TDA4VM: DP to HDMI conveter Display is not working
Part Number: TDA4VM
Other Parts Discussed in Thread: TDA4VL,
DP Port to HDMI converter not working;
We try to use the vision apps application(app_single_cam) to display output using DP0 to hdmi converter as our output device having hdmi Interface.
But the output display is not outputting any data on the display screen, But when we try to do same thing using DP0 to DP0 Cable we able to get the display. Can you help us why the DP to hdmi converter is not working
sdk used : 8.6
We also tried one suggestion provided in the below thread, But still we cannot able to get any display using hdmi
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/915793/tda4vm-can-display-port0-be-converted-to-hdmi
Note : when we tried the same experiment on TDA4VL Board with dp to hdmi converter we able to get display , Can you help on this issue
  • your timely help is appreciated
  • I have suggested DP0->HDMI convertor on the above ticket. So, if it is working on TDA4VL board, it should work even for TDA4VM board. I dont see reason for it to not work on TDA4VM.
  • Can you please share your log of vision_apps_init.sh script running?
  • For TDA4VL we haven't applied the patch suggested above but still it worked well
    For TDA4VM with out patch applied log
    root@j7-evm:/opt/vision_apps# ./vision_apps_init.sh
    root@j7-evm:/opt/vision_apps# [MPU1_0]
    [MCU2_0] 4.221668 s: CIO: Init ... Done !!!
    [MCU2_0] 4.221740 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0] 4.221787 s: CPU is running FreeRTOS
    [MCU2_0] 4.221818 s: APP: Init ... !!!
    [MCU2_0] 4.221846 s: SCICLIENT: Init ... !!!
    [MCU2_0] 4.222092 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [MCU2_0] 4.222145 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_0] 4.222182 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0] 4.222220 s: SCICLIENT: Init ... Done !!!
    [MCU2_0] 4.222251 s: UDMA: Init ... !!!
    [MCU2_0] 4.223591 s: UDMA: Init ... Done !!!
    [MCU2_0] 4.223653 s: MEM: Init ... !!!
    [MCU2_0] 4.223702 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
    [MCU2_0] 4.223783 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
    [MCU2_0] 4.223848 s: MEM: Init ... Done !!!
    [MCU2_0] 4.223879 s: IPC: Init ... !!!
    [MCU2_0] 4.223943 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_0] 4.223998 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0] 16.972175 s: IPC: HLOS is ready !!!
    [MCU2_0] 16.987458 s: IPC: Init ... Done !!!
    [MCU2_0] 16.987528 s: APP: Syncing with 5 CPUs ... !!!
    [MCU2_0] 17.150720 s: APP: Syncing with 5 CPUs ... Done !!!
    [MCU2_0] 17.150953 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0] 17.152491 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0] 17.152558 s: ETHFW: Init ... !!!
    [MCU2_0] 17.157526 s: Warning: Using 6 MAC address(es) from static pool
    [MCU2_0] 17.157643 s: ETHFW: Shared multicasts (software fanout):
    [MCU2_0] 17.157777 s: ETHFW: Reserved multicasts:
    [MCU2_0] 17.157821 s: 01:80:c2:00:00:0e
    [MCU2_0] 17.157879 s: 01:1b:19:00:00:00
    [MCU2_0] 17.158133 s: EnetMcm: CPSW_9G on MAIN NAVSS
    [MCU2_0] 17.167572 s: Mdio_open: MDIO manual mode enabled
    [MCU2_0] 17.171453 s: PHY 16 is alive
    [MCU2_0] 17.171606 s: PHY 17 is alive
    [MCU2_0] 17.171724 s: PHY 18 is alive
    [MCU2_0] 17.171835 s: PHY 19 is alive
    [MCU2_0] 17.175059 s:
    [MCU2_0] ETHFW Version : 0.02.00
    [MCU2_0] 17.175146 s: ETHFW Build Date: Oct 10, 2023
    [MCU2_0] 17.175186 s: ETHFW Build Time: 17:48:27
    [MCU2_0] 17.175215 s: ETHFW Commit SHA:
    [MCU2_0] 17.175285 s: ETHFW: Init ... DONE !!!
    [MCU2_0] 17.175322 s: ETHFW: Remove server Init ... !!!
    [MCU2_0] 17.175515 s: CpswProxyServer: Virtual port configuration:
    [MCU2_0] 17.175578 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
    [MCU2_0] 17.175630 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
    [MCU2_0] 17.175676 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
    [MCU2_0] 17.175721 s: mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
    [MCU2_0] 17.176738 s: CpswProxyServer: initialization completed (core: mcu2_0)
    [MCU2_0] 17.176808 s: ETHFW: Remove server Init ... DONE !!!
    [MCU2_0] 17.177925 s: Starting lwIP, local interface IP is dhcp-enabled
    [MCU2_0] 17.185807 s: Host MAC address: 70:ff:76:1d:92:c3
    [MCU2_0] 17.189985 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
    [MCU2_0] 17.190082 s: Added interface 'ti1', IP is 0.0.0.0
    [MCU2_0] 17.226386 s: FVID2: Init ... !!!
    [MCU2_0] 17.226500 s: FVID2: Init ... Done !!!
    [MCU2_0] 17.226556 s: DSS: Init ... !!!
    [MCU2_0] 17.226588 s: DSS: Display type is eDP !!!
    [MCU2_0] 17.226619 s: DSS: M2M Path is enabled !!!
    [MCU2_0] 17.226648 s: DSS: SoC init ... !!!
    [MCU2_0] 17.226673 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
    [MCU2_0] 17.226900 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.226943 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
    [MCU2_0] 17.227141 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.227178 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
    [MCU2_0] 17.227337 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.227468 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
    [MCU2_0] 17.227621 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0] 17.227665 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
    [MCU2_0] 17.227789 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0] 17.227829 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
    [MCU2_0] 17.227934 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0] 17.227972 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
    [MCU2_0] 17.229225 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
    [MCU2_0] 17.229279 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
    [MCU2_0] 17.229453 s: SCICLIENT: Sciclient_pmModuleClkRequest success
    [MCU2_0] 17.229503 s: DSS: SoC init ... Done !!!
    [MCU2_0] 17.229534 s: DSS: Board init ... !!!
    [MCU2_0] 17.229562 s: DSS: Board init ... Done !!!
    [MCU2_0] 17.279976 s: DSS: Init ... Done !!!
    [MCU2_0] 17.280047 s: VHWA: VPAC Init ... !!!
    [MCU2_0] 17.280079 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
    [MCU2_0] 17.280291 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.280331 s: VHWA: LDC Init ... !!!
    [MCU2_0] 17.284297 s: VHWA: LDC Init ... Done !!!
    [MCU2_0] 17.284465 s: VHWA: MSC Init ... !!!
    [MCU2_0] 17.296577 s: VHWA: MSC Init ... Done !!!
    [MCU2_0] 17.296640 s: VHWA: NF Init ... !!!
    [MCU2_0] 17.298505 s: VHWA: NF Init ... Done !!!
    [MCU2_0] 17.298568 s: VHWA: VISS Init ... !!!
    [MCU2_0] 17.309865 s: VHWA: VISS Init ... Done !!!
    [MCU2_0] 17.309936 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0] 17.309991 s: VX_ZONE_INIT:Enabled
    [MCU2_0] 17.310027 s: VX_ZONE_ERROR:Enabled
    [MCU2_0] 17.310058 s: VX_ZONE_WARNING:Enabled
    [MCU2_0] 17.311718 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
    [MCU2_0] 17.311977 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
    [MCU2_0] 17.312211 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
    [MCU2_0] 17.312679 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
    [MCU2_0] 17.312965 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
    [MCU2_0] 17.313259 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
    [MCU2_0] 17.313650 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
    [MCU2_0] 17.313939 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
    [MCU2_0] 17.314217 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
    [MCU2_0] 17.314605 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
    [MCU2_0] 17.314875 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
    [MCU2_0] 17.315150 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
    [MCU2_0] 17.315543 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
    [MCU2_0] 17.315848 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
    [MCU2_0] 17.316135 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
    [MCU2_0] 17.316525 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
    [MCU2_0] 17.316825 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
    [MCU2_0] 17.317075 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
    [MCU2_0] 17.317335 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
    [MCU2_0] 17.317738 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
    [MCU2_0] 17.318001 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
    [MCU2_0] 17.318064 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_0] 17.318101 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0] 17.327813 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0] 17.339614 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0] 17.339684 s: CSI2RX: Init ... !!!
    [MCU2_0] 17.339716 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
    [MCU2_0] 17.339846 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.339886 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
    [MCU2_0] 17.340057 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.340093 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
    [MCU2_0] 17.340238 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.340272 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
    [MCU2_0] 17.340460 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.340508 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
    [MCU2_0] 17.340616 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.340855 s: CSI2RX: Init ... Done !!!
    [MCU2_0] 17.340895 s: CSI2TX: Init ... !!!
    [MCU2_0] 17.340922 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
    [MCU2_0] 17.341021 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.341059 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
    [MCU2_0] 17.341212 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.341248 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
    [MCU2_0] 17.341470 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0] 17.341589 s: CSI2TX: Init ... Done !!!
    [MCU2_0] 17.341631 s: ISS: Init ... !!!
    [MCU2_0] 17.341665 s: Found sensor IMX390-UB953_D3 at location 0
    [MCU2_0] 17.341714 s: Found sensor AR0233-UB953_MARS at location 1
    [MCU2_0] 17.341760 s: Found sensor AR0820-UB953_LI at location 2
    [MCU2_0] 17.341811 s: IssSensor_SG2_IMX390_5200_Init()
    [MCU2_0] 17.341848 s: IssSensor_Register()
    [MCU2_0] 17.341879 s: Found sensor SG2-IMX390-5200 at location 3
    [MCU2_0] 17.341923 s: Found sensor UB9xxx_RAW12_TESTPATTERN at location 4
    [MCU2_0] 17.341966 s: Found sensor UB96x_UYVY_TESTPATTERN at location 5
    [MCU2_0] 17.342009 s: Found sensor GW_AR0233_UYVY at location 6
    [MCU2_0] 17.342049 s: IssSensor_Init ... Done !!!
    [MCU2_0] 17.342141 s: IttRemoteServer_Init ... Done !!!
    [MCU2_0] 17.342180 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU2_0] 17.342249 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU2_0] 17.342287 s: UDMA Copy: Init ... !!!
    [MCU2_0] 17.344329 s: UDMA Copy: Init ... Done !!!
    [MCU2_0] 17.344546 s: APP: Init ... Done !!!
    [MCU2_0] 17.344588 s: APP: Run ... !!!
    [MCU2_0] 17.344616 s: IPC: Starting echo test ...
    [MCU2_0] 17.347586 s: APP: Run ... Done !!!
    [MCU2_0] 17.349256 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_0] 17.349515 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_0] 17.349628 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_0] 17.349729 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
    [MCU2_0] 17.444071 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0] 19.801994 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:173, FlowIdxOffset:1
    [MCU2_0] 19.836932 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6,mode:disable
    [MCU2_0] 19.837312 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6,mode:disable
    [MCU2_0] 19.837749 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6,mode:disable
    [MCU2_0] 19.854601 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
    [MCU2_0] 19.857770 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:2
    [MCU2_0] 19.893759 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 19.897318 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 19.900815 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 20.070689 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6,mode:disable
    [MCU2_0] 20.087455 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 20.091206 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 20.094714 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 20.094869 s: CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
    [MCU2_0] 20.221009 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6,mode:disable
    [MCU2_0] 20.221199 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_0] 21.079098 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6,mode:disable
    [MCU2_0] 21.205238 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3ac7ebc,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
    [MCU2_1] 4.172249 s: CIO: Init ... Done !!!
    [MCU2_1] 4.172321 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1] 4.172362 s: CPU is running FreeRTOS
    [MCU2_1] 4.172388 s: APP: Init ... !!!
    [MCU2_1] 4.172412 s: SCICLIENT: Init ... !!!
    [MCU2_1] 4.172670 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [MCU2_1] 4.172719 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_1] 4.172768 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1] 4.172808 s: SCICLIENT: Init ... Done !!!
    [MCU2_1] 4.172835 s: UDMA: Init ... !!!
    [MCU2_1] 4.174240 s: UDMA: Init ... Done !!!
    [MCU2_1] 4.174299 s: MEM: Init ... !!!
    [MCU2_1] 4.174344 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
    [MCU2_1] 4.174419 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
    [MCU2_1] 4.174480 s: MEM: Init ... Done !!!
    [MCU2_1] 4.174505 s: IPC: Init ... !!!
    [MCU2_1] 4.174568 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_1] 4.174620 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1] 17.135294 s: IPC: HLOS is ready !!!
    [MCU2_1] 17.150605 s: IPC: Init ... Done !!!
    [MCU2_1] 17.150668 s: APP: Syncing with 5 CPUs ... !!!
    [MCU2_1] 17.150718 s: APP: Syncing with 5 CPUs ... Done !!!
    [MCU2_1] 17.150769 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1] 17.152522 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1] 17.152586 s: FVID2: Init ... !!!
    [MCU2_1] 17.152654 s: FVID2: Init ... Done !!!
    [MCU2_1] 17.152687 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1] 17.152713 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
    [MCU2_1] 17.153301 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1] 17.153345 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
    [MCU2_1] 17.153789 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1] 17.153828 s: VHWA: DOF Init ... !!!
    [MCU2_1] 17.162299 s: VHWA: DOF Init ... Done !!!
    [MCU2_1] 17.162366 s: VHWA: SDE Init ... !!!
    [MCU2_1] 17.165017 s: VHWA: SDE Init ... Done !!!
    [MCU2_1] 17.165079 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1] 17.165125 s: VX_ZONE_INIT:Enabled
    [MCU2_1] 17.165156 s: VX_ZONE_ERROR:Enabled
    [MCU2_1] 17.165183 s: VX_ZONE_WARNING:Enabled
    [MCU2_1] 17.166590 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
    [MCU2_1] 17.166846 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
    [MCU2_1] 17.167069 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
    [MCU2_1] 17.167125 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_1] 17.167162 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1] 17.167438 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1] 17.167483 s: UDMA Copy: Init ... !!!
    [MCU2_1] 17.169548 s: UDMA Copy: Init ... Done !!!
    [MCU2_1] 17.169624 s: APP: Init ... Done !!!
    [MCU2_1] 17.169656 s: APP: Run ... !!!
    [MCU2_1] 17.169683 s: IPC: Starting echo test ...
    [MCU2_1] 17.172269 s: APP: Run ... Done !!!
    [MCU2_1] 17.173471 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_1] 17.173589 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_1] 17.173680 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
    [MCU2_1] 17.348316 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
    [C6x_1 ] 4.237842 s: CIO: Init ... Done !!!
    [C6x_1 ] 4.237866 s: ### CPU Frequency = 1350000000 Hz
    [C6x_1 ] 4.237876 s: CPU is running FreeRTOS
    [C6x_1 ] 4.237883 s: APP: Init ... !!!
    [C6x_1 ] 4.237891 s: SCICLIENT: Init ... !!!
    [C6x_1 ] 4.238104 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [C6x_1 ] 4.238116 s: SCICLIENT: DMSC FW revision 0x8
    [C6x_1 ] 4.238125 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_1 ] 4.238135 s: SCICLIENT: Init ... Done !!!
    [C6x_1 ] 4.238144 s: UDMA: Init ... !!!
    [C6x_1 ] 4.239639 s: UDMA: Init ... Done !!!
    [C6x_1 ] 4.239658 s: MEM: Init ... !!!
    [C6x_1 ] 4.239670 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
    [C6x_1 ] 4.239687 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_1 ] 4.239702 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!!
    [C6x_1 ] 4.239718 s: MEM: Init ... Done !!!
    [C6x_1 ] 4.239725 s: IPC: Init ... !!!
    [C6x_1 ] 4.239746 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_1 ] 4.239760 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ] 16.241733 s: IPC: HLOS is ready !!!
    [C6x_1 ] 16.245500 s: IPC: Init ... Done !!!
    [C6x_1 ] 16.245528 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_1 ] 17.150718 s: APP: Syncing with 5 CPUs ... Done !!!
    [C6x_1 ] 17.150731 s: REMOTE_SERVICE: Init ... !!!
    [C6x_1 ] 17.151377 s: REMOTE_SERVICE: Init ... Done !!!
    [C6x_1 ] 17.151410 s: VX_ZONE_INIT:Enabled
    [C6x_1 ] 17.151420 s: VX_ZONE_ERROR:Enabled
    [C6x_1 ] 17.151429 s: VX_ZONE_WARNING:Enabled
    [C6x_1 ] 17.152201 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C6x_1 ] 17.152214 s: APP: OpenVX Target kernel init ... !!!
    [C6x_1 ] 17.152470 s: APP: OpenVX Target kernel init ... Done !!!
    [C6x_1 ] 17.152485 s: UDMA Copy: Init ... !!!
    [C6x_1 ] 17.156209 s: UDMA Copy: Init ... Done !!!
    [C6x_1 ] 17.156230 s: APP: Init ... Done !!!
    [C6x_1 ] 17.156238 s: APP: Run ... !!!
    [C6x_1 ] 17.156247 s: IPC: Starting echo test ...
    [C6x_1 ] 17.157313 s: APP: Run ... Done !!!
    [C6x_1 ] 17.157623 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P]
    [C6x_1 ] 17.157940 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_1 ] 17.172839 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_1 ] 17.348216 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_2 ] 4.327256 s: CIO: Init ... Done !!!
    [C6x_2 ] 4.327282 s: ### CPU Frequency = 1350000000 Hz
    [C6x_2 ] 4.327292 s: CPU is running FreeRTOS
    [C6x_2 ] 4.327300 s: APP: Init ... !!!
    [C6x_2 ] 4.327308 s: SCICLIENT: Init ... !!!
    [C6x_2 ] 4.327508 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [C6x_2 ] 4.327520 s: SCICLIENT: DMSC FW revision 0x8
    [C6x_2 ] 4.327530 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_2 ] 4.327540 s: SCICLIENT: Init ... Done !!!
    [C6x_2 ] 4.327549 s: UDMA: Init ... !!!
    [C6x_2 ] 4.329039 s: UDMA: Init ... Done !!!
    [C6x_2 ] 4.329057 s: MEM: Init ... !!!
    [C6x_2 ] 4.329070 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
    [C6x_2 ] 4.329087 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_2 ] 4.329103 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!!
    [C6x_2 ] 4.329119 s: MEM: Init ... Done !!!
    [C6x_2 ] 4.329127 s: IPC: Init ... !!!
    [C6x_2 ] 4.329147 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_2 ] 4.329161 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_2 ] 16.611404 s: IPC: HLOS is ready !!!
    [C6x_2 ] 16.615093 s: IPC: Init ... Done !!!
    [C6x_2 ] 16.615118 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_2 ] 17.150718 s: APP: Syncing with 5 CPUs ... Done !!!
    [C6x_2 ] 17.150731 s: REMOTE_SERVICE: Init ... !!!
    [C6x_2 ] 17.151391 s: REMOTE_SERVICE: Init ... Done !!!
    [C6x_2 ] 17.151424 s: VX_ZONE_INIT:Enabled
    [C6x_2 ] 17.151434 s: VX_ZONE_ERROR:Enabled
    [C6x_2 ] 17.151443 s: VX_ZONE_WARNING:Enabled
    [C6x_2 ] 17.152212 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C6x_2 ] 17.152226 s: APP: OpenVX Target kernel init ... !!!
    [C6x_2 ] 17.152483 s: APP: OpenVX Target kernel init ... Done !!!
    [C6x_2 ] 17.152498 s: UDMA Copy: Init ... !!!
    [C6x_2 ] 17.156406 s: UDMA Copy: Init ... Done !!!
    [C6x_2 ] 17.156428 s: APP: Init ... Done !!!
    [C6x_2 ] 17.156437 s: APP: Run ... !!!
    [C6x_2 ] 17.156446 s: IPC: Starting echo test ...
    [C6x_2 ] 17.157602 s: APP: Run ... Done !!!
    [C6x_2 ] 17.157938 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.]
    [C6x_2 ] 17.157972 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
    [C6x_2 ] 17.172867 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
    [C6x_2 ] 17.348246 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
    [C7x_1 ] 4.557687 s: CIO: Init ... Done !!!
    [C7x_1 ] 4.557701 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ] 4.557712 s: CPU is running FreeRTOS
    [C7x_1 ] 4.557720 s: APP: Init ... !!!
    [C7x_1 ] 4.557728 s: SCICLIENT: Init ... !!!
    [C7x_1 ] 4.557929 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
    [C7x_1 ] 4.557944 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_1 ] 4.557954 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ] 4.557965 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ] 4.557973 s: UDMA: Init ... !!!
    [C7x_1 ] 4.559114 s: UDMA: Init ... Done !!!
    [C7x_1 ] 4.559126 s: MEM: Init ... !!!
    [C7x_1 ] 4.559137 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 107000000 of size 536870912 bytes !!!
    [C7x_1 ] 4.559158 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
    [C7x_1 ] 4.559176 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ] 4.559193 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ] 4.559210 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 117440512 bytes !!!
    [C7x_1 ] 4.559229 s: MEM: Init ... Done !!!
    [C7x_1 ] 4.559237 s: IPC: Init ... !!!
    [C7x_1 ] 4.559252 s: IPC: 6 CPUs participating in IPC !!!
    [C7x_1 ] 4.559265 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ] 16.955058 s: IPC: HLOS is ready !!!
    [C7x_1 ] 16.957021 s: IPC: Init ... Done !!!
    [C7x_1 ] 16.957036 s: APP: Syncing with 5 CPUs ... !!!
    [C7x_1 ] 17.150719 s: APP: Syncing with 5 CPUs ... Done !!!
    [C7x_1 ] 17.150736 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ] 17.150882 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ] 17.150904 s: VX_ZONE_INIT:Enabled
    [C7x_1 ] 17.150915 s: VX_ZONE_ERROR:Enabled
    [C7x_1 ] 17.150925 s: VX_ZONE_WARNING:Enabled
    [C7x_1 ] 17.151077 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
    [C7x_1 ] 17.151140 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
    [C7x_1 ] 17.151235 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
    [C7x_1 ] 17.151326 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
    [C7x_1 ] 17.151391 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
    [C7x_1 ] 17.151455 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
    [C7x_1 ] 17.151586 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
    [C7x_1 ] 17.151652 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
    [C7x_1 ] 17.151674 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C7x_1 ] 17.151687 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ] 17.151827 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ] 17.151840 s: APP: Init ... Done !!!
    [C7x_1 ] 17.151849 s: APP: Run ... !!!
    [C7x_1 ] 17.151857 s: IPC: Starting echo test ...
    [C7x_1 ] 17.152006 s: APP: Run ... Done !!!
    [C7x_1 ] 17.157625 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s]
    [C7x_1 ] 17.157932 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ] 17.172889 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ] 17.348299 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    Can we dicuss the same in the Private community as ticket has been raised:
    https://e2e.ti.com/e2eprivate/valeo/valeo-ep-automotive/f/valeo-emid-jacinto-forum/1290621/tda4vm-dp-to-hdmi-converter-display-is-not-working/4895419#4895419
    Proivded the more info on this on the above link
  • Closing this ticket. Lets discuss it on the other ticket.
