Part Number: DRA829V
Hi TI Team,
We are using PCIe to interface with FPGA and operating host PCIe in Root port mode.
We are accessing BAR memory and can read 32bit registers OK.
root@dra829-a72:~# k3conf write 0x18114000 0x12341234abcdabcd Value at addr 0x18114000 = 0xabcdabcd
root@dra829-a72:~# k3conf read 0x18114000
root@dra829-a72:~# lspci -v
0000:01:00.0 Memory controller: Xilinx Corporation Device 7022
0001:00:00.0 PCI bridge: Texas Instruments Device b00d (prog-if 00 [Normal decode]) |
AXI bus on FPGA side uses 64bit and we would like to read/write 64bit values. Could you please let us know the procedure to enable 64bit PCIe read/write access ?
Swapna
