TDA4VM: source code for c66 and c7
Genius 13655 points
Part Number: TDA4VM
Hello Champs,
1. How does the edgeai-gst-apps demo use c66 and c7 core? Is there some source code for c66 and c7?
2. What is the function of edgeai-tiovx-kernels and edgeai-tiovx-modules and the test?
Shine
  • Due to regional holiday, the expert handling this thread  is currently out of office. Please expect a 1~2 day delay in responses.
    Apologies for the delay, and thank you for you patience.
    Thank you for your patience.
    As part of edgeai sdk offering, it uses C6x and C7x binaries however the source code is not exposed.
    The gstreamer is plugin based framework we have, there are few open source plugins and few TIs TIOVX (Based on OpenVx)
    • Plugins which start with "tiovx" name: The uses TIOVX framework internally
    • Plugins which start with just "ti" name: Runs on ARM natively
    • Other plugins: There are open-source plugins that comes with gstreamer
    The tiovx based modules/plugins enables OpenVx pipeline on TI SoC, where openvx pipeline will run on ARM core, and based on specified targets of each node it will get offloaded to it, via internal IPC mechanism.
    Pratik
