Part Number: PROCESSOR-SDK-J721S2
I am using J721S2 PDK 8.6.1.2 and trying to establish an IPC communication b/w A72 (Linux) and Main R5F(MCU2_0).
The below are the errors I am getting.
"pru_rproc: Unknown symbol pruss_cfg_update (err -2)"
ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue May 2 16:19:15 UTC 2023
[ 0.000000] Machine model: Texas Instruments J721S2 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71_1-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node c71_1-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 111 MiB
[ 0.000000] OF: reserved mem: initialized node c71_0-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memory-region@b2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node dma-memory@b4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bc000000, size 48 MiB
[ 0.000000] OF: reserved mem: initialized node core-heap-memory-lo@bc000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000b0ffffff]
[ 0.000000] node 0: [mem 0x00000000b1000000-0x00000000b1ffffff]
[ 0.000000] node 0: [mem 0x00000000b2000000-0x00000000b9ffffff]
[ 0.000000] node 0: [mem 0x00000000ba000000-0x00000000bbffffff]
[ 0.000000] node 0: [mem 0x00000000bc000000-0x00000000beffffff]
[ 0.000000] node 0: [mem 0x00000000bf000000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000
[ 0.000000] mtdid=spi-nand0
[ 0.000000] mtdparts=spi-nand0:512k(ospi_nand.sbl),512k(ospi_nand.tifs),27648k(ospi_nand.combined),102144k(ospi_nand.rootfs),256k(ospi_nand.phypattern)
[ 0.000000] ubi part ospi_nand.rootfs
[ 0.000000] ubi.mtd=ospi_nand.rootfs root=ubi0:rootfs rw rootfstype=ubifs rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 518228K/1048576K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 530348K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @81c00000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000081430000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081440000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008396] Console: colour dummy device 80x25
[ 0.012961] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023632] pid_max: default: 32768 minimum: 301
[ 0.028388] LSM: Security Framework initializing
[ 0.033135] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.040698] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.049603] rcu: Hierarchical SRCU implementation.
[ 0.054679] Platform MSI: msi-controller@1820000 domain created
[ 0.060880] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070181] EFI services will not be available.
[ 0.074919] smp: Bringing up secondary CPUs ...
[ 0.085798] Detected PIPT I-cache on CPU1
[ 0.085826] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.085839] GICv3: CPU1: using allocated LPI pending table @0x0000000081450000
[ 0.085879] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.085934] smp: Brought up 1 node, 2 CPUs
[ 0.115281] SMP: Total of 2 processors activated.
[ 0.120087] CPU features: detected: 32-bit EL0 Support
[ 0.125342] CPU features: detected: CRC32 instructions
[ 0.140049] CPU: All CPU(s) started at EL2
[ 0.144252] alternatives: patching kernel code
[ 0.149403] devtmpfs: initialized
[ 0.157114] KASLR disabled due to lack of seed
[ 0.161775] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.171742] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.178812] pinctrl core: initialized pinctrl subsystem
[ 0.184417] DMI not present or invalid.
[ 0.188661] NET: Registered protocol family 16
[ 0.193467] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.200704] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.208649] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.216960] thermal_sys: Registered thermal governor 'step_wise'
[ 0.216963] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.223583] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.237224] ASID allocator initialised with 32768 entries
[ 0.259559] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.266417] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.273268] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.280116] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.287603] cryptd: max_cpu_qlen set to 1000
[ 0.293760] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
[ 0.302872] vsys_3v3: supplied by evm_12v0
[ 0.307308] vsys_5v0: supplied by evm_12v0
[ 0.312092] iommu: Default domain type: Translated
[ 0.317239] SCSI subsystem initialized
[ 0.321373] mc: Linux media interface: v0.10
[ 0.325754] videodev: Linux video capture interface: v2.00
[ 0.331387] pps_core: LinuxPPS API ver. 1 registered
[ 0.336457] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.345795] PTP clock support registered
[ 0.349817] EDAC MC: Ver: 3.0.0
[ 0.353629] FPGA manager framework
[ 0.357146] Advanced Linux Sound Architecture Driver Initialized.
[ 0.363802] clocksource: Switched to clocksource arch_sys_counter
[ 0.370158] VFS: Disk quotas dquot_6.6.0
[ 0.374197] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.383932] Carveout Heap: Exported 32 MiB at 0x00000000ba000000
[ 0.390140] NET: Registered protocol family 2
[ 0.394712] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.402812] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.411389] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.419336] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.426793] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.433374] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.440147] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.447419] NET: Registered protocol family 1
[ 0.452132] RPC: Registered named UNIX socket transport module.
[ 0.458193] RPC: Registered udp transport module.
[ 0.463009] RPC: Registered tcp transport module.
[ 0.467812] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.474394] NET: Registered protocol family 44
[ 0.478942] PCI: CLS 0 bytes, default 64
[ 0.483332] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.493851] Initialise system trusted keyrings
[ 0.498487] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.506690] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.512969] NFS: Registering the id_resolver key type
[ 0.518150] Key type id_resolver registered
[ 0.522426] Key type id_legacy registered
[ 0.526552] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.533402] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.541048] 9p: Installing v9fs 9p2000 file system support
[ 0.565873] Key type asymmetric registered
[ 0.570062] Asymmetric key parser 'x509' registered
[ 0.575062] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.582622] io scheduler mq-deadline registered
[ 0.587247] io scheduler kyber registered
[ 0.592842] pinctrl-single 4301c000.pinctrl: 101 pins, size 404
[ 0.599064] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.609717] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.622850] brd: module loaded
[ 0.629805] loop: module loaded
[ 0.633572] megasas: 07.714.04.00-rc1
[ 0.639473] tun: Universal TUN/TAP device driver, 1.6
[ 0.645021] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.651430] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.657508] sky2: driver version 1.30
[ 0.661900] VFIO - User Level meta-driver version: 0.3
[ 0.667728] i2c /dev entries driver
[ 0.672204] sdhci: Secure Digital Host Controller Interface driver
[ 0.678522] sdhci: Copyright(c) Pierre Ossman
[ 0.683180] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.689559] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.695913] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.703328] optee: probing for conduit method.
[ 0.707880] optee: api uid mismatch
[ 0.711441] optee: probe of firmware:optee failed with error -22
[ 0.718959] NET: Registered protocol family 17
[ 0.723609] 9pnet: Installing 9P2000 support
[ 0.728024] Key type dns_resolver registered
[ 0.732531] Loading compiled-in X.509 certificates
[ 0.745946] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara')
[ 0.784628] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.790819] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.796902] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.803376] pca953x 3-0021: supply vcc not found, using dummy regulator
[ 0.810212] pca953x 3-0021: using no AI
[ 0.835846] pca953x 3-0021: failed writing register
[ 0.840895] pca953x: probe of 3-0021 failed with error -121
[ 0.846871] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.853684] pca953x 3-0020: using no AI
[ 0.857654] pca953x 3-0020: failed writing register
[ 0.862686] pca953x: probe of 3-0020 failed with error -121
[ 0.868623] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.875422] pca953x 3-0022: using AI
[ 0.879125] pca953x 3-0022: failed writing register
[ 0.884150] pca953x: probe of 3-0022 failed with error -121
[ 0.889886] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.896510] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 0.903343] pca953x 4-0020: using no AI
[ 0.927823] omap_i2c 2040000.i2c: Arbitration lost
[ 0.932729] pca953x 4-0020: failed writing register
[ 0.937768] pca953x: probe of 4-0020 failed with error -11
[ 0.943418] omap_i2c 2040000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.949794] pca953x 5-0020: supply vcc not found, using dummy regulator
[ 0.956646] pca953x 5-0020: using no AI
[ 0.983995] omap_i2c 2050000.i2c: Arbitration lost
[ 0.988899] pca953x 5-0020: failed writing register
[ 0.993939] pca953x: probe of 5-0020 failed with error -11
[ 0.999599] omap_i2c 2050000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.006024] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
[ 1.014574] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
[ 1.023914] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
[ 1.032525] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
[ 1.044965] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.052643] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.060921] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.069197] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.078302] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 1.085045] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 1.094293] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
[ 1.104180] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.110940] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.119827] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
[ 1.129967] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.136731] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.144417] omap8250 40a00000.serial: failed to get alias
[ 1.150532] printk: console [ttyS2] disabled
[ 1.154932] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 27, base_baud = 3000000) is a 8250
[ 1.163680] printk: console [ttyS2] enabled
[ 1.172119] printk: bootconsole [ns16550a0] disabled
[ 1.184178] cadence-qspi 47040000.spi: error -ENODEV: No Rx DMA available
[ 1.191253] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.196561] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[ 1.204868] 7 fixed-partitions partitions found on MTD device spi0.0
[ 1.211210] Creating 7 MTD partitions on "spi0.0":
[ 1.215991] 0x000000000000-0x000000080000 : "ospi_nand.sbl"
[ 1.222345] 0x000000080000-0x000000140000 : "ospi_nand.tifs"
[ 1.228773] 0x000000140000-0x000000180000 : "ospi_nand.uartval"
[ 1.235237] 0x000000180000-0x0000002c0000 : "ospi_nand.btdldr"
[ 1.242013] 0x0000002c0000-0x0000026c0000 : "ospi_nand.combined"
[ 1.263203] 0x0000026c0000-0x000007fc0000 : "ospi_nand.rootfs"
[ 1.305920] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[ 1.313315] cadence-qspi 47050000.spi: error -ENODEV: No Rx DMA available
[ 1.320322] spi-nor spi1.0: unrecognized JEDEC id bytes: e0 00 00 00 00 00
[ 1.327192] spi-nor: probe of spi1.0 failed with error -2
[ 1.335723] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
[ 1.379806] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.387709] mdio_bus c200f00.mdio: MDIO device at address 0 is missing.
[ 1.394349] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.407121] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 1.413380] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 1.420500] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 1.426742] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 1.436979] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
[ 1.546784] mmc0: CQHCI version 5.10
[ 1.554494] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 1.561352] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 1.568169] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 1.574965] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 1.581737] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.589225] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.591612] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.597307] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.612845] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.621952] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.631969] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
[ 1.643157] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
[ 1.687807] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.695708] mdio_bus c200f00.mdio: MDIO device at address 0 is missing.
[ 1.702358] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.715131] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 1.721390] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 1.728507] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 1.734731] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 1.744611] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[ 1.753275] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.760780] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.768863] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.776945] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.787205] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.794723] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.802812] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.810899] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.820204] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present!
[ 1.827518] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present!
[ 1.835266] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
[ 1.843174] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
[ 1.850994] ubi0: attaching mtd5
[ 2.384804] ubi0: scanning is finished
[ 2.412991] ubi0: volume 0 ("rootfs") re-sized from 56 to 342 LEBs
[ 2.419436] ubi0: attached mtd5 (name "ospi_nand.rootfs", size 89 MiB)
[ 2.425958] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 2.432818] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 2.439588] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
[ 2.446532] ubi0: good PEBs: 356, bad PEBs: 0, corrupted PEBs: 0
[ 2.452525] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.459729] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 405937904
[ 2.468754] ubi0: available PEBs: 0, total reserved PEBs: 356, PEBs reserved for bad PEB handling: 10
[ 2.477989] ubi0: background thread "ubi_bgt0d" started, PID 136
[ 2.489214] ALSA device list:
[ 2.492178] No soundcards found.
[ 2.497521] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 2.503382] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 137
[ 2.667833] UBIFS (ubi0:0): start fixing up free space
[ 2.860045] UBIFS (ubi0:0): free space fixup complete
[ 2.949097] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.956480] UBIFS (ubi0:0): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 2.966372] UBIFS (ubi0:0): FS size: 33775616 bytes (32 MiB, 133 LEBs), journal size 5079040 bytes (4 MiB, 20 LEBs)
[ 2.976784] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 2.982605] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 4338E179-D43D-4851-8F3A-B41FCD861675, small LPT model
[ 3.006089] VFS: Mounted root (ubifs filesystem) on device 0:20.
[ 3.024306] devtmpfs: mounted
[ 3.028317] Freeing unused kernel memory: 1856K
[ 3.032940] Run /sbin/init as init process
INIT: version 2.96 booting
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue May 2 16:30:19 UTC 2023
[ 4.914144] random: dd: uninitialized urandom read (512 bytes read)
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... [ 5.184166] eth0: mtu greater than device maximum
ifconfig: SIOCSIFMTU: Invalid argument
[ 5.193260] am65-cpsw-nuss c200000.ethernet eth0: configuring for fixed/rgmii-rxid link mode
[ 5.201785] am65-cpsw-nuss c200000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
done.
Starting syslogd/klogd: done
root@j721s2-evm:~#
root@j721s2-evm:~#
root@j721s2-evm:~#
root@j721s2-evm:~#
root@j721s2-evm:~#
root@j721s2-evm:~# cd /lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random#
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random# insmod rng-core.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random# insmod omap-rng.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random# [ 33.867822] tlv71033: disabling
insmod optee-rng.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random# insmod optee-rng.ko
insmod: ERROR: could not insert module optee-rng.ko: File exists
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/hw_random# cd ../ipmi/
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/ipmi#
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/ipmi# insmod ipmi_msghandler.ko
[ 48.493790] IPMI message handler: version 39.2
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/ipmi# insmod ipmi_devintf.ko
[ 52.920222] ipmi device interface
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/ipmi# insmod ipmi_si.ko
[ 57.110781] ipmi_si: IPMI System Interface driver
[ 57.115926] ipmi_si: Unable to find any System Interface(s)
insmod: ERROR: could not insert module ipmi_si.ko: No such device
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/char/ipmi# cd ../../remoteproc/
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/remoteproc#
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/remoteproc# insmod pru_rproc.ko
[ 72.541709] pru_rproc: Unknown symbol pruss_cfg_update (err -2)
[ 72.547655] pru_rproc: Unknown symbol pruss_cfg_read (err -2)
insmod: ERROR: could not insert module pru_rproc.ko: Unknown symbol in module
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/remoteproc# insmod ti_k3_r5_remoteproc.ko
[ 77.344152] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 77.355979] platform 41000000.r5f: configured R5F for IPC-only mode
[ 77.362429] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[ 77.370809] remoteproc remoteproc0: 41000000.r5f is available
[ 77.376594] remoteproc remoteproc0: attaching to 41000000.r5f
[ 77.382337] remoteproc remoteproc0: rsc table is truncated
[ 77.387813] remoteproc remoteproc0: Failed to process resources: -22
[ 77.394156] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: rproc_add failed, ret = -22
[ 77.402545] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_rproc_init failed, ret = -22
[ 77.412543] k3_r5_rproc: probe of bus@100000:bus@28380000:r5fss@41000000 failed with error -22
[ 77.422117] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 77.433846] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 77.440145] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[ 77.448679] remoteproc remoteproc1: 5c00000.r5f is available
[ 77.454367] remoteproc remoteproc1: attaching to 5c00000.r5f
[ 77.460110] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 77.466719] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[ 77.475093] remoteproc1#vdev0buffer: registered virtio0 (type 7)
[ 77.481177] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
[ 77.488604] platform 5d00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 77.500343] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 77.506562] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[ 77.515146] remoteproc remoteproc2: 5d00000.r5f is available
[ 77.520832] remoteproc remoteproc2: attaching to 5d00000.r5f
[ 77.526552] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 77.533160] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[ 77.541542] remoteproc2#vdev0buffer: registered virtio1 (type 7)
[ 77.547624] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached
[ 77.556426] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 77.563938] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 77.564750] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 77.572213] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 77.578668] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
[ 77.586561] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 77.594826] remoteproc remoteproc3: 5e00000.r5f is available
[ 77.609956] platform 5f00000.r5f: configured R5F for remoteproc mode
[ 77.612423] remoteproc remoteproc3: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
[ 77.625690] remoteproc remoteproc3: powering up 5e00000.r5f
[ 77.631323] remoteproc remoteproc3: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
[ 77.631450] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a7000000
[ 77.640774] remoteproc remoteproc3: request_firmware failed: -2
[ 77.649091] remoteproc remoteproc4: 5f00000.r5f is available
[ 77.660341] remoteproc remoteproc4: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -2
[ 77.665420] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 77.670117] remoteproc remoteproc4: powering up 5f00000.r5f
[ 77.677681] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 77.690935] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers[ 77.699099] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
/remoteproc# [ 77.699116] remoteproc remoteproc4: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -2
[ 77.723492] remoteproc remoteproc4: request_firmware failed: -2
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/remoteproc# insmod ti_k3_dsp_remoteproc.ko
[ 84.144042] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@aa000000
[ 84.154298] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 84.160979] remoteproc remoteproc5: 64800000.dsp is available
[ 84.166752] remoteproc remoteproc5: attaching to 64800000.dsp
[ 84.172524] remoteproc remoteproc5: unsupported resource 65538
[ 84.178409] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 84.185019] remoteproc5#vdev0buffer: assigned reserved memory node c71-dma-memory@aa000000
[ 84.193398] remoteproc5#vdev0buffer: registered virtio2 (type 7)
[ 84.199483] remoteproc remoteproc5: remote processor 64800000.dsp is now attached
[ 84.208162] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 84.208199] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71_1-dma-memory@a8000000
[ 84.215660] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 84.232334] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[ 84.232340] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 84.238990] remoteproc remoteproc6: 65800000.dsp is available
[ 84.247129] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 84.252780] remoteproc remoteproc6: attaching to 65800000.dsp
[ 84.266768] remoteproc remoteproc6: unsupported resource 65538
[ 84.272653] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[ 84.279266] remoteproc6#vdev0buffer: assigned reserved memory node c71_1-dma-memory@a8000000
[ 84.287833] remoteproc6#vdev0buffer: registered virtio3 (type 7)
[ 84.293913] remoteproc remoteproc6: remote processor 65800000.dsp is now attached
[ 84.302405] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 84.310284] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers[ 84.318740] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
/remoteproc# [ 84.332326] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/remoteproc# insmod ti_k3_m4_remoteproc.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/remoteproc# cd ../rpmsg
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg#
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg# insmod rpmsg_char.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg# insmod virtio_rpmsg_bus.ko
[ 109.983864] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 109.990404] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 109.996097] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 109.998159] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 110.003590] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 110.011518] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 110.017121] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 110.025045] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers[ 110.041258] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
/rpmsg# [ 110.051782] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 110.060533] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 110.068621] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg# insmod rpmsg_pru.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg# cd ../rpmsg-kdrv/
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg-kdrv#
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg-kdrv# insmod rpmsg_kdrv_switch.ko
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg-kdrv# export LD_LIBRARY_PATH=/lib:/usr/lib:$LD_LIBRARY_PATH
root@j721s2-evm:/lib/modules/5.10.162-g76b3e88d56/kernel/drivers/rpmsg-kdrv# cd
root@j721s2-evm:~# cd /opt/
root@j721s2-evm:/opt# ls -lrt
total 1908
drwxrwxrwx 4 root root 296 Oct 26 2023 ltp
-rwxrwxrwx 1 root root 643 Oct 27 2023 start.sh
-rwxrwxrwx 1 root root 658688 Oct 27 2023 main_renderer_tda4xx_linux_a72_r
-rwxrwxrwx 1 root root 628456 Oct 27 2023 main_mcu_comms_tda4xx_linux_a72_r
-rwxrwxrwx 1 root root 658256 Oct 27 2023 main_app_tda4xx_linux_a72_r
root@j721s2-evm:/opt# ./main_app_tda4xx_linux_a72_r
A72_MAIN Application
Before LPC Fire
LpcInit
MAP Completed
MAP LPC_IPC_HW_SPIN_LOCK_MMR_SIZE
i am in else
initDescriptors
initDescriptors
initDescriptors
initDescriptors
initDescriptors
initDescriptors
initDescriptors
initDescriptors
initDescriptors
rpmsg_char_init 0
_rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.13
ERR_LPC_STATIC_INIT_FAILED
Segmentation fault
