Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
Hello, I'm working on TDA4VH with sdk0805, and ran into a problem when running my tiovx application.
Here is the dot files of my graph structure, exported by `tivxExportGraphToDot` api: dot.zip
My graph features that it consists of two capture nodes, two viss nodes and aewb nodes. The first capture node has 3 channels of 1920x1080 images, while the second has 1 channel of 3840x2160 image. A mosaic node is added to join these 4 images into a 1920x1080 image.
I tried four different way to run my graph, and got different result:
1. graph streaming.
I tried to call `vxEnableGraphStreaming(graph, capture_node_0)` and `vxStartGraphStreaming` to run my graph, but the graph cannot run.
2. vxProcessGraph
I tried to call vxProcessGraph in a while loop to run my graph, this time it ran for one cycle and couldn't run anymore.
3. pipeline with capture node output as graph parameter
I tried to add the outputs of two capture nodes as graph parameter, and called `vxSetGraphScheduleConfig(graph, VX_GRAPH_SCHEDULE_MODE_QUEUE_AUTO, 2, graph_prms_list)`, this time the graph ran pretty well, and the display image is pretty well.
4. pipeline with viss node output as graph parameter
similar to the last method, the difference is that the image outputs of two viss node is added as graph parameter. this time the graph run with many errors, I can see many error lines in the remote log(the error in iss_sensors.c makes no difference to this problem).
I tried to find the error line in source code, and print the value of fvid2_status, it was -2, which meas bad args.
022-01-01 00:00:46 [MCU2_0] 446.481326 s: iss_sensors.c[644](error): ctrlCmd: 0, status is -1
2022-01-01 00:00:46 [MCU2_0] 446.481390 s: iss_sensors.c[787](error): status is -1
2022-01-01 00:00:46 [MCU2_0] 446.504940 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.512037 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.512334 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.512600 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.520238 s: iss_sensors.c[644](error): ctrlCmd: 0, status is -1
2022-01-01 00:00:46 [MCU2_0] 446.520299 s: iss_sensors.c[787](error): status is -1
2022-01-01 00:00:46 [MCU2_0] 446.542659 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.545301 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.545594 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.545925 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.566513 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.567205 s: iss_sensors.c[644](error): ctrlCmd: 0, status is -1
2022-01-01 00:00:46 [MCU2_0] 446.567263 s: iss_sensors.c[787](error): status is -1
2022-01-01 00:00:46 [MCU2_0] 446.578569 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.578903 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.579237 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:46 [MCU2_0] 446.579789 s: iss_sensors.c[644](error): ctrlCmd: 0, status is -1
2022-01-01 00:00:46 [MCU2_0] 446.579951 s: iss_sensors.c[787](error): status is -1
2022-01-01 00:00:46 [MCU2_0] 446.580404 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.611161 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.645136 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.645493 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.645822 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.649155 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.656020 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.678348 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.678707 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.679098 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.688168 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.693695 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.704742 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.711579 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.711940 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.712271 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.731463 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.732242 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.782471 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.782818 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.783200 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.807024 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.811314 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.811649 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.812027 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.821460 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.844676 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.845063 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.845388 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.845952 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.846607 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.890548 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.891304 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.911123 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.911474 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.911786 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.944383 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.944729 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.945116 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.958054 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.971453 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.977600 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.978014 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.978358 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.995767 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 446.996511 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.033525 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.034295 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.044138 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.044492 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.044805 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.084505 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.084902 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.085240 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.109096 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.110582 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.110940 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.111290 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.121577 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.156425 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.157200 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.177144 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.177497 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.177814 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.184506 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.185249 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.210375 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.210710 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.211078 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.243650 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.244105 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.244464 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.260098 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.271557 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.297890 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.298562 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.310154 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.310495 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.310814 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.335546 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.336302 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.343391 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.343726 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.344104 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.386442 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.386950 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.387287 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.411144 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.422205 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.443147 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.443494 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.443798 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.448837 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.449543 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.486595 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.487360 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.509658 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.510059 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.510393 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.542961 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.543326 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.543678 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.562210 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:47 [MCU2_0] 447.571573 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.599954 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.600666 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.609437 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.609781 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.610141 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.637662 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.638425 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.642646 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.643034 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.643377 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.688730 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.689126 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.689457 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.713194 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.722186 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.742423 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.742761 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.743129 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.750935 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.751587 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.788653 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.789403 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.808951 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.809305 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.809628 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.842396 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.842769 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.843151 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.864243 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.871549 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.902023 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.902695 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.908707 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.909112 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.909450 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.939671 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.940418 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.941958 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.942303 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.942619 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.975204 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.975547 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 447.975902 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.015239 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.022184 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.041696 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.042098 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.042440 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.052985 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.053644 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.090720 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.091475 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.108245 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.108592 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.108927 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.141779 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.142164 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.142491 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.166298 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.171521 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.204079 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.204779 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.208020 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.208365 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.208671 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.241214 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.241687 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.242065 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.242492 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.243228 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.274483 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.274817 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.275197 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.317319 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.322174 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.341042 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.341392 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.341705 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.355059 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.355742 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.392776 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.393499 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.407638 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.408036 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.408381 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.443743 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.444135 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.444470 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.468368 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.471528 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.506116 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.507396 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.507696 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.507784 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.508124 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.540613 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.541003 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.541327 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.543814 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.544538 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.573943 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.574301 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:48 [MCU2_0] 448.574616 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.619348 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.622172 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.640414 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.640775 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.641134 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.657110 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.657772 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.694895 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.695562 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.706949 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.707294 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.707610 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.745690 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.746243 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.746579 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.770395 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.788796 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.806707 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.807104 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.807438 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.808131 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.808791 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.845917 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.846578 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.873263 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.873610 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.874001 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.906525 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.906944 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.907307 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.921546 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.922314 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.959203 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.959974 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.973040 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.973391 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.973699 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.996953 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 448.997632 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.006273 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.006620 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.006998 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.047912 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.048265 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.048588 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.072454 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.088778 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.106073 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.106425 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.106744 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.110211 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.110966 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.147948 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.148607 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.172527 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.172914 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.173246 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.205817 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.206252 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.206585 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.223483 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.238345 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.261265 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.262037 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.272306 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.272643 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.273028 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.299014 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.299682 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.305542 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.305924 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.306272 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.350080 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.350432 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.350759 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.374583 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.388801 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.405304 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.405653 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.406032 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.412261 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.413037 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.450054 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.450712 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.471805 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.472213 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.472533 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.505226 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.505595 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.506054 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.525564 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.538952 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.563350 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.564151 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.571586 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.571941 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:49 [MCU2_0] 449.572276 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.601073 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.601746 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.638105 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.638596 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.638981 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.671369 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.671715 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.672093 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.676612 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.688276 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.717291 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.718067 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.737923 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.738283 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.738596 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.752091 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.752750 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.771173 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.771522 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.771841 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.804445 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.804801 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.805360 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.827619 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.838785 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.865365 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.866148 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.871020 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.871458 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.871805 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.903160 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.904007 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.937399 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.937779 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.938135 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.970648 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.971110 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.971524 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.978660 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 449.988279 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.016627 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.017374 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.037163 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.037564 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.037938 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.054173 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.054992 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.070373 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.070705 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.071268 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.105187 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.105538 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.105912 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.129680 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.138971 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.167448 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.168225 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.170177 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.170524 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.171040 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.205192 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.205973 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.236647 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.237024 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.237346 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.269955 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.270326 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.270659 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.280697 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.288271 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.318458 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.319221 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.336418 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.336753 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.337121 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.356214 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.356978 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.369649 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.370044 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.370377 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.407314 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.407673 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.408054 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.431809 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.438812 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.469489 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.469826 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.470210 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.470624 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.471426 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.507244 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.508009 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.535948 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.536305 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.536620 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.569251 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.569626 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.570034 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:50 [MCU2_0] 450.582794 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.588279 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.620550 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.621348 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.635709 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.636114 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.636461 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.658311 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.659093 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.668958 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.669319 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.669659 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.709310 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.709649 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.710033 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.733824 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.738811 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.768700 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.769108 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.769432 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.771531 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.772269 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.809305 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.810091 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.835242 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.835592 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.835930 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.868560 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.868956 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.869311 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.884829 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.888254 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.922598 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.923357 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.935015 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.935360 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.935667 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.960347 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.961128 s: VX_ZONE_ERROR:[tivxKernelImgMosaicMscDrvSubmit:1074] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.968250 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
2022-01-01 00:00:51 [MCU2_0] 450.968596 s: VX_ZONE_ERROR:[tivxVpacVissProcess:1050] Failed to Submit Request
My graph could successfully run in method 3, so there should not be any problem in my graph structure. So I would like to know why my graph couldn't run in the other 3 methods? the errors in method 4 is especially strange, how could the args be invalid?
