Hi:
I need a routine to use LPM on the evm board. I am following the instructions in pdk, but the linux kernel is not starting.Please help me to solve this problem.
[pdk userguide link: https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/08_06_01_03/exports/docs/pdk_jacinto_08_06_01_03/doc s/userguide/jacinto/modules/lpm/lpm_mcu_only_mode_jacinto.html]
[version: ti-processor-sdk-rtos-j721e-evm-08_06_01_03.tar.gz]
Serial port information is as follows:
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 15:48:38, Jan 24 2023 I/TC: I/TC: OP-TEE version: 3.19.0-15-gd6c5d0037 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Thu Jan 12 00:27:56 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.162-g2927372e2c (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Feb 3 22:05:06 UTC 2023 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff] [ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff] [ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff] [ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000abffffff] [ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000adffffff] [ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=13e5e494-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 0.000000] Memory: 3271308K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 398708K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008387] Console: colour dummy device 80x25 [ 0.012950] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023621] pid_max: default: 32768 minimum: 301 [ 0.028376] LSM: Security Framework initializing [ 0.033131] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040706] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049530] rcu: Hierarchical SRCU implementation. [ 0.054597] Platform MSI: msi-controller@1820000 domain created [ 0.060831] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070129] EFI services will not be available. [ 0.074851] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088010] Detected PIPT I-cache on CPU1 [ 0.088034] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088045] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.088079] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088125] smp: Brought up 1 node, 2 CPUs [ 0.117470] SMP: Total of 2 processors activated. [ 0.122275] CPU features: detected: 32-bit EL0 Support [ 0.127529] CPU features: detected: CRC32 instructions [ 0.141580] CPU: All CPU(s) started at EL2 [ 0.145775] alternatives: patching kernel code [ 0.150841] devtmpfs: initialized [ 0.159818] KASLR disabled due to lack of seed [ 0.164461] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.174425] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.187326] pinctrl core: initialized pinctrl subsystem [ 0.192972] DMI not present or invalid. [ 0.197212] NET: Registered protocol family 16 [ 0.202415] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.209721] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.217768] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.226072] thermal_sys: Registered thermal governor 'step_wise' [ 0.226074] thermal_sys: Registered thermal governor 'power_allocator' [ 0.232636] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.246273] ASID allocator initialised with 32768 entries [ 0.270722] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.277577] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.284423] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.291269] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.298726] cryptd: max_cpu_qlen set to 1000 [ 0.304796] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.313621] vsys_3v3: supplied by evm_12v0 [ 0.317981] vsys_5v0: supplied by evm_12v0 [ 0.322724] iommu: Default domain type: Translated [ 0.327892] SCSI subsystem initialized [ 0.332055] mc: Linux media interface: v0.10 [ 0.336432] videodev: Linux video capture interface: v2.00 [ 0.342072] pps_core: LinuxPPS API ver. 1 registered [ 0.347143] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.356480] PTP clock support registered [ 0.360500] EDAC MC: Ver: 3.0.0 [ 0.364298] FPGA manager framework [ 0.367812] Advanced Linux Sound Architecture Driver Initialized. [ 0.374404] clocksource: Switched to clocksource arch_sys_counter [ 0.380726] VFS: Disk quotas dquot_6.6.0 [ 0.384757] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.394311] NET: Registered protocol family 2 [ 0.399042] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.407628] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.416384] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.424583] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.432376] TCP: Hash tables configured (established 32768 bind 32768) [ 0.439169] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.446063] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.453459] NET: Registered protocol family 1 [ 0.458173] RPC: Registered named UNIX socket transport module. [ 0.464236] RPC: Registered udp transport module. [ 0.469040] RPC: Registered tcp transport module. [ 0.473844] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.480425] NET: Registered protocol family 44 [ 0.484971] PCI: CLS 0 bytes, default 64 [ 0.489334] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.499694] Initialise system trusted keyrings [ 0.504313] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.512414] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.518707] NFS: Registering the id_resolver key type [ 0.523897] Key type id_resolver registered [ 0.528170] Key type id_legacy registered [ 0.532290] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.539138] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.546777] 9p: Installing v9fs 9p2000 file system support [ 0.571404] Key type asymmetric registered [ 0.575591] Asymmetric key parser 'x509' registered [ 0.580590] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.588149] io scheduler mq-deadline registered [ 0.592775] io scheduler kyber registered [ 0.598488] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.604669] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.613716] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.620156] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.628147] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.634567] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.642505] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.648925] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.656850] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.663174] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.671126] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.677452] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.687176] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.695461] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.703679] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.710714] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.719185] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.732386] brd: module loaded [ 0.738835] loop: module loaded [ 0.742522] megasas: 07.714.04.00-rc1 [ 0.748336] tun: Universal TUN/TAP device driver, 1.6 [ 0.753820] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.760228] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.766299] sky2: driver version 1.30 [ 0.770670] VFIO - User Level meta-driver version: 0.3 [ 0.776459] i2c /dev entries driver [ 0.780963] sdhci: Secure Digital Host Controller Interface driver [ 0.787285] sdhci: Copyright(c) Pierre Ossman [ 0.791950] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.798367] ledtrig-cpu: registered to indicate activity on CPUs [ 0.804695] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.812079] optee: probing for conduit method. [ 0.816639] optee: revision 3.19 (d6c5d003) [ 0.816761] optee: dynamic shared memory is enabled [ 0.826219] optee: initialized driver [ 0.831352] NET: Registered protocol family 17 [ 0.835981] 9pnet: Installing 9P2000 support [ 0.840376] Key type dns_resolver registered [ 0.844825] Loading compiled-in X.509 certificates [ 0.858299] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') [ 0.912291] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.919894] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.925966] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.932319] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.938798] pca953x 3-0020: supply vcc not found, using dummy regulator [ 0.945614] pca953x 3-0020: using no AI [ 0.971205] pca953x 3-0022: supply vcc not found, using dummy regulator [ 0.978008] pca953x 3-0022: using AI [ 0.982278] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low [ 0.988519] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high [ 0.995013] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 1.001321] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 1.007345] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz [ 1.013440] pca953x 6-0020: supply vcc not found, using dummy regulator [ 1.020261] pca953x 6-0020: using no AI [ 1.046975] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz [ 1.053038] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz [ 1.058975] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz [ 1.065078] pca953x 9-0020: supply vcc not found, using dummy regulator [ 1.071892] pca953x 9-0020: using no AI [ 1.098733] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz [ 1.105191] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.115155] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.123945] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.133779] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.144372] ------------[ cut here ]------------ [ 1.149098] wiz bus@100000:wiz@5000000: Unable to create SERDES platform device [ 1.156604] WARNING: CPU: 0 PID: 22 at drivers/phy/ti/phy-j721e-wiz.c:1597 wiz_probe+0xc28/0x1178 [ 1.165668] Modules linked in: [ 1.168786] CPU: 0 PID: 22 Comm: kworker/0:1 Not tainted 5.10.162-g2927372e2c #1 [ 1.176341] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 1.182303] Workqueue: events deferred_probe_work_func [ 1.187550] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--) [ 1.193684] pc : wiz_probe+0xc28/0x1178 [ 1.197596] lr : wiz_probe+0xc28/0x1178 [ 1.201507] sp : ffff8000113b3a80 [ 1.204885] x29: ffff8000113b3a80 x28: ffff00087f81eb00 [ 1.210310] x27: 0000000000000000 x26: 0000000000000002 [ 1.215733] x25: 0000000000000002 x24: ffff0008003aa410 [ 1.221157] x23: ffff0008019dd108 x22: ffff0008019dd0e8 [ 1.226580] x21: 0000000000000002 x20: ffff0008003aa410 [ 1.232004] x19: ffff0008019dd080 x18: 0000000000000010 [ 1.237427] x17: 00000000e992f488 x16: 000000007067bfde [ 1.242851] x15: ffff000800151390 x14: 000000000000010f [ 1.248274] x13: ffff000800151390 x12: 00000000ffffffea [ 1.253698] x11: ffff8000112205b0 x10: ffff800011208570 [ 1.259122] x9 : ffff8000112085c8 x8 : 0000000000017fe8 [ 1.264545] x7 : c0000000ffffefff x6 : 0000000000000001 [ 1.269968] x5 : 0000000000000000 x4 : 0000000000000000 [ 1.275392] x3 : 00000000ffffffff x2 : ffff8000111b0540 [ 1.280816] x1 : 368b9e474decc900 x0 : 0000000000000000 [ 1.286240] Call trace: [ 1.288732] wiz_probe+0xc28/0x1178 [ 1.292289] platform_drv_probe+0x54/0xa8 [ 1.296378] really_probe+0xec/0x3e0 [ 1.300024] driver_probe_device+0x58/0xb8 [ 1.304202] __device_attach_driver+0xb8/0xe0 [ 1.308649] bus_for_each_drv+0x78/0xc8 [ 1.312560] __device_attach+0xf8/0x188 [ 1.316472] device_initial_probe+0x14/0x20 [ 1.320739] bus_probe_device+0x9c/0xa8 [ 1.324650] deferred_probe_work_func+0x88/0xc0 [ 1.329276] process_one_work+0x1a0/0x328 [ 1.333366] worker_thread+0x1f8/0x420 [ 1.337189] kthread+0x140/0x160 [ 1.340481] ret_from_fork+0x10/0x34 [ 1.344127] ---[ end trace 79f28d8ee929bf91 ]--- [ 1.349110] wiz: probe of bus@100000:wiz@5000000 failed with error -12 [ 1.357681] ------------[ cut here ]------------ [ 1.362409] wiz bus@100000:wiz@5010000: Unable to create SERDES platform device [ 1.369899] WARNING: CPU: 0 PID: 22 at drivers/phy/ti/phy-j721e-wiz.c:1597 wiz_probe+0xc28/0x1178 [ 1.378964] Modules linked in: [ 1.382080] CPU: 0 PID: 22 Comm: kworker/0:1 Tainted: G W 5.10.162-g2927372e2c #1 [ 1.391056] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 1.397016] Workqueue: events deferred_probe_work_func [ 1.402263] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--) [ 1.408396] pc : wiz_probe+0xc28/0x1178 [ 1.412308] lr : wiz_probe+0xc28/0x1178 [ 1.416219] sp : ffff8000113b3a80 [ 1.419596] x29: ffff8000113b3a80 x28: ffff00087f820b78 [ 1.425020] x27: 0000000000000000 x26: 0000000000000002 [ 1.430444] x25: 0000000000000002 x24: ffff0008003aa810 [ 1.435868] x23: ffff0008019dd108 x22: ffff0008019dd0e8 [ 1.441291] x21: 0000000000000002 x20: ffff0008003aa810 [ 1.446714] x19: ffff0008019dd080 x18: 0000000000000010 [ 1.452138] x17: 00000000e992f488 x16: 000000007067bfde [ 1.457562] x15: ffff000800151390 x14: 000000000000013a [ 1.462986] x13: ffff000800151390 x12: 00000000ffffffea [ 1.468409] x11: ffff8000112205b0 x10: ffff800011208570 [ 1.473833] x9 : ffff8000112085c8 x8 : 0000000000017fe8 [ 1.479257] x7 : c0000000ffffefff x6 : 0000000000000001 [ 1.484680] x5 : 0000000000000000 x4 : 0000000000000000 [ 1.490104] x3 : 00000000ffffffff x2 : ffff8000111b0540 [ 1.495527] x1 : 368b9e474decc900 x0 : 0000000000000000 [ 1.500951] Call trace: [ 1.503442] wiz_probe+0xc28/0x1178 [ 1.507000] platform_drv_probe+0x54/0xa8 [ 1.511089] really_probe+0xec/0x3e0 [ 1.514734] driver_probe_device+0x58/0xb8 [ 1.518913] __device_attach_driver+0xb8/0xe0 [ 1.523360] bus_for_each_drv+0x78/0xc8 [ 1.527271] __device_attach+0xf8/0x188 [ 1.531183] device_initial_probe+0x14/0x20 [ 1.535449] bus_probe_device+0x9c/0xa8 [ 1.539361] deferred_probe_work_func+0x88/0xc0 [ 1.543986] process_one_work+0x1a0/0x328 [ 1.548075] worker_thread+0x1f8/0x420 [ 1.551899] kthread+0x140/0x160 [ 1.555190] ret_from_fork+0x10/0x34 [ 1.558835] ---[ end trace 79f28d8ee929bf92 ]--- [ 1.563808] wiz: probe of bus@100000:wiz@5010000 failed with error -12 [ 1.572387] ------------[ cut here ]------------ [ 1.577115] wiz bus@100000:wiz@5020000: Unable to create SERDES platform device [ 1.584644] WARNING: CPU: 0 PID: 22 at drivers/phy/ti/phy-j721e-wiz.c:1597 wiz_probe+0xc28/0x1178 [ 1.593708] Modules linked in: [ 1.596824] CPU: 0 PID: 22 Comm: kworker/0:1 Tainted: G W 5.10.162-g2927372e2c #1 [ 1.605800] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 1.611760] Workqueue: events deferred_probe_work_func [ 1.617006] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--) [ 1.623139] pc : wiz_probe+0xc28/0x1178 [ 1.627051] lr : wiz_probe+0xc28/0x1178 [ 1.630961] sp : ffff8000113b3a80 [ 1.634340] x29: ffff8000113b3a80 x28: ffff00087f822898 [ 1.639764] x27: 0000000000000000 x26: 0000000000000002 [ 1.645188] x25: 0000000000000002 x24: ffff0008003aac10 [ 1.650611] x23: ffff0008019dd108 x22: ffff0008019dd0e8 [ 1.656034] x21: 0000000000000002 x20: ffff0008003aac10 [ 1.661458] x19: ffff0008019dd080 x18: 0000000000000010 [ 1.666882] x17: 00000000e992f488 x16: 000000007067bfde [ 1.672306] x15: ffff000800151390 x14: 000000000000025a [ 1.677729] x13: 0000000000000000 x12: 000000000000004d [ 1.683153] x11: 00000000000000d8 x10: 00000000000009f0 [ 1.688576] x9 : ffff8000113b37b0 x8 : ffff000800151890 [ 1.694000] x7 : ffff00087f7d3340 x6 : ffff00087f7d32c0 [ 1.699424] x5 : 00000000410fd080 x4 : 0000000000f0000f [ 1.704847] x3 : ffff80086e784000 x2 : ffff8000111b0540 [ 1.710271] x1 : 368b9e474decc900 x0 : 0000000000000000 [ 1.715695] Call trace: [ 1.718185] wiz_probe+0xc28/0x1178 [ 1.721742] platform_drv_probe+0x54/0xa8 [ 1.725832] really_probe+0xec/0x3e0 [ 1.729477] driver_probe_device+0x58/0xb8 [ 1.733655] __device_attach_driver+0xb8/0xe0 [ 1.738101] bus_for_each_drv+0x78/0xc8 [ 1.742013] __device_attach+0xf8/0x188 [ 1.745925] device_initial_probe+0x14/0x20 [ 1.750191] bus_probe_device+0x9c/0xa8 [ 1.754103] deferred_probe_work_func+0x88/0xc0 [ 1.758727] process_one_work+0x1a0/0x328 [ 1.762817] worker_thread+0x1f8/0x420 [ 1.766640] kthread+0x140/0x160 [ 1.769931] ret_from_fork+0x10/0x34 [ 1.773577] ---[ end trace 79f28d8ee929bf93 ]--- [ 1.778561] wiz: probe of bus@100000:wiz@5020000 failed with error -12 [ 1.788502] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.796189] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.804465] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.812740] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.821549] j721e-pcie 2900000.pcie: Failed to init phy [ 1.827298] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 1.834965] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 1.843241] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 1.851520] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.860181] j721e-pcie 2910000.pcie: Failed to init phy [ 1.865801] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 1.873463] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 1.881741] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 1.890017] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.898811] j721e-pcie 2920000.pcie: Failed to init phy [ 1.904914] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.914794] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.921554] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.930603] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.940741] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.947500] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.955424] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 1.964810] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250 [ 1.973556] printk: console [ttyS2] enabled [ 1.973556] printk: console [ttyS2] enabled [ 1.981993] printk: bootconsole [ns16550a0] disabled [ 1.981993] printk: bootconsole [ns16550a0] disabled [ 1.992436] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250 [ 2.001356] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250 [ 2.011740] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 2.022255] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 2.032413] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 2.042651] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 2.053646] scsi host0: ufshcd [ 2.062006] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.075425] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 2.106502] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.115055] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.123424] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 2.136182] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 2.136276] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.155014] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.155017] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 2.172060] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 2.172387] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 2.189799] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 2.198496] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 2.206704] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 2.308114] mmc0: CQHCI version 5.10 [ 2.310506] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 2.322921] vdd_mmc1: supplied by vsys_3v3 [ 2.327743] pca953x 4-0020: supply vcc not found, using dummy regulator [ 2.334404] pca953x 4-0020: using no AI [ 2.352580] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 2.359326] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.366917] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.373769] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 2.380563] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 2.387390] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 2.397712] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.405211] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 2.413300] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 2.421379] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.429867] j721e-pcie 2900000.pcie: Failed to init phy [ 2.435460] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.442948] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.451029] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.459114] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.467569] j721e-pcie 2910000.pcie: Failed to init phy [ 2.473076] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 2.480562] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 2.488645] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 2.496728] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.505197] j721e-pcie 2920000.pcie: Failed to init phy [ 2.511100] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 2.521695] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 2.535728] spi-nor spi7.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 2.542613] spi-nor: probe of spi7.0 failed with error -2 [ 2.548784] mmc0: Command Queue Engine enabled [ 2.550241] spi-nor spi8.0: mt25qu512a (65536 Kbytes) [ 2.553228] mmc0: new HS200 MMC card at address 0001 [ 2.553516] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 2.559463] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.563371] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 2.580366] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 2.586361] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0) [ 2.606419] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.614918] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.623226] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 2.636081] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.643287] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.649501] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 2.659516] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.667559] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 2.673487] mmc1: CQHCI version 5.10 [ 2.680182] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.687675] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 2.695754] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 2.703832] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.712306] j721e-pcie 2900000.pcie: Failed to init phy [ 2.717885] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.725380] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.733457] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.741543] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.750001] j721e-pcie 2910000.pcie: Failed to init phy [ 2.755501] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 2.762980] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 2.771057] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 2.779135] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.787600] j721e-pcie 2920000.pcie: Failed to init phy [ 2.793796] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.801293] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 2.809372] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 2.817451] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.825912] j721e-pcie 2900000.pcie: Failed to init phy [ 2.831436] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.838919] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.847000] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.855078] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.863531] j721e-pcie 2910000.pcie: Failed to init phy [ 2.869023] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 2.876507] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 2.884585] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 2.892663] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.901121] j721e-pcie 2920000.pcie: Failed to init phy [ 2.907118] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.914620] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 2.922699] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 2.930780] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.939245] j721e-pcie 2900000.pcie: Failed to init phy [ 2.944769] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.952254] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.960334] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.968412] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.976863] j721e-pcie 2910000.pcie: Failed to init phy [ 2.982346] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 2.989836] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 2.997915] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 3.005993] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.014454] j721e-pcie 2920000.pcie: Failed to init phy [ 3.019897] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 3.027199] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 3.035555] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 3.042876] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 3.050181] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 3.057492] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 3.065811] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 3.073499] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 3.080994] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 3.083651] ALSA device list: [ 3.089074] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 3.092033] No soundcards found. [ 3.100101] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.111966] j721e-pcie 2900000.pcie: Failed to init phy [ 3.117558] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 3.125043] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 3.133131] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 3.141214] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.149671] j721e-pcie 2910000.pcie: Failed to init phy [ 3.155166] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 3.162645] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 3.170733] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 3.178812] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.187273] j721e-pcie 2920000.pcie: Failed to init phy [ 3.739133] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 3.747545] Waiting for root device PARTUUID=13e5e494-02... [ 3.747745] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 3.760612] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 3.768704] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 3.776828] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.785311] j721e-pcie 2900000.pcie: Failed to init phy [ 3.790935] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 3.798471] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 3.806609] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 3.814746] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.823214] j721e-pcie 2910000.pcie: Failed to init phy [ 3.828756] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 3.836246] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 3.844334] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 3.852451] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.860924] j721e-pcie 2920000.pcie: Failed to init phy [ 4.025006] mmc1: new ultra high speed DDR50 SDHC card at address aaaa [ 4.031873] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 4.041729] mmcblk1: p1 p2 [ 4.045693] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 4.053194] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 4.061275] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 4.069356] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 4.077829] j721e-pcie 2900000.pcie: Failed to init phy [ 4.083372] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 4.090854] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 4.098930] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 4.107008] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 4.115458] j721e-pcie 2910000.pcie: Failed to init phy [ 4.120955] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 4.128437] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 4.136518] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 4.144596] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 4.153064] j721e-pcie 2920000.pcie: Failed to init phy
