1. I tried running a UDMA example code in C7x core , is it possible to run it using C7x-hostemu since it is defined only in baremetal test application ?
2. What will be the build command for C7x-hostemu? Below is the command tried for a test app
You can check the udma_component.mk file for supported cores for above mentioned application, and if that supports c7x-hostemu then you can build it host emulation mode.
Yes, above listed command is correct.
