AM6442: SK-AM64B USB host mode boot is not proceeding to u-boot
Part Number: AM6442
Other Parts Discussed in Thread: SK-AM64B
Dear TI team,
I attempted to boot the SK-AM64B board using a USB mass storage device, specifically the SanDisk Cruzade - 16GB. I adjusted the boot switches according to the instructions found in the TRM and SK-AM64B user guide, setting SW2.8, SW3.2, SW3.4, SW3.7, and SW3.8 to the 'ON' position, while leaving the others in the 'OFF' position. I then proceeded to flash the provided filesystem from SDK 9.0 release onto the USB device, mirroring the SD card flashing process using Balena Etcher.
Subsequently, I connected the USB device to the port and powered on the board. Regrettably, I encountered an error message (please see below) indicating that the boot process had failed, and it did not progress to the u-boot for further steps. I'm in need of assistance in identifying the underlying issue. Could you please provide guidance on resolving this problem?"
U-Boot SPL 2023.04-g24098ea90d (Jul 06 2023 - 12:59:40 +0000)
EEPROM not available at 0x50, trying to read at 0x51
Resetting on cold boot to workaround ErrataID:i2331
Please resend tiboot3.bin in case of UART/DFU boot
resetting ...
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from USB
Bus usb@f400000: Register 2000840 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@f400000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Authentication passed
Loading Environment from MMC... MMC Device 0 not found
*** Warning - No MMC card found, using default environment
init_env from device 42 not supported!
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 00:42:57, Jan 13 2023
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
Bus usb@f400000: cdns-usb3-host usb@f400000: set 1 has failed, back to 0
scanning bus usb@f400000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Thank you
Chris
  • Hi Chris,
    Due to Errata i2328, USB MSC boot in U-Boot is not validated. But please check the link below, it seems another customer had the same problem, but resolved by a U-Boot dts change.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1279456/sk-am64b-sk-am64b-booting-with-usb-pen-drive
  • Thanks Bin LIu. Let me check the work around. Can we expect a fix in the upcoming SDK release
  • Hi Chris,
    Currently there is no requirement in place to enable USB MSC boot for AM64x due to errata i2328.
    But please let me know if this code change resolves the failure for you, then we might request to implement it in the next SDK.
  • Dear Bin Liu,
    Yes, the above code changes resolved my case. I had not done any extensive tests, but i am able to reach at the uboot prompt and successfully booted to linux login. Here is the log
    U-Boot SPL 2023.04-00001-g3f59154839-dirty (Oct 19 2023 - 20:06:44 +0530)
    resetting ...
    USB XHCI 1.00
    I/TC:
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    U-Boot SPL 2023.04-00001-g3f59154839-dirty (Oct 19 2023 - 20:10:18 +0530)
    USB XHCI 1.00
    U-Boot 2023.04-00001-g3f59154839-dirty (Oct 19 2023 - 20:10:18 +0530)
    SoC:   AM64X SR2.0 HS-FS
    Model: Texas Instruments AM642 SK
    Board: AM64B-SKEVM rev A
    DRAM:  2 GiB
    Core:  63 devices, 31 uclasses, devicetree: separate
    MMC:   mmc@fa00000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 MAC addresses don't match:
    Address in ROM is               34:08:e1:80:af:0b
    Address in environment is       70:ff:76:1e:bc:3f
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  0
    => run usbboot
    starting USB...
    USB XHCI 1.00
    20658688 bytes read in 925 ms (21.3 MiB/s)
    55213 bytes read in 33 ms (1.6 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008ffef000, end 000000008ffff7ac ... OK
    Working FDT set to 8ffef000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.33-rt11-00001-g3ab301d00947-dirty (chris@chris-HP-Pavilion-All-in-One-Desktop-27-ca2xxx) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Fri Oct 20 12:51:19 IST 2023
    [    0.000000] Machine model: Texas Instruments AM642 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
    [    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fba00000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=5d4769e6-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1888776K/2097152K available (12544K kernel code, 1294K rwdata, 4052K rodata, 2176K init, 498K bss, 175608K reserved, 32768K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008614] Console: colour dummy device 80x25
    [    0.013208] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023889] pid_max: default: 32768 minimum: 301
    [    0.028673] LSM: Security Framework initializing
    [    0.033546] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041132] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051180] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.058658] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.064971] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.071493] rcu: Hierarchical SRCU implementation.
    [    0.071497] rcu:     Max phase no-delay instances is 1000.
    [    0.071562] printk: bootconsole [ns16550a0] printing thread started
    I[/ T C :  0Se.0c8o8n4d5ar0]y  PClPUat f1o rimn itMiSIa:l imzsiin-gc
    gntIro/lTlCe:r S@e18c2o0n0d0a0r yd oCmPUa i1n  csrweiattcehidn
    : [ t o   n0o.r0m8al8 74w2or] lPdC Ib/oMotSI
      /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.089625] EFI services will not be available.
    [    0.089952] smp: Bringing up secondary CPUs ...
    [    0.106890] Detected VIPT I-cache on CPU1
    [    0.107037] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.107056] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.107120] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.148434] smp: Brought up 1 node, 2 CPUs
    [    0.148442] SMP: Total of 2 processors activated.
    [    0.148449] CPU features: detected: 32-bit EL0 Support
    [    0.148456] CPU features: detected: CRC32 instructions
    [    0.148535] CPU: All CPU(s) started at EL2
    [    0.148538] alternatives: applying system-wide alternatives
    [    0.150653] devtmpfs: initialized
    [    0.160040] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.160067] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.161602] pinctrl core: initialized pinctrl subsystem
    [    0.162287] DMI not present or invalid.
    [    0.163058] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.164460] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.167634] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.168120] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.168241] audit: initializing netlink subsys (disabled)
    [    0.169067] thermal_sys: Registered thermal governor 'step_wise'
    [    0.169077] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.169149] cpuidle: using governor menu
    [    0.169389] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.169464] audit: type=2000 audit(0.136:1): state=initialized audit_enabled=0 res=1
    [    0.169477] ASID allocator initialised with 65536 entries
    [    0.182909] KASLR disabled due to lack of seed
    [    0.191745] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.191760] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.191765] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
         0.191769] HugeTLB: 0 KiB vmemmap can bIe/ fTrCe:e dR efseorr vaed  32s.ha0 rMediB  mpeamogrey
    7i[s   e  n0a.bl19e1d7
     4]I/ HTuC:ge DTyLBn:a mriec gsishtaereredd  m2e.m0o0r yM iisB  peangaeb lseidz
    e, pI/reT-Ca:l lNoorcamtaeld  Wo0r lpad gevsir
    vm[a l  i z0a.t1io91n7 7s7u]pp oHrugt eiTLsB :d is0 aKbilBe d
      emI/maTpC : cAans ynbec hfrroeneodu s fonro tai f2i.c0a0t iMonisB  parage ed
    1s[ a bl e d0.
     91783] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.191786] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.208858] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
    [    0.210185] iommu: Default domain type: Translated
    [    0.210200] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.210551] SCSI subsystem initialized
    [    0.211074] usbcore: registered new interface driver usbfs
    [    0.211120] usbcore: registered new interface driver hub
    [    0.211153] usbcore: registered new device driver usb
    [    0.211777] pps_core: LinuxPPS API ver. 1 registered
    [    0.211782] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.211802] PTP clock support registered
    [    0.211929] EDAC MC: Ver: 3.0.0
    [    0.213092] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.213351] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.213518] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.214248] FPGA manager framework
    [ ▒r▒▒▒▒▒▒▒Advanced Linux Sound Architecture Driver Initialized.
    [    0.215686] clocksource: Switched to clocksource arch_sys_counter
    [    0.468675] printk: console [ttyS2] printing thread started
    [    0.216013] VFS: Disk quotas dquot_6.6.0
    [    0.468690] printk: console [ttyS2] enabled
    [    0.468696] printk: bootconsole [ns16550a0] disabled
    [    0.478273] printk: bootconsole [ns16550a0] printing thread stopped
    [    0.496496] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    0.496656] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    0.496669] Creating 7 MTD partitions on "fc40000.spi.0":
    [    0.496676] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    0.498251] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    0.499605] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    0.501174] 0x000000700000-0x000000740000 : "ospi.env"
    [    0.502424] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    0.503766] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    0.505170] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    0.512744] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    0.551698] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.554440] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    0.554457] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    0.554517] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    0.554741] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    0.554749] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    0.562358] pps pps0: new PPS source ptp0
    [    0.562728] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    0.615593] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    0.635053] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    0.661744] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    0.661778] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    0.662105] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [    0.662167] xhci-hcd xhci-hcd.0.auto: irq 498, io mem 0x0f410000
    [    0.662410] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    0.662428] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    0.662442] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [    0.663304] hub 1-0:1.0: USB hub found
    [    0.663342] hub 1-0:1.0: 1 port detected
    [    0.663789] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    0.664453] hub 2-0:1.0: USB hub found
    [    0.664486] hub 2-0:1.0: 1 port detected
    [    0.667775] mmc0: CQHCI version 5.10
    [    0.669948] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
    [    0.679775] ALSA device list:
    [    0.679790]   No soundcards found.
    [    0.684541] mmc1: CQHCI version 5.10
    [    0.711706] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    0.718297] sdhci-am654 fa10000.mmc: card claims to support voltages below defined range
    [    0.729608] mmc0: new SDIO card at address 0001
    [    1.919705] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    2.069309] usb-storage 1-1:1.0: USB Mass Storage device detected
    [    2.069904] scsi host0: usb-storage 1-1:1.0
    [    2.197751] sdhci-am654 fa00000.mmc: Power on failed
    [    2.228371] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.228617] Waiting for root device PARTUUID=5d4769e6-02...
    [    3.100699] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00 PQ: 0 ANSI: 6
    [    3.103191] sd 0:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
    [    3.104030] sd 0:0:0:0: [sda] Write Protect is off
    [    3.104349] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
    [    3.115790]  sda: sda1 sda2
    [    3.116401] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [    3.632351] EXT4-fs (sda2): recovery complete
    [    3.633241] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [    3.633342] VFS: Mounted root (ext4 filesystem) on device 8:2.
    [    3.636717] devtmpfs: mounted
    [    3.638278] Freeing unused kernel memory: 2176K
    [    3.638421] Run /sbin/init as init process
    [    4.065604] systemd[1]: System time before build time, advancing clock.
    [    4.349652] NET: Registered PF_INET6 protocol family
    [    4.351275] Segment Routing with IPv6
    [    4.351318] In-situ OAM (IOAM) with IPv6
    [    4.402287] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    4.402880] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.04!
    [    4.497547] systemd[1]: Hostname set to <am64xx-evm>.
    [    4.676970] systemd-sysv-generator[139]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.710774] systemd-sysv-generator[139]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.710964] systemd-sysv-generator[139]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.712715] systemd-sysv-generator[139]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.716832] systemd-sysv-generator[139]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.719479] systemd-sysv-generator[139]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.721227] systemd-sysv-generator[139]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.722443] systemd-sysv-generator[139]: SysV service '/etc/init.d/resize_rootfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    4.726080] systemd-sysv-generator[139]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    5.110974] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    5.113231] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    5.171362] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    5.252946] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    5.343020] systemd[1]: Queued start job for default target Graphical Interface.
    [  OK  ] Created slice Slice /system/getty    5.409518] systemd[1]: Created slice Slice /system/getty.
    0m.
    [  OK  ] Created slice Slice /system/modprob[    5.435867] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    5.459821] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    5.486872] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password …ts to [    5.508476] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password R…uests [    5.532352] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Reached target Path Units.[    5.556533] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems.
    [0m.
    [  OK  ] Reached target Slice Units.[    5.596016] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Swaps.[    5.616041] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    5.686681] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    5.708093] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    5.736750] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    5.760504] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    5.785079] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    5.808811] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [  OK  ] Listening on Journal Socket.
    [    5.832883] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Network Service Netlin[    5.845195] systemd[1]: Listening on Network Service Netlink Socket.
    k Socket.
    [  OK  ] Listening on udev Control Socket    5.869011] systemd[1]: Listening on udev Control Socket.
    m.
    [  OK  ] Listening on udev Kernel Socket[    5.892717] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    5.916925] systemd[1]: Listening on User Database Manager Socket.
    Socket.
             Mounting Huge Pages File System...
    [    5.972485] systemd[1]: Mounting Huge Pages File System...
             Mounting POSIX Message Queue File System..[    5.991653] systemd[1]: Mounting POSIX Message Queue File System...
             Mounting Kernel Debug File System...[    6.040501] systemd[1]: Mounting Kernel Debug File System...
    [    6.060585] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
             Mounting Temporary Directory /tmp...[    6.092615] systemd[1]: Mounting Temporary Directory /tmp...
             Starting Create List of Static Device Nodes    6.140879] systemd[1]: Starting Create List of Static Device Nodes...
    m...
             Starting Load Kernel Module configfs...[    6.170466] systemd[1]: Starting Load Kernel Module configfs...
             Starting Load Kernel Module drm...
    [    6.198608] systemd[1]: Starting Load Kernel Module drm...
             Starting Load Kernel Module fuse...[    6.233015] systemd[1]: Starting Load Kernel Module fuse...
    [    6.275377] systemd[1]: Starting RPC Bind...
    [    6.292439] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
             Starting Journal Service...
    [    6.312467] systemd[1]: Starting Journal Service...
             Starting Load Kernel Modules...
    [    6.385236] systemd[1]: Starting Load Kernel Modules...
             Starting Generate network …ts from Kernel co[    6.404448] systemd[1]: Starting Generate network units from Kernel command line...
    mmand line...
             Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems...
    [0m...
             Starting Coldplug All udev Devices...
    [    6.476840] systemd[1]: Starting Coldplug All udev Devices...
    [    6.507648] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    6.523204] fuse: init (API version 7.37)
    [  OK  ] Mounted POSIX Message Queue File Sy[    6.529146] systemd[1]: Mounted POSIX Message Queue File System.
    stem.
    [    6.560550] EXT4-fs (sda2): re-mounted. Quota mode: none.
    [    6.567575] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp    6.593463] systemd[1]: Mounted Temporary Directory /tmp.
    m.
    [  OK  ] Finished Create List of Static Devi[    6.619157] systemd[1]: Finished Create List of Static Device Nodes.
    ce Nodes.
    [  OK  ] Finished Load Kernel Module configf[    6.641564] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    s.
    [    6.642863] systemd[1]: Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module fuse    6.669556] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    m.
    [    6.670819] systemd[1]: Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [    6.695469] systemd[1]: Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units fro[    6.713307] systemd[1]: Finished Generate network units from Kernel command line.
    [  OK  ] Started RPC Bind.
    [    6.741012] systemd[1]: Started RPC Bind.
    [  OK  ] Started Journal Service.
    [    6.753052] systemd[1]: Started Journal Service.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    6.894822] systemd-journald[153]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
    [    7.138444] audit: type=1334 audit(1651167748.072:2): prog-id=5 op=LOAD
    [    7.146534] audit: type=1334 audit(1651167748.084:3): prog-id=6 op=LOAD
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
    [    7.515792] random: crng init done
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Timer service to update the IP on OLED each 10s.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
             Starting Weston socket...
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Listening on Weston socket.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting startwlanap...
             Starting startwlansta...
    [    8.949329] audit: type=1334 audit(1651168234.212:4): prog-id=7 op=LOAD
    [    8.960472] audit: type=1334 audit(1651168234.224:5): prog-id=8 op=LOAD
             Starting User Login Management...
    [  OK  ] Started TEE Supplicant.
             Starting telnetd.service...
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Started startwlansta.
    [  OK  ] Started startwlanap.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [    9.137599] /dev/mmcblk1p1: Can't open blockdev
    [    9.133689] startwlansta.sh[230]: mount: /media/mmcblk1p1: special device /dev/mmcblk1p1 does not exist.
    [  OK  ] Started telnetd.service.
             Starting LSB: Expand Rootfs of boot device...
    [  OK  ] Started LSB: Expand Rootfs of boot device.
    [    9.719405] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    9.753177] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    9.808599] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [    9.822040] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    9.831324] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    9.844003] remoteproc remoteproc0: 5000000.m4fss is available
    [    9.888433] remoteproc remoteproc0: powering up 5000000.m4fss
    [    9.888464] remoteproc remoteproc0: Booting fw image am64-mcu-m4f0_0-fw, size 86084
    [    9.891351] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node m4f-dma-memory@a4000000
    [    9.891584] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
    [    9.891595] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
    [  OK  ] Started User Login Management.
    [   10.301315] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   10.302351] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.302584] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   10.386469] platform 78000000.r5f: configured R5F for remoteproc mode
    [   10.388286] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.388750] remoteproc remoteproc1: 78000000.r5f is available
    [   10.396258] platform 78200000.r5f: configured R5F for remoteproc mode
    [   10.403584] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [   10.404121] remoteproc remoteproc2: 78200000.r5f is available
    [   10.437460] remoteproc remoteproc1: powering up 78000000.r5f
    [   10.437489] remoteproc remoteproc1: Booting fw image am64-main-r5f0_0-fw, size 86352
    [   10.465169] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.466135] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   10.466186] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
    [   10.466195] remoteproc remoteproc1: remote processor 78000000.r5f is now up
    [   10.467225] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [   10.477351] platform 78400000.r5f: configured R5F for remoteproc mode
    [   10.480258] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.507426] remoteproc remoteproc2: powering up 78200000.r5f
    [   10.507459] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
    [   10.510613] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a1000000
    [   10.511491] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   10.511525] rproc-virtio rproc-virtio.3.auto: registered virtio2 (type 7)
    [   10.511534] remoteproc remoteproc2: remote processor 78200000.r5f is now up
    [   10.512711] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   10.542728] remoteproc remoteproc3: 78400000.r5f is available
    [   10.551905] remoteproc remoteproc3: powering up 78400000.r5f
    [   10.551935] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
    [   10.553787] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.554609] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.554654] rproc-virtio rproc-virtio.4.auto: registered virtio3 (type 7)
    [   10.554663] remoteproc remoteproc3: remote processor 78400000.r5f is now up
    [   10.555577] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   10.568094] platform 78600000.r5f: configured R5F for remoteproc mode
    [   10.568522] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.569097] remoteproc remoteproc4: 78600000.r5f is available
    [   10.602737] remoteproc remoteproc4: powering up 78600000.r5f
    [   10.602766] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
    [  OK  ] Started Network Configuration.
    [   10.605469] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.606224] virtio_rpmsg_bus virtio4: rpmsg host is online
             Starting Wait for Network to be Configured...
    [   10.606258] rproc-virtio rproc-virtio.5.auto: registered virtio4 (type 7)
    [   10.606267] remoteproc remoteproc4: remote processor 78600000.r5f is now up
             Starting Network Name Resolution...
    [   10.607141] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [   10.661908] wl18xx_driver wl18xx.6.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [   10.965886] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [   10.965924] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   11.012717] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   11.012757] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   11.036657] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [   11.049773] wlcore: loaded
    [   11.727853] startwlansta.sh[218]: Wi-Fi user configuration file missing, exit
    [   12.099518] startwlanap.sh[377]: adding wlan1 interface
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
    [   12.381704] startwlanap.sh[385]: Line 499: unknown configuration item 'wep_rekey_period'
    [   12.382513] startwlanap.sh[385]: 1 errors found in configuration file '/usr/share/wl18xx/hostapd.conf'
    [   12.383089] startwlanap.sh[385]: Failed to set up interface with /usr/share/wl18xx/hostapd.conf
    [   12.383612] startwlanap.sh[385]: Failed to initialize interface
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland…ositor, as a system service...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [   13.307898] audit: type=1334 audit(1651168238.568:6): prog-id=9 op=LOAD
    [   13.308345] audit: type=1334 audit(1651168238.572:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    [   13.493205] remoteproc remoteproc5: 30034000.pru is available
    [   13.511319] remoteproc remoteproc6: 30004000.rtu is available
    [   13.544271] remoteproc remoteproc7: 3000a000.txpru is available
    [   13.548835] remoteproc remoteproc8: 30038000.pru is available
    [   13.564433] remoteproc remoteproc9: 30006000.rtu is available
    [   13.577669] remoteproc remoteproc10: 3000c000.txpru is available
    [   13.592201] remoteproc remoteproc11: 300b4000.pru is available
    [   13.611845] remoteproc remoteproc12: 30084000.rtu is available
    [   13.625310] remoteproc remoteproc13: 3008a000.txpru is available
    [   13.629693] remoteproc remoteproc14: 300b8000.pru is available
    [   13.650323] remoteproc remoteproc15: 30086000.rtu is available
    [   13.660021] remoteproc remoteproc16: 3008c000.txpru is available
    [   13.781224] wlcore: using inverted interrupt logic: 2
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting Load/Save RF Kill Switch Status...
    [  OK  ] Started User Database Manager.
    [   13.887593] wlcore: PHY firmware version: Rev 8.2.0.0.245
    [   13.983441] wlcore: firmware booted (Rev 8.9.0.0.86)
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [   14.228310] audit: type=1006 audit(1651168239.492:8): pid=459 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   14.228418] audit: type=1300 audit(1651168239.492:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd36d6658 a2=4 a3=ffffba3ba020 items=0 ppid=1 pid=459 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   14.228466] audit: type=1327 audit(1651168239.492:8): proctitle="(systemd)"
    [  OK  ] Started Load/Save RF Kill Switch Status.
    [   14.884264] audit: type=1325 audit(1651168240.096:9): table=nat family=2 entries=0 op=xt_register pid=462 comm="iptables"
    [   14.885184] audit: type=1300 audit(1651168240.096:9): arch=c00000b7 syscall=209 success=yes exit=0 a0=4 a1=0 a2=40 a3=ffffce94c568 items=0 ppid=377 pid=462 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" key=(null)
    [   14.899000] audit: type=1327 audit(1651168240.096:9): proctitle=69707461626C6573002D74006E6174002D4100504F5354524F5554494E47002D6F0065746830002D6A004D415351554552414445
    [   14.899586] audit: type=1325 audit(1651168240.160:10): table=nat family=2 entries=5 op=xt_replace pid=462 comm="iptables"
    [   14.902164] audit: type=1300 audit(1651168240.160:10): arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=1e4e2210 items=0 ppid=377 pid=462 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" key=(null)
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston.
    [FAILED] Failed to start Weston, a …mpositor, as a system service.
    See 'systemctl status weston.service' for details.
    [DEPEND] Dependency failed for Matrix GUI.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am64xx-evm -
    Arago 2023.04 am64xx-evm -
    am64xx-evm login:
