Part Number: TMDS64EVM
I am currently working with the AM64 EVM platform and I use Yocto to build custom images, currently my repo are synced to the SDK SDK 09.00.00.009. I was successfully able to flash my own keys and sign tiboot3.bin, tispl.bin and u-boot.img. My system boots up to U-Boot, but something's wrong with my fitImage as U-Boot refuses to load it. Here's the log:
> bootm 0x90000000 conf-se_se-k3-am642-test-cpu.dtb ## Loading kernel from FIT Image at 90000000 ... Using 'conf-se_se-k3-am642-test-cpu.dtb' configuration Verifying Hash Integrity ... fit_config_verify_required_keys: No signature nD Bad Data Hash ERROR: can't get kernel image!
an iminfo shows the following:
> iminfo 0x90000000
## Checking Image at 90000000 ...
FIT image found
FIT description: Kernel fitImage for Arago/6.1.46+gitAUTOINC+f8110d9ce8/sepce
Image 0 (kernel-1)
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x900000f8
Data Size: 27106169 Bytes = 25.9 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x80008000
Entry Point: 0x80008000
Hash algo: sha512
Hash value: dfde425c7f8ba0f9d3daa79a26ad0c09202b321f374a26e4fc465540c8a1e
Image 1 (fdt-se_se-k3-am642-test-cpu.dtb)
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x919d9dc0
Data Size: 58701 Bytes = 57.3 KiB
Hash algo: sha512
Hash value: e161ce3f516122d3b0521dbcb3d0018f88652423cea7f6da2cd1462dd6ac9
Default Configuration: 'conf-se_se-k3-am642-test-cpu.dtb'
Configuration 0 (conf-se_se-k3-am642-test-cpu.dtb)
Description: 1 Linux kernel, FDT blob
Kernel: kernel-1
FDT: fdt-se_se-k3-am642-test-cpu.dtb
Hash algo: sha512
Hash value: unavailable
Sign algo: sha512,rsa4096:custMpk
Sign padding: pkcs-1.5
Sign value: 1a07c185d50cb2a7d87aa1ea48761da10a9bdca63d60b9d78b4697274c13b
## Checking hash(es) for FIT Image at 90000000 ...
Hash(es) for Image 0 (kernel-1): sha512+
Hash(es) for Image 1 (fdt-se_se-k3-am642-test-cpu.dtb): sha512
What worries me is the "Hash value: unavailable". As far as I understand the fitimage generation is performed trough the kernel task using a task called do_assemble_fitimage() that is inherited from the kernel-fitimage.class. On top of that the kernel-fitimage-ti-u-boot.class overrides the fit_image_assemble() method, adding some signature processes. I suppose something is not right in that area.
Looking at the log.do_assemble_fitimage_initramfs file I can see the following:
DEBUG: Python function extend_recipe_sysroot finished DEBUG: Executing shell function do_assemble_fitimage_initramfs gzip FIT description: Kernel fitImage for Arago/6.1.46+gitAUTOINC+f8110d9ce8/sepcos-cpu-core Created: Mon Sep 4 04:45:34 2023 Image 0 (kernel-1) Description: Linux kernel Created: Mon Sep 4 04:45:34 2023 Type: Kernel Image Compression: gzip compressed Data Size: 27104488 Bytes = 26469.23 KiB = 25.85 MiB Architecture: AArch64 OS: Linux Load Address: 0x80008000 Entry Point: 0x80008000 Hash algo: sha512 Hash value: 4bf2f18e13a970742bd7c68528c2787057ef5691c86caa39d4ee58a52dc8b32bee7ab9b298cc85f36e58ae5727c8235c1952afd8aab0faa7e70324591ab58486 Image 1 (fdt-secheron_secheron-k3-am642-sepcos-cpu.dtb) Description: Flattened Device Tree blob Created: Mon Sep 4 04:45:34 2023 Type: Flat Device Tree Compression: uncompressed Data Size: 57021 Bytes = 55.68 KiB = 0.05 MiB Architecture: AArch64 Hash algo: sha512 Hash value: b8c37b73989be8a18cd5eed9134492e3d7c4e9956984936f648eed35cc07969a92e3bab65783584804e28b5e75613b882543940d21661aa7a49d102e3b0cfde6 Default Configuration: 'conf-secheron_secheron-k3-am642-sepcos-cpu.dtb' Configuration 0 (conf-secheron_secheron-k3-am642-sepcos-cpu.dtb) Description: 1 Linux kernel, FDT blob Kernel: kernel-1 FDT: fdt-secheron_secheron-k3-am642-sepcos-cpu.dtb Hash algo: sha512 Hash value: unavailable Sign algo: sha512,rsa4096:smpk Sign padding: pkcs-1.5 Sign value: unavailable Timestamp: unavailable Failed to add verification data for 'signature-1' signature node in 'conf-secheron_secheron-k3-am642-sepcos-cpu.dtb' configuration node FIT description: Kernel fitImage for Arago/6.1.46+gitAUTOINC+f8110d9ce8/sepcos-cpu-core Created: Mon Sep 4 04:45:34 2023 Image 0 (kernel-1) Description: Linux kernel Created: Mon Sep 4 04:45:34 2023 Type: Kernel Image Compression: gzip compressed Data Size: 27104488 Bytes = 26469.23 KiB = 25.85 MiB Architecture: AArch64 OS: Linux Load Address: 0x80008000 Entry Point: 0x80008000 Hash algo: sha512 Hash value: 4bf2f18e13a970742bd7c68528c2787057ef5691c86caa39d4ee58a52dc8b32bee7ab9b298cc85f36e58ae5727c8235c1952afd8aab0faa7e70324591ab58486 Image 1 (fdt-secheron_secheron-k3-am642-sepcos-cpu.dtb) Description: Flattened Device Tree blob Created: Mon Sep 4 04:45:34 2023 Type: Flat Device Tree Compression: uncompressed Data Size: 57021 Bytes = 55.68 KiB = 0.05 MiB Architecture: AArch64 Hash algo: sha512 Hash value: b8c37b73989be8a18cd5eed9134492e3d7c4e9956984936f648eed35cc07969a92e3bab65783584804e28b5e75613b882543940d21661aa7a49d102e3b0cfde6 Default Configuration: 'conf-secheron_secheron-k3-am642-sepcos-cpu.dtb' Configuration 0 (conf-secheron_secheron-k3-am642-sepcos-cpu.dtb) Description: 1 Linux kernel, FDT blob Kernel: kernel-1 FDT: fdt-secheron_secheron-k3-am642-sepcos-cpu.dtb Hash algo: sha512 Hash value: unavailable Sign algo: sha512,rsa4096:smpk Sign padding: pkcs-1.5 Sign value: 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 Timestamp: Mon Sep 4 04:45:34 2023 DEBUG: Shell function do_assemble_fitimage_initramfs finished
The interesting part is that message: "Failed to add verification data for 'signature-1' signature node in 'conf-secheron_secheron-k3-am642-sepcos-cpu.dtb' configuration node".
That message is emitted by uboot-mkimage, which is called from the fitimage_assemble() method. One can find the definition of that error message in "U-Boot git source"/tools/image-host.c:1070. The error is raised because the previous operation (ret = info.crypto->add_verify_data(&info, keydest);) failed, but I've got no clues on why.
Any help is appreciated, this is starting to drive me nuts.
Cheers
Pierre
