[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.162-g76b3e88d56 (ssubra13@TUA1-L04862-Ubuntu-18.04-valeo-genie-wsl) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Nov 2 20:02:08 GMT 2023
[ 0.000000] Machine model: Texas Instruments J721S2 EVM
[ 0.000000] The version of tidtb_linux.appimage is P2_ADC_AP_R400_RX1_10
[ 0.000000] efi: UEFI not found.
[ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 111 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@b2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 89 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d9978000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d9978000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 736 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b0ffffff]
[ 0.000000] node 0: [mem 0x00000000b1000000-0x00000000b1ffffff]
[ 0.000000] node 0: [mem 0x00000000b2000000-0x00000000b9977fff]
[ 0.000000] node 0: [mem 0x00000000b9978000-0x00000000d9977fff]
[ 0.000000] node 0: [mem 0x00000000d9978000-0x00000000dd977fff]
[ 0.000000] node 0: [mem 0x00000000dd978000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] cma: Reserved 256 MiB at 0x00000000ed000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=serial2
[ 0.000000] mtdid=spi-nand0
[ 0.000000] mtdparts=spi-nand0:512k(ospi_nand.tiboot3),512k(ospi_nand.sysfw),10m(ospi_nand.mcu1_0),768k(ospi_nand.atf),19m(ospi_nand.kernel),1m(ospi_nand.dtb),24320k(ospi_nand.lateapp1),256k(ospi_nand.caldata_merge),40m(ospi_nand.lateapp2),32m(ospi_nand.rootfs),256k(ospi_nand.phypattern)
[ 0.000000] ubi part ospi_nand.rootfs
[ 0.000000] ubi.mtd=ospi_nand.rootfs root=ubi0:rootfs rw rootfstype=ubifs rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 758924K/2097152K available (11264K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1076084K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @81c00000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000081430000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081440000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000187] Console: colour dummy device 80x25
[ 0.000217] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000225] pid_max: default: 32768 minimum: 301
[ 0.000271] LSM: Security Framework initializing
[ 0.000307] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000320] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001195] rcu: Hierarchical SRCU implementation.
[ 0.001349] Platform MSI: msi-controller@1820000 domain created
[ 0.001464] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.001506] EFI services will not be available.
[ 0.001608] smp: Bringing up secondary CPUs ...
[ 0.016032] Detected PIPT I-cache on CPU1
[ 0.016058] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.016071] GICv3: CPU1: using allocated LPI pending table @0x0000000081450000
[ 0.016109] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.016170] smp: Brought up 1 node, 2 CPUs
[ 0.016177] SMP: Total of 2 processors activated.
[ 0.016182] CPU features: detected: 32-bit EL0 Support
[ 0.016185] CPU features: detected: CRC32 instructions
[ 0.025474] CPU: All CPU(s) started at EL2
[ 0.025498] alternatives: patching kernel code
[ 0.026073] devtmpfs: initialized
[ 0.029899] KASLR disabled due to lack of seed
[ 0.030006] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.030016] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.033143] pinctrl core: initialized pinctrl subsystem
[ 0.033457] DMI not present or invalid.
[ 0.033801] NET: Registered protocol family 16
[ 0.034649] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.034715] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.034781] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.035045] thermal_sys: Registered thermal governor 'step_wise'
[ 0.035048] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.035516] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.035560] ASID allocator initialised with 32768 entries
[ 0.046160] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.046168] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.046172] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.046175] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.046818] cryptd: max_cpu_qlen set to 1000
[ 0.048447] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
[ 0.048844] vsys_3v3: supplied by evm_12v0
[ 0.049038] vsys_5v0: supplied by evm_12v0
[ 0.049456] iommu: Default domain type: Translated
[ 0.049611] SCSI subsystem initialized
[ 0.049801] mc: Linux media interface: v0.10
[ 0.049814] videodev: Linux video capture interface: v2.00
[ 0.049854] pps_core: LinuxPPS API ver. 1 registered
[ 0.049859] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.049866] PTP clock support registered
[ 0.049882] EDAC MC: Ver: 3.0.0
[ 0.050414] FPGA manager framework
[ 0.050451] Advanced Linux Sound Architecture Driver Initialized.
[ 0.050884] clocksource: Switched to clocksource arch_sys_counter
[ 0.050983] VFS: Disk quotas dquot_6.6.0
[ 0.051011] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.053571] Carveout Heap: Exported 512 MiB at 0x00000000b9978000
[ 0.053635] NET: Registered protocol family 2
[ 0.053785] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.054465] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.054488] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.054544] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.054652] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.054748] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.054774] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.054860] NET: Registered protocol family 1
[ 0.055164] RPC: Registered named UNIX socket transport module.
[ 0.055169] RPC: Registered udp transport module.
[ 0.055172] RPC: Registered tcp transport module.
[ 0.055175] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.055180] NET: Registered protocol family 44
[ 0.055190] PCI: CLS 0 bytes, default 64
[ 0.055568] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.057619] Initialise system trusted keyrings
[ 0.057709] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.059263] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.059524] NFS: Registering the id_resolver key type
[ 0.059545] Key type id_resolver registered
[ 0.059549] Key type id_legacy registered
[ 0.059580] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.059584] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.059677] 9p: Installing v9fs 9p2000 file system support
[ 0.079301] Key type asymmetric registered
[ 0.079309] Asymmetric key parser 'x509' registered
[ 0.079336] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.079341] io scheduler mq-deadline registered
[ 0.079344] io scheduler kyber registered
[ 0.080529] pinctrl-single 4301c000.pinctrl: 101 pins, size 404
[ 0.080672] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.084680] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.090457] brd: module loaded
[ 0.093795] loop: module loaded
[ 0.094223] megasas: 07.714.04.00-rc1
[ 0.096034] tun: Universal TUN/TAP device driver, 1.6
[ 0.096306] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.096310] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.096336] sky2: driver version 1.30
[ 0.096858] VFIO - User Level meta-driver version: 0.3
[ 0.097355] i2c /dev entries driver
[ 0.098030] sdhci: Secure Digital Host Controller Interface driver
[ 0.098034] sdhci: Copyright(c) Pierre Ossman
[ 0.098192] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.098637] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.098809] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.099511] optee: probing for conduit method.
[ 0.099532] optee: revision 3.20 (8e74d476)
[ 0.115966] optee: dynamic shared memory is enabled
[ 0.116182] optee: initialized driver
[ 0.117135] NET: Registered protocol family 17
[ 0.117213] 9pnet: Installing 9P2000 support
[ 0.117254] Key type dns_resolver registered
[ 0.117370] Loading compiled-in X.509 certificates
[ 0.123815] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara')
[ 0.141223] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.141644] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.142376] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
[ 0.142475] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
[ 0.142561] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
[ 0.142764] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
[ 0.144710] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 0.145335] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 0.146266] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
[ 0.146272] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.146277] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.147755] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
[ 0.147762] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.147766] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.148122] omap8250 40a00000.serial: failed to get alias
[ 0.148878] 2810000.serial: ttyS1 at MMIO 0x2810000 (irq = 19, base_baud = 3000000) is a 8250
[ 0.149532] 2830000.serial: ttyS2 at MMIO 0x2830000 (irq = 20, base_baud = 3000000) is a 8250
[ 1.740275] printk: console [ttyS2] enabled
[ 1.744792] omap8250 2880000.serial: failed to get alias
[ 1.750848] cadence-qspi 47040000.spi: error -ENODEV: No Rx DMA available
[ 1.757939] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.763244] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[ 1.771548] 11 fixed-partitions partitions found on MTD device spi0.0
[ 1.777979] Creating 11 MTD partitions on "spi0.0":
[ 1.782847] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
[ 1.789532] 0x000000080000-0x000000100000 : "ospi_nand.sysfw"
[ 1.795933] 0x000000100000-0x000000b00000 : "ospi_nand.mcu1_0"
[ 1.806338] 0x000000b00000-0x000000bc0000 : "ospi_nand.atf"
[ 1.812659] 0x000000bc0000-0x000001ec0000 : "ospi_nand.kernel"
[ 1.826769] 0x000001ec0000-0x000001fc0000 : "ospi_nand.dtb"
[ 1.833172] 0x000001fc0000-0x000003780000 : "ospi_nand.lateapp1"
[ 1.849413] 0x000003780000-0x0000037c0000 : "ospi_nand.caldata_merge"
[ 1.856376] 0x0000037c0000-0x000005fc0000 : "ospi_nand.lateapp2"
[ 1.879341] 0x000005fc0000-0x000007fc0000 : "ospi_nand.rootfs"
[ 1.898815] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[ 1.909366] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
[ 1.915906] (null): ***of_mdiobus_register mdio-capabilities is [2]***
[ 1.958889] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.969223] davinci_mdio c200f00.mdio: phy[7]: device c200f00.mdio:07, driver Marvell 88Q2220
[ 1.977789] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.990554] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 1.996811] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 2.003929] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 2.010231] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 2.020705] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
[ 2.130763] mmc0: CQHCI version 5.10
[ 2.137337] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 2.144306] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 2.151253] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 2.158207] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 2.165471] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 2.174465] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.183009] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
[ 2.193476] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
[ 2.200022] (null): ***of_mdiobus_register mdio-capabilities is [2]***
[ 2.242893] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.252902] mmc0: Command Queue Engine enabled
[ 2.253347] davinci_mdio c200f00.mdio: phy[7]: device c200f00.mdio:07, driver Marvell 88Q2220
[ 2.257363] mmc0: new high speed MMC card at address 0001
[ 2.265932] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.284088] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 2.284090] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[ 2.284163] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[ 2.290356] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 2.290359] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 2.294969] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[ 2.314030] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 2.319768] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[ 2.336451] mmcblk0: p1 p2
[ 2.340594] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[ 2.348463] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present!
[ 2.355748] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present!
[ 2.363432] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
[ 2.371098] debugfs: Directory 'pd:357' with parent 'pm_genpd' already present!
[ 2.378396] debugfs: Directory 'pd:357' with parent 'pm_genpd' already present!
[ 2.385809] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
[ 2.393498] ubi0: attaching mtd9
[ 2.725909] ubi0: scanning is finished
[ 2.745484] ubi0: attached mtd9 (name "ospi_nand.rootfs", size 32 MiB)
[ 2.752008] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 2.758868] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 2.765639] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
[ 2.772585] ubi0: good PEBs: 128, bad PEBs: 0, corrupted PEBs: 0
[ 2.778576] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.785783] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 470570305
[ 2.794809] ubi0: available PEBs: 0, total reserved PEBs: 128, PEBs reserved for bad PEB handling: 10
[ 2.804015] ubi0: background thread "ubi_bgt0d" started, PID 148
[ 2.813556] ALSA device list:
[ 2.816524] No soundcards found.
[ 2.821588] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 2.827341] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 149
[ 2.988225] UBIFS (ubi0:0): recovery needed
[ 3.288192] UBIFS (ubi0:0): recovery completed
[ 3.292692] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 3.300075] UBIFS (ubi0:0): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.309968] UBIFS (ubi0:0): FS size: 26411008 bytes (25 MiB, 104 LEBs), journal size 4825088 bytes (4 MiB, 19 LEBs)
[ 3.320380] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 3.326201] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID D10557AE-EEB1-4C1C-A538-82ECBE2FBE2D, small LPT model
[ 3.343987] VFS: Mounted root (ubifs filesystem) on device 0:20.
[ 3.355177] devtmpfs: mounted
[ 3.358841] Freeing unused kernel memory: 1856K
[ 3.363481] Run /sbin/init as init process
INIT: version 2.96 booting
[ 4.486523] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 4.497862] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 4.504519] remoteproc remoteproc0: 64800000.dsp is available
[ 4.510288] remoteproc remoteproc0: attaching to 64800000.dsp
[ 4.516048] remoteproc remoteproc0: unsupported resource 65538
[ 4.521930] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 4.528537] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 4.538146] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 4.543658] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 4.549739] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[ 4.557588] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
[ 4.567871] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[ 4.574502] remoteproc remoteproc1: 65800000.dsp is available
[ 4.580286] remoteproc remoteproc1: attaching to 65800000.dsp
[ 4.586049] remoteproc remoteproc1: unsupported resource 65538
[ 4.591893] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[ 4.598498] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
[ 4.608256] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 4.613752] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 4.619834] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
[ 4.920184] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: [test]MCU cluster requires both R5F cores to be enabled but num_cores is set to = 1
[ 4.934188] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 4.946160] platform 41000000.r5f: configured R5F for IPC-only mode
[ 4.952515] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 4.961920] remoteproc remoteproc2: 41000000.r5f is available
[ 4.967694] remoteproc remoteproc2: attaching to 41000000.r5f
[ 4.973530] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 4.980224] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 4.989830] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 4.995336] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 5.001417] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[ 5.013151] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x1e
[ 5.020454] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 5.027767] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.039676] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 5.045929] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 5.055489] remoteproc remoteproc3: 5c00000.r5f is available
[ 5.061170] remoteproc remoteproc3: attaching to 5c00000.r5f
[ 5.066832] Unable to handle kernel paging request at virtual address ffff800021ffffff
[ 5.074732] Mem abort info:
[ 5.077515] ESR = 0x96000007
[ 5.080560] EC = 0x25: DABT (current EL), IL = 32 bits
[ 5.085858] SET = 0, FnV = 0
[ 5.088905] EA = 0, S1PTW = 0
[ 5.092048] Data abort info:
[ 5.094922] ISV = 0, ISS = 0x00000007
[ 5.098744] CM = 0, WnR = 0
[ 5.101701] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080fc8000
[ 5.108387] [ffff800021ffffff] pgd=00000000fffff003, p4d=00000000fffff003, pud=00000000ffffe003, pmd=0000000083300003, pte=0000000000000000
[ 5.120889] Internal error: Oops: 96000007 [#1] PREEMPT SMP
[ 5.126444] Modules linked in: ti_k3_r5_remoteproc(+) ti_k3_dsp_remoteproc rpmsg_kdrv_switch virtio_rpmsg_bus rpmsg_pru rpmsg_char
[ 5.138167] CPU: 1 PID: 168 Comm: insmod Not tainted 5.10.162-g76b3e88d56 #1
[ 5.145195] Hardware name: Texas Instruments J721S2 EVM (DT)
[ 5.150838] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 5.156834] pc : rproc_handle_resources.constprop.0+0x94/0x168
[ 5.162651] lr : rproc_boot+0x334/0x670
[ 5.166472] sp : ffff80001167b790
[ 5.169773] x29: ffff80001167b790 x28: ffff0000032314e8
[ 5.175069] x27: ffff000003231000 x26: ffffffffffffffff
[ 5.180366] x25: ffff800022000000 x24: ffff800010efd8a8
[ 5.185662] x23: ffff000003231038 x22: 0000000000000000
[ 5.190958] x21: ffff80001129cfa0 x20: ffff000003231000
[ 5.196253] x19: 0000000000000000 x18: 0000000000000010
[ 5.201549] x17: 0000000000000000 x16: 0000000000000000
[ 5.206845] x15: ffff0000033b8550 x14: ffffffffffffffff
[ 5.212142] x13: ffffffffffffffff x12: ffffffffffffffff
[ 5.217438] x11: ffffffffffffffff x10: ffffffffffffffff
[ 5.222735] x9 : ffffffffffffffff x8 : ffffffffffffffff
[ 5.228031] x7 : ffffffffffffffff x6 : ffff0000033ff600
[ 5.233327] x5 : 0000000000000000 x4 : 0000000000000000
[ 5.238623] x3 : 00000000000000fd x2 : 00000000ffffffff
[ 5.243919] x1 : ffff800022000003 x0 : ffff800022000000
[ 5.249216] Call trace:
[ 5.251652] rproc_handle_resources.constprop.0+0x94/0x168
[ 5.257120] rproc_boot+0x334/0x670
[ 5.260595] rproc_add+0x88/0x158
[ 5.263903] k3_r5_probe+0x720/0xdb8 [ti_k3_r5_remoteproc]
[ 5.269374] platform_drv_probe+0x54/0xa8
[ 5.273368] really_probe+0xec/0x3e0
[ 5.276929] driver_probe_device+0x58/0xb8
[ 5.281011] device_driver_attach+0x74/0x80
[ 5.285179] __driver_attach+0x64/0xf8
[ 5.288915] bus_for_each_dev+0x70/0xc0
[ 5.292737] driver_attach+0x24/0x30
[ 5.296298] bus_add_driver+0x150/0x200
[ 5.300120] driver_register+0x64/0x120
[ 5.303942] __platform_driver_register+0x48/0x58
[ 5.308631] k3_r5_rproc_driver_init+0x20/0x1000 [ti_k3_r5_remoteproc]
[ 5.315141] do_one_initcall+0x54/0x1b8
[ 5.318965] do_init_module+0x44/0x1f0
[ 5.322701] load_module+0x1f08/0x24a8
[ 5.326436] __do_sys_finit_module+0xb8/0xf8
[ 5.330691] __arm64_sys_finit_module+0x20/0x30
[ 5.335209] el0_svc_common.constprop.0+0x78/0x1c8
[ 5.339984] do_el0_svc+0x24/0x90
[ 5.343286] el0_svc+0x14/0x20
[ 5.346329] el0_sync_handler+0xb0/0xb8
[ 5.350149] el0_sync+0x180/0x1c0
[ 5.353453] Code: 128002b3 9121c021 97ffeb45 1400002e (b87a6b20)
[ 5.359530] ---[ end trace 590125883e204713 ]---
Segmentation fault
insmod: ERROR: could not load module /lib/modules/5.10.162-g76b3e88d56/extra/cryptodev.ko: No such file or directory
[ 6.367002] pvrsrvkm: loading out-of-tree module taints kernel.
[ 6.380329] PVR_K: 170: Read BVNC 36.53.104.796 from HW device registers
[ 6.387125] PVR_K: 170: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ 6.395782] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue May 2 16:30:19 UTC 2023
[ 6.898603] random: dd: uninitialized urandom read (512 bytes read)
INIT: Entering runlevel: 5
Configuring network interfaces... [ 7.052429] Marvell 88Q2220 c200f00.mdio:07: [m88q222x_soft_reset] called
[ 7.071554] Marvell 88Q2220 c200f00.mdio:07: buf 1
[ 7.076627] Marvell 88Q2220 c200f00.mdio:07: current speed is 1000
[ 7.101039] Marvell 88Q2220 c200f00.mdio:07: slave
[ 7.106095] Marvell 88Q2220 c200f00.mdio:07: speed 100
[ 7.171696] am65-cpsw-nuss c200000.ethernet eth0: PHY [c200f00.mdio:07] driver [Marvell 88Q2220] (irq=POLL)
[ 7.181424] am65-cpsw-nuss c200000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 7.189649] Marvell 88Q2220 c200f00.mdio:07: [m88q222x_config_aneg] called
[ 7.197522] am65-cpsw-nuss c200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
udhcpc: started, v1.31.1
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting Dropbear SSH server: dropbear.
Starting syslogd/klogd: done
[ 16.472473] EXT4-fs (mmcblk0p2): recovery complete
[ 16.478223] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 16.563207] libcrc32c: disagrees about version of symbol module_layout
insmod: ERROR: could not insert module /opt/rootfs/lib/modules/5.10.162-g76b3e88d56/kernel/net/lib/libcrc32c.ko: Invalid module format
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j721s2-evm /dev/ttyS2
Arago 2021.09 j721s2-evm /dev/ttyS2
j721s2-evm login:
