AM625: unable to boot Android 9.0
Part Number: AM625
Other Parts Discussed in Thread: SK-AM62, SK-AM62B
decompress AM62x_userdebug_09.00.00_emmc.tar.gz
SK-AM62 E2, HDMI, Mouse connected.
cp tiboot3.bin, tispl.bin, u-boot.img to SD card to boot up. then flash from SD card according to https://software-dl.ti.com/processor-sdk-android/esd/AM62X/09_00_00/docs/devices/AM62X/android/Application_Notes_Android_Bootloader_SD_Card.html
flash command on gp board:
sudo ./flashall.sh --board am62x-sk
power off the board, remove SD card, switch to eMMC boot mode. power on again.
log hang on below:
tony@tony-HP:~$ sudo picocom -b 115200 -r -l /dev/ttyUSB0
[sudo] password for tony:
picocom v2.2
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 115200
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : yes
nolock is      : yes
send_cmd is    : sz -vv
receive_cmd is : rz -vv -E
imap is        :
omap is        :
emap is        : crcrlf,delbs,
Type [C-a] [C-h] to see available commands
Terminal ready
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:52:36 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC1
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from MMC... OK
init_env from device 9 not supported!
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-diLoading Android boot partition...
switch to partitions #0, OK
mmc0(part 0) is current device
rom DT.
[    0.000000][    T0] psci: PSCIv1.1 detected in firmware.
[    0.000000][    T0] psci: Using standard PSCI v0.2 funcabled.
[    0.000000][    T0] rcu: 	RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=4.
[    0.000000][    T0] rcu: 	RCU pri[    T0] 	Trampoline variant of Tasks RCU enabled.
[    0.000000][    T0] 	Tracing variant of Tasks RCU enabled.
[    0.000000.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.086178][    T1] PTP clock support registered
[    0.086 Advanced Linux Sound Architecture Driver Initialized.
[    0.088888][    T1] clocksource: Switched to clocksource arch_sys_counter
[    0.089551][    T1] VFS: Disk quotas dquot_6.6.0
[    0.089620][    T1] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.090547][    T1] NET: Registered s hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.092647][    T1] tcp_listen_portaddr_hash hash table entries   T1] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.093030][    T1] TCP established hash tab 0.093411][    T1] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.093930][    T1] TCP: Hash tables NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.094612][    T1] NET: Registered PF_XDP protocol family
[    0.094634][T48] Trying to unpack rootfs image as initramfs...
[    0.095755][    T1] hw perfevents: enabled with armv8_cortex_a53 PMU drivkvm [1]: vgic interrupt IRQ9
[    0.202446][    T1] kvm [1]: Protected nVHE mode initialized successfully
[    0.204473][    T1] Initialise system trusted keyrings
[    0.204980][    T1] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.215789][    T1] fuse: init (API version 7.37)
[    0.25397][    T1] Asymmetric key parser 'x509' registered
[    0.257582][    T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 238)
[    0.258013][    T1] io scheduler mq-deadline registered
[    0.258038][    T1] io scheduler kyber registered
[    0.258266][    T1] io scheduler bfq registered
[    0.260667][    T1] pinctrl-single 4084000.pinctrl: 3 T1] loop: module loaded
[    0.295331][    T1] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[   son A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[    0.296102][    T1] MACsec IEEE 802.1AE
[    0.296752][    T1] tun: Universal TUN/TAP device driver, 1.6
[    0.298399][ e driver xpad
[    0.299029][    T1] gspca_main: v2.14.0 registered
[    0.299133][    T1] usbcore: registered new interface dvent: version 1.0.3
[    0.299966][    T1] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[    0.302285][    T1] sdhci: Secure Digital Host Controller Interface driver
[    0.302323][    T1] sdhci: Copyright(c) Pierre Ossman
[    0.302332][    T1] sdhci-pltfm: SDHCI platfordump compression: deflate
[    0.395044][    T1] ALSA device list:
[    0.395084][    T1]   No soundcards found.
[    0.697758][   T48] Freeing initrd memory: 14200K
[    0.701666]nel module /lib/modules/k3-udma-glue.ko
[    0.868038][    T1] init: Loading module /lib/modules/rtc-ti-k3.ko with args ''
[    0.869563][   T48] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.871187][    T1] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    0.871246][    T1] rtc-ti-k3 2b1f0000.rkernel module /lib/modules/leds-tlc591xx.ko
[    0.938064][    T1] init: Loading module /lib/modules/omap-mailbox.ko with args ''
[    0.939857][    T1] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.940254][    T1] init: Loaded kernel module /lib/modules/omap-mailbox.ko
[    0.940622][  rgs ''
[    0.941888][    T1] init: Loaded kernel module /lib/modules/palmas.ko
[    0.942266][    T1] init: Loading module /lo
[    2.499592][    T1] init: Loading module /lib/modules/cdns-dphy-rx.ko with args ''
[    2.501280][    T1] init: Loaded keule /lib/modules/phy-can-transceiver.ko with args ''
[    2.507587][    T1] init: Loaded kernel module /lib/modules/phy-can-traory node m4f-dma-memory@9cb00000
[    2.525202][    T1] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    2.52 failed with error -2
[    2.528513][   T90] remoteproc remoteproc0: powering up 5000000.m4fss
[    2.528577][   T90] remotepr-fw failed with error -2
[    2.528590][   T90] remoteproc remoteproc0: request_firmware failed: -2
[    2.529523][    T1] pla a different host, programmed state (0) != actual state (1)
[    2.529676][    T1] platform 78000000.r5f: configured R5F for IPf: assigned reserved memory node r5f-dma-memory@9da00000
[    2.530137][    T1] remoteproc remoteproc1: 78000000.r5f is availabing to 78000000.r5f
[    2.530747][    T1] platform 78000000.r5f: R5F core initialized in IPC-only mode
[    2.530767][    T1]78000000.r5f is now attached
[    2.531555][    T1] init: Loaded kernel module /lib/modules/ti_k3_r5_remoteproc.ko
[    2.5319rpmsg_bus virtio0: rpmsg host is online
[    2.539647][    T1] init: Loaded kernel module /lib/modules/virtio_rpmsg_bus.ko
[  uss.ko with args ''
[    2.542268][    T6] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    2.542505   T1] init: Loaded kernel module /lib/modules/pruss.ko
[    2.546855][    T1] init: Loading module /lib/modules/spi-cadence-qul module /lib/modules/spi-omap2-mcspi.ko
[    2.554060][    T1] init: Loading module /lib/modules/optee.ko with args ''
[    2  2.557212][    T1] optee: revision 3.20 (8e74d476)
[    2.557427][    T1] optee: dynamic shared memory is enabled
[    2.5576ure-sensor: invalid resource
[    2.561639][    T1] k3-j72xx-soc-thermal: probe of b00000.temperature-sensor failed with error lib/modules/k3_j72xx_bandgap.ko
[    2.562527][    T1] init: Loading module /lib/modules/dwc3-am62.ko with args ''
[    2.5643e(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    2.566805][    T1] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
/modules/dwc3-of-simple.ko with args ''
[    2.572694][    T1] init: Loaded kernel module /lib/modules/dwc3-of-simple.ko
[    2.573117][    T1] init: Loading module /lib/modules/tps6598x.ko with args ''
[    2.600157][    T1] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[    2.600610]][    T1] init: [libfs_mgr]Created logical partition vendor_a on device /dev/block/dm-1
[    3.624068][    T1] init: [libfs_mgr]Skipping zero-length logical partition: vendor_b
[    3.624231][    T1] init: DSU not detected, proceeding with normal boot
[    3.634457][    T1] init: [libfs_avb]Invalid hash sizerify vbmeta digest
[    3.634545][    T1] init: [libfs_avb]Returning avb_handle with status: Success
[    3.635108][    T1] inev/block/dm-0 4096 4096 314369 314369 sha1 85dbd07d92885ee10501348c25cbf2f41feabb5f 8a11e4d415b4fb2ade2c566828364ff4bca475e1 10 : [libfs_mgr]__mount(source=/dev/block/dm-2,target=/system,type=ext4)=0: Success
[    3.649389][    T1] init: Switching root tostorecon: No such file or directory.
[    4.549322][    T1] selinux:
[    4.549440][    T1] selinux: SELinux:  Could not stat7][    T1] selinux:
[    4.550856][    T1] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[   Added '/init.environ.rc' to import list
[    4.569162][    T1] init: Added '/system/etc/init/hw/init.usb.rc' to import list
[port list
[    4.569262][    T1] init: Added '/vendor/etc/init/hw/init.am62x.rc' to import list
[    4.569287][    T1] init: A2x.rc': open() failed: No such file or directory
[    4.578863][    T1] init: Parsing file /vendor/etc/init/hw/init.am62x.rc....rc...
[    4.599248][    T1] init: Parsing file /system/etc/init/bootstat.rc...
[    4.600590][    T1] init: Parsing file /syystem/etc/init/cppreopts.rc...
[    4.605078][    T1] init: Parsing file /system/etc/init/credstore.rc...
[    4.606058][    Tit/gpuservice.rc...
[    4.612459][    T1] init: Parsing file /system/etc/init/gsid.rc...
[    4.613650][    T1] init: Parsingystem/etc/init/incidentd.rc...
[    4.618179][    T1] init: Parsing file /system/etc/init/init-debug.rc...
[    4.619145][    ...
[    4.624959][    T1] init: Parsing file /system/etc/init/logd.rc...
[    4.625928][    T1] init: Parsing file /system/etng file /system/etc/init/lpdumpd.rc...
[    4.627275][    T1] init: Parsing file /system/etc/init/mdnsd.rc...
[    4.627967][ t/etc/init': open() failed: No such file or directory
[    4.649263][    T1] init: Parsing directory /vendor/etc/init...
[     T1] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.5-external-service.rc...
[    4.653444][    T1] inillocator@4.0-service.img.rc...
[    4.657672][    T1] init: Parsing file /vendor/etc/init/android.hardware.graphics.composer@2.
[    4.659585][    T1] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.optee.rc...
[    4.660269][ware.media.omx@1.0-service.rc...
[    4.661097][    T1] init: Parsing file /vendor/etc/init/android.hardware.thermal@2.0-servic    T1] init: Parsing file /vendor/etc/init/boringssl_self_test.rc...
[    4.664233][    T1] init: Parsing file /vendor/etc/inirvice 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconfig/bootstrap)' (pid 106) process group...
[    4.832477][ueventd.rc' to import list
[    4.919977][  T107] ueventd: Added '/odm/etc/ueventd.rc' to import list
[    4.921181][  T107] ueventd: Parsing file /vendor/etc/ueventd.rc...
[    4.924401][  T107] ueventd: Parsing file /odm/etc/ueventd.rc...
[    4.924509][  T107] ueventd: Unable to read config file '/odm/etcd: LoadWithAliases was unable to load platform:reg-dummy
[    5.154681][  T109] ueventd: LoadWithAliases was unable to load of:09] ueventd: LoadWithAliases was unable to load of:NramoopsT(null)Cramoops
[    5.157517][  T109] ueventd: LoadWithAliases was T110] ueventd: Loading module /vendor/lib/modules/gpio-regulator.ko with args ''
[    5.159254][  T109] ueventd: LoadWithAliase61615][  T109] ueventd: Loading module /vendor/lib/modules/pvrsrvkm.ko with args ''
[    5.164561][  T110] ueventd: LoadWithAlibus
[    5.168298][  T110] ueventd: LoadWithAliases was unable to load of:NsramT(null)Cmmio-sram
[    5.175138][  T112] uevente to load of:NbusT(null)Csimple-bus
[    5.349503][  T110] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cpinctventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
[    5.356833][  T109] ueventd: Loaded kernel module /vendor/lib/modules/v4l2-async.ko
[    5.357129][  T109] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
[    5.357271][  T112] ueventd: Loading module /vendor/lib/368440][  T111] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
[    5.369689][  T111] ueventd: Loading modu70195][  T112] ueventd: Loading module /vendor/lib/modules/i2c-omap.ko with args ''
[    5.370195][  T110] ueventd: Loading module /vendor/lib/modules/pru_rproc.ko with args ''
[    :feature:,0000,0001,0002,0003,0004,0005,0006,0007,000B
[    5.400418][  T112] ueventd:
[    5.401062][  T109] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-tinfiguring MDIO in manual mode
[    5.567336][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-edma.ko
[      T87] omap_i2c 20000000.i2c: controller timed out
[    8.808582][  T109] ueventd: Loading module /vendor/lib/modules/rpmsg_ns[   12.053068][  T111] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format error
[   12.063052][  T111] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
[   12.063926][  T109d-soc-simple-card-utils.ko
[   12.071542][  T111] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
[  ithAliases was unable to load of:NgpioT(null)Cti,am64-gpioCti,keystone-gpio
[   12.127558][  T109] ueventd: Loaded kernel modulWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,0003,0004,0005,0006,0007,000B
[   12.162957][  T111] ueapexd: wait for '/dev/loop-control' took 7110ms
[   12.210344][  T111] cqhci: exports duplicate symbol cqhci_deactivate (owned reatest stack depth: 10400 bytes left
[   12.234554][  T108] apexd: Pre-allocated 15 loopback devices
[   12.240418][  T108] apexd: Scanning /system/apex for pre-installed ApexFiles
[   12.248319][  T108]ex/com.android.resolv.capex
[   12.257086][  T111] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format error
[   12.265652][  T108] apexd: Found pre-installed APEX /system/apex/com.android.ondevicepersonalization.apex
[   12.267021][  T111] ueventd: LoadWithAliases was un0][  T108] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
[   12.284963][  T111] ueventd: LoadWithAliases fgCsyscon
[   12.311180][  T108] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
[   12.322556][  T111] ueventd: Loading module /vendor/lib/modules/i2c-omap.k_wdt.ko with args ''
[   12.349374][  T108] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
[   12.354157][  T111] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
[   12.369684][  T108] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
[   12.3und pre-installed APEX /system/apex/com.android.mediaprovider.capex
[   12.379887][  T111] ueventd: Loaded kernel module /vendor/lib/modules/mcrc.ko
[   12.395454][  T108] apexd:th args ''
[   12.639536][  T108] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
[   12.654516][  T108] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
[   12.655520][  T107] ueventd: Loading module /vendor/lib/modules/v4l2-async.ko wit unable to load of:Nethernet-phyT(null)
[   12.968211][  T107] ueventd: LoadWithAliases was unable to load of:NmdioT(null)Cti,cpsw-mdioCti,davinci_mdio
[   12.993776][  T107] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-edma.ko with args ''
[   12.999539][  T151] EXT4-fs (loop2):fs (loop3): mounted filesystem without journal. Quota mode: none.
[   13.006340][  T150] apexd: Successfully mounted package /system/apex/com.android.runtime.apex on /apex/com.android13.933472][    T1] init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
[   13.942180][    T1] init: staready set
[   13.950902][    T1] init: processing action (SetMmapRndBits) from (<Builtin Action>:0)
[   13.960083][    T1] init: processing action (KeychordInit) from (<Builtin Action>:0)
[   13.968054][    T1] init: processing action (init) from (/system/etc/init/hw/init.rc:89)
[   13.977159][    T1] init: Command 'copy /system/etcory
[   14.021296][    T1] init: Command 'write /dev/blkio/blkio.weight 1000' action=init (/system/etc/init/hw/init.rc:230) took 0ms and failed: Unable to write to file '/dev/blkio/blkio.weight': open() failed: Permission denied
[   14.042397][    T1] init: Command 'write /dev/blkio/background/blkio.weight 200' action=init (/system/etc/init/hw/init.rc:231) took 0ms and failed: Unable to write ted: Permission denied
[   14.065762][    T1] init: Command 'write /dev/blkio/blkio.group_idle 0' action=init (/system/etc/init/7035][    T1] init: Sending signal 9 to service 'boringssl_self_test32' (pid 171) process group...
[   14.566840][    T1] libprocessgroup: Successfully killed process cgroup uid 0[   14.628370][    T1] init: SVC_EXEC service 'boringssl_self_test64' pid 173 (uid 0 gid 0+0 context default) started; waiting...
[   14.640404][    T1] init: Command 'exec_start boringssl_self_test64' action=ro.product.cpu.abilist64=*[   14.717140][    T1] init: Service 'boringssl_self_test64' (pid 173) exited with status 0 waiting took 0.117000 seconds
[   14.72794self_test64' (pid 173) process group...
[   14.737793][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 17ction (queue_property_triggers) from (<Builtin Action>:0)
[   14.963094][    T1] init: processing action (early-fs) from (/syst[   15.000390][    T1] init: processing action (early-fs) from (/vendor/etc/init/hw/init.am62x.rc:71)
[   15.009784][    T1] init: service 'vold' requested start, but it is already running [   15.142966][    T1] EXT4-fs (mmcblk0p13): recovery complete
[   15.149396][    T1] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Quota mode: none.
[   15.160580][    T1] inev/block/platform/bus@f0000/fa10000.mmc/by-name/persist,/mnt/vendor/persist,ext4)=0: Success
[   15.176162][    T1] EXT4-fs (mmcblk0p13): unmounting filesystem.
[   15.191027][    T1] init: [libfs_mgr]umount_retry(): unmount(/mnt/vendor/persist) succeeded
[   15.199999][    T1] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/mmcblk0p13
] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --early' action=fs (/vendor/etc/init/hw/init.am62x.rc:75) took 344msi.rc:25)
[   15.407786][    T1] init: processing action (post-fs) from (/system/etc/init/hw/init.rc:554)
[   15.417359][    T1] init: starting service 'exe[   15.505617][    T1] init: Service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' (pid 187) exited with status 0 waitin70 root system' action=post-fs (/system/etc/init/hw/init.rc:626) took 0ms and failed: mkdir() failed on /metadata/staged-installit: Command 'mkdir /metadata/sepolicy 0700 root root' action=post-fs (/system/etc/init/hw/init.rc:627) took 0ms and failed: mkdi'mkdir /metadata/gsi 0771 root system' action=post-fs (/system/etc/init/gsid.rc:9) took 0ms and failed: mkdir() failed on /metadec 3 (/system/bin/recovery-refresh)' (pid 188) process group...
[   15.939739][    T1] libprocessgroup: Successfully killed pro[   16.047142][    T1] init: starting service 'vendor.boot-hal-1-2'...
[   16.074370][    T1] init: starting service 'tee-supplicant'...
[   16.092477]][    T1] init: Service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' (pid 196) exited with status 0 waiting took 0.ignal 9 to service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' (pid 196) process group...
[   16.215448][    T1] libprocessgroup: Successfully killed process cgro[   16.432249][    T1] init: Command 'class_start animation' action=late-fs (/vendor/etc/init/hw/init.am62x.rc:90) took 141ms an[   16.484609][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.0::IKeymasterDevice/default' from pid: 163 (/system/bin/hwservicemanager)
[   16.502252][    T1] init: start_waiting_for_ntrol message: Processed ctl.interface_start for 'android.hardware.keymaster@3.0::IKeymasterDevice/default' from pid: 163 (/systit: processing action (late-fs) from (/vendor/etc/init/init.optee.rc:4)
[   16.549434][    T1] init: starting service 'wait_for_keymaster_optee'...
[   16.571106][    T1] init: 176] vold: Failed to create /metadata/vold: Read-only file system
[   17.443895][  T176] vold: read_key failed in mountFstab
[[   17.471708][    T1] vdc: vdc terminated by exit(25)
[   17.476919][    T1] vdc:
[   17.480013][    T1] init: vdc call fail
[   17.486027][    T1] init: [libfs_mgr]Encryption failed
[   17.493019][    T1] init: Command 'mount_all /vendor/etc/fstab.$e-fs (/vendor/etc/init/init.optee.rc:6) took 635ms and failed: queue_fs_event() failed: Invalid code: -1
[   17.512593][    T1][   17.543482][    T1] init: SVC_EXEC service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' pid 237 (uid 1000 gid 1000+0 context default) started; waiting...
[   17.597817][    T1] init: Service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' (pid 237) exited with status 0 waiting took 0.061000 seconds
[   17.611728][    T1-fs-data (/system/etc/init/hw/init.rc:687) took 1ms and failed: mkdir() failed on /data/vendor: Read-only file system
[   17.75policy on: /data/vendor_ce
[   17.762540][    T1] init: Command 'mkdir /data/vendor_ce 0771 root root encryption=None' action=p[   18.495296][  T172] type=1400 audit(24.120:4): avc: denied { read } for comm="crash_dump64" name="status" dev="selinuxfs" ino=19 scontext=u:r:crash_dump:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=0
[   18.497712][  T168] logd: logdr: UID=1017 GID=1017 PID=257 n tail=0 logMask=8 pid=190 start=0ns deadline=0ns
[   18.515613][  T172] type=1400 audit(24.120:5): avc: denied { read } for comm="crash_dump64" name="status" dev="selinuxfs" ino=19 scontext=u:r:crash_dump:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=0
[   18.527787][  T168] logd: logdr: UID=1017 GID=1017 PID=257 n tail=0 logMask=1 pid=190 start=0ns deadline=0ns
[   18.565605][  T257] DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[   18.565926][  T257] DEBUG: Build fingerprint: 'TI/am62x/am62x:13/TQ3A.230705.001.A1/eng.root.20230721.190301:userdebug/test-keys'
[   18.574908][  T257] DEe60507f03365eb208bb4f00)
[   19.042431][  T257] DEBUG:       #14 pc 0000000000064398  /system/bin/keystore2 (_RNvXs2_NtCs6pfwsPMdzSo_6binder6nativeINtB5_6BinderNtNtNtNtNtNtCsinder.so (android::BBinder::transact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+236) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
[   19.126621][  f04e7ae60507f03365eb208bb4f00)
[   19.214140][  T257] DEBUG:       #22 pc 0000000000163788  /system/bin/keystore2 (_RNvNtCs4p8Yrnal+344) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   19.234105][  T257] DEBUG:       #23 pc 0000000000046ac0  /system/bin/3365eb208bb4f00)
[   19.251014][  T257] DEBUG:       #24 pc 000000000004b730  /apex/com.android.runtime/lib64/bionic/libc.so (__libc_init+96) (BuildId: dfb63f03d096213c51b3eecca455feac)
[   19.292129][    T1] init: Untracked pid 257 exited with status 0
[   19.294016][   T60] binder: release 190:190 transaction 542 in, still active
[   1ve an associated service entry and will not be reaped
[   19.313655][   T60] binder: send failed reply for transaction 542 to 1e2' (pid 190) received signal 6
[   19.331067][  T176] vold: keystore2 Communication with Keystore earlyBootEnded failed error: -129
[   19.337716][    T1] init: Sending signal 9 init: Unable to load legacy persistent properties: Unable to open persistent property directory "/data/property": No such file oction=post-fs-data (/system/etc/init/hw/init.rc:765) took 1ms and failed: Could not write to output file '/data/misc/recovery/pr[   19.834738][  T272] apexd: Found pre-installed APEX /system/apex/com.android.ondevicepersonalization.apex
[   19.867126][  Tpex
[   19.888191][  T272] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
[   19.896458][    T1] init272] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.capex
[   19.926370][  T272] apexd: Found pre-installed/apex/com.android.apex.cts.shim.apex
[   19.987060][  T272] apexd: Found pre-installed APEX /system/apex/com.android. 19.997101][   T74] sdhci-am654 fa00000.mmc: Power on failed
[   19.997576][  T272] apexd: Found pre-installed APEX /system/ape 20.013083][  T272] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
[   20.022410][    T1] init: SVC_EXEC irtualizationservice)' pid 273 (uid 1081 gid 1000+0 context default) started; waiting...
[   20.023120][  T272] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
[   20.150762][  T272] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
[   20.161056][    T1] init: Not sed APEX /system/apex/com.android.tethering.capex
[   20.203865][    T1] init: Not setting encryption policy on: /data/data
[   20.211578][  T272] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
[   20.219018][    T1] init: Command 'mkdir /data/data 0771 system system encryption=None' action=post-fs-data (/system/etc/init/hw/init.rc:844) took 15ms and failed: mkdir() failed on /data/data: Read-only file system
[   20.226792][  T272] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
[   20.246467][    T1] init: Command 'mkdir /data/app-private 0771 system system encryption=Require' action=post-fs-data (/system/etc/init/hw/init.rc:845) took 1ms and failed: mkdir() failed on /data/app-private: Read-only file system
[   20.254165][  T272] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
[   20.275517][    T1] init: Command 'mkdir /data/app-ephemeral 0771 system system encryption=Require' action=post-fs-data (/system/etc/init/hw/init.rc:846) took 1ms and failed: mkdir() failed on /data/app-ephemeral: Read-only file system
[   20.281078][  T272] apexd: /system_ext/apex does not exist. Skipping
[   20.304076][    T1] init: Command 'mkdir /data/apinit: Could not open '/metadata/bootstat/persist.sys.boot.reason' to persist reboot reason: No such file or directory
[   20.749779][    T1] init: Reboot ending, jumping to kernel
[   20.755517][    T1] kvm: exiting hardware virtualization
  21.549096][   T74] sdhci-am654 fa00000.mmc: Power on failed
| Slot int: 0x00000000
[   31.278642][    C2] mmc0: sdhci: Caps:      0x3decc801 | Caps_1:   0x18002407
[   31.285775][    C2]   C2] mmc0: sdhci: Host ctl2: 0x00000000
[   31.312274][    C2] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000[   51.680879][    C2] mmc0: Timeout waiting for hardware cmd interrupt.
[   51.687361][    C2] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   51.694485][    C2] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001004
[   5lk cnt:  0x00000000
[   51.708731][    C2] mmc0: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   51.715854][    C2] mm[   51.722977][    C2] mmc0: sdhci: Power:     0x00000000 | Blk gap:  0x00000080
[   51.730104][    C2] mmc0: sdhci: Wake-up:  2] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   51.744355][    C2] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enMax curr: 0x00000000
[   51.772848][    C2] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   51.779970][    C2] m290][    C2] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   61.984413][    C2] mmc0: sdhci: Int enab:  0x00ff008dhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   61.998659][    C2] mmc0: sdhci: Caps:      0x3decc801 | Caps_1:   0x18000x00000000
[   62.027151][    C2] mmc0: sdhci: Host ctl2: 0x00000000
[   62.032280][    C2] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
[   62.040096][    C2]
With the same board, I can boot Android SDK8.3.
flash again, AM62-SK E2 Android SDK 9.0 boot log:
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE:  BL31: Built : 05:06:58, Feb 24 2023
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000)
U-Boot 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000)
SoC:   AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Board: AM62-SKEVM rev E2
DRAM:  2 GiB
MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
Verify GPT: success!
misc partition number:0x4
ANDROID: Attempting slot a, tries remaining 6
ANDROID: Booting slot: a
A/B cmdline addition: androidboot.slot_suffix=_a
Running without AVB...
MMC read: dev # 0, block # 28672, count 81920 ... 81920 blocks read: OK
Preparing FDT...
  Reading DTB for am62x_skevm...
MMC read: dev # 0, block # 192512, count 16384 ... 16384 blocks read: OK
  Applying DTBOs...
Running Android...
## Booting Android Image at 0x82000000 ...
Kernel load addr 0x92000000 size 19077 KiB
Kernel command line: no_console_suspend console=ttyS2,115200 printk.devkmsg=on androidboot.boot_devices=bus@f0
000/fa10000.mmc init=/init cma=512M firmware_class.path=/vendor/firmware androidboot.hardware=am62x 8250.nr_ua
rts=10 mem_sleep_default=deep buildvariant=userdebug
RAM disk load addr 0xe0000000 size 14201 KiB
   Uncompressing Kernel Image
   Loading Ramdisk to 8f221000, end 8ffff211 ... OK
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000)
   Loading Device Tree to 000000008f20f000, end 000000008f22009b ... OK
Starting kernel ...
[    0.000000][    T0] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000][    T0] Linux version 6.1.25-android13-11 (build-user@build-host) (Android (10087095, +pgo, +bo
lt, +lto, -mlgo, based on r487747c) clang version 17.0.2 (https://android.googlesource.com/toolchain/llvm-proj
ect d9f89f4d16663d5012e5c09495f3b30ece3d2362), LLD 17.0.2) #1 SMP PREEMPT Wed Jul 19 22:16:08 UTC 2023
[    0.000000][    T0] Machine model: Texas Instruments AM625 SK
[    0.000000][    T0] Stack Depot is disabled
[    0.000000][    T0] Enabling dynamic shadow call stack
[    0.000000][    T0] efi: UEFI not found.
[    0.000000][    T0] Reserved memory: bypass linux,cma node, using cmdline CMA params instead
[    0.000000][    T0] OF: reserved mem: node linux,cma compatible matching fail
[    0.000000][    T0] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000][    T0] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000][    T0] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000][    T0] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-po
ol
[    0.000000][    T0] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[    0.000000][    T0] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000][    T0] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[    0.000000][    T0] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-po
ol
[    0.000000][    T0] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000][    T0] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000][    T0] kvm [0]: Reserved 16 MiB at 0xfe200000
[    0.000000][    T0] Zone ranges:
[    0.000000][    T0]   DMA32    [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000][    T0]   Normal   empty
[    0.000000][    T0]   Device   empty
[    0.000000][    T0] Movable zone start for each node
[    0.000000][    T0] Early memory node ranges
[    0.000000][    T0]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
[    0.000000][    T0]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000][    T0]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000][    T0]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000][    T0]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[    0.000000][    T0]   node   0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[    0.000000][    T0]   node   0: [mem 0x00000000fffca000-0x00000000ffffffff]
[    0.000000][    T0] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000][    T0] cma: Reserved 512 MiB at 0x00000000dc000000
[    0.000000][    T0] psci: probing for conduit method from DT.
[    0.000000][    T0] psci: Using standard PSCI v0.2 function IDs
[    0.000000][    T0] psci: Trusted OS migration not required
[    0.000000][    T0] psci: SMC Calling Convention v1.2
[    0.000000][    T0] 'bootconfig' found on command line, but no bootconfig found
[    0.000000][    T0] percpu: Embedded 29 pages/cpu s81920 r8192 d28672 u118784
[    0.000000][    T0] Detected VIPT I-cache on CPU0
[    0.000000][    T0] CPU features: SYS_ID_AA64MMFR1_EL1[11:8]: already set to 0
[    0.000000][    T0] CPU features: detected: GIC system register CPU interface
[    0.000000][    T0] CPU features: detected: ARM erratum 845719
[    0.000000][    T0] alternatives: applying boot alternatives
[    0.000000][    T0] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000][    T0] Kernel command line: console=ttynull stack_depot_disable=on cgroup_disable=pressure kas
an.page_alloc.sample=10 kasan.stacktrace=off kvm-arm.mode=protected bootconfig ioremap_guard androidboot.seria
lno=0000000000000117 androidboot.slot_suffix=_a androidboot.verifiedbootstate=orange androidboot.dtbo_idx=   a
ndroidboot.force_normal_boot=1 no_console_suspend console=ttyS2,115200 printk.devkmsg=on androidboot.boot_devi
ces=bus@f0000/fa10000.mmc init=/init cma=512M firmware_class.path=/vendor/firmware androidboot.hardware=am62x
8250.nr_uarts=10 mem_sleep_default=deep buildvariant=userdebug
[    0.000000][    T0] cgroup: Disabling pressure control group feature
[    0.000000][    T0] Unknown kernel command line parameters "buildvariant=userdebug", will be passed to user
 space.
[    0.000000][    T0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000][    T0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000][    T0] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.000000][    T0] Memory: 1394120K/2097152K available (20544K kernel code, 2082K rwdata, 11548K rodata, 5
120K init, 629K bss, 178744K reserved, 524288K cma-reserved)
[    0.000000][    T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000][    T0] trace event string verifier disabled
[    0.000000][    T0] rcu: Preemptible hierarchical RCU implementation.
[    0.000000][    T0] rcu:     RCU event tracing is enabled.
[    0.000000][    T0] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000][    T0]  Trampoline variant of Tasks RCU enabled.
[    0.000000][    T0] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000][    T0] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000][    T0] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000][    T0] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000][    T0] GICv3: 256 SPIs implemented
[    0.000000][    T0] GICv3: 0 Extended SPIs implemented
[    0.000000][    T0] Root IRQ handler: gic_handle_irq
[    0.000000][    T0] GICv3: GICv3 features: 16 PPIs
[    0.000000][    T0] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000][    T0] ITS [mem 0x01820000-0x0182ffff]
[    0.000000][    T0] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000][    T0] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000][    T0] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0
[    0.000000][    T0] ITS: using cache flushing for cmd queue
[    0.000000][    T0] GICv3: using LPI property table @0x00000000800d0000
[    0.000000][    T0] GIC: using cache flushing for LPI property table
[    0.000000][    T0] GICv3: CPU0: using allocated LPI pending table @0x00000000800e0000
[    0.000000][    T0] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000][    T0] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000][    T0] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_id
le_ns: 440795210634 ns
[    0.000001][    T0] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.000442][    T0] kfence: initialized - using 524288 bytes for 63 objects at 0x(____ptrval____)-0x(____pt
rval____)
[    0.000578][    T0] serial port 2 not yet initialized
[    0.000617][    T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoM
IPS (lpj=800000)
[    0.000630][    T0] pid_max: default: 32768 minimum: 301
[    0.000883][    T0] LSM: Security Framework initializing
[    0.000955][    T0] SELinux:  Initializing.
[    0.001365][    T0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001391][    T0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.004119][    T1] cblist_init_generic: Setting adjustable number of callback queues.
[    0.004140][    T1] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.004252][    T1] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.004527][    T1] rcu: Hierarchical SRCU implementation.
[    0.004531][    T1] rcu:     Max phase no-delay instances is 1000.
[    0.005649][    T1] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.005730][    T1] Platform MSI: msi-controller@1820000 domain created
[    0.005973][    T1] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.006096][    T1] EFI services will not be available.
[    0.006672][    T1] smp: Bringing up secondary CPUs ...
[    0.007471][    T0] Detected VIPT I-cache on CPU1
[    0.007588][    T0] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.007607][    T0] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
[    0.007667][    T0] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.008764][    T0] Detected VIPT I-cache on CPU2
[    0.008868][    T0] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.008883][    T0] GICv3: CPU2: using allocated LPI pending table @0x0000000080100000
[    0.008924][    T0] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.009762][    T0] Detected VIPT I-cache on CPU3
[    0.009858][    T0] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.009873][    T0] GICv3: CPU3: using allocated LPI pending table @0x0000000080110000
[    0.009905][    T0] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.009991][    T1] smp: Brought up 1 node, 4 CPUs
[    0.009998][    T1] SMP: Total of 4 processors activated.
[    0.010004][    T1] CPU features: detected: 32-bit EL0 Support
[    0.010007][    T1] CPU features: detected: 32-bit EL1 Support
[    0.010013][    T1] CPU features: detected: CRC32 instructions
[    0.010020][    T1] CPU features: detected: Protected KVM
[    0.010084][    T1] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.010092][    T1] CPU: All CPU(s) started at EL2
[    0.010126][    T1] alternatives: applying system-wide alternatives
[    0.026419][    T1] Registered cp15_barrier emulation handler
[    0.026439][    T1] Registered setend emulation handler
[    0.026686][    T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417851
00000 ns
[    0.026739][    T1] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.046427][    T1] pinctrl core: initialized pinctrl subsystem
[    0.047950][    T1] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.051649][    T1] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.051911][    T1] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.052022][    T1] audit: initializing netlink subsys (disabled)
[    0.052339][   T37] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[    0.053012][    T1] thermal_sys: Registered thermal governor 'step_wise'
[    0.053018][    T1] thermal_sys: Registered thermal governor 'user_space'
[    0.053021][    T1] thermal_sys: Registered thermal governor 'power_allocator'
[    0.053080][    T1] cpuidle: using governor menu
[    0.053440][    T1] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.053559][    T1] ASID allocator initialised with 65536 entries
[    0.053736][    T1] Serial: AMBA PL011 UART driver
[    0.055373][    T1] printk: console [ramoops-1] enabled
[    0.055484][    T1] pstore: Registered ramoops as persistent store backend
[    0.055493][    T1] ramoops: using 0x100000@0x9c700000, ecc: 0
[    0.066859][    T1] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3
b
[    0.069203][    T1] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.071547][    T1] KASLR disabled due to lack of seed
[    0.083152][    T1] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.084611][    T1] iommu: Default domain type: Translated
[    0.084641][    T1] iommu: DMA domain TLB invalidation policy: strict mode
[    0.085343][    T1] SCSI subsystem initialized
[    0.085511][    T1] usbcore: registered new interface driver usbfs
[    0.085564][    T1] usbcore: registered new interface driver hub
[    0.085601][    T1] usbcore: registered new device driver usb
[    0.085829][    T1] mc: Linux media interface: v0.10
[    0.085859][    T1] videodev: Linux video capture interface: v2.00
[    0.085960][    T1] pps_core: LinuxPPS API ver. 1 registered
[    0.085968][    T1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it
[    0.085998][    T1] PTP clock support registered
[    0.086032][    T1] EDAC MC: Ver: 3.0.0
[    0.087373][    T1] Advanced Linux Sound Architecture Driver Initialized.
[    0.088704][    T1] clocksource: Switched to clocksource arch_sys_counter
[    0.089362][    T1] VFS: Disk quotas dquot_6.6.0
[    0.089427][    T1] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.090359][    T1] NET: Registered PF_INET protocol family
[    0.090712][    T1] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.092516][    T1] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.092719][    T1] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.092836][    T1] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.093215][    T1] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.093722][    T1] TCP: Hash tables configured (established 16384 bind 16384)
[    0.094020][    T1] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.094102][    T1] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.094347][    T1] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.094397][    T1] NET: Registered PF_XDP protocol family
[    0.094421][    T1] PCI: CLS 0 bytes, default 64
[    0.095368][   T48] Trying to unpack rootfs image as initramfs...
[    0.095572][    T1] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.096300][    T1] kvm [1]: IPA Size Limit: 40 bits
[    0.149565][    T1] kvm [1]: disabling GICv2 emulation
[    0.149660][    T1] kvm [1]: GIC system register CPU interface enabled
[    0.149941][    T1] kvm [1]: vgic interrupt IRQ9
[    0.150464][    T1] kvm [1]: Protected nVHE mode initialized successfully
[    0.152911][    T1] Initialise system trusted keyrings
[    0.153482][    T1] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.165289][    T1] fuse: init (API version 7.37)
[    0.206705][    T1] Key type asymmetric registered
[    0.206766][    T1] Asymmetric key parser 'x509' registered
[    0.206907][    T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 238)
[    0.207292][    T1] io scheduler mq-deadline registered
[    0.207310][    T1] io scheduler kyber registered
[    0.207533][    T1] io scheduler bfq registered
[    0.210026][    T1] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.211059][    T1] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.212495][    T1] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.215056][    T1] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.218548][    T1] printk: console [ttynull0] enabled
[    0.229007][    T1] brd: module loaded
[    0.242279][    T1] loop: module loaded
[    0.245168][    T1] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[    0.245207][    T1] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Res
erved.
[    0.245989][    T1] MACsec IEEE 802.1AE
[    0.246632][    T1] tun: Universal TUN/TAP device driver, 1.6
[    0.248204][    T1] usbcore: registered new interface driver uas
[    0.248279][    T1] usbcore: registered new interface driver usb-storage
[    0.248675][    T1] usbcore: registered new interface driver xpad
[    0.248896][    T1] gspca_main: v2.14.0 registered
[    0.248968][    T1] usbcore: registered new interface driver uvcvideo
[    0.249542][    T1] device-mapper: uevent: version 1.0.3
[    0.249836][    T1] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[    0.251921][    T1] sdhci: Secure Digital Host Controller Interface driver
[    0.251971][    T1] sdhci: Copyright(c) Pierre Ossman
[    0.251979][    T1] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.252587][    T1] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.253038][    T1] hid: raw HID events driver (C) Jiri Kosina
[    0.254291][    T1] usbcore: registered new interface driver usbhid
[    0.254316][    T1] usbhid: USB HID core driver
[    0.254685][    T1] ashmem: initialized
[    0.255418][    T1] gnss: GNSS driver registered with major 503
[    0.256217][    T1] usbcore: registered new interface driver snd-usb-audio
[    0.256938][    T1] GACT probability NOT on
[    0.256977][    T1] Mirror/redirect action on
[    0.257009][    T1] netem: version 1.3
[    0.257140][    T1] u32 classifier
[    0.257149][    T1]     input device check on
[    0.257156][    T1]     Actions configured
[    0.326381][    T1] xt_time: kernel timezone is -0000
[    0.326564][    T1] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    0.327119][    T1] gre: GRE over IPv4 demultiplexor driver
[    0.327142][    T1] ip_gre: GRE over IPv4 tunneling driver
[    0.328504][    T1] IPv4 over IPsec tunneling driver
[    0.329057][    T1] Initializing XFRM netlink socket
[    0.329116][    T1] IPsec XFRM device driver
[    0.329745][    T1] NET: Registered PF_INET6 protocol family
[    0.332522][    T1] Segment Routing with IPv6
[    0.332601][    T1] In-situ OAM (IOAM) with IPv6
[    0.332880][    T1] mip6: Mobile IPv6
[    0.333753][    T1] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.334861][    T1] ip6_gre: GRE over IPv6 tunneling driver
[    0.335450][    T1] NET: Registered PF_PACKET protocol family
[    0.335483][    T1] NET: Registered PF_KEY protocol family
[    0.335786][    T1] NET: Registered PF_VSOCK protocol family
[    0.337495][    T1] registered taskstats version 1
[    0.337591][    T1] Loading compiled-in X.509 certificates
[    0.338279][   T70] cryptomgr_probe (70) used greatest stack depth: 14032 bytes left
[    0.340220][    T1] Loaded X.509 cert 'Build time autogenerated kernel key: 95eea77eb463f6846643eae7e9761af
2252bdee8'
[    0.340415][    T1] page_owner is disabled
[    0.340657][    T1] Key type .fscrypt registered
[    0.340668][    T1] Key type fscrypt-provisioning registered
[    0.341287][    T1] pstore: Using crash dump compression: deflate
[    0.344138][    T1] ALSA device list:
[    0.344179][    T1]   No soundcards found.
[    0.700053][   T48] Freeing initrd memory: 14200K
[    0.703983][    T1] Freeing unused kernel memory: 5120K
[    0.708858][    T1] Run /init as init process
[    0.747093][    T1] init: init first stage started!
[    0.754947][    T1] init: Loading module /lib/modules/zsmalloc.ko with args ''
[    0.755517][    T1] zsmalloc: module verification failed: signature and/or required key missing - tainting
kernel
[    0.756942][    T1] init: Loaded kernel module /lib/modules/zsmalloc.ko
[    0.757317][    T1] init: Loading module /lib/modules/zram.ko with args ''
[    0.759587][    T1] zram: Added device: zram0
[    0.759830][    T1] init: Loaded kernel module /lib/modules/zram.ko
[    0.760194][    T1] init: Loading module /lib/modules/ti-msgmgr.ko with args ''
[    0.762137][    T1] init: Loaded kernel module /lib/modules/ti-msgmgr.ko
[    0.762566][    T1] init: Loading module /lib/modules/ti_sci.ko with args ''
[    0.769945][    T1] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chi
ll Capybar')
[    0.775918][    T1] init: Loaded kernel module /lib/modules/ti_sci.ko
[    0.776426][    T1] init: Loading module /lib/modules/ti_sci_pm_domains.ko with args ''
[    0.781961][    T1] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    0.782945][    T1] init: Loaded kernel module /lib/modules/ti_sci_pm_domains.ko
[    0.783393][    T1] init: Loading module /lib/modules/phy-omap-usb2.ko with args ''
[    0.785119][    T1] init: Loaded kernel module /lib/modules/phy-omap-usb2.ko
[    0.785521][    T1] init: Loading module /lib/modules/syscon-clk.ko with args ''
[    0.787575][    T1] init: Loaded kernel module /lib/modules/syscon-clk.ko
[    0.787983][    T1] init: Loading module /lib/modules/tee.ko with args ''
[    0.790719][    T1] init: Loaded kernel module /lib/modules/tee.ko
[    0.791135][    T1] init: Loading module /lib/modules/k3-ringacc.ko with args ''
[    0.792951][    T1] init: Loaded kernel module /lib/modules/k3-ringacc.ko
[    0.793334][    T1] init: Loading module /lib/modules/irq-ti-sci-intr.ko with args ''
[    0.794458][    T1] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    0.794841][    T1] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    0.795223][    T1] init: Loaded kernel module /lib/modules/irq-ti-sci-intr.ko
[    0.795612][    T1] init: Loading module /lib/modules/sci-clk.ko with args ''
[    0.851686][    T1] init: Loaded kernel module /lib/modules/sci-clk.ko
[    0.852215][    T1] init: Loading module /lib/modules/k3-psil-lib.ko with args ''
[    0.853481][    T1] init: Loaded kernel module /lib/modules/k3-psil-lib.ko
[    0.854011][    T1] init: Loading module /lib/modules/k3-udma.ko with args ''
[    0.857449][    T1] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.857717][    T1] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.858318][    T1] init: Loaded kernel module /lib/modules/k3-udma.ko
[    0.858808][    T1] init: Loading module /lib/modules/reset-ti-sci.ko with args ''
[    0.859477][   T48] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.859892][   T48] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.860430][    T1] init: Loaded kernel module /lib/modules/reset-ti-sci.ko
[    0.860655][   T48] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.861015][    T1] init: Loading module /lib/modules/irq-ti-sci-inta.ko with args ''
[    0.861397][   T48] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.862720][    T1] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    0.863237][    T1] init: Loaded kernel module /lib/modules/irq-ti-sci-inta.ko
[    0.863306][   T48] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.863720][    T1] init: Loading module /lib/modules/reset-ti-syscon.ko with args ''
[    0.865183][    T1] init: Loaded kernel module /lib/modules/reset-ti-syscon.ko
[    0.865633][    T1] init: Loading module /lib/modules/k3-udma-glue.ko with args ''
[    0.865954][   T48] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    0.867491][    T1] init: Loaded kernel module /lib/modules/k3-udma-glue.ko
[    0.867945][    T1] init: Loading module /lib/modules/rtc-ti-k3.ko with args ''
[    0.869612][   T48] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.871248][    T1] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:06 UTC (6)
[    0.871968][    T1] init: Loaded kernel module /lib/modules/rtc-ti-k3.ko
[    0.872482][    T1] init: Loading module /lib/modules/optee-rng.ko with args ''
[    0.873648][    T1] init: Loaded kernel module /lib/modules/optee-rng.ko
[    0.874052][    T1] init: Loading module /lib/modules/sa2ul.ko with args ''
[    0.874649][   T48] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    0.876633][    T1] init: Loaded kernel module /lib/modules/sa2ul.ko
[    0.877212][    T1] init: Loading module /lib/modules/cma_heap.ko with args ''
[    0.878420][    T1] init: Loaded kernel module /lib/modules/cma_heap.ko
[    0.878827][    T1] init: Loading module /lib/modules/system_heap.ko with args ''
[    0.880008][    T1] init: Loaded kernel module /lib/modules/system_heap.ko
[    0.880412][    T1] init: Loading module /lib/modules/gpio-davinci.ko with args ''
[    0.889472][    T1] init: Loaded kernel module /lib/modules/gpio-davinci.ko
[    0.889964][    T1] init: Loading module /lib/modules/gpio-pca953x.ko with args ''
[    0.891605][    T1] init: Loaded kernel module /lib/modules/gpio-pca953x.ko
[    0.892003][    T1] init: Loading module /lib/modules/gpio-regulator.ko with args ''
[    0.893899][    T1] init: Loaded kernel module /lib/modules/gpio-regulator.ko
[    0.894276][    T1] init: Loading module /lib/modules/drm_dma_helper.ko with args ''
[    0.895369][    T1] init: Loaded kernel module /lib/modules/drm_dma_helper.ko
[    0.895722][    T1] init: Loading module /lib/modules/omap_hwspinlock.ko with args ''
[    0.897281][    T1] init: Loaded kernel module /lib/modules/omap_hwspinlock.ko
[    0.897686][    T1] init: Loading module /lib/modules/i2c-omap.ko with args ''
[    0.900055][    T1] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    0.902026][    T1] pca953x 1-0022: supply vcc not found, using dummy regulator
[    0.902198][    T1] pca953x 1-0022: using AI
[    0.927827][    T1] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    0.929309][    T1] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    0.929830][    T1] init: Loaded kernel module /lib/modules/i2c-omap.ko
[    0.930313][    T1] init: Loading module /lib/modules/i2c-mux.ko with args ''
[    0.931443][    T1] init: Loaded kernel module /lib/modules/i2c-mux.ko
[    0.931848][    T1] init: Loading module /lib/modules/i2c-mux-pca954x.ko with args ''
[    0.933143][    T1] init: Loaded kernel module /lib/modules/i2c-mux-pca954x.ko
[    0.933541][    T1] init: Loading module /lib/modules/ili210x.ko with args ''
[    0.934738][    T1] init: Loaded kernel module /lib/modules/ili210x.ko
[    0.935097][    T1] init: Loading module /lib/modules/irq-pruss-intc.ko with args ''
[    0.936383][    T1] init: Loaded kernel module /lib/modules/irq-pruss-intc.ko
[    0.936794][    T1] init: Loading module /lib/modules/leds-tlc591xx.ko with args ''
[    0.937563][    T1] init: Loaded kernel module /lib/modules/leds-tlc591xx.ko
[    0.937890][    T1] init: Loading module /lib/modules/omap-mailbox.ko with args ''
[    0.939712][    T1] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.940108][    T1] init: Loaded kernel module /lib/modules/omap-mailbox.ko
[    0.940481][    T1] init: Loading module /lib/modules/palmas.ko with args ''
[    0.941732][    T1] init: Loaded kernel module /lib/modules/palmas.ko
[    0.942105][    T1] init: Loading module /lib/modules/sdhci_am654.ko with args ''
[    0.945034][   T48] mmc0: CQHCI version 5.10
[    0.945095][    T8] mmc2: CQHCI version 5.10
[    0.945303][   T10] mmc1: CQHCI version 5.10
[    0.983358][    T8] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    0.996657][   T48] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    0.996740][   T10] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    0.997013][    T1] init: Loaded kernel module /lib/modules/sdhci_am654.ko
[    0.997450][    T1] init: Loading module /lib/modules/mux-core.ko with args ''
[    0.998903][    T1] init: Loaded kernel module /lib/modules/mux-core.ko
[    0.999299][    T1] init: Loading module /lib/modules/mux-mmio.ko with args ''
[    1.000479][    T1] init: Loaded kernel module /lib/modules/mux-mmio.ko
[    1.001091][    T1] init: Loading module /lib/modules/mdio-bitbang.ko with args ''
[    1.001929][    T1] init: Loaded kernel module /lib/modules/mdio-bitbang.ko
[    1.002032][    T1] init: Loading module /lib/modules/davinci_mdio.ko with args ''
[    1.003668][    T1] init: Loaded kernel module /lib/modules/davinci_mdio.ko
[    1.004065][    T1] init: Loading module /lib/modules/mdio-gpio.ko with args ''
[    1.005408][    T1] init: Loaded kernel module /lib/modules/mdio-gpio.ko
[    1.005783][    T1] init: Loading module /lib/modules/cdns-dphy-rx.ko with args ''
[    1.007479][    T1] init: Loaded kernel module /lib/modules/cdns-dphy-rx.ko
[    1.007938][    T1] init: Loading module /lib/modules/cdns-dphy.ko with args ''
[    1.009463][    T1] init: Loaded kernel module /lib/modules/cdns-dphy.ko
[    1.009858][    T1] init: Loading module /lib/modules/phy-cadence-torrent.ko with args ''
[    1.012408][    T1] init: Loaded kernel module /lib/modules/phy-cadence-torrent.ko
[    1.012902][    T1] init: Loading module /lib/modules/phy-can-transceiver.ko with args ''
[    1.014140][    T1] init: Loaded kernel module /lib/modules/phy-can-transceiver.ko
[    1.014499][    T1] init: Loading module /lib/modules/phy-gmii-sel.ko with args ''
[    1.016312][    T1] init: Loaded kernel module /lib/modules/phy-gmii-sel.ko
[    1.016825][    T1] init: Loading module /lib/modules/phy-j721e-wiz.ko with args ''
[    1.018780][    T1] init: Loaded kernel module /lib/modules/phy-j721e-wiz.ko
[    1.019279][    T1] init: Loading module /lib/modules/pwm-tiecap.ko with args ''
[    1.020377][    T1] init: Loaded kernel module /lib/modules/pwm-tiecap.ko
[    1.020878][    T1] init: Loading module /lib/modules/pwm-tiehrpwm.ko with args ''
[    1.022070][    T1] init: Loaded kernel module /lib/modules/pwm-tiehrpwm.ko
[    1.022429][    T1] init: Loading module /lib/modules/palmas-regulator.ko with args ''
[    1.024104][    T1] init: Loaded kernel module /lib/modules/palmas-regulator.ko
[    1.024459][    T1] init: Loading module /lib/modules/pru_rproc.ko with args ''
[    1.026557][    T1] init: Loaded kernel module /lib/modules/pru_rproc.ko
[    1.026957][    T1] init: Loading module /lib/modules/ti_k3_common.ko with args ''
[    1.027988][    T1] init: Loaded kernel module /lib/modules/ti_k3_common.ko
[    1.028324][    T1] init: Loading module /lib/modules/ti_k3_dsp_remoteproc.ko with args ''
[    1.029924][    T1] init: Loaded kernel module /lib/modules/ti_k3_dsp_remoteproc.ko
[    1.030305][    T1] init: Loading module /lib/modules/ti_k3_m4_remoteproc.ko with args ''
[    1.032029][    T1] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[    1.032181][    T1] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    1.032252][    T1] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[    1.032471][    T1] remoteproc remoteproc0: 5000000.m4fss is available
[    1.033223][    T1] init: Loaded kernel module /lib/modules/ti_k3_m4_remoteproc.ko
[    1.033661][    T1] init: Loading module /lib/modules/ti_k3_r5_remoteproc.ko with args ''
[    1.035608][   T86] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -
2
[    1.035658][   T86] remoteproc remoteproc0: powering up 5000000.m4fss
[    1.035725][   T86] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -
2
[    1.035738][   T86] remoteproc remoteproc0: request_firmware failed: -2
[    1.036584][    T1] platform 78000000.r5f: R5F core may have been powered on by a different host, programme
[    1.036740][    T1] platform 78000000.r5f: configured R5F for IPC-only mode
[    1.036877][    T1] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[    1.037222][    T1] remoteproc remoteproc1: 78000000.r5f is available
[    1.037310][    T1] remoteproc remoteproc1: attaching to 78000000.r5f
[    1.037689][    T1] platform 78000000.r5f: R5F core initialized in IPC-only mode
[    1.037709][    T1] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9da00000
[    1.037790][    T1] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    1.037803][    T1] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[    1.038505][    T1] init: Loaded kernel module /lib/modules/ti_k3_r5_remoteproc.ko
[    1.038935][    T1] init: Loading module /lib/modules/rpmsg_kdrv.ko with args ''
[    1.040984][    T1] init: Loaded kernel module /lib/modules/rpmsg_kdrv.ko
[    1.041431][    T1] init: Loading module /lib/modules/rpmsg_kdrv_switch.ko with args ''
[    1.043070][    T1] init: Loaded kernel module /lib/modules/rpmsg_kdrv_switch.ko
[    1.043461][    T1] init: Loading module /lib/modules/rpmsg_ns.ko with args ''
[    1.044278][    T1] init: Loaded kernel module /lib/modules/rpmsg_ns.ko
[    1.044591][    T1] init: Loading module /lib/modules/virtio_rpmsg_bus.ko with args ''
[    1.046447][    T1] virtio_rpmsg_bus virtio0: rpmsg host is online
[    1.046671][    T1] init: Loaded kernel module /lib/modules/virtio_rpmsg_bus.ko
[    1.047057][    T1] init: Loading module /lib/modules/pruss.ko with args ''
[    1.047353][   T86] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    1.047533][   T86] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    1.052067][    T1] remoteproc remoteproc2: 30074000.pru is available
[    1.052981][    T1] remoteproc remoteproc3: 30078000.pru is available
[    1.053671][    T1] init: Loaded kernel module /lib/modules/pruss.ko
[    1.054124][    T1] init: Loading module /lib/modules/spi-cadence-quadspi.ko with args ''
[    1.058663][    T1] init: Loaded kernel module /lib/modules/spi-cadence-quadspi.ko
[    1.059096][    T1] init: Loading module /lib/modules/spi-omap2-mcspi.ko with args ''
[    1.060996][    T1] init: Loaded kernel module /lib/modules/spi-omap2-mcspi.ko
[    1.061445][    T1] init: Loading module /lib/modules/optee.ko with args ''
[    1.064525][    T1] optee: probing for conduit method.
[    1.064597][    T1] optee: revision 3.20 (8e74d476)
[    1.064942][    T1] optee: dynamic shared memory is enabled
[    1.065226][    T1] optee: initialized driver
[    1.065852][    T1] init: Loaded kernel module /lib/modules/optee.ko
[    1.066289][    T1] init: Loading module /lib/modules/k3_bandgap.ko with args ''
[    1.067575][    T1] init: Loaded kernel module /lib/modules/k3_bandgap.ko
[    1.067950][    T1] init: Loading module /lib/modules/k3_j72xx_bandgap.ko with args ''
[    1.069227][    T1] k3-j72xx-soc-thermal b00000.temperature-sensor: invalid resource
[    1.069276][    T1] k3-j72xx-soc-thermal: probe of b00000.temperature-sensor failed with error -22
[    1.069793][    T1] init: Loaded kernel module /lib/modules/k3_j72xx_bandgap.ko
[    1.070154][    T1] init: Loading module /lib/modules/dwc3-am62.ko with args ''
[    1.071945][    T1] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@
3f/connector
[    1.074491][    T1] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.074589][    T1] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    1.074792][    T1] xhci-hcd xhci-hcd.2.auto: USB3 root hub has no ports
[    1.074808][    T1] xhci-hcd xhci-hcd.2.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x000000000001
0010
[    1.074903][    T1] xhci-hcd xhci-hcd.2.auto: irq 437, io mem 0x31100000
[    1.075502][    T1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    1.075532][    T1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.075544][    T1] usb usb1: Product: xHCI Host Controller
[    1.075553][    T1] usb usb1: Manufacturer: Linux 6.1.25-android13-11 xhci-hcd
[    1.075563][    T1] usb usb1: SerialNumber: xhci-hcd.2.auto
[    1.076126][    T1] hub 1-0:1.0: USB hub found
[    1.076199][    T1] hub 1-0:1.0: 1 port detected
[    1.077450][    T1] init: Loaded kernel module /lib/modules/dwc3-am62.ko
[    1.077907][    T1] init: Loading module /lib/modules/dwc3-haps.ko with args ''
[    1.078858][    T1] init: Loaded kernel module /lib/modules/dwc3-haps.ko
[    1.079196][    T1] init: Loading module /lib/modules/dwc3-of-simple.ko with args ''
[    1.080485][    T1] init: Loaded kernel module /lib/modules/dwc3-of-simple.ko
[    1.081168][    T1] init: Loading module /lib/modules/tps6598x.ko with args ''
[    1.090230][   T73] mmc0: Command Queue Engine enabled
[    1.090288][   T73] mmc0: new HS200 MMC card at address 0001
[    1.091609][   T73] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    1.096100][   T73]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    1.097985][   T73] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[    1.099821][   T73] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[    1.101321][   T73] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (507:0)
[    1.107983][    T1] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[    1.108443][    T1] init: Loaded kernel module /lib/modules/tps6598x.ko
[    1.108944][    T1] init: Loading module /lib/modules/rti_wdt.ko with args ''
[    1.112919][    T1] init: Loaded kernel module /lib/modules/rti_wdt.ko
[    1.113358][    T1] init: Loading module /lib/modules/i2c-dev.ko with args ''
[    1.114813][    T1] i2c_dev: i2c /dev entries driver
[    1.115217][    T1] init: Loaded kernel module /lib/modules/i2c-dev.ko
[    1.115580][    T1] init: Loading module /lib/modules/tidss.ko with args ''
[    1.121349][    T1] init: Loaded kernel module /lib/modules/tidss.ko
[    1.121798][    T1] init: Loading module /lib/modules/sii902x.ko with args ''
[    1.123870][    T1] init: Loaded kernel module /lib/modules/sii902x.ko
[    1.124261][    T1] init: Loading module /lib/modules/display-connector.ko with args ''
[    1.126125][    T1] init: Loaded kernel module /lib/modules/display-connector.ko
[    1.126559][    T1] init: Loading module /lib/modules/panel-simple.ko with args ''
[    1.127779][   T48] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    1.128005][   T48] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    1.131082][   T48] i2c i2c-1: Added multiplexed i2c bus 3
[    1.131432][    T1] init: Loaded kernel module /lib/modules/panel-simple.ko
[    1.132201][    T1] init: Loaded 75 kernel modules took 384 ms
[    1.133108][    T1] init: Copied ramdisk prop to /second_stage_resources/system/etc/ramdisk/build.prop
[    1.133279][    T1] init: Not moving /system/bin/snapuserd because it cannot be accessed: No such file or d
irectory
[    1.134265][   T48] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    1.134307][    T1] init: Switching root to '/first_stage_ramdisk'
[    1.135090][    T1] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[    1.137298][    T1] init: Using Android DT directory /proc/device-tree/firmware/android/
[    1.155647][    T1] init: [libfs_mgr]Invalid ext4 superblock on '/dev/block/platform/bus@f0000/fa10000.mmc/
by-name/metadata'
[    1.177153][   T71] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    1.178704][   T71] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    1.182959][   T71]  mmcblk1: p1 p2
[    1.348730][   T73] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[    1.499616][   T73] usb 1-1: New USB device found, idVendor=0461, idProduct=4d15, bcdDevice= 2.00
[    1.499633][   T73] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    1.499644][   T73] usb 1-1: Product: USB Optical Mouse
[    1.518167][   T73] input: USB Optical Mouse as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/x
hci-hcd.2.auto/usb1/1-1/1-1:1.0/0003:0461:4D15.0001/input/input0
[    1.518354][   T73] hid-generic 0003:0461:4D15.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse]
 on usb-xhci-hcd.2.auto-1/input0
[    2.112702][    C3] random: crng init done
[    2.114428][    T1] init: [libfs_mgr]Created logical partition system_a on device /dev/block/dm-0
[    2.114487][    T1] init: [libfs_mgr]Skipping zero-length logical partition: system_b
[    2.115912][    T1] init: [libfs_mgr]Created logical partition vendor_a on device /dev/block/dm-1
[    2.115969][    T1] init: [libfs_mgr]Skipping zero-length logical partition: vendor_b
[    2.116133][    T1] init: DSU not detected, proceeding with normal boot
[    2.126584][    T1] init: [libfs_avb]Invalid hash size:
[    2.126649][    T1] init: [libfs_avb]Failed to verify vbmeta digest
[    2.126674][    T1] init: [libfs_avb]Returning avb_handle with status: Success
[    2.127221][    T1] init: [libfs_avb]Built verity table: '1 /dev/block/dm-0 /dev/block/dm-0 4096 4096 31436
9 314369 sha1 85dbd07d92885ee10501348c25cbf2f41feabb5f 8a11e4d415b4fb2ade2c566828364ff4bca475e1 10 use_fec_fro
m_device /dev/block/dm-0 fec_roots 2 fec_blocks 316847 fec_start 316847 restart_on_corruption ignore_zero_bloc
ks'
[    2.127973][    T1] device-mapper: verity: sha1 using implementation "sha1-generic"
[    2.134464][    T1] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-2
[    2.140090][    T1] EXT4-fs (dm-2): mounted filesystem without journal. Quota mode: none.
[    2.140327][    T1] init: [libfs_mgr]__mount(source=/dev/block/dm-2,target=/system,type=ext4)=0: Success
[    2.141141][    T1] init: Switching root to '/system'
[    2.156513][    T1] init: [libfs_avb]Built verity table: '1 /dev/block/dm-1 /dev/block/dm-1 4096 4096 42159
 42159 sha1 3f1e640e86cca91941bf83904257cc12de6db7e1 60f1818382a9d94ea8e6ffeebad07d77a4b6256b 10 use_fec_from_
device /dev/block/dm-1 fec_roots 2 fec_blocks 42493 fec_start 42493 restart_on_corruption ignore_zero_blocks'
[    2.157329][    T1] device-mapper: verity: sha1 using implementation "sha1-generic"
[    2.163512][    T1] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-3
[    2.169660][    T1] EXT4-fs (dm-3): mounted filesystem without journal. Quota mode: none.
[    2.169908][    T1] init: [libfs_mgr]__mount(source=/dev/block/dm-3,target=/vendor,type=ext4)=0: Success
[    2.201283][    T1] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[    2.566614][    T1] init: DM_DEV_STATUS failed for system_ext_a: No such device or address
[    2.566682][    T1] init: Could not update logical partition
[    2.567020][    T1] init: DM_DEV_STATUS failed for product_a: No such device or address
[    2.567045][    T1] init: Could not update logical partition
[    2.567098][    T1] init: Opening SELinux policy
[    2.574481][    T1] init: Falling back to standard signature check. TODO implementent support for fsverity
SEPolicy.
[    2.574601][    T1] init: Error: Apex SEPolicy failed signature check
[    2.574628][    T1] init: Loading APEX Sepolicy from /system/etc/selinux/apex/SEPolicy.zip
[    2.574675][    T1] init: Failed to open package /system/etc/selinux/apex/SEPolicy.zip: No such file or dir
ectory
[    2.595551][    T1] init: Loading SELinux policy
[    2.628392][    T1] SELinux:  Permission bpf in class capability2 not defined in policy.
[    2.628445][    T1] SELinux:  Permission checkpoint_restore in class capability2 not defined in policy.
[    2.628480][    T1] SELinux:  Permission bpf in class cap2_userns not defined in policy.
[    2.628488][    T1] SELinux:  Permission checkpoint_restore in class cap2_userns not defined in policy.
[    2.628655][    T1] SELinux:  Class mctp_socket not defined in policy.
[    2.628677][    T1] SELinux:  Class io_uring not defined in policy.
[    2.628684][    T1] SELinux:  Class user_namespace not defined in policy.
[    2.628760][    T1] SELinux: the above unknown classes and permissions will be denied
[    2.638799][    T1] SELinux:  policy capability network_peer_controls=1
[    2.638854][    T1] SELinux:  policy capability open_perms=1
[    2.638863][    T1] SELinux:  policy capability extended_socket_class=1
[    2.638870][    T1] SELinux:  policy capability always_check_network=0
[    2.638879][    T1] SELinux:  policy capability cgroup_seclabel=0
[    2.638887][    T1] SELinux:  policy capability nnp_nosuid_transition=1
[    2.638895][    T1] SELinux:  policy capability genfs_seclabel_symlinks=0
[    2.638903][    T1] SELinux:  policy capability ioctl_skip_cloexec=0
[    2.844819][   T37] audit: type=1403 audit(8.472:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    2.855243][    T1] selinux: SELinux: Loaded file_contexts
[    2.855299][    T1] selinux:
[    2.869270][   T37] audit: type=1404 audit(8.496:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=429496
7295 enabled=1 old-enabled=1 lsm=selinux res=1
[    2.933637][    T1] init: init second stage started!
[    3.000585][    T1] init: Using Android DT directory /proc/device-tree/firmware/android/
[    3.012288][    T1] init: Couldn't load property file '/system_dlkm/etc/build.prop': open() failed: No such
 file or directory: No such file or directory
[    3.012466][    T1] init: Couldn't load property file '/vendor/default.prop': open() failed: No such file o
[    3.015804][    T1] init: Do not have permissions to set 'wifi.supplicant_scan_interval' to '15' in propert
y file '/vendor/build.prop': SELinux permission check failed
[    3.016338][    T1] init: Overriding previous property 'pm.dexopt.shared':'speed' with new value 'quicken'
[    3.019707][    T1] init: Couldn't load property file '/odm_dlkm/etc/build.prop': open() failed: No such fi
[    3.024840][    T1] init: Setting product property ro.product.brand to 'TI' (from ro.product.product.brand)
[    3.024929][    T1] init: Setting product property ro.product.device to 'am62x' (from ro.product.product.de
vice)
[    3.024980][    T1] init: Setting product property ro.product.manufacturer to 'TexasInstruments' (from ro.p
roduct.product.manufacturer)
[    3.025029][    T1] init: Setting product property ro.product.model to 'AOSP on AM62X EVM' (from ro.product
.product.model)
[    3.025099][    T1] init: Setting product property ro.product.name to 'am62x' (from ro.product.product.name
[    3.025182][    T1] init: Setting property 'ro.build.fingerprint' to 'TI/am62x/am62x:13/TQ3A.230705.001.A1/
[    3.025251][    T1] init: Setting property 'ro.product.cpu.abilist' to 'arm64-v8a,armeabi-v7a,armeabi'
[    3.025289][    T1] init: Setting property 'ro.product.cpu.abilist32' to 'armeabi-v7a,armeabi'
[    3.025327][    T1] init: Setting property 'ro.product.cpu.abilist64' to 'arm64-v8a'
[    3.030634][    T1] selinux: SELinux: Loaded file_contexts
[    3.030687][    T1] selinux:
[    3.030770][    T1] init: Running restorecon...
[    3.053152][    T1] selinux: SELinux: Could not get canonical path for /metadata/ota/rollback-indicator res
torecon: No such file or directory.
[    3.053201][    T1] selinux:
[    3.053320][    T1] selinux: SELinux:  Could not stat /metadata/gsi: No such file or directory.
[    3.053335][    T1] selinux:
[    3.054656][    T1] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[    3.063514][    T1] init: SetupMountNamespaces done
[    3.067689][    T1] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 107
[    3.069947][    T1] init: Parsing file /system/etc/init/hw/init.rc...
[    3.073042][    T1] init: Added '/init.environ.rc' to import list
[    3.073163][    T1] init: Added '/system/etc/init/hw/init.usb.rc' to import list
[    3.073231][    T1] init: Added '/init.am62x.rc' to import list
[    3.073270][    T1] init: Added '/vendor/etc/init/hw/init.am62x.rc' to import list
[    3.073296][    T1] init: Added '/system/etc/init/hw/init.usb.configfs.rc' to import list
[    3.073337][    T1] init: Added '/system/etc/init/hw/init.zygote64_32.rc' to import list
[    3.078144][    T1] init: Parsing file /init.environ.rc...
[    3.079473][    T1] init: Parsing file /system/etc/init/hw/init.usb.rc...
[    3.081253][    T1] init: Parsing file /init.am62x.rc...
[    3.081362][    T1] init: Unable to read config file '/init.am62x.rc': open() failed: No such file or direc
tory
[    3.083019][    T1] init: Parsing file /vendor/etc/init/hw/init.am62x.rc...
[    3.086379][    T1] init: Parsing file /system/etc/init/hw/init.usb.configfs.rc...
[    3.088518][    T1] init: Parsing file /system/etc/init/hw/init.zygote64_32.rc...
[    3.089949][    T1] init: Parsing directory /system/etc/init...
[    3.090493][    T1] init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc...
[    3.091621][    T1] init: Parsing file /system/etc/init/android.system.suspend@1.0-service.rc...
[    3.092814][    T1] init: Parsing file /system/etc/init/apexd.rc...
[    3.093883][    T1] init: Parsing file /system/etc/init/atrace.rc...
[    3.097856][    T1] init: Parsing file /system/etc/init/atrace_userdebug.rc...
[    3.099092][    T1] init: Parsing file /system/etc/init/audioserver.rc...
[    3.100403][    T1] init: Parsing file /system/etc/init/blank_screen.rc...
[    3.101420][    T1] init: Parsing file /system/etc/init/bootanim.rc...
[    3.102430][    T1] init: Parsing file /system/etc/init/bootstat-debug.rc...
[    3.103348][    T1] init: Parsing file /system/etc/init/bootstat.rc...
[    3.104626][    T1] init: Parsing file /system/etc/init/bpfloader.rc...
[    3.105986][    T1] init: Parsing file /system/etc/init/cameraserver.rc...
[    3.107098][    T1] init: Parsing file /system/etc/init/clean_scratch_files.rc...
[    3.108034][    T1] init: Parsing file /system/etc/init/cppreopts.rc...
[    3.109215][    T1] init: Parsing file /system/etc/init/credstore.rc...
[    3.110218][    T1] init: Parsing file /system/etc/init/dmesgd.rc...
[    3.111174][    T1] init: Parsing file /system/etc/init/drmserver.rc...
[    3.112114][    T1] init: Parsing file /system/etc/init/dumpstate.rc...
[    3.113229][    T1] init: Parsing file /system/etc/init/flags_health_check.rc...
[    3.114343][    T1] init: Parsing file /system/etc/init/gatekeeperd.rc...
[    3.115335][    T1] init: Parsing file /system/etc/init/gpuservice.rc...
[    3.116433][    T1] init: Parsing file /system/etc/init/gsid.rc...
[    3.117656][    T1] init: Parsing file /system/etc/init/heapprofd.rc...
[    3.118900][    T1] init: Parsing file /system/etc/init/hwservicemanager.rc...
[    3.119975][    T1] init: Parsing file /system/etc/init/idmap2d.rc...
[    3.121030][    T1] init: Parsing file /system/etc/init/incidentd.rc...
[    3.122084][    T1] init: Parsing file /system/etc/init/init-debug.rc...
[    3.123116][    T1] init: Parsing file /system/etc/init/installd.rc...
[    3.124584][    T1] init: Parsing file /system/etc/init/keystore2.rc...
[    3.125606][    T1] init: Parsing file /system/etc/init/llkd-debuggable.rc...
[    3.126429][    T1] init: Parsing file /system/etc/init/llkd.rc...
[    3.127237][    T1] init: Parsing file /system/etc/init/lmkd.rc...
[    3.128147][    T1] init: Parsing file /system/etc/init/logcatd.rc...
[    3.129053][    T1] init: Parsing file /system/etc/init/logd.rc...
[    3.129980][    T1] init: Parsing file /system/etc/init/logtagd.rc...
[    3.130645][    T1] init: Parsing file /system/etc/init/lpdumpd.rc...
[    3.131331][    T1] init: Parsing file /system/etc/init/mdnsd.rc...
[    3.132027][    T1] init: Parsing file /system/etc/init/mediaextractor.rc...
[    3.132720][    T1] init: Parsing file /system/etc/init/mediametrics.rc...
[    3.133392][    T1] init: Parsing file /system/etc/init/mediaserver.rc...
[    3.134061][    T1] init: Parsing file /system/etc/init/mtpd.rc...
[    3.134683][    T1] init: Parsing file /system/etc/init/netd.rc...
[    3.135409][    T1] init: Parsing file /system/etc/init/odsign.rc...
[    3.136141][    T1] init: Parsing file /system/etc/init/otapreopt.rc...
[    3.136786][    T1] init: Parsing file /system/etc/init/perfetto.rc...
[    3.138097][    T1] init: Parsing file /system/etc/init/prng_seeder.rc...
[    3.138876][    T1] init: Parsing file /system/etc/init/profcollectd.rc...
[    3.139584][    T1] init: Parsing file /system/etc/init/racoon.rc...
[    3.140209][    T1] init: Parsing file /system/etc/init/recovery-persist.rc...
[    3.140886][    T1] init: Parsing file /system/etc/init/recovery-refresh.rc...
[    3.141671][    T1] init: Parsing file /system/etc/init/rss_hwm_reset.rc...
[    3.142393][    T1] init: Parsing file /system/etc/init/servicemanager.rc...
[    3.143124][    T1] init: Parsing file /system/etc/init/simpleperf.rc...
[    3.143731][    T1] init: Parsing file /system/etc/init/snapuserd.rc...
[    3.144402][    T1] init: Parsing file /system/etc/init/storaged.rc...
[    3.145062][    T1] init: Parsing file /system/etc/init/surfaceflinger.rc...
[    3.145813][    T1] init: Parsing file /system/etc/init/tombstoned.rc...
[    3.146507][    T1] init: Parsing file /system/etc/init/traced_perf.rc...
[    3.147282][    T1] init: Parsing file /system/etc/init/uncrypt.rc...
[    3.147961][    T1] init: Parsing file /system/etc/init/update_engine.rc...
[    3.148607][    T1] init: Parsing file /system/etc/init/update_verifier.rc...
[    3.149394][    T1] init: Parsing file /system/etc/init/usbd.rc...
[    3.150062][    T1] init: Parsing file /system/etc/init/vold.rc...
[    3.150677][    T1] init: Parsing file /system/etc/init/wifi.rc...
[    3.151743][    T1] init: Parsing file /system/etc/init/wificond.rc...
[    3.152613][    T1] init: Parsing file /system_ext/etc/init...
[    3.152732][    T1] init: Unable to read config file '/system_ext/etc/init': open() failed: No such file or
 directory
[    3.152783][    T1] init: Parsing directory /vendor/etc/init...
[    3.153040][    T1] init: Parsing file /vendor/etc/init/android.hardware.atrace@1.0-service.rc...
[    3.154005][    T1] init: Parsing file /vendor/etc/init/android.hardware.audio.service.rc...
[    3.154919][    T1] init: Parsing file /vendor/etc/init/android.hardware.bluetooth@1.1-service.btlinux.rc..
[    3.155584][    T1] init: Parsing file /vendor/etc/init/android.hardware.boot@1.2-service.rc...
[    3.156239][    T1] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.5-external-servi
ce.rc...
[    3.156971][    T1] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.5-service_64.rc.
[    3.157747][    T1] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.5-service_64_am6
2x.rc...
[    3.158460][    T1] init: Parsing file /vendor/etc/init/android.hardware.cas@1.2-service.rc...
[    3.159080][    T1] init: Parsing file /vendor/etc/init/android.hardware.drm-service.clearkey.rc...
[    3.159742][    T1] init: Parsing file /vendor/etc/init/android.hardware.gatekeeper@1.0-service.optee.rc...
[    3.160405][    T1] init: Parsing file /vendor/etc/init/android.hardware.graphics.allocator@4.0-service.img
.rc...
[    3.161112][    T1] init: Parsing file /vendor/etc/init/android.hardware.graphics.composer@2.4-service.rc..
[    3.161789][    T1] init: Parsing file /vendor/etc/init/android.hardware.health-service.cuttlefish.rc...
[    3.162406][    T1] init: Parsing file /vendor/etc/init/android.hardware.health.storage-service.cuttlefish.
rc...
[    3.163052][    T1] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.optee.rc...
[    3.163714][    T1] init: Parsing file /vendor/etc/init/android.hardware.media.omx@1.0-service.rc...
[    3.164337][    T1] init: Parsing file /vendor/etc/init/android.hardware.thermal@2.0-service-ti.rc...
[    3.165007][    T1] init: Parsing file /vendor/etc/init/android.hardware.usb@1.2-service.generic.rc...
[    3.165759][    T1] init: Parsing file /vendor/etc/init/android.hardware.wifi.supplicant-service.rc...
[    3.166447][    T1] init: Parsing file /vendor/etc/init/boringssl_self_test.rc...
[    3.167423][    T1] init: Parsing file /vendor/etc/init/dumpstate-default.rc...
[    3.168175][    T1] init: Parsing file /vendor/etc/init/hostapd.android.rc...
[    3.169064][    T1] init: Parsing file /vendor/etc/init/init.am62x.usb.rc...
[    3.170155][    T1] init: Parsing file /vendor/etc/init/init.am62x.zygote_wakelock.rc...
[    3.171129][    T1] init: Parsing file /vendor/etc/init/init.optee.rc...
[    3.171909][    T1] init: Parsing file /vendor/etc/init/memtrack-default.rc...
[    3.172596][    T1] init: Parsing file /vendor/etc/init/power-default.rc...
[    3.173397][    T1] init: Parsing file /vendor/etc/init/wait_for_keymaster_optee.rc...
[    3.174165][    T1] init: Parsing file /odm/etc/init...
[    3.174258][    T1] init: Unable to read config file '/odm/etc/init': open() failed: No such file or direct
ory
[    3.174325][    T1] init: Parsing file /product/etc/init...
[    3.174365][    T1] init: Unable to read config file '/product/etc/init': open() failed: No such file or di
rectory
[    3.175773][    T1] init: processing action (SetupCgroups) from (<Builtin Action>:0)
[    3.233526][    T1] init: Command 'SetupCgroups' action=SetupCgroups (<Builtin Action>:0) took 57ms and suc
ceeded
[    3.237582][    T1] init: processing action (SetKptrRestrict) from (<Builtin Action>:0)
[    3.238390][    T1] init: processing action (TestPerfEventSelinux) from (<Builtin Action>:0)
[    3.239274][    T1] init: processing action (ConnectEarlyStageSnapuserd) from (<Builtin Action>:0)
[    3.239457][    T1] init: processing action (early-init) from (/system/etc/init/hw/init.rc:15)
[    3.245311][    T1] init: Command 'mkdir /acct/uid' action=early-init (/system/etc/init/hw/init.rc:30) took
 3ms and failed: mkdir() failed on /acct/uid: Read-only file system
[    3.253839][    T1] init: starting service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconf
ig/bootstrap)'...
[    3.283717][    T1] init: SVC_EXEC service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconf
ig/bootstrap)' pid 108 (uid 0 gid 0+0 context default) started; waiting...
[    3.324155][  T108] linkerconfig: Unable to access VNDK APEX at path: /apex/com.android.vndk.v33: No such f
ile or directory
[    3.324303][  T108] linkerconfig: Unable to access VNDK APEX at path: /apex/com.android.vndk.v33: No such f
ile or directory
[    3.331540][  T108] linkerconfig (108) used greatest stack depth: 11696 bytes left
[    3.331862][    T1] init: Service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconfig/bootst
rap)' (pid 108) exited with status 0 waiting took 0.073000 seconds
[    3.331906][    T1] init: Sending signal 9 to service 'exec 1 (/system/bin/bootstrap/linkerconfig --target
/linkerconfig/bootstrap)' (pid 108) process group...
[    3.332282][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 108 in 0ms
[    3.335491][    T1] init: starting service 'ueventd'...
[    3.361800][    T1] init: starting service 'apexd-bootstrap'...
[    3.373732][    T1] init: SVC_EXEC service 'apexd-bootstrap' pid 110 (uid 0 gid 1000+0 context default) sta
rted; waiting...
[    3.411036][  T109] ueventd: ueventd started!
[    3.417226][  T109] selinux: SELinux: Loaded file_contexts
[    3.417281][  T109] selinux:
[    3.418320][  T109] ueventd: Parsing file /system/etc/ueventd.rc...
[    3.419420][  T109] ueventd: Added '/vendor/etc/ueventd.rc' to import list
[    3.419488][  T109] ueventd: Added '/odm/etc/ueventd.rc' to import list
[    3.420578][  T109] ueventd: Parsing file /vendor/etc/ueventd.rc...
[    3.422128][  T109] ueventd: Parsing file /odm/etc/ueventd.rc...
[    3.422257][  T109] ueventd: Unable to read config file '/odm/etc/ueventd.rc': open() failed: No such file
or directory
[    3.528265][  T110] apexd: Bootstrap subcommand detected
[    3.532459][  T110] cutils-trace: Error opening trace file: No such file or directory (2)
[    3.654682][  T111] ueventd: LoadWithAliases was unable to load platform:reg-dummy
[    3.656972][  T111] ueventd: LoadWithAliases was unable to load of:Nregulator-2T(null)Cregulator-fixed
[    3.658583][  T111] ueventd: LoadWithAliases was unable to load of:NramoopsT(null)Cramoops
[    3.659308][  T112] ueventd: Loading module /vendor/lib/modules/gpio-regulator.ko with args ''
[    3.659382][  T111] ueventd: LoadWithAliases was unable to load platform:Fixed MDIO bus
[    3.661184][  T111] ueventd: LoadWithAliases was unable to load of:NledsT(null)Cgpio-leds
[    3.663490][  T111] ueventd: Loading module /vendor/lib/modules/pvrsrvkm.ko with args ''
[    3.666489][  T112] ueventd: LoadWithAliases was unable to load of:Nregulator-0T(null)Cregulator-fixed
[    3.666664][  T113] ueventd: Loading module /vendor/lib/modules/tee.ko with args ''
[    3.668328][  T112] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
[    3.670146][  T112] ueventd: LoadWithAliases was unable to load of:NsramT(null)Cmmio-sram
[    3.678761][  T114] ueventd: LoadWithAliases was unable to load platform:ti-cpufreq
[    3.683270][  T114] ueventd: LoadWithAliases was unable to load of:Nl2-cache0T(null)Ccache
[    3.685633][  T114] ueventd: LoadWithAliases was unable to load of:NpsciT(null)Carm,psci-1.0
[    3.687117][  T114] ueventd: LoadWithAliases was unable to load platform:snd-soc-dummy
[    3.688860][  T112] ueventd: LoadWithAliases was unable to load mmc:block
[    3.689132][  T114] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.729094][  T113] ueventd: Loading module /vendor/lib/modules/optee.ko with args ''
[    3.729488][  T111] pvrsrvkm: loading out-of-tree module taints kernel.
[    3.736562][  T113] ueventd: Loading module /vendor/lib/modules/display-connector.ko with args ''
[    3.737426][  T112] ueventd: Loading module /vendor/lib/modules/omap-mailbox.ko with args ''
[    3.742656][  T113] ueventd: LoadWithAliases was unable to load of:Nregulator-7T(null)Cregulator-fixed
[    3.744814][  T113] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.745621][  T114] ueventd: Loading module /vendor/lib/modules/syscon-clk.ko with args ''
[    3.749144][  T113] ueventd: Loading module /vendor/lib/modules/gpio-davinci.ko with args ''
[    3.749144][  T114] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
[    3.752108][  T114] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
[    3.757224][  T113] ueventd: Loading module /vendor/lib/modules/cqhci.ko with args ''
[    3.758107][  T112] ueventd: Loading module /vendor/lib/modules/syscon-clk.ko with args ''
[    3.759091][  T114] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cpinctrl-single
[    3.760588][  T114] ueventd: Loading module /vendor/lib/modules/snd-soc-hdmi-codec.ko with args ''
[    3.760680][  T113] cqhci: exports duplicate symbol cqhci_deactivate (owned by kernel)
[    3.764597][  T112] ueventd: Loading module /vendor/lib/modules/phy-gmii-sel.ko with args ''
[    3.765395][  T114] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-hdmi-codec.ko
[    3.767690][  T111] PVR_K:  111: Device: fd00000.gpu
[    3.767987][  T111] PVR_K:  111: Read BVNC 33.15.11.3 from HW device registers
[    3.768187][  T111] PVR_K:  111: RGX Device registered with BVNC 33.15.11.3
[    3.768443][  T114] ueventd: Loading module /vendor/lib/modules/irq-ti-sci-intr.ko with args ''
[    3.769499][  T111] [drm] Initialized pvr 23.1.6404501 20170530 for fd00000.gpu on minor 1
[    3.771049][  T111] ueventd: Loaded kernel module /vendor/lib/modules/pvrsrvkm.ko
[    3.772980][  T112] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
[    3.773534][  T114] ueventd: LoadWithAliases was unable to load of:Ndma-controllerT(null)Cti,am64-dmss-bcdm
a
[    3.773579][  T111] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
[    3.774112][  T112] ueventd: Loading module /vendor/lib/modules/ti_sci_pm_domains.ko with args ''
[    3.775869][  T114] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cti,am6-padconf
[    3.778325][  T112] ueventd: Loading module /vendor/lib/modules/i2c-omap.ko with args ''
[    3.787646][  T114] ueventd: Loading module /vendor/lib/modules/dwc3-am62.ko with args ''
[    3.800965][  T113] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format erro
r
[    3.801065][  T113] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
[    3.801094][  T113] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
[    3.809685][  T112] ueventd: Loading module /vendor/lib/modules/gpio-pca953x.ko with args ''
[    3.814255][  T111] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.814539][  T112] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.816158][  T111] ueventd: LoadWithAliases was unable to load of:NsysconT(null)CsysconCsimple-mfd
[    3.816484][  T112] ueventd: LoadWithAliases was unable to load of:Ndma-controllerT(null)Cti,am64-dmss-pktd
ma
[    3.818419][  T111] ueventd: Loading module /vendor/lib/modules/syscon-clk.ko with args ''
[    3.818720][  T112] ueventd: Loading module /vendor/lib/modules/ti-msgmgr.ko with args ''
[    3.821025][  T111] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
[    3.823503][  T111] ueventd: Loading module /vendor/lib/modules/spi-cadence-quadspi.ko with args ''
[    3.825177][  T112] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.826166][  T112] ueventd: LoadWithAliases was unable to load mmc:block
[    3.827854][  T112] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
[    3.829741][  T112] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cpinctrl-single
[    3.829741][  T111] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
[    3.830903][  T111] ueventd: Loading module /vendor/lib/modules/reset-ti-sci.ko with args ''
[    3.832178][  T112] ueventd: Loading module /vendor/lib/modules/gpio-davinci.ko with args ''
[    3.834375][  T112] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
[    3.835503][  T112] ueventd: LoadWithAliases was unable to load usb:v0461p4D15d0200dc00dsc00dp00ic03isc01ip
02in00
[    3.835755][  T111] ueventd: Loading module /vendor/lib/modules/v4l2-async.ko with args ''
[    3.837685][  T114] ueventd: LoadWithAliases was unable to load input:b0003v0461p4D15e0111-e0,1,2,4,k110,11
1,112,r0,1,8,B,am4,lsfw
[    3.839921][  T112] ueventd: Loading module /vendor/lib/modules/pruss.ko with args ''
[    3.839921][  T111] ueventd: Loaded kernel module /vendor/lib/modules/v4l2-async.ko
[    3.840062][  T111] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
[    3.843619][  T114] ueventd: Loading module /vendor/lib/modules/drm_dma_helper.ko with args ''
[    3.846015][  T114] ueventd: Loading module /vendor/lib/modules/tidss.ko with args ''
[    3.847827][  T112] ueventd: Loading module /vendor/lib/modules/pru_rproc.ko with args ''
[    3.853372][  T114] ueventd: Loading module /vendor/lib/modules/pru_rproc.ko with args ''
[    3.854822][  T111] ueventd: Loaded kernel module /vendor/lib/modules/j721e-csi2rx.ko
[    3.857092][  T114] ueventd: Loading module /vendor/lib/modules/irq-pruss-intc.ko with args ''
[    3.859493][  T112] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.860255][  T113] ueventd: LoadWithAliases was unable to load of:Ndss-oldi-io-ctrlT(null)Csyscon
[    3.861326][  T112] ueventd: Loading module /vendor/lib/modules/cdns-dphy-rx.ko with args ''
[    3.861326][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x.ko with args ''
[    3.863591][  T113] ueventd: LoadWithAliases was unable to load spi:spi-nor
[    3.864469][  T114] ueventd: Loading module /vendor/lib/modules/sa2ul.ko with args ''
[    3.867086][  T113] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
[    3.868279][  T113] ueventd: Loading module /vendor/lib/modules/sci-clk.ko with args ''
[    3.871881][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-tlv320aic3x.ko
[    3.872052][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x-i2c.ko with args ''
[    3.872954][  T114] ueventd: Loading module /vendor/lib/modules/i2c-omap.ko with args ''
[    3.874422][  T112] ueventd: Loading module /vendor/lib/modules/omap_hwspinlock.ko with args ''
[    3.876296][  T114] ueventd: Loading module /vendor/lib/modules/k3_j72xx_bandgap.ko with args ''
[    3.877296][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-tlv320aic3x-i2c.ko
[    3.879295][  T114] ueventd: LoadWithAliases was unable to load platform:rproc-virtio
[    3.879893][  T111] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.879950][  T112] ueventd: LoadWithAliases was unable to load of:NchipidT(null)Cti,am654-chipid
[    3.881550][  T111] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
[    3.883115][  T111] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-mfd
[    3.883115][  T112] ueventd: LoadWithAliases was unable to load of:Nr5fT(null)Cti,am62-r5f
[    3.883582][  T114] ueventd: LoadWithAliases was unable to load of:Ntimer-cl0-cpu0T(null)Carm,armv8-timer
[    3.884149][  T112] ueventd: Loading module /vendor/lib/modules/rpmsg_ns.ko with args ''
[    3.885382][  T114] ueventd: LoadWithAliases was unable to load of:Nregulator-3T(null)Cregulator-fixed
[    3.885584][  T111] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
[    3.886310][  T114] ueventd: LoadWithAliases was unable to load platform:psci-cpuidle
[    3.886524][  T113] ueventd: Loading module /vendor/lib/modules/i2c-mux.ko with args ''
[    3.887017][  T111] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
[    3.888180][  T112] ueventd: LoadWithAliases was unable to load rpmsg:ti.ipc4.ping-pong
[    3.890804][  T112] ueventd: LoadWithAliases was unable to load of:Nregulator-1T(null)Cregulator-fixed
[    3.891793][  T112] ueventd: LoadWithAliases was unable to load platform:serial8250
[    3.893455][  T114] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
03,0004,0005,0006,0007,000B
[    3.893518][  T114] ueventd:
[    3.893933][  T111] ueventd: LoadWithAliases was unable to load of:NesmT(null)Cti,j721e-esm
[    3.896509][  T111] ueventd: Loading module /vendor/lib/modules/irq-ti-sci-intr.ko with args ''
[    3.897359][  T113] ueventd: Loading module /vendor/lib/modules/sii902x.ko with args ''
[    3.898507][  T112] ueventd: LoadWithAliases was unable to load of:NpmuT(null)Carm,cortex-a53-pmu
[    3.903997][  T113] ueventd: Loading module /vendor/lib/modules/dwc3-am62.ko with args ''
[    3.907589][  T113] ueventd: Loading module /vendor/lib/modules/irq-ti-sci-inta.ko with args ''
[    3.908507][  T112] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
[    3.908563][  T112] ueventd:
[    3.910017][  T111] ueventd: Loading module /vendor/lib/modules/8250_omap.ko with args ''
[    3.916256][  T111] printk: console [ttyS2] disabled
[    3.916391][  T111] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 449, base_baud = 3000000) is a 8250
[    3.928622][  T113] ueventd: Loading module /vendor/lib/modules/k3-ringacc.ko with args ''
[    3.951922][  T111] printk: console [ttyS2] enabled
[    5.216717][   T29] omap_i2c 20000000.i2c: controller timed out
[    5.223958][  T111] ueventd: Loaded kernel module /vendor/lib/modules/8250_omap.ko
[    5.225741][  T113] ueventd: Loading module /vendor/lib/modules/k3-psil-lib.ko with args ''
[    5.231198][  T113] ueventd: Loading module /vendor/lib/modules/k3-udma.ko with args ''
[    5.234262][  T111] ueventd: Loading module /vendor/lib/modules/tps6598x.ko with args ''
[    5.244174][  T113] ueventd: Loading module /vendor/lib/modules/k3-udma-glue.ko with args ''
[    5.249607][   T29] tps6598x 0-003f: tps6598x_interrupt: failed to read events
[    5.254064][  T111] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
[    5.254353][  T113] ueventd: Loading module /vendor/lib/modules/ti-am65-cpsw-nuss.ko with args ''
[    5.270050][  T113] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    5.276958][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-edma.ko with args ''
[    5.316727][  T113] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    5.323216][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-edma.ko
[    5.329188][  T113] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver unknown
[    5.335520][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-sdma.ko with args ''
[    5.341012][  T113] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver unknown
[    5.341160][  T113] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw v
ersion 0x6BA81103 Ports: 3 quirks:00000006
[    5.352574][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-sdma.ko
[    5.358680][  T113] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    5.364881][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-udma.ko with args ''
[    5.372858][  T113] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    5.373576][  T113] pps pps0: new PPS source ptp0
[    5.391781][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-udma.ko
[    5.398771][  T113] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    5.404322][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-davinci-mcasp.ko with args ''
[   10.405072][  T113] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[   10.416285][  T113] ueventd: Loaded kernel module /vendor/lib/modules/ti-am65-cpsw-nuss.ko
[   10.418246][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-davinci-mcasp.ko
[   10.426928][  T113] ueventd: Loading module /vendor/lib/modules/cqhci.ko with args ''
[   10.434892][  T111] ueventd: LoadWithAliases was unable to load of:NsysconT(null)CsysconCsimple-mfd
[   10.450160][  T113] cqhci: exports duplicate symbol cqhci_deactivate (owned by kernel)
[   10.460151][  T111] ueventd: Loading module /vendor/lib/modules/ti_k3_r5_remoteproc.ko with args ''
[   10.475490][  T111] ueventd: Loading module /vendor/lib/modules/rpmsg_ns.ko with args ''
[   10.484033][  T111] ueventd: Loading module /vendor/lib/modules/virtio_rpmsg_bus.ko with args ''
[   10.495570][  T111] ueventd: LoadWithAliases was unable to load rpmsg:rpmsg_ctrl
[   10.505023][  T111] ueventd: LoadWithAliases was unable to load of:Nregulator-5T(null)Cregulator-fixed
[   10.516660][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card-utils.ko with args ''
[   10.532876][  T113] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format erro
r
[   10.542852][  T113] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
[   10.543719][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-simple-card-utils.ko
[   10.551332][  T113] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
[   10.560432][  T111] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card.ko with args ''
[   10.574214][  T113] ueventd: Loading module /vendor/lib/modules/ti_k3_common.ko with args ''
[   10.588075][  T113] ueventd: Loading module /vendor/lib/modules/ti_k3_m4_remoteproc.ko with args ''
[   10.602455][  T113] ueventd: LoadWithAliases was unable to load of:NgpioT(null)Cti,am64-gpioCti,keystone-gp
io
[   10.607437][  T111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-simple-card.ko
[   10.615032][  T113] ueventd: LoadWithAliases was unable to load platform:xhci-hcd
[   10.623629][  T111] ueventd: LoadWithAliases was unable to load platform:cpufreq-dt
[   10.629151][  T113] ueventd: LoadWithAliases was unable to load hid:b0003g0001v00000461p00004D15
[   10.636917][  T111] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
[   10.645789][  T113] ueventd: LoadWithAliases was unable to load usb:v1D6Bp0002d0601dc09dsc00dp01ic09isc00ip
00in00
[   10.656976][  T111] ueventd:
[   10.661076][  T110] apexd: wait for '/dev/loop-control' took 7070ms
[   10.669837][  T113] ueventd: Loading module /vendor/lib/modules/cqhci.ko with args ''
[   10.678410][  T111] ueventd (111) used greatest stack depth: 10352 bytes left
[   10.691824][  T113] cqhci: exports duplicate symbol cqhci_deactivate (owned by kernel)
[   10.692167][  T110] apexd: Pre-allocated 15 loopback devices
[   10.705743][  T110] apexd: Scanning /system/apex for pre-installed ApexFiles
[   10.713607][  T110] apexd: Found pre-installed APEX /system/apex/com.android.resolv.capex
[   10.729320][  T110] apexd: Found pre-installed APEX /system/apex/com.android.ondevicepersonalization.apex
[   10.736839][  T113] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format erro
r
[   10.740133][  T110] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
[   10.748828][  T113] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
[   10.763953][  T110] apexd: Found pre-installed APEX /system/apex/com.android.vndk.current.apex
[   10.765275][  T113] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
[   10.774904][  T110] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
[   10.784081][  T113] ueventd: LoadWithAliases was unable to load of:NcfgT(null)Cti,pruss-cfgCsyscon
[   10.791808][  T110] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.capex
[   10.803234][  T113] ueventd: Loading module /vendor/lib/modules/i2c-omap.ko with args ''
[   10.813788][  T110] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
[   10.818874][  T113] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
[   10.832182][  T110] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
[   10.834924][  T113] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
[   10.842200][  T110] apexd: Found pre-installed APEX /system/apex/com.android.mediaprovider.capex
[   10.859401][  T113] ueventd: Loaded kernel module /vendor/lib/modules/mcrc.ko
[   10.865405][  T110] apexd: Found pre-installed APEX /system/apex/com.android.os.statsd.apex
[   10.868195][  T113] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
[   10.876142][  T110] apexd: Found pre-installed APEX /system/apex/com.android.apex.cts.shim.apex
[   10.885153][  T113] ueventd: Loading module /vendor/lib/modules/rtc-ti-k3.ko with args ''
[   10.893051][  T110] apexd: Found pre-installed APEX /system/apex/com.android.art.capex
[   10.902765][  T113] ueventd: LoadWithAliases was unable to load platform:alarmtimer
[   10.913259][  T110] apexd: Found pre-installed APEX /system/apex/com.android.adbd.capex
[   10.918195][  T113] ueventd: LoadWithAliases was unable to load rpmsg:rpmsg_chrdev
[   10.930998][  T110] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
[   10.933109][  T113] ueventd: LoadWithAliases was unable to load of:NesmT(null)Cti,j721e-esm
[   10.940575][  T110] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
[   10.949900][  T113] ueventd: LoadWithAliases was unable to load of:Nopp-tableT(null)Coperating-points-v2-ti
-cpu
[   10.961313][  T110] apexd: Found pre-installed APEX /system/apex/com.android.adservices.capex
[   10.971107][  T113] ueventd: LoadWithAliases was unable to load of:Nregulator-6T(null)Cregulator-fixed
[   10.981504][  T110] apexd: Found pre-installed APEX /system/apex/com.android.uwb.capex
[   10.985013][  T113] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
[   10.998960][  T110] apexd: Found pre-installed APEX /system/apex/com.android.neuralnetworks.capex
[   11.003900][  T113] ueventd:
[   11.019828][  T110] apexd: Found pre-installed APEX /system/apex/com.android.extservices.capex
[   11.036340][  T110] apexd: Found pre-installed APEX /system/apex/com.android.i18n.apex
[   11.045756][  T110] apexd: Found pre-installed APEX /system/apex/com.android.scheduling.apex
[   11.045823][  T109] ueventd: Coldboot took 7.583 seconds
[   11.055322][  T110] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
[   11.063937][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-hdmi-codec.ko with args ''
[   11.068919][  T110] apexd: Found pre-installed APEX /system/apex/com.android.btservices.apex
[   11.086458][  T110] apexd: Found pre-installed APEX /system/apex/com.android.tethering.capex
[   11.096518][  T109] ueventd: Loading module /vendor/lib/modules/pvrsrvkm.ko with args ''
[   11.104510][  T110] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
[   11.121750][  T110] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
[   11.137816][  T110] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
[   11.138820][  T109] ueventd: Loading module /vendor/lib/modules/v4l2-async.ko with args ''
[   11.145516][  T110] apexd: /system_ext/apex does not exist. Skipping
[   11.154949][  T109] ueventd: Loading module /vendor/lib/modules/v4l2-fwnode.ko with args ''
[   11.160027][  T110] apexd: Scanning /product/apex for pre-installed ApexFiles
[   11.175667][  T110] apexd: /product/apex does not exist. Skipping
[   11.176328][  T109] ueventd: Loaded kernel module /vendor/lib/modules/v4l2-fwnode.ko
[   11.181881][  T110] apexd: Scanning /vendor/apex for pre-installed ApexFiles
[   11.189752][  T109] ueventd: Loading module /vendor/lib/modules/cdns-csi2rx.ko with args ''
[   11.196767][  T110] apexd: /vendor/apex does not exist. Skipping
[   11.212375][  T110] apexd: No block apex metadata partition found, not adding block apexes
[   11.221203][  T110] apexd: Pre-allocated 0 loopback devices
[   11.226964][  T109] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[   11.235390][  T109] ueventd: Loaded kernel module /vendor/lib/modules/cdns-csi2rx.ko
[   11.237258][  T150] loop0: detected capacity change from 0 to 74600
[   11.249904][  T151] loop1: detected capacity change from 0 to 96512
[   11.255669][  T109] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
[   11.281773][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x.ko with args ''
[   11.291927][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x-i2c.ko with args ''
[   11.310833][  T109] ueventd: Loading module /vendor/lib/modules/8250_omap.ko with args ''
[   11.333961][  T109] ueventd: LoadWithAliases was unable to load of:NserialT(null)Cti,am64-uartCti,am654-uar
t
[   11.337758][  T151] EXT4-fs (loop1): mounted filesystem without journal. Quota mode: none.
[   11.338037][  T150] apexd: Successfully mounted package /system/apex/com.android.i18n.apex on /apex/com.and
roid.i18n@1 duration=101
[   11.350703][  T150] loop2: detected capacity change from 0 to 1728
[   11.355366][  T109] ueventd: Loading module /vendor/lib/modules/mdio-bitbang.ko with args ''
[   11.361207][  T151] apexd: Successfully mounted package /system/apex/com.android.vndk.current.apex on /apex
/com.android.vndk.v33@1 duration=124
[   11.366880][  T151] loop3: detected capacity change from 0 to 16208
[   11.371827][  T109] ueventd: Loading module /vendor/lib/modules/davinci_mdio.ko with args ''
[   11.422214][  T109] ueventd: LoadWithAliases was unable to load of:Nethernet-phyT(null)
[   11.434805][  T109] ueventd: LoadWithAliases was unable to load of:Nethernet-phyT(null)
[   11.447328][  T109] ueventd: LoadWithAliases was unable to load of:NmdioT(null)Cti,cpsw-mdioCti,davinci_mdi
o
[   11.457552][  T150] EXT4-fs (loop2): mounted filesystem without journal. Quota mode: none.
[   11.457938][  T151] EXT4-fs (loop3): mounted filesystem without journal. Quota mode: none.
[   11.469702][  T150] apexd: Successfully mounted package /system/apex/com.android.tzdata.apex on /apex/com.a
ndroid.tzdata@330400000 duration=119
[   11.474583][  T151] apexd: Successfully mounted package /system/apex/com.android.runtime.apex on /apex/com.
android.runtime@1 duration=108
[   11.502056][  T110] apexd: Activated 4 packages.
[   11.522709][  T110] apexd: OnBootstrap done, duration=7989
[   11.533565][    T1] init: Service 'apexd-bootstrap' (pid 110) exited with status 0 waiting took 8.167000 se
conds
[   11.538249][  T109] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
[   11.543853][    T1] init: Sending signal 9 to service 'apexd-bootstrap' (pid 110) process group...
[   11.553440][  T109] ueventd: Loading module /vendor/lib/modules/k3-ringacc.ko with args ''
[   11.561006][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 110 in 0ms
[   11.570229][  T109] ueventd: Loading module /vendor/lib/modules/k3-psil-lib.ko with args ''
[   11.587336][  T109] ueventd: Loading module /vendor/lib/modules/k3-udma.ko with args ''
[   11.597744][  T109] ueventd: Loading module /vendor/lib/modules/k3-udma-glue.ko with args ''
[   11.607034][  T109] ueventd: Loading module /vendor/lib/modules/ti-am65-cpsw-nuss.ko with args ''
[   11.629406][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-edma.ko with args ''
[   11.639518][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-sdma.ko with args ''
[   11.649723][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-udma.ko with args ''
[   11.659026][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-davinci-mcasp.ko with args ''
[   11.662040][    T1] init: linkerconfig generated /linkerconfig with mounted APEX modules info
[   11.677170][    T1] init: Command 'update_linker_config' action=early-init (/system/etc/init/hw/init.rc:75)
 took 97ms and succeeded
[   11.694325][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card-utils.ko with args ''
[   11.703331][    T1] init: processing action (early-init) from (/init.environ.rc:2)
[   11.704543][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card.ko with args ''
[   11.711719][    T1] init: processing action (early-init) from (/vendor/etc/init/hw/init.am62x.rc:1)
[   11.736168][    T1] init: processing action (ro.product.debugfs_restrictions.enabled=true && early-init) fr
om (/system/etc/init/init-debug.rc:10)
[   11.749767][    T1] init: Command 'mount debugfs debugfs /sys/kernel/debug' action=ro.product.debugfs_restr
ictions.enabled=true && early-init (/system/etc/init/init-debug.rc:11) took 0ms and failed: mount() failed: De
vice or resource busy
[   11.771309][    T1] init: processing action (early-init) from (/system/etc/init/prng_seeder.rc:5)
[   11.781113][    T1] init: starting service 'prng_seeder'...
[   11.787871][    T1] init: Created socket '/dev/socket/prng_seeder', mode 666, user 1092, group 1092
[   11.817592][  T109] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
[   11.838016][    T1] init: Command 'start prng_seeder' action=early-init (/system/etc/init/prng_seeder.rc:6)
 took 57ms and succeeded
[   11.850123][    T1] init: processing action (ro.product.cpu.abilist32=* && early-init) from (/vendor/etc/in
it/boringssl_self_test.rc:2)
[   11.867120][    T1] init: starting service 'boringssl_self_test32_vendor'...
[   11.886507][    T1] init: SVC_EXEC service 'boringssl_self_test32_vendor' pid 158 (uid 0 gid 0+0 context de
[   12.054020][  T157] prng_seeder: Hanging forever because setup failed: hwrng.read_exact in new
[   12.054020][  T157]
[   12.065173][  T157] Caused by:
[   12.068297][  T157]     No such device (os error 19)
[   12.145909][    T1] init: Service 'boringssl_self_test32_vendor' (pid 158) exited with status 0 waiting too
k 0.267000 seconds
[   12.157296][    T1] init: Sending signal 9 to service 'boringssl_self_test32_vendor' (pid 158) process grou
p...
[   12.167729][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 158 in 0ms
[   12.177895][    T1] init: processing action (ro.product.cpu.abilist64=* && early-init) from (/vendor/etc/in
it/boringssl_self_test.rc:4)
[   12.190985][    T1] init: starting service 'boringssl_self_test64_vendor'...
[   12.228225][    T1] init: SVC_EXEC service 'boringssl_self_test64_vendor' pid 159 (uid 0 gid 0+0 context de
[   12.369193][    T1] init: Service 'boringssl_self_test64_vendor' (pid 159) exited with status 0 waiting too
k 0.167000 seconds
[   12.380585][    T1] init: Sending signal 9 to service 'boringssl_self_test64_vendor' (pid 159) process grou
p...
[   12.391041][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 159 in 0ms
[   12.401317][    T1] init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
[   12.410034][    T1] init: start_waiting_for_property("ro.cold_boot_done", "true"): already set
[   12.418774][    T1] init: processing action (SetMmapRndBits) from (<Builtin Action>:0)
[   12.427835][    T1] init: processing action (KeychordInit) from (<Builtin Action>:0)
[   12.435803][    T1] init: processing action (init) from (/system/etc/init/hw/init.rc:89)
[   12.444868][    T1] init: Command 'copy /system/etc/prop.default /dev/urandom' action=init (/system/etc/ini
t/hw/init.rc:94) took 0ms and failed: Could not read input file '/system/etc/prop.default': open() failed: No
[   12.488592][    T1] init: Command 'write /dev/blkio/blkio.weight 1000' action=init (/system/etc/init/hw/ini
t.rc:230) took 0ms and failed: Unable to write to file '/dev/blkio/blkio.weight': open() failed: Permission de
nied
[   12.509681][    T1] init: Command 'write /dev/blkio/background/blkio.weight 200' action=init (/system/etc/i
nit/hw/init.rc:231) took 0ms and failed: Unable to write to file '/dev/blkio/background/blkio.weight': open()
failed: Permission denied
[   12.532944][    T1] init: Command 'write /dev/blkio/blkio.group_idle 0' action=init (/system/etc/init/hw/in
it.rc:233) took 0ms and failed: Unable to write to file '/dev/blkio/blkio.group_idle': open() failed: Permissi
on denied
[   12.553942][    T1] init: Command 'write /dev/blkio/background/blkio.group_idle 0' action=init (/system/etc
/init/hw/init.rc:234) took 0ms and failed: Unable to write to file '/dev/blkio/background/blkio.group_idle': o
pen() failed: Permission denied
[   12.644423][    T1] Registered swp emulation handler
[   12.653605][    T1] init: starting service 'logd'...
[   12.659455][    T1] init: Created socket '/dev/socket/logd', mode 666, user 1036, group 1036
[   12.668470][    T1] init: Created socket '/dev/socket/logdr', mode 666, user 1036, group 1036
[   12.677574][    T1] init: Created socket '/dev/socket/logdw', mode 222, user 1036, group 1036
[   12.713310][    T1] init: Command 'start logd' action=init (/system/etc/init/hw/init.rc:465) took 60ms and
succeeded
[   12.726685][    T1] init: starting service 'lmkd'...
[   12.733114][    T1] init: Created socket '/dev/socket/lmkd', mode 660, user 1000, group 1000
[   12.758460][    T1] init: starting service 'servicemanager'...
[   12.804257][    T1] init: starting service 'hwservicemanager'...
[   12.804428][  T160] logd.auditd: start
[   12.826489][    T1] init: Command 'start vndservicemanager' action=init (/system/etc/init/hw/init.rc:477) t
ook 0ms and failed: service vndservicemanager not found
[   12.840108][  T160] logd: Loaded bug_map file: /vendor/etc/selinux/selinux_denial_metadata
[   12.841410][    T1] init: processing action (ro.product.cpu.abilist32=* && init) from (/system/etc/init/hw/
init.rc:480)
[   12.851831][  T160] logd: Loaded bug_map file: /system/etc/selinux/bug_map
[   12.861894][    T1] init: starting service 'boringssl_self_test32'...
[   12.886189][    T1] init: SVC_EXEC service 'boringssl_self_test32' pid 172 (uid 0 gid 0+0 context default)
started; waiting...
[   13.015824][    T1] init: Service 'boringssl_self_test32' (pid 172) exited with status 0 waiting took 0.137
000 seconds
[   13.026618][    T1] init: Sending signal 9 to service 'boringssl_self_test32' (pid 172) process group...
[   13.036417][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 172 in 0ms
[   13.046528][    T1] init: processing action (ro.product.cpu.abilist64=* && init) from (/system/etc/init/hw/
init.rc:482)
[   13.058047][    T1] init: starting service 'boringssl_self_test64'...
[   13.088290][    T1] init: SVC_EXEC service 'boringssl_self_test64' pid 173 (uid 0 gid 0+0 context default)
started; waiting...
[   13.167709][    T1] init: Service 'boringssl_self_test64' (pid 173) exited with status 0 waiting took 0.099
000 seconds
[   13.178502][    T1] init: Sending signal 9 to service 'boringssl_self_test64' (pid 173) process group...
[   13.188315][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 173 in 0ms
[   13.198475][    T1] init: processing action (ro.debuggable=1 && init) from (/system/etc/init/hw/init.rc:128
3)
[   13.209709][    T1] init: starting service 'console'...
[   13.253769][    T1] init: processing action (init) from (/system/etc/init/hw/init.usb.rc:27)
[   13.263152][    T1] init: processing action (init) from (/vendor/etc/init/hw/init.am62x.rc:5)
console:/ $ [   13.333485][    T1] init: Command 'start watchdogd' action=init (/vendor/etc/init/hw/init.am62x
.rc:56) took 0ms and failed: service watchdogd not found
[   13.347153][    T1] init: processing action (init) from (/system/etc/init/audioserver.rc:62)
[   13.357320][    T1] init: processing action (late-init) from (/system/etc/init/hw/init.rc:517)
[   13.366093][    T1] init: processing action (late-init) from (/system/etc/init/atrace.rc:3)
[   13.393197][    T1] init: processing action (late-init) from (/vendor/etc/init/android.hardware.atrace@1.0-
service.rc:1)
[   13.405396][    T1] init: processing action (queue_property_triggers) from (<Builtin Action>:0)
[   13.414663][    T1] init: processing action (early-fs) from (/system/etc/init/hw/init.rc:550)
[   13.423893][    T1] init: starting service 'vold'...
[   13.452169][    T1] init: processing action (early-fs) from (/vendor/etc/init/hw/init.am62x.rc:71)
[   13.461566][    T1] init: service 'vold' requested start, but it is already running (flags: 2052)
[   13.470711][    T1] init: processing action (fs) from (/vendor/etc/init/hw/init.am62x.rc:74)
[   13.484927][    T1] init: [libfs_mgr]Invalid ext4 superblock on '/dev/block/platform/bus@f0000/fa10000.mmc/
by-name/metadata'
[   13.496759][    T1] init: [libfs_mgr]mount_with_alternatives(): skipping mount due to invalid magic, mountp
oint=/metadata blk_dev=/dev/block/mmcblk0p12 rec[2].fs_type=ext4
[   13.512878][    T1] init: [libfs_mgr]Failed to mount an un-encryptable or wiped partition on /dev/block/pla
tform/bus@f0000/fa10000.mmc/by-name/metadata at /metadata options: discard: Invalid argument
[   13.531922][    T1] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/platform/bus@f0000/fa10000
.mmc/by-name/persist
[   13.543729][    T1] init: [libfs_mgr]Filesystem on /dev/block/platform/bus@f0000/fa10000.mmc/by-name/persis
t was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[   13.560147][    T1] EXT4-fs: Ignoring removed nomblk_io_submit option
[   13.595746][    T1] EXT4-fs (mmcblk0p13): recovery complete
[   13.602226][    T1] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Quota mode: none.
[   13.611973][    T1] init: [libfs_mgr]check_fs(): mount(/dev/block/platform/bus@f0000/fa10000.mmc/by-name/pe
rsist,/mnt/vendor/persist,ext4)=0: Success
[   13.626270][    T1] EXT4-fs (mmcblk0p13): unmounting filesystem.
[   13.638211][    T1] init: [libfs_mgr]umount_retry(): unmount(/mnt/vendor/persist) succeeded
[   13.647258][    T1] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/mmcblk0p13
[   13.724289][    T1] e2fsck: e2fsck 1.46.2 (28-Feb-2021)
[   13.735131][    T1] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   13.741928][    T1] e2fsck: Pass 2: Checking directory structure
[   13.748052][    T1] e2fsck: Pass 3: Checking directory connectivity
[   13.754518][    T1] e2fsck: Pass 4: Checking reference counts
[   13.760394][    T1] e2fsck: Pass 5: Checking group summary information
[   13.767184][    T1] e2fsck: /mnt/vendor/pers: 17/8192 files (29.4% non-contiguous), 1566/8192 blocks
[   13.781346][    T1] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Quota mode: none.
[   13.791328][    T1] init: [libfs_mgr]__mount(source=/dev/block/platform/bus@f0000/fa10000.mmc/by-name/persi
st,target=/mnt/vendor/persist,type=ext4)=0: Success
[   13.816163][    T1] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --early' action=fs (/vendor/e
tc/init/hw/init.am62x.rc:75) took 336ms and succeeded
[   13.834326][    T1] init: processing action (fs) from (/system/etc/init/logd.rc:29)
[   13.843338][    T1] init: processing action (fs) from (/system/etc/init/wifi.rc:25)
[   13.852121][    T1] init: processing action (post-fs) from (/system/etc/init/hw/init.rc:554)
[   13.861668][    T1] init: starting service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)'...
[   13.903126][    T1] init: SVC_EXEC service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' pid 187 (u
id 1000 gid 1000+0 context default) started; waiting...
[   13.918134][    T1] init: Command 'exec - system system -- /system/bin/vdc checkpoint markBootAttempt' acti
on=post-fs (/system/etc/init/hw/init.rc:555) took 57ms and succeeded
[   13.952352][    T1] init: Service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' (pid 187) exited wi
th status 0 waiting took 0.077000 seconds
[   13.966104][    T1] init: Sending signal 9 to service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)'
 (pid 187) process group...
[   13.979003][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 187 in 0ms
[   14.003287][    T1] init: Command 'chown system cache /cache' action=post-fs (/system/etc/init/hw/init.rc:5
70) took 0ms and failed: lchown() failed: Read-only file system
[   14.019048][    T1] init: Command 'chmod 0770 /cache' action=post-fs (/system/etc/init/hw/init.rc:571) took
 0ms and failed: fchmodat() failed: Read-only file system
[   14.040883][    T1] selinux: SELinux:  setxattr failed: /metadata:  Read-only file system
[   14.049153][    T1] selinux:
[   14.053199][    T1] init: Command 'mkdir /metadata/vold' action=post-fs (/system/etc/init/hw/init.rc:608) t
ook 0ms and failed: mkdir() failed on /metadata/vold: Read-only file system
[   14.070271][    T1] init: Command 'mkdir /metadata/password_slots 0771 root system' action=post-fs (/system
/etc/init/hw/init.rc:610) took 0ms and failed: mkdir() failed on /metadata/password_slots: Read-only file syst
em
[   14.090371][    T1] init: Command 'mkdir /metadata/bootstat 0750 system log' action=post-fs (/system/etc/in
it/hw/init.rc:611) took 0ms and failed: mkdir() failed on /metadata/bootstat: Read-only file system
[   14.109326][    T1] init: Command 'mkdir /metadata/ota 0700 root system' action=post-fs (/system/etc/init/h
w/init.rc:612) took 0ms and failed: mkdir() failed on /metadata/ota: Read-only file system
[   14.127790][    T1] init: Command 'mkdir /metadata/userspacereboot 0770 root system' action=post-fs (/syste
m/etc/init/hw/init.rc:614) took 0ms and failed: mkdir() failed on /metadata/userspacereboot: Read-only file sy
stem
[   14.147998][    T1] init: Command 'mkdir /metadata/watchdog 0770 root system' action=post-fs (/system/etc/i
nit/hw/init.rc:615) took 0ms and failed: mkdir() failed on /metadata/watchdog: Read-only file system
[   14.166950][    T1] init: Command 'mkdir /metadata/apex 0700 root system' action=post-fs (/system/etc/init/
hw/init.rc:617) took 0ms and failed: mkdir() failed on /metadata/apex: Read-only file system
[   14.185361][    T1] selinux: SELinux:  Could not stat /metadata/apex: No such file or directory.
[   14.194278][    T1] selinux:
[   14.197815][    T1] init: Command 'mkdir /metadata/staged-install 0770 root system' action=post-fs (/system
/etc/init/hw/init.rc:626) took 0ms and failed: mkdir() failed on /metadata/staged-install: Read-only file syst
em
[   14.217779][    T1] init: Command 'mkdir /metadata/sepolicy 0700 root root' action=post-fs (/system/etc/ini
t/hw/init.rc:627) took 0ms and failed: mkdir() failed on /metadata/sepolicy: Read-only file system
[   14.236144][    T1] init: processing action (post-fs) from (/vendor/etc/init/hw/init.am62x.rc:77)
[   14.246228][    T1] init: processing action (post-fs) from (/system/etc/init/atrace_userdebug.rc:7)
[   14.255971][    T1] init: processing action (post-fs) from (/system/etc/init/gsid.rc:8)
[   14.264777][    T1] init: Command 'mkdir /metadata/gsi 0771 root system' action=post-fs (/system/etc/init/g
sid.rc:9) took 0ms and failed: mkdir() failed on /metadata/gsi: Read-only file system
[   14.283146][    T1] init: processing action (post-fs) from (/system/etc/init/recovery-refresh.rc:1)
[   14.292969][    T1] init: starting service 'exec 3 (/system/bin/recovery-refresh)'...
[   14.322721][    T1] init: processing action (post-fs) from (/vendor/etc/init/init.optee.rc:1)
[   14.344771][    T1] init: processing action (late-fs) from (/system/etc/init/hw/init.rc:628)
[   14.353896][    T1] init: Service 'exec 3 (/system/bin/recovery-refresh)' (pid 188) exited with status 254
oneshot service took 0.048000 seconds in background
[   14.368198][    T1] init: Sending signal 9 to service 'exec 3 (/system/bin/recovery-refresh)' (pid 188) pro
cess group...
[   14.379425][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 188 in 0ms
[   14.393074][    T1] init: starting service 'system_suspend'...
[   14.425166][    T1] init: starting service 'keystore2'...
[   14.448488][    T1] init: starting service 'vendor.atrace-hal-1-0'...
[   14.478161][    T1] init: starting service 'vendor.boot-hal-1-2'...
[   14.499857][    T1] init: starting service 'tee-supplicant'...
[   14.520956][    T1] init: Command 'class_start early_hal' action=late-fs (/system/etc/init/hw/init.rc:635)
took 131ms and succeeded
[   14.534118][    T1] init: starting service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)'...
[   14.554392][    T1] init: SVC_EXEC service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' pid 19
6 (uid 0 gid 0+0 context default) started; waiting...
[   14.611408][    T1] init: Service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' (pid 196) exite
d with status 0 waiting took 0.062000 seconds
[   14.625561][    T1] init: Sending signal 9 to service 'exec 4 (/system/bin/fsverity_init --load-verified-ke
ys)' (pid 196) process group...
[   14.638555][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 196 in 0ms
[   14.648378][    T1] init: processing action (late-fs) from (/system/etc/init/hw/init.rc:649)
[   14.657897][    T1] init: processing action (late-fs) from (/vendor/etc/init/hw/init.am62x.rc:87)
[   14.667918][    T1] init: starting service 'bootanim'...
[   14.707386][    T1] init: service 'bootanim' requested start, but it is already running (flags: 134)
[   14.716921][    T1] init: service 'hwservicemanager' requested start, but it is already running (flags: 221
2)
[   14.727069][    T1] init: service 'servicemanager' requested start, but it is already running (flags: 2084)
[   14.737697][    T1] init: starting service 'surfaceflinger'...
[   14.744484][    T1] init: Could not create socket 'pdx/system/vr/display/client': Failed to bind socket 'pd
x/system/vr/display/client': No such file or directory
[   14.759870][    T1] init: Could not create socket 'pdx/system/vr/display/manager': Failed to bind socket 'p
dx/system/vr/display/manager': No such file or directory
[   14.775397][    T1] init: Could not create socket 'pdx/system/vr/display/vsync': Failed to bind socket 'pdx
/system/vr/display/vsync': No such file or directory
[   14.802445][    T1] init: starting service 'vendor.gralloc-4-0'...
[   14.825449][    T1] init: starting service 'vendor.hwcomposer-2-4'...
[   14.851785][    T1] init: Command 'class_start animation' action=late-fs (/vendor/etc/init/hw/init.am62x.rc
:90) took 144ms and succeeded
[   14.865904][    T1] init: starting service 'vendor.keymaster-3-0-optee'...
[   14.889963][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.
0::IKeymasterDevice/default' from pid: 166 (/system/bin/hwservicemanager)
[   14.907568][    T1] init: start_waiting_for_property("hwservicemanager.ready", "true"): already set
[   14.917455][    T1] init: service 'vendor.keymaster-3-0-optee' requested start, but it is already running (
flags: 132)
[   14.928381][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.
[   14.945562][    T1] init: processing action (late-fs) from (/vendor/etc/init/init.optee.rc:4)
[   14.955563][    T1] init: starting service 'wait_for_keymaster_optee'...
[   15.009565][    T1] init: SVC_EXEC service 'wait_for_keymaster_optee' pid 210 (uid 1000 gid 1000+1 context
[   15.022075][    T1] init: Command 'exec_start wait_for_keymaster_optee' action=late-fs (/vendor/etc/init/in
it.optee.rc:5) took 67ms and succeeded
[   15.151436][  T201] PVR_K:  201: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[   15.179959][  T201] PVR_K:  201: Shader binary image 'rgx.sh.33.15.11.3' loaded
[   15.190298][    T1] init: Service 'wait_for_keymaster_optee' (pid 210) exited with status 0 waiting took 0.
223000 seconds
[   15.203126][    T1] init: Sending signal 9 to service 'wait_for_keymaster_optee' (pid 210) process group...
[   15.213657][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 210 in 0ms
[   15.229921][    T1] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
[   15.297726][    T1] vdc: vdc terminated by exit(1)
[   15.302796][    T1] vdc:
[   15.310057][    T1] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a -c 10000 --debug-cache /dev/block/mmc
blk0p14
[   15.363771][    T1] fsck.f2fs: Info: Fix the reported corruption.
[   15.370622][    T1] fsck.f2fs: Info: not exist /proc/version!
[   15.376640][    T1] fsck.f2fs: Info: Segments per section = 1
[   15.383075][    T1] fsck.f2fs: Info: Sections per zone = 1
[   15.388736][    T1] fsck.f2fs: Info: sector size = 512
[   15.394089][    T1] fsck.f2fs: Info: total sectors = 21319391 (10409 MB)
[   15.401028][    T1] fsck.f2fs: Info: MKFS version
[   15.405874][    T1] fsck.f2fs:   "5.15.0-76-generic"
[   15.411100][    T1] fsck.f2fs: Info: FSCK version
[   15.415943][    T1] fsck.f2fs:   from "6.1.25-android13-11"
[   15.421698][    T1] fsck.f2fs:     to "6.1.25-android13-11"
[   15.427402][    T1] fsck.f2fs: Info: version timestamp cur: 21, prev: 21
[   15.434351][    T1] fsck.f2fs: [update_superblock: 701] Info: Done to update superblock
[   15.442540][    T1] fsck.f2fs: Info: superblock features = 1499 :  encrypt verity extra_attr project_quota
quota_ino casefold
[   15.454062][    T1] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
[   15.463926][    T1] fsck.f2fs: Info: total FS sectors = 20891648 (10201 MB)
[   15.471077][    T1] fsck.f2fs: Info: CKPT version = 3e0b370a
[   15.513674][    T1] fsck.f2fs: Info: checkpoint state = 10c0 :  nat_bits crc disabled sudden-power-off
[   15.523175][    T1] fsck.f2fs: Info: No error was reported
[   15.528789][    T1] fsck.f2fs:
[   15.531979][    T1] fsck.f2fs: c, u, RA, CH, CM, Repl=
[   15.537232][    T1] fsck.f2fs: 10000 1640 6610 4970 1640 0
[   15.545103][    T1] F2FS-fs (mmcblk0p14): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
[   15.621675][    T1] F2FS-fs (mmcblk0p14): Disable nat_bits due to incorrect cp_ver (17379437713782683402, 9
18373693800527625)
[   15.642419][    T1] F2FS-fs (mmcblk0p14): Start checkpoint disabled!
[   15.651930][    T1] F2FS-fs (mmcblk0p14): Mounted with checkpoint version = 3e0b370b
[   15.660652][    T1] init: [libfs_mgr]__mount(source=/dev/block/platform/bus@f0000/fa10000.mmc/by-name/userd
ata,target=/data,type=f2fs)=0: Success
[   15.705707][    T1] init: [libfs_mgr]umount_retry(): unmount(/data) succeeded
[   15.713151][    T1] init: Calling: /system/bin/vdc cryptfs encryptFstab /dev/block/platform/bus@f0000/fa100
00.mmc/by-name/userdata /data false f2fs
[   15.772031][  T176] vold: Failed to create /metadata/vold: Read-only file system
[   15.779854][  T176] vold: read_key failed in mountFstab
[   15.785897][  T233] vdc: Command: cryptfs encryptFstab /dev/block/platform/bus@f0000/fa10000.mmc/by-name/us
erdata /data false f2fs Failed: Status(-8, EX_SERVICE_SPECIFIC): '0: '
[   15.805733][    T1] vdc: vdc terminated by exit(25)
[   15.812779][    T1] vdc:
[   15.817720][    T1] init: vdc call failed with error code: 25
[   15.823726][    T1] init: [libfs_mgr]Encryption failed
[   15.833097][    T1] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --late' action=late-fs (/vend
or/etc/init/init.optee.rc:6) took 607ms and failed: queue_fs_event() failed: Invalid code: -1
[   15.852598][    T1] init: processing action (post-fs-data) from (/system/etc/init/hw/init.rc:663)
[   15.862420][    T1] init: starting service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)'...
[   15.903195][    T1] init: SVC_EXEC service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' pid 234
(uid 1000 gid 1000+0 context default) started; waiting...
[   15.918249][    T1] init: Command 'exec - system system -- /system/bin/vdc checkpoint prepareCheckpoint' ac
tion=post-fs-data (/system/etc/init/hw/init.rc:668) took 56ms and succeeded
[   15.959838][    T1] init: Service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' (pid 234) exited
with status 0 waiting took 0.083000 seconds
[   15.973698][    T1] init: Sending signal 9 to service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint
)' (pid 234) process group...
[   15.986516][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 234 in 0ms
[   15.996842][    T1] init: Command 'chown system system /data' action=post-fs-data (/system/etc/init/hw/init
.rc:671) took 0ms and failed: lchown() failed: Read-only file system
[   16.013889][    T1] init: Command 'chmod 0771 /data' action=post-fs-data (/system/etc/init/hw/init.rc:672)
took 0ms and failed: fchmodat() failed: Read-only file system
[   16.031081][    T1] init: Command 'installkey /data' action=post-fs-data (/system/etc/init/hw/init.rc:677)
took 1ms and failed: Failed to create /data/unencrypted: Read-only file system
[   16.049332][    T1] init: Command 'mkdir /data/bootchart 0755 shell shell encryption=Require' action=post-f
s-data (/system/etc/init/hw/init.rc:681) took 1ms and failed: mkdir() failed on /data/bootchart: Read-only fil
e system
[   16.070005][    T1] init: Command 'copy /data/system/entropy.dat /dev/urandom' action=post-fs-data (/system
/etc/init/hw/init.rc:685) took 0ms and failed: Could not read input file '/data/system/entropy.dat': open() fa
iled: No such file or directory
[   16.093600][    T1] init: Command 'mkdir /data/vendor 0771 root root encryption=Require' action=post-fs-dat
a (/system/etc/init/hw/init.rc:687) took 1ms and failed: mkdir() failed on /data/vendor: Read-only file system
[   16.113803][    T1] init: Not setting encryption policy on: /data/vendor_ce
[   16.123409][    T1] init: Command 'mkdir /data/vendor_ce 0771 root root encryption=None' action=post-fs-dat
a (/system/etc/init/hw/init.rc:688) took 9ms and failed: mkdir() failed on /data/vendor_ce: Read-only file sys
tem
[   16.143508][    T1] init: Not setting encryption policy on: /data/vendor_de
[   16.153246][    T1] init: Command 'mkdir /data/vendor_de 0771 root root encryption=None' action=post-fs-dat
a (/system/etc/init/hw/init.rc:689) took 9ms and failed: mkdir() failed on /data/vendor_de: Read-only file sys
tem
[   16.177538][    T1] init: Command 'mkdir /data/anr 0775 system system encryption=Require' action=post-fs-da
ta (/system/etc/init/hw/init.rc:693) took 2ms and failed: mkdir() failed on /data/anr: Read-only file system
[   16.198776][    T1] init: Command 'mkdir /data/tombstones 0771 system system encryption=Require' action=pos
t-fs-data (/system/etc/init/hw/init.rc:694) took 1ms and failed: mkdir() failed on /data/tombstones: Read-only
 file system
[   16.224195][    T1] init: starting service 'tombstoned'...
[   16.231050][    T1] init: Created socket '/dev/socket/tombstoned_crash', mode 666, user 1000, group 1000
[   16.241840][    T1] init: Created socket '/dev/socket/tombstoned_intercept', mode 666, user 1000, group 100
0
[   16.252933][    T1] init: Created socket '/dev/socket/tombstoned_java_trace', mode 666, user 1000, group 10
00
[   16.287983][    T1] init: Command 'start tombstoned' action=post-fs-data (/system/etc/init/hw/init.rc:697)
took 64ms and succeeded
[   16.303603][    T1] init: Switched to default mount namespace
[   16.313775][    T1] init: Command 'mkdir /data/misc 01771 system misc encryption=Require' action=post-fs-da
ta (/system/etc/init/hw/init.rc:704) took 2ms and failed: mkdir() failed on /data/misc: Read-only file system
[   16.335049][    T1] selinux: SELinux: Could not get canonical path for /data/misc/keystore restorecon: No s
[   16.346895][    T1] selinux:
[   16.351903][    T1] init: starting service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)'...
[   16.370997][    T1] init: SVC_EXEC service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' pid 246 (uid
[   16.385944][    T1] init: Service 'tombstoned' (pid 240) exited with status 1
[   16.393293][    T1] init: Sending signal 9 to service 'tombstoned' (pid 240) process group...
[   16.402427][    T1] libprocessgroup: Successfully killed process cgroup uid 1058 pid 240 in 0ms
[   16.540082][    T1] init: service 'bootanim' requested start, but it is already running (flags: 134)
[   16.549913][    T1] init: Control message: Processed ctl.start for 'bootanim' from pid: 200 (/system/bin/su
rfaceflinger)
[   16.791010][  T171] type=1400 audit(22.416:4): avc: denied { read } for comm="crash_dump64" name="status" d
ev="selinuxfs" ino=19 scontext=u:r:crash_dump:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=0
[   16.793538][  T163] logd: logdr: UID=1017 GID=1017 PID=251 n tail=0 logMask=8 pid=190 start=0ns deadline=0n
s
[   16.810577][  T171] type=1400 audit(22.416:5): avc: denied { read } for comm="crash_dump64" name="status" d
[   16.824274][  T163] logd: logdr: UID=1017 GID=1017 PID=251 n tail=0 logMask=1 pid=190 start=0ns deadline=0n
s
[   16.851003][  T251] DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[   16.851210][  T251] DEBUG: Build fingerprint: 'TI/am62x/am62x:13/TQ3A.230705.001.A1/eng.root.20230721.19030
1:userdebug/test-keys'
[   16.859983][  T251] DEBUG: Revision: '0'
[   16.872083][  T251] DEBUG: ABI: 'arm64'
[   16.876423][  T251] DEBUG: Timestamp: 1970-01-01 00:00:22.138568105+0000
[   16.880774][  T251] DEBUG: Process uptime: 3s
[   16.888244][  T251] DEBUG: Cmdline: /system/bin/keystore2 /data/misc/keystore
[   16.893146][  T251] DEBUG: pid: 190, tid: 190, name: binder:190_2  >>> /system/bin/keystore2 <<<
[   16.900822][  T251] DEBUG: uid: 1017
[   16.910777][  T251] DEBUG: tagged_addr_ctrl: 0000000000000001 (PR_TAGGED_ADDR_ENABLE)
[   16.916773][  T251] DEBUG: signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
[   16.925444][  T251] DEBUG: Abort message: 'Failed to open database.: Failed to attach database persistent.
[   16.943246][  T251] DEBUG:
[   16.946204][  T251] DEBUG: Caused by:
[   16.949958][  T251] DEBUG:     0: unable to open database: file:/data/misc/keystore/persistent.sqlite
[   16.959252][  T251] DEBUG:     1: Error code 14: Unable to open the database file'
[   16.959855][  T251] DEBUG:     x0  0000000000000000  x1  00000000000000be  x2  0000000000000006  x3  000000
7fca960d60
[   16.968238][  T251] DEBUG:     x4  0000000000000000  x5  0000000000000000  x6  0000000000000000  x7  203a34
312065646f
[   16.979558][  T251] DEBUG:     x8  00000000000000f0  x9  00000072eb1a5a00  x10 0000000000000001  x11 000000
72eb1e76a0
[   16.990832][  T251] DEBUG:     x12 7265702f65726f74  x13 2e746e6574736973  x14 0000007fca95fd7c  x15 000000
0000000000
[   17.002096][  T251] DEBUG:     x16 00000072eb255d58  x17 00000072eb230770  x18 00000072f0776000  x19 000000
00000000ac
[   17.013264][  T251] DEBUG:     x20 00000000000000b2  x21 00000000000000be  x22 00000000000000be  x23 000000
00ffffffff
[   17.024590][  T251] DEBUG:     x24 0000000000000001  x25 00000059dd9c5750  x26 00000059dd9c57a8  x27 b40000
713647e92c
[   17.035915][  T251] DEBUG:     x28 00000059dd9c55f0  x29 0000007fca960de0
[   17.049070][  T251] DEBUG:     lr  00000072eb1d73f4  sp  0000007fca960d40  pc  00000072eb1d7424  pst 000000
0000000000
[   17.058506][  T251] DEBUG: backtrace:
[   17.069828][  T251] DEBUG:       #00 pc 0000000000053424  /apex/com.android.runtime/lib64/bionic/libc.so (a
bort+180) (BuildId: dfb63f03d096213c51b3eecca455feac)
[   17.074117][  T251] DEBUG:       #01 pc 00000000001576ac  /system/bin/keystore2 (_RNvNvCs2yrrfPAoZZX_11pani
c_abort18___rust_start_panic5abort.llvm.16868985108068327187+4) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.089284][  T251] DEBUG:       #02 pc 00000000001576a0  /system/bin/keystore2 (__rust_start_panic+8) (Bui
[   17.109207][  T251] DEBUG:       #03 pc 0000000000165c5c  /system/bin/keystore2 (rust_panic+16) (BuildId: 4
[   17.122816][  T251] DEBUG:       #04 pc 000000000016592c  /system/bin/keystore2 (_RNvNtCs4p8YLn7dL5m_3std9p
anicking20rust_panic_with_hook+996) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.136036][  T251] DEBUG:       #05 pc 0000000000165498  /system/bin/keystore2 (_RNCNvNtCs4p8YLn7dL5m_3std
9panicking19begin_panic_handler0B5_.llvm.8848384190362852836+112) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.153334][  T251] DEBUG:       #06 pc 0000000000163d90  /system/bin/keystore2 (_RINvNtNtCs4p8YLn7dL5m_3st
d10sys_common9backtrace26___rust_end_short_backtraceNCNvNtB6_9panicking19begin_panic_handler0zEB6_.llvm.884838
4190362852836+16) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.173437][  T251] DEBUG:       #07 pc 000000000016526c  /system/bin/keystore2 (rust_begin_unwind+36) (Bui
[   17.198788][  T251] DEBUG:       #08 pc 0000000000077388  /system/bin/keystore2 (_RNvNtCsl9ljXaK2GKD_4core9
panicking9panic_fmt+36) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.214156][  T251] DEBUG:       #09 pc 0000000000077560  /system/bin/keystore2 (_RNvNtCsl9ljXaK2GKD_4core6
result13unwrap_failed+80) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.231477][  T251] DEBUG:       #10 pc 00000000000d5bb0  /system/bin/keystore2 (_RNvNtCsjeBucwD6oYH_9keyst
ore27globals22create_thread_local_db+664) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.248256][  T251] DEBUG:       #11 pc 00000000001204c4  /system/bin/keystore2 (_RNvNvNtCsjeBucwD6oYH_9key
store27globals2DB7___getit+216) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.266182][  T251] DEBUG:       #12 pc 00000000000ecf74  /system/bin/keystore2 (_RNvXs0_NtCsjeBucwD6oYH_9k
eystore211maintenanceNtB5_11MaintenanceNtNtNtNtNtNtCs5RsHhU1Nfkr_28android_security_maintenance4aidl7android8s
ecurity11maintenance20IKeystoreMaintenance20IKeystoreMaintenance14earlyBootEnded+348) (BuildId: 4d0f04e7ae6050
7f03365eb208bb4f00)
[   17.283516][  T251] DEBUG:       #13 pc 0000000000064038  /system/bin/keystore2 (_RNvXs8_NtNtNtNtNtCs5RsHhU
1Nfkr_28android_security_maintenance4aidl7android8security11maintenance20IKeystoreMaintenanceNtB5_21BnKeystore
MaintenanceNtNtCs6pfwsPMdzSo_6binder6binder9Remotable11on_transact+396) (BuildId: 4d0f04e7ae60507f03365eb208bb
4f00)
[   17.314795][  T251] DEBUG:       #14 pc 0000000000064398  /system/bin/keystore2 (_RNvXs2_NtCs6pfwsPMdzSo_6b
inder6nativeINtB5_6BinderNtNtNtNtNtNtCs5RsHhU1Nfkr_28android_security_maintenance4aidl7android8security11maint
enance20IKeystoreMaintenance21BnKeystoreMaintenanceENtNtB7_6binder21InterfaceClassMethods11on_transactBY_+44)
[   17.345955][  T251] DEBUG:       #15 pc 000000000000b1fc  /system/lib64/libbinder_ndk.so (ABBinder::onTrans
act(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+140) (BuildId: 24e43640e469fbda0fca8
574a4564056)
[   17.379616][  T251] DEBUG:       #16 pc 000000000005213c  /system/lib64/libbinder.so (android::BBinder::tra
nsact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+236) (BuildId: 59206956ecca114b1ca
96a4d909f91d5)
[   17.402402][  T251] DEBUG:       #17 pc 000000000005d9d4  /system/lib64/libbinder.so (android::IPCThreadSta
te::executeCommand(int)+1012) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
[   17.424772][  T251] DEBUG:       #18 pc 000000000005d510  /system/lib64/libbinder.so (android::IPCThreadSta
te::getAndExecuteCommand()+160) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
[   17.444281][  T251] DEBUG:       #19 pc 000000000005dda4  /system/lib64/libbinder.so (android::IPCThreadSta
te::joinThreadPool(bool)+68) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
[   17.461948][  T251] DEBUG:       #20 pc 0000000000045e90  /system/bin/keystore2 (_RNvCsdV139EorvfX_14keysto
re2_main4main+3004) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.478992][  T251] DEBUG:       #21 pc 00000000000469bc  /system/bin/keystore2 (_RNCINvNtCs4p8YLn7dL5m_3st
d2rt10lang_startuE0CsdV139EorvfX_14keystore2_main+8) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.495507][  T251] DEBUG:       #22 pc 0000000000163788  /system/bin/keystore2 (_RNvNtCs4p8YLn7dL5m_3std2r
t19lang_start_internal+344) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
[   17.514524][  T251] DEBUG:       #23 pc 0000000000046ac0  /system/bin/keystore2 (main+40) (BuildId: 4d0f04e
[   17.531290][  T251] DEBUG:       #24 pc 000000000004b730  /apex/com.android.runtime/lib64/bionic/libc.so (_
_libc_init+96) (BuildId: dfb63f03d096213c51b3eecca455feac)
[   17.570791][    T1] init: Untracked pid 251 exited with status 0
[   17.576268][   T89] binder: release 190:190 transaction 531 in, still active
[   17.586065][    T1] init: Untracked pid 251 did not have an associated service entry and will not be reaped
[   17.592233][   T89] binder: send failed reply for transaction 531 to 176:176
[   17.599443][    T1] init: Service 'keystore2' (pid 190) received signal 6
[   17.623764][  T176] vold: keystore2 Communication with Keystore earlyBootEnded failed error: -129
[   17.633479][    T1] init: Sending signal 9 to service 'keystore2' (pid 190) process group...
[   17.643073][    T1] libprocessgroup: Successfully killed process cgroup uid 1017 pid 190 in 0ms
[   17.655089][    T1] init: Service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' (pid 246) exited with
 status 0 waiting took 1.289000 seconds
[   17.668677][    T1] init: Sending signal 9 to service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' (
pid 246) process group...
[   17.681449][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 246 in 0ms
[   17.693266][    T1] init: Untracked pid 253 exited with status 0
[   17.699568][    T1] init: Untracked pid 253 did not have an associated service entry and will not be reaped
[   17.711817][    T1] init: Command 'mkdir /data/property 0700 root root encryption=Require' action=post-fs-d
ata (/system/etc/init/hw/init.rc:725) took 1ms and failed: mkdir() failed on /data/property: Read-only file sy
stem
[   17.732580][  T106] init: Couldn't load property file '/data/local.prop': open() failed: No such file or di
rectory: No such file or directory
[   17.746548][  T106] init: Could not load single persistent property file, trying legacy directory: Unable t
o read persistent property file: open() failed: No such file or directory
[   17.763109][  T106] init: Unable to load legacy persistent properties: Unable to open persistent property d
irectory "/data/property": No such file or directory
[   17.778203][  T106] init: Wait for property 'ro.persistent_properties.ready=true' took 46ms
[   17.787168][    T1] init: service 'logd' requested start, but it is already running (flags: 4)
[   17.797245][    T1] init: starting service 'logd-reinit'...
[   17.842329][    T1] init: Not setting encryption policy on: /data/apex
[   17.851644][    T1] init: Command 'mkdir /data/apex 0755 root system encryption=None' action=post-fs-data (
/system/etc/init/hw/init.rc:742) took 9ms and failed: mkdir() failed on /data/apex: Read-only file system
[   17.875327][    T1] init: Inferred action different from explicit one, expected 0 but got 2
[   17.894417][    T1] init: Inferred action different from explicit one, expected 0 but got 3
[   17.905794][    T1] init: Command 'mkdir /data/app-staging 0751 system system encryption=DeleteIfNecessary'
 action=post-fs-data (/system/etc/init/hw/init.rc:748) took 11ms and failed: mkdir() failed on /data/app-stagi
ng: Read-only file system
[   17.927987][    T1] init: Inferred action different from explicit one, expected 0 but got 2
[   17.940618][    T1] init: starting service 'apexd'...
[   17.943224][  T165] logd: logd reinit
[   17.950422][  T165] logd: Cannot read /data/misc/logd/event-log-tags
[   17.961682][  T165] logd: FrameworkListener: read() failed (Connection reset by peer)
[   17.982538][    T1] init: Service 'logd-reinit' (pid 269) exited with status 0 oneshot service took 0.17300
[   17.995750][    T1] init: Sending signal 9 to service 'logd-reinit' (pid 269) process group...
[   18.005885][    T1] libprocessgroup: Successfully killed process cgroup uid 1036 pid 269 in 0ms
[   18.020099][    T1] init: Command 'copy /data/misc/recovery/ro.build.fingerprint /data/misc/recovery/ro.bui
ld.fingerprint.1' action=post-fs-data (/system/etc/init/hw/init.rc:755) took 0ms and failed: Could not read in
put file '/data/misc/recovery/ro.build.fingerprint': open() failed: No such file or directory
[   18.051160][  T270] apexd: Scanning /system/apex for pre-installed ApexFiles
[   18.051661][    T1] init: Command 'copy /data/misc/recovery/proc/version /data/misc/recovery/proc/version.1
' action=post-fs-data (/system/etc/init/hw/init.rc:762) took 0ms and failed: Could not read input file '/data/
misc/recovery/proc/version': open() failed: No such file or directory
[   18.061395][  T270] apexd: Found pre-installed APEX /system/apex/com.android.resolv.capex
[   18.086209][    T1] init: Command 'copy /proc/version /data/misc/recovery/proc/version' action=post-fs-data
 (/system/etc/init/hw/init.rc:765) took 2ms and failed: Could not write to output file '/data/misc/recovery/pr
[   18.094511][  T270] apexd: Found pre-installed APEX /system/apex/com.android.ondevicepersonalization.apex
[   18.128431][  T270] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
[   18.138740][  T270] apexd: Found pre-installed APEX /system/apex/com.android.vndk.current.apex
[   18.144676][    T1] init: Command 'mkdir /data/local 0751 root root encryption=Require' action=post-fs-data
 (/system/etc/init/hw/init.rc:799) took 1ms and failed: mkdir() failed on /data/local: Read-only file system
[   18.149408][  T270] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
[   18.177167][  T270] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.capex
[   18.188186][  T270] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
[   18.198869][  T270] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
[   18.209751][  T270] apexd: Found pre-installed APEX /system/apex/com.android.mediaprovider.capex
[   18.211444][    T1] init: starting service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice)'...
[   18.220152][  T270] apexd: Found pre-installed APEX /system/apex/com.android.os.statsd.apex
[   18.238422][  T270] apexd: Found pre-installed APEX /system/apex/com.android.apex.cts.shim.apex
[   18.249218][  T270] apexd: Found pre-installed APEX /system/apex/com.android.art.capex
[   18.258785][  T270] apexd: Found pre-installed APEX /system/apex/com.android.adbd.capex
[   18.268412][  T270] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
[   18.278593][  T270] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
[   18.288972][  T270] apexd: Found pre-installed APEX /system/apex/com.android.adservices.capex
[   18.299295][  T270] apexd: Found pre-installed APEX /system/apex/com.android.uwb.capex
[   18.299742][    T1] init: SVC_EXEC service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice)' pid 271
(uid 1081 gid 1000+0 context default) started; waiting...
[   18.309856][  T270] apexd: Found pre-installed APEX /system/apex/com.android.neuralnetworks.capex
[   18.322479][    T1] init: Command 'exec - virtualizationservice system -- /bin/rm -rf /data/misc/virtualiza
tionservice' action=post-fs-data (/system/etc/init/hw/init.rc:835) took 112ms and succeeded
[   18.334726][  T270] apexd: Found pre-installed APEX /system/apex/com.android.extservices.capex
[   18.362000][  T270] apexd: Found pre-installed APEX /system/apex/com.android.i18n.apex
[   18.372826][  T270] apexd: Found pre-installed APEX /system/apex/com.android.scheduling.apex
[   18.383934][  T270] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
[   18.393083][    T1] init: Service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice)' (pid 271) exited
with status 0 waiting took 0.159000 seconds
[   18.398730][  T270] apexd: Found pre-installed APEX /system/apex/com.android.btservices.apex
[   18.406862][    T1] init: Sending signal 9 to service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice
)' (pid 271) process group...
[   18.417615][  T270] apexd: Found pre-installed APEX /system/apex/com.android.tethering.capex
[   18.428474][    T1] libprocessgroup: Successfully killed process cgroup uid 1081 pid 271 in 0ms
[   18.437795][  T270] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
[   18.447919][    T1] init: Not setting encryption policy on: /data/preloads
[   18.456031][  T270] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
[   18.463248][    T1] init: Command 'mkdir /data/preloads 0775 system system encryption=None' action=post-fs-
data (/system/etc/init/hw/init.rc:838) took 15ms and failed: mkdir() failed on /data/preloads: Read-only file
system
[   18.470853][  T270] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
[   18.492317][    T1] init: Not setting encryption policy on: /data/data
[   18.497010][  T270] apexd: /system_ext/apex does not exist. Skipping
[   18.505279][    T1] init: Command 'mkdir /data/data 0771 system system encryption=None' action=post-fs-data
 (/system/etc/init/hw/init.rc:844) took 12ms and failed: mkdir() failed on /data/data: Read-only file system
[   18.509871][  T270] apexd: Scanning /product/apex for pre-installed ApexFiles
[   18.530588][    T1] init: Command 'mkdir /data/app-private 0771 system system encryption=Require' action=po
st-fs-data (/system/etc/init/hw/init.rc:845) took 1ms and failed: mkdir() failed on /data/app-private: Read-on
ly file system
[   18.536466][  T270] apexd: /product/apex does not exist. Skipping
[   18.559209][    T1] init: Command 'mkdir /data/app-ephemeral 0771 system system encryption=Require' action=
post-fs-data (/system/etc/init/hw/init.rc:846) took 1ms and failed: mkdir() failed on /data/app-ephemeral: Rea
d-only file system
[   18.563265][  T270] apexd: Scanning /vendor/apex for pre-installed ApexFiles
[   18.586906][    T1] init: Command 'mkdir /data/app-asec 0700 root root encryption=Require' action=post-fs-d
ata (/system/etc/init/hw/init.rc:847) took 1ms and failed: mkdir() failed on /data/app-asec: Read-only file sy
stem
[   18.591670][  T270] apexd: /vendor/apex does not exist. Skipping
[   18.612940][    T1] init: Command 'mkdir /data/app-lib 0771 system system encryption=Require' action=post-f
s-data (/system/etc/init/hw/init.rc:848) took 1ms and failed: mkdir() failed on /data/app-lib: Read-only file
system
[   18.617644][  T270] apexd: No block apex metadata partition found, not adding block apexes
[   18.638874][    T1] init: Command 'mkdir /data/app 0771 system system encryption=Require' action=post-fs-da
ta (/system/etc/init/hw/init.rc:849) took 1ms and failed: mkdir() failed on /data/app: Read-only file system
[   18.645478][  T270] apexd: Populating APEX database from mounts...
[   18.664799][    T1] init: Inferred action different from explicit one, expected 0 but got 2
[   18.672959][  T270] apexd: 0 packages restored.
[   18.680936][    T1] init: Command 'mkdir /data/fonts/ 0771 root root encryption=Require' action=post-fs-dat
a (/system/etc/init/hw/init.rc:852) took 16ms and failed: mkdir() failed on /data/fonts/: Read-only file syste
m
[   18.684122][  T270] apexd: Failed to migrate sessions to /metadata partition : Failed to stat /metadata/ape
x/sessions: No such file or directory
[   18.714110][    T1] init: Command 'mkdir /data/dalvik-cache 0771 root root encryption=Require' action=post-
fs-data (/system/etc/init/hw/init.rc:868) took 1ms and failed: mkdir() failed on /data/dalvik-cache: Read-only
 file system
[   18.717126][  T270] apexd: Marking APEXd as starting
[   18.738520][    T1] init: Command 'mkdir /data/ota 0771 root root encryption=Require' action=post-fs-data (
/system/etc/init/hw/init.rc:870) took 1ms and failed: mkdir() failed on /data/ota: Read-only file system
[   18.744853][  T270] apexd: Failed to stat /metadata/apex/sessions: No such file or directory
[   18.762427][    T1] init: Command 'mkdir /data/ota_package 0770 system cache encryption=Require' action=pos
t-fs-data (/system/etc/init/hw/init.rc:874) took 1ms and failed: mkdir() failed on /data/ota_package: Read-onl
y file system
[   18.769481][  T270] apexd: Failed to stat /data/apex/sessions: No such file or directory
[   18.791076][    T1] init: Command 'mkdir /data/resource-cache 0771 system system encryption=Require' action
=post-fs-data (/system/etc/init/hw/init.rc:877) took 1ms and failed: mkdir() failed on /data/resource-cache: R
[   18.819484][    T1] init: Service 'apexd' (pid 270) received signal 6 oneshot service took 0.867000 seconds
 in background
[   18.831078][    T1] init: Sending signal 9 to service 'apexd' (pid 270) process group...
[   18.840239][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 270 in 0ms
[   18.850302][    T1] init: Service with 'reboot_on_failure' option failed, shutting down system.
[   18.861443][    T1] init: Untracked pid 273 exited with status 1
[   18.867795][    T1] init: Untracked pid 273 did not have an associated service entry and will not be reaped
[   18.877970][    T1] init: Got shutdown_command 'reboot,apexd-failed' Calling HandlePowerctlMessage()
[   18.887443][    T1] init: Clear action queue and start shutdown trigger
[   18.894522][    T1] init: Entering shutdown mode
[   18.899881][    T1] init: processing action (shutdown_done) from (<Builtin Action>:0)
[   18.907983][    T1] init: Reboot start, reason: reboot,apexd-failed, reboot_target: apexd-failed
[   18.917001][    T1] init: Shutdown timeout: 6000 ms
[   18.922114][    T1] init: Create reboot monitor thread.
[   18.929352][  T106] init: Recovering persistent properties from memory: Unable to read persistent property
[   18.944067][  T106] init: Could not store persistent property: Could not open temporary properties file: No
[   18.956559][  T274] init: shutdown_timeout_timespec.tv_sec: 324
[   18.956559][    T1] init: Could not open '/metadata/bootstat/persist.sys.boot.reason' to persist reboot rea
son: No such file or directory
[   18.977624][    T1] init: Reboot ending, jumping to kernel
[   18.983419][    T1] kvm: exiting hardware virtualization
[   19.048810][    T1] reboot: Restarting system with command 'apexd-failed'
SK-AM62 E3, after flashing Android SDK9, switch to eMMC boot, no any output from console after power cycle.
SK-AM62B, after flashing with command sudo ./flashall.sh --board am62x-sk --hsfs, switch to eMMC boot mode, no output from console Also.
log of flashing SK-AM62B:
=> fastboot 0
generic_phy_get_bulk : no phys property
Writing GPT: success!
dwc3-generic-peripheral usb@31000000: request 00000000f75ff0c0 was not queued to ep1in-bulk
** Bad device specification mmc tiboot3_a **
Couldn't find partition mmc tiboot3_a
Starting download of 294306 bytes
downloading of 294306 bytes finished
Flashing Raw Image
........ wrote 294400 bytes to 'tiboot3'
** Bad device specification mmc bootloader_a **
Couldn't find partition mmc bootloader_a
Starting download of 8388608 bytes
downloading of 8388608 bytes finished
Flashing Raw Image
........ wrote 8388608 bytes to 'bootloader'
** Bad device specification mmc super_a **
Couldn't find partition mmc super_a
Starting download of 760255408 bytes
downloading of 760255408 bytes finished
Flashing sparse image at offset 225536
Flashing Sparse Image
........ wrote 760512512 bytes to 'super'
Starting download of 712720072 bytes
downloading of 712720072 bytes finished
........ wrote 723816448 bytes to 'super'
** Bad device specification mmc boot_a_a **
Couldn't find partition mmc boot_a_a
Starting download of 41943040 bytes
downloading of 41943040 bytes finished
Flashing Raw Image
........ wrote 41943040 bytes to 'boot_a'
** Bad device specification mmc boot_b_a **
Couldn't find partition mmc boot_b_a
Flashing Raw Image
........ wrote 41943040 bytes to 'boot_b'
** Bad device specification mmc userdata_a **
Couldn't find partition mmc userdata_a
Starting download of 2621716 bytes
downloading of 2621716 bytes finished
Flashing sparse image at offset 9761024
........ wrote 56762368 bytes to 'userdata'
** Bad device specification mmc vbmeta_a_a **
Couldn't find partition mmc vbmeta_a_a
Starting download of 4096 bytes
downloading of 4096 bytes finished
Flashing Raw Image
........ wrote 4096 bytes to 'vbmeta_a'
** Bad device specification mmc vbmeta_b_a **
Couldn't find partition mmc vbmeta_b_a
Flashing Raw Image
........ wrote 4096 bytes to 'vbmeta_b'
** Bad device specification mmc dtbo_a_a **
Couldn't find partition mmc dtbo_a_a
Flashing Raw Image
........ wrote 8388608 bytes to 'dtbo_a'
** Bad device specification mmc dtbo_b_a **
Couldn't find partition mmc dtbo_b_a
Flashing Raw Image
........ wrote 8388608 bytes to 'dtbo_b'
** Bad device specification mmc persist_a **
Couldn't find partition mmc persist_a
Starting download of 33554432 bytes
downloading of 33554432 bytes finished
Flashing Raw Image
........ wrote 33554432 bytes to 'persist'
** Bad device specification mmc misc_a **
Couldn't find partition mmc misc_a
Erasing blocks 27648 to 28672 due to alignment
........ erased 524288 bytes from 'misc'
** Bad device specification mmc metadata_a **
Couldn't find partition mmc metadata_a
Erasing blocks 9663488 to 9695232 due to alignment
........ erased 16252928 bytes from 'metadata'
  • Hi Tony.
    your fisrt error is link to an inssue at flash step , already fix in main branch ,
    solution is to define in uboot console this variable :
    setenv fastboot.partition-type:metadata ext4; saveenv;
    Go in fastboot mode and then relaunch flash script.
    For not booting with AM62B  please share log from your PC ?
    in general when it's not booting it's because not good tiboot3.bin file was flashed .
    you can confirm if you go in uboot from sd card , then fastboot mode and try to flash manually tiboot3-hsfs.bin with this command :
    fastboot flash tiboot3 tiboot3-am62x-sk-hsfs.bin
    Guillaume
  • On E2 board,
    set to SD boot mode to boot to UBOOT, setenv fastboot.partition-type:metadata ext4; saveenv; and env default -f -a; saveenv
    power cycle board, reflash with sudo ./flashall.sh --board am62x-sk, power cycle the board and switch to eMMC boot mode, still similar log:
    [    5.276697][  T110] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.277085][  T109] ueventd: Loaded kernel module /vendor/lib/modules/pvrsrvkm.ko
    [    5.277216][  T112] ueventd: LoadWithAliases was unable to load of:Ndma-controllerT(null)Cti,am64-dmss-bcdm
    a
    [    5.278908][  T112] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cti,am6-padconf
    [    5.279061][  T110] ueventd: LoadWithAliases was unable to load of:Ndma-controllerT(null)Cti,am64-dmss-pktd
    ma
    [    5.279295][  T109] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
    [    5.282478][  T110] ueventd: Loading module /vendor/lib/modules/ti-msgmgr.ko with args ''
    [    5.285897][  T112] ueventd: Loading module /vendor/lib/modules/dwc3-am62.ko with args ''
    [    5.289994][  T110] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.291758][  T110] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
    [    5.293814][  T110] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cpinctrl-single
    [    5.293814][  T112] ueventd: LoadWithAliases was unable to load input:b0003v0461p4D15e0111-e0,1,2,4,k110,11
    1,112,r0,1,8,B,am4,lsfw
    [    5.295889][  T110] ueventd: Loading module /vendor/lib/modules/gpio-davinci.ko with args ''
    [    5.296730][  T112] ueventd: Loading module /vendor/lib/modules/drm_dma_helper.ko with args ''
    [    5.298972][  T112] ueventd: Loading module /vendor/lib/modules/tidss.ko with args ''
    [    5.300559][  T110] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
    [    5.300559][  T111] ueventd: LoadWithAliases was unable to load of:Nregulator-7T(null)Cregulator-fixed
    [    5.302604][  T111] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.304537][  T110] ueventd: LoadWithAliases was unable to load usb:v0461p4D15d0200dc00dsc00dp00ic03isc01ip
    02in00
    [    5.306010][  T112] ueventd: Loading module /vendor/lib/modules/pru_rproc.ko with args ''
    [    5.310095][  T110] ueventd: Loading module /vendor/lib/modules/pruss.ko with args ''
    [    5.311416][  T112] ueventd: Loading module /vendor/lib/modules/irq-pruss-intc.ko with args ''
    [    5.312664][  T111] ueventd: Loading module /vendor/lib/modules/gpio-davinci.ko with args ''
    [    5.314919][  T110] ueventd: Loading module /vendor/lib/modules/pru_rproc.ko with args ''
    [    5.315282][  T112] ueventd: Loading module /vendor/lib/modules/sa2ul.ko with args ''
    [    5.319089][  T110] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.321227][  T110] ueventd: Loading module /vendor/lib/modules/cdns-dphy-rx.ko with args ''
    [    5.322563][  T109] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.322616][  T112] ueventd: Loading module /vendor/lib/modules/i2c-omap.ko with args ''
    [    5.324547][  T109] ueventd: LoadWithAliases was unable to load of:NsysconT(null)CsysconCsimple-mfd
    [    5.325648][  T112] ueventd: Loading module /vendor/lib/modules/k3_j72xx_bandgap.ko with args ''
    [    5.326678][  T109] ueventd: Loading module /vendor/lib/modules/syscon-clk.ko with args ''
    [    5.328311][  T110] ueventd: Loading module /vendor/lib/modules/omap_hwspinlock.ko with args ''
    [    5.328377][  T112] ueventd: LoadWithAliases was unable to load platform:rproc-virtio
    [    5.329016][  T109] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    5.331634][  T109] ueventd: Loading module /vendor/lib/modules/spi-cadence-quadspi.ko with args ''
    [    5.332403][  T111] ueventd: Loading module /vendor/lib/modules/cqhci.ko with args ''
    [    5.333174][  T112] ueventd: LoadWithAliases was unable to load of:Ntimer-cl0-cpu0T(null)Carm,armv8-timer
    [    5.335314][  T112] ueventd: LoadWithAliases was unable to load of:Nregulator-3T(null)Cregulator-fixed
    [    5.335966][  T112] ueventd: LoadWithAliases was unable to load platform:psci-cpuidle
    [    5.336173][  T110] ueventd: LoadWithAliases was unable to load of:NchipidT(null)Cti,am654-chipid
    [    5.338228][  T109] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
    [    5.339272][  T109] ueventd: Loading module /vendor/lib/modules/reset-ti-sci.ko with args ''
    [    5.340113][  T110] ueventd: LoadWithAliases was unable to load of:Nr5fT(null)Cti,am62-r5f
    [    5.340776][  T111] cqhci: exports duplicate symbol cqhci_deactivate (owned by kernel)
    [    5.342376][  T110] ueventd: Loading module /vendor/lib/modules/rpmsg_ns.ko with args ''
    [    5.343444][  T112] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
    03,0004,0005,0006,0007,000B
    [    5.343503][  T112] ueventd:
    [    5.344799][  T110] ueventd: LoadWithAliases was unable to load rpmsg:ti.ipc4.ping-pong
    [    5.345133][  T109] ueventd: Loading module /vendor/lib/modules/v4l2-async.ko with args ''
    [    5.347102][  T110] ueventd: LoadWithAliases was unable to load of:Nregulator-1T(null)Cregulator-fixed
    [    5.348142][  T110] ueventd: LoadWithAliases was unable to load platform:serial8250
    [    5.349426][  T109] ueventd: Loaded kernel module /vendor/lib/modules/v4l2-async.ko
    [    5.349633][  T109] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
    [    5.354109][  T110] ueventd: LoadWithAliases was unable to load of:NpmuT(null)Carm,cortex-a53-pmu
    [    5.355357][  T110] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
    [    5.355408][  T110] ueventd:
    [    5.361942][  T109] ueventd: Loaded kernel module /vendor/lib/modules/j721e-csi2rx.ko
    [    5.368180][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x.ko with args ''
    [    5.405257][  T111] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format erro
    r
    [    5.405394][  T111] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
    [    5.405425][  T111] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
    [    5.405944][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-tlv320aic3x.ko
    [    5.406239][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x-i2c.ko with args ''
    [    5.410607][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-tlv320aic3x-i2c.ko
    [    5.412749][  T109] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.414702][  T109] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
    [    5.416393][  T109] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-mfd
    [    5.418699][  T109] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    5.420513][  T109] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    5.422298][  T109] ueventd: LoadWithAliases was unable to load of:NesmT(null)Cti,j721e-esm
    [    5.425148][  T109] ueventd: Loading module /vendor/lib/modules/irq-ti-sci-intr.ko with args ''
    [    5.436087][  T109] ueventd: Loading module /vendor/lib/modules/8250_omap.ko with args ''
    [    5.441854][  T109] printk: console [ttyS2] disabled
    [    5.441980][  T109] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 449, base_baud = 3000000) is a 8250
    [    5.446416][  T111] ueventd: LoadWithAliases was unable to load of:Ndss-oldi-io-ctrlT(null)Csyscon
    [    5.449208][  T109] printk: console [ttyS2] enabled
    [    5.479899][  T111] ueventd: LoadWithAliases was unable to load spi:spi-nor
    [    5.484179][  T109] ueventd: Loaded kernel module /vendor/lib/modules/8250_omap.ko
    [    5.490674][  T111] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
    [    5.494722][  T109] ueventd: Loading module /vendor/lib/modules/tps6598x.ko with args ''
    [    5.497507][  T111] ueventd: Loading module /vendor/lib/modules/sci-clk.ko with args ''
    [    5.514957][  T109] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    5.525949][  T111] ueventd: Loading module /vendor/lib/modules/i2c-mux.ko with args ''
    [    5.534353][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-edma.ko with args ''
    [    5.541095][  T111] ueventd: Loading module /vendor/lib/modules/sii902x.ko with args ''
    [    5.558720][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-edma.ko
    [    5.573457][  T111] ueventd: Loading module /vendor/lib/modules/dwc3-am62.ko with args ''
    [    5.577192][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-sdma.ko with args ''
    [    5.588967][  T111] ueventd: Loading module /vendor/lib/modules/irq-ti-sci-inta.ko with args ''
    [    5.605016][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-sdma.ko
    [    5.614849][  T111] ueventd: Loading module /vendor/lib/modules/k3-ringacc.ko with args ''
    [    5.620852][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-udma.ko with args ''
    [    5.627102][  T111] ueventd: Loading module /vendor/lib/modules/k3-psil-lib.ko with args ''
    [    5.630345][  T111] ueventd: Loading module /vendor/lib/modules/k3-udma.ko with args ''
    [    5.637130][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-ti-udma.ko
    [    5.649653][  T111] ueventd: Loading module /vendor/lib/modules/k3-udma-glue.ko with args ''
    [    5.650550][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-davinci-mcasp.ko with args ''
    [    5.660125][  T111] ueventd: Loading module /vendor/lib/modules/ti-am65-cpsw-nuss.ko with args ''
    [    5.677078][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-davinci-mcasp.ko
    [    7.204836][   T88] omap_i2c 20000000.i2c: controller timed out
    [    7.215740][  T109] ueventd: LoadWithAliases was unable to load of:NsysconT(null)CsysconCsimple-mfd
    [    7.224848][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [    7.230351][  T109] ueventd: Loading module /vendor/lib/modules/ti_k3_r5_remoteproc.ko with args ''
    [    7.237097][   T88] tps6598x 0-003f: tps6598x_interrupt: failed to read events
    [    7.239488][  T111] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    7.249877][  T109] ueventd: Loading module /vendor/lib/modules/rpmsg_ns.ko with args ''
    [    7.276844][  T111] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    7.279778][  T109] ueventd: Loading module /vendor/lib/modules/virtio_rpmsg_bus.ko with args ''
    [    7.286455][  T111] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver unknown
    [    7.295768][  T109] ueventd: LoadWithAliases was unable to load rpmsg:rpmsg_ctrl
    [    7.299702][  T111] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver unknown
    [    7.299909][  T111] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw v
    ersion 0x6BA81103 Ports: 3 quirks:00000006
    [    7.309433][  T109] ueventd: LoadWithAliases was unable to load of:Nregulator-5T(null)Cregulator-fixed
    [    7.316614][  T111] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    7.328215][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card-utils.ko with args ''
    [    7.332972][  T111] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    7.347642][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-simple-card-utils.ko
    [    7.354888][  T111] pps pps0: new PPS source ptp0
    [    7.361193][  T109] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card.ko with args ''
    [    7.368529][  T111] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    8.784831][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [    9.792831][   T88] omap_i2c 20000000.i2c: controller timed out
    [   11.344823][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   12.028593][   T88] tps6598x 0-003f: tps6598x_interrupt: failed to read events
    [   12.038245][  T111] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [   12.040397][  T109] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-simple-card.ko
    [   12.048925][  T111] ueventd: Loaded kernel module /vendor/lib/modules/ti-am65-cpsw-nuss.ko
    [   12.056689][  T109] ueventd: LoadWithAliases was unable to load platform:cpufreq-dt
    [   12.064585][  T111] ueventd: Loading module /vendor/lib/modules/cqhci.ko with args ''
    [   12.070871][  T109] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
    [   12.089920][  T111] cqhci: exports duplicate symbol cqhci_deactivate (owned by kernel)
    [   12.097895][  T109] ueventd:
    [   12.109071][  T108] apexd: wait for '/dev/loop-control' took 7017ms
    [   12.130562][  T109] ueventd (109) used greatest stack depth: 10400 bytes left
    [   12.134488][  T108] apexd: Pre-allocated 15 loopback devices
    [   12.143676][  T108] apexd: Scanning /system/apex for pre-installed ApexFiles
    [   12.144965][  T111] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format erro
    r
    [   12.151475][  T108] apexd: Found pre-installed APEX /system/apex/com.android.resolv.capex
    [   12.160616][  T111] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
    [   12.178636][  T111] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
    [   12.189322][  T108] apexd: Found pre-installed APEX /system/apex/com.android.ondevicepersonalization.apex
    [   12.192468][  T111] ueventd: Loading module /vendor/lib/modules/ti_k3_common.ko with args ''
    [   12.200248][  T108] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
    [   12.209326][  T111] ueventd: Loading module /vendor/lib/modules/ti_k3_m4_remoteproc.ko with args ''
    [   12.231327][  T108] apexd: Found pre-installed APEX /system/apex/com.android.vndk.current.apex
    [   12.232247][  T111] ueventd: LoadWithAliases was unable to load of:NgpioT(null)Cti,am64-gpioCti,keystone-gp
    io
    [   12.241221][  T108] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
    [   12.252288][  T111] ueventd: LoadWithAliases was unable to load platform:xhci-hcd
    [   12.259553][  T108] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.capex
    [   12.266675][  T111] ueventd: LoadWithAliases was unable to load hid:b0003g0001v00000461p00004D15
    [   12.286571][  T111] ueventd: LoadWithAliases was unable to load usb:v1D6Bp0002d0601dc09dsc00dp01ic09isc00ip
    00in00
    [   12.297601][  T108] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
    [   12.300783][  T111] ueventd: Loading module /vendor/lib/modules/cqhci.ko with args ''
    [   12.315073][  T111] cqhci: exports duplicate symbol cqhci_deactivate (owned by kernel)
    [   12.320542][  T108] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
    [   12.332256][  T108] apexd: Found pre-installed APEX /system/apex/com.android.mediaprovider.capex
    [   12.348375][  T108] apexd: Found pre-installed APEX /system/apex/com.android.os.statsd.apex
    [   12.357896][  T108] apexd: Found pre-installed APEX /system/apex/com.android.apex.cts.shim.apex
    [   12.367564][  T108] apexd: Found pre-installed APEX /system/apex/com.android.art.capex
    [   12.380550][  T108] apexd: Found pre-installed APEX /system/apex/com.android.adbd.capex
    [   12.393015][  T111] ueventd: Failed to insmod '/vendor/lib/modules/cqhci.ko' with args '': Exec format erro
    r
    [   12.395606][  T108] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
    [   12.402947][  T111] ueventd: LoadWithAliases was unable to load /vendor/lib/modules/cqhci.ko
    [   12.412012][  T108] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
    [   12.419473][  T111] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
    [   12.432674][  T108] apexd: Found pre-installed APEX /system/apex/com.android.adservices.capex
    [   12.437804][  T111] ueventd: LoadWithAliases was unable to load of:NcfgT(null)Cti,pruss-cfgCsyscon
    [   12.451061][  T108] apexd: Found pre-installed APEX /system/apex/com.android.uwb.capex
    [   12.457087][  T111] ueventd: Loading module /vendor/lib/modules/i2c-omap.ko with args ''
    [   12.468566][  T108] apexd: Found pre-installed APEX /system/apex/com.android.neuralnetworks.capex
    [   12.471921][  T111] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
    [   12.485503][  T108] apexd: Found pre-installed APEX /system/apex/com.android.extservices.capex
    [   12.488537][  T111] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
    [   12.502054][  T108] apexd: Found pre-installed APEX /system/apex/com.android.i18n.apex
    [   12.512119][  T108] apexd: Found pre-installed APEX /system/apex/com.android.scheduling.apex
    [   12.512673][  T111] ueventd: Loaded kernel module /vendor/lib/modules/mcrc.ko
    [   12.521711][  T108] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
    [   12.529400][  T111] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
    [   12.536968][  T108] apexd: Found pre-installed APEX /system/apex/com.android.btservices.apex
    [   12.545828][  T111] ueventd: Loading module /vendor/lib/modules/rtc-ti-k3.ko with args ''
    [   12.553602][  T108] apexd: Found pre-installed APEX /system/apex/com.android.tethering.capex
    [   12.565394][  T111] ueventd: LoadWithAliases was unable to load platform:alarmtimer
    [   12.576453][  T108] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
    [   12.579290][  T111] ueventd: LoadWithAliases was unable to load rpmsg:rpmsg_chrdev
    [   12.591034][  T108] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
    [   12.594834][  T111] ueventd: LoadWithAliases was unable to load of:NesmT(null)Cti,j721e-esm
    [   12.608380][  T108] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
    [   12.611800][  T111] ueventd: LoadWithAliases was unable to load of:Nopp-tableT(null)Coperating-points-v2-ti
    -cpu
    [   12.617205][  T108] apexd: /system_ext/apex does not exist. Skipping
    [   12.632229][  T111] ueventd: LoadWithAliases was unable to load of:Nregulator-6T(null)Cregulator-fixed
    [   12.633579][  T108] apexd: Scanning /product/apex for pre-installed ApexFiles
    [   12.643677][  T111] ueventd: LoadWithAliases was unable to load cpu:type:aarch64:feature:,0000,0001,0002,00
    [   12.650030][  T108] apexd: /product/apex does not exist. Skipping
    [   12.662044][  T111] ueventd:
    [   12.668133][  T108] apexd: Scanning /vendor/apex for pre-installed ApexFiles
    [   12.678341][  T108] apexd: /vendor/apex does not exist. Skipping
    [   12.684740][  T108] apexd: No block apex metadata partition found, not adding block apexes
    [   12.693487][  T106] ueventd: Coldboot took 7.727 seconds
    [   12.693555][  T108] apexd: Pre-allocated 0 loopback devices
    [   12.703224][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-hdmi-codec.ko with args ''
    [   12.717657][  T151] loop0: detected capacity change from 0 to 96512
    [   12.724458][  T150] loop1: detected capacity change from 0 to 74600
    [   12.734711][  T106] ueventd: Loading module /vendor/lib/modules/pvrsrvkm.ko with args ''
    [   12.775491][  T106] ueventd: Loading module /vendor/lib/modules/v4l2-async.ko with args ''
    [   12.786228][  T106] ueventd: Loading module /vendor/lib/modules/v4l2-fwnode.ko with args ''
    [   12.797237][  T150] EXT4-fs (loop1): mounted filesystem without journal. Quota mode: none.
    [   12.797865][  T151] EXT4-fs (loop0): mounted filesystem without journal. Quota mode: none.
    [   12.805937][  T150] apexd: Successfully mounted package /system/apex/com.android.i18n.apex on /apex/com.and
    roid.i18n@1 duration=89
    [   12.806582][  T106] ueventd: Loaded kernel module /vendor/lib/modules/v4l2-fwnode.ko
    [   12.806740][  T106] ueventd: Loading module /vendor/lib/modules/cdns-csi2rx.ko with args ''
    [   12.814241][  T151] apexd: Successfully mounted package /system/apex/com.android.vndk.current.apex on /apex
    /com.android.vndk.v33@1 duration=97
    [   12.815488][  T106] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [   12.816102][  T106] ueventd: Loaded kernel module /vendor/lib/modules/cdns-csi2rx.ko
    [   12.827918][  T106] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
    [   12.837764][  T150] loop2: detected capacity change from 0 to 1728
    [   12.858364][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x.ko with args ''
    [   12.862692][  T151] loop3: detected capacity change from 0 to 16208
    [   12.871237][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x-i2c.ko with args ''
    [   12.919115][  T106] ueventd: Loading module /vendor/lib/modules/8250_omap.ko with args ''
    [   12.941225][  T106] ueventd: LoadWithAliases was unable to load of:NserialT(null)Cti,am64-uartCti,am654-uar
    t
    [   12.955868][  T150] EXT4-fs (loop2): mounted filesystem without journal. Quota mode: none.
    [   12.964681][  T150] apexd: Successfully mounted package /system/apex/com.android.tzdata.apex on /apex/com.a
    ndroid.tzdata@330400000 duration=127
    [   12.968572][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-edma.ko with args ''
    [   12.973959][  T151] EXT4-fs (loop3): mounted filesystem without journal. Quota mode: none.
    [   12.974206][  T151] apexd: Successfully mounted package /system/apex/com.android.runtime.apex on /apex/com.
    android.runtime@1 duration=136
    [   12.980176][  T108] apexd: Activated 4 packages.
    [   12.987619][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-sdma.ko with args ''
    [   13.009481][  T108] apexd: OnBootstrap done, duration=7975
    [   13.013066][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-ti-udma.ko with args ''
    [   13.025324][    T1] init: Service 'apexd-bootstrap' (pid 108) exited with status 0 waiting took 8.154000 se
    conds
    [   13.026349][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-davinci-mcasp.ko with args ''
    [   13.034704][    T1] init: Sending signal 9 to service 'apexd-bootstrap' (pid 108) process group...
    [   13.055689][  T106] ueventd: Loading module /vendor/lib/modules/mdio-bitbang.ko with args ''
    [   13.063431][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 108 in 0ms
    [   13.081020][  T106] ueventd: Loading module /vendor/lib/modules/davinci_mdio.ko with args ''
    [   13.105055][  T106] ueventd: LoadWithAliases was unable to load of:Nethernet-phyT(null)
    [   13.118010][  T106] ueventd: LoadWithAliases was unable to load of:Nethernet-phyT(null)
    [   13.130998][  T106] ueventd: LoadWithAliases was unable to load of:NmdioT(null)Cti,cpsw-mdioCti,davinci_mdi
    o
    [   13.166068][    T1] init: linkerconfig generated /linkerconfig with mounted APEX modules info
    [   13.174941][    T1] init: Command 'update_linker_config' action=early-init (/system/etc/init/hw/init.rc:75)
     took 92ms and succeeded
    [   13.182593][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card-utils.ko with args ''
    [   13.197241][  T106] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card.ko with args ''
    [   13.200678][    T1] init: processing action (early-init) from (/init.environ.rc:2)
    [   13.214422][    T1] init: processing action (early-init) from (/vendor/etc/init/hw/init.am62x.rc:1)
    [   13.230161][    T1] init: processing action (ro.product.debugfs_restrictions.enabled=true && early-init) fr
    om (/system/etc/init/init-debug.rc:10)
    [   13.243936][    T1] init: Command 'mount debugfs debugfs /sys/kernel/debug' action=ro.product.debugfs_restr
    ictions.enabled=true && early-init (/system/etc/init/init-debug.rc:11) took 0ms and failed: mount() failed: De
    vice or resource busy
    [   13.261111][  T106] ueventd: Loading module /vendor/lib/modules/ti_sci.ko with args ''
    [   13.265497][    T1] init: processing action (early-init) from (/system/etc/init/prng_seeder.rc:5)
    [   13.274676][  T106] ueventd: Loading module /vendor/lib/modules/k3-ringacc.ko with args ''
    [   13.282655][    T1] init: starting service 'prng_seeder'...
    [   13.291545][  T106] ueventd: Loading module /vendor/lib/modules/k3-psil-lib.ko with args ''
    [   13.296765][    T1] init: Created socket '/dev/socket/prng_seeder', mode 666, user 1092, group 1092
    [   13.305519][  T106] ueventd: Loading module /vendor/lib/modules/k3-udma.ko with args ''
    [   13.323512][  T106] ueventd: Loading module /vendor/lib/modules/k3-udma-glue.ko with args ''
    [   13.332682][  T106] ueventd: Loading module /vendor/lib/modules/ti-am65-cpsw-nuss.ko with args ''
    [   13.378348][    T1] init: Command 'start prng_seeder' action=early-init (/system/etc/init/prng_seeder.rc:6)
     took 96ms and succeeded
    [   13.391164][    T1] init: processing action (ro.product.cpu.abilist32=* && early-init) from (/vendor/etc/in
    it/boringssl_self_test.rc:2)
    [   13.406631][    T1] init: starting service 'boringssl_self_test32_vendor'...
    [   13.423972][  T106] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
    [   13.438852][    T1] init: SVC_EXEC service 'boringssl_self_test32_vendor' pid 158 (uid 0 gid 0+0 context de
    [   13.634062][  T157] prng_seeder: Hanging forever because setup failed: hwrng.read_exact in new
    [   13.634062][  T157]
    [   13.645186][  T157] Caused by:
    [   13.648269][  T157]     No such device (os error 19)
    [   13.702690][    T1] init: Service 'boringssl_self_test32_vendor' (pid 158) exited with status 0 waiting too
    k 0.276000 seconds
    [   13.714124][    T1] init: Sending signal 9 to service 'boringssl_self_test32_vendor' (pid 158) process grou
    p...
    [   13.724585][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 158 in 0ms
    [   13.734760][    T1] init: processing action (ro.product.cpu.abilist64=* && early-init) from (/vendor/etc/in
    it/boringssl_self_test.rc:4)
    [   13.747901][    T1] init: starting service 'boringssl_self_test64_vendor'...
    [   13.784090][    T1] init: SVC_EXEC service 'boringssl_self_test64_vendor' pid 159 (uid 0 gid 0+0 context de
    [   13.828896][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   13.925449][    T1] init: Service 'boringssl_self_test64_vendor' (pid 159) exited with status 0 waiting too
    k 0.165000 seconds
    [   13.936906][    T1] init: Sending signal 9 to service 'boringssl_self_test64_vendor' (pid 159) process grou
    p...
    [   13.947354][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 159 in 0ms
    [   13.957621][    T1] init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
    [   13.966385][    T1] init: start_waiting_for_property("ro.cold_boot_done", "true"): already set
    [   13.975141][    T1] init: processing action (SetMmapRndBits) from (<Builtin Action>:0)
    [   13.984756][    T1] init: processing action (KeychordInit) from (<Builtin Action>:0)
    [   13.992805][    T1] init: processing action (init) from (/system/etc/init/hw/init.rc:89)
    [   14.001882][    T1] init: Command 'copy /system/etc/prop.default /dev/urandom' action=init (/system/etc/ini
    t/hw/init.rc:94) took 0ms and failed: Could not read input file '/system/etc/prop.default': open() failed: No
    [   14.045163][    T1] init: Command 'write /dev/blkio/blkio.weight 1000' action=init (/system/etc/init/hw/ini
    t.rc:230) took 0ms and failed: Unable to write to file '/dev/blkio/blkio.weight': open() failed: Permission de
    nied
    [   14.066072][    T1] init: Command 'write /dev/blkio/background/blkio.weight 200' action=init (/system/etc/i
    nit/hw/init.rc:231) took 0ms and failed: Unable to write to file '/dev/blkio/background/blkio.weight': open()
    failed: Permission denied
    [   14.089408][    T1] init: Command 'write /dev/blkio/blkio.group_idle 0' action=init (/system/etc/init/hw/in
    it.rc:233) took 0ms and failed: Unable to write to file '/dev/blkio/blkio.group_idle': open() failed: Permissi
    on denied
    [   14.110425][    T1] init: Command 'write /dev/blkio/background/blkio.group_idle 0' action=init (/system/etc
    /init/hw/init.rc:234) took 0ms and failed: Unable to write to file '/dev/blkio/background/blkio.group_idle': o
    pen() failed: Permission denied
    [   14.205273][    T1] Registered swp emulation handler
    [   14.214868][    T1] init: starting service 'logd'...
    [   14.220771][    T1] init: Created socket '/dev/socket/logd', mode 666, user 1036, group 1036
    [   14.230092][    T1] init: Created socket '/dev/socket/logdr', mode 666, user 1036, group 1036
    [   14.239252][    T1] init: Created socket '/dev/socket/logdw', mode 222, user 1036, group 1036
    [   14.277578][    T1] init: Command 'start logd' action=init (/system/etc/init/hw/init.rc:465) took 63ms and
    succeeded
    [   14.290619][    T1] init: starting service 'lmkd'...
    [   14.296677][    T1] init: Created socket '/dev/socket/lmkd', mode 660, user 1000, group 1000
    [   14.322581][    T1] init: starting service 'servicemanager'...
    [   14.357882][    T1] init: starting service 'hwservicemanager'...
    [   14.406351][    T1] init: Command 'start vndservicemanager' action=init (/system/etc/init/hw/init.rc:477) t
    ook 0ms and failed: service vndservicemanager not found
    [   14.411090][  T162] logd.auditd: start
    [   14.421989][    T1] init: processing action (ro.product.cpu.abilist32=* && init) from (/system/etc/init/hw/
    init.rc:480)
    [   14.436967][    T1] init: starting service 'boringssl_self_test32'...
    [   14.442194][  T162] logd: Loaded bug_map file: /vendor/etc/selinux/selinux_denial_metadata
    [   14.454345][  T162] logd: Loaded bug_map file: /system/etc/selinux/bug_map
    [   14.456590][    T1] init: SVC_EXEC service 'boringssl_self_test32' pid 173 (uid 0 gid 0+0 context default)
    started; waiting...
    [   14.595481][    T1] init: Service 'boringssl_self_test32' (pid 173) exited with status 0 waiting took 0.147
    000 seconds
    [   14.606308][    T1] init: Sending signal 9 to service 'boringssl_self_test32' (pid 173) process group...
    [   14.616135][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 173 in 0ms
    [   14.626375][    T1] init: processing action (ro.product.cpu.abilist64=* && init) from (/system/etc/init/hw/
    init.rc:482)
    [   14.637951][    T1] init: starting service 'boringssl_self_test64'...
    [   14.680318][    T1] init: SVC_EXEC service 'boringssl_self_test64' pid 175 (uid 0 gid 0+0 context default)
    started; waiting...
    [   14.692078][    T1] init: Command 'exec_start boringssl_self_test64' action=ro.product.cpu.abilist64=* && i
    nit (/system/etc/init/hw/init.rc:483) took 54ms and succeeded
    [   14.759385][    T1] init: Service 'boringssl_self_test64' (pid 175) exited with status 0 waiting took 0.110
    000 seconds
    [   14.770174][    T1] init: Sending signal 9 to service 'boringssl_self_test64' (pid 175) process group...
    [   14.779998][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 175 in 0ms
    [   14.790132][    T1] init: processing action (ro.debuggable=1 && init) from (/system/etc/init/hw/init.rc:128
    3)
    [   14.801308][    T1] init: starting service 'console'...
    [   14.841929][    T1] init: processing action (init) from (/system/etc/init/hw/init.usb.rc:27)
    [   14.851689][    T1] init: processing action (init) from (/vendor/etc/init/hw/init.am62x.rc:5)
    console:/ $ [   14.922001][    T1] init: Command 'start watchdogd' action=init (/vendor/etc/init/hw/init.am62x
    .rc:56) took 0ms and failed: service watchdogd not found
    [   14.935686][    T1] init: processing action (init) from (/system/etc/init/audioserver.rc:62)
    [   14.945886][    T1] init: processing action (late-init) from (/system/etc/init/hw/init.rc:517)
    [   14.954672][    T1] init: processing action (late-init) from (/system/etc/init/atrace.rc:3)
    [   14.981591][    T1] init: processing action (late-init) from (/vendor/etc/init/android.hardware.atrace@1.0-
    service.rc:1)
    [   14.993734][    T1] init: processing action (queue_property_triggers) from (<Builtin Action>:0)
    [   15.003066][    T1] init: processing action (early-fs) from (/system/etc/init/hw/init.rc:550)
    [   15.012368][    T1] init: starting service 'vold'...
    [   15.048290][    T1] init: processing action (early-fs) from (/vendor/etc/init/hw/init.am62x.rc:71)
    [   15.057687][    T1] init: service 'vold' requested start, but it is already running (flags: 2052)
    [   15.066816][    T1] init: processing action (fs) from (/vendor/etc/init/hw/init.am62x.rc:74)
    [   15.081027][    T1] init: [libfs_mgr]Invalid ext4 superblock on '/dev/block/platform/bus@f0000/fa10000.mmc/
    by-name/metadata'
    [   15.092931][    T1] init: [libfs_mgr]mount_with_alternatives(): skipping mount due to invalid magic, mountp
    oint=/metadata blk_dev=/dev/block/mmcblk0p12 rec[2].fs_type=ext4
    [   15.109002][    T1] init: [libfs_mgr]Failed to mount an un-encryptable or wiped partition on /dev/block/pla
    tform/bus@f0000/fa10000.mmc/by-name/metadata at /metadata options: discard: Invalid argument
    [   15.127859][    T1] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/platform/bus@f0000/fa10000
    .mmc/by-name/persist
    [   15.139726][    T1] EXT4-fs: Ignoring removed nomblk_io_submit option
    [   15.149517][    T1] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Quota mode: none.
    [   15.159325][    T1] init: [libfs_mgr]check_fs(): mount(/dev/block/platform/bus@f0000/fa10000.mmc/by-name/pe
    rsist,/mnt/vendor/persist,ext4)=0: Success
    [   15.176163][    T1] EXT4-fs (mmcblk0p13): unmounting filesystem.
    [   15.186154][    T1] init: [libfs_mgr]umount_retry(): unmount(/mnt/vendor/persist) succeeded
    [   15.195262][    T1] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/mmcblk0p13
    [   15.274780][    T1] e2fsck: e2fsck 1.46.2 (28-Feb-2021)
    [   15.281602][    T1] e2fsck: /mnt/vendor/pers: clean, 11/8192 files, 1545/8192 blocks
    [   15.297645][    T1] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Quota mode: none.
    [   15.307473][    T1] init: [libfs_mgr]__mount(source=/dev/block/platform/bus@f0000/fa10000.mmc/by-name/persi
    st,target=/mnt/vendor/persist,type=ext4)=0: Success
    [   15.331915][    T1] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --early' action=fs (/vendor/e
    tc/init/hw/init.am62x.rc:75) took 256ms and succeeded
    [   15.349746][    T1] init: processing action (fs) from (/system/etc/init/logd.rc:29)
    [   15.358585][    T1] init: processing action (fs) from (/system/etc/init/wifi.rc:25)
    [   15.367194][    T1] init: processing action (post-fs) from (/system/etc/init/hw/init.rc:554)
    [   15.376547][    T1] init: starting service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)'...
    [   15.384927][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   15.419255][    T1] init: SVC_EXEC service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' pid 189 (u
    id 1000 gid 1000+0 context default) started; waiting...
    [   15.434152][    T1] init: Command 'exec - system system -- /system/bin/vdc checkpoint markBootAttempt' acti
    on=post-fs (/system/etc/init/hw/init.rc:555) took 58ms and succeeded
    [   15.470392][    T1] init: Service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' (pid 189) exited wi
    th status 0 waiting took 0.080000 seconds
    [   15.483926][    T1] init: Sending signal 9 to service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)'
     (pid 189) process group...
    [   15.496474][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 189 in 0ms
    [   15.520328][    T1] init: Command 'chown system cache /cache' action=post-fs (/system/etc/init/hw/init.rc:5
    70) took 0ms and failed: lchown() failed: Read-only file system
    [   15.536699][    T1] init: Command 'chmod 0770 /cache' action=post-fs (/system/etc/init/hw/init.rc:571) took
     0ms and failed: fchmodat() failed: Read-only file system
    [   15.559010][    T1] selinux: SELinux:  setxattr failed: /metadata:  Read-only file system
    [   15.567335][    T1] selinux:
    [   15.571346][    T1] init: Command 'mkdir /metadata/vold' action=post-fs (/system/etc/init/hw/init.rc:608) t
    ook 0ms and failed: mkdir() failed on /metadata/vold: Read-only file system
    [   15.588663][    T1] init: Command 'mkdir /metadata/password_slots 0771 root system' action=post-fs (/system
    /etc/init/hw/init.rc:610) took 0ms and failed: mkdir() failed on /metadata/password_slots: Read-only file syst
    em
    [   15.608912][    T1] init: Command 'mkdir /metadata/bootstat 0750 system log' action=post-fs (/system/etc/in
    it/hw/init.rc:611) took 0ms and failed: mkdir() failed on /metadata/bootstat: Read-only file system
    [   15.628016][    T1] init: Command 'mkdir /metadata/ota 0700 root system' action=post-fs (/system/etc/init/h
    w/init.rc:612) took 0ms and failed: mkdir() failed on /metadata/ota: Read-only file system
    [   15.646507][    T1] init: Command 'mkdir /metadata/userspacereboot 0770 root system' action=post-fs (/syste
    m/etc/init/hw/init.rc:614) took 0ms and failed: mkdir() failed on /metadata/userspacereboot: Read-only file sy
    stem
    [   15.666727][    T1] init: Command 'mkdir /metadata/watchdog 0770 root system' action=post-fs (/system/etc/i
    nit/hw/init.rc:615) took 0ms and failed: mkdir() failed on /metadata/watchdog: Read-only file system
    [   15.685729][    T1] init: Command 'mkdir /metadata/apex 0700 root system' action=post-fs (/system/etc/init/
    hw/init.rc:617) took 0ms and failed: mkdir() failed on /metadata/apex: Read-only file system
    [   15.704126][    T1] selinux: SELinux:  Could not stat /metadata/apex: No such file or directory.
    [   15.712943][    T1] selinux:
    [   15.716458][    T1] init: Command 'mkdir /metadata/staged-install 0770 root system' action=post-fs (/system
    /etc/init/hw/init.rc:626) took 0ms and failed: mkdir() failed on /metadata/staged-install: Read-only file syst
    em
    [   15.736394][    T1] init: Command 'mkdir /metadata/sepolicy 0700 root root' action=post-fs (/system/etc/ini
    t/hw/init.rc:627) took 0ms and failed: mkdir() failed on /metadata/sepolicy: Read-only file system
    [   15.754693][    T1] init: processing action (post-fs) from (/vendor/etc/init/hw/init.am62x.rc:77)
    [   15.764746][    T1] init: processing action (post-fs) from (/system/etc/init/atrace_userdebug.rc:7)
    [   15.774423][    T1] init: processing action (post-fs) from (/system/etc/init/gsid.rc:8)
    [   15.783147][    T1] init: Command 'mkdir /metadata/gsi 0771 root system' action=post-fs (/system/etc/init/g
    sid.rc:9) took 0ms and failed: mkdir() failed on /metadata/gsi: Read-only file system
    [   15.801566][    T1] init: processing action (post-fs) from (/system/etc/init/recovery-refresh.rc:1)
    [   15.811408][    T1] init: starting service 'exec 3 (/system/bin/recovery-refresh)'...
    [   15.842883][    T1] init: processing action (post-fs) from (/vendor/etc/init/init.optee.rc:1)
    [   15.870401][    T1] init: processing action (late-fs) from (/system/etc/init/hw/init.rc:628)
    [   15.879506][    T1] init: Service 'exec 3 (/system/bin/recovery-refresh)' (pid 190) exited with status 254
    oneshot service took 0.056000 seconds in background
    [   15.893782][    T1] init: Sending signal 9 to service 'exec 3 (/system/bin/recovery-refresh)' (pid 190) pro
    cess group...
    [   15.905014][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 190 in 0ms
    [   15.916542][    T1] init: starting service 'system_suspend'...
    [   15.949177][    T1] init: starting service 'keystore2'...
    [   15.972710][    T1] init: starting service 'vendor.atrace-hal-1-0'...
    [   16.011007][    T1] init: starting service 'vendor.boot-hal-1-2'...
    [   16.038407][    T1] init: starting service 'tee-supplicant'...
    [   16.064145][    T1] init: Command 'class_start early_hal' action=late-fs (/system/etc/init/hw/init.rc:635)
    took 149ms and succeeded
    [   16.077427][    T1] init: starting service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)'...
    [   16.115709][    T1] init: SVC_EXEC service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' pid 19
    8 (uid 0 gid 0+0 context default) started; waiting...
    [   16.130445][    T1] init: Command 'exec -- /system/bin/fsverity_init --load-verified-keys' action=late-fs (
    /system/etc/init/hw/init.rc:638) took 54ms and succeeded
    [   16.167173][    T1] init: Service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' (pid 198) exite
    d with status 0 waiting took 0.075000 seconds
    [   16.181157][    T1] init: Sending signal 9 to service 'exec 4 (/system/bin/fsverity_init --load-verified-ke
    ys)' (pid 198) process group...
    [   16.194253][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 198 in 0ms
    [   16.204250][    T1] init: processing action (late-fs) from (/system/etc/init/hw/init.rc:649)
    [   16.213755][    T1] init: processing action (late-fs) from (/vendor/etc/init/hw/init.am62x.rc:87)
    [   16.224076][    T1] init: starting service 'bootanim'...
    [   16.263343][    T1] init: service 'bootanim' requested start, but it is already running (flags: 134)
    [   16.277074][    T1] init: service 'hwservicemanager' requested start, but it is already running (flags: 221
    2)
    [   16.287314][    T1] init: service 'servicemanager' requested start, but it is already running (flags: 2084)
    [   16.298239][    T1] init: starting service 'surfaceflinger'...
    [   16.305322][    T1] init: Could not create socket 'pdx/system/vr/display/client': Failed to bind socket 'pd
    x/system/vr/display/client': No such file or directory
    [   16.320656][    T1] init: Could not create socket 'pdx/system/vr/display/manager': Failed to bind socket 'p
    dx/system/vr/display/manager': No such file or directory
    [   16.336068][    T1] init: Could not create socket 'pdx/system/vr/display/vsync': Failed to bind socket 'pdx
    /system/vr/display/vsync': No such file or directory
    [   16.385281][    T1] init: starting service 'vendor.gralloc-4-0'...
    [   16.404661][    T1] init: starting service 'vendor.hwcomposer-2-4'...
    [   16.423992][    T1] init: Command 'class_start animation' action=late-fs (/vendor/etc/init/hw/init.am62x.rc
    :90) took 160ms and succeeded
    [   16.437818][    T1] init: starting service 'vendor.keymaster-3-0-optee'...
    [   16.458569][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.
    0::IKeymasterDevice/default' from pid: 166 (/system/bin/hwservicemanager)
    [   16.477199][    T1] init: start_waiting_for_property("hwservicemanager.ready", "true"): already set
    [   16.487101][    T1] init: service 'vendor.keymaster-3-0-optee' requested start, but it is already running (
    flags: 132)
    [   16.498082][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.
    [   16.514845][    T1] init: processing action (late-fs) from (/vendor/etc/init/init.optee.rc:4)
    [   16.524750][    T1] init: starting service 'wait_for_keymaster_optee'...
    [   16.584632][    T1] init: SVC_EXEC service 'wait_for_keymaster_optee' pid 212 (uid 1000 gid 1000+1 context
    [   16.598483][    T1] init: Command 'exec_start wait_for_keymaster_optee' action=late-fs (/vendor/etc/init/in
    it.optee.rc:5) took 74ms and succeeded
    [   16.756111][  T209] PVR_K:  209: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
    [   16.762001][    T1] init: service 'vendor.keymaster-3-0-optee' requested start, but it is already running (
    flags: 132)
    [   16.775030][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.
    [   16.784546][  T209] PVR_K:  209: Shader binary image 'rgx.sh.33.15.11.3' loaded
    [   16.792494][    T1] init: service 'vendor.keymaster-3-0-optee' requested start, but it is already running (
    flags: 132)
    [   16.809630][    T1] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.
    [   16.938095][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   17.105057][    T1] init: Service 'wait_for_keymaster_optee' (pid 212) exited with status 0 waiting took 0.
    568000 seconds
    [   17.117050][    T1] init: Sending signal 9 to service 'wait_for_keymaster_optee' (pid 212) process group...
    [   17.127567][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 212 in 0ms
    [   17.148802][    T1] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
    [   17.234265][    T1] vdc: vdc terminated by exit(1)
    [   17.239321][    T1] vdc:
    [   17.244376][    T1] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a -c 10000 --debug-cache /dev/block/mmc
    blk0p14
    [   17.300996][    T1] fsck.f2fs: Info: Fix the reported corruption.
    [   17.308906][    T1] fsck.f2fs: Info: not exist /proc/version!
    [   17.315709][    T1] fsck.f2fs: Info: Segments per section = 1
    [   17.321660][    T1] fsck.f2fs: Info: Sections per zone = 1
    [   17.327242][    T1] fsck.f2fs: Info: sector size = 512
    [   17.332506][    T1] fsck.f2fs: Info: total sectors = 21319391 (10409 MB)
    [   17.339362][    T1] fsck.f2fs: Info: MKFS version
    [   17.344169][    T1] fsck.f2fs:   "5.15.0-76-generic"
    [   17.349206][    T1] fsck.f2fs: Info: FSCK version
    [   17.354013][    T1] fsck.f2fs:   from "5.15.0-76-generic"
    [   17.359515][    T1] fsck.f2fs:     to "6.1.25-android13-11"
    [   17.365187][    T1] fsck.f2fs: Info: version timestamp cur: 22, prev: 1689960871
    [   17.372679][    T1] fsck.f2fs: [update_superblock: 701] Info: Done to update superblock
    [   17.380900][    T1] fsck.f2fs: Info: superblock features = 1499 :  encrypt verity extra_attr project_quota
    quota_ino casefold
    [   17.392316][    T1] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
    [   17.402053][    T1] fsck.f2fs: Info: total FS sectors = 20891648 (10201 MB)
    [   17.409092][    T1] fsck.f2fs: Info: CKPT version = 3e0b3709
    [   17.414821][    T1] fsck.f2fs: Info: checkpoint state = 281 :  allow_nocrc nat_bits unmount
    [   17.423263][    T1] fsck.f2fs: Info: No error was reported
    [   17.428868][    T1] fsck.f2fs:
    [   17.432046][    T1] fsck.f2fs: c, u, RA, CH, CM, Repl=
    [   17.437272][    T1] fsck.f2fs: 10000 11 11 0 11 0
    [   17.444421][    T1] F2FS-fs (mmcblk0p14): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
    [   17.467658][    T1] F2FS-fs (mmcblk0p14): Found nat_bits in checkpoint
    [   17.582105][    T1] F2FS-fs (mmcblk0p14): Start checkpoint disabled!
    [   17.591449][    T1] F2FS-fs (mmcblk0p14): Mounted with checkpoint version = 3e0b370a
    [   17.600255][    T1] init: [libfs_mgr]__mount(source=/dev/block/platform/bus@f0000/fa10000.mmc/by-name/userd
    ata,target=/data,type=f2fs)=0: Success
    [   17.644708][    T1] init: [libfs_mgr]umount_retry(): unmount(/data) succeeded
    [   17.652697][    T1] init: Calling: /system/bin/vdc cryptfs encryptFstab /dev/block/platform/bus@f0000/fa100
    00.mmc/by-name/userdata /data false f2fs
    [   17.721291][  T178] vold: Failed to create /metadata/vold: Read-only file system
    [   17.730358][  T178] vold: read_key failed in mountFstab
    [   17.738854][  T244] vdc: Command: cryptfs encryptFstab /dev/block/platform/bus@f0000/fa10000.mmc/by-name/us
    erdata /data false f2fs Failed: Status(-8, EX_SERVICE_SPECIFIC): '0: '
    [   17.760034][    T1] vdc: vdc terminated by exit(25)
    [   17.765124][    T1] vdc:
    [   17.768243][    T1] init: vdc call failed with error code: 25
    [   17.774606][    T1] init: [libfs_mgr]Encryption failed
    [   17.786468][    T1] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --late' action=late-fs (/vend
    or/etc/init/init.optee.rc:6) took 647ms and failed: queue_fs_event() failed: Invalid code: -1
    [   17.808389][    T1] init: processing action (post-fs-data) from (/system/etc/init/hw/init.rc:663)
    [   17.819137][    T1] init: starting service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)'...
    [   17.851851][    T1] init: SVC_EXEC service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' pid 248
    (uid 1000 gid 1000+0 context default) started; waiting...
    [   17.899533][    T1] init: Service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' (pid 248) exited
    with status 0 waiting took 0.062000 seconds
    [   17.913340][    T1] init: Sending signal 9 to service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint
    )' (pid 248) process group...
    [   17.926208][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 248 in 0ms
    [   17.936414][    T1] init: Command 'chown system system /data' action=post-fs-data (/system/etc/init/hw/init
    .rc:671) took 0ms and failed: lchown() failed: Read-only file system
    [   17.953293][    T1] init: Command 'chmod 0771 /data' action=post-fs-data (/system/etc/init/hw/init.rc:672)
    took 0ms and failed: fchmodat() failed: Read-only file system
    [   17.971486][    T1] init: Command 'installkey /data' action=post-fs-data (/system/etc/init/hw/init.rc:677)
    took 1ms and failed: Failed to create /data/unencrypted: Read-only file system
    [   17.989634][    T1] init: Command 'mkdir /data/bootchart 0755 shell shell encryption=Require' action=post-f
    s-data (/system/etc/init/hw/init.rc:681) took 1ms and failed: mkdir() failed on /data/bootchart: Read-only fil
    e system
    [   18.010097][    T1] init: Command 'copy /data/system/entropy.dat /dev/urandom' action=post-fs-data (/system
    /etc/init/hw/init.rc:685) took 0ms and failed: Could not read input file '/data/system/entropy.dat': open() fa
    [   18.033725][    T1] init: Command 'mkdir /data/vendor 0771 root root encryption=Require' action=post-fs-dat
    a (/system/etc/init/hw/init.rc:687) took 1ms and failed: mkdir() failed on /data/vendor: Read-only file system
    [   18.053480][    T1] init: Not setting encryption policy on: /data/vendor_ce
    [   18.062117][    T1] init: Command 'mkdir /data/vendor_ce 0771 root root encryption=None' action=post-fs-dat
    a (/system/etc/init/hw/init.rc:688) took 8ms and failed: mkdir() failed on /data/vendor_ce: Read-only file sys
    tem
    [   18.082375][    T1] init: service 'bootanim' requested start, but it is already running (flags: 134)
    [   18.091708][    T1] init: Control message: Processed ctl.start for 'bootanim' from pid: 205 (/system/bin/su
    rfaceflinger)
    [   18.102944][    T1] init: Not setting encryption policy on: /data/vendor_de
    [   18.111143][    T1] init: Command 'mkdir /data/vendor_de 0771 root root encryption=None' action=post-fs-dat
    a (/system/etc/init/hw/init.rc:689) took 8ms and failed: mkdir() failed on /data/vendor_de: Read-only file sys
    tem
    [   18.133123][    T1] init: Command 'mkdir /data/anr 0775 system system encryption=Require' action=post-fs-da
    ta (/system/etc/init/hw/init.rc:693) took 0ms and failed: mkdir() failed on /data/anr: Read-only file system
    [   18.153740][    T1] init: Command 'mkdir /data/tombstones 0771 system system encryption=Require' action=pos
    t-fs-data (/system/etc/init/hw/init.rc:694) took 1ms and failed: mkdir() failed on /data/tombstones: Read-only
     file system
    [   18.176972][    T1] init: starting service 'tombstoned'...
    [   18.183595][    T1] init: Created socket '/dev/socket/tombstoned_crash', mode 666, user 1000, group 1000
    [   18.194010][    T1] init: Created socket '/dev/socket/tombstoned_intercept', mode 666, user 1000, group 100
    0
    [   18.205496][    T1] init: Created socket '/dev/socket/tombstoned_java_trace', mode 666, user 1000, group 10
    00
    [   18.258362][    T1] init: Command 'start tombstoned' action=post-fs-data (/system/etc/init/hw/init.rc:697)
    took 81ms and succeeded
    [   18.271038][    T1] init: Switched to default mount namespace
    [   18.280570][    T1] init: Command 'mkdir /data/misc 01771 system misc encryption=Require' action=post-fs-da
    ta (/system/etc/init/hw/init.rc:704) took 2ms and failed: mkdir() failed on /data/misc: Read-only file system
    [   18.302510][    T1] selinux: SELinux: Could not get canonical path for /data/misc/keystore restorecon: No s
    [   18.314361][    T1] selinux:
    [   18.320497][    T1] init: starting service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)'...
    [   18.371987][    T1] init: SVC_EXEC service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' pid 259 (uid
    [   18.389185][    T1] init: Command 'exec - system system -- /system/bin/vdc keymaster earlyBootEnded' action
    =post-fs-data (/system/etc/init/hw/init.rc:719) took 70ms and succeeded
    [   18.405630][    T1] init: Service 'tombstoned' (pid 255) exited with status 1
    [   18.413111][    T1] init: Sending signal 9 to service 'tombstoned' (pid 255) process group...
    [   18.422314][    T1] libprocessgroup: Successfully killed process cgroup uid 1058 pid 255 in 0ms
    [   18.504932][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   18.783407][  T174] type=1400 audit(24.408:4): avc: denied { read } for comm="crash_dump64" name="status" d
    ev="selinuxfs" ino=19 scontext=u:r:crash_dump:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=0
    [   18.785620][  T170] logd: logdr: UID=1017 GID=1017 PID=266 n tail=0 logMask=8 pid=192 start=0ns deadline=0n
    s
    [   18.803055][  T174] type=1400 audit(24.408:5): avc: denied { read } for comm="crash_dump64" name="status" d
    [   18.816533][  T170] logd: logdr: UID=1017 GID=1017 PID=266 n tail=0 logMask=1 pid=192 start=0ns deadline=0n
    s
    [   18.854136][  T266] DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
    [   18.857798][  T266] DEBUG: Build fingerprint: 'TI/am62x/am62x:13/TQ3A.230705.001.A1/eng.root.20230721.19030
    1:userdebug/test-keys'
    [   18.867071][  T266] DEBUG: Revision: '0'
    [   18.885594][  T266] DEBUG: ABI: 'arm64'
    [   18.890443][  T266] DEBUG: Timestamp: 1970-01-01 00:00:24.179868865+0000
    [   18.895252][  T266] DEBUG: Process uptime: 4s
    [   18.902689][  T266] DEBUG: Cmdline: /system/bin/keystore2 /data/misc/keystore
    [   18.909981][  T266] DEBUG: pid: 192, tid: 192, name: binder:192_2  >>> /system/bin/keystore2 <<<
    [   18.917898][  T266] DEBUG: uid: 1017
    [   18.927751][  T266] DEBUG: tagged_addr_ctrl: 0000000000000001 (PR_TAGGED_ADDR_ENABLE)
    [   18.932028][  T266] DEBUG: signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
    [   18.940980][  T266] DEBUG: Abort message: 'Failed to open database.: Failed to attach database persistent.
    [   18.959183][  T266] DEBUG:
    [   18.962172][  T266] DEBUG: Caused by:
    [   18.966192][  T266] DEBUG:     0: unable to open database: file:/data/misc/keystore/persistent.sqlite
    [   18.975887][  T266] DEBUG:     1: Error code 14: Unable to open the database file'
    [   18.976477][  T266] DEBUG:     x0  0000000000000000  x1  00000000000000c0  x2  0000000000000006  x3  000000
    7fd3dc76f0
    [   18.985185][  T266] DEBUG:     x4  0000000000808080  x5  0000000000808080  x6  0000000000808080  x7  808080
    0000000000
    [   18.998354][  T266] DEBUG:     x8  00000000000000f0  x9  0000007f056b1a00  x10 0000000000000001  x11 000000
    7f056f36a0
    [   19.009830][  T266] DEBUG:     x12 0101010101010101  x13 2e746e6574736973  x14 0000007fd3dc670c  x15 000000
    0000000070
    [   19.021338][  T266] DEBUG:     x16 0000007f05761d58  x17 0000007f0573c770  x18 0000007f16216000  x19 000000
    00000000ac
    [   19.032878][  T266] DEBUG:     x20 00000000000000b2  x21 00000000000000c0  x22 00000000000000c0  x23 000000
    00ffffffff
    [   19.044509][  T266] DEBUG:     x24 0000000000000001  x25 0000005ee2249750  x26 0000005ee22497a8  x27 b40000
    7d52e1229c
    [   19.055949][  T266] DEBUG:     x28 0000005ee22495f0  x29 0000007fd3dc7770
    [   19.067473][  T266] DEBUG:     lr  0000007f056e33f4  sp  0000007fd3dc76d0  pc  0000007f056e3424  pst 000000
    0000000000
    [   19.076712][  T266] DEBUG: backtrace:
    [   19.088373][  T266] DEBUG:       #00 pc 0000000000053424  /apex/com.android.runtime/lib64/bionic/libc.so (a
    bort+180) (BuildId: dfb63f03d096213c51b3eecca455feac)
    [   19.092588][  T266] DEBUG:       #01 pc 00000000001576ac  /system/bin/keystore2 (_RNvNvCs2yrrfPAoZZX_11pani
    c_abort18___rust_start_panic5abort.llvm.16868985108068327187+4) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.107867][  T266] DEBUG:       #02 pc 00000000001576a0  /system/bin/keystore2 (__rust_start_panic+8) (Bui
    [   19.127730][  T266] DEBUG:       #03 pc 0000000000165c5c  /system/bin/keystore2 (rust_panic+16) (BuildId: 4
    [   19.141690][  T266] DEBUG:       #04 pc 000000000016592c  /system/bin/keystore2 (_RNvNtCs4p8YLn7dL5m_3std9p
    anicking20rust_panic_with_hook+996) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.155022][  T266] DEBUG:       #05 pc 0000000000165498  /system/bin/keystore2 (_RNCNvNtCs4p8YLn7dL5m_3std
    9panicking19begin_panic_handler0B5_.llvm.8848384190362852836+112) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.172620][  T266] DEBUG:       #06 pc 0000000000163d90  /system/bin/keystore2 (_RINvNtNtCs4p8YLn7dL5m_3st
    d10sys_common9backtrace26___rust_end_short_backtraceNCNvNtB6_9panicking19begin_panic_handler0zEB6_.llvm.884838
    4190362852836+16) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.192749][  T266] DEBUG:       #07 pc 000000000016526c  /system/bin/keystore2 (rust_begin_unwind+36) (Bui
    [   19.218182][  T266] DEBUG:       #08 pc 0000000000077388  /system/bin/keystore2 (_RNvNtCsl9ljXaK2GKD_4core9
    panicking9panic_fmt+36) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.232219][  T266] DEBUG:       #09 pc 0000000000077560  /system/bin/keystore2 (_RNvNtCsl9ljXaK2GKD_4core6
    result13unwrap_failed+80) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.249010][  T266] DEBUG:       #10 pc 00000000000d5bb0  /system/bin/keystore2 (_RNvNtCsjeBucwD6oYH_9keyst
    ore27globals22create_thread_local_db+664) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.265571][  T266] DEBUG:       #11 pc 00000000001204c4  /system/bin/keystore2 (_RNvNvNtCsjeBucwD6oYH_9key
    store27globals2DB7___getit+216) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.283613][  T266] DEBUG:       #12 pc 00000000000ecf74  /system/bin/keystore2 (_RNvXs0_NtCsjeBucwD6oYH_9k
    eystore211maintenanceNtB5_11MaintenanceNtNtNtNtNtNtCs5RsHhU1Nfkr_28android_security_maintenance4aidl7android8s
    ecurity11maintenance20IKeystoreMaintenance20IKeystoreMaintenance14earlyBootEnded+348) (BuildId: 4d0f04e7ae6050
    7f03365eb208bb4f00)
    [   19.300992][  T266] DEBUG:       #13 pc 0000000000064038  /system/bin/keystore2 (_RNvXs8_NtNtNtNtNtCs5RsHhU
    1Nfkr_28android_security_maintenance4aidl7android8security11maintenance20IKeystoreMaintenanceNtB5_21BnKeystore
    MaintenanceNtNtCs6pfwsPMdzSo_6binder6binder9Remotable11on_transact+396) (BuildId: 4d0f04e7ae60507f03365eb208bb
    4f00)
    [   19.332515][  T266] DEBUG:       #14 pc 0000000000064398  /system/bin/keystore2 (_RNvXs2_NtCs6pfwsPMdzSo_6b
    inder6nativeINtB5_6BinderNtNtNtNtNtNtCs5RsHhU1Nfkr_28android_security_maintenance4aidl7android8security11maint
    enance20IKeystoreMaintenance21BnKeystoreMaintenanceENtNtB7_6binder21InterfaceClassMethods11on_transactBY_+44)
    [   19.362747][  T266] DEBUG:       #15 pc 000000000000b1fc  /system/lib64/libbinder_ndk.so (ABBinder::onTrans
    act(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+140) (BuildId: 24e43640e469fbda0fca8
    574a4564056)
    [   19.396616][  T266] DEBUG:       #16 pc 000000000005213c  /system/lib64/libbinder.so (android::BBinder::tra
    nsact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+236) (BuildId: 59206956ecca114b1ca
    96a4d909f91d5)
    [   19.417929][  T266] DEBUG:       #17 pc 000000000005d9d4  /system/lib64/libbinder.so (android::IPCThreadSta
    te::executeCommand(int)+1012) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
    [   19.439252][  T266] DEBUG:       #18 pc 000000000005d510  /system/lib64/libbinder.so (android::IPCThreadSta
    te::getAndExecuteCommand()+160) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
    [   19.456219][  T266] DEBUG:       #19 pc 000000000005dda4  /system/lib64/libbinder.so (android::IPCThreadSta
    te::joinThreadPool(bool)+68) (BuildId: 59206956ecca114b1ca96a4d909f91d5)
    [   19.473347][  T266] DEBUG:       #20 pc 0000000000045e90  /system/bin/keystore2 (_RNvCsdV139EorvfX_14keysto
    re2_main4main+3004) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.490057][  T266] DEBUG:       #21 pc 00000000000469bc  /system/bin/keystore2 (_RNCINvNtCs4p8YLn7dL5m_3st
    d2rt10lang_startuE0CsdV139EorvfX_14keystore2_main+8) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.506201][  T266] DEBUG:       #22 pc 0000000000163788  /system/bin/keystore2 (_RNvNtCs4p8YLn7dL5m_3std2r
    t19lang_start_internal+344) (BuildId: 4d0f04e7ae60507f03365eb208bb4f00)
    [   19.525185][  T266] DEBUG:       #23 pc 0000000000046ac0  /system/bin/keystore2 (main+40) (BuildId: 4d0f04e
    [   19.541888][  T266] DEBUG:       #24 pc 000000000004b730  /apex/com.android.runtime/lib64/bionic/libc.so (_
    _libc_init+96) (BuildId: dfb63f03d096213c51b3eecca455feac)
    [   19.584245][    T1] init: Untracked pid 266 exited with status 0
    [   19.588669][   T53] binder: release 192:192 transaction 619 in, still active
    [   19.599410][    T1] init: Untracked pid 266 did not have an associated service entry and will not be reaped
    [   19.605537][   T53] binder: send failed reply for transaction 619 to 178:178
    [   19.612967][    T1] init: Service 'keystore2' (pid 192) received signal 6
    [   19.623146][  T178] vold: keystore2 Communication with Keystore earlyBootEnded failed error: -129
    [   19.629491][    T1] init: Sending signal 9 to service 'keystore2' (pid 192) process group...
    [   19.654417][    T1] libprocessgroup: Successfully killed process cgroup uid 1017 pid 192 in 0ms
    [   19.666695][    T1] init: Service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' (pid 259) exited with
     status 0 waiting took 1.328000 seconds
    [   19.680327][    T1] init: Sending signal 9 to service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' (
    pid 259) process group...
    [   19.694889][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 259 in 1ms
    [   19.705938][    T1] init: Untracked pid 268 exited with status 0
    [   19.712236][    T1] init: Untracked pid 268 did not have an associated service entry and will not be reaped
    [   19.724298][    T1] init: Command 'mkdir /data/property 0700 root root encryption=Require' action=post-fs-d
    ata (/system/etc/init/hw/init.rc:725) took 1ms and failed: mkdir() failed on /data/property: Read-only file sy
    stem
    [   19.744935][  T103] init: Couldn't load property file '/data/local.prop': open() failed: No such file or di
    rectory: No such file or directory
    [   19.758094][  T103] init: Could not load single persistent property file, trying legacy directory: Unable t
    o read persistent property file: open() failed: No such file or directory
    [   19.774796][  T103] init: Unable to load legacy persistent properties: Unable to open persistent property d
    irectory "/data/property": No such file or directory
    [   19.790886][  T103] init: Wait for property 'ro.persistent_properties.ready=true' took 46ms
    [   19.800093][    T1] init: service 'logd' requested start, but it is already running (flags: 4)
    [   19.811215][    T1] init: starting service 'logd-reinit'...
    [   19.866652][    T1] init: Command 'start logd-reinit' action=post-fs-data (/system/etc/init/hw/init.rc:729)
     took 55ms and succeeded
    [   19.879752][    T1] init: Not setting encryption policy on: /data/apex
    [   19.889639][    T1] init: Command 'mkdir /data/apex 0755 root system encryption=None' action=post-fs-data (
    /system/etc/init/hw/init.rc:742) took 9ms and failed: mkdir() failed on /data/apex: Read-only file system
    [   19.912745][    T1] init: Inferred action different from explicit one, expected 0 but got 2
    [   19.927334][    T1] init: Inferred action different from explicit one, expected 0 but got 3
    [   19.938010][    T1] init: Command 'mkdir /data/app-staging 0751 system system encryption=DeleteIfNecessary'
     action=post-fs-data (/system/etc/init/hw/init.rc:748) took 10ms and failed: mkdir() failed on /data/app-stagi
    ng: Read-only file system
    [   19.960108][    T1] init: Inferred action different from explicit one, expected 0 but got 2
    [   19.973308][    T1] init: starting service 'apexd'...
    [   19.975166][  T172] logd: logd reinit
    [   19.983027][  T172] logd: Cannot read /data/misc/logd/event-log-tags
    [   19.995176][  T172] logd: FrameworkListener: read() failed (Connection reset by peer)
    [   20.025280][    T1] init: Command 'restart apexd' action=post-fs-data (/system/etc/init/hw/init.rc:751) too
    k 52ms and succeeded
    [   20.037779][    T1] init: Service 'logd-reinit' (pid 275) exited with status 0 oneshot service took 0.21400
    [   20.050002][    T1] init: Sending signal 9 to service 'logd-reinit' (pid 275) process group...
    [   20.059717][    T1] libprocessgroup: Successfully killed process cgroup uid 1036 pid 275 in 0ms
    [   20.082827][    T1] init: Command 'copy /data/misc/recovery/ro.build.fingerprint /data/misc/recovery/ro.bui
    ld.fingerprint.1' action=post-fs-data (/system/etc/init/hw/init.rc:755) took 0ms and failed: Could not read in
    put file '/data/misc/recovery/ro.build.fingerprint': open() failed: No such file or directory
    [   20.115011][  T276] apexd: Scanning /system/apex for pre-installed ApexFiles
    [   20.115217][    T1] init: Command 'copy /data/misc/recovery/proc/version /data/misc/recovery/proc/version.1
    ' action=post-fs-data (/system/etc/init/hw/init.rc:762) took 0ms and failed: Could not read input file '/data/
    misc/recovery/proc/version': open() failed: No such file or directory
    [   20.123762][  T276] apexd: Found pre-installed APEX /system/apex/com.android.resolv.capex
    [   20.150214][    T1] init: Command 'copy /proc/version /data/misc/recovery/proc/version' action=post-fs-data
     (/system/etc/init/hw/init.rc:765) took 1ms and failed: Could not write to output file '/data/misc/recovery/pr
    [   20.158153][  T276] apexd: Found pre-installed APEX /system/apex/com.android.ondevicepersonalization.apex
    [   20.191643][  T276] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
    [   20.201520][  T276] apexd: Found pre-installed APEX /system/apex/com.android.vndk.current.apex
    [   20.207430][    T1] init: Command 'mkdir /data/local 0751 root root encryption=Require' action=post-fs-data
     (/system/etc/init/hw/init.rc:799) took 1ms and failed: mkdir() failed on /data/local: Read-only file system
    [   20.212076][  T276] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
    [   20.239422][  T276] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.capex
    [   20.249646][  T276] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
    [   20.253648][    T1] init: starting service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice)'...
    [   20.259836][  T276] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
    [   20.269028][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   20.277668][  T276] apexd: Found pre-installed APEX /system/apex/com.android.mediaprovider.capex
    [   20.293075][  T276] apexd: Found pre-installed APEX /system/apex/com.android.os.statsd.apex
    [   20.303230][  T276] apexd: Found pre-installed APEX /system/apex/com.android.apex.cts.shim.apex
    [   20.306702][    T1] init: SVC_EXEC service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice)' pid 277
    (uid 1081 gid 1000+0 context default) started; waiting...
    [   20.314041][  T276] apexd: Found pre-installed APEX /system/apex/com.android.art.capex
    [   20.327099][    T1] init: Command 'exec - virtualizationservice system -- /bin/rm -rf /data/misc/virtualiza
    tionservice' action=post-fs-data (/system/etc/init/hw/init.rc:835) took 74ms and succeeded
    [   20.336247][  T276] apexd: Found pre-installed APEX /system/apex/com.android.adbd.capex
    [   20.362123][  T276] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
    [   20.372254][  T276] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
    [   20.372568][    T1] init: Service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice)' (pid 277) exited
    with status 0 waiting took 0.100000 seconds
    [   20.382050][  T276] apexd: Found pre-installed APEX /system/apex/com.android.adservices.capex
    [   20.394506][    T1] init: Sending signal 9 to service 'exec 7 (/bin/rm -rf /data/misc/virtualizationservice
    )' (pid 277) process group...
    [   20.404147][  T276] apexd: Found pre-installed APEX /system/apex/com.android.uwb.capex
    [   20.415636][    T1] libprocessgroup: Successfully killed process cgroup uid 1081 pid 277 in 0ms
    [   20.424761][  T276] apexd: Found pre-installed APEX /system/apex/com.android.neuralnetworks.capex
    [   20.435270][    T1] init: Not setting encryption policy on: /data/preloads
    [   20.442728][  T276] apexd: Found pre-installed APEX /system/apex/com.android.extservices.capex
    [   20.449865][    T1] init: Command 'mkdir /data/preloads 0775 system system encryption=None' action=post-fs-
    data (/system/etc/init/hw/init.rc:838) took 14ms and failed: mkdir() failed on /data/preloads: Read-only file
    system
    [   20.458202][  T276] apexd: Found pre-installed APEX /system/apex/com.android.i18n.apex
    [   20.479959][    T1] init: Not setting encryption policy on: /data/data
    [   20.486572][  T276] apexd: Found pre-installed APEX /system/apex/com.android.scheduling.apex
    [   20.492935][    T1] init: Command 'mkdir /data/data 0771 system system encryption=None' action=post-fs-data
     (/system/etc/init/hw/init.rc:844) took 12ms and failed: mkdir() failed on /data/data: Read-only file system
    [   20.501664][  T276] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
    [   20.521586][    T1] init: Command 'mkdir /data/app-private 0771 system system encryption=Require' action=po
    st-fs-data (/system/etc/init/hw/init.rc:845) took 1ms and failed: mkdir() failed on /data/app-private: Read-on
    ly file system
    [   20.528940][  T276] apexd: Found pre-installed APEX /system/apex/com.android.btservices.apex
    [   20.549708][    T1] init: Command 'mkdir /data/app-ephemeral 0771 system system encryption=Require' action=
    post-fs-data (/system/etc/init/hw/init.rc:846) took 1ms and failed: mkdir() failed on /data/app-ephemeral: Rea
    d-only file system
    [   20.557911][  T276] apexd: Found pre-installed APEX /system/apex/com.android.tethering.capex
    [   20.578908][    T1] init: Command 'mkdir /data/app-asec 0700 root root encryption=Require' action=post-fs-d
    ata (/system/etc/init/hw/init.rc:847) took 1ms and failed: mkdir() failed on /data/app-asec: Read-only file sy
    stem
    [   20.587177][  T276] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
    [   20.607265][    T1] init: Command 'mkdir /data/app-lib 0771 system system encryption=Require' action=post-f
    s-data (/system/etc/init/hw/init.rc:848) took 1ms and failed: mkdir() failed on /data/app-lib: Read-only file
    system
    [   20.616342][  T276] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
    [   20.636277][    T1] init: Command 'mkdir /data/app 0771 system system encryption=Require' action=post-fs-da
    ta (/system/etc/init/hw/init.rc:849) took 1ms and failed: mkdir() failed on /data/app: Read-only file system
    [   20.643929][  T276] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
    [   20.661800][    T1] init: Inferred action different from explicit one, expected 0 but got 2
    [   20.669397][  T276] apexd: /system_ext/apex does not exist. Skipping
    [   20.679172][    T1] init: Command 'mkdir /data/fonts/ 0771 root root encryption=Require' action=post-fs-dat
    a (/system/etc/init/hw/init.rc:852) took 17ms and failed: mkdir() failed on /data/fonts/: Read-only file syste
    m
    [   20.683979][  T276] apexd: Scanning /product/apex for pre-installed ApexFiles
    [   20.710854][  T276] apexd: /product/apex does not exist. Skipping
    [   20.712452][    T1] init: Command 'mkdir /data/dalvik-cache 0771 root root encryption=Require' action=post-
    fs-data (/system/etc/init/hw/init.rc:868) took 1ms and failed: mkdir() failed on /data/dalvik-cache: Read-only
     file system
    [   20.717135][  T276] apexd: Scanning /vendor/apex for pre-installed ApexFiles
    [   20.739195][    T1] init: Command 'mkdir /data/ota 0771 root root encryption=Require' action=post-fs-data (
    /system/etc/init/hw/init.rc:870) took 1ms and failed: mkdir() failed on /data/ota: Read-only file system
    [   20.744722][  T276] apexd: /vendor/apex does not exist. Skipping
    [   20.764996][    T1] init: Command 'mkdir /data/ota_package 0770 system cache encryption=Require' action=pos
    t-fs-data (/system/etc/init/hw/init.rc:874) took 1ms and failed: mkdir() failed on /data/ota_package: Read-onl
    y file system
    [   20.769927][  T276] apexd: No block apex metadata partition found, not adding block apexes
    [   20.791524][    T1] init: Command 'mkdir /data/resource-cache 0771 system system encryption=Require' action
    =post-fs-data (/system/etc/init/hw/init.rc:877) took 1ms and failed: mkdir() failed on /data/resource-cache: R
    [   20.798393][  T276] apexd: Populating APEX database from mounts...
    [   20.819987][    T1] init: Not setting encryption policy on: /data/lost+found
    [   20.827586][  T276] apexd: 0 packages restored.
    [   20.834804][    T1] init: Command 'mkdir /data/lost+found 0770 root root encryption=None' action=post-fs-da
    ta (/system/etc/init/hw/init.rc:882) took 14ms and failed: mkdir() failed on /data/lost+found: Read-only file
    system
    [   20.837785][  T276] apexd: Failed to migrate sessions to /metadata partition : Failed to stat /metadata/ape
    x/sessions: No such file or directory
    [   20.859280][    T1] init: Command 'mkdir /data/drm 0770 drm drm encryption=Require' action=post-fs-data (/s
    ystem/etc/init/hw/init.rc:886) took 1ms and failed: mkdir() failed on /data/drm: Read-only file system
    [   20.871192][  T276] apexd: Marking APEXd as starting
    [   20.890637][    T1] init: Command 'mkdir /data/mediadrm 0770 mediadrm mediadrm encryption=Require' action=p
    ost-fs-data (/system/etc/init/hw/init.rc:890) took 1ms and failed: mkdir() failed on /data/mediadrm: Read-only
     file system
    [   20.897028][  T276] apexd: Failed to stat /metadata/apex/sessions: No such file or directory
    [   20.916172][    T1] init: Command 'mkdir /data/nfc 0770 nfc nfc encryption=Require' action=post-fs-data (/s
    ystem/etc/init/hw/init.rc:893) took 1ms and failed: mkdir() failed on /data/nfc: Read-only file system
    [   20.923213][  T276] apexd: Failed to stat /data/apex/sessions: No such file or directory
    [   20.944978][    T1] init: Command 'mkdir /data/backup 0700 system system encryption=Require' action=post-fs
    -data (/system/etc/init/hw/init.rc:898) took 1ms and failed: mkdir() failed on /data/backup: Read-only file sy
    stem
    [   20.970434][    T1] init: starting service 'keystore2'...
    [   21.027882][    T1] init: Service 'apexd' (pid 276) received signal 6 oneshot service took 1.043000 seconds
     in background
    [   21.039317][    T1] init: Sending signal 9 to service 'apexd' (pid 276) process group...
    [   21.049228][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 276 in 0ms
    [   21.059399][    T1] init: Service with 'reboot_on_failure' option failed, shutting down system.
    [   21.071614][    T1] init: Untracked pid 279 exited with status 1
    [   21.078034][    T1] init: Untracked pid 279 did not have an associated service entry and will not be reaped
    [   21.088254][    T1] init: Got shutdown_command 'reboot,apexd-failed' Calling HandlePowerctlMessage()
    [   21.098513][    T1] init: Clear action queue and start shutdown trigger
    [   21.106576][    T1] init: Entering shutdown mode
    [   21.112909][    T1] init: processing action (shutdown_done) from (<Builtin Action>:0)
    [   21.121546][    T1] init: Reboot start, reason: reboot,apexd-failed, reboot_target: apexd-failed
    [   21.130753][    T1] init: Shutdown timeout: 6000 ms
    [   21.135942][    T1] init: Create reboot monitor thread.
    [   21.143775][  T103] init: Recovering persistent properties from memory: Unable to read persistent property
    [   21.152118][  T281] init: shutdown_timeout_timespec.tv_sec: 327
    [   21.159071][  T103] init: Could not store persistent property: Could not open temporary properties file: No
    [   21.179233][    T1] init: Could not open '/metadata/bootstat/persist.sys.boot.reason' to persist reboot rea
    son: No such file or directory
    [   21.199210][    T1] init: Reboot ending, jumping to kernel
    [   21.205027][    T1] kvm: exiting hardware virtualization
    [   21.844961][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   23.405031][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   24.956936][   T91] sdhci-am654 fa00000.mmc: Power on failed
    [   31.456818][    C0] mmc0: Timeout waiting for hardware cmd interrupt.
    [   31.463298][    C0] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
    [   31.470422][    C0] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001004
    [   31.477546][    C0] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
    [   31.484669][    C0] mmc0: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
    [   31.491792][    C0] mmc0: sdhci: Present:   0x01ff00f1 | Host ctl: 0x00000001
    [   31.498915][    C0] mmc0: sdhci: Power:     0x00000000 | Blk gap:  0x00000080
    [   31.506037][    C0] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
    [   31.513160][    C0] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [   31.520283][    C0] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
    [   31.527406][    C0] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [   31.534528][    C0] mmc0: sdhci: Caps:      0x3decc801 | Caps_1:   0x18002407
    [   31.541651][    C0] mmc0: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
    [   31.548773][    C0] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
    [   31.555896][    C0] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
    [   31.563018][    C0] mmc0: sdhci: Host ctl2: 0x00000000
    [   31.568146][    C0] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
    [   31.575961][    C0] mmc0: sdhci: ============================================
    [   41.696827][    C0] mmc0: Timeout waiting for hardware cmd interrupt.
    [   41.703317][    C0] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
    [   41.710446][    C0] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001004
    [   41.717573][    C0] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
    [   41.724698][    C0] mmc0: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
    [   41.731823][    C0] mmc0: sdhci: Present:   0x01ff00f1 | Host ctl: 0x00000001
    [   41.738946][    C0] mmc0: sdhci: Power:     0x00000000 | Blk gap:  0x00000080
    [   41.746070][    C0] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
    [   41.753193][    C0] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [   41.760316][    C0] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
    [   41.767444][    C0] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [   41.774572][    C0] mmc0: sdhci: Caps:      0x3decc801 | Caps_1:   0x18002407
    [   41.781699][    C0] mmc0: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
    [   41.788822][    C0] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
    [   41.795945][    C0] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
    [   41.803067][    C0] mmc0: sdhci: Host ctl2: 0x00000000
    [   41.808196][    C0] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
    [   41.816013][    C0] mmc0: sdhci: ============================================
    [   51.936828][    C0] mmc0: Timeout waiting for hardware cmd interrupt.
    [   51.943306][    C0] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
    [   51.950433][    C0] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001004
    [   51.957562][    C0] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
    [   51.964689][    C0] mmc0: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
    [   51.971813][    C0] mmc0: sdhci: Present:   0x01ff00f1 | Host ctl: 0x00000001
    [   51.978936][    C0] mmc0: sdhci: Power:     0x00000000 | Blk gap:  0x00000080
    [   51.986060][    C0] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
    [   51.993183][    C0] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [   52.000305][    C0] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
    [   52.007428][    C0] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [   52.014551][    C0] mmc0: sdhci: Caps:      0x3decc801 | Caps_1:   0x18002407
    [   52.021674][    C0] mmc0: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
    [   52.028797][    C0] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
    [   52.035935][    C0] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
    [   52.043074][    C0] mmc0: sdhci: Host ctl2: 0x00000000
    [   52.048204][    C0] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
    [   52.056022][    C0] mmc0: sdhci: ============================================
    [   62.176824][    C0] mmc0: Timeout waiting for hardware cmd interrupt.
    [   62.183304][    C0] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
    [   62.190428][    C0] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001004
    [   62.197551][    C0] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
    [   62.204674][    C0] mmc0: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
    [   62.211797][    C0] mmc0: sdhci: Present:   0x01ff00f1 | Host ctl: 0x00000001
    [   62.218937][    C0] mmc0: sdhci: Power:     0x00000000 | Blk gap:  0x00000080
    [   62.226076][    C0] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
    [   62.233202][    C0] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [   62.240327][    C0] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
    [   62.247452][    C0] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [   62.254576][    C0] mmc0: sdhci: Caps:      0x3decc801 | Caps_1:   0x18002407
    [   62.261699][    C0] mmc0: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
    [   62.268822][    C0] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
    [   62.275945][    C0] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
    [   62.283068][    C0] mmc0: sdhci: Host ctl2: 0x00000000
    [   62.288197][    C0] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
    [   62.296013][    C0] mmc0: sdhci: ============================================
    [   62.304011][    T6] mmc0: card 0001 removed
    Today I reflashed again on E2 Board, can boot to Android, but console keep on output mmc power on failed...
    [ 4190.473537][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4192.233353][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4193.793974][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4195.353403][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4196.907531][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4198.673842][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4200.233351][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4201.791375][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4203.353479][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4205.113131][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4206.671141][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4208.233344][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4209.792744][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4211.553711][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4213.113214][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4214.673829][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4216.233337][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4217.994169][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4219.553704][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4221.113215][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4222.667513][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4224.433580][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4225.993330][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4227.551551][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4229.113203][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4230.881175][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4232.443619][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4234.001968][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4235.557422][   T61] sdhci-am654 fa00000.mmc: Power on failed
    [ 4237.323477][   T61] sdhci-am654 fa00000.mmc: Power on failed
    On E3 board, after reflash, switch to eMMC boot and remove SD card, no output as before
    But if set to SD boot, can boot Uboot from SD card then to Android, something wrong on setting boot partition? how to make it boot directly from eMMC?
    [  118.194849][  T594] AidlLazyServiceRegistrar: Process has 0 (of 1 available) client(s) in use after notific
    ation apexservice has clients: 0
    [  118.233455][  T594] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [  120.972251][  T286] apexd: Deleting unused dm device com.android.apex.cts.shim
    [  121.017468][  T286] apexd: Didn't generate uevent for [com.android.apex.cts.shim] removal
    [  121.108525][  T286] apexd: Failed to delete dm-device com.android.apex.cts.shim
    [  121.117636][  T286] apexd: Deleting unused dm device com.android.appsearch
    [  121.141710][  T286] apexd: Didn't generate uevent for [com.android.appsearch] removal
    [  121.150180][  T286] apexd: Failed to delete dm-device com.android.appsearch
    [  121.160414][  T286] apexd: Deleting unused dm device com.android.btservices
    [  121.169515][  T286] apexd: Didn't generate uevent for [com.android.btservices] removal
    [  121.179018][  T286] apexd: Failed to delete dm-device com.android.btservices
    [  121.186692][  T286] apexd: Deleting unused dm device com.android.i18n
    [  121.196601][  T286] apexd: Didn't generate uevent for [com.android.i18n] removal
    [  121.206324][  T286] apexd: Failed to delete dm-device com.android.i18n
    [  121.213527][  T286] apexd: Deleting unused dm device com.android.ondevicepersonalization
    [  121.223748][  T286] apexd: Didn't generate uevent for [com.android.ondevicepersonalization] removal
    [  121.233351][  T286] apexd: Failed to delete dm-device com.android.ondevicepersonalization
    [  121.243287][  T286] apexd: Deleting unused dm device com.android.os.statsd
    [  121.301655][  T286] apexd: Didn't generate uevent for [com.android.os.statsd] removal
    [  121.363717][  T286] apexd: Failed to delete dm-device com.android.os.statsd
    [  121.419970][  T286] apexd: Deleting unused dm device com.android.runtime
    [  121.497001][  T286] apexd: Didn't generate uevent for [com.android.runtime] removal
    [  121.525619][  T286] apexd: Failed to delete dm-device com.android.runtime
    [  121.577608][  T286] apexd: Deleting unused dm device com.android.scheduling
    [  121.590541][  T286] apexd: Didn't generate uevent for [com.android.scheduling] removal
    [  121.598994][  T286] apexd: Failed to delete dm-device com.android.scheduling
    [  121.606691][  T286] apexd: Deleting unused dm device com.android.sdkext
    [  121.616258][  T286] apexd: Didn't generate uevent for [com.android.sdkext] removal
    [  121.626894][  T286] apexd: Failed to delete dm-device com.android.sdkext
    [  121.635065][  T286] apexd: Deleting unused dm device com.android.tzdata
    [  121.642967][  T286] apexd: Didn't generate uevent for [com.android.tzdata] removal
    [  121.652250][  T286] apexd: Failed to delete dm-device com.android.tzdata
    [  121.659725][  T286] apexd: Deleting unused dm device com.android.vndk.v33
    [  121.668245][  T286] apexd: Didn't generate uevent for [com.android.vndk.v33] removal
    [  121.676942][  T286] apexd: Failed to delete dm-device com.android.vndk.v33
    [  121.684745][  T286] AidlLazyServiceRegistrar: Trying to shut down the service. No clients in use for any se
    rvice in process.
    [  121.739274][  T286] AidlLazyServiceRegistrar: Unregistered all clients and exiting
    [  121.814372][    T1] init: Service 'apexd' (pid 286) exited with status 0 oneshot service took 101.481003 se
    conds in background
    [  121.838624][    T1] init: Sending signal 9 to service 'apexd' (pid 286) process group...
    [  121.848570][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 286 in 1ms
    [  122.614904][    T1] init: Untracked pid 1580 received signal 15
    [  122.621471][    T1] init: Untracked pid 1580 did not have an associated service entry and will not be reape
    d
    [  122.633969][  T341] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please
     run fsck.
    [  122.865682][  T177] type=1400 audit(1689960922.404:13): avc: denied { read } for comm="binder:195_4" name="
    wakeup7" dev="sysfs" ino=30746 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power_supply:s0 tclass
    =dir permissive=0
    [  124.382654][    T1] init: Sending signal 9 to service 'idmap2d' (pid 1256) process group...
    [  124.457865][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 1256 in 43ms
    [  124.598853][    T1] init: Control message: Processed ctl.stop for 'idmap2d' from pid: 509 (system_server)
    [  124.666888][    T1] init: Service 'idmap2d' (pid 1256) received signal 9
    console:/ $
    you can confirm if you go in uboot from sd card , then fastboot mode and try to flash manually tiboot3-hsfs.bin with this command :
    fastboot flash tiboot3 tiboot3-am62x-sk-hsfs.bin
    Where to do it? Does it need to boot from eMMC to UBOOT first?
    In UBOOT:
    => fastboot flash tiboot3 tiboot3-am62x-sk-hsfs.bin
    Error: Wrong USB controller index format
    => fastboot 0
    generic_phy_get_bulk : no phys property
    On Linux PC,
    Which files should copy to SD card for GP SK board?
    tiboot3-am62x-sk.bin or tiboot3-am62x-sk-dfu.bin, also tispl-am62x-sk.bin or tispl-am62x-sk-dfu.bin, u-boot-am62x-sk.img or u-boot-am62x-sk-dfu.img
  • Hi ,
    I recheck your log and something is not good uboot version was version on previous release and not 09 release.
    - For E2 mmc power was link to sdcard , i suppose you don't have an sdcard inserted , it's linux issue not android issue and not a problem .
    - For E2 and E3 to clarify can you please redo process and share complete log from you pc and from serial console ?
    - For AM62b command.
    you need to launch in uboot this command :
    fastboot 0
    from your PC (perhaps with sudo command) :
    and plug usb c cable to you PC.
    Can you say me which uboot you copy on sdcard too  and where come from?
  • E2.
    I insert SD card, can boot normally to console without error, do you mean it is Linux driver configuration issue? who should consult?
    [   88.143787][  T332] AidlLazyServiceRegistrar: Process has 0 (of 1 available) client(s) in use after notification apexservice has clients: 0
    [   88.181446][  T332] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   90.473870][  T281] apexd: Deleting unused dm device com.android.apex.cts.shim
    [   90.494778][  T281] apexd: Didn't generate uevent for [com.android.apex.cts.shim] removal
    [   90.504659][  T281] apexd: Failed to delete dm-device com.android.apex.cts.shim
    [   90.518150][  T281] apexd: Deleting unused dm device com.android.appsearch
    [   90.559923][  T281] apexd: Didn't generate uevent for [com.android.appsearch] removal
    [   90.655969][  T281] apexd: Failed to delete dm-device com.android.appsearch
    [   90.736198][  T281] apexd: Deleting unused dm device com.android.btservices
    [   90.900221][  T281] apexd: Didn't generate uevent for [com.android.btservices] removal
    [   90.915877][  T281] apexd: Failed to delete dm-device com.android.btservices
    [   90.923762][  T281] apexd: Deleting unused dm device com.android.i18n
    [   90.934614][  T281] apexd: Didn't generate uevent for [com.android.i18n] removal
    [   90.948670][  T281] apexd: Failed to delete dm-device com.android.i18n
    [   90.956482][  T281] apexd: Deleting unused dm device com.android.ondevicepersonalization
    [   90.975076][  T281] apexd: Didn't generate uevent for [com.android.ondevicepersonalization] removal
    [   90.994732][  T281] apexd: Failed to delete dm-device com.android.ondevicepersonalization
    [   91.006707][  T281] apexd: Deleting unused dm device com.android.os.statsd
    [   91.021702][  T281] apexd: Didn't generate uevent for [com.android.os.statsd] removal
    [   91.044028][  T281] apexd: Failed to delete dm-device com.android.os.statsd
    [   91.051393][  T281] apexd: Deleting unused dm device com.android.runtime
    [   91.153660][  T281] apexd: Didn't generate uevent for [com.android.runtime] removal
    [   91.163567][  T281] apexd: Failed to delete dm-device com.android.runtime
    [   91.170829][  T281] apexd: Deleting unused dm device com.android.scheduling
    [   91.178885][  T281] apexd: Didn't generate uevent for [com.android.scheduling] removal
    [   91.187125][  T281] apexd: Failed to delete dm-device com.android.scheduling
    [   91.194513][  T281] apexd: Deleting unused dm device com.android.sdkext
    [   91.204122][  T281] apexd: Didn't generate uevent for [com.android.sdkext] removal
    [   91.212401][  T281] apexd: Failed to delete dm-device com.android.sdkext
    [   91.222025][  T281] apexd: Deleting unused dm device com.android.tzdata
    [   91.229914][  T281] apexd: Didn't generate uevent for [com.android.tzdata] removal
    [   91.238387][  T281] apexd: Failed to delete dm-device com.android.tzdata
    [   91.245844][  T281] apexd: Deleting unused dm device com.android.vndk.v33
    [   91.256412][  T281] apexd: Didn't generate uevent for [com.android.vndk.v33] removal
    [   91.289461][  T281] apexd: Failed to delete dm-device com.android.vndk.v33
    [   91.363636][  T281] AidlLazyServiceRegistrar: Trying to shut down the service. No clients in use for any service in process.
    [   91.390553][    T1] init: Untracked pid 1427 received signal 15
    [   91.399712][    T1] init: Untracked pid 1427 did not have an associated service entry and will not be reaped
    [   91.425627][  T240] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   91.541565][  T281] AidlLazyServiceRegistrar: Unregistered all clients and exiting
    [   91.726906][    T1] init: Service 'apexd' (pid 281) exited with status 0 oneshot service took 74.623001 seconds in background
    [   91.740595][    T1] init: Sending signal 9 to service 'apexd' (pid 281) process group...
    [   91.772550][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 281 in 0ms
    console:/ $
    console:/ $
    console:/ $
    console:/ $
    I do it step by step on E3 board:
    copy files to sd card
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ ls /media/tony/BOOT
    adb                      mke2fs.conf                       tiboot3-am62x-sk-dfu.bin       u-boot-am62x-lp-sk.img
    am62x-sk-evm.yaml        persist.img                       tiboot3-am62x-sk-dfu-hsfs.bin  u-boot-am62x-sk-dfu.img
    boot.img                 super.img                         tiboot3-am62x-sk-hsfs.bin      u-boot-am62x-sk.img
    bootloader-am62x-sk.img  tiboot3-am62x-lp-sk.bin           tispl-am62x-lp-sk.bin          userdata.img
    dtbo.img                 tiboot3-am62x-lp-sk-dfu.bin       tispl-am62x-lp-sk-dfu.bin      vbmeta.img
    fastboot                 tiboot3-am62x-lp-sk-dfu-hsfs.bin  tispl-am62x-sk.bin
    flashall.sh              tiboot3-am62x-lp-sk-hsfs.bin      tispl-am62x-sk-dfu.bin
    mke2fs                   tiboot3-am62x-sk.bin              u-boot-am62x-lp-sk-dfu.img
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ cp tiboot3-am62x-sk.bin /media/tony/BOOT/tiboot3.bin
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ cp tispl-am62x-sk.bin /media/tony/BOOT/tispl.bin
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ cp u-boot-am62x-sk.img /media/tony/BOOT/u-boot.img
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ sync
    tiboot3.bin  tispl.bin  u-boot.img
    power up to boot from SD card, console log:
    tony@tony-HP:~$ sudo picocom -b 115200 -r -l /dev/ttyUSB
    ttyUSB0  ttyUSB1  ttyUSB2  ttyUSB3
    tony@tony-HP:~$ sudo picocom -b 115200 -r -l /dev/ttyUSB0
    [sudo] password for tony:
    picocom v2.2
    port is        : /dev/ttyUSB0
    flowcontrol    : none
    baudrate is    : 115200
    parity is      : none
    databits are   : 8
    stopbits are   : 1
    escape is      : C-a
    local echo is  : no
    noinit is      : no
    noreset is     : yes
    nolock is      : yes
    send_cmd is    : sz -vv
    receive_cmd is : rz -vv -E
    imap is        : => setenv fastboot.partition-type:metadata ext4; saveenv;
    Saving Environment to MMC... Writing to MMC(0)... OK
    omap is        :
    emap is        : crcrlf,delbs,
    Type [C-a] [C-h] to see available commands
    Terminal ready
    U-Boot SPL 2023.04 (Jul 20 2023 - 00:43:28 +0200)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
    SPL initial stack usage: 13392 bytes
    Trying to boot from MMC2
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):08.06.00.006
    NOTICE:  BL31: Built : 00:43:25, Jul 20 2023
    U-Boot SPL 2023.04 (Jul 20 2023 - 00:43:46 +0200)
    SPL initial stack usage: 1856 bytes
    Error (-2): cannot determine file size
    U-Boot 2023.04 (Jul 20 2023 - 00:43:46 +0200)
    SoC:   AM62X SR1.0 GP
    Model: Texas Instruments AM625 SK
    EEPROM not available at 80, trying to read at 81
    Board: AM62-SKEVM rev E3
    DRAM:  2 GiB
    Core:  71 devices, 31 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from MMC... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    power cycle board, console log:
    SoC:   AM62X SR1.0 GP
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    => fastboot 0
    Writing GPT: success!
    dwc3-generic-peripheral usb@31000000: request 00000000f75ff140 was not queued to ep1in-bulk
    ** Bad device specification mmc tiboot3_a **
    Couldn't find partition mmc tiboot3_a
    Starting download of 291717 bytes
    downloading of 291717 bytes finished
    Flashing Raw Image
    ........ wrote 291840 bytes to 'tiboot3'
    ** Bad device specification mmc bootloader_a **
    Couldn't find partition mmc bootloader_a
    Starting download of 8388608 bytes
    downloading of 8388608 bytes finished
    Flashing Raw Image
    ........ wrote 8388608 bytes to 'bootloader'
    ** Bad device specification mmc super_a **
    Couldn't find partition mmc super_a
    Starting download of 760255408 bytes
    downloading of 760255408 bytes finished
    Flashing sparse image at offset 225536
    Flashing Sparse Image
    ........ wrote 760512512 bytes to 'super'
    Starting download of 712720072 bytes
    downloading of 712720072 bytes finished
    ........ wrote 723816448 bytes to 'super'
    ** Bad device specification mmc boot_a_a **
    Couldn't find partition mmc boot_a_a
    Starting download of 41943040 bytes
    downloading of 41943040 bytes finished
    Flashing Raw Image
    ........ wrote 41943040 bytes to 'boot_a'
    ** Bad device specification mmc boot_b_a **
    Couldn't find partition mmc boot_b_a
    Flashing Raw Image
    ........ wrote 41943040 bytes to 'boot_b'
    ** Bad device specification mmc userdata_a **
    Couldn't find partition mmc userdata_a
    Starting download of 2621716 bytes
    downloading of 2621716 bytes finished
    Flashing sparse image at offset 9761024
    ........ wrote 56762368 bytes to 'userdata'
    ** Bad device specification mmc vbmeta_a_a **
    Couldn't find partition mmc vbmeta_a_a
    Starting download of 4096 bytes
    downloading of 4096 bytes finished
    Flashing Raw Image
    ........ wrote 4096 bytes to 'vbmeta_a'
    ** Bad device specification mmc vbmeta_b_a **
    Couldn't find partition mmc vbmeta_b_a
    Flashing Raw Image
    ........ wrote 4096 bytes to 'vbmeta_b'
    ** Bad device specification mmc dtbo_a_a **
    Couldn't find partition mmc dtbo_a_a
    Flashing Raw Image
    ........ wrote 8388608 bytes to 'dtbo_a'
    ** Bad device specification mmc dtbo_b_a **
    Couldn't find partition mmc dtbo_b_a
    Flashing Raw Image
    ........ wrote 8388608 bytes to 'dtbo_b'
    ** Bad device specification mmc persist_a **
    Couldn't find partition mmc persist_a
    Starting download of 33554432 bytes
    downloading of 33554432 bytes finished
    Flashing Raw Image
    ........ wrote 33554432 bytes to 'persist'
    ** Bad device specification mmc misc_a **
    Couldn't find partition mmc misc_a
    Erasing blocks 27648 to 28672 due to alignment
    ........ erased 524288 bytes from 'misc'
    ** Bad device specification mmc metadata_a **
    Couldn't find partition mmc metadata_a
    Starting download of 45132 bytes
    => fastboot 0
    flashall.sh log
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ sudo ./flashall.sh --board am62x-sk
    board: am62x-sk
    8+0 records in
    8+0 records out
    8388608 bytes (8.4 MB, 8.0 MiB) copied, 0.0349141 s, 240 MB/s
    mkfs.fat 4.1 (2017-01-24)
    Fastboot: ./fastboot
    Image location: ./
    Fastboot - device detected: 0000000000000269
    Create GPT partition table
    OKAY [  0.018s]
    Finished. Total time: 0.018s
    Flashing tiboot3.....
       tiboot3bin:     ./tiboot3-am62x-sk.bin
    Sending 'tiboot3' (284 KB)                         OKAY [  0.046s]
    Writing 'tiboot3'                                  OKAY [  0.024s]
    Finished. Total time: 0.114s
       bootloader:  ./bootloader-am62x-sk.img
    Sending 'bootloader' (8192 KB)                     OKAY [  0.389s]
    Writing 'bootloader'                               OKAY [  0.152s]
    Finished. Total time: 0.587s
    Flash android partitions
    Sending sparse 'super' 1/2 (742436 KB)             OKAY [ 31.830s]
    Writing 'super'                                    OKAY [ 15.318s]
    Sending sparse 'super' 2/2 (696015 KB)             OKAY [ 30.829s]
    Writing 'super'                                    OKAY [ 16.378s]
    Finished. Total time: 94.722s
    Flashing Boot Image
    Sending 'boot_a' (40960 KB)                        OKAY [  1.756s]
    Writing 'boot_a'                                   OKAY [  0.701s]
    Finished. Total time: 2.523s
    Sending 'boot_b' (40960 KB)                        OKAY [  1.869s]
    Writing 'boot_b'                                   OKAY [  0.708s]
    Finished. Total time: 2.633s
    Flashing userdata Image
    Sending 'userdata' (2560 KB)                       OKAY [  0.135s]
    Writing 'userdata'                                 OKAY [  1.002s]
    Finished. Total time: 1.196s
    Flashing vbmeta Image
    Sending 'vbmeta_a' (4 KB)                          OKAY [  0.023s]
    Writing 'vbmeta_a'                                 OKAY [  0.020s]
    Finished. Total time: 0.101s
    Sending 'vbmeta_b' (4 KB)                          OKAY [  0.023s]
    Writing 'vbmeta_b'                                 OKAY [  0.019s]
    Finished. Total time: 0.091s
    Flashing DTBO Image
    Sending 'dtbo_a' (8192 KB)                         OKAY [  0.379s]
    Writing 'dtbo_a'                                   OKAY [  0.162s]
    Finished. Total time: 0.588s
    Sending 'dtbo_b' (8192 KB)                         OKAY [  0.389s]
    Writing 'dtbo_b'                                   OKAY [  0.153s]
    Flashing persist partition
    Sending 'persist' (32768 KB)                       OKAY [  1.417s]
    Writing 'persist'                                  OKAY [  0.564s]
    Finished. Total time: 2.030s
    Erasing misc partitions
    Erasing 'misc'                                     OKAY [  0.019s]
    Finished. Total time: 0.058s
    Formatting metadata partition
    mke2fs 1.46.2 (28-Feb-2021)
    Creating filesystem with 4096 4k blocks and 4096 inodes
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (1024 blocks): done
    Writing superblocks and filesystem accounting information: done
    Sending 'metadata' (44 KB)                         OKAY [  0.025s]
    Writing 'metadata'                                 OKAY [  0.026s]
    Finished. Total time: 0.154s
    power off board, set boot mode to eMMC. power up. nothing output on console.
    Reflash AM62B again. still no output. Same as E3 board, can boot to Android with SD card in MMC boot mode.
    Authentication passed
    SoC:   AM62X SR1.0 HS-FS
    Board: AM62B-SKEVM rev A
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    => fastboot.partition-type:metadata ext4; fastboot 0;
    dwc3-generic-peripheral usb@31000000: request 00000000f75ff240 was not queued to ep1in-bulk
    Starting download of 294306 bytes
    downloading of 294306 bytes finished
    Flashing Raw Image
    ........ wrote 294400 bytes to 'tiboot3'
    Flashing Raw Image
    Flashing Raw Image
    Flashing Raw Image
    Flashing Raw Image
    Flashing Raw Image
    Flashing Raw Image
    Flashing Raw Image
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ sudo cp tiboot3-am62x-sk-hsfs.bin /media/tony/BOOT/tiboot3.bin
    tony@tony-HP:~/Downloads/am62x/AM62x_userdebug_09.00.00_emmc$ sudo ./flashall.sh --board am62x-sk --hsfs
    board: am62x-sk
    8+0 records in
    8+0 records out
    8388608 bytes (8.4 MB, 8.0 MiB) copied, 0.0400699 s, 209 MB/s
    Image location: ./
    Fastboot - device detected: 0000000000000115
    OKAY [  0.018s]
       tiboot3bin:     ./tiboot3-am62x-sk-hsfs.bin
    Sending 'tiboot3' (287 KB)                         OKAY [  0.038s]
    Writing 'tiboot3'                                  OKAY [  0.025s]
    Finished. Total time: 0.108s
    Sending 'bootloader' (8192 KB)                     OKAY [  0.425s]
    Writing 'bootloader'                               OKAY [  0.162s]
    Finished. Total time: 0.632s
    Sending sparse 'super' 1/2 (742436 KB)             OKAY [ 38.293s]
    Writing 'super'                                    OKAY [ 15.288s]
    Sending sparse 'super' 2/2 (696015 KB)             OKAY [ 35.818s]
    Writing 'super'                                    OKAY [ 16.408s]
    Finished. Total time: 106.040s
    Flashing Boot Image
    Sending 'boot_a' (40960 KB)                        OKAY [  2.063s]
    Writing 'boot_a'                                   OKAY [  0.713s]
    Finished. Total time: 2.832s
    Sending 'boot_b' (40960 KB)                        OKAY [  2.094s]
    Writing 'boot_b'                                   OKAY [  0.707s]
    Finished. Total time: 2.859s
    Sending 'userdata' (2560 KB)                       OKAY [  0.144s]
    Writing 'userdata'                                 OKAY [  1.034s]
    Finished. Total time: 1.235s
    Writing 'vbmeta_a'                                 OKAY [  0.017s]
    Finished. Total time: 0.086s
    Writing 'vbmeta_b'                                 OKAY [  0.017s]
    Flashing DTBO Image
    Sending 'dtbo_a' (8192 KB)                         OKAY [  0.430s]
    Writing 'dtbo_a'                                   OKAY [  0.154s]
    Finished. Total time: 0.629s
    Sending 'dtbo_b' (8192 KB)                         OKAY [  0.429s]
    Writing 'dtbo_b'                                   OKAY [  0.166s]
    Finished. Total time: 0.640s
    Sending 'persist' (32768 KB)                       OKAY [  1.704s]
    Writing 'persist'                                  OKAY [  0.578s]
    Finished. Total time: 2.329s
    Finished. Total time: 0.056s
    FAILED (remote: 'failed to set partition')
    fastboot: error: Command failed
    formating failed
    Erasing 'metadata'                                 OKAY [  0.065s]
