TDA4VM: How to clear the allocated memory in TIDL or C7x without restarting the board
Part Number: TDA4VM
Hi TI Experts,
Customer is working on TDA4VM SDK8.6.
When they are running C7x applications, if they exit the first run and rerun the application, it will have the below error.
Processing config file #0 : infer_config.txt
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
  2429.291504 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
  2429.292035 s:  VX_ZONE_INIT:Enabled
  2429.292102 s:  VX_ZONE_ERROR:Enabled
  2429.292154 s:  VX_ZONE_WARNING:Enabled
  2429.293350 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
  2429.293728 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
  2429.339047 s:  VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1
  2429.339074 s:  VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed.
  2429.339086 s:  VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
  2429.339094 s:  VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core
  2429.339100 s:  VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
  2429.339109 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!!
  2429.339127 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
  2429.339136 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
Error at line:   506 : in file /home/yuming/Projects/TDA4VM/ti-processor-sdk-rtos-j721e-evm-08_06_00_12/tidl_j721e_08_06_00_10/arm-tidl/rt/test/armv8/../src/tidl_tb.c, of function : tidlMultiInstanceTest
Invalid Error Type!
We have followed the below FAQ to find out the root cause for the problem, and the log is provided below.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1227571/faq-sk-tda4vm-error-while-running-custom-compiled-model?tisearch=e2e-sitesearch&keymatch=faq%3Atrue
[C7x_1 ] 676768.300111 s: PREEMPTION: Requesting memory of size 128 for targetPriority = 512
[C7x_1 ] 676768.300256 s: min(FM):        0, max(FM): 18300686, min(WT): 18300800, max(WT): 32063360
[C7x_1 ] 676768.300277 s:
[C7x_1 ] 676768.300295 s: --------------------------------------------
[C7x_1 ] 676768.300319 s: TIDL Memory size requiement (record wise):
[C7x_1 ] 676768.300349 s: MemRecNum   , Space       , Attribute   , Size(KBytes)
[C7x_1 ] 676768.300946 s:
[C7x_1 ] 689761.121186 s:  VX_ZONE_ERROR:[tivxAlgiVisionAllocMem:194] Failed to Allocate memory record 5 @ space = 17 and size = 5743728 !!!
[C7x_1 ] 689761.121214 s:  VX_ZONE_ERROR:[tivxAlgiVisionCreate:358] tivxAlgiVisionAllocMem Failed
[C7x_1 ] 689761.121238 s:  VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL
Based on the above log, it shows that the problem is about the memory allocation.
We found out that if we restart the board and give it a fresh run, then there will be no problem.
The problem only happens when we exit the current run, and rerun the application.
Hence this may due to the previous allocated memory is not clean, and the next rerun does not have the sufficient memory.
Although restarting the board could solve this problem, but it is not very convenient.
May I know if there are any other suggested methods that could clean the memory without restarting the board?
Thanks a lot!
Kevin
  • Hi TI Experts,
    After solving the memory allocation problem through restarting the EVM, there is another problem shown below.
    [C7x_1 ] 699988.493474 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s]
    [C7x_1 ] 699988.493936 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ] 699988.512075 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ] 699988.554638 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ] 700090.741527 s:  VX_ZONE_ERROR:[tivxAlgiVisionCreate:335] Calling ialg.algInit failed with status = 1
    [C7x_1 ] 700090.741574 s:  VX_ZONE_ERROR:[tivxKernelTIDLCreate:720] tivxAlgiVisionCreate returned NULL
    I think normally this problem should relate to the model, but seeing from customers' model compilation log, there seems no error shown below.
    ONNX Model (Proto) File  : /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1109/seg.onnx
    TIDL Network File      : /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_net.bin
    TIDL IO Info File      : /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_io_
    Current ONNX OpSet Version   : 11
    Running tidl_optimizeNet
    printing Current net
        0|TIDL_DataLayer                |                                                  |input.1_original                                  |    0|    0|
        1|TIDL_BatchNormLayer           |input.1_original                                  |input.1                                           |    0|    1|
        2|TIDL_ConvolutionLayer         |input.1                                           |/backend/conv1/conv1.0/Conv_output_0              |    1|    2|
        3|TIDL_ReLULayer                |/backend/conv1/conv1.0/Conv_output_0              |/backend/conv1/conv1.2/Relu_output_0              |    2|    3|
        4|TIDL_ConvolutionLayer         |/backend/conv1/conv1.2/Relu_output_0              |/backend/conv1/conv1.3/Conv_output_0              |    3|    4|
        5|TIDL_ReLULayer                |/backend/conv1/conv1.3/Conv_output_0              |/backend/conv1/conv1.5/Relu_output_0              |    4|    5|
        6|TIDL_ConvolutionLayer         |/backend/conv1/conv1.5/Relu_output_0              |/backend/layer1/layer1.0/conv0/conv0.0/Conv_output_0|    5|    6|
        7|TIDL_ReLULayer                |/backend/layer1/layer1.0/conv0/conv0.0/Conv_output_0|/backend/layer1/layer1.0/conv0/conv0.2/Relu_output_0|    6|    7|
        8|TIDL_SliceLayer               |/backend/layer1/layer1.0/conv0/conv0.2/Relu_output_0|/backend/layer1/layer1.0/Split_output_0           |    7|    8|
        9|TIDL_ConvolutionLayer         |/backend/layer1/layer1.0/Split_output_0           |/backend/layer1/layer1.0/conv1/conv1.0/Conv_output_0|    8|   12|
       10|TIDL_ReLULayer                |/backend/layer1/layer1.0/conv1/conv1.0/Conv_output_0|/backend/layer1/layer1.0/conv1/conv1.2/Relu_output_0|   12|   13|
       11|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/conv1/conv1.2/Relu_output_0|/backend/layer1/layer1.0/Add_output_0             |   13|   14|
       12|TIDL_ConvolutionLayer         |/backend/layer1/layer1.0/Add_output_0             |/backend/layer1/layer1.0/conv2/conv2.0/Conv_output_0|   14|   15|
       13|TIDL_ReLULayer                |/backend/layer1/layer1.0/conv2/conv2.0/Conv_output_0|/backend/layer1/layer1.0/conv2/conv2.2/Relu_output_0|   15|   16|
       14|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/conv2/conv2.2/Relu_output_0|/backend/layer1/layer1.0/Add_1_output_0           |   16|   17|
       15|TIDL_PoolingLayer             |/backend/layer1/layer1.0/Add_1_output_0           |/backend/layer1/layer1.0/conv3/conv3.0/MaxPool_output_0|   17|   18|
       16|TIDL_ConvolutionLayer         |/backend/layer1/layer1.0/conv3/conv3.0/MaxPool_output_0|/backend/layer1/layer1.0/conv3/conv3.1/Conv_output_0|   18|   19|
       17|TIDL_ReLULayer                |/backend/layer1/layer1.0/conv3/conv3.1/Conv_output_0|/backend/layer1/layer1.0/conv3/conv3.3/Relu_output_0|   19|   20|
       18|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/conv3/conv3.3/Relu_output_0|/backend/layer1/layer1.0/Add_2_output_0           |   20|   21|
       19|TIDL_PoolingLayer             |/backend/layer1/layer1.0/Add_2_output_0           |/backend/layer1/layer1.0/conv4/conv4.0/AveragePool_output_0|   21|   22|
       20|TIDL_ConvolutionLayer         |/backend/layer1/layer1.0/conv4/conv4.0/AveragePool_output_0|/backend/layer1/layer1.0/conv4/conv4.1/Conv_output_0|   22|   23|
       21|TIDL_ReLULayer                |/backend/layer1/layer1.0/conv4/conv4.1/Conv_output_0|/backend/layer1/layer1.0/conv4/conv4.3/Relu_output_0|   23|   24|
       22|TIDL_ConcatLayer              |/backend/layer1/layer1.0/conv1/conv1.2/Relu_output_0|/backend/layer1/layer1.0/Concat_output_0          |   13|   25|
       23|TIDL_ConvolutionLayer         |/backend/layer1/layer1.0/Concat_output_0          |/backend/layer1/layer1.0/conv_out/conv_out.0/Conv_output_0|   25|   26|
       24|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/conv_out/conv_out.0/Conv_output_0|/backend/layer1/layer1.0/Add_3_output_0           |   26|   27|
       25|TIDL_ReLULayer                |/backend/layer1/layer1.0/Add_3_output_0           |/backend/layer1/layer1.0/relu/Relu_output_0       |   27|   28|
       26|TIDL_ConvolutionLayer         |/backend/layer1/layer1.0/relu/Relu_output_0       |/backend/layer1/layer1.1/conv0/conv0.0/Conv_output_0|   28|   29|
       27|TIDL_ReLULayer                |/backend/layer1/layer1.1/conv0/conv0.0/Conv_output_0|/backend/layer1/layer1.1/conv0/conv0.2/Relu_output_0|   29|   30|
       28|TIDL_SliceLayer               |/backend/layer1/layer1.1/conv0/conv0.2/Relu_output_0|/backend/layer1/layer1.1/Split_output_0           |   30|   31|
       29|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/Split_output_0           |/backend/layer1/layer1.1/conv1/conv1.0/Conv_output_0|   31|   35|
       30|TIDL_ReLULayer                |/backend/layer1/layer1.1/conv1/conv1.0/Conv_output_0|/backend/layer1/layer1.1/conv1/conv1.2/Relu_output_0|   35|   36|
       31|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/conv1/conv1.2/Relu_output_0|/backend/layer1/layer1.1/Add_output_0             |   36|   37|
       32|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/Add_output_0             |/backend/layer1/layer1.1/conv2/conv2.0/Conv_output_0|   37|   38|
       33|TIDL_ReLULayer                |/backend/layer1/layer1.1/conv2/conv2.0/Conv_output_0|/backend/layer1/layer1.1/conv2/conv2.2/Relu_output_0|   38|   39|
       34|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/conv2/conv2.2/Relu_output_0|/backend/layer1/layer1.1/Add_1_output_0           |   39|   40|
       35|TIDL_PoolingLayer             |/backend/layer1/layer1.1/Add_1_output_0           |/backend/layer1/layer1.1/conv3/conv3.0/MaxPool_output_0|   40|   41|
       36|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/conv3/conv3.0/MaxPool_output_0|/backend/layer1/layer1.1/conv3/conv3.1/Conv_output_0|   41|   42|
       37|TIDL_ReLULayer                |/backend/layer1/layer1.1/conv3/conv3.1/Conv_output_0|/backend/layer1/layer1.1/conv3/conv3.3/Relu_output_0|   42|   43|
       38|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/conv3/conv3.3/Relu_output_0|/backend/layer1/layer1.1/Add_2_output_0           |   43|   44|
       39|TIDL_PoolingLayer             |/backend/layer1/layer1.1/Add_2_output_0           |/backend/layer1/layer1.1/conv4/conv4.0/AveragePool_output_0|   44|   45|
       40|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/conv4/conv4.0/AveragePool_output_0|/backend/layer1/layer1.1/conv4/conv4.1/Conv_output_0|   45|   46|
       41|TIDL_ReLULayer                |/backend/layer1/layer1.1/conv4/conv4.1/Conv_output_0|/backend/layer1/layer1.1/conv4/conv4.3/Relu_output_0|   46|   47|
       42|TIDL_ConcatLayer              |/backend/layer1/layer1.1/conv1/conv1.2/Relu_output_0|/backend/layer1/layer1.1/Concat_output_0          |   36|   48|
       43|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/Concat_output_0          |/backend/layer1/layer1.1/conv_out/conv_out.0/Conv_output_0|   48|   49|
       44|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/conv_out/conv_out.0/Conv_output_0|/backend/layer1/layer1.1/Add_3_output_0           |   49|   50|
       45|TIDL_ReLULayer                |/backend/layer1/layer1.1/Add_3_output_0           |/backend/layer1/layer1.1/relu/Relu_output_0       |   50|   51|
       46|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/relu/Relu_output_0       |/backend/layer2/layer2.0/downsample/downsample.0/Conv_output_0|   51|   52|
       47|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/relu/Relu_output_0       |/backend/layer2/layer2.0/conv0/conv0.0/Conv_output_0|   51|   53|
       48|TIDL_ConvolutionLayer         |/backend/layer1/layer1.1/relu/Relu_output_0       |/c1/Conv_output_0                                 |   51|   54|
       49|TIDL_ReLULayer                |/backend/layer2/layer2.0/conv0/conv0.0/Conv_output_0|/backend/layer2/layer2.0/conv0/conv0.2/Relu_output_0|   53|   55|
       50|TIDL_SliceLayer               |/backend/layer2/layer2.0/conv0/conv0.2/Relu_output_0|/backend/layer2/layer2.0/Split_output_0           |   55|   56|
       51|TIDL_ConvolutionLayer         |/backend/layer2/layer2.0/Split_output_0           |/backend/layer2/layer2.0/conv1/conv1.0/Conv_output_0|   56|   60|
       52|TIDL_ReLULayer                |/backend/layer2/layer2.0/conv1/conv1.0/Conv_output_0|/backend/layer2/layer2.0/conv1/conv1.2/Relu_output_0|   60|   61|
       53|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/conv1/conv1.2/Relu_output_0|/backend/layer2/layer2.0/Add_output_0             |   61|   62|
       54|TIDL_ConvolutionLayer         |/backend/layer2/layer2.0/Add_output_0             |/backend/layer2/layer2.0/conv2/conv2.0/Conv_output_0|   62|   63|
       55|TIDL_ReLULayer                |/backend/layer2/layer2.0/conv2/conv2.0/Conv_output_0|/backend/layer2/layer2.0/conv2/conv2.2/Relu_output_0|   63|   64|
       56|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/conv2/conv2.2/Relu_output_0|/backend/layer2/layer2.0/Add_1_output_0           |   64|   65|
       57|TIDL_PoolingLayer             |/backend/layer2/layer2.0/Add_1_output_0           |/backend/layer2/layer2.0/conv3/conv3.0/MaxPool_output_0|   65|   66|
       58|TIDL_ConvolutionLayer         |/backend/layer2/layer2.0/conv3/conv3.0/MaxPool_output_0|/backend/layer2/layer2.0/conv3/conv3.1/Conv_output_0|   66|   67|
       59|TIDL_ReLULayer                |/backend/layer2/layer2.0/conv3/conv3.1/Conv_output_0|/backend/layer2/layer2.0/conv3/conv3.3/Relu_output_0|   67|   68|
       60|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/conv3/conv3.3/Relu_output_0|/backend/layer2/layer2.0/Add_2_output_0           |   68|   69|
       61|TIDL_PoolingLayer             |/backend/layer2/layer2.0/Add_2_output_0           |/backend/layer2/layer2.0/conv4/conv4.0/AveragePool_output_0|   69|   70|
       62|TIDL_ConvolutionLayer         |/backend/layer2/layer2.0/conv4/conv4.0/AveragePool_output_0|/backend/layer2/layer2.0/conv4/conv4.1/Conv_output_0|   70|   71|
       63|TIDL_ReLULayer                |/backend/layer2/layer2.0/conv4/conv4.1/Conv_output_0|/backend/layer2/layer2.0/conv4/conv4.3/Relu_output_0|   71|   72|
       64|TIDL_ConcatLayer              |/backend/layer2/layer2.0/conv1/conv1.2/Relu_output_0|/backend/layer2/layer2.0/Concat_output_0          |   61|   73|
       65|TIDL_ConvolutionLayer         |/backend/layer2/layer2.0/Concat_output_0          |/backend/layer2/layer2.0/conv_out/conv_out.0/Conv_output_0|   73|   74|
       66|TIDL_PoolingLayer             |/backend/layer2/layer2.0/conv_out/conv_out.0/Conv_output_0|/backend/layer2/layer2.0/conv_downsample/MaxPool_output_0|   74|   75|
       67|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/conv_downsample/MaxPool_output_0|/backend/layer2/layer2.0/Add_3_output_0           |   75|   76|
       68|TIDL_ReLULayer                |/backend/layer2/layer2.0/Add_3_output_0           |/backend/layer2/layer2.0/relu/Relu_output_0       |   76|   77|
       69|TIDL_ConvolutionLayer         |/backend/layer2/layer2.0/relu/Relu_output_0       |/backend/layer2/layer2.1/conv0/conv0.0/Conv_output_0|   77|   78|
       70|TIDL_ReLULayer                |/backend/layer2/layer2.1/conv0/conv0.0/Conv_output_0|/backend/layer2/layer2.1/conv0/conv0.2/Relu_output_0|   78|   79|
       71|TIDL_SliceLayer               |/backend/layer2/layer2.1/conv0/conv0.2/Relu_output_0|/backend/layer2/layer2.1/Split_output_0           |   79|   80|
       72|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/Split_output_0           |/backend/layer2/layer2.1/conv1/conv1.0/Conv_output_0|   80|   84|
       73|TIDL_ReLULayer                |/backend/layer2/layer2.1/conv1/conv1.0/Conv_output_0|/backend/layer2/layer2.1/conv1/conv1.2/Relu_output_0|   84|   85|
       74|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/conv1/conv1.2/Relu_output_0|/backend/layer2/layer2.1/Add_output_0             |   85|   86|
       75|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/Add_output_0             |/backend/layer2/layer2.1/conv2/conv2.0/Conv_output_0|   86|   87|
       76|TIDL_ReLULayer                |/backend/layer2/layer2.1/conv2/conv2.0/Conv_output_0|/backend/layer2/layer2.1/conv2/conv2.2/Relu_output_0|   87|   88|
       77|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/conv2/conv2.2/Relu_output_0|/backend/layer2/layer2.1/Add_1_output_0           |   88|   89|
       78|TIDL_PoolingLayer             |/backend/layer2/layer2.1/Add_1_output_0           |/backend/layer2/layer2.1/conv3/conv3.0/MaxPool_output_0|   89|   90|
       79|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/conv3/conv3.0/MaxPool_output_0|/backend/layer2/layer2.1/conv3/conv3.1/Conv_output_0|   90|   91|
       80|TIDL_ReLULayer                |/backend/layer2/layer2.1/conv3/conv3.1/Conv_output_0|/backend/layer2/layer2.1/conv3/conv3.3/Relu_output_0|   91|   92|
       81|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/conv3/conv3.3/Relu_output_0|/backend/layer2/layer2.1/Add_2_output_0           |   92|   93|
       82|TIDL_PoolingLayer             |/backend/layer2/layer2.1/Add_2_output_0           |/backend/layer2/layer2.1/conv4/conv4.0/AveragePool_output_0|   93|   94|
       83|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/conv4/conv4.0/AveragePool_output_0|/backend/layer2/layer2.1/conv4/conv4.1/Conv_output_0|   94|   95|
       84|TIDL_ReLULayer                |/backend/layer2/layer2.1/conv4/conv4.1/Conv_output_0|/backend/layer2/layer2.1/conv4/conv4.3/Relu_output_0|   95|   96|
       85|TIDL_ConcatLayer              |/backend/layer2/layer2.1/conv1/conv1.2/Relu_output_0|/backend/layer2/layer2.1/Concat_output_0          |   85|   97|
       86|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/Concat_output_0          |/backend/layer2/layer2.1/conv_out/conv_out.0/Conv_output_0|   97|   98|
       87|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/conv_out/conv_out.0/Conv_output_0|/backend/layer2/layer2.1/Add_3_output_0           |   98|   99|
       88|TIDL_ReLULayer                |/backend/layer2/layer2.1/Add_3_output_0           |/backend/layer2/layer2.1/relu/Relu_output_0       |   99|  100|
       89|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/relu/Relu_output_0       |/backend/layer3/layer3.0/downsample/downsample.0/Conv_output_0|  100|  101|
       90|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/relu/Relu_output_0       |/backend/layer3/layer3.0/conv0/conv0.0/Conv_output_0|  100|  102|
       91|TIDL_ConvolutionLayer         |/backend/layer2/layer2.1/relu/Relu_output_0       |/c2/Conv_output_0                                 |  100|  103|
       92|TIDL_ReLULayer                |/backend/layer3/layer3.0/conv0/conv0.0/Conv_output_0|/backend/layer3/layer3.0/conv0/conv0.2/Relu_output_0|  102|  104|
       93|TIDL_SliceLayer               |/backend/layer3/layer3.0/conv0/conv0.2/Relu_output_0|/backend/layer3/layer3.0/Split_output_0           |  104|  105|
       94|TIDL_ConvolutionLayer         |/backend/layer3/layer3.0/Split_output_0           |/backend/layer3/layer3.0/conv1/conv1.0/Conv_output_0|  105|  109|
       95|TIDL_ReLULayer                |/backend/layer3/layer3.0/conv1/conv1.0/Conv_output_0|/backend/layer3/layer3.0/conv1/conv1.2/Relu_output_0|  109|  110|
       96|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/conv1/conv1.2/Relu_output_0|/backend/layer3/layer3.0/Add_output_0             |  110|  111|
       97|TIDL_ConvolutionLayer         |/backend/layer3/layer3.0/Add_output_0             |/backend/layer3/layer3.0/conv2/conv2.0/Conv_output_0|  111|  112|
       98|TIDL_ReLULayer                |/backend/layer3/layer3.0/conv2/conv2.0/Conv_output_0|/backend/layer3/layer3.0/conv2/conv2.2/Relu_output_0|  112|  113|
       99|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/conv2/conv2.2/Relu_output_0|/backend/layer3/layer3.0/Add_1_output_0           |  113|  114|
      100|TIDL_PoolingLayer             |/backend/layer3/layer3.0/Add_1_output_0           |/backend/layer3/layer3.0/conv3/conv3.0/MaxPool_output_0|  114|  115|
      101|TIDL_ConvolutionLayer         |/backend/layer3/layer3.0/conv3/conv3.0/MaxPool_output_0|/backend/layer3/layer3.0/conv3/conv3.1/Conv_output_0|  115|  116|
      102|TIDL_ReLULayer                |/backend/layer3/layer3.0/conv3/conv3.1/Conv_output_0|/backend/layer3/layer3.0/conv3/conv3.3/Relu_output_0|  116|  117|
      103|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/conv3/conv3.3/Relu_output_0|/backend/layer3/layer3.0/Add_2_output_0           |  117|  118|
      104|TIDL_PoolingLayer             |/backend/layer3/layer3.0/Add_2_output_0           |/backend/layer3/layer3.0/conv4/conv4.0/AveragePool_output_0|  118|  119|
      105|TIDL_ConvolutionLayer         |/backend/layer3/layer3.0/conv4/conv4.0/AveragePool_output_0|/backend/layer3/layer3.0/conv4/conv4.1/Conv_output_0|  119|  120|
      106|TIDL_ReLULayer                |/backend/layer3/layer3.0/conv4/conv4.1/Conv_output_0|/backend/layer3/layer3.0/conv4/conv4.3/Relu_output_0|  120|  121|
      107|TIDL_ConcatLayer              |/backend/layer3/layer3.0/conv1/conv1.2/Relu_output_0|/backend/layer3/layer3.0/Concat_output_0          |  110|  122|
      108|TIDL_ConvolutionLayer         |/backend/layer3/layer3.0/Concat_output_0          |/backend/layer3/layer3.0/conv_out/conv_out.0/Conv_output_0|  122|  123|
      109|TIDL_PoolingLayer             |/backend/layer3/layer3.0/conv_out/conv_out.0/Conv_output_0|/backend/layer3/layer3.0/conv_downsample/MaxPool_output_0|  123|  124|
      110|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/conv_downsample/MaxPool_output_0|/backend/layer3/layer3.0/Add_3_output_0           |  124|  125|
      111|TIDL_ReLULayer                |/backend/layer3/layer3.0/Add_3_output_0           |/backend/layer3/layer3.0/relu/Relu_output_0       |  125|  126|
      112|TIDL_ConvolutionLayer         |/backend/layer3/layer3.0/relu/Relu_output_0       |/backend/layer3/layer3.1/conv0/conv0.0/Conv_output_0|  126|  127|
      113|TIDL_ReLULayer                |/backend/layer3/layer3.1/conv0/conv0.0/Conv_output_0|/backend/layer3/layer3.1/conv0/conv0.2/Relu_output_0|  127|  128|
      114|TIDL_SliceLayer               |/backend/layer3/layer3.1/conv0/conv0.2/Relu_output_0|/backend/layer3/layer3.1/Split_output_0           |  128|  129|
      115|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/Split_output_0           |/backend/layer3/layer3.1/conv1/conv1.0/Conv_output_0|  129|  133|
      116|TIDL_ReLULayer                |/backend/layer3/layer3.1/conv1/conv1.0/Conv_output_0|/backend/layer3/layer3.1/conv1/conv1.2/Relu_output_0|  133|  134|
      117|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/conv1/conv1.2/Relu_output_0|/backend/layer3/layer3.1/Add_output_0             |  134|  135|
      118|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/Add_output_0             |/backend/layer3/layer3.1/conv2/conv2.0/Conv_output_0|  135|  136|
      119|TIDL_ReLULayer                |/backend/layer3/layer3.1/conv2/conv2.0/Conv_output_0|/backend/layer3/layer3.1/conv2/conv2.2/Relu_output_0|  136|  137|
      120|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/conv2/conv2.2/Relu_output_0|/backend/layer3/layer3.1/Add_1_output_0           |  137|  138|
      121|TIDL_PoolingLayer             |/backend/layer3/layer3.1/Add_1_output_0           |/backend/layer3/layer3.1/conv3/conv3.0/MaxPool_output_0|  138|  139|
      122|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/conv3/conv3.0/MaxPool_output_0|/backend/layer3/layer3.1/conv3/conv3.1/Conv_output_0|  139|  140|
      123|TIDL_ReLULayer                |/backend/layer3/layer3.1/conv3/conv3.1/Conv_output_0|/backend/layer3/layer3.1/conv3/conv3.3/Relu_output_0|  140|  141|
      124|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/conv3/conv3.3/Relu_output_0|/backend/layer3/layer3.1/Add_2_output_0           |  141|  142|
      125|TIDL_PoolingLayer             |/backend/layer3/layer3.1/Add_2_output_0           |/backend/layer3/layer3.1/conv4/conv4.0/AveragePool_output_0|  142|  143|
      126|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/conv4/conv4.0/AveragePool_output_0|/backend/layer3/layer3.1/conv4/conv4.1/Conv_output_0|  143|  144|
      127|TIDL_ReLULayer                |/backend/layer3/layer3.1/conv4/conv4.1/Conv_output_0|/backend/layer3/layer3.1/conv4/conv4.3/Relu_output_0|  144|  145|
      128|TIDL_ConcatLayer              |/backend/layer3/layer3.1/conv1/conv1.2/Relu_output_0|/backend/layer3/layer3.1/Concat_output_0          |  134|  146|
      129|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/Concat_output_0          |/backend/layer3/layer3.1/conv_out/conv_out.0/Conv_output_0|  146|  147|
      130|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/conv_out/conv_out.0/Conv_output_0|/backend/layer3/layer3.1/Add_3_output_0           |  147|  148|
      131|TIDL_ReLULayer                |/backend/layer3/layer3.1/Add_3_output_0           |/backend/layer3/layer3.1/relu/Relu_output_0       |  148|  149|
      132|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/relu/Relu_output_0       |/backend/layer4/layer4.0/downsample/downsample.0/Conv_output_0|  149|  150|
      133|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/relu/Relu_output_0       |/backend/layer4/layer4.0/conv0/conv0.0/Conv_output_0|  149|  151|
      134|TIDL_ConvolutionLayer         |/backend/layer3/layer3.1/relu/Relu_output_0       |/c3/Conv_output_0                                 |  149|  152|
      135|TIDL_ReLULayer                |/backend/layer4/layer4.0/conv0/conv0.0/Conv_output_0|/backend/layer4/layer4.0/conv0/conv0.2/Relu_output_0|  151|  153|
      136|TIDL_SliceLayer               |/backend/layer4/layer4.0/conv0/conv0.2/Relu_output_0|/backend/layer4/layer4.0/Split_output_0           |  153|  154|
      137|TIDL_ConvolutionLayer         |/backend/layer4/layer4.0/Split_output_0           |/backend/layer4/layer4.0/conv1/conv1.0/Conv_output_0|  154|  158|
      138|TIDL_ReLULayer                |/backend/layer4/layer4.0/conv1/conv1.0/Conv_output_0|/backend/layer4/layer4.0/conv1/conv1.2/Relu_output_0|  158|  159|
      139|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/conv1/conv1.2/Relu_output_0|/backend/layer4/layer4.0/Add_output_0             |  159|  160|
      140|TIDL_ConvolutionLayer         |/backend/layer4/layer4.0/Add_output_0             |/backend/layer4/layer4.0/conv2/conv2.0/Conv_output_0|  160|  161|
      141|TIDL_ReLULayer                |/backend/layer4/layer4.0/conv2/conv2.0/Conv_output_0|/backend/layer4/layer4.0/conv2/conv2.2/Relu_output_0|  161|  162|
      142|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/conv2/conv2.2/Relu_output_0|/backend/layer4/layer4.0/Add_1_output_0           |  162|  163|
      143|TIDL_PoolingLayer             |/backend/layer4/layer4.0/Add_1_output_0           |/backend/layer4/layer4.0/conv3/conv3.0/MaxPool_output_0|  163|  164|
      144|TIDL_ConvolutionLayer         |/backend/layer4/layer4.0/conv3/conv3.0/MaxPool_output_0|/backend/layer4/layer4.0/conv3/conv3.1/Conv_output_0|  164|  165|
      145|TIDL_ReLULayer                |/backend/layer4/layer4.0/conv3/conv3.1/Conv_output_0|/backend/layer4/layer4.0/conv3/conv3.3/Relu_output_0|  165|  166|
      146|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/conv3/conv3.3/Relu_output_0|/backend/layer4/layer4.0/Add_2_output_0           |  166|  167|
      147|TIDL_PoolingLayer             |/backend/layer4/layer4.0/Add_2_output_0           |/backend/layer4/layer4.0/conv4/conv4.0/AveragePool_output_0|  167|  168|
      148|TIDL_ConvolutionLayer         |/backend/layer4/layer4.0/conv4/conv4.0/AveragePool_output_0|/backend/layer4/layer4.0/conv4/conv4.1/Conv_output_0|  168|  169|
      149|TIDL_ReLULayer                |/backend/layer4/layer4.0/conv4/conv4.1/Conv_output_0|/backend/layer4/layer4.0/conv4/conv4.3/Relu_output_0|  169|  170|
      150|TIDL_ConcatLayer              |/backend/layer4/layer4.0/conv1/conv1.2/Relu_output_0|/backend/layer4/layer4.0/Concat_output_0          |  159|  171|
      151|TIDL_ConvolutionLayer         |/backend/layer4/layer4.0/Concat_output_0          |/backend/layer4/layer4.0/conv_out/conv_out.0/Conv_output_0|  171|  172|
      152|TIDL_PoolingLayer             |/backend/layer4/layer4.0/conv_out/conv_out.0/Conv_output_0|/backend/layer4/layer4.0/conv_downsample/MaxPool_output_0|  172|  173|
      153|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/conv_downsample/MaxPool_output_0|/backend/layer4/layer4.0/Add_3_output_0           |  173|  174|
      154|TIDL_ReLULayer                |/backend/layer4/layer4.0/Add_3_output_0           |/backend/layer4/layer4.0/relu/Relu_output_0       |  174|  175|
      155|TIDL_ConvolutionLayer         |/backend/layer4/layer4.0/relu/Relu_output_0       |/backend/layer4/layer4.1/conv0/conv0.0/Conv_output_0|  175|  176|
      156|TIDL_ReLULayer                |/backend/layer4/layer4.1/conv0/conv0.0/Conv_output_0|/backend/layer4/layer4.1/conv0/conv0.2/Relu_output_0|  176|  177|
      157|TIDL_SliceLayer               |/backend/layer4/layer4.1/conv0/conv0.2/Relu_output_0|/backend/layer4/layer4.1/Split_output_0           |  177|  178|
      158|TIDL_ConvolutionLayer         |/backend/layer4/layer4.1/Split_output_0           |/backend/layer4/layer4.1/conv1/conv1.0/Conv_output_0|  178|  182|
      159|TIDL_ReLULayer                |/backend/layer4/layer4.1/conv1/conv1.0/Conv_output_0|/backend/layer4/layer4.1/conv1/conv1.2/Relu_output_0|  182|  183|
      160|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/conv1/conv1.2/Relu_output_0|/backend/layer4/layer4.1/Add_output_0             |  183|  184|
      161|TIDL_ConvolutionLayer         |/backend/layer4/layer4.1/Add_output_0             |/backend/layer4/layer4.1/conv2/conv2.0/Conv_output_0|  184|  185|
      162|TIDL_ReLULayer                |/backend/layer4/layer4.1/conv2/conv2.0/Conv_output_0|/backend/layer4/layer4.1/conv2/conv2.2/Relu_output_0|  185|  186|
      163|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/conv2/conv2.2/Relu_output_0|/backend/layer4/layer4.1/Add_1_output_0           |  186|  187|
      164|TIDL_PoolingLayer             |/backend/layer4/layer4.1/Add_1_output_0           |/backend/layer4/layer4.1/conv3/conv3.0/MaxPool_output_0|  187|  188|
      165|TIDL_ConvolutionLayer         |/backend/layer4/layer4.1/conv3/conv3.0/MaxPool_output_0|/backend/layer4/layer4.1/conv3/conv3.1/Conv_output_0|  188|  189|
      166|TIDL_ReLULayer                |/backend/layer4/layer4.1/conv3/conv3.1/Conv_output_0|/backend/layer4/layer4.1/conv3/conv3.3/Relu_output_0|  189|  190|
      167|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/conv3/conv3.3/Relu_output_0|/backend/layer4/layer4.1/Add_2_output_0           |  190|  191|
      168|TIDL_PoolingLayer             |/backend/layer4/layer4.1/Add_2_output_0           |/backend/layer4/layer4.1/conv4/conv4.0/AveragePool_output_0|  191|  192|
      169|TIDL_ConvolutionLayer         |/backend/layer4/layer4.1/conv4/conv4.0/AveragePool_output_0|/backend/layer4/layer4.1/conv4/conv4.1/Conv_output_0|  192|  193|
      170|TIDL_ReLULayer                |/backend/layer4/layer4.1/conv4/conv4.1/Conv_output_0|/backend/layer4/layer4.1/conv4/conv4.3/Relu_output_0|  193|  194|
      171|TIDL_ConcatLayer              |/backend/layer4/layer4.1/conv1/conv1.2/Relu_output_0|/backend/layer4/layer4.1/Concat_output_0          |  183|  195|
      172|TIDL_ConvolutionLayer         |/backend/layer4/layer4.1/Concat_output_0          |/backend/layer4/layer4.1/conv_out/conv_out.0/Conv_output_0|  195|  196|
      173|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/conv_out/conv_out.0/Conv_output_0|/backend/layer4/layer4.1/Add_3_output_0           |  196|  197|
      174|TIDL_ReLULayer                |/backend/layer4/layer4.1/Add_3_output_0           |/backend/layer4/layer4.1/relu/Relu_output_0       |  197|  198|
      175|TIDL_ConvolutionLayer         |/backend/layer4/layer4.1/relu/Relu_output_0       |/c4/Conv_output_0                                 |  198|  199|
      176|TIDL_ResizeLayer              |/c4/Conv_output_0                                 |/Resize_output_0                                  |  199|  200|
      177|TIDL_ConcatLayer              |/Resize_output_0                                  |/Concat_output_0                                  |  200|  201|
      178|TIDL_ConvolutionLayer         |/Concat_output_0                                  |/fue_c4_c3/Conv_output_0                          |  201|  202|
      179|TIDL_ResizeLayer              |/fue_c4_c3/Conv_output_0                          |/Resize_1_output_0                                |  202|  203|
      180|TIDL_ConcatLayer              |/Resize_1_output_0                                |/Concat_1_output_0                                |  203|  204|
      181|TIDL_ConvolutionLayer         |/Concat_1_output_0                                |/fue_c3_c2/Conv_output_0                          |  204|  205|
      182|TIDL_ResizeLayer              |/fue_c3_c2/Conv_output_0                          |/Resize_2_output_0                                |  205|  206|
      183|TIDL_ConcatLayer              |/Resize_2_output_0                                |/Concat_2_output_0                                |  206|  207|
      184|TIDL_ConvolutionLayer         |/Concat_2_output_0                                |/fue_c1_c0/Conv_output_0                          |  207|  208|
      185|TIDL_ConvolutionLayer         |/fue_c1_c0/Conv_output_0                          |/mask_pred/Conv_output_0                          |  208|  209|
      186|TIDL_ResizeLayer              |/mask_pred/Conv_output_0                          |/Resize_3_output_0                                |  209|  210|
      187|TIDL_ArgMaxLayer              |/Resize_3_output_0                                |629                                               |  210|  211|
      188|TIDL_DataLayer                |629                                               |629                                               |  211|    0|
    Completed tidl_optimizeNet
    Num of Layer Detected : 162
      Num|TIDL Layer Name               |Out Data Name                                     |Group |#Ins  |#Outs |Inbuf Ids                       |Outbuf Id |In NCHW                             |Out NCHW                            |MACS       |
        0|TIDL_DataLayer                |input.1_original                                  |     0|    -1|     1|  x   x   x   x   x   x   x   x |  0       |       0        0        0        0 |       1        3      640      960 |         0 |
        1|TIDL_ConvolutionLayer         |/backend/conv1/conv1.2/Relu_output_0              |     0|     1|     1|  0   x   x   x   x   x   x   x |  1       |       1        3      640      960 |       1       32      320      480 | 137625600 |
        2|TIDL_ConvolutionLayer         |/backend/conv1/conv1.5/Relu_output_0              |     0|     1|     1|  1   x   x   x   x   x   x   x |  2       |       1       32      320      480 |       1       64      160      240 | 710246400 |
        3|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv0/conv0.2/Relu_output_0|     0|     1|     1|  2   x   x   x   x   x   x   x |  3       |       1       64      160      240 |       1       64      160      240 | 159744000 |
        4|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_0           |     0|     1|     1|  3   x   x   x   x   x   x   x |  4       |       1       64      160      240 |       1       16      160      240 |         0 |
        5|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_1           |     0|     1|     1|  3   x   x   x   x   x   x   x |  5       |       1       64      160      240 |       1       16      160      240 |         0 |
        6|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_2           |     0|     1|     1|  3   x   x   x   x   x   x   x |  6       |       1       64      160      240 |       1       16      160      240 |         0 |
        7|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_3           |     0|     1|     1|  3   x   x   x   x   x   x   x |  7       |       1       64      160      240 |       1       16      160      240 |         0 |
        8|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv1/conv1.2/Relu_output_0|     0|     1|     1|  4   x   x   x   x   x   x   x |  8       |       1       16      160      240 |       1       16      160      240 |  89088000 |
        9|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/Add_output_0             |     0|     2|     1|  8   5   x   x   x   x   x   x |  9       |       1       16      160      240 |       1       16      160      240 |    614400 |
       10|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv2/conv2.2/Relu_output_0|     0|     1|     1|  9   x   x   x   x   x   x   x | 10       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       11|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/Add_1_output_0           |     0|     2|     1| 10   6   x   x   x   x   x   x | 11       |       1       16      160      240 |       1       16      160      240 |    614400 |
       12|TIDL_PoolingLayer             |end/layer1/layer1.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 11   x   x   x   x   x   x   x | 12       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       13|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv3/conv3.3/Relu_output_0|     0|     1|     1| 12   x   x   x   x   x   x   x | 13       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       14|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/Add_2_output_0           |     0|     2|     1| 13   7   x   x   x   x   x   x | 14       |       1       16      160      240 |       1       16      160      240 |    614400 |
       15|TIDL_PoolingLayer             |layer1/layer1.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 14   x   x   x   x   x   x   x | 15       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       16|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv4/conv4.3/Relu_output_0|     0|     1|     1| 15   x   x   x   x   x   x   x | 16       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       17|TIDL_ConcatLayer              |/backend/layer1/layer1.0/Concat_output_0          |     0|     4|     1|  8  10  13  16   x   x   x   x | 17       |       1       16      160      240 |       1       64      160      240 |   2457600 |
       18|TIDL_ConvolutionLayer         |/layer1/layer1.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 17   x   x   x   x   x   x   x | 18       |       1       64      160      240 |       1       64      160      240 | 157286400 |
       19|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/relu/Relu_output_0       |     0|     2|     1| 18   2   x   x   x   x   x   x | 19       |       1       64      160      240 |       1       64      160      240 |   4915200 |
       20|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv0/conv0.2/Relu_output_0|     0|     1|     1| 19   x   x   x   x   x   x   x | 20       |       1       64      160      240 |       1       64      160      240 | 159744000 |
       21|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_0           |     0|     1|     1| 20   x   x   x   x   x   x   x | 21       |       1       64      160      240 |       1       16      160      240 |         0 |
       22|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_1           |     0|     1|     1| 20   x   x   x   x   x   x   x | 22       |       1       64      160      240 |       1       16      160      240 |         0 |
       23|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_2           |     0|     1|     1| 20   x   x   x   x   x   x   x | 23       |       1       64      160      240 |       1       16      160      240 |         0 |
       24|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_3           |     0|     1|     1| 20   x   x   x   x   x   x   x | 24       |       1       64      160      240 |       1       16      160      240 |         0 |
       25|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv1/conv1.2/Relu_output_0|     0|     1|     1| 21   x   x   x   x   x   x   x | 25       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       26|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/Add_output_0             |     0|     2|     1| 25  22   x   x   x   x   x   x | 26       |       1       16      160      240 |       1       16      160      240 |    614400 |
       27|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv2/conv2.2/Relu_output_0|     0|     1|     1| 26   x   x   x   x   x   x   x | 27       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       28|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/Add_1_output_0           |     0|     2|     1| 27  23   x   x   x   x   x   x | 28       |       1       16      160      240 |       1       16      160      240 |    614400 |
       29|TIDL_PoolingLayer             |end/layer1/layer1.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 28   x   x   x   x   x   x   x | 29       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       30|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv3/conv3.3/Relu_output_0|     0|     1|     1| 29   x   x   x   x   x   x   x | 30       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       31|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/Add_2_output_0           |     0|     2|     1| 30  24   x   x   x   x   x   x | 31       |       1       16      160      240 |       1       16      160      240 |    614400 |
       32|TIDL_PoolingLayer             |layer1/layer1.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 31   x   x   x   x   x   x   x | 32       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       33|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv4/conv4.3/Relu_output_0|     0|     1|     1| 32   x   x   x   x   x   x   x | 33       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       34|TIDL_ConcatLayer              |/backend/layer1/layer1.1/Concat_output_0          |     0|     4|     1| 25  27  30  33   x   x   x   x | 34       |       1       16      160      240 |       1       64      160      240 |   2457600 |
       35|TIDL_ConvolutionLayer         |/layer1/layer1.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 34   x   x   x   x   x   x   x | 35       |       1       64      160      240 |       1       64      160      240 | 157286400 |
       36|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/relu/Relu_output_0       |     0|     2|     1| 35  19   x   x   x   x   x   x | 36       |       1       64      160      240 |       1       64      160      240 |   4915200 |
       37|TIDL_ConvolutionLayer         |er2/layer2.0/downsample/downsample.0/Conv_output_0|     0|     1|     1| 36   x   x   x   x   x   x   x | 37       |       1       64      160      240 |       1      128       80      120 |  78643200 |
       38|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv0/conv0.2/Relu_output_0|     0|     1|     1| 36   x   x   x   x   x   x   x | 38       |       1       64      160      240 |       1      128      160      240 | 319488000 |
       39|TIDL_ConvolutionLayer         |/c1/Conv_output_0                                 |     0|     1|     1| 36   x   x   x   x   x   x   x | 39       |       1       64      160      240 |       1      128      160      240 | 314572800 |
       40|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_0           |     0|     1|     1| 38   x   x   x   x   x   x   x | 40       |       1      128      160      240 |       1       32      160      240 |         0 |
       41|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_1           |     0|     1|     1| 38   x   x   x   x   x   x   x | 41       |       1      128      160      240 |       1       32      160      240 |         0 |
       42|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_2           |     0|     1|     1| 38   x   x   x   x   x   x   x | 42       |       1      128      160      240 |       1       32      160      240 |         0 |
       43|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_3           |     0|     1|     1| 38   x   x   x   x   x   x   x | 43       |       1      128      160      240 |       1       32      160      240 |         0 |
       44|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv1/conv1.2/Relu_output_0|     0|     1|     1| 40   x   x   x   x   x   x   x | 44       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       45|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/Add_output_0             |     0|     2|     1| 44  41   x   x   x   x   x   x | 45       |       1       32      160      240 |       1       32      160      240 |   1228800 |
       46|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv2/conv2.2/Relu_output_0|     0|     1|     1| 45   x   x   x   x   x   x   x | 46       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       47|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/Add_1_output_0           |     0|     2|     1| 46  42   x   x   x   x   x   x | 47       |       1       32      160      240 |       1       32      160      240 |   1228800 |
       48|TIDL_PoolingLayer             |end/layer2/layer2.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 47   x   x   x   x   x   x   x | 48       |       1       32      160      240 |       1       32      160      240 |  11059200 |
       49|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv3/conv3.3/Relu_output_0|     0|     1|     1| 48   x   x   x   x   x   x   x | 49       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       50|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/Add_2_output_0           |     0|     2|     1| 49  43   x   x   x   x   x   x | 50       |       1       32      160      240 |       1       32      160      240 |   1228800 |
       51|TIDL_PoolingLayer             |layer2/layer2.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 50   x   x   x   x   x   x   x | 51       |       1       32      160      240 |       1       32      160      240 |  11059200 |
       52|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv4/conv4.3/Relu_output_0|     0|     1|     1| 51   x   x   x   x   x   x   x | 52       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       53|TIDL_ConcatLayer              |/backend/layer2/layer2.0/Concat_output_0          |     0|     4|     1| 44  46  49  52   x   x   x   x | 53       |       1       32      160      240 |       1      128      160      240 |   4915200 |
       54|TIDL_ConvolutionLayer         |/layer2/layer2.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 53   x   x   x   x   x   x   x | 54       |       1      128      160      240 |       1      128      160      240 | 629145600 |
       55|TIDL_PoolingLayer             |d/layer2/layer2.0/conv_downsample/MaxPool_output_0|     0|     1|     1| 54   x   x   x   x   x   x   x | 55       |       1      128      160      240 |       1      128       80      120 |  11059200 |
       56|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/relu/Relu_output_0       |     0|     2|     1| 55  37   x   x   x   x   x   x | 56       |       1      128       80      120 |       1      128       80      120 |   2457600 |
       57|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv0/conv0.2/Relu_output_0|     0|     1|     1| 56   x   x   x   x   x   x   x | 57       |       1      128       80      120 |       1      128       80      120 | 158515200 |
       58|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_0           |     0|     1|     1| 57   x   x   x   x   x   x   x | 58       |       1      128       80      120 |       1       32       80      120 |         0 |
       59|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_1           |     0|     1|     1| 57   x   x   x   x   x   x   x | 59       |       1      128       80      120 |       1       32       80      120 |         0 |
       60|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_2           |     0|     1|     1| 57   x   x   x   x   x   x   x | 60       |       1      128       80      120 |       1       32       80      120 |         0 |
       61|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_3           |     0|     1|     1| 57   x   x   x   x   x   x   x | 61       |       1      128       80      120 |       1       32       80      120 |         0 |
       62|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv1/conv1.2/Relu_output_0|     0|     1|     1| 58   x   x   x   x   x   x   x | 62       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       63|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/Add_output_0             |     0|     2|     1| 62  59   x   x   x   x   x   x | 63       |       1       32       80      120 |       1       32       80      120 |    307200 |
       64|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv2/conv2.2/Relu_output_0|     0|     1|     1| 63   x   x   x   x   x   x   x | 64       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       65|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/Add_1_output_0           |     0|     2|     1| 64  60   x   x   x   x   x   x | 65       |       1       32       80      120 |       1       32       80      120 |    307200 |
       66|TIDL_PoolingLayer             |end/layer2/layer2.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 65   x   x   x   x   x   x   x | 66       |       1       32       80      120 |       1       32       80      120 |   2764800 |
       67|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv3/conv3.3/Relu_output_0|     0|     1|     1| 66   x   x   x   x   x   x   x | 67       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       68|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/Add_2_output_0           |     0|     2|     1| 67  61   x   x   x   x   x   x | 68       |       1       32       80      120 |       1       32       80      120 |    307200 |
       69|TIDL_PoolingLayer             |layer2/layer2.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 68   x   x   x   x   x   x   x | 69       |       1       32       80      120 |       1       32       80      120 |   2764800 |
       70|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv4/conv4.3/Relu_output_0|     0|     1|     1| 69   x   x   x   x   x   x   x | 70       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       71|TIDL_ConcatLayer              |/backend/layer2/layer2.1/Concat_output_0          |     0|     4|     1| 62  64  67  70   x   x   x   x | 71       |       1       32       80      120 |       1      128       80      120 |   1228800 |
       72|TIDL_ConvolutionLayer         |/layer2/layer2.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 71   x   x   x   x   x   x   x | 72       |       1      128       80      120 |       1      128       80      120 | 157286400 |
       73|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/relu/Relu_output_0       |     0|     2|     1| 72  56   x   x   x   x   x   x | 73       |       1      128       80      120 |       1      128       80      120 |   2457600 |
       74|TIDL_ConvolutionLayer         |er3/layer3.0/downsample/downsample.0/Conv_output_0|     0|     1|     1| 73   x   x   x   x   x   x   x | 74       |       1      128       80      120 |       1      256       40       60 |  78643200 |
       75|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv0/conv0.2/Relu_output_0|     0|     1|     1| 73   x   x   x   x   x   x   x | 75       |       1      128       80      120 |       1      256       80      120 | 317030400 |
       76|TIDL_ConvolutionLayer         |/c2/Conv_output_0                                 |     0|     1|     1| 73   x   x   x   x   x   x   x | 76       |       1      128       80      120 |       1      128       80      120 | 157286400 |
       77|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_0           |     0|     1|     1| 75   x   x   x   x   x   x   x | 77       |       1      256       80      120 |       1       64       80      120 |         0 |
       78|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_1           |     0|     1|     1| 75   x   x   x   x   x   x   x | 78       |       1      256       80      120 |       1       64       80      120 |         0 |
       79|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_2           |     0|     1|     1| 75   x   x   x   x   x   x   x | 79       |       1      256       80      120 |       1       64       80      120 |         0 |
       80|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_3           |     0|     1|     1| 75   x   x   x   x   x   x   x | 80       |       1      256       80      120 |       1       64       80      120 |         0 |
       81|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv1/conv1.2/Relu_output_0|     0|     1|     1| 77   x   x   x   x   x   x   x | 81       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       82|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/Add_output_0             |     0|     2|     1| 81  78   x   x   x   x   x   x | 82       |       1       64       80      120 |       1       64       80      120 |    614400 |
       83|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv2/conv2.2/Relu_output_0|     0|     1|     1| 82   x   x   x   x   x   x   x | 83       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       84|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/Add_1_output_0           |     0|     2|     1| 83  79   x   x   x   x   x   x | 84       |       1       64       80      120 |       1       64       80      120 |    614400 |
       85|TIDL_PoolingLayer             |end/layer3/layer3.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 84   x   x   x   x   x   x   x | 85       |       1       64       80      120 |       1       64       80      120 |   5529600 |
       86|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv3/conv3.3/Relu_output_0|     0|     1|     1| 85   x   x   x   x   x   x   x | 86       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       87|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/Add_2_output_0           |     0|     2|     1| 86  80   x   x   x   x   x   x | 87       |       1       64       80      120 |       1       64       80      120 |    614400 |
       88|TIDL_PoolingLayer             |layer3/layer3.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 87   x   x   x   x   x   x   x | 88       |       1       64       80      120 |       1       64       80      120 |   5529600 |
       89|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv4/conv4.3/Relu_output_0|     0|     1|     1| 88   x   x   x   x   x   x   x | 89       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       90|TIDL_ConcatLayer              |/backend/layer3/layer3.0/Concat_output_0          |     0|     4|     1| 81  83  86  89   x   x   x   x | 90       |       1       64       80      120 |       1      256       80      120 |   2457600 |
       91|TIDL_ConvolutionLayer         |/layer3/layer3.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 90   x   x   x   x   x   x   x | 91       |       1      256       80      120 |       1      256       80      120 | 629145600 |
       92|TIDL_PoolingLayer             |d/layer3/layer3.0/conv_downsample/MaxPool_output_0|     0|     1|     1| 91   x   x   x   x   x   x   x | 92       |       1      256       80      120 |       1      256       40       60 |   5529600 |
       93|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/relu/Relu_output_0       |     0|     2|     1| 92  74   x   x   x   x   x   x | 93       |       1      256       40       60 |       1      256       40       60 |   1228800 |
       94|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv0/conv0.2/Relu_output_0|     0|     1|     1| 93   x   x   x   x   x   x   x | 94       |       1      256       40       60 |       1      256       40       60 | 157900800 |
       95|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_0           |     0|     1|     1| 94   x   x   x   x   x   x   x | 95       |       1      256       40       60 |       1       64       40       60 |         0 |
       96|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_1           |     0|     1|     1| 94   x   x   x   x   x   x   x | 96       |       1      256       40       60 |       1       64       40       60 |         0 |
       97|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_2           |     0|     1|     1| 94   x   x   x   x   x   x   x | 97       |       1      256       40       60 |       1       64       40       60 |         0 |
       98|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_3           |     0|     1|     1| 94   x   x   x   x   x   x   x | 98       |       1      256       40       60 |       1       64       40       60 |         0 |
       99|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv1/conv1.2/Relu_output_0|     0|     1|     1| 95   x   x   x   x   x   x   x | 99       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      100|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/Add_output_0             |     0|     2|     1| 99  96   x   x   x   x   x   x |100       |       1       64       40       60 |       1       64       40       60 |    153600 |
      101|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv2/conv2.2/Relu_output_0|     0|     1|     1|100   x   x   x   x   x   x   x |101       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      102|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/Add_1_output_0           |     0|     2|     1|101  97   x   x   x   x   x   x |102       |       1       64       40       60 |       1       64       40       60 |    153600 |
      103|TIDL_PoolingLayer             |end/layer3/layer3.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1|102   x   x   x   x   x   x   x |103       |       1       64       40       60 |       1       64       40       60 |   1382400 |
      104|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv3/conv3.3/Relu_output_0|     0|     1|     1|103   x   x   x   x   x   x   x |104       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      105|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/Add_2_output_0           |     0|     2|     1|104  98   x   x   x   x   x   x |105       |       1       64       40       60 |       1       64       40       60 |    153600 |
      106|TIDL_PoolingLayer             |layer3/layer3.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1|105   x   x   x   x   x   x   x |106       |       1       64       40       60 |       1       64       40       60 |   1382400 |
      107|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv4/conv4.3/Relu_output_0|     0|     1|     1|106   x   x   x   x   x   x   x |107       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      108|TIDL_ConcatLayer              |/backend/layer3/layer3.1/Concat_output_0          |     0|     4|     1| 99 101 104 107   x   x   x   x |108       |       1       64       40       60 |       1      256       40       60 |    614400 |
      109|TIDL_ConvolutionLayer         |/layer3/layer3.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1|108   x   x   x   x   x   x   x |109       |       1      256       40       60 |       1      256       40       60 | 157286400 |
      110|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/relu/Relu_output_0       |     0|     2|     1|109  93   x   x   x   x   x   x |110       |       1      256       40       60 |       1      256       40       60 |   1228800 |
      111|TIDL_ConvolutionLayer         |er4/layer4.0/downsample/downsample.0/Conv_output_0|     0|     1|     1|110   x   x   x   x   x   x   x |111       |       1      256       40       60 |       1      512       20       30 |  78643200 |
      112|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv0/conv0.2/Relu_output_0|     0|     1|     1|110   x   x   x   x   x   x   x |112       |       1      256       40       60 |       1      512       40       60 | 315801600 |
      113|TIDL_ConvolutionLayer         |/c3/Conv_output_0                                 |     0|     1|     1|110   x   x   x   x   x   x   x |113       |       1      256       40       60 |       1      128       40       60 |  78643200 |
      114|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_0           |     0|     1|     1|112   x   x   x   x   x   x   x |114       |       1      512       40       60 |       1      128       40       60 |         0 |
      115|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_1           |     0|     1|     1|112   x   x   x   x   x   x   x |115       |       1      512       40       60 |       1      128       40       60 |         0 |
      116|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_2           |     0|     1|     1|112   x   x   x   x   x   x   x |116       |       1      512       40       60 |       1      128       40       60 |         0 |
      117|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_3           |     0|     1|     1|112   x   x   x   x   x   x   x |117       |       1      512       40       60 |       1      128       40       60 |         0 |
      118|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv1/conv1.2/Relu_output_0|     0|     1|     1|114   x   x   x   x   x   x   x |118       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      119|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/Add_output_0             |     0|     2|     1|118 115   x   x   x   x   x   x |119       |       1      128       40       60 |       1      128       40       60 |    307200 |
      120|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv2/conv2.2/Relu_output_0|     0|     1|     1|119   x   x   x   x   x   x   x |120       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      121|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/Add_1_output_0           |     0|     2|     1|120 116   x   x   x   x   x   x |121       |       1      128       40       60 |       1      128       40       60 |    307200 |
      122|TIDL_PoolingLayer             |end/layer4/layer4.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1|121   x   x   x   x   x   x   x |122       |       1      128       40       60 |       1      128       40       60 |   2764800 |
      123|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv3/conv3.3/Relu_output_0|     0|     1|     1|122   x   x   x   x   x   x   x |123       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      124|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/Add_2_output_0           |     0|     2|     1|123 117   x   x   x   x   x   x |124       |       1      128       40       60 |       1      128       40       60 |    307200 |
      125|TIDL_PoolingLayer             |layer4/layer4.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1|124   x   x   x   x   x   x   x |125       |       1      128       40       60 |       1      128       40       60 |   2764800 |
      126|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv4/conv4.3/Relu_output_0|     0|     1|     1|125   x   x   x   x   x   x   x |126       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      127|TIDL_ConcatLayer              |/backend/layer4/layer4.0/Concat_output_0          |     0|     4|     1|118 120 123 126   x   x   x   x |127       |       1      128       40       60 |       1      512       40       60 |   1228800 |
      128|TIDL_ConvolutionLayer         |/layer4/layer4.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1|127   x   x   x   x   x   x   x |128       |       1      512       40       60 |       1      512       40       60 | 629145600 |
      129|TIDL_PoolingLayer             |d/layer4/layer4.0/conv_downsample/MaxPool_output_0|     0|     1|     1|128   x   x   x   x   x   x   x |129       |       1      512       40       60 |       1      512       20       30 |   2764800 |
      130|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/relu/Relu_output_0       |     0|     2|     1|129 111   x   x   x   x   x   x |130       |       1      512       20       30 |       1      512       20       30 |    614400 |
      131|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv0/conv0.2/Relu_output_0|     0|     1|     1|130   x   x   x   x   x   x   x |131       |       1      512       20       30 |       1      512       20       30 | 157593600 |
      132|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_0           |     0|     1|     1|131   x   x   x   x   x   x   x |132       |       1      512       20       30 |       1      128       20       30 |         0 |
      133|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_1           |     0|     1|     1|131   x   x   x   x   x   x   x |133       |       1      512       20       30 |       1      128       20       30 |         0 |
      134|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_2           |     0|     1|     1|131   x   x   x   x   x   x   x |134       |       1      512       20       30 |       1      128       20       30 |         0 |
      135|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_3           |     0|     1|     1|131   x   x   x   x   x   x   x |135       |       1      512       20       30 |       1      128       20       30 |         0 |
      136|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv1/conv1.2/Relu_output_0|     0|     1|     1|132   x   x   x   x   x   x   x |136       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      137|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/Add_output_0             |     0|     2|     1|136 133   x   x   x   x   x   x |137       |       1      128       20       30 |       1      128       20       30 |     76800 |
      138|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv2/conv2.2/Relu_output_0|     0|     1|     1|137   x   x   x   x   x   x   x |138       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      139|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/Add_1_output_0           |     0|     2|     1|138 134   x   x   x   x   x   x |139       |       1      128       20       30 |       1      128       20       30 |     76800 |
      140|TIDL_PoolingLayer             |end/layer4/layer4.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1|139   x   x   x   x   x   x   x |140       |       1      128       20       30 |       1      128       20       30 |    691200 |
      141|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv3/conv3.3/Relu_output_0|     0|     1|     1|140   x   x   x   x   x   x   x |141       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      142|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/Add_2_output_0           |     0|     2|     1|141 135   x   x   x   x   x   x |142       |       1      128       20       30 |       1      128       20       30 |     76800 |
      143|TIDL_PoolingLayer             |layer4/layer4.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1|142   x   x   x   x   x   x   x |143       |       1      128       20       30 |       1      128       20       30 |    691200 |
      144|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv4/conv4.3/Relu_output_0|     0|     1|     1|143   x   x   x   x   x   x   x |144       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      145|TIDL_ConcatLayer              |/backend/layer4/layer4.1/Concat_output_0          |     0|     4|     1|136 138 141 144   x   x   x   x |145       |       1      128       20       30 |       1      512       20       30 |    307200 |
      146|TIDL_ConvolutionLayer         |/layer4/layer4.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1|145   x   x   x   x   x   x   x |146       |       1      512       20       30 |       1      512       20       30 | 157286400 |
      147|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/relu/Relu_output_0       |     0|     2|     1|146 130   x   x   x   x   x   x |147       |       1      512       20       30 |       1      512       20       30 |    614400 |
      148|TIDL_ConvolutionLayer         |/c4/Conv_output_0                                 |     0|     1|     1|147   x   x   x   x   x   x   x |148       |       1      512       20       30 |       1      128       20       30 |  39321600 |
      149|TIDL_ResizeLayer              |/Resize_output_0                                  |     0|     1|     1|148   x   x   x   x   x   x   x |149       |       1      128       20       30 |       1      128       40       60 |   1228800 |
      150|TIDL_ConcatLayer              |/Concat_output_0                                  |     0|     2|     1|149 113   x   x   x   x   x   x |150       |       1      128       40       60 |       1      256       40       60 |    614400 |
      151|TIDL_ConvolutionLayer         |/fue_c4_c3/Conv_output_0                          |     0|     1|     1|150   x   x   x   x   x   x   x |151       |       1      256       40       60 |       1      128       40       60 | 707788800 |
      152|TIDL_ResizeLayer              |/Resize_1_output_0                                |     0|     1|     1|151   x   x   x   x   x   x   x |152       |       1      128       40       60 |       1      128       80      120 |   4915200 |
      153|TIDL_ConcatLayer              |/Concat_1_output_0                                |     0|     2|     1|152  76   x   x   x   x   x   x |153       |       1      128       80      120 |       1      256       80      120 |   2457600 |
      154|TIDL_ConvolutionLayer         |/fue_c3_c2/Conv_output_0                          |     0|     1|     1|153   x   x   x   x   x   x   x |154       |       1      256       80      120 |       1      128       80      120 |2831155200 |
      155|TIDL_ResizeLayer              |/Resize_2_output_0                                |     0|     1|     1|154   x   x   x   x   x   x   x |155       |       1      128       80      120 |       1      128      160      240 |  19660800 |
      156|TIDL_ConcatLayer              |/Concat_2_output_0                                |     0|     2|     1|155  39   x   x   x   x   x   x |156       |       1      128      160      240 |       1      256      160      240 |   9830400 |
      157|TIDL_ConvolutionLayer         |/fue_c1_c0/Conv_output_0                          |     0|     1|     1|156   x   x   x   x   x   x   x |157       |       1      256      160      240 |       1      128      160      240 |11324620800 |
      158|TIDL_ConvolutionLayer         |/mask_pred/Conv_output_0                          |     0|     1|     1|157   x   x   x   x   x   x   x |158       |       1      128      160      240 |       1        9      160      240 |  44236800 |
      159|TIDL_ResizeLayer              |/Resize_3_output_0                                |     0|     1|     1|158   x   x   x   x   x   x   x |159       |       1        9      160      240 |       1        9      640      960 |  22118400 |
      160|TIDL_ArgMaxLayer              |629                                               |     0|     1|     1|159   x   x   x   x   x   x   x |160       |       1        9      640      960 |       1        1      640      960 |    614400 |
      161|TIDL_DataLayer                |629                                               |     0|     1|    -1|160   x   x   x   x   x   x   x |  0       |       1        1      640      960 |       0        0        0        0 |         0 |
    Total Giga Macs : 27.2301
    Processing config file #0 : /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/import_model.txt.qunat_stats_config.txt
    Input : dataId=0, name=input.1_original, elementType 6, scale=1.000000, zero point=0, layout=0
    Ouput : dataId=160, name=629, elementType 6, scale=1.000000, zero point=0, layout=0
         17581284,     16.767 0x7f0b887cf010
    worstCaseDelay for Pre-emption is 0.0000000
    Network File Read done
    Calling algAlloc
    Alg Alloc for Layer # -    0
    Alg Alloc for Layer # -    1
    Alg Alloc for Layer # -    2
    Alg Alloc for Layer # -    3
    Alg Alloc for Layer # -    4
    Alg Alloc for Layer # -    5
    Alg Alloc for Layer # -    6
    Alg Alloc for Layer # -    7
    Alg Alloc for Layer # -    8
    Alg Alloc for Layer # -    9
    Alg Alloc for Layer # -   10
    Alg Alloc for Layer # -   11
    Alg Alloc for Layer # -   12
    Alg Alloc for Layer # -   13
    Alg Alloc for Layer # -   14
    Alg Alloc for Layer # -   15
    Alg Alloc for Layer # -   16
    Alg Alloc for Layer # -   17
    Alg Alloc for Layer # -   18
    Alg Alloc for Layer # -   19
    Alg Alloc for Layer # -   20
    Alg Alloc for Layer # -   21
    Alg Alloc for Layer # -   22
    Alg Alloc for Layer # -   23
    Alg Alloc for Layer # -   24
    Alg Alloc for Layer # -   25
    Alg Alloc for Layer # -   26
    Alg Alloc for Layer # -   27
    Alg Alloc for Layer # -   28
    Alg Alloc for Layer # -   29
    Alg Alloc for Layer # -   30
    Alg Alloc for Layer # -   31
    Alg Alloc for Layer # -   32
    Alg Alloc for Layer # -   33
    Alg Alloc for Layer # -   34
    Alg Alloc for Layer # -   35
    Alg Alloc for Layer # -   36
    Alg Alloc for Layer # -   37
    Alg Alloc for Layer # -   38
    Alg Alloc for Layer # -   39
    Alg Alloc for Layer # -   40
    Alg Alloc for Layer # -   41
    Alg Alloc for Layer # -   42
    Alg Alloc for Layer # -   43
    Alg Alloc for Layer # -   44
    Alg Alloc for Layer # -   45
    Alg Alloc for Layer # -   46
    Alg Alloc for Layer # -   47
    Alg Alloc for Layer # -   48
    Alg Alloc for Layer # -   49
    Alg Alloc for Layer # -   50
    Alg Alloc for Layer # -   51
    Alg Alloc for Layer # -   52
    Alg Alloc for Layer # -   53
    Alg Alloc for Layer # -   54
    Alg Alloc for Layer # -   55
    Alg Alloc for Layer # -   56
    Alg Alloc for Layer # -   57
    Alg Alloc for Layer # -   58
    Alg Alloc for Layer # -   59
    Alg Alloc for Layer # -   60
    Alg Alloc for Layer # -   61
    Alg Alloc for Layer # -   62
    Alg Alloc for Layer # -   63
    Alg Alloc for Layer # -   64
    Alg Alloc for Layer # -   65
    Alg Alloc for Layer # -   66
    Alg Alloc for Layer # -   67
    Alg Alloc for Layer # -   68
    Alg Alloc for Layer # -   69
    Alg Alloc for Layer # -   70
    Alg Alloc for Layer # -   71
    Alg Alloc for Layer # -   72
    Alg Alloc for Layer # -   73
    Alg Alloc for Layer # -   74
    Alg Alloc for Layer # -   75
    Alg Alloc for Layer # -   76
    Alg Alloc for Layer # -   77
    Alg Alloc for Layer # -   78
    Alg Alloc for Layer # -   79
    Alg Alloc for Layer # -   80
    Alg Alloc for Layer # -   81
    Alg Alloc for Layer # -   82
    Alg Alloc for Layer # -   83
    Alg Alloc for Layer # -   84
    Alg Alloc for Layer # -   85
    Alg Alloc for Layer # -   86
    Alg Alloc for Layer # -   87
    Alg Alloc for Layer # -   88
    Alg Alloc for Layer # -   89
    Alg Alloc for Layer # -   90
    Alg Alloc for Layer # -   91
    Alg Alloc for Layer # -   92
    Alg Alloc for Layer # -   93
    Alg Alloc for Layer # -   94
    Alg Alloc for Layer # -   95
    Alg Alloc for Layer # -   96
    Alg Alloc for Layer # -   97
    Alg Alloc for Layer # -   98
    Alg Alloc for Layer # -   99
    Alg Alloc for Layer # -  100
    Alg Alloc for Layer # -  101
    Alg Alloc for Layer # -  102
    Alg Alloc for Layer # -  103
    Alg Alloc for Layer # -  104
    Alg Alloc for Layer # -  105
    Alg Alloc for Layer # -  106
    Alg Alloc for Layer # -  107
    Alg Alloc for Layer # -  108
    Alg Alloc for Layer # -  109
    Alg Alloc for Layer # -  110
    Alg Alloc for Layer # -  111
    Alg Alloc for Layer # -  112
    Alg Alloc for Layer # -  113
    Alg Alloc for Layer # -  114
    Alg Alloc for Layer # -  115
    Alg Alloc for Layer # -  116
    Alg Alloc for Layer # -  117
    Alg Alloc for Layer # -  118
    Alg Alloc for Layer # -  119
    Alg Alloc for Layer # -  120
    Alg Alloc for Layer # -  121
    Alg Alloc for Layer # -  122
    Alg Alloc for Layer # -  123
    Alg Alloc for Layer # -  124
    Alg Alloc for Layer # -  125
    Alg Alloc for Layer # -  126
    Alg Alloc for Layer # -  127
    Alg Alloc for Layer # -  128
    Alg Alloc for Layer # -  129
    Alg Alloc for Layer # -  130
    Alg Alloc for Layer # -  131
    Alg Alloc for Layer # -  132
    Alg Alloc for Layer # -  133
    Alg Alloc for Layer # -  134
    Alg Alloc for Layer # -  135
    Alg Alloc for Layer # -  136
    Alg Alloc for Layer # -  137
    Alg Alloc for Layer # -  138
    Alg Alloc for Layer # -  139
    Alg Alloc for Layer # -  140
    Alg Alloc for Layer # -  141
    Alg Alloc for Layer # -  142
    Alg Alloc for Layer # -  143
    Alg Alloc for Layer # -  144
    Alg Alloc for Layer # -  145
    Alg Alloc for Layer # -  146
    Alg Alloc for Layer # -  147
    Alg Alloc for Layer # -  148
    Alg Alloc for Layer # -  149
    Alg Alloc for Layer # -  150
    Alg Alloc for Layer # -  151
    Alg Alloc for Layer # -  152
    Alg Alloc for Layer # -  153
    Alg Alloc for Layer # -  154
    Alg Alloc for Layer # -  155
    Alg Alloc for Layer # -  156
    Alg Alloc for Layer # -  157
    Alg Alloc for Layer # -  158
    Alg Alloc for Layer # -  159
    Alg Alloc for Layer # -  160
    Alg Alloc for Layer # -  161
    0           , DDR Cacheable, Persistent  , 14.84
    1           , DDR Cacheable, Persistent  , 0.14
    2           , DDR Cacheable, Scratch     , 16.00
    3           , DDR Cacheable, Scratch     , 4.00
    4           , DDR Cacheable, Scratch     , 56.00
    5           , DDR Cacheable, Persistent  , 1447.25
    6           , DDR Cacheable, Scratch     , 510798.81
    7           , DDR Cacheable, Scratch     , 0.12
    8           , DDR Cacheable, Scratch     , 157132.12
    9           , DDR Cacheable, Scratch     , 314267.00
    10          , DDR Cacheable, Scratch     , 0.12
    11          , DDR Cacheable, Persistent  , 1644.12
    12          , DDR Cacheable, Scratch     , 607.62
    13          , DDR Cacheable, Persistent  , 0.12
    14          , DDR Cacheable, Persistent  , 17169.22
    Total memory size requirement (space wise):
    Mem Space , Size(KBytes)
    DDR Cacheable, 1003157.52
    NOTE: Memory requirement in host emulation can be different from the same on EVM
          To get the actual TIDL memory requirement make sure to run on EVM with
          debugTraceLevel = 2
    Num,    Space,     SizeinBytes,   SineInMB
       0,    17,        15192,      0.014 0x55df4e076890
       1,    17,          144,      0.000 0x55df4e076130
       2,    17,        16384,      0.016 0x55df4e07a3f0
       3,    17,         4096,      0.004 0x55df4e07e400
       4,    17,        57344,      0.055 0x55df4e07f410
       5,    17,      1481988,      1.413 0x7f0b88665010
       6,    17,    523057984,    498.827 0x7f0b69391010
       7,    17,          128,      0.000 0x55df4e0718d0
       8,    17,    160903296,    153.449 0x7f0b5fa1d010
       9,    17,    321809408,    306.901 0x7f0b4c736010
      10,    17,          128,      0.000 0x55df4e067720
      11,    17,      1683584,      1.606 0x7f0b4c59a010
      12,    17,       622208,      0.593 0x7f0c1ed39010
      13,    17,          128,      0.000 0x55df4e0761d0
      14,    17,     17581284,     16.767 0x7f0b4b4d5010
    Total External Memory (DDR) Size =   1027233296,    979.646
    Alg Init for Layer # -    0 out of  161
    Alg Init for Layer # -    1 out of  161
    Alg Init for Layer # -    2 out of  161
    Alg Init for Layer # -    3 out of  161
    Alg Init for Layer # -    4 out of  161
    Alg Init for Layer # -    5 out of  161
    Alg Init for Layer # -    6 out of  161
    Alg Init for Layer # -    7 out of  161
    Alg Init for Layer # -    8 out of  161
    Alg Init for Layer # -    9 out of  161
    Alg Init for Layer # -   10 out of  161
    Alg Init for Layer # -   11 out of  161
    Alg Init for Layer # -   12 out of  161
    Alg Init for Layer # -   13 out of  161
    Alg Init for Layer # -   14 out of  161
    Alg Init for Layer # -   15 out of  161
    Alg Init for Layer # -   16 out of  161
    Alg Init for Layer # -   17 out of  161
    Alg Init for Layer # -   18 out of  161
    Alg Init for Layer # -   19 out of  161
    Alg Init for Layer # -   20 out of  161
    Alg Init for Layer # -   21 out of  161
    Alg Init for Layer # -   22 out of  161
    Alg Init for Layer # -   23 out of  161
    Alg Init for Layer # -   24 out of  161
    Alg Init for Layer # -   25 out of  161
    Alg Init for Layer # -   26 out of  161
    Alg Init for Layer # -   27 out of  161
    Alg Init for Layer # -   28 out of  161
    Alg Init for Layer # -   29 out of  161
    Alg Init for Layer # -   30 out of  161
    Alg Init for Layer # -   31 out of  161
    Alg Init for Layer # -   32 out of  161
    Alg Init for Layer # -   33 out of  161
    Alg Init for Layer # -   34 out of  161
    Alg Init for Layer # -   35 out of  161
    Alg Init for Layer # -   36 out of  161
    Alg Init for Layer # -   37 out of  161
    Alg Init for Layer # -   38 out of  161
    Alg Init for Layer # -   39 out of  161
    Alg Init for Layer # -   40 out of  161
    Alg Init for Layer # -   41 out of  161
    Alg Init for Layer # -   42 out of  161
    Alg Init for Layer # -   43 out of  161
    Alg Init for Layer # -   44 out of  161
    Alg Init for Layer # -   45 out of  161
    Alg Init for Layer # -   46 out of  161
    Alg Init for Layer # -   47 out of  161
    Alg Init for Layer # -   48 out of  161
    Alg Init for Layer # -   49 out of  161
    Alg Init for Layer # -   50 out of  161
    Alg Init for Layer # -   51 out of  161
    Alg Init for Layer # -   52 out of  161
    Alg Init for Layer # -   53 out of  161
    Alg Init for Layer # -   54 out of  161
    Alg Init for Layer # -   55 out of  161
    Alg Init for Layer # -   56 out of  161
    Alg Init for Layer # -   57 out of  161
    Alg Init for Layer # -   58 out of  161
    Alg Init for Layer # -   59 out of  161
    Alg Init for Layer # -   60 out of  161
    Alg Init for Layer # -   61 out of  161
    Alg Init for Layer # -   62 out of  161
    Alg Init for Layer # -   63 out of  161
    Alg Init for Layer # -   64 out of  161
    Alg Init for Layer # -   65 out of  161
    Alg Init for Layer # -   66 out of  161
    Alg Init for Layer # -   67 out of  161
    Alg Init for Layer # -   68 out of  161
    Alg Init for Layer # -   69 out of  161
    Alg Init for Layer # -   70 out of  161
    Alg Init for Layer # -   71 out of  161
    Alg Init for Layer # -   72 out of  161
    Alg Init for Layer # -   73 out of  161
    Alg Init for Layer # -   74 out of  161
    Alg Init for Layer # -   75 out of  161
    Alg Init for Layer # -   76 out of  161
    Alg Init for Layer # -   77 out of  161
    Alg Init for Layer # -   78 out of  161
    Alg Init for Layer # -   79 out of  161
    Alg Init for Layer # -   80 out of  161
    Alg Init for Layer # -   81 out of  161
    Alg Init for Layer # -   82 out of  161
    Alg Init for Layer # -   83 out of  161
    Alg Init for Layer # -   84 out of  161
    Alg Init for Layer # -   85 out of  161
    Alg Init for Layer # -   86 out of  161
    Alg Init for Layer # -   87 out of  161
    Alg Init for Layer # -   88 out of  161
    Alg Init for Layer # -   89 out of  161
    Alg Init for Layer # -   90 out of  161
    Alg Init for Layer # -   91 out of  161
    Alg Init for Layer # -   92 out of  161
    Alg Init for Layer # -   93 out of  161
    Alg Init for Layer # -   94 out of  161
    Alg Init for Layer # -   95 out of  161
    Alg Init for Layer # -   96 out of  161
    Alg Init for Layer # -   97 out of  161
    Alg Init for Layer # -   98 out of  161
    Alg Init for Layer # -   99 out of  161
    Alg Init for Layer # -  100 out of  161
    Alg Init for Layer # -  101 out of  161
    Alg Init for Layer # -  102 out of  161
    Alg Init for Layer # -  103 out of  161
    Alg Init for Layer # -  104 out of  161
    Alg Init for Layer # -  105 out of  161
    Alg Init for Layer # -  106 out of  161
    Alg Init for Layer # -  107 out of  161
    Alg Init for Layer # -  108 out of  161
    Alg Init for Layer # -  109 out of  161
    Alg Init for Layer # -  110 out of  161
    Alg Init for Layer # -  111 out of  161
    Alg Init for Layer # -  112 out of  161
    Alg Init for Layer # -  113 out of  161
    Alg Init for Layer # -  114 out of  161
    Alg Init for Layer # -  115 out of  161
    Alg Init for Layer # -  116 out of  161
    Alg Init for Layer # -  117 out of  161
    Alg Init for Layer # -  118 out of  161
    Alg Init for Layer # -  119 out of  161
    Alg Init for Layer # -  120 out of  161
    Alg Init for Layer # -  121 out of  161
    Alg Init for Layer # -  122 out of  161
    Alg Init for Layer # -  123 out of  161
    Alg Init for Layer # -  124 out of  161
    Alg Init for Layer # -  125 out of  161
    Alg Init for Layer # -  126 out of  161
    Alg Init for Layer # -  127 out of  161
    Alg Init for Layer # -  128 out of  161
    Alg Init for Layer # -  129 out of  161
    Alg Init for Layer # -  130 out of  161
    Alg Init for Layer # -  131 out of  161
    Alg Init for Layer # -  132 out of  161
    Alg Init for Layer # -  133 out of  161
    Alg Init for Layer # -  134 out of  161
    Alg Init for Layer # -  135 out of  161
    Alg Init for Layer # -  136 out of  161
    Alg Init for Layer # -  137 out of  161
    Alg Init for Layer # -  138 out of  161
    Alg Init for Layer # -  139 out of  161
    Alg Init for Layer # -  140 out of  161
    Alg Init for Layer # -  141 out of  161
    Alg Init for Layer # -  142 out of  161
    Alg Init for Layer # -  143 out of  161
    Alg Init for Layer # -  144 out of  161
    Alg Init for Layer # -  145 out of  161
    Alg Init for Layer # -  146 out of  161
    Alg Init for Layer # -  147 out of  161
    Alg Init for Layer # -  148 out of  161
    Alg Init for Layer # -  149 out of  161
    Alg Init for Layer # -  150 out of  161
    Alg Init for Layer # -  151 out of  161
    Alg Init for Layer # -  152 out of  161
    Alg Init for Layer # -  153 out of  161
    Alg Init for Layer # -  154 out of  161
    Alg Init for Layer # -  155 out of  161
    Alg Init for Layer # -  156 out of  161
    Alg Init for Layer # -  157 out of  161
    Alg Init for Layer # -  158 out of  161
    Alg Init for Layer # -  159 out of  161
    Alg Init for Layer # -  160 out of  161
    Alg Init for Layer # -  161 out of  161
    PREEMPTION: Adding a new priority object for targetPriority = 0, handle = 0x55df4e076890
    PREEMPTION: Now total number of priority objects = 1 at priorityId = 0,    with new memRec of base = 0x55df4e0761d0 and size = 128
    PREEMPTION: Requesting context memory addr for handle 0x55df4e076890, return Addr = 0x55df4e0761d0
     Freeing memory for user provided Net
     Instance created for  /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/import_model.txt.qunat_stats_config.txt
    Processing Cnt :    0, InstCnt :    0 /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_net.bin!
    /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/test_images/images_640_384/102.jpg
        14830152,     14.143 0x55df4ef8acd0
        19660800,     18.750 0x7f0b2953c010
     ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
    #    0 . ..TIDL_activate is called with handle : 4e076890
    Starting Layer # -    1
    Processing Layer # -    1
    End of Layer # -    1 with outPtrs[0] = 0x7f0b69391010
    Starting Layer # -    2
    Processing Layer # -    2
    End of Layer # -    2 with outPtrs[0] = 0x7f0b6a688190
    Starting Layer # -    3
    Processing Layer # -    3
    End of Layer # -    3 with outPtrs[0] = 0x7f0b6afe8190
    Starting Layer # -    4
    Processing Layer # -    4
    End of Layer # -    4 with outPtrs[0] = 0x7f0b6b948190
    Starting Layer # -    5
    Processing Layer # -    5
    End of Layer # -    5 with outPtrs[0] = 0x7f0b6bbade90
    Starting Layer # -    6
    Processing Layer # -    6
    End of Layer # -    6 with outPtrs[0] = 0x7f0b6be05e90
    Starting Layer # -    7
    Processing Layer # -    7
    End of Layer # -    7 with outPtrs[0] = 0x7f0b6c05de90
    Starting Layer # -    8
    Processing Layer # -    8
    End of Layer # -    8 with outPtrs[0] = 0x7f0b6c2b5e90
    Starting Layer # -    9
    Processing Layer # -    9
    End of Layer # -    9 with outPtrs[0] = 0x7f0b6c50de90
    Starting Layer # -   10
    Processing Layer # -   10
    End of Layer # -   10 with outPtrs[0] = 0x7f0b6c773b90
    Starting Layer # -   11
    Processing Layer # -   11
    End of Layer # -   11 with outPtrs[0] = 0x7f0b6c50de90
    Starting Layer # -   12
    Processing Layer # -   12
    End of Layer # -   12 with outPtrs[0] = 0x7f0b6c9cbb90
    Starting Layer # -   13
    Processing Layer # -   13
    End of Layer # -   13 with outPtrs[0] = 0x7f0b6cc31890
    Starting Layer # -   14
    Processing Layer # -   14
    End of Layer # -   14 with outPtrs[0] = 0x7f0b6c50de90
    Starting Layer # -   15
    Processing Layer # -   15
    End of Layer # -   15 with outPtrs[0] = 0x7f0b6c9cbb90
    Starting Layer # -   16
    Processing Layer # -   16
    End of Layer # -   16 with outPtrs[0] = 0x7f0b6ce89890
    Starting Layer # -   17
    Processing Layer # -   17
    End of Layer # -   17 with outPtrs[0] = 0x7f0b6d0e1890
    Starting Layer # -   18
    Processing Layer # -   18
    End of Layer # -   18 with outPtrs[0] = 0x7f0b6da41890
    Starting Layer # -   19
    Processing Layer # -   19
    End of Layer # -   19 with outPtrs[0] = 0x7f0b6e3a1890
    Starting Layer # -   20
    Processing Layer # -   20
    End of Layer # -   20 with outPtrs[0] = 0x7f0b6da41890
    Starting Layer # -   21
    Processing Layer # -   21
    End of Layer # -   21 with outPtrs[0] = 0x7f0b6b948190
    Starting Layer # -   22
    Processing Layer # -   22
    End of Layer # -   22 with outPtrs[0] = 0x7f0b6c05de90
    Starting Layer # -   23
    Processing Layer # -   23
    End of Layer # -   23 with outPtrs[0] = 0x7f0b6be05e90
    Starting Layer # -   24
    Processing Layer # -   24
    End of Layer # -   24 with outPtrs[0] = 0x7f0b6bbade90
    Starting Layer # -   25
    Processing Layer # -   25
    End of Layer # -   25 with outPtrs[0] = 0x7f0b6ed01890
    Starting Layer # -   26
    Processing Layer # -   26
    End of Layer # -   26 with outPtrs[0] = 0x7f0b6c50de90
    Starting Layer # -   27
    Processing Layer # -   27
    End of Layer # -   27 with outPtrs[0] = 0x7f0b6ef59890
    Starting Layer # -   28
    Processing Layer # -   28
    End of Layer # -   28 with outPtrs[0] = 0x7f0b6c50de90
    Starting Layer # -   29
    Processing Layer # -   29
    End of Layer # -   29 with outPtrs[0] = 0x7f0b6c9cbb90
    Starting Layer # -   30
    Processing Layer # -   30
    End of Layer # -   30 with outPtrs[0] = 0x7f0b6f1b1890
    Starting Layer # -   31
    Processing Layer # -   31
    End of Layer # -   31 with outPtrs[0] = 0x7f0b6c50de90
    Starting Layer # -   32
    Processing Layer # -   32
    End of Layer # -   32 with outPtrs[0] = 0x7f0b6c9cbb90
    Starting Layer # -   33
    Processing Layer # -   33
    End of Layer # -   33 with outPtrs[0] = 0x7f0b6f409890
    Starting Layer # -   34
    Processing Layer # -   34
    End of Layer # -   34 with outPtrs[0] = 0x7f0b6d0e1890
    Starting Layer # -   35
    Processing Layer # -   35
    End of Layer # -   35 with outPtrs[0] = 0x7f0b6f661890
    Starting Layer # -   36
    Processing Layer # -   36
    End of Layer # -   36 with outPtrs[0] = 0x7f0b6ffc1890
    Starting Layer # -   37
    Processing Layer # -   37
    End of Layer # -   37 with outPtrs[0] = 0x7f0b70921890
    Starting Layer # -   38
    Processing Layer # -   38
    End of Layer # -   38 with outPtrs[0] = 0x7f0b70dd1890
    Starting Layer # -   39
    Processing Layer # -   39
    End of Layer # -   39 with outPtrs[0] = 0x7f0b72091890
    Starting Layer # -   40
    Processing Layer # -   40
    End of Layer # -   40 with outPtrs[0] = 0x7f0b73351890
    Starting Layer # -   41
    Processing Layer # -   41
    End of Layer # -   41 with outPtrs[0] = 0x7f0b7381d210
    Starting Layer # -   42
    Processing Layer # -   42
    End of Layer # -   42 with outPtrs[0] = 0x7f0b73ccd210
    Starting Layer # -   43
    Processing Layer # -   43
    End of Layer # -   43 with outPtrs[0] = 0x7f0b7417d210
    Starting Layer # -   44
    Processing Layer # -   44
    End of Layer # -   44 with outPtrs[0] = 0x7f0b7462d210
    Starting Layer # -   45
    Processing Layer # -   45
    End of Layer # -   45 with outPtrs[0] = 0x7f0b74add210
    Starting Layer # -   46
    Processing Layer # -   46
    End of Layer # -   46 with outPtrs[0] = 0x7f0b74fa8b90
    Starting Layer # -   47
    Processing Layer # -   47
    End of Layer # -   47 with outPtrs[0] = 0x7f0b74add210
    Starting Layer # -   48
    Processing Layer # -   48
    End of Layer # -   48 with outPtrs[0] = 0x7f0b75458b90
    Starting Layer # -   49
    Processing Layer # -   49
    End of Layer # -   49 with outPtrs[0] = 0x7f0b75924510
    Starting Layer # -   50
    Processing Layer # -   50
    End of Layer # -   50 with outPtrs[0] = 0x7f0b74add210
    Starting Layer # -   51
    Processing Layer # -   51
    End of Layer # -   51 with outPtrs[0] = 0x7f0b75458b90
    Starting Layer # -   52
    Processing Layer # -   52
    End of Layer # -   52 with outPtrs[0] = 0x7f0b75dd4510
    Starting Layer # -   53
    Processing Layer # -   53
    End of Layer # -   53 with outPtrs[0] = 0x7f0b76284510
    Starting Layer # -   54
    Processing Layer # -   54
    End of Layer # -   54 with outPtrs[0] = 0x7f0b77544510
    Starting Layer # -   55
    Processing Layer # -   55
    End of Layer # -   55 with outPtrs[0] = 0x7f0b78872b10
    Starting Layer # -   56
    Processing Layer # -   56
    End of Layer # -   56 with outPtrs[0] = 0x7f0b78d22b10
    Starting Layer # -   57
    Processing Layer # -   57
    End of Layer # -   57 with outPtrs[0] = 0x7f0b70921890
    Starting Layer # -   58
    Processing Layer # -   58
    End of Layer # -   58 with outPtrs[0] = 0x7f0b791d2b10
    Starting Layer # -   59
    Processing Layer # -   59
    End of Layer # -   59 with outPtrs[0] = 0x7f0b7930c890
    Starting Layer # -   60
    Processing Layer # -   60
    End of Layer # -   60 with outPtrs[0] = 0x7f0b79438890
    Starting Layer # -   61
    Processing Layer # -   61
    End of Layer # -   61 with outPtrs[0] = 0x7f0b79564890
    Starting Layer # -   62
    Processing Layer # -   62
    End of Layer # -   62 with outPtrs[0] = 0x7f0b79690890
    Starting Layer # -   63
    Processing Layer # -   63
    End of Layer # -   63 with outPtrs[0] = 0x7f0b797bc890
    Starting Layer # -   64
    Processing Layer # -   64
    End of Layer # -   64 with outPtrs[0] = 0x7f0b798f6610
    Starting Layer # -   65
    Processing Layer # -   65
    End of Layer # -   65 with outPtrs[0] = 0x7f0b797bc890
    Starting Layer # -   66
    Processing Layer # -   66
    End of Layer # -   66 with outPtrs[0] = 0x7f0b79a22610
    Starting Layer # -   67
    Processing Layer # -   67
    End of Layer # -   67 with outPtrs[0] = 0x7f0b79b5c390
    Starting Layer # -   68
    Processing Layer # -   68
    End of Layer # -   68 with outPtrs[0] = 0x7f0b797bc890
    Starting Layer # -   69
    Processing Layer # -   69
    End of Layer # -   69 with outPtrs[0] = 0x7f0b79a22610
    Starting Layer # -   70
    Processing Layer # -   70
    End of Layer # -   70 with outPtrs[0] = 0x7f0b79c88390
    Starting Layer # -   71
    Processing Layer # -   71
    End of Layer # -   71 with outPtrs[0] = 0x7f0b79db4390
    Starting Layer # -   72
    Processing Layer # -   72
    End of Layer # -   72 with outPtrs[0] = 0x7f0b7a264390
    Starting Layer # -   73
    Processing Layer # -   73
    End of Layer # -   73 with outPtrs[0] = 0x7f0b7a714390
    Starting Layer # -   74
    Processing Layer # -   74
    End of Layer # -   74 with outPtrs[0] = 0x7f0b7abc4390
    Starting Layer # -   75
    Processing Layer # -   75
    End of Layer # -   75 with outPtrs[0] = 0x7f0b7ae1c390
    Starting Layer # -   76
    Processing Layer # -   76
    End of Layer # -   76 with outPtrs[0] = 0x7f0b7a264390
    Starting Layer # -   77
    Processing Layer # -   77
    End of Layer # -   77 with outPtrs[0] = 0x7f0b7b77c390
    Starting Layer # -   78
    Processing Layer # -   78
    End of Layer # -   78 with outPtrs[0] = 0x7f0b7b9efe90
    Starting Layer # -   79
    Processing Layer # -   79
    End of Layer # -   79 with outPtrs[0] = 0x7f0b7bc47e90
    Starting Layer # -   80
    Processing Layer # -   80
    End of Layer # -   80 with outPtrs[0] = 0x7f0b7be9fe90
    Starting Layer # -   81
    Processing Layer # -   81
    End of Layer # -   81 with outPtrs[0] = 0x7f0b7c0f7e90
    Starting Layer # -   82
    Processing Layer # -   82
    End of Layer # -   82 with outPtrs[0] = 0x7f0b7c34fe90
    Starting Layer # -   83
    Processing Layer # -   83
    End of Layer # -   83 with outPtrs[0] = 0x7f0b7c5c3990
    Starting Layer # -   84
    Processing Layer # -   84
    End of Layer # -   84 with outPtrs[0] = 0x7f0b7c34fe90
    Starting Layer # -   85
    Processing Layer # -   85
    End of Layer # -   85 with outPtrs[0] = 0x7f0b7c81b990
    Starting Layer # -   86
    Processing Layer # -   86
    End of Layer # -   86 with outPtrs[0] = 0x7f0b7ca8f490
    Starting Layer # -   87
    Processing Layer # -   87
    End of Layer # -   87 with outPtrs[0] = 0x7f0b7c34fe90
    Starting Layer # -   88
    Processing Layer # -   88
    End of Layer # -   88 with outPtrs[0] = 0x7f0b7c81b990
    Starting Layer # -   89
    Processing Layer # -   89
    End of Layer # -   89 with outPtrs[0] = 0x7f0b7cce7490
    Starting Layer # -   90
    Processing Layer # -   90
    End of Layer # -   90 with outPtrs[0] = 0x7f0b7cf3f490
    Starting Layer # -   91
    Processing Layer # -   91
    End of Layer # -   91 with outPtrs[0] = 0x7f0b7d89f490
    Starting Layer # -   92
    Processing Layer # -   92
    End of Layer # -   92 with outPtrs[0] = 0x7f0b7e26e090
    Starting Layer # -   93
    Processing Layer # -   93
    End of Layer # -   93 with outPtrs[0] = 0x7f0b7e4c6090
    Starting Layer # -   94
    Processing Layer # -   94
    End of Layer # -   94 with outPtrs[0] = 0x7f0b7abc4390
    Starting Layer # -   95
    Processing Layer # -   95
    End of Layer # -   95 with outPtrs[0] = 0x7f0b7e71e090
    Starting Layer # -   96
    Processing Layer # -   96
    End of Layer # -   96 with outPtrs[0] = 0x7f0b7e7c1f90
    Starting Layer # -   97
    Processing Layer # -   97
    End of Layer # -   97 with outPtrs[0] = 0x7f0b7e857f90
    Starting Layer # -   98
    Processing Layer # -   98
    End of Layer # -   98 with outPtrs[0] = 0x7f0b7e8edf90
    Starting Layer # -   99
    Processing Layer # -   99
    End of Layer # -   99 with outPtrs[0] = 0x7f0b7e983f90
    Starting Layer # -  100
    Processing Layer # -  100
    End of Layer # -  100 with outPtrs[0] = 0x7f0b7ea19f90
    Starting Layer # -  101
    Processing Layer # -  101
    End of Layer # -  101 with outPtrs[0] = 0x7f0b7eabde90
    Starting Layer # -  102
    Processing Layer # -  102
    End of Layer # -  102 with outPtrs[0] = 0x7f0b7ea19f90
    Starting Layer # -  103
    Processing Layer # -  103
    End of Layer # -  103 with outPtrs[0] = 0x7f0b7eb53e90
    Starting Layer # -  104
    Processing Layer # -  104
    End of Layer # -  104 with outPtrs[0] = 0x7f0b7ebf7d90
    Starting Layer # -  105
    Processing Layer # -  105
    End of Layer # -  105 with outPtrs[0] = 0x7f0b7ea19f90
    Starting Layer # -  106
    Processing Layer # -  106
    End of Layer # -  106 with outPtrs[0] = 0x7f0b7eb53e90
    Starting Layer # -  107
    Processing Layer # -  107
    End of Layer # -  107 with outPtrs[0] = 0x7f0b7ec8dd90
    Starting Layer # -  108
    Processing Layer # -  108
    End of Layer # -  108 with outPtrs[0] = 0x7f0b7ed23d90
    Starting Layer # -  109
    Processing Layer # -  109
    End of Layer # -  109 with outPtrs[0] = 0x7f0b7ef7bd90
    Starting Layer # -  110
    Processing Layer # -  110
    End of Layer # -  110 with outPtrs[0] = 0x7f0b7f1d3d90
    Starting Layer # -  111
    Processing Layer # -  111
    End of Layer # -  111 with outPtrs[0] = 0x7f0b7f42bd90
    Starting Layer # -  112
    Processing Layer # -  112
    End of Layer # -  112 with outPtrs[0] = 0x7f0b7f557d90
    Starting Layer # -  113
    Processing Layer # -  113
    End of Layer # -  113 with outPtrs[0] = 0x7f0b7ef7bd90
    Starting Layer # -  114
    Processing Layer # -  114
    End of Layer # -  114 with outPtrs[0] = 0x7f0b7fa07d90
    Starting Layer # -  115
    Processing Layer # -  115
    End of Layer # -  115 with outPtrs[0] = 0x7f0b7fb4fb90
    Starting Layer # -  116
    Processing Layer # -  116
    End of Layer # -  116 with outPtrs[0] = 0x7f0b7fc7bb90
    Starting Layer # -  117
    Processing Layer # -  117
    End of Layer # -  117 with outPtrs[0] = 0x7f0b7fda7b90
    Starting Layer # -  118
    Processing Layer # -  118
    End of Layer # -  118 with outPtrs[0] = 0x7f0b7fed3b90
    Starting Layer # -  119
    Processing Layer # -  119
    End of Layer # -  119 with outPtrs[0] = 0x7f0b7ffffb90
    Starting Layer # -  120
    Processing Layer # -  120
    End of Layer # -  120 with outPtrs[0] = 0x7f0b80147990
    Starting Layer # -  121
    Processing Layer # -  121
    End of Layer # -  121 with outPtrs[0] = 0x7f0b7ffffb90
    Starting Layer # -  122
    Processing Layer # -  122
    End of Layer # -  122 with outPtrs[0] = 0x7f0b80273990
    Starting Layer # -  123
    Processing Layer # -  123
    End of Layer # -  123 with outPtrs[0] = 0x7f0b803bb790
    Starting Layer # -  124
    Processing Layer # -  124
    End of Layer # -  124 with outPtrs[0] = 0x7f0b7ffffb90
    Starting Layer # -  125
    Processing Layer # -  125
    End of Layer # -  125 with outPtrs[0] = 0x7f0b80273990
    Starting Layer # -  126
    Processing Layer # -  126
    End of Layer # -  126 with outPtrs[0] = 0x7f0b804e7790
    Starting Layer # -  127
    Processing Layer # -  127
    End of Layer # -  127 with outPtrs[0] = 0x7f0b80613790
    Starting Layer # -  128
    Processing Layer # -  128
    End of Layer # -  128 with outPtrs[0] = 0x7f0b80ac3790
    Starting Layer # -  129
    Processing Layer # -  129
    End of Layer # -  129 with outPtrs[0] = 0x7f0b80fe2f90
    Starting Layer # -  130
    Processing Layer # -  130
    End of Layer # -  130 with outPtrs[0] = 0x7f0b8110ef90
    Starting Layer # -  131
    Processing Layer # -  131
    End of Layer # -  131 with outPtrs[0] = 0x7f0b7f42bd90
    Starting Layer # -  132
    Processing Layer # -  132
    End of Layer # -  132 with outPtrs[0] = 0x7f0b8123af90
    Starting Layer # -  133
    Processing Layer # -  133
    End of Layer # -  133 with outPtrs[0] = 0x7f0b81294190
    Starting Layer # -  134
    Processing Layer # -  134
    End of Layer # -  134 with outPtrs[0] = 0x7f0b812df190
    Starting Layer # -  135
    Processing Layer # -  135
    End of Layer # -  135 with outPtrs[0] = 0x7f0b8132a190
    Starting Layer # -  136
    Processing Layer # -  136
    End of Layer # -  136 with outPtrs[0] = 0x7f0b81375190
    Starting Layer # -  137
    Processing Layer # -  137
    End of Layer # -  137 with outPtrs[0] = 0x7f0b813c0190
    Starting Layer # -  138
    Processing Layer # -  138
    End of Layer # -  138 with outPtrs[0] = 0x7f0b81419390
    Starting Layer # -  139
    Processing Layer # -  139
    End of Layer # -  139 with outPtrs[0] = 0x7f0b813c0190
    Starting Layer # -  140
    Processing Layer # -  140
    End of Layer # -  140 with outPtrs[0] = 0x7f0b81464390
    Starting Layer # -  141
    Processing Layer # -  141
    End of Layer # -  141 with outPtrs[0] = 0x7f0b814bd590
    Starting Layer # -  142
    Processing Layer # -  142
    End of Layer # -  142 with outPtrs[0] = 0x7f0b813c0190
    Starting Layer # -  143
    Processing Layer # -  143
    End of Layer # -  143 with outPtrs[0] = 0x7f0b81464390
    Starting Layer # -  144
    Processing Layer # -  144
    End of Layer # -  144 with outPtrs[0] = 0x7f0b81508590
    Starting Layer # -  145
    Processing Layer # -  145
    End of Layer # -  145 with outPtrs[0] = 0x7f0b81553590
    Starting Layer # -  146
    Processing Layer # -  146
    End of Layer # -  146 with outPtrs[0] = 0x7f0b8167f590
    Starting Layer # -  147
    Processing Layer # -  147
    End of Layer # -  147 with outPtrs[0] = 0x7f0b817ab590
    Starting Layer # -  148
    Processing Layer # -  148
    End of Layer # -  148 with outPtrs[0] = 0x7f0b818d7590
    Starting Layer # -  149
    Processing Layer # -  149
    End of Layer # -  149 with outPtrs[0] = 0x7f0b81930790
    Starting Layer # -  150
    Processing Layer # -  150
    End of Layer # -  150 with outPtrs[0] = 0x7f0b81a5c790
    Starting Layer # -  151
    Processing Layer # -  151
    End of Layer # -  151 with outPtrs[0] = 0x7f0b80ac3790
    Starting Layer # -  152
    Processing Layer # -  152
    End of Layer # -  152 with outPtrs[0] = 0x7f0b81cec390
    Starting Layer # -  153
    Processing Layer # -  153
    End of Layer # -  153 with outPtrs[0] = 0x7f0b8219c390
    Starting Layer # -  154
    Processing Layer # -  154
    End of Layer # -  154 with outPtrs[0] = 0x7f0b7d89f490
    Starting Layer # -  155
    Processing Layer # -  155
    End of Layer # -  155 with outPtrs[0] = 0x7f0b82b6af90
    Starting Layer # -  156
    Processing Layer # -  156
    End of Layer # -  156 with outPtrs[0] = 0x7f0b83e2af90
    Starting Layer # -  157
    Processing Layer # -  157
    End of Layer # -  157 with outPtrs[0] = 0x7f0b72091890
    Starting Layer # -  158
    Processing Layer # -  158
    End of Layer # -  158 with outPtrs[0] = 0x7f0b77544510
    Starting Layer # -  159
    Processing Layer # -  159
    End of Layer # -  159 with outPtrs[0] = 0x7f0b86487b90
    Starting Layer # -  160
    Processing Layer # -  160
    End of Layer # -  160 with outPtrs[0] = 0x7f0b2953c010
    TIDL_process is completed with handle : 4e076890
     T   73140.94 Skipping static gen-set function
     .... ..... .../home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/test_images/images_640_384/102.jpg
    Processing Cnt :    1, InstCnt :    0 /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_net.bin!
        14830152,     14.143 0x55df4f7dcfc0
        19660800,     18.750 0x55df50601a10
    #    1 . ..Starting Layer # -    1
    End of Layer # -  160 with outPtrs[0] = 0x55df50601a10
     T   71310.62 Skipping static gen-set function
     .... .....TIDL_deactivate is called with handle : 4e076890
    PREEMPTION: Removing priroty object with handle = 0x55df4e076890 and targetPriority = 0,      Number of obejcts left are = 0, removed object with base  = 0x55df4e0761d0 and size =128
    ~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
    cd /home/yuming/Projects/TDA4VM/tidl_tools_all && ./PC_dsp_test_dl_algo.out s:/home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/import_model.txt.qunat_stats_config.txt
    Warning :: Weight Scale Clipped -       1.11,     528.09,     475.04,    0,  0,   52, /backend/layer2/layer2.0/conv4/conv4.1/Conv
    Warning :: Weight Scale Clipped -       1.39,     727.00,     523.60,    0,  0,   67, /backend/layer2/layer2.1/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       1.40,     363.47,     260.09,    0,  0,   70, /backend/layer2/layer2.1/conv4/conv4.1/Conv
    Warning :: Tensor Scale for layer 82 is reduced by 1 Bits
    Warning :: Weight Scale Clipped -       1.84,     939.68,     510.87,    0,  0,   86, /backend/layer3/layer3.0/conv3/conv3.1/Conv
    Warning :: Tensor Scale for layer 100 is reduced by 1 Bits
    Warning :: Weight Scale Clipped -       1.78,     997.28,     561.84,    0,  0,  104, /backend/layer3/layer3.1/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       1.02,     534.94,     524.41,    0,  0,  107, /backend/layer3/layer3.1/conv4/conv4.1/Conv
    Warning :: Tensor Scale for layer 119 is reduced by 1 Bits
    Warning :: Weight Scale Clipped -       3.27,    1271.38,     388.45,    0,  0,  123, /backend/layer4/layer4.0/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       3.52,     713.82,     202.84,    0,  0,  126, /backend/layer4/layer4.0/conv4/conv4.1/Conv
    Warning :: Weight Scale Clipped -       1.01,     681.45,     677.26,    0,  0,  136, /backend/layer4/layer4.1/conv1/conv1.0/Conv
    Warning :: Tensor Scale for layer 137 is reduced by 1 Bits
    Warning :: Weight Scale Clipped -       2.04,     673.04,     329.36,    0,  0,  141, /backend/layer4/layer4.1/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       2.57,     476.74,     185.18,    0,  0,  144, /backend/layer4/layer4.1/conv4/conv4.1/Conv
    Warning :: Tensor Scale for layer 156 is reduced by 1 Bits
    Input : dataId=0, name=input.1_original, elementType 0, scale=1.000000, zero point=0, layout=0
    Ouput : dataId=160, name=629, elementType 0, scale=1.000000, zero point=0, layout=0
          5603986,      5.344 0x7fb0c3504010
    Calling algAlloc
    TIDL Memory size requiement (record wise):
    MemRecNum   , Space       , Attribute   , Size(KBytes)
    5           , DDR Cacheable, Persistent  , 623.78
    6           , DDR Cacheable, Scratch     , 137506.80
    8           , DDR Cacheable, Scratch     , 39283.12
    9           , DDR Cacheable, Scratch     , 78569.00
    12          , DDR Cacheable, Scratch     , 602.00
    14          , DDR Cacheable, Persistent  , 5472.64
    DDR Cacheable, 263792.82
          debugTraceLevel = 2
       0,    17,        15192,      0.014 0x555d0139c1c0
       1,    17,          144,      0.000 0x555d0139ba60
       2,    17,        16384,      0.016 0x555d0139fd20
       3,    17,         4096,      0.004 0x555d013a3d30
       4,    17,        57344,      0.055 0x555d013a4d40
       5,    17,       638748,      0.609 0x7fb158efe010
       6,    17,    140806960,    134.284 0x7fb0baebb010
       7,    17,          128,      0.000 0x555d01397200
       8,    17,     40225920,     38.362 0x7fb0b885e010
       9,    17,     80454656,     76.728 0x7fb0b3ba3010
      10,    17,          128,      0.000 0x555d0138f730
      11,    17,      1683584,      1.606 0x7fb0b3a07010
      12,    17,       616448,      0.588 0x7fb0b3970010
      13,    17,          128,      0.000 0x555d0139bb00
      14,    17,      5603986,      5.344 0x7fb0b3417010
    Total External Memory (DDR) Size =    270123846,    257.610
    PREEMPTION: Adding a new priority object for targetPriority = 0, handle = 0x555d0139c1c0
    PREEMPTION: Now total number of priority objects = 1 at priorityId = 0,    with new memRec of base = 0x555d0139bb00 and size = 128
    PREEMPTION: Requesting context memory addr for handle 0x555d0139c1c0, return Addr = 0x555d0139bb00
         3707538,      3.536 0x555d01b82a80
         1228800,      1.172 0x555d01617a70
    #    0 . ..TIDL_activate is called with handle : 139c1c0
    End of Layer # -    1 with outPtrs[0] = 0x7fb0baebb010
    End of Layer # -    2 with outPtrs[0] = 0x7fb0bb378c90
    End of Layer # -    3 with outPtrs[0] = 0x7fb0bb5d0c90
    End of Layer # -    4 with outPtrs[0] = 0x7fb0bb828c90
    End of Layer # -    5 with outPtrs[0] = 0x7fb0bb8c2410
    End of Layer # -    6 with outPtrs[0] = 0x7fb0bb958410
    End of Layer # -    7 with outPtrs[0] = 0x7fb0bb9ee410
    End of Layer # -    8 with outPtrs[0] = 0x7fb0bba84410
    End of Layer # -    9 with outPtrs[0] = 0x7fb0bbb1a410
    End of Layer # -   10 with outPtrs[0] = 0x7fb0bbbb3b90
    End of Layer # -   11 with outPtrs[0] = 0x7fb0bbb1a410
    End of Layer # -   12 with outPtrs[0] = 0x7fb0bbc49b90
    End of Layer # -   13 with outPtrs[0] = 0x7fb0bbce3310
    End of Layer # -   14 with outPtrs[0] = 0x7fb0bbb1a410
    End of Layer # -   15 with outPtrs[0] = 0x7fb0bbc49b90
    End of Layer # -   16 with outPtrs[0] = 0x7fb0bbd79310
    End of Layer # -   17 with outPtrs[0] = 0x7fb0bbe0f310
    End of Layer # -   18 with outPtrs[0] = 0x7fb0bc067310
    End of Layer # -   19 with outPtrs[0] = 0x7fb0bc2bf310
    End of Layer # -   20 with outPtrs[0] = 0x7fb0bc067310
    End of Layer # -   21 with outPtrs[0] = 0x7fb0bb828c90
    End of Layer # -   22 with outPtrs[0] = 0x7fb0bb9ee410
    End of Layer # -   23 with outPtrs[0] = 0x7fb0bb958410
    End of Layer # -   24 with outPtrs[0] = 0x7fb0bb8c2410
    End of Layer # -   25 with outPtrs[0] = 0x7fb0bc517310
    End of Layer # -   26 with outPtrs[0] = 0x7fb0bbb1a410
    End of Layer # -   27 with outPtrs[0] = 0x7fb0bc5ad310
    End of Layer # -   28 with outPtrs[0] = 0x7fb0bbb1a410
    End of Layer # -   29 with outPtrs[0] = 0x7fb0bbc49b90
    End of Layer # -   30 with outPtrs[0] = 0x7fb0bc643310
    End of Layer # -   31 with outPtrs[0] = 0x7fb0bbb1a410
    End of Layer # -   32 with outPtrs[0] = 0x7fb0bbc49b90
    End of Layer # -   33 with outPtrs[0] = 0x7fb0bc6d9310
    End of Layer # -   34 with outPtrs[0] = 0x7fb0bbe0f310
    End of Layer # -   35 with outPtrs[0] = 0x7fb0bc76f310
    End of Layer # -   36 with outPtrs[0] = 0x7fb0bc9c7310
    End of Layer # -   37 with outPtrs[0] = 0x7fb0bcc1f310
    End of Layer # -   38 with outPtrs[0] = 0x7fb0bcd4b310
    End of Layer # -   39 with outPtrs[0] = 0x7fb0bd1fb310
    End of Layer # -   40 with outPtrs[0] = 0x7fb0bd6ab310
    End of Layer # -   41 with outPtrs[0] = 0x7fb0bd7de190
    End of Layer # -   42 with outPtrs[0] = 0x7fb0bd90a190
    End of Layer # -   43 with outPtrs[0] = 0x7fb0bda36190
    End of Layer # -   44 with outPtrs[0] = 0x7fb0bdb62190
    End of Layer # -   45 with outPtrs[0] = 0x7fb0bdc8e190
    End of Layer # -   46 with outPtrs[0] = 0x7fb0bddc1010
    End of Layer # -   47 with outPtrs[0] = 0x7fb0bdc8e190
    End of Layer # -   48 with outPtrs[0] = 0x7fb0bdeed010
    End of Layer # -   49 with outPtrs[0] = 0x7fb0be01fe90
    End of Layer # -   50 with outPtrs[0] = 0x7fb0bdc8e190
    End of Layer # -   51 with outPtrs[0] = 0x7fb0bdeed010
    End of Layer # -   52 with outPtrs[0] = 0x7fb0be14be90
    End of Layer # -   53 with outPtrs[0] = 0x7fb0be277e90
    End of Layer # -   54 with outPtrs[0] = 0x7fb0be727e90
    End of Layer # -   55 with outPtrs[0] = 0x7fb0bebf3810
    End of Layer # -   56 with outPtrs[0] = 0x7fb0bed1f810
    End of Layer # -   57 with outPtrs[0] = 0x7fb0bcc1f310
    End of Layer # -   58 with outPtrs[0] = 0x7fb0bee4b810
    End of Layer # -   59 with outPtrs[0] = 0x7fb0bee99f90
    End of Layer # -   60 with outPtrs[0] = 0x7fb0beee4f90
    End of Layer # -   61 with outPtrs[0] = 0x7fb0bef2ff90
    End of Layer # -   62 with outPtrs[0] = 0x7fb0bef7af90
    End of Layer # -   63 with outPtrs[0] = 0x7fb0befc5f90
    End of Layer # -   64 with outPtrs[0] = 0x7fb0bf014710
    End of Layer # -   65 with outPtrs[0] = 0x7fb0befc5f90
    End of Layer # -   66 with outPtrs[0] = 0x7fb0bf05f710
    End of Layer # -   67 with outPtrs[0] = 0x7fb0bf0ade90
    End of Layer # -   68 with outPtrs[0] = 0x7fb0befc5f90
    End of Layer # -   69 with outPtrs[0] = 0x7fb0bf05f710
    End of Layer # -   70 with outPtrs[0] = 0x7fb0bf0f8e90
    End of Layer # -   71 with outPtrs[0] = 0x7fb0bf143e90
    End of Layer # -   72 with outPtrs[0] = 0x7fb0bf26fe90
    End of Layer # -   73 with outPtrs[0] = 0x7fb0bf39be90
    End of Layer # -   74 with outPtrs[0] = 0x7fb0bf4c7e90
    End of Layer # -   75 with outPtrs[0] = 0x7fb0bf55de90
    End of Layer # -   76 with outPtrs[0] = 0x7fb0bf26fe90
    End of Layer # -   77 with outPtrs[0] = 0x7fb0bf7b5e90
    End of Layer # -   78 with outPtrs[0] = 0x7fb0bf852d90
    End of Layer # -   79 with outPtrs[0] = 0x7fb0bf8e8d90
    End of Layer # -   80 with outPtrs[0] = 0x7fb0bf97ed90
    End of Layer # -   81 with outPtrs[0] = 0x7fb0bfa14d90
    End of Layer # -   82 with outPtrs[0] = 0x7fb0bfaaad90
    End of Layer # -   83 with outPtrs[0] = 0x7fb0bfb47c90
    End of Layer # -   84 with outPtrs[0] = 0x7fb0bfaaad90
    End of Layer # -   85 with outPtrs[0] = 0x7fb0bfbddc90
    End of Layer # -   86 with outPtrs[0] = 0x7fb0bfc7ab90
    End of Layer # -   87 with outPtrs[0] = 0x7fb0bfaaad90
    End of Layer # -   88 with outPtrs[0] = 0x7fb0bfbddc90
    End of Layer # -   89 with outPtrs[0] = 0x7fb0bfd10b90
    End of Layer # -   90 with outPtrs[0] = 0x7fb0bfda6b90
    End of Layer # -   91 with outPtrs[0] = 0x7fb0bfffeb90
    End of Layer # -   92 with outPtrs[0] = 0x7fb0c0272690
    End of Layer # -   93 with outPtrs[0] = 0x7fb0c0308690
    End of Layer # -   94 with outPtrs[0] = 0x7fb0bf4c7e90
    End of Layer # -   95 with outPtrs[0] = 0x7fb0c039e690
    End of Layer # -   96 with outPtrs[0] = 0x7fb0c03c7690
    End of Layer # -   97 with outPtrs[0] = 0x7fb0c03ece90
    End of Layer # -   98 with outPtrs[0] = 0x7fb0c0412690
    End of Layer # -   99 with outPtrs[0] = 0x7fb0c0437e90
    End of Layer # -  100 with outPtrs[0] = 0x7fb0c045d690
    End of Layer # -  101 with outPtrs[0] = 0x7fb0c0486690
    End of Layer # -  102 with outPtrs[0] = 0x7fb0c045d690
    End of Layer # -  103 with outPtrs[0] = 0x7fb0c04abe90
    End of Layer # -  104 with outPtrs[0] = 0x7fb0c04d4e90
    End of Layer # -  105 with outPtrs[0] = 0x7fb0c045d690
    End of Layer # -  106 with outPtrs[0] = 0x7fb0c04abe90
    End of Layer # -  107 with outPtrs[0] = 0x7fb0c04fa690
    End of Layer # -  108 with outPtrs[0] = 0x7fb0c051fe90
    End of Layer # -  109 with outPtrs[0] = 0x7fb0c05b5e90
    End of Layer # -  110 with outPtrs[0] = 0x7fb0c064be90
    End of Layer # -  111 with outPtrs[0] = 0x7fb0c06e1e90
    End of Layer # -  112 with outPtrs[0] = 0x7fb0c072ce90
    End of Layer # -  113 with outPtrs[0] = 0x7fb0c05b5e90
    End of Layer # -  114 with outPtrs[0] = 0x7fb0c0858e90
    End of Layer # -  115 with outPtrs[0] = 0x7fb0c08aae10
    End of Layer # -  116 with outPtrs[0] = 0x7fb0c08f5e10
    End of Layer # -  117 with outPtrs[0] = 0x7fb0c0940e10
    End of Layer # -  118 with outPtrs[0] = 0x7fb0c098be10
    End of Layer # -  119 with outPtrs[0] = 0x7fb0c09d6e10
    End of Layer # -  120 with outPtrs[0] = 0x7fb0c0a28d90
    End of Layer # -  121 with outPtrs[0] = 0x7fb0c09d6e10
    End of Layer # -  122 with outPtrs[0] = 0x7fb0c0a73d90
    End of Layer # -  123 with outPtrs[0] = 0x7fb0c0ac5d10
    End of Layer # -  124 with outPtrs[0] = 0x7fb0c09d6e10
    End of Layer # -  125 with outPtrs[0] = 0x7fb0c0a73d90
    End of Layer # -  126 with outPtrs[0] = 0x7fb0c0b10d10
    End of Layer # -  127 with outPtrs[0] = 0x7fb0c0b5bd10
    End of Layer # -  128 with outPtrs[0] = 0x7fb0c0c87d10
    End of Layer # -  129 with outPtrs[0] = 0x7fb0c0dcfb10
    End of Layer # -  130 with outPtrs[0] = 0x7fb0c0e1ab10
    End of Layer # -  131 with outPtrs[0] = 0x7fb0c06e1e90
    End of Layer # -  132 with outPtrs[0] = 0x7fb0c0e65b10
    End of Layer # -  133 with outPtrs[0] = 0x7fb0c0e7bf90
    End of Layer # -  134 with outPtrs[0] = 0x7fb0c0e8eb90
    End of Layer # -  135 with outPtrs[0] = 0x7fb0c0ea1790
    End of Layer # -  136 with outPtrs[0] = 0x7fb0c0eb4390
    End of Layer # -  137 with outPtrs[0] = 0x7fb0c0ec6f90
    End of Layer # -  138 with outPtrs[0] = 0x7fb0c0edd410
    End of Layer # -  139 with outPtrs[0] = 0x7fb0c0ec6f90
    End of Layer # -  140 with outPtrs[0] = 0x7fb0c0ef0010
    End of Layer # -  141 with outPtrs[0] = 0x7fb0c0f06490
    End of Layer # -  142 with outPtrs[0] = 0x7fb0c0ec6f90
    End of Layer # -  143 with outPtrs[0] = 0x7fb0c0ef0010
    End of Layer # -  144 with outPtrs[0] = 0x7fb0c0f19090
    End of Layer # -  145 with outPtrs[0] = 0x7fb0c0f2bc90
    End of Layer # -  146 with outPtrs[0] = 0x7fb0c0f76c90
    End of Layer # -  147 with outPtrs[0] = 0x7fb0c0fc1c90
    End of Layer # -  148 with outPtrs[0] = 0x7fb0c100cc90
    End of Layer # -  149 with outPtrs[0] = 0x7fb0c1023110
    End of Layer # -  150 with outPtrs[0] = 0x7fb0c106e110
    End of Layer # -  151 with outPtrs[0] = 0x7fb0c0c87d10
    End of Layer # -  152 with outPtrs[0] = 0x7fb0c1112010
    End of Layer # -  153 with outPtrs[0] = 0x7fb0c123e010
    End of Layer # -  154 with outPtrs[0] = 0x7fb0bfffeb90
    End of Layer # -  155 with outPtrs[0] = 0x7fb0c14b1b10
    End of Layer # -  156 with outPtrs[0] = 0x7fb0c1961b10
    End of Layer # -  157 with outPtrs[0] = 0x7fb0bd1fb310
    End of Layer # -  158 with outPtrs[0] = 0x7fb0be727e90
    End of Layer # -  159 with outPtrs[0] = 0x7fb0c22f8e10
    End of Layer # -  160 with outPtrs[0] = 0x555d01617a70
    TIDL_process is completed with handle : 139c1c0
     T   48970.02 Skipping static gen-set function
         3707538,      3.536 0x555d013bd100
         1228800,      1.172 0x555d023d4d80
    End of Layer # -  160 with outPtrs[0] = 0x555d023d4d80
     T   49336.82 Skipping static gen-set function
     .... .....TIDL_deactivate is called with handle : 139c1c0
    PREEMPTION: Removing priroty object with handle = 0x555d0139c1c0 and targetPriority = 0,      Number of obejcts left are = 0, removed object with base  = 0x555d0139bb00 and size =128
     *****************   Calibration iteration number 0 completed ************************
    Warning :: Weight Scale Clipped -       1.83,     727.00,     398.19,    0,  0,   67, /backend/layer2/layer2.1/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       1.34,     939.68,     703.83,    0,  0,   86, /backend/layer3/layer3.0/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       2.09,     997.28,     476.65,    0,  0,  104, /backend/layer3/layer3.1/conv3/conv3.1/Conv
    Warning :: Weight Scale Clipped -       1.12,     534.94,     477.89,    0,  0,  107, /backend/layer3/layer3.1/conv4/conv4.1/Conv
    Warning :: Weight Scale Clipped -       1.06,    2541.74,    2394.50,    1,  0,  157, /fue_c1_c0/Conv
    Num of Layer Detected : 162
      Num|TIDL Layer Name               |Out Data Name                                     |Group |#Ins  |#Outs |Inbuf Ids                       |Outbuf Id |In NCHW                             |Out NCHW                            |MACS       |
        0|TIDL_DataLayer                |input.1_original                                  |     0|    -1|     1|  x   x   x   x   x   x   x   x |  0       |       0        0        0        0 |       1        3      640      960 |         0 |
        1|TIDL_ConvolutionLayer         |/backend/conv1/conv1.2/Relu_output_0              |     0|     1|     1|  0   x   x   x   x   x   x   x |  1       |       1        3      640      960 |       1       32      320      480 | 137625600 |
        2|TIDL_ConvolutionLayer         |/backend/conv1/conv1.5/Relu_output_0              |     0|     1|     1|  1   x   x   x   x   x   x   x |  2       |       1       32      320      480 |       1       64      160      240 | 710246400 |
        3|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv0/conv0.2/Relu_output_0|     0|     1|     1|  2   x   x   x   x   x   x   x |  3       |       1       64      160      240 |       1       64      160      240 | 159744000 |
        4|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_0           |     0|     1|     1|  3   x   x   x   x   x   x   x |  4       |       1       64      160      240 |       1       16      160      240 |         0 |
        5|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_1           |     0|     1|     1|  3   x   x   x   x   x   x   x |  5       |       1       64      160      240 |       1       16      160      240 |         0 |
        6|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_2           |     0|     1|     1|  3   x   x   x   x   x   x   x |  6       |       1       64      160      240 |       1       16      160      240 |         0 |
        7|TIDL_SliceLayer               |/backend/layer1/layer1.0/Split_output_3           |     0|     1|     1|  3   x   x   x   x   x   x   x |  7       |       1       64      160      240 |       1       16      160      240 |         0 |
        8|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv1/conv1.2/Relu_output_0|     0|     1|     1|  4   x   x   x   x   x   x   x |  8       |       1       16      160      240 |       1       16      160      240 |  89088000 |
        9|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/Add_output_0             |     0|     2|     1|  8   5   x   x   x   x   x   x |  9       |       1       16      160      240 |       1       16      160      240 |    614400 |
       10|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv2/conv2.2/Relu_output_0|     0|     1|     1|  9   x   x   x   x   x   x   x | 10       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       11|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/Add_1_output_0           |     0|     2|     1| 10   6   x   x   x   x   x   x | 11       |       1       16      160      240 |       1       16      160      240 |    614400 |
       12|TIDL_PoolingLayer             |end/layer1/layer1.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 11   x   x   x   x   x   x   x | 12       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       13|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv3/conv3.3/Relu_output_0|     0|     1|     1| 12   x   x   x   x   x   x   x | 13       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       14|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/Add_2_output_0           |     0|     2|     1| 13   7   x   x   x   x   x   x | 14       |       1       16      160      240 |       1       16      160      240 |    614400 |
       15|TIDL_PoolingLayer             |layer1/layer1.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 14   x   x   x   x   x   x   x | 15       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       16|TIDL_ConvolutionLayer         |ackend/layer1/layer1.0/conv4/conv4.3/Relu_output_0|     0|     1|     1| 15   x   x   x   x   x   x   x | 16       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       17|TIDL_ConcatLayer              |/backend/layer1/layer1.0/Concat_output_0          |     0|     4|     1|  8  10  13  16   x   x   x   x | 17       |       1       16      160      240 |       1       64      160      240 |   2457600 |
       18|TIDL_ConvolutionLayer         |/layer1/layer1.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 17   x   x   x   x   x   x   x | 18       |       1       64      160      240 |       1       64      160      240 | 157286400 |
       19|TIDL_EltWiseLayer             |/backend/layer1/layer1.0/relu/Relu_output_0       |     0|     2|     1| 18   2   x   x   x   x   x   x | 19       |       1       64      160      240 |       1       64      160      240 |   4915200 |
       20|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv0/conv0.2/Relu_output_0|     0|     1|     1| 19   x   x   x   x   x   x   x | 20       |       1       64      160      240 |       1       64      160      240 | 159744000 |
       21|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_0           |     0|     1|     1| 20   x   x   x   x   x   x   x | 21       |       1       64      160      240 |       1       16      160      240 |         0 |
       22|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_1           |     0|     1|     1| 20   x   x   x   x   x   x   x | 22       |       1       64      160      240 |       1       16      160      240 |         0 |
       23|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_2           |     0|     1|     1| 20   x   x   x   x   x   x   x | 23       |       1       64      160      240 |       1       16      160      240 |         0 |
       24|TIDL_SliceLayer               |/backend/layer1/layer1.1/Split_output_3           |     0|     1|     1| 20   x   x   x   x   x   x   x | 24       |       1       64      160      240 |       1       16      160      240 |         0 |
       25|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv1/conv1.2/Relu_output_0|     0|     1|     1| 21   x   x   x   x   x   x   x | 25       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       26|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/Add_output_0             |     0|     2|     1| 25  22   x   x   x   x   x   x | 26       |       1       16      160      240 |       1       16      160      240 |    614400 |
       27|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv2/conv2.2/Relu_output_0|     0|     1|     1| 26   x   x   x   x   x   x   x | 27       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       28|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/Add_1_output_0           |     0|     2|     1| 27  23   x   x   x   x   x   x | 28       |       1       16      160      240 |       1       16      160      240 |    614400 |
       29|TIDL_PoolingLayer             |end/layer1/layer1.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 28   x   x   x   x   x   x   x | 29       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       30|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv3/conv3.3/Relu_output_0|     0|     1|     1| 29   x   x   x   x   x   x   x | 30       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       31|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/Add_2_output_0           |     0|     2|     1| 30  24   x   x   x   x   x   x | 31       |       1       16      160      240 |       1       16      160      240 |    614400 |
       32|TIDL_PoolingLayer             |layer1/layer1.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 31   x   x   x   x   x   x   x | 32       |       1       16      160      240 |       1       16      160      240 |   5529600 |
       33|TIDL_ConvolutionLayer         |ackend/layer1/layer1.1/conv4/conv4.3/Relu_output_0|     0|     1|     1| 32   x   x   x   x   x   x   x | 33       |       1       16      160      240 |       1       16      160      240 |  89088000 |
       34|TIDL_ConcatLayer              |/backend/layer1/layer1.1/Concat_output_0          |     0|     4|     1| 25  27  30  33   x   x   x   x | 34       |       1       16      160      240 |       1       64      160      240 |   2457600 |
       35|TIDL_ConvolutionLayer         |/layer1/layer1.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 34   x   x   x   x   x   x   x | 35       |       1       64      160      240 |       1       64      160      240 | 157286400 |
       36|TIDL_EltWiseLayer             |/backend/layer1/layer1.1/relu/Relu_output_0       |     0|     2|     1| 35  19   x   x   x   x   x   x | 36       |       1       64      160      240 |       1       64      160      240 |   4915200 |
       37|TIDL_ConvolutionLayer         |er2/layer2.0/downsample/downsample.0/Conv_output_0|     0|     1|     1| 36   x   x   x   x   x   x   x | 37       |       1       64      160      240 |       1      128       80      120 |  78643200 |
       38|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv0/conv0.2/Relu_output_0|     0|     1|     1| 36   x   x   x   x   x   x   x | 38       |       1       64      160      240 |       1      128      160      240 | 319488000 |
       39|TIDL_ConvolutionLayer         |/c1/Conv_output_0                                 |     0|     1|     1| 36   x   x   x   x   x   x   x | 39       |       1       64      160      240 |       1      128      160      240 | 314572800 |
       40|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_0           |     0|     1|     1| 38   x   x   x   x   x   x   x | 40       |       1      128      160      240 |       1       32      160      240 |         0 |
       41|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_1           |     0|     1|     1| 38   x   x   x   x   x   x   x | 41       |       1      128      160      240 |       1       32      160      240 |         0 |
       42|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_2           |     0|     1|     1| 38   x   x   x   x   x   x   x | 42       |       1      128      160      240 |       1       32      160      240 |         0 |
       43|TIDL_SliceLayer               |/backend/layer2/layer2.0/Split_output_3           |     0|     1|     1| 38   x   x   x   x   x   x   x | 43       |       1      128      160      240 |       1       32      160      240 |         0 |
       44|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv1/conv1.2/Relu_output_0|     0|     1|     1| 40   x   x   x   x   x   x   x | 44       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       45|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/Add_output_0             |     0|     2|     1| 44  41   x   x   x   x   x   x | 45       |       1       32      160      240 |       1       32      160      240 |   1228800 |
       46|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv2/conv2.2/Relu_output_0|     0|     1|     1| 45   x   x   x   x   x   x   x | 46       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       47|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/Add_1_output_0           |     0|     2|     1| 46  42   x   x   x   x   x   x | 47       |       1       32      160      240 |       1       32      160      240 |   1228800 |
       48|TIDL_PoolingLayer             |end/layer2/layer2.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 47   x   x   x   x   x   x   x | 48       |       1       32      160      240 |       1       32      160      240 |  11059200 |
       49|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv3/conv3.3/Relu_output_0|     0|     1|     1| 48   x   x   x   x   x   x   x | 49       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       50|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/Add_2_output_0           |     0|     2|     1| 49  43   x   x   x   x   x   x | 50       |       1       32      160      240 |       1       32      160      240 |   1228800 |
       51|TIDL_PoolingLayer             |layer2/layer2.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 50   x   x   x   x   x   x   x | 51       |       1       32      160      240 |       1       32      160      240 |  11059200 |
       52|TIDL_ConvolutionLayer         |ackend/layer2/layer2.0/conv4/conv4.3/Relu_output_0|     0|     1|     1| 51   x   x   x   x   x   x   x | 52       |       1       32      160      240 |       1       32      160      240 | 355123200 |
       53|TIDL_ConcatLayer              |/backend/layer2/layer2.0/Concat_output_0          |     0|     4|     1| 44  46  49  52   x   x   x   x | 53       |       1       32      160      240 |       1      128      160      240 |   4915200 |
       54|TIDL_ConvolutionLayer         |/layer2/layer2.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 53   x   x   x   x   x   x   x | 54       |       1      128      160      240 |       1      128      160      240 | 629145600 |
       55|TIDL_PoolingLayer             |d/layer2/layer2.0/conv_downsample/MaxPool_output_0|     0|     1|     1| 54   x   x   x   x   x   x   x | 55       |       1      128      160      240 |       1      128       80      120 |  11059200 |
       56|TIDL_EltWiseLayer             |/backend/layer2/layer2.0/relu/Relu_output_0       |     0|     2|     1| 55  37   x   x   x   x   x   x | 56       |       1      128       80      120 |       1      128       80      120 |   2457600 |
       57|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv0/conv0.2/Relu_output_0|     0|     1|     1| 56   x   x   x   x   x   x   x | 57       |       1      128       80      120 |       1      128       80      120 | 158515200 |
       58|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_0           |     0|     1|     1| 57   x   x   x   x   x   x   x | 58       |       1      128       80      120 |       1       32       80      120 |         0 |
       59|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_1           |     0|     1|     1| 57   x   x   x   x   x   x   x | 59       |       1      128       80      120 |       1       32       80      120 |         0 |
       60|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_2           |     0|     1|     1| 57   x   x   x   x   x   x   x | 60       |       1      128       80      120 |       1       32       80      120 |         0 |
       61|TIDL_SliceLayer               |/backend/layer2/layer2.1/Split_output_3           |     0|     1|     1| 57   x   x   x   x   x   x   x | 61       |       1      128       80      120 |       1       32       80      120 |         0 |
       62|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv1/conv1.2/Relu_output_0|     0|     1|     1| 58   x   x   x   x   x   x   x | 62       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       63|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/Add_output_0             |     0|     2|     1| 62  59   x   x   x   x   x   x | 63       |       1       32       80      120 |       1       32       80      120 |    307200 |
       64|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv2/conv2.2/Relu_output_0|     0|     1|     1| 63   x   x   x   x   x   x   x | 64       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       65|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/Add_1_output_0           |     0|     2|     1| 64  60   x   x   x   x   x   x | 65       |       1       32       80      120 |       1       32       80      120 |    307200 |
       66|TIDL_PoolingLayer             |end/layer2/layer2.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 65   x   x   x   x   x   x   x | 66       |       1       32       80      120 |       1       32       80      120 |   2764800 |
       67|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv3/conv3.3/Relu_output_0|     0|     1|     1| 66   x   x   x   x   x   x   x | 67       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       68|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/Add_2_output_0           |     0|     2|     1| 67  61   x   x   x   x   x   x | 68       |       1       32       80      120 |       1       32       80      120 |    307200 |
       69|TIDL_PoolingLayer             |layer2/layer2.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 68   x   x   x   x   x   x   x | 69       |       1       32       80      120 |       1       32       80      120 |   2764800 |
       70|TIDL_ConvolutionLayer         |ackend/layer2/layer2.1/conv4/conv4.3/Relu_output_0|     0|     1|     1| 69   x   x   x   x   x   x   x | 70       |       1       32       80      120 |       1       32       80      120 |  88780800 |
       71|TIDL_ConcatLayer              |/backend/layer2/layer2.1/Concat_output_0          |     0|     4|     1| 62  64  67  70   x   x   x   x | 71       |       1       32       80      120 |       1      128       80      120 |   1228800 |
       72|TIDL_ConvolutionLayer         |/layer2/layer2.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 71   x   x   x   x   x   x   x | 72       |       1      128       80      120 |       1      128       80      120 | 157286400 |
       73|TIDL_EltWiseLayer             |/backend/layer2/layer2.1/relu/Relu_output_0       |     0|     2|     1| 72  56   x   x   x   x   x   x | 73       |       1      128       80      120 |       1      128       80      120 |   2457600 |
       74|TIDL_ConvolutionLayer         |er3/layer3.0/downsample/downsample.0/Conv_output_0|     0|     1|     1| 73   x   x   x   x   x   x   x | 74       |       1      128       80      120 |       1      256       40       60 |  78643200 |
       75|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv0/conv0.2/Relu_output_0|     0|     1|     1| 73   x   x   x   x   x   x   x | 75       |       1      128       80      120 |       1      256       80      120 | 317030400 |
       76|TIDL_ConvolutionLayer         |/c2/Conv_output_0                                 |     0|     1|     1| 73   x   x   x   x   x   x   x | 76       |       1      128       80      120 |       1      128       80      120 | 157286400 |
       77|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_0           |     0|     1|     1| 75   x   x   x   x   x   x   x | 77       |       1      256       80      120 |       1       64       80      120 |         0 |
       78|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_1           |     0|     1|     1| 75   x   x   x   x   x   x   x | 78       |       1      256       80      120 |       1       64       80      120 |         0 |
       79|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_2           |     0|     1|     1| 75   x   x   x   x   x   x   x | 79       |       1      256       80      120 |       1       64       80      120 |         0 |
       80|TIDL_SliceLayer               |/backend/layer3/layer3.0/Split_output_3           |     0|     1|     1| 75   x   x   x   x   x   x   x | 80       |       1      256       80      120 |       1       64       80      120 |         0 |
       81|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv1/conv1.2/Relu_output_0|     0|     1|     1| 77   x   x   x   x   x   x   x | 81       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       82|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/Add_output_0             |     0|     2|     1| 81  78   x   x   x   x   x   x | 82       |       1       64       80      120 |       1       64       80      120 |    614400 |
       83|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv2/conv2.2/Relu_output_0|     0|     1|     1| 82   x   x   x   x   x   x   x | 83       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       84|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/Add_1_output_0           |     0|     2|     1| 83  79   x   x   x   x   x   x | 84       |       1       64       80      120 |       1       64       80      120 |    614400 |
       85|TIDL_PoolingLayer             |end/layer3/layer3.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1| 84   x   x   x   x   x   x   x | 85       |       1       64       80      120 |       1       64       80      120 |   5529600 |
       86|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv3/conv3.3/Relu_output_0|     0|     1|     1| 85   x   x   x   x   x   x   x | 86       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       87|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/Add_2_output_0           |     0|     2|     1| 86  80   x   x   x   x   x   x | 87       |       1       64       80      120 |       1       64       80      120 |    614400 |
       88|TIDL_PoolingLayer             |layer3/layer3.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1| 87   x   x   x   x   x   x   x | 88       |       1       64       80      120 |       1       64       80      120 |   5529600 |
       89|TIDL_ConvolutionLayer         |ackend/layer3/layer3.0/conv4/conv4.3/Relu_output_0|     0|     1|     1| 88   x   x   x   x   x   x   x | 89       |       1       64       80      120 |       1       64       80      120 | 354508800 |
       90|TIDL_ConcatLayer              |/backend/layer3/layer3.0/Concat_output_0          |     0|     4|     1| 81  83  86  89   x   x   x   x | 90       |       1       64       80      120 |       1      256       80      120 |   2457600 |
       91|TIDL_ConvolutionLayer         |/layer3/layer3.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1| 90   x   x   x   x   x   x   x | 91       |       1      256       80      120 |       1      256       80      120 | 629145600 |
       92|TIDL_PoolingLayer             |d/layer3/layer3.0/conv_downsample/MaxPool_output_0|     0|     1|     1| 91   x   x   x   x   x   x   x | 92       |       1      256       80      120 |       1      256       40       60 |   5529600 |
       93|TIDL_EltWiseLayer             |/backend/layer3/layer3.0/relu/Relu_output_0       |     0|     2|     1| 92  74   x   x   x   x   x   x | 93       |       1      256       40       60 |       1      256       40       60 |   1228800 |
       94|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv0/conv0.2/Relu_output_0|     0|     1|     1| 93   x   x   x   x   x   x   x | 94       |       1      256       40       60 |       1      256       40       60 | 157900800 |
       95|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_0           |     0|     1|     1| 94   x   x   x   x   x   x   x | 95       |       1      256       40       60 |       1       64       40       60 |         0 |
       96|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_1           |     0|     1|     1| 94   x   x   x   x   x   x   x | 96       |       1      256       40       60 |       1       64       40       60 |         0 |
       97|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_2           |     0|     1|     1| 94   x   x   x   x   x   x   x | 97       |       1      256       40       60 |       1       64       40       60 |         0 |
       98|TIDL_SliceLayer               |/backend/layer3/layer3.1/Split_output_3           |     0|     1|     1| 94   x   x   x   x   x   x   x | 98       |       1      256       40       60 |       1       64       40       60 |         0 |
       99|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv1/conv1.2/Relu_output_0|     0|     1|     1| 95   x   x   x   x   x   x   x | 99       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      100|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/Add_output_0             |     0|     2|     1| 99  96   x   x   x   x   x   x |100       |       1       64       40       60 |       1       64       40       60 |    153600 |
      101|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv2/conv2.2/Relu_output_0|     0|     1|     1|100   x   x   x   x   x   x   x |101       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      102|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/Add_1_output_0           |     0|     2|     1|101  97   x   x   x   x   x   x |102       |       1       64       40       60 |       1       64       40       60 |    153600 |
      103|TIDL_PoolingLayer             |end/layer3/layer3.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1|102   x   x   x   x   x   x   x |103       |       1       64       40       60 |       1       64       40       60 |   1382400 |
      104|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv3/conv3.3/Relu_output_0|     0|     1|     1|103   x   x   x   x   x   x   x |104       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      105|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/Add_2_output_0           |     0|     2|     1|104  98   x   x   x   x   x   x |105       |       1       64       40       60 |       1       64       40       60 |    153600 |
      106|TIDL_PoolingLayer             |layer3/layer3.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1|105   x   x   x   x   x   x   x |106       |       1       64       40       60 |       1       64       40       60 |   1382400 |
      107|TIDL_ConvolutionLayer         |ackend/layer3/layer3.1/conv4/conv4.3/Relu_output_0|     0|     1|     1|106   x   x   x   x   x   x   x |107       |       1       64       40       60 |       1       64       40       60 |  88627200 |
      108|TIDL_ConcatLayer              |/backend/layer3/layer3.1/Concat_output_0          |     0|     4|     1| 99 101 104 107   x   x   x   x |108       |       1       64       40       60 |       1      256       40       60 |    614400 |
      109|TIDL_ConvolutionLayer         |/layer3/layer3.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1|108   x   x   x   x   x   x   x |109       |       1      256       40       60 |       1      256       40       60 | 157286400 |
      110|TIDL_EltWiseLayer             |/backend/layer3/layer3.1/relu/Relu_output_0       |     0|     2|     1|109  93   x   x   x   x   x   x |110       |       1      256       40       60 |       1      256       40       60 |   1228800 |
      111|TIDL_ConvolutionLayer         |er4/layer4.0/downsample/downsample.0/Conv_output_0|     0|     1|     1|110   x   x   x   x   x   x   x |111       |       1      256       40       60 |       1      512       20       30 |  78643200 |
      112|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv0/conv0.2/Relu_output_0|     0|     1|     1|110   x   x   x   x   x   x   x |112       |       1      256       40       60 |       1      512       40       60 | 315801600 |
      113|TIDL_ConvolutionLayer         |/c3/Conv_output_0                                 |     0|     1|     1|110   x   x   x   x   x   x   x |113       |       1      256       40       60 |       1      128       40       60 |  78643200 |
      114|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_0           |     0|     1|     1|112   x   x   x   x   x   x   x |114       |       1      512       40       60 |       1      128       40       60 |         0 |
      115|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_1           |     0|     1|     1|112   x   x   x   x   x   x   x |115       |       1      512       40       60 |       1      128       40       60 |         0 |
      116|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_2           |     0|     1|     1|112   x   x   x   x   x   x   x |116       |       1      512       40       60 |       1      128       40       60 |         0 |
      117|TIDL_SliceLayer               |/backend/layer4/layer4.0/Split_output_3           |     0|     1|     1|112   x   x   x   x   x   x   x |117       |       1      512       40       60 |       1      128       40       60 |         0 |
      118|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv1/conv1.2/Relu_output_0|     0|     1|     1|114   x   x   x   x   x   x   x |118       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      119|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/Add_output_0             |     0|     2|     1|118 115   x   x   x   x   x   x |119       |       1      128       40       60 |       1      128       40       60 |    307200 |
      120|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv2/conv2.2/Relu_output_0|     0|     1|     1|119   x   x   x   x   x   x   x |120       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      121|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/Add_1_output_0           |     0|     2|     1|120 116   x   x   x   x   x   x |121       |       1      128       40       60 |       1      128       40       60 |    307200 |
      122|TIDL_PoolingLayer             |end/layer4/layer4.0/conv3/conv3.0/MaxPool_output_0|     0|     1|     1|121   x   x   x   x   x   x   x |122       |       1      128       40       60 |       1      128       40       60 |   2764800 |
      123|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv3/conv3.3/Relu_output_0|     0|     1|     1|122   x   x   x   x   x   x   x |123       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      124|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/Add_2_output_0           |     0|     2|     1|123 117   x   x   x   x   x   x |124       |       1      128       40       60 |       1      128       40       60 |    307200 |
      125|TIDL_PoolingLayer             |layer4/layer4.0/conv4/conv4.0/AveragePool_output_0|     0|     1|     1|124   x   x   x   x   x   x   x |125       |       1      128       40       60 |       1      128       40       60 |   2764800 |
      126|TIDL_ConvolutionLayer         |ackend/layer4/layer4.0/conv4/conv4.3/Relu_output_0|     0|     1|     1|125   x   x   x   x   x   x   x |126       |       1      128       40       60 |       1      128       40       60 | 354201600 |
      127|TIDL_ConcatLayer              |/backend/layer4/layer4.0/Concat_output_0          |     0|     4|     1|118 120 123 126   x   x   x   x |127       |       1      128       40       60 |       1      512       40       60 |   1228800 |
      128|TIDL_ConvolutionLayer         |/layer4/layer4.0/conv_out/conv_out.0/Conv_output_0|     0|     1|     1|127   x   x   x   x   x   x   x |128       |       1      512       40       60 |       1      512       40       60 | 629145600 |
      129|TIDL_PoolingLayer             |d/layer4/layer4.0/conv_downsample/MaxPool_output_0|     0|     1|     1|128   x   x   x   x   x   x   x |129       |       1      512       40       60 |       1      512       20       30 |   2764800 |
      130|TIDL_EltWiseLayer             |/backend/layer4/layer4.0/relu/Relu_output_0       |     0|     2|     1|129 111   x   x   x   x   x   x |130       |       1      512       20       30 |       1      512       20       30 |    614400 |
      131|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv0/conv0.2/Relu_output_0|     0|     1|     1|130   x   x   x   x   x   x   x |131       |       1      512       20       30 |       1      512       20       30 | 157593600 |
      132|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_0           |     0|     1|     1|131   x   x   x   x   x   x   x |132       |       1      512       20       30 |       1      128       20       30 |         0 |
      133|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_1           |     0|     1|     1|131   x   x   x   x   x   x   x |133       |       1      512       20       30 |       1      128       20       30 |         0 |
      134|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_2           |     0|     1|     1|131   x   x   x   x   x   x   x |134       |       1      512       20       30 |       1      128       20       30 |         0 |
      135|TIDL_SliceLayer               |/backend/layer4/layer4.1/Split_output_3           |     0|     1|     1|131   x   x   x   x   x   x   x |135       |       1      512       20       30 |       1      128       20       30 |         0 |
      136|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv1/conv1.2/Relu_output_0|     0|     1|     1|132   x   x   x   x   x   x   x |136       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      137|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/Add_output_0             |     0|     2|     1|136 133   x   x   x   x   x   x |137       |       1      128       20       30 |       1      128       20       30 |     76800 |
      138|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv2/conv2.2/Relu_output_0|     0|     1|     1|137   x   x   x   x   x   x   x |138       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      139|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/Add_1_output_0           |     0|     2|     1|138 134   x   x   x   x   x   x |139       |       1      128       20       30 |       1      128       20       30 |     76800 |
      140|TIDL_PoolingLayer             |end/layer4/layer4.1/conv3/conv3.0/MaxPool_output_0|     0|     1|     1|139   x   x   x   x   x   x   x |140       |       1      128       20       30 |       1      128       20       30 |    691200 |
      141|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv3/conv3.3/Relu_output_0|     0|     1|     1|140   x   x   x   x   x   x   x |141       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      142|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/Add_2_output_0           |     0|     2|     1|141 135   x   x   x   x   x   x |142       |       1      128       20       30 |       1      128       20       30 |     76800 |
      143|TIDL_PoolingLayer             |layer4/layer4.1/conv4/conv4.0/AveragePool_output_0|     0|     1|     1|142   x   x   x   x   x   x   x |143       |       1      128       20       30 |       1      128       20       30 |    691200 |
      144|TIDL_ConvolutionLayer         |ackend/layer4/layer4.1/conv4/conv4.3/Relu_output_0|     0|     1|     1|143   x   x   x   x   x   x   x |144       |       1      128       20       30 |       1      128       20       30 |  88550400 |
      145|TIDL_ConcatLayer              |/backend/layer4/layer4.1/Concat_output_0          |     0|     4|     1|136 138 141 144   x   x   x   x |145       |       1      128       20       30 |       1      512       20       30 |    307200 |
      146|TIDL_ConvolutionLayer         |/layer4/layer4.1/conv_out/conv_out.0/Conv_output_0|     0|     1|     1|145   x   x   x   x   x   x   x |146       |       1      512       20       30 |       1      512       20       30 | 157286400 |
      147|TIDL_EltWiseLayer             |/backend/layer4/layer4.1/relu/Relu_output_0       |     0|     2|     1|146 130   x   x   x   x   x   x |147       |       1      512       20       30 |       1      512       20       30 |    614400 |
      148|TIDL_ConvolutionLayer         |/c4/Conv_output_0                                 |     0|     1|     1|147   x   x   x   x   x   x   x |148       |       1      512       20       30 |       1      128       20       30 |  39321600 |
      149|TIDL_ResizeLayer              |/Resize_output_0                                  |     0|     1|     1|148   x   x   x   x   x   x   x |149       |       1      128       20       30 |       1      128       40       60 |   1228800 |
      150|TIDL_ConcatLayer              |/Concat_output_0                                  |     0|     2|     1|149 113   x   x   x   x   x   x |150       |       1      128       40       60 |       1      256       40       60 |    614400 |
      151|TIDL_ConvolutionLayer         |/fue_c4_c3/Conv_output_0                          |     0|     1|     1|150   x   x   x   x   x   x   x |151       |       1      256       40       60 |       1      128       40       60 | 707788800 |
      152|TIDL_ResizeLayer              |/Resize_1_output_0                                |     0|     1|     1|151   x   x   x   x   x   x   x |152       |       1      128       40       60 |       1      128       80      120 |   4915200 |
      153|TIDL_ConcatLayer              |/Concat_1_output_0                                |     0|     2|     1|152  76   x   x   x   x   x   x |153       |       1      128       80      120 |       1      256       80      120 |   2457600 |
      154|TIDL_ConvolutionLayer         |/fue_c3_c2/Conv_output_0                          |     0|     1|     1|153   x   x   x   x   x   x   x |154       |       1      256       80      120 |       1      128       80      120 |2831155200 |
      155|TIDL_ResizeLayer              |/Resize_2_output_0                                |     0|     1|     1|154   x   x   x   x   x   x   x |155       |       1      128       80      120 |       1      128      160      240 |  19660800 |
      156|TIDL_ConcatLayer              |/Concat_2_output_0                                |     0|     2|     1|155  39   x   x   x   x   x   x |156       |       1      128      160      240 |       1      256      160      240 |   9830400 |
      157|TIDL_ConvolutionLayer         |/fue_c1_c0/Conv_output_0                          |     0|     1|     1|156   x   x   x   x   x   x   x |157       |       1      256      160      240 |       1      128      160      240 |11324620800 |
      158|TIDL_ConvolutionLayer         |/mask_pred/Conv_output_0                          |     0|     1|     1|157   x   x   x   x   x   x   x |158       |       1      128      160      240 |       1        9      160      240 |  44236800 |
      159|TIDL_ResizeLayer              |/Resize_3_outp
    ------------------ Network Compiler Traces -----------------------------
    successful Memory allocation
    ut_0                                |     0|     1|     1|158   x   x   x   x   x   x   x |159       |       1        9      160      240 |       1        9      640      960 |  22118400 |
      160|TIDL_ArgMaxLayer              |629                                               |     0|     1|     1|159   x   x   x   x   x   x   x |160       |       1        9      640      960 |       1        1      640      960 |    614400 |
      161|TIDL_DataLayer                |629                                               |     0|     1|    -1|160   x   x   x   x   x   x   x |  0       |       1        1      640      960 |       0        0        0        0 |         0 |
    Total Giga Macs : 27.2301
    cp /home/yuming/Projects/TDA4VM/tidl_tools_all/device_config.cfg /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/import_model.txt.perf_sim_config.txt
    cd /home/yuming/Projects/TDA4VM/tidl_tools_all && ./ti_cnnperfsim.out /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/import_model.txt.perf_sim_config.txt 1601 0 2
    Network buffer segments:
    buf(0), offset(       0), size(  290496)
    buf(1), offset( 1600960), size( 4003026)
    buf(2), offset(  290496), size( 1310464)
    /home/yuming/Projects/TDA4VM/tidl_tools_all/tidl_graphVisualiser.out /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_net.bin
    /home/yuming/Projects/TDA4VM/tidl_tools_all/tidl_dump.out -model /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_net.bin -io /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_io_1.bin -perfsim -o /home/yuming/Projects/XAIEdge/test_samples/tda4/onnx/1111/obstacle_tidl_net.bin.txt
    **               TIDL Model Checker               **
    INFORMATION: [TIDL_ResizeLayer] /Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /Resize_1 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /Resize_2 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] /Resize_3 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    **          4 WARNINGS          0 ERRORS          **
    May I know if this is related the problem in the below thread which will fix in SDK9.1?
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1269458/model-compiles-and-runs-in-tidl-x86-docker-without-error-but-produces-vx_zone_error-on-devboard-with-onnx-backend/4812369
    Thanks a lot!
    Kevin
  • Hello Kevin,
    The engineer is OoO for regional holidays until 11/20 so please expect 5~6 business-day delay in response.
    Apologies for the inconvenience and thank you for your patience.
    Josue
  • Hi Josue,
    Is there any update internally so far?
    Currently the most urgent feature asked by customer is that if there is an abnormal exit occurred, the only method we could use is to reboot to clear the allocated memory. However,  in the upgrade process, the reboot is not convenient and will loss data.
    Hence, may I know if we could use any other method to clear the allocated memory when an abnormal exit occurred?
    Kevin
  • Hi Peng,
    Which flow you are using ? is this a Vision Apps OpenVx based or TIDL-RT ?
    Secondly, can you confirm is this issue coming on 9.1 sdk ? (It has all the recent fixes added in it)
    If this is coming on  9.1 as well please share the logs so we can continue debug to next
  • Hi Pratik,
    Thanks for your reply!
    Customer is using the OpenVx flow, not using the TIDL-RT.
    Customer is working on SDK8.6, and glad to hear that we have some fixes in the SDK9.1, we will have a try for the SDK9.1 later.
    As for now, apart from the reboot, do we have any other method to clear the allocated memory when an abnormal exit occurred?
    Kevin
  • Hi Kevin,
    Understand the request and concern, customer is on 8.6 SDK side.
    I have gone through above posted question thoroughly.
    The problem only happens when we exit the current run, and rerun the application.
    It seems like you are exiting the current OpenVx based application using external interrupt (Cltr + C) to halt the current OpenVX based process.
    And it appears to me that the Deinit is not occurring in this case, that leads to not clearing the previously allocate memory behavior , and the next rerun does not have the sufficient memory.
    The possible solution to fix this issue could be handle the interrupt, i.e whenever you halt the process, you can call deinit.
    To implement this functionality you can refer to the our demo example app_fd_exchange in vision apps.
    Here is the path : vision_apps/apps/basic_demos/app_fd_exchange/main_consumer.c
    Would recommend to see how we have implemented Signal Handler method, that internally calls AppDeinit method, you can deinit for your custom application.
    223static void App_intSigHandler(int sig)
    224{
    225    App_Context    *appCntxt = &gAppCntxt;
    226    int32_t         status;
    227
    228    status = App_deInit(appCntxt);
    229
    230    exit(status);
    231}
