GPIO Question
The way that I understand you will need the GPMC_A* (*=1~10)  used as an address line when you are communicating with the NOR memory?  If you are having only a NAND memory you will not use these address line.  My question is when you only have a NAND memory in your system can you use these address lines as a GPIO only?
High Regards,
Ali.
