Part Number: TDA4VM
HI TI Experts,
Customer is using TDA4VM SDK8.6.
When they are testing our SPI module, they have enabled the DMA. As we know that there is a tigger level parameter in the SPI DMA, the default value is 32.
We have tested that every time if the input data size is less or equal to the trigger level, then the dma interrupt transmitted data is correct. If the input data size is larger than the trigger level, then the dma interrupt can only transmit the data equal to the trigger level. For example, if the trigger level is 32, then every dma interrupt can only transmit at most 32.
The following diagram shows that if the input data size if 31 less than the triLvl 32, it will finally transmit the entire 31 input data.
However, if the input data size is 33 larger than the triLvl 32, it will only transmit the 32 data, and there will be 1 data loss.
The following is the log for trigLvl = 32.
[0 0] D/mcu1_0.bsp.uart: wkup_uart0 open success,115200,interrupt mode [0 0] D/mcu1_0.bsp.board: mcu1_0 is running... [0 0] D/mcu1_0.bsp.sci: Sciclient_init success! [0 0] I/mcu1_0.bsp.sci: Sciserver_tirtosInit success! [0 0] D/mcu1_0.bsp.sci: Built On: Nov 8 2023 17:06:03 [0 0] D/mcu1_0.bsp.sci: Sciserver Version: v2022.01.1.0 [0 0] D/mcu1_0.bsp.sci: RM_PM_HAL Version: [0 0] I/mcu1_0.bsp.sci: Starting Sciserver..... PASSED [0 0] D/mcu1_0.bsp.gpio: WKUP_GPIO0_55 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO0_98 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO0_127 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO1_0 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO0_65 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO0_64 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO0_63 inited [0 0] D/mcu1_0.bsp.gpio: MAIN_GPIO1_23 inited [0 0] D/mcu1_0.bsp.gpio: WKUP_GPIO0_6 route wkup intr to main,intNum:124 [0 0] D/mcu1_0.bsp.gpio: WKUP_GPIO0_6 inited [0 0] D/mcu1_0.bsp.adc: MCU_ADC0 registered ISR [0 0] I/mcu1_0.bsp.adc: MCU_ADC0 inited [0 0] D/mcu1_0.bsp.adc: MCU_ADC1 registered ISR [0 0] I/mcu1_0.bsp.adc: MCU_ADC1 inited [0 0] D/mcu1_0.bsp.board: boardType:SUPER_X5_V2,readVal:585 mV [0 0] D/mcu1_0.bsp.cpu: DIE_ID:69A00002-070B0009-08045ACE-0101000C [0 0] I/mcu1_0.bsp.i2c: mcu_i2c1 open success,bitrate:100000Hz [0 0] D/mcu1_0.bsp.utils: src_id:188,src_index:0,dst_id:250,dst_host_irq:160 [0 0] D/mcu1_0.bsp.utils: intNum:160 [0 0] I/mcu1_0.bsp.i2c: main_i2c1 open success,bitrate:100000Hz [0 0] D/mcu1_0.drv.spi.SPI_dma: MCSPI_dmaConfig success! [0 0] I/bsp.spi: mcu_spi1 opened,speed:10.0Mbps,interrupt dma mode [0 0] D/mcu1_0.bsp.bus.spi: mcu_spi1 bus inited. [0 0] D/mcu1_0.bsp.gpio: WKUP_GPIO0_3 inited [0 0] I/mcu1_0.bsp.bus.spi: eeprom registered to mcu_spi1 bus,deviceId:0,1 device on bus [0 0] D/mcu1_0.bsp.gpio: WKUP_GPIO0_15 inited [0 0] I/mcu1_0.bsp.bus.spi: nand registered to mcu_spi1 bus,deviceId:1,2 device on bus [0 0] D/mcu1_0.test.eeprom: eepromWorkTest created [4 0] D/mcu1_0.test.eeprom: eepromMonitorTask created [9 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:1 [15 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 1 << 0 [20 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 1 [25 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [32 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:1 [37 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:1 [43 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:1,rxTrigLvl:1,txTrigLvl:1 [52 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1 [56 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:1 [62 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:1,transBytes:1 D/HEX write: 0000-000F: 00 . D/HEX read: 0000-000F: 00 . [83 0] D/mcu1_0.main: task:task1 created [1000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [1083 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:2 [1088 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 2 << 0 [1094 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 2 [1099 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [1106 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:2 [1112 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:2 [1117 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:2,rxTrigLvl:2,txTrigLvl:2 [1126 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:2 [1131 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:2 [1137 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:2,transBytes:2 D/HEX write: 0000-000F: 01 01 .. D/HEX read: 0000-000F: 01 01 .. [2000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [2158 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:3 [2163 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 3 << 0 [2169 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 3 [2174 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [2181 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:3 [2187 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:3 [2192 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:3,rxTrigLvl:3,txTrigLvl:3 [2201 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:3 [2206 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:3 [2212 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:3,transBytes:3 D/HEX write: 0000-000F: 02 02 02 ... D/HEX read: 0000-000F: 02 02 02 ... [3000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [3233 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:4 [3238 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 4 << 0 [3244 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 4 [3249 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [3256 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:4 [3262 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:4 [3267 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:4,rxTrigLvl:4,txTrigLvl:4 [3276 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:4 [3281 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:4 [3287 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:4,transBytes:4 D/HEX write: 0000-000F: 03 03 03 03 .... D/HEX read: 0000-000F: 03 03 03 03 .... [4000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [4308 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:5 [4313 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 5 << 0 [4319 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 5 [4324 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [4331 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:5 [4337 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:5 [4342 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:5,rxTrigLvl:5,txTrigLvl:5 [4351 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:5 [4356 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:5 [4362 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:5,transBytes:5 D/HEX write: 0000-000F: 04 04 04 04 04 ..... D/HEX read: 0000-000F: 04 04 04 04 04 ..... [5000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [5383 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:6 [5388 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 6 << 0 [5394 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 6 [5399 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [5406 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:6 [5412 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:6 [5417 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:6,rxTrigLvl:6,txTrigLvl:6 [5426 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:6 [5431 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:6 [5437 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:6,transBytes:6 D/HEX write: 0000-000F: 05 05 05 05 05 05 ...... D/HEX read: 0000-000F: 05 05 05 05 05 05 ...... [6000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [6459 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:7 [6464 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 7 << 0 [6470 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 7 [6475 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [6482 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:7 [6488 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:7 [6493 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:7,rxTrigLvl:7,txTrigLvl:7 [6502 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:7 [6507 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:7 [6513 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:7,transBytes:7 D/HEX write: 0000-000F: 06 06 06 06 06 06 06 ....... D/HEX read: 0000-000F: 06 06 06 06 06 06 06 ....... [7000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [7535 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:8 [7540 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 8 << 0 [7546 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 8 [7551 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [7558 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:8 [7564 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:8 [7569 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:8,rxTrigLvl:8,txTrigLvl:8 [7578 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:8 [7583 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:8 [7589 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:8,transBytes:8 D/HEX write: 0000-000F: 07 07 07 07 07 07 07 07 ........ D/HEX read: 0000-000F: 07 07 07 07 07 07 07 07 ........ [8000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [8612 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:9 [8617 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 9 << 0 [8623 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 9 [8628 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [8635 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:9 [8641 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:9 [8646 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:9,rxTrigLvl:9,txTrigLvl:9 [8655 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:9 [8660 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:9 [8666 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:9,transBytes:9 D/HEX write: 0000-000F: 08 08 08 08 08 08 08 08 08 ......... D/HEX read: 0000-000F: 08 08 08 08 08 08 08 08 08 ......... [9000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [9689 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:10 [9694 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 10 << 0 [9700 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 10 [9705 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [9712 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:10 [9718 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:10 [9724 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:10,rxTrigLvl:10,txTrigLvl:10 [9733 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:10 [9738 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:10 [9744 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:10,transBytes:10 D/HEX write: 0000-000F: 09 09 09 09 09 09 09 09 09 09 .......... D/HEX read: 0000-000F: 09 09 09 09 09 09 09 09 09 09 .......... [10000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [10767 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:11 [10772 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 11 << 0 [10778 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 11 [10784 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [10791 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:11 [10796 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:11 [10802 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:11,rxTrigLvl:11,txTrigLvl:11 [10811 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:11 [10817 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:11 [10822 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:11,transBytes:11 D/HEX write: 0000-000F: 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A ........... D/HEX read: 0000-000F: 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A 0A ........... [11000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [11846 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:12 [11851 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 12 << 0 [11857 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 12 [11863 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [11870 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:12 [11875 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:12 [11881 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:12,rxTrigLvl:12,txTrigLvl:12 [11890 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:12 [11896 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:12 [11901 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:12,transBytes:12 D/HEX write: 0000-000F: 0B 0B 0B 0B 0B 0B 0B 0B 0B 0B 0B 0B ............ D/HEX read: 0000-000F: 0B 0B 0B 0B 0B 0B 0B 0B 0B 0B 0B 0B ............ [12000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [12925 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:13 [12930 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 13 << 0 [12936 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 13 [12942 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [12949 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:13 [12954 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:13 [12960 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:13,rxTrigLvl:13,txTrigLvl:13 [12969 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:13 [12975 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:13 [12980 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:13,transBytes:13 D/HEX write: 0000-000F: 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ............. D/HEX read: 0000-000F: 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ............. [13004 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [14000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [14007 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:14 [14013 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 14 << 0 [14019 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 14 [14025 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [14032 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:14 [14037 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:14 [14043 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:14,rxTrigLvl:14,txTrigLvl:14 [14052 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:14 [14058 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:14 [14064 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:14,transBytes:14 D/HEX write: 0000-000F: 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D .............. D/HEX read: 0000-000F: 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D 0D .............. [15000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [15088 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:15 [15093 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 15 << 0 [15099 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 15 [15105 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [15112 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:15 [15117 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:15 [15123 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:15,rxTrigLvl:15,txTrigLvl:15 [15132 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:15 [15138 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:15 [15143 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:15,transBytes:15 D/HEX write: 0000-000F: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E ............... D/HEX read: 0000-000F: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E ............... [16000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.01 KB 0.00MB/s,rx:0.01 KB 0.00MB/s [16168 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:16 [16173 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 16 << 0 [16179 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 16 [16185 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [16192 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:16 [16197 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:16 [16203 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:16,rxTrigLvl:16,txTrigLvl:16 [16212 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:16 [16218 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:16 [16223 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:16,transBytes:16 D/HEX write: 0000-000F: 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F ................ D/HEX read: 0000-000F: 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F ................ [17000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [17248 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:17 [17253 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 17 << 0 [17259 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 17 [17265 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [17272 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:17 [17277 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:17 [17283 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:17,rxTrigLvl:17,txTrigLvl:17 [17292 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:17 [17298 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:17 [17303 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:17,transBytes:17 D/HEX write: 0000-000F: 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 ................ 0010-001F: 10 . D/HEX read: 0000-000F: 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 ................ 0010-001F: 10 . [18000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [18342 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:18 [18347 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 18 << 0 [18353 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 18 [18359 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [18366 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:18 [18371 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:18 [18377 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:18,rxTrigLvl:18,txTrigLvl:18 [18386 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:18 [18392 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:18 [18397 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:18,transBytes:18 D/HEX write: 0000-000F: 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 ................ 0010-001F: 11 11 .. D/HEX read: 0000-000F: 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 ................ 0010-001F: 11 11 .. [19000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [19436 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:19 [19441 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 19 << 0 [19447 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 19 [19453 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [19460 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:19 [19465 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:19 [19471 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:19,rxTrigLvl:19,txTrigLvl:19 [19480 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:19 [19486 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:19 [19491 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:19,transBytes:19 D/HEX write: 0000-000F: 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 ................ 0010-001F: 12 12 12 ... D/HEX read: 0000-000F: 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 ................ 0010-001F: 12 12 12 ... [20000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [20530 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:20 [20535 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 20 << 0 [20541 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 20 [20547 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [20554 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:20 [20559 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:20 [20565 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:20,rxTrigLvl:20,txTrigLvl:20 [20574 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:20 [20580 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:20 [20585 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:20,transBytes:20 D/HEX write: 0000-000F: 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 ................ 0010-001F: 13 13 13 13 .... D/HEX read: 0000-000F: 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 ................ 0010-001F: 13 13 13 13 .... [21000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [21624 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:21 [21629 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 21 << 0 [21635 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 21 [21641 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [21648 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:21 [21653 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:21 [21659 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:21,rxTrigLvl:21,txTrigLvl:21 [21668 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:21 [21674 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:21 [21679 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:21,transBytes:21 D/HEX write: 0000-000F: 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 ................ 0010-001F: 14 14 14 14 14 ..... D/HEX read: 0000-000F: 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 ................ 0010-001F: 14 14 14 14 14 ..... [22000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [22719 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:22 [22724 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 22 << 0 [22730 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 22 [22736 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [22743 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:22 [22748 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:22 [22754 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:22,rxTrigLvl:22,txTrigLvl:22 [22763 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:22 [22769 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:22 [22774 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:22,transBytes:22 D/HEX write: 0000-000F: 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 ................ 0010-001F: 15 15 15 15 15 15 ...... D/HEX read: 0000-000F: 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 ................ 0010-001F: 15 15 15 15 15 15 ...... [23000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [23814 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:23 [23819 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 23 << 0 [23825 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 23 [23831 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [23838 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:23 [23843 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:23 [23849 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:23,rxTrigLvl:23,txTrigLvl:23 [23858 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:23 [23864 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:23 [23869 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:23,transBytes:23 D/HEX write: 0000-000F: 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 ................ 0010-001F: 16 16 16 16 16 16 16 ....... D/HEX read: 0000-000F: 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 ................ 0010-001F: 16 16 16 16 16 16 16 ....... [24000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [24909 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:24 [24914 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 24 << 0 [24920 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 24 [24926 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [24933 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:24 [24938 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:24 [24944 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:24,rxTrigLvl:24,txTrigLvl:24 [24953 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:24 [24959 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:24 [24964 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:24,transBytes:24 D/HEX write: 0000-000F: 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 ................ 0010-001F: 17 17 17 17 17 17 17 17 ........ D/HEX read: 0000-000F: 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 ................ 0010-001F: 17 17 17 17 17 17 17 17 ........ [25004 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [26000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [26007 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:25 [26013 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 25 << 0 [26019 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 25 [26025 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [26032 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:25 [26037 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:25 [26043 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:25,rxTrigLvl:25,txTrigLvl:25 [26052 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:25 [26058 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:25 [26064 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:25,transBytes:25 D/HEX write: 0000-000F: 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 ................ 0010-001F: 18 18 18 18 18 18 18 18 18 ......... D/HEX read: 0000-000F: 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 ................ 0010-001F: 18 18 18 18 18 18 18 18 18 ......... [27000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.02 KB 0.00MB/s,rx:0.02 KB 0.00MB/s [27103 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:26 [27108 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 26 << 0 [27114 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 26 [27120 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [27127 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:26 [27132 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:26 [27138 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:26,rxTrigLvl:26,txTrigLvl:26 [27147 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:26 [27153 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:26 [27158 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:26,transBytes:26 D/HEX write: 0000-000F: 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 ................ 0010-001F: 19 19 19 19 19 19 19 19 19 19 .......... D/HEX read: 0000-000F: 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 ................ 0010-001F: 19 19 19 19 19 19 19 19 19 19 .......... [28000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [28198 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:27 [28203 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 27 << 0 [28209 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 27 [28215 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [28222 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:27 [28227 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:27 [28233 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:27,rxTrigLvl:27,txTrigLvl:27 [28242 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:27 [28248 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:27 [28253 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:27,transBytes:27 D/HEX write: 0000-000F: 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A ................ 0010-001F: 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A ........... D/HEX read: 0000-000F: 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A ................ 0010-001F: 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A 1A ........... [29000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [29294 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:28 [29299 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 28 << 0 [29305 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 28 [29311 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [29318 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:28 [29323 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:28 [29329 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:28,rxTrigLvl:28,txTrigLvl:28 [29338 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:28 [29344 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:28 [29349 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:28,transBytes:28 D/HEX write: 0000-000F: 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B ................ 0010-001F: 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B ............ D/HEX read: 0000-000F: 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B ................ 0010-001F: 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B 1B ............ [30000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [30390 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:29 [30395 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 29 << 0 [30401 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 29 [30407 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [30414 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:29 [30419 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:29 [30425 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:29,rxTrigLvl:29,txTrigLvl:29 [30434 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:29 [30440 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:29 [30445 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:29,transBytes:29 D/HEX write: 0000-000F: 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C ................ 0010-001F: 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C ............. D/HEX read: 0000-000F: 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C ................ 0010-001F: 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C 1C ............. [31000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [31486 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:30 [31491 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 30 << 0 [31497 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 30 [31503 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [31510 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:30 [31515 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:30 [31521 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:30,rxTrigLvl:30,txTrigLvl:30 [31530 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:30 [31536 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:30 [31541 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:30,transBytes:30 D/HEX write: 0000-000F: 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D ................ 0010-001F: 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D .............. D/HEX read: 0000-000F: 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D ................ 0010-001F: 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D .............. [32000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [32582 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:31 [32587 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 31 << 0 [32593 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 31 [32599 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [32606 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:31 [32611 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:31 [32617 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:31,rxTrigLvl:31,txTrigLvl:31 [32626 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:31 [32632 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:31 [32637 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:31,transBytes:31 D/HEX write: 0000-000F: 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E ................ 0010-001F: 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E ............... D/HEX read: 0000-000F: 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E ................ 0010-001F: 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E 1E ............... [33000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [33678 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:32 [33683 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 32 << 0 [33689 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 32 [33695 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO [33702 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:32 [33707 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:32 [33713 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [33722 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [33728 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [33733 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F ................ 0010-001F: 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F ................ D/HEX read: 0000-000F: 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F ................ 0010-001F: 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F 1F ................ [34000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [34775 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:33 [34780 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 33 << 0 [34786 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 33 [34792 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [34799 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [34805 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [34811 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (33 / 32) * 32 [34817 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [34823 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [34829 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [34835 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [34844 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [34849 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [34855 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0010-001F: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0020-002F: 20 D/HEX read: 0000-000F: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0010-001F: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0020-002F: A5 . [35000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [35910 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:34 [35915 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 34 << 0 [35921 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 34 [35927 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [35934 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [35940 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [35946 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (34 / 32) * 32 [35952 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [35958 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [35964 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [35970 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [35979 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [35984 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [35990 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 !!!!!!!!!!!!!!!! 0010-001F: 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 !!!!!!!!!!!!!!!! 0020-002F: 21 21 !! D/HEX read: 0000-000F: 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 !!!!!!!!!!!!!!!! 0010-001F: 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 !!!!!!!!!!!!!!!! 0020-002F: A5 A5 .. [36046 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [37000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s [37046 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:35 [37051 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 35 << 0 [37057 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 35 [37063 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [37070 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [37076 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [37082 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (35 / 32) * 32 [37088 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [37094 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [37100 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [37106 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [37115 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [37120 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [37126 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 """""""""""""""" 0010-001F: 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 """""""""""""""" 0020-002F: 22 22 22 """ D/HEX read: 0000-000F: 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 """""""""""""""" 0010-001F: 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 """""""""""""""" 0020-002F: A5 A5 A5 ... [38000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [38181 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:36 [38186 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 36 << 0 [38192 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 36 [38198 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [38205 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [38211 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [38217 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (36 / 32) * 32 [38223 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [38229 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [38235 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [38241 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [38250 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [38255 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [38261 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 ################ 0010-001F: 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 ################ 0020-002F: 23 23 23 23 #### D/HEX read: 0000-000F: 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 ################ 0010-001F: 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 ################ 0020-002F: A5 A5 A5 A5 .... [39000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [39317 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:37 [39322 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 37 << 0 [39328 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 37 [39334 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [39341 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [39347 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [39353 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (37 / 32) * 32 [39359 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [39365 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [39371 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [39377 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [39386 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [39391 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [39397 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 $$$$$$$$$$$$$$$$ 0010-001F: 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 $$$$$$$$$$$$$$$$ 0020-002F: 24 24 24 24 24 $$$$$ D/HEX read: 0000-000F: 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 $$$$$$$$$$$$$$$$ 0010-001F: 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 $$$$$$$$$$$$$$$$ 0020-002F: A5 A5 A5 A5 A5 ..... [40000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [40453 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:38 [40458 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 38 << 0 [40464 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 38 [40470 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [40477 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [40483 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [40489 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (38 / 32) * 32 [40495 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [40501 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [40507 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [40513 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [40522 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [40527 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [40533 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 %%%%%%%%%%%%%%%% 0010-001F: 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 %%%%%%%%%%%%%%%% 0020-002F: 25 25 25 25 25 25 %%%%%% D/HEX read: 0000-000F: 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 %%%%%%%%%%%%%%%% 0010-001F: 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 %%%%%%%%%%%%%%%% 0020-002F: A5 A5 A5 A5 A5 A5 ...... [41000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [41589 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:39 [41594 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 39 << 0 [41600 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 39 [41606 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [41613 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [41619 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [41625 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (39 / 32) * 32 [41631 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [41637 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [41643 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [41649 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [41658 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [41663 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [41669 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 &&&&&&&&&&&&&&&& 0010-001F: 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 &&&&&&&&&&&&&&&& 0020-002F: 26 26 26 26 26 26 26 &&&&&&& D/HEX read: 0000-000F: 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 &&&&&&&&&&&&&&&& 0010-001F: 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 &&&&&&&&&&&&&&&& 0020-002F: A5 A5 A5 A5 A5 A5 A5 ....... [42000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s [42725 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:40 [42730 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 40 << 0 [42736 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 40 [42742 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size [42749 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:32 [42755 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:32 [42761 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (40 / 32) * 32 [42767 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:32 [42773 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 32 >> 0 [42779 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:32 [42785 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32 [42794 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32 [42799 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32 [42805 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32 D/HEX write: 0000-000F: 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 '''''''''''''''' 0010-001F: 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 '''''''''''''''' 0020-002F: 27 27 27 27 27 27 27 27 '''''''' D/HEX read: 0000-000F: 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 '''''''''''''''' 0010-001F: 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 '''''''''''''''' 0020-002F: A5 A5 A5 A5 A5 A5 A5 A5 ........ [43000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s
We have tried to make the trigLvl = 1 , the corresponding result is a little bit different with trigLvl = 32. When trigLvl = 1, the DMA can transmit the input data up to 128, but when it is equal or larger than 128, there will be a timeout error and the eeprom transmit will have some failed data transmit.
The following is the log for trigLvl = 1.
TIFS ver: 8.6.3--v08.06.03 (Chill Capybar
[1154 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 2 bytes timeout!
D/HEX read: 0000-000F: 00 A5 ..
[2000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[2175 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:3
[2182 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 3 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 ...
[3000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[3204 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:4
[3209 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 4 << 0
[3215 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 4
[3220 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[3227 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:4
[3233 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:4
[3238 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:4,rxTrigLvl:4,txTrigLvl:4
[3247 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:4
[3252 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:4
[3258 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:4,transBytes:4
[3275 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 4 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 ....
[4000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[4296 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:5
[4303 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 5 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 .....
[5000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[5325 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:6
[5330 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 6 << 0
[5336 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 6
[5341 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[5348 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:6
[5354 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:6
[5359 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:6,rxTrigLvl:6,txTrigLvl:6
[5368 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:6
[5373 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:6
[5379 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:6,transBytes:6
[5396 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 6 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 ......
[6000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[6418 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:7
[6425 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 7 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 .......
[7000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[7448 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:8
[7453 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 8 << 0
[7459 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 8
[7464 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[7471 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:8
[7477 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:8
[7482 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:8,rxTrigLvl:8,txTrigLvl:8
[7491 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:8
[7496 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:8
[7502 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:8,transBytes:8
[7519 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 8 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 ........
[8000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[8541 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:9
[8548 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 9 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 .........
[9000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[9571 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:10
[9576 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 10 << 0
[9582 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 10
[9587 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[9594 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:10
[9600 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:10
[9606 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:10,rxTrigLvl:10,txTrigLvl:10
[9615 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:10
[9620 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:10
[9626 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:10,transBytes:10
[9643 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 10 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 ..........
[10000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[10666 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:11
[10674 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 11 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ...........
[11000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[11697 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:12
[11702 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 12 << 0
[11708 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 12
[11714 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[11721 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:12
[11726 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:12
[11732 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:12,rxTrigLvl:12,txTrigLvl:12
[11741 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:12
[11747 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:12
[11752 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:12,transBytes:12
[11770 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 12 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ............
[12000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[12793 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:13
[12801 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 13 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 .............
[13000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[13824 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:14
[13829 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 14 << 0
[13835 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 14
[13841 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[13848 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:14
[13853 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:14
[13859 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:14,rxTrigLvl:14,txTrigLvl:14
[13868 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:14
[13874 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:14
[13879 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:14,transBytes:14
[13897 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 14 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ..............
[14920 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:15
[14928 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 15 bytes fail with:2
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ...............
[15000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[15952 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:16
[15957 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 16 << 0
[15963 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 16
[15969 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[15976 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:16
[15981 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:16
[15987 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:16,rxTrigLvl:16,txTrigLvl:16
[15996 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:16
[16002 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:16
[16007 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:16,transBytes:16
[16015 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[16025 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 16 bytes timeout!
D/HEX read: 0000-000F: 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ................
[17000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[17049 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:17
[17057 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 17 bytes fail with:2
0010-001F: 10 .
0010-001F: A5 .
[18000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[18095 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:18
[18100 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 18 << 0
[18106 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 18
[18112 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[18119 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:18
[18124 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:18
[18130 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:18,rxTrigLvl:18,txTrigLvl:18
[18139 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:18
[18145 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:18
[18150 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:18,transBytes:18
[18168 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 18 bytes timeout!
0010-001F: 11 11 ..
0010-001F: A5 A5 ..
[19000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[19206 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:19
[19214 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 19 bytes fail with:2
0010-001F: A5 A5 A5 ...
[20000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[20252 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:20
[20257 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 20 << 0
[20263 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 20
[20269 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[20276 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:20
[20281 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:20
[20287 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:20,rxTrigLvl:20,txTrigLvl:20
[20296 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:20
[20302 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:20
[20307 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:20,transBytes:20
[20325 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 20 bytes timeout!
0010-001F: A5 A5 A5 A5 ....
[21000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[21363 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:21
[21371 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 21 bytes fail with:2
0010-001F: A5 A5 A5 A5 A5 .....
[22000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[22409 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:22
[22414 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 22 << 0
[22420 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 22
[22426 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[22433 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:22
[22438 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:22
[22444 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:22,rxTrigLvl:22,txTrigLvl:22
[22453 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:22
[22459 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:22
[22464 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:22,transBytes:22
[22482 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 22 bytes timeout!
0010-001F: A5 A5 A5 A5 A5 A5 ......
[23000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[23520 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:23
[23528 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 23 bytes fail with:2
0010-001F: A5 A5 A5 A5 A5 A5 A5 .......
[24000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[24567 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:24
[24572 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 24 << 0
[24578 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 24
[24584 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[24591 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:24
[24596 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:24
[24602 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:24,rxTrigLvl:24,txTrigLvl:24
[24611 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:24
[24617 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:24
[24622 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:24,transBytes:24
[24640 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 24 bytes timeout!
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 ........
[25000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[25679 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:25
[25687 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 25 bytes fail with:2
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 .........
[26726 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:26
[26731 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 26 << 0
[26737 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 26
[26743 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[26750 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:26
[26755 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:26
[26761 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:26,rxTrigLvl:26,txTrigLvl:26
[26770 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:26
[26776 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:26
[26781 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:26,transBytes:26
[26799 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 26 bytes timeout!
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ..........
[27000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[27838 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:27
[27846 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 27 bytes fail with:2
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ...........
[28000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[28885 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:28
[28890 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 28 << 0
[28896 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 28
[28902 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[28909 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:28
[28914 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:28
[28920 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:28,rxTrigLvl:28,txTrigLvl:28
[28929 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:28
[28935 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:28
[28940 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:28,transBytes:28
[28958 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 28 bytes timeout!
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ............
[29000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[29998 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:29
[30006 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 29 bytes fail with:2
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 .............
[30046 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[31000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[31046 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:30
[31051 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 30 << 0
[31057 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 30
[31063 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[31070 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:30
[31075 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:30
[31081 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:30,rxTrigLvl:30,txTrigLvl:30
[31090 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:30
[31096 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:30
[31101 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:30,transBytes:30
[31119 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 30 bytes timeout!
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ..............
[32000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[32159 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:31
[32167 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 31 bytes fail with:2
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ...............
[33000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[33207 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:32
[33212 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 32 << 0
[33218 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 32
[33224 0] I/mcu1_0.drv.spi.SPI_v1: Transaction fits entirely in FIFO
[33231 0] D/mcu1_0.drv.spi.SPI_v1: line:602,object->rxTrigLvl:32
[33236 0] D/mcu1_0.drv.spi.SPI_v1: line:603,object->txTrigLvl:32
[33242 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:32,rxTrigLvl:32,txTrigLvl:32
[33251 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:32
[33257 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:32
[33262 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:32,transBytes:32
[33280 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 32 bytes timeout!
0010-001F: A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ................
[34000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[34320 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:33
[34328 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 33 bytes fail with:2
0020-002F: 20
0020-002F: A5 .
[35000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[35382 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:34
[35387 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 34 << 0
[35393 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 34
[35399 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[35406 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[35412 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[35418 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (34 / 1) * 1
[35424 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:34
[35429 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 34 >> 0
[35436 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:34
[35442 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:34,rxTrigLvl:1,txTrigLvl:1
[35451 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[35456 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:34
[35462 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:34,transBytes:34
0020-002F: 21 21 !!
0020-002F: A5 A5 ..
[36000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s
[36516 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:35
[36521 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 35 << 0
[36527 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 35
[36533 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[36540 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[36546 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[36552 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (35 / 1) * 1
[36558 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:35
[36563 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 35 >> 0
[36570 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:35
[36576 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:35,rxTrigLvl:1,txTrigLvl:1
[36585 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[36590 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:35
[36596 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:35,transBytes:35
0020-002F: 21 21 A5 !!.
[37000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.03 KB 0.00MB/s,rx:0.03 KB 0.00MB/s
[37650 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:36
[37655 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 36 << 0
[37661 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 36
[37667 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[37674 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[37680 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[37686 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (36 / 1) * 1
[37692 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:36
[37697 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 36 >> 0
[37704 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:36
[37710 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:36,rxTrigLvl:1,txTrigLvl:1
[37719 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[37724 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:36
[37730 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:36,transBytes:36
0020-002F: 22 22 22 A5 """.
[38000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.04 KB 0.00MB/s,rx:0.04 KB 0.00MB/s
[38784 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:37
[38789 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 37 << 0
[38795 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 37
[38801 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[38808 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[38814 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[38820 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (37 / 1) * 1
[38826 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:37
[38831 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 37 >> 0
[38838 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:37
[38844 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:37,rxTrigLvl:1,txTrigLvl:1
[38853 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[38858 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:37
[38864 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:37,transBytes:37
0020-002F: 23 23 23 23 A5 ####.
[39000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.04 KB 0.00MB/s,rx:0.04 KB 0.00MB/s
[39919 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:38
[39924 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 38 << 0
[39930 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 38
[39936 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[39943 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[39949 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[39955 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (38 / 1) * 1
[39961 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:38
[39966 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 38 >> 0
[39973 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:38
[39979 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:38,rxTrigLvl:1,txTrigLvl:1
[39988 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[39993 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:38
[39999 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:38,transBytes:38
[40006 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[40016 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 38 bytes timeout!
0020-002F: 23 23 23 23 A5 A5 ####..
[41000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[41071 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:39
[41079 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 39 bytes fail with:2
0020-002F: 23 23 23 23 A5 A5 A5 ####...
[42000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[42134 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:40
[42139 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 40 << 0
[42145 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 40
[42151 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[42158 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[42164 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[42170 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (40 / 1) * 1
[42176 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:40
[42181 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 40 >> 0
[42188 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:40
[42194 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:40,rxTrigLvl:1,txTrigLvl:1
[42203 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[42208 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:40
[42214 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:40,transBytes:40
0020-002F: 25 25 25 25 25 A5 A5 A5 %%%%%...
[43000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.04 KB 0.00MB/s,rx:0.04 KB 0.00MB/s
[43269 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:41
[43274 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 41 << 0
[43280 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 41
[43286 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[43293 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[43299 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[43305 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (41 / 1) * 1
[43311 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:41
[43316 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 41 >> 0
[43323 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:41
[43329 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:41,rxTrigLvl:1,txTrigLvl:1
[43338 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[43343 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:41
[43349 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:41,transBytes:41
[43366 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 41 bytes timeout!
D/HEX write: 0000-000F: 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 ((((((((((((((((
0010-001F: 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 ((((((((((((((((
0020-002F: 28 28 28 28 28 28 28 28 28 (((((((((
0020-002F: 25 25 25 25 25 A5 A5 A5 A5 %%%%%....
[44000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[44422 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:42
[44430 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 42 bytes fail with:2
D/HEX write: 0000-000F: 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 ))))))))))))))))
0010-001F: 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 ))))))))))))))))
0020-002F: 29 29 29 29 29 29 29 29 29 29 ))))))))))
0020-002F: 25 25 25 25 25 A5 A5 A5 A5 A5 %%%%%.....
[45000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[45486 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:43
[45491 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 43 << 0
[45497 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 43
[45503 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[45510 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[45516 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[45522 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (43 / 1) * 1
[45528 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:43
[45533 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 43 >> 0
[45540 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:43
[45546 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:43,rxTrigLvl:1,txTrigLvl:1
[45555 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[45560 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:43
[45566 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:43,transBytes:43
D/HEX write: 0000-000F: 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A ****************
0010-001F: 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A ****************
0020-002F: 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A 2A ***********
D/HEX read: 0000-000F: 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 ((((((((((((((((
0020-002F: 28 28 28 28 28 28 28 28 A5 A5 A5 ((((((((...
[46000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.04 KB 0.00MB/s,rx:0.04 KB 0.00MB/s
[46622 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:44
[46627 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 44 << 0
[46633 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 44
[46639 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[46646 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[46652 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[46658 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (44 / 1) * 1
[46664 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:44
[46669 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 44 >> 0
[46676 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:44
[46682 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:44,rxTrigLvl:1,txTrigLvl:1
[46691 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[46696 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:44
[46702 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:44,transBytes:44
[46719 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 44 bytes timeout!
D/HEX write: 0000-000F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B ++++++++++++++++
0010-001F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B ++++++++++++++++
0020-002F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B ++++++++++++
0020-002F: 28 28 28 28 28 28 28 28 A5 A5 A5 A5 ((((((((....
[47000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[47775 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:45
[47783 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 45 bytes fail with:2
D/HEX write: 0000-000F: 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C ,,,,,,,,,,,,,,,,
0010-001F: 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C ,,,,,,,,,,,,,,,,
0020-002F: 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C 2C ,,,,,,,,,,,,,
0020-002F: 28 28 28 28 28 28 28 28 A5 A5 A5 A5 A5 ((((((((.....
[48000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[48839 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:46
[48844 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 46 << 0
[48850 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 46
[48856 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[48863 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[48869 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[48875 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (46 / 1) * 1
[48881 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:46
[48886 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 46 >> 0
[48893 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:46
[48899 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:46,rxTrigLvl:1,txTrigLvl:1
[48908 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[48913 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:46
[48919 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:46,transBytes:46
D/HEX write: 0000-000F: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D ----------------
0010-001F: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D ----------------
0020-002F: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D --------------
D/HEX read: 0000-000F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B ++++++++++++++++
0020-002F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B A5 A5 A5 +++++++++++...
[49000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.04 KB 0.00MB/s,rx:0.04 KB 0.00MB/s
[49975 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:47
[49980 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 47 << 0
[49986 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 47
[49992 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[49999 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[50005 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[50011 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (47 / 1) * 1
[50017 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:47
[50022 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 47 >> 0
[50029 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:47
[50035 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:47,rxTrigLvl:1,txTrigLvl:1
[50044 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[50049 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:47
[50055 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:47,transBytes:47
[50062 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[50072 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 47 bytes timeout!
D/HEX write: 0000-000F: 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E ................
0010-001F: 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E ................
0020-002F: 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E ...............
0020-002F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B A5 A5 A5 A5 +++++++++++....
[51000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[51129 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:48
[51137 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 48 bytes fail with:2
D/HEX write: 0000-000F: 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F ////////////////
0010-001F: 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F ////////////////
0020-002F: 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F 2F ////////////////
0020-002F: 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B A5 A5 A5 A5 A5 +++++++++++.....
[52000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[52194 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:49
[52199 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 49 << 0
[52205 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 49
[52211 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[52218 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[52224 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[52230 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (49 / 1) * 1
[52236 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:49
[52241 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 49 >> 0
[52248 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:49
[52254 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:49,rxTrigLvl:1,txTrigLvl:1
[52263 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[52268 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:49
[52274 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:49,transBytes:49
D/HEX write: 0000-000F: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 0000000000000000
0010-001F: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 0000000000000000
0020-002F: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 0000000000000000
0030-003F: 30 0
D/HEX read: 0000-000F: 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E ................
0020-002F: 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E A5 A5 ................
0030-003F: A5 .
[53000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.05 KB 0.00MB/s,rx:0.05 KB 0.00MB/s
[53344 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:50
[53349 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 50 << 0
[53355 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 50
[53361 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[53368 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[53374 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[53380 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (50 / 1) * 1
[53386 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:50
[53391 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 50 >> 0
[53398 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:50
[53404 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:50,rxTrigLvl:1,txTrigLvl:1
[53413 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[53418 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:50
[53424 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:50,transBytes:50
[53441 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 50 bytes timeout!
D/HEX write: 0000-000F: 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 1111111111111111
0010-001F: 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 1111111111111111
0020-002F: 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 1111111111111111
0030-003F: 31 31 11
0030-003F: A5 A5 ..
[54000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[54512 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:51
[54520 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 51 bytes fail with:2
D/HEX write: 0000-000F: 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 2222222222222222
0010-001F: 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 2222222222222222
0020-002F: 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 2222222222222222
0030-003F: 32 32 32 222
0030-003F: A5 A5 A5 ...
[55000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[55591 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:52
[55596 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 52 << 0
[55602 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 52
[55608 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[55615 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[55621 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[55627 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (52 / 1) * 1
[55633 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:52
[55638 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 52 >> 0
[55645 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:52
[55651 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:52,rxTrigLvl:1,txTrigLvl:1
[55660 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[55665 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:52
[55671 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:52,transBytes:52
D/HEX write: 0000-000F: 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 3333333333333333
0010-001F: 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 3333333333333333
0020-002F: 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 3333333333333333
0030-003F: 33 33 33 33 3333
D/HEX read: 0000-000F: 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 1111111111111111
0030-003F: 31 A5 A5 A5 1...
[56000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.05 KB 0.00MB/s,rx:0.05 KB 0.00MB/s
[56742 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:53
[56747 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 53 << 0
[56753 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 53
[56759 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[56766 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[56772 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[56778 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (53 / 1) * 1
[56784 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:53
[56789 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 53 >> 0
[56796 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:53
[56802 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:53,rxTrigLvl:1,txTrigLvl:1
[56811 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[56816 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:53
[56822 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:53,transBytes:53
[56839 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 53 bytes timeout!
D/HEX write: 0000-000F: 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 4444444444444444
0010-001F: 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 4444444444444444
0020-002F: 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 4444444444444444
0030-003F: 34 34 34 34 34 44444
0030-003F: 31 A5 A5 A5 A5 1....
[57000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[57910 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:54
[57918 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 54 bytes fail with:2
D/HEX write: 0000-000F: 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 5555555555555555
0010-001F: 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 5555555555555555
0020-002F: 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 5555555555555555
0030-003F: 35 35 35 35 35 35 555555
0030-003F: 31 A5 A5 A5 A5 A5 1.....
[58000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[58990 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:55
[58995 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 55 << 0
[59001 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 55
[59007 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[59014 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[59020 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[59026 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (55 / 1) * 1
[59032 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:55
[59037 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 55 >> 0
[59044 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:55
[59050 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:55,rxTrigLvl:1,txTrigLvl:1
[59059 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[59064 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:55
[59070 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:55,transBytes:55
D/HEX write: 0000-000F: 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 6666666666666666
0010-001F: 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 6666666666666666
0020-002F: 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 6666666666666666
0030-003F: 36 36 36 36 36 36 36 6666666
D/HEX read: 0000-000F: 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 4444444444444444
0030-003F: 34 34 34 34 A5 A5 A5 4444...
[59141 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[60000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[60141 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:56
[60146 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 56 << 0
[60152 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 56
[60158 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[60165 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[60171 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[60177 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (56 / 1) * 1
[60183 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:56
[60188 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 56 >> 0
[60195 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:56
[60201 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:56,rxTrigLvl:1,txTrigLvl:1
[60210 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[60215 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:56
[60221 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:56,transBytes:56
[60238 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 56 bytes timeout!
D/HEX write: 0000-000F: 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 7777777777777777
0010-001F: 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 7777777777777777
0020-002F: 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 7777777777777777
0030-003F: 37 37 37 37 37 37 37 37 77777777
0030-003F: 34 34 34 34 A5 A5 A5 A5 4444....
[61000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[61310 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:57
[61318 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 57 bytes fail with:2
D/HEX write: 0000-000F: 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 8888888888888888
0010-001F: 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 8888888888888888
0020-002F: 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 8888888888888888
0030-003F: 38 38 38 38 38 38 38 38 38 888888888
0030-003F: 34 34 34 34 A5 A5 A5 A5 A5 4444.....
[62000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[62390 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:58
[62395 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 58 << 0
[62401 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 58
[62407 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[62414 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[62420 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[62426 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (58 / 1) * 1
[62432 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:58
[62437 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 58 >> 0
[62444 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:58
[62450 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:58,rxTrigLvl:1,txTrigLvl:1
[62459 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[62464 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:58
[62470 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:58,transBytes:58
D/HEX write: 0000-000F: 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 9999999999999999
0010-001F: 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 9999999999999999
0020-002F: 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 9999999999999999
0030-003F: 39 39 39 39 39 39 39 39 39 39 9999999999
D/HEX read: 0000-000F: 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 7777777777777777
0030-003F: 37 37 37 37 37 37 37 A5 A5 A5 7777777...
[63000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.06 KB 0.00MB/s,rx:0.06 KB 0.00MB/s
[63542 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:59
[63547 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 59 << 0
[63553 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 59
[63559 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[63566 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[63572 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[63578 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (59 / 1) * 1
[63584 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:59
[63589 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 59 >> 0
[63596 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:59
[63602 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:59,rxTrigLvl:1,txTrigLvl:1
[63611 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[63616 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:59
[63622 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:59,transBytes:59
[63639 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 59 bytes timeout!
D/HEX write: 0000-000F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A ::::::::::::::::
0010-001F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A ::::::::::::::::
0020-002F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A ::::::::::::::::
0030-003F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A :::::::::::
0030-003F: 37 37 37 37 37 37 37 A5 A5 A5 A5 7777777....
[64000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[64711 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:60
[64719 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 60 bytes fail with:2
D/HEX write: 0000-000F: 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B ;;;;;;;;;;;;;;;;
0010-001F: 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B ;;;;;;;;;;;;;;;;
0020-002F: 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B ;;;;;;;;;;;;;;;;
0030-003F: 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B 3B ;;;;;;;;;;;;
0030-003F: 37 37 37 37 37 37 37 A5 A5 A5 A5 A5 7777777.....
[65000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[65792 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:61
[65797 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 61 << 0
[65803 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 61
[65809 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[65816 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[65822 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[65828 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (61 / 1) * 1
[65834 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:61
[65839 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 61 >> 0
[65846 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:61
[65852 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:61,rxTrigLvl:1,txTrigLvl:1
[65861 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[65866 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:61
[65872 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:61,transBytes:61
D/HEX write: 0000-000F: 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C <<<<<<<<<<<<<<<<
0010-001F: 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C <<<<<<<<<<<<<<<<
0020-002F: 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C <<<<<<<<<<<<<<<<
0030-003F: 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C <<<<<<<<<<<<<
D/HEX read: 0000-000F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A ::::::::::::::::
0030-003F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A A5 A5 A5 ::::::::::...
[66000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.06 KB 0.00MB/s,rx:0.06 KB 0.00MB/s
[66944 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:62
[66949 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 62 << 0
[66955 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 62
[66961 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[66968 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[66974 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[66980 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (62 / 1) * 1
[66986 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:62
[66991 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 62 >> 0
[66998 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:62
[67004 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:62,rxTrigLvl:1,txTrigLvl:1
[67013 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[67018 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:62
[67024 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:62,transBytes:62
[67031 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[67041 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 62 bytes timeout!
D/HEX write: 0000-000F: 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================
0010-001F: 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================
0020-002F: 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================
0030-003F: 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ==============
D/HEX read: 0000-000F: 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C 3C <<<<<<<<<<<<<<<<
0030-003F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A A5 A5 A5 A5 ::::::::::....
[68000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[68114 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:63
[68122 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 63 bytes fail with:2
D/HEX write: 0000-000F: 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E >>>>>>>>>>>>>>>>
0010-001F: 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E >>>>>>>>>>>>>>>>
0020-002F: 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E >>>>>>>>>>>>>>>>
0030-003F: 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E 3E >>>>>>>>>>>>>>>
0030-003F: 3A 3A 3A 3A 3A 3A 3A 3A 3A 3A A5 A5 A5 A5 A5 ::::::::::.....
[69000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[69195 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:64
[69200 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 64 << 0
[69206 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 64
[69212 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[69219 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[69225 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[69231 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (64 / 1) * 1
[69237 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:64
[69242 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 64 >> 0
[69249 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:64
[69255 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:64,rxTrigLvl:1,txTrigLvl:1
[69264 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[69269 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:64
[69275 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:64,transBytes:64
D/HEX write: 0000-000F: 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F ????????????????
0010-001F: 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F ????????????????
0020-002F: 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F ????????????????
0030-003F: 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F ????????????????
D/HEX read: 0000-000F: 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================
0030-003F: 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D A5 A5 A5 =============...
[70000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.06 KB 0.00MB/s,rx:0.06 KB 0.00MB/s
[70348 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:65
[70353 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 65 << 0
[70359 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 65
[70365 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[70372 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[70378 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[70384 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (65 / 1) * 1
[70390 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:65
[70395 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 65 >> 0
[70402 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:65
[70408 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:65,rxTrigLvl:1,txTrigLvl:1
[70417 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[70422 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:65
[70428 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:65,transBytes:65
[70445 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 65 bytes timeout!
D/HEX write: 0000-000F: 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 @@@@@@@@@@@@@@@@
0010-001F: 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 @@@@@@@@@@@@@@@@
0020-002F: 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 @@@@@@@@@@@@@@@@
0030-003F: 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 @@@@@@@@@@@@@@@@
0040-004F: 40 @
D/HEX read: 0000-000F: 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F 3F ????????????????
0040-004F: A5 .
[71000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[71532 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:66
[71540 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 66 bytes fail with:2
D/HEX write: 0000-000F: 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 AAAAAAAAAAAAAAAA
0010-001F: 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 AAAAAAAAAAAAAAAA
0020-002F: 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 AAAAAAAAAAAAAAAA
0030-003F: 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 AAAAAAAAAAAAAAAA
0040-004F: 41 41 AA
0040-004F: A5 A5 ..
[72000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[72627 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:67
[72632 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 67 << 0
[72638 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 67
[72644 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[72651 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[72657 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[72663 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (67 / 1) * 1
[72669 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:67
[72674 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 67 >> 0
[72681 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:67
[72687 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:67,rxTrigLvl:1,txTrigLvl:1
[72696 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[72701 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:67
[72707 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:67,transBytes:67
D/HEX write: 0000-000F: 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 BBBBBBBBBBBBBBBB
0010-001F: 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 BBBBBBBBBBBBBBBB
0020-002F: 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 BBBBBBBBBBBBBBBB
0030-003F: 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 BBBBBBBBBBBBBBBB
0040-004F: 42 42 42 BBB
D/HEX read: 0000-000F: 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 @@@@@@@@@@@@@@@@
0040-004F: A5 A5 A5 ...
[73000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.07 KB 0.00MB/s,rx:0.07 KB 0.00MB/s
[73794 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:68
[73799 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 68 << 0
[73805 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 68
[73811 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[73818 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[73824 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[73830 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (68 / 1) * 1
[73836 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:68
[73841 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 68 >> 0
[73848 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:68
[73854 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:68,rxTrigLvl:1,txTrigLvl:1
[73863 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[73868 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:68
[73874 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:68,transBytes:68
[73891 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 68 bytes timeout!
D/HEX write: 0000-000F: 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 CCCCCCCCCCCCCCCC
0010-001F: 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 CCCCCCCCCCCCCCCC
0020-002F: 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 CCCCCCCCCCCCCCCC
0030-003F: 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 CCCCCCCCCCCCCCCC
0040-004F: 43 43 43 43 CCCC
D/HEX read: 0000-000F: 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 BBBBBBBBBBBBBBBB
0040-004F: A5 A5 A5 A5 ....
[74000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[74979 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:69
[74987 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 69 bytes fail with:2
D/HEX write: 0000-000F: 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 DDDDDDDDDDDDDDDD
0010-001F: 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 DDDDDDDDDDDDDDDD
0020-002F: 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 DDDDDDDDDDDDDDDD
0030-003F: 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 DDDDDDDDDDDDDDDD
0040-004F: 44 44 44 44 44 DDDDD
0040-004F: A5 A5 A5 A5 01 .....
[75075 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[76000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[76075 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:70
[76080 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 70 << 0
[76086 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 70
[76092 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[76099 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[76105 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[76111 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (70 / 1) * 1
[76117 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:70
[76122 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 70 >> 0
[76129 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:70
[76135 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:70,rxTrigLvl:1,txTrigLvl:1
[76144 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[76149 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:70
[76155 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:70,transBytes:70
D/HEX write: 0000-000F: 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 EEEEEEEEEEEEEEEE
0010-001F: 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 EEEEEEEEEEEEEEEE
0020-002F: 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 EEEEEEEEEEEEEEEE
0030-003F: 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 EEEEEEEEEEEEEEEE
0040-004F: 45 45 45 45 45 45 EEEEEE
D/HEX read: 0000-000F: 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 CCCCCCCCCCCCCCCC
0040-004F: 43 43 43 A5 01 00 CCC...
[77000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.07 KB 0.00MB/s,rx:0.07 KB 0.00MB/s
[77243 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:71
[77248 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 71 << 0
[77254 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 71
[77260 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[77267 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[77273 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[77279 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (71 / 1) * 1
[77285 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:71
[77290 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 71 >> 0
[77297 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:71
[77303 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:71,rxTrigLvl:1,txTrigLvl:1
[77312 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[77317 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:71
[77323 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:71,transBytes:71
[77340 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 71 bytes timeout!
D/HEX write: 0000-000F: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF
0010-001F: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF
0020-002F: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF
0030-003F: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF
0040-004F: 46 46 46 46 46 46 46 FFFFFFF
D/HEX read: 0000-000F: 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 EEEEEEEEEEEEEEEE
0040-004F: 43 43 43 A5 01 00 00 CCC....
[78000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[78428 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:72
[78436 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 72 bytes fail with:2
D/HEX write: 0000-000F: 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 GGGGGGGGGGGGGGGG
0010-001F: 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 GGGGGGGGGGGGGGGG
0020-002F: 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 GGGGGGGGGGGGGGGG
0030-003F: 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 GGGGGGGGGGGGGGGG
0040-004F: 47 47 47 47 47 47 47 47 GGGGGGGG
0040-004F: 43 43 43 A5 01 00 00 00 CCC.....
[79000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[79525 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:73
[79530 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 73 << 0
[79536 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 73
[79542 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[79549 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[79555 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[79561 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (73 / 1) * 1
[79567 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:73
[79572 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 73 >> 0
[79579 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:73
[79585 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:73,rxTrigLvl:1,txTrigLvl:1
[79594 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[79599 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:73
[79605 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:73,transBytes:73
D/HEX write: 0000-000F: 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 HHHHHHHHHHHHHHHH
0010-001F: 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 HHHHHHHHHHHHHHHH
0020-002F: 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 HHHHHHHHHHHHHHHH
0030-003F: 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 HHHHHHHHHHHHHHHH
0040-004F: 48 48 48 48 48 48 48 48 48 HHHHHHHHH
D/HEX read: 0000-000F: 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 FFFFFFFFFFFFFFFF
0040-004F: 46 46 46 46 46 46 00 00 00 FFFFFF...
[80000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.07 KB 0.00MB/s,rx:0.07 KB 0.00MB/s
[80693 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:74
[80698 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 74 << 0
[80704 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 74
[80710 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[80717 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[80723 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[80729 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (74 / 1) * 1
[80735 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:74
[80740 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 74 >> 0
[80747 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:74
[80753 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:74,rxTrigLvl:1,txTrigLvl:1
[80762 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[80767 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:74
[80773 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:74,transBytes:74
[80790 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 74 bytes timeout!
D/HEX write: 0000-000F: 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 IIIIIIIIIIIIIIII
0010-001F: 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 IIIIIIIIIIIIIIII
0020-002F: 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 IIIIIIIIIIIIIIII
0030-003F: 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 IIIIIIIIIIIIIIII
0040-004F: 49 49 49 49 49 49 49 49 49 49 IIIIIIIIII
D/HEX read: 0000-000F: 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 HHHHHHHHHHHHHHHH
0040-004F: 46 46 46 46 46 46 00 00 00 00 FFFFFF....
[81000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[81879 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:75
[81887 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 75 bytes fail with:2
D/HEX write: 0000-000F: 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A JJJJJJJJJJJJJJJJ
0010-001F: 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A JJJJJJJJJJJJJJJJ
0020-002F: 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A JJJJJJJJJJJJJJJJ
0030-003F: 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A JJJJJJJJJJJJJJJJ
0040-004F: 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A 4A JJJJJJJJJJJ
0040-004F: 46 46 46 46 46 46 00 00 00 00 00 FFFFFF.....
[82000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[82976 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:76
[82981 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 76 << 0
[82987 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 76
[82993 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[83000 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[83006 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[83012 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (76 / 1) * 1
[83018 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:76
[83023 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 76 >> 0
[83030 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:76
[83036 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:76,rxTrigLvl:1,txTrigLvl:1
[83045 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[83050 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:76
[83056 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:76,transBytes:76
D/HEX write: 0000-000F: 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B KKKKKKKKKKKKKKKK
0010-001F: 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B KKKKKKKKKKKKKKKK
0020-002F: 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B KKKKKKKKKKKKKKKK
0030-003F: 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B KKKKKKKKKKKKKKKK
0040-004F: 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B KKKKKKKKKKKK
D/HEX read: 0000-000F: 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 IIIIIIIIIIIIIIII
0040-004F: 49 49 49 49 49 49 49 49 49 00 00 00 IIIIIIIII...
[83145 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[84000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[84145 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:77
[84150 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 77 << 0
[84156 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 77
[84162 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[84169 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[84175 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[84181 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (77 / 1) * 1
[84187 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:77
[84192 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 77 >> 0
[84199 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:77
[84205 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:77,rxTrigLvl:1,txTrigLvl:1
[84214 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[84219 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:77
[84225 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:77,transBytes:77
[84242 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 77 bytes timeout!
D/HEX write: 0000-000F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C LLLLLLLLLLLLLLLL
0010-001F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C LLLLLLLLLLLLLLLL
0020-002F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C LLLLLLLLLLLLLLLL
0030-003F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C LLLLLLLLLLLLLLLL
0040-004F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C LLLLLLLLLLLLL
D/HEX read: 0000-000F: 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B 4B KKKKKKKKKKKKKKKK
0040-004F: 49 49 49 49 49 49 49 49 49 00 00 00 00 IIIIIIIII....
[85000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[85331 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:78
[85339 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 78 bytes fail with:2
D/HEX write: 0000-000F: 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D MMMMMMMMMMMMMMMM
0010-001F: 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D MMMMMMMMMMMMMMMM
0020-002F: 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D MMMMMMMMMMMMMMMM
0030-003F: 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D MMMMMMMMMMMMMMMM
0040-004F: 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D 4D MMMMMMMMMMMMMM
0040-004F: 49 49 49 49 49 49 49 49 49 00 00 00 00 00 IIIIIIIII.....
[86000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[86429 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:79
[86434 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 79 << 0
[86440 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 79
[86446 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[86453 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[86459 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[86465 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (79 / 1) * 1
[86471 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:79
[86476 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 79 >> 0
[86483 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:79
[86489 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:79,rxTrigLvl:1,txTrigLvl:1
[86498 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[86503 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:79
[86509 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:79,transBytes:79
D/HEX write: 0000-000F: 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E NNNNNNNNNNNNNNNN
0010-001F: 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E NNNNNNNNNNNNNNNN
0020-002F: 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E NNNNNNNNNNNNNNNN
0030-003F: 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E NNNNNNNNNNNNNNNN
0040-004F: 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E NNNNNNNNNNNNNNN
D/HEX read: 0000-000F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C LLLLLLLLLLLLLLLL
0040-004F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 00 00 00 LLLLLLLLLLLL...
[87000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.08 KB 0.00MB/s,rx:0.08 KB 0.00MB/s
[87598 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:80
[87603 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 80 << 0
[87609 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 80
[87615 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[87622 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[87628 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[87634 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (80 / 1) * 1
[87640 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:80
[87645 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 80 >> 0
[87652 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:80
[87658 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:80,rxTrigLvl:1,txTrigLvl:1
[87667 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[87672 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:80
[87678 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:80,transBytes:80
[87695 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 80 bytes timeout!
D/HEX write: 0000-000F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F OOOOOOOOOOOOOOOO
0010-001F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F OOOOOOOOOOOOOOOO
0020-002F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F OOOOOOOOOOOOOOOO
0030-003F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F OOOOOOOOOOOOOOOO
0040-004F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F OOOOOOOOOOOOOOOO
D/HEX read: 0000-000F: 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E 4E NNNNNNNNNNNNNNNN
0040-004F: 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 4C 00 00 00 00 LLLLLLLLLLLL....
[88000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[88785 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:81
[88793 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 81 bytes fail with:2
D/HEX write: 0000-000F: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 PPPPPPPPPPPPPPPP
0010-001F: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 PPPPPPPPPPPPPPPP
0020-002F: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 PPPPPPPPPPPPPPPP
0030-003F: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 PPPPPPPPPPPPPPPP
0040-004F: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 PPPPPPPPPPPPPPPP
0050-005F: 50 P
0050-005F: 00 .
[89000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[89897 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:82
[89902 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 82 << 0
[89908 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 82
[89914 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[89921 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[89927 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[89933 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (82 / 1) * 1
[89939 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:82
[89944 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 82 >> 0
[89951 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:82
[89957 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:82,rxTrigLvl:1,txTrigLvl:1
[89966 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[89971 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:82
[89977 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:82,transBytes:82
D/HEX write: 0000-000F: 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 QQQQQQQQQQQQQQQQ
0010-001F: 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 QQQQQQQQQQQQQQQQ
0020-002F: 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 QQQQQQQQQQQQQQQQ
0030-003F: 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 QQQQQQQQQQQQQQQQ
0040-004F: 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 QQQQQQQQQQQQQQQQ
0050-005F: 51 51 QQ
D/HEX read: 0000-000F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F OOOOOOOOOOOOOOOO
0040-004F: 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 4F 00 OOOOOOOOOOOOOOO.
0050-005F: 00 00 ..
[90081 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.08 KB 0.00MB/s,rx:0.08 KB 0.00MB/s
[91000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[91081 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:83
[91086 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 83 << 0
[91092 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 83
[91098 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[91105 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[91111 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[91117 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (83 / 1) * 1
[91123 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:83
[91128 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 83 >> 0
[91135 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:83
[91141 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:83,rxTrigLvl:1,txTrigLvl:1
[91150 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[91155 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:83
[91161 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:83,transBytes:83
[91178 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 83 bytes timeout!
D/HEX write: 0000-000F: 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 RRRRRRRRRRRRRRRR
0010-001F: 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 RRRRRRRRRRRRRRRR
0020-002F: 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 RRRRRRRRRRRRRRRR
0030-003F: 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 RRRRRRRRRRRRRRRR
0040-004F: 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 RRRRRRRRRRRRRRRR
0050-005F: 52 52 52 RRR
D/HEX read: 0000-000F: 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 QQQQQQQQQQQQQQQQ
0050-005F: 00 00 00 ...
[92000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[92282 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:84
[92290 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 84 bytes fail with:2
D/HEX write: 0000-000F: 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 SSSSSSSSSSSSSSSS
0010-001F: 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 SSSSSSSSSSSSSSSS
0020-002F: 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 SSSSSSSSSSSSSSSS
0030-003F: 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 SSSSSSSSSSSSSSSS
0040-004F: 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 53 SSSSSSSSSSSSSSSS
0050-005F: 53 53 53 53 SSSS
0050-005F: 00 00 00 00 ....
[93000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[93394 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:85
[93399 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 85 << 0
[93405 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 85
[93411 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[93418 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[93424 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[93430 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (85 / 1) * 1
[93436 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:85
[93441 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 85 >> 0
[93448 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:85
[93454 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:85,rxTrigLvl:1,txTrigLvl:1
[93463 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[93468 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:85
[93474 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:85,transBytes:85
D/HEX write: 0000-000F: 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 TTTTTTTTTTTTTTTT
0010-001F: 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 TTTTTTTTTTTTTTTT
0020-002F: 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 TTTTTTTTTTTTTTTT
0030-003F: 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 TTTTTTTTTTTTTTTT
0040-004F: 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 TTTTTTTTTTTTTTTT
0050-005F: 54 54 54 54 54 TTTTT
D/HEX read: 0000-000F: 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 RRRRRRRRRRRRRRRR
0050-005F: 52 52 00 00 00 RR...
[94000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.08 KB 0.00MB/s,rx:0.08 KB 0.00MB/s
[94578 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:86
[94583 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 86 << 0
[94589 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 86
[94595 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[94602 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[94608 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[94614 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (86 / 1) * 1
[94620 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:86
[94625 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 86 >> 0
[94632 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:86
[94638 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:86,rxTrigLvl:1,txTrigLvl:1
[94647 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[94652 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:86
[94658 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:86,transBytes:86
[94675 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 86 bytes timeout!
D/HEX write: 0000-000F: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
0010-001F: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
0020-002F: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
0030-003F: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
0040-004F: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
0050-005F: 55 55 55 55 55 55 UUUUUU
D/HEX read: 0000-000F: 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 TTTTTTTTTTTTTTTT
0050-005F: 52 52 00 00 00 00 RR....
[95000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[95780 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:87
[95788 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 87 bytes fail with:2
D/HEX write: 0000-000F: 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 VVVVVVVVVVVVVVVV
0010-001F: 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 VVVVVVVVVVVVVVVV
0020-002F: 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 VVVVVVVVVVVVVVVV
0030-003F: 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 VVVVVVVVVVVVVVVV
0040-004F: 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 VVVVVVVVVVVVVVVV
0050-005F: 56 56 56 56 56 56 56 VVVVVVV
0050-005F: 52 52 00 00 00 00 00 RR.....
[96000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[96893 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:88
[96898 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 88 << 0
[96904 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 88
[96910 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[96917 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[96923 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[96929 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (88 / 1) * 1
[96935 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:88
[96940 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 88 >> 0
[96947 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:88
[96953 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:88,rxTrigLvl:1,txTrigLvl:1
[96962 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[96967 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:88
[96973 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:88,transBytes:88
D/HEX write: 0000-000F: 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 WWWWWWWWWWWWWWWW
0010-001F: 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 WWWWWWWWWWWWWWWW
0020-002F: 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 WWWWWWWWWWWWWWWW
0030-003F: 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 WWWWWWWWWWWWWWWW
0040-004F: 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 WWWWWWWWWWWWWWWW
0050-005F: 57 57 57 57 57 57 57 57 WWWWWWWW
D/HEX read: 0000-000F: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
0050-005F: 55 55 55 55 55 00 00 00 UUUUU...
[97078 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.09 KB 0.00MB/s,rx:0.09 KB 0.00MB/s
[98000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[98078 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:89
[98083 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 89 << 0
[98089 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 89
[98095 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[98102 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[98108 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[98114 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (89 / 1) * 1
[98120 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:89
[98125 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 89 >> 0
[98132 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:89
[98138 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:89,rxTrigLvl:1,txTrigLvl:1
[98147 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[98152 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:89
[98158 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:89,transBytes:89
[98175 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 89 bytes timeout!
D/HEX write: 0000-000F: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
0010-001F: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
0020-002F: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
0030-003F: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
0040-004F: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
0050-005F: 58 58 58 58 58 58 58 58 58 XXXXXXXXX
D/HEX read: 0000-000F: 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 WWWWWWWWWWWWWWWW
0050-005F: 55 55 55 55 55 00 00 00 00 UUUUU....
[99000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[99280 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:90
[99288 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 90 bytes fail with:2
D/HEX write: 0000-000F: 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 YYYYYYYYYYYYYYYY
0010-001F: 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 YYYYYYYYYYYYYYYY
0020-002F: 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 YYYYYYYYYYYYYYYY
0030-003F: 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 YYYYYYYYYYYYYYYY
0040-004F: 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 YYYYYYYYYYYYYYYY
0050-005F: 59 59 59 59 59 59 59 59 59 59 YYYYYYYYYY
0050-005F: 55 55 55 55 55 00 00 00 00 00 UUUUU.....
[100000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[100393 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:91
[100398 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 91 << 0
[100404 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 91
[100410 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[100418 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[100423 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[100429 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (91 / 1) * 1
[100436 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:91
[100441 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 91 >> 0
[100448 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:91
[100454 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:91,rxTrigLvl:1,txTrigLvl:1
[100463 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[100468 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:91
[100474 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:91,transBytes:91
D/HEX write: 0000-000F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZZZZZZ
0010-001F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZZZZZZ
0020-002F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZZZZZZ
0030-003F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZZZZZZ
0040-004F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZZZZZZ
0050-005F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZ
D/HEX read: 0000-000F: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
0050-005F: 58 58 58 58 58 58 58 58 00 00 00 XXXXXXXX...
[101000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.09 KB 0.00MB/s,rx:0.09 KB 0.00MB/s
[101579 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:92
[101584 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 92 << 0
[101590 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 92
[101596 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[101604 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[101609 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[101615 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (92 / 1) * 1
[101622 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:92
[101627 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 92 >> 0
[101634 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:92
[101640 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:92,rxTrigLvl:1,txTrigLvl:1
[101649 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[101654 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:92
[101660 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:92,transBytes:92
[101677 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 92 bytes timeout!
D/HEX write: 0000-000F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[[[[[
0010-001F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[[[[[
0020-002F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[[[[[
0030-003F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[[[[[
0040-004F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[[[[[
0050-005F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[
D/HEX read: 0000-000F: 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A ZZZZZZZZZZZZZZZZ
0050-005F: 58 58 58 58 58 58 58 58 00 00 00 00 XXXXXXXX....
[102000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[102783 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:93
[102791 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 93 bytes fail with:2
D/HEX write: 0000-000F: 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C \\\\\\\\\\\\\\\\
0010-001F: 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C \\\\\\\\\\\\\\\\
0020-002F: 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C \\\\\\\\\\\\\\\\
0030-003F: 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C \\\\\\\\\\\\\\\\
0040-004F: 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C \\\\\\\\\\\\\\\\
0050-005F: 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C 5C \\\\\\\\\\\\\
0050-005F: 58 58 58 58 58 58 58 58 00 00 00 00 00 XXXXXXXX.....
[103000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[103897 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:94
[103902 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 94 << 0
[103908 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 94
[103914 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[103922 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[103927 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[103933 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (94 / 1) * 1
[103940 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:94
[103945 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 94 >> 0
[103952 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:94
[103958 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:94,rxTrigLvl:1,txTrigLvl:1
[103967 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[103972 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:94
[103978 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:94,transBytes:94
D/HEX write: 0000-000F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]]
0010-001F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]]
0020-002F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]]
0030-003F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]]
0040-004F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]]
0050-005F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]
D/HEX read: 0000-000F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B [[[[[[[[[[[[[[[[
0050-005F: 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 5B 00 00 00 [[[[[[[[[[[...
[104084 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.09 KB 0.00MB/s,rx:0.09 KB 0.00MB/s
[105000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[105084 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:95
[105089 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 95 << 0
[105095 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 95
[105101 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[105109 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[105114 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[105120 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (95 / 1) * 1
[105127 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:95
[105132 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 95 >> 0
[105139 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:95
[105145 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:95,rxTrigLvl:1,txTrigLvl:1
[105154 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[105159 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:95
[105165 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:95,transBytes:95
[105182 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 95 bytes timeout!
D/HEX write: 0000-000F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^^
0010-001F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^^
0020-002F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^^
0030-003F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^^
0040-004F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^^
0050-005F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^
D/HEX read: 0000-000F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]]
0030-003F: 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5E 5E 5E ]]]]]]]]]]]]]^^^
0050-005F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 00 ^^^^^^^^^^^^^^.
[106000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[106288 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:96
[106296 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 96 bytes fail with:2
D/HEX write: 0000-000F: 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F ________________
0010-001F: 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F ________________
0020-002F: 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F ________________
0030-003F: 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F ________________
0040-004F: 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F ________________
0050-005F: 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F ________________
0050-005F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 00 00 ^^^^^^^^^^^^^^..
[107000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[107403 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:97
[107408 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 97 << 0
[107414 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 97
[107420 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[107428 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[107433 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[107439 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (97 / 1) * 1
[107446 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:97
[107451 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 97 >> 0
[107458 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:97
[107464 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:97,rxTrigLvl:1,txTrigLvl:1
[107473 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[107478 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:97
[107484 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:97,transBytes:97
D/HEX write: 0000-000F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0010-001F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0020-002F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0030-003F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0040-004F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0050-005F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0060-006F: 60 `
D/HEX read: 0000-000F: 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E 5E ^^^^^^^^^^^^^^^^
0060-006F: 00 .
[108000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.09 KB 0.00MB/s,rx:0.09 KB 0.00MB/s
[108604 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:98
[108609 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 98 << 0
[108615 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 98
[108621 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[108629 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[108634 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[108640 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (98 / 1) * 1
[108647 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:98
[108652 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 98 >> 0
[108658 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:98
[108665 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:98,rxTrigLvl:1,txTrigLvl:1
[108674 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[108679 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:98
[108685 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:98,transBytes:98
[108702 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 98 bytes timeout!
D/HEX write: 0000-000F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0010-001F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0020-002F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0030-003F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0040-004F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0050-005F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0060-006F: 61 61 aa
D/HEX read: 0000-000F: 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 ````````````````
0060-006F: 00 00 ..
[109000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[109823 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:99
[109831 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 99 bytes fail with:2
D/HEX write: 0000-000F: 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 bbbbbbbbbbbbbbbb
0010-001F: 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 bbbbbbbbbbbbbbbb
0020-002F: 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 bbbbbbbbbbbbbbbb
0030-003F: 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 bbbbbbbbbbbbbbbb
0040-004F: 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 bbbbbbbbbbbbbbbb
0050-005F: 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 bbbbbbbbbbbbbbbb
0060-006F: 62 62 62 bbb
0060-006F: 00 00 00 ...
[110000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[110952 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:100
[110958 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 100 << 0
[110964 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 100
[110969 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[110977 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[110983 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[110988 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (100 / 1) * 1
[110995 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:100
[111000 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 100 >> 0
[111007 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:100
[111013 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:100,rxTrigLvl:1,txTrigLvl:1
[111022 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[111027 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:100
[111034 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:100,transBytes:100
D/HEX write: 0000-000F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0010-001F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0020-002F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0030-003F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0040-004F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0050-005F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0060-006F: 63 63 63 63 cccc
D/HEX read: 0000-000F: 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 aaaaaaaaaaaaaaaa
0060-006F: 61 00 00 00 a...
[111155 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[112000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[112155 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:101
[112161 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 101 << 0
[112167 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 101
[112172 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[112180 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[112186 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[112191 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (101 / 1) * 1
[112198 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:101
[112203 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 101 >> 0
[112210 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:101
[112216 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:101,rxTrigLvl:1,txTrigLvl:1
[112225 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[112230 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:101
[112237 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:101,transBytes:101
[112254 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 101 bytes timeout!
D/HEX write: 0000-000F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0010-001F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0020-002F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0030-003F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0040-004F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0050-005F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0060-006F: 64 64 64 64 64 ddddd
D/HEX read: 0000-000F: 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 cccccccccccccccc
0040-004F: 63 63 63 64 64 64 64 64 64 64 64 64 64 64 64 64 cccddddddddddddd
0060-006F: 61 00 00 00 00 a....
[113000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[113375 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:102
[113383 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 102 bytes fail with:2
D/HEX write: 0000-000F: 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 eeeeeeeeeeeeeeee
0010-001F: 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 eeeeeeeeeeeeeeee
0020-002F: 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 eeeeeeeeeeeeeeee
0030-003F: 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 eeeeeeeeeeeeeeee
0040-004F: 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 eeeeeeeeeeeeeeee
0050-005F: 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 eeeeeeeeeeeeeeee
0060-006F: 65 65 65 65 65 65 eeeeee
0060-006F: 61 00 00 00 00 00 a.....
[114000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[114505 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:103
[114511 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 103 << 0
[114517 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 103
[114522 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[114530 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[114536 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[114541 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (103 / 1) * 1
[114548 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:103
[114553 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 103 >> 0
[114560 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:103
[114566 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:103,rxTrigLvl:1,txTrigLvl:1
[114575 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[114580 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:103
[114587 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:103,transBytes:103
D/HEX write: 0000-000F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0010-001F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0020-002F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0030-003F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0040-004F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0050-005F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0060-006F: 66 66 66 66 66 66 66 fffffff
D/HEX read: 0000-000F: 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 dddddddddddddddd
0060-006F: 64 64 64 64 00 00 00 dddd...
[115000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.10 KB 0.00MB/s,rx:0.10 KB 0.00MB/s
[115708 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:104
[115714 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 104 << 0
[115720 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 104
[115725 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[115733 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[115739 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[115744 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (104 / 1) * 1
[115751 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:104
[115756 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 104 >> 0
[115763 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:104
[115769 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:104,rxTrigLvl:1,txTrigLvl:1
[115778 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[115783 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:104
[115790 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:104,transBytes:104
[115807 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 104 bytes timeout!
D/HEX write: 0000-000F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0010-001F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0020-002F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0030-003F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0040-004F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0050-005F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0060-006F: 67 67 67 67 67 67 67 67 gggggggg
D/HEX read: 0000-000F: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 ffffffffffffffff
0040-004F: 66 66 66 66 66 66 67 67 67 67 67 67 67 67 67 67 ffffffgggggggggg
0060-006F: 64 64 64 64 00 00 00 00 dddd....
[116000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[116929 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:105
[116937 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 105 bytes fail with:2
D/HEX write: 0000-000F: 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 hhhhhhhhhhhhhhhh
0010-001F: 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 hhhhhhhhhhhhhhhh
0020-002F: 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 hhhhhhhhhhhhhhhh
0030-003F: 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 hhhhhhhhhhhhhhhh
0040-004F: 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 hhhhhhhhhhhhhhhh
0050-005F: 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 hhhhhhhhhhhhhhhh
0060-006F: 68 68 68 68 68 68 68 68 68 hhhhhhhhh
0060-006F: 64 64 64 64 00 00 00 00 00 dddd.....
[117059 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[118000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[118059 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:106
[118065 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 106 << 0
[118071 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 106
[118076 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[118084 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[118090 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[118095 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (106 / 1) * 1
[118102 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:106
[118107 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 106 >> 0
[118114 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:106
[118120 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:106,rxTrigLvl:1,txTrigLvl:1
[118129 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[118134 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:106
[118141 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:106,transBytes:106
D/HEX write: 0000-000F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0010-001F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0020-002F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0030-003F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0040-004F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0050-005F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0060-006F: 69 69 69 69 69 69 69 69 69 69 iiiiiiiiii
D/HEX read: 0000-000F: 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 gggggggggggggggg
0060-006F: 67 67 67 67 67 67 67 00 00 00 ggggggg...
[119000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.10 KB 0.00MB/s,rx:0.10 KB 0.00MB/s
[119263 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:107
[119269 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 107 << 0
[119275 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 107
[119280 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[119288 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[119294 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[119299 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (107 / 1) * 1
[119306 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:107
[119311 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 107 >> 0
[119318 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:107
[119324 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:107,rxTrigLvl:1,txTrigLvl:1
[119333 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[119338 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:107
[119345 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:107,transBytes:107
[119362 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 107 bytes timeout!
D/HEX write: 0000-000F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0010-001F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0020-002F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0030-003F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0040-004F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0050-005F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0060-006F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjj
D/HEX read: 0000-000F: 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 iiiiiiiiiiiiiiii
0040-004F: 69 69 69 69 69 69 69 69 69 6A 6A 6A 6A 6A 6A 6A iiiiiiiiijjjjjjj
0060-006F: 67 67 67 67 67 67 67 00 00 00 00 ggggggg....
[120000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[120484 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:108
[120492 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 108 bytes fail with:2
D/HEX write: 0000-000F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkkkkkk
0010-001F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkkkkkk
0020-002F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkkkkkk
0030-003F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkkkkkk
0040-004F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkkkkkk
0050-005F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkkkkkk
0060-006F: 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B kkkkkkkkkkkk
0060-006F: 67 67 67 67 67 67 67 00 00 00 00 00 ggggggg.....
[121000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[121615 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:109
[121621 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 109 << 0
[121627 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 109
[121632 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[121640 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[121646 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[121651 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (109 / 1) * 1
[121658 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:109
[121663 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 109 >> 0
[121670 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:109
[121676 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:109,rxTrigLvl:1,txTrigLvl:1
[121685 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[121690 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:109
[121697 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:109,transBytes:109
D/HEX write: 0000-000F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0010-001F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0020-002F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0030-003F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0040-004F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0050-005F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0060-006F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C lllllllllllll
D/HEX read: 0000-000F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A jjjjjjjjjjjjjjjj
0060-006F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 00 00 00 jjjjjjjjjj...
[122000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.11 KB 0.00MB/s,rx:0.11 KB 0.00MB/s
[122819 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:110
[122825 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 110 << 0
[122831 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 110
[122836 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[122844 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[122850 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[122855 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (110 / 1) * 1
[122862 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:110
[122867 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 110 >> 0
[122874 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:110
[122880 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:110,rxTrigLvl:1,txTrigLvl:1
[122889 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[122894 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:110
[122901 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:110,transBytes:110
[122918 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 110 bytes timeout!
D/HEX write: 0000-000F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0010-001F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0020-002F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0030-003F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0040-004F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0050-005F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0060-006F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmm
D/HEX read: 0000-000F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C llllllllllllllll
0040-004F: 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6C 6D 6D 6D 6D llllllllllllmmmm
0060-006F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 00 00 00 00 jjjjjjjjjj....
[123041 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[124000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[124041 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:111
[124049 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 111 bytes fail with:2
D/HEX write: 0000-000F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnnn
0010-001F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnnn
0020-002F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnnn
0030-003F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnnn
0040-004F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnnn
0050-005F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnnn
0060-006F: 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E 6E nnnnnnnnnnnnnnn
0060-006F: 6A 6A 6A 6A 6A 6A 6A 6A 6A 6A 00 00 00 00 00 jjjjjjjjjj.....
[125000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[125172 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:112
[125178 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 112 << 0
[125184 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 112
[125189 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[125197 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[125203 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[125208 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (112 / 1) * 1
[125215 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:112
[125220 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 112 >> 0
[125227 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:112
[125233 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:112,rxTrigLvl:1,txTrigLvl:1
[125242 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[125247 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:112
[125254 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:112,transBytes:112
D/HEX write: 0000-000F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0010-001F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0020-002F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0030-003F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0040-004F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0050-005F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0060-006F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
D/HEX read: 0000-000F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D mmmmmmmmmmmmmmmm
0060-006F: 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 6D 00 00 00 mmmmmmmmmmmmm...
[126000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.11 KB 0.00MB/s,rx:0.11 KB 0.00MB/s
[126377 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:113
[126383 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 113 << 0
[126389 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 113
[126394 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[126402 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[126408 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[126413 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (113 / 1) * 1
[126420 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:113
[126425 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 113 >> 0
[126432 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:113
[126438 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:113,rxTrigLvl:1,txTrigLvl:1
[126447 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[126452 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:113
[126459 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:113,transBytes:113
[126476 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 113 bytes timeout!
D/HEX write: 0000-000F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0010-001F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0020-002F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0030-003F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0040-004F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0050-005F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0060-006F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0070-007F: 70 p
D/HEX read: 0000-000F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F oooooooooooooooo
0040-004F: 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 6F 70 ooooooooooooooop
0070-007F: 00 .
[127000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[127613 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:114
[127621 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 114 bytes fail with:2
D/HEX write: 0000-000F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0010-001F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0020-002F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0030-003F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0040-004F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0050-005F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0060-006F: 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 qqqqqqqqqqqqqqqq
0070-007F: 71 71 qq
0070-007F: 00 00 ..
[128000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[128758 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:115
[128764 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 115 << 0
[128770 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 115
[128775 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[128783 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[128789 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[128794 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (115 / 1) * 1
[128801 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:115
[128806 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 115 >> 0
[128813 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:115
[128819 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:115,rxTrigLvl:1,txTrigLvl:1
[128828 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[128833 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:115
[128840 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:115,transBytes:115
D/HEX write: 0000-000F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0010-001F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0020-002F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0030-003F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0040-004F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0050-005F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0060-006F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0070-007F: 72 72 72 rrr
D/HEX read: 0000-000F: 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 pppppppppppppppp
0070-007F: 00 00 00 ...
[129000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.11 KB 0.00MB/s,rx:0.11 KB 0.00MB/s
[129977 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:116
[129983 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 116 << 0
[129989 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 116
[129994 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[130002 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[130008 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[130013 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (116 / 1) * 1
[130020 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:116
[130025 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 116 >> 0
[130032 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:116
[130038 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:116,rxTrigLvl:1,txTrigLvl:1
[130047 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[130052 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:116
[130059 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:116,transBytes:116
[130066 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[130076 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 116 bytes timeout!
D/HEX write: 0000-000F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0010-001F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0020-002F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0030-003F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0040-004F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0050-005F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0060-006F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0070-007F: 73 73 73 73 ssss
D/HEX read: 0000-000F: 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 72 rrrrrrrrrrrrrrrr
0050-005F: 72 72 73 73 73 73 73 73 73 73 73 73 73 73 73 73 rrssssssssssssss
0070-007F: 00 00 00 00 ....
[131000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[131214 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:117
[131222 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 117 bytes fail with:2
D/HEX write: 0000-000F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0010-001F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0020-002F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0030-003F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0040-004F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0050-005F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0060-006F: 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 tttttttttttttttt
0070-007F: 74 74 74 74 74 ttttt
0070-007F: 00 00 00 00 00 .....
[132000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[132360 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:118
[132366 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 118 << 0
[132372 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 118
[132377 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[132385 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[132391 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[132396 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (118 / 1) * 1
[132403 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:118
[132408 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 118 >> 0
[132415 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:118
[132421 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:118,rxTrigLvl:1,txTrigLvl:1
[132430 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[132435 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:118
[132442 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:118,transBytes:118
D/HEX write: 0000-000F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0010-001F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0020-002F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0030-003F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0040-004F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0050-005F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0060-006F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0070-007F: 75 75 75 75 75 75 uuuuuu
D/HEX read: 0000-000F: 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 73 ssssssssssssssss
0070-007F: 73 73 73 00 00 00 sss...
[133000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.12 KB 0.00MB/s,rx:0.12 KB 0.00MB/s
[133580 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:119
[133586 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 119 << 0
[133592 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 119
[133597 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[133605 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[133611 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[133616 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (119 / 1) * 1
[133623 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:119
[133628 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 119 >> 0
[133635 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:119
[133641 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:119,rxTrigLvl:1,txTrigLvl:1
[133650 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[133655 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:119
[133662 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:119,transBytes:119
[133679 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 119 bytes timeout!
D/HEX write: 0000-000F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0010-001F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0020-002F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0030-003F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0040-004F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0050-005F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0060-006F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0070-007F: 76 76 76 76 76 76 76 vvvvvvv
D/HEX read: 0000-000F: 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 uuuuuuuuuuuuuuuu
0050-005F: 75 75 75 75 75 75 76 76 76 76 76 76 76 76 76 76 uuuuuuvvvvvvvvvv
0070-007F: 73 73 73 00 00 00 00 sss....
[134000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[134817 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:120
[134825 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 120 bytes fail with:2
D/HEX write: 0000-000F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0010-001F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0020-002F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0030-003F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0040-004F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0050-005F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0060-006F: 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 wwwwwwwwwwwwwwww
0070-007F: 77 77 77 77 77 77 77 77 wwwwwwww
0070-007F: 73 73 73 00 00 00 00 00 sss.....
[135000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[135963 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:121
[135969 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 121 << 0
[135975 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 121
[135980 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[135988 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[135994 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[135999 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (121 / 1) * 1
[136006 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:121
[136011 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 121 >> 0
[136018 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:121
[136024 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:121,rxTrigLvl:1,txTrigLvl:1
[136033 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[136038 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:121
[136045 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:121,transBytes:121
D/HEX write: 0000-000F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0010-001F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0020-002F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0030-003F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0040-004F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0050-005F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0060-006F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0070-007F: 78 78 78 78 78 78 78 78 78 xxxxxxxxx
D/HEX read: 0000-000F: 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 76 vvvvvvvvvvvvvvvv
0070-007F: 76 76 76 76 76 76 00 00 00 vvvvvv...
[136183 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[137000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[137183 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:122
[137189 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 122 << 0
[137195 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 122
[137200 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[137208 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[137214 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[137219 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (122 / 1) * 1
[137226 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:122
[137231 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 122 >> 0
[137238 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:122
[137244 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:122,rxTrigLvl:1,txTrigLvl:1
[137253 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[137258 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:122
[137265 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:122,transBytes:122
[137282 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 122 bytes timeout!
D/HEX write: 0000-000F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0010-001F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0020-002F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0030-003F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0040-004F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0050-005F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0060-006F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0070-007F: 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyy
D/HEX read: 0000-000F: 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 78 xxxxxxxxxxxxxxxx
0050-005F: 78 78 78 78 78 78 78 78 79 79 79 79 79 79 79 79 xxxxxxxxyyyyyyyy
0070-007F: 76 76 76 76 76 76 00 00 00 00 vvvvvv....
[138000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[138421 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:123
[138429 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 123 bytes fail with:2
D/HEX write: 0000-000F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0010-001F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0020-002F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0030-003F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0040-004F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0050-005F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0060-006F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzzzzzzz
0070-007F: 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A zzzzzzzzzzz
0070-007F: 76 76 76 76 76 76 00 00 00 00 00 vvvvvv.....
[139000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[139568 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:124
[139574 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 124 << 0
[139580 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 124
[139585 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[139593 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[139599 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[139604 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (124 / 1) * 1
[139611 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:124
[139616 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 124 >> 0
[139623 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:124
[139629 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:124,rxTrigLvl:1,txTrigLvl:1
[139638 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[139643 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:124
[139650 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:124,transBytes:124
D/HEX write: 0000-000F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0010-001F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0020-002F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0030-003F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0040-004F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0050-005F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0060-006F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0070-007F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{
D/HEX read: 0000-000F: 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy
0070-007F: 79 79 79 79 79 79 79 79 79 00 00 00 yyyyyyyyy...
[140000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.12 KB 0.00MB/s,rx:0.12 KB 0.00MB/s
[140789 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:125
[140795 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 125 << 0
[140801 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 125
[140806 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[140814 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[140820 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[140825 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (125 / 1) * 1
[140832 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:125
[140837 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 125 >> 0
[140844 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:125
[140850 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:125,rxTrigLvl:1,txTrigLvl:1
[140859 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[140864 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:125
[140871 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:125,transBytes:125
[140888 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 125 bytes timeout!
D/HEX write: 0000-000F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0010-001F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0020-002F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0030-003F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0040-004F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0050-005F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0060-006F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0070-007F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C |||||||||||||
D/HEX read: 0000-000F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B {{{{{{{{{{{{{{{{
0050-005F: 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7B 7C 7C 7C 7C 7C {{{{{{{{{{{|||||
0070-007F: 79 79 79 79 79 79 79 79 79 00 00 00 00 yyyyyyyyy....
[141027 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[142000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[142027 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:126
[142035 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 126 bytes fail with:2
D/HEX write: 0000-000F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0010-001F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0020-002F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0030-003F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0040-004F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0050-005F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0060-006F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}}}
0070-007F: 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D 7D }}}}}}}}}}}}}}
0070-007F: 79 79 79 79 79 79 79 79 79 00 00 00 00 00 yyyyyyyyy.....
[143000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[143174 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:127
[143180 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 127 << 0
[143186 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 127
[143191 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[143199 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[143205 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[143210 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (127 / 1) * 1
[143217 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:127
[143222 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 127 >> 0
[143229 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:127
[143235 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:127,rxTrigLvl:1,txTrigLvl:1
[143244 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[143249 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:127
[143256 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:127,transBytes:127
D/HEX write: 0000-000F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0010-001F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0020-002F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0030-003F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0040-004F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0050-005F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0060-006F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0070-007F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~
D/HEX read: 0000-000F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C ||||||||||||||||
0070-007F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 00 00 00 ||||||||||||...
[144000 0] D/mcu1_0.test.eeprom: mcu_spi1 tx:0.12 KB 0.00MB/s,rx:0.12 KB 0.00MB/s
[144395 0] D/mcu1_0.drv.spi.SPI_v1: line:499,transaction->count:128
[144401 0] D/mcu1_0.drv.spi.SPI_v1: line:593,transBytes = 128 << 0
[144407 0] D/mcu1_0.drv.spi.SPI_v1: line:594,transBytes = 128
[144412 0] I/mcu1_0.drv.spi.SPI_v1: Transaction count is more than FIFO size
[144420 0] D/mcu1_0.drv.spi.SPI_v1: line:613,object->rxTrigLvl:1
[144426 0] D/mcu1_0.drv.spi.SPI_v1: line:614,object->txTrigLvl:1
[144431 0] D/mcu1_0.drv.spi.SPI_v1: line:628,transBytes = (128 / 1) * 1
[144438 0] D/mcu1_0.drv.spi.SPI_v1: line:630,transBytes:128
[144443 0] D/mcu1_0.drv.spi.SPI_v1: line:633,transaction->count = 128 >> 0
[144450 0] D/mcu1_0.drv.spi.SPI_v1: line:634,transaction->count:128
[144456 0] D/mcu1_0.drv.spi.SPI_v1: line:651,object fifoSize:32,transBytes:128,rxTrigLvl:1,txTrigLvl:1
[144465 0] D/mcu1_0.drv.spi.SPI_v1: line:666,wordCount:1
[144470 0] D/mcu1_0.drv.spi.SPI_v1: line:687,transaction->count:128
[144477 0] D/mcu1_0.drv.spi.SPI_dma: line:429,transaction->count:128,transBytes:128
[144494 0] E/mcu1_0.bsp.bus.spi: mcu_spi1 transmit receive 128 bytes timeout!
D/HEX write: 0000-000F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0010-001F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0020-002F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0030-003F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0040-004F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0050-005F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0060-006F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
0070-007F: 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ................
D/HEX read: 0000-000F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E ~~~~~~~~~~~~~~~~
0050-005F: 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7E 7F 7F ~~~~~~~~~~~~~~..
0070-007F: 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 7C 00 00 00 00 ||||||||||||....
[145000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
[145634 0] E/mcu1_0.drv.spi.SPI_v1: 1543 transfer in progress,transaction count:1
[145642 0] E/mcu1_0.bsp.bus.spi: eeprom transmit receive 1 bytes fail with:2
D/HEX write: 0000-000F: 00 .
D/HEX read: 0000-000F: 7E ~
[146000 0] E/mcu1_0.test.eeprom: mcu_spi1 tx:0.00 KB 0.00MB/s,rx:0.00 KB 0.00MB/s
In customers' actual use cases, they could not ensure that every time the input data is a fix value. Hence, in this situation if the input data size is larger than customers' trigLvl setting, there will be data loss happen. It seems by making trigLvl = 1 could solve it, but when the input data is larger than 128, there will be some problem mentioned above.
Customers hope that if there is a method that could help them solve this problem.
Thanks a lot!
Kevin
