AM5718: OpenCV some UnitTest had failed with standard procedure.
Genius 3186 points
Part Number: AM5718
Hi
May I have questions about AM5718 OpenCV unittest?
My customer is testing SoC with Processor-sdk-linux 06_03_00_106.
First, My customer is set to the setting: 3.12.5.10. OpenCV profiling   standard procedure,
https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_OpenCV.html#opencv-profiling-standard-procedure
Second, Run the Unit test
https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_OpenCV.html#unit-tests
Result, If use DSP, some test had timed out.
Q1:
In the setting, we will run OpenCL kernel including OpenCV baseline ?
Q2:
The profiling result's DSP baseline wall clock is run-time of OpenCL kernel including OpenCV baseline?
https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_OpenCV.html#profiling-results-of-dsp-optimized-opencv-opencl-kernels-plsdk-3-1-am5728-platform
GR
