EVMC6474 SRIO interrupt
I modify the example to make srio generate interrupt to CPU, but it seems not to work, please help me, thank you!
Best regard,2553.srio_evm_dio_intr_example.rar
Chester
  • What example project did you modify? From the name, it would appear that it should have generated an interrupt already, unless I am confused about what you have changed.
    The DirectIO Library DIOLIB has examples that setup interrupts. If you have not found this yet, go to the TI Wiki Pages and search for DIOLIB.
    RandyP
    If you need more help, please reply back. If this answers the question, please click  Verify Answer  , below.
  • Thanks for your apply.
     2068.srio_evm_dio_example.rar
    The example project before i modified is showed above.  I tried the project  modified  by myself (srio_evm_dio_intr_example)  many times , but it cannot generate any interrupt, there must be some configurations are mistakes. So help me, take a look at it.
    I have found the DIOLIB, I will try it , thank you for providing another method.
    Chester
  • Chester,
    Did the example project work correctly before you modified it? There needs to be a known starting point. If the example did work correctly before you modified it, then you will want to go back to the original and make your changes more slowly so you can figure out which changes made it fail.
    The same thing will apply with the DIOLIB. Make sure the example you start from will work before moving forward.
    RandyP
