problem building dvsdk examples
I am trying to build the video_copy example included in dvsdk_1_01_00_15 ,for dm6437.I am getting the following error persistantly.
    "C:/dvsdk_1_01_00_15/xdc_2_95_02/packages/xdc/xs.js", line 137
xdc_2_95_02\gmake.exe: *** [package/cfg/video_copy_x64P.c] Error 1
Configuration step failed.
Explanation:
XDC tools could not find file 'common.tci' in your package path.
If this is a valid script name --
To correct this error, you must locate a directory on your system
that contains that script and add it to your package path.
(You can use an absolute path or one relative to your project,
e.g. '../../myTconfScripts/'.)
If you are unsure which script attempted to load the missing script,
please look at the list of scripts located below the original error line above.\n
Please review the above information carefully to correct this configuration error.
I have edited the xdcpaths.dat ,xdcpaths.mak, and xdcpaths_dm6437.dat files, accordingly,although I am not sure if I have done the same in the right way.
Please help.
Thanks in advance
BadriRam
