ 9.235208] xhci-hcd xhci-hcd.2.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
[ 9.243216] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 8 (src: 0xd)
[ 9.252562] xhci-hcd xhci-hcd.2.auto: irq 449, io mem 0x31100000
[ 9.261007] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 9 (src: 0xd)
[ 9.269198] hub 1-0:1.0: USB hub found
[ 9.275406] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 10 (src: 0xd)
[ 9.279137] hub 1-0:1.0: 1 port detected
[ 9.291677] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 11 (src: 0xd)
[ 9.300222] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 12 (src: 0xd)
Starting systemd-logind.se…ice - User Lo[ 9.308799] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 13 (src: 0xd)
gin Management...
[ 9.322809] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 14 (src: 0xd)
[ 9.332851] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 15 (src: 0xd)
[ 9.341347] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 16 (src: 0xd)
[ 9.349844] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 17 (src: 0xd)
[ 9.358344] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 18 (src: 0xd)
[ 9.366836] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 19 (src: 0xd)
[ 9.375492] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 20 (src: 0xd)
[ 9.384016] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 21 (src: 0xd)
[ 9.392502] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 22 (src: 0xd)
[ 9.401147] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 23 (src: 0xd)
[ 9.409682] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 24 (src: 0xd)
[ 9.418166] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 25 (src: 0xd)
[ OK ] Reached target sound.target - S[ 9.426657] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 26 (src: 0xd)
ound Card.
[ 9.440587] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 27 (src: 0xd)
[ 9.450047] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 28 (src: 0xd)
[ 9.458524] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 29 (src: 0xd)
[ 9.466991] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 30 (src: 0xd)
[ 9.475468] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 31 (src: 0xd)
[ 9.483921] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 32 (src: 0xd)
[ OK ] Reached target usb-gadget.…m - Ha[ 9.492446] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 33 (src: 0xd)
rdware activated USB gadget.
[ 9.506353] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 34 (src: 0xd)
[ 9.517340] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 35 (src: 0xd)
[ 9.525907] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 36 (src: 0xd)
[ 9.534431] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 37 (src: 0xd)
[ 9.544374] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[ 9.546015] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 38 (src: 0xd)
[ 9.559955] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 39 (src: 0xd)
[ 9.568435] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 40 (src: 0xd)
[ OK ] Started dbus.service - D-Bus Sy[ 9.577041] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 41 (src: 0xd)
stem Message Bus.
[ 9.590949] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 42 (src: 0xd)
[ 9.601121] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 43 (src: 0xd)
[ 9.609672] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 44 (src: 0xd)
[ 9.618297] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 45 (src: 0xd)
[ 9.626881] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 46 (src: 0xd)
[ 9.635548] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 47 (src: 0xd)
[ 9.644150] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 48 (src: 0xd)
[ 9.652693] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 49 (src: 0xd)
[ 9.661236] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 50 (src: 0xd)
[ 9.661297] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 51 (src: 0xd)
[ 9.678330] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 52 (src: 0xd)
[ 9.678426] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 53 (src: 0xd)
[ 9.695317] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 54 (src: 0xd)
Starting NetworkManager.service - Network [ 9.703915] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 55 (src: 0xd)
Manager...
[ 9.717865] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 56 (src: 0xd)
[ 9.727227] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 57 (src: 0xd)
[ 9.735798] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 58 (src: 0xd)
[ 9.744335] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 59 (src: 0xd)
[ 9.752895] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 60 (src: 0xd)
[ 9.761392] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 61 (src: 0xd)
[ 9.769909] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 62 (src: 0xd)
[ 9.778484] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 63 (src: 0xd)
[ 9.786970] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 64 (src: 0xd)
[ 9.787040] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 65 (src: 0xd)
[ 9.787080] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 66 (src: 0xd)
[ 9.787122] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 67 (src: 0xd)
[ 9.787160] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 68 (src: 0xd)
[ 9.787198] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 69 (src: 0xd)
[ 9.787236] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 70 (src: 0xd)
[ 9.787276] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 71 (src: 0xd)
[ 9.787377] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 72 (src: 0xd)
[ 9.787419] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 73 (src: 0xd)
[ 9.787457] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 74 (src: 0xd)
[ 9.787494] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 75 (src: 0xd)
[ 9.787532] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 76 (src: 0xd)
[ 9.787571] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 77 (src: 0xd)
[ 9.787609] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 78 (src: 0xd)
[ 9.787647] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 79 (src: 0xd)
[ 9.787684] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 80 (src: 0xd)
[ 9.787722] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 81 (src: 0xd)
[ 9.787758] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 82 (src: 0xd)
[ 9.787797] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 83 (src: 0xd)
[ 9.787834] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 84 (src: 0xd)
[ 9.787873] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 85 (src: 0xd)
[ 9.790022] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 86 (src: 0xd)
[ 9.980228] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 87 (src: 0xd)
[ 9.988715] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 88 (src: 0xd)
[ 9.988773] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 89 (src: 0xd)
[ 9.988815] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 90 (src: 0xd)
[ 9.988853] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 91 (src: 0xd)
[ 9.988891] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 92 (src: 0xd)
[ 9.988930] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 93 (src: 0xd)
[ 9.988968] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 94 (src: 0xd)
[ 9.989008] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 95 (src: 0xd)
[ 9.992487] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 96 (src: 0xd)
[ 10.064726] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 97 (src: 0xd)
[ 10.073227] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 98 (src: 0xd)
[ 10.073278] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 99 (src: 0xd)
[ 10.073319] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 100 (src: 0xd)
[ 10.073326] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: goodbye!
[ OK ] Started systemd-logind.service - User Login Management.
[ OK ] Finished e2scrub_reap.serv…ine ext4 Metadata Check Snapshots.
[ OK ] Started NetworkManager.service - Network Manager.
[ OK ] Reached target network.target - Network.
Starting ssh.service - OpenBSD Secure Shell server...
Starting systemd-user-sess…vice - Permit User Sessions...
Starting systemd-hostnamed.service - Hostname Service...
[ OK ] Finished systemd-user-sess…ervice - Permit User Sessions.
[ OK ] Started getty@tty1.service - Getty on tty1.
[ OK ] Started serial-getty@ttyS2…rvice - Serial Getty on ttyS2.
[ OK ] Reached target getty.target - Login Prompts.
[ OK ] Started weston.service…d compositor, as a system service.
[FAILED] Failed to start ssh.servic…[0m - OpenBSD Secure Shell server.
See 'systemctl status ssh.service' for details.
[ OK ] Reached target multi-user.target - Multi-User System.
[ OK ] Reached target graphical.target - Graphical Interface.
Starting systemd-update-ut… Record Runlevel Change in UTMP...
[ OK ] Started systemd-hostnamed.service - Hostname Service.
[ 10.828377] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 10.837987] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ OK ] Listening on systemd-rfkil…l Switch Status /dev/rfkill Watch.
[ 10.884400] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[ 10.894010] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
Starting NetworkManager-di…nager Script Dispatcher Service...
[ OK ] Stopped ssh.service - OpenBSD Secure Shell server.
[ OK ] Finished systemd-update-ut… - Record Runlevel Change in UTMP.
[ OK ] Started NetworkManager-dis…Manager Script Dispatcher Service.
[ OK ] Created slice user-0.slice - User Slice of UID 0.
Starting user-runtime-dir@…r Runtime Directory /run/user/0...
[ OK ] Finished user-runtime-dir@…ser Runtime Directory /run/user/0.
Starting user@0.service - User Manager for UID 0...
[ OK ] Started user@0.service - User Manager for UID 0.
[ OK ] Started session-c1.scope - Session c1 of User root.
Debian GNU/Linux 12 am62xx ttyS2
am62xx login:
But if I only use tisdk-debian-bookworm-am62xx-evm.wic.xz and the following two lines of instructions, the error will disappear.
sudo cp board-support/built-images/tiboot3-am62*-gp-evm.bin /media/$USER/boot/tiboot3.bin
sudo cp board-support/built-images/u-boot.img board-support/built-images/tispl.bin /media/$USER/boot
U-Boot SPL 2023.04 (Sep 19 2023 - 15:02:33 +0800)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 00:42:57, Jan 13 2023
U-Boot SPL 2023.04 (Sep 19 2023 - 15:03:03 +0800)
SPL initial stack usage: 1856 bytes
Error (-2): cannot determine file size
U-Boot 2023.04 (Sep 19 2023 - 15:03:03 +0800)
SoC: AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 80, trying to read at 81
Board: AM62-SKEVM rev E3
DRAM: 2 GiB
Core: 75 devices, 31 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
## Error: "main_cpsw0_qsgmii_phyinit" not defined
20451840 bytes read in 238 ms (82 MiB/s)
48524 bytes read in 18 ms (2.6 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK
Working FDT set to 8fef1000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.26 (root@SHIELD01) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #4 SMP PREEMPT Wed Jun 21 09:25:41 UTC 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=a0ea9fb9-02 rw rootfstype=ext4 rootwait
[ 0.000000] Unknown kernel command line parameters "mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system)", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 1838272K/2097152K available (12416K kernel code, 1284K rwdata, 3988K rodata, 2176K init, 499K bss, 127808K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008521] Console: colour dummy device 80x25
[ 0.013113] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023796] pid_max: default: 32768 minimum: 301
[ 0.028572] LSM: Security Framework initializing
[ 0.033435] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.041019] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.050833] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.058293] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.064591] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.070991] rcu: Hierarchical SRCU implementation.
[ 0.075897] rcu: Max phase no-delay instances is 1000.
[ 0.081498] Platform MSI: msi-controller@1820000 domain created
[ 0.087778] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.097524] EFI services will not be available.
[ 0.102439] smp: Bringing up secondary CPUs ...
[ 0.107744] Detected VIPT I-cache on CPU1
[ 0.107864] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.107883] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[ 0.107942] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.108643] Detected VIPT I-cache on CPU2
[ 0.108726] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.108740] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
[ 0.108773] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.109390] Detected VIPT I-cache on CPU3
[ 0.109473] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.109485] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
[ 0.109516] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.109589] smp: Brought up 1 node, 4 CPUs
[ 0.189319] SMP: Total of 4 processors activated.
[ 0.194132] CPU features: detected: 32-bit EL0 Support
[ 0.199405] CPU features: detected: CRC32 instructions
[ 0.204726] CPU: All CPU(s) started at EL2
[ 0.208922] alternatives: applying system-wide alternatives
[ 0.216518] devtmpfs: initialized
[ 0.227170] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.237194] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.248860] pinctrl core: initialized pinctrl subsystem
[ 0.254863] DMI not present or invalid.
[ 0.259446] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.266695] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.274248] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.282359] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.290548] audit: initializing netlink subsys (disabled)
[ 0.296254] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[ 0.296733] thermal_sys: Registered thermal governor 'step_wise'
[ 0.304186] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.310376] cpuidle: using governor menu
[ 0.321242] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.328272] ASID allocator initialised with 65536 entries
[ 0.343137] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.354343] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.364873] KASLR disabled due to lack of seed
[ 0.376425] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.383398] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.389807] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.396746] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.403153] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.410092] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.416499] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.423438] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.431578] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.441652] iommu: Default domain type: Translated
[ 0.446684] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.453395] SCSI subsystem initialized
[ 0.457603] usbcore: registered new interface driver usbfs
[ 0.463252] usbcore: registered new interface driver hub
[ 0.468708] usbcore: registered new device driver usb
[ 0.474345] pps_core: LinuxPPS API ver. 1 registered
[ 0.479424] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.488776] PTP clock support registered
[ 0.492894] EDAC MC: Ver: 3.0.0
[ 0.496925] FPGA manager framework
[ 0.500481] Advanced Linux Sound Architecture Driver Initialized.
[ 0.507745] clocksource: Switched to clocksource arch_sys_counter
[ 0.514249] VFS: Disk quotas dquot_6.6.0
[ 0.518304] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.531366] NET: Registered PF_INET protocol family
[ 0.536675] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.545915] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.554727] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.562666] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.570870] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.578870] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.585787] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.592711] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.600243] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.606518] RPC: Registered named UNIX socket transport module.
[ 0.612601] RPC: Registered udp transport module.
[ 0.617410] RPC: Registered tcp transport module.
[ 0.622218] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.628819] NET: Registered PF_XDP protocol family
[ 0.633733] PCI: CLS 0 bytes, default 64
[ 0.638542] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.648544] Initialise system trusted keyrings
[ 0.653370] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.665602] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.672285] NFS: Registering the id_resolver key type
[ 0.677510] Key type id_resolver registered
[ 0.681787] Key type id_legacy registered
[ 0.685950] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.692820] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.700604] 9p: Installing v9fs 9p2000 file system support
[ 0.740807] Key type asymmetric registered
[ 0.744999] Asymmetric key parser 'x509' registered
[ 0.750037] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.757779] io scheduler mq-deadline registered
[ 0.762421] io scheduler kyber registered
[ 0.769633] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.776162] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.783088] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.795604] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.810297] loop: module loaded
[ 0.814655] megasas: 07.719.03.00-rc1
[ 0.822094] tun: Universal TUN/TAP device driver, 1.6
[ 0.827957] thunder_xcv, ver 1.0
[ 0.831285] thunder_bgx, ver 1.0
[ 0.834618] nicpf, ver 1.0
[ 0.837721] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.845115] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.850629] hclge is initializing
[ 0.854039] e1000: Intel(R) PRO/1000 Network Driver
[ 0.859024] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.864935] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.870009] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.876094] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.881614] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.887337] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.893744] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.899919] sky2: driver version 1.30
[ 0.904298] VFIO - User Level meta-driver version: 0.3
[ 0.910297] usbcore: registered new interface driver usb-storage
[ 0.917105] i2c_dev: i2c /dev entries driver
[ 0.923362] sdhci: Secure Digital Host Controller Interface driver
[ 0.929732] sdhci: Copyright(c) Pierre Ossman
[ 0.934601] Synopsys Designware Multimedia Card Interface Driver
[ 0.941126] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.947855] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.954195] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.961072] usbcore: registered new interface driver usbhid
[ 0.966775] usbhid: USB HID core driver
[ 0.971724] optee: probing for conduit method.
[ 0.976324] optee: revision 3.20 (8e74d476)
[ 0.976647] optee: dynamic shared memory is enabled
[ 0.986186] optee: initialized driver
[ 0.991595] Initializing XFRM netlink socket
[ 0.996026] NET: Registered PF_PACKET protocol family
[ 1.001334] 9pnet: Installing 9P2000 support
[ 1.005766] Key type dns_resolver registered
[ 1.010591] registered taskstats version 1
[ 1.014816] Loading compiled-in X.509 certificates
[ 1.028177] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
[ 1.059393] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.066867] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.073961] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.079972] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.088311] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.097538] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.106542] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.114662] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.125741] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.135802] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.145968] printk: console [ttyS2] disabled
[ 1.150421] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 230, base_baud = 3000000) is a 8250
[ 1.159320] printk: console [ttyS2] enabled
[ 1.167779] printk: bootconsole [ns16550a0] disabled
[ 1.180869] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.186525] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.193512] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.198914] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.205731] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.212237] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.218716] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.224921] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.231716] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.238189] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.246521] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.291766] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.301490] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.309597] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.317721] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.330586] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.337714] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.344208] pps pps0: new PPS source ptp0
[ 1.348490] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.358828] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.370134] mmc0: CQHCI version 5.10
[ 1.379670] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.386422] pca953x 1-0022: using AI
[ 1.414492] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.418305] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.429714] mmc1: CQHCI version 5.10
[ 1.434730] ALSA device list:
[ 1.437723] No soundcards found.
[ 1.472908] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.480680] Waiting for root device PARTUUID=a0ea9fb9-02...
[ 1.508964] mmc0: Command Queue Engine enabled
[ 1.513439] mmc0: new HS200 MMC card at address 0001
[ 1.519500] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.526569] mmcblk0: p1 p2
[ 1.530362] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.533979] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 1.536475] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.542677] mmcblk1: mmc1:59b4 USDU1 14.9 GiB
[ 1.547934] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 1.553294] mmcblk1: p1 p2
[ 1.754239] EXT4-fs (mmcblk1p2): recovery complete
[ 1.762309] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.770928] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 1.780487] devtmpfs: mounted
[ 1.784993] Freeing unused kernel memory: 2176K
[ 1.789736] Run /sbin/init as init process
[ 2.098141] systemd[1]: System time before build time, advancing clock.
[ 2.152885] NET: Registered PF_INET6 protocol family
[ 2.159048] Segment Routing with IPv6
[ 2.162796] In-situ OAM (IOAM) with IPv6
[ 2.228815] systemd[1]: systemd 252.6-1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 2.260853] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 12 (bookworm)!
[ 2.283164] systemd[1]: Hostname set to <am62xx>.
[ 2.920688] systemd[1]: Queued start job for default target graphical.target.
[ 2.948192] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 2.973938] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 2.997901] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ 3.025441] systemd[1]: Created slice user.slice - User and Session Slice.
[ 3.048540] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ 3.076355] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 3.104435] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[ 3.124078] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ 3.148211] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 3.172190] systemd[1]: Reached target paths.target - Path Units.
[ 3.196043] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ 3.220208] systemd[1]: Reached target slices.target - Slice Units.
[ 3.244432] systemd[1]: Reached target swap.target - Swaps.
[ 3.268275] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 3.293816] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 3.322201] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 3.350067] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 3.379035] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 3.408482] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 3.434727] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 3.500391] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[ 3.531401] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 3.565585] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 3.595350] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 3.632603] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 3.664168] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[ 3.696312] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[ 3.721900] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 3.726131] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 3.763119] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 3.797691] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 3.822810] fuse: init (API version 7.37)
[ 3.834046] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[ 3.888712] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 3.925378] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 3.957803] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 4.012606] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 4.047119] systemd[1]: Started systemd-journald.service - Journal Service.
[ 4.460994] systemd-journald[169]: Received client request to flush runtime journal.
Starting systemd-sysctl.se…ce - Apply Ke[ 4.477876] systemd-journald[169]: File /var/log/journal/7a66f0daf53247f78f7c3d7bc6159b52/system.journal corrupted or uncleanly shut down, renaming and replacing.
rnel Variables...
[ 5.375787] random: crng init done
[ OK ] Started systemd-timesyncd.…0m - Network Time Synchronization.
[ OK ] Started apt-daily.timer - Daily[ 5.966431] mc: Linux media interface: v0.10
[ OK ] Started apt-daily-upgrade.… apt upgrade and clean activities.
[ 5.992671] videodev: Linux video capture interface: v2.00
[ OK ] Started dpkg-db-backup.tim… Daily[ 6.003586] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ OK ] Started e2scrub_all.timer▒▒etadata Check for All Filesystems.
[ OK ] Started fstrim.timer - Discard unused blocks once a week.
[ 6.106204] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[ OK ] Listening on dbus.socket▒▒- D-Bu[ 6.112884] systemd-journald[169]: Time jumped backwards, rotating.
[ 6.113010] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:11 UTC (11)
[ 6.136401] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[ OK ] Listening on weston.socket - We[ 6.147995] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
ston socket.
[ 6.161379] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[ 6.180848] remoteproc remoteproc0: 5000000.m4fss is available
[ OK ] Reached target basic.target - B[ 6.188708] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
asic System.
[ 6.202988] remoteproc remoteproc0: powering up 5000000.m4fss
[ 6.209786] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ 6.219009] remoteproc remoteproc0: request_firmware failed: -2
[ OK ] Started cron.service -…kground program processing daemon.
Starting dbus.service - D-Bus System Message Bus...
Starting systemd-logind.se…ice - User Login Management...
[ 6.388346] sii902x 1-003b: supply iovcc not found, using dummy regulator
[ 6.395443] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[ 6.396348] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 6.416366] platform 78000000.r5f: configured R5F for IPC-only mode
[ 6.423526] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[ 6.424882] i2c i2c-1: Added multiplexed i2c bus 3
[ 6.447495] remoteproc remoteproc1: 78000000.r5f is available
[ 6.453705] remoteproc remoteproc1: attaching to 78000000.r5f
[ 6.460497] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 6.461000] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 6.467387] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9da00000
[ 6.477261] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[ 6.483899] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
[ 6.496876] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[ 6.607825] pvrsrvkm: loading out-of-tree module taints kernel.
[ 6.634654] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[ 6.663277] PVR_K: 221: Device: fd00000.gpu
[ 6.669155] PVR_K: 221: Read BVNC 33.15.11.3 from HW device registers
[ 6.689548] PVR_K: 221: RGX Device registered with BVNC 33.15.11.3
[ 6.709431] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[ 6.713214] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ OK ] Reached target usb-gadget.…m - Ha[ 6.726712] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[ 6.735926] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
[ 6.737587] [drm] Initialized pvr 23.1.6404501 20170530 for fd00000.gpu on minor 1
[ 6.744264] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
[ 6.754606] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.755454] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 6.755630] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 6.761373] xhci-hcd xhci-hcd.3.auto: irq 424, io mem 0x31100000
[ OK ] Started dbus.service - D-Bus Sy[ 6.789330] hub 1-0:1.0: USB hub found
stem Message Bus.
[ 6.789410] hub 1-0:1.0: 1 port detected
[ OK ] Reached target sound.target - Sound Card.
Starting NetworkManager.service - Network Manager...
[ OK ] Started ssh.service - OpenBSD Secure Shell server.
[ 7.928148] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 7.937551] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
Starting user-runtime-dir@…r Runtime Directo[ 7.988365] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
ry /run/user/0...
[ 8.003032] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
am62xx login: [ 10.269937] PVR_K: 280: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[ 10.284729] PVR_K: 280: Shader binary image 'rgx.sh.33.15.11.3' loaded
[ 17.053577] platform 40900000.crypto: deferred probe pending
Andrew
