SK-AM68: Unable to create bootable sdcard
Part Number: SK-AM68
I'm using v9.00.01.03 of the linux sdk for the SK-AM68. I'm able to build and install u-boot and linux to an sdcard using the top-level make file following the getting started guide. I've run into issues getting the newly built sdcard to boot. Before getting into the details of that issue, I thought it would be a good idea to "start over" and flash the reference sdcard image from this link:
PROCESSOR-SDK-LINUX-AM68A Software development kit (SDK) | TI.com
Following the instructions in the getting started guide, I decompressed the wic file and used balenaEtcher to flash it to the sdcard. I confirmed that the md5 of the downloaded compressed file matched what was listed on the site.
When I insert the newly flashed sdcard into the SK-AM68 and power it on, I see this on the UART console:
U-Boot SPL 2023.04-gbd74e615a6 (Sep 06 2023 - 10:09:25 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
EEPROM not available at 0x50, trying to read at 0x51
k3_lpddr4_start: FAIL
### ERROR ### Please RESET the board ###
Any idea why the reference image fails to boot? Whatever was on there initially from the factory worked, but if I try to flash it back on I get this error.
Thanks!
    It's failing at DDR initialisation. Can you confirm that the default SD card that worked still works on your board or even that fails?
    Keerthy
  • The sdcard worked when I first received it. By the way, I'm talking about the sdcard that came with the evm. When I first received the evm kit, I popped in the sdcard that came with it and it booted just fine. I could get to and login to the shell via uart and see the edge ai demo when connected to a monitor. Since then I've had to overwrite its contents while attempting to build my own image. What I'm seeing is that flashing the sdcard with the image I've downloaded - which I think should be the image that was on the sdcard originally - gives me the boot errors I listed above.
    Can you reproduce my issue by downloading the image from the link in my 1st post?
    I checked with our team internally. Can you go one version back.
    https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM68A/09.00.00.08
    9.00.00 is definitely booting. Can you build sd card with that wic image and let us know.
    Keerthy
  • That scard image works. When I flash it, the evm can boot properly. When connected to a monitor, what I see on my screen when it boots up is different compared to what was on the sdcard originally. The original sdcard image, I could interact with the screen and point and click to run some demos. This image, all I see on the screen is a picture with some green text telling me that ethernet is not connected and to use command line. Regardless, it seems to boot, so thank you for that advice.
    Is there a bug with v9.00.00.01.03 image and/or sdk? Should I not be using this version with the SK-AM68? The product page for the SK-AM68 points me to this version so I'd like to be clear on which version I should be using.
    I'm still having issues with creating an sdcard from u-boot and linux that I build, but I'll post a new question about that once I know which version of the sdk I should be using.
    Thanks!
    We will get back to you on this. Checking internally on this.
    Keerthy
  • Hi Amandio,
    I have recently seen the following boot log for a different, but similar platform:
    Trying to boot from MMC2
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Loading Environment from nowhere... OK
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.9(release):v2.9.0-dirty
    NOTICE:  BL31: Built : 14:12:59, May 22 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-GESI-EXP rev E2
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2023.04-gbd74e615a6 (Sep 06 2023 - 10:09:25 +0000)
    SoC:   J721E SR1.1 GP
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E8
    DRAM:  4 GiB
    Core:  125 devices, 34 uclasses, devicetree: separate
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    cdns,sierra serdes@5000000: sierra probed
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    unable to select a mode
    mmc_init: -524, time 222
    SD/MMC found on device 1
    mmc_init: -524, time 227
    ** Bad device specification mmc 1 **
    Couldn't find partition mmc 1
    Can't set block device
    mmc_init: -524, time 226
    gpio: pin gpio@22_17 (gpio 281) value is 1
    gpio: pin gpio@22_16 (gpio 280) value is 0
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    Couldn't find partition mmc 1:2
    mmc_init: -524, time 228
    mmc_init: -524, time 229
    mmc_init: -524, time 230
    libfdt fdt_check_header(): FDT_ERR_BADMAGIC
    No FDT memory address configured. Please configure
    the FDT address via "fdt addr <address>" command.
    Aborting!
    Bad Linux ARM64 Image magic!
    switch to partitions #0, OK
    mmc0(part 0) is current device
    ** No partition table - mmc 0 **
    Couldn't find partition mmc 0:1
    starting USB...
    Bus usb@6400000: cdns-usb3-host usb@6400000: Unable to get USB2 phy (ret -61)
    cdns-usb3-host usb@6400000: Unable to get USB3 phy (ret -61)
    cdns-usb3-host usb@6400000: DRD version v1 (ID: 0004024e, rev: 00000200)
    Register 2000840 NbrPorts 2
    Starting the controller
    USB XHCI 1.00
    scanning bus usb@6400000 for devices... 2 USB Device(s) found
           scanning usb for storage devices... 0 Storage Device(s) found
    Device 0: unknown device
    k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
    am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2
    ethernet@46000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
    am65_cpsw_nuss_port ethernet@46000000port@1: phy_startup failed
    am65_cpsw_nuss_port ethernet@46000000port@1: am65_cpsw_start end error
    missing environment variable: pxeuuid
    Retrieving file: pxelinux.cfg/01-24-76-25-93-43-73
    Retrieving file: pxelinux.cfg/00000000
    Retrieving file: pxelinux.cfg/default-arm-k3-j721e
    Config file not found
    I was able to resolve this by flashing a different SD card with the same 9.0.1.3 image.
    It seems that for some reason u-boot sometimes cannot correctly run "mmc dev 1" as part of the bootcmd's to switch mmc to load from micro SD card instead of onboard eMMC. And this is even when "mmc list" detects both eMMC and SD card. It could be that the SD card is not getting flashed correctly and somehow getting corrupted.
    If you have an extra SD card, could you try flashing the SDK on the new card to see if the same behavior can be observed?
    Takuma
  • Unfortunately, I do not have a spare sdcard.
    Using the same procedure, I can flash the previous version image (v9.00.00.08) to the same sdcard and it boots up fine. If the root of the problem was the sdcard, then I would expect this to fail as well.
  • Hi Amandio,
    The reasoning makes sense that if the SD card worked with 9.0.0.8, then it should work with 9.0.1.3. However, I have found that for some SD cards that worked with 9.0.0.8, when reflashed with 9.0.1.3 the SD card stops working, and sometimes reflashing this same SD card that did not work, or flashing onto a new SD card resolved the error logs I am getting.
    There are a couple of SD card and MMC1 related changes in 9.0.1.3, so it may be due to one of these changes, which we are looking into: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/09_00_01_03/exports/docs/devices/J7_Family/linux/Release_Specific_Release_Notes.html#issues-opened-in-previous-releases-that-were-closed-on-this-release
    Since we have not root caused the issue, it will take time for debugging, so as a potential quick workaround, flashing a new SD card, and/or reflashing the current SD card is my recommendation.
    Takuma
  • reflashing the current SD card is my recommendation
    This is what I'm doing. I am reflashing the sdcard that came with the evm. We just bought these evm's a few weeks ago so I would assume the latest image was on there initially, but I don't know that for sure. I know that what I saw when booting v9.00.00.08 was different than what I saw when I booted the sdcard when I first got it.
  • Hi Amandio,
    Would you be able to reflash the SD card for a second time? For example, there was a different customer with a similar issue: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1291225/sk-tda4vm-sk-tda4vm-sd-boot-fail-by/4902033?tisearch=e2e-sitesearch&keymatch=daiwang#4902033
    Takuma
  • I've flashed it a few times with the same error. I just tried it again and got the same error on boot. I also tried the same process in Ubuntu 22.04 and got the same error.
  • Another bit of info. In the v09.00.01.03 sdk, I ran create_sdcard.sh as described in the getting started guide and chose the options to flash the edgeai pre-built image. When I insert the resulting sdcard in the evm I get the same boot error that I posted in my first post.
  • Hi Amandio,
    Thanks for the information. Currently in discussion with the broader team for what the root cause for this could be. In the meantime, would it be fine to continue development and evaluation with 9.0.0.8?
    Takuma
  • Yes, I have no problem using the previous version as long as it works. As an aside, in v9.00.00.08 I just used create_sdcard.sh to create an sdcard using the default edgeai image inside the sdk and that appears to work. Via the serial console everything looks like it is loading ok and I can login as root. Nothing shows up on the screen, but I don't know if that is to be expected.
    Would you mind reviewing the boot log I've captured from the serial session to see if this is a normal boot? I'm new to this, and I want to make sure I'm starting off on the right foot. I see some sparse errors here and there but I don't know if they are of any real concern. Also, I do not have ethernet connected so maybe it has to do with that. Log is below:
    U-Boot SPL 2023.04-g756ba776d4 (Jul 13 2023 - 05:36:12 +0000)
    SPL initial stack usage: 13424 bytes
    Authentication passed
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb-dirty
    NOTICE:  BL31: Built : 00:42:57, Jan 13 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 U        TC 2023 aarch64
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/        porting_guidelines.html
    U-Boot 2023.04-g756ba776d4 (Jul 13 2023 - 05:36:12 +0000)
    SoC:   J721S2 SR1.0 HS-FS
    Model: Texas Instruments AM68 SK
    Board: AM68-SK-SOM rev E2
    DRAM:  16 GiB
    Core:  73 devices, 31 uclasses, devicetree: separate
    Flash: 0 Bytes
    MMC:   mmc@4fb0000: 1
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA8        2102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    mmc1 is current device
    Failed to load 'boot.scr'
    1319 bytes read in 3 ms (428.7 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    ## Error: "main_cpsw0_qsgmii_phyinit" not defined
    539832 bytes read in 30 ms (17.2 MiB/s)
    Warning: Did not detect image signing certificate. Skipping authentication to pr        event boot failure. This will fail on Security Enforcing(HS-SE) devices
    Load Remote Processor 2 with data@addr=0x82000000 539832 bytes: Success!
    400444 bytes read in 22 ms (17.4 MiB/s)
    Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices
    Load Remote Processor 3 with data@addr=0x82000000 400444 bytes: Success!
    Failed to load '/lib/firmware/j721s2-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j721s2-main-r5f1_1-fw'
    14381032 bytes read in 599 ms (22.9 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 14381032 bytes: Success!
    9777224 bytes read in 410 ms (22.7 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 9777224 bytes: Success!
    20593152 bytes read in 854 ms (23 MiB/s)
    76203 bytes read in 8 ms (9.1 MiB/s)
    Working FDT set to 88000000
    10448 bytes read in 6 ms (1.7 MiB/s)
    10182 bytes read in 5 ms (1.9 MiB/s)
    ERROR: reserving fdt memory region failed (addr=880000000 size=2c000000 flags=4)
       Loading Device Tree to 000000008feea000, end 000000008fffffff ... OK
    Working FDT set to 8feea000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.1.33-g8f7f371be2 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Jul 14 00:39:55 UTC 2023
    [    0.000000] Machine model: Texas Instruments AM68 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b0100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 704 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB
    [    0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000bffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000bbffffff]
    [    0.000000]   node   0: [mem 0x00000000bc000000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008abffffff]
    [    0.000000]   node   0: [mem 0x00000008ac000000-0x0000000bffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4128766
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) systemd.hostname=am68a-sk root=PARTUUID=38358c03-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 13726380K/16777208K available (12480K kernel code, 1294K rwdata, 4048K rodata, 2176K init, 498K bss, 2133324K reserved, 917504K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8ac800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008ac030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008ac040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008430] Console: colour dummy device 80x25
    [    0.012996] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023668] pid_max: default: 32768 minimum: 301
    [    0.028410] LSM: Security Framework initializing
    [    0.033218] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.041000] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.050094] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.057504] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.063772] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.070092] rcu: Hierarchical SRCU implementation.
    [    0.074990] rcu:     Max phase no-delay instances is 1000.
    [    0.080505] Platform MSI: msi-controller@1820000 domain created
    [    0.086719] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.096531] EFI services will not be available.
    [    0.101282] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.114359] Detected PIPT I-cache on CPU1
    [    0.114418] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.114432] GICv3: CPU1: using allocated LPI pending table @0x00000008ac050000
    [    0.114466] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.114522] smp: Brought up 1 node, 2 CPUs
    [    0.143871] SMP: Total of 2 processors activated.
    [    0.148675] CPU features: detected: 32-bit EL0 Support
    [    0.153929] CPU features: detected: CRC32 instructions
    [    0.159217] CPU: All CPU(s) started at EL2
    [    0.163399] alternatives: applying system-wide alternatives
    [    0.170056] devtmpfs: initialized
    [    0.180223] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.190212] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.208719] pinctrl core: initialized pinctrl subsystem
    [    0.214432] DMI not present or invalid.
    [    0.218690] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.225562] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
    [    0.233237] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.241575] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.249801] audit: initializing netlink subsys (disabled)
    [    0.255460] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.255707] thermal_sys: Registered thermal governor 'step_wise'
    [    0.263383] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.269616] cpuidle: using governor menu
    [    0.280378] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.287348] ASID allocator initialised with 65536 entries
    [    0.301408] platform hdmi-connector: Fixed dependency cycle(s) with /dvi-bridge
    [    0.309088] KASLR disabled due to lack of seed
    [    0.316773] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.323718] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.330120] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.337053] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.343455] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.350388] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.356789] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.363723] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.371135] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.380606] iommu: Default domain type: Translated
    [    0.385596] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.392129] SCSI subsystem initialized
    [    0.396164] usbcore: registered new interface driver usbfs
    [    0.401790] usbcore: registered new interface driver hub
    [    0.407228] usbcore: registered new device driver usb
    [    0.412657] pps_core: LinuxPPS API ver. 1 registered
    [    0.417732] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.427072] PTP clock support registered
    [    0.431148] EDAC MC: Ver: 3.0.0
    [    0.434945] FPGA manager framework
    [    0.438460] Advanced Linux Sound Architecture Driver Initialized.
    [    0.445126] clocksource: Switched to clocksource arch_sys_counter
    [    0.451487] VFS: Disk quotas dquot_6.6.0
    [    0.455526] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.465578] Carveout Heap: Exported 512 MiB at 0x0000000900000000
    [    0.471879] NET: Registered PF_INET protocol family
    [    0.477277] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.490128] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
    [    0.499040] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.506989] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.515671] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.524285] TCP: Hash tables configured (established 131072 bind 65536)
    [    0.531178] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.538308] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.545987] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.552126] RPC: Registered named UNIX socket transport module.
    [    0.558193] RPC: Registered udp transport module.
    [    0.562998] RPC: Registered tcp transport module.
    [    0.567800] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.574395] NET: Registered PF_XDP protocol family
    [    0.579301] PCI: CLS 0 bytes, default 64
    [    0.583728] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.592952] Initialise system trusted keyrings
    [    0.597656] workingset: timestamp_bits=46 max_order=22 bucket_order=0
    [    0.606863] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.613189] NFS: Registering the id_resolver key type
    [    0.618370] Key type id_resolver registered
    [    0.622642] Key type id_legacy registered
    [    0.626768] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.633617] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.641280] 9p: Installing v9fs 9p2000 file system support
    [    0.666081] Key type asymmetric registered
    [    0.670266] Asymmetric key parser 'x509' registered
    [    0.675278] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.682939] io scheduler mq-deadline registered
    [    0.687584] io scheduler kyber registered
    [    0.693615] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [    0.699661] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
    [    0.705671] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
    [    0.711719] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
    [    0.717560] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.727650] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.738055] loop: module loaded
    [    0.742131] megasas: 07.719.03.00-rc1
    [    0.747956] tun: Universal TUN/TAP device driver, 1.6
    [    0.753510] thunder_xcv, ver 1.0
    [    0.756815] thunder_bgx, ver 1.0
    [    0.760134] nicpf, ver 1.0
    [    0.763126] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
    [    0.770507] hns3: Copyright (c) 2017 Huawei Corporation.
    [    0.775960] hclge is initializing
    [    0.779351] e1000: Intel(R) PRO/1000 Network Driver
    [    0.784331] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    0.790218] e1000e: Intel(R) PRO/1000 Network Driver
    [    0.795288] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    0.801347] igb: Intel(R) Gigabit Ethernet Network Driver
    [    0.806861] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    0.812566] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.818968] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.825088] sky2: driver version 1.30
    [    0.829234] VFIO - User Level meta-driver version: 0.3
    [    0.834928] usbcore: registered new interface driver usb-storage
    [    0.841530] i2c_dev: i2c /dev entries driver
    [    0.846894] sdhci: Secure Digital Host Controller Interface driver
    [    0.853219] sdhci: Copyright(c) Pierre Ossman
    [    0.857919] Synopsys Designware Multimedia Card Interface Driver
    [    0.864298] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.870551] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.876792] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.883524] usbcore: registered new interface driver usbhid
    [    0.889220] usbhid: USB HID core driver
    [    0.893879] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.898444] optee: revision 3.20 (8e74d476)
    [    0.914892] optee: dynamic shared memory is enabled
    [    0.924381] optee: initialized driver
    [    0.929324] Initializing XFRM netlink socket
    [    0.933713] NET: Registered PF_PACKET protocol family
    [    0.938953] 9pnet: Installing 9P2000 support
    [    0.943353] Key type dns_resolver registered
    [    0.947941] registered taskstats version 1
    [    0.952145] Loading compiled-in X.509 certificates
    [    0.962030] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
    [    0.987974] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.994385] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    1.001249] pca953x 1-0020: using no AI
    [    1.030181] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.036625] pca953x 2-0021: supply vcc not found, using dummy regulator
    [    1.043468] pca953x 2-0021: using no AI
    [    1.069702] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.075506] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    1.084051] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    1.093389] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    1.102042] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    1.110842] ti-udma 311a0000.dma-controller: Number of rings: 48
    [    1.117585] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
    [    1.126873] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.136767] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.143527] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.152389] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.162553] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.169313] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.177296] printk: console [ttyS2] disabled
    [    1.181696] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 215, base_baud = 3000000) is a 8250
    [    1.190550] printk: console [ttyS2] enabled
    [    1.198996] printk: bootconsole [ns16550a0] disabled
    [    1.210607] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.257137] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.265798] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.274076] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.286937] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.294146] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.300459] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.310927] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
    [    1.425979] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.432793] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.439585] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.446370] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.453497] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.463531] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
    [    1.475804] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.480818] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.487420] Creating 7 MTD partitions on "47040000.spi.0":
    [    1.492892] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.499045] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.504929] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.510835] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.516467] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.522737] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.528640] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.538998] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.585137] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.593776] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.602056] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.614916] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.622126] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.628398] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.638540] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.646428] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present!
    [    1.646956] mmc1: CQHCI version 5.10
    [    1.653734] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present!
    [    1.665529] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
    [    1.676903] ALSA device list:
    [    1.679880]   No soundcards found.
    [    1.695741] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.703345] Waiting for root device PARTUUID=38358c03-02...
    [    1.758022] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    1.765067] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
    [    1.773900]  mmcblk1: p1 p2
    [    1.805917] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.814475] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.824816] devtmpfs: mounted
    [    1.828635] Freeing unused kernel memory: 2176K
    [    1.833337] Run /sbin/init as init process
    [    1.997885] systemd[1]: System time before build time, advancing clock.
    [    2.035813] NET: Registered PF_INET6 protocol family
    [    2.041471] Segment Routing with IPv6
    [    2.045153] In-situ OAM (IOAM) with IPv6
    [    2.072804] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    2.104212] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.04!
    [    2.173313] systemd[1]: Hostname set to <am68a-sk>.
    [    2.250629] systemd-sysv-generator[133]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.279067] systemd-sysv-generator[133]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.303146] systemd-sysv-generator[133]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.327394] systemd-sysv-generator[133]: SysV service '/etc/init.d/autolaunch-demo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.352614] systemd-sysv-generator[133]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.377322] systemd-sysv-generator[133]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.400919] systemd-sysv-generator[133]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.425670] systemd-sysv-generator[133]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.450699] systemd-sysv-generator[133]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.474418] systemd-sysv-generator[133]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.498291] systemd-sysv-generator[133]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.523948] systemd-sysv-generator[133]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.548135] systemd-sysv-generator[133]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.572872] systemd-sysv-generator[133]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.596738] systemd-sysv-generator[133]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.621278] systemd-sysv-generator[133]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.646744] systemd-sysv-generator[133]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.670509] systemd-sysv-generator[133]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.853484] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.899638] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.951146] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.993831] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.018715] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.042593] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.066246] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.089372] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    3.113292] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    3.137339] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.153200] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.173188] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.189193] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.240329] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.261314] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.286468] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.309407] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.333574] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    3.353464] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.373507] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.389566] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.413562] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.433421] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.453420] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.497467] systemd[1]: Mounting Huge Pages File System...
    [    3.516038] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.539936] systemd[1]: Mounting Kernel Debug File System...
    [    3.557481] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.575760] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.596787] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.637625] systemd[1]: Starting Load Kernel Module configfs...
    [    3.660017] systemd[1]: Starting Load Kernel Module drm...
    [    3.684459] systemd[1]: Starting Load Kernel Module fuse...
    [    3.695773] fuse: init (API version 7.37)
    [    3.737693] systemd[1]: Starting Start psplash boot splash screen...
    [    3.767452] systemd[1]: Starting RPC Bind...
    [    3.785419] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    3.825750] systemd[1]: Starting Journal Service...
    [    3.856775] systemd[1]: Starting Load Kernel Modules...
    [    3.872558] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network …ts from Kernel command line...
    [    3.887514] cryptodev: loading out-of-tree module taints kernel.
    [    3.896478] cryptodev: driver 1.12 loaded.
    [    3.913755] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.929917] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    3.940515] systemd[1]: Starting Coldplug All udev Devices...
    [    3.966446] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.985724] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...[    4.320155] systemd-journald[148]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
    [    4.507850] audit: type=1334 audit(1651167747.508:2): prog-id=5 op=LOAD
    [    4.514814] audit: type=1334 audit(1651167747.516:3): prog-id=6 op=LOAD
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [    5.053432] random: crng init done
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [    5.070820] CAN device driver interface
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [    5.117960] mc: Linux media interface: v0.10
    [  OK  ] Listening on dropbear.socket.
    [    5.142370] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b0000000
             Starting Weston socket...
    [    5.166984] PVR_K:  184: Device: 4e20000000.gpu
    [    5.178913] videodev: Linux video capture interface: v2.00
             Starting Console System Startup Logging...
    [    5.199171] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    5.215449] remoteproc remoteproc0: 64800000.dsp is available
    [    5.222736] remoteproc remoteproc0: attaching to 64800000.dsp
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [    5.260013] PVR_K:  184: Read BVNC 36.53.104.796 from HW device registers
    [    5.269918] at24 0-0051: supply vcc not found, using dummy regulator
    [  OK  ] Finished Load/Save Random Seed.[    5.278024] PVR_K:  184: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    5.283427] remoteproc remoteproc0: unsupported resource 65538
    [  OK  ] Listening on Docker Socket for the [    5.297665] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    API.
    [    5.309704] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c71-dma-memory@b0000000
    [  OK  ] Listening on Weston socket.[    5.321831] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.323652] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    5.332713] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    5.346097] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    5.354816] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000
    [    5.374169] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    5.386414] remoteproc remoteproc1: 65800000.dsp is available
    [    5.392419] remoteproc remoteproc1: attaching to 65800000.dsp
    [  OK  ] Finished Console System Startup Log[    5.398590] remoteproc remoteproc1: unsupported resource 65538
    ging.
    [    5.410072] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    5.410975] [drm] Initialized pvr 23.1.6404501 20170530 for 4e20000000.gpu on minor 0
    [    5.417481] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000
    [    5.436670] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.442229] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    5.450091] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [    5.456901] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [  OK  ] Finished Reboot and dump vmcore via[    5.468325] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
     kexec.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Started D-Bus System Message Bus    5.528550] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    m.
    [    5.554787] platform 41000000.r5f: configured R5F for IPC-only mode
    [  OK  ] Reached target Basic System.
    [    5.562895] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.586759] remoteproc remoteproc2: 41000000.r5f is available
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [    5.621944] remoteproc remoteproc2: attaching to 41000000.r5f
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Expand the rootfs…ll size of the boot device....
    [    5.739116] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [  OK  ] Started startwlanap.[    5.756501] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [  OK  ] Started startwlansta.
    [    5.802441] audit: type=1334 audit(1651168232.332:4): prog-id=7 op=LOAD
    [    5.814633] audit: type=1334 audit(1651168232.344:5): prog-id=8 op=LOAD
    [    5.824061] m_can_platform 40528000.can: m_can device registered (irq=484, version=32)
    [    5.836322] m_can_platform 40568000.can: m_can device registered (irq=485, version=32)
             Starting User Login Management...
    [  OK  ] Started TEE Supplicant.
             Starting telnetd.service...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Fi[    5.873053] m_can_platform 2761000.can: m_can device registered (irq=486, version=32)
    ltering Framework.
    [  OK  ] Reached target Preparation for Network.
    [    5.898650] m_can_platform 2771000.can: m_can device registered (irq=487, version=32)
             Starting Network Configuration...
    [  OK  ] Started Telephony service.
    [    5.944125] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.962370] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.972384] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [    5.979640] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started telnetd.service.
    [    6.113424] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [    6.169252] Bluetooth: Core ver 2.22
    [    6.172929] NET: Registered PF_BLUETOOTH protocol family
    [    6.178436] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    6.185758] Bluetooth: HCI device and connection manager initialized
    [    6.187705] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.192399] Bluetooth: HCI socket layer initialized
    [    6.206249] Bluetooth: L2CAP socket layer initialized
    [    6.211365] Bluetooth: SCO socket layer initialized
    [    6.218946] remoteproc remoteproc3: 5c00000.r5f is available
    [    6.224879] remoteproc remoteproc3: attaching to 5c00000.r5f
    [    6.231195] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [  OK  ] Finished Expand the rootfs…full s[    6.238039] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.254339] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.257559] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    6.262444] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [    6.275619] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [    6.328764] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.381075] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.387683] platform 5d00000.r5f: configured R5F for IPC-only mode
    [  OK  ] Started User Login Management.[    6.395131] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.411468] remoteproc remoteproc4: 5d00000.r5f is available
    [    6.418235] remoteproc remoteproc4: attaching to 5d00000.r5f
    [    6.425185] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    6.431928] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.442756] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    6.448402] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    6.455741] rproc-virtio rproc-virtio.4.auto: registered virtio4 (type 7)
    [    6.463132] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    6.470424] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    6.477737] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.485404] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    6.492713] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.496005] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
    [    6.500350] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    6.517323] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.527541] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.544138] platform 5e00000.r5f: configured R5F for remoteproc mode
    [  OK  ] Started Network Configuration.
    [    6.608362] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [    6.656641] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    6.679735] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    6.846307] remoteproc remoteproc5: 5e00000.r5f is available
    [    6.855192] remoteproc remoteproc5: loading /lib/firmware/j721s2-main-r5f1_0-fw failed with error -22
    [    6.867364] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -22
    [    6.882866] remoteproc remoteproc5: powering up 5e00000.r5f
    [    6.888552] remoteproc remoteproc5: loading /lib/firmware/j721s2-main-r5f1_0-fw failed with error -22
    [    6.899787] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    6.901320] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -22
    [    6.916162] remoteproc remoteproc5: request_firmware failed: -22
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name L[    6.957555] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    ookups.
    [    6.980737] remoteproc remoteproc6: 5f00000.r5f is available
    [    6.987413] remoteproc remoteproc6: loading /lib/firmware/j721s2-main-r5f1_1-fw failed with error -22
             Starting Avahi mDNS/DNS-SD Stack...[    6.998222] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -22
             Starting Enable and configure wl18xx bluetooth[    7.014598] remoteproc remoteproc6: powering up 5f00000.r5f
     stack...
    [    7.022541] remoteproc remoteproc6: loading /lib/firmware/j721s2-main-r5f1_1-fw failed with error -22
             Starting containerd container runtime...
    [    7.033193] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -22
    [  OK  ] Started Netperf Benchmark Server    7.048371] remoteproc remoteproc6: request_firmware failed: -22
    m.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Permit User Sessions.
    [    7.293253] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland…ositor, as a system service...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [    7.470127] [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* remote dsi host node not found
    [    7.509264] audit: type=1334 audit(1651168234.040:6): prog-id=9 op=LOAD
    [    7.520053] audit: type=1334 audit(1651168234.044:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    [  OK  ] Started User Database Manager.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [    7.937870] audit: type=1006 audit(1651168234.468:8): pid=504 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    7.953849] audit: type=1300 audit(1651168234.468:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff0d38058 a2=4 a3=ffffa7d5f020 items=0 ppid=1 pid=504 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    7.980529] audit: type=1327 audit(1651168234.468:8): proctitle="(systemd)"
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User wes[    8.305851] audit: type=1006 audit(1651168234.836:9): pid=438 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    ton.
    [    8.318623] audit: type=1300 audit(1651168234.836:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff0d38058 a2=4 a3=ffffa7d5f020 items=0 ppid=1 pid=438 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [    8.345913] audit: type=1327 audit(1651168234.836:9): proctitle="(weston)"
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [FAILED] Failed to start Weston, a …mpositor, as a system service.
    See 'systemctl status weston.service' for details.
    [DEPEND] Dependency failed for DEMO.
             Starting EdgeAI OOB demos...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/boot-mmcblk1p1...
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [  OK  ] Started containerd container runtime.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk-dev
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libeigen-dev
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5sensors-plugins
            libqt5sensors-qmlplugins
            libqt5sensors5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libqt5webchannel-plugins
            libqt5webchannel-qmlplugins
            libqt5webchannel5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring2
            m4-dev
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am68a-sk -
    Arago 2023.04 am68a-sk -
    am68a-sk login: [   15.036754] audit: type=1701 audit(1651168241.564:10): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1099 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
    [   15.058684] audit: type=1334 audit(1651168241.588:11): prog-id=11 op=LOAD
    [   15.065723] audit: type=1334 audit(1651168241.588:12): prog-id=12 op=LOAD
    [   15.517303] audit: type=1334 audit(1651168242.048:13): prog-id=12 op=UNLOAD
    [   15.524287] audit: type=1334 audit(1651168242.048:14): prog-id=11 op=UNLOAD
    [   17.765618] platform 2910000.pcie: deferred probe pending
    [   17.771034] platform 6000000.usb: deferred probe pending
    root
    [   25.721353] audit: type=1006 audit(1651168252.248:15): pid=1158 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   25.733929] audit: type=1300 audit(1651168252.248:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff0d38058 a2=1 a3=0 items=0 ppid=1 pid=1158 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   25.759567] audit: type=1327 audit(1651168252.248:15): proctitle="(systemd)"
    [   25.766650] audit: type=1334 audit(1651168252.264:16): prog-id=13 op=LOAD
    [   25.773593] audit: type=1300 audit(1651168252.264:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc4c83b00 a2=78 a3=0 items=0 ppid=1 pid=1158 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   25.799087] audit: type=1327 audit(1651168252.264:16): proctitle="(systemd)"
    [   25.806197] audit: type=1334 audit(1651168252.288:17): prog-id=13 op=UNLOAD
    [   25.813242] audit: type=1334 audit(1651168252.288:18): prog-id=14 op=LOAD
    [   25.820064] audit: type=1300 audit(1651168252.288:18): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc4c83ba0 a2=78 a3=0 items=0 ppid=1 pid=1158 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   25.845528] audit: type=1327 audit(1651168252.288:18): proctitle="(systemd)"
    root@am68a-sk:/opt/edgeai-gst-apps#
    I very much appreciate the help!
  • Hi Amandio,
    Boot logs look to be correct if you were able to reach the login prompt and login as root.
    There may be some PCIe and USB related issue based on platform 2910000.pcie: deferred probe pending and platform 6000000.usb: deferred probe pending, but there are some logs that say usbcore has been registered, so these logs may be coming from one of the unconnected instances of PCIe and USB on the SoC.
    Let us know if you face any issues with the system.
    Takuma
  • Thank you for the help! I'll mark this as resolved.
