Part Number: TDA4VM
hello!
I need test firewall id 1050, but I can't find the corresponding Firewall Exception Register to check the log for MCU CBASS, It's not in the manual
Part Number: TDA4VM
hello!
HI Ji
One quick question why this information is needed ,TIFS already dumps the exception register data once there is a exception ?
ref:software-dl.ti.com/.../firewall_faq.html
Diwakar
thanks
Is there any example or demo? It is better to provide the code path based on SDK8.6
Hi
What I want to ask is which Exception Register corresponds to MCU CBASS. I did not find it in TRM, please tell me the specific register address
thanks
Hi
There is no such demo but you can configure the firewall and try to access it you will see the exception logs in the Wakeup UART.
As TRM says "All register offset addresses not listed in these tables should be considered as reserved locations and
the register contents should not be modified."
Diwakar
