J784S4XEVM: SBL runs "Combined appimage" and prints an error message "Kernel panic"
Part Number: J784S4XEVM
Other Parts Discussed in Thread: TDA4VH
Run the TI official PDK on J784S4XEVM with the firmware "combined_dev. appimage" or "combined_opt. appimage" provided in the path "pdk_j784s4:09:00_45/packages/ti/boot/sbl/tools/combined_appimage/bin/j784s4_evm", but the error message "Kernel panic" will be printed. Provide detailed log information in the form of attachments
SBL Revision: 01.00.10.01 (Nov  9 2023 - 20:17:23)
TIFS  ver: 9.0.6--v09.00.06 (Kool Koala)
SCISERVER Board Configuration header population... PASSED
Sciclient_setBoardConfigHeader... PASSED
Initlialzing PLLs ...done.
InitlialzingClocks ...done.
Initlialzing DDR ...done.
Initializing GTC ...Copying EEPROM content to DDR ...
EEPROM Data Copy Done.
Begin parsing user application
Calling Sciclient_procBootRequestProcessor, ProcId 0x20...
Calling Sciclient_procBootRequestProcessor, ProcId 0x21...
Calling Sciclient_procBootRequestProcessor, ProcId 0x22...
Calling Sciclient_procBootRequestProcessor, ProcId 0x23...
Calling Sciclient_procBootRequestProcessor, ProcId 0x24...
Calling Sciclient_procBootRequestProcessor, ProcId 0x25...
Calling Sciclient_procBootRequestProcessor, ProcId 0x26...
Calling Sciclient_procBootRequestProcessor, ProcId 0x27...
Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
Calling Sciclient_procBootRequestProcessor, ProcId 0x2...
Calling Sciclient_procBootRequestProcessor, ProcId 0x6...
Calling Sciclient_procBootRequestProcessor, ProcId 0x7...
Calling Sciclient_procBootRequestProcessor, ProcId 0x8...
Calling Sciclient_procBootRequestProcessor, ProcId 0x9...
Calling Sciclient_procBootRequestProcessor, ProcId 0xa...
Calling Sciclient_procBootRequestProcessor, ProcId 0xb...
Calling Sciclient_procBootRequestProcessor, ProcId 0x30...
Calling Sciclient_procBootRequestProcessor, ProcId 0x31...
Calling Sciclient_procBootRequestProcessor, ProcId 0x32...
Calling Sciclient_procBootRequestProcessor, ProcId 0x33...
Calling Sciclient_procBootRequestProcessor, ProcId 0x80...
Searching for X509 certificate ...not found
Switching core id 8, proc_id 0x1 to split mode...
Calling Sciclient_procBootGetProcessorState, ProcId 0x1...
Sciclient_procBootSetProcessorCfg, ProcId 0x1, enabling split mode...
Enabling MCU TCMs after reset for core 8
Disabling HW-based memory init of MCU TCMs for core 8
Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
Copying 0x40 bytes to 0x41010000
Copying 0x490 bytes to 0x41010040
Copying 0x490 bytes to 0x410104d0
Copying 0x118 bytes to 0x41010960
Copying 0x58 bytes to 0x41010a78
Copying 0x8c bytes to 0xa0100000
Copying 0x4f84 bytes to 0xa05f0700
Copying 0x1404 bytes to 0xa05f5700
Copying 0x1ea30 bytes to 0xa0646f60
Copying 0xc950 bytes to 0xa0665990
Copying 0x558 bytes to 0xa0676e80
Setting entry point for core 8 @0x41010000
Copying 0x6c878 bytes to 0x9e800000
Only load (not execute) image @0x9e800000
Copying 0x12e7a00 bytes to 0x80080000
Only load (not execute) image @0x80080000
Copying 0x11f94 bytes to 0x82000000
Only load (not execute) image @0x82000000
Sciclient_pmSetModuleState On, DevId 0xc6...
Copying 0xabc0 bytes to 0x70000000
Setting entry point for core 0 @0x70000000
Sciclient_procBootSetProcessorCfg, ProcId 0x20, EntryPoint 0x70000000...
Sciclient_pmSetModuleClkFreq, DevId 0xca @ 2000000000Hz...
Sciclient_pmSetModuleState Off, DevId 0xca...
Sciclient_pmSetModuleState On, DevId 0xca...
Sciclient_procBootReleaseProcessor, ProcId 0x20...
Sciclient_procBootReleaseProcessor, ProcId 0x21...
Sciclient_procBootReleaseProcessor, ProcId 0x22...
Sciclient_procBootReleaseProcessor, ProcId 0x23...
Sciclient_procBootReleaseProcessor, ProcId 0x24...
Sciclient_procBootReleaseProcessor, ProcId 0x25...
Sciclient_procBootReleaseProcessor, ProcId 0x26...
Sciclient_procBootReleaseProcessor, ProcId 0x27...
Sciclient_procBootReleaseProcessor, ProcId 0x1...
Sciclient_procBootReleaseProcessor, ProcId 0x2...
Sciclient_procBootReleaseProcessor, ProcId 0x6...
Sciclient_procBootReleaseProcessor, ProcId 0x7...
Sciclient_procBootReleaseProcessor, ProcId 0x8...
Sciclient_procBootReleaseProcessor, ProcId 0x9...
Sciclient_procBootReleaseProcessor, ProcId 0xa...
Sciclient_procBootReleaseProcessor, ProcId 0xb...
Sciclient_procBootReleaseProcessor, ProcId 0x30...
Sciclient_procBootReleaseProcessor, ProcId 0x31...
Sciclient_procBootReleaseProcessor, ProcId 0x32...
Sciclient_procBootReleaseProcessor, ProcId 0x33...
Sciclient_procBootReleaseProcessor, ProcId 0x80...
Sciclient_procBootSetProcessorCfg, ProcId 0x1, EntryPoint 0x41010000...
Sciclient_pmSetModuleClkFreq, DevId 0x15a @ 1000000000Hz...
Copying first 128 bytes from app to MCU ATCM @ 0x0 for core 8
Skipping Sciclient_procBootSetProcessorCfg for ProcId 0x2, EntryPoint 0xfffffffe...
Copying 0x520 bytes to 0x41010040
Copying 0x490 bytes to 0x41010560
Copying 0x118 bytes to 0x410109f0
Copying 0x58 bytes to 0x41010b08
Copying 0x4fb4 bytes to 0xa05f0700
Copying 0x21360 bytes to 0xa0647180
Copying 0xc990 bytes to 0xa06684e0
Copying 0x5e8 bytes to 0xa0679c80
Copying 0x44160 bytes to 0x80080000
3124.LinuxKernel_Opt_Log.txt
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE:  BL31: Built : 00:42:57, Jan 13 2023
ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2023.04-gd6bccb1b9e (Jun 09 2023 - 06:25:21 +0000)
Trying to boot from MMC2
U-Boot 2023.04-g010afc1fe7 (May 22 2023 - 16:37:17 +0000)
SoC:   J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
DRAM:  32 GiB
Core:  45 devices, 25 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4fb0000: 1
Loading Environment from MMC... MMC Device 0 not found
*** Warning - No MMC card found, using default environment
In:    serial@2880000
Out:   serial@2880000
Err:   serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
19823104 bytes read in 530 ms (35.7 MiB/s)
103270 bytes read in 8 ms (12.3 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008fee3000, end 000000008fffffff ... OK
Working FDT set to 8fee3000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.1.26-g30bcc25e7c (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Mon May 22 14:16:59 UTC 2023
[    0.000000] Machine model: Texas Instruments J784S4 EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000f8fe00000, size 1792 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffefff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000ffffefff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x0000000fffffefff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
[    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 19 pages/cpu s38248 r8192 d31384 u77824
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8257534
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=eb2c7cc6-02 rw rootfstype=ext4 rootwait
[    0.000000] Unknown kernel command line parameters "mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 30772156K/33554424K available (12032K kernel code, 1246K rwdata, 3868K rodata, 2112K init, 484K bss, 947260K reserved, 1835008K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.010556] Console: colour dummy device 80x25
[    0.016272] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.029613] pid_max: default: 32768 minimum: 301
[    0.035545] LSM: Security Framework initializing
[    0.041560] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.051317] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.062771] cblist_init_generic: Setting adjustable number of callback queues.
[    0.072039] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.079895] cblist_init_generic: Setting shift to 3 and lim to 1.
[    0.087794] rcu: Hierarchical SRCU implementation.
[    0.093918] rcu:     Max phase no-delay instances is 1000.
[    0.100798] Platform MSI: msi-controller@1820000 domain created
[    0.108579] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.120861] EFI services will not be available.
[    0.126960] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
[    0.150635] Detected PIPT I-cache on CPU1
[    0.150717] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.150735] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
[    0.150778] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.168725] Detected PIPT I-cache on CPU2
[    0.168790] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[    0.168806] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
[    0.168839] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[    0.186741] Detected PIPT I-cache on CPU3
[    0.186802] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[    0.186818] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
[    0.186849] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[    0.204760] Detected PIPT I-cache on CPU4
[    0.204864] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[    0.204881] GICv3: CPU4: using allocated LPI pending table @0x00000008800a0000
[    0.204923] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[    0.222878] Detected PIPT I-cache on CPU5
[    0.222950] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[    0.222966] GICv3: CPU5: using allocated LPI pending table @0x00000008800b0000
[    0.222998] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[    0.240899] Detected PIPT I-cache on CPU6
[    0.240972] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[    0.240990] GICv3: CPU6: using allocated LPI pending table @0x00000008800c0000
[    0.241019] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[    0.258918] Detected PIPT I-cache on CPU7
[    0.258994] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[    0.259011] GICv3: CPU7: using allocated LPI pending table @0x00000008800d0000
[    0.259044] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[    0.259107] smp: Brought up 1 node, 8 CPUs
[    0.485345] SMP: Total of 8 processors activated.
[    0.491352] CPU features: detected: 32-bit EL0 Support
[    0.497920] CPU features: detected: CRC32 instructions
[    0.504543] CPU: All CPU(s) started at EL2
[    0.509771] alternatives: applying system-wide alternatives
[    0.518226] devtmpfs: initialized
[    0.534720] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.547196] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.582919] pinctrl core: initialized pinctrl subsystem
[    0.590061] DMI not present or invalid.
[    0.595427] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.604679] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.614712] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.625614] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.635926] audit: initializing netlink subsys (disabled)
[    0.643021] audit: type=2000 audit(0.420:1): state=initialized audit_enabled=0 res=1
[    0.643300] thermal_sys: Registered thermal governor 'step_wise'
[    0.652925] thermal_sys: Registered thermal governor 'power_allocator'
[    0.660731] cpuidle: using governor menu
[    0.674182] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.682990] ASID allocator initialised with 65536 entries
[    0.701055] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.714033] platform a000000.dp-bridge: Fixed dependency cycle(s) with /dp0-connector
[    0.724727] KASLR disabled due to lack of seed
[    0.734297] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.742994] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.751000] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.759669] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.767673] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.776343] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.784346] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.793015] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.802268] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[    0.814387] iommu: Default domain type: Translated
[    0.820632] iommu: DMA domain TLB invalidation policy: strict mode
[    0.828809] SCSI subsystem initialized
[    0.833832] usbcore: registered new interface driver usbfs
[    0.840864] usbcore: registered new interface driver hub
[    0.847665] usbcore: registered new device driver usb
[    0.854480] pps_core: LinuxPPS API ver. 1 registered
[    0.860825] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.872501] PTP clock support registered
[    0.877602] EDAC MC: Ver: 3.0.0
[    0.882254] FPGA manager framework
[    0.886645] Advanced Linux Sound Architecture Driver Initialized.
[    0.895053] clocksource: Switched to clocksource arch_sys_counter
[    0.903014] VFS: Disk quotas dquot_6.6.0
[    0.908053] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.920559] NET: Registered PF_INET protocol family
[    0.927300] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.943291] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.954597] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.964533] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.975907] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.986513] TCP: Hash tables configured (established 262144 bind 65536)
[    0.995168] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.004361] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.014248] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.021931] RPC: Registered named UNIX socket transport module.
[    1.029505] RPC: Registered udp transport module.
[    1.035512] RPC: Registered tcp transport module.
[    1.041515] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.049747] NET: Registered PF_XDP protocol family
[    1.055874] PCI: CLS 0 bytes, default 64
[    1.061797] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.073452] Initialise system trusted keyrings
[    1.079306] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    1.090760] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.098648] NFS: Registering the id_resolver key type
[    1.105145] Key type id_resolver registered
[    1.110486] Key type id_legacy registered
[    1.115637] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.124200] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.133766] 9p: Installing v9fs 9p2000 file system support
[    1.164793] Key type asymmetric registered
[    1.170036] Asymmetric key parser 'x509' registered
[    1.176313] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.185764] io scheduler mq-deadline registered
[    1.191547] io scheduler kyber registered
[    1.199534] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    1.206983] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[    1.214468] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[    1.222016] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[    1.229296] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[    1.237081] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    1.249655] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.264061] loop: module loaded
[    1.269013] megasas: 07.719.03.00-rc1
[    1.276332] tun: Universal TUN/TAP device driver, 1.6
[    1.283284] thunder_xcv, ver 1.0
[    1.287425] thunder_bgx, ver 1.0
[    1.291557] nicpf, ver 1.0
[    1.295327] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.304553] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.311370] hclge is initializing
[    1.315612] e1000: Intel(R) PRO/1000 Network Driver
[    1.321840] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.329198] e1000e: Intel(R) PRO/1000 Network Driver
[    1.335536] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.343111] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.350004] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.357131] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.365134] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.372793] sky2: driver version 1.30
[    1.377986] VFIO - User Level meta-driver version: 0.3
[    1.385086] usbcore: registered new interface driver usb-storage
[    1.393306] i2c_dev: i2c /dev entries driver
[    1.399793] sdhci: Secure Digital Host Controller Interface driver
[    1.407696] sdhci: Copyright(c) Pierre Ossman
[    1.413620] Synopsys Designware Multimedia Card Interface Driver
[    1.421645] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.429647] ledtrig-cpu: registered to indicate activity on CPUs
[    1.437478] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.445911] usbcore: registered new interface driver usbhid
[    1.453028] usbhid: USB HID core driver
[    1.458753] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    1.464457] optee: revision 3.20 (8e74d476)
[    1.485003] optee: dynamic shared memory is enabled
[    1.496868] optee: initialized driver
[    1.503023] NET: Registered PF_PACKET protocol family
[    1.509576] 9pnet: Installing 9P2000 support
[    1.515079] Key type dns_resolver registered
[    1.520798] registered taskstats version 1
[    1.526054] Loading compiled-in X.509 certificates
[    1.538617] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
[    1.579646] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz
[    1.587721] pca953x 0-0020: supply vcc not found, using dummy regulator
[    1.596267] pca953x 0-0020: using no AI
[    1.615839] pca953x 0-0022: supply vcc not found, using dummy regulator
[    1.624352] pca953x 0-0022: using AI
[    1.629732] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.637416] pca953x 2-0020: supply vcc not found, using dummy regulator
[    1.645938] pca953x 2-0020: using no AI
[    1.671636] omap_i2c 2040000.i2c: bus 2 rev0.12 at 400 kHz
[    1.679402] pca953x 3-0020: supply vcc not found, using dummy regulator
[    1.687923] pca953x 3-0020: using no AI
[    1.715433] omap_i2c 2050000.i2c: bus 3 rev0.12 at 400 kHz
[    1.722601] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[    1.733278] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[    1.744861] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[    1.755696] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[    1.766732] ti-udma 311a0000.dma-controller: Number of rings: 48
[    1.775213] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[    1.786774] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[    1.799133] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.807582] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.818704] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[    1.831401] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.839853] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.849838] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 216, base_baud = 6000000) is a 8250
[    1.861758] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 217, base_baud = 3000000) is a 8250
[    1.872836] printk: console [ttyS2] enabled
[    1.883389] printk: bootconsole [ns16550a0] disabled
[    1.935074] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.946037] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.956383] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.972455] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.981469] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.989278] pps pps0: new PPS source ptp0
[    1.994490] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    2.047062] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.057751] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    2.067873] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.083822] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    2.091647] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    2.100543] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[    2.108310] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    2.121292] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[    2.132594] mmc0: CQHCI version 5.10
[    2.137774] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[    2.150315] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[    2.165816] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    2.172465] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
[    2.178313] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.181269] Creating 7 MTD partitions on "47040000.spi.0":
[    2.181274] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    2.205213] 0x000000080000-0x000000280000 : "ospi.tispl"
[    2.212566] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    2.220072] 0x000000680000-0x0000006c0000 : "ospi.env"
[    2.227244] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    2.235131] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    2.242563] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    2.264477] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[    2.271340] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[    2.280152] Creating 7 MTD partitions on "47050000.spi.0":
[    2.287005] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[    2.287202] mmc0: Command Queue Engine enabled
[    2.294780] 0x000000080000-0x000000280000 : "qspi.tispl"
[    2.299407] mmc0: new HS400 MMC card at address 0001
[    2.306747] 0x000000280000-0x000000680000 : "qspi.u-boot"
[    2.312699] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.319836] 0x000000680000-0x0000006c0000 : "qspi.env"
[    2.326117] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    2.331877] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
[    2.338173] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    2.345247] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[    2.351451] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[    2.358138] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[    2.411081] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.422059] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.432409] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.448502] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.457517] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    2.465286] pps pps0: new PPS source ptp1
[    2.470517] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    2.482846] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    2.531096] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.541980] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    2.552114] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.568090] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    2.575916] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    2.584813] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[    2.592585] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    2.604880] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[    2.614505] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present!
[    2.615127] mmc1: CQHCI version 5.10
[    2.623594] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[    2.637120] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[    2.646763] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[    2.655915] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[    2.665061] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[    2.669063] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.682315] ALSA device list:
[    2.687241]   No soundcards found.
[    2.691773] Waiting for root device PARTUUID=eb2c7cc6-02...
[    2.741381] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    2.750240] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[    2.761968]  mmcblk1: p1 p2
[    2.782715] mmc1: ADMA error: 0x02000002
[    2.787630] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    2.795657] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
[    2.803684] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    2.811712] mmc1: sdhci: Argument:  0x00042930 | Trn mode: 0x0000003b
[    2.819740] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    2.827767] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    2.835793] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    2.843820] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    2.851846] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    2.859872] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    2.867898] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    2.875924] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    2.883950] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x00edc87f
[    2.891976] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[    2.900001] mmc1: sdhci: Host ctl2: 0x00000c0b
[    2.905535] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000882374218
[    2.914429] mmc1: sdhci: ============================================
[    2.922454] mmc1: sdhci: 882374200: DMA 0x0000000881f3a000, LEN 0x6000, Attr=0x21
[    2.931780] mmc1: sdhci: 88237420c: DMA 0x0000000881180000, LEN 0x0000, Attr=0x21
[    2.941106] mmc1: sdhci: 882374218: DMA 0x0000000881190000, LEN 0xa000, Attr=0x21
[    2.950434] mmc1: sdhci: 882374224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    2.964919] mmc1: ADMA error: 0x02000002
[    2.969806] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    2.977832] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
[    2.985859] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    2.993885] mmc1: sdhci: Argument:  0x00042930 | Trn mode: 0x0000003b
[    3.001911] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    3.009937] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    3.017964] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    3.025990] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    3.034016] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    3.042043] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    3.050068] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    3.058095] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    3.066121] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x00edc87f
[    3.074148] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[    3.082173] mmc1: sdhci: Host ctl2: 0x00000c0b
[    3.087708] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000882374218
[    3.096600] mmc1: sdhci: ============================================
[    3.104625] mmc1: sdhci: 882374200: DMA 0x0000000881f3a000, LEN 0x6000, Attr=0x21
[    3.113951] mmc1: sdhci: 88237420c: DMA 0x0000000881180000, LEN 0x0000, Attr=0x21
[    3.123278] mmc1: sdhci: 882374218: DMA 0x0000000881190000, LEN 0xa000, Attr=0x21
[    3.132603] mmc1: sdhci: 882374224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    3.317124] EXT4-fs (mmcblk1p2): warning: mounting fs with errors, running e2fsck is recommended
[    3.348410] EXT4-fs (mmcblk1p2): recovery complete
[    3.354409] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[    3.365078] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    3.377373] devtmpfs: mounted
[    3.382112] Freeing unused kernel memory: 2112K
[    3.387893] Run /sbin/init as init process
[    3.401589] mmc1: ADMA error: 0x02000002
[    3.406482] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    3.414508] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
[    3.422534] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    3.430561] mmc1: sdhci: Argument:  0x03440908 | Trn mode: 0x0000003b
[    3.438587] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    3.446614] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    3.454641] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    3.462668] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    3.470693] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    3.478720] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    3.486747] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    3.494774] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    3.502800] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    3.510827] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    3.518853] mmc1: sdhci: Host ctl2: 0x00000c0b
[    3.524388] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    3.533281] mmc1: sdhci: ============================================
[    3.541307] mmc1: sdhci: 882374200: DMA 0x0000000881a28000, LEN 0x0000, Attr=0x21
[    3.550633] mmc1: sdhci: 88237420c: DMA 0x0000000881a38000, LEN 0x0000, Attr=0x21
[    3.559959] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    3.575605] mmc1: ADMA error: 0x02000002
[    3.580491] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    3.588517] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
[    3.596544] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    3.604570] mmc1: sdhci: Argument:  0x03440908 | Trn mode: 0x0000003b
[    3.612597] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    3.620622] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    3.628647] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    3.636674] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    3.644699] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    3.652726] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    3.660753] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    3.668780] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    3.676806] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    3.684832] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    3.692858] mmc1: sdhci: Host ctl2: 0x00000c0b
[    3.698393] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    3.707285] mmc1: sdhci: ============================================
[    3.715311] mmc1: sdhci: 882374200: DMA 0x0000000881a28000, LEN 0x0000, Attr=0x21
[    3.724637] mmc1: sdhci: 88237420c: DMA 0x0000000881a38000, LEN 0x0000, Attr=0x21
[    3.733963] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    3.916261] mmc1: ADMA error: 0x02000002
[    3.921148] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    3.929175] mmc1: sdhci: Sys addr:  0x00000080 | Version:  0x00001004
[    3.937201] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    3.945228] mmc1: sdhci: Argument:  0x03440b00 | Trn mode: 0x0000003b
[    3.953254] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    3.961280] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    3.969306] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    3.977333] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    3.985359] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    3.993385] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    4.001411] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    4.009437] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    4.017464] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    4.025490] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    4.033516] mmc1: sdhci: Host ctl2: 0x00000c0b
[    4.039051] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    4.047942] mmc1: sdhci: ============================================
[    4.055967] mmc1: sdhci: 882374200: DMA 0x0000000881a48000, LEN 0x0000, Attr=0x21
[    4.065294] mmc1: sdhci: 88237420c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    4.079966] mmc1: ADMA error: 0x02000002
[    4.084851] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    4.092877] mmc1: sdhci: Sys addr:  0x00000080 | Version:  0x00001004
[    4.100903] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    4.108930] mmc1: sdhci: Argument:  0x03440b88 | Trn mode: 0x0000003b
[    4.116956] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    4.124983] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    4.133009] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    4.141036] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    4.149062] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    4.157088] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    4.165115] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    4.173141] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    4.181167] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    4.189194] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    4.197220] mmc1: sdhci: Host ctl2: 0x00000c0b
[    4.202754] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    4.211645] mmc1: sdhci: ============================================
[    4.219670] mmc1: sdhci: 882374200: DMA 0x0000000881a58000, LEN 0x0000, Attr=0x21
[    4.228998] mmc1: sdhci: 88237420c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    4.242888] mmc1: ADMA error: 0x02000002
[    4.247773] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    4.255799] mmc1: sdhci: Sys addr:  0x00000080 | Version:  0x00001004
[    4.263826] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    4.271852] mmc1: sdhci: Argument:  0x03440b00 | Trn mode: 0x0000003b
[    4.279879] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    4.287904] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    4.295931] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    4.303957] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    4.311983] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    4.320009] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    4.328035] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    4.336061] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    4.344088] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    4.352114] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    4.360140] mmc1: sdhci: Host ctl2: 0x00000c0b
[    4.365676] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    4.374567] mmc1: sdhci: ============================================
[    4.382592] mmc1: sdhci: 882374200: DMA 0x0000000881a48000, LEN 0x0000, Attr=0x21
[    4.391918] mmc1: sdhci: 88237420c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    4.533393] mmc1: ADMA error: 0x02000002
[    4.538280] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    4.546305] mmc1: sdhci: Sys addr:  0x00000080 | Version:  0x00001004
[    4.554331] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    4.562358] mmc1: sdhci: Argument:  0x03440b88 | Trn mode: 0x0000003b
[    4.570385] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    4.578411] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    4.586438] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    4.594463] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    4.602489] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    4.610516] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    4.618543] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    4.626570] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    4.634597] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    4.642622] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    4.650649] mmc1: sdhci: Host ctl2: 0x00000c0b
[    4.656184] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    4.665077] mmc1: sdhci: ============================================
[    4.673102] mmc1: sdhci: 882374200: DMA 0x0000000881a58000, LEN 0x0000, Attr=0x21
[    4.682428] mmc1: sdhci: 88237420c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    4.826540] mmc1: ADMA error: 0x02000002
[    4.831427] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    4.839453] mmc1: sdhci: Sys addr:  0x000000c8 | Version:  0x00001004
[    4.847480] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    4.855506] mmc1: sdhci: Argument:  0x03440c40 | Trn mode: 0x0000003b
[    4.863532] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    4.871559] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    4.879586] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    4.887612] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    4.895638] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    4.903665] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    4.911691] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    4.919718] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    4.927744] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    4.935770] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    4.943796] mmc1: sdhci: Host ctl2: 0x00000c0b
[    4.949330] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    4.958223] mmc1: sdhci: ============================================
[    4.966248] mmc1: sdhci: 882374200: DMA 0x0000000881a6e000, LEN 0x0000, Attr=0x21
[    4.975574] mmc1: sdhci: 88237420c: DMA 0x0000000881a7e000, LEN 0x9000, Attr=0x21
[    4.984900] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    5.000335] mmc1: ADMA error: 0x02000002
[    5.005224] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    5.013250] mmc1: sdhci: Sys addr:  0x000000c8 | Version:  0x00001004
[    5.021276] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    5.029303] mmc1: sdhci: Argument:  0x03440c40 | Trn mode: 0x0000003b
[    5.037329] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    5.045356] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    5.053382] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    5.061409] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    5.069435] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    5.077462] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    5.085488] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    5.093514] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    5.101540] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    5.109566] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    5.117592] mmc1: sdhci: Host ctl2: 0x00000c0b
[    5.123126] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    5.132018] mmc1: sdhci: ============================================
[    5.140043] mmc1: sdhci: 882374200: DMA 0x0000000881a6e000, LEN 0x0000, Attr=0x21
[    5.149370] mmc1: sdhci: 88237420c: DMA 0x0000000881a7e000, LEN 0x9000, Attr=0x21
[    5.158696] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    5.324171] mmc1: ADMA error: 0x02000002
[    5.329061] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    5.337087] mmc1: sdhci: Sys addr:  0x00000088 | Version:  0x00001004
[    5.345114] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    5.353140] mmc1: sdhci: Argument:  0x0348c8d8 | Trn mode: 0x0000003b
[    5.361166] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    5.369192] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    5.377219] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    5.385245] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    5.393271] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    5.401297] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    5.409323] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    5.417349] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    5.425375] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    5.433401] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    5.441427] mmc1: sdhci: Host ctl2: 0x00000c0b
[    5.446962] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    5.455855] mmc1: sdhci: ============================================
[    5.463881] mmc1: sdhci: 882374200: DMA 0x0000000f8be4c000, LEN 0x0000, Attr=0x21
[    5.473207] mmc1: sdhci: 88237420c: DMA 0x0000000f8be5c000, LEN 0x1000, Attr=0x21
[    5.482533] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    5.495799] mmc1: ADMA error: 0x02000002
[    5.500685] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    5.508712] mmc1: sdhci: Sys addr:  0x00000088 | Version:  0x00001004
[    5.516738] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    5.524764] mmc1: sdhci: Argument:  0x0348c8d8 | Trn mode: 0x0000003b
[    5.532791] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    5.540817] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    5.548844] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    5.556870] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    5.564896] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    5.572922] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    5.580949] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    5.588975] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    5.597002] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    5.605028] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    5.613054] mmc1: sdhci: Host ctl2: 0x00000c0b
[    5.618588] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    5.627479] mmc1: sdhci: ============================================
[    5.635504] mmc1: sdhci: 882374200: DMA 0x0000000f8be4c000, LEN 0x0000, Attr=0x21
[    5.644830] mmc1: sdhci: 88237420c: DMA 0x0000000f8be5c000, LEN 0x1000, Attr=0x21
[    5.654156] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    5.801459] mmc1: ADMA error: 0x02000002
[    5.806350] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    5.814377] mmc1: sdhci: Sys addr:  0x000000b0 | Version:  0x00001004
[    5.822403] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    5.830430] mmc1: sdhci: Argument:  0x034960e8 | Trn mode: 0x0000003b
[    5.838456] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    5.846483] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    5.854509] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    5.862535] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    5.870561] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    5.878588] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    5.886614] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    5.894641] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    5.902668] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    5.910694] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    5.918720] mmc1: sdhci: Host ctl2: 0x00000c0b
[    5.924254] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    5.933146] mmc1: sdhci: ============================================
[    5.941172] mmc1: sdhci: 882374200: DMA 0x0000000f8be0f000, LEN 0x0000, Attr=0x21
[    5.950499] mmc1: sdhci: 88237420c: DMA 0x0000000f8be1f000, LEN 0x6000, Attr=0x21
[    5.959826] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    5.973363] mmc1: ADMA error: 0x02000002
[    5.978249] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    5.986275] mmc1: sdhci: Sys addr:  0x000000b0 | Version:  0x00001004
[    5.994302] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    6.002328] mmc1: sdhci: Argument:  0x034960e8 | Trn mode: 0x0000003b
[    6.010354] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    6.018381] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    6.026407] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    6.034434] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    6.042459] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    6.050486] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    6.058512] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    6.066538] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    6.074564] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    6.082590] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    6.090616] mmc1: sdhci: Host ctl2: 0x00000c0b
[    6.096150] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    6.105042] mmc1: sdhci: ============================================
[    6.113067] mmc1: sdhci: 882374200: DMA 0x0000000f8be0f000, LEN 0x0000, Attr=0x21
[    6.122393] mmc1: sdhci: 88237420c: DMA 0x0000000f8be1f000, LEN 0x6000, Attr=0x21
[    6.131720] mmc1: sdhci: 882374218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    6.291671] mmc1: ADMA error: 0x02000002
[    6.296560] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    6.304586] mmc1: sdhci: Sys addr:  0x000000e0 | Version:  0x00001004
[    6.312613] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    6.320640] mmc1: sdhci: Argument:  0x0348bcd0 | Trn mode: 0x0000003b
[    6.328666] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    6.336692] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    6.344718] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    6.352745] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    6.360771] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    6.368797] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    6.376823] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    6.384850] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    6.392876] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    6.400902] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    6.408928] mmc1: sdhci: Host ctl2: 0x00000c0b
[    6.414462] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    6.423355] mmc1: sdhci: ============================================
[    6.431379] mmc1: sdhci: 882374200: DMA 0x0000000f8be2c000, LEN 0x0000, Attr=0x21
[    6.440706] mmc1: sdhci: 88237420c: DMA 0x0000000f8be3c000, LEN 0x4000, Attr=0x21
[    6.450032] mmc1: sdhci: 882374218: DMA 0x0000000f68c00000, LEN 0x8000, Attr=0x21
[    6.459358] mmc1: sdhci: 882374224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
[    6.473336] mmc1: ADMA error: 0x02000002
[    6.478223] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    6.486248] mmc1: sdhci: Sys addr:  0x000000e0 | Version:  0x00001004
[    6.494275] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[    6.502302] mmc1: sdhci: Argument:  0x0348bcd0 | Trn mode: 0x0000003b
[    6.510328] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[    6.518354] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[    6.526380] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000007
[    6.534407] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    6.542433] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
[    6.550460] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    6.558486] mmc1: sdhci: Caps:      0x3de8c801 | Caps_1:   0x18002407
[    6.566512] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[    6.574538] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780517d
[    6.582565] mmc1: sdhci: Resp[2]:   0x534c3332 | Resp[3]:  0x00000900
[    6.590590] mmc1: sdhci: Host ctl2: 0x00000c0b
[    6.596126] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x000000088237420c
[    6.605017] mmc1: sdhci: ============================================
[    6.613043] mmc1: sdhci: 882374200: DMA 0x0000000f8be2c000, LEN 0x0000, Attr=0x21
[    6.622369] mmc1: sdhci: 88237420c: DMA 0x0000000f8be3c000, LEN 0x4000, Attr=0x21
[    6.631696] mmc1: sdhci: 882374218: DMA 0x0000000f68c00000, LEN 0x8000, Attr=0x21
[    6.641022] mmc1: sdhci: 882374224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
Inconsistency detected by ld.so: rtld.c: 1808: dl_main: Assertio[    6.813398] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
n `rtld_ehdr->e_ehsize == sizeof *rtld_ehdr' failed!
[    6.829858] CPU: 3 PID: 1 Comm: init Not tainted 6.1.26-g30bcc25e7c #1
[    6.843837] Hardware name: Texas Instruments J784S4 EVM (DT)
[    6.850887] Call trace:
[    6.853930]  dump_backtrace.part.0+0xdc/0xf0
[    6.859269]  show_stack+0x18/0x30
[    6.863400]  dump_stack_lvl+0x68/0x84
[    6.867967]  dump_stack+0x18/0x34
[    6.872095]  panic+0x184/0x344
[    6.875900]  do_exit+0x8f4/0x8fc
[    6.879920]  do_group_exit+0x34/0x90
[    6.884372]  __arm64_sys_exit_group+0x18/0x20
[    6.889801]  invoke_syscall+0x48/0x114
[    6.894475]  el0_svc_common.constprop.0+0x44/0xfc
[    6.900337]  do_el0_svc+0x30/0xd0
[    6.904466]  el0_svc+0x2c/0x84
[    6.908269]  el0t_64_sync_handler+0xbc/0x140
[    6.913590]  el0t_64_sync+0x18c/0x190
[    6.918153] SMP: stopping secondary CPUs
[    6.923046] Kernel Offset: disabled
[    6.927388] CPU features: 0x20000,20028084,0000420b
[    6.933467] Memory Limit: none
[    6.937272] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
    I'll need to try this on my end. Will get back to you on this by tomorrow.
    Parth
  • Dear Parth.
    Let me share one way to try with boot app to customer as temporary solution to let them do test with SBL+UBOOT solution on SDK9.1/TDA4VH.
    Dear customer.
    please try below steps to build SD cards for SBL+UBOOT solution with boot app.
    SBL->boot app-> ATF/OPTEE + Kernel(or A72 SPL)
                    |-> R core/DSP core.
    0. prepare prebuilt SD.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01-prebuilt$ sudo ./mk-linux-card.sh /dev/sdc
    insert SD card again.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01-prebuilt$ ./install_to_sd_card.sh
    1.
    1.1 build SBL
    apply 0008-j784s4-set-GTC.patch to RTOS SDK.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/build$ make BOARD=j784s4_evm CORE=mcu1_0 BUILD_PROFILE=release TOOLS_INSTALL_PATH=/home/a0224068local/ti sbl_mmcsd_img
    1.2 build ipc_echo_testb demo with boot app task.
    apply 0006-j784s4-port-boot-app-to-ipc_echo_testb.patch, 0007-j784s4-build-appimage-for-ipc_echo_testb.patch, 0010-j784s4-correct-pdk-path-in-launch.js.patch, 0011-j784s4-disable-MMCSD1-clock-after-loading-image.patch, to RTOS SDK.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/build$ make BOARD=j784s4_evm CORE=mcu1_0 BUILD_PROFILE=release TOOLS_INSTALL_PATH=/home/a0224068local/ti ipc_echo_testb_freertos
    1.3 build lateapp1 and lateapp2
    apply 0003-j784s4-add-tool-path-in-generate_lateapps.sh.patch, 0004-j784s4-add-vision-apps-to-generate_lateapps.sh.patch to RTOS SDK.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/sdk_builder$ make vision_apps
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/boot/sbl/example/boot_app/scripts$ ./generate_lateapps.sh j784s4_evm
    1.4 build dtb with vision apps dts
    apply 0001-j784s4-add-rootfstype-to-dtb.patch, 0002-j784s4-add-vision-apps-related-dts-to-evm-dts.patch, to LINUX SDK
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-linux-adas-j784s4-evm-09_00_01_03$ make linux-dtbs
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-linux-adas-j784s4-evm-09_00_01_03$ cp board-support/linux-6.1.46+gitAUTOINC+f8110d9ce8-gf8110d9ce8/arch/arm64/boot/dts/ti/k3-j784s4-evm.dtb board-support/prebuilt-images/base-board.dtb
    1.5 build atf_optee.appimage, tidtb_linux.appimage, and tikernelimage_linux.appimage.
    apply 0005-j784s4-go-linux-in-constructappimageshlos.sh.patch to RTOS SDK.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps$ mkdir -p binary/bin/j784s4_evm
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos$ ./constructappimageshlos.sh j784s4_evm
    1.6 update BOOT partition.
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/build$ rm -rf /media/a0224068local/BOOT/*
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/build$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/boot/sbl/binary/j784s4_evm/mmcsd/bin/sbl_mmcsd_img_mcu1_0_release.tiimage /media/a0224068local/BOOT/tiboot3.bin
    cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/drv/sciclient/soc/V6/tifs.bin /media/a0224068local/BOOT/tifs.bin
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/build$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/binary/ipc_echo_testb_freertos/bin/j784s4_evm/ipc_echo_testb_freertos_mcu1_0_release.appimage /media/a0224068local/BOOT/app
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/boot/sbl/example/boot_app/scripts$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/boot/sbl/example/boot_app/multicore_images/j784s4_evm/multicore_MCU2_0_MCU2_1_stage1.appimage /media/a0224068local/BOOT/lateapp1
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/boot/sbl/example/boot_app/scripts$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/boot/sbl/example/boot_app/multicore_images/j784s4_evm/multicore_DSPs_MCU3_0_MCU3_1_MCU4_0_MCU4_1_stage2.appimage /media/a0224068local/BOOT/lateapp2
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos/../../binary/bin/j784s4_evm/atf_optee.appimage /media/a0224068local/BOOT/atf_optee.appimage
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos/../../binary/bin/j784s4_evm/tidtb_linux.appimage /media/a0224068local/BOOT/tidtb_linux.appimage
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos/../../binary/bin/j784s4_evm/tikernelimage_linux.appimage /media/a0224068local/BOOT/tikernelimage_linux.appimage
    1.7 power on with updated SD card. try to check remote core status.
    root@j784s4-evm:~# modprobe rpmsg_client_sample count=1
    [ 18.522083] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.593741] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.608954] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.473426] rpmsg_client_sample virtio1.ti.ipc4.ping-pong.-1.13: new channel: 0x401 -> 0xd!
    [ 18.481927] rpmsg_client_sample virtio1.ti.ipc4.ping-pong.-1.13: incoming msg 1 (src: 0xd)
    [ 18.498497] rpmsg_client_sample virtio1.ti.ipc4.ping-pong.-1.13: goodbye!
    [ 18.553756] rpmsg_client_sample virtio2.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.680305] rpmsg_client_sample virtio2.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.688558] rpmsg_client_sample virtio2.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.570342] rpmsg_client_sample virtio3.ti.ipc4.ping-pong.-1.14: new channel: 0x403 -> 0xe!
    [ 18.695356] rpmsg_client_sample virtio3.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.703617] rpmsg_client_sample virtio3.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.490309] rpmsg_client_sample virtio4.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.545385] rpmsg_client_sample virtio4.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.561957] rpmsg_client_sample virtio4.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.585442] rpmsg_client_sample virtio5.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.710422] rpmsg_client_sample virtio5.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.718676] rpmsg_client_sample virtio5.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.602217] rpmsg_client_sample virtio6.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.725472] rpmsg_client_sample virtio6.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.733724] rpmsg_client_sample virtio6.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.617257] rpmsg_client_sample virtio7.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.740521] rpmsg_client_sample virtio7.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.748774] rpmsg_client_sample virtio7.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.481882] rpmsg_client_sample virtio8.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.513633] rpmsg_client_sample virtio8.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.530272] rpmsg_client_sample virtio8.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.538663] rpmsg_client_sample virtio9.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.622696] rpmsg_client_sample virtio9.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.673499] rpmsg_client_sample virtio9.ti.ipc4.ping-pong.-1.14: goodbye!
    [ 18.506871] rpmsg_client_sample virtio10.ti.ipc4.ping-pong.-1.14: new channel: 0x402 -> 0xe!
    [ 18.577070] rpmsg_client_sample virtio10.ti.ipc4.ping-pong.-1.14: incoming msg 1 (src: 0xe)
    [ 18.593730] rpmsg_client_sample virtio10.ti.ipc4.ping-pong.-1.14: goodbye!
    1.8 build u-boot-spl.bin
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-linux-adas-j784s4-evm-09_00_01_03$ make u-boot-a72
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-linux-adas-j784s4-evm-09_00_01_03$ cp board-support/u-boot-2023.04+gitAUTOINC+bd74e615a6-gbd74e615a6/build/a72/spl/u-boot-spl.bin board-support/prebuilt-images/
    1.9 build demo with boot app task.
    apply 0001-j784s4-let-boot-app-boot-a72-spl.patch to RTOS SDK.
    1.10 build tiu-boot-spl.appimage
    1.11 update BOOT partition
    a0224068local@a0224068local-Latitude-5289:/opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/pdk_j784s4_09_00_01_04/packages/ti/build$ cp /opt/1Twork/repository/ti-processor-sdk-rtos-j784s4-evm-09_00_01_01/mcusw/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos/../../binary/bin/j784s4_evm/tiu-boot-spl.appimage /media/a0224068local/BOOT/tiu-boot-spl.appimage
    1.12 update uEnv.txt in BOOT partition.
    dorprocboot=0
    1.13 power on with updated SD card.
    patch:
    0336.Patch.zip
    reference image:
    BOOT_PARTITION_boot_app_with_kernel.zip
    BOOT_PARTITION_boot_app_with_u_boot_spl.zip
    thanks a lot!
    yong
