Other Parts Discussed in Thread: TDA4VH, SN65DSI86
TI experts,
Now we are working on SDK 0900 on TDA4VH EVM board.
We are now conducting a long-stability test of the open-and-close video, and we have found that there is a leak in the use of CMA memory by the encode driver. Every time the encoding is turned off and on, the CMA free memory drops a bit. A system crash occurs when the CMA free memory drops to a certain level and encoding can no longer be started.
Details are as follows:
1. Run the following command,
Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.004924525 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002256465 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002020965 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002226210 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001944340 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002159265 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001969180 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001827275 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002466185 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001996425 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002157375 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002519110 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002192600 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002225560 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002453480 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002131165 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002199800 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001875080 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001961295 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002015515 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002266945 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001987715 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002225725 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002372605 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002363840 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002046325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001989725 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002294465 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002002240 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001989765 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001978270 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002180260 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001846440 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002636440 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002407605 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002015900 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002056855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002432650 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001744095 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002044695 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002098965 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001885420 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002083950 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002360760 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002292115 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002368925 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002170115 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002249925 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002423150 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002248515 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002189195 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001977020 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002424410 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002492650 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001739250 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002418440 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002399135 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002271245 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002231965 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002310560 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002017685 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002022220 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002229310 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002163670 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002103865 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002098665 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002084005 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001867975 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002052835 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002312475 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002477385 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002000225 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002197560 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002432345 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002218855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002239005 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002264335 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002087410 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001655120 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002191830 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002417915 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002323595 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001958020 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002048100 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002090810 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002273085 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002278390 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002169120 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002231435 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001742685 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001976550 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002252345 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002056905 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002205675 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002321250 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001987020 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002433700 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002474260 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002167295 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002221960 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002270855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002351510 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002137965 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002242135 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002222325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002547700 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002186980 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002212045 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002124210 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002003600 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001914015 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002031290 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002085780 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001993795 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001854485 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001999390 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002102055 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001944100 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002209345 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002110585 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002211325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002737335 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002334235 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002260700 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002337365 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002211050 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001949355 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002059290 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002266905 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002093750 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002123395 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002040855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002283960 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002300435 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002267845 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002196150 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002078325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002181735 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002102870 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001941085 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002256220 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002046555 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002262375 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002377900 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002270775 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002337805 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002099065 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002059790 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002372765 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002066235 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001833200 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001994105 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002026040 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001867780 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002087445 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002155850 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002394005 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002194315 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002289815 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002105245 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002406965 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001887780 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001961155 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002291380 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002019940 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001916800 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001982540 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002230520 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001896530 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001880110 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002014490 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002392550 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002419825 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002128820 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002404050 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002106160 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002013785 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002330670 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002121715 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002235095 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001903070 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002207530 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001793320 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001905695 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002263575 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002077820 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002291400 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002338410 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002177040 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002224370 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001928070 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002075765 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002152845 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002096350 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002355895 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002257855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001926355 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002327370 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002160075 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002253815 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002163270 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002346025 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002291465 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002036135 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002076810 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002037575 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002242480 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002132130 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002409825 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002338630 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002148460 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002053875 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002021730 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002118325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002160010 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002038150 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001949180 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002465755 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002169295 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002195845 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002196955 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002570395 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002336415 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002029435 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002381495 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002106235 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002306750 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002255345 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002427760 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002427565 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002537630 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002312695 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002071475 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002216545 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001962505 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002399625 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002060585 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002590445 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002058980 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002058265 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002406950 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002534855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001961735 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002146900 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002229650 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002155540 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002111855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002160585 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002257115 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002329620 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001987880 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002242940 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002164710 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002469120 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002073410 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002392070 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001990065 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002207500 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002615725 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002158760 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001974130 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002100290 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002364125 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002504395 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002464325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002443500 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002209300 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002076380 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002107190 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002332810 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001935085 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002409210 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001859790 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002309425 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002204330 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002596535 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002085045 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002375965 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002340905 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002198810 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002476550 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002480330 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002312920 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002526865 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002119255 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002345060 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002278855 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002323425 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002302195 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001893100 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.001974715 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002563405 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.002345215 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:03.021060380 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.318913225 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:16.841639785 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.015538165 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.016260460 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.016387735 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017277405 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017450260 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.025158325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017969120 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.018730320 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.018963325 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.037836210 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055694820 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055607925 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055639760 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017587700 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.018324610 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010189350 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060077700 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055720210 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010300440 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010131590 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010310455 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.059928150 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055512370 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017125980 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010226750 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017362255 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060187185 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.109681115 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.804292335 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.109068335 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.849535730 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.097724765 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.849874355 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.076921790 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.846700530 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.104388920 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.804144310 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.108808510 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.842218990 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.090613265 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.842568680 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.077805645 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.847244540 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.111290045 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017567515 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060098570 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055887660 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017214635 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010277590 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017167385 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.059898395 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055552920 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017338330 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010095785 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010068055 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060231805 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055624280 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010294345 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010139715 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.009975510 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060369540 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.062525665 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010172170 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010261070 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017141860 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.066867385 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.848052760 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.066419520 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.854016075 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.104443990 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.797166440 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.115744355 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.849368605 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.090811575 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.842623575 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.077230400 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.847139615 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.104463230 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.797275515 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.109213960 Setting pipeline to NULL ... ^CFreeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.842517615 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.090608455 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.842571675 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.297814975 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010260845 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.059858600 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.062447375 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.009902035 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010234055 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.009978150 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060029580 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055617230 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010187715 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.009989840 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.009975210 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.059969580 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.062907220 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010260005 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.009941255 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010140915 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.060024700 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.055661625 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010184405 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.010013100 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.017009425 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.114013555 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.842669765 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error. Additional debug info: ../gstreamer-1.20.6/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:01.090339270 Setting pipeline to NULL ...
Initial CmaFree Value:CmaFree: 1824408 kB Running number: 1 CmaFree: CmaFree: 1818276 kB Running number: 2 CmaFree: CmaFree: 1812156 kB Running number: 3 CmaFree: CmaFree: 1806036 kB Running number: 4 CmaFree: CmaFree: 1799916 kB Running number: 5 CmaFree: CmaFree: 1793796 kB Running number: 6 CmaFree: CmaFree: 1787676 kB Running number: 7 CmaFree: CmaFree: 1781556 kB Running number: 8 CmaFree: CmaFree: 1775436 kB Running number: 9 CmaFree: CmaFree: 1769316 kB Running number: 10 CmaFree: CmaFree: 1763196 kB Running number: 11 CmaFree: CmaFree: 1756988 kB Running number: 12 CmaFree: CmaFree: 1750956 kB Running number: 13 CmaFree: CmaFree: 1744836 kB Running number: 14 CmaFree: CmaFree: 1738628 kB Running number: 15 CmaFree: CmaFree: 1732596 kB Running number: 16 CmaFree: CmaFree: 1726476 kB Running number: 17 CmaFree: CmaFree: 1720356 kB Running number: 18 CmaFree: CmaFree: 1714248 kB Running number: 19 CmaFree: CmaFree: 1708116 kB Running number: 20 CmaFree: CmaFree: 1702008 kB Running number: 21 CmaFree: CmaFree: 1695876 kB Running number: 22 CmaFree: CmaFree: 1689756 kB Running number: 23 CmaFree: CmaFree: 1683636 kB Running number: 24 CmaFree: CmaFree: 1677516 kB Running number: 25 CmaFree: CmaFree: 1671396 kB Running number: 26 CmaFree: CmaFree: 1665276 kB Running number: 27 CmaFree: CmaFree: 1659156 kB Running number: 28 CmaFree: CmaFree: 1652996 kB Running number: 29 CmaFree: CmaFree: 1646828 kB Running number: 30 CmaFree: CmaFree: 1640708 kB Running number: 31 CmaFree: CmaFree: 1634588 kB Running number: 32 CmaFree: CmaFree: 1628556 kB Running number: 33 CmaFree: CmaFree: 1622436 kB Running number: 34 CmaFree: CmaFree: 1616316 kB Running number: 35 CmaFree: CmaFree: 1610108 kB Running number: 36 CmaFree: CmaFree: 1604076 kB Running number: 37 CmaFree: CmaFree: 1597956 kB Running number: 38 CmaFree: CmaFree: 1591748 kB Running number: 39 CmaFree: CmaFree: 1585716 kB Running number: 40 CmaFree: CmaFree: 1579596 kB Running number: 41 CmaFree: CmaFree: 1573476 kB Running number: 42 CmaFree: CmaFree: 1567356 kB Running number: 43 CmaFree: CmaFree: 1561148 kB Running number: 44 CmaFree: CmaFree: 1555116 kB Running number: 45 CmaFree: CmaFree: 1548996 kB Running number: 46 CmaFree: CmaFree: 1542888 kB Running number: 47 CmaFree: CmaFree: 1536756 kB Running number: 48 CmaFree: CmaFree: 1530636 kB Running number: 49 CmaFree: CmaFree: 1524516 kB Running number: 50 CmaFree: CmaFree: 1518396 kB Running number: 51 CmaFree: CmaFree: 1512276 kB Running number: 52 CmaFree: CmaFree: 1506156 kB Running number: 53 CmaFree: CmaFree: 1500036 kB Running number: 54 CmaFree: CmaFree: 1493916 kB Running number: 55 CmaFree: CmaFree: 1487796 kB Running number: 56 CmaFree: CmaFree: 1481676 kB Running number: 57 CmaFree: CmaFree: 1475556 kB Running number: 58 CmaFree: CmaFree: 1469436 kB Running number: 59 CmaFree: CmaFree: 1463316 kB Running number: 60 CmaFree: CmaFree: 1457196 kB Running number: 61 CmaFree: CmaFree: 1451076 kB Running number: 62 CmaFree: CmaFree: 1444956 kB Running number: 63 CmaFree: CmaFree: 1438836 kB Running number: 64 CmaFree: CmaFree: 1432716 kB Running number: 65 CmaFree: CmaFree: 1426508 kB Running number: 66 CmaFree: CmaFree: 1420476 kB Running number: 67 CmaFree: CmaFree: 1414356 kB Running number: 68 CmaFree: CmaFree: 1408044 kB Running number: 69 CmaFree: CmaFree: 1402116 kB Running number: 70 CmaFree: CmaFree: 1395908 kB Running number: 71 CmaFree: CmaFree: 1389876 kB Running number: 72 CmaFree: CmaFree: 1383668 kB Running number: 73 CmaFree: CmaFree: 1377648 kB Running number: 74 CmaFree: CmaFree: 1371516 kB Running number: 75 CmaFree: CmaFree: 1365308 kB Running number: 76 CmaFree: CmaFree: 1359276 kB Running number: 77 CmaFree: CmaFree: 1353156 kB Running number: 78 CmaFree: CmaFree: 1346948 kB Running number: 79 CmaFree: CmaFree: 1340916 kB Running number: 80 CmaFree: CmaFree: 1334708 kB Running number: 81 CmaFree: CmaFree: 1328676 kB Running number: 82 CmaFree: CmaFree: 1322556 kB Running number: 83 CmaFree: CmaFree: 1316436 kB Running number: 84 CmaFree: CmaFree: 1310316 kB Running number: 85 CmaFree: CmaFree: 1304196 kB Running number: 86 CmaFree: CmaFree: 1298076 kB Running number: 87 CmaFree: CmaFree: 1291868 kB Running number: 88 CmaFree: CmaFree: 1285748 kB Running number: 89 CmaFree: CmaFree: 1279716 kB Running number: 90 CmaFree: CmaFree: 1273596 kB Running number: 91 CmaFree: CmaFree: 1267388 kB Running number: 92 CmaFree: CmaFree: 1261268 kB Running number: 93 CmaFree: CmaFree: 1255236 kB Running number: 94 CmaFree: CmaFree: 1249116 kB Running number: 95 CmaFree: CmaFree: 1242996 kB Running number: 96 CmaFree: CmaFree: 1236684 kB Running number: 97 CmaFree: CmaFree: 1230668 kB Running number: 98 CmaFree: CmaFree: 1224636 kB Running number: 99 CmaFree: CmaFree: 1218428 kB Running number: 100 CmaFree: CmaFree: 1212396 kB Running number: 101 CmaFree: CmaFree: 1206276 kB Running number: 102 CmaFree: CmaFree: 1200068 kB Running number: 103 CmaFree: CmaFree: 1193948 kB Running number: 104 CmaFree: CmaFree: 1187916 kB Running number: 105 CmaFree: CmaFree: 1181796 kB Running number: 106 CmaFree: CmaFree: 1175676 kB Running number: 107 CmaFree: CmaFree: 1169556 kB Running number: 108 CmaFree: CmaFree: 1163436 kB Running number: 109 CmaFree: CmaFree: 1157316 kB Running number: 110 CmaFree: CmaFree: 1151196 kB Running number: 111 CmaFree: CmaFree: 1145076 kB Running number: 112 CmaFree: CmaFree: 1138868 kB Running number: 113 CmaFree: CmaFree: 1132836 kB Running number: 114 CmaFree: CmaFree: 1126716 kB Running number: 115 CmaFree: CmaFree: 1120596 kB Running number: 116 CmaFree: CmaFree: 1114476 kB Running number: 117 CmaFree: CmaFree: 1108368 kB Running number: 118 CmaFree: CmaFree: 1102148 kB Running number: 119 CmaFree: CmaFree: 1096116 kB Running number: 120 CmaFree: CmaFree: 1089996 kB Running number: 121 CmaFree: CmaFree: 1083876 kB Running number: 122 CmaFree: CmaFree: 1077668 kB Running number: 123 CmaFree: CmaFree: 1071636 kB Running number: 124 CmaFree: CmaFree: 1065516 kB Running number: 125 CmaFree: CmaFree: 1059396 kB Running number: 126 CmaFree: CmaFree: 1053276 kB Running number: 127 CmaFree: CmaFree: 1047156 kB Running number: 128 CmaFree: CmaFree: 1041036 kB Running number: 129 CmaFree: CmaFree: 1034916 kB Running number: 130 CmaFree: CmaFree: 1028796 kB Running number: 131 CmaFree: CmaFree: 1022676 kB Running number: 132 CmaFree: CmaFree: 1016468 kB Running number: 133 CmaFree: CmaFree: 1010348 kB Running number: 134 CmaFree: CmaFree: 1004328 kB Running number: 135 CmaFree: CmaFree: 998196 kB Running number: 136 CmaFree: CmaFree: 992076 kB Running number: 137 CmaFree: CmaFree: 985956 kB Running number: 138 CmaFree: CmaFree: 979848 kB Running number: 139 CmaFree: CmaFree: 973716 kB Running number: 140 CmaFree: CmaFree: 967596 kB Running number: 141 CmaFree: CmaFree: 961488 kB Running number: 142 CmaFree: CmaFree: 955356 kB Running number: 143 CmaFree: CmaFree: 949148 kB Running number: 144 CmaFree: CmaFree: 943028 kB Running number: 145 CmaFree: CmaFree: 936996 kB Running number: 146 CmaFree: CmaFree: 930876 kB Running number: 147 CmaFree: CmaFree: 924756 kB Running number: 148 CmaFree: CmaFree: 918548 kB Running number: 149 CmaFree: CmaFree: 912516 kB Running number: 150 CmaFree: CmaFree: 906308 kB Running number: 151 CmaFree: CmaFree: 900276 kB Running number: 152 CmaFree: CmaFree: 894068 kB Running number: 153 CmaFree: CmaFree: 888036 kB Running number: 154 CmaFree: CmaFree: 881724 kB Running number: 155 CmaFree: CmaFree: 875796 kB Running number: 156 CmaFree: CmaFree: 869676 kB Running number: 157 CmaFree: CmaFree: 863556 kB Running number: 158 CmaFree: CmaFree: 857436 kB Running number: 159 CmaFree: CmaFree: 851316 kB Running number: 160 CmaFree: CmaFree: 845196 kB Running number: 161 CmaFree: CmaFree: 839076 kB Running number: 162 CmaFree: CmaFree: 832956 kB Running number: 163 CmaFree: CmaFree: 826836 kB Running number: 164 CmaFree: CmaFree: 820628 kB Running number: 165 CmaFree: CmaFree: 814508 kB Running number: 166 CmaFree: CmaFree: 808476 kB Running number: 167 CmaFree: CmaFree: 802268 kB Running number: 168 CmaFree: CmaFree: 796236 kB Running number: 169 CmaFree: CmaFree: 790116 kB Running number: 170 CmaFree: CmaFree: 783996 kB Running number: 171 CmaFree: CmaFree: 777876 kB Running number: 172 CmaFree: CmaFree: 771668 kB Running number: 173 CmaFree: CmaFree: 765636 kB Running number: 174 CmaFree: CmaFree: 759516 kB Running number: 175 CmaFree: CmaFree: 753396 kB Running number: 176 CmaFree: CmaFree: 747276 kB Running number: 177 CmaFree: CmaFree: 741156 kB Running number: 178 CmaFree: CmaFree: 735036 kB Running number: 179 CmaFree: CmaFree: 728916 kB Running number: 180 CmaFree: CmaFree: 722708 kB Running number: 181 CmaFree: CmaFree: 716676 kB Running number: 182 CmaFree: CmaFree: 710556 kB Running number: 183 CmaFree: CmaFree: 704436 kB Running number: 184 CmaFree: CmaFree: 698316 kB Running number: 185 CmaFree: CmaFree: 692196 kB Running number: 186 CmaFree: CmaFree: 686076 kB Running number: 187 CmaFree: CmaFree: 679956 kB Running number: 188 CmaFree: CmaFree: 673748 kB Running number: 189 CmaFree: CmaFree: 667716 kB Running number: 190 CmaFree: CmaFree: 661596 kB Running number: 191 CmaFree: CmaFree: 655476 kB Running number: 192 CmaFree: CmaFree: 649356 kB Running number: 193 CmaFree: CmaFree: 643236 kB Running number: 194 CmaFree: CmaFree: 637116 kB Running number: 195 CmaFree: CmaFree: 630908 kB Running number: 196 CmaFree: CmaFree: 624876 kB Running number: 197 CmaFree: CmaFree: 618756 kB Running number: 198 CmaFree: CmaFree: 612636 kB Running number: 199 CmaFree: CmaFree: 606428 kB Running number: 200 CmaFree: CmaFree: 600396 kB Running number: 201 CmaFree: CmaFree: 594188 kB Running number: 202 CmaFree: CmaFree: 588156 kB Running number: 203 CmaFree: CmaFree: 581948 kB Running number: 204 CmaFree: CmaFree: 575916 kB Running number: 205 CmaFree: CmaFree: 569796 kB Running number: 206 CmaFree: CmaFree: 563676 kB Running number: 207 CmaFree: CmaFree: 557556 kB Running number: 208 CmaFree: CmaFree: 551436 kB Running number: 209 CmaFree: CmaFree: 545228 kB Running number: 210 CmaFree: CmaFree: 539108 kB Running number: 211 CmaFree: CmaFree: 533076 kB Running number: 212 CmaFree: CmaFree: 526956 kB Running number: 213 CmaFree: CmaFree: 520748 kB Running number: 214 CmaFree: CmaFree: 514716 kB Running number: 215 CmaFree: CmaFree: 508508 kB Running number: 216 CmaFree: CmaFree: 502476 kB Running number: 217 CmaFree: CmaFree: 496356 kB Running number: 218 CmaFree: CmaFree: 490236 kB Running number: 219 CmaFree: CmaFree: 484116 kB Running number: 220 CmaFree: CmaFree: 477996 kB Running number: 221 CmaFree: CmaFree: 471876 kB Running number: 222 CmaFree: CmaFree: 465756 kB Running number: 223 CmaFree: CmaFree: 459636 kB Running number: 224 CmaFree: CmaFree: 453372 kB Running number: 225 CmaFree: CmaFree: 447396 kB Running number: 226 CmaFree: CmaFree: 441276 kB Running number: 227 CmaFree: CmaFree: 435156 kB Running number: 228 CmaFree: CmaFree: 429036 kB Running number: 229 CmaFree: CmaFree: 422916 kB Running number: 230 CmaFree: CmaFree: 416796 kB Running number: 231 CmaFree: CmaFree: 410676 kB Running number: 232 CmaFree: CmaFree: 404556 kB Running number: 233 CmaFree: CmaFree: 398448 kB Running number: 234 CmaFree: CmaFree: 392316 kB Running number: 235 CmaFree: CmaFree: 386196 kB Running number: 236 CmaFree: CmaFree: 380076 kB Running number: 237 CmaFree: CmaFree: 373956 kB Running number: 238 CmaFree: CmaFree: 367836 kB Running number: 239 CmaFree: CmaFree: 361716 kB Running number: 240 CmaFree: CmaFree: 355508 kB Running number: 241 CmaFree: CmaFree: 349284 kB Running number: 242 CmaFree: CmaFree: 343268 kB Running number: 243 CmaFree: CmaFree: 337236 kB Running number: 244 CmaFree: CmaFree: 331128 kB Running number: 245 CmaFree: CmaFree: 324996 kB Running number: 246 CmaFree: CmaFree: 318876 kB Running number: 247 CmaFree: CmaFree: 312756 kB Running number: 248 CmaFree: CmaFree: 306636 kB Running number: 249 CmaFree: CmaFree: 300516 kB Running number: 250 CmaFree: CmaFree: 294308 kB Running number: 251 CmaFree: CmaFree: 288276 kB Running number: 252 CmaFree: CmaFree: 282156 kB Running number: 253 CmaFree: CmaFree: 276036 kB Running number: 254 CmaFree: CmaFree: 269916 kB Running number: 255 CmaFree: CmaFree: 263796 kB Running number: 256 CmaFree: CmaFree: 257676 kB Running number: 257 CmaFree: CmaFree: 251468 kB Running number: 258 CmaFree: CmaFree: 245436 kB Running number: 259 CmaFree: CmaFree: 239316 kB Running number: 260 CmaFree: CmaFree: 233208 kB Running number: 261 CmaFree: CmaFree: 227076 kB Running number: 262 CmaFree: CmaFree: 220868 kB Running number: 263 CmaFree: CmaFree: 214836 kB Running number: 264 CmaFree: CmaFree: 208476 kB Running number: 265 CmaFree: CmaFree: 202508 kB Running number: 266 CmaFree: CmaFree: 196476 kB Running number: 267 CmaFree: CmaFree: 190356 kB Running number: 268 CmaFree: CmaFree: 184236 kB Running number: 269 CmaFree: CmaFree: 178116 kB Running number: 270 CmaFree: CmaFree: 171996 kB Running number: 271 CmaFree: CmaFree: 165876 kB Running number: 272 CmaFree: CmaFree: 159756 kB Running number: 273 CmaFree: CmaFree: 153548 kB Running number: 274 CmaFree: CmaFree: 147516 kB Running number: 275 CmaFree: CmaFree: 141308 kB Running number: 276 CmaFree: CmaFree: 135276 kB Running number: 277 CmaFree: CmaFree: 129156 kB Running number: 278 CmaFree: CmaFree: 122948 kB Running number: 279 CmaFree: CmaFree: 116916 kB Running number: 280 CmaFree: CmaFree: 110796 kB Running number: 281 CmaFree: CmaFree: 104676 kB Running number: 282 CmaFree: CmaFree: 98556 kB Running number: 283 CmaFree: CmaFree: 92436 kB Running number: 284 CmaFree: CmaFree: 86316 kB Running number: 285 CmaFree: CmaFree: 80196 kB Running number: 286 CmaFree: CmaFree: 73988 kB Running number: 287 CmaFree: CmaFree: 67956 kB Running number: 288 CmaFree: CmaFree: 61748 kB Running number: 289 CmaFree: CmaFree: 55628 kB Running number: 290 CmaFree: CmaFree: 49596 kB Running number: 291 CmaFree: CmaFree: 43388 kB Running number: 292 CmaFree: CmaFree: 37356 kB Running number: 293 CmaFree: CmaFree: 31004 kB Running number: 294 CmaFree: CmaFree: 25124 kB Running number: 295 CmaFree: CmaFree: 18276 kB Running number: 296 CmaFree: CmaFree: 17672 kB Running number: 297 CmaFree: CmaFree: 17944 kB Running number: 298 CmaFree: CmaFree: 16464 kB Running number: 299 CmaFree: CmaFree: 15860 kB Running number: 300 CmaFree: CmaFree: 15256 kB Running number: 301 CmaFree: CmaFree: 14652 kB Running number: 302 CmaFree: CmaFree: 14048 kB Running number: 303 CmaFree: CmaFree: 13444 kB Running number: 304 CmaFree: CmaFree: 12840 kB Running number: 305 CmaFree: CmaFree: 12236 kB Running number: 306 CmaFree: CmaFree: 12032 kB Running number: 307 CmaFree: CmaFree: 12032 kB Running number: 308 CmaFree: CmaFree: 12032 kB Running number: 309 CmaFree: CmaFree: 12032 kB Running number: 310 CmaFree: CmaFree: 12032 kB Running number: 311 CmaFree: CmaFree: 12032 kB Running number: 312 CmaFree: CmaFree: 12032 kB Running number: 313 CmaFree: CmaFree: 12032 kB Running number: 314 CmaFree: CmaFree: 12032 kB Running number: 315 CmaFree: CmaFree: 12032 kB Running number: 316 CmaFree: CmaFree: 12032 kB Running number: 317 CmaFree: CmaFree: 12032 kB Running number: 318 CmaFree: CmaFree: 12032 kB Running number: 319 CmaFree: CmaFree: 12032 kB Running number: 320 CmaFree: CmaFree: 12032 kB Running number: 321 CmaFree: CmaFree: 12032 kB Running number: 322 CmaFree: CmaFree: 12032 kB Running number: 323 CmaFree: CmaFree: 12032 kB Running number: 324 CmaFree: CmaFree: 12032 kB Running number: 325 CmaFree: CmaFree: 12032 kB Running number: 326 CmaFree: CmaFree: 12032 kB Running number: 327 CmaFree: CmaFree: 12032 kB Running number: 328 CmaFree: CmaFree: 12032 kB Running number: 329 CmaFree: CmaFree: 12032 kB Running number: 330 CmaFree: CmaFree: 12032 kB Running number: 331 CmaFree: CmaFree: 12032 kB Running number: 332 CmaFree: CmaFree: 12032 kB Running number: 333 CmaFree: CmaFree: 12032 kB Running number: 334 CmaFree: CmaFree: 12032 kB Running number: 335 CmaFree: CmaFree: 12032 kB Running number: 336 CmaFree: CmaFree: 12032 kB Running number: 337 CmaFree: CmaFree: 12032 kB Running number: 338 CmaFree: CmaFree: 12032 kB Running number: 339 CmaFree: CmaFree: 12032 kB Running number: 340 CmaFree: CmaFree: 12032 kB Running number: 341 CmaFree: CmaFree: 12032 kB Running number: 342 CmaFree: CmaFree: 12032 kB Running number: 343 CmaFree: CmaFree: 12032 kB Running number: 344 CmaFree: CmaFree: 12032 kB Running number: 345 CmaFree: CmaFree: 12032 kB Running number: 346 CmaFree: CmaFree: 12032 kB Running number: 347 CmaFree: CmaFree: 12032 kB Running number: 348 CmaFree: CmaFree: 12032 kB Running number: 349 CmaFree: CmaFree: 12032 kB Running number: 350 CmaFree: CmaFree: 12032 kB Running number: 351 CmaFree: CmaFree: 12032 kB Running number: 352 CmaFree: CmaFree: 12032 kB Running number: 353 CmaFree: CmaFree: 12032 kB Running number: 354 CmaFree: CmaFree: 12032 kB Running number: 355 CmaFree: CmaFree: 12032 kB Running number: 356 CmaFree: CmaFree: 12032 kB Running number: 357 CmaFree: CmaFree: 12032 kB Running number: 358 CmaFree: CmaFree: 12032 kB Running number: 359 CmaFree: CmaFree: 12032 kB Running number: 360 CmaFree: CmaFree: 12032 kB Running number: 361 CmaFree: CmaFree: 12032 kB Running number: 362 CmaFree: CmaFree: 12032 kB Running number: 363 CmaFree: CmaFree: 12032 kB Running number: 364 CmaFree: CmaFree: 12032 kB Running number: 365 CmaFree: CmaFree: 12032 kB Running number: 366 CmaFree: CmaFree: 12032 kB Running number: 367 CmaFree: CmaFree: 12032 kB Running number: 368 CmaFree: CmaFree: 12032 kB Running number: 369 CmaFree: CmaFree: 12032 kB Running number: 370 CmaFree: CmaFree: 12032 kB Running number: 371 CmaFree: CmaFree: 12032 kB Running number: 372 CmaFree: CmaFree: 12032 kB Running number: 373 CmaFree: CmaFree: 12032 kB Running number: 374 CmaFree: CmaFree: 12032 kB Running number: 375 CmaFree: CmaFree: 12032 kB Running number: 376 CmaFree: CmaFree: 12032 kB Running number: 377 CmaFree: CmaFree: 12032 kB Running number: 378 CmaFree: CmaFree: 12032 kB Running number: 379 CmaFree: CmaFree: 12032 kB Running number: 380 CmaFree: CmaFree: 12032 kB Running number: 381 CmaFree: CmaFree: 12032 kB Running number: 382 CmaFree: CmaFree: 12032 kB Running number: 383 CmaFree: CmaFree: 12032 kB Running number: 384 CmaFree: CmaFree: 12032 kB Running number: 385 CmaFree: CmaFree: 12032 kB Running number: 386 CmaFree: CmaFree: 12032 kB Running number: 387 CmaFree: CmaFree: 12032 kB Running number: 388 CmaFree: CmaFree: 12032 kB Running number: 389 CmaFree: CmaFree: 12032 kB Running number: 390 CmaFree: CmaFree: 12032 kB Running number: 391 CmaFree: CmaFree: 12032 kB Running number: 392 CmaFree: CmaFree: 12032 kB Running number: 393 CmaFree: CmaFree: 12032 kB Running number: 394 CmaFree: CmaFree: 12032 kB Running number: 395 CmaFree: CmaFree: 12032 kB Running number: 396 CmaFree: CmaFree: 12032 kB Running number: 397 CmaFree: CmaFree: 12032 kB Running number: 398 CmaFree: CmaFree: 12032 kB Running number: 399 CmaFree: CmaFree: 12032 kB Running number: 400 CmaFree: CmaFree: 12032 kB Running number: 401 CmaFree: CmaFree: 13784 kB Running number: 402 CmaFree: CmaFree: 12032 kB Running number: 403 CmaFree: CmaFree: 12032 kB Running number: 404 CmaFree: CmaFree: 12032 kB Running number: 405 CmaFree: CmaFree: 12032 kB Running number: 406 CmaFree: CmaFree: 12032 kB Running number: 407 CmaFree: CmaFree: 12032 kB Running number: 408
U-Boot SPL 2023.04-g756ba776d4 (Jul 13 2023 - 05:36:12 +0000)
ti_i2c_eeprom_am6_get: Ignoring record id 255
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
SPL initial stack usage: 13424 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb-dirty
NOTICE: BL31: Built : 00:42:57, Jan 13 2023
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2023.04-g756ba776d4 (Jul 13 2023 - 05:36:12 +0000)
SoC: J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
Board: J784S4X-EVM rev E3
DRAM: 32 GiB
idle-statesCore: 88 devices, 31 uclasses, devicetree: separate
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Unidentified board claims J784S4X-EVM in eeprom header
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1477 bytes read in 21 ms (68.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
## Error: "main_cpsw0_qsgmii_phyinit" not defined
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
1555864 bytes read in 38 ms (39 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1555864 bytes: Success!
400444 bytes read in 27 ms (14.1 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 400444 bytes: Success!
191564 bytes read in 25 ms (7.3 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 191564 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 191564 bytes: Success!
547820 bytes read in 28 ms (18.7 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 547820 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 191564 bytes: Success!
14815504 bytes read in 175 ms (80.7 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 14815504 bytes: Success!
15208720 bytes read in 180 ms (80.6 MiB/s)
Load Remote Processor 9 with data@addr=0x82000000 15208720 bytes: Success!
14815504 bytes read in 176 ms (80.3 MiB/s)
Load Remote Processor 10 with data@addr=0x82000000 14815504 bytes: Success!
Load Remote Processor 11 with data@addr=0x82000000 14815504 bytes: Success!
20593152 bytes read in 235 ms (83.6 MiB/s)
103302 bytes read in 23 ms (4.3 MiB/s)
Working FDT set to 88000000
13362 bytes read in 22 ms (592.8 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=80000000 flags=4)
Loading Device Tree to 000000008fee3000, end 000000008fffffff ... OK
Working FDT set to 8fee3000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.1.33-g8f7f371be2 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Jul 14 00:39:55 UTC 2023
[ 0.000000] Machine model: Texas Instruments J784S4 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 47 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b7100000, size 47 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@ba000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba100000, size 47 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@ba100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bd000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@bd000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bd100000, size 47 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@bd100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e0000000, size 80 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e5000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e5800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e5800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 2048 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 1792 MiB
[ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000fffffefff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000bfffffff]
[ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000dfffffff]
[ 0.000000] node 0: [mem 0x00000000e0000000-0x00000000e6ffffff]
[ 0.000000] node 0: [mem 0x00000000e7000000-0x00000000ffffefff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] node 0: [mem 0x0000000900000000-0x0000000fffffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
[ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8257534
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 root=PARTUUID=27d080c5-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 8.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 27712516K/33554424K available (12480K kernel code, 1294K rwdata, 4048K rodata, 2176K init, 498K bss, 4006900K reserved, 1835008K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @920800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000920050000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000920060000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008408] Console: colour dummy device 80x25
[ 0.012975] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023647] pid_max: default: 32768 minimum: 301
[ 0.028389] LSM: Security Framework initializing
[ 0.033204] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.041004] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.050118] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.057520] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.063783] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.070092] rcu: Hierarchical SRCU implementation.
[ 0.074989] rcu: Max phase no-delay instances is 1000.
[ 0.080475] Platform MSI: msi-controller@1820000 domain created
[ 0.086654] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.096401] EFI services will not be available.
[ 0.101230] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
[ 0.114304] Detected PIPT I-cache on CPU1
[ 0.114354] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.114367] GICv3: CPU1: using allocated LPI pending table @0x0000000920070000
[ 0.114397] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.122844] Detected PIPT I-cache on CPU2
[ 0.122887] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[ 0.122900] GICv3: CPU2: using allocated LPI pending table @0x0000000920080000
[ 0.122923] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[ 0.131326] Detected PIPT I-cache on CPU3
[ 0.131368] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[ 0.131381] GICv3: CPU3: using allocated LPI pending table @0x0000000920090000
[ 0.131403] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[ 0.139850] Detected PIPT I-cache on CPU4
[ 0.139929] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[ 0.139943] GICv3: CPU4: using allocated LPI pending table @0x00000009200a0000
[ 0.139974] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[ 0.148426] Detected PIPT I-cache on CPU5
[ 0.148477] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[ 0.148489] GICv3: CPU5: using allocated LPI pending table @0x00000009200b0000
[ 0.148512] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[ 0.156937] Detected PIPT I-cache on CPU6
[ 0.156990] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[ 0.157002] GICv3: CPU6: using allocated LPI pending table @0x00000009200c0000
[ 0.157025] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[ 0.165451] Detected PIPT I-cache on CPU7
[ 0.165503] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[ 0.165516] GICv3: CPU7: using allocated LPI pending table @0x00000009200d0000
[ 0.165539] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[ 0.165585] smp: Brought up 1 node, 8 CPUs
[ 0.346573] SMP: Total of 8 processors activated.
[ 0.351379] CPU features: detected: 32-bit EL0 Support
[ 0.356635] CPU features: detected: CRC32 instructions
[ 0.361936] CPU: All CPU(s) started at EL2
[ 0.366125] alternatives: applying system-wide alternatives
[ 0.372794] devtmpfs: initialized
[ 0.385830] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.395807] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.424423] pinctrl core: initialized pinctrl subsystem
[ 0.430070] DMI not present or invalid.
[ 0.434311] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.441626] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.449648] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.458366] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.466595] audit: initializing netlink subsys (disabled)
[ 0.472215] audit: type=2000 audit(0.336:1): state=initialized audit_enabled=0 res=1
[ 0.472417] thermal_sys: Registered thermal governor 'step_wise'
[ 0.480141] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.486361] cpuidle: using governor menu
[ 0.497099] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.504126] ASID allocator initialised with 65536 entries
[ 0.517927] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.528215] platform a000000.dp-bridge: Fixed dependency cycle(s) with /dp0-connector
[ 0.536714] KASLR disabled due to lack of seed
[ 0.544217] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.551167] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.557572] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.564507] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.570910] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.577845] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.584248] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.591182] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.598422] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[ 0.607797] iommu: Default domain type: Translated
[ 0.612783] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.619301] SCSI subsystem initialized
[ 0.623282] usbcore: registered new interface driver usbfs
[ 0.628900] usbcore: registered new interface driver hub
[ 0.634339] usbcore: registered new device driver usb
[ 0.639726] pps_core: LinuxPPS API ver. 1 registered
[ 0.644797] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.654135] PTP clock support registered
[ 0.658210] EDAC MC: Ver: 3.0.0
[ 0.661901] FPGA manager framework
[ 0.665408] Advanced Linux Sound Architecture Driver Initialized.
[ 0.672024] clocksource: Switched to clocksource arch_sys_counter
[ 0.678372] VFS: Disk quotas dquot_6.6.0
[ 0.682397] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.692336] Carveout Heap: Exported 512 MiB at 0x0000000900000000
[ 0.698617] NET: Registered PF_INET protocol family
[ 0.703946] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.716652] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.725682] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.733612] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.742716] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.751114] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.757991] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.765344] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.773224] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.779282] RPC: Registered named UNIX socket transport module.
[ 0.785337] RPC: Registered udp transport module.
[ 0.790140] RPC: Registered tcp transport module.
[ 0.794943] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.801528] NET: Registered PF_XDP protocol family
[ 0.806430] PCI: CLS 0 bytes, default 64
[ 0.811065] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.820317] Initialise system trusted keyrings
[ 0.824970] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.834053] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.840290] NFS: Registering the id_resolver key type
[ 0.845468] Key type id_resolver registered
[ 0.849740] Key type id_legacy registered
[ 0.853863] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.860712] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.868333] 9p: Installing v9fs 9p2000 file system support
[ 0.893272] Key type asymmetric registered
[ 0.897455] Asymmetric key parser 'x509' registered
[ 0.902462] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.910088] io scheduler mq-deadline registered
[ 0.914718] io scheduler kyber registered
[ 0.920891] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[ 0.926846] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[ 0.932831] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[ 0.938854] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[ 0.944663] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.950854] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.960831] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.971765] loop: module loaded
[ 0.975667] megasas: 07.719.03.00-rc1
[ 0.981401] tun: Universal TUN/TAP device driver, 1.6
[ 0.986883] thunder_xcv, ver 1.0
[ 0.990193] thunder_bgx, ver 1.0
[ 0.993502] nicpf, ver 1.0
[ 0.996499] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 1.003880] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.009327] hclge is initializing
[ 1.012717] e1000: Intel(R) PRO/1000 Network Driver
[ 1.017698] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.023581] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.028654] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.034759] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.040280] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.045987] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.052390] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.058513] sky2: driver version 1.30
[ 1.062645] VFIO - User Level meta-driver version: 0.3
[ 1.068205] usbcore: registered new interface driver usb-storage
[ 1.074752] i2c_dev: i2c /dev entries driver
[ 1.080068] sdhci: Secure Digital Host Controller Interface driver
[ 1.086382] sdhci: Copyright(c) Pierre Ossman
[ 1.091087] Synopsys Designware Multimedia Card Interface Driver
[ 1.097476] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.103823] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.110052] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.116777] usbcore: registered new interface driver usbhid
[ 1.122470] usbhid: USB HID core driver
[ 1.127104] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 1.131663] optee: revision 3.20 (8e74d476)
[ 1.148067] optee: dynamic shared memory is enabled
[ 1.157537] optee: initialized driver
[ 1.162260] Initializing XFRM netlink socket
[ 1.166641] NET: Registered PF_PACKET protocol family
[ 1.171868] 9pnet: Installing 9P2000 support
[ 1.176262] Key type dns_resolver registered
[ 1.180791] registered taskstats version 1
[ 1.184991] Loading compiled-in X.509 certificates
[ 1.195136] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
[ 1.226976] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.233284] pca953x 0-0020: supply vcc not found, using dummy regulator
[ 1.240126] pca953x 0-0020: using no AI
[ 1.268659] pca953x 0-0022: supply vcc not found, using dummy regulator
[ 1.275458] pca953x 0-0022: using AI
[ 1.279755] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.285802] pca953x 2-0020: supply vcc not found, using dummy regulator
[ 1.292605] pca953x 2-0020: using no AI
[ 1.320488] omap_i2c 2040000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.326590] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 1.333392] pca953x 3-0020: using no AI
[ 1.360335] omap_i2c 2050000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.366137] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[ 1.374675] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[ 1.383918] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[ 1.392557] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[ 1.406402] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 1.413170] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 1.422331] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[ 1.432207] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.438967] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.447792] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[ 1.457936] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.464695] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.472571] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 216, base_baud = 6000000) is a 8250
[ 1.481991] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 217, base_baud = 3000000) is a 8250
[ 1.490846] printk: console [ttyS2] enabled
[ 1.499289] printk: bootconsole [ns16550a0] disabled
[ 1.548030] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.556883] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.565150] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.577994] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.585200] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.591342] pps pps0: new PPS source ptp0
[ 1.595475] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 1.644030] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.652673] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 1.660766] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.673510] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 1.679764] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 1.686881] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 1.692992] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[ 1.703166] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[ 1.812814] mmc0: CQHCI version 5.10
[ 1.857337] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.952328] mmc0: Command Queue Engine enabled
[ 1.956771] mmc0: new HS400 MMC card at address 0001
[ 1.962059] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 1.968835] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 1.976223] GPT:29360127 != 62160895
[ 1.979785] GPT:Alternate GPT header not at the end of the disk.
[ 1.985774] GPT:29360127 != 62160895
[ 1.989338] GPT: Use GNU Parted to correct GPT errors.
[ 1.994479] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.002912] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[ 2.008515] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[ 2.014001] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[ 2.107947] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[ 2.113908] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
[ 2.122179] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 2.128966] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 2.135753] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 2.142539] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[ 2.149321] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 2.156099] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[ 2.165065] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[ 2.174988] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[ 2.186535] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ef dc 21 00 00
[ 2.195152] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 2.200236] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[ 2.207273] Creating 7 MTD partitions on "47050000.spi.0":
[ 2.212749] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[ 2.218909] 0x000000080000-0x000000280000 : "qspi.tispl"
[ 2.224730] 0x000000280000-0x000000680000 : "qspi.u-boot"
[ 2.230656] 0x000000680000-0x0000006c0000 : "qspi.env"
[ 2.236301] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
[ 2.242563] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[ 2.248471] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[ 2.292035] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.300910] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.309180] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.322043] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.329250] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.335395] pps pps0: new PPS source ptp1
[ 2.339530] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 2.349482] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 2.396032] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.404674] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 2.412766] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.425520] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 2.431773] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 2.438891] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 2.445021] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 2.454859] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[ 2.462485] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present!
[ 2.469744] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[ 2.469881] mmc1: CQHCI version 5.10
[ 2.477017] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[ 2.488223] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[ 2.495534] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[ 2.502838] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[ 2.516352] ALSA device list:
[ 2.519314] No soundcards found.
[ 2.521423] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 2.530346] Waiting for root device PARTUUID=27d080c5-02...
[ 2.582352] mmc1: new ultra high speed SDR104 SDHC card at address 5048
[ 2.589341] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[ 2.595359] mmcblk1: p1 p2
[ 2.859753] EXT4-fs (mmcblk1p2): recovery complete
[ 2.865336] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.873880] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 2.884139] devtmpfs: mounted
[ 2.887889] Freeing unused kernel memory: 2176K
[ 2.892508] Run /sbin/init as init process
[ 3.047866] systemd[1]: System time before build time, advancing clock.
[ 3.084783] NET: Registered PF_INET6 protocol family
[ 3.090323] Segment Routing with IPv6
[ 3.093998] In-situ OAM (IOAM) with IPv6
[ 3.120148] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 3.151578] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.04!
[ 3.224856] systemd[1]: Hostname set to <j784s4-evm>.
[ 3.293157] systemd-sysv-generator[191]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.317725] systemd-sysv-generator[191]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.341896] systemd-sysv-generator[191]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.365656] systemd-sysv-generator[191]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.389971] systemd-sysv-generator[191]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.414056] systemd-sysv-generator[191]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.437794] systemd-sysv-generator[191]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.461624] systemd-sysv-generator[191]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.486092] systemd-sysv-generator[191]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.509928] systemd-sysv-generator[191]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.536609] systemd-sysv-generator[191]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.560829] systemd-sysv-generator[191]: SysV service '/etc/init.d/autolaunch-demo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.585380] systemd-sysv-generator[191]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.609648] systemd-sysv-generator[191]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.634480] systemd-sysv-generator[191]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.658304] systemd-sysv-generator[191]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.682211] systemd-sysv-generator[191]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.821830] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.863401] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.910060] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.956112] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 3.977305] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 4.001111] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 4.024915] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.048182] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 4.072136] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 4.096210] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 4.112089] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.132074] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 4.148083] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 4.185721] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 4.208135] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 4.231101] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 4.252178] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 4.276341] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 4.296249] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.316267] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.332305] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.356309] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.376192] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.396223] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 4.432259] systemd[1]: Mounting Huge Pages File System...
[ 4.450359] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.474360] systemd[1]: Mounting Kernel Debug File System...
[ 4.492255] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.507904] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.526823] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.550272] systemd[1]: Starting Load Kernel Module configfs...
[ 4.570205] systemd[1]: Starting Load Kernel Module drm...
[ 4.586310] systemd[1]: Starting Load Kernel Module fuse...
[ 4.595894] fuse: init (API version 7.37)
[ 4.608233] systemd[1]: Starting Start psplash boot splash screen...
[ 4.635373] systemd[1]: Starting RPC Bind...
[ 4.648206] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 4.663856] systemd[1]: Starting Journal Service...
[ 4.684731] systemd[1]: Starting Load Kernel Modules...
[ 4.696595] cryptodev: loading out-of-tree module taints kernel.
[ 4.703401] cryptodev: driver 1.12 loaded.
[ 4.710267] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel command line...
[ 4.738730] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting Remount Root and Kernel File Systems EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[0m...
[ 4.774898] systemd[1]: Starting Coldplug All udev Devices...
[ 4.800271] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 4.816339] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 5.129253] systemd-journald[211]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /media/ram...
Mounting /var/volatile...
[ 5.358299] audit: type=1334 audit(1651167747.308:2): prog-id=5 op=LOAD
[ 5.364932] audit: type=1334 audit(1651167747.316:3): prog-id=6 op=LOAD
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Rule-based Manager for Device Events and Files.
[ 5.523181] random: crng init done
[ OK ] Finished Create Volatile Files and [ 5.532748] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
Directories.
[ 5.543505] j721e-pcie-host 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 5.553482] j721e-pcie-host 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ OK ] Finished Load/Save Random Seed.[ 5.562250] j721e-pcie-host 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ OK ] Found device /dev/ttyS2.
[ 5.593134] pinctrl-single 4301c068.pinctrl: mux offset out of range: 0x134 (0x120)
[ 5.604885] pinctrl-single 4301c068.pinctrl: could not add functions for mcu-adc0-pins-default 308x
[ 5.615209] pinctrl-single 4301c068.pinctrl: mux offset out of range: 0x154 (0x120)
[ 5.623110] pinctrl-single 4301c068.pinctrl: could not add functions for mcu-adc1-pins-default 340x
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ 5.659501] mc: Linux media interface: v0.10
[ 5.664708] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
[ 5.680630] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 5.681966] PVR_K: 263: Device: 4e20000000.gpu
[ 5.682119] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.682230] platform 41000000.r5f: configured R5F for IPC-only mode
[ 5.682363] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 5.683189] remoteproc remoteproc1: 41000000.r5f is available
[ 5.683232] remoteproc remoteproc1: attaching to 41000000.r5f
[ 5.683479] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 5.683486] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 5.683848] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 5.683861] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
[ 5.683865] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[ 5.685321] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 5.685447] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 5.686398] remoteproc remoteproc2: 5c00000.r5f is available
[ 5.686435] remoteproc remoteproc2: attaching to 5c00000.r5f
[ 5.686627] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 5.686634] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 5.686964] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 5.686982] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
[ 5.686986] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached
[ 5.687142] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 5.687220] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 5.689573] remoteproc remoteproc0: 64800000.dsp is available
[ 5.692715] PVR_K: 263: Read BVNC 36.53.104.796 from HW device registers
[ 5.703589] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 5.704082] remoteproc remoteproc0: attaching to 64800000.dsp
[ 5.704184] remoteproc remoteproc3: 5d00000.r5f is available
[ 5.704230] remoteproc remoteproc3: attaching to 5d00000.r5f
[ 5.704384] remoteproc remoteproc0: unsupported resource 65538
[ 5.704521] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 5.704566] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
[ 5.704575] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 5.704586] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 5.705282] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 5.705300] rproc-virtio rproc-virtio.10.auto: registered virtio3 (type 7)
[ 5.705305] remoteproc remoteproc3: remote processor 5d00000.r5f is now attached
[ 5.705664] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 5.705680] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
[ 5.705683] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
[ 5.719198] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b7000000
[ 5.719802] videodev: Linux video capture interface: v2.00
[ 5.724767] PVR_K: 263: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ 5.724971] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 5.725099] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[ 5.725326] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 5.725385] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 5.725790] platform 5e00000.r5f: configured R5F for IPC-only mode
[ 5.725924] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 5.726472] remoteproc remoteproc5: 5e00000.r5f is available
[ 5.726515] remoteproc remoteproc5: attaching to 5e00000.r5f
[ 5.726818] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[ 5.726826] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 5.727159] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 5.727181] rproc-virtio rproc-virtio.11.auto: registered virtio4 (type 7)
[ 5.727185] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached
[ 5.727362] platform 5f00000.r5f: configured R5F for IPC-only mode
[ 5.727450] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 5.727940] remoteproc remoteproc6: 5f00000.r5f is available
[ 5.727984] remoteproc remoteproc6: attaching to 5f00000.r5f
[ 5.728933] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[ 5.728943] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 5.729355] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 5.729375] rproc-virtio rproc-virtio.12.auto: registered virtio5 (type 7)
[ 5.729379] remoteproc remoteproc6: remote processor 5f00000.r5f is now attached
[ 5.731670] platform 5900000.r5f: configured R5F for IPC-only mode
[ 5.737205] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 5.740093] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
[ 5.740171] remoteproc remoteproc4: 65800000.dsp is available
[ 5.740216] remoteproc remoteproc4: attaching to 65800000.dsp
[ 5.740430] remoteproc remoteproc4: unsupported resource 65538
[ 5.740518] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
[ 5.740528] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b7000000
[ 5.740834] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 5.740848] rproc-virtio rproc-virtio.13.auto: registered virtio6 (type 7)
[ 5.740852] remoteproc remoteproc4: remote processor 65800000.dsp is now attached
[ 5.747537] [drm] Initialized pvr 23.1.6404501 20170530 for 4e20000000.gpu on minor 0
[ 5.747646] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba000000
[ 5.748868] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[ 5.750303] remoteproc remoteproc7: 5900000.r5f is available
[ 5.750349] remoteproc remoteproc7: attaching to 5900000.r5f
[ 5.750663] platform 5900000.r5f: R5F core initialized in IPC-only mode
[ 5.750671] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[ 5.751020] virtio_rpmsg_bus virtio7: rpmsg host is online
[ 5.751040] rproc-virtio rproc-virtio.14.auto: registered virtio7 (type 7)
[ 5.751044] remoteproc remoteproc7: remote processor 5900000.r5f is now attached
[ 5.753064] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[ 5.753096] platform 5a00000.r5f: configured R5F for IPC-only mode
[ 5.753178] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[ 5.754687] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
[ 5.754739] remoteproc remoteproc8: 66800000.dsp is available
[ 5.754784] remoteproc remoteproc8: attaching to 66800000.dsp
[ 5.755030] remoteproc remoteproc8: unsupported resource 65538
[ 5.755156] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
[ 5.755168] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@ba000000
[ 5.755480] virtio_rpmsg_bus virtio8: rpmsg host is online
[ 5.755500] rproc-virtio rproc-virtio.15.auto: registered virtio8 (type 7)
[ 5.755504] remoteproc remoteproc8: remote processor 66800000.dsp is now attached
[ 5.755909] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bd000000
[ 5.757533] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[ 5.758849] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
[ 5.760054] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
[ 5.770158] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
[ 5.774465] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[ 5.777731] remoteproc remoteproc10: 67800000.dsp is available
[ 5.777783] remoteproc remoteproc10: attaching to 67800000.dsp
[ 5.777963] remoteproc remoteproc10: unsupported resource 65538
[ 5.778056] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
[ 5.778068] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@bd000000
[ 5.779780] virtio_rpmsg_bus virtio9: rpmsg host is online
[ 5.779796] rproc-virtio rproc-virtio.16.auto: registered virtio9 (type 7)
[ 5.779800] remoteproc remoteproc10: remote processor 67800000.dsp is now attached
[ 5.784948] remoteproc remoteproc9: 5a00000.r5f is available
[ 5.788117] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
[ 5.788203] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 5.793760] remoteproc remoteproc9: attaching to 5a00000.r5f
[ 5.801632] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[ 5.811624] platform 5a00000.r5f: R5F core initialized in IPC-only mode
[ 5.817070] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 5.827752] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
[ 6.212905] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 6.214101] virtio_rpmsg_bus virtio10: rpmsg host is online
[ 6.220617] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
[ 6.220931] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
[ 6.221054] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
[ 6.221119] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[ 6.221389] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[ 6.221495] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
[ 6.232272] rproc-virtio rproc-virtio.17.auto: registered virtio10 (type 7)
[ 6.241745] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.246070] remoteproc remoteproc9: remote processor 5a00000.r5f is now attached
[ 6.263839] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 6.580149] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00
[ 6.582186] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[ 6.588131] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.595990] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.602969] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 6.602974] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 6.603016] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 6.610147] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.616779] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 6.616900] pci 0000:00:00.0: supports D1
[ 6.624154] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 6.629375] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 6.631262] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.637297] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[ 6.646571] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 6.653302] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.659265] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 6.666859] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ OK ] Finished Record System Boot/Shutdow[ 6.734797] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
n in UTMP.
[ 6.747975] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.756854] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.757018] pcieport 0000:00:00.0: PME: Signaling with IRQ 631
[ 6.764377] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.770344] pcieport 0000:00:00.0: AER: enabled with IRQ 631
[ 6.777861] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[ 6.790762] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 6.793661] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e
[ 6.798716] j721e-pcie-host 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ OK ] Started Network Time Synchronizatio[ 6.815226] j721e-pcie-host 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
n.
[ 6.821074] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
[ 6.829280] j721e-pcie-host 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 6.879337] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
[ 6.896468] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[ 6.912180] [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* remote dsi host node not found
[ 6.931690] cdns-csi2rx: probe of 4524000.csi-bridge failed with error -22
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Started Daily rotation of log files[ 7.037921] mmc0: running CQE recovery
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API...
[ OK ] Listening on dropbear.socket.
Starting Weston socket...
Starting Console System Startup Logging...
Starting D-Bus System Message Bus...
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Listening on Weston socket.
[ OK ] Finished Console System Startup Logging.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Finished Reboot and dump vmcore via kexec.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Telephony service...
Starting Expand the rootfs…ll size of the boot device....
[ OK ] Started startwlanap.[ 7.479297] audit: type=1334 audit(1651182507.140:4): prog-id=7 op=LOAD
[ OK ] Started startwlansta.
[ 7.493717] audit: type=1334 audit(1651182507.152:5): prog-id=8 op=LOAD
Starting User Login Management...
[ OK ] Started TEE Supplicant.
Starting telnetd.service...
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Started telnetd.service.
[ OK ] Finished Expand the rootfs…full size of the boot device..
[ OK ] Started 7.729316] Bluetooth: Core ver 2.22
39mTelephony service.
[ OK ] Started [ 7.734832] NET: Registered PF_BLUETOOTH protocol family
[ OK ] Created slice 7.745631] Bluetooth: HCI device and connection manager initialized
0;1;39mSlice /system/systemd-fsck.
[ OK ] Reac[ 7.757505] Bluetooth: HCI socket layer initialized
hed target Preparation for Network.
[ OK [ 7.767910] Bluetooth: L2CAP socket layer initialized
] Listening on Load/Save RF …itch Status /dev/rfk[ 7.778506] Bluetooth: SCO socket layer initialized
ill Watch.
Starting File System Check on /dev/mmcblk0p12...
Starting File System Check on /dev/mmcblk0p13...
Starting File System Check on /dev/mmcblk0p14...
Starting File System Check on /dev/mmcblk0p15...
Starting File [ 7.848313] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0001:00
System Check on /dev/mmcblk0p16...
Starting 7.860210] pci_bus 0001:00: root bus resource [bus 00-ff]
39mFile System Check on /dev/mmcblk0p17...
[ 7.871283] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 7.884998] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 7.891918] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400
[ 7.897937] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
Starting File System Check on /dev/mmcblk0p3 7.907727] pci 0001:00:00.0: supports D1
0m...
[ 7.917197] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 7.917238] pci 0001:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 7.930366] pci 0001:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 7.932754] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Starting File System Check on /dev/mmcblk0p4 7.948495] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
0m...
[ 7.960367] pci 0001:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[ 7.968215] pci 0001:00:00.0: PCI bridge to [bus 01]
Starting File System Check on /dev/mmcblk1p1 7.973713] pcieport 0001:00:00.0: PME: Signaling with IRQ 636
0m...
Starting Network Configuration...
[ 7.986176] pcieport 0001:00:00.0: AER: enabled with IRQ 636
[ OK ] Finished File System Check on /dev/mmcblk0p4.
Mounting /run/media/firmware_b-mmcblk0p4...
[ OK ] Finished File System Check on /dev/mmcblk0p17.
Mounting /run/media/data-mmcblk0p17...
[ OK ] Finished File System Check on /dev/mmcblk0p13.
[ OK ] Finished File System Check on /dev/mmcblk0p12.
[ OK ] Finished File System Check on /dev/mmcblk0p15.
[ OK ] Finished File System Check on /dev/mmcblk0p3.
Mounting /run/media/App_b-mmcblk0p15...
Mounting /run/media/firmware_a-mmcblk0p3[ 8.078608] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Quota mode: none.
Mounting /run/media/system_a-mmcblk0p12 8.083453] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Quota mode: none.
0m...
Mounting /run/media/system_b-mmcblk0p13[ 8.083947] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Quota mode: none.
[ OK ] Finished File System Check[ 8.097741] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: none.
on /dev/mmcblk0p16.
[ 8.109459] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Quota mode: none.
[ 8.110929] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Quota mode: none.
[ 8.119789] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Quota mode: none.
[ 8.133918] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mounting /run/media/update-mmcblk0p16...
[ 8.172095] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ OK ] Finished File System Check on /dev/mmcblk0p14.
[ OK ] Finished File System Check on /dev/mmcblk1p1.
[ OK ] Mounted /run/media/firmware_b-mmcblk0p4.
[ OK ] Mounted /run/media/data-mmcblk0p17.
[ OK ] Mounted /run/media/App_b-mmcblk0p15.
[ OK ] Mounted /run/media/firmware_a-mmcblk0p3.
[ OK ] Mounted /run/media/system_a-mmcblk0p12.
[ OK ] Mounted /run/media/sy[ 8.228478] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
stem_b-mmcblk0p13.
[ OK ] Mounted /ru[ 8.235737] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Quota mode: none.
Mounting /run/[ 8.239160] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
media/App_a-mmcblk0p14...
Mounting /run/media/boot-mmcblk1p1...
[ OK ] Started Network Configuration.
[ OK ] Mounted 8.279915] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
9m/run/media/App_a-mmcblk0p14.
[ OK ] Mounted [ 8.293189] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
Starting containerd container runtime...
[ OK ] Started Netperf Benchmark Server.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions...
[ OK ] Finished Enable and configure wl18xx bluetooth stack.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
Starting Weston, a Wayland…ositor, as a system service...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 8.669094] audit: type=1334 audit(1651182508.332:6): prog-id=9 op=LOAD
[ 8.675743] audit: type=1334 audit(1651182508.336:7): prog-id=10 op=LOAD
Starting User Database Manager...
[ OK ] Started User Database Manager.
[ OK ] Created slice User Slice of UID 1000.
Starting User Runtime Directory /run/user/1000...
[ OK ] Finished User Runtime Directory /run/user/1000.
Starting User Manager for UID 1000...
[ 8.924999] audit: type=1006 audit(1651182508.588:8): pid=1256 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 8.937987] audit: type=1300 audit(1651182508.588:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe8844738 a2=4 a3=ffff828bf020 items=0 ppid=1 pid=1256 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 8.964557] audit: type=1327 audit(1651182508.588:8): proctitle="(systemd)"
[ OK ] Finished Synchronize System and HW clocks.
[ OK ] Started User Manager for UID 1000.
[ OK ] Started Session c1 of User wes[ 9.394486] audit: type=1006 audit(1651182509.056:9): pid=1245 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
ton.
[ 9.412193] audit: type=1300 audit(1651182509.056:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe8844738 a2=4 a3=ffff828bf020 items=0 ppid=1 pid=1245 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[ 9.439324] audit: type=1327 audit(1651182509.056:9): proctitle="(weston)"
[ OK ] Started containerd container runtime.
[ 9.767319] PVR_K: 1245: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[ 9.780086] PVR_K: 1245: Shader binary image 'rgx.sh.36.53.104.796' loaded
[ OK ] Started Weston, a Wayland …mpositor, as a system service.
Starting DEMO...
[ OK ] Started DEMO.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gnu-config
grub-common
grub-editenv
grub-efi
gzip
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libeigen-dev
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libopcodes
libqt5charts-examples
libqt5charts-plugins
libqt5charts-qmlplugins
libqt5charts5
libqt5sensors-plugins
libqt5sensors-qmlplugins
libqt5sensors5
libqt5serialport-examples
libqt5serialport-plugins
libqt5serialport-qmlplugins
libqt5serialport5
libqt5svg-examples
libqt5svg-plugins
libqt5svg-qmlplugins
libqt5svg5
libqt5virtualkeyboard-plugins
libqt5virtualkeyboard-qmlplugins
libqt5virtualkeyboard5
libqt5webchannel-plugins
libqt5webchannel-qmlplugins
libqt5webchannel5
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libunistring2
m4-dev
m4
make
nettle
parted
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase
qtconnectivity-plugins
qtconnectivity-qmlplugins
qtconnectivity
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-tools
qtdeclarative
qtgraphicaleffects-qmlplugins
qtlocation-examples
qtlocation-plugins
qtlocation-qmlplugins
qtlocation
qtmultimedia-examples
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquics-qmlplugins.control
qtquics2-plugins.control
qtquics2-qmlplugins.control
qtquics2.control
qtscript-examples
qtscript-plugins
qtscript-qmlplugins
qtscript
qtwayland-examples
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Finished Print notice about GPLv3 packages.
[ 12.361504] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.370140] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j784s4-evm -
Arago 2023.04 j784s4-evm -
j784s4-evm login: root
[ 15.576740] audit: type=1006 audit(1651182515.240:10): pid=1664 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[ 15.589193] audit: type=1300 audit(1651182515.240:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe8844738 a2=1 a3=ffff828bf020 items=0 ppid=1 pid=1664 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 15.615571] audit: type=1327 audit(1651182515.240:10): proctitle="(systemd)"
[ 15.622632] audit: type=1334 audit(1651182515.248:11): prog-id=11 op=LOAD
[ 15.629420] audit: type=1300 audit(1651182515.248:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe84aa220 a2=78 a3=0 items=0 ppid=1 pid=1664 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[ 15.654837] audit: type=1327 audit(1651182515.248:11): proctitle="(systemd)"
[ 15.661883] audit: type=1334 audit(1651182515.252:12): prog-id=11 op=UNLOAD
[ 15.668838] audit: type=1334 audit(1651182515.252:13): prog-id=12 op=LOAD
[ 15.675624] audit: type=1300 audit(1651182515.252:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe84aa2c0 a2=78 a3=0 items=0 ppid=1 pid=1664 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[ 15.701043] audit: type=1327 audit(1651182515.252:13): proctitle="(systemd)"
root@j784s4-evm:~# ifconfig eth 192.168.1.10
SIOCSIFADDR: No such device
eth: ERROR while getting interface flags: No such device
root@j784s4-evm:~# ifconfig eth1 192.168.1.10
root@j784s4-evm:~# ping 192.168.1.102
PING 192.168.1.102 (192.168.1.102): 56 data bytes
64 bytes from 192.168.1.102: seq=0 ttl=128 time=1.307 ms
64 bytes from 192.168.1.102: seq=1 ttl=128 time=0.806 ms
^C
--- 192.168.1.102 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.806/1.056/1.307 ms
root@j784s4-evm:~# ^C
root@j784s4-evm:~# [ 1534.625059] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 190 pages, ret: -12
[ 1534.634448] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 190 pages, ret: -12
[ 1537.662883] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 760 pages, ret: -12
[ 1537.672926] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 760 pages, ret: -12
[ 1537.702475] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 190 pages, ret: -12
[ 1537.711845] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 190 pages, ret: -12
[ 1540.736888] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1540.746122] ------------[ cut here ]------------
[ 1540.750722] WARNING: CPU: 6 PID: 3257 at mm/page_alloc.c:5535 __alloc_pages+0x44c/0xcec
[ 1540.758716] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1540.830419] CPU: 6 PID: 3257 Comm: videotestsrc0:s Tainted: G O 6.1.33-g8f7f371be2 #1
[ 1540.839616] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1540.845257] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1540.852200] pc : __alloc_pages+0x44c/0xcec
[ 1540.856284] lr : __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1540.862363] sp : ffff80000c3c3370
[ 1540.865662] x29: ffff80000c3c3370 x28: 000000000000000c x27: 0000000000110000
[ 1540.872781] x26: 0000000000220000 x25: 0000000000000440 x24: ffff8000080d2a1c
[ 1540.879899] x23: ffff0008a02b4c10 x22: ffff80000c3c35d0 x21: ffff0008a02b4c10
[ 1540.887017] x20: 0000000000000cc0 x19: 0000000000000000 x18: ffffffffffffffff
[ 1540.894134] x17: 732d716572202c64 x16: 656c69616620636f x15: 6c6c61203a303030
[ 1540.901251] x14: 3030303038394073 x13: ffff800009281550 x12: 00000000000008c1
[ 1540.908368] x11: 00000000000002eb x10: ffff8000092d9550 x9 : ffff800009281550
[ 1540.915485] x8 : 0000000000000000 x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1540.922602] x5 : 0000000000000003 x4 : 0000000000000000 x3 : 0000000000000000
[ 1540.929720] x2 : ffff0008aae163c0 x1 : 0000000000000001 x0 : ffff80000938e000
[ 1540.936837] Call trace:
[ 1540.939271] __alloc_pages+0x44c/0xcec
[ 1540.943007] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1540.948737] dma_direct_alloc+0xd8/0x304
[ 1540.952645] dma_alloc_attrs+0x7c/0xe4
[ 1540.956381] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1540.962040] wave5_vpu_enc_register_framebuffer+0x2b8/0x6f0 [wave5]
[ 1540.968295] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1540.974636] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1540.980110] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1540.985761] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1540.990632] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1540.996284] v4l_reqbufs+0x50/0x64 [videodev]
[ 1541.000652] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1541.005623] video_usercopy+0x214/0x6c4 [videodev]
[ 1541.010418] video_ioctl2+0x18/0x2c [videodev]
[ 1541.014868] v4l2_ioctl+0x40/0x60 [videodev]
[ 1541.019144] __arm64_sys_ioctl+0xa8/0xf0
[ 1541.023054] invoke_syscall+0x48/0x114
[ 1541.026792] el0_svc_common.constprop.0+0xd4/0xfc
[ 1541.031482] do_el0_svc+0x30/0xd0
[ 1541.034784] el0_svc+0x2c/0x84
[ 1541.037827] el0t_64_sync_handler+0xbc/0x140
[ 1541.042082] el0t_64_sync+0x18c/0x190
[ 1541.045732] ---[ end trace 0000000000000000 ]---
[ 1541.051448] ------------[ cut here ]------------
[ 1541.056120] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1541.062535] WARNING: CPU: 5 PID: 3256 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1541.069744] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1541.141432] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1541.150541] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1541.156182] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1541.163125] pc : __vunmap+0x78/0x30c
[ 1541.166687] lr : __vunmap+0x78/0x30c
[ 1541.170248] sp : ffff80000baebad0
[ 1541.173548] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1541.180667] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1541.187784] x23: 00000009ef580000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1541.194901] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1541.202018] x17: 0000000000000000 x16: 0000000000000000 x15: 000026af263639d0
[ 1541.209135] x14: 0000000000000022 x13: 0000000000000022 x12: 0000000000000000
[ 1541.216252] x11: 0000000000000001 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1541.223368] x8 : ffff0008aa582690 x7 : ffff000f5c3cf340 x6 : 0000000000000000
[ 1541.230485] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a41cc648
[ 1541.237602] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1541.244719] Call trace:
[ 1541.247152] __vunmap+0x78/0x30c
[ 1541.250366] vunmap+0x40/0x5c
[ 1541.253322] dma_direct_free+0x10c/0x110
[ 1541.257231] dma_free_attrs+0x98/0xe0
[ 1541.260879] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1541.266186] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1541.271141] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1541.276442] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1541.281397] v4l2_release+0xbc/0xf0 [videodev]
[ 1541.285850] __fput+0x70/0x250
[ 1541.288895] ____fput+0x10/0x20
[ 1541.292024] task_work_run+0x80/0xe0
[ 1541.295588] do_notify_resume+0x208/0x1280
[ 1541.299672] el0_svc+0x74/0x84
[ 1541.302714] el0t_64_sync_handler+0xbc/0x140
[ 1541.306968] el0t_64_sync+0x18c/0x190
[ 1541.310616] ---[ end trace 0000000000000000 ]---
[ 1541.315319] ------------[ cut here ]------------
[ 1541.319936] 65 pages are still in use!
[ 1541.323685] WARNING: CPU: 5 PID: 3256 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1541.331847] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1541.403524] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1541.412633] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1541.418274] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1541.425216] pc : free_contig_range+0xa4/0xc0
[ 1541.429471] lr : free_contig_range+0xa4/0xc0
[ 1541.433726] sp : ffff80000baeba90
[ 1541.437026] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1541.444144] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1541.451261] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef5c1
[ 1541.458378] x20: 0000000000000041 x19: 00000000009ef5c1 x18: ffffffffffffffff
[ 1541.465496] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1541.472612] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000009bd
[ 1541.479729] x11: 000000000000033f x10: ffff8000092d9550 x9 : ffff800009281550
[ 1541.486846] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1541.493962] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1541.501079] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1541.508196] Call trace:
[ 1541.510629] free_contig_range+0xa4/0xc0
[ 1541.514539] cma_release+0x7c/0xd0
[ 1541.517927] dma_free_contiguous+0xa0/0xac
[ 1541.522010] dma_direct_free+0xc0/0x110
[ 1541.525833] dma_free_attrs+0x98/0xe0
[ 1541.529481] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1541.534786] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1541.539740] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1541.545041] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1541.549996] v4l2_release+0xbc/0xf0 [videodev]
[ 1541.554450] __fput+0x70/0x250
[ 1541.557493] ____fput+0x10/0x20
[ 1541.560622] task_work_run+0x80/0xe0
[ 1541.564185] do_notify_resume+0x208/0x1280
[ 1541.568269] el0_svc+0x74/0x84
[ 1541.571310] el0t_64_sync_handler+0xbc/0x140
[ 1541.575564] el0t_64_sync+0x18c/0x190
[ 1541.579212] ---[ end trace 0000000000000000 ]---
[ 1541.583875] ------------[ cut here ]------------
[ 1541.588495] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1541.594934] WARNING: CPU: 5 PID: 3256 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1541.602148] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1541.673841] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1541.682950] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1541.688591] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1541.695532] pc : __vunmap+0x78/0x30c
[ 1541.699094] lr : __vunmap+0x78/0x30c
[ 1541.702655] sp : ffff80000baebad0
[ 1541.705955] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1541.713072] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1541.720188] x23: 00000009804c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1541.727305] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1541.734422] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1541.741538] x14: 000000000000028d x13: 0000000000000000 x12: 0000000000000000
[ 1541.748655] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1541.755771] x8 : ffff0008aa582690 x7 : ffff000f5c3cf340 x6 : 0000000000000000
[ 1541.762888] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a41cc648
[ 1541.770005] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1541.777122] Call trace:
[ 1541.779555] __vunmap+0x78/0x30c
[ 1541.782771] vunmap+0x40/0x5c
[ 1541.785726] dma_direct_free+0x10c/0x110
[ 1541.789635] dma_free_attrs+0x98/0xe0
[ 1541.793284] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1541.798591] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1541.803545] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1541.808846] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1541.813801] v4l2_release+0xbc/0xf0 [videodev]
[ 1541.818253] __fput+0x70/0x250
[ 1541.821296] ____fput+0x10/0x20
[ 1541.824425] task_work_run+0x80/0xe0
[ 1541.827990] do_notify_resume+0x208/0x1280
[ 1541.832075] el0_svc+0x74/0x84
[ 1541.835117] el0t_64_sync_handler+0xbc/0x140
[ 1541.839371] el0t_64_sync+0x18c/0x190
[ 1541.843019] ---[ end trace 0000000000000000 ]---
[ 1541.847649] ------------[ cut here ]------------
[ 1541.852257] 33 pages are still in use!
[ 1541.855997] WARNING: CPU: 5 PID: 3256 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1541.864156] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1541.935833] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1541.944941] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1541.950581] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1541.957523] pc : free_contig_range+0xa4/0xc0
[ 1541.961778] lr : free_contig_range+0xa4/0xc0
[ 1541.966033] sp : ffff80000baeba90
[ 1541.969332] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1541.976449] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1541.983566] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009804e1
[ 1541.990683] x20: 0000000000000021 x19: 00000000009804e1 x18: ffffffffffffffff
[ 1541.997799] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1542.004916] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000aa4
[ 1542.012032] x11: 000000000000038c x10: ffff8000092d9550 x9 : ffff800009281550
[ 1542.019149] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1542.026265] x5 : ffff000f5c3c8b60 x4 : 0000000000000000 x3 : 0000000000000027
[ 1542.033382] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1542.040499] Call trace:
[ 1542.042931] free_contig_range+0xa4/0xc0
[ 1542.046840] cma_release+0x7c/0xd0
[ 1542.050229] dma_free_contiguous+0xa0/0xac
[ 1542.054311] dma_direct_free+0xc0/0x110
[ 1542.058133] dma_free_attrs+0x98/0xe0
[ 1542.061780] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1542.067083] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1542.072038] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1542.077339] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1542.082294] v4l2_release+0xbc/0xf0 [videodev]
[ 1542.086744] __fput+0x70/0x250
[ 1542.089787] ____fput+0x10/0x20
[ 1542.092916] task_work_run+0x80/0xe0
[ 1542.096478] do_notify_resume+0x208/0x1280
[ 1542.100560] el0_svc+0x74/0x84
[ 1542.103601] el0t_64_sync_handler+0xbc/0x140
[ 1542.107856] el0t_64_sync+0x18c/0x190
[ 1542.111504] ---[ end trace 0000000000000000 ]---
[ 1542.116139] ------------[ cut here ]------------
[ 1542.120751] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1542.127112] WARNING: CPU: 5 PID: 3256 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1542.134317] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1542.205993] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1542.215101] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1542.220742] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1542.227683] pc : __vunmap+0x78/0x30c
[ 1542.231244] lr : __vunmap+0x78/0x30c
[ 1542.234806] sp : ffff80000baebad0
[ 1542.238106] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1542.245223] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1542.252340] x23: 00000009ef500000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1542.259456] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1542.266573] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1542.273690] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000b19
[ 1542.280807] x11: 00000000000003b3 x10: ffff8000092d9550 x9 : ffff800009281550
[ 1542.287924] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1542.295042] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1542.302160] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1542.309277] Call trace:
[ 1542.311709] __vunmap+0x78/0x30c
[ 1542.314923] vunmap+0x40/0x5c
[ 1542.317878] dma_direct_free+0x10c/0x110
[ 1542.321787] dma_free_attrs+0x98/0xe0
[ 1542.325435] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1542.330739] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1542.335693] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1542.340994] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1542.345948] v4l2_release+0xbc/0xf0 [videodev]
[ 1542.350402] __fput+0x70/0x250
[ 1542.353444] ____fput+0x10/0x20
[ 1542.356574] task_work_run+0x80/0xe0
[ 1542.360136] do_notify_resume+0x208/0x1280
[ 1542.364219] el0_svc+0x74/0x84
[ 1542.367260] el0t_64_sync_handler+0xbc/0x140
[ 1542.371515] el0t_64_sync+0x18c/0x190
[ 1542.375162] ---[ end trace 0000000000000000 ]---
[ 1542.379788] ------------[ cut here ]------------
[ 1542.384396] 35 pages are still in use!
[ 1542.388143] WARNING: CPU: 5 PID: 3256 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1542.396302] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1542.467977] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1542.477085] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1542.482725] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1542.489666] pc : free_contig_range+0xa4/0xc0
[ 1542.493921] lr : free_contig_range+0xa4/0xc0
[ 1542.498176] sp : ffff80000baeba90
[ 1542.501476] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1542.508593] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1542.515711] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef523
[ 1542.522828] x20: 0000000000000023 x19: 00000000009ef523 x18: ffffffffffffffff
[ 1542.529945] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1542.537061] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000b8b
[ 1542.544178] x11: 00000000000003d9 x10: ffff8000092d9550 x9 : ffff800009281550
[ 1542.551295] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1542.558412] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1542.565529] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1542.572646] Call trace:
[ 1542.575078] free_contig_range+0xa4/0xc0
[ 1542.578987] cma_release+0x7c/0xd0
[ 1542.582375] dma_free_contiguous+0xa0/0xac
[ 1542.586458] dma_direct_free+0xc0/0x110
[ 1542.590280] dma_free_attrs+0x98/0xe0
[ 1542.593928] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1542.599230] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1542.604184] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1542.609484] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1542.614438] v4l2_release+0xbc/0xf0 [videodev]
[ 1542.618889] __fput+0x70/0x250
[ 1542.621931] ____fput+0x10/0x20
[ 1542.625060] task_work_run+0x80/0xe0
[ 1542.628622] do_notify_resume+0x208/0x1280
[ 1542.632706] el0_svc+0x74/0x84
[ 1542.635748] el0t_64_sync_handler+0xbc/0x140
[ 1542.640002] el0t_64_sync+0x18c/0x190
[ 1542.643651] ---[ end trace 0000000000000000 ]---
[ 1542.648270] ------------[ cut here ]------------
[ 1542.652879] Trying to vfree() nonexistent vm area (000000008a4148f5)
[ 1542.659225] WARNING: CPU: 5 PID: 3256 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1542.666430] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1542.738104] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1542.747212] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1542.752853] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1542.759794] pc : __vunmap+0x78/0x30c
[ 1542.763355] lr : __vunmap+0x78/0x30c
[ 1542.766917] sp : ffff80000baebad0
[ 1542.770216] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1542.777333] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1542.784450] x23: 00000009804a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1542.791567] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1542.798686] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1542.805802] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000c00
[ 1542.812919] x11: 0000000000000400 x10: ffff8000092d9550 x9 : ffff800009281550
[ 1542.820036] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1542.827154] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1542.834270] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1542.841387] Call trace:
[ 1542.843820] __vunmap+0x78/0x30c
[ 1542.847033] vunmap+0x40/0x5c
[ 1542.849989] dma_direct_free+0x10c/0x110
[ 1542.853897] dma_free_attrs+0x98/0xe0
[ 1542.857545] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1542.862848] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1542.867715] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1542.873016] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1542.877970] v4l2_release+0xbc/0xf0 [videodev]
[ 1542.882420] __fput+0x70/0x250
[ 1542.885462] ____fput+0x10/0x20
[ 1542.888591] task_work_run+0x80/0xe0
[ 1542.892154] do_notify_resume+0x208/0x1280
[ 1542.896237] el0_svc+0x74/0x84
[ 1542.899278] el0t_64_sync_handler+0xbc/0x140
[ 1542.903532] el0t_64_sync+0x18c/0x190
[ 1542.907180] ---[ end trace 0000000000000000 ]---
[ 1542.911803] ------------[ cut here ]------------
[ 1542.916410] 18 pages are still in use!
[ 1542.920157] WARNING: CPU: 5 PID: 3256 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1542.928316] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1542.999990] CPU: 5 PID: 3256 Comm: gst-launch-1.0 Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1543.009097] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1543.014738] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1543.021679] pc : free_contig_range+0xa4/0xc0
[ 1543.025934] lr : free_contig_range+0xa4/0xc0
[ 1543.030189] sp : ffff80000baeba90
[ 1543.033489] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1543.040606] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1543.047722] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009804b2
[ 1543.054839] x20: 0000000000000012 x19: 00000000009804b2 x18: ffffffffffffffff
[ 1543.061956] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1543.069073] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000c72
[ 1543.076190] x11: 0000000000000426 x10: ffff8000092d9550 x9 : ffff800009281550
[ 1543.083306] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1543.090423] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1543.097540] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa581c80
[ 1543.104657] Call trace:
[ 1543.107089] free_contig_range+0xa4/0xc0
[ 1543.110998] cma_release+0x7c/0xd0
[ 1543.114387] dma_free_contiguous+0xa0/0xac
[ 1543.118469] dma_direct_free+0xc0/0x110
[ 1543.122291] dma_free_attrs+0x98/0xe0
[ 1543.125938] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1543.131241] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1543.136108] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1543.141409] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1543.146364] v4l2_release+0xbc/0xf0 [videodev]
[ 1543.150815] __fput+0x70/0x250
[ 1543.153857] ____fput+0x10/0x20
[ 1543.156987] task_work_run+0x80/0xe0
[ 1543.160549] do_notify_resume+0x208/0x1280
[ 1543.164632] el0_svc+0x74/0x84
[ 1543.167673] el0t_64_sync_handler+0xbc/0x140
[ 1543.171927] el0t_64_sync+0x18c/0x190
[ 1543.175574] ---[ end trace 0000000000000000 ]---
[ 1543.237068] BUG: Bad page state in process videotestsrc0:s pfn:9ef580
[ 1543.243591] page:000000007854a13d refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef580
[ 1543.253048] flags: 0x8000000000000000(zone=2) CMA
[ 1543.257742] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1543.265464] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1543.273185] page dumped because: nonzero _refcount
[ 1543.277959] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1543.349658] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G W O 6.1.33-g8f7f371be2 #1
[ 1543.358854] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1543.364495] Call trace:
[ 1543.366929] dump_backtrace.part.0+0xdc/0xf0
[ 1543.371196] show_stack+0x18/0x30
[ 1543.374499] dump_stack_lvl+0x68/0x84
[ 1543.378152] dump_stack+0x18/0x34
[ 1543.381455] bad_page+0xe8/0x110
[ 1543.384673] free_page_is_bad_report+0x7c/0x90
[ 1543.389102] free_pcppages_bulk+0x198/0x1fc
[ 1543.393271] drain_pages_zone+0x64/0x84
[ 1543.397094] __drain_all_pages+0x178/0x220
[ 1543.401176] alloc_contig_range+0x130/0x280
[ 1543.405346] cma_alloc+0x120/0x310
[ 1543.408736] cma_alloc_aligned+0x44/0x70
[ 1543.412647] dma_alloc_contiguous+0x30/0x44
[ 1543.416817] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1543.422459] dma_direct_alloc+0xd8/0x304
[ 1543.426368] dma_alloc_attrs+0x7c/0xe4
[ 1543.430103] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1543.435759] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1543.441407] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1543.446187] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1543.451661] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1543.457313] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1543.462184] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1543.467835] v4l_reqbufs+0x50/0x64 [videodev]
[ 1543.472204] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1543.477174] video_usercopy+0x214/0x6c4 [videodev]
[ 1543.481969] video_ioctl2+0x18/0x2c [videodev]
[ 1543.486419] v4l2_ioctl+0x40/0x60 [videodev]
[ 1543.490695] __arm64_sys_ioctl+0xa8/0xf0
[ 1543.494605] invoke_syscall+0x48/0x114
[ 1543.498343] el0_svc_common.constprop.0+0xd4/0xfc
[ 1543.503032] do_el0_svc+0x30/0xd0
[ 1543.506335] el0_svc+0x2c/0x84
[ 1543.509376] el0t_64_sync_handler+0xbc/0x140
[ 1543.513631] el0t_64_sync+0x18c/0x190
[ 1543.517281] Disabling lock debugging due to kernel taint
[ 1543.522574] BUG: Bad page state in process videotestsrc0:s pfn:9ef581
[ 1543.529083] page:00000000a1ac2981 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef581
[ 1543.538539] flags: 0x8000000000000000(zone=2) CMA
[ 1543.543228] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1543.550950] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1543.558670] page dumped because: nonzero _refcount
[ 1543.563443] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1543.635121] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1543.644317] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1543.649957] Call trace:
[ 1543.652389] dump_backtrace.part.0+0xdc/0xf0
[ 1543.656646] show_stack+0x18/0x30
[ 1543.659949] dump_stack_lvl+0x68/0x84
[ 1543.663599] dump_stack+0x18/0x34
[ 1543.666902] bad_page+0xe8/0x110
[ 1543.670116] free_page_is_bad_report+0x7c/0x90
[ 1543.674544] free_pcppages_bulk+0x198/0x1fc
[ 1543.678713] drain_pages_zone+0x64/0x84
[ 1543.682536] __drain_all_pages+0x178/0x220
[ 1543.686618] alloc_contig_range+0x130/0x280
[ 1543.690788] cma_alloc+0x120/0x310
[ 1543.694176] cma_alloc_aligned+0x44/0x70
[ 1543.698085] dma_alloc_contiguous+0x30/0x44
[ 1543.702254] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1543.707896] dma_direct_alloc+0xd8/0x304
[ 1543.711805] dma_alloc_attrs+0x7c/0xe4
[ 1543.715540] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1543.721189] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1543.726836] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1543.731617] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1543.737091] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1543.742740] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1543.747608] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1543.753258] v4l_reqbufs+0x50/0x64 [videodev]
[ 1543.757624] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1543.762592] video_usercopy+0x214/0x6c4 [videodev]
[ 1543.767388] video_ioctl2+0x18/0x2c [videodev]
[ 1543.771837] v4l2_ioctl+0x40/0x60 [videodev]
[ 1543.776112] __arm64_sys_ioctl+0xa8/0xf0
[ 1543.780020] invoke_syscall+0x48/0x114
[ 1543.783757] el0_svc_common.constprop.0+0xd4/0xfc
[ 1543.788446] do_el0_svc+0x30/0xd0
[ 1543.791749] el0_svc+0x2c/0x84
[ 1543.794791] el0t_64_sync_handler+0xbc/0x140
[ 1543.799045] el0t_64_sync+0x18c/0x190
[ 1543.802692] BUG: Bad page state in process videotestsrc0:s pfn:9ef582
[ 1543.809198] page:00000000023554ae refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef582
[ 1543.818654] flags: 0x8000000000000000(zone=2) CMA
[ 1543.823342] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1543.831063] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1543.838783] page dumped because: nonzero _refcount
[ 1543.843557] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1543.915230] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1543.924426] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1543.930066] Call trace:
[ 1543.932499] dump_backtrace.part.0+0xdc/0xf0
[ 1543.936756] show_stack+0x18/0x30
[ 1543.940059] dump_stack_lvl+0x68/0x84
[ 1543.943709] dump_stack+0x18/0x34
[ 1543.947012] bad_page+0xe8/0x110
[ 1543.950228] free_page_is_bad_report+0x7c/0x90
[ 1543.954656] free_pcppages_bulk+0x198/0x1fc
[ 1543.958825] drain_pages_zone+0x64/0x84
[ 1543.962647] __drain_all_pages+0x178/0x220
[ 1543.966728] alloc_contig_range+0x130/0x280
[ 1543.970898] cma_alloc+0x120/0x310
[ 1543.974286] cma_alloc_aligned+0x44/0x70
[ 1543.978195] dma_alloc_contiguous+0x30/0x44
[ 1543.982364] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1543.988007] dma_direct_alloc+0xd8/0x304
[ 1543.991915] dma_alloc_attrs+0x7c/0xe4
[ 1543.995650] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1544.001298] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1544.006946] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1544.011727] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1544.017201] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1544.022850] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1544.027717] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1544.033366] v4l_reqbufs+0x50/0x64 [videodev]
[ 1544.037730] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1544.042699] video_usercopy+0x214/0x6c4 [videodev]
[ 1544.047495] video_ioctl2+0x18/0x2c [videodev]
[ 1544.051944] v4l2_ioctl+0x40/0x60 [videodev]
[ 1544.056220] __arm64_sys_ioctl+0xa8/0xf0
[ 1544.060128] invoke_syscall+0x48/0x114
[ 1544.063864] el0_svc_common.constprop.0+0xd4/0xfc
[ 1544.068554] do_el0_svc+0x30/0xd0
[ 1544.071856] el0_svc+0x2c/0x84
[ 1544.074897] el0t_64_sync_handler+0xbc/0x140
[ 1544.079151] el0t_64_sync+0x18c/0x190
[ 1544.082799] BUG: Bad page state in process videotestsrc0:s pfn:9ef583
[ 1544.089306] page:00000000f1ba9696 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef583
[ 1544.098761] flags: 0x8000000000000000(zone=2) CMA
[ 1544.103449] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1544.111170] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1544.118890] page dumped because: nonzero _refcount
[ 1544.123664] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remotep__dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1544.268118] dma_direct_alloc+0xd8/0x304
[ 1544.272028] dma_alloc_attrs+0x7c/0xe4
[ 1544.275764] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1544.281413] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1544.287060] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1544.291841] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1544.297315] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1544.302964] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1544.307832] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1544.313481] v4l_reqbufs+0x50/0x64 [videodev]
[ 1544.317844] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1544.322814] video_usercopy+0x214/0x6c4 [videodev]
[ 1544.327609] video_ioctl2+0x18/0x2c [videodev]
[ 1544.332059] v4l2_ioctl+0x40/0x60 [videodev]
[ 1544.336335] __arm64_sys_ioctl+0xa8/0xf0
[ 1544.340243] invoke_syscall+0x48/0x114
[ 1544.343979] el0_svc_common.constprop.0+0xd4/0xfc
[ 1544.348669] do_el0_svc+0x30/0xd0
[ 1544.351971] el0_svc+0x2c/0x84
[ 1544.355012] el0t_64_sync_handler+0xbc/0x140
[ 1544.359267] el0t_64_sync+0x18c/0x190
[ 1544.362916] BUG: Bad page state in process videotestsrc0:s pfn:9ef584
[ 1544.369423] page:0000000074485a88 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef584
[ 1544.378879] flags: 0x8000000000000000(zone=2) CMA
[ 1544.383568] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1544.391288] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1544.399008] page dumped because: nonzero _refcount
[ 1544.403781] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt reqbufs+0x50/0x64 [videodev]
[ 1544.597955] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1544.602925] video_usercopy+0x214/0x6c4 [videodev]
[ 1544.607720] video_ioctl2+0x18/0x2c [videodev]
[ 1544.612169] v4l2_ioctl+0x40/0x60 [videodev]
[ 1544.616444] __arm64_sys_ioctl+0xa8/0xf0
[ 1544.620353] invoke_syscall+0x48/0x114
[ 1544.624089] el0_svc_common.constprop.0+0xd4/0xfc
[ 1544.628779] do_el0_svc+0x30/0xd0
[ 1544.632081] el0_svc+0x2c/0x84
[ 1544.635122] el0t_64_sync_handler+0xbc/0x140
[ 1544.639378] el0t_64_sync+0x18c/0x190
[ 1544.643025] BUG: Bad page state in process videotestsrc0:s pfn:9ef585
[ 1544.649532] page:00000000ef7245e9 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef585
[ 1544.658988] flags: 0x8000000000000000(zone=2) CMA
[ 1544.663677] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1544.671397] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1544.679117] page dumped because: nonzero _refcount
[ 1544.683890] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1544.755565] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1544.764760] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1544.770400] Call trace:
[ 1544.772833] dump_backtrace.part.0+0xdc/0xf0
[ 1544.777090] show_stack+0x18/0x30
[ 1544.780393] dump_stack_lvl+0x68/0x84
[ 1544.784043] dump_stack+0x18/0x34
[ 1544.787346] bad_40
[ 1544.919485] el0t_64_sync+0x18c/0x190
[ 1544.923133] BUG: Bad page state in process videotestsrc0:s pfn:9ef586
[ 1544.929644] page:000000002494eafc refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef586
[ 1544.939099] flags: 0x8000000000000000(zone=2) CMA
[ 1544.943788] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1544.951509] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1544.959229] page dumped because: nonzero _refcount
[ 1544.964001] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1545.035676] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1545.044870] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1545.050510] Call trace:
[ 1545.052943] dump_backtrace.part.0+0xdc/0xf0
[ 1545.057200] show_stack+0x18/0x30
[ 1545.060503] dump_stack_lvl+0x68/0x84
[ 1545.064154] dump_stack+0x18/0x34
[ 1545.067457] bad_page+0xe8/0x110
[ 1545.070672] free_page_is_bad_report+0x7c/0x90
[ 1545.075101] free_pcppages_bulk+0x198/0x1fc
[ 1545.079269] drain_pages_zone+0x64/0x84
[ 1545.083091] __drain_all_pages+0x178/0x220
[ 1545.087174] alloc_contig_range+0x130/0x280
[ 1545.091343] cma_alloc+0x120/0x310
[ 1545.094731] cma_alloc_aligned+0x44/0x70
[ 1545.098640] dma_alloc_contiguous+0x30/0x44
[ 1545.102808] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1545.108451] dma_direct_alloc+0xd8/0x30rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1545.315786] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1545.324983] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1545.330623] Call trace:
[ 1545.333056] dump_backtrace.part.0+0xdc/0xf0
[ 1545.337312] show_stack+0x18/0x30
[ 1545.340615] dump_stack_lvl+0x68/0x84
[ 1545.344265] dump_stack+0x18/0x34
[ 1545.347568] bad_page+0xe8/0x110
[ 1545.350783] free_page_is_bad_report+0x7c/0x90
[ 1545.355211] free_pcppages_bulk+0x198/0x1fc
[ 1545.359380] drain_pages_zone+0x64/0x84
[ 1545.363201] __drain_all_pages+0x178/0x220
[ 1545.367283] alloc_contig_range+0x130/0x280
[ 1545.371452] cma_alloc+0x120/0x310
[ 1545.374839] cma_alloc_aligned+0x44/0x70
[ 1545.378748] dma_alloc_contiguous+0x30/0x44
[ 1545.382917] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1545.388559] dma_direct_alloc+0xd8/0x304
[ 1545.392467] dma_alloc_attrs+0x7c/0xe4
[ 1545.396202] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1545.401851] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1545.407498] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1545.412279] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1545.417753] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1545.423402] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1545.428270] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1545.433918] v4l_reqbufs+0x50/0x64 [videodev]
[ 1545.438281] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1545.443251] video_usercopy+0x214/0x6c4 [videodev]
[ 1545.448047] video_ioctl2+0x18/0x2c [videodev]
[ 1545.452496] v4l1e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1545.595893] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1545.605090] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1545.610731] Call trace:
[ 1545.613164] dump_backtrace.part.0+0xdc/0xf0
[ 1545.617421] show_stack+0x18/0x30
[ 1545.620723] dump_stack_lvl+0x68/0x84
[ 1545.624374] dump_stack+0x18/0x34
[ 1545.627677] bad_page+0xe8/0x110
[ 1545.630893] free_page_is_bad_report+0x7c/0x90
[ 1545.635322] free_pcppages_bulk+0x198/0x1fc
[ 1545.639490] drain_pages_zone+0x64/0x84
[ 1545.643312] __drain_all_pages+0x178/0x220
[ 1545.647395] alloc_contig_range+0x130/0x280
[ 1545.651564] cma_alloc+0x120/0x310
[ 1545.654952] cma_alloc_aligned+0x44/0x70
[ 1545.658860] dma_alloc_contiguous+0x30/0x44
[ 1545.663029] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1545.668671] dma_direct_alloc+0xd8/0x304
[ 1545.672579] dma_alloc_attrs+0x7c/0xe4
[ 1545.676314] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1545.681962] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1545.687609] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1545.692390] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1545.697864] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1545.703513] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1545.708381] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1545.714030] v4l_reqbufs+0x50/0x64 [videodev]
[ 1545.718393] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1545.723363] video_usercopy+0x214/0x6c4 [videodev]
[ 1545.728159] video_ioctl2+0x18/0x2c [videodev]
[ 1545.732608] v4l2_ioctl+0x40/0x60 [videodev]
[ 1s tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1545.876002] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1545.885201] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1545.890841] Call trace:
[ 1545.893275] dump_backtrace.part.0+0xdc/0xf0
[ 1545.897532] show_stack+0x18/0x30
[ 1545.900835] dump_stack_lvl+0x68/0x84
[ 1545.904485] dump_stack+0x18/0x34
[ 1545.907788] bad_page+0xe8/0x110
[ 1545.911004] free_page_is_bad_report+0x7c/0x90
[ 1545.915432] free_pcppages_bulk+0x198/0x1fc
[ 1545.919600] drain_pages_zone+0x64/0x84
[ 1545.923422] __drain_all_pages+0x178/0x220
[ 1545.927504] alloc_contig_range+0x130/0x280
[ 1545.931672] cma_alloc+0x120/0x310
[ 1545.935060] cma_alloc_aligned+0x44/0x70
[ 1545.938970] dma_alloc_contiguous+0x30/0x44
[ 1545.943138] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1545.948779] dma_direct_alloc+0xd8/0x304
[ 1545.952688] dma_alloc_attrs+0x7c/0xe4
[ 1545.956423] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1545.962072] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1545.967720] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1545.972500] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1545.977974] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1545.983624] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1545.988491] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1545.994140] v4l_reqbufs+0x50/0x64 [videodev]
[ 1545.998503] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1546.003472] video_usercopy+0x214/0x6c4 [videodev]
[ 1546.008267] video_ioctl2+0x18/0x2c [videodev]
[ 1546.012717] v4l2_ioctl+0x40/0x60 [videodev]
[ 1546.016993] __arm64_sys_ioctl+0xa8/0xf0
[ 1546.020901] invoke_syscall+0x48/0x114
[ 1546.024637] el0_svc_common.constpropmap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1546.156115] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1546.165311] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1546.170952] Call trace:
[ 1546.173385] dump_backtrace.part.0+0xdc/0xf0
[ 1546.177643] show_stack+0x18/0x30
[ 1546.180945] dump_stack_lvl+0x68/0x84
[ 1546.184595] dump_stack+0x18/0x34
[ 1546.187898] bad_page+0xe8/0x110
[ 1546.191113] free_page_is_bad_report+0x7c/0x90
[ 1546.195542] free_pcppages_bulk+0x198/0x1fc
[ 1546.199710] drain_pages_zone+0x64/0x84
[ 1546.203532] __drain_all_pages+0x178/0x220
[ 1546.207615] alloc_contig_range+0x130/0x280
[ 1546.211784] cma_alloc+0x120/0x310
[ 1546.215172] cma_alloc_aligned+0x44/0x70
[ 1546.219081] dma_alloc_contiguous+0x30/0x44
[ 1546.223249] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1546.228891] dma_direct_alloc+0xd8/0x304
[ 1546.232799] dma_alloc_attrs+0x7c/0xe4
[ 1546.236533] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1546.242182] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1546.247830] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1546.252611] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1546.258084] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1546.263734] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1546.268602] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1546.274250] v4l_reqbufs+0x50/0x64 [videodev]
[ 1546.278613] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1546.283581] video_usercopy+0x214/0x6c4 [videodev]
[ 1546.288377] video_ioctl2+0x18/0x2c [videodev]
[ 1546.292826]000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1546.359777] page dumped because: nonzero _refcount
[ 1546.364553] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1546.436228] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1546.445422] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1546.451062] Call trace:
[ 1546.453495] dump_backtrace.part.0+0xdc/0xf0
[ 1546.457752] show_stack+0x18/0x30
[ 1546.461055] dump_stack_lvl+0x68/0x84
[ 1546.464704] dump_stack+0x18/0x34
[ 1546.468007] bad_page+0xe8/0x110
[ 1546.471222] free_page_is_bad_report+0x7c/0x90
[ 1546.475651] free_pcppages_bulk+0x198/0x1fc
[ 1546.479819] drain_pages_zone+0x64/0x84
[ 1546.483642] __drain_all_pages+0x178/0x220
[ 1546.487724] alloc_contig_range+0x130/0x280
[ 1546.491893] cma_alloc+0x120/0x310
[ 1546.495281] cma_alloc_aligned+0x44/0x70
[ 1546.499190] dma_alloc_contiguous+0x30/0x44
[ 1546.503358] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1546.509000] dma_direct_alloc+0xd8/0x304
[ 1546.512910] dma_alloc_attrs+0x7c/0xe4
[ 1546.516644] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1546.522293] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1546.527941] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1546.532721] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1546.538195] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1546.543844] vb2_reqbufs+0x80/0xa0 [videobuf000000
[ 1546.632168] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1546.639892] page dumped because: nonzero _refcount
[ 1546.644666] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1546.716340] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1546.725535] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1546.731175] Call trace:
[ 1546.733608] dump_backtrace.part.0+0xdc/0xf0
[ 1546.737864] show_stack+0x18/0x30
[ 1546.741167] dump_stack_lvl+0x68/0x84
[ 1546.744817] dump_stack+0x18/0x34
[ 1546.748120] bad_page+0xe8/0x110
[ 1546.751336] free_page_is_bad_report+0x7c/0x90
[ 1546.755764] free_pcppages_bulk+0x198/0x1fc
[ 1546.759933] drain_pages_zone+0x64/0x84
[ 1546.763755] __drain_all_pages+0x178/0x220
[ 1546.767837] alloc_contig_range+0x130/0x280
[ 1546.772006] cma_alloc+0x120/0x310
[ 1546.775395] cma_alloc_aligned+0x44/0x70
[ 1546.779304] dma_alloc_contiguous+0x30/0x44
[ 1546.783473] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1546.789115] dma_direct_alloc+0xd8/0x304
[ 1546.793024] dma_alloc_attrs+0x7c/0xe4
[ 1546.796759] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1546.802406] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1546.808054] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1546.812835] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1546.818309] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1546.8239dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1546.996445] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1547.005642] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1547.011282] Call trace:
[ 1547.013715] dump_backtrace.part.0+0xdc/0xf0
[ 1547.017972] show_stack+0x18/0x30
[ 1547.021276] dump_stack_lvl+0x68/0x84
[ 1547.024925] dump_stack+0x18/0x34
[ 1547.028228] bad_page+0xe8/0x110
[ 1547.031444] free_page_is_bad_report+0x7c/0x90
[ 1547.035873] free_pcppages_bulk+0x198/0x1fc
[ 1547.040041] drain_pages_zone+0x64/0x84
[ 1547.043863] __drain_all_pages+0x178/0x220
[ 1547.047946] alloc_contig_range+0x130/0x280
[ 1547.052115] cma_alloc+0x120/0x310
[ 1547.055503] cma_alloc_aligned+0x44/0x70
[ 1547.059412] dma_alloc_contiguous+0x30/0x44
[ 1547.063580] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1547.069223] dma_direct_alloc+0xd8/0x304
[ 1547.073131] dma_alloc_attrs+0x7c/0xe4
[ 1547.076865] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1547.082515] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1547.088163] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1547.092943] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1547.098417] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1547.104066] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1547.108933] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1547.114582] v4l_reqbufs+0x50/0x64 [videodev]
[ 1547.118944] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1547.123914] video_usercopy+0x214/0x6c4 [videodev]
[ 1547.128710] video_ioctl2+0x18/0x2c [videodev]
[ 1547.133159] v4l2_ioctl+0x40/0x60 [videodev]
[ 1547.137436] __arm64_sys_ioctl+0xa8/0xf0
[ 1547.141344] invocsi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1547.276557] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1547.285754] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1547.291394] Call trace:
[ 1547.293827] dump_backtrace.part.0+0xdc/0xf0
[ 1547.298085] show_stack+0x18/0x30
[ 1547.301387] dump_stack_lvl+0x68/0x84
[ 1547.305038] dump_stack+0x18/0x34
[ 1547.308341] bad_page+0xe8/0x110
[ 1547.311555] free_page_is_bad_report+0x7c/0x90
[ 1547.315984] free_pcppages_bulk+0x198/0x1fc
[ 1547.320152] drain_pages_zone+0x64/0x84
[ 1547.323975] __drain_all_pages+0x178/0x220
[ 1547.328057] alloc_contig_range+0x130/0x280
[ 1547.332226] cma_alloc+0x120/0x310
[ 1547.335614] cma_alloc_aligned+0x44/0x70
[ 1547.339523] dma_alloc_contiguous+0x30/0x44
[ 1547.343691] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1547.349333] dma_direct_alloc+0xd8/0x304
[ 1547.353241] dma_alloc_attrs+0x7c/0xe4
[ 1547.356976] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1547.362625] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1547.368272] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1547.373053] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1547.378527] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1547.384175] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1547.389043] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1547.394692] v4l_reqbufs+0x50/0x64 [videodev]
[ 1547.399054] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1547.404023] video_usercopy+0x214/0x6c4 [videodev]
[ 1547.408818] video_ioctl2+0x18/0x2c [videodev]
[ 1547.413267] v4l2_ioctl+0x40/0x60 [videodev]
[ 154ryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1547.556670] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1547.565868] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1547.571508] Call trace:
[ 1547.573941] dump_backtrace.part.0+0xdc/0xf0
[ 1547.578198] show_stack+0x18/0x30
[ 1547.581502] dump_stack_lvl+0x68/0x84
[ 1547.585151] dump_stack+0x18/0x34
[ 1547.588455] bad_page+0xe8/0x110
[ 1547.591669] free_page_is_bad_report+0x7c/0x90
[ 1547.596098] free_pcppages_bulk+0x198/0x1fc
[ 1547.600267] drain_pages_zone+0x64/0x84
[ 1547.604089] __drain_all_pages+0x178/0x220
[ 1547.608171] alloc_contig_range+0x130/0x280
[ 1547.612341] cma_alloc+0x120/0x310
[ 1547.615728] cma_alloc_aligned+0x44/0x70
[ 1547.619637] dma_alloc_contiguous+0x30/0x44
[ 1547.623805] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1547.629447] dma_direct_alloc+0xd8/0x304
[ 1547.633355] dma_alloc_attrs+0x7c/0xe4
[ 1547.637090] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1547.642740] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1547.648387] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1547.653167] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1547.658641] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1547.664289] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1547.669157] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1547.674806] v4l_reqbufs+0x50/0x64 [videodev]
[ 1547.679171] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1547.684140] video_usercopy+0x214/0x6c4 [videodev]
[ 1547.688936] video_ioctl2+0x18/0x2c [videodev]
[ 1547.693385] v4l2_ioctl+0x40/0x60 [videodev]
[ 1547.697661] __arm64_sys_ioctl+0xa8/0xf0
[ 1547.701568] invoke_syscall+0x48/0x114
[ 1547.705305] el0_svc_common.constprop.0+0xd4/0xfc
[ 1547.709993] do_el0_svc+0x30/0xd0
[ 1547.713296] el0_svc+0x2c/0x84
[ 1547.716338] el0t_64_sync_handler+0xbc/0x140
[ 1547.720593] el0t_64_sync+0x18c/0x190
[ 1547.724241] BUG: Bad page state in process videotestsrc0:s pfn:9ef590
[ 1547.730747] page:000000000b63cbdc refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef590
[ 1547.740203] flags: 0x8000000000000000(zone=2) CMA
[ Instruments J784S4 EVM (DT)
[ 1547.851620] Call trace:
[ 1547.854057] dump_backtrace.part.0+0xdc/0xf0
[ 1547.858314] show_stack+0x18/0x30
[ 1547.861617] dump_stack_lvl+0x68/0x84
[ 1547.865267] dump_stack+0x18/0x34
[ 1547.868570] bad_page+0xe8/0x110
[ 1547.871787] free_page_is_bad_report+0x7c/0x90
[ 1547.876214] free_pcppages_bulk+0x198/0x1fc
[ 1547.880384] drain_pages_zone+0x64/0x84
[ 1547.884205] __drain_all_pages+0x178/0x220
[ 1547.888287] alloc_contig_range+0x130/0x280
[ 1547.892456] cma_alloc+0x120/0x310
[ 1547.895845] cma_alloc_aligned+0x44/0x70
[ 1547.899754] dma_alloc_contiguous+0x30/0x44
[ 1547.903923] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1547.909565] dma_direct_alloc+0xd8/0x304
[ 1547.913474] dma_alloc_attrs+0x7c/0xe4
[ 1547.917209] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1547.922857] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1547.928505] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1547.933286] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1547.938760] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1547.944409] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1547.949276] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1547.954925] v4l_reqbufs+0x50/0x64 [videodev]
[ 1547.959288] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1547.964257] video_usercopy+0x214/0x6c4 [videodev]
[ 1547.969054] video_ioctl2+0x18/0x2c [videodev]
[ 1547.973503] v4l2_ioctl+0x40/0x60 [videodev]
[ 1547.977779] __arm64_sys_ioctl+0xa8/0xf0
[ 1547.981687] invoke_syscall+0x48/0x114
[ 1547.985424] el0_svc_common.constprop.0+0xd4/0xfc
[ 1547.990113] do_el0_svc+0x30/0xd0
[ 1547.993416] el0_svc+0x2c/0x84
[ 1547.996457] el0t_64_sync_handler+0xbc/0x140
[ 1548.000711] el0t_64_sync+0x18c/0x190
[ 1548.004360] BUG: Bad page state in process videotestsrc0:s pfn:9ef591
[ 1548.010868] page:000000001f1f2b17 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef591
[ 1548.020323] flags: 0x8000000000000000(zone=2) CMA
[ 1548.025011] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1548.032731] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1548.040452] page dumped bep_enc_param+0x64/0x270 [wave5]
[ 1548.208613] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1548.213393] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1548.218869] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1548.224519] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1548.229388] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1548.235037] v4l_reqbufs+0x50/0x64 [videodev]
[ 1548.239406] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1548.244376] video_usercopy+0x214/0x6c4 [videodev]
[ 1548.249171] video_ioctl2+0x18/0x2c [videodev]
[ 1548.253620] v4l2_ioctl+0x40/0x60 [videodev]
[ 1548.257896] __arm64_sys_ioctl+0xa8/0xf0
[ 1548.261804] invoke_syscall+0x48/0x114
[ 1548.265541] el0_svc_common.constprop.0+0xd4/0xfc
[ 1548.270230] do_el0_svc+0x30/0xd0
[ 1548.273534] el0_svc+0x2c/0x84
[ 1548.276576] el0t_64_sync_handler+0xbc/0x140
[ 1548.280830] el0t_64_sync+0x18c/0x190
[ 1548.284480] BUG: Bad page state in process videotestsrc0:s pfn:9ef592
[ 1548.290988] page:000000006d4f4fa4 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef592
[ 1548.300443] flags: 0x8000000000000000(zone=2) CMA
[ 1548.305131] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1548.312852] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1548.320572] page dumped because: nonzero _refcount
[ 1548.325345] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1548.397024] CPU: 7 l+0x48/0x114
[ 1548.545678] el0_svc_common.constprop.0+0xd4/0xfc
[ 1548.550372] do_el0_svc+0x30/0xd0
[ 1548.553674] el0_svc+0x2c/0x84
[ 1548.556717] el0t_64_sync_handler+0xbc/0x140
[ 1548.560971] el0t_64_sync+0x18c/0x190
[ 1548.564620] BUG: Bad page state in process videotestsrc0:s pfn:9ef593
[ 1548.571128] page:00000000835fdff8 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef593
[ 1548.580585] flags: 0x8000000000000000(zone=2) CMA
[ 1548.585273] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1548.592995] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1548.600716] page dumped because: nonzero _refcount
[ 1548.605489] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1548.677172] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1548.686366] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1548.692006] Call trace:
[ 1548.694439] dump_backtrace.part.0+0xdc/0xf0
[ 1548.698696] show_stack+0x18/0x30
[ 1548.701999] dump_stack_lvl+0x68/0x84
[ 1548.705649] dump_stack+0x18/0x34
[ 1548.708952] bad_page+0xe8/0x110
[ 1548.712167] free_page_is_bad_report+0x7c/0x90
[ 1548.716595] free_pcppages_bulk+0x198/0x1fc
[ 1548.720764] drain_pages_zone+0x64/0x84
[ 1548.724586] __drain_all_pages+0x178/0x220
[ 1548.728668] alloc_contig_range+0x130/0x280
[ 1548.732837] cma_alloc+0x120/0x310
[ 1548.736226] cm(zone=2) CMA
[ 1548.865395] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1548.873119] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1548.880839] page dumped because: nonzero _refcount
[ 1548.885612] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1548.957289] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1548.966483] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1548.972123] Call trace:
[ 1548.974557] dump_backtrace.part.0+0xdc/0xf0
[ 1548.978814] show_stack+0x18/0x30
[ 1548.982117] dump_stack_lvl+0x68/0x84
[ 1548.985767] dump_stack+0x18/0x34
[ 1548.989070] bad_page+0xe8/0x110
[ 1548.992285] free_page_is_bad_report+0x7c/0x90
[ 1548.996713] free_pcppages_bulk+0x198/0x1fc
[ 1549.000881] drain_pages_zone+0x64/0x84
[ 1549.004703] __drain_all_pages+0x178/0x220
[ 1549.008786] alloc_contig_range+0x130/0x280
[ 1549.012954] cma_alloc+0x120/0x310
[ 1549.016342] cma_alloc_aligned+0x44/0x70
[ 1549.020252] dma_alloc_contiguous+0x30/0x44
[ 1549.024420] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1549.030061] dma_direct_alloc+0xd8/0x304
[ 1549.033970] dma_alloc_attrs+0x7c/0xe4
[ 1549.037705] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1549.043354] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1549.049001] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1549.053782] wave5_vpu_enc_queue_setup+0x1cles linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1549.237402] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1549.246600] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1549.252240] Call trace:
[ 1549.254673] dump_backtrace.part.0+0xdc/0xf0
[ 1549.258931] show_stack+0x18/0x30
[ 1549.262234] dump_stack_lvl+0x68/0x84
[ 1549.265885] dump_stack+0x18/0x34
[ 1549.269188] bad_page+0xe8/0x110
[ 1549.272402] free_page_is_bad_report+0x7c/0x90
[ 1549.276831] free_pcppages_bulk+0x198/0x1fc
[ 1549.281000] drain_pages_zone+0x64/0x84
[ 1549.284822] __drain_all_pages+0x178/0x220
[ 1549.288905] alloc_contig_range+0x130/0x280
[ 1549.293074] cma_alloc+0x120/0x310
[ 1549.296462] cma_alloc_aligned+0x44/0x70
[ 1549.300370] dma_alloc_contiguous+0x30/0x44
[ 1549.304539] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1549.310181] dma_direct_alloc+0xd8/0x304
[ 1549.314089] dma_alloc_attrs+0x7c/0xe4
[ 1549.317823] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1549.323472] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1549.329120] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1549.333900] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1549.339374] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1549.345022] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1549.349889] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1549.355538] v4l_reqbufs+0x50/0x64 [videodev]
[ 1549.35drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1549.517513] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1549.526712] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1549.532352] Call trace:
[ 1549.534785] dump_backtrace.part.0+0xdc/0xf0
[ 1549.539042] show_stack+0x18/0x30
[ 1549.542345] dump_stack_lvl+0x68/0x84
[ 1549.545994] dump_stack+0x18/0x34
[ 1549.549297] bad_page+0xe8/0x110
[ 1549.552512] free_page_is_bad_report+0x7c/0x90
[ 1549.556941] free_pcppages_bulk+0x198/0x1fc
[ 1549.561109] drain_pages_zone+0x64/0x84
[ 1549.564931] __drain_all_pages+0x178/0x220
[ 1549.569014] alloc_contig_range+0x130/0x280
[ 1549.573183] cma_alloc+0x120/0x310
[ 1549.576571] cma_alloc_aligned+0x44/0x70
[ 1549.580480] dma_alloc_contiguous+0x30/0x44
[ 1549.584648] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1549.590291] dma_direct_alloc+0xd8/0x304
[ 1549.594200] dma_alloc_attrs+0x7c/0xe4
[ 1549.597934] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1549.603582] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1549.609229] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1549.614009] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1549.619483] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1549.625132] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1549.630000] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1549.635651] v4l_reqbufs+0x50/0x64 [videodev]
[ 1549.640017] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1549.644985] video_usercopy+0x214/0x6c4 [videodev]
[ 1549.649781] video_ioctl2+0x18/0x2c [videodev]
[ 1549.654230] v4l2_ioctl+0x40/0x60 [videodev]
[ 1549.658506] __arm64_sys_ioctl+0xa8/0xf0
[ 1549.662414] invoke_syscall+0x48/0x114
[ 1549.666151] el0_svc_common.constprop.0+0xd4/0xfc
[ 1549.670840] do_el0_svc+0x30/0xd0
[ 1549.674143] el0_svc+0x2c/0x84
[ 1549.677184] el0721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1549.797631] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1549.806829] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1549.812470] Call trace:
[ 1549.814903] dump_backtrace.part.0+0xdc/0xf0
[ 1549.819160] show_stack+0x18/0x30
[ 1549.822463] dump_stack_lvl+0x68/0x84
[ 1549.826114] dump_stack+0x18/0x34
[ 1549.829417] bad_page+0xe8/0x110
[ 1549.832632] free_page_is_bad_report+0x7c/0x90
[ 1549.837061] free_pcppages_bulk+0x198/0x1fc
[ 1549.841229] drain_pages_zone+0x64/0x84
[ 1549.845052] __drain_all_pages+0x178/0x220
[ 1549.849133] alloc_contig_range+0x130/0x280
[ 1549.853303] cma_alloc+0x120/0x310
[ 1549.856691] cma_alloc_aligned+0x44/0x70
[ 1549.860600] dma_alloc_contiguous+0x30/0x44
[ 1549.864768] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1549.870410] dma_direct_alloc+0xd8/0x304
[ 1549.874318] dma_alloc_attrs+0x7c/0xe4
[ 1549.878053] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1549.883701] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1549.889350] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1549.894130] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1549.899604] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1549.905253] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1549.910120] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1549.915769] v4l_reqbufs+0x50/0x64 [videodev]
[ 1549.920133] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1549.925103] video_usercopy+0x214/0x6c4 [videodev]
[ 1549.929899] video_ioctl2+0x18/0x2c [videodev]
[ 1549.934348] v4l2_ioctl+0x40/0x60 [videodev]
[ 1549.938623] __arm64_sys_ioctl+0xa8/0xf0
[ 1549.942530] invoke_syscall+0x48/0x114
[ 1549.946267] el0_svc_common.constprop.0+0xd4/0xfc
[ 1549.950956] do_el0_svc+0x30/0xd0
[ 1549.954258] el0_svc+0x2c/0x84
[ 1549.957299] el0t_64_sync_handler+0xbc/0x140
[ 1549.961555] el0t_64_sync+0x18c/0x190
[ 1549.965204] BUG: Bad page state in process videotestsrc0:s pfn:9ef598
[ 1549.971711] page:00000000830b6872 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef506071] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1550.077746] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1550.086943] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1550.092584] Call trace:
[ 1550.095018] dump_backtrace.part.0+0xdc/0xf0
[ 1550.099275] show_stack+0x18/0x30
[ 1550.102577] dump_stack_lvl+0x68/0x84
[ 1550.106227] dump_stack+0x18/0x34
[ 1550.109530] bad_page+0xe8/0x110
[ 1550.112745] free_page_is_bad_report+0x7c/0x90
[ 1550.117173] free_pcppages_bulk+0x198/0x1fc
[ 1550.121341] drain_pages_zone+0x64/0x84
[ 1550.125162] __drain_all_pages+0x178/0x220
[ 1550.129245] alloc_contig_range+0x130/0x280
[ 1550.133413] cma_alloc+0x120/0x310
[ 1550.136801] cma_alloc_aligned+0x44/0x70
[ 1550.140710] dma_alloc_contiguous+0x30/0x44
[ 1550.144880] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1550.150522] dma_direct_alloc+0xd8/0x304
[ 1550.154431] dma_alloc_attrs+0x7c/0xe4
[ 1550.158166] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1550.163815] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1550.169462] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1550.174242] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1550.179716] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1550.185364] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1550.190233] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1550.195881] v4l_reqbufs+0x50/0x64 [videodev]
[ 155:0 mapping:0000000000000000 index:0x4 pfn:0x9ef599
[ 1550.261275] flags: 0x8000000000000000(zone=2) CMA
[ 1550.265966] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1550.273688] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1550.281409] page dumped because: nonzero _refcount
[ 1550.286181] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1550.357855] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1550.367050] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1550.372690] Call trace:
[ 1550.375123] dump_backtrace.part.0+0xdc/0xf0
[ 1550.379380] show_stack+0x18/0x30
[ 1550.382683] dump_stack_lvl+0x68/0x84
[ 1550.386334] dump_stack+0x18/0x34
[ 1550.389636] bad_page+0xe8/0x110
[ 1550.392851] free_page_is_bad_report+0x7c/0x90
[ 1550.397280] free_pcppages_bulk+0x198/0x1fc
[ 1550.401448] drain_pages_zone+0x64/0x84
[ 1550.405270] __drain_all_pages+0x178/0x220
[ 1550.409351] alloc_contig_range+0x130/0x280
[ 1550.413520] cma_alloc+0x120/0x310
[ 1550.416908] cma_alloc_aligned+0x44/0x70
[ 1550.420816] dma_alloc_contiguous+0x30/0x44
[ 1550.424985] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1550.430627] dma_direct_alloc+0xd8/0x304
[ 1550.434535] dma_alloc_attrs+0x7c/0xe4
[ 1550.438270] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1550.443918] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1550.44956__video_do_ioctl+0x184/0x3d0 [videodev]
[ 1550.485319] video_usercopy+0x214/0x6c4 [videodev]
[ 1550.490115] video_ioctl2+0x18/0x2c [videodev]
[ 1550.494564] v4l2_ioctl+0x40/0x60 [videodev]
[ 1550.498839] __arm64_sys_ioctl+0xa8/0xf0
[ 1550.502748] invoke_syscall+0x48/0x114
[ 1550.506484] el0_svc_common.constprop.0+0xd4/0xfc
[ 1550.511173] do_el0_svc+0x30/0xd0
[ 1550.514475] el0_svc+0x2c/0x84
[ 1550.517516] el0t_64_sync_handler+0xbc/0x140
[ 1550.521770] el0t_64_sync+0x18c/0x190
[ 1550.525417] BUG: Bad page state in process videotestsrc0:s pfn:9ef59a
[ 1550.531925] page:000000006e5fdbdc refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef59a
[ 1550.541380] flags: 0x8000000000000000(zone=2) CMA
[ 1550.546068] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1550.553789] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1550.561509] page dumped because: nonzero _refcount
[ 1550.566282] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1550.637958] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1550.647153] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1550.652793] Call trace:
[ 1550.655226] dump_backtrace.part.0+0xdc/0xf0
[ 1550.659483] show_stack+0x18/0x30
[ 1550.662786] dump_stack_lvl+0x68/0x84
[ 1550.666437] dump_stack+0x18/0x34
[ 1550.669740] bad_page+0xe8/0x110
[ 1550.672954] free_page_is_bs+0x7c/0xe4
[ 1550.718379] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1550.724027] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1550.729674] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1550.734455] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1550.739930] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1550.745578] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1550.750446] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1550.756094] v4l_reqbufs+0x50/0x64 [videodev]
[ 1550.760458] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1550.765427] video_usercopy+0x214/0x6c4 [videodev]
[ 1550.770224] video_ioctl2+0x18/0x2c [videodev]
[ 1550.774674] v4l2_ioctl+0x40/0x60 [videodev]
[ 1550.778950] __arm64_sys_ioctl+0xa8/0xf0
[ 1550.782858] invoke_syscall+0x48/0x114
[ 1550.786594] el0_svc_common.constprop.0+0xd4/0xfc
[ 1550.791285] do_el0_svc+0x30/0xd0
[ 1550.794588] el0_svc+0x2c/0x84
[ 1550.797629] el0t_64_sync_handler+0xbc/0x140
[ 1550.801884] el0t_64_sync+0x18c/0x190
[ 1550.805533] BUG: Bad page state in process videotestsrc0:s pfn:9ef59b
[ 1550.812040] page:00000000cc947a91 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef59b
[ 1550.821494] flags: 0x8000000000000000(zone=2) CMA
[ 1550.826182] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1550.833903] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1550.841624] page dumped because: nonzero _refcount
[ 1550.846397] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence n_quirks ipv6
[ 1550.918071] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1550.927269] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1550.932910] Call trace:
[ 1550.935343] dump_backtrace.part.0+0xdc/0xf0
[ 1550.939601] show_stack+0x18/0x30
[ 1550.942904] dump_stack_lvl+0x68/0x84
[ 1550.946555] dump_stack+0x18/0x34
[ 1550.949858] bad_page+0xe8/0x110
[ 1550.953072] free_page_is_bad_report+0x7c/0x90
[ 1550.957501] free_pcppages_bulk+0x198/0x1fc
[ 1550.961669] drain_pages_zone+0x64/0x84
[ 1550.965490] __drain_all_pages+0x178/0x220
[ 1550.969572] alloc_contig_range+0x130/0x280
[ 1550.973742] cma_alloc+0x120/0x310
[ 1550.977129] cma_alloc_aligned+0x44/0x70
[ 1550.981038] dma_alloc_contiguous+0x30/0x44
[ 1550.985206] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1550.990849] dma_direct_alloc+0xd8/0x304
[ 1550.994757] dma_alloc_attrs+0x7c/0xe4
[ 1550.998492] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1551.004142] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1551.009790] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1551.014570] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1551.020044] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1551.025692] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1551.030561] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1551.036211] v4l_reqbufs+0x50/0x64 [videodev]
[ 1551.040577] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1551.045547] video_usercopy+0x214/0x6c4 [videodev]
[ 1551.050342] video_ioctl2+0x18/0x2c [videodev]
[ 1551.054791] v4l2_ioctl+0x40/0x60 [videodev]
[ 1551.059067] __arm64_sys_ioctl+0xa8/0xf0
[ 1551.062975] invoke_syscall+0x48/0x114
[ 1551.066712] el0_svc_common.constprop.0+0xd4/0xfc
[ 1551.071401] do_el0_svc+0x30/0xd0
[ 1551.074703] el0_svc+0x2c/0x84
[ 1551.077744] el0t_64_sync_handler+0xbc/0x140
[ 1551.081998] el0t_64_sync+0x18c/0x190
[ 1551.085646] BUG: Bad page state in process videotestsrc0:s pfn:9ef59c
[ 1551.092153] page:00000000989a5506 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef59c
[ 1551.101608] flags: 0x8000000000000000(zone=2) CMA
[ 1551.106297] raw: 8000000000000000 dead0000000001deodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1551.198192] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1551.207390] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1551.213031] Call trace:
[ 1551.215465] dump_backtrace.part.0+0xdc/0xf0
[ 1551.219722] show_stack+0x18/0x30
[ 1551.223026] dump_stack_lvl+0x68/0x84
[ 1551.226676] dump_stack+0x18/0x34
[ 1551.229978] bad_page+0xe8/0x110
[ 1551.233194] free_page_is_bad_report+0x7c/0x90
[ 1551.237622] free_pcppages_bulk+0x198/0x1fc
[ 1551.241790] drain_pages_zone+0x64/0x84
[ 1551.245612] __drain_all_pages+0x178/0x220
[ 1551.249694] alloc_contig_range+0x130/0x280
[ 1551.253862] cma_alloc+0x120/0x310
[ 1551.257249] cma_alloc_aligned+0x44/0x70
[ 1551.261159] dma_alloc_contiguous+0x30/0x44
[ 1551.265327] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1551.270970] dma_direct_alloc+0xd8/0x304
[ 1551.274879] dma_alloc_attrs+0x7c/0xe4
[ 1551.278614] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1551.284263] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1551.289911] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1551.294691] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1551.300165] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1551.305812] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1551.310680] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1551.316329] v4l_reqbufs+0x50/0x64 [videodev]
[ 1551.320692] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1551.325661] video_usercopy+0x214/0x6c4 [videodev]
[ 1551.330456] video_ioctl2+0x18/0x2c [videodev]
[ 1551.334906] v4l2_ioctl+0x40/0x60 [videodev]
[ 1551.339181] __arm64_sys_ioctl+0xa8/0xf0
[ 1551.343089] invoke_syscall+0x48/0x114
[ 1551.346826] el0_svc_common.constprop.0+0xd4/0xfc
[ 1551.351515] do_el0_svc+0x30/0xd0
[ 1551.354818] el0_svc+0x2c/0x84
[ 1551.357g_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1551.478307] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1551.487515] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1551.493155] Call trace:
[ 1551.495588] dump_backtrace.part.0+0xdc/0xf0
[ 1551.499844] show_stack+0x18/0x30
[ 1551.503147] dump_stack_lvl+0x68/0x84
[ 1551.506796] dump_stack+0x18/0x34
[ 1551.510100] bad_page+0xe8/0x110
[ 1551.513314] free_page_is_bad_report+0x7c/0x90
[ 1551.517742] free_pcppages_bulk+0x198/0x1fc
[ 1551.521911] drain_pages_zone+0x64/0x84
[ 1551.525733] __drain_all_pages+0x178/0x220
[ 1551.529815] alloc_contig_range+0x130/0x280
[ 1551.533984] cma_alloc+0x120/0x310
[ 1551.537372] cma_alloc_aligned+0x44/0x70
[ 1551.541281] dma_alloc_contiguous+0x30/0x44
[ 1551.545451] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1551.551093] dma_direct_alloc+0xd8/0x304
[ 1551.555001] dma_alloc_attrs+0x7c/0xe4
[ 1551.558736] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1551.564384] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1551.570031] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1551.574812] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1551.580286] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1551.585935] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1551.590802] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1551.596451] v4l_reqbufs+0x50/0x64 [videodev]
[ 1551.600815] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1551.605785] video_usercopy+0x214/0x6c4 [videodev]
[ 1551.610581] video_ioctl2+0x18/0_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1551.758427] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1551.767624] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1551.773265] Call trace:
[ 1551.775697] dump_backtrace.part.0+0xdc/0xf0
[ 1551.779954] show_stack+0x18/0x30
[ 1551.783257] dump_stack_lvl+0x68/0x84
[ 1551.786906] dump_stack+0x18/0x34
[ 1551.790209] bad_page+0xe8/0x110
[ 1551.793424] free_page_is_bad_report+0x7c/0x90
[ 1551.797852] free_pcppages_bulk+0x198/0x1fc
[ 1551.802021] drain_pages_zone+0x64/0x84
[ 1551.805842] __drain_all_pages+0x178/0x220
[ 1551.809924] alloc_contig_range+0x130/0x280
[ 1551.814093] cma_alloc+0x120/0x310
[ 1551.817482] cma_alloc_aligned+0x44/0x70
[ 1551.821391] dma_alloc_contiguous+0x30/0x44
[ 1551.825560] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1551.831202] dma_direct_alloc+0xd8/0x304
[ 1551.835111] dma_alloc_attrs+0x7c/0xe4
[ 1551.838845] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1551.844493] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1551.850140] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1551.854921] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1551.860395] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1551.866043] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1551.870910] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1551.876559] v4l_reqbufs+0x50/0x64 [videodev]
[ 1551.880923] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1551.885892] video_usercopy+0x214/0x6c4 [videodev]
[ 1551.890689] video_ioctl2+0x18/0x2c [videodev]
[ 1551.895139] v4l2_ioctl+0x40/0x60 [videodev]
[ 1551.899414] __arm64_sys_ioctl+0xa8/0xf0
[ 1551.903322] invoke_syscall+0x48/0x114
[ 1551.907059] el0_svc_common1 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1552.038535] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1552.047732] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1552.053372] Call trace:
[ 1552.055804] dump_backtrace.part.0+0xdc/0xf0
[ 1552.060061] show_stack+0x18/0x30
[ 1552.063364] dump_stack_lvl+0x68/0x84
[ 1552.067014] dump_stack+0x18/0x34
[ 1552.070317] bad_page+0xe8/0x110
[ 1552.073532] free_page_is_bad_report+0x7c/0x90
[ 1552.077960] free_pcppages_bulk+0x198/0x1fc
[ 1552.082128] drain_pages_zone+0x64/0x84
[ 1552.085950] __drain_all_pages+0x178/0x220
[ 1552.090032] alloc_contig_range+0x130/0x280
[ 1552.094201] cma_alloc+0x120/0x310
[ 1552.097588] cma_alloc_aligned+0x44/0x70
[ 1552.101497] dma_alloc_contiguous+0x30/0x44
[ 1552.105665] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1552.111308] dma_direct_alloc+0xd8/0x304
[ 1552.115216] dma_alloc_attrs+0x7c/0xe4
[ 1552.118952] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1552.124599] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1552.130246] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1552.135027] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1552.140501] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1552.146149] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1552.151017] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1552.156665] v4l_reqbufs+0x50/0x64 [videodev]
[ 1552.161031] __video_do_ioctl+0x184/0:0000000000000000 index:0x4 pfn:0x9ef5a0
[ 1552.222063] flags: 0x8000000000000000(zone=2) CMA
[ 1552.226754] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1552.234475] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1552.242196] page dumped because: nonzero _refcount
[ 1552.246970] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1552.318644] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1552.327838] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1552.333478] Call trace:
[ 1552.335911] dump_backtrace.part.0+0xdc/0xf0
[ 1552.340167] show_stack+0x18/0x30
[ 1552.343470] dump_stack_lvl+0x68/0x84
[ 1552.347120] dump_stack+0x18/0x34
[ 1552.350423] bad_page+0xe8/0x110
[ 1552.353637] free_page_is_bad_report+0x7c/0x90
[ 1552.358065] free_pcppages_bulk+0x198/0x1fc
[ 1552.362234] drain_pages_zone+0x64/0x84
[ 1552.366057] __drain_all_pages+0x178/0x220
[ 1552.370138] alloc_contig_range+0x130/0x280
[ 1552.374308] cma_alloc+0x120/0x310
[ 1552.377696] cma_alloc_aligned+0x44/0x70
[ 1552.381605] dma_alloc_contiguous+0x30/0x44
[ 1552.385775] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1552.391416] dma_direct_alloc+0xd8/0x304
[ 1552.395325] dma_alloc_attrs+0x7c/0xe4
[ 1552.399059] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1552.404707] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1552.41035usercopy+0x214/0x6c4 [videodev]
[ 1552.450904] video_ioctl2+0x18/0x2c [videodev]
[ 1552.455354] v4l2_ioctl+0x40/0x60 [videodev]
[ 1552.459630] __arm64_sys_ioctl+0xa8/0xf0
[ 1552.463537] invoke_syscall+0x48/0x114
[ 1552.467274] el0_svc_common.constprop.0+0xd4/0xfc
[ 1552.471963] do_el0_svc+0x30/0xd0
[ 1552.475266] el0_svc+0x2c/0x84
[ 1552.478307] el0t_64_sync_handler+0xbc/0x140
[ 1552.482562] el0t_64_sync+0x18c/0x190
[ 1552.486210] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a1
[ 1552.492717] page:000000000918dd3c refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a1
[ 1552.502172] flags: 0x8000000000000000(zone=2) CMA
[ 1552.506860] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1552.514581] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1552.522301] page dumped because: nonzero _refcount
[ 1552.527074] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1552.598748] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1552.607943] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1552.613583] Call trace:
[ 1552.616015] dump_backtrace.part.0+0xdc/0xf0
[ 1552.620272] show_stack+0x18/0x30
[ 1552.623575] dump_stack_lvl+0x68/0x84
[ 1552.627225] dump_stack+0x18/0x34
[ 1552.630527] bad_page+0xe8/0x110
[ 1552.633742] free_page_is_bad_report+0x7c/0x90
[ 1552.638171] free_pcppages_bulk+0xx460 [videobuf2_common]
[ 1552.706367] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1552.711235] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1552.716885] v4l_reqbufs+0x50/0x64 [videodev]
[ 1552.721251] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1552.726221] video_usercopy+0x214/0x6c4 [videodev]
[ 1552.731016] video_ioctl2+0x18/0x2c [videodev]
[ 1552.735465] v4l2_ioctl+0x40/0x60 [videodev]
[ 1552.739742] __arm64_sys_ioctl+0xa8/0xf0
[ 1552.743649] invoke_syscall+0x48/0x114
[ 1552.747385] el0_svc_common.constprop.0+0xd4/0xfc
[ 1552.752075] do_el0_svc+0x30/0xd0
[ 1552.755378] el0_svc+0x2c/0x84
[ 1552.758419] el0t_64_sync_handler+0xbc/0x140
[ 1552.762674] el0t_64_sync+0x18c/0x190
[ 1552.766321] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a2
[ 1552.772829] page:000000007f9d865f refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a2
[ 1552.782283] flags: 0x8000000000000000(zone=2) CMA
[ 1552.786971] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1552.794693] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1552.802413] page dumped because: nonzero _refcount
[ 1552.807186] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1552.878863] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1552.888058] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1552.893698] Call trace:
[ 1552.896131] dma_alloc_contiguous+0x30/0x44
[ 1552.945993] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1552.951637] dma_direct_alloc+0xd8/0x304
[ 1552.955546] dma_alloc_attrs+0x7c/0xe4
[ 1552.959281] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1552.964929] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1552.970578] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1552.975359] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1552.980833] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1552.986481] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1552.991349] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1552.996997] v4l_reqbufs+0x50/0x64 [videodev]
[ 1553.001360] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1553.006330] video_usercopy+0x214/0x6c4 [videodev]
[ 1553.011127] video_ioctl2+0x18/0x2c [videodev]
[ 1553.015577] v4l2_ioctl+0x40/0x60 [videodev]
[ 1553.019853] __arm64_sys_ioctl+0xa8/0xf0
[ 1553.023760] invoke_syscall+0x48/0x114
[ 1553.027497] el0_svc_common.constprop.0+0xd4/0xfc
[ 1553.032186] do_el0_svc+0x30/0xd0
[ 1553.035489] el0_svc+0x2c/0x84
[ 1553.038530] el0t_64_sync_handler+0xbc/0x140
[ 1553.042785] el0t_64_sync+0x18c/0x190
[ 1553.046434] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a3
[ 1553.052942] page:000000004c62a875 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a3
[ 1553.062396] flags: 0x8000000000000000(zone=2) CMA
[ 1553.067084] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1553.074806] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1553.082526] page dumped because: nonzero _refcount
[ 1553.087300] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimg fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1553.158976] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1553.168174] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1553.173814] Call trace:
[ 1553.176247] dump_backtrace.part.0+0xdc/0xf0
[ 1553.180504] show_stack+0x18/0x30
[ 1553.183807] dump_stack_lvl+0x68/0x84
[ 1553.187456] dump_stack+0x18/0x34
[ 1553.190759] bad_page+0xe8/0x110
[ 1553.193975] free_page_is_bad_report+0x7c/0x90
[ 1553.198403] free_pcppages_bulk+0x198/0x1fc
[ 1553.202572] drain_pages_zone+0x64/0x84
[ 1553.206395] __drain_all_pages+0x178/0x220
[ 1553.210477] alloc_contig_range+0x130/0x280
[ 1553.214647] cma_alloc+0x120/0x310
[ 1553.218035] cma_alloc_aligned+0x44/0x70
[ 1553.221944] dma_alloc_contiguous+0x30/0x44
[ 1553.226113] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1553.231755] dma_direct_alloc+0xd8/0x304
[ 1553.235664] dma_alloc_attrs+0x7c/0xe4
[ 1553.239399] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1553.245047] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1553.250694] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1553.255475] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1553.260948] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1553.266596] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1553.271464] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1553.277114] v4l_reqbufs+0x50/0x64 [videodev]
[ 1553.281478] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1553.286446] video_usercopy+0x214/0x6c4 [videodev]
[ 1553.291242] video_ioctl2+0x18/0x2c [videodev]
[ 1553.295692] v4l2_ioctl+0x40/0x60 [videodev]
[ 1553.299968] __arm64_sys_ioctl+0xa8/0xf0
[ 1553.303876] invoke_syscall+0x48/0x114
[ 1553.307613] el0_svc_common.constprop.0+0xd4/0xfc
[ 1553.312302] do_el0_svc+0x30/0xd0
[ 1553.315605] el0_svc+0x2c/0x84
[ 1553.318646] el0t_64_sync_handler+0xbc/0x140
[ 1553.322901] el0t_64_sync+0x18c/0x190
[ 1553.326548] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a4
[ 1553.333055] page:000000009ec826f9 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a4
[ 1553.342511] flags: 0x8000000000000000(zone=2) CMA
[ 1553.347198] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1553.354920] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1553.362641] page dumped because: nonzero _refcount
[ 1553.367414] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1553.439093] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1553.448288] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1553.453928] Call trace:
[ 1553.456361] dump_backtrace.part.0+0xdc/0xf0
[ 1553.460617] show_stack+0x18/0x30
[ 1553.463920] dump_stack_lvl+0x68/0x84
[ 1553.467570] dump_stack+0x18/0x34
[ 1553.470873] bad_page+0xe8/0x110
[ 1553.474089] free_page_is_bad_report+0x7c/0x90
[ 1553.478517] free_pcppages_bulk+0x198/0x1fc
[ 1553.482686] drain_pages_zone+0x64/0x84
[ 1553.486507] __drain_all_pages+0x178/0x220
[ 1553.490589] alloc_contig_range+0x130/0x280
[ 1553.494759] cma_alloc+0x120/0x310
[ 1553.498147] cma_alloc_aligned+0x44/0x70
[ 1553.502056] dma_alloc_contiguous+0x30/0x44
[ 1553.506225] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1553.511868] dma_direct_alloc+0xd8/0x304
[ 1553.515776] dma_alloc_attrs+0x7c/0xe4
[ 1553.519511] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1553.525160] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1553.530807] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1553.535588] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1553.541062] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1553.546709] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1553.551576] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1553.557225] v4l_reqbufs+0x50/0x64 [videodev]
[ 1553.561588] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1553.566557] video_usercopy+0x214/0x6c4 [videodev]
[ 1553.571353] video_ioctl2+0x18/0x2c [videodev]
[ 1553.575803] v4l2_ioctl+0x40/0x60 [videodev]
[ 1553.580078] __arm64_sys_ioctl+0xa8/0xf0
[ 1553.583986] invoke_syscall+0x48/0x114
[ 1553.587723] el0_svc_common.constprop.0+0xd4/0xfc
[ 1553.592412] do_el0_svc+0x30/0xd0
[ 1553.595715] el0_svc+0x2c/0x84
[ 1553.598757] el0t_64_sync_handler+0xbc/0x140
[ 1553.603011] el0t_64_sync+0x18c/0x190
[ 1553.606660] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a5
[ 1553.613168] page:00000000e915ebea refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a5
[ 1553.622623] flags: 0x8000000000000000(zone=2) CMA
[ 1553.627311] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1553.635032] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1553.642752] page dumped because: nonzero _refcount
[ 1553.647526] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1553.719202] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1553.728397] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1553.734038] Call trace:
[ 1553.736471] dump_backtrace.part.0+0xdc/0xf0
[ 1553.740727] show_stack+0x18/0x30
[ 1553.744030] dump_stack_lvl+0x68/0x84
[ 1553.747680] dump_stack+0x18/0x34
[ 1553.750983] bad_page+0xe8/0x110
[ 1553.754198] free_page_is_bad_report+0x7c/0x90
[ 1553.758627] free_pcppages_bulk+0x198/0x1fc
[ 1553.762797] drain_pages_zone+0x64/0x84
[ 1553.766618] __drain_all_pages+0x178/0x220
[ 1553.770700] alloc_contig_range+0x130/0x280
[ 1553.774868] cma_alloc+0x120/0x310
[ 1553.778256] cma_alloc_aligned+0x44/0x70
[ 1553.782166] dma_alloc_contiguous+0x30/0x44
[ 1553.786335] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1553.791978] dma_direct_alloc+0xd8/0x304
[ 1553.795886] dma_alloc_attrs+0x7c/0xe4
[ 1553.799621] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1553.805270] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1553.810917] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1553.815698] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1553.821172] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1553.826820] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1553.831688] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1553.837336] v4l_reqbufs+0x50/0x64 [videodev]
[ 1553.841700] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1553.846670] video_usercopy+0x214/0x6c4 [videodev]
[ 1553.851466] video_ioctl2+0x18/0x2c [videodev]
[ 1553.855915] v4l2_ioctl+0x40/0x60 [videodev]
[ 1553.860191] __arm64_sys_ioctl+0xa8/0xf0
[ 1553.864099] invoke_syscall+0x48/0x114
[ 1553.867835] el0_svc_common.constprop.0+0xd4/0xfc
[ 1553.872524] do_el0_svc+0x30/0xd0
[ 1553.875827] el0_svc+0x2c/0x84
[ 1553.878869] el0t_64_sync_handler+0xbc/0x140
[ 1553.883123] el0t_64_sync+0x18c/0x190
[ 1553.886772] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a6
[ 1553.893280] page:00000000eabe3cc1 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a6
[ 1553.902734] flags: 0x8000000000000000(zone=2) CMA
[ 1553.907422] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1553.915143] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1553.922863] page dumped because: nonzero _refcount
[ 1553.927637] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1553.999312] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1554.008507] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1554.014148] Call trace:
[ 1554.016580] dump_backtrace.part.0+0xdc/0xf0
[ 1554.020837] show_stack+0x18/0x30
[ 1554.024139] dump_stack_lvl+0x68/0x84
[ 1554.027789] dump_stack+0x18/0x34
[ 1554.031092] bad_page+0xe8/0x110
[ 1554.034306] free_page_is_bad_report+0x7c/0x90
[ 1554.038736] free_pcppages_bulk+0x198/0x1fc
[ 1554.042905] drain_pages_zone+0x64/0x84
[ 1554.046727] __drain_all_pages+0x178/0x220
[ 1554.050808] alloc_contig_range+0x130/0x280
[ 1554.054976] cma_alloc+0x120/0x310
[ 1554.058364] cma_alloc_aligned+0x44/0x70
[ 1554.062273] dma_alloc_contiguous+0x30/0x44
[ 1554.066443] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1554.072085] dma_direct_alloc+0xd8/0x304
[ 1554.075993] dma_alloc_attrs+0x7c/0xe4
[ 1554.079728] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1554.085376] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1554.091024] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1554.095804] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1554.101277] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1554.106926] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1554.111794] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1554.117443] v4l_reqbufs+0x50/0x64 [videodev]
[ 1554.121806] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1554.126775] video_usercopy+0x214/0x6c4 [videodev]
[ 1554.131571] video_ioctl2+0x18/0x2c [videodev]
[ 1554.136021] v4l2_ioctl+0x40/0x60 [videodev]
[ 1554.140297] __arm64_sys_ioctl+0xa8/0xf0
[ 1554.144205] invoke_syscall+0x48/0x114
[ 1554.147942] el0_svc_common.constprop.0+0xd4/0xfc
[ 1554.152631] do_el0_svc+0x30/0xd0
[ 1554.155933] el0_svc+0x2c/0x84
[ 1554.158974] el0t_64_sync_handler+0xbc/0x140
[ 1554.163229] el0t_64_sync+0x18c/0x190
[ 1554.166876] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a7
[ 1554.173384] page:0000000051606b8d refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a7
[ 1554.182839] flags: 0x8000000000000000(zone=2) CMA
[ 1554.187527] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1554.195248] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1554.202969] page dumped because: nonzero _refcount
[ 1554.207743] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1554.279421] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1554.288616] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1554.294256] Call trace:
[ 1554.296689] dump_backtrace.part.0+0xdc/0xf0
[ 1554.300945] show_stack+0x18/0x30
[ 1554.304248] dump_stack_lvl+0x68/0x84
[ 1554.307898] dump_stack+0x18/0x34
[ 1554.311201] bad_page+0xe8/0x110
[ 1554.314415] free_page_is_bad_report+0x7c/0x90
[ 1554.318843] free_pcppages_bulk+0x198/0x1fc
[ 1554.323012] drain_pages_zone+0x64/0x84
[ 1554.326835] __drain_all_pages+0x178/0x220
[ 1554.330916] alloc_contig_range+0x130/0x280
[ 1554.335086] cma_alloc+0x120/0x310
[ 1554.338475] cma_alloc_aligned+0x44/0x70
[ 1554.342384] dma_alloc_contiguous+0x30/0x44
[ 1554.346553] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1554.352195] dma_direct_alloc+0xd8/0x304
[ 1554.356103] dma_alloc_attrs+0x7c/0xe4
[ 1554.359838] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1554.365486] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1554.371133] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1554.375913] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1554.381387] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1554.387036] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1554.391903] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1554.397551] v4l_reqbufs+0x50/0x64 [videodev]
[ 1554.401914] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1554.406883] video_usercopy+0x214/0x6c4 [videodev]
[ 1554.411679] video_ioctl2+0x18/0x2c [videodev]
[ 1554.416128] v4l2_ioctl+0x40/0x60 [videodev]
[ 1554.420404] __arm64_sys_ioctl+0xa8/0xf0
[ 1554.424312] invoke_syscall+0x48/0x114
[ 1554.428048] el0_svc_common.constprop.0+0xd4/0xfc
[ 1554.432738] do_el0_svc+0x30/0xd0
[ 1554.436040] el0_svc+0x2c/0x84
[ 1554.439082] el0t_64_sync_handler+0xbc/0x140
[ 1554.443337] el0t_64_sync+0x18c/0x190
[ 1554.446986] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a8
[ 1554.453492] page:00000000649f7e6f refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a8
[ 1554.462947] flags: 0x8000000000000000(zone=2) CMA
[ 1554.467634] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1554.475356] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1554.483076] page dumped because: nonzero _refcount
[ 1554.487850] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse dr554.632304] dma_direct_alloc+0xd8/0x304
[ 1554.636212] dma_alloc_attrs+0x7c/0xe4
[ 1554.639949] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1554.645598] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1554.651245] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1554.656026] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1554.661500] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1554.667149] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1554.672017] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1554.677666] v4l_reqbufs+0x50/0x64 [videodev]
[ 1554.682030] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1554.686998] video_usercopy+0x214/0x6c4 [videodev]
[ 1554.691793] video_ioctl2+0x18/0x2c [videodev]
[ 1554.696243] v4l2_ioctl+0x40/0x60 [videodev]
[ 1554.700519] __arm64_sys_ioctl+0xa8/0xf0
[ 1554.704427] invoke_syscall+0x48/0x114
[ 1554.708163] el0_svc_common.constprop.0+0xd4/0xfc
[ 1554.712852] do_el0_svc+0x30/0xd0
[ 1554.716155] el0_svc+0x2c/0x84
[ 1554.719195] el0t_64_sync_handler+0xbc/0x140
[ 1554.723451] el0t_64_sync+0x18c/0x190
[ 1554.727100] BUG: Bad page state in process videotestsrc0:s pfn:9ef5a9
[ 1554.733607] page:0000000012f7ec41 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5a9
[ 1554.743062] flags: 0x8000000000000000(zone=2) CMA
[ 1554.747750] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1554.755471] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1554.763191] page dumped because: nonzero _refcount
[ 1554.767964] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1554.925711] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1554.931360] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1554.936140] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1554.941614] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1554.947263] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1554.952132] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1554.957780] v4l_reqbufs+0x50/0x64 [videodev]
[ 1554.962146] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1554.967116] video_usercopy+0x214/0x6c4 [videodev]
[ 1554.971911] video_ioctl2+0x18/0x2c [videodev]
[ 1554.976360] v4l2_ioctl+0x40/0x60 [videodev]
[ 1554.980637] __arm64_sys_ioctl+0xa8/0xf0
[ 1554.984545] invoke_syscall+0x48/0x114
[ 1554.988281] el0_svc_common.constprop.0+0xd4/0xfc
[ 1554.992971] do_el0_svc+0x30/0xd0
[ 1554.996274] el0_svc+0x2c/0x84
[ 1554.999315] el0t_64_sync_handler+0xbc/0x140
[ 1555.003569] el0t_64_sync+0x18c/0x190
[ 1555.007218] BUG: Bad page state in process videotestsrc0:s pfn:9ef5aa
[ 1555.013724] page:0000000049107f61 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5aa
[ 1555.023179] flags: 0x8000000000000000(zone=2) CMA
[ 1555.027868] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1555.035589] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1555.043309] page dumped because: nonzero _refcount
[ 1555.048083] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core crypto wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1555.221726] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1555.227374] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1555.232242] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1555.237891] v4l_reqbufs+0x50/0x64 [videodev]
[ 1555.242253] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1555.247223] video_usercopy+0x214/0x6c4 [videodev]
[ 1555.252019] video_ioctl2+0x18/0x2c [videodev]
[ 1555.256468] v4l2_ioctl+0x40/0x60 [videodev]
[ 1555.260745] __arm64_sys_ioctl+0xa8/0xf0
[ 1555.264654] invoke_syscall+0x48/0x114
[ 1555.268390] el0_svc_common.constprop.0+0xd4/0xfc
[ 1555.273080] do_el0_svc+0x30/0xd0
[ 1555.276382] el0_svc+0x2c/0x84
[ 1555.279423] el0t_64_sync_handler+0xbc/0x140
[ 1555.283679] el0t_64_sync+0x18c/0x190
[ 1555.287328] BUG: Bad page state in process videotestsrc0:s pfn:9ef5ab
[ 1555.293835] page:0000000001d797de refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5ab
[ 1555.303289] flags: 0x8000000000000000(zone=2) CMA
[ 1555.307976] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1555.315697] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1555.323417] page dumped because: nonzero _refcount
[ 1555.328190] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1555.399867] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1555.409062] Hardware n0x7c/0x90
[ 1555.439295] free_pcppages_bulk+0x198/0x1fc
[ 1555.443467] drain_pages_zone+0x64/0x84
[ 1555.447290] __drain_all_pages+0x178/0x220
[ 1555.451371] alloc_contig_range+0x130/0x280
[ 1555.455541] cma_alloc+0x120/0x310
[ 1555.458929] cma_alloc_aligned+0x44/0x70
[ 1555.462838] dma_alloc_contiguous+0x30/0x44
[ 1555.467008] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1555.472650] dma_direct_alloc+0xd8/0x304
[ 1555.476558] dma_alloc_attrs+0x7c/0xe4
[ 1555.480293] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1555.485941] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1555.491588] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1555.496369] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1555.501842] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1555.507491] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1555.512359] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1555.518008] v4l_reqbufs+0x50/0x64 [videodev]
[ 1555.522371] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1555.527341] video_usercopy+0x214/0x6c4 [videodev]
[ 1555.532137] video_ioctl2+0x18/0x2c [videodev]
[ 1555.536586] v4l2_ioctl+0x40/0x60 [videodev]
[ 1555.540862] __arm64_sys_ioctl+0xa8/0xf0
[ 1555.544769] invoke_syscall+0x48/0x114
[ 1555.548505] el0_svc_common.constprop.0+0xd4/0xfc
[ 1555.553196] do_el0_svc+0x30/0xd0
[ 1555.556499] el0_svc+0x2c/0x84
[ 1555.559540] el0t_64_sync_handler+0xbc/0x140
[ 1555.563794] el0t_64_sync+0x18c/0x190
[ 1555.567442] BUG: Bad page state in process videotestsrc0:s pfn:9ef5ac
[ 1555.573948] page:000000007c995c2b refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5ac
[ 1555.583404] flags: 0x8000000000000000(zone=2) CMA
[ 1555.588092] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1555.595813] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1555.603534] page dumped because: nonzero _refcount
[ 1555.608308] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2d8/0x304
[ 1555.756666] dma_alloc_attrs+0x7c/0xe4
[ 1555.760404] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1555.766052] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1555.771699] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1555.776479] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1555.781953] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1555.787603] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1555.792471] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1555.798120] v4l_reqbufs+0x50/0x64 [videodev]
[ 1555.802482] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1555.807451] video_usercopy+0x214/0x6c4 [videodev]
[ 1555.812247] video_ioctl2+0x18/0x2c [videodev]
[ 1555.816697] v4l2_ioctl+0x40/0x60 [videodev]
[ 1555.820973] __arm64_sys_ioctl+0xa8/0xf0
[ 1555.824880] invoke_syscall+0x48/0x114
[ 1555.828617] el0_svc_common.constprop.0+0xd4/0xfc
[ 1555.833306] do_el0_svc+0x30/0xd0
[ 1555.836608] el0_svc+0x2c/0x84
[ 1555.839650] el0t_64_sync_handler+0xbc/0x140
[ 1555.843905] el0t_64_sync+0x18c/0x190
[ 1555.847554] BUG: Bad page state in process videotestsrc0:s pfn:9ef5ad
[ 1555.854061] page:000000009e2e42bc refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5ad
[ 1555.863516] flags: 0x8000000000000000(zone=2) CMA
[ 1555.868205] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1555.875925] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1555.883646] page dumped because: nonzero _refcount
[ 1555.888419] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host p
[ 1555.977363] dump_backtrace.part.0+0xdc/0xf0
[ 1555.981619] show_stack+0x18/0x30
[ 1555.984924] dump_stack_lvl+0x68/0x84
[ 1555.988574] dump_stack+0x18/0x34
[ 1555.991877] bad_page+0xe8/0x110
[ 1555.995093] free_page_is_bad_report+0x7c/0x90
[ 1555.999522] free_pcppages_bulk+0x198/0x1fc
[ 1556.003691] drain_pages_zone+0x64/0x84
[ 1556.007513] __drain_all_pages+0x178/0x220
[ 1556.011595] alloc_contig_range+0x130/0x280
[ 1556.015764] cma_alloc+0x120/0x310
[ 1556.019151] cma_alloc_aligned+0x44/0x70
[ 1556.023060] dma_alloc_contiguous+0x30/0x44
[ 1556.027230] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1556.032872] dma_direct_alloc+0xd8/0x304
[ 1556.036780] dma_alloc_attrs+0x7c/0xe4
[ 1556.040515] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1556.046164] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1556.051811] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1556.056593] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1556.062067] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1556.067715] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1556.072583] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1556.078232] v4l_reqbufs+0x50/0x64 [videodev]
[ 1556.082595] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1556.087565] video_usercopy+0x214/0x6c4 [videodev]
[ 1556.092360] video_ioctl2+0x18/0x2c [videodev]
[ 1556.096809] v4l2_ioctl+0x40/0x60 [videodev]
[ 1556.101086] __arm64_sys_ioctl+0xa8/0xf0
[ 1556.104993] invoke_syscall+0x48/0x114
[ 1556.108729] el0_svc_common.constprop.0+0xd4/0xfc
[ 1556.113419] do_el0_svc+0x30/0xd0
[ 1556.116722] el0_svc+0x2c/0x84
[ 1556.119762] el0t_64_sync_handler+0xbc/0x140
[ 1556.124018] el0t_64_sync+0x18c/0x190
[ 1556.127667] BUG: Bad page state in process videotestsrc0:s pfn:9ef5ae
[ 1556.134173] page:00000000e9ac4c89 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5ae
[ 1556.143628] flags: 0x8000000000000000(zone=2) CMA
[ 1556.148316] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1556.156038] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1556.163757] page dumped because: nonzero _refcount
[ 1556.168530] Modules linked i2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1556.240206] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1556.249405] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1556.255045] Call trace:
[ 1556.257478] dump_backtrace.part.0+0xdc/0xf0
[ 1556.261735] show_stack+0x18/0x30
[ 1556.265038] dump_stack_lvl+0x68/0x84
[ 1556.268687] dump_stack+0x18/0x34
[ 1556.271990] bad_page+0xe8/0x110
[ 1556.275205] free_page_is_bad_report+0x7c/0x90
[ 1556.279633] free_pcppages_bulk+0x198/0x1fc
[ 1556.283802] drain_pages_zone+0x64/0x84
[ 1556.287623] __drain_all_pages+0x178/0x220
[ 1556.291705] alloc_contig_range+0x130/0x280
[ 1556.295874] cma_alloc+0x120/0x310
[ 1556.299262] cma_alloc_aligned+0x44/0x70
[ 1556.303172] dma_alloc_contiguous+0x30/0x44
[ 1556.307341] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1556.312983] dma_direct_alloc+0xd8/0x304
[ 1556.316891] dma_alloc_attrs+0x7c/0xe4
[ 1556.320626] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1556.326275] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1556.331922] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1556.336702] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1556.342176] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1556.347824] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1556.352693] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1556.358342] v4l_reqbufs+0x50/0x64 [videodev]
[ 1556.362704] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1556.367674] video_usercopy+0x214/0x6c4 [videodev]
[ 1556.372470] video_ioctl2+0x18/0x2c [videodev]
[ 1556.376920] v4l2_ioctl+0x40/0x60 [videodev]
[ 1556.381196] __arm64_sys_ioctl+0xa8/0xf0
[ 1556.385104_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1556.520319] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1556.529517] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1556.535157] Call trace:
[ 1556.537590] dump_backtrace.part.0+0xdc/0xf0
[ 1556.541846] show_stack+0x18/0x30
[ 1556.545149] dump_stack_lvl+0x68/0x84
[ 1556.548799] dump_stack+0x18/0x34
[ 1556.552102] bad_page+0xe8/0x110
[ 1556.555316] free_page_is_bad_report+0x7c/0x90
[ 1556.559744] free_pcppages_bulk+0x198/0x1fc
[ 1556.563913] drain_pages_zone+0x64/0x84
[ 1556.567736] __drain_all_pages+0x178/0x220
[ 1556.571818] alloc_contig_range+0x130/0x280
[ 1556.575987] cma_alloc+0x120/0x310
[ 1556.579375] cma_alloc_aligned+0x44/0x70
[ 1556.583285] dma_alloc_contiguous+0x30/0x44
[ 1556.587454] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1556.593096] dma_direct_alloc+0xd8/0x304
[ 1556.597004] dma_alloc_attrs+0x7c/0xe4
[ 1556.600739] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1556.606387] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1556.612035] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1556.616815] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1556.622289] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1556.627938] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1556.632806] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1556.638455] v4l_reqbufs+0x50/0x64 [videodev]
[ 1556.642818] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1556.647788] video_usercopy+0x214/0x6c4 [videodev]
[ 1556.652583] video_ioctl2+0x18/0x2c [videodev]
[ 1556.657033] v4l2_ioctl+0x40/0x60 [videodev]
[ 1556.661309] __arm64_sys_ioctl+0xa8/0xf0
[ 1556.665216] invoke_syscall+0x48/0x114
[ 1556.668953] el0_svc_common.constprop.0+0xd4/0xfc
[ 1556.673643] do_el0_svc+0x30/0xd0
[ 1556.676946] hdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1556.800436] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1556.809633] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1556.815273] Call trace:
[ 1556.817705] dump_backtrace.part.0+0xdc/0xf0
[ 1556.821962] show_stack+0x18/0x30
[ 1556.825265] dump_stack_lvl+0x68/0x84
[ 1556.828915] dump_stack+0x18/0x34
[ 1556.832218] bad_page+0xe8/0x110
[ 1556.835434] free_page_is_bad_report+0x7c/0x90
[ 1556.839862] free_pcppages_bulk+0x198/0x1fc
[ 1556.844030] drain_pages_zone+0x64/0x84
[ 1556.847852] __drain_all_pages+0x178/0x220
[ 1556.851934] alloc_contig_range+0x130/0x280
[ 1556.856102] cma_alloc+0x120/0x310
[ 1556.859489] cma_alloc_aligned+0x44/0x70
[ 1556.863398] dma_alloc_contiguous+0x30/0x44
[ 1556.867568] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1556.873210] dma_direct_alloc+0xd8/0x304
[ 1556.877118] dma_alloc_attrs+0x7c/0xe4
[ 1556.880853] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1556.886501] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1556.892148] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1556.896928] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1556.902402] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1556.908051] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1556.912919] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1556.918567] v4l_reqbufs+0x50/0x64 [videodev]
[ 1556.922929] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1556.927898] video_usercopy+0x214/0x6c4 [videodev]
[ 1556.932694] video_ioctl2+0x18/0x2c [videodev]
[ 1556.937143] v4l2_ioctl+0x40/0x60 [videodev]
[ 1556.941419] __arm64_sys_ioctl+0xa8/0xf0
[ 1556.945327] invoke_syscall+0x48/0x114
[ 1556.949064] el0_svc_d because: nonzero _refcount
[ 1557.008869] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1557.080545] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1557.089741] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1557.095381] Call trace:
[ 1557.097813] dump_backtrace.part.0+0xdc/0xf0
[ 1557.102071] show_stack+0x18/0x30
[ 1557.105373] dump_stack_lvl+0x68/0x84
[ 1557.109024] dump_stack+0x18/0x34
[ 1557.112327] bad_page+0xe8/0x110
[ 1557.115543] free_page_is_bad_report+0x7c/0x90
[ 1557.119971] free_pcppages_bulk+0x198/0x1fc
[ 1557.124140] drain_pages_zone+0x64/0x84
[ 1557.127962] __drain_all_pages+0x178/0x220
[ 1557.132043] alloc_contig_range+0x130/0x280
[ 1557.136212] cma_alloc+0x120/0x310
[ 1557.139600] cma_alloc_aligned+0x44/0x70
[ 1557.143508] dma_alloc_contiguous+0x30/0x44
[ 1557.147677] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1557.153319] dma_direct_alloc+0xd8/0x304
[ 1557.157227] dma_alloc_attrs+0x7c/0xe4
[ 1557.160962] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1557.166610] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1557.172258] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1557.177038] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1557.182512] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1557.188160] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1557.193028] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1557.198677] 9] el0t_64_sync_handler+0xbc/0x140
[ 1557.244464] el0t_64_sync+0x18c/0x190
[ 1557.248115] BUG: Bad page state in process videotestsrc0:s pfn:9ef5b2
[ 1557.254622] page:000000005e1b83cf refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5b2
[ 1557.264077] flags: 0x8000000000000000(zone=2) CMA
[ 1557.268765] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1557.276486] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1557.284207] page dumped because: nonzero _refcount
[ 1557.288981] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1557.360656] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1557.369850] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1557.375490] Call trace:
[ 1557.377923] dump_backtrace.part.0+0xdc/0xf0
[ 1557.382179] show_stack+0x18/0x30
[ 1557.385482] dump_stack_lvl+0x68/0x84
[ 1557.389132] dump_stack+0x18/0x34
[ 1557.392435] bad_page+0xe8/0x110
[ 1557.395649] free_page_is_bad_report+0x7c/0x90
[ 1557.400077] free_pcppages_bulk+0x198/0x1fc
[ 1557.404246] drain_pages_zone+0x64/0x84
[ 1557.408067] __drain_all_pages+0x178/0x220
[ 1557.412148] alloc_contig_range+0x130/0x280
[ 1557.416318] cma_alloc+0x120/0x310
[ 1557.419706] cma_alloc_aligned+0x44/0x70
[ 1557.423615] dma_alloc_contiguous+0x30/0x44
[ 1557.427784] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1557.433426] dm 0x8000000000000000(zone=2) CMA
[ 1557.548872] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1557.556597] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1557.564316] page dumped because: nonzero _refcount
[ 1557.569090] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1557.640764] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1557.649960] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1557.655599] Call trace:
[ 1557.658032] dump_backtrace.part.0+0xdc/0xf0
[ 1557.662289] show_stack+0x18/0x30
[ 1557.665592] dump_stack_lvl+0x68/0x84
[ 1557.669243] dump_stack+0x18/0x34
[ 1557.672546] bad_page+0xe8/0x110
[ 1557.675760] free_page_is_bad_report+0x7c/0x90
[ 1557.680189] free_pcppages_bulk+0x198/0x1fc
[ 1557.684357] drain_pages_zone+0x64/0x84
[ 1557.688180] __drain_all_pages+0x178/0x220
[ 1557.692262] alloc_contig_range+0x130/0x280
[ 1557.696432] cma_alloc+0x120/0x310
[ 1557.699820] cma_alloc_aligned+0x44/0x70
[ 1557.703728] dma_alloc_contiguous+0x30/0x44
[ 1557.707897] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1557.713540] dma_direct_alloc+0xd8/0x304
[ 1557.717448] dma_alloc_attrs+0x7c/0xe4
[ 1557.721183] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1557.726831] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1557.732478] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1557.737258] wave4
[ 1557.814841] page:00000000584652f7 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x4 pfn:0x9ef5b4
[ 1557.824297] flags: 0x8000000000000000(zone=2) CMA
[ 1557.828990] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1557.836710] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1557.844430] page dumped because: nonzero _refcount
[ 1557.849203] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1557.920879] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1557.930074] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1557.935714] Call trace:
[ 1557.938147] dump_backtrace.part.0+0xdc/0xf0
[ 1557.942404] show_stack+0x18/0x30
[ 1557.945707] dump_stack_lvl+0x68/0x84
[ 1557.949358] dump_stack+0x18/0x34
[ 1557.952661] bad_page+0xe8/0x110
[ 1557.955876] free_page_is_bad_report+0x7c/0x90
[ 1557.960304] free_pcppages_bulk+0x198/0x1fc
[ 1557.964473] drain_pages_zone+0x64/0x84
[ 1557.968295] __drain_all_pages+0x178/0x220
[ 1557.972376] alloc_contig_range+0x130/0x280
[ 1557.976545] cma_alloc+0x120/0x310
[ 1557.979933] cma_alloc_aligned+0x44/0x70
[ 1557.983842] dma_alloc_contiguous+0x30/0x44
[ 1557.988010] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1557.993653] dma_direct_alloc+0xd8/0x304
[ 1557.997561] dma_alloc_attrs+0x7c/0xe4
[ 1558.001296] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1558.00694000000000122 0000000000000000
[ 1558.116815] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1558.124539] page dumped because: nonzero _refcount
[ 1558.129312] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1558.200988] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1558.210183] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1558.215823] Call trace:
[ 1558.218256] dump_backtrace.part.0+0xdc/0xf0
[ 1558.222512] show_stack+0x18/0x30
[ 1558.225815] dump_stack_lvl+0x68/0x84
[ 1558.229465] dump_stack+0x18/0x34
[ 1558.232768] bad_page+0xe8/0x110
[ 1558.235984] free_page_is_bad_report+0x7c/0x90
[ 1558.240413] free_pcppages_bulk+0x198/0x1fc
[ 1558.244582] drain_pages_zone+0x64/0x84
[ 1558.248403] __drain_all_pages+0x178/0x220
[ 1558.252485] alloc_contig_range+0x130/0x280
[ 1558.256654] cma_alloc+0x120/0x310
[ 1558.260043] cma_alloc_aligned+0x44/0x70
[ 1558.263953] dma_alloc_contiguous+0x30/0x44
[ 1558.268122] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1558.273764] dma_direct_alloc+0xd8/0x304
[ 1558.277672] dma_alloc_attrs+0x7c/0xe4
[ 1558.281407] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1558.287055] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1558.292703] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1558.297483] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1558.302958] vb2_core_reqbufs+0x138/0x460 [videobuf2_g:0000000000000000 index:0x4 pfn:0x9ef5b6
[ 1558.384526] flags: 0x8000000000000000(zone=2) CMA
[ 1558.389219] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1558.396941] raw: 0000000000000004 0000000000000000 ffffffffffffffff 0000000000000000
[ 1558.404660] page dumped because: nonzero _refcount
[ 1558.409433] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1558.481114] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1558.490310] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1558.495950] Call trace:
[ 1558.498383] dump_backtrace.part.0+0xdc/0xf0
[ 1558.502640] show_stack+0x18/0x30
[ 1558.505942] dump_stack_lvl+0x68/0x84
[ 1558.509592] dump_stack+0x18/0x34
[ 1558.512895] bad_page+0xe8/0x110
[ 1558.516109] free_page_is_bad_report+0x7c/0x90
[ 1558.520538] free_pcppages_bulk+0x198/0x1fc
[ 1558.524707] drain_pages_zone+0x64/0x84
[ 1558.528528] __drain_all_pages+0x178/0x220
[ 1558.532610] alloc_contig_range+0x130/0x280
[ 1558.536780] cma_alloc+0x120/0x310
[ 1558.540168] cma_alloc_aligned+0x44/0x70
[ 1558.544077] dma_alloc_contiguous+0x30/0x44
[ 1558.548245] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1558.553886] dma_direct_alloc+0xd8/0x304
[ 1558.557795] dma_alloc_attrs+0x7c/0xe4
[ 1558.561530] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1558.567179] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1558.57282 ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1558.761221] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1558.770419] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1558.776060] Call trace:
[ 1558.778492] dump_backtrace.part.0+0xdc/0xf0
[ 1558.782749] show_stack+0x18/0x30
[ 1558.786052] dump_stack_lvl+0x68/0x84
[ 1558.789701] dump_stack+0x18/0x34
[ 1558.793004] bad_page+0xe8/0x110
[ 1558.796219] free_page_is_bad_report+0x7c/0x90
[ 1558.800647] free_pcppages_bulk+0x198/0x1fc
[ 1558.804816] drain_pages_zone+0x64/0x84
[ 1558.808637] __drain_all_pages+0x178/0x220
[ 1558.812719] alloc_contig_range+0x130/0x280
[ 1558.816889] cma_alloc+0x120/0x310
[ 1558.820275] cma_alloc_aligned+0x44/0x70
[ 1558.824185] dma_alloc_contiguous+0x30/0x44
[ 1558.828354] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1558.833996] dma_direct_alloc+0xd8/0x304
[ 1558.837904] dma_alloc_attrs+0x7c/0xe4
[ 1558.841639] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1558.847288] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1558.852935] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1558.857716] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1558.863190] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1558.868838] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1558.873705] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1558.879354] v4l_reqbufs+0x50/0x64 [videodev]
[ 1558.883717] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1558.888686] video_usecdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1559.041328] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1559.050525] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1559.056165] Call trace:
[ 1559.058598] dump_backtrace.part.0+0xdc/0xf0
[ 1559.062855] show_stack+0x18/0x30
[ 1559.066158] dump_stack_lvl+0x68/0x84
[ 1559.069808] dump_stack+0x18/0x34
[ 1559.073112] bad_page+0xe8/0x110
[ 1559.076326] free_page_is_bad_report+0x7c/0x90
[ 1559.080755] free_pcppages_bulk+0x198/0x1fc
[ 1559.084923] drain_pages_zone+0x64/0x84
[ 1559.088745] __drain_all_pages+0x178/0x220
[ 1559.092828] alloc_contig_range+0x130/0x280
[ 1559.096997] cma_alloc+0x120/0x310
[ 1559.100385] cma_alloc_aligned+0x44/0x70
[ 1559.104294] dma_alloc_contiguous+0x30/0x44
[ 1559.108462] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1559.114104] dma_direct_alloc+0xd8/0x304
[ 1559.118013] dma_alloc_attrs+0x7c/0xe4
[ 1559.121747] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1559.127396] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1559.133043] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1559.137824] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1559.143298] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1559.148947] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1559.153814] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1559.159463] v4l_reqbufs+0x50/0x64 [videodev]
[ 1559.163826] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1559.168796] video_usercopy+0x214v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1559.321436] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1559.330633] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1559.336273] Call trace:
[ 1559.338706] dump_backtrace.part.0+0xdc/0xf0
[ 1559.342963] show_stack+0x18/0x30
[ 1559.346266] dump_stack_lvl+0x68/0x84
[ 1559.349917] dump_stack+0x18/0x34
[ 1559.353220] bad_page+0xe8/0x110
[ 1559.356434] free_page_is_bad_report+0x7c/0x90
[ 1559.360863] free_pcppages_bulk+0x198/0x1fc
[ 1559.365032] drain_pages_zone+0x64/0x84
[ 1559.368854] __drain_all_pages+0x178/0x220
[ 1559.372937] alloc_contig_range+0x130/0x280
[ 1559.377106] cma_alloc+0x120/0x310
[ 1559.380494] cma_alloc_aligned+0x44/0x70
[ 1559.384403] dma_alloc_contiguous+0x30/0x44
[ 1559.388572] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1559.394214] dma_direct_alloc+0xd8/0x304
[ 1559.398122] dma_alloc_attrs+0x7c/0xe4
[ 1559.401856] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1559.407504] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1559.413152] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1559.417932] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1559.423406] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1559.429055] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1559.433922] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1559.439571] v4l_reqbufs+0x50/0x64 [videodev]
[ 1559.443933] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1559.448903] video_usercopy+0x214/0x6c4 [videodev]
[ 1559.453698] video_ioctl2+0x18/0x2c [videodev]
[ 1559.458147] v4l2_ioctl+0x40/0x60 [videodev]
[ 1559.462424] __arm64_sys_ioctl+0xa8/0xf0
[ 1559.466332] invoke_syscall+0x48/0x114
[ 1559.470068] el0_svc_common.constprop.0+0xd4/0xfc
[ ync drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1559.601543] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1559.610741] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1559.616380] Call trace:
[ 1559.618813] dump_backtrace.part.0+0xdc/0xf0
[ 1559.623070] show_stack+0x18/0x30
[ 1559.626373] dump_stack_lvl+0x68/0x84
[ 1559.630023] dump_stack+0x18/0x34
[ 1559.633326] bad_page+0xe8/0x110
[ 1559.636540] free_page_is_bad_report+0x7c/0x90
[ 1559.640968] free_pcppages_bulk+0x198/0x1fc
[ 1559.645137] drain_pages_zone+0x64/0x84
[ 1559.648958] __drain_all_pages+0x178/0x220
[ 1559.653040] alloc_contig_range+0x130/0x280
[ 1559.657210] cma_alloc+0x120/0x310
[ 1559.660598] cma_alloc_aligned+0x44/0x70
[ 1559.664507] dma_alloc_contiguous+0x30/0x44
[ 1559.668676] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1559.674318] dma_direct_alloc+0xd8/0x304
[ 1559.678227] dma_alloc_attrs+0x7c/0xe4
[ 1559.681962] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1559.687610] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1559.693258] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1559.698038] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1559.703512] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1559.709161] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1559.714028] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1559.719676] v4l_reqbufs+0x50/0x64 [videodev]
[ 1559.724041] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1559.729012] video_usercopy+0x214/0x6c4 [videodev]
[ 1559.733809] video_ioctl2+0x18/0x2c [videodev]
[ 1559.738259] v4l2_ioctl+0x40/0x60 [videodev]
[ 1559.742534] __arm64_sys_ioctl+0xa8/0xf0
[ 1559.746442] invoke_syscall+0x48/0x114
[ 1559.750178] el0_svc_common.constprop.0+0xd4/0xfc
[ v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1559.881659] CPU: 7 PID: 3261 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1559.890855] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1559.896496] Call trace:
[ 1559.898928] dump_backtrace.part.0+0xdc/0xf0
[ 1559.903185] show_stack+0x18/0x30
[ 1559.906487] dump_stack_lvl+0x68/0x84
[ 1559.910137] dump_stack+0x18/0x34
[ 1559.913440] bad_page+0xe8/0x110
[ 1559.916655] free_page_is_bad_report+0x7c/0x90
[ 1559.921083] free_pcppages_bulk+0x198/0x1fc
[ 1559.925252] drain_pages_zone+0x64/0x84
[ 1559.929073] __drain_all_pages+0x178/0x220
[ 1559.933155] alloc_contig_range+0x130/0x280
[ 1559.937324] cma_alloc+0x120/0x310
[ 1559.940713] cma_alloc_aligned+0x44/0x70
[ 1559.944621] dma_alloc_contiguous+0x30/0x44
[ 1559.948791] __dma_direct_alloc_pages.constprop.0+0x64/0x1c4
[ 1559.954433] dma_direct_alloc+0xd8/0x304
[ 1559.958341] dma_alloc_attrs+0x7c/0xe4
[ 1559.962076] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1559.967725] wave5_vpu_build_up_enc_param+0x64/0x270 [wave5]
[ 1559.973372] wave5_vpu_enc_open+0x9c/0x124 [wave5]
[ 1559.978153] wave5_vpu_enc_queue_setup+0x1c4/0x42c [wave5]
[ 1559.983627] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1559.989275] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1559.994143] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1559.999791] v4l_reqbufs+0x50/0x64 [videodev]
[ 1560.004155] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1560.163047] CPU: 4 PID: 3260 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1560.172162] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1560.177805] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1560.184747] pc : __vunmap+0x78/0x30c
[ 1560.188310] lr : __vunmap+0x78/0x30c
[ 1560.191871] sp : ffff80000c0b3ad0
[ 1560.195171] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1560.202291] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1560.209408] x23: 00000009ef680000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1560.216527] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1560.223644] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1560.230761] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002c94
[ 1560.237879] x11: 0000000000000edc x10: ffff8000092d9550 x9 : ffff800009281550
[ 1560.244997] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1560.252114] x5 : ffff000f5c3b5b60 x4 : ffff000f5c3b5b60 x3 : ffff000f5c3b8da0
[ 1560.259231] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1560.266348] Call trace:
[ 1560.268782] __vunmap+0x78/0x30c
[ 1560.271998] vunmap+0x40/0x5c
[ 1560.274953] dma_direct_free+0x10c/0x110
[ 1560.278865] dma_free_attrs+0x98/0xe0
[ 1560.282514] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1560.287824] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1560.292780] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1560.298081] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1560.303034] v4l2_release+0xbc/0xf0 [videodev]
[ 1560.307491] __fput+0x70/0x250
[ 1560.310536] ____fput+0x10/0x20
[ 1560.313665] task_work_run+0x80/0.434294] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1560.439934] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1560.446878] pc : free_contig_range+0xa4/0xc0
[ 1560.451134] lr : free_contig_range+0xa4/0xc0
[ 1560.455389] sp : ffff80000c0b3a90
[ 1560.458689] x29: ffff80000c0b3a90 x28: 0000000000000204 x27: 0000000000000000
[ 1560.465807] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1560.472923] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef6c1
[ 1560.480040] x20: 0000000000000041 x19: 00000000009ef6c1 x18: ffffffffffffffff
[ 1560.487159] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b3777
[ 1560.494275] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002d06
[ 1560.501394] x11: 0000000000000f02 x10: ffff8000092d9550 x9 : ffff800009281550
[ 1560.508511] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1560.515629] x5 : ffff000f5c3b5b60 x4 : ffff000f5c3b5b60 x3 : ffff000f5c3b8da0
[ 1560.522746] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1560.529862] Call trace:
[ 1560.532295] free_contig_range+0xa4/0xc0
[ 1560.536203] cma_release+0x7c/0xd0
[ 1560.539592] dma_free_contiguous+0xa0/0xac
[ 1560.543675] dma_direct_free+0xc0/0x110
[ 1560.547497] dma_free_attrs+0x98/0xe0
[ 1560.551144] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1560.556447] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1560.561402] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1560.566703] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1560.571658] v4l2_release+0xbc/0xf0 [videodev]
[ 1560.576111] __fput+0x70/0x250
[ 1560.579153] ____fput+0x10/0x20
[ 1560.582283] task_work_run+0x80/0xe0
[ 1560.585845] do_notify_resume+0x208/0x1280
[ 1560.589927] el0_svc+0x74/0x84
[ 1560.592968] el0t_64_sync_handler+0xbc/0x140
[ 1560.597223] el0t_64_sync+0x18c/0x190
[ 1560.600872] ---[ end trace 0000000000000000 ]---
[ 1560.605493] ------------[ cut here ]------------
[ 1560.610100] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1560.616451] WARNING: CPU: 4 PID: 3260 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1560.623657] Modules linked in: overlay cfg802ate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1560.717031] pc : __vunmap+0x78/0x30c
[ 1560.720597] lr : __vunmap+0x78/0x30c
[ 1560.724159] sp : ffff80000c0b3ad0
[ 1560.727459] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1560.734578] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1560.741695] x23: 00000009ef540000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1560.748813] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1560.755930] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1560.763046] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002d7b
[ 1560.770163] x11: 0000000000000f29 x10: ffff8000092d9550 x9 : ffff800009281550
[ 1560.777280] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1560.784397] x5 : ffff000f5c3b5b60 x4 : ffff000f5c3b5b60 x3 : ffff000f5c3b8da0
[ 1560.791514] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1560.798633] Call trace:
[ 1560.801065] __vunmap+0x78/0x30c
[ 1560.804280] vunmap+0x40/0x5c
[ 1560.807235] dma_direct_free+0x10c/0x110
[ 1560.811144] dma_free_attrs+0x98/0xe0
[ 1560.814792] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1560.820093] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1560.825049] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1560.830350] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1560.835304] v4l2_release+0xbc/0xf0 [videodev]
[ 1560.839757] __fput+0x70/0x250
[ 1560.842800] ____fput+0x10/0x20
[ 1560.845929] task_work_run+0x80/0xe0
[ 1560.849492] do_notify_resume+0x208/0x1280
[ 1560.853577] el0_svc+0x74/0x84
[ 1560.856618] el0t_64_sync_handler+0xbc/0x140
[ 1560.860873] el0t_64_sync+0x18c/0x190
[ 1560.864521] ---[ end trace 0000000000000000 ]---
[ 1560.869144] ------------[ cut here ]------------
[ 1560.873752] 33 pages are still in use!
[ 1560.877497] WARNING: CPU: 4 PID: 3260 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1560.885657] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 jc0b3777
[ 1561.026426] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002ded
[ 1561.033544] x11: 0000000000000f4f x10: ffff8000092d9550 x9 : ffff800009281550
[ 1561.040661] x8 : 00000000ffffefff x7 : ffff8000092d9550 x6 : 0000000000000000
[ 1561.047777] x5 : ffff000f5c3b5b60 x4 : ffff000f5c3b5b60 x3 : ffff000f5c3b8da0
[ 1561.054894] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1561.062011] Call trace:
[ 1561.064444] free_contig_range+0xa4/0xc0
[ 1561.068353] cma_release+0x7c/0xd0
[ 1561.071740] dma_free_contiguous+0xa0/0xac
[ 1561.075823] dma_direct_free+0xc0/0x110
[ 1561.079646] dma_free_attrs+0x98/0xe0
[ 1561.083293] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1561.088596] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1561.093551] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1561.098852] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1561.103806] v4l2_release+0xbc/0xf0 [videodev]
[ 1561.108258] __fput+0x70/0x250
[ 1561.111301] ____fput+0x10/0x20
[ 1561.114430] task_work_run+0x80/0xe0
[ 1561.117992] do_notify_resume+0x208/0x1280
[ 1561.122075] el0_svc+0x74/0x84
[ 1561.125116] el0t_64_sync_handler+0xbc/0x140
[ 1561.129370] el0t_64_sync+0x18c/0x190
[ 1561.133018] ---[ end trace 0000000000000000 ]---
[ 1561.137639] ------------[ cut here ]------------
[ 1561.142245] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1561.148592] WARNING: CPU: 4 PID: 3260 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1561.155798] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_ho0000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1561.330769] Call trace:
[ 1561.333205] __vunmap+0x78/0x30c
[ 1561.336420] vunmap+0x40/0x5c
[ 1561.339375] dma_direct_free+0x10c/0x110
[ 1561.343284] dma_free_attrs+0x98/0xe0
[ 1561.346932] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1561.352234] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1561.357189] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1561.362490] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1561.367444] v4l2_release+0xbc/0xf0 [videodev]
[ 1561.371897] __fput+0x70/0x250
[ 1561.374940] ____fput+0x10/0x20
[ 1561.378069] task_work_run+0x80/0xe0
[ 1561.381631] do_notify_resume+0x208/0x1280
[ 1561.385715] el0_svc+0x74/0x84
[ 1561.388756] el0t_64_sync_handler+0xbc/0x140
[ 1561.393010] el0t_64_sync+0x18c/0x190
[ 1561.396659] ---[ end trace 0000000000000000 ]---
[ 1561.401282] ------------[ cut here ]------------
[ 1561.405888] 35 pages are still in use!
[ 1561.409634] WARNING: CPU: 4 PID: 3260 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1561.417793] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1561.489471] CPU: 4 PID: 3260 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1561.498578] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1561.504219] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1561.511160] pc : free_contig_range+0xa4/0xc0
[ 1561.515416] lr : free_contig_range+00000000000
[ 1561.579912] x5 : ffff000f5c3b5b60 x4 : ffff000f5c3b5b60 x3 : ffff000f5c3b8da0
[ 1561.587030] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1561.594147] Call trace:
[ 1561.596581] free_contig_range+0xa4/0xc0
[ 1561.600490] cma_release+0x7c/0xd0
[ 1561.603878] dma_free_contiguous+0xa0/0xac
[ 1561.607961] dma_direct_free+0xc0/0x110
[ 1561.611783] dma_free_attrs+0x98/0xe0
[ 1561.615431] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1561.620733] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1561.625687] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1561.630988] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1561.635942] v4l2_release+0xbc/0xf0 [videodev]
[ 1561.640394] __fput+0x70/0x250
[ 1561.643437] ____fput+0x10/0x20
[ 1561.646566] task_work_run+0x80/0xe0
[ 1561.650127] do_notify_resume+0x208/0x1280
[ 1561.654211] el0_svc+0x74/0x84
[ 1561.657253] el0t_64_sync_handler+0xbc/0x140
[ 1561.661507] el0t_64_sync+0x18c/0x190
[ 1561.665154] ---[ end trace 0000000000000000 ]---
[ 1561.669772] ------------[ cut here ]------------
[ 1561.674380] Trying to vfree() nonexistent vm area (0000000008b3bc44)
[ 1561.680725] WARNING: CPU: 4 PID: 3260 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1561.687930] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1561.759608] CPU: 4 PID: 3260 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1561.768716] Hardware name: Texas Instrument: ffff8000092d9550 x6 : 0000000000000000
[ 1561.848660] x5 : ffff000f5c3b5b60 x4 : ffff000f5c3b5b60 x3 : ffff000f5c3b8da0
[ 1561.855778] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa585580
[ 1561.862895] Call trace:
[ 1561.865327] __vunmap+0x78/0x30c
[ 1561.868543] vunmap+0x40/0x5c
[ 1561.871498] dma_direct_free+0x10c/0x110
[ 1561.875406] dma_free_attrs+0x98/0xe0
[ 1561.879054] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1561.884356] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1561.889223] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1561.894525] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1561.899479] v4l2_release+0xbc/0xf0 [videodev]
[ 1561.903930] __fput+0x70/0x250
[ 1561.906973] ____fput+0x10/0x20
[ 1561.910102] task_work_run+0x80/0xe0
[ 1561.913664] do_notify_resume+0x208/0x1280
[ 1561.917747] el0_svc+0x74/0x84
[ 1561.920789] el0t_64_sync_handler+0xbc/0x140
[ 1561.925043] el0t_64_sync+0x18c/0x190
[ 1561.928692] ---[ end trace 0000000000000000 ]---
[ 1561.933310] ------------[ cut here ]------------
[ 1561.937917] 18 pages are still in use!
[ 1561.941662] WARNING: CPU: 4 PID: 3260 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1561.949822] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1562.021498] CPU: 4 PID: 3260 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1562.030606] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1562.036246] pstate: 60000race:
[ 1562.128606] free_contig_range+0xa4/0xc0
[ 1562.132515] cma_release+0x7c/0xd0
[ 1562.135906] dma_free_contiguous+0xa0/0xac
[ 1562.139989] dma_direct_free+0xc0/0x110
[ 1562.143811] dma_free_attrs+0x98/0xe0
[ 1562.147459] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1562.152761] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1562.157628] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1562.162929] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1562.167883] v4l2_release+0xbc/0xf0 [videodev]
[ 1562.172333] __fput+0x70/0x250
[ 1562.175375] ____fput+0x10/0x20
[ 1562.178504] task_work_run+0x80/0xe0
[ 1562.182066] do_notify_resume+0x208/0x1280
[ 1562.186149] el0_svc+0x74/0x84
[ 1562.189190] el0t_64_sync_handler+0xbc/0x140
[ 1562.193445] el0t_64_sync+0x18c/0x190
[ 1562.197094] ---[ end trace 0000000000000000 ]---
[ 1562.263045] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1562.273400] ------------[ cut here ]------------
[ 1562.278069] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1562.284465] WARNING: CPU: 7 PID: 3263 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1562.291679] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1562.363383] CPU: 7 PID: 3263 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1562.372493] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1562.378135] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1562.385078] pc : __vunmap+0x78/0x30c
[ 1562.388640] lr : __vunmap+0x78/0x30c
[ 1562.392202] sp : ffff80000baebad0
[ 1562.395502] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1562.402621] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1562.409739] x23: 00000009ef780000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1562.416857] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1562.423974] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1562.431092] x14: 0000000000000223 x13: 0000000000000000 x12: 0000000000000000
[ 1562.438210] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1562.445327] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1562.452445] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a02348
[ 1562.459562] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1562.466680] Call trace:
[ 1562.469114] __vunmap+0x78/0x30c
[ 1562.472330] vunmap+0x40/0x5c
[ 1562.475285] dma_direct_free+0x10c/0x110
[ 1562.479196] dma_free_attrs+0x98/0xe0
[ 1562.482846] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1562.488157] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1562.493111] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1562.498413] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1562.503368] v4l2_release+0xbc/0xf0 [videodev]
[ 1562.507825] __fput+0x70/0x250
[ 1562.510874] ____fput+0x10/0x20
[ 1562.514003] task_work_run+0x80/0xe0
[ 1562.517566] do_notify_resume+0x208/0x1280
[ 1562.521652] el0_svc+0x74/0x84
[ 1562.524696] el0t_64_sync_handler+0xbc/0x140
[ 1562.528952] el0t_64_sync+0x18c/0x190
[ 1562.532602] ---[ end trace 0000000000000000 ]---
[ 1562.537344] ------------[ cut here ]------------
[ 1562.541952] 65 pages are still in use!
[ 1562.545756] WARNING: CPU: 7 PID: 3263 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1562.553920] Modules linked in: .1.33-g8f7f371be2 #1
[ 1562.634716] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1562.640362] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1562.647305] pc : free_contig_range+0xa4/0xc0
[ 1562.651561] lr : free_contig_range+0xa4/0xc0
[ 1562.655816] sp : ffff80000baeba90
[ 1562.659117] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1562.666236] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1562.673353] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef7c1
[ 1562.680472] x20: 0000000000000041 x19: 00000000009ef7c1 x18: ffffffffffffffff
[ 1562.687588] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1562.694705] x14: 00000000000002bd x13: 0000000000000000 x12: 0000000000000000
[ 1562.701823] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb940
[ 1562.708941] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1562.716058] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a02348
[ 1562.723175] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1562.730293] Call trace:
[ 1562.732727] free_contig_range+0xa4/0xc0
[ 1562.736636] cma_release+0x7c/0xd0
[ 1562.740025] dma_free_contiguous+0xa0/0xac
[ 1562.744109] dma_direct_free+0xc0/0x110
[ 1562.747931] dma_free_attrs+0x98/0xe0
[ 1562.751579] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1562.756883] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1562.761838] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1562.767140] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1562.772094] v4l2_release+0xbc/0xf0 [videodev]
[ 1562.776548] __fput+0x70/0x250
[ 1562.779590] ____fput+0x10/0x20
[ 1562.782719] task_work_run+0x80/0xe0
[ 1562.786282] do_notify_resume+0x208/0x1280
[ 1562.790366] el0_svc+0x74/0x84
[ 1562.793407] el0t_64_sync_handler+0xbc/0x140
[ 1562.797663] el0t_64_sync+0x18c/0x190
[ 1562.801310] ---[ end trace 0000000000000000 ]---
[ 1562.805935] ------------[ cut here ]------------
[ 1562.810542] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1562.816888] WARNING: CPU: 7 PID: 3263 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1562.824094] Modules linkedh-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1562.904883] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1562.910527] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1562.917468] pc : __vunmap+0x78/0x30c
[ 1562.921030] lr : __vunmap+0x78/0x30c
[ 1562.924591] sp : ffff80000baebad0
[ 1562.927891] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1562.935008] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1562.942126] x23: 00000009ef640000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1562.949244] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1562.956361] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1562.963478] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000011a
[ 1562.970596] x11: 000000000000005e x10: ffff8000092d9e20 x9 : ffff800009281550
[ 1562.977713] x8 : 00000000fffff05e x7 : ffff8000092d9550 x6 : 00000000000008d0
[ 1562.984830] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1562.991947] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1562.999065] Call trace:
[ 1563.001498] __vunmap+0x78/0x30c
[ 1563.004713] vunmap+0x40/0x5c
[ 1563.007668] dma_direct_free+0x10c/0x110
[ 1563.011577] dma_free_attrs+0x98/0xe0
[ 1563.015226] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1563.020529] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1563.025484] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1563.030785] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1563.035740] v4l2_release+0xbc/0xf0 [videodev]
[ 1563.040191] __fput+0x70/0x250
[ 1563.043234] ____fput+0x10/0x20
[ 1563.046364] task_work_run+0x80/0xe0
[ 1563.049926] do_notify_resume+0x208/0x1280
[ 1563.054009] el0_svc+0x74/0x84
[ 1563.057050] el0t_64_sync_handler+0xbc/0x140
[ 1563.061305] el0t_64_sync+0x18c/0x190
[ 1563.064953] ---[ end trace 0000000000000000 ]---
[ 1563.069577] ------------[ cut here ]------------
[ 1563.074184] 33 pages are still in use!
[ 1563.077929] WARNING: CPU: 7 PID: 3263 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1563.086088] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_genO -TCO -DIT -SSBS BTYPE=--)
[ 1563.179459] pc : free_contig_range+0xa4/0xc0
[ 1563.183715] lr : free_contig_range+0xa4/0xc0
[ 1563.187972] sp : ffff80000baeba90
[ 1563.191272] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1563.198390] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1563.205507] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef661
[ 1563.212625] x20: 0000000000000021 x19: 00000000009ef661 x18: ffffffffffffffff
[ 1563.219743] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1563.226860] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000018c
[ 1563.233977] x11: 0000000000000084 x10: ffff8000092da1b0 x9 : ffff800009281550
[ 1563.241094] x8 : 00000000fffff084 x7 : ffff8000092d9550 x6 : 0000000000000c60
[ 1563.248212] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1563.255330] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1563.262447] Call trace:
[ 1563.264880] free_contig_range+0xa4/0xc0
[ 1563.268788] cma_release+0x7c/0xd0
[ 1563.272177] dma_free_contiguous+0xa0/0xac
[ 1563.276260] dma_direct_free+0xc0/0x110
[ 1563.280083] dma_free_attrs+0x98/0xe0
[ 1563.283730] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1563.289032] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1563.293988] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1563.299289] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1563.304244] v4l2_release+0xbc/0xf0 [videodev]
[ 1563.308697] __fput+0x70/0x250
[ 1563.311741] ____fput+0x10/0x20
[ 1563.314870] task_work_run+0x80/0xe0
[ 1563.318431] do_notify_resume+0x208/0x1280
[ 1563.322515] el0_svc+0x74/0x84
[ 1563.325557] el0t_64_sync_handler+0xbc/0x140
[ 1563.329812] el0t_64_sync+0x18c/0x190
[ 1563.333461] ---[ end trace 0000000000000000 ]---
[ 1563.338080] ------------[ cut here ]------------
[ 1563.342688] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1563.349034] WARNING: CPU: 7 PID: 3263 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1563.356239] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 00000 x25: 0000000000000000 x24: 0000000000000000
[ 1563.474268] x23: 00000009ef700000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1563.481386] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1563.488503] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1563.495621] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000201
[ 1563.502738] x11: 00000000000000ab x10: ffff8000092da558 x9 : ffff800009281550
[ 1563.509856] x8 : 00000000fffff0ab x7 : ffff8000092d9550 x6 : 0000000000001008
[ 1563.516974] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1563.524091] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1563.531208] Call trace:
[ 1563.533640] __vunmap+0x78/0x30c
[ 1563.536854] vunmap+0x40/0x5c
[ 1563.539809] dma_direct_free+0x10c/0x110
[ 1563.543718] dma_free_attrs+0x98/0xe0
[ 1563.547366] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1563.552668] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1563.557623] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1563.562924] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1563.567877] v4l2_release+0xbc/0xf0 [videodev]
[ 1563.572329] __fput+0x70/0x250
[ 1563.575371] ____fput+0x10/0x20
[ 1563.578500] task_work_run+0x80/0xe0
[ 1563.582062] do_notify_resume+0x208/0x1280
[ 1563.586146] el0_svc+0x74/0x84
[ 1563.589187] el0t_64_sync_handler+0xbc/0x140
[ 1563.593443] el0t_64_sync+0x18c/0x190
[ 1563.597091] ---[ end trace 0000000000000000 ]---
[ 1563.601714] ------------[ cut here ]------------
[ 1563.606321] 35 pages are still in use!
[ 1563.610065] WARNING: CPU: 7 PID: 3263 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1563.618224] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pv12: 0000000000000273
[ 1563.766109] x11: 00000000000000d1 x10: ffff8000092da8e8 x9 : ffff800009281550
[ 1563.773227] x8 : 00000000fffff0d1 x7 : ffff8000092d9550 x6 : 0000000000001398
[ 1563.780345] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1563.787463] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1563.794579] Call trace:
[ 1563.797012] free_contig_range+0xa4/0xc0
[ 1563.800921] cma_release+0x7c/0xd0
[ 1563.804309] dma_free_contiguous+0xa0/0xac
[ 1563.808393] dma_direct_free+0xc0/0x110
[ 1563.812215] dma_free_attrs+0x98/0xe0
[ 1563.815864] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1563.821166] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1563.826120] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1563.831422] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1563.836377] v4l2_release+0xbc/0xf0 [videodev]
[ 1563.840828] __fput+0x70/0x250
[ 1563.843871] ____fput+0x10/0x20
[ 1563.847000] task_work_run+0x80/0xe0
[ 1563.850562] do_notify_resume+0x208/0x1280
[ 1563.854646] el0_svc+0x74/0x84
[ 1563.857687] el0t_64_sync_handler+0xbc/0x140
[ 1563.861941] el0t_64_sync+0x18c/0x190
[ 1563.865590] ---[ end trace 0000000000000000 ]---
[ 1563.870208] ------------[ cut here ]------------
[ 1563.874814] Trying to vfree() nonexistent vm area (0000000008b3bc44)
[ 1563.881159] WARNING: CPU: 7 PID: 3263 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1563.888364] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_pa767] __vunmap+0x78/0x30c
[ 1564.068981] vunmap+0x40/0x5c
[ 1564.071939] dma_direct_free+0x10c/0x110
[ 1564.075848] dma_free_attrs+0x98/0xe0
[ 1564.079496] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1564.084798] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1564.089666] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1564.094967] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1564.099921] v4l2_release+0xbc/0xf0 [videodev]
[ 1564.104370] __fput+0x70/0x250
[ 1564.107414] ____fput+0x10/0x20
[ 1564.110543] task_work_run+0x80/0xe0
[ 1564.114105] do_notify_resume+0x208/0x1280
[ 1564.118189] el0_svc+0x74/0x84
[ 1564.121230] el0t_64_sync_handler+0xbc/0x140
[ 1564.125485] el0t_64_sync+0x18c/0x190
[ 1564.129134] ---[ end trace 0000000000000000 ]---
[ 1564.133764] ------------[ cut here ]------------
[ 1564.138369] 18 pages are still in use!
[ 1564.142114] WARNING: CPU: 7 PID: 3263 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1564.150273] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1564.221949] CPU: 7 PID: 3263 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1564.231057] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1564.236696] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1564.243637] pc : free_contig_range+0xa4/0xc0
[ 1564.247893] lr : free_contig_range+0xa4/0xc0
[ 1564.252148] sp : ffff80000baeba90
[ 1564.255448] x29: ffff80000baeba90 x28: 0000000000000204397544] ---[ end trace 0000000000000000 ]---
[ 1564.463599] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1564.473921] ------------[ cut here ]------------
[ 1564.478537] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1564.484916] WARNING: CPU: 6 PID: 3266 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1564.492131] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1564.563835] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1564.572946] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1564.578587] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1564.585530] pc : __vunmap+0x78/0x30c
[ 1564.589092] lr : __vunmap+0x78/0x30c
[ 1564.592654] sp : ffff80000ba8bad0
[ 1564.595953] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1564.603072] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1564.610190] x23: 00000009ef880000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1564.617307] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1564.624425] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1564.631542] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000003d2
[ 1564.638659] x11: 0000000000000146 x10: ffflease_device+0x64/0x18c [wave5]
[ 1564.698869] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1564.703824] v4l2_release+0xbc/0xf0 [videodev]
[ 1564.708282] __fput+0x70/0x250
[ 1564.711327] ____fput+0x10/0x20
[ 1564.714456] task_work_run+0x80/0xe0
[ 1564.718020] do_notify_resume+0x208/0x1280
[ 1564.722105] el0_svc+0x74/0x84
[ 1564.725149] el0t_64_sync_handler+0xbc/0x140
[ 1564.729405] el0t_64_sync+0x18c/0x190
[ 1564.733055] ---[ end trace 0000000000000000 ]---
[ 1564.737688] ------------[ cut here ]------------
[ 1564.742311] 65 pages are still in use!
[ 1564.746059] WARNING: CPU: 6 PID: 3266 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1564.754222] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1564.825902] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1564.835011] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1564.840652] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1564.847594] pc : free_contig_range+0xa4/0xc0
[ 1564.851851] lr : free_contig_range+0xa4/0xc0
[ 1564.856107] sp : ffff80000ba8ba90
[ 1564.859407] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1564.866524] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1564.873642] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef8c1
[ 1564.880759] x20: 0000000000000041 x19: 00000000009ef8c1 x18: ffffffffffffffff
[ 1564.887876] x1 [videodev]
[ 1564.976834] __fput+0x70/0x250
[ 1564.979877] ____fput+0x10/0x20
[ 1564.983006] task_work_run+0x80/0xe0
[ 1564.986569] do_notify_resume+0x208/0x1280
[ 1564.990651] el0_svc+0x74/0x84
[ 1564.993692] el0t_64_sync_handler+0xbc/0x140
[ 1564.997947] el0t_64_sync+0x18c/0x190
[ 1565.001595] ---[ end trace 0000000000000000 ]---
[ 1565.006219] ------------[ cut here ]------------
[ 1565.010833] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1565.017224] WARNING: CPU: 6 PID: 3266 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1565.024432] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1565.096109] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1565.105218] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1565.110859] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1565.117801] pc : __vunmap+0x78/0x30c
[ 1565.121362] lr : __vunmap+0x78/0x30c
[ 1565.124924] sp : ffff80000ba8bad0
[ 1565.128224] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1565.135342] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1565.142459] x23: 00000009ef740000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1565.149576] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1565.156694] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1565.163811] x14: 00000000000001b4 x13: 0000000000000000 x12: rm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1565.358104] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1565.367216] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1565.372857] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1565.379799] pc : free_contig_range+0xa4/0xc0
[ 1565.384055] lr : free_contig_range+0xa4/0xc0
[ 1565.388311] sp : ffff80000ba8ba90
[ 1565.391610] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1565.398728] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1565.405845] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef761
[ 1565.412962] x20: 0000000000000021 x19: 00000000009ef761 x18: ffffffffffffffff
[ 1565.420079] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b777
[ 1565.427196] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000052b
[ 1565.434313] x11: 00000000000001b9 x10: ffff8000092dbea8 x9 : ffff800009281550
[ 1565.441430] x8 : 00000000fffff1b9 x7 : ffff8000092d9550 x6 : 0000000000002958
[ 1565.448547] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1565.455664] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1565.462781] Call trace:
[ 1565.465215] free_contig_range+0xa4/0xc0
[ 1565.469123] cma_release+0x7c/0xd0
[ 1565.472511] dma_free_contiguous+0xa0/0xac
[ 1565.476594] dma_direct_free+0xc0/0x110
[ 1565.480415] dma_free_attrs+0x98/0xe0
[ 1565.484064] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1565.489367] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1565.494322] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1565.499624] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1565.504578] v4l2_release+0xbc/0xf0 [videodev]
[ 1dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1565.628247] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1565.637357] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1565.642997] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1565.649940] pc : __vunmap+0x78/0x30c
[ 1565.653500] lr : __vunmap+0x78/0x30c
[ 1565.657061] sp : ffff80000ba8bad0
[ 1565.660360] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1565.667478] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1565.674595] x23: 00000009ef800000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1565.681713] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1565.688830] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1565.695949] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000005a0
[ 1565.703066] x11: 00000000000001e0 x10: ffff8000092dc250 x9 : ffff800009281550
[ 1565.710183] x8 : 00000000fffff1e0 x7 : ffff8000092d9550 x6 : 0000000000002d00
[ 1565.717300] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1565.724417] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1565.731534] Call trace:
[ 1565.733966] __vunmap+0x78/0x30c
[ 1565.737182] vunmap+0x40/0x5c
[ 1565.740137] dma_direct_free+0x10c/0x110
[ 1565.744045] dma_free_attrs+0x98/0xe0
[ 1565.747694] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1565.752996] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1565.757950] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1565.763252] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1565.768207] v4l2_release+0xbc/0xf0 [videodev]
[ 1565.772658] __fput+0x70/0x250
[ 1565.775701] ____fput+0x10/0x20
[ 1565.778830] task_work_run+0x80/0xe0
[ 1565.782392] do_notify_resume+0x208/0x1280
[ 1565.78buf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1565.890229] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1565.899339] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1565.904979] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1565.911921] pc : free_contig_range+0xa4/0xc0
[ 1565.916177] lr : free_contig_range+0xa4/0xc0
[ 1565.920433] sp : ffff80000ba8ba90
[ 1565.923732] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1565.930850] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1565.937966] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef823
[ 1565.945084] x20: 0000000000000023 x19: 00000000009ef823 x18: ffffffffffffffff
[ 1565.952202] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b777
[ 1565.959319] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000612
[ 1565.966437] x11: 0000000000000206 x10: ffff8000092dc5e0 x9 : ffff800009281550
[ 1565.973554] x8 : 00000000fffff206 x7 : ffff8000092d9550 x6 : 0000000000003090
[ 1565.980671] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1565.987788] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1565.994905] Call trace:
[ 1565.997338] free_contig_range+0xa4/0xc0
[ 1566.001247] cma_release+0x7c/0xd0
[ 1566.004635] dma_free_contiguous+0xa0/0xac
[ 1566.008719] dma_direct_free+0xc0/0x110
[ 1566.012541] dma_free_attrs+0x98/0xe0
[ 1566.016190] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1566.021494] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1566.026447] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 156simgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1566.160382] CPU: 6 PID: 3266 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1566.169493] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1566.175134] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1566.182076] pc : __vunmap+0x78/0x30c
[ 1566.185638] lr : __vunmap+0x78/0x30c
[ 1566.189199] sp : ffff80000ba8bad0
[ 1566.192499] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1566.199616] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1566.206734] x23: 00000009ef7e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1566.213851] x20: 0000000000000000 x19: ffff80000c0e1000 x18: ffffffffffffffff
[ 1566.220969] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1566.228087] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000687
[ 1566.235204] x11: 000000000000022d x10: ffff8000092dc988 x9 : ffff800009281550
[ 1566.242322] x8 : 00000000fffff22d x7 : ffff8000092d9550 x6 : 0000000000003438
[ 1566.249440] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1566.256557] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1566.263674] Call trace:
[ 1566.266107] __vunmap+0x78/0x30c
[ 1566.269322] vunmap+0x40/0x5c
[ 1566.272278] dma_direct_free+0x10c/0x110
[ 1566.276186] dma_free_attrs+0x98/0xe0
[ 1566.279835] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1566.285137] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1566.290004] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1566.295305] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1566.300260] v4l2_release+0xbc/0xf0 [videodev]
[ 1566.304713] __fput+0x70/0x250
[ 1566.307757] ____fput+0x10/0x20
[ 1566.310886] task_work_run+0x80/0xe0
[ 1566.314448] do_notify_resume+0x208/0x1280
[ 1566.318531] el0_svc+0x74/0x84
[ 1566.321573] el0t_64_sync_handler+0xbc/0x140
[ 1566.325827] el0t_64_sync+0x18c/0x190
[ 1566.329476] ---[ end trace 0000000000000000 ]---
[ 1566.334125]launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1566.431476] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1566.437119] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1566.444062] pc : free_contig_range+0xa4/0xc0
[ 1566.448319] lr : free_contig_range+0xa4/0xc0
[ 1566.452575] sp : ffff80000ba8ba90
[ 1566.455874] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1566.462993] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1566.470110] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef7f2
[ 1566.477228] x20: 0000000000000012 x19: 00000000009ef7f2 x18: ffffffffffffffff
[ 1566.484346] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b777
[ 1566.491463] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000006f9
[ 1566.498580] x11: 0000000000000253 x10: ffff8000092dcd18 x9 : ffff800009281550
[ 1566.505697] x8 : 00000000fffff253 x7 : ffff8000092d9550 x6 : 00000000000037c8
[ 1566.512815] x5 : ffff000f5c37cb60 x4 : ffff000f5c37cb60 x3 : ffff000f5c37fda0
[ 1566.519931] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1566.527049] Call trace:
[ 1566.529482] free_contig_range+0xa4/0xc0
[ 1566.533391] cma_release+0x7c/0xd0
[ 1566.536781] dma_free_contiguous+0xa0/0xac
[ 1566.540864] dma_direct_free+0xc0/0x110
[ 1566.544687] dma_free_attrs+0x98/0xe0
[ 1566.548336] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1566.553644] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1566.558512] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1566.563814] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1566.568769] v4l2_release+0xbc/0xf0 [videodev]
[ 1566.573221] __fput+0x70/0x250
[ 1566.576264] ____fput+0x10/0x20
[ 1566.579394] task_work_run+0x80/0xe0
[ 1566.582957] do_notify_resume+0x208/0x1280
[ 1566.587042] el0_svc+0x74/0x84
[ 1566.590085] el0t_64_sync_handler+0xbc/0x140
[ 1566.594340] el0t_64_sync+0x18c/0x190
[ 1566.597990] ---[ end trace 0000000000000000 ]---
[ 1566.665936] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1566.676394] ------------[ cut here ]------------
[ 1566.681028] Trying to vfree() display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1566.766307] CPU: 6 PID: 3269 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1566.775420] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1566.781062] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1566.788005] pc : __vunmap+0x78/0x30c
[ 1566.791567] lr : __vunmap+0x78/0x30c
[ 1566.795129] sp : ffff80000c0ebad0
[ 1566.798429] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1566.805548] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1566.812665] x23: 00000009ef980000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1566.819783] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1566.826900] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1566.834018] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000771
[ 1566.841135] x11: 000000000000027b x10: ffff8000092dd0d8 x9 : ffff800009281550
[ 1566.848252] x8 : 00000000fffff27b x7 : ffff8000092d9550 x6 : 0000000000003b88
[ 1566.855370] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1566.862487] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1566.869604] Call trace:
[ 1566.872038] __vunmap+0x78/0x30c
[ 1566.875253] vunmap+0x40/0x5c
[ 1566.878209] dma_direct_free+0x10c/0x110
[ 1566.882119] dma_free_attrs+0x98/0xe0
[ 1566.885770] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1566.891083] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1566.896037] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1566.901338] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1566.906293] v4l2_release+0xbc/0xf0 [videodev]
[ 1566.910748] __fput+0x70/0x250
[ 1566.913792] ____fput+0x10/0x20
[ 1566.916921] task_work_run+0x80/0xe0
[ 1566.920486] do_notify_resum 3269 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1567.037467] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1567.043111] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1567.050054] pc : free_contig_range+0xa4/0xc0
[ 1567.054309] lr : free_contig_range+0xa4/0xc0
[ 1567.058565] sp : ffff80000c0eba90
[ 1567.061864] x29: ffff80000c0eba90 x28: 0000000000000204 x27: 0000000000000000
[ 1567.068983] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1567.076101] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef9c1
[ 1567.083219] x20: 0000000000000041 x19: 00000000009ef9c1 x18: ffffffffffffffff
[ 1567.090336] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb777
[ 1567.097454] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000007e3
[ 1567.104572] x11: 00000000000002a1 x10: ffff8000092dd468 x9 : ffff800009281550
[ 1567.111690] x8 : 00000000fffff2a1 x7 : ffff8000092d9550 x6 : 0000000000003f18
[ 1567.118808] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1567.125926] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1567.133043] Call trace:
[ 1567.135476] free_contig_range+0xa4/0xc0
[ 1567.139386] cma_release+0x7c/0xd0
[ 1567.142775] dma_free_contiguous+0xa0/0xac
[ 1567.146858] dma_direct_free+0xc0/0x110
[ 1567.150680] dma_free_attrs+0x98/0xe0
[ 1567.154327] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1567.159631] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1567.164585] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1567.169886] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1567.174841] v4l2_release+0xbc/0xf0 [videodev]
[ 1567.179295] __fput+0x70/0x250
[ 1567.182337] ____fput+0x10/0x20
[ 1567.185467] task_work_run+0x80/0xe0
[ 1567.189029] do_notify_resume+0x208/0x1280
[ 1567.193112] el0_svc+0x74/0x84
[ 1567.196153] el0t_64_sync_handler+0xbc/0x140
[ 1567.200409] el0t_64_sync+0x18c/0x190
[ 1567.204057] ---[ end trace 0000000000000000 ]---
[ 1567.208675] ------------[ cut here ]------------
[ 1567.213291] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1567.219686] WARNING: CPU: 6 PID: 3269 at mm/vmallo824] lr : __vunmap+0x78/0x30c
[ 1567.327385] sp : ffff80000c0ebad0
[ 1567.330686] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1567.337805] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1567.344924] x23: 00000009ef840000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1567.352042] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1567.359160] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1567.366278] x14: 000000000000010b x13: 0000000000000000 x12: 0000000000000000
[ 1567.373396] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0eb980
[ 1567.380512] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1567.387630] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dd7c8
[ 1567.394748] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1567.401868] Call trace:
[ 1567.404300] __vunmap+0x78/0x30c
[ 1567.407514] vunmap+0x40/0x5c
[ 1567.410470] dma_direct_free+0x10c/0x110
[ 1567.414379] dma_free_attrs+0x98/0xe0
[ 1567.418027] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1567.423330] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1567.428284] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1567.433585] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1567.438539] v4l2_release+0xbc/0xf0 [videodev]
[ 1567.442993] __fput+0x70/0x250
[ 1567.446036] ____fput+0x10/0x20
[ 1567.449165] task_work_run+0x80/0xe0
[ 1567.452727] do_notify_resume+0x208/0x1280
[ 1567.456811] el0_svc+0x74/0x84
[ 1567.459852] el0t_64_sync_handler+0xbc/0x140
[ 1567.464107] el0t_64_sync+0x18c/0x190
[ 1567.467754] ---[ end trace 0000000000000000 ]---
[ 1567.472376] ------------[ cut here ]------------
[ 1567.476984] 33 pages are still in use!
[ 1567.480730] WARNING: CPU: 6 PID: 3269 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1567.488889] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp85467.615423] x20: 0000000000000021 x19: 00000000009ef861 x18: ffffffffffffffff
[ 1567.622540] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb777
[ 1567.629660] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000008ca
[ 1567.636777] x11: 00000000000002ee x10: ffff8000092ddba0 x9 : ffff800009281550
[ 1567.643895] x8 : 00000000fffff2ee x7 : ffff8000092d9550 x6 : 0000000000004650
[ 1567.651012] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1567.658128] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1567.665246] Call trace:
[ 1567.667680] free_contig_range+0xa4/0xc0
[ 1567.671590] cma_release+0x7c/0xd0
[ 1567.674978] dma_free_contiguous+0xa0/0xac
[ 1567.679060] dma_direct_free+0xc0/0x110
[ 1567.682883] dma_free_attrs+0x98/0xe0
[ 1567.686531] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1567.691835] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1567.696790] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1567.702091] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1567.707045] v4l2_release+0xbc/0xf0 [videodev]
[ 1567.711498] __fput+0x70/0x250
[ 1567.714541] ____fput+0x10/0x20
[ 1567.717670] task_work_run+0x80/0xe0
[ 1567.721232] do_notify_resume+0x208/0x1280
[ 1567.725317] el0_svc+0x74/0x84
[ 1567.728358] el0t_64_sync_handler+0xbc/0x140
[ 1567.732613] el0t_64_sync+0x18c/0x190
[ 1567.736261] ---[ end trace 0000000000000000 ]---
[ 1567.740881] ------------[ cut here ]------------
[ 1567.745489] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1567.751837] WARNING: CPU: 6 PID: 3269 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1567.759042] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfill2] vunmap+0x40/0x5c
[ 1567.942617] dma_direct_free+0x10c/0x110
[ 1567.946528] dma_free_attrs+0x98/0xe0
[ 1567.950177] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1567.955480] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1567.960435] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1567.965736] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1567.970692] v4l2_release+0xbc/0xf0 [videodev]
[ 1567.975142] __fput+0x70/0x250
[ 1567.978184] ____fput+0x10/0x20
[ 1567.981314] task_work_run+0x80/0xe0
[ 1567.984876] do_notify_resume+0x208/0x1280
[ 1567.988960] el0_svc+0x74/0x84
[ 1567.992000] el0t_64_sync_handler+0xbc/0x140
[ 1567.996256] el0t_64_sync+0x18c/0x190
[ 1567.999905] ---[ end trace 0000000000000000 ]---
[ 1568.004533] ------------[ cut here ]------------
[ 1568.009140] 35 pages are still in use!
[ 1568.012886] WARNING: CPU: 6 PID: 3269 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1568.021046] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1568.092724] CPU: 6 PID: 3269 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1568.101833] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1568.107474] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1568.114417] pc : free_contig_range+0xa4/0xc0
[ 1568.118672] lr : free_contig_range+0xa4/0xc0
[ 1568.122928] sp : ffff80000c0eba90
[ 1568.126227] x29: ffff80000c0eba90 x28: 0000000000000204 x27: 0000000000000000
[ 1568.130x110
[ 1568.215040] dma_free_attrs+0x98/0xe0
[ 1568.218690] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1568.223996] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1568.228950] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1568.234251] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1568.239205] v4l2_release+0xbc/0xf0 [videodev]
[ 1568.243661] __fput+0x70/0x250
[ 1568.246706] ____fput+0x10/0x20
[ 1568.249835] task_work_run+0x80/0xe0
[ 1568.253397] do_notify_resume+0x208/0x1280
[ 1568.257481] el0_svc+0x74/0x84
[ 1568.260523] el0t_64_sync_handler+0xbc/0x140
[ 1568.264777] el0t_64_sync+0x18c/0x190
[ 1568.268425] ---[ end trace 0000000000000000 ]---
[ 1568.273051] ------------[ cut here ]------------
[ 1568.277662] Trying to vfree() nonexistent vm area (00000000b51279e6)
[ 1568.284013] WARNING: CPU: 6 PID: 3269 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1568.291218] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1568.362898] CPU: 6 PID: 3269 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1568.372008] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1568.377648] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1568.384589] pc : __vunmap+0x78/0x30c
[ 1568.388150] lr : __vunmap+0x78/0x30c
[ 1568.391712] sp : ffff80000c0ebad0
[ 1568.395012] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1568.402130] x26: 0000000000000000 x25: 0000000000000000 x24: 00000228] __fput+0x70/0x250
[ 1568.510271] ____fput+0x10/0x20
[ 1568.513403] task_work_run+0x80/0xe0
[ 1568.516965] do_notify_resume+0x208/0x1280
[ 1568.521049] el0_svc+0x74/0x84
[ 1568.524091] el0t_64_sync_handler+0xbc/0x140
[ 1568.528346] el0t_64_sync+0x18c/0x190
[ 1568.531995] ---[ end trace 0000000000000000 ]---
[ 1568.536612] ------------[ cut here ]------------
[ 1568.541221] 18 pages are still in use!
[ 1568.544967] WARNING: CPU: 6 PID: 3269 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1568.553126] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1568.624803] CPU: 6 PID: 3269 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1568.633911] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1568.639552] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1568.646493] pc : free_contig_range+0xa4/0xc0
[ 1568.650748] lr : free_contig_range+0xa4/0xc0
[ 1568.655003] sp : ffff80000c0eba90
[ 1568.658302] x29: ffff80000c0eba90 x28: 0000000000000204 x27: 0000000000000000
[ 1568.665421] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1568.672539] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef8f2
[ 1568.679658] x20: 0000000000000012 x19: 00000000009ef8f2 x18: ffffffffffffffff
[ 1568.686776] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb777
[ 1568.693894] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000a98
bc/0x140
[ 1568.796755] el0t_64_sync+0x18c/0x190
[ 1568.800406] ---[ end trace 0000000000000000 ]---
[ 1568.874863] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1568.885434] ------------[ cut here ]------------
[ 1568.890061] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1568.896427] WARNING: CPU: 7 PID: 3272 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1568.903642] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1568.975345] CPU: 7 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1568.984456] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1568.990098] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1568.997041] pc : __vunmap+0x78/0x30c
[ 1569.000604] lr : __vunmap+0x78/0x30c
[ 1569.004164] sp : ffff80000c33bad0
[ 1569.007465] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1569.014583] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1569.021700] x23: 00000009efa80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1569.028818] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1569.035936] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1569.043054] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000b10
[ 1569.050171] x11: 00000000000003b0 x10: fff0000000005880
[ 1569.064412] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1569.071529] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1569.078647] Call trace:
[ 1569.081081] __vunmap+0x78/0x30c
[ 1569.084296] vunmap+0x40/0x5c
[ 1569.087251] dma_direct_free+0x10c/0x110
[ 1569.091161] dma_free_attrs+0x98/0xe0
[ 1569.094811] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1569.100122] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1569.105076] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1569.110378] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1569.115333] v4l2_release+0xbc/0xf0 [videodev]
[ 1569.119789] __fput+0x70/0x250
[ 1569.122834] ____fput+0x10/0x20
[ 1569.125963] task_work_run+0x80/0xe0
[ 1569.129527] do_notify_resume+0x208/0x1280
[ 1569.133613] el0_svc+0x74/0x84
[ 1569.136656] el0t_64_sync_handler+0xbc/0x140
[ 1569.140912] el0t_64_sync+0x18c/0x190
[ 1569.144560] ---[ end trace 0000000000000000 ]---
[ 1569.149190] ------------[ cut here ]------------
[ 1569.153816] 65 pages are still in use!
[ 1569.157632] WARNING: CPU: 7 PID: 3272 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1569.165795] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1569.237475] CPU: 7 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1569.246584] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1569.252225] pstate: 60000005 (nZCv daif -PAN -UAO -TCOwave5]
[ 1569.373703] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1569.379005] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1569.383958] v4l2_release+0xbc/0xf0 [videodev]
[ 1569.388413] __fput+0x70/0x250
[ 1569.391456] ____fput+0x10/0x20
[ 1569.394585] task_work_run+0x80/0xe0
[ 1569.398147] do_notify_resume+0x208/0x1280
[ 1569.402232] el0_svc+0x74/0x84
[ 1569.405273] el0t_64_sync_handler+0xbc/0x140
[ 1569.409528] el0t_64_sync+0x18c/0x190
[ 1569.413177] ---[ end trace 0000000000000000 ]---
[ 1569.417804] ------------[ cut here ]------------
[ 1569.422414] Trying to vfree() nonexistent vm area (00000000b84bacf7)
[ 1569.428763] WARNING: CPU: 7 PID: 3272 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1569.435969] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1569.507647] CPU: 7 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1569.516756] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1569.522396] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1569.529339] pc : __vunmap+0x78/0x30c
[ 1569.532901] lr : __vunmap+0x78/0x30c
[ 1569.536463] sp : ffff80000c33bad0
[ 1569.539763] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1569.546881] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1569.553999] x23: 00000009ef940000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1569.561117] x20: 0000000000000000 x19: ffff80000c35e04/0x18c [wave5]
[ 1569.642661] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1569.647616] v4l2_release+0xbc/0xf0 [videodev]
[ 1569.652071] __fput+0x70/0x250
[ 1569.655115] ____fput+0x10/0x20
[ 1569.658244] task_work_run+0x80/0xe0
[ 1569.661805] do_notify_resume+0x208/0x1280
[ 1569.665890] el0_svc+0x74/0x84
[ 1569.668932] el0t_64_sync_handler+0xbc/0x140
[ 1569.673187] el0t_64_sync+0x18c/0x190
[ 1569.676834] ---[ end trace 0000000000000000 ]---
[ 1569.681458] ------------[ cut here ]------------
[ 1569.686066] 33 pages are still in use!
[ 1569.689813] WARNING: CPU: 7 PID: 3272 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1569.697972] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1569.769650] CPU: 7 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1569.778758] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1569.784398] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1569.791341] pc : free_contig_range+0xa4/0xc0
[ 1569.795596] lr : free_contig_range+0xa4/0xc0
[ 1569.799851] sp : ffff80000c33ba90
[ 1569.803151] x29: ffff80000c33ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1569.810269] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1569.817387] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef961
[ 1569.824505] x20: 0000000000000021 x19: 00000000009ef961 x18: ffffffffffffffff
[ 1569.831622] x17: 0000000000000000 x ]---
[ 1569.949954] ------------[ cut here ]------------
[ 1569.954560] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1569.960905] WARNING: CPU: 7 PID: 3272 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1569.968109] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1570.039785] CPU: 7 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1570.048894] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1570.054534] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1570.061477] pc : __vunmap+0x78/0x30c
[ 1570.065039] lr : __vunmap+0x78/0x30c
[ 1570.068600] sp : ffff80000c33bad0
[ 1570.071900] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1570.079018] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1570.086136] x23: 00000009efa00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1570.093253] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1570.100371] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1570.107489] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000cde
[ 1570.114607] x11: 000000000000044a x10: ffff8000092dfc40 x9 : ffff800009281550
[ 1570.121725] x8 : 00000000fffff44a x7 : ffff8000092d9550 x6 : 00000000000066f0
[ 1570.128843] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1570.135960] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae1558ARNING: CPU: 6 PID: 3272 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1570.230145] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1570.301824] CPU: 6 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1570.310934] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1570.316574] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1570.323517] pc : free_contig_range+0xa4/0xc0
[ 1570.327773] lr : free_contig_range+0xa4/0xc0
[ 1570.332029] sp : ffff80000c33ba90
[ 1570.335329] x29: ffff80000c33ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1570.342448] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1570.349565] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efa23
[ 1570.356682] x20: 0000000000000023 x19: 00000000009efa23 x18: ffffffffffffffff
[ 1570.363800] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b777
[ 1570.370917] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000d50
[ 1570.378036] x11: 0000000000000470 x10: ffff8000092dffd0 x9 : ffff800009281550
[ 1570.385153] x8 : 00000000fffff470 x7 : ffff8000092d9550 x6 : 0000000000006a80
[ 1570.392269] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1570.399387] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1570.406506] Call trace:
[ 1570.408938] free_contig_range+0xa4/0xc0
[ 1570.412847] cma_release+0x7c/0xd0
[ 1570RNING: CPU: 6 PID: 3272 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1570.500317] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1570.572002] CPU: 6 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1570.581111] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1570.586751] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1570.593694] pc : __vunmap+0x78/0x30c
[ 1570.597256] lr : __vunmap+0x78/0x30c
[ 1570.600818] sp : ffff80000c33bad0
[ 1570.604118] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1570.611236] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1570.618354] x23: 00000009ef9e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1570.625471] x20: 0000000000000000 x19: ffff80000c3bd000 x18: ffffffffffffffff
[ 1570.632589] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1570.639705] x14: 0000000000000106 x13: 0000000000000000 x12: 0000000000000000
[ 1570.646822] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c33b980
[ 1570.653939] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1570.661056] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a06248
[ 1570.668173] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1570.675289] Call trace:
[ 1570.677723] __vunmap+0x78/0x30c
[ 1570.680938] vunmap+0x40/0x5c
v61570.683894] dma_direct_free+0x10c/0x110
[ 1570.833906] CPU: 6 PID: 3272 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1570.843014] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1570.848659] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1570.855601] pc : free_contig_range+0xa4/0xc0
[ 1570.859856] lr : free_contig_range+0xa4/0xc0
[ 1570.864112] sp : ffff80000c33ba90
[ 1570.867412] x29: ffff80000c33ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1570.874529] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1570.881646] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009ef9f2
[ 1570.888763] x20: 0000000000000012 x19: 00000000009ef9f2 x18: ffffffffffffffff
[ 1570.895881] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b777
[ 1570.902998] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000e37
[ 1570.910115] x11: 00000000000004bd x10: ffff8000092e0708 x9 : ffff800009281550
[ 1570.917233] x8 : 00000000fffff4bd x7 : ffff8000092d9550 x6 : 00000000000071b8
[ 1570.924351] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1570.931469] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1570.938587] Call trace:
[ 1570.941020] free_contig_range+0xa4/0xc0
[ 1570.944928] cma_release+0x7c/0xd0
[ 1570.948316] dma_free_contiguous+0xa0/0xac
[ 1570.952398] dma_direct_free+0xc0/0x110
[ 1570.956220] dma_free_attrs+0x98/0xe0
[ 1570.959867] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1570.965169] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1570.970037] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1570.975338] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1570.980292] v4l2_release+0xbc/0xf0 [videodev]
[ 1570.984743] __fput+0x70/0x250
[ 1570.987786] ____fput+0x10/0x20
[ 1570.990915] task_work_run+0x80/0xe0
[ 1570.994477] do_notify_resume+0x208/0x1280
[ 1570.998561] el0_svc+0x74/0x84
[ 1571.001602] el0t_64_sync_handler+0xbc/0x140
[ 1571.005857] el0t_64_sync+0x18c/0x190
[ 1571.009504] ---[ end trace 0000000000000000 ]---
[ 1571.078387] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1571.088811] ------------[ cut here ]--videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1571.178717] CPU: 7 PID: 3275 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1571.187828] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1571.193471] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1571.200414] pc : __vunmap+0x78/0x30c
[ 1571.203976] lr : __vunmap+0x78/0x30c
[ 1571.207538] sp : ffff80000ba8bad0
[ 1571.210838] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1571.217956] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1571.225074] x23: 00000009efb80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1571.232192] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1571.239309] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1571.246426] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000eaf
[ 1571.253543] x11: 00000000000004e5 x10: ffff8000092e0ac8 x9 : ffff800009281550
[ 1571.260662] x8 : 00000000fffff4e5 x7 : ffff8000092d9550 x6 : 0000000000007578
[ 1571.267779] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1571.274896] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1571.282014] Call trace:
[ 1571.284448] __vunmap+0x78/0x30c
[ 1571.287664] vunmap+0x40/0x5c
[ 1571.290619] dma_direct_free+0x10c/0x110
[ 1571.294530] dma_free_attrs+0x98/0xe0
[ 1571.298178] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1571.303489] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1571.308443] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1571.313744] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1571.318698] v4l2_release+0xbc/0xf0 [videodev]
[ 1571.tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1571.440905] CPU: 7 PID: 3275 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1571.450017] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1571.455658] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1571.462600] pc : free_contig_range+0xa4/0xc0
[ 1571.466857] lr : free_contig_range+0xa4/0xc0
[ 1571.471114] sp : ffff80000ba8ba90
[ 1571.474414] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1571.481532] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1571.488649] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efbc1
[ 1571.495767] x20: 0000000000000041 x19: 00000000009efbc1 x18: ffffffffffffffff
[ 1571.502885] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1571.510002] x14: 000000000000023f x13: 0000000000000000 x12: 0000000000000000
[ 1571.517120] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000ba8b940
[ 1571.524238] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1571.531355] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a05ec8
[ 1571.538473] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1571.545590] Call trace:
[ 1571.548023] free_contig_range+0xa4/0xc0
[ 1571.551932] cma_release+0x7c/0xd0
[ 1571.555321] dma_free_contiguous+0xa0/0xac
[ 1571.559403] dma_direct_free+0xc0/0x110
[ 1571.563226] dma_free_attrs+0x98/0xe0
[ 1571.566874] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1571.572177] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1571.577131] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1571.582432] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1571.587387] v4l2_release+0xbc/0xf0 [videodev]
[ 1571.591840] __fput+0x70/0x250
[ 1571.594883] ____fput+0x10/0x20
[ 1571.598013] task_work_run+0x80/0xe0
[ 1571.601575] do_notify_resume+0x208/0x1280
[ 1571.605660] el0_svc+0x74/0x84
[ 1571.608702] el0t_64_sync_handler+0xbc/0x140
[ 1571.612956] el0t__fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1571.711101] CPU: 7 PID: 3275 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1571.720213] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1571.725854] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1571.732796] pc : __vunmap+0x78/0x30c
[ 1571.736358] lr : __vunmap+0x78/0x30c
[ 1571.739919] sp : ffff80000ba8bad0
[ 1571.743219] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1571.750339] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1571.757457] x23: 00000009efa40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1571.764574] x20: 0000000000000000 x19: ffff80000c35e000 x18: ffffffffffffffff
[ 1571.771692] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1571.778810] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000f96
[ 1571.785927] x11: 0000000000000532 x10: ffff8000092e1200 x9 : ffff800009281550
[ 1571.793045] x8 : 00000000fffff532 x7 : ffff8000092d9550 x6 : 0000000000007cb0
[ 1571.800163] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1571.807280] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1571.814396] Call trace:
[ 1571.816830] __vunmap+0x78/0x30c
[ 1571.820044] vunmap+0x40/0x5c
[ 1571.822999] dma_direct_free+0x10c/0x110
[ 1571.826909] dma_free_attrs+0x98/0xe0
[ 1571.830557] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1571.835858] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1571.840812] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1571.846114] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1571.851068] v4l2_release+0xbc/0xf0 [videodev]
[ 1571.855523] __fput+0x70/0x250
[ 1571.858566] ____fput+0x10/0x20
[ 1571.861696] task_work_run+0x80/0xe0
[ 1571.865257] do_notify_resume+0x208/0x1280
[ 1571.869342] el0_svc+0x74/0x84
[ 1571.872383] el0t_64_sync_handler+0xbc/0x140
[ 1571.876638] el0t_64_sync+0x18c/0x190
[ 1571.880285] ---[ end trace 0000000000000000 ]---
[ 1571.884907] ------------[ cut here ]------------
[ 1571.889520] rea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1571.973153] CPU: 7 PID: 3275 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1571.982264] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1571.987905] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1571.994848] pc : free_contig_range+0xa4/0xc0
[ 1571.999104] lr : free_contig_range+0xa4/0xc0
[ 1572.003360] sp : ffff80000ba8ba90
[ 1572.006660] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1572.013778] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1572.020896] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efa61
[ 1572.028013] x20: 0000000000000021 x19: 00000000009efa61 x18: ffffffffffffffff
[ 1572.035131] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1572.042248] x14: 0000000000000051 x13: 0000000000000000 x12: 0000000000000000
[ 1572.049366] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000ba8b940
[ 1572.056483] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1572.063600] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a05ec8
[ 1572.070717] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1572.077835] Call trace:
[ 1572.080268] free_contig_range+0xa4/0xc0
[ 1572.084177] cma_release+0x7c/0xd0
[ 1572.087565] dma_free_contiguous+0xa0/0xac
[ 1572.091649] dma_direct_free+0xc0/0x110
[ 1572.095471] dma_free_attrs+0x98/0xe0
[ 1572.099120] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1572.104423] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1572.109379] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1572.114680] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1572.119635] v4l2_release+0xbc/0xf0 [videodev]
[ 1572.124087] __fput+0x70/0x250
[ 1572.127131] ____fput+0x10/0x20
[ 1572.130260] task_work_run+0x80/0xe0
[ 1572.133821] do_notify_resume+0x208/0x1280
[ 1572.137905] el0_svc+0x74/0x84
[ 1572.14mm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1572.252435] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1572.258076] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1572.265019] pc : __vunmap+0x78/0x30c
[ 1572.268581] lr : __vunmap+0x78/0x30c
[ 1572.272143] sp : ffff80000ba8bad0
[ 1572.275443] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1572.282561] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1572.289679] x23: 00000009efb00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1572.296798] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1572.303916] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1572.311034] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000107d
[ 1572.318152] x11: 000000000000057f x10: ffff8000092e1938 x9 : ffff800009281550
[ 1572.325270] x8 : 00000000fffff57f x7 : ffff8000092d9550 x6 : 00000000000083e8
[ 1572.332387] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1572.339505] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1572.346622] Call trace:
[ 1572.349056] __vunmap+0x78/0x30c
[ 1572.352272] vunmap+0x40/0x5c
[ 1572.355227] dma_direct_free+0x10c/0x110
[ 1572.359137] dma_free_attrs+0x98/0xe0
[ 1572.362785] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1572.368086] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1572.373040] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1572.378341] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1572.383295] v4l2_release+0xbc/0xf0 [videodev]
[ 1572.387748] __fput+0x70/0x250
[ 1572.390791] ____fput+0x10/0x20
[ 1572.393920] task_work_run+0x80/0xe0
[ 1572.397481] do_notify_resume+0x208/0x1280
[ 1572.401565] el0_svc+0x74/0x84
[ 1572.404607] el0t_64_sync_handler+0xbc/0x140
[ 1572.408862] el0t_64_sync+0x18c/0x190
[ 1572.412511] ---[ end trace 0000000000000000 ]---
[ 1572.417135] ------------[ cut here ]------------
[ 1572.421744] 35 pages are still in use!
[ 1572.425488] WARNING: CPU: 7 PID: 3275 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1572.433647] Modules linked in: overlay cfg80211 pci_endpoint_test bl72.535530] sp : ffff80000ba8ba90
[ 1572.538830] x29: ffff80000ba8ba90 x28: 0000000000000204 x27: 0000000000000000
[ 1572.545947] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1572.553065] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efb23
[ 1572.560183] x20: 0000000000000023 x19: 00000000009efb23 x18: ffffffffffffffff
[ 1572.567302] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b777
[ 1572.574419] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000010ef
[ 1572.581537] x11: 00000000000005a5 x10: ffff8000092e1cc8 x9 : ffff800009281550
[ 1572.588654] x8 : 00000000fffff5a5 x7 : ffff8000092d9550 x6 : 0000000000008778
[ 1572.595770] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1572.602888] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1572.610006] Call trace:
[ 1572.612438] free_contig_range+0xa4/0xc0
[ 1572.616346] cma_release+0x7c/0xd0
[ 1572.619735] dma_free_contiguous+0xa0/0xac
[ 1572.623817] dma_direct_free+0xc0/0x110
[ 1572.627640] dma_free_attrs+0x98/0xe0
[ 1572.631287] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1572.636590] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1572.641544] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1572.646845] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1572.651799] v4l2_release+0xbc/0xf0 [videodev]
[ 1572.656250] __fput+0x70/0x250
[ 1572.659294] ____fput+0x10/0x20
[ 1572.662423] task_work_run+0x80/0xe0
[ 1572.665985] do_notify_resume+0x208/0x1280
[ 1572.670069] el0_svc+0x74/0x84
[ 1572.673111] el0t_64_sync_handler+0xbc/0x140
[ 1572.677365] el0t_64_sync+0x18c/0x190
[ 1572.681012] ---[ end trace 0000000000000000 ]---
[ 1572.685633] ------------[ cut here ]------------
[ 1572.690241] Trying to vfree() nonexistent vm area (00000000b51279e6)
[ 1572.696588] WARNING: CPU: 7 PID: 3275 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1572.703794] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1572.814703] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1572.821820] x23: 00000009efae0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1572.828940] x20: 0000000000000000 x19: ffff80000c3bd000 x18: ffffffffffffffff
[ 1572.836056] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1572.843173] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001164
[ 1572.850290] x11: 00000000000005cc x10: ffff8000092e2070 x9 : ffff800009281550
[ 1572.857407] x8 : 00000000fffff5cc x7 : ffff8000092d9550 x6 : 0000000000008b20
[ 1572.864524] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1572.871642] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1572.878760] Call trace:
[ 1572.881192] __vunmap+0x78/0x30c
[ 1572.884407] vunmap+0x40/0x5c
[ 1572.887362] dma_direct_free+0x10c/0x110
[ 1572.891272] dma_free_attrs+0x98/0xe0
[ 1572.894920] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1572.900222] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1572.905090] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1572.910390] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1572.915344] v4l2_release+0xbc/0xf0 [videodev]
[ 1572.919795] __fput+0x70/0x250
[ 1572.922838] ____fput+0x10/0x20
[ 1572.925967] task_work_run+0x80/0xe0
[ 1572.929529] do_notify_resume+0x208/0x1280
[ 1572.933613] el0_svc+0x74/0x84
[ 1572.936654] el0t_64_sync_handler+0xbc/0x140
[ 1572.940909] el0t_64_sync+0x18c/0x190
[ 1572.944557] ---[ end trace 0000000000000000 ]---
[ 1572.949184] ------------[ cut here ]------------
[ 1572.953793] 18 pages are still in use!
[ 1572.957538] WARNING: CPU: 7 PID: 3275 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1572.965697] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helpe0000000000000 x13: ffff800009281550 x12: 00000000000011d6
[ 1573.113585] x11: 00000000000005f2 x10: ffff8000092e2400 x9 : ffff800009281550
[ 1573.120704] x8 : 00000000fffff5f2 x7 : ffff8000092d9550 x6 : 0000000000008eb0
[ 1573.127821] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1573.134938] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1573.142055] Call trace:
[ 1573.144488] free_contig_range+0xa4/0xc0
[ 1573.148396] cma_release+0x7c/0xd0
[ 1573.151785] dma_free_contiguous+0xa0/0xac
[ 1573.155867] dma_direct_free+0xc0/0x110
[ 1573.159689] dma_free_attrs+0x98/0xe0
[ 1573.163337] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1573.168639] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1573.173508] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1573.178809] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1573.183764] v4l2_release+0xbc/0xf0 [videodev]
[ 1573.188214] __fput+0x70/0x250
[ 1573.191257] ____fput+0x10/0x20
[ 1573.194386] task_work_run+0x80/0xe0
[ 1573.197948] do_notify_resume+0x208/0x1280
[ 1573.202031] el0_svc+0x74/0x84
[ 1573.205072] el0t_64_sync_handler+0xbc/0x140
[ 1573.209327] el0t_64_sync+0x18c/0x190
[ 1573.212976] ---[ end trace 0000000000000000 ]---
[ 1573.281292] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1573.291581] ------------[ cut here ]------------
[ 1573.296246] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1573.302709] WARNING: CPU: 6 PID: 3278 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1573.309924] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_0000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1573.427983] x23: 00000009efc80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1573.435101] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1573.442218] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1573.449335] x14: 0000000000000346 x13: 0000000000000000 x12: 0000000000000000
[ 1573.456452] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1573.463569] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1573.470686] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dd7c8
[ 1573.477803] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1573.484921] Call trace:
[ 1573.487356] __vunmap+0x78/0x30c
[ 1573.490571] vunmap+0x40/0x5c
[ 1573.493527] dma_direct_free+0x10c/0x110
[ 1573.497438] dma_free_attrs+0x98/0xe0
[ 1573.501087] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1573.506398] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1573.511353] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1573.516655] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1573.521611] v4l2_release+0xbc/0xf0 [videodev]
[ 1573.526067] __fput+0x70/0x250
[ 1573.529111] ____fput+0x10/0x20
[ 1573.532240] task_work_run+0x80/0xe0
[ 1573.535804] do_notify_resume+0x208/0x1280
[ 1573.539890] el0_svc+0x74/0x84
[ 1573.542934] el0t_64_sync_handler+0xbc/0x140
[ 1573.547190] el0t_64_sync+0x18c/0x190
[ 1573.550840] ---[ end trace 0000000000000000 ]---
[ 1573.555482] ------------[ cut here ]------------
[ 1573.560091] 65 pages are still in use!
[ 1573.563832] WARNING: CPU: 6 PID: 3278 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1573.571994] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteprog_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1573.643672] CPU: 6 PID: 3278 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1573.652783] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1573.658424] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1573.665366] pc : free_contig_range+0xa4/0xc0
[ 1573.669622] lr : free_contig_range+0xa4/0xc0
[ 1573.673878] sp : ffff80000baeba90
[ 1573.677178] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1573.684296] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1573.691413] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efcc1
[ 1573.698530] x20: 0000000000000041 x19: 00000000009efcc1 x18: ffffffffffffffff
[ 1573.705648] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1573.712765] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000012c0
[ 1573.719882] x11: 0000000000000640 x10: ffff8000092e2b50 x9 : ffff800009281550
[ 1573.726999] x8 : 00000000fffff640 x7 : ffff8000092d9550 x6 : 0000000000009600
[ 1573.734116] x5 : ffff000f5c3dbb60 x4 : 0000000000000000 x3 : 0000000000000027
[ 1573.741233] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1573.748350] Call trace:
[ 1573.750783] free_contig_range+0xa4/0xc0
[ 1573.754692] cma_release+0x7c/0xd0
[ 1573.758080] dma_free_contiguous+0xa0/0xac
[ 1573.762163] dma_direct_free+0xc0/0x110
[ 1573.765986] dma_free_attrs+0x98/0xe0
[ 1573.769635] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1573.774937] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1573.779893] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1573.785194] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1573.790149] v4l2_release+0xbc/0xf0 [videodev]
[ 1573.794603] __fput+0x70/0x250
[ 1573.797647] ____fput+0x10/0x20
[ 1573.800776] task_work_run+0x80/0xe0
[ 1573.804337] do_notify_resume+0x208/0x1280
[ 1573.808421] el0_svc+0x74/0x84
[ 1573.811463] el0t_64_sync_handler+0xbc/0x140
[ 1573.815717] el0t_64_sync+0x18c/0x190
[ 1573.819365] ---[ end trace 0000000000000000 ]---
[ 1573.823987] ------------[ cut here ]------------
[ 1573.828603] Trying to vfree() no0000000000000000
[ 1573.960224] x23: 00000009efb40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1573.967342] x20: 0000000000000000 x19: ffff80000c35e000 x18: ffffffffffffffff
[ 1573.974459] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1573.981576] x14: 000000000000018d x13: 0000000000000000 x12: 0000000000000000
[ 1573.988693] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1573.995810] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1574.002927] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dd7c8
[ 1574.010044] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1574.017162] Call trace:
[ 1574.019595] __vunmap+0x78/0x30c
[ 1574.022809] vunmap+0x40/0x5c
[ 1574.025765] dma_direct_free+0x10c/0x110
[ 1574.029673] dma_free_attrs+0x98/0xe0
[ 1574.033322] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1574.038626] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1574.043580] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1574.048881] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1574.053836] v4l2_release+0xbc/0xf0 [videodev]
[ 1574.058288] __fput+0x70/0x250
[ 1574.061332] ____fput+0x10/0x20
[ 1574.064460] task_work_run+0x80/0xe0
[ 1574.068022] do_notify_resume+0x208/0x1280
[ 1574.072106] el0_svc+0x74/0x84
[ 1574.075148] el0t_64_sync_handler+0xbc/0x140
[ 1574.079403] el0t_64_sync+0x18c/0x190
[ 1574.083052] ---[ end trace 0000000000000000 ]---
[ 1574.087672] ------------[ cut here ]------------
[ 1574.092279] 33 pages are still in use!
[ 1574.096018] WARNING: CPU: 6 PID: 3278 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1574.104176] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_b000000000000 x3 : 0000000000000027
[ 1574.273414] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1574.280533] Call trace:
[ 1574.282965] free_contig_range+0xa4/0xc0
[ 1574.286874] cma_release+0x7c/0xd0
[ 1574.290263] dma_free_contiguous+0xa0/0xac
[ 1574.294346] dma_direct_free+0xc0/0x110
[ 1574.298168] dma_free_attrs+0x98/0xe0
[ 1574.301818] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1574.307121] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1574.312075] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1574.317376] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1574.322330] v4l2_release+0xbc/0xf0 [videodev]
[ 1574.326783] __fput+0x70/0x250
[ 1574.329826] ____fput+0x10/0x20
[ 1574.332955] task_work_run+0x80/0xe0
[ 1574.336517] do_notify_resume+0x208/0x1280
[ 1574.340600] el0_svc+0x74/0x84
[ 1574.343642] el0t_64_sync_handler+0xbc/0x140
[ 1574.347896] el0t_64_sync+0x18c/0x190
[ 1574.351544] ---[ end trace 0000000000000000 ]---
[ 1574.356166] ------------[ cut here ]------------
[ 1574.360772] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1574.367119] WARNING: CPU: 6 PID: 3278 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1574.374325] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1574.446001] CPU: 6 PID: 3278 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1574.455109] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1574.460750] pstate: 60000005 f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1574.542173] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1574.549290] Call trace:
[ 1574.551723] __vunmap+0x78/0x30c
[ 1574.554939] vunmap+0x40/0x5c
[ 1574.557894] dma_direct_free+0x10c/0x110
[ 1574.561803] dma_free_attrs+0x98/0xe0
[ 1574.565451] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1574.570754] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1574.575709] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1574.581010] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1574.585963] v4l2_release+0xbc/0xf0 [videodev]
[ 1574.590415] __fput+0x70/0x250
[ 1574.593458] ____fput+0x10/0x20
[ 1574.596587] task_work_run+0x80/0xe0
[ 1574.600149] do_notify_resume+0x208/0x1280
[ 1574.604232] el0_svc+0x74/0x84
[ 1574.607273] el0t_64_sync_handler+0xbc/0x140
[ 1574.611528] el0t_64_sync+0x18c/0x190
[ 1574.615176] ---[ end trace 0000000000000000 ]---
[ 1574.619796] ------------[ cut here ]------------
[ 1574.624403] 35 pages are still in use!
[ 1574.628148] WARNING: CPU: 6 PID: 3278 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1574.636308] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1574.707984] CPU: 6 PID: 3278 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1574.717093] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1574.722733] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1574.7294.741487] x29: ffff80000baeba90 x28: 0000000000000204 x27: 0000000000000000
[ 1574.748606] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1574.755723] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efc23
[ 1574.762840] x20: 0000000000000023 x19: 00000000009efc23 x18: ffffffffffffffff
[ 1574.769957] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1574.777074] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000148e
[ 1574.784192] x11: 00000000000006da x10: ffff8000092e39c0 x9 : ffff800009281550
[ 1574.791310] x8 : 00000000fffff6da x7 : ffff8000092d9550 x6 : 000000000000a470
[ 1574.798427] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1574.805545] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1574.812663] Call trace:
[ 1574.815097] free_contig_range+0xa4/0xc0
[ 1574.819006] cma_release+0x7c/0xd0
[ 1574.822393] dma_free_contiguous+0xa0/0xac
[ 1574.826476] dma_direct_free+0xc0/0x110
[ 1574.830297] dma_free_attrs+0x98/0xe0
[ 1574.833945] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1574.839246] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1574.844201] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1574.849501] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1574.854455] v4l2_release+0xbc/0xf0 [videodev]
[ 1574.858907] __fput+0x70/0x250
[ 1574.861950] ____fput+0x10/0x20
[ 1574.865079] task_work_run+0x80/0xe0
[ 1574.868641] do_notify_resume+0x208/0x1280
[ 1574.872724] el0_svc+0x74/0x84
[ 1574.875766] el0t_64_sync_handler+0xbc/0x140
[ 1574.880021] el0t_64_sync+0x18c/0x190
[ 1574.883668] ---[ end trace 0000000000000000 ]---
[ 1574.888284] ------------[ cut here ]------------
[ 1574.892890] Trying to vfree() nonexistent vm area (00000000b51279e6)
[ 1574.899237] WARNING: CPU: 6 PID: 3278 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1574.906442] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp800000000000000
[ 1575.024469] x23: 00000009efbe0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1575.031587] x20: 0000000000000000 x19: ffff80000c3bd000 x18: ffffffffffffffff
[ 1575.038703] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1575.045820] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001503
[ 1575.052938] x11: 0000000000000701 x10: ffff8000092e3d68 x9 : ffff800009281550
[ 1575.060056] x8 : 00000000fffff701 x7 : ffff8000092d9550 x6 : 000000000000a818
[ 1575.067172] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1575.074290] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1575.081408] Call trace:
[ 1575.083841] __vunmap+0x78/0x30c
[ 1575.087056] vunmap+0x40/0x5c
[ 1575.090011] dma_direct_free+0x10c/0x110
[ 1575.093920] dma_free_attrs+0x98/0xe0
[ 1575.097568] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1575.102869] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1575.107737] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1575.113037] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1575.117992] v4l2_release+0xbc/0xf0 [videodev]
[ 1575.122442] __fput+0x70/0x250
[ 1575.125485] ____fput+0x10/0x20
[ 1575.128614] task_work_run+0x80/0xe0
[ 1575.132176] do_notify_resume+0x208/0x1280
[ 1575.136259] el0_svc+0x74/0x84
[ 1575.139300] el0t_64_sync_handler+0xbc/0x140
[ 1575.143555] el0t_64_sync+0x18c/0x190
[ 1575.147202] ---[ end trace 0000000000000000 ]---
[ 1575.151839] ------------[ cut here ]------------
[ 1575.156447] 18 pages are still in use!
[ 1575.160192] WARNING: CPU: 6 PID: 3278 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1575.168351] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpms0: 0000000000000012 x19: 00000000009efbf2 x18: ffffffffffffffff
[ 1575.302003] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb777
[ 1575.309121] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001575
[ 1575.316239] x11: 0000000000000727 x10: ffff8000092e40f8 x9 : ffff800009281550
[ 1575.323356] x8 : 00000000fffff727 x7 : ffff8000092d9550 x6 : 000000000000aba8
[ 1575.330473] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1575.337589] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1575.344707] Call trace:
[ 1575.347140] free_contig_range+0xa4/0xc0
[ 1575.351048] cma_release+0x7c/0xd0
[ 1575.354437] dma_free_contiguous+0xa0/0xac
[ 1575.358519] dma_direct_free+0xc0/0x110
[ 1575.362340] dma_free_attrs+0x98/0xe0
[ 1575.365988] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1575.371290] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1575.376157] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1575.381459] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1575.386412] v4l2_release+0xbc/0xf0 [videodev]
[ 1575.390864] __fput+0x70/0x250
[ 1575.393907] ____fput+0x10/0x20
[ 1575.397036] task_work_run+0x80/0xe0
[ 1575.400597] do_notify_resume+0x208/0x1280
[ 1575.404681] el0_svc+0x74/0x84
[ 1575.407722] el0t_64_sync_handler+0xbc/0x140
[ 1575.411977] el0t_64_sync+0x18c/0x190
[ 1575.415624] ---[ end trace 0000000000000000 ]---
[ 1575.483267] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1575.493552] ------------[ cut here ]------------
[ 1575.498179] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1575.504534] WARNING: CPU: 0 PID: 3281 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1575.511748] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteprolr : __vunmap+0x78/0x30c
[ 1575.612269] sp : ffff8000094d3ad0
[ 1575.615569] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1575.622688] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1575.629807] x23: 00000009efd80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1575.636925] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1575.644043] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1575.651160] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000015ed
[ 1575.658277] x11: 000000000000074f x10: ffff8000092e44b8 x9 : ffff800009281550
[ 1575.665394] x8 : 00000000fffff74f x7 : ffff8000092d9550 x6 : 000000000000af68
[ 1575.672512] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1575.679631] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1575.686749] Call trace:
[ 1575.689183] __vunmap+0x78/0x30c
[ 1575.692398] vunmap+0x40/0x5c
[ 1575.695354] dma_direct_free+0x10c/0x110
[ 1575.699267] dma_free_attrs+0x98/0xe0
[ 1575.702917] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1575.708228] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1575.713183] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1575.718484] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1575.723438] v4l2_release+0xbc/0xf0 [videodev]
[ 1575.727894] __fput+0x70/0x250
[ 1575.730940] ____fput+0x10/0x20
[ 1575.734069] task_work_run+0x80/0xe0
[ 1575.737632] do_notify_resume+0x208/0x1280
[ 1575.741719] el0_svc+0x74/0x84
[ 1575.744763] el0t_64_sync_handler+0xbc/0x140
[ 1575.749018] el0t_64_sync+0x18c/0x190
[ 1575.752668] ---[ end trace 0000000000000000 ]---
[ 1575.757312] ------------[ cut here ]------------
[ 1575.761939] 65 pages are still in use!
[ 1575.765747] WARNING: CPU: 0 PID: 3281 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1575.773910] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm x8 : ffff0008aae15150 x7 : ffff000f5c370340 x6 : 0000000000000000
[ 1575.936037] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1b465c8
[ 1575.943154] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1575.950272] Call trace:
[ 1575.952705] free_contig_range+0xa4/0xc0
[ 1575.956614] cma_release+0x7c/0xd0
[ 1575.960003] dma_free_contiguous+0xa0/0xac
[ 1575.964085] dma_direct_free+0xc0/0x110
[ 1575.967907] dma_free_attrs+0x98/0xe0
[ 1575.971556] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1575.976860] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1575.981815] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1575.987117] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1575.992071] v4l2_release+0xbc/0xf0 [videodev]
[ 1575.996525] __fput+0x70/0x250
[ 1575.999568] ____fput+0x10/0x20
[ 1576.002698] task_work_run+0x80/0xe0
[ 1576.006260] do_notify_resume+0x208/0x1280
[ 1576.010344] el0_svc+0x74/0x84
[ 1576.013386] el0t_64_sync_handler+0xbc/0x140
[ 1576.017641] el0t_64_sync+0x18c/0x190
[ 1576.021290] ---[ end trace 0000000000000000 ]---
[ 1576.025921] ------------[ cut here ]------------
[ 1576.030529] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1576.036876] WARNING: CPU: 0 PID: 3281 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1576.044081] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1576.115757] CPU: 0 PID: 3281 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33ma_direct_free+0x10c/0x110
[ 1576.231564] dma_free_attrs+0x98/0xe0
[ 1576.235212] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1576.240515] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1576.245468] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1576.250769] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1576.255723] v4l2_release+0xbc/0xf0 [videodev]
[ 1576.260175] __fput+0x70/0x250
[ 1576.263218] ____fput+0x10/0x20
[ 1576.266347] task_work_run+0x80/0xe0
[ 1576.269909] do_notify_resume+0x208/0x1280
[ 1576.273993] el0_svc+0x74/0x84
[ 1576.277035] el0t_64_sync_handler+0xbc/0x140
[ 1576.281290] el0t_64_sync+0x18c/0x190
[ 1576.284938] ---[ end trace 0000000000000000 ]---
[ 1576.289566] ------------[ cut here ]------------
[ 1576.294174] 33 pages are still in use!
[ 1576.297918] WARNING: CPU: 0 PID: 3281 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1576.306078] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1576.377753] CPU: 0 PID: 3281 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1576.386862] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1576.392503] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1576.399444] pc : free_contig_range+0xa4/0xc0
[ 1576.403699] lr : free_contig_range+0xa4/0xc0
[ 1576.407954] sp : ffff8000094d3a90
[ 1576.411255] x29: ffff8000094d3a90 x28: 0000000000000204 x27: 0000000000000000
[ 1576.418373] x26: 0000000000000000 x25: 000028680] __fput+0x70/0x250
[ 1576.531723] ____fput+0x10/0x20
[ 1576.534852] task_work_run+0x80/0xe0
[ 1576.538414] do_notify_resume+0x208/0x1280
[ 1576.542498] el0_svc+0x74/0x84
[ 1576.545539] el0t_64_sync_handler+0xbc/0x140
[ 1576.549794] el0t_64_sync+0x18c/0x190
[ 1576.553442] ---[ end trace 0000000000000000 ]---
[ 1576.558071] ------------[ cut here ]------------
[ 1576.562680] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1576.569024] WARNING: CPU: 0 PID: 3281 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1576.576228] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1576.647904] CPU: 0 PID: 3281 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1576.657013] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1576.662653] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1576.669596] pc : __vunmap+0x78/0x30c
[ 1576.673158] lr : __vunmap+0x78/0x30c
[ 1576.676720] sp : ffff8000094d3ad0
[ 1576.680019] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1576.687138] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1576.694256] x23: 00000009efd00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1576.701374] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1576.708491] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1576.715609] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001---
[ 1576.826318] 35 pages are still in use!
[ 1576.830068] WARNING: CPU: 0 PID: 3281 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1576.838228] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1576.909904] CPU: 0 PID: 3281 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1576.919013] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1576.924653] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1576.931595] pc : free_contig_range+0xa4/0xc0
[ 1576.935850] lr : free_contig_range+0xa4/0xc0
[ 1576.940105] sp : ffff8000094d3a90
[ 1576.943405] x29: ffff8000094d3a90 x28: 0000000000000204 x27: 0000000000000000
[ 1576.950522] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1576.957639] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efd23
[ 1576.964758] x20: 0000000000000023 x19: 00000000009efd23 x18: ffffffffffffffff
[ 1576.971876] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d3777
[ 1576.978994] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000182d
[ 1576.986112] x11: 000000000000080f x10: ffff8000092e56b8 x9 : ffff800009281550
[ 1576.993229] x8 : 00000000fffff80f x7 : ffff8000092d9550 x6 : 000000000000c168
[ 1577.000347] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1577.007464] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1577.014581] Call trace:
[ 1577.017014] free_conma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1577.180067] CPU: 0 PID: 3281 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1577.189176] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1577.194816] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1577.201759] pc : __vunmap+0x78/0x30c
[ 1577.205321] lr : __vunmap+0x78/0x30c
[ 1577.208882] sp : ffff8000094d3ad0
[ 1577.212182] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1577.219300] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1577.226418] x23: 00000009efce0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1577.233536] x20: 0000000000000000 x19: ffff80000c3bd000 x18: ffffffffffffffff
[ 1577.240655] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1577.247773] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000018a2
[ 1577.254891] x11: 0000000000000836 x10: ffff8000092e5a60 x9 : ffff800009281550
[ 1577.262009] x8 : 00000000fffff836 x7 : ffff8000092d9550 x6 : 000000000000c510
[ 1577.269126] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1577.276243] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1577.283361] Call trace:
[ 1577.285795] __vunmap+0x78/0x30c
[ 1577.289010] vunmap+0x40/0x5c
[ 1577.291965] dma_direct_free+0x10c/0x110
[ 1577.295873] dma_free_attrs+0x98/0xe0
[ 1577.299521] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1577.304823] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1577.309691] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1577.314991] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1577.319945] v4l2_release+0xbc/0xf0 [videodev]
[ 1577.324395] __fput+0x70/0x250
[ 1577.327438] ____fput+0x10/0x20
[ 1577.330568] task_work_run+0x80/0xe0
[ 1577.334129] do_notify_resume+0x208/0x1280
[ 1577.33821a2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1577.441966] CPU: 0 PID: 3281 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1577.451075] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1577.456716] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1577.463658] pc : free_contig_range+0xa4/0xc0
[ 1577.467913] lr : free_contig_range+0xa4/0xc0
[ 1577.472168] sp : ffff8000094d3a90
[ 1577.475468] x29: ffff8000094d3a90 x28: 0000000000000204 x27: 0000000000000000
[ 1577.482586] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1577.489704] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efcf2
[ 1577.496822] x20: 0000000000000012 x19: 00000000009efcf2 x18: ffffffffffffffff
[ 1577.503939] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d3777
[ 1577.511056] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001914
[ 1577.518174] x11: 000000000000085c x10: ffff8000092e5df0 x9 : ffff800009281550
[ 1577.525293] x8 : 00000000fffff85c x7 : ffff8000092d9550 x6 : 000000000000c8a0
[ 1577.532411] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1577.539528] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1577.546645] Call trace:
[ 1577.549077] free_contig_range+0xa4/0xc0
[ 1577.552987] cma_release+0x7c/0xd0
[ 1577.556376] dma_free_contiguous+0xa0/0xac
[ 1577.560459] dma_direct_free+0xc0/0x110
[ 1577.564280] dma_free_attrs+0x98/0xe0
[ 1577.567928] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1577.573230] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1577.578097] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1577.583399] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1577.588353] v4l2_release+0xbc/0xf0 [videodev]
[ 1577.592806] __fput+0x70/0x250
[ 1577.595850] ____fput+0x10/0x20
[ 1577.598979] task_work_run+0x80/0xe0
[ 1577.602540] do_notify_resume+0x208/0x1280
[ 1577.606624] el0_svc+0x74/0x84
[ 1577.609666] el0t_64_sync_handler+0xbc/0x140
[ 15rlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1577.786192] CPU: 6 PID: 3284 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1577.795308] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1577.800950] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1577.807893] pc : __vunmap+0x78/0x30c
[ 1577.811456] lr : __vunmap+0x78/0x30c
[ 1577.815018] sp : ffff80000bacbad0
[ 1577.818318] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1577.825438] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1577.832557] x23: 00000009efe80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1577.839675] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1577.846793] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1577.853910] x14: 00000000000001e7 x13: 0000000000000000 x12: 0000000000000000
[ 1577.861029] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bacb980
[ 1577.868147] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1577.875265] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dd7c8
[ 1577.882383] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1577.889501] Call trace:
[ 1577.891936] __vunmap+0x78/0x30c
[ 1577.895152] vunmap+0x40/0x5c
[ 1577.898107] dma_direct_free+0x10c/0x110
[ 1577.902019] dma_free_attrs+0x98/0xe0
[ 1577.905667] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ ci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1578.048262] CPU: 6 PID: 3284 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1578.057373] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1578.063014] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1578.069957] pc : free_contig_range+0xa4/0xc0
[ 1578.074212] lr : free_contig_range+0xa4/0xc0
[ 1578.078467] sp : ffff80000bacba90
[ 1578.081767] x29: ffff80000bacba90 x28: 0000000000000204 x27: 0000000000000000
[ 1578.088886] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1578.096004] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efec1
[ 1578.103123] x20: 0000000000000041 x19: 00000000009efec1 x18: ffffffffffffffff
[ 1578.110240] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb777
[ 1578.117358] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000019fe
[ 1578.124475] x11: 00000000000008aa x10: ffff8000092e6540 x9 : ffff800009281550
[ 1578.131591] x8 : 00000000fffff8aa x7 : ffff8000092d9550 x6 : 000000000000cff0
[ 1578.138709] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1578.145827] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1578.152945] Call trace:
[ 1578.155377] free_contig_range+0xa4/0xc0
[ 1578.159286] cma_release+0x7c/0xd0
[ 1578.162674] dma_free_contiguous+0xa0/0xac
[ 1578.166757] dma_direct_free+0xc0/0x110
[ 1578.170579] dma_free_attrs+0x98/0xe0
[ 1578.174228] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1578.179531] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1578.184485] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1578.189786] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1578.194740] v4l2_release+0xbc/0xf0 [videodev]
[ 1578.199193] __fput+0x70/0x250
[ 1578.202237] ____fput+0x10/0x20
[ 1578.205366] task_work_run+0x80/0xe0
[ 1578.208928] do_notify_resume+0x208/0x1280
[ 1578.213013] el0_svc+0x74/0x84
[ 1578.216056] el0t_64_sync_handler+0xbc/0x140
[ 1578.220312] el0t_64_sync+0x18c/0x190
[ 1578.223960] ---[ end trace 0000000000000000 ]---
[ 1578.000204 x27: 0000000000000000
[ 1578.357741] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1578.364860] x23: 00000009efd40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1578.371979] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1578.379097] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1578.386215] x14: 000000000000004c x13: 0000000000000000 x12: 0000000000000000
[ 1578.393333] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bacb980
[ 1578.400451] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1578.407568] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dd7c8
[ 1578.414687] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1578.421804] Call trace:
[ 1578.424238] __vunmap+0x78/0x30c
[ 1578.427452] vunmap+0x40/0x5c
[ 1578.430407] dma_direct_free+0x10c/0x110
[ 1578.434316] dma_free_attrs+0x98/0xe0
[ 1578.437964] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1578.443268] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1578.448223] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1578.453524] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1578.458479] v4l2_release+0xbc/0xf0 [videodev]
[ 1578.462935] __fput+0x70/0x250
[ 1578.465978] ____fput+0x10/0x20
[ 1578.469108] task_work_run+0x80/0xe0
[ 1578.472671] do_notify_resume+0x208/0x1280
[ 1578.476755] el0_svc+0x74/0x84
[ 1578.479797] el0t_64_sync_handler+0xbc/0x140
[ 1578.484052] el0t_64_sync+0x18c/0x190
[ 1578.487700] ---[ end trace 0000000000000000 ]---
[ 1578.492332] ------------[ cut here ]------------
[ 1578.496944] 33 pages are still in use!
[ 1578.500689] WARNING: CPU: 6 PID: 3284 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1578.508849] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_k8bacb777
[ 1578.649631] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001ae5
[ 1578.656750] x11: 00000000000008f7 x10: ffff8000092e6c78 x9 : ffff800009281550
[ 1578.663869] x8 : 00000000fffff8f7 x7 : ffff8000092d9550 x6 : 000000000000d728
[ 1578.670987] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1578.678105] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1578.685223] Call trace:
[ 1578.687659] free_contig_range+0xa4/0xc0
[ 1578.691568] cma_release+0x7c/0xd0
[ 1578.694959] dma_free_contiguous+0xa0/0xac
[ 1578.699042] dma_direct_free+0xc0/0x110
[ 1578.702865] dma_free_attrs+0x98/0xe0
[ 1578.706514] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1578.711825] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1578.716780] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1578.722081] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1578.727036] v4l2_release+0xbc/0xf0 [videodev]
[ 1578.731490] __fput+0x70/0x250
[ 1578.734534] ____fput+0x10/0x20
[ 1578.737663] task_work_run+0x80/0xe0
[ 1578.741227] do_notify_resume+0x208/0x1280
[ 1578.745313] el0_svc+0x74/0x84
[ 1578.748356] el0t_64_sync_handler+0xbc/0x140
[ 1578.752611] el0t_64_sync+0x18c/0x190
[ 1578.756261] ---[ end trace 0000000000000000 ]---
[ 1578.760929] ------------[ cut here ]------------
[ 1578.765636] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1578.772008] WARNING: CPU: 1 PID: 3284 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1578.779223] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host x0 : ffff0008aae15580
[ 1578.954218] Call trace:
[ 1578.956655] __vunmap+0x78/0x30c
[ 1578.959871] vunmap+0x40/0x5c
[ 1578.962826] dma_direct_free+0x10c/0x110
[ 1578.966737] dma_free_attrs+0x98/0xe0
[ 1578.970386] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1578.975694] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1578.980649] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1578.985951] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1578.990904] v4l2_release+0xbc/0xf0 [videodev]
[ 1578.995358] __fput+0x70/0x250
[ 1578.998401] ____fput+0x10/0x20
[ 1579.001531] task_work_run+0x80/0xe0
[ 1579.005094] do_notify_resume+0x208/0x1280
[ 1579.009180] el0_svc+0x74/0x84
[ 1579.012223] el0t_64_sync_handler+0xbc/0x140
[ 1579.016479] el0t_64_sync+0x18c/0x190
[ 1579.020129] ---[ end trace 0000000000000000 ]---
[ 1579.024757] ------------[ cut here ]------------
[ 1579.029365] 35 pages are still in use!
[ 1579.033113] WARNING: CPU: 1 PID: 3284 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1579.041273] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1579.112951] CPU: 1 PID: 3284 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1579.122060] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1579.127700] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1579.134643] pc : free_contig_range+0xa4/0xc0
[ 1579.138898] lr : free_contig_range+0xa4/0xc0
[ 1579.143154] sp : fff.273619] do_notify_resume+0x208/0x1280
[ 1579.277703] el0_svc+0x74/0x84
[ 1579.280749] el0t_64_sync_handler+0xbc/0x140
[ 1579.285005] el0t_64_sync+0x18c/0x190
[ 1579.288653] ---[ end trace 0000000000000000 ]---
[ 1579.293278] ------------[ cut here ]------------
[ 1579.297886] Trying to vfree() nonexistent vm area (00000000b51279e6)
[ 1579.304232] WARNING: CPU: 1 PID: 3284 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1579.311438] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1579.383113] CPU: 1 PID: 3284 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1579.392222] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1579.397862] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1579.404805] pc : __vunmap+0x78/0x30c
[ 1579.408366] lr : __vunmap+0x78/0x30c
[ 1579.411928] sp : ffff80000bacbad0
[ 1579.415228] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1579.422345] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1579.429462] x23: 00000009efde0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1579.436579] x20: 0000000000000000 x19: ffff80000c3bd000 x18: ffffffffffffffff
[ 1579.443696] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb7b7
[ 1579.450813] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001c41
[ 1579.457930] x11: 000000000000096b x10: ffff8000092e7758 x9 : ffff800009281550
[ 1579.465047] x8 : 000er videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1579.645029] CPU: 1 PID: 3284 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1579.654141] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1579.659782] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1579.666724] pc : free_contig_range+0xa4/0xc0
[ 1579.670981] lr : free_contig_range+0xa4/0xc0
[ 1579.675237] sp : ffff80000bacba90
[ 1579.678536] x29: ffff80000bacba90 x28: 0000000000000204 x27: 0000000000000000
[ 1579.685655] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1579.692772] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efdf2
[ 1579.699889] x20: 0000000000000012 x19: 00000000009efdf2 x18: ffffffffffffffff
[ 1579.707006] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb777
[ 1579.714124] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001cb3
[ 1579.721241] x11: 0000000000000991 x10: ffff8000092e7ae8 x9 : ffff800009281550
[ 1579.728358] x8 : 00000000fffff991 x7 : ffff8000092d9550 x6 : 000000000000e598
[ 1579.735475] x5 : ffff000f5c37cb60 x4 : ffff000f5c37cb60 x3 : ffff000f5c37fda0
[ 1579.742593] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1579.749710] Call trace:
[ 1579.752143] free_contig_range+0xa4/0xc0
[ 1579.756051] cma_release+0x7c/0xd0
[ 1579.759440] dma_free_contiguous+0xa0/0xac
[ 1579.763524] dma_direct_free+0xc0/0x110
[ 1579.767346] dma_free_attrs+0x98/0xe0
[ 1579.770994] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1579.776296] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1579.781164] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1579.786465] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1579.791420] v4l2_release+0xbc/0xf0 [videodev]
[ 1579.795872] __fput+0x70/0x250
[ 1579.798914] ____fput+0x10/0x20
[ 1579.802043] task_work_run+0x80uetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1579.990693] CPU: 2 PID: 3287 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1579.999809] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1580.005451] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1580.012394] pc : __vunmap+0x78/0x30c
[ 1580.015957] lr : __vunmap+0x78/0x30c
[ 1580.019519] sp : ffff80000beabad0
[ 1580.022820] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1580.029938] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1580.037055] x23: 00000009eff80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1580.044173] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1580.051291] x17: 0000000000000000 x16: 0000000000000000 x15: 0000893fa13fa15a
[ 1580.058408] x14: 0000000000000023 x13: 0000000000000023 x12: 0000000000000000
[ 1580.065525] x11: 0000000000000001 x10: 00000000000009b0 x9 : ffff80000beab980
[ 1580.072642] x8 : ffff0008aae15150 x7 : ffff000f5c396340 x6 : 0000000000000000
[ 1580.079758] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a2698748
[ 1580.086875] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1580.093992] Call trace:
[ 1580.096427] __vunmap+0x78/0x30c
[ 1580.099642] vunmap+0x40/0x5c
[ 1580.102598] dma_direct_free+0x10c/0x110
[ 1580.106509] dma_free_attrs+0x98/0xe0
[ 1580.110158] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1580.115471] wave5_vpu_enc_close+0x12y ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1580.252782] CPU: 2 PID: 3287 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1580.261893] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1580.267534] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1580.274476] pc : free_contig_range+0xa4/0xc0
[ 1580.278732] lr : free_contig_range+0xa4/0xc0
[ 1580.282987] sp : ffff80000beaba90
[ 1580.286287] x29: ffff80000beaba90 x28: 0000000000000204 x27: 0000000000000000
[ 1580.293406] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1580.300522] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009effc1
[ 1580.307641] x20: 0000000000000041 x19: 00000000009effc1 x18: ffffffffffffffff
[ 1580.314759] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab777
[ 1580.321877] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001d9d
[ 1580.328995] x11: 00000000000009df x10: ffff8000092e8238 x9 : ffff800009281550
[ 1580.336112] x8 : 00000000fffff9df x7 : ffff8000092d9550 x6 : 000000000000ece8
[ 1580.343230] x5 : ffff000f5c38fb60 x4 : ffff000f5c38fb60 x3 : ffff000f5c392da0
[ 1580.350348] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1580.357466] Call trace:
[ 1580.359899] free_contig_range+0xa4/0xc0
[ 1580.363808] cma_release+0x7c/0xd0
[ 1580.367197] dma_free_contiguous+0xa0/0xac
[ 1580.371280] dma_direct_free+0xc0/0x110
[ 1580.375102] dma_free_attrs+0x98/0xe0
[ 1580.378750] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1580.384054] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1580.389009] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1580.394311] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1580.399265] v4l2_release+0xbc/0xf0 [videodev]
[ 1580.403719] __fput+0x70/0x250
[ 1580.406761] ____fput+0x10/0x20
[ 1580.409891] task_work_run+0x80/0xe0
[ 1580.413453] do_notify_resume+0x208/0x1280
[ 1580.417537] el0_svc+0x74/0x84
[ 1580.420579] el0t_64_sync_handler+0xbc/0x140
[ 1580.424835] el0t_64_sync+0x18c/0x190
[ 1580ci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1580.522994] CPU: 2 PID: 3287 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1580.532105] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1580.537747] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1580.544690] pc : __vunmap+0x78/0x30c
[ 1580.548252] lr : __vunmap+0x78/0x30c
[ 1580.551813] sp : ffff80000beabad0
[ 1580.555113] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1580.562232] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1580.569350] x23: 00000009efe40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1580.576467] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1580.583585] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1580.590703] x14: 0000000000000282 x13: 0000000000000000 x12: 0000000000000000
[ 1580.597820] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000beab980
[ 1580.604936] x8 : ffff0008aae15150 x7 : ffff000f5c396340 x6 : 0000000000000000
[ 1580.612053] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a2698748
[ 1580.619171] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1580.626289] Call trace:
[ 1580.628723] __vunmap+0x78/0x30c
[ 1580.631937] vunmap+0x40/0x5c
[ 1580.634892] dma_direct_free+0x10c/0x110
[ 1580.638801] dma_free_attrs+0x98/0xe0
[ 1580.642449] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1580.647751] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1580.652706] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1580.658007] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1580.662961] v4l2_release+0xbc/0xf0 [videodev]
[ 1580.667415] __fput+0x70/0x250
[ 1580.670459] ____fput+0x10/0x20
[ 1580.673588] task_work_run+0x80/0xe0
[ 1580.677150] do_notify_resume+0x208/0x1280
[ 1580.681234] el0_svc+0x74/0x84
[ 1580.684275] el0t_64_sync_handler+0xbc/0x140
[ 1580.688530] el0t_64_sync+0x18c/0x190
[ 1580.692177] ---[ end trace 0000000000000000 ]---
[ 1580.696800] ------------[ cut here ]------------
[ 1580.701410] 33 pages are st B W O 6.1.33-g8f7f371be2 #1
[ 1580.794099] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1580.799744] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1580.806688] pc : free_contig_range+0xa4/0xc0
[ 1580.810945] lr : free_contig_range+0xa4/0xc0
[ 1580.815200] sp : ffff80000beaba90
[ 1580.818500] x29: ffff80000beaba90 x28: 0000000000000204 x27: 0000000000000000
[ 1580.825618] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1580.832735] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efe61
[ 1580.839852] x20: 0000000000000021 x19: 00000000009efe61 x18: ffffffffffffffff
[ 1580.846969] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab777
[ 1580.854086] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001e84
[ 1580.861203] x11: 0000000000000a2c x10: ffff8000092e8970 x9 : ffff800009281550
[ 1580.868320] x8 : 00000000fffffa2c x7 : ffff8000092d9550 x6 : 000000000000f420
[ 1580.875438] x5 : ffff000f5c38fb60 x4 : ffff000f5c38fb60 x3 : ffff000f5c392da0
[ 1580.882555] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1580.889671] Call trace:
[ 1580.892105] free_contig_range+0xa4/0xc0
[ 1580.896013] cma_release+0x7c/0xd0
[ 1580.899400] dma_free_contiguous+0xa0/0xac
[ 1580.903483] dma_direct_free+0xc0/0x110
[ 1580.907306] dma_free_attrs+0x98/0xe0
[ 1580.910955] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1580.916257] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1580.921213] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1580.926514] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1580.931468] v4l2_release+0xbc/0xf0 [videodev]
[ 1580.935922] __fput+0x70/0x250
[ 1580.938966] ____fput+0x10/0x20
[ 1580.942095] task_work_run+0x80/0xe0
[ 1580.945656] do_notify_resume+0x208/0x1280
[ 1580.949740] el0_svc+0x74/0x84
[ 1580.952781] el0t_64_sync_handler+0xbc/0x140
[ 1580.957035] el0t_64_sync+0x18c/0x190
[ 1580.960684] ---[ end trace 0000000000000000 ]---
[ 1580.965300] ------------[ cut here ]------------
[ 1580.969910] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1580.976257] WARNING: CPU: 2 PID: 3287 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1580truments J784S4 EVM (DT)
[ 1581.069887] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1581.076832] pc : __vunmap+0x78/0x30c
[ 1581.080394] lr : __vunmap+0x78/0x30c
[ 1581.083956] sp : ffff80000beabad0
[ 1581.087256] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1581.094374] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1581.101491] x23: 00000009eff00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1581.108608] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1581.115725] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1581.122842] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001ef9
[ 1581.129959] x11: 0000000000000a53 x10: ffff8000092e8d18 x9 : ffff800009281550
[ 1581.137077] x8 : 00000000fffffa53 x7 : ffff8000092d9550 x6 : 000000000000f7c8
[ 1581.144194] x5 : ffff000f5c38fb60 x4 : ffff000f5c38fb60 x3 : ffff000f5c392da0
[ 1581.151311] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1581.158428] Call trace:
[ 1581.160860] __vunmap+0x78/0x30c
[ 1581.164075] vunmap+0x40/0x5c
[ 1581.167030] dma_direct_free+0x10c/0x110
[ 1581.170939] dma_free_attrs+0x98/0xe0
[ 1581.174588] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1581.179891] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1581.184845] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1581.190146] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1581.195101] v4l2_release+0xbc/0xf0 [videodev]
[ 1581.199553] __fput+0x70/0x250
[ 1581.202595] ____fput+0x10/0x20
[ 1581.205724] task_work_run+0x80/0xe0
[ 1581.209286] do_notify_resume+0x208/0x1280
[ 1581.213369] el0_svc+0x74/0x84
[ 1581.216411] el0t_64_sync_handler+0xbc/0x140
[ 1581.220666] el0t_64_sync+0x18c/0x190
[ 1581.224315] ---[ end trace 0000000000000000 ]---
[ 1581.228943] ------------[ cut here ]------------
[ 1581.233551] 35 pages are still in use!
[ 1581.237298] WARNING: CPU: 2 PID: 3287 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1581.245458] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc 0000000000000
[ 1581.364874] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009eff23
[ 1581.371992] x20: 0000000000000023 x19: 00000000009eff23 x18: ffffffffffffffff
[ 1581.379110] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab777
[ 1581.386226] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001f6b
[ 1581.393344] x11: 0000000000000a79 x10: ffff8000092e90a8 x9 : ffff800009281550
[ 1581.400461] x8 : 00000000fffffa79 x7 : ffff8000092d9550 x6 : 000000000000fb58
[ 1581.407578] x5 : ffff000f5c38fb60 x4 : ffff000f5c38fb60 x3 : ffff000f5c392da0
[ 1581.414695] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1581.421812] Call trace:
[ 1581.424245] free_contig_range+0xa4/0xc0
[ 1581.428153] cma_release+0x7c/0xd0
[ 1581.431542] dma_free_contiguous+0xa0/0xac
[ 1581.435624] dma_direct_free+0xc0/0x110
[ 1581.439446] dma_free_attrs+0x98/0xe0
[ 1581.443095] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1581.448398] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1581.453353] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1581.458654] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1581.463608] v4l2_release+0xbc/0xf0 [videodev]
[ 1581.468063] __fput+0x70/0x250
[ 1581.471106] ____fput+0x10/0x20
[ 1581.474235] task_work_run+0x80/0xe0
[ 1581.477798] do_notify_resume+0x208/0x1280
[ 1581.481882] el0_svc+0x74/0x84
[ 1581.484924] el0t_64_sync_handler+0xbc/0x140
[ 1581.489179] el0t_64_sync+0x18c/0x190
[ 1581.492828] ---[ end trace 0000000000000000 ]---
[ 1581.497444] ------------[ cut here ]------------
[ 1581.502052] Trying to vfree() nonexistent vm area (00000000b51279e6)
[ 1581.508400] WARNING: CPU: 2 PID: 3287 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1581.515604] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_rem33] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1581.716900] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1581.722203] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1581.727159] v4l2_release+0xbc/0xf0 [videodev]
[ 1581.731611] __fput+0x70/0x250
[ 1581.734653] ____fput+0x10/0x20
[ 1581.737782] task_work_run+0x80/0xe0
[ 1581.741345] do_notify_resume+0x208/0x1280
[ 1581.745429] el0_svc+0x74/0x84
[ 1581.748470] el0t_64_sync_handler+0xbc/0x140
[ 1581.752726] el0t_64_sync+0x18c/0x190
[ 1581.756374] ---[ end trace 0000000000000000 ]---
[ 1581.760991] ------------[ cut here ]------------
[ 1581.765598] 18 pages are still in use!
[ 1581.769342] WARNING: CPU: 2 PID: 3287 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1581.777501] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1581.849175] CPU: 2 PID: 3287 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1581.858283] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1581.863923] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1581.870865] pc : free_contig_range+0xa4/0xc0
[ 1581.875121] lr : free_contig_range+0xa4/0xc0
[ 1581.879377] sp : ffff80000beaba90
[ 1581.882677] x29: ffff80000beaba90 x28: 0000000000000204 x27: 0000000000000000
[ 1581.889794] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1581.896911] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009efef2
[ 1581.904028] x20: 000000000000582.112505] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -12
[ 1582.122851] ------------[ cut here ]------------
[ 1582.127538] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1582.133927] WARNING: CPU: 6 PID: 3290 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1582.141141] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1582.212845] CPU: 6 PID: 3290 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1582.221955] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1582.227596] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1582.234539] pc : __vunmap+0x78/0x30c
[ 1582.238101] lr : __vunmap+0x78/0x30c
[ 1582.241663] sp : ffff80000bacbad0
[ 1582.244963] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1582.252083] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1582.259201] x23: 000000092d800000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1582.266320] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1582.273438] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1582.280557] x14: 0000000000000079 x13: 0000000000000000 x12: 0000000000000000
[ 1582.287675] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bacb980
[ 1582.294793] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1582.301911] x5 : 00000000410fd080 x4 : 00084
[ 1582.374157] el0t_64_sync_handler+0xbc/0x140
[ 1582.378413] el0t_64_sync+0x18c/0x190
[ 1582.382066] ---[ end trace 0000000000000000 ]---
[ 1582.386725] ------------[ cut here ]------------
[ 1582.391341] Trying to vfree() nonexistent vm area (000000009c81bd07)
[ 1582.397732] WARNING: CPU: 6 PID: 3290 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1582.404939] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1582.476620] CPU: 6 PID: 3290 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1582.485729] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1582.491369] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1582.498312] pc : __vunmap+0x78/0x30c
[ 1582.501873] lr : __vunmap+0x78/0x30c
[ 1582.505435] sp : ffff80000bacbad0
[ 1582.508734] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1582.515853] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1582.522970] x23: 00000009eff40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1582.530087] x20: 0000000000000000 x19: ffff80000c356000 x18: ffffffffffffffff
[ 1582.537205] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1582.544322] x14: 00000000000002a6 x13: 0000000000000000 x12: 0000000000000000
[ 1582.551439] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bacb980
[ 1582.558556] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1582.56567382] WARNING: CPU: 6 PID: 3290 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1582.666942] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1582.738618] CPU: 6 PID: 3290 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1582.747728] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1582.753369] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1582.760310] pc : free_contig_range+0xa4/0xc0
[ 1582.764565] lr : free_contig_range+0xa4/0xc0
[ 1582.768820] sp : ffff80000bacba90
[ 1582.772121] x29: ffff80000bacba90 x28: 0000000000000204 x27: 0000000000000000
[ 1582.779237] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1582.786354] x23: ffff800008fcb348 x22: fffffc0000000000 x21: 00000000009eff61
[ 1582.793472] x20: 0000000000000021 x19: 00000000009eff61 x18: ffffffffffffffff
[ 1582.800590] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb777
[ 1582.807707] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000021b4
[ 1582.814825] x11: 0000000000000b3c x10: ffff8000092ea2f0 x9 : ffff800009281550
[ 1582.821943] x8 : 00000000fffffb3c x7 : ffff8000092d9550 x6 : 0000000000010da0
[ 1582.829061] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1582.836179] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1582.843297] Call trace:
[ 1582.845730] free_contig_range+0xa4/0xc0
[ 1582.849639] cma_release+0x7c/077] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1583.023518] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1583.030462] pc : __vunmap+0x78/0x30c
[ 1583.034024] lr : __vunmap+0x78/0x30c
[ 1583.037586] sp : ffff80000bacbad0
[ 1583.040886] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1583.048004] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1583.055121] x23: 000000092d980000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1583.062238] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1583.069355] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb7b7
[ 1583.076473] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002229
[ 1583.083590] x11: 0000000000000b63 x10: ffff8000092ea698 x9 : ffff800009281550
[ 1583.090708] x8 : 00000000fffffb63 x7 : ffff8000092d9550 x6 : 0000000000011148
[ 1583.097824] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1583.104941] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1583.112058] Call trace:
[ 1583.114491] __vunmap+0x78/0x30c
[ 1583.117707] vunmap+0x40/0x5c
[ 1583.120662] dma_direct_free+0x10c/0x110
[ 1583.124570] dma_free_attrs+0x98/0xe0
[ 1583.128219] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1583.133522] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1583.138476] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1583.143777] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1583.148731] v4l2_release+0xbc/0xf0 [videodev]
[ 1583.153182] __fput+0x70/0x250
[ 1583.156226] ____fput+0x10/0x20
[ 1583.159355] task_work_run+0x80/0xe0
[ 1583.162917] do_notify_resume+0x208/0x1280
[ 1583.167000] el0_svc+0x74/0x84
[ 1583.170042] el0t_64_sync_handler+0xbc/0x140
[ 1583.174297] el0t_64_sync+0x18c/0x190
[ 1583.177946] ---[ end trace 0000000000000000 ]---
[ 1583.182578] ------------[ cut here ]------------
[ 1583.187185] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1583.193530] WARNING: CPU: 6 PID: 3290 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1583.200735] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rp] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1583.368592] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1583.375710] Call trace:
[ 1583.378143] __vunmap+0x78/0x30c
[ 1583.381358] vunmap+0x40/0x5c
[ 1583.384313] dma_direct_free+0x10c/0x110
[ 1583.388222] dma_free_attrs+0x98/0xe0
[ 1583.391870] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1583.397172] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1583.402040] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1583.407341] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1583.412296] v4l2_release+0xbc/0xf0 [videodev]
[ 1583.416748] __fput+0x70/0x250
[ 1583.419790] ____fput+0x10/0x20
[ 1583.422919] task_work_run+0x80/0xe0
[ 1583.426482] do_notify_resume+0x208/0x1280
[ 1583.430566] el0_svc+0x74/0x84
[ 1583.433607] el0t_64_sync_handler+0xbc/0x140
[ 1583.437862] el0t_64_sync+0x18c/0x190
[ 1583.441511] ---[ end trace 0000000000000000 ]---
[ 1583.446130] ------------[ cut here ]------------
[ 1583.450735] 18 pages are still in use!
[ 1583.454478] WARNING: CPU: 6 PID: 3290 at mm/page_alloc.c:9521 free_contig_range+0xa4/0xc0
[ 1583.462637] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1583.534314] CPU: 6 PID: 3290 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1583.543422] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1583.549062] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--0 x3 : ffff000f5c3deda0
[ 1583.631876] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1583.638994] Call trace:
[ 1583.641428] free_contig_range+0xa4/0xc0
[ 1583.645337] cma_release+0x7c/0xd0
[ 1583.648726] dma_free_contiguous+0xa0/0xac
[ 1583.652809] dma_direct_free+0xc0/0x110
[ 1583.656630] dma_free_attrs+0x98/0xe0
[ 1583.660278] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1583.665581] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1583.670448] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1583.675750] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1583.680703] v4l2_release+0xbc/0xf0 [videodev]
[ 1583.685154] __fput+0x70/0x250
[ 1583.688197] ____fput+0x10/0x20
[ 1583.691326] task_work_run+0x80/0xe0
[ 1583.694888] do_notify_resume+0x208/0x1280
[ 1583.698972] el0_svc+0x74/0x84
[ 1583.702013] el0t_64_sync_handler+0xbc/0x140
[ 1583.706269] el0t_64_sync+0x18c/0x190
[ 1583.709917] ---[ end trace 0000000000000000 ]---
[ 1583.775440] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1583.785526] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1583.796744] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1583.806310] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1583.815524] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1583.825917] ------------[ cut here ]------------
[ 1583.830536] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1583.836901] WARNING: CPU: 7 PID: 3293 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1583.844114] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1583.915815] CPU: 7 PID: 3293 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1583.924932] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1583.930575] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1583.937517] pc : __vunmap+0x78/0x30c
[ 1583.941080] lr : __vunmap+0x78/0x30c
[ 1583.944643] sp : ffff80000c33bad0
[ 1583.947943] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1583.955061] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1583.962179] x23: 000000092dd00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1583.969297] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1583.976414] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1583.983532] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002391
[ 1583.990650] x11: 0000000000000bdb x10: ffff8000092eb1d8 x9 : ffff800009281550
[ 1583.997769] x8 : 00000000fffffbdb x7 : ffff8000092d9550 x6 : 0000000000011c88
[ 1584.004886] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1584.012004] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1584.019123] Call trace:
[ 1584.021557] __vunmap+0x78/0x30c
[ 1584.024771] vunmap+0x40/0x5c
[ 1584.027727] dma_direct_free+0x10c/0x110
[ 1584.031638] dma_free_attrs+0x98/0xe0
[ 1584.035286] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1584.040596] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1584.045551] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1584.050852] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1584.055806] v4l2_release+0xbc/0xf0 [videodev]
[ 1584.060261] __fput+0x70/0x250
[ 1584.063305] ____fput+0x10/0x20
[ 1584.066435] task_work_run+0x80/0xe0
[ 1584.069999] do_notify_resume+0x208/0x1280
[ 1584.074083] el0_svc+0x74/0x84
[ 1584.077126] el0t_64_sync_handler+0xbc/0x140
[ 15584.201267] pc : __vunmap+0x78/0x30c
[ 1584.204829] lr : __vunmap+0x78/0x30c
[ 1584.208395] sp : ffff80000c33bad0
[ 1584.211696] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1584.218814] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1584.225931] x23: 000000092d840000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1584.233050] x20: 0000000000000000 x19: ffff80000c35e000 x18: ffffffffffffffff
[ 1584.240167] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1584.247284] x14: 00000000000003f0 x13: 0000000000000000 x12: 0000000000000000
[ 1584.254402] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c33b980
[ 1584.261520] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1584.268637] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a050c8
[ 1584.275754] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1584.282872] Call trace:
[ 1584.285304] __vunmap+0x78/0x30c
[ 1584.288519] vunmap+0x40/0x5c
[ 1584.291474] dma_direct_free+0x10c/0x110
[ 1584.295383] dma_free_attrs+0x98/0xe0
[ 1584.299032] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1584.304335] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1584.309290] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1584.314591] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1584.319545] v4l2_release+0xbc/0xf0 [videodev]
[ 1584.323999] __fput+0x70/0x250
[ 1584.327041] ____fput+0x10/0x20
[ 1584.330171] task_work_run+0x80/0xe0
[ 1584.333734] do_notify_resume+0x208/0x1280
[ 1584.337818] el0_svc+0x74/0x84
[ 1584.340861] el0t_64_sync_handler+0xbc/0x140
[ 1584.345117] el0t_64_sync+0x18c/0x190
[ 1584.348766] ---[ end trace 0000000000000000 ]---
[ 1584.353416] ------------[ cut here ]------------
[ 1584.358034] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1584.364388] WARNING: CPU: 0 PID: 3293 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1584.371598] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem 8/0x30c
[ 1584.468543] lr : __vunmap+0x78/0x30c
[ 1584.472105] sp : ffff80000c33bad0
[ 1584.475405] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1584.482524] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1584.489642] x23: 000000092d7c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1584.496760] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1584.503877] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1584.510995] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002475
[ 1584.518114] x11: 0000000000000c27 x10: ffff8000092eb8f8 x9 : ffff800009281550
[ 1584.525231] x8 : 00000000fffffc27 x7 : ffff8000092d9550 x6 : 00000000000123a8
[ 1584.532349] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1584.539466] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1584.546584] Call trace:
[ 1584.549018] __vunmap+0x78/0x30c
[ 1584.552233] vunmap+0x40/0x5c
[ 1584.555188] dma_direct_free+0x10c/0x110
[ 1584.559098] dma_free_attrs+0x98/0xe0
[ 1584.562746] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1584.568053] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1584.573009] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1584.578311] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1584.583265] v4l2_release+0xbc/0xf0 [videodev]
[ 1584.587717] __fput+0x70/0x250
[ 1584.590762] ____fput+0x10/0x20
[ 1584.593891] task_work_run+0x80/0xe0
[ 1584.597453] do_notify_resume+0x208/0x1280
[ 1584.601539] el0_svc+0x74/0x84
[ 1584.604582] el0t_64_sync_handler+0xbc/0x140
[ 1584.608837] el0t_64_sync+0x18c/0x190
[ 1584.612487] ---[ end trace 0000000000000000 ]---
[ 1584.617121] ------------[ cut here ]------------
[ 1584.621731] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1584.628076] WARNING: CPU: 0 PID: 3293 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1584.635282] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65 0000000000000000
[ 1584.760426] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1584.767543] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1584.774661] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000024e7
[ 1584.781779] x11: 0000000000000c4d x10: ffff8000092ebc88 x9 : ffff800009281550
[ 1584.788897] x8 : 00000000fffffc4d x7 : ffff8000092d9550 x6 : 0000000000012738
[ 1584.796014] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1584.803132] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1584.810249] Call trace:
[ 1584.812682] __vunmap+0x78/0x30c
[ 1584.815896] vunmap+0x40/0x5c
[ 1584.818852] dma_direct_free+0x10c/0x110
[ 1584.822760] dma_free_attrs+0x98/0xe0
[ 1584.826408] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1584.831710] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1584.836578] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1584.841879] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1584.846833] v4l2_release+0xbc/0xf0 [videodev]
[ 1584.851284] __fput+0x70/0x250
[ 1584.854327] ____fput+0x10/0x20
[ 1584.857456] task_work_run+0x80/0xe0
[ 1584.861018] do_notify_resume+0x208/0x1280
[ 1584.865101] el0_svc+0x74/0x84
[ 1584.868142] el0t_64_sync_handler+0xbc/0x140
[ 1584.872397] el0t_64_sync+0x18c/0x190
[ 1584.876046] ---[ end trace 0000000000000000 ]---
[ 1584.942447] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1584.952638] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1584.963647] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1584.973241] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1584.982472] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1584.992876] ------------[ cut here ]------------
[ 1584.997497] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1585.003856] WARNING: CPU: 7 PID: 3296 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1585.011071] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rf8f7f371be2 #1
[ 1585.091888] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1585.097533] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1585.104476] pc : __vunmap+0x78/0x30c
[ 1585.108039] lr : __vunmap+0x78/0x30c
[ 1585.111601] sp : ffff80000baebad0
[ 1585.114901] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1585.122020] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1585.129139] x23: 0000000933200000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1585.136256] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1585.143374] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1585.150492] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002568
[ 1585.157609] x11: 0000000000000c78 x10: ffff8000092ec090 x9 : ffff800009281550
[ 1585.164727] x8 : 00000000fffffc78 x7 : ffff8000092d9550 x6 : 0000000000012b40
[ 1585.171845] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1585.178962] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1585.186080] Call trace:
[ 1585.188515] __vunmap+0x78/0x30c
[ 1585.191729] vunmap+0x40/0x5c
[ 1585.194685] dma_direct_free+0x10c/0x110
[ 1585.198595] dma_free_attrs+0x98/0xe0
[ 1585.202245] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1585.207557] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1585.212513] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1585.217816] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1585.222770] v4l2_release+0xbc/0xf0 [videodev]
[ 1585.227227] __fput+0x70/0x250
[ 1585.230272] ____fput+0x10/0x20
[ 1585.233401] task_work_run+0x80/0xe0
[ 1585.236966] do_notify_resume+0x208/0x1280
[ 1585.241052] el0_svc+0x74/0x84
[ 1585.244095] el0t_64_sync_handler+0xbc/0x140
[ 1585.248350] el0t_64_sync+0x18c/0x190
[ 1585.251999] ---[ end trace 0000000000000000 ]---
[ 1585.256628] ------------[ cut here ]------------
[ 1585.261250] Trying to vfree() nonexistent vm area (00000000b84bacf7)
[ 1585.267598] WARNING: CPU: 7 PID: 3296 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1585.274804] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill) fuse drm drm_panel_orientation_quirks ipv6
[ 1585.346482] CPU: 7 PID: 3296 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1585.355592] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1585.361233] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1585.368176] pc : __vunmap+0x78/0x30c
[ 1585.371738] lr : __vunmap+0x78/0x30c
[ 1585.375298] sp : ffff80000baebad0
[ 1585.378599] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1585.385718] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1585.392835] x23: 000000092dd40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1585.399953] x20: 0000000000000000 x19: ffff80000c35e000 x18: ffffffffffffffff
[ 1585.407071] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1585.414189] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000025da
[ 1585.421307] x11: 0000000000000c9e x10: ffff8000092ec420 x9 : ffff800009281550
[ 1585.428426] x8 : 00000000fffffc9e x7 : ffff8000092d9550 x6 : 0000000000012ed0
[ 1585.435543] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1585.442660] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1585.449777] Call trace:
[ 1585.452210] __vunmap+0x78/0x30c
[ 1585.455424] vunmap+0x40/0x5c
[ 1585.458379] dma_direct_free+0x10c/0x110
[ 1585.462289] dma_free_attrs+0x98/0xe0
[ 1585.465937] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1585.471240] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1585.476194] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1585.481496] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1585.486450] v4l2_release+0xbc/0xf0 [videodev]
[ 1585.490904] __fput+0x70/0x250
[ 1585.493947] ____fput+0x10/0x20
[ 1585.497076] task_work_run+0x80/0xe0
[ 1585.500639] do_notify_resume+0x208/0x1280
[ 1585.504722] el0_svc+0x74/0x84
[ 1585.507765] el0t_64_sync_handler+0xbc/0x140
[ 1585.512021] el0t_64_sync+0x18c/0x190
[ 1585.515670] ---[ end trace 0000000000000000 ]---
[ 1585.520296] ------------[ cut here ]------------
[ 1585.524903] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1585.531249] WARNING: CPU: 7 PID: 3296 at mm/vmaame: Texas Instruments J784S4 EVM (DT)
[ 1585.624882] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1585.631827] pc : __vunmap+0x78/0x30c
[ 1585.635389] lr : __vunmap+0x78/0x30c
[ 1585.638950] sp : ffff80000baebad0
[ 1585.642250] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1585.649368] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1585.656485] x23: 000000092dd80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1585.663603] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1585.670720] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1585.677837] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000264c
[ 1585.684955] x11: 0000000000000cc4 x10: ffff8000092ec7b0 x9 : ffff800009281550
[ 1585.692072] x8 : 00000000fffffcc4 x7 : ffff8000092d9550 x6 : 0000000000013260
[ 1585.699191] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1585.706308] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1585.713426] Call trace:
[ 1585.715859] __vunmap+0x78/0x30c
[ 1585.719073] vunmap+0x40/0x5c
[ 1585.722028] dma_direct_free+0x10c/0x110
[ 1585.725937] dma_free_attrs+0x98/0xe0
[ 1585.729586] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1585.734889] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1585.739845] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1585.745146] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1585.750101] v4l2_release+0xbc/0xf0 [videodev]
[ 1585.754555] __fput+0x70/0x250
[ 1585.757598] ____fput+0x10/0x20
[ 1585.760728] task_work_run+0x80/0xe0
[ 1585.764290] do_notify_resume+0x208/0x1280
[ 1585.768375] el0_svc+0x74/0x84
[ 1585.771416] el0t_64_sync_handler+0xbc/0x140
[ 1585.775670] el0t_64_sync+0x18c/0x190
[ 1585.779319] ---[ end trace 0000000000000000 ]---
[ 1585.783941] ------------[ cut here ]------------
[ 1585.788549] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1585.794896] WARNING: CPU: 7 PID: 3296 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1585.802100] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_c x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000026be
[ 1585.948600] x11: 0000000000000cea x10: ffff8000092ecb40 x9 : ffff800009281550
[ 1585.955717] x8 : 00000000fffffcea x7 : ffff8000092d9550 x6 : 00000000000135f0
[ 1585.962834] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1585.969951] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1585.977070] Call trace:
[ 1585.979503] __vunmap+0x78/0x30c
[ 1585.982717] vunmap+0x40/0x5c
[ 1585.985672] dma_direct_free+0x10c/0x110
[ 1585.989581] dma_free_attrs+0x98/0xe0
[ 1585.993230] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1585.998533] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1586.003401] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1586.008702] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1586.013656] v4l2_release+0xbc/0xf0 [videodev]
[ 1586.018109] __fput+0x70/0x250
[ 1586.021153] ____fput+0x10/0x20
[ 1586.024282] task_work_run+0x80/0xe0
[ 1586.027843] do_notify_resume+0x208/0x1280
[ 1586.031928] el0_svc+0x74/0x84
[ 1586.034970] el0t_64_sync_handler+0xbc/0x140
[ 1586.039224] el0t_64_sync+0x18c/0x190
[ 1586.042871] ---[ end trace 0000000000000000 ]---
[ 1586.116092] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1586.126175] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1586.137350] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1586.146912] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1586.156177] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1586.166598] ------------[ cut here ]------------
[ 1586.171216] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1586.177574] WARNING: CPU: 0 PID: 3299 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1586.184789] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_chy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1586.256489] CPU: 0 PID: 3299 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1586.265600] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1586.271241] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1586.278184] pc : __vunmap+0x78/0x30c
[ 1586.281745] lr : __vunmap+0x78/0x30c
[ 1586.285307] sp : ffff80000c363ad0
[ 1586.288608] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1586.295727] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1586.302845] x23: 0000000933280000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1586.309963] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1586.317081] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3637b7
[ 1586.324198] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000273f
[ 1586.331316] x11: 0000000000000d15 x10: ffff8000092ecf48 x9 : ffff800009281550
[ 1586.338433] x8 : 00000000fffffd15 x7 : ffff8000092d9550 x6 : 00000000000139f8
[ 1586.345551] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1586.352667] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1586.359786] Call trace:
[ 1586.362219] __vunmap+0x78/0x30c
[ 1586.365434] vunmap+0x40/0x5c
[ 1586.368390] dma_direct_free+0x10c/0x110
[ 1586.372301] dma_free_attrs+0x98/0xe0
[ 1586.375950] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1586.381263] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1586.386217] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1586.391518] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1586.396472] v4l2_release+0xbc/0xf0 [videodev]
[ 1586.400928] __fput+0x70/0x250
[ 1586.403972] ____fput+0x10/0x20
[ 1586.407102] task_work_run+0x80/0xe0
[ 1586.410666] do_notify_resume+0x208/0x1280
[ 1586.414751] el0_svc+0x74/0x84
[ 1586.417793] el0t_64_sync_handler+0xbc/0x140
[ 1586.422049] el0t_64_sync+0x18c/0x190
[ 1586.425698] ---[ end trace 0000000000000000 ]---
[ 1586.430348] ------------[ cut heremmon cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1586.555831] CPU: 0 PID: 3299 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1586.564942] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1586.570582] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1586.577525] pc : __vunmap+0x78/0x30c
[ 1586.581088] lr : __vunmap+0x78/0x30c
[ 1586.584650] sp : ffff80000c363ad0
[ 1586.587950] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1586.595069] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1586.602187] x23: 0000000933240000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1586.609304] x20: 0000000000000000 x19: ffff80000c365000 x18: ffffffffffffffff
[ 1586.616421] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3637b7
[ 1586.623538] x14: 0000000000000000 x13: 2937613431393561 x12: 3930303030303030
[ 1586.630656] x11: 3028206165726120 x10: 6d7620746e657473 x9 : 6d7620746e657473
[ 1586.637773] x8 : 6978656e6f6e2029 x7 : 205d313839343334 x6 : 342e36383531205b
[ 1586.644891] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1586.652007] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1586.659124] Call trace:
[ 1586.661558] __vunmap+0x78/0x30c
[ 1586.664773] vunmap+0x40/0x5c
[ 1586.667730] dma_direct_free+0x10c/0x110
[ 1586.671640] dma_free_attrs+0x98/0xe0
[ 1586.675289] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1586.680595] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1586.685550] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1586.690851] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1586.695805] v4l2_release+0xbc/0xf0 [videodev]
[ 1586.700259] __fput+0x70/0x250
[ 1586.703303] ____fput+0x10/0x20
[ 1586.706432] task_work_run+0x80/0xe0
[ 1586.709995] do_notify_resume+0x208/0x1280
[ 1586.714079] el0_svc+0x74/0x84
[ 1586.717121] el0t_64_sync_handler+0xbc/0x140
[ 1586.721376] el0t_64_sync+0x18c/0x190
[ 1586.725024] ---[ end trace 0000000000000000 ]---
[ 1586.729672] ------------[ cut here ]-----daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1586.841223] pc : __vunmap+0x78/0x30c
[ 1586.844785] lr : __vunmap+0x78/0x30c
[ 1586.848346] sp : ffff80000c363ad0
[ 1586.851647] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1586.858765] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1586.865883] x23: 000000092ddc0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1586.873001] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1586.880119] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3637b7
[ 1586.887236] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002829
[ 1586.894353] x11: 0000000000000d63 x10: ffff8000092ed698 x9 : ffff800009281550
[ 1586.901471] x8 : 00000000fffffd63 x7 : ffff8000092d9550 x6 : 0000000000014148
[ 1586.908589] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1586.915706] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1586.922824] Call trace:
[ 1586.925257] __vunmap+0x78/0x30c
[ 1586.928473] vunmap+0x40/0x5c
[ 1586.931428] dma_direct_free+0x10c/0x110
[ 1586.935337] dma_free_attrs+0x98/0xe0
[ 1586.938986] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1586.944289] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1586.949243] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1586.954544] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1586.959498] v4l2_release+0xbc/0xf0 [videodev]
[ 1586.963951] __fput+0x70/0x250
[ 1586.966993] ____fput+0x10/0x20
[ 1586.970123] task_work_run+0x80/0xe0
[ 1586.973685] do_notify_resume+0x208/0x1280
[ 1586.977770] el0_svc+0x74/0x84
[ 1586.980811] el0t_64_sync_handler+0xbc/0x140
[ 1586.985066] el0t_64_sync+0x18c/0x190
[ 1586.988715] ---[ end trace 0000000000000000 ]---
[ 1586.993345] ------------[ cut here ]------------
[ 1586.997952] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1587.004298] WARNING: CPU: 0 PID: 3299 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1587.011503] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi200f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1587.179354] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1587.186471] Call trace:
[ 1587.188904] __vunmap+0x78/0x30c
[ 1587.192120] vunmap+0x40/0x5c
[ 1587.195075] dma_direct_free+0x10c/0x110
[ 1587.198984] dma_free_attrs+0x98/0xe0
[ 1587.202632] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1587.207933] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1587.212802] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1587.218103] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1587.223058] v4l2_release+0xbc/0xf0 [videodev]
[ 1587.227511] __fput+0x70/0x250
[ 1587.230553] ____fput+0x10/0x20
[ 1587.233682] task_work_run+0x80/0xe0
[ 1587.237244] do_notify_resume+0x208/0x1280
[ 1587.241328] el0_svc+0x74/0x84
[ 1587.244369] el0t_64_sync_handler+0xbc/0x140
[ 1587.248624] el0t_64_sync+0x18c/0x190
[ 1587.252273] ---[ end trace 0000000000000000 ]---
[ 1587.328729] ------------[ cut here ]------------
[ 1587.333427] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1587.339827] WARNING: CPU: 7 PID: 3303 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1587.347041] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1587.418742] CPU: 7 PID: 3303 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1587.427853] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1587.433494] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS0000000000000000 x24: 0000000000000000
[ 1587.465103] x23: 0000000933380000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1587.472222] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1587.479340] x17: 0000000000000000 x16: 0000000000000000 x15: 0000002400cfb3a3
[ 1587.486458] x14: 0000000000000313 x13: 0000000000000000 x12: 0000000000000000
[ 1587.493575] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000ba8b980
[ 1587.500693] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1587.507810] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a042c8
[ 1587.514928] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1587.522046] Call trace:
[ 1587.524480] __vunmap+0x78/0x30c
[ 1587.527695] vunmap+0x40/0x5c
[ 1587.530651] dma_direct_free+0x10c/0x110
[ 1587.534562] dma_free_attrs+0x98/0xe0
[ 1587.538211] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1587.543524] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1587.548479] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1587.553780] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1587.558735] v4l2_release+0xbc/0xf0 [videodev]
[ 1587.563191] __fput+0x70/0x250
[ 1587.566234] ____fput+0x10/0x20
[ 1587.569364] task_work_run+0x80/0xe0
[ 1587.572928] do_notify_resume+0x208/0x1280
[ 1587.577013] el0_svc+0x74/0x84
[ 1587.580056] el0t_64_sync_handler+0xbc/0x140
[ 1587.584311] el0t_64_sync+0x18c/0x190
[ 1587.587960] ---[ end trace 0000000000000000 ]---
[ 1587.592614] ------------[ cut here ]------------
[ 1587.597231] Trying to vfree() nonexistent vm area (000000009a5914a7)
[ 1587.603628] WARNING: CPU: 7 PID: 3303 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1587.610835] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remotepro18] Call trace:
[ 1587.788252] __vunmap+0x78/0x30c
[ 1587.791471] vunmap+0x40/0x5c
[ 1587.794426] dma_direct_free+0x10c/0x110
[ 1587.798336] dma_free_attrs+0x98/0xe0
[ 1587.801984] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1587.807288] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1587.812243] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1587.817545] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1587.822500] v4l2_release+0xbc/0xf0 [videodev]
[ 1587.826953] __fput+0x70/0x250
[ 1587.829996] ____fput+0x10/0x20
[ 1587.833126] task_work_run+0x80/0xe0
[ 1587.836688] do_notify_resume+0x208/0x1280
[ 1587.840773] el0_svc+0x74/0x84
[ 1587.843814] el0t_64_sync_handler+0xbc/0x140
[ 1587.848069] el0t_64_sync+0x18c/0x190
[ 1587.851718] ---[ end trace 0000000000000000 ]---
[ 1587.856361] ------------[ cut here ]------------
[ 1587.860968] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1587.867313] WARNING: CPU: 7 PID: 3303 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1587.874518] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1587.946195] CPU: 7 PID: 3303 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1587.955304] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1587.960945] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1587.967887] pc : __vunmap+0x78/0x30c
[ 1587.971449] lr : __vunmap+0x78/0x30c
[ 1587.975011] sp : ffff80000ba8bad0
[ 1587.978312] x29: ffffe+0x64/0x18c [wave5]
[ 1588.081207] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1588.086161] v4l2_release+0xbc/0xf0 [videodev]
[ 1588.090615] __fput+0x70/0x250
[ 1588.093658] ____fput+0x10/0x20
[ 1588.096787] task_work_run+0x80/0xe0
[ 1588.100350] do_notify_resume+0x208/0x1280
[ 1588.104433] el0_svc+0x74/0x84
[ 1588.107474] el0t_64_sync_handler+0xbc/0x140
[ 1588.111729] el0t_64_sync+0x18c/0x190
[ 1588.115377] ---[ end trace 0000000000000000 ]---
[ 1588.120002] ------------[ cut here ]------------
[ 1588.124609] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1588.130957] WARNING: CPU: 7 PID: 3303 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1588.138162] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1588.209838] CPU: 7 PID: 3303 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1588.218948] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1588.224589] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1588.231530] pc : __vunmap+0x78/0x30c
[ 1588.235094] lr : __vunmap+0x78/0x30c
[ 1588.238655] sp : ffff80000ba8bad0
[ 1588.241956] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1588.249073] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1588.256190] x23: 000000092dde0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1588.263309] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1588.270426] x17: 000000000000000 x0 : ffff0008aae15580
[ 1588.313133] Call trace:
[ 1588.315567] __vunmap+0x78/0x30c
[ 1588.318782] vunmap+0x40/0x5c
[ 1588.321737] dma_direct_free+0x10c/0x110
[ 1588.325648] dma_free_attrs+0x98/0xe0
[ 1588.329296] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1588.334598] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1588.339467] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1588.344767] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1588.349722] v4l2_release+0xbc/0xf0 [videodev]
[ 1588.354176] __fput+0x70/0x250
[ 1588.357219] ____fput+0x10/0x20
[ 1588.360348] task_work_run+0x80/0xe0
[ 1588.363910] do_notify_resume+0x208/0x1280
[ 1588.367995] el0_svc+0x74/0x84
[ 1588.371037] el0t_64_sync_handler+0xbc/0x140
[ 1588.375291] el0t_64_sync+0x18c/0x190
[ 1588.378940] ---[ end trace 0000000000000000 ]---
[ 1588.449139] ------------[ cut here ]------------
[ 1588.453804] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1588.460167] WARNING: CPU: 6 PID: 3306 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1588.467381] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1588.539086] CPU: 6 PID: 3306 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1588.548197] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1588.553839] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1588.560783] pc : __vunmap+0x78/0x30c
[ 1588.564345] lr : __vunmap+0x78/0x30c
[ 1588.567907fff8000093d6a28 x21: 0000000000000000
[ 1588.592565] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1588.599684] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1588.606803] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002ad5
[ 1588.613921] x11: 0000000000000e47 x10: ffff8000092eebf8 x9 : ffff800009281550
[ 1588.621038] x8 : 00000000fffffe47 x7 : ffff8000092d9550 x6 : 00000000000156a8
[ 1588.628156] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1588.635274] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1588.642393] Call trace:
[ 1588.644826] __vunmap+0x78/0x30c
[ 1588.648041] vunmap+0x40/0x5c
[ 1588.650997] dma_direct_free+0x10c/0x110
[ 1588.654908] dma_free_attrs+0x98/0xe0
[ 1588.658557] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1588.663868] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1588.668824] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1588.674125] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1588.679079] v4l2_release+0xbc/0xf0 [videodev]
[ 1588.683538] __fput+0x70/0x250
[ 1588.686581] ____fput+0x10/0x20
[ 1588.689711] task_work_run+0x80/0xe0
[ 1588.693274] do_notify_resume+0x208/0x1280
[ 1588.697359] el0_svc+0x74/0x84
[ 1588.700402] el0t_64_sync_handler+0xbc/0x140
[ 1588.704658] el0t_64_sync+0x18c/0x190
[ 1588.708308] ---[ end trace 0000000000000000 ]---
[ 1588.712937] ------------[ cut here ]------------
[ 1588.717608] Trying to vfree() nonexistent vm area (000000009a5914a7)
[ 1588.724047] WARNING: CPU: 6 PID: 3306 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1588.731253] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul t88.908665] __vunmap+0x78/0x30c
[ 1588.911880] vunmap+0x40/0x5c
[ 1588.914836] dma_direct_free+0x10c/0x110
[ 1588.918746] dma_free_attrs+0x98/0xe0
[ 1588.922395] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1588.927699] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1588.932653] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1588.937954] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1588.942909] v4l2_release+0xbc/0xf0 [videodev]
[ 1588.947363] __fput+0x70/0x250
[ 1588.950406] ____fput+0x10/0x20
[ 1588.953536] task_work_run+0x80/0xe0
[ 1588.957099] do_notify_resume+0x208/0x1280
[ 1588.961182] el0_svc+0x74/0x84
[ 1588.964223] el0t_64_sync_handler+0xbc/0x140
[ 1588.968478] el0t_64_sync+0x18c/0x190
[ 1588.972126] ---[ end trace 0000000000000000 ]---
[ 1588.976764] ------------[ cut here ]------------
[ 1588.981375] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1588.987721] WARNING: CPU: 6 PID: 3306 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1588.994925] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1589.066603] CPU: 6 PID: 3306 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1589.075712] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1589.081353] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1589.088294] pc : __vunmap+0x78/0x30c
[ 1589.091856] lr : __vunmap+0x78/0x30c
[ 1589.095418] sp : ffff80000c33bad0
[ 1589.098717] x29: ffff80000c33bad0 x28:andler+0xbc/0x140
[ 1589.232135] el0t_64_sync+0x18c/0x190
[ 1589.235784] ---[ end trace 0000000000000000 ]---
[ 1589.240409] ------------[ cut here ]------------
[ 1589.245023] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1589.251418] WARNING: CPU: 6 PID: 3306 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1589.258624] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1589.330303] CPU: 6 PID: 3306 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1589.339412] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1589.345053] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1589.351995] pc : __vunmap+0x78/0x30c
[ 1589.355556] lr : __vunmap+0x78/0x30c
[ 1589.359118] sp : ffff80000c33bad0
[ 1589.362418] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1589.369535] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1589.376653] x23: 0000000933320000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1589.383770] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1589.390887] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1589.398004] x14: 0000000000000145 x13: 0000000000000000 x12: 0000000000000000
[ 1589.405121] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c33b980
[ 1589.412238] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1589.419355] x5 : 00000000410fd080 x4 : 0000000000c00
[ 1589.577156] ------------[ cut here ]------------
[ 1589.581786] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1589.588296] WARNING: CPU: 7 PID: 3309 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1589.595511] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1589.667215] CPU: 7 PID: 3309 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1589.676327] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1589.681968] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1589.688911] pc : __vunmap+0x78/0x30c
[ 1589.692473] lr : __vunmap+0x78/0x30c
[ 1589.696035] sp : ffff8000094d3ad0
[ 1589.699335] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1589.706454] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1589.713572] x23: 0000000938900000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1589.720690] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1589.727807] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1589.734924] x14: 0000000000000281 x13: 0000000000000000 x12: 0000000000000000
[ 1589.742042] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000094d3980
[ 1589.749160] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000008] v4l2_release+0xbc/0xf0 [videodev]
[ 1589.811663] __fput+0x70/0x250
[ 1589.814711] ____fput+0x10/0x20
[ 1589.817840] task_work_run+0x80/0xe0
[ 1589.821403] do_notify_resume+0x208/0x1280
[ 1589.825489] el0_svc+0x74/0x84
[ 1589.828532] el0t_64_sync_handler+0xbc/0x140
[ 1589.832787] el0t_64_sync+0x18c/0x190
[ 1589.836435] ---[ end trace 0000000000000000 ]---
[ 1589.841125] ------------[ cut here ]------------
[ 1589.845738] Trying to vfree() nonexistent vm area (000000009a5914a7)
[ 1589.852092] WARNING: CPU: 7 PID: 3309 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1589.859298] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1589.930979] CPU: 7 PID: 3309 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1589.940089] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1589.945729] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1589.952672] pc : __vunmap+0x78/0x30c
[ 1589.956233] lr : __vunmap+0x78/0x30c
[ 1589.959795] sp : ffff8000094d3ad0
[ 1589.963095] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1589.970214] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1589.977331] x23: 0000000938840000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1589.984450] x20: 0000000000000000 x19: ffff80000c365000 x18: ffffffffffffffff
[ 1589.991567] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1589.998686] x14: 000000000----
[ 1590.109409] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1590.115756] WARNING: CPU: 7 PID: 3309 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1590.122962] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1590.194639] CPU: 7 PID: 3309 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1590.203748] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1590.209388] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1590.216330] pc : __vunmap+0x78/0x30c
[ 1590.219891] lr : __vunmap+0x78/0x30c
[ 1590.223453] sp : ffff8000094d3ad0
[ 1590.226753] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1590.233870] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1590.240987] x23: 0000000938880000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1590.248104] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1590.255222] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1590.262341] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002d81
[ 1590.269458] x11: 0000000000000f2b x10: ffff8000092f0158 x9 : ffff800009281550
[ 1590.276576] x8 : 00000000ffffff2b x7 : ffff8000092d9550 x6 : 0000000000016c08
[ 1590.283694] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1590.290811] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1590.297928] Call trace:
[ 1590.300361] __k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1590.458274] CPU: 7 PID: 3309 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1590.467385] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1590.473026] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1590.479968] pc : __vunmap+0x78/0x30c
[ 1590.483530] lr : __vunmap+0x78/0x30c
[ 1590.487092] sp : ffff8000094d3ad0
[ 1590.490391] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1590.497509] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1590.504626] x23: 0000000933360000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1590.511743] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1590.518860] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1590.525978] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002df3
[ 1590.533096] x11: 0000000000000f51 x10: ffff8000092f04e8 x9 : ffff800009281550
[ 1590.540214] x8 : 00000000ffffff51 x7 : ffff8000092d9550 x6 : 0000000000016f98
[ 1590.547333] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1590.554450] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1590.561568] Call trace:
[ 1590.564001] __vunmap+0x78/0x30c
[ 1590.567215] vunmap+0x40/0x5c
[ 1590.570170] dma_direct_free+0x10c/0x110
[ 1590.574079] dma_free_attrs+0x98/0xe0
[ 1590.577728] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1590.583030] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1590.587898] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1590.593199] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1590.598153] v4l2_release+0xbc/0xf0 [videodev]
[ 1590.602606] __fput+0x70/0x250
[ 1590.605649] ____fput+0x10/0x20
[ 1590.608778] task_work_run+0x80/0xe0
[ 1590.612340] do_notify_resume+0x208/0x1280
[ 1590.616424] el0_svc+0x74/0x84
[ 1590.619466] el0t_64_sync_handler+0xbc/000: alloc failed, req-size: 18 pages, ret: -16
[ 1590.735651] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1590.744871] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1590.755320] ------------[ cut here ]------------
[ 1590.759936] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1590.766297] WARNING: CPU: 0 PID: 3312 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1590.773511] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1590.845217] CPU: 0 PID: 3312 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1590.854329] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1590.859970] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1590.866914] pc : __vunmap+0x78/0x30c
[ 1590.870476] lr : __vunmap+0x78/0x30c
[ 1590.874038] sp : ffff80000c0b3ad0
[ 1590.877338] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1590.884457] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1590.891576] x23: 0000000938980000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1590.898695] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1590.905813] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1590.912931] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002e77
[ 1590.920049] x11: 0000000000000f7d x10: ffff8000092f0908 x18c/0x190
[ 1591.014432] ---[ end trace 0000000000000000 ]---
[ 1591.019091] ------------[ cut here ]------------
[ 1591.023718] Trying to vfree() nonexistent vm area (000000009a5914a7)
[ 1591.030160] WARNING: CPU: 0 PID: 3312 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1591.037367] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1591.109046] CPU: 0 PID: 3312 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1591.118154] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1591.123795] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1591.130737] pc : __vunmap+0x78/0x30c
[ 1591.134300] lr : __vunmap+0x78/0x30c
[ 1591.137860] sp : ffff80000c0b3ad0
[ 1591.141161] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1591.148279] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1591.155397] x23: 0000000938940000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1591.162515] x20: 0000000000000000 x19: ffff80000c365000 x18: ffffffffffffffff
[ 1591.169633] x17: 0000000000000000 x16: 0000000000000000 x15: 0000b5e654836e74
[ 1591.176751] x14: 000000000000002a x13: 000000000000002a x12: 0000000000000000
[ 1591.183867] x11: 0000000000000001 x10: 00000000000009b0 x9 : ffff80000c0b3980
[ 1591.190986] x8 : ffff0008aae15150 x7 : ffff000f5c370340 x6 : 0000000000000000
[ 1591.198103] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1b42348
[ 1591.205221] x2 : 01591.301049] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1591.372728] CPU: 0 PID: 3312 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1591.381837] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1591.387477] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1591.394419] pc : __vunmap+0x78/0x30c
[ 1591.397981] lr : __vunmap+0x78/0x30c
[ 1591.401542] sp : ffff80000c0b3ad0
[ 1591.404842] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1591.411960] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1591.419077] x23: 00000009388c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1591.426194] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1591.433313] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1591.440430] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002f5b
[ 1591.447546] x11: 0000000000000fc9 x10: ffff8000092f1028 x9 : ffff800009281550
[ 1591.454664] x8 : 00000000ffffffc9 x7 : ffff8000092d9550 x6 : 0000000000017ad8
[ 1591.461780] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1591.468899] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1591.476016] Call trace:
[ 1591.478450] __vunmap+0x78/0x30c
[ 1591.481665] vunmap+0x40/0x5c
[ 1591.484620] dma_direct_free+0x10c/0x110
[ 1591.488529] dma_free_attrs+0x98/0xe0
[ 1591.492177] wave5_vdi_free_e_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1591.636373] CPU: 0 PID: 3312 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1591.645482] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1591.651121] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1591.658064] pc : __vunmap+0x78/0x30c
[ 1591.661626] lr : __vunmap+0x78/0x30c
[ 1591.665188] sp : ffff80000c0b3ad0
[ 1591.668488] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1591.675607] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1591.682725] x23: 00000009388a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1591.689842] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1591.696958] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1591.704076] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002fcd
[ 1591.711194] x11: 0000000000000fef x10: ffff8000092f13b8 x9 : ffff800009281550
[ 1591.718312] x8 : 00000000ffffffef x7 : ffff8000092d9550 x6 : 0000000000017e68
[ 1591.725429] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1591.732547] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1591.739665] Call trace:
[ 1591.742099] __vunmap+0x78/0x30c
[ 1591.745313] vunmap+0x40/0x5c
[ 1591.748268] dma_direct_free+0x10c/0x110
[ 1591.752177] dma_free_attrs+0x98/0xe0
[ 1591.755826] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1591.761128] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1591.765996] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1591.771297] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1591.776250] v4l2_release+0xbc/0xf0 [videodev]
[ 1591.780702] __fput+0x70/0x250
[ 1591.783744] ____fput+0x10/0x20
[ 1591.786873] task_work_run+0x80/0xe0
[ 1591.790436] do_notify_resume+0x208/0x1280
[ 1591.794518] el0_svc+0x74/0x84
[ 1591.797559] el0t_64_sync_handler+0xbc/0x140
[ 1591.801814] el0t_64_sync+0x18c/0x190
[ 1591.805463] ---[ end trace 0000000000000000 ]---
[ 1591.870761] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1591.8809(00000000953119ba)
[ 1591.932215] WARNING: CPU: 7 PID: 3315 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1591.939431] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1592.011135] CPU: 7 PID: 3315 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1592.020246] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1592.025888] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1592.032830] pc : __vunmap+0x78/0x30c
[ 1592.036392] lr : __vunmap+0x78/0x30c
[ 1592.039954] sp : ffff80000ba8bad0
[ 1592.043255] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1592.050374] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1592.057491] x23: 0000000938a80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1592.064609] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1592.071727] x17: 0000000000000000 x16: 0000000000000000 x15: 00000002a2669cc1
[ 1592.078844] x14: 00000000000000a7 x13: 0000000000000000 x12: 0000000000000000
[ 1592.085961] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000ba8b980
[ 1592.093079] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1592.100196] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a003c8
[ 1592.107312] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1592.114430] Call trace:
[ 1592.116863] __vunmap+0x78/0x30c
[ 1592.120077] vunmap+0x40/0x5c
[ 1592.12ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1592.274834] CPU: 7 PID: 3315 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1592.283944] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1592.289585] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1592.296527] pc : __vunmap+0x78/0x30c
[ 1592.300088] lr : __vunmap+0x78/0x30c
[ 1592.303650] sp : ffff80000ba8bad0
[ 1592.306950] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1592.314067] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1592.321184] x23: 00000009389c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1592.328302] x20: 0000000000000000 x19: ffff80000c35e000 x18: ffffffffffffffff
[ 1592.335420] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1592.342538] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000000c0
[ 1592.349656] x11: 0000000000000040 x10: ffff8000092d9b50 x9 : ffff800009281550
[ 1592.356773] x8 : 0000000100000040 x7 : ffff8000092d9550 x6 : 0000000000000600
[ 1592.363891] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1592.371009] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1592.378127] Call trace:
[ 1592.380559] __vunmap+0x78/0x30c
[ 1592.383773] vunmap+0x40/0x5c
[ 1592.386729] dma_direct_free+0x10c/0x110
[ 1592.390638] dma_free_attrs+0x98/0xe0
[ 1592.394286] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1592.399590] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1592.404545] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1592.409847] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1592.414802] v4l2_release+0xbc/0xf0 [videodev]
[ 1592.419257] __fput+0x70/0xx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1592.538496] CPU: 7 PID: 3315 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1592.547606] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1592.553247] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1592.560189] pc : __vunmap+0x78/0x30c
[ 1592.563751] lr : __vunmap+0x78/0x30c
[ 1592.567312] sp : ffff80000ba8bad0
[ 1592.570612] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1592.577730] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1592.584846] x23: 0000000938a00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1592.591963] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1592.599081] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1592.606197] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000132
[ 1592.613315] x11: 0000000000000066 x10: ffff8000092d9ee0 x9 : ffff800009281550
[ 1592.620432] x8 : 0000000100000066 x7 : ffff8000092d9550 x6 : 0000000000000990
[ 1592.627550] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1592.634667] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1592.641784] Call trace:
[ 1592.644217] __vunmap+0x78/0x30c
[ 1592.647431] vunmap+0x40/0x5c
[ 1592.650387] dma_direct_free+0x10c/0x110
[ 1592.654296] dma_free_attrs+0x98/0xe0
[ 1592.657943] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1592.663247] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1592.668200] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1592.673502] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1592.678457] v4l2_release+0xbc/0xf0 [videodev]
[ 1592.682913] __fput+0x70/0x250
[ 1592.685956] ____fput+0x10/0x20
[ 1592.689085] task_work_run+0x80/0xe0
[ 1592.692647] do_notify_resume+0x208/0x1280
[ 1592.696732] el0_svc+0x74/0x84
[ 1592.699773] el0t_64_sync_handler+0xbc/0x140
[ 1592.704027] el0t_64_sync+0x18c/0x190
[ 1592.707676] ---[ end trace 0000000000000000 ]---
[ 1592.712301] ------------[ cut here ]------------
[ 1592.71690--)
[ 1592.823825] pc : __vunmap+0x78/0x30c
[ 1592.827387] lr : __vunmap+0x78/0x30c
[ 1592.830950] sp : ffff80000ba8bad0
[ 1592.834251] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1592.841369] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1592.848487] x23: 00000009388e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1592.855605] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1592.862722] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1592.869840] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000001a4
[ 1592.876958] x11: 000000000000008c x10: ffff8000092da270 x9 : ffff800009281550
[ 1592.884076] x8 : 000000010000008c x7 : ffff8000092d9550 x6 : 0000000000000d20
[ 1592.891193] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1592.898309] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1592.905426] Call trace:
[ 1592.907859] __vunmap+0x78/0x30c
[ 1592.911073] vunmap+0x40/0x5c
[ 1592.914028] dma_direct_free+0x10c/0x110
[ 1592.917937] dma_free_attrs+0x98/0xe0
[ 1592.921584] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1592.926887] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1592.931754] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1592.937056] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1592.942011] v4l2_release+0xbc/0xf0 [videodev]
[ 1592.946461] __fput+0x70/0x250
[ 1592.949503] ____fput+0x10/0x20
[ 1592.952633] task_work_run+0x80/0xe0
[ 1592.956195] do_notify_resume+0x208/0x1280
[ 1592.960279] el0_svc+0x74/0x84
[ 1592.963320] el0t_64_sync_handler+0xbc/0x140
[ 1592.967575] el0t_64_sync+0x18c/0x190
[ 1592.971223] ---[ end trace 0000000000000000 ]---
[ 1593.040891] ------------[ cut here ]------------
[ 1593.045556] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1593.051917] WARNING: CPU: 6 PID: 3318 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1593.059131] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2me optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1593.130837] CPU: 6 PID: 3318 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1593.139953] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1593.145594] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1593.152540] pc : __vunmap+0x78/0x30c
[ 1593.156103] lr : __vunmap+0x78/0x30c
[ 1593.159664] sp : ffff80000baebad0
[ 1593.162965] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1593.170085] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1593.177203] x23: 0000000938b00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1593.184322] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1593.191440] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1593.198558] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000216
[ 1593.205676] x11: 00000000000000b2 x10: ffff8000092da600 x9 : ffff800009281550
[ 1593.212794] x8 : 00000001000000b2 x7 : ffff8000092d9550 x6 : 00000000000010b0
[ 1593.219912] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1593.227030] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1593.234149] Call trace:
[ 1593.236583] __vunmap+0x78/0x30c
[ 1593.239797] vunmap+0x40/0x5c
[ 1593.242753] dma_direct_free+0x10c/0x110
[ 1593.246664] dma_free_attrs+0x98/0xe0
[ 1593.250314] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1593.255625] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1593.260581] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1593.265882] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1593.270836] v4l2_release+0xbc/0xf0 [videodev]
[ 1593.275292] __fput+0x70/0x250
[ 1593.278339] ____fput+0x10/0x20
[ 1593.281468] task_work_run+0x80/0xe0
[ 1593.285032] do_notify_resume+0x208/0x1280
[ 1593.289118] el0_svc+0x74/0x84
[ 1593.292160] el0t_64_sync_handler+0xbc/0x140
[ 1593.296416] el0t_64_sync+0x18c/0x190
[ 1593.300065] ---[ end trace 0000000000000000 ]---
[ 1593.304698] ------------[ cut here ]------------
[ 1593.309366] Trying to vfree() nonexistent vm area (00000000b84bacf7)
[ 1593.315793] ffff80000baebad0
[ 1593.426796] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1593.433915] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1593.441033] x23: 0000000938ac0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1593.448151] x20: 0000000000000000 x19: ffff80000c35e000 x18: ffffffffffffffff
[ 1593.455267] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1593.462385] x14: 0000000000000268 x13: 0000000000000000 x12: 0000000000000000
[ 1593.469503] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1593.476621] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1593.483739] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33df048
[ 1593.490857] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1593.497974] Call trace:
[ 1593.500407] __vunmap+0x78/0x30c
[ 1593.503621] vunmap+0x40/0x5c
[ 1593.506577] dma_direct_free+0x10c/0x110
[ 1593.510486] dma_free_attrs+0x98/0xe0
[ 1593.514134] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1593.519439] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1593.524393] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1593.529695] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1593.534649] v4l2_release+0xbc/0xf0 [videodev]
[ 1593.539103] __fput+0x70/0x250
[ 1593.542147] ____fput+0x10/0x20
[ 1593.545277] task_work_run+0x80/0xe0
[ 1593.548839] do_notify_resume+0x208/0x1280
[ 1593.552923] el0_svc+0x74/0x84
[ 1593.555965] el0t_64_sync_handler+0xbc/0x140
[ 1593.560220] el0t_64_sync+0x18c/0x190
[ 1593.563868] ---[ end trace 0000000000000000 ]---
[ 1593.568502] ------------[ cut here ]------------
[ 1593.573112] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1593.579458] WARNING: CPU: 6 PID: 3318 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1593.586663] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async 1593.726046] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000002fa
[ 1593.733164] x11: 00000000000000fe x10: ffff8000092dad20 x9 : ffff800009281550
[ 1593.740282] x8 : 00000001000000fe x7 : ffff8000092d9550 x6 : 00000000000017d0
[ 1593.747400] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1593.754517] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1593.761634] Call trace:
[ 1593.764067] __vunmap+0x78/0x30c
[ 1593.767281] vunmap+0x40/0x5c
[ 1593.770237] dma_direct_free+0x10c/0x110
[ 1593.774145] dma_free_attrs+0x98/0xe0
[ 1593.777794] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1593.783097] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1593.788052] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1593.793353] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1593.798307] v4l2_release+0xbc/0xf0 [videodev]
[ 1593.802759] __fput+0x70/0x250
[ 1593.805801] ____fput+0x10/0x20
[ 1593.808930] task_work_run+0x80/0xe0
[ 1593.812492] do_notify_resume+0x208/0x1280
[ 1593.816576] el0_svc+0x74/0x84
[ 1593.819618] el0t_64_sync_handler+0xbc/0x140
[ 1593.823873] el0t_64_sync+0x18c/0x190
[ 1593.827522] ---[ end trace 0000000000000000 ]---
[ 1593.832145] ------------[ cut here ]------------
[ 1593.836756] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1593.843153] WARNING: CPU: 6 PID: 3318 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1593.850358] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_: ffffffffffffffff
[ 1593.982626] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1593.989743] x14: 00000000000001e8 x13: 0000000000000000 x12: 0000000000000000
[ 1593.996861] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1594.003979] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1594.011097] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33df048
[ 1594.018215] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1594.025332] Call trace:
[ 1594.027766] __vunmap+0x78/0x30c
[ 1594.030980] vunmap+0x40/0x5c
[ 1594.033935] dma_direct_free+0x10c/0x110
[ 1594.037843] dma_free_attrs+0x98/0xe0
[ 1594.041492] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1594.046794] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1594.051662] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1594.056963] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1594.061917] v4l2_release+0xbc/0xf0 [videodev]
[ 1594.066368] __fput+0x70/0x250
[ 1594.069411] ____fput+0x10/0x20
[ 1594.072541] task_work_run+0x80/0xe0
[ 1594.076103] do_notify_resume+0x208/0x1280
[ 1594.080187] el0_svc+0x74/0x84
[ 1594.083229] el0t_64_sync_handler+0xbc/0x140
[ 1594.087483] el0t_64_sync+0x18c/0x190
[ 1594.091132] ---[ end trace 0000000000000000 ]---
[ 1594.168684] ------------[ cut here ]------------
[ 1594.173362] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1594.179828] WARNING: CPU: 7 PID: 3321 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1594.187044] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pc00000000 x24: 0000000000000000
[ 1594.305113] x23: 0000000938400000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1594.312232] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1594.319350] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1594.326467] x14: 000000000000025d x13: 0000000000000000 x12: 0000000000000000
[ 1594.333584] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c343980
[ 1594.340701] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1594.347819] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a049c8
[ 1594.354937] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1594.362055] Call trace:
[ 1594.364489] __vunmap+0x78/0x30c
[ 1594.367705] vunmap+0x40/0x5c
[ 1594.370661] dma_direct_free+0x10c/0x110
[ 1594.374572] dma_free_attrs+0x98/0xe0
[ 1594.378220] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1594.383533] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1594.388488] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1594.393789] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1594.398744] v4l2_release+0xbc/0xf0 [videodev]
[ 1594.403201] __fput+0x70/0x250
[ 1594.406245] ____fput+0x10/0x20
[ 1594.409374] task_work_run+0x80/0xe0
[ 1594.412937] do_notify_resume+0x208/0x1280
[ 1594.417022] el0_svc+0x74/0x84
[ 1594.420066] el0t_64_sync_handler+0xbc/0x140
[ 1594.424322] el0t_64_sync+0x18c/0x190
[ 1594.427972] ---[ end trace 0000000000000000 ]---
[ 1594.432610] ------------[ cut here ]------------
[ 1594.437222] Trying to vfree() nonexistent vm area (0000000025e623b3)
[ 1594.443594] WARNING: CPU: 7 PID: 3321 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1594.450801] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mcf
[ 1594.583073] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3437b7
[ 1594.590191] x14: 0000000000000067 x13: 0000000000000001 x12: 0000000000000001
[ 1594.597310] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c343980
[ 1594.604429] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1594.611547] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a049c8
[ 1594.618664] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1594.625781] Call trace:
[ 1594.628214] __vunmap+0x78/0x30c
[ 1594.631428] vunmap+0x40/0x5c
[ 1594.634384] dma_direct_free+0x10c/0x110
[ 1594.638293] dma_free_attrs+0x98/0xe0
[ 1594.641941] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1594.647245] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1594.652200] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1594.657501] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1594.662455] v4l2_release+0xbc/0xf0 [videodev]
[ 1594.666909] __fput+0x70/0x250
[ 1594.669952] ____fput+0x10/0x20
[ 1594.673081] task_work_run+0x80/0xe0
[ 1594.676643] do_notify_resume+0x208/0x1280
[ 1594.680728] el0_svc+0x74/0x84
[ 1594.683770] el0t_64_sync_handler+0xbc/0x140
[ 1594.688024] el0t_64_sync+0x18c/0x190
[ 1594.691673] ---[ end trace 0000000000000000 ]---
[ 1594.696358] ------------[ cut here ]------------
[ 1594.700972] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1594.707319] WARNING: CPU: 7 PID: 3321 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1594.714524] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cad0: ffff8000092dbb60 x9 : ffff800009281550
[ 1594.868142] x8 : 0000000100000196 x7 : ffff8000092d9550 x6 : 0000000000002610
[ 1594.875260] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1594.882377] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1594.889494] Call trace:
[ 1594.891927] __vunmap+0x78/0x30c
[ 1594.895141] vunmap+0x40/0x5c
[ 1594.898096] dma_direct_free+0x10c/0x110
[ 1594.902005] dma_free_attrs+0x98/0xe0
[ 1594.905652] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1594.910955] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1594.915910] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1594.921212] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1594.926165] v4l2_release+0xbc/0xf0 [videodev]
[ 1594.930618] __fput+0x70/0x250
[ 1594.933662] ____fput+0x10/0x20
[ 1594.936791] task_work_run+0x80/0xe0
[ 1594.940353] do_notify_resume+0x208/0x1280
[ 1594.944436] el0_svc+0x74/0x84
[ 1594.947478] el0t_64_sync_handler+0xbc/0x140
[ 1594.951734] el0t_64_sync+0x18c/0x190
[ 1594.955382] ---[ end trace 0000000000000000 ]---
[ 1594.960026] ------------[ cut here ]------------
[ 1594.964634] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1594.970980] WARNING: CPU: 7 PID: 3321 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1594.978185] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1595.049862] CPU: 7 PID: 3321 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g80000000000000 x0 : ffff0008aae15580
[ 1595.153148] Call trace:
[ 1595.155581] __vunmap+0x78/0x30c
[ 1595.158796] vunmap+0x40/0x5c
[ 1595.161752] dma_direct_free+0x10c/0x110
[ 1595.165661] dma_free_attrs+0x98/0xe0
[ 1595.169310] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1595.174613] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1595.179481] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1595.184782] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1595.189737] v4l2_release+0xbc/0xf0 [videodev]
[ 1595.194187] __fput+0x70/0x250
[ 1595.197230] ____fput+0x10/0x20
[ 1595.200360] task_work_run+0x80/0xe0
[ 1595.203923] do_notify_resume+0x208/0x1280
[ 1595.208006] el0_svc+0x74/0x84
[ 1595.211047] el0t_64_sync_handler+0xbc/0x140
[ 1595.215302] el0t_64_sync+0x18c/0x190
[ 1595.218949] ---[ end trace 0000000000000000 ]---
[ 1595.298256] ------------[ cut here ]------------
[ 1595.302890] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1595.309250] WARNING: CPU: 0 PID: 3324 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1595.316465] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1595.388167] CPU: 0 PID: 3324 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1595.397278] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1595.402920] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1595.409862] pc : __vunmap+0x78/0x30c
[ 1595.413423] lr : __vunmap+0x78/0x30c
[ 1595.416984] spffffffff
[ 1595.448756] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb7b7
[ 1595.455875] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000005a6
[ 1595.462993] x11: 00000000000001e2 x10: ffff8000092dc280 x9 : ffff800009281550
[ 1595.470111] x8 : 00000001000001e2 x7 : ffff8000092d9550 x6 : 0000000000002d30
[ 1595.477228] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1595.484345] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1595.491463] Call trace:
[ 1595.493898] __vunmap+0x78/0x30c
[ 1595.497114] vunmap+0x40/0x5c
[ 1595.500069] dma_direct_free+0x10c/0x110
[ 1595.503980] dma_free_attrs+0x98/0xe0
[ 1595.507629] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1595.512941] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1595.517896] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1595.523197] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1595.528152] v4l2_release+0xbc/0xf0 [videodev]
[ 1595.532607] __fput+0x70/0x250
[ 1595.535654] ____fput+0x10/0x20
[ 1595.538784] task_work_run+0x80/0xe0
[ 1595.542347] do_notify_resume+0x208/0x1280
[ 1595.546433] el0_svc+0x74/0x84
[ 1595.549476] el0t_64_sync_handler+0xbc/0x140
[ 1595.553732] el0t_64_sync+0x18c/0x190
[ 1595.557380] ---[ end trace 0000000000000000 ]---
[ 1595.562028] ------------[ cut here ]------------
[ 1595.566697] Trying to vfree() nonexistent vm area (0000000025e623b3)
[ 1595.573164] WARNING: CPU: 0 PID: 3324 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1595.580370] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e8aae14740
[ 1595.755344] Call trace:
[ 1595.757778] __vunmap+0x78/0x30c
[ 1595.760992] vunmap+0x40/0x5c
[ 1595.763948] dma_direct_free+0x10c/0x110
[ 1595.767857] dma_free_attrs+0x98/0xe0
[ 1595.771506] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1595.776808] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1595.781762] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1595.787063] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1595.792018] v4l2_release+0xbc/0xf0 [videodev]
[ 1595.796471] __fput+0x70/0x250
[ 1595.799514] ____fput+0x10/0x20
[ 1595.802643] task_work_run+0x80/0xe0
[ 1595.806205] do_notify_resume+0x208/0x1280
[ 1595.810289] el0_svc+0x74/0x84
[ 1595.813330] el0t_64_sync_handler+0xbc/0x140
[ 1595.817585] el0t_64_sync+0x18c/0x190
[ 1595.821235] ---[ end trace 0000000000000000 ]---
[ 1595.825892] ------------[ cut here ]------------
[ 1595.830502] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1595.836850] WARNING: CPU: 0 PID: 3324 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1595.844055] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1595.915733] CPU: 0 PID: 3324 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1595.924841] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1595.930482] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1595.937423] pc : __vunmap+0x78/0x30c
[ 1595.940985] lr : __vunmap+0x78/0x30c
[ 1595.944547] sp : ffff80000bacbad0e5]
[ 1596.045443] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1596.050744] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1596.055698] v4l2_release+0xbc/0xf0 [videodev]
[ 1596.060149] __fput+0x70/0x250
[ 1596.063192] ____fput+0x10/0x20
[ 1596.066321] task_work_run+0x80/0xe0
[ 1596.069884] do_notify_resume+0x208/0x1280
[ 1596.073967] el0_svc+0x74/0x84
[ 1596.077008] el0t_64_sync_handler+0xbc/0x140
[ 1596.081264] el0t_64_sync+0x18c/0x190
[ 1596.084911] ---[ end trace 0000000000000000 ]---
[ 1596.089565] ------------[ cut here ]------------
[ 1596.094180] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1596.100571] WARNING: CPU: 0 PID: 3324 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1596.107778] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1596.179454] CPU: 0 PID: 3324 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1596.188563] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1596.194204] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1596.201147] pc : __vunmap+0x78/0x30c
[ 1596.204710] lr : __vunmap+0x78/0x30c
[ 1596.208270] sp : ffff80000bacbad0
[ 1596.211570] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1596.218688] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1596.225806] x23: 0000000938ba0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1596.232924] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ff x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1596.282745] Call trace:
[ 1596.285179] __vunmap+0x78/0x30c
[ 1596.288395] vunmap+0x40/0x5c
[ 1596.291350] dma_direct_free+0x10c/0x110
[ 1596.295259] dma_free_attrs+0x98/0xe0
[ 1596.298907] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1596.304210] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1596.309078] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1596.314378] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1596.319332] v4l2_release+0xbc/0xf0 [videodev]
[ 1596.323784] __fput+0x70/0x250
[ 1596.326827] ____fput+0x10/0x20
[ 1596.329957] task_work_run+0x80/0xe0
[ 1596.333518] do_notify_resume+0x208/0x1280
[ 1596.337602] el0_svc+0x74/0x84
[ 1596.340644] el0t_64_sync_handler+0xbc/0x140
[ 1596.344898] el0t_64_sync+0x18c/0x190
[ 1596.348546] ---[ end trace 0000000000000000 ]---
[ 1596.413542] cma_alloc: 15 callbacks suppressed
[ 1596.413552] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1596.428080] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1596.439077] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1596.448674] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1596.457902] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1596.468280] ------------[ cut here ]------------
[ 1596.472898] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1596.479254] WARNING: CPU: 6 PID: 3327 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1596.486469] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1596.558174] CPU: 6 PID: 3327 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1596.567284] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1596.572926] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1596.579869] pc : __vunmap+0x78/0x30c
[ 1596.583431] lr : __vunmap+0x78/0x30c
[ 1596.586993] sp : ffff80000ba8bad0
[ 1596.590293] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1596.597412] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1596.604530] x23: 0000000938580000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1596.611647] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1596.618765] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1596.625881] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000780
[ 1596.632998] x11: 0000000000000280 x10: ffff8000092dd150 x9 : ffff800009281550
[ 1596.640116] x8 : 0000000100000280 x7 : ffff8000092d9550 x6 : 0000000000003c00
[ 1596.647233] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1596.654350] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1596.661467] Call trace:
[ 1596.663901] __vunmap+0x78/0x30c
[ 1596.667116] vunmap+0x40/0x5c
[ 1596.670072] dma_direct_free+0x10c/0x110
[ 1596.673986] dma_free_attrs+0x98/0xe0
[ 1596.677635] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1596.682946] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1596.687901] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1596.693201] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1596.698155] v4l2_release+0xbc/0xf0 [videodev]
[ 1596.702611] __fput+0x70/0x250
[ 1596.705656] ____fput+0x10/0x20
[ 1596.708785] task_work_run+0x80/0xe0
[ 1596.712348] do_notify_resume+0x208/0x1280
[ 1596.716434] el0_svc+0x74/0x84
[ 1596.719479] el0t_64_sync_handler+0xbc/0x140
[ 1596.723734] el0t_64_sync+0x18c/0x190
[ 1596.727383]ost pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1596.821882] CPU: 6 PID: 3327 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1596.830995] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1596.836636] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1596.843578] pc : __vunmap+0x78/0x30c
[ 1596.847139] lr : __vunmap+0x78/0x30c
[ 1596.850700] sp : ffff80000ba8bad0
[ 1596.854000] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1596.861119] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1596.868236] x23: 00000009384c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1596.875353] x20: 0000000000000000 x19: ffff80000c366000 x18: ffffffffffffffff
[ 1596.882470] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1596.889587] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000007f2
[ 1596.896705] x11: 00000000000002a6 x10: ffff8000092dd4e0 x9 : ffff800009281550
[ 1596.903822] x8 : 00000001000002a6 x7 : ffff8000092d9550 x6 : 0000000000003f90
[ 1596.910938] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1596.918055] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1596.925172] Call trace:
[ 1596.927605] __vunmap+0x78/0x30c
[ 1596.930819] vunmap+0x40/0x5c
[ 1596.933774] dma_direct_free+0x10c/0x110
[ 1596.937684] dma_free_attrs+0x98/0xe0
[ 1596.941332] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1596.946635] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1596.951590] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1596.956891] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1596.961845] v4l2_release+0xbc/0xf0 [videodev]
[ 1596.966301] __fput+0x70/0x250
[ 1596.969343] ____fput+0x10/0x20
[ 1596.972473] task_work_run+0x80/0xe0
[ 1596.976035] do_notify_resume+0x208/0x1280
[ 1596.980120] el0_svc+0x74/0x84
[ 1596.983161] el0t_64_sync_handler+0xbc/0x140
[ 1596.987416] el0t_64_sync+0x18c/0x190
[ 1596.991065] ---[ end trace 0000000000000000 ]---
[ 1596.995688] ------------[ cut here ]------------
[ 1597.085521] CPU: 6 PID: 3327 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1597.094630] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1597.100273] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1597.107215] pc : __vunmap+0x78/0x30c
[ 1597.110778] lr : __vunmap+0x78/0x30c
[ 1597.114340] sp : ffff80000ba8bad0
[ 1597.117640] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1597.124758] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1597.131875] x23: 0000000938500000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1597.138994] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1597.146111] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1597.153228] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000864
[ 1597.160345] x11: 00000000000002cc x10: ffff8000092dd870 x9 : ffff800009281550
[ 1597.167462] x8 : 00000001000002cc x7 : ffff8000092d9550 x6 : 0000000000004320
[ 1597.174579] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1597.181696] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1597.188813] Call trace:
[ 1597.191245] __vunmap+0x78/0x30c
[ 1597.194460] vunmap+0x40/0x5c
[ 1597.197415] dma_direct_free+0x10c/0x110
[ 1597.201324] dma_free_attrs+0x98/0xe0
[ 1597.204972] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1597.210275] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1597.215230] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1597.220531] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1597.225485] v4l2_release+0xbc/0xf0 [videodev]
[ 1597.229937] __fput+0x70/0x250
[ 1597.232980] ____fput+0x10/0x20
[ 1597.236109] task_work_run+0x80/0xe0
[ 1597.239672] do_notify_resume+0x208/0x1280
[ 1597.243755] el0_svc+0x74/0x84
[ 1597.246797] el0t84S4 EVM (DT)
[ 1597.363987] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1597.370930] pc : __vunmap+0x78/0x30c
[ 1597.374492] lr : __vunmap+0x78/0x30c
[ 1597.378053] sp : ffff80000ba8bad0
[ 1597.381353] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1597.388472] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1597.395590] x23: 0000000938be0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1597.402707] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1597.409824] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1597.416940] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000008d6
[ 1597.424058] x11: 00000000000002f2 x10: ffff8000092ddc00 x9 : ffff800009281550
[ 1597.431175] x8 : 00000001000002f2 x7 : ffff8000092d9550 x6 : 00000000000046b0
[ 1597.438293] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1597.445411] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1597.452528] Call trace:
[ 1597.454962] __vunmap+0x78/0x30c
[ 1597.458177] vunmap+0x40/0x5c
[ 1597.461133] dma_direct_free+0x10c/0x110
[ 1597.465042] dma_free_attrs+0x98/0xe0
[ 1597.468691] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1597.473999] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1597.478866] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1597.484168] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1597.489123] v4l2_release+0xbc/0xf0 [videodev]
[ 1597.493575] __fput+0x70/0x250
[ 1597.496619] ____fput+0x10/0x20
[ 1597.499748] task_work_run+0x80/0xe0
[ 1597.503312] do_notify_resume+0x208/0x1280
[ 1597.507397] el0_svc+0x74/0x84
[ 1597.510439] el0t_64_sync_handler+0xbc/0x140
[ 1597.514693] el0t_64_sync+0x18c/0x190
[ 1597.518342] ---[ end trace 0000000000000000 ]---
[ 1597.584644] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1597.594716] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1597.605887] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1597.615450] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, rdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1597.724932] CPU: 6 PID: 3330 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1597.734044] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1597.739685] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1597.746628] pc : __vunmap+0x78/0x30c
[ 1597.750190] lr : __vunmap+0x78/0x30c
[ 1597.753753] sp : ffff80000c0b3ad0
[ 1597.757053] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1597.764173] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1597.771292] x23: 0000000938600000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1597.778411] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1597.785530] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1597.792648] x14: 0000000000000332 x13: 0000000000000000 x12: 0000000000000000
[ 1597.799767] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0b3980
[ 1597.806884] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1597.814001] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dbbc8
[ 1597.821117] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1597.828235] Call trace:
[ 1597.830670] __vunmap+0x78/0x30c
[ 1597.833884] vunmap+0x40/0x5c
[ 1597.836840] dma_direct_free+0x10c/0x110
[ 1597.840751] dma_free_attrs+0x98/0xe0
[ 1597.844400] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1597.849711] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1597.854667] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1597.859969] wave5_vpu_enc_release+0x20/0x2c [watscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1597.988636] CPU: 6 PID: 3330 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1597.997747] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1598.003388] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1598.010331] pc : __vunmap+0x78/0x30c
[ 1598.013892] lr : __vunmap+0x78/0x30c
[ 1598.017454] sp : ffff80000c0b3ad0
[ 1598.020753] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1598.027871] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1598.034989] x23: 00000009385c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1598.042106] x20: 0000000000000000 x19: ffff80000c366000 x18: ffffffffffffffff
[ 1598.049223] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1598.056340] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000009c9
[ 1598.063457] x11: 0000000000000343 x10: ffff8000092de398 x9 : ffff800009281550
[ 1598.070574] x8 : 0000000100000343 x7 : ffff8000092d9550 x6 : 0000000000004e48
[ 1598.077691] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1598.084808] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1598.091925] Call trace:
[ 1598.094358] __vunmap+0x78/0x30c
[ 1598.097574] vunmap+0x40/0x5c
[ 1598.100529] dma_direct_free+0x10c/0x110
[ 1598.104437] dma_free_attrs+0x98/0xe0
[ 1598.108085] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1598.113388] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1598.118343] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1598.123645] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1598.128600] v4l2_release+0xbc/0xf0 [videodev]
[ 1598.133053] __fput+0x70/0x250
[ 1598.136096] ____fput+0x10/0x20
[ 1598.139225] task_work_run+0x80/0xe0
[ 1598.142787] do_notify_resume+0x208/0x1280
[ 1598.146871] el0_svc+0x74/0x84
[ 1598.149913] el0t_64_sync_handler+0xbc/0x140
[ 1598.154168] el0t_64_sync+0x18c/0x190
[ 1598.157817] ---[ end trace 0000000000000000 ]---
[ 1598.319977] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000a3b
[ 1598.327095] x11: 0000000000000369 x10: ffff8000092de728 x9 : ffff800009281550
[ 1598.334213] x8 : 0000000100000369 x7 : ffff8000092d9550 x6 : 00000000000051d8
[ 1598.341329] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1598.348446] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1598.355564] Call trace:
[ 1598.357997] __vunmap+0x78/0x30c
[ 1598.361211] vunmap+0x40/0x5c
[ 1598.364166] dma_direct_free+0x10c/0x110
[ 1598.368075] dma_free_attrs+0x98/0xe0
[ 1598.371723] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1598.377027] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1598.381981] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1598.387282] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1598.392235] v4l2_release+0xbc/0xf0 [videodev]
[ 1598.396689] __fput+0x70/0x250
[ 1598.399733] ____fput+0x10/0x20
[ 1598.402862] task_work_run+0x80/0xe0
[ 1598.406424] do_notify_resume+0x208/0x1280
[ 1598.410508] el0_svc+0x74/0x84
[ 1598.413550] el0t_64_sync_handler+0xbc/0x140
[ 1598.417805] el0t_64_sync+0x18c/0x190
[ 1598.421454] ---[ end trace 0000000000000000 ]---
[ 1598.426083] ------------[ cut here ]------------
[ 1598.430690] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1598.437038] WARNING: CPU: 6 PID: 3330 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1598.444242] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core crypt0000000000000000
[ 1598.569388] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1598.576507] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1598.583624] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000aad
[ 1598.590743] x11: 000000000000038f x10: ffff8000092deab8 x9 : ffff800009281550
[ 1598.597860] x8 : 000000010000038f x7 : ffff8000092d9550 x6 : 0000000000005568
[ 1598.604977] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1598.612094] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1598.619211] Call trace:
[ 1598.621645] __vunmap+0x78/0x30c
[ 1598.624859] vunmap+0x40/0x5c
[ 1598.627814] dma_direct_free+0x10c/0x110
[ 1598.631722] dma_free_attrs+0x98/0xe0
[ 1598.635370] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1598.640674] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1598.645543] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1598.650844] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1598.655799] v4l2_release+0xbc/0xf0 [videodev]
[ 1598.660251] __fput+0x70/0x250
[ 1598.663295] ____fput+0x10/0x20
[ 1598.666424] task_work_run+0x80/0xe0
[ 1598.669986] do_notify_resume+0x208/0x1280
[ 1598.674070] el0_svc+0x74/0x84
[ 1598.677111] el0t_64_sync_handler+0xbc/0x140
[ 1598.681365] el0t_64_sync+0x18c/0x190
[ 1598.685014] ---[ end trace 0000000000000000 ]---
[ 1598.756892] ------------[ cut here ]------------
[ 1598.761530] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1598.767894] WARNING: CPU: 0 PID: 3333 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1598.775108] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1598.846811] CPU: 0 PID: 3333 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1598.855923] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1598.861564] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1598.868508] pc : __vunmap+0x78/0x30c
[ 1598.872070] lr : __vunmap+0x78/0x30c
[ 1598.875632] sp : ffff80000c34bad0
[ 1598.878933] x29: ffff80000c34bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1598.886052] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1598.893171] x23: 0000000938700000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1598.900289] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1598.907406] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c34b7b7
[ 1598.914524] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000b1f
[ 1598.921642] x11: 00000000000003b5 x10: ffff8000092dee48 x9 : ffff800009281550
[ 1598.928760] x8 : 00000001000003b5 x7 : ffff8000092d9550 x6 : 00000000000058f8
[ 1598.935878] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1598.942995] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1598.950114] Call trace:
[ 1598.952548] __vunmap+0x78/0x30c
[ 1598.955762] vunmap+0x40/0x5c
[ 1598.958718] dma_direct_free+0x10c/0x110
[ 1598.962628] dma_free_attrs+0x98/0xe0
[ 1598.966277] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1598.971589] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1598.976544] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1598.981845] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1598.986801] v4l2_release+0xbc/0xf0 [videodev]
[ 1598.991256] __fput+0x70/0x250
[ 1598.994300] ____fput+0x10/0x20
[ 1598.997430] task_work_run+0x80/0xe0
[ 1599.000993] do_notify_resume+0x208/0x1280
[ 1599.005080] el0_svc+0x74/0x84
[ 1599.008125] el0t_64_sync_handler+0xbc/0x140
[ 1599.012380] el0t_64_sync+0x18c/0x190
[ 1599.016029] ---[ end trace 0000000000000000 ]---
[ 1599.0206] x29: ffff80000c34bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1599.149926] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1599.157043] x23: 0000000938640000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1599.164162] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1599.171280] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1599.178398] x14: 0000000000000178 x13: 0000000000000000 x12: 0000000000000000
[ 1599.185515] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c34b980
[ 1599.192633] x8 : ffff0008aae15f90 x7 : ffff000f5c370340 x6 : 0000000000000000
[ 1599.199751] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1b42dc8
[ 1599.206868] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1599.213986] Call trace:
[ 1599.216419] __vunmap+0x78/0x30c
[ 1599.219634] vunmap+0x40/0x5c
[ 1599.222589] dma_direct_free+0x10c/0x110
[ 1599.226499] dma_free_attrs+0x98/0xe0
[ 1599.230148] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1599.235451] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1599.240406] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1599.245707] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1599.250661] v4l2_release+0xbc/0xf0 [videodev]
[ 1599.255114] __fput+0x70/0x250
[ 1599.258157] ____fput+0x10/0x20
[ 1599.261286] task_work_run+0x80/0xe0
[ 1599.264849] do_notify_resume+0x208/0x1280
[ 1599.268933] el0_svc+0x74/0x84
[ 1599.271975] el0t_64_sync_handler+0xbc/0x140
[ 1599.276230] el0t_64_sync+0x18c/0x190
[ 1599.279877] ---[ end trace 0000000000000000 ]---
[ 1599.284519] ------------[ cut here ]------------
[ 1599.289129] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1599.295477] WARNING: CPU: 0 PID: 3333 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1599.302695] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_0/0x5c
[ 1599.486267] dma_direct_free+0x10c/0x110
[ 1599.490176] dma_free_attrs+0x98/0xe0
[ 1599.493824] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1599.499127] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1599.504081] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1599.509382] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1599.514335] v4l2_release+0xbc/0xf0 [videodev]
[ 1599.518788] __fput+0x70/0x250
[ 1599.521832] ____fput+0x10/0x20
[ 1599.524961] task_work_run+0x80/0xe0
[ 1599.528523] do_notify_resume+0x208/0x1280
[ 1599.532607] el0_svc+0x74/0x84
[ 1599.535649] el0t_64_sync_handler+0xbc/0x140
[ 1599.539904] el0t_64_sync+0x18c/0x190
[ 1599.543551] ---[ end trace 0000000000000000 ]---
[ 1599.548183] ------------[ cut here ]------------
[ 1599.552800] Trying to vfree() nonexistent vm area (00000000896e1dbc)
[ 1599.559196] WARNING: CPU: 0 PID: 3333 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1599.566402] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1599.638081] CPU: 0 PID: 3333 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1599.647191] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1599.652831] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1599.659773] pc : __vunmap+0x78/0x30c
[ 1599.663335] lr : __vunmap+0x78/0x30c
[ 1599.666897] sp : ffff80000c34bad0
[ 1599.670197] x29: ffff80000c34bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1599.677315] x26: 0000sync_handler+0xbc/0x140
[ 1599.803522] el0t_64_sync+0x18c/0x190
[ 1599.807171] ---[ end trace 0000000000000000 ]---
[ 1599.877818] ------------[ cut here ]------------
[ 1599.882495] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1599.888926] WARNING: CPU: 7 PID: 3336 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1599.896142] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1599.967843] CPU: 7 PID: 3336 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1599.976954] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1599.982596] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1599.989538] pc : __vunmap+0x78/0x30c
[ 1599.993102] lr : __vunmap+0x78/0x30c
[ 1599.996664] sp : ffff8000094d3ad0
[ 1599.999964] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1600.007082] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1600.014201] x23: 0000000938780000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1600.021320] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1600.028436] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1600.035553] x14: 00000000000002f7 x13: 0000000000000000 x12: 0000000000000000
[ 1600.042671] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000094d3980
[ 1600.049790] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1600.056907] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a049c8
[ 1600.064025] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1600.071142] Call trace:
[ 1600.073576] __vunmap+0x78/0x30c
[ 1600.076791] vunmap+0x40/0x5c
[ 1600.079747] dma_direct_free+0x10c/0x110
[ 1600.083658] dma_free_attrs+0x98/0xe0
[ 1600.087307] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1600.092619] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1600.097574] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1600.102876] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1600.107830] v4l2_release+0xbc/0xf0 [videodev]
[ 1600.112287] __fput+0x70/0x250
[ 1600.115332] ____fput+0x10/0x20
[ 1600.118461] task_work_run+0x80/0xe0
[ 1600.122025] do_notify_resume+0x208/0x1280
[ 1600.126111] el0_svc+0x74/0x84
[ 1600.129155] el0t_64_sync_handler+0xbc/0x140
[ 1600.133409] el0t_64_sync+0x18c/0x190
[ 1600.137058] ---[ end trace 0000000000000000 ]---
[ 1600.141720] ------------[ cut here ]------------
[ 1600.146329] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1600.152675] WARNING: CPU: 7 PID: 3336 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1600.159881] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1600.231561] CPU: 7 PID: 3336 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1600.240670] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1600.246310] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1600.253252] pc : __vunmap+0x78/0x30c
[ 1600.256813] lr : __vunmap+0x78/0x30c
[ 1600.260375] sp : ffff8000094d3ad0
[ 1600.263675] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1600.270794] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1600.277911] x23: 0000000938740000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1600.285029] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1600.292147] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1600.299265] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000d59
[ 1600.306384] x11: 0000000000000473 x10: ffff8000092e0018 x9 : ffff800009281550
[ 1600.313502] x8 : 0000000100000473 x7 : ffff8000092d9550 x6 : 0000000000006ac8
[ 1600.320620] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1600.327738] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1600.334856] Call trace:
[ 1600.337289] __vunmap+0x78/0x30c
[ 1600.340504] vunmap+0x40/0x5c
[ 1600.343459] dma_direct_free+0x10c/0x110
[ 1600.347368] dma_free_attrs+0x98/0xe0
[ 1600.351016] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1600.356321] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1600.361276] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1600.366577] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1600.371531] v4l2_release+0xbc/0xf0 [videodev]
[ 1600.375985] __fput+0x70/0x250
[ 1600.379027] ____fput+0x10/0x20
[ 1600.382157] task_work_run+0x80/0xe0
[ 1600.385719] do_notify_resume+0x208/0x1280
[ 1600.389804] el0_svc+0x74/0x84
[ 1600.392845] el0t_64_sync_handler+0xbc/0x140
[ fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1600.495275] CPU: 7 PID: 3336 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1600.504387] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1600.510028] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1600.516970] pc : __vunmap+0x78/0x30c
[ 1600.520533] lr : __vunmap+0x78/0x30c
[ 1600.524095] sp : ffff8000094d3ad0
[ 1600.527395] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1600.534514] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1600.541631] x23: 00000009386c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1600.548748] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1600.555865] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1600.562982] x14: 00000000000002d7 x13: 0000000000000000 x12: 0000000000000000
[ 1600.570099] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000094d3980
[ 1600.577216] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1600.584334] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a049c8
[ 1600.591451] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1600.598568] Call trace:
[ 1600.601002] __vunmap+0x78/0x30c
[ 1600.604218] vunmap+0x40/0x5c
[ 1600.607173] dma_direct_free+0x10c/0x110
[ 1600.611082] dma_free_attrs+0x98/0xe0
[ 1600.614730] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1600.620033] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1600.624988] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1600.630290] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1600.635244] v4l2_release+0xbc/0xf0 [videodev]
[ 1600.639697] __fput+0x70/0x250
[ 1600.642740] ____fput+0x10/0x20
[ 1600.645869] task_work_run+0x80/0xe0
[ 1600.649432] do_notify_resume+0x208/0x1280
[ 1600.653516] el0_svc+0x74/0x84
[ 1600.656557] el0t_64_sync_handler+0xbc/0x140
[ 1600.660813] el0t_64_sync+0x18c/0x190
[ 1600.664461] ---[ end trace 0000000000000000 ]---
[ 1600.669087] ------------[ cut here ]------------
[ 1600x25: 0000000000000000 x24: 0000000000000000
[ 1600.805270] x23: 00000009386a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1600.812389] x20: 0000000000000000 x19: ffff80000c36e000 x18: ffffffffffffffff
[ 1600.819507] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1600.826624] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000e3d
[ 1600.833741] x11: 00000000000004bf x10: ffff8000092e0738 x9 : ffff800009281550
[ 1600.840858] x8 : 00000001000004bf x7 : ffff8000092d9550 x6 : 00000000000071e8
[ 1600.847975] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1600.855092] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1600.862210] Call trace:
[ 1600.864644] __vunmap+0x78/0x30c
[ 1600.867859] vunmap+0x40/0x5c
[ 1600.870814] dma_direct_free+0x10c/0x110
[ 1600.874723] dma_free_attrs+0x98/0xe0
[ 1600.878371] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1600.883675] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1600.888543] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1600.893844] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1600.898798] v4l2_release+0xbc/0xf0 [videodev]
[ 1600.903248] __fput+0x70/0x250
[ 1600.906291] ____fput+0x10/0x20
[ 1600.909420] task_work_run+0x80/0xe0
[ 1600.912983] do_notify_resume+0x208/0x1280
[ 1600.917066] el0_svc+0x74/0x84
[ 1600.920107] el0t_64_sync_handler+0xbc/0x140
[ 1600.924362] el0t_64_sync+0x18c/0x190
[ 1600.928010] ---[ end trace 0000000000000000 ]---
[ 1600.998075] ------------[ cut here ]------------
[ 1601.002701] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1601.009067] WARNING: CPU: 6 PID: 3339 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1601.016282] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1601.087985] CPU: 6 PID: 3339 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1601.097096] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1601.102737] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1601.109680] pc : __vunmap+0x78/0x30c
[ 1601.113243] lr : __vunmap+0x78/0x30c
[ 1601.116803] sp : ffff80000bacbad0
[ 1601.120104] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1601.127223] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1601.134340] x23: 0000000938c80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1601.141458] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1601.148574] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb7b7
[ 1601.155691] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000eaf
[ 1601.162810] x11: 00000000000004e5 x10: ffff8000092e0ac8 x9 : ffff800009281550
[ 1601.169927] x8 : 00000001000004e5 x7 : ffff8000092d9550 x6 : 0000000000007578
[ 1601.177044] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1601.184160] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1601.191278] Call trace:
[ 1601.193713] __vunmap+0x78/0x30c
[ 1601.196928] vunmap+0x40/0x5c
[ 1601.199883] dma_direct_free+0x10c/0x110
[ 1601.203795] dma_free_attrs+0x98/0xe0
[ 1601.207444] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1601.212754] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1601.217709] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1601.22301fo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1601.351853] CPU: 6 PID: 3339 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1601.360965] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1601.366606] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1601.373549] pc : __vunmap+0x78/0x30c
[ 1601.377111] lr : __vunmap+0x78/0x30c
[ 1601.380673] sp : ffff80000bacbad0
[ 1601.383973] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1601.391091] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1601.398208] x23: 00000009387c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1601.405327] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1601.412443] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1601.419560] x14: 0000000000000274 x13: 0000000000000000 x12: 0000000000000000
[ 1601.426678] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bacb980
[ 1601.433795] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1601.440913] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dbf48
[ 1601.448030] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1601.455148] Call trace:
[ 1601.457581] __vunmap+0x78/0x30c
[ 1601.460795] vunmap+0x40/0x5c
[ 1601.463751] dma_direct_free+0x10c/0x110
[ 1601.467661] dma_free_attrs+0x98/0xe0
[ 1601.471310] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1601.476614] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1601.481569] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1601.486870] wave5_vpuarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1601.615523] CPU: 6 PID: 3339 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1601.624632] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1601.630274] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1601.637217] pc : __vunmap+0x78/0x30c
[ 1601.640780] lr : __vunmap+0x78/0x30c
[ 1601.644341] sp : ffff80000bacbad0
[ 1601.647641] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1601.654758] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1601.661876] x23: 0000000938c00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1601.668993] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1601.676109] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bacb7b7
[ 1601.683226] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000f93
[ 1601.690343] x11: 0000000000000531 x10: ffff8000092e11e8 x9 : ffff800009281550
[ 1601.697460] x8 : 0000000100000531 x7 : ffff8000092d9550 x6 : 0000000000007c98
[ 1601.704577] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1601.711693] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1601.718812] Call trace:
[ 1601.721246] __vunmap+0x78/0x30c
[ 1601.724460] vunmap+0x40/0x5c
[ 1601.727415] dma_direct_free+0x10c/0x110
[ 1601.731324] dma_free_attrs+0x98/0xe0
[ 1601.734972] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1601.740276] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1601.745231] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1601.750532] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1601.755486] v4l2_release+0xbc/0xf0 [videodev]
[ 1601.759939] __fput+0x70/0x250
[ 1601.762982] ____fput+0x10/0x20
[ 1601.766111] task_work_run+0x80/0xe0
[ 1601.769673] do_notify_resume+0x208/0x1280
[ 1601.773757] el0_svc+0x74/0x84
[ 1601.776799] el0t_64_sync_handler+0xbc/0x140
[ 1601.781053] el0t_64_sync+0x18c/0x190
[ 1601.784700] ---[ end trace 0000000000000000 ]---
[ 1601.789322] ------------[ cut here ]------------
[ 1601.793933] Trying to el_orientation_quirks ipv6
[ 1601.879226] CPU: 6 PID: 3339 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1601.888336] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1601.893978] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1601.900921] pc : __vunmap+0x78/0x30c
[ 1601.904482] lr : __vunmap+0x78/0x30c
[ 1601.908044] sp : ffff80000bacbad0
[ 1601.911344] x29: ffff80000bacbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1601.918461] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1601.925577] x23: 00000009386e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1601.932694] x20: 0000000000000000 x19: ffff80000c36e000 x18: ffffffffffffffff
[ 1601.939812] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1601.946930] x14: 00000000000001f4 x13: 0000000000000000 x12: 0000000000000000
[ 1601.954048] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bacb980
[ 1601.961166] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1601.968285] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dbf48
[ 1601.975403] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1601.982521] Call trace:
[ 1601.984954] __vunmap+0x78/0x30c
[ 1601.988170] vunmap+0x40/0x5c
[ 1601.991125] dma_direct_free+0x10c/0x110
[ 1601.995035] dma_free_attrs+0x98/0xe0
[ 1601.998682] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1602.003984] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1602.008852] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1602.014153] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1602.019107] v4l2_release+0xbc/0xf0 [videodev]
[ 1602.023559] __fput+0x70/0x250
[ 1602.026602] ____fput+0x10/0x20
[ 1602.029731] task_work_run+0x80/0xe0
[ 1602.033293] do_notify_resume+0x208/0x1280
[ 1602.037377] el0_svc+0x74/0x84
[ 1602.040419] el0t_64_sync_handler+0xbc/0x140
[ 1602.044673] el0t_64_sync+0x18c/0x190
[ 1602.048322] ---[ end trace 0000000000000000 ]---
[ 1602.120428] cma_alloc: 15 callbacks suppressed
[ 1602.120440] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1602.134976] cma: cma_alloc: linux-cma-bu ret: -16
[ 1602.164820] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1602.175345] ------------[ cut here ]------------
[ 1602.179970] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1602.186383] WARNING: CPU: 7 PID: 3342 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1602.193598] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1602.265301] CPU: 7 PID: 3342 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1602.274412] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1602.280053] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1602.286997] pc : __vunmap+0x78/0x30c
[ 1602.290559] lr : __vunmap+0x78/0x30c
[ 1602.294121] sp : ffff80000baebad0
[ 1602.297421] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1602.304539] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1602.311658] x23: 0000000938d00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1602.318776] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1602.325893] x17: 0000000000000000 x16: 0000000000000000 x15: 00000001c199bdd6
[ 1602.333010] x14: 00000000000002c8 x13: 0000000000000000 x12: 0000000000000000
[ 1602.340127] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1602.347245] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1602.354361] x5 : 00000000410190
[ 1602.434521] ---[ end trace 0000000000000000 ]---
[ 1602.439155] ------------[ cut here ]------------
[ 1602.443765] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1602.450114] WARNING: CPU: 7 PID: 3342 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1602.457319] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1602.528996] CPU: 7 PID: 3342 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1602.538106] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1602.543746] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1602.550688] pc : __vunmap+0x78/0x30c
[ 1602.554250] lr : __vunmap+0x78/0x30c
[ 1602.557812] sp : ffff80000baebad0
[ 1602.561112] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1602.568230] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1602.575348] x23: 0000000938cc0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1602.582465] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1602.589582] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1602.596699] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000010fb
[ 1602.603817] x11: 00000000000005a9 x10: ffff8000092e1d28 x9 : ffff800009281550
[ 1602.610934] x8 : 00000001000005a9 x7 : ffff8000092d9550 x6 : 00000000000087d8
[ 1602.618051] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1602.625168] x2 : 000000000000
[ 1602.698185] ---[ end trace 0000000000000000 ]---
[ 1602.702811] ------------[ cut here ]------------
[ 1602.707437] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1602.713785] WARNING: CPU: 7 PID: 3342 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1602.720989] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1602.792666] CPU: 7 PID: 3342 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1602.801776] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1602.807416] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1602.814358] pc : __vunmap+0x78/0x30c
[ 1602.817920] lr : __vunmap+0x78/0x30c
[ 1602.821482] sp : ffff80000baebad0
[ 1602.824782] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1602.831900] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1602.839018] x23: 0000000938c40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1602.846136] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1602.853254] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1602.860372] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000116d
[ 1602.867490] x11: 00000000000005cf x10: ffff8000092e20b8 x9 : ffff800009281550
[ 1602.874606] x8 : 00000001000005cf x7 : ffff8000092d9550 x6 : 0000000000008b68
[ 1602.881724] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1602.888842] x2 : 000000000000000 fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1603.056325] CPU: 7 PID: 3342 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1603.065435] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1603.071075] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1603.078019] pc : __vunmap+0x78/0x30c
[ 1603.081581] lr : __vunmap+0x78/0x30c
[ 1603.085143] sp : ffff80000baebad0
[ 1603.088443] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1603.095561] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1603.102678] x23: 0000000938c20000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1603.109797] x20: 0000000000000000 x19: ffff80000c36e000 x18: ffffffffffffffff
[ 1603.116915] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1603.124033] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000011df
[ 1603.131151] x11: 00000000000005f5 x10: ffff8000092e2448 x9 : ffff800009281550
[ 1603.138269] x8 : 00000001000005f5 x7 : ffff8000092d9550 x6 : 0000000000008ef8
[ 1603.145387] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1603.152503] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1603.159621] Call trace:
[ 1603.162055] __vunmap+0x78/0x30c
[ 1603.165270] vunmap+0x40/0x5c
[ 1603.168226] dma_direct_free+0x10c/0x110
[ 1603.172135] dma_free_attrs+0x98/0xe0
[ 1603.175783] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1603.181085] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1603.185953] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1603.191254] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1603.196208] v4l2_release+0xbc/0xf0 [videodev]
[ 1603.200660] __fput+0x70/0x250
[ 1603.203704] ____fput+0x10/0x20
[ 1603.206833] task_work_run+0x80/0xe0
[ 1603.210395] do_notify_resume+0x208/0x1280
[ 1603.214478] el0_svc+0x74/0x84
[ 1603.217520] el0t_64_sync_handler+0xbc/0x140
[ 1603.221775] el0t_64_sync+0x18c/0x190
[ 1603.225423] ---[ end trace 0000000000000000 ]---
[ 1603.291635] cma: cma_alloc: linux-cma-buffers@98000000ux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1603.428457] CPU: 7 PID: 3346 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1603.437656] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1603.443297] Call trace:
[ 1603.445730] dump_backtrace.part.0+0xdc/0xf0
[ 1603.449997] show_stack+0x18/0x30
[ 1603.453300] dump_stack_lvl+0x68/0x84
[ 1603.456953] dump_stack+0x18/0x34
[ 1603.460256] bad_page+0xe8/0x110
[ 1603.463473] check_new_pages+0xe0/0x110
[ 1603.467294] get_page_from_freelist+0x574/0xf10
[ 1603.471811] __alloc_pages+0x134/0xcec
[ 1603.475547] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1603.481277] dma_direct_alloc+0xd8/0x304
[ 1603.485186] dma_alloc_attrs+0x7c/0xe4
[ 1603.488922] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1603.494580] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1603.500835] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1603.507177] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1603.512652] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1603.518303] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1603.523173] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1603.528825] v4l_reqbufs+0x50/0x64 [videodev]
[ 1603.533193] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1603.538164] video_usercopy+0x214/0x6c4 [videodev]
[ 1603.542960] video_ioctl2+0x18/0x2c [videodev]
[ 1603.547410] v4l2_ioctl+0x40/0x60 [videodev]
[ 1603.551686] __arm64_sys_ioctl+0xa8/0xf0
[ 1603.555596] invoke_syscall+0x48/0x114
[ 1603.559334] el0_svc_common.constprop.0+0xd4/0xfc
[ 1603.564023] do_el0_svc+0x30/0xd0
[ 1603.567325] el0_svc+0x2c/0x84
[ 1603.570367] el0t_64_sync_handler+0xbc/0x140
[ 1603.574622] el0t_64_sync+0x18c/0x190
[ 1603.578291] BUG: Bs_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1603.690564] CPU: 7 PID: 3346 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1603.699761] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1603.705401] Call trace:
[ 1603.707834] dump_backtrace.part.0+0xdc/0xf0
[ 1603.712092] show_stack+0x18/0x30
[ 1603.715395] dump_stack_lvl+0x68/0x84
[ 1603.719045] dump_stack+0x18/0x34
[ 1603.722349] bad_page+0xe8/0x110
[ 1603.725565] check_new_pages+0xe0/0x110
[ 1603.729386] get_page_from_freelist+0x574/0xf10
[ 1603.733902] __alloc_pages+0x134/0xcec
[ 1603.737638] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1603.743368] dma_direct_alloc+0xd8/0x304
[ 1603.747277] dma_alloc_attrs+0x7c/0xe4
[ 1603.751012] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1603.756662] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1603.762916] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1603.769257] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1603.774731] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1603.780380] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1603.785248] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1603.790897] v4l_reqbufs+0x50/0x64 [videodev]
[ 1603.795262] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1603.800232] video_usercopy+0x214/0x6c4 [videodev]
[ 1603.805028] video_ioctl2+0x18/0x2c [videodev]
[ 1603.809477] v4l2_ioctl+0x40/0x60 [videodev]
[ 1603.813752] __arm64_sys_ioctl+0xa8/0xf0
[ 1603.817661] invoke_syscall+0x48/0x114
[ 1603.821397] el0_svc_common.constprop.0+0xd4/0xfc
[ 1603.826086] do_el0_svc+0x30/0xd0
[ 1603.829388] el0_svc+0x2c/0x84
[ 1603.832429] el0t_64_sync_handler+0xbc/0x140
[ 1603.836684] el0t_64_sync+0x18c/0x190
[ 1603.840349] BUG: Bad page state in process videotestsrc0:s pfn:938d00
[ 1603.846866] page:000000009b9982ca refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938d00
[ 1603.856329] flags: 0x8000000000000000(zone=2)
[ 1603.860679] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1603.8 6.1.33-g8f7f371be2 #1
[ 1603.961823] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1603.967466] Call trace:
[ 1603.969899] dump_backtrace.part.0+0xdc/0xf0
[ 1603.974157] show_stack+0x18/0x30
[ 1603.977460] dump_stack_lvl+0x68/0x84
[ 1603.981111] dump_stack+0x18/0x34
[ 1603.984415] bad_page+0xe8/0x110
[ 1603.987629] check_new_pages+0xe0/0x110
[ 1603.991451] get_page_from_freelist+0x574/0xf10
[ 1603.995967] __alloc_pages+0x134/0xcec
[ 1603.999703] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1604.005433] dma_direct_alloc+0xd8/0x304
[ 1604.009342] dma_alloc_attrs+0x7c/0xe4
[ 1604.013078] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1604.018727] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1604.024981] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1604.031323] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1604.036797] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1604.042445] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1604.047313] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1604.052963] v4l_reqbufs+0x50/0x64 [videodev]
[ 1604.057328] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1604.062298] video_usercopy+0x214/0x6c4 [videodev]
[ 1604.067094] video_ioctl2+0x18/0x2c [videodev]
[ 1604.071543] v4l2_ioctl+0x40/0x60 [videodev]
[ 1604.075820] __arm64_sys_ioctl+0xa8/0xf0
[ 1604.079728] invoke_syscall+0x48/0x114
[ 1604.083464] el0_svc_common.constprop.0+0xd4/0xfc
[ 1604.088153] do_el0_svc+0x30/0xd0
[ 1604.091455] el0_svc+0x2c/0x84
[ 1604.094496] el0t_64_sync_handler+0xbc/0x140
[ 1604.098751] el0t_64_sync+0x18c/0x190
[ 1604.102416] BUG: Bad page state in process videotestsrc0:s pfn:938d40
[ 1604.108932] page:000000000d0158c0 refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938d40
[ 1604.118310] flags: 0x8000000000000000(zone=2)
[ 1604.122660] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1604.130389] raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
[ 1604.138116] page dumped because: nonzero _refcount
[ 1604.142896] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx pae5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1604.286944] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1604.293284] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1604.298759] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1604.304408] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1604.309277] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1604.314926] v4l_reqbufs+0x50/0x64 [videodev]
[ 1604.319293] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1604.324263] video_usercopy+0x214/0x6c4 [videodev]
[ 1604.329058] video_ioctl2+0x18/0x2c [videodev]
[ 1604.333508] v4l2_ioctl+0x40/0x60 [videodev]
[ 1604.337784] __arm64_sys_ioctl+0xa8/0xf0
[ 1604.341692] invoke_syscall+0x48/0x114
[ 1604.345429] el0_svc_common.constprop.0+0xd4/0xfc
[ 1604.350119] do_el0_svc+0x30/0xd0
[ 1604.353421] el0_svc+0x2c/0x84
[ 1604.356462] el0t_64_sync_handler+0xbc/0x140
[ 1604.360717] el0t_64_sync+0x18c/0x190
[ 1604.366836] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1604.376442] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1604.385653] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1604.395998] ------------[ cut here ]------------
[ 1604.400617] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1604.406974] WARNING: CPU: 6 PID: 3345 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1604.414184] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rn68] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1604.589187] Call trace:
[ 1604.591625] __vunmap+0x78/0x30c
[ 1604.594840] vunmap+0x40/0x5c
[ 1604.597796] dma_direct_free+0x10c/0x110
[ 1604.601722] dma_free_attrs+0x98/0xe0
[ 1604.605370] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1604.610678] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1604.615633] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1604.620935] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1604.625889] v4l2_release+0xbc/0xf0 [videodev]
[ 1604.630344] __fput+0x70/0x250
[ 1604.633387] ____fput+0x10/0x20
[ 1604.636517] task_work_run+0x80/0xe0
[ 1604.640081] do_notify_resume+0x208/0x1280
[ 1604.644165] el0_svc+0x74/0x84
[ 1604.647207] el0t_64_sync_handler+0xbc/0x140
[ 1604.651462] el0t_64_sync+0x18c/0x190
[ 1604.655110] ---[ end trace 0000000000000000 ]---
[ 1604.659738] ------------[ cut here ]------------
[ 1604.664346] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1604.670691] WARNING: CPU: 6 PID: 3345 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1604.677897] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1604.749574] CPU: 6 PID: 3345 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1604.758684] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1604.764324] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1604.771267] pc : __vunmap+0x78/0x30c
[ 1604.774829] lr : __v4/0x18c [wave5]
[ 1604.879292] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1604.884592] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1604.889547] v4l2_release+0xbc/0xf0 [videodev]
[ 1604.893999] __fput+0x70/0x250
[ 1604.897043] ____fput+0x10/0x20
[ 1604.900172] task_work_run+0x80/0xe0
[ 1604.903735] do_notify_resume+0x208/0x1280
[ 1604.907819] el0_svc+0x74/0x84
[ 1604.910859] el0t_64_sync_handler+0xbc/0x140
[ 1604.915114] el0t_64_sync+0x18c/0x190
[ 1604.918762] ---[ end trace 0000000000000000 ]---
[ 1604.923387] ------------[ cut here ]------------
[ 1604.928008] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1604.934354] WARNING: CPU: 6 PID: 3345 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1604.941559] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1605.013235] CPU: 6 PID: 3345 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1605.022344] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1605.027985] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1605.034928] pc : __vunmap+0x78/0x30c
[ 1605.038490] lr : __vunmap+0x78/0x30c
[ 1605.042051] sp : ffff80000ba8bad0
[ 1605.045351] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1605.052469] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1605.059588] x23: 0000000938d80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1605.066705] x20: 0000000000000000 x19: ffff80000c715000 5.163829] task_work_run+0x80/0xe0
[ 1605.167392] do_notify_resume+0x208/0x1280
[ 1605.171478] el0_svc+0x74/0x84
[ 1605.174520] el0t_64_sync_handler+0xbc/0x140
[ 1605.178776] el0t_64_sync+0x18c/0x190
[ 1605.182423] ---[ end trace 0000000000000000 ]---
[ 1605.187057] ------------[ cut here ]------------
[ 1605.191665] Trying to vfree() nonexistent vm area (000000008a4148f5)
[ 1605.198011] WARNING: CPU: 6 PID: 3345 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1605.205215] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1605.276890] CPU: 6 PID: 3345 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1605.286000] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1605.291641] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1605.298582] pc : __vunmap+0x78/0x30c
[ 1605.302144] lr : __vunmap+0x78/0x30c
[ 1605.305705] sp : ffff80000ba8bad0
[ 1605.309005] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1605.316123] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1605.323241] x23: 0000000938c60000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1605.330359] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1605.337475] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1605.344593] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001599
[ 1605.351711] x11: 0000000000000733 x10: ffff8000092e4218 x9 : ffff8
[ 1605.520131] BUG: Bad page state in process videotestsrc0:s pfn:938d40
[ 1605.526663] page:000000000d0158c0 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938d40
[ 1605.536133] flags: 0x8000000000000000(zone=2)
[ 1605.540491] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1605.548222] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1605.555952] page dumped because: nonzero _refcount
[ 1605.560739] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1605.632461] CPU: 0 PID: 3349 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1605.641660] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1605.647301] Call trace:
[ 1605.649735] dump_backtrace.part.0+0xdc/0xf0
[ 1605.654004] show_stack+0x18/0x30
[ 1605.657308] dump_stack_lvl+0x68/0x84
[ 1605.660961] dump_stack+0x18/0x34
[ 1605.664265] bad_page+0xe8/0x110
[ 1605.667482] check_new_pages+0xe0/0x110
[ 1605.671305] get_page_from_freelist+0x574/0xf10
[ 1605.675822] __alloc_pages+0x134/0xcec
[ 1605.679559] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1605.685291] dma_direct_alloc+0xd8/0x304
[ 1605.689199] dma_alloc_attrs+0x7c/0xe4
[ 1605.692935] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wa0x214/0x6c4 [videodev]
[ 1605.746974] video_ioctl2+0x18/0x2c [videodev]
[ 1605.751424] v4l2_ioctl+0x40/0x60 [videodev]
[ 1605.755700] __arm64_sys_ioctl+0xa8/0xf0
[ 1605.759610] invoke_syscall+0x48/0x114
[ 1605.763348] el0_svc_common.constprop.0+0xd4/0xfc
[ 1605.768039] do_el0_svc+0x30/0xd0
[ 1605.771341] el0_svc+0x2c/0x84
[ 1605.774384] el0t_64_sync_handler+0xbc/0x140
[ 1605.778639] el0t_64_sync+0x18c/0x190
[ 1605.782320] BUG: Bad page state in process videotestsrc0:s pfn:938d80
[ 1605.788843] page:00000000b2563c22 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938d80
[ 1605.798308] flags: 0x8000000000000000(zone=2)
[ 1605.802662] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1605.810392] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1605.818122] page dumped because: nonzero _refcount
[ 1605.822904] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1605.894602] CPU: 0 PID: 3349 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1605.903799] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1605.909440] Call trace:
[ 1605.911873] dump_backtrace.part.0+0xdc/0xf0
[ 1605.916130] show_stack+0x18/0x30
[ 1605.919433] dump_stack_lvl+0x68/0x84
[ 1605.923084] dump_stack+0x18/0x34
[ 1605.926387] bad_page+0xe8/0x110
[ 1605.929603] check_new_pages+0xe0/0x110
[ 1605.933424] get_page_from_freelist+0x574/0xf10
[ 1605.93n process videotestsrc0:s pfn:938e00
[ 1606.054050] page:0000000049171f39 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938e00
[ 1606.063517] flags: 0x8000000000000000(zone=2)
[ 1606.067869] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1606.075599] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1606.083328] page dumped because: nonzero _refcount
[ 1606.088111] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1606.159810] CPU: 0 PID: 3349 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1606.169007] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1606.174648] Call trace:
[ 1606.177081] dump_backtrace.part.0+0xdc/0xf0
[ 1606.181340] show_stack+0x18/0x30
[ 1606.184643] dump_stack_lvl+0x68/0x84
[ 1606.188294] dump_stack+0x18/0x34
[ 1606.191597] bad_page+0xe8/0x110
[ 1606.194812] check_new_pages+0xe0/0x110
[ 1606.198634] get_page_from_freelist+0x574/0xf10
[ 1606.203151] __alloc_pages+0x134/0xcec
[ 1606.206886] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1606.212616] dma_direct_alloc+0xd8/0x304
[ 1606.216524] dma_alloc_attrs+0x7c/0xe4
[ 1606.220259] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1606.225909] wave5_vpu_enc_register_framebuffer+0x274/0x6f0 [wave5]
[ 1606.232164] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1606.238506] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5si2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1606.401030] CPU: 7 PID: 3348 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1606.410143] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1606.415785] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1606.422729] pc : __vunmap+0x78/0x30c
[ 1606.426291] lr : __vunmap+0x78/0x30c
[ 1606.429852] sp : ffff80000c33bad0
[ 1606.433152] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1606.440272] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1606.447390] x23: 0000000938e80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1606.454508] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1606.461626] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1606.468743] x14: 00000000000003bc x13: 0000000000000000 x12: 0000000000000000
[ 1606.475860] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c33b980
[ 1606.482978] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1606.490095] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a018c8
[ 1606.497213] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1606.504331] Call trace:
[ 1606.506765] __vunmap+0x78/0x30c
[ 1606.509981] vunmap+0x40/0x5c
[ 1606.512936] dma_direct_free+0x10c/0x110
[ 1606.516848] dma_free_attrs+0x98/0xe0
[ 1606.520496] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1606.525806] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1606.530760] wave5j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1606.664705] CPU: 7 PID: 3348 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1606.673815] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1606.679456] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1606.686398] pc : __vunmap+0x78/0x30c
[ 1606.689959] lr : __vunmap+0x78/0x30c
[ 1606.693520] sp : ffff80000c33bad0
[ 1606.696820] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1606.703938] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1606.711057] x23: 0000000938e40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1606.718174] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1606.725291] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1606.732409] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000017e5
[ 1606.739526] x11: 00000000000007f7 x10: ffff8000092e5478 x9 : ffff800009281550
[ 1606.746643] x8 : 00000001000007f7 x7 : ffff8000092d9550 x6 : 000000000000bf28
[ 1606.753761] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1606.760879] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1606.767996] Call trace:
[ 1606.770429] __vunmap+0x78/0x30c
[ 1606.773645] vunmap+0x40/0x5c
[ 1606.776600] dma_direct_free+0x10c/0x110
[ 1606.780510] dma_free_attrs+0x98/0xe0
[ 1606.784158] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1606.789461] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1606.794415] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1606.799716] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1606.804 pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1606.928362] CPU: 7 PID: 3348 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1606.937472] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1606.943114] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1606.950056] pc : __vunmap+0x78/0x30c
[ 1606.953618] lr : __vunmap+0x78/0x30c
[ 1606.957178] sp : ffff80000c33bad0
[ 1606.960477] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1606.967596] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1606.974713] x23: 0000000938dc0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1606.981831] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1606.988949] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1606.996066] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001857
[ 1607.003183] x11: 000000000000081d x10: ffff8000092e5808 x9 : ffff800009281550
[ 1607.010301] x8 : 000000010000081d x7 : ffff8000092d9550 x6 : 000000000000c2b8
[ 1607.017419] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1607.024538] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1607.031656] Call trace:
[ 1607.034088] __vunmap+0x78/0x30c
[ 1607.037302] vunmap+0x40/0x5c
[ 1607.040258] dma_direct_free+0x10c/0x110
[ 1607.044166] dma_free_attrs+0x98/0xe0
[ 1607.047816] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1607.053118] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1607.058073] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1607.063374] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1607.068328] v4l2_release+0xbc/0xf0 [videodev]
[ 1607.072779] __fput+0x70/0x250
[ 1607.075822] ____fput+0x10/0x20
[ 1607.078952] task_work_run+0x80/0xe0
[ 1607.082514] do_notify_resume+0x208/0x1280
[ 1607.086598] el0_svc+0x74/0x84
[ 1607.089640] el0t_64_sync_handler+0xbc/0x140
[ 1607.093894] el0t_64_sync+0x18c/0x190
[ 1607.097543] ---[ end trace 0000000000000000 ]---
[ 1607.102177] ------------[ cut here ]------------
[ 1607.106784] Trying to vfree() ns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1607.192009] CPU: 7 PID: 3348 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1607.201119] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1607.206759] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1607.213702] pc : __vunmap+0x78/0x30c
[ 1607.217262] lr : __vunmap+0x78/0x30c
[ 1607.220824] sp : ffff80000c33bad0
[ 1607.224123] x29: ffff80000c33bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1607.231240] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1607.238358] x23: 0000000938da0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1607.245475] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1607.252592] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c33b7b7
[ 1607.259710] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000018c9
[ 1607.266827] x11: 0000000000000843 x10: ffff8000092e5b98 x9 : ffff800009281550
[ 1607.273944] x8 : 0000000100000843 x7 : ffff8000092d9550 x6 : 000000000000c648
[ 1607.281062] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1607.288179] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1607.295297] Call trace:
[ 1607.297731] __vunmap+0x78/0x30c
[ 1607.300946] vunmap+0x40/0x5c
[ 1607.303901] dma_direct_free+0x10c/0x110
[ 1607.307809] dma_free_attrs+0x98/0xe0
[ 1607.311457] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1607.316759] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1607.321627] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1607.326928] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1607.331882] v4l2_release+0xbc/0xf0 [videodev]
[ 1607.336334] __fput+0x70/0x250
[ 1607.339379] ____fput+0x10/0x20
[ 1607.342508] task_work_run+0x80/0xe0
[ 1607.346070] do_notify_resume+0x208/0x1280
[ 1607.350153] el0_svc+0x74/0x84
[ 1607.353195] el0t_64_sync_handler+0xbc/0x140
[ 1607.357450] el0t_64_sync+0x18c/0x190
[ 1607.361097] ---[ end trace 0000000000000000 ]---
[ 1607.427169] cma_alloc: 5 callbacks suppressed
[ 1607.427179] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1607deotestsrc0:s pfn:938dc0
[ 1607.457180] page:00000000c68ae93a refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938dc0
[ 1607.466646] flags: 0x8000000000000000(zone=2)
[ 1607.471000] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1607.478730] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1607.486459] page dumped because: nonzero _refcount
[ 1607.491238] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1607.562957] CPU: 7 PID: 3352 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1607.572157] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1607.577799] Call trace:
[ 1607.580233] dump_backtrace.part.0+0xdc/0xf0
[ 1607.584501] show_stack+0x18/0x30
[ 1607.587804] dump_stack_lvl+0x68/0x84
[ 1607.591457] dump_stack+0x18/0x34
[ 1607.594759] bad_page+0xe8/0x110
[ 1607.597976] check_new_pages+0xe0/0x110
[ 1607.601798] get_page_from_freelist+0x574/0xf10
[ 1607.606315] __alloc_pages+0x134/0xcec
[ 1607.610051] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1607.615781] dma_direct_alloc+0xd8/0x304
[ 1607.619690] dma_alloc_attrs+0x7c/0xe4
[ 1607.623425] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1607.629083] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1607.635338] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1607.641680] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1607.647155] v0 0000000000000000 ffffffffffffffff 0000000000000000
[ 1607.748584] page dumped because: nonzero _refcount
[ 1607.753363] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1607.825061] CPU: 7 PID: 3352 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1607.834257] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1607.839898] Call trace:
[ 1607.842331] dump_backtrace.part.0+0xdc/0xf0
[ 1607.846589] show_stack+0x18/0x30
[ 1607.849892] dump_stack_lvl+0x68/0x84
[ 1607.853542] dump_stack+0x18/0x34
[ 1607.856844] bad_page+0xe8/0x110
[ 1607.860059] check_new_pages+0xe0/0x110
[ 1607.863882] get_page_from_freelist+0x574/0xf10
[ 1607.868398] __alloc_pages+0x134/0xcec
[ 1607.872134] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1607.877863] dma_direct_alloc+0xd8/0x304
[ 1607.881771] dma_alloc_attrs+0x7c/0xe4
[ 1607.885506] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1607.891156] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1607.897411] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1607.903751] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1607.909226] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1607.914876] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1607.919745] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1607.925395] v4l_reqbufs+0x50/0x64 [videodev]
[ 1607.929762] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1607.934732] video_usercopy+0aw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1608.002921] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1608.010647] page dumped because: nonzero _refcount
[ 1608.015427] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1608.087119] CPU: 7 PID: 3352 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1608.096315] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1608.101956] Call trace:
[ 1608.104389] dump_backtrace.part.0+0xdc/0xf0
[ 1608.108645] show_stack+0x18/0x30
[ 1608.111949] dump_stack_lvl+0x68/0x84
[ 1608.115600] dump_stack+0x18/0x34
[ 1608.118903] bad_page+0xe8/0x110
[ 1608.122118] check_new_pages+0xe0/0x110
[ 1608.125940] get_page_from_freelist+0x574/0xf10
[ 1608.130457] __alloc_pages+0x134/0xcec
[ 1608.134192] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1608.139923] dma_direct_alloc+0xd8/0x304
[ 1608.143831] dma_alloc_attrs+0x7c/0xe4
[ 1608.147566] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1608.153216] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1608.159470] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1608.165812] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1608.171286] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1608.176936] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1608.181804] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1608.187454] v4l_reqbufs+0x50/0x000000000000
[ 1608.264883] raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
[ 1608.272612] page dumped because: nonzero _refcount
[ 1608.277391] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1608.349092] CPU: 7 PID: 3352 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1608.358288] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1608.363929] Call trace:
[ 1608.366362] dump_backtrace.part.0+0xdc/0xf0
[ 1608.370621] show_stack+0x18/0x30
[ 1608.373924] dump_stack_lvl+0x68/0x84
[ 1608.377575] dump_stack+0x18/0x34
[ 1608.380878] bad_page+0xe8/0x110
[ 1608.384095] check_new_pages+0xe0/0x110
[ 1608.387917] get_page_from_freelist+0x574/0xf10
[ 1608.392434] __alloc_pages+0x134/0xcec
[ 1608.396169] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1608.401899] dma_direct_alloc+0xd8/0x304
[ 1608.405807] dma_alloc_attrs+0x7c/0xe4
[ 1608.409542] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1608.415193] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1608.421448] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1608.427790] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1608.433263] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1608.438914] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1608.443782] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1608.449433] v4l_reqbufs+0x50/0x64 [videodev]
[ 1608.453801] __video_do_ioctl+0x184/0x3elper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1608.620357] CPU: 6 PID: 3351 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1608.629468] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1608.635109] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1608.642052] pc : __vunmap+0x78/0x30c
[ 1608.645614] lr : __vunmap+0x78/0x30c
[ 1608.649176] sp : ffff8000094d3ad0
[ 1608.652476] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1608.659594] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1608.666712] x23: 0000000938f80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1608.673830] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1608.680947] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1608.688065] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001b2d
[ 1608.695182] x11: 000000000000090f x10: ffff8000092e6eb8 x9 : ffff800009281550
[ 1608.702299] x8 : 000000010000090f x7 : ffff8000092d9550 x6 : 000000000000d968
[ 1608.709416] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1608.716533] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1608.723651] Call trace:
[ 1608.726085] __vunmap+0x78/0x30c
[ 1608.729301] vunmap+0x40/0x5c
[ 1608.732256] dma_direct_free+0x10c/0x110
[ 1608.736165] dma_free_attrs+0x98/0xe0
[ 1608.739814] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1608.745122] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1608.750078] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1608.755379] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1608.760333] v4l2_release+0xbc/0xf0 [videodev]
[ 1608.764787] __fput+0x70/0x250
[ 1608.767833] ____fput+0x10/0x20
[ 1608.770962] task_work_run+0x80/0xe0
[ 1608.774593152] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1608.898793] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1608.905736] pc : __vunmap+0x78/0x30c
[ 1608.909299] lr : __vunmap+0x78/0x30c
[ 1608.912861] sp : ffff8000094d3ad0
[ 1608.916161] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1608.923279] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1608.930396] x23: 0000000938ec0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1608.937514] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1608.944631] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1608.951749] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001b9f
[ 1608.958868] x11: 0000000000000935 x10: ffff8000092e7248 x9 : ffff800009281550
[ 1608.965985] x8 : 0000000100000935 x7 : ffff8000092d9550 x6 : 000000000000dcf8
[ 1608.973103] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1608.980220] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1608.987338] Call trace:
[ 1608.989771] __vunmap+0x78/0x30c
[ 1608.992988] vunmap+0x40/0x5c
[ 1608.995943] dma_direct_free+0x10c/0x110
[ 1608.999852] dma_free_attrs+0x98/0xe0
[ 1609.003500] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1609.008808] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1609.013763] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1609.019064] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1609.024020] v4l2_release+0xbc/0xf0 [videodev]
[ 1609.028474] __fput+0x70/0x250
[ 1609.031519] ____fput+0x10/0x20
[ 1609.034649] task_work_run+0x80/0xe0
[ 1609.038211] do_notify_resume+0x208/0x1280
[ 1609.042296] el0_svc+0x74/0x84
[ 1609.045339] el0t_64_sync_handler+0xbc/0x140
[ 1609.049595] el0t_64_sync+0x18c/0x190
[ 1609.053244] ---[ end trace 0000000000000000 ]---
[ 1609.057879] ------------[ cut here ]------------
[ 1609.062492] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1609.068844] WARNING: CPU: 6 PID: 3351 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1609.076050] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fw5: ffff8000894d37b7
[ 1609.215441] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001c11
[ 1609.222559] x11: 000000000000095b x10: ffff8000092e75d8 x9 : ffff800009281550
[ 1609.229678] x8 : 000000010000095b x7 : ffff8000092d9550 x6 : 000000000000e088
[ 1609.236796] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1609.243914] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1609.251032] Call trace:
[ 1609.253464] __vunmap+0x78/0x30c
[ 1609.256679] vunmap+0x40/0x5c
[ 1609.259634] dma_direct_free+0x10c/0x110
[ 1609.263543] dma_free_attrs+0x98/0xe0
[ 1609.267191] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1609.272494] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1609.277448] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1609.282749] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1609.287703] v4l2_release+0xbc/0xf0 [videodev]
[ 1609.292157] __fput+0x70/0x250
[ 1609.295201] ____fput+0x10/0x20
[ 1609.298330] task_work_run+0x80/0xe0
[ 1609.301892] do_notify_resume+0x208/0x1280
[ 1609.305976] el0_svc+0x74/0x84
[ 1609.309019] el0t_64_sync_handler+0xbc/0x140
[ 1609.313274] el0t_64_sync+0x18c/0x190
[ 1609.316921] ---[ end trace 0000000000000000 ]---
[ 1609.321544] ------------[ cut here ]------------
[ 1609.326152] Trying to vfree() nonexistent vm area (000000008a4148f5)
[ 1609.332501] WARNING: CPU: 6 PID: 3351 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1609.339705] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1609.536139] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1609.541008] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1609.546308] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1609.551263] v4l2_release+0xbc/0xf0 [videodev]
[ 1609.555716] __fput+0x70/0x250
[ 1609.558760] ____fput+0x10/0x20
[ 1609.561889] task_work_run+0x80/0xe0
[ 1609.565451] do_notify_resume+0x208/0x1280
[ 1609.569536] el0_svc+0x74/0x84
[ 1609.572578] el0t_64_sync_handler+0xbc/0x140
[ 1609.576832] el0t_64_sync+0x18c/0x190
[ 1609.580480] ---[ end trace 0000000000000000 ]---
[ 1609.645610] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1609.655688] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1609.664729] BUG: Bad page state in process videotestsrc0:s pfn:938ec0
[ 1609.671252] page:00000000a362fc80 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938ec0
[ 1609.680717] flags: 0x8000000000000000(zone=2)
[ 1609.685069] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1609.692797] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1609.700522] page dumped because: nonzero _refcount
[ 1609.705301] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1609.777020] CPU: 7 PID: 3355 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1609.78alloc_pages+0x134/0xcec
[ 1609.824121] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1609.829852] dma_direct_alloc+0xd8/0x304
[ 1609.833761] dma_alloc_attrs+0x7c/0xe4
[ 1609.837497] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1609.843155] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1609.849409] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1609.855750] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1609.861225] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1609.866877] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1609.871748] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1609.877399] v4l_reqbufs+0x50/0x64 [videodev]
[ 1609.881767] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1609.886737] video_usercopy+0x214/0x6c4 [videodev]
[ 1609.891533] video_ioctl2+0x18/0x2c [videodev]
[ 1609.895983] v4l2_ioctl+0x40/0x60 [videodev]
[ 1609.900259] __arm64_sys_ioctl+0xa8/0xf0
[ 1609.904169] invoke_syscall+0x48/0x114
[ 1609.907907] el0_svc_common.constprop.0+0xd4/0xfc
[ 1609.912596] do_el0_svc+0x30/0xd0
[ 1609.915899] el0_svc+0x2c/0x84
[ 1609.918941] el0t_64_sync_handler+0xbc/0x140
[ 1609.923196] el0t_64_sync+0x18c/0x190
[ 1609.926865] BUG: Bad page state in process videotestsrc0:s pfn:938f00
[ 1609.933382] page:00000000ccc38c18 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938f00
[ 1609.942846] flags: 0x8000000000000000(zone=2)
[ 1609.947194] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1609.954921] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1609.962647] page dumped because: nonzero _refcount
[ 1609.967426] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpm+0x40/0xb0 [wave5]
[ 1610.105224] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1610.111479] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1610.117820] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1610.123294] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1610.128943] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1610.133812] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1610.139461] v4l_reqbufs+0x50/0x64 [videodev]
[ 1610.143827] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1610.148797] video_usercopy+0x214/0x6c4 [videodev]
[ 1610.153593] video_ioctl2+0x18/0x2c [videodev]
[ 1610.158043] v4l2_ioctl+0x40/0x60 [videodev]
[ 1610.162320] __arm64_sys_ioctl+0xa8/0xf0
[ 1610.166228] invoke_syscall+0x48/0x114
[ 1610.169965] el0_svc_common.constprop.0+0xd4/0xfc
[ 1610.174653] do_el0_svc+0x30/0xd0
[ 1610.177956] el0_svc+0x2c/0x84
[ 1610.180997] el0t_64_sync_handler+0xbc/0x140
[ 1610.185252] el0t_64_sync+0x18c/0x190
[ 1610.191356] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1610.200931] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1610.209967] BUG: Bad page state in process videotestsrc0:s pfn:938f80
[ 1610.216484] page:00000000e5db4851 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938f80
[ 1610.225947] flags: 0x8000000000000000(zone=2)
[ 1610.230296] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1610.238023] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1610.245749] page dumped because: nonzero _refcount
[ 1610.250528] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfx3dc/0x42c [wave5]
[ 1610.406403] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1610.412053] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1610.416922] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1610.422573] v4l_reqbufs+0x50/0x64 [videodev]
[ 1610.426938] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1610.431909] video_usercopy+0x214/0x6c4 [videodev]
[ 1610.436705] video_ioctl2+0x18/0x2c [videodev]
[ 1610.441155] v4l2_ioctl+0x40/0x60 [videodev]
[ 1610.445431] __arm64_sys_ioctl+0xa8/0xf0
[ 1610.449340] invoke_syscall+0x48/0x114
[ 1610.453077] el0_svc_common.constprop.0+0xd4/0xfc
[ 1610.457767] do_el0_svc+0x30/0xd0
[ 1610.461069] el0_svc+0x2c/0x84
[ 1610.464110] el0t_64_sync_handler+0xbc/0x140
[ 1610.468365] el0t_64_sync+0x18c/0x190
[ 1610.472237] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1610.482560] ------------[ cut here ]------------
[ 1610.487175] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1610.493535] WARNING: CPU: 6 PID: 3354 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1610.500744] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1610.572434] CPU: 6 PID: 3354 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1610.581544] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1610.587185] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1610.594128] pc : __vunmap+0x78/0x30c
[ 1610.597690] lr : __vux78/0x30c
[ 1610.681385] vunmap+0x40/0x5c
[ 1610.684343] dma_direct_free+0x10c/0x110
[ 1610.688253] dma_free_attrs+0x98/0xe0
[ 1610.691901] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1610.697209] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1610.702164] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1610.707465] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1610.712419] v4l2_release+0xbc/0xf0 [videodev]
[ 1610.716875] __fput+0x70/0x250
[ 1610.719919] ____fput+0x10/0x20
[ 1610.723049] task_work_run+0x80/0xe0
[ 1610.726611] do_notify_resume+0x208/0x1280
[ 1610.730696] el0_svc+0x74/0x84
[ 1610.733739] el0t_64_sync_handler+0xbc/0x140
[ 1610.737994] el0t_64_sync+0x18c/0x190
[ 1610.741642] ---[ end trace 0000000000000000 ]---
[ 1610.746266] ------------[ cut here ]------------
[ 1610.750875] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1610.757222] WARNING: CPU: 6 PID: 3354 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1610.764427] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1610.836104] CPU: 6 PID: 3354 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1610.845213] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1610.850854] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1610.857796] pc : __vunmap+0x78/0x30c
[ 1610.861358] lr : __vunmap+0x78/0x30c
[ 1610.864919] sp : ffff80000baebad0
[ 1610.868219] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1610.875336] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1610.882453] x23: 0000000938fc0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1610.889570] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1610.896688] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1610.903806] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001ede
[ 1610.910924] x11: 0000000000000a4a x10: ffff8000092e8c40 x9 : ffff800009281550
[ 1610.918042] x8 : 0000000100000a4a x7 : ffff8000092d9550 x6 : 000000000000f6f0
[ 1610.925159] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1610.932277] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1610.939395] Call trace:
[ 1610.941827] __vunmap+0x78/0x30c
[ 1610.945041] vunmap+0x40/0x5c
[ 1610.947997] dma_direct_free+0x10c/0x110
[ 1610.951906] dma_free_attrs+0x98/0xe0
[ 1610.955554] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1610.960857] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1610.965812] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1610.971113] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1610.976067] v4l2_release+0xbc/0xf0 [videodev]
[ 1610.980518] __fput+0x70/0x250
[ 1610.983561] ____fput+0x10/0x20
[ 1610.986690] task_work_run+0x80/0xe0
[ 1610.990252] do_notify_resume+0x208/0x1280
[ 1610.994335] el0_svc+0x74/0x84
[ 1610.997376] el0t_64_sync_handler+0xbc/0x140
[ 1611.001632] el0t_64_sync+0x18c/0x190
[ 1611.005279] ---[ end trace 0000000000000000 ]---
[ 1611.009910] ------------[ cut here ]------------
[ 1611.014532] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1611.020877] WARNING: CPU: 6 PID: 3354 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1611.028082] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1611.099757] CPU: 6 PID: 3354 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1611.108865] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1611.114505] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1611.121446] pc : __vunmap+0x78/0x30c
[ 1611.125007] lr : __vunmap+0x78/0x30c
[ 1611.128567] sp : ffff80000baebad0
[ 1611.131867] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1611.138985] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1611.146103] x23: 0000000938f40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1611.153221] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1611.160339] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1611.167457] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001f50
[ 1611.174575] x11: 0000000000000a70 x10: ffff8000092e8fd0 x9 : ffff800009281550
[ 1611.181694] x8 : 0000000100000a70 x7 : ffff8000092d9550 x6 : 000000000000fa80
[ 1611.188812] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1611.195929] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1611.203047] Call trace:
[ 1611.205481] __vunmap+0x78/0x30c
[ 1611.208696] vunmap+0x40/0x5c
[ 1611.211651] dma_direct_free+0x10c/0x110
[ 1611.215560] dma_free_attrs+0x98/0xe0
[ 1611.219208] wave5_vdi_free_dma_memory+0x34/0x64 [wav vm area (000000008a4148f5)
[ 1611.284512] WARNING: CPU: 6 PID: 3354 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1611.291717] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1611.363394] CPU: 6 PID: 3354 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1611.372502] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1611.378142] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1611.385084] pc : __vunmap+0x78/0x30c
[ 1611.388646] lr : __vunmap+0x78/0x30c
[ 1611.392207] sp : ffff80000baebad0
[ 1611.395507] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1611.402626] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1611.409744] x23: 0000000938f20000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1611.416862] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1611.423980] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1611.431098] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001fc2
[ 1611.438216] x11: 0000000000000a96 x10: ffff8000092e9360 x9 : ffff800009281550
[ 1611.445332] x8 : 0000000100000a96 x7 : ffff8000092d9550 x6 : 000000000000fe10
[ 1611.452449] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1611.459565] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1611.466684] Call trace:
[ 1611.469117] __vunmap+0x78/0x30c
[ 1611.472333] vunmap+0x40/0x5
[ 1611.606243] BUG: Bad page state in process videotestsrc0:s pfn:938fc0
[ 1611.612781] page:00000000a67db344 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938fc0
[ 1611.622257] flags: 0x8000000000000000(zone=2)
[ 1611.626616] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1611.634347] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1611.642079] page dumped because: nonzero _refcount
[ 1611.646864] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1611.718589] CPU: 0 PID: 3358 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1611.727787] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1611.733429] Call trace:
[ 1611.735863] dump_backtrace.part.0+0xdc/0xf0
[ 1611.740129] show_stack+0x18/0x30
[ 1611.743433] dump_stack_lvl+0x68/0x84
[ 1611.747086] dump_stack+0x18/0x34
[ 1611.750389] bad_page+0xe8/0x110
[ 1611.753606] check_new_pages+0xe0/0x110
[ 1611.757428] get_page_from_freelist+0x574/0xf10
[ 1611.761945] __alloc_pages+0x134/0xcec
[ 1611.765681] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1611.771411] dma_direct_alloc+0xd8/0x304
[ 1611.775320] dma_alloc_attrs+0x7c/0xe4
[ 1611.779056] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wa0xa0 [videobuf2_v4l2]
[ 1611.813308] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1611.818960] v4l_reqbufs+0x50/0x64 [videodev]
[ 1611.823328] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1611.828298] video_usercopy+0x214/0x6c4 [videodev]
[ 1611.833095] video_ioctl2+0x18/0x2c [videodev]
[ 1611.837545] v4l2_ioctl+0x40/0x60 [videodev]
[ 1611.841821] __arm64_sys_ioctl+0xa8/0xf0
[ 1611.845730] invoke_syscall+0x48/0x114
[ 1611.849468] el0_svc_common.constprop.0+0xd4/0xfc
[ 1611.854157] do_el0_svc+0x30/0xd0
[ 1611.857461] el0_svc+0x2c/0x84
[ 1611.860503] el0t_64_sync_handler+0xbc/0x140
[ 1611.864758] el0t_64_sync+0x18c/0x190
[ 1611.868442] BUG: Bad page state in process videotestsrc0:s pfn:938f40
[ 1611.874959] page:000000006cc7136b refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x938f40
[ 1611.884423] flags: 0x8000000000000000(zone=2)
[ 1611.888775] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1611.896505] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1611.904233] page dumped because: nonzero _refcount
[ 1611.909014] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1611.980712] CPU: 0 PID: 3358 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1611.989924] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1611.995565] Call trace:
[ 1611.997998] dump_backtrace.part.0+0xdc/0xf0
[ 1612.002256] show_stack+0x18/0x3612.126850] el0t_64_sync+0x18c/0x190
[ 1612.130543] BUG: Bad page state in process videotestsrc0:s pfn:939000
[ 1612.137059] page:000000004768dc63 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939000
[ 1612.146523] flags: 0x8000000000000000(zone=2)
[ 1612.150874] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1612.158603] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1612.166332] page dumped because: nonzero _refcount
[ 1612.171113] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1612.242808] CPU: 0 PID: 3358 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1612.252006] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1612.257647] Call trace:
[ 1612.260080] dump_backtrace.part.0+0xdc/0xf0
[ 1612.264337] show_stack+0x18/0x30
[ 1612.267640] dump_stack_lvl+0x68/0x84
[ 1612.271291] dump_stack+0x18/0x34
[ 1612.274594] bad_page+0xe8/0x110
[ 1612.277808] check_new_pages+0xe0/0x110
[ 1612.281631] get_page_from_freelist+0x574/0xf10
[ 1612.286148] __alloc_pages+0x134/0xcec
[ 1612.289883] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1612.295614] dma_direct_alloc+0xd8/0x304
[ 1612.299523] dma_alloc_attrs+0x7c/0xe4
[ 1612.303258] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1612.308907] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1612.315161] wave5_vpu_enc_register_frame_buffer+0x110/13] page dumped because: nonzero _refcount
[ 1612.433100] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1612.504795] CPU: 0 PID: 3358 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1612.513992] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1612.519632] Call trace:
[ 1612.522066] dump_backtrace.part.0+0xdc/0xf0
[ 1612.526323] show_stack+0x18/0x30
[ 1612.529627] dump_stack_lvl+0x68/0x84
[ 1612.533277] dump_stack+0x18/0x34
[ 1612.536581] bad_page+0xe8/0x110
[ 1612.539797] check_new_pages+0xe0/0x110
[ 1612.543619] get_page_from_freelist+0x574/0xf10
[ 1612.548135] __alloc_pages+0x134/0xcec
[ 1612.551870] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1612.557600] dma_direct_alloc+0xd8/0x304
[ 1612.561508] dma_alloc_attrs+0x7c/0xe4
[ 1612.565244] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1612.570893] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1612.577147] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1612.583489] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1612.588963] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1612.594613] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1612.599481] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1612.605130] v4l_reqbufs+0x50/0x64 [videodev]
[ 1612.609497] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1612.614467] video_usercopy+0x214/0x6c4 [videodev]
[ 1612.619263] video_ioctl2+0x18/0x2c [videg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1612.780981] CPU: 7 PID: 3357 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1612.790091] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1612.795733] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1612.802675] pc : __vunmap+0x78/0x30c
[ 1612.806237] lr : __vunmap+0x78/0x30c
[ 1612.809799] sp : ffff80000c373ad0
[ 1612.813100] x29: ffff80000c373ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1612.820219] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1612.827337] x23: 0000000939100000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1612.834456] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1612.841573] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3737b7
[ 1612.848690] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002220
[ 1612.855806] x11: 0000000000000b60 x10: ffff8000092ea650 x9 : ffff800009281550
[ 1612.862925] x8 : 0000000100000b60 x7 : ffff8000092d9550 x6 : 0000000000011100
[ 1612.870043] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1612.877161] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1612.884280] Call trace:
[ 1612.886714] __vunmap+0x78/0x30c
[ 1612.889930] vunmap+0x40/0x5c
[ 1612.892886] dma_direct_free+0x10c/0x110
[ 1612.896798] dma_free_attrs+0x98/0xe0
[ 1612.900447] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1612.905757] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1612.910713] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1613.044714] CPU: 7 PID: 3357 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1613.053830] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1613.059473] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1613.066416] pc : __vunmap+0x78/0x30c
[ 1613.069981] lr : __vunmap+0x78/0x30c
[ 1613.073542] sp : ffff80000c373ad0
[ 1613.076842] x29: ffff80000c373ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1613.083960] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1613.091078] x23: 0000000939040000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1613.098196] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1613.105314] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3737b7
[ 1613.112431] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002292
[ 1613.119549] x11: 0000000000000b86 x10: ffff8000092ea9e0 x9 : ffff800009281550
[ 1613.126667] x8 : 0000000100000b86 x7 : ffff8000092d9550 x6 : 0000000000011490
[ 1613.133784] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1613.140902] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1613.148020] Call trace:
[ 1613.150454] __vunmap+0x78/0x30c
[ 1613.153671] vunmap+0x40/0x5c
[ 1613.156626] dma_direct_free+0x10c/0x110
[ 1613.160537] dma_free_attrs+0x98/0xe0
[ 1613.164186] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1613.169496] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1613.174452] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1613.179753] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1613.184708] v4l2_release+0xbc/0xf0 [videodev]
[ 1613.189163] __fput+0x70/0x250
[ 1613.192208] ____fput+0x10/0x20
[ 1613.195337] task_work_run+0x80/0xe0
[ 1613.198900] do_notify_resume+0x208/0x1280
[ 1613.202986] el0_svc+0x74/0x84
[ 1613.206029] el0t_64_sync_handler+0xbc/0x140
[ 1613.210285] el0t_ drm drm_panel_orientation_quirks ipv6
[ 1613.308495] CPU: 0 PID: 3357 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1613.317605] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1613.323246] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1613.330188] pc : __vunmap+0x78/0x30c
[ 1613.333750] lr : __vunmap+0x78/0x30c
[ 1613.337311] sp : ffff80000c373ad0
[ 1613.340611] x29: ffff80000c373ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1613.347730] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1613.354848] x23: 0000000939080000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1613.361967] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1613.369084] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3737b7
[ 1613.376201] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002304
[ 1613.383319] x11: 0000000000000bac x10: ffff8000092ead70 x9 : ffff800009281550
[ 1613.390436] x8 : 0000000100000bac x7 : ffff8000092d9550 x6 : 0000000000011820
[ 1613.397554] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1613.404672] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1613.411789] Call trace:
[ 1613.414223] __vunmap+0x78/0x30c
[ 1613.417438] vunmap+0x40/0x5c
[ 1613.420393] dma_direct_free+0x10c/0x110
[ 1613.424303] dma_free_attrs+0x98/0xe0
[ 1613.427951] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1613.433258] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1613.438212] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1613.443514] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1613.448467] v4l2_release+0xbc/0xf0 [videodev]
[ 1613.452920] __fput+0x70/0x250
[ 1613.455964] ____fput+0x10/0x20
[ 1613.459093] task_work_run+0x80/0xe0
[ 1613.462657] do_notify_resume+0x208/0x1280
[ 1613.466742] el0_svc+0x74/0x84
[ 1613.469785] el0t_64_sync_handler+0xbc/0x140
[ 1613.474041] el0t_64_sync+0x18c/0x190
[ 1613.477688] ---[ end trace 0000000000000000 ]---
[ 1613.482321] ------------[ cut here ]------------
[ 1613.486960] Trying to vfree() nonexistent vm area (000000008a4148f5)
[ 1613.493307] WARNING: CPU: 0 PID: 3357 at mm/vmalloc.c0
[ 1613.618538] x23: 0000000938f60000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1613.625656] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1613.632773] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3737b7
[ 1613.639890] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002376
[ 1613.647007] x11: 0000000000000bd2 x10: ffff8000092eb100 x9 : ffff800009281550
[ 1613.654125] x8 : 0000000100000bd2 x7 : ffff8000092d9550 x6 : 0000000000011bb0
[ 1613.661242] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1613.668360] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1613.675478] Call trace:
[ 1613.677911] __vunmap+0x78/0x30c
[ 1613.681126] vunmap+0x40/0x5c
[ 1613.684082] dma_direct_free+0x10c/0x110
[ 1613.687990] dma_free_attrs+0x98/0xe0
[ 1613.691638] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1613.696942] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1613.701810] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1613.707111] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1613.712064] v4l2_release+0xbc/0xf0 [videodev]
[ 1613.716517] __fput+0x70/0x250
[ 1613.719561] ____fput+0x10/0x20
[ 1613.722690] task_work_run+0x80/0xe0
[ 1613.726251] do_notify_resume+0x208/0x1280
[ 1613.730335] el0_svc+0x74/0x84
[ 1613.733377] el0t_64_sync_handler+0xbc/0x140
[ 1613.737632] el0t_64_sync+0x18c/0x190
[ 1613.741280] ---[ end trace 0000000000000000 ]---
[ 1613.807734] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1613.817823] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1613.826861] BUG: Bad page state in process videotestsrc0:s pfn:939040
[ 1613.833379] page:00000000738289ec refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939040
[ 1613.842845] flags: 0x8000000000000000(zone=2)
[ 1613.847197] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1613.854925] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1613.862651] page dumped because: nonzero _refcount
[ 1613.867431] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_gen videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1613.939149] CPU: 7 PID: 3365 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1613.948348] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1613.953989] Call trace:
[ 1613.956423] dump_backtrace.part.0+0xdc/0xf0
[ 1613.960690] show_stack+0x18/0x30
[ 1613.963994] dump_stack_lvl+0x68/0x84
[ 1613.967647] dump_stack+0x18/0x34
[ 1613.970950] bad_page+0xe8/0x110
[ 1613.974169] check_new_pages+0xe0/0x110
[ 1613.977990] get_page_from_freelist+0x574/0xf10
[ 1613.982507] __alloc_pages+0x134/0xcec
[ 1613.986243] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1613.991973] dma_direct_alloc+0xd8/0x304
[ 1613.995882] dma_alloc_attrs+0x7c/0xe4
[ 1613.999618] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1614.005275] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1614.011530] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1614.017870] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1614.023344] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1614.028996] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1614.033868] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1614.039519] v4l_reqbufs+0x50/0x64 [videodev]
[ 1614.043888] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1614.048858] video_usercopy+0x214/0x6c4 [videodev]
[ 1614.053654] video_ioctl2+0x18/0x2c [videodev]
[ 1614.058104] v4l2_ioctl+0x40/0x60 [videodev]
[ 1614.062380] __arm64_sys_ioctl+0xa8/0xf0
[ 1614.066290] invoke_syscall+0x48/0x114
[ 1614.070028] el0_svc_common.constprop.0+0xd4/0xfc
[ 1614.074718] do_el0_svc+0x30/0xd0
[ 1614.078020] el0_svc+0x2c/0x84
[ 1614.081061] el0t_64_sync_handler+0xbc/0x140
[ 1614.085316] el0t_64_sync+0x180000000000000 index:0x0 pfn:0x939080
[ 1614.104970] flags: 0x8000000000000000(zone=2)
[ 1614.109320] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1614.117047] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1614.124772] page dumped because: nonzero _refcount
[ 1614.129552] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1614.201246] CPU: 7 PID: 3365 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1614.210443] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1614.216084] Call trace:
[ 1614.218517] dump_backtrace.part.0+0xdc/0xf0
[ 1614.222777] show_stack+0x18/0x30
[ 1614.226080] dump_stack_lvl+0x68/0x84
[ 1614.229731] dump_stack+0x18/0x34
[ 1614.233034] bad_page+0xe8/0x110
[ 1614.236249] check_new_pages+0xe0/0x110
[ 1614.240070] get_page_from_freelist+0x574/0xf10
[ 1614.244586] __alloc_pages+0x134/0xcec
[ 1614.248322] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1614.254051] dma_direct_alloc+0xd8/0x304
[ 1614.257960] dma_alloc_attrs+0x7c/0xe4
[ 1614.261695] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1614.267345] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1614.273599] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1614.279939] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1614.285413] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1614.291063] vb2_reqbufs+0x80/0xa0 [videob000000000000000
[ 1614.400191] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1614.407916] page dumped because: nonzero _refcount
[ 1614.412697] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1614.484397] CPU: 7 PID: 3365 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1614.493595] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1614.499235] Call trace:
[ 1614.501668] dump_backtrace.part.0+0xdc/0xf0
[ 1614.505927] show_stack+0x18/0x30
[ 1614.509230] dump_stack_lvl+0x68/0x84
[ 1614.512881] dump_stack+0x18/0x34
[ 1614.516184] bad_page+0xe8/0x110
[ 1614.519399] check_new_pages+0xe0/0x110
[ 1614.523221] get_page_from_freelist+0x574/0xf10
[ 1614.527738] __alloc_pages+0x134/0xcec
[ 1614.531474] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1614.537204] dma_direct_alloc+0xd8/0x304
[ 1614.541112] dma_alloc_attrs+0x7c/0xe4
[ 1614.544847] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1614.550498] wave5_vpu_enc_register_framebuffer+0x274/0x6f0 [wave5]
[ 1614.556752] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1614.563093] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1614.568567] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1614.574217] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1614.579086] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1614.584737] v4l_reqbufs+0x50/0x64 [videodev]
[ 1614.589103] __video_do_ioctlwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1614.734651] CPU: 6 PID: 3364 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1614.743762] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1614.749405] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1614.756348] pc : __vunmap+0x78/0x30c
[ 1614.759910] lr : __vunmap+0x78/0x30c
[ 1614.763472] sp : ffff80000c37bad0
[ 1614.766772] x29: ffff80000c37bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1614.773891] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1614.781008] x23: 0000000939180000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1614.788126] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1614.795243] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c37b7b7
[ 1614.802360] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000255f
[ 1614.809479] x11: 0000000000000c75 x10: ffff8000092ec048 x9 : ffff800009281550
[ 1614.816596] x8 : 0000000100000c75 x7 : ffff8000092d9550 x6 : 0000000000012af8
[ 1614.823713] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1614.830830] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1614.837947] Call trace:
[ 1614.840381] __vunmap+0x78/0x30c
[ 1614.843595] vunmap+0x40/0x5c
[ 1614.846550] dma_direct_free+0x10c/0x110
[ 1614.850461] dma_free_attrs+0x98/0xe0
[ 1614.854110] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1614.859418] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1614.864373] wave5_vpu_release_device334] CPU: 6 PID: 3364 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1615.007444] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1615.013088] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1615.020030] pc : __vunmap+0x78/0x30c
[ 1615.023592] lr : __vunmap+0x78/0x30c
[ 1615.027154] sp : ffff80000c37bad0
[ 1615.030454] x29: ffff80000c37bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1615.037572] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1615.044689] x23: 0000000939140000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1615.051806] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1615.058923] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c37b7b7
[ 1615.066040] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000025d1
[ 1615.073158] x11: 0000000000000c9b x10: ffff8000092ec3d8 x9 : ffff800009281550
[ 1615.080275] x8 : 0000000100000c9b x7 : ffff8000092d9550 x6 : 0000000000012e88
[ 1615.087393] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1615.094510] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1615.101627] Call trace:
[ 1615.104060] __vunmap+0x78/0x30c
[ 1615.107274] vunmap+0x40/0x5c
[ 1615.110230] dma_direct_free+0x10c/0x110
[ 1615.114139] dma_free_attrs+0x98/0xe0
[ 1615.117787] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1615.123090] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1615.128044] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1615.133345] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1615.138300] v4l2_release+0xbc/0xf0 [videodev]
[ 1615.142754] __fput+0x70/0x250
[ 1615.145798] ____fput+0x10/0x20
[ 1615.148926] task_work_run+0x80/0xe0
[ 1615.152488] do_notify_resume+0x208/0x1280
[ 1615.156572] el0_svc+0x74/0x84
[ 1615.159614] el0t_64_sync_handler+0xbc/0x140
[ 1615.163869] el0t_64_sync+0x18c/0x190
[ 1615.167517] ---[ end trace 0000000000000000 ]---
[ 1615.172151] ------------[ cut here ]------------
[ 1615.176776] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1615.183123] WARNING: CPU: 6 PID: 3364 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1615.190327] Modules linked 20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1615.322589] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c37b7b7
[ 1615.329706] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002643
[ 1615.336825] x11: 0000000000000cc1 x10: ffff8000092ec768 x9 : ffff800009281550
[ 1615.343942] x8 : 0000000100000cc1 x7 : ffff8000092d9550 x6 : 0000000000013218
[ 1615.351059] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1615.358176] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1615.365293] Call trace:
[ 1615.367726] __vunmap+0x78/0x30c
[ 1615.370941] vunmap+0x40/0x5c
[ 1615.373896] dma_direct_free+0x10c/0x110
[ 1615.377805] dma_free_attrs+0x98/0xe0
[ 1615.381453] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1615.386756] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1615.391711] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1615.397012] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1615.401966] v4l2_release+0xbc/0xf0 [videodev]
[ 1615.406418] __fput+0x70/0x250
[ 1615.409461] ____fput+0x10/0x20
[ 1615.412590] task_work_run+0x80/0xe0
[ 1615.416152] do_notify_resume+0x208/0x1280
[ 1615.420235] el0_svc+0x74/0x84
[ 1615.423276] el0t_64_sync_handler+0xbc/0x140
[ 1615.427532] el0t_64_sync+0x18c/0x190
[ 1615.431180] ---[ end trace 0000000000000000 ]---
[ 1615.435802] ------------[ cut here ]------------
[ 1615.440411] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1615.446767] WARNING: CPU: 6 PID: 3364 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1615.453971] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_com00000009b0 x9 : ffff80000c37b980
[ 1615.607586] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1615.614704] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d91c8
[ 1615.621823] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1615.628939] Call trace:
[ 1615.631373] __vunmap+0x78/0x30c
[ 1615.634587] vunmap+0x40/0x5c
[ 1615.637542] dma_direct_free+0x10c/0x110
[ 1615.641451] dma_free_attrs+0x98/0xe0
[ 1615.645099] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1615.650401] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1615.655269] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1615.660569] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1615.665524] v4l2_release+0xbc/0xf0 [videodev]
[ 1615.669977] __fput+0x70/0x250
[ 1615.673021] ____fput+0x10/0x20
[ 1615.676150] task_work_run+0x80/0xe0
[ 1615.679711] do_notify_resume+0x208/0x1280
[ 1615.683795] el0_svc+0x74/0x84
[ 1615.686836] el0t_64_sync_handler+0xbc/0x140
[ 1615.691091] el0t_64_sync+0x18c/0x190
[ 1615.694739] ---[ end trace 0000000000000000 ]---
[ 1615.761274] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1615.771348] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1615.780392] BUG: Bad page state in process videotestsrc0:s pfn:9390c0
[ 1615.786919] page:00000000c9ad5c64 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9390c0
[ 1615.796386] flags: 0x8000000000000000(zone=2)
[ 1615.800747] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1615.808475] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1615.816203] page dumped because: nonzero _refcount
[ 1615.820984] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_hel574/0xf10
[ 1615.936060] __alloc_pages+0x134/0xcec
[ 1615.939798] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1615.945530] dma_direct_alloc+0xd8/0x304
[ 1615.949439] dma_alloc_attrs+0x7c/0xe4
[ 1615.953175] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1615.958833] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1615.965088] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1615.971428] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1615.976903] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1615.982554] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1615.987424] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1615.993075] v4l_reqbufs+0x50/0x64 [videodev]
[ 1615.997446] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1616.002415] video_usercopy+0x214/0x6c4 [videodev]
[ 1616.007211] video_ioctl2+0x18/0x2c [videodev]
[ 1616.011661] v4l2_ioctl+0x40/0x60 [videodev]
[ 1616.015938] __arm64_sys_ioctl+0xa8/0xf0
[ 1616.019848] invoke_syscall+0x48/0x114
[ 1616.023586] el0_svc_common.constprop.0+0xd4/0xfc
[ 1616.028276] do_el0_svc+0x30/0xd0
[ 1616.031579] el0_svc+0x2c/0x84
[ 1616.034620] el0t_64_sync_handler+0xbc/0x140
[ 1616.038874] el0t_64_sync+0x18c/0x190
[ 1616.042553] BUG: Bad page state in process videotestsrc0:s pfn:939140
[ 1616.049071] page:000000009cfb41fb refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939140
[ 1616.058538] flags: 0x8000000000000000(zone=2)
[ 1616.062889] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1616.070619] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1616.078348] page dumped because: nonzero _refcount
[ 1616.083127] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1616.154820] CPU: 6 PID: 3368 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1616.164016] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1616.169656] Call trace:
[ 1616.172089] dump_backtrace.part.0+0xdc/0xf0
[ 1616.176347] show_stack+0x18/0x30
[ 1616.179650] dump_stack_lvl+0x68/0x84
[ 1616.183300] dump_stack+0x18/0x34
[ 1616.186603] bad_page+0xe8/0x110
[ 1616.189819] check_new_pages+0xe0/0x110
[ 1616.193641] get_page_from_freelist+0x574/0xf10
[ 1616.198156] __alloc_pages+0x134/0xcec
[ 1616.201892] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1616.207622] dma_direct_alloc+0xd8/0x304
[ 1616.211531] dma_alloc_attrs+0x7c/0xe4
[ 1616.215266] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1616.220915] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1616.227170] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1616.233512] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1616.238987] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1616.244636] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1616.249504] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1616.255154] v4l_reqbufs+0x50/0x64 [videodev]
[ 1616.259520] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1616.264490] video_usercopy+0x214/0x6c4 [videodev]
[ 1616.269286] video_ioctl2+0x18/0x2c [videodev]
[ 1616.273735] v4l2_ioctl+0x40/0x60 [videodev]
[ 1616.278012] __arm64_sys_ioctl+0xa8/0xf0
[ 1616.281920] invoke_syscall+0x48/0x114
[ 1616.285656] el0_svc_common.constprop.0+0xd4/0xfc
[ 1616.290346] do_el0_svc+0x30/0xd0
[ 1616.293649] el0_svc+0x2c/0x84
[ 1616.296691] el0t_64_sync_handler+0xbc/0x140
[ 1616.300945] el0t_64_sync+0x18c/0x190
[ 1616.304609] BUG: Bad page state in process videotestsrc0:s pfn:939180
[ 1616.311128] page:0000000026142635 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939180
[ 1616.320590] flags: 0x8000000000000000(zone=2)
[ 1616.324940] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1616.332669] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1616.340397] page dumped because: nonzero _refcount
[ 1616.345176] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1616.416866] CPU: 6 PID: 3368 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1616.426062] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1616.431707] Call trace:
[ 1616.434140] dump_backtrace.part.0+0xdc/0xf0
[ 1616.438398] show_stack+0x18/0x30
[ 1616.441701] dump_stack_lvl+0x68/0x84
[ 1616.445351] dump_stack+0x18/0x34
[ 1616.448654] bad_page+0xe8/0x110
[ 1616.451870] check_new_pages+0xe0/0x110
[ 1616.455692] get_page_from_freelist+0x574/0xf10
[ 1616.460208] __alloc_pages+0x134/0xcec
[ 1616.463943] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1616.469674] dma_direct_alloc+0xd8/0x304
[ 1616.473583] dma_alloc_attrs+0x7c/0xe4
[ 1616.477318] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1616.482968] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1616.489223] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1616.495563] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1616.501037] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1616.506686] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1616.511554] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1616.517205] v4l_reqbufs+0x50/0x64 [videodev]
[ 1616.521573] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1616.526543] video_usercopy+0x214/0x6c4 [videodev]
[ 1616.531340] video_ioctl2+0x18/0x2c [videodev]
[ 1616.535790] v4l2_ioctl+0x40/0x60 [videodev]
[ 1616.540065] __arm64_sys_ioctl+0xa8/0xf0
[ 1616.543973] invoke_syscall+0x48/0x114
[ 1616.547710] el0_svc_common.constprop.0+0xd4/0xfc
[ 1616.552399] do_el0_svc+0x30/0xd0
[ 1616.555703] el0_svc+0x2c/0x84
[ 1616.558745] el0t_64_sync_handler+0xbc/0x140
[ 1616.563000] el0t_64_sync+0x18c/0x190
[ 1616.566667] BUG: Bad page state in process videotestsrc0:s pfn:9391c0
[ 1616.573182] page:0000000045aa9421 refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9391c0
[ 1616.582556] flags: 0x8000000000000000(zone=2)
[ 1616.586907] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1616.594637] raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
[ 1616.602365] page dumped because: nonzero _refcount
[ 1616.607144] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooths ipv6
[ 1616.678835] CPU: 6 PID: 3368 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1616.688032] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1616.693674] Call trace:
[ 1616.696107] dump_backtrace.part.0+0xdc/0xf0
[ 1616.700365] show_stack+0x18/0x30
[ 1616.703668] dump_stack_lvl+0x68/0x84
[ 1616.707319] dump_stack+0x18/0x34
[ 1616.710622] bad_page+0xe8/0x110
[ 1616.713837] check_new_pages+0xe0/0x110
[ 1616.717658] get_page_from_freelist+0x574/0xf10
[ 1616.722174] __alloc_pages+0x134/0xcec
[ 1616.725910] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1616.731640] dma_direct_alloc+0xd8/0x304
[ 1616.735549] dma_alloc_attrs+0x7c/0xe4
[ 1616.739284] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1616.744933] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1616.751188] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1616.757528] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1616.763002] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1616.768651] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1616.773520] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1616.779169] v4l_reqbufs+0x50/0x64 [videodev]
[ 1616.783534] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1616.788504] video_usercopy+0x214/0x6c4 [videodev]
[ 1616.793301] video_ioctl2+0x18/0x2c [videodev]
[ 1616.797751] v4l2_ioctl+0x40/0x60 [videodev]
[ 1616.802026] __arm64_sys_ioctl+0xa8/0xf0
[ 1616.805934] invoke_syscall+0x48/0x114
[ 1616.809671] el0_svc_common.constprop.0+0xd4/0xfc
[ 1616.814361] do_el0_svc+0x30/0xd0
[ 1616.817663] el0_svc+0x2c/0x84
[ 1616.820704] el0t_64_sync_handler+0xbc/0x140
[ 1616.824959] el0t_64_sync+0x18c/0x190
[ 1616.832911] ------------[ cut here ]------------
[ 1616.837534] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1616.843894] WARNING: CPU: 2 PID: 3367 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1616.851105] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct176280] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1616.983398] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1616.990517] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000290d
[ 1616.997635] x11: 0000000000000daf x10: ffff8000092eddb8 x9 : ffff800009281550
[ 1617.004753] x8 : 0000000100000daf x7 : ffff8000092d9550 x6 : 0000000000014868
[ 1617.011871] x5 : ffff000f5c38fb60 x4 : ffff000f5c38fb60 x3 : ffff000f5c392da0
[ 1617.018989] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1617.026107] Call trace:
[ 1617.028541] __vunmap+0x78/0x30c
[ 1617.031757] vunmap+0x40/0x5c
[ 1617.034713] dma_direct_free+0x10c/0x110
[ 1617.038623] dma_free_attrs+0x98/0xe0
[ 1617.042271] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1617.047581] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1617.052537] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1617.057838] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1617.062792] v4l2_release+0xbc/0xf0 [videodev]
[ 1617.067246] __fput+0x70/0x250
[ 1617.070291] ____fput+0x10/0x20
[ 1617.073420] task_work_run+0x80/0xe0
[ 1617.076984] do_notify_resume+0x208/0x1280
[ 1617.081068] el0_svc+0x74/0x84
[ 1617.084111] el0t_64_sync_handler+0xbc/0x140
[ 1617.088366] el0t_64_sync+0x18c/0x190
[ 1617.092015] ---[ end trace 0000000000000000 ]---
[ 1617.096650] ------------[ cut here ]------------
[ 1617.101260] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1617.107606] WARNING: CPU: 2 PID: 3367 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1617.114812] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_comm617.302295] dma_free_attrs+0x98/0xe0
[ 1617.305943] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1617.311247] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1617.316203] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1617.321504] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1617.326459] v4l2_release+0xbc/0xf0 [videodev]
[ 1617.330912] __fput+0x70/0x250
[ 1617.333955] ____fput+0x10/0x20
[ 1617.337085] task_work_run+0x80/0xe0
[ 1617.340647] do_notify_resume+0x208/0x1280
[ 1617.344731] el0_svc+0x74/0x84
[ 1617.347772] el0t_64_sync_handler+0xbc/0x140
[ 1617.352027] el0t_64_sync+0x18c/0x190
[ 1617.355675] ---[ end trace 0000000000000000 ]---
[ 1617.360324] ------------[ cut here ]------------
[ 1617.364944] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1617.371315] WARNING: CPU: 4 PID: 3367 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1617.378524] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1617.450211] CPU: 4 PID: 3367 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1617.459320] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1617.464961] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1617.471903] pc : __vunmap+0x78/0x30c
[ 1617.475466] lr : __vunmap+0x78/0x30c
[ 1617.479028] sp : ffff80000ba8bad0
[ 1617.482328] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1617.489446] x26: 0000000000000000 x25: 0000000000000000 x24: 000000000k_work_run+0x80/0xe0
[ 1617.604370] do_notify_resume+0x208/0x1280
[ 1617.608455] el0_svc+0x74/0x84
[ 1617.611497] el0t_64_sync_handler+0xbc/0x140
[ 1617.615752] el0t_64_sync+0x18c/0x190
[ 1617.619400] ---[ end trace 0000000000000000 ]---
[ 1617.624078] ------------[ cut here ]------------
[ 1617.628684] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1617.635031] WARNING: CPU: 4 PID: 3367 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1617.642236] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1617.713913] CPU: 4 PID: 3367 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1617.723023] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1617.728664] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1617.735605] pc : __vunmap+0x78/0x30c
[ 1617.739167] lr : __vunmap+0x78/0x30c
[ 1617.742729] sp : ffff80000ba8bad0
[ 1617.746028] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1617.753146] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1617.760263] x23: 00000009390e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1617.767380] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1617.774497] x17: ffff800f532c8000 x16: ffff800009448000 x15: ffff80008ba8b7b7
[ 1617.781614] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002a63
[ 1617.788731] x11: 0000000000000e21 x10: ffff8000092ee868 x9 : ffff8000092815507.883005] ---[ end trace 0000000000000000 ]---
[ 1617.949832] cma_alloc: 3 callbacks suppressed
[ 1617.949842] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1617.964280] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1617.973315] BUG: Bad page state in process videotestsrc0:s pfn:9391c0
[ 1617.979831] page:0000000045aa9421 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9391c0
[ 1617.989317] flags: 0x8000000000000000(zone=2)
[ 1617.993672] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1618.001402] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1618.009130] page dumped because: nonzero _refcount
[ 1618.013911] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1618.085655] CPU: 2 PID: 3371 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1618.094855] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1618.100497] Call trace:
[ 1618.102933] dump_backtrace.part.0+0xdc/0xf0
[ 1618.107200] show_stack+0x18/0x30
[ 1618.110504] dump_stack_lvl+0x68/0x84
[ 1618.114157] dump_stack+0x18/0x34
[ 1618.117460] bad_page+0xe8/0x110
[ 1618.120676] check_new_pages+0xe0/0x110
[ 1618.124498] get_page_from_freelist+0x574/0xf1040/0xb0 [wave5]
[ 1618.151791] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1618.158046] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1618.164386] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1618.169861] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1618.175514] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1618.180386] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1618.186038] v4l_reqbufs+0x50/0x64 [videodev]
[ 1618.190406] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1618.195375] video_usercopy+0x214/0x6c4 [videodev]
[ 1618.200171] video_ioctl2+0x18/0x2c [videodev]
[ 1618.204620] v4l2_ioctl+0x40/0x60 [videodev]
[ 1618.208897] __arm64_sys_ioctl+0xa8/0xf0
[ 1618.212806] invoke_syscall+0x48/0x114
[ 1618.216545] el0_svc_common.constprop.0+0xd4/0xfc
[ 1618.221235] do_el0_svc+0x30/0xd0
[ 1618.224537] el0_svc+0x2c/0x84
[ 1618.227578] el0t_64_sync_handler+0xbc/0x140
[ 1618.231833] el0t_64_sync+0x18c/0x190
[ 1618.235505] BUG: Bad page state in process videotestsrc0:s pfn:939200
[ 1618.242029] page:0000000042658513 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939200
[ 1618.251499] flags: 0x8000000000000000(zone=2)
[ 1618.255852] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1618.263581] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1618.271310] page dumped because: nonzero _refcount
[ 1618.276092] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(Oideodev]
[ 1618.452502] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1618.457472] video_usercopy+0x214/0x6c4 [videodev]
[ 1618.462269] video_ioctl2+0x18/0x2c [videodev]
[ 1618.466718] v4l2_ioctl+0x40/0x60 [videodev]
[ 1618.470994] __arm64_sys_ioctl+0xa8/0xf0
[ 1618.474903] invoke_syscall+0x48/0x114
[ 1618.478640] el0_svc_common.constprop.0+0xd4/0xfc
[ 1618.483330] do_el0_svc+0x30/0xd0
[ 1618.486632] el0_svc+0x2c/0x84
[ 1618.489673] el0t_64_sync_handler+0xbc/0x140
[ 1618.493928] el0t_64_sync+0x18c/0x190
[ 1618.500201] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1618.509768] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1618.518808] BUG: Bad page state in process videotestsrc0:s pfn:939280
[ 1618.525324] page:00000000e0ac8997 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939280
[ 1618.534789] flags: 0x8000000000000000(zone=2)
[ 1618.539139] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1618.546869] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1618.554597] page dumped because: nonzero _refcount
[ 1618.559379] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1618.631073] CPU: 2 PID: 3371 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1618.640271] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1618.645911] Call t+0x184/0x3d0 [videodev]
[ 1618.740753] video_usercopy+0x214/0x6c4 [videodev]
[ 1618.745549] video_ioctl2+0x18/0x2c [videodev]
[ 1618.749998] v4l2_ioctl+0x40/0x60 [videodev]
[ 1618.754275] __arm64_sys_ioctl+0xa8/0xf0
[ 1618.758183] invoke_syscall+0x48/0x114
[ 1618.761920] el0_svc_common.constprop.0+0xd4/0xfc
[ 1618.766609] do_el0_svc+0x30/0xd0
[ 1618.769913] el0_svc+0x2c/0x84
[ 1618.772954] el0t_64_sync_handler+0xbc/0x140
[ 1618.777210] el0t_64_sync+0x18c/0x190
[ 1618.781087] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1618.791433] ------------[ cut here ]------------
[ 1618.796056] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1618.802414] WARNING: CPU: 0 PID: 3370 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1618.809623] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1618.881315] CPU: 0 PID: 3370 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1618.890425] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1618.896066] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1618.903009] pc : __vunmap+0x78/0x30c
[ 1618.906572] lr : __vunmap+0x78/0x30c
[ 1618.910133] sp : ffff80000c0b3ad0
[ 1618.913433] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1618.920552] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1618.927670] x23: 0000000939300000 x22: ffff8000093d6a28 x40
[ 1619.046865] el0t_64_sync+0x18c/0x190
[ 1619.050514] ---[ end trace 0000000000000000 ]---
[ 1619.055173] ------------[ cut here ]------------
[ 1619.059785] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1619.066132] WARNING: CPU: 0 PID: 3370 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1619.073339] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1619.145014] CPU: 0 PID: 3370 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1619.154124] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1619.159764] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1619.166707] pc : __vunmap+0x78/0x30c
[ 1619.170268] lr : __vunmap+0x78/0x30c
[ 1619.173830] sp : ffff80000c0b3ad0
[ 1619.177130] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1619.184248] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1619.191365] x23: 00000009392c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1619.198483] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1619.205600] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1619.212718] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002cc1
[ 1619.219835] x11: 0000000000000eeb x10: ffff8000092efb58 x9 : ffff800009281550
[ 1619.226952] x8 : 0000000100000eeb x7 : ffff8000092d9550 x6 : 0000000000016608
[ 1619.234070] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 ic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1619.408683] CPU: 0 PID: 3370 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1619.417793] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1619.423434] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1619.430376] pc : __vunmap+0x78/0x30c
[ 1619.433938] lr : __vunmap+0x78/0x30c
[ 1619.437499] sp : ffff80000c0b3ad0
[ 1619.440798] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1619.447916] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1619.455034] x23: 0000000939240000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1619.462151] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1619.469269] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1619.476386] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002d33
[ 1619.483503] x11: 0000000000000f11 x10: ffff8000092efee8 x9 : ffff800009281550
[ 1619.490621] x8 : 0000000100000f11 x7 : ffff8000092d9550 x6 : 0000000000016998
[ 1619.497738] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1619.504856] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1619.511973] Call trace:
[ 1619.514406] __vunmap+0x78/0x30c
[ 1619.517622] vunmap+0x40/0x5c
[ 1619.520577] dma_direct_free+0x10c/0x110
[ 1619.524485] dma_free_attrs+0x98/0xe0
[ 1619.528133] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1619.533436] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1619.672327] CPU: 0 PID: 3370 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1619.681437] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1619.687077] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1619.694019] pc : __vunmap+0x78/0x30c
[ 1619.697581] lr : __vunmap+0x78/0x30c
[ 1619.701142] sp : ffff80000c0b3ad0
[ 1619.704442] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1619.711560] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1619.718678] x23: 0000000939220000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1619.725796] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1619.732913] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1619.740031] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002da5
[ 1619.747149] x11: 0000000000000f37 x10: ffff8000092f0278 x9 : ffff800009281550
[ 1619.754266] x8 : 0000000100000f37 x7 : ffff8000092d9550 x6 : 0000000000016d28
[ 1619.761384] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1619.768501] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1619.775618] Call trace:
[ 1619.778051] __vunmap+0x78/0x30c
[ 1619.781267] vunmap+0x40/0x5c
[ 1619.784222] dma_direct_free+0x10c/0x110
[ 1619.788131] dma_free_attrs+0x98/0xe0
[ 1619.791778] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1619.797081] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 161
[ 1619.907266] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1619.917366] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1619.926410] BUG: Bad page state in process videotestsrc0:s pfn:9392c0
[ 1619.932933] page:00000000f8cfc4ea refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9392c0
[ 1619.942400] flags: 0x8000000000000000(zone=2)
[ 1619.946758] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1619.954495] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1619.962227] page dumped because: nonzero _refcount
[ 1619.967011] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1620.038730] CPU: 0 PID: 3374 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1620.047930] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1620.053571] Call trace:
[ 1620.056006] dump_backtrace.part.0+0xdc/0xf0
[ 1620.060274] show_stack+0x18/0x30
[ 1620.063577] dump_stack_lvl+0x68/0x84
[ 1620.067230] dump_stack+0x18/0x34
[ 1620.070534] bad_page+0xe8/0x110
[ 1620.073750] check_new_pages+0xe0/0x110
[ 1620.077571] get_page_from_freelist+0x574/0xf10
[ 1620.082088] __alloc_pages+0x134/0xcec
[ 1620.085824] __dm el0t_64_sync_handler+0xbc/0x140
[ 1620.184898] el0t_64_sync+0x18c/0x190
[ 1620.188598] BUG: Bad page state in process videotestsrc0:s pfn:939240
[ 1620.195123] page:00000000e2a96819 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939240
[ 1620.204588] flags: 0x8000000000000000(zone=2)
[ 1620.208943] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1620.216676] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1620.224407] page dumped because: nonzero _refcount
[ 1620.229189] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1620.300891] CPU: 0 PID: 3374 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1620.310089] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1620.315729] Call trace:
[ 1620.318163] dump_backtrace.part.0+0xdc/0xf0
[ 1620.322421] show_stack+0x18/0x30
[ 1620.325725] dump_stack_lvl+0x68/0x84
[ 1620.329375] dump_stack+0x18/0x34
[ 1620.332678] bad_page+0xe8/0x110
[ 1620.335894] check_new_pages+0xe0/0x110
[ 1620.339715] get_page_from_freelist+0x574/0xf10
[ 1620.344231] __alloc_pages+0x134/0xcec
[ 1620.347967] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1620.353696] dma_direct_alloc+0xd8/0x304
[ 1620.357604] dma_alloc_attrs+0x7c/0xe4
[ 1620.361340] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1620.366989] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1620.373243] wave5_vpuc/0x190
[ 1620.450694] BUG: Bad page state in process videotestsrc0:s pfn:939300
[ 1620.457208] page:00000000b4439abc refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939300
[ 1620.466674] flags: 0x8000000000000000(zone=2)
[ 1620.471026] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1620.478759] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1620.486491] page dumped because: nonzero _refcount
[ 1620.491273] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1620.562970] CPU: 0 PID: 3374 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1620.572167] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1620.577807] Call trace:
[ 1620.580240] dump_backtrace.part.0+0xdc/0xf0
[ 1620.584497] show_stack+0x18/0x30
[ 1620.587800] dump_stack_lvl+0x68/0x84
[ 1620.591450] dump_stack+0x18/0x34
[ 1620.594753] bad_page+0xe8/0x110
[ 1620.597968] check_new_pages+0xe0/0x110
[ 1620.601789] get_page_from_freelist+0x574/0xf10
[ 1620.606306] __alloc_pages+0x134/0xcec
[ 1620.610041] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1620.615771] dma_direct_alloc+0xd8/0x304
[ 1620.619680] dma_alloc_attrs+0x7c/0xe4
[ 1620.623415] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1620.629065] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1620.635320] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1620.641662] wave j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1620.824972] CPU: 0 PID: 3374 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1620.834169] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1620.839810] Call trace:
[ 1620.842242] dump_backtrace.part.0+0xdc/0xf0
[ 1620.846500] show_stack+0x18/0x30
[ 1620.849803] dump_stack_lvl+0x68/0x84
[ 1620.853454] dump_stack+0x18/0x34
[ 1620.856757] bad_page+0xe8/0x110
[ 1620.859973] check_new_pages+0xe0/0x110
[ 1620.863794] get_page_from_freelist+0x574/0xf10
[ 1620.868310] __alloc_pages+0x134/0xcec
[ 1620.872046] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1620.877775] dma_direct_alloc+0xd8/0x304
[ 1620.881683] dma_alloc_attrs+0x7c/0xe4
[ 1620.885419] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1620.891068] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1620.897323] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1620.903663] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1620.909138] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1620.914787] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1620.919655] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1620.925304] v4l_reqbufs+0x50/0x64 [videodev]
[ 1620.929671] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1620.934641] video_usercopy+0x214/0x6c4 [videodev]
[ 1620.939436] video_ioctl2+0x18/0x2c [videodev]
[ 1620.943885] v4l2_ioctl+0x40/0x60 [videodev]
[ 1620.948162] __arm64_sys_ioctl+0xa8/0xf0
[ 1620.952071] invoke_syscall+0x48/0x114
[ 1620.955808] el0_svc_common.constprop.0+0xd4/0xfc
[ 1620.960498] do_el0_svc+0x30/0xd0
[ 1620.963800] el0rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1621.096514] CPU: 6 PID: 3373 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1621.105625] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1621.111267] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1621.118210] pc : __vunmap+0x78/0x30c
[ 1621.121773] lr : __vunmap+0x78/0x30c
[ 1621.125334] sp : ffff80000c0bbad0
[ 1621.128634] x29: ffff80000c0bbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1621.135753] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1621.142871] x23: 0000000939400000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1621.149989] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1621.157106] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1621.164224] x14: 000000000000035a x13: 0000000000000000 x12: 0000000000000000
[ 1621.171341] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0bb980
[ 1621.178459] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1621.185576] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d83c8
[ 1621.192693] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1621.199811] Call trace:
[ 1621.202245] __vunmap+0x78/0x30c
[ 1621.205461] vunmap+0x40/0x5c
[ 1621.208417] dma_direct_free+0x10c/0x110
[ 1621.212326] dma_free_attrs+0x98/0xe0
[ 1621.215974] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1621.221284] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1621.226239] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1621.231541] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1621.236494] v4l2_release+0xbc/0xf0 [videodev]
[ 1621.240950] __fput+0x70/0x250
[ 1621.243994] ____fput+0x10/0x20
[ 1621.247124] task_work_run+0x80/0xe0
[ 1621.250688] do_notify_resume+0x208/0x1280
[ 1621.254773] el0_svc+0x74/0x84
[ 1621.257816] el0t_64_sync_handler+0xbc/0x140
[ 1621.262072] el0t_64_sync+0x18c/0x190
[ 1621.265721] ---[ end trace 0000000000000000 ]---
[ 1621.27035e2 #1
[ 1621.369310] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1621.374951] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1621.381895] pc : __vunmap+0x78/0x30c
[ 1621.385456] lr : __vunmap+0x78/0x30c
[ 1621.389019] sp : ffff80000c0bbad0
[ 1621.392319] x29: ffff80000c0bbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1621.399437] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1621.406554] x23: 0000000939340000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1621.413672] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1621.420790] x17: 0000000000000000 x16: 0000000000000000 x15: 00000017dd0b596d
[ 1621.427908] x14: 0000000000000143 x13: 0000000000000000 x12: 0000000000000000
[ 1621.435025] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0bb980
[ 1621.442143] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1621.449261] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d83c8
[ 1621.456379] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1621.463497] Call trace:
[ 1621.465930] __vunmap+0x78/0x30c
[ 1621.469146] vunmap+0x40/0x5c
[ 1621.472101] dma_direct_free+0x10c/0x110
[ 1621.476010] dma_free_attrs+0x98/0xe0
[ 1621.479658] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1621.484962] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1621.489917] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1621.495218] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1621.500171] v4l2_release+0xbc/0xf0 [videodev]
[ 1621.504624] __fput+0x70/0x250
[ 1621.507668] ____fput+0x10/0x20
[ 1621.510797] task_work_run+0x80/0xe0
[ 1621.514359] do_notify_resume+0x208/0x1280
[ 1621.518443] el0_svc+0x74/0x84
[ 1621.521484] el0t_64_sync_handler+0xbc/0x140
[ 1621.525739] el0t_64_sync+0x18c/0x190
[ 1621.529386] ---[ end trace 0000000000000000 ]---
[ 1621.534011] ------------[ cut here ]------------
[ 1621.538636] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1621.544980] WARNING: CPU: 6 PID: 3373 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1621.552184] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx pan x29: ffff80000c0bbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1621.663097] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1621.670215] x23: 0000000939380000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1621.677332] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1621.684451] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0bb7b7
[ 1621.691568] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000000ea
[ 1621.698685] x11: 000000000000004e x10: ffff8000092d9ca0 x9 : ffff800009281550
[ 1621.705802] x8 : 000000010000104e x7 : ffff8000092d9550 x6 : 0000000000000750
[ 1621.712919] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1621.720035] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1621.727153] Call trace:
[ 1621.729587] __vunmap+0x78/0x30c
[ 1621.732801] vunmap+0x40/0x5c
[ 1621.735756] dma_direct_free+0x10c/0x110
[ 1621.739665] dma_free_attrs+0x98/0xe0
[ 1621.743313] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1621.748616] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1621.753571] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1621.758872] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1621.763826] v4l2_release+0xbc/0xf0 [videodev]
[ 1621.768279] __fput+0x70/0x250
[ 1621.771322] ____fput+0x10/0x20
[ 1621.774451] task_work_run+0x80/0xe0
[ 1621.778014] do_notify_resume+0x208/0x1280
[ 1621.782098] el0_svc+0x74/0x84
[ 1621.785140] el0t_64_sync_handler+0xbc/0x140
[ 1621.789394] el0t_64_sync+0x18c/0x190
[ 1621.793043] ---[ end trace 0000000000000000 ]---
[ 1621.797664] ------------[ cut here ]------------
[ 1621.802272] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1621.808618] WARNING: CPU: 6 PID: 3373 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1621.815823] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf000000
[ 1621.933850] x23: 0000000939260000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1621.940968] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1621.948086] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0bb7b7
[ 1621.955204] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000015c
[ 1621.962323] x11: 0000000000000074 x10: ffff8000092da030 x9 : ffff800009281550
[ 1621.969440] x8 : 0000000100001074 x7 : ffff8000092d9550 x6 : 0000000000000ae0
[ 1621.976557] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1621.983673] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1621.990791] Call trace:
[ 1621.993225] __vunmap+0x78/0x30c
[ 1621.996440] vunmap+0x40/0x5c
[ 1621.999395] dma_direct_free+0x10c/0x110
[ 1622.003305] dma_free_attrs+0x98/0xe0
[ 1622.006953] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1622.012255] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1622.017123] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1622.022424] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1622.027377] v4l2_release+0xbc/0xf0 [videodev]
[ 1622.031827] __fput+0x70/0x250
[ 1622.034870] ____fput+0x10/0x20
[ 1622.038000] task_work_run+0x80/0xe0
[ 1622.041561] do_notify_resume+0x208/0x1280
[ 1622.045645] el0_svc+0x74/0x84
[ 1622.048687] el0t_64_sync_handler+0xbc/0x140
[ 1622.052942] el0t_64_sync+0x18c/0x190
[ 1622.056589] ---[ end trace 0000000000000000 ]---
[ 1622.129040] BUG: Bad page state in process videotestsrc0:s pfn:939340
[ 1622.135578] page:0000000012c5a0d4 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939340
[ 1622.145049] flags: 0x8000000000000000(zone=2)
[ 1622.149410] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1622.157144] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1622.164898] page dumped because: nonzero _refcount
[ 1622.169681] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memopsidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1622.241416] CPU: 1 PID: 3377 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1622.250615] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1622.256257] Call trace:
[ 1622.258692] dump_backtrace.part.0+0xdc/0xf0
[ 1622.262960] show_stack+0x18/0x30
[ 1622.266264] dump_stack_lvl+0x68/0x84
[ 1622.269919] dump_stack+0x18/0x34
[ 1622.273222] bad_page+0xe8/0x110
[ 1622.276439] check_new_pages+0xe0/0x110
[ 1622.280261] get_page_from_freelist+0x574/0xf10
[ 1622.284778] __alloc_pages+0x134/0xcec
[ 1622.288514] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1622.294246] dma_direct_alloc+0xd8/0x304
[ 1622.298154] dma_alloc_attrs+0x7c/0xe4
[ 1622.301889] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1622.307546] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1622.313801] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1622.320143] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1622.325617] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1622.331269] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1622.336140] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1622.341792] v4l_reqbufs+0x50/0x64 [videodev]
[ 1622.346160] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1622.351130] video_usercopy+0x214/0x6c4 [videodev]
[ 1622.355926] video_ioctl2+0x18/0x2c [videodev]
[ 1622.360376] v4l2_ioctl+0x40/0x60 [videodev]
[ 1622.364653] __arm64_sys_ioctl+0xa8/0xf0
[ 1622.368562] invoke_syscall+0x48/0x114
[ 1622.372300] el0_svc_common.constprop.0+0xd4/0xfc
[ 1622.376990] do_el0_svc+0x30/0xd0
[ 1622.380291] el0_svc+0x2c/0x84
[ 1622.383333] el0t_64_sync_handler+0xbc/0x140
[ 1622.387589] el0t_64_sync+0x18c/0x190
[ 1622.391262] BUG: Bad page state insfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1622.503546] CPU: 1 PID: 3377 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1622.512743] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1622.518383] Call trace:
[ 1622.520816] dump_backtrace.part.0+0xdc/0xf0
[ 1622.525075] show_stack+0x18/0x30
[ 1622.528378] dump_stack_lvl+0x68/0x84
[ 1622.532030] dump_stack+0x18/0x34
[ 1622.535333] bad_page+0xe8/0x110
[ 1622.538549] check_new_pages+0xe0/0x110
[ 1622.542371] get_page_from_freelist+0x574/0xf10
[ 1622.546886] __alloc_pages+0x134/0xcec
[ 1622.550622] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1622.556352] dma_direct_alloc+0xd8/0x304
[ 1622.560260] dma_alloc_attrs+0x7c/0xe4
[ 1622.563995] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1622.569645] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1622.575899] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1622.582241] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1622.587715] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1622.593365] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1622.598233] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1622.603882] v4l_reqbufs+0x50/0x64 [videodev]
[ 1622.608249] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1622.613219] video_usercopy+0x214/0x6c4 [videodev]
[ 1622.618015] video_ioctl2+0x18/0x2c [videodev]
[ 1622.622464] v4l2_ioctl+0x40/0x60 [videodev]
[ 1622.626741] __arm64_sys_ioctl+0xa8/0xf0
[ 1622.630649] invoke_syscall+0x48/0x114
[ 1622.634385] el0_svc_common.constprop.0+0xd4/0xfc
[ 1622.639075] do_el0_svc+0x30/0xd0
[ 1622.642378] el0_svc+0x2c/0x84
[ 1622.645419] el0t_64_sync_handler+0xbc/0x140
[ 1622.649675] el0t_64_sync+0x18c/0x190
[ 1622.656465] BUG: Bad page state in process videotestsrc0:s pfn:939400
[ 1622.662985] page:000000000fa197fe refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939400
[ 1622.672453] flags: 0x8000000000000000(zone=2)
[ 1622.676804] raw: 22.768740] CPU: 1 PID: 3377 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1622.777937] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1622.783580] Call trace:
[ 1622.786013] dump_backtrace.part.0+0xdc/0xf0
[ 1622.790271] show_stack+0x18/0x30
[ 1622.793574] dump_stack_lvl+0x68/0x84
[ 1622.797225] dump_stack+0x18/0x34
[ 1622.800528] bad_page+0xe8/0x110
[ 1622.803743] check_new_pages+0xe0/0x110
[ 1622.807565] get_page_from_freelist+0x574/0xf10
[ 1622.812081] __alloc_pages+0x134/0xcec
[ 1622.815817] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1622.821548] dma_direct_alloc+0xd8/0x304
[ 1622.825456] dma_alloc_attrs+0x7c/0xe4
[ 1622.829191] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1622.834842] wave5_vpu_enc_register_framebuffer+0x274/0x6f0 [wave5]
[ 1622.841096] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1622.847438] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1622.852912] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1622.858562] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1622.863431] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1622.869081] v4l_reqbufs+0x50/0x64 [videodev]
[ 1622.873448] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1622.878418] video_usercopy+0x214/0x6c4 [videodev]
[ 1622.883215] video_ioctl2+0x18/0x2c [videodev]
[ 1622.887664] v4l2_ioctl+0x40/0x60 [videodev]
[ 1622.891941] __arm64_sys_ioctl+0xa8/0xf0
[ 1622.895849] invoke_syscall+0x48/0x114
[ 1622.899585] el0_svc_common.constprop.0+0xd4/0xfc
[ 1622.904275] do_el0_svc+0x30/0xd0
[ 1622.907577] el0_svc+0x2c/0x84
[ 1622.910617] el0t_64_sync_handler+0xbc/0x140
[ 1622.914873] el0t_64_sync+0x18c/0x190
[ 1622.919926] ------------[ cut here ]------------
[ 1622.924560] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1622.930970] WARNING: CPU: 0 PID: 3376 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1622.938179] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce0000000000000
[ 1623.049109] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1623.056227] x23: 0000000939480000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1623.063345] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1623.070463] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1623.077581] x14: 000000000000002b x13: 0000000000000000 x12: 0000000000000000
[ 1623.084698] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0eb980
[ 1623.091816] x8 : ffff0008aae15150 x7 : ffff000f5c370340 x6 : 0000000000000000
[ 1623.098934] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1b473c8
[ 1623.106052] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1623.113169] Call trace:
[ 1623.115603] __vunmap+0x78/0x30c
[ 1623.118819] vunmap+0x40/0x5c
[ 1623.121775] dma_direct_free+0x10c/0x110
[ 1623.125685] dma_free_attrs+0x98/0xe0
[ 1623.129333] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1623.134640] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1623.139596] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1623.144898] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1623.149852] v4l2_release+0xbc/0xf0 [videodev]
[ 1623.154303] __fput+0x70/0x250
[ 1623.157348] ____fput+0x10/0x20
[ 1623.160477] task_work_run+0x80/0xe0
[ 1623.164040] do_notify_resume+0x208/0x1280
[ 1623.168125] el0_svc+0x74/0x84
[ 1623.171167] el0t_64_sync_handler+0xbc/0x140
[ 1623.175423] el0t_64_sync+0x18c/0x190
[ 1623.179072] ---[ end trace 0000000000000000 ]---
[ 1623.183746] ------------[ cut here ]------------
[ 1623.188356] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1623.194706] WARNING: CPU: 0 PID: 3376 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1623.201912] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_k31] vunmap+0x40/0x5c
[ 1623.385487] dma_direct_free+0x10c/0x110
[ 1623.389395] dma_free_attrs+0x98/0xe0
[ 1623.393043] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1623.398346] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1623.403300] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1623.408602] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1623.413555] v4l2_release+0xbc/0xf0 [videodev]
[ 1623.418007] __fput+0x70/0x250
[ 1623.421049] ____fput+0x10/0x20
[ 1623.424179] task_work_run+0x80/0xe0
[ 1623.427741] do_notify_resume+0x208/0x1280
[ 1623.431825] el0_svc+0x74/0x84
[ 1623.434867] el0t_64_sync_handler+0xbc/0x140
[ 1623.439123] el0t_64_sync+0x18c/0x190
[ 1623.442771] ---[ end trace 0000000000000000 ]---
[ 1623.447410] ------------[ cut here ]------------
[ 1623.452050] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1623.458452] WARNING: CPU: 0 PID: 3376 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1623.465659] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1623.537339] CPU: 0 PID: 3376 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1623.546449] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1623.552090] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1623.559033] pc : __vunmap+0x78/0x30c
[ 1623.562594] lr : __vunmap+0x78/0x30c
[ 1623.566156] sp : ffff80000c0ebad0
[ 1623.569455] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1623.590
[ 1623.706523] ---[ end trace 0000000000000000 ]---
[ 1623.711200] ------------[ cut here ]------------
[ 1623.715811] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1623.722160] WARNING: CPU: 0 PID: 3376 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1623.729365] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1623.801041] CPU: 0 PID: 3376 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1623.810150] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1623.815791] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1623.822734] pc : __vunmap+0x78/0x30c
[ 1623.826295] lr : __vunmap+0x78/0x30c
[ 1623.829857] sp : ffff80000c0ebad0
[ 1623.833157] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1623.840275] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1623.847393] x23: 00000009393a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1623.854510] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1623.861627] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1623.868745] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000048c
[ 1623.875862] x11: 0000000000000184 x10: ffff8000092db9b0 x9 : 0000000000000027
[ 1623.882980] x8 : 0000000000000000 x7 : 0000000000000076 x6 : 0000000000009f5b
[ 1623.890099] x5 : 000000000000002b x4 : 000000000000af5b x3 : ffff000f5c370d30
[ 1623.897216] x2 : 000000000000
[ 1624.035974] cma_alloc: 5 callbacks suppressed
[ 1624.035984] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1624.050451] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1624.059491] BUG: Bad page state in process videotestsrc0:s pfn:9393c0
[ 1624.066011] page:000000001a5c4471 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9393c0
[ 1624.075479] flags: 0x8000000000000000(zone=2)
[ 1624.079838] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1624.087571] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1624.095301] page dumped because: nonzero _refcount
[ 1624.100085] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1624.171813] CPU: 0 PID: 3380 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1624.181010] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1624.186652] Call trace:
[ 1624.189086] dump_backtrace.part.0+0xdc/0xf0
[ 1624.193354] show_stack+0x18/0x30
[ 1624.196659] dump_stack_lvl+0x68/0x84
[ 1624.200311] dump_stack+0x18/0x34
[ 1624.203614] bad_page+0xe8/0x110
[ 1624.206830] check_new_pages+0xe0/0x110
[ 1624.210653] get_page_from_freelist+0x574/0xf10+0xbc/0x140
[ 1624.317980] el0t_64_sync+0x18c/0x190
[ 1624.321663] BUG: Bad page state in process videotestsrc0:s pfn:939440
[ 1624.328186] page:00000000b8fec8c8 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939440
[ 1624.337651] flags: 0x8000000000000000(zone=2)
[ 1624.342004] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1624.349737] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1624.357468] page dumped because: nonzero _refcount
[ 1624.362249] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1624.433950] CPU: 0 PID: 3380 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1624.443148] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1624.448789] Call trace:
[ 1624.451222] dump_backtrace.part.0+0xdc/0xf0
[ 1624.455481] show_stack+0x18/0x30
[ 1624.458784] dump_stack_lvl+0x68/0x84
[ 1624.462435] dump_stack+0x18/0x34
[ 1624.465737] bad_page+0xe8/0x110
[ 1624.468954] check_new_pages+0xe0/0x110
[ 1624.472776] get_page_from_freelist+0x574/0xf10
[ 1624.477291] __alloc_pages+0x134/0xcec
[ 1624.481026] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1624.486755] dma_direct_alloc+0xd8/0x304
[ 1624.490663] dma_alloc_attrs+0x7c/0xe4
[ 1624.494398] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1624.500048] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1624.506303] wave5_vpu_enc_register_fram000080ac67b3 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939480
[ 1624.599739] flags: 0x8000000000000000(zone=2)
[ 1624.604089] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1624.611819] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1624.619550] page dumped because: nonzero _refcount
[ 1624.624332] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1624.696034] CPU: 0 PID: 3380 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1624.705232] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1624.710872] Call trace:
[ 1624.713306] dump_backtrace.part.0+0xdc/0xf0
[ 1624.717564] show_stack+0x18/0x30
[ 1624.720867] dump_stack_lvl+0x68/0x84
[ 1624.724518] dump_stack+0x18/0x34
[ 1624.727821] bad_page+0xe8/0x110
[ 1624.731038] check_new_pages+0xe0/0x110
[ 1624.734860] get_page_from_freelist+0x574/0xf10
[ 1624.739377] __alloc_pages+0x134/0xcec
[ 1624.743113] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1624.748843] dma_direct_alloc+0xd8/0x304
[ 1624.752751] dma_alloc_attrs+0x7c/0xe4
[ 1624.756486] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1624.762135] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1624.768390] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1624.774731] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1624.780206] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ page:00000000eadf23ff refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9394c0
[ 1624.861735] flags: 0x8000000000000000(zone=2)
[ 1624.866088] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1624.873820] raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
[ 1624.881551] page dumped because: nonzero _refcount
[ 1624.886332] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1624.958035] CPU: 0 PID: 3380 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1624.967232] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1624.972873] Call trace:
[ 1624.975306] dump_backtrace.part.0+0xdc/0xf0
[ 1624.979564] show_stack+0x18/0x30
[ 1624.982867] dump_stack_lvl+0x68/0x84
[ 1624.986517] dump_stack+0x18/0x34
[ 1624.989820] bad_page+0xe8/0x110
[ 1624.993034] check_new_pages+0xe0/0x110
[ 1624.996856] get_page_from_freelist+0x574/0xf10
[ 1625.001373] __alloc_pages+0x134/0xcec
[ 1625.005108] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1625.010837] dma_direct_alloc+0xd8/0x304
[ 1625.014745] dma_alloc_attrs+0x7c/0xe4
[ 1625.018480] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1625.024130] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1625.030385] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1625.036727] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1625.042202] vb2_core_reqbufs+0x138/0x460 [videobuf2_h ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1625.229547] CPU: 6 PID: 3379 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1625.238658] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1625.244300] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1625.251243] pc : __vunmap+0x78/0x30c
[ 1625.254805] lr : __vunmap+0x78/0x30c
[ 1625.258367] sp : ffff80000bdf3ad0
[ 1625.261667] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1625.268786] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1625.275903] x23: 0000000939580000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1625.283021] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1625.290138] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1625.297255] x14: 0000000000000056 x13: 0000000000000000 x12: 0000000000000000
[ 1625.304373] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bdf3980
[ 1625.311490] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1625.318607] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d83c8
[ 1625.325725] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1625.332843] Call trace:
[ 1625.335277] __vunmap+0x78/0x30c
[ 1625.338493] vunmap+0x40/0x5c
[ 1625.341448] dma_direct_free+0x10c/0x110
[ 1625.345358] dma_free_attrs+0x98/0xe0
[ 1625.349007] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1625.354316] wave5_vpu_enc_close+0x124211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1625.493211] CPU: 6 PID: 3379 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1625.502321] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1625.507963] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1625.514905] pc : __vunmap+0x78/0x30c
[ 1625.518467] lr : __vunmap+0x78/0x30c
[ 1625.522029] sp : ffff80000bdf3ad0
[ 1625.525328] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1625.532446] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1625.539563] x23: 00000009394c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1625.546680] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1625.553798] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bdf37b7
[ 1625.560915] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000762
[ 1625.568032] x11: 0000000000000276 x10: ffff8000092dd060 x9 : ffff800009281550
[ 1625.575149] x8 : 0000000100001276 x7 : ffff8000092d9550 x6 : 0000000000003b10
[ 1625.582266] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1625.589383] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1625.596500] Call trace:
[ 1625.598933] __vunmap+0x78/0x30c
[ 1625.602149] vunmap+0x40/0x5c
[ 1625.605104] dma_direct_free+0x10c/0x110
[ 1625.609014] dma_free_attrs+0x98/0xe0
[ 1625.612661] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1625.617nt_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1625.756865] CPU: 6 PID: 3379 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1625.765975] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1625.771616] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1625.778559] pc : __vunmap+0x78/0x30c
[ 1625.782120] lr : __vunmap+0x78/0x30c
[ 1625.785681] sp : ffff80000bdf3ad0
[ 1625.788981] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1625.796099] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1625.803216] x23: 0000000939500000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1625.810334] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1625.817451] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bdf37b7
[ 1625.824568] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000007d4
[ 1625.831686] x11: 000000000000029c x10: ffff8000092dd3f0 x9 : ffff800009281550
[ 1625.838803] x8 : 000000010000129c x7 : ffff8000092d9550 x6 : 0000000000003ea0
[ 1625.845920] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1625.853038] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1625.860155] Call trace:
[ 1625.862588] __vunmap+0x78/0x30c
[ 1625.865803] vunmap+0x40/0x5c
[ 1625.868758] dma_direct_free+0x10c/0x110
[ 1625.872667] dma_free_attrs+0x98/0xe0
[ 1625.876315] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1625.881617] wave5_vpu
[ 1625.935265] Trying to vfree() nonexistent vm area (00000000203b84ee)
[ 1625.941609] WARNING: CPU: 6 PID: 3379 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1625.948813] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1626.020488] CPU: 6 PID: 3379 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1626.029597] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1626.035238] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1626.042180] pc : __vunmap+0x78/0x30c
[ 1626.045741] lr : __vunmap+0x78/0x30c
[ 1626.049302] sp : ffff80000bdf3ad0
[ 1626.052602] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1626.059720] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1626.066837] x23: 00000009393e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1626.073954] x20: 0000000000000000 x19: ffff80000c375000 x18: ffffffffffffffff
[ 1626.081071] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bdf37b7
[ 1626.088188] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000846
[ 1626.095305] x11: 00000000000002c2 x10: ffff8000092dd780 x9 : ffff800009281550
[ 1626.102423] x8 : 00000001000012c2 x7 : ffff8000092d9550 x6 : 0000000000004230
[ 1626.109540] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1626.116657] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1626.123774] Call trace:
[ 1626.126207] __vunmap+0x78
[ 1626.261887] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1626.271973] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1626.281014] BUG: Bad page state in process videotestsrc0:s pfn:9394c0
[ 1626.287533] page:00000000eadf23ff refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9394c0
[ 1626.297026] flags: 0x8000000000000000(zone=2)
[ 1626.301382] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1626.309112] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1626.316840] page dumped because: nonzero _refcount
[ 1626.321624] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1626.393352] CPU: 1 PID: 3383 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1626.402550] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1626.408193] Call trace:
[ 1626.410627] dump_backtrace.part.0+0xdc/0xf0
[ 1626.414894] show_stack+0x18/0x30
[ 1626.418198] dump_stack_lvl+0x68/0x84
[ 1626.421852] dump_stack+0x18/0x34
[ 1626.425155] bad_page+0xe8/0x110
[ 1626.428372] check_new_pages+0xe0/0x110
[ 1626.432194] get_page_from_freelist+0x574/0xf10
[ 1626.436712] __alloc_pages+0x134/0xcec
[ 16212317] v4l2_ioctl+0x40/0x60 [videodev]
[ 1626.516593] __arm64_sys_ioctl+0xa8/0xf0
[ 1626.520504] invoke_syscall+0x48/0x114
[ 1626.524242] el0_svc_common.constprop.0+0xd4/0xfc
[ 1626.528932] do_el0_svc+0x30/0xd0
[ 1626.532234] el0_svc+0x2c/0x84
[ 1626.535276] el0t_64_sync_handler+0xbc/0x140
[ 1626.539531] el0t_64_sync+0x18c/0x190
[ 1626.543205] BUG: Bad page state in process videotestsrc0:s pfn:939500
[ 1626.549727] page:000000000c00e5cc refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939500
[ 1626.559195] flags: 0x8000000000000000(zone=2)
[ 1626.563545] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1626.571273] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1626.579001] page dumped because: nonzero _refcount
[ 1626.583785] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1626.655488] CPU: 1 PID: 3383 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1626.664686] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1626.670326] Call trace:
[ 1626.672759] dump_backtrace.part.0+0xdc/0xf0
[ 1626.677020] show_stack+0x18/0x30
[ 1626.680322] dump_stack_lvl+0x68/0x84
[ 1626.683973] dump_stack+0x18/0x34
[ 1626.687276] bad_page+0xe8/0x110
[ 1626.690492] check_new_pages+0xe0/0x110
[ 1626.694314] get_page_from_freelist+0x574/0xf10
[ 1626.698831] __alloc_pages+0x134/0xcec
[ 1626.702567] __dma_direct_alloc_pages.constpropx140
[ 1626.801624] el0t_64_sync+0x18c/0x190
[ 1626.807857] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1626.817420] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1626.826457] BUG: Bad page state in process videotestsrc0:s pfn:939580
[ 1626.832975] page:000000002571cc05 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939580
[ 1626.842440] flags: 0x8000000000000000(zone=2)
[ 1626.846790] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1626.854520] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1626.862255] page dumped because: nonzero _refcount
[ 1626.867037] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1626.938735] CPU: 1 PID: 3383 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1626.947933] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1626.953574] Call trace:
[ 1626.956006] dump_backtrace.part.0+0xdc/0xf0
[ 1626.960265] show_stack+0x18/0x30
[ 1626.963568] dump_stack_lvl+0x68/0x84
[ 1626.967218] dump_stack+0x18/0x34
[ 1626.970521] bad_page+0xe8/0x110
[ 1626.973736] check_new_pages+0xe0/0x110
[ 1626.977558] get_page_from_freelist+0x574/0xf10
[ 1626.982074] __alloc_pages+0x134/0xcec
[ 1626.985810] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1626.991539] dma_direct_alloc+0xd8/0x304_v4l2]
[ 1627.033427] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1627.039077] v4l_reqbufs+0x50/0x64 [videodev]
[ 1627.043444] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1627.048413] video_usercopy+0x214/0x6c4 [videodev]
[ 1627.053209] video_ioctl2+0x18/0x2c [videodev]
[ 1627.057659] v4l2_ioctl+0x40/0x60 [videodev]
[ 1627.061935] __arm64_sys_ioctl+0xa8/0xf0
[ 1627.065843] invoke_syscall+0x48/0x114
[ 1627.069580] el0_svc_common.constprop.0+0xd4/0xfc
[ 1627.074270] do_el0_svc+0x30/0xd0
[ 1627.077572] el0_svc+0x2c/0x84
[ 1627.080613] el0t_64_sync_handler+0xbc/0x140
[ 1627.084868] el0t_64_sync+0x18c/0x190
[ 1627.088792] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1627.099461] ------------[ cut here ]------------
[ 1627.104085] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1627.110441] WARNING: CPU: 0 PID: 3382 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1627.117648] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1627.189336] CPU: 0 PID: 3382 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1627.198446] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1627.204086] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1627.211030] pc : __vunmap+0x78/0x30c
[ 1627.214592] lr : __vunmap+0x78/0x30c
[ 1627.218154] sp : ffff80000c3bbad0
[ 1627.221454] x29: ffff80000c3bbad0 x28: 0000000000000204 x27: 00000000000000000005178
[ 1627.278398] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1627.285514] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1627.292633] Call trace:
[ 1627.295066] __vunmap+0x78/0x30c
[ 1627.298281] vunmap+0x40/0x5c
[ 1627.301236] dma_direct_free+0x10c/0x110
[ 1627.305146] dma_free_attrs+0x98/0xe0
[ 1627.308794] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1627.314099] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1627.319054] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1627.324355] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1627.329309] v4l2_release+0xbc/0xf0 [videodev]
[ 1627.333761] __fput+0x70/0x250
[ 1627.336805] ____fput+0x10/0x20
[ 1627.339935] task_work_run+0x80/0xe0
[ 1627.343499] do_notify_resume+0x208/0x1280
[ 1627.347583] el0_svc+0x74/0x84
[ 1627.350624] el0t_64_sync_handler+0xbc/0x140
[ 1627.354878] el0t_64_sync+0x18c/0x190
[ 1627.358526] ---[ end trace 0000000000000000 ]---
[ 1627.363169] ------------[ cut here ]------------
[ 1627.367777] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1627.374123] WARNING: CPU: 0 PID: 3382 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1627.381329] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1627.453006] CPU: 0 PID: 3382 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1627.462115] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1627.467756] pstate: 60000005 (nZClose+0x114/0x18c [wave5]
[ 1627.582716] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1627.588017] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1627.592972] v4l2_release+0xbc/0xf0 [videodev]
[ 1627.597425] __fput+0x70/0x250
[ 1627.600467] ____fput+0x10/0x20
[ 1627.603597] task_work_run+0x80/0xe0
[ 1627.607159] do_notify_resume+0x208/0x1280
[ 1627.611244] el0_svc+0x74/0x84
[ 1627.614285] el0t_64_sync_handler+0xbc/0x140
[ 1627.618540] el0t_64_sync+0x18c/0x190
[ 1627.622189] ---[ end trace 0000000000000000 ]---
[ 1627.626825] ------------[ cut here ]------------
[ 1627.631448] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1627.637795] WARNING: CPU: 0 PID: 3382 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1627.645001] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1627.716679] CPU: 0 PID: 3382 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1627.725788] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1627.731429] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1627.738370] pc : __vunmap+0x78/0x30c
[ 1627.741932] lr : __vunmap+0x78/0x30c
[ 1627.745494] sp : ffff80000c3bbad0
[ 1627.748793] x29: ffff80000c3bbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1627.755911] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1627.763028] x23: 0000000939540000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1627.770145] x20: 0000000000000000 x19: 74/0x84
[ 1627.877953] el0t_64_sync_handler+0xbc/0x140
[ 1627.882207] el0t_64_sync+0x18c/0x190
[ 1627.885856] ---[ end trace 0000000000000000 ]---
[ 1627.890488] ------------[ cut here ]------------
[ 1627.895096] Trying to vfree() nonexistent vm area (00000000203b84ee)
[ 1627.901443] WARNING: CPU: 0 PID: 3382 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1627.908647] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1627.980323] CPU: 0 PID: 3382 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1627.989433] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1627.995073] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1628.002016] pc : __vunmap+0x78/0x30c
[ 1628.005578] lr : __vunmap+0x78/0x30c
[ 1628.009139] sp : ffff80000c3bbad0
[ 1628.012439] x29: ffff80000c3bbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1628.019557] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1628.026674] x23: 0000000939520000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1628.033792] x20: 0000000000000000 x19: ffff80000c375000 x18: ffffffffffffffff
[ 1628.040910] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3bb7b7
[ 1628.048028] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000b85
[ 1628.055145] x11: 00000000000003d7 x10: ffff8000092df178 x9 : ffff800009281550
[ 1628.062262] x8 : 00000001000013d7 x7 : ffff8000092d9550 x6 : 0000000000005c28
[ 1628.069381] l0_svc+0x74/0x84
[ 1628.141512] el0t_64_sync_handler+0xbc/0x140
[ 1628.145767] el0t_64_sync+0x18c/0x190
[ 1628.149415] ---[ end trace 0000000000000000 ]---
[ 1628.216719] BUG: Bad page state in process videotestsrc0:s pfn:9395c0
[ 1628.223249] page:0000000055ba592d refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9395c0
[ 1628.232721] flags: 0x8000000000000000(zone=2)
[ 1628.237075] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1628.244804] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1628.252531] page dumped because: nonzero _refcount
[ 1628.257310] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1628.329028] CPU: 7 PID: 3386 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1628.338225] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1628.343866] Call trace:
[ 1628.346300] dump_backtrace.part.0+0xdc/0xf0
[ 1628.350567] show_stack+0x18/0x30
[ 1628.353871] dump_stack_lvl+0x68/0x84
[ 1628.357524] dump_stack+0x18/0x34
[ 1628.360827] bad_page+0xe8/0x110
[ 1628.364045] check_new_pages+0xe0/0x110
[ 1628.367866] get_page_from_freelist+0x574/0xf10
[ 1628.372384] __alloc_pages+0x134/0xcec
[ 1628.376121] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1628.381852] dma_direct_alloc+0xd8/0x304
[ 1628.385761] dma_alloc_attrs+0x7c/0xe4
[ 1628.389497] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wa0 [videodev]
[ 1628.452261] __arm64_sys_ioctl+0xa8/0xf0
[ 1628.456172] invoke_syscall+0x48/0x114
[ 1628.459911] el0_svc_common.constprop.0+0xd4/0xfc
[ 1628.464601] do_el0_svc+0x30/0xd0
[ 1628.467903] el0_svc+0x2c/0x84
[ 1628.470944] el0t_64_sync_handler+0xbc/0x140
[ 1628.475201] el0t_64_sync+0x18c/0x190
[ 1628.478870] BUG: Bad page state in process videotestsrc0:s pfn:939540
[ 1628.485391] page:000000006b48464b refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939540
[ 1628.494855] flags: 0x8000000000000000(zone=2)
[ 1628.499203] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1628.506931] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1628.514657] page dumped because: nonzero _refcount
[ 1628.519437] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1628.591134] CPU: 7 PID: 3386 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1628.600331] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1628.605972] Call trace:
[ 1628.608406] dump_backtrace.part.0+0xdc/0xf0
[ 1628.612667] show_stack+0x18/0x30
[ 1628.615970] dump_stack_lvl+0x68/0x84
[ 1628.619621] dump_stack+0x18/0x34
[ 1628.622924] bad_page+0xe8/0x110
[ 1628.626139] check_new_pages+0xe0/0x110
[ 1628.629960] get_page_from_freelist+0x574/0xf10
[ 1628.634477] __alloc_pages+0x134/0xcec
[ 1628.638213] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1628.64ctl+0x40/0x60 [videodev]
[ 1628.714335] __arm64_sys_ioctl+0xa8/0xf0
[ 1628.718246] invoke_syscall+0x48/0x114
[ 1628.721983] el0_svc_common.constprop.0+0xd4/0xfc
[ 1628.726673] do_el0_svc+0x30/0xd0
[ 1628.729976] el0_svc+0x2c/0x84
[ 1628.733018] el0t_64_sync_handler+0xbc/0x140
[ 1628.737274] el0t_64_sync+0x18c/0x190
[ 1628.740936] BUG: Bad page state in process videotestsrc0:s pfn:939600
[ 1628.747452] page:00000000dcc26feb refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939600
[ 1628.756915] flags: 0x8000000000000000(zone=2)
[ 1628.761263] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1628.768990] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1628.776715] page dumped because: nonzero _refcount
[ 1628.781494] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1628.853186] CPU: 7 PID: 3386 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1628.862383] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1628.868024] Call trace:
[ 1628.870457] dump_backtrace.part.0+0xdc/0xf0
[ 1628.874717] show_stack+0x18/0x30
[ 1628.878019] dump_stack_lvl+0x68/0x84
[ 1628.881669] dump_stack+0x18/0x34
[ 1628.884972] bad_page+0xe8/0x110
[ 1628.888189] check_new_pages+0xe0/0x110
[ 1628.892011] get_page_from_freelist+0x574/0xf10
[ 1628.896527] __alloc_pages+0x134/0xcec
[ 1628.900263] __dma_direct_alloc_pages.constprop.0+0x164/0x167658] video_ioctl2+0x18/0x2c [videodev]
[ 1628.972108] v4l2_ioctl+0x40/0x60 [videodev]
[ 1628.976385] __arm64_sys_ioctl+0xa8/0xf0
[ 1628.980293] invoke_syscall+0x48/0x114
[ 1628.984029] el0_svc_common.constprop.0+0xd4/0xfc
[ 1628.988719] do_el0_svc+0x30/0xd0
[ 1628.992021] el0_svc+0x2c/0x84
[ 1628.995062] el0t_64_sync_handler+0xbc/0x140
[ 1628.999317] el0t_64_sync+0x18c/0x190
[ 1629.002979] BUG: Bad page state in process videotestsrc0:s pfn:939640
[ 1629.009493] page:000000001310396a refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939640
[ 1629.018869] flags: 0x8000000000000000(zone=2)
[ 1629.023217] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1629.030943] raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
[ 1629.038669] page dumped because: nonzero _refcount
[ 1629.043447] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1629.115138] CPU: 7 PID: 3386 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1629.124334] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1629.129974] Call trace:
[ 1629.132407] dump_backtrace.part.0+0xdc/0xf0
[ 1629.136666] show_stack+0x18/0x30
[ 1629.139969] dump_stack_lvl+0x68/0x84
[ 1629.143620] dump_stack+0x18/0x34
[ 1629.146923] bad_page+0xe8/0x110
[ 1629.150139] check_new_pages+0xe0/0x110
[ 1629.153962] get_page_from_freelist+0x574/0xf10
[ 1629.158477] __alloc_pages+0x134/ 1629.267400] cma_alloc: 2 callbacks suppressed
[ 1629.267405] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1629.281327] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1629.290544] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1629.300951] ------------[ cut here ]------------
[ 1629.305570] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1629.311928] WARNING: CPU: 6 PID: 3385 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1629.319138] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1629.390834] CPU: 6 PID: 3385 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1629.399944] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1629.405585] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1629.412528] pc : __vunmap+0x78/0x30c
[ 1629.416090] lr : __vunmap+0x78/0x30c
[ 1629.419652] sp : ffff80000beabad0
[ 1629.422952] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1629.430072] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1629.437190] x23: 0000000939700000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1629.444309] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1629.451426] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1629.458544] x14: 0000000000000000 x13mory+0x34/0x64 [wave5]
[ 1629.515605] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1629.520562] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1629.525863] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1629.530817] v4l2_release+0xbc/0xf0 [videodev]
[ 1629.535272] __fput+0x70/0x250
[ 1629.538315] ____fput+0x10/0x20
[ 1629.541445] task_work_run+0x80/0xe0
[ 1629.545009] do_notify_resume+0x208/0x1280
[ 1629.549094] el0_svc+0x74/0x84
[ 1629.552137] el0t_64_sync_handler+0xbc/0x140
[ 1629.556392] el0t_64_sync+0x18c/0x190
[ 1629.560042] ---[ end trace 0000000000000000 ]---
[ 1629.564673] ------------[ cut here ]------------
[ 1629.569281] Trying to vfree() nonexistent vm area (00000000e0c066f9)
[ 1629.575627] WARNING: CPU: 6 PID: 3385 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1629.582834] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1629.654516] CPU: 6 PID: 3385 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1629.663625] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1629.669265] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1629.676208] pc : __vunmap+0x78/0x30c
[ 1629.679769] lr : __vunmap+0x78/0x30c
[ 1629.683330] sp : ffff80000beabad0
[ 1629.686630] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1629.693748] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1629.700865] x23: 0000000939640000 x22: ffff8000093d6a28 x21: 00vpu_enc_close+0x114/0x18c [wave5]
[ 1629.784222] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1629.789523] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1629.794479] v4l2_release+0xbc/0xf0 [videodev]
[ 1629.798931] __fput+0x70/0x250
[ 1629.801974] ____fput+0x10/0x20
[ 1629.805103] task_work_run+0x80/0xe0
[ 1629.808666] do_notify_resume+0x208/0x1280
[ 1629.812750] el0_svc+0x74/0x84
[ 1629.815792] el0t_64_sync_handler+0xbc/0x140
[ 1629.820047] el0t_64_sync+0x18c/0x190
[ 1629.823696] ---[ end trace 0000000000000000 ]---
[ 1629.828322] ------------[ cut here ]------------
[ 1629.832944] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1629.839291] WARNING: CPU: 6 PID: 3385 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1629.846498] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1629.918176] CPU: 6 PID: 3385 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1629.927285] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1629.932925] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1629.939868] pc : __vunmap+0x78/0x30c
[ 1629.943429] lr : __vunmap+0x78/0x30c
[ 1629.946991] sp : ffff80000beabad0
[ 1629.950291] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1629.957408] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1629.964526] x23: 0000000939680000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1629.971643] x20: 00000000000000 1630.042934] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1630.047887] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1630.053189] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1630.058143] v4l2_release+0xbc/0xf0 [videodev]
[ 1630.062597] __fput+0x70/0x250
[ 1630.065642] ____fput+0x10/0x20
[ 1630.068771] task_work_run+0x80/0xe0
[ 1630.072334] do_notify_resume+0x208/0x1280
[ 1630.076419] el0_svc+0x74/0x84
[ 1630.079460] el0t_64_sync_handler+0xbc/0x140
[ 1630.083715] el0t_64_sync+0x18c/0x190
[ 1630.087363] ---[ end trace 0000000000000000 ]---
[ 1630.092004] ------------[ cut here ]------------
[ 1630.096616] Trying to vfree() nonexistent vm area (000000008a4148f5)
[ 1630.102962] WARNING: CPU: 7 PID: 3385 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1630.110167] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1630.181848] CPU: 7 PID: 3385 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1630.190957] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1630.196599] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1630.203542] pc : __vunmap+0x78/0x30c
[ 1630.207104] lr : __vunmap+0x78/0x30c
[ 1630.210666] sp : ffff80000beabad0
[ 1630.213966] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1630.221085] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1630.228203] x23: 0000000939560000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1630.235320] 0000000000000000 ]---
[ 1630.415948] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1630.426030] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1630.435068] BUG: Bad page state in process videotestsrc0:s pfn:939640
[ 1630.441586] page:000000001310396a refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939640
[ 1630.451051] flags: 0x8000000000000000(zone=2)
[ 1630.455407] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1630.463136] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1630.470865] page dumped because: nonzero _refcount
[ 1630.475644] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1630.547368] CPU: 7 PID: 3389 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1630.556567] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1630.562208] Call trace:
[ 1630.564643] dump_backtrace.part.0+0xdc/0xf0
[ 1630.568911] show_stack+0x18/0x30
[ 1630.572215] dump_stack_lvl+0x68/0x84
[ 1630.575870] dump_stack+0x18/0x34
[ 1630.579173] bad_page+0xe8/0x110
[ 1630.582391] check_new_pages+0xe0/0x110
[ 1630.586213] get_page_from_freelist+0x574/0xf10
[ 1630.590731] __alloc_pages+0x134/0xcec
[ 163y+0x40/0xb0 [wave5]
[ 1630.613505] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1630.619762] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1630.626104] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1630.631579] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1630.637230] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1630.642100] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1630.647752] v4l_reqbufs+0x50/0x64 [videodev]
[ 1630.652121] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1630.657090] video_usercopy+0x214/0x6c4 [videodev]
[ 1630.661886] video_ioctl2+0x18/0x2c [videodev]
[ 1630.666336] v4l2_ioctl+0x40/0x60 [videodev]
[ 1630.670613] __arm64_sys_ioctl+0xa8/0xf0
[ 1630.674522] invoke_syscall+0x48/0x114
[ 1630.678261] el0_svc_common.constprop.0+0xd4/0xfc
[ 1630.682952] do_el0_svc+0x30/0xd0
[ 1630.686255] el0_svc+0x2c/0x84
[ 1630.689297] el0t_64_sync_handler+0xbc/0x140
[ 1630.693552] el0t_64_sync+0x18c/0x190
[ 1630.697219] BUG: Bad page state in process videotestsrc0:s pfn:939680
[ 1630.703744] page:0000000071b38e86 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939680
[ 1630.713209] flags: 0x8000000000000000(zone=2)
[ 1630.717561] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1630.725292] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1630.733021] page dumped because: nonzero _refcount
[ 1630.737802] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) do_ioctl+0x184/0x3d0 [videodev]
[ 1630.919170] video_usercopy+0x214/0x6c4 [videodev]
[ 1630.923966] video_ioctl2+0x18/0x2c [videodev]
[ 1630.928415] v4l2_ioctl+0x40/0x60 [videodev]
[ 1630.932692] __arm64_sys_ioctl+0xa8/0xf0
[ 1630.936600] invoke_syscall+0x48/0x114
[ 1630.940336] el0_svc_common.constprop.0+0xd4/0xfc
[ 1630.945026] do_el0_svc+0x30/0xd0
[ 1630.948329] el0_svc+0x2c/0x84
[ 1630.951371] el0t_64_sync_handler+0xbc/0x140
[ 1630.955626] el0t_64_sync+0x18c/0x190
[ 1630.961751] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1630.971319] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1630.980354] BUG: Bad page state in process videotestsrc0:s pfn:939700
[ 1630.986869] page:00000000c299124f refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939700
[ 1630.996331] flags: 0x8000000000000000(zone=2)
[ 1631.000681] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1631.008408] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1631.016135] page dumped because: nonzero _refcount
[ 1631.020927] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1631.092630] CPU: 7 PID: 3389 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1631.101827] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1631.107467] Call trace:
[ 1631.109900] dump_backtracen.constprop.0+0xd4/0xfc
[ 1631.228165] do_el0_svc+0x30/0xd0
[ 1631.231470] el0_svc+0x2c/0x84
[ 1631.234511] el0t_64_sync_handler+0xbc/0x140
[ 1631.238767] el0t_64_sync+0x18c/0x190
[ 1631.242651] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1631.252986] ------------[ cut here ]------------
[ 1631.257608] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1631.263967] WARNING: CPU: 6 PID: 3388 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1631.271176] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1631.342871] CPU: 6 PID: 3388 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1631.351981] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1631.357623] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1631.364566] pc : __vunmap+0x78/0x30c
[ 1631.368128] lr : __vunmap+0x78/0x30c
[ 1631.371689] sp : ffff80000c0cbad0
[ 1631.374989] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1631.382108] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1631.389225] x23: 0000000939780000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1631.396343] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1631.403461] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1631.410578] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001122
[ 1631.417695] x11: 00000000000005b6ideobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1631.606559] CPU: 6 PID: 3388 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1631.615669] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1631.621310] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1631.628254] pc : __vunmap+0x78/0x30c
[ 1631.631816] lr : __vunmap+0x78/0x30c
[ 1631.635378] sp : ffff80000c0cbad0
[ 1631.638678] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1631.645796] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1631.652913] x23: 0000000939740000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1631.660030] x20: 0000000000000000 x19: ffff80000c5dd000 x18: ffffffffffffffff
[ 1631.667147] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1631.674264] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001194
[ 1631.681381] x11: 00000000000005dc x10: ffff8000092e21f0 x9 : ffff800009281550
[ 1631.688498] x8 : 00000001000015dc x7 : ffff8000092d9550 x6 : 0000000000008ca0
[ 1631.695616] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1631.702733] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1631.709850] Call trace:
[ 1631.712283] __vunmap+0x78/0x30c
[ 1631.715497] vunmap+0x40/0x5c
[ 1631.718452] dma_direct_free+0x10c/0x110
[ 1631.722361] dma_free_attrs+0x98/0xe0
[ 1631.726009] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1631.731312] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1631.736266] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1631.741567] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1631.746522] v4l2_release+0xbc/0xf0 [videodev]
[ 16_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1631.870203] CPU: 6 PID: 3388 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1631.879313] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1631.884954] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1631.891896] pc : __vunmap+0x78/0x30c
[ 1631.895458] lr : __vunmap+0x78/0x30c
[ 1631.899019] sp : ffff80000c0cbad0
[ 1631.902319] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1631.909437] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1631.916554] x23: 00000009396c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1631.923672] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1631.930789] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1631.937906] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001206
[ 1631.945023] x11: 0000000000000602 x10: ffff8000092e2580 x9 : ffff800009281550
[ 1631.952140] x8 : 0000000100001602 x7 : ffff8000092d9550 x6 : 0000000000009030
[ 1631.959258] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1631.966375] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1631.973492] Call trace:
[ 1631.975925] __vunmap+0x78/0x30c
[ 1631.979141] vunmap+0x40/0x5c
[ 1631.982096] dma_direct_free+0x10c/0x110
[ 1631.986005] dma_free_attrs+0x98/0xe0
[ 1631.989652] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1631.994955] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1631.999909] wave5_vpu_release_devicm videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1632.133846] CPU: 6 PID: 3388 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1632.142959] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1632.148599] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1632.155542] pc : __vunmap+0x78/0x30c
[ 1632.159103] lr : __vunmap+0x78/0x30c
[ 1632.162665] sp : ffff80000c0cbad0
[ 1632.165965] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1632.173083] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1632.180201] x23: 00000009396a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1632.187318] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1632.194435] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1632.201552] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001278
[ 1632.208669] x11: 0000000000000628 x10: ffff8000092e2910 x9 : ffff800009281550
[ 1632.215787] x8 : 0000000100001628 x7 : ffff8000092d9550 x6 : 00000000000093c0
[ 1632.222904] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1632.230021] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1632.237138] Call trace:
[ 1632.239571] __vunmap+0x78/0x30c
[ 1632.242786] vunmap+0x40/0x5c
[ 1632.245742] dma_direct_free+0x10c/0x110
[ 1632.249650] dma_free_attrs+0x98/0xe0
[ 1632.253297] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1632.258599] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1632.263467] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1632.268769] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1632.273723] v4l2_release+0xbc/0xf0 [videodev]
[ rs@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1632.378186] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1632.387223] BUG: Bad page state in process videotestsrc0:s pfn:9396c0
[ 1632.393742] page:00000000c3afb317 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9396c0
[ 1632.403208] flags: 0x8000000000000000(zone=2)
[ 1632.407564] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1632.415293] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1632.423022] page dumped because: nonzero _refcount
[ 1632.427804] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1632.499525] CPU: 2 PID: 3392 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1632.508724] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1632.514366] Call trace:
[ 1632.516800] dump_backtrace.part.0+0xdc/0xf0
[ 1632.521067] show_stack+0x18/0x30
[ 1632.524372] dump_stack_lvl+0x68/0x84
[ 1632.528026] dump_stack+0x18/0x34
[ 1632.531329] bad_page+0xe8/0x110
[ 1632.534546] check_new_pages+0xe0/0x110
[ 1632.538368] get_page_from_freelist+0x574/0xf10
[ 1632.542885] __alloc_pages+0x134/0xcec
[ 1632.546621] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1632.552352] dma_direct_alloc+0xd8/0x304
[ 1632.556261] dma_alloc_attrs+0x7c/0xe4
[ 1632.559996] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5x939740
[ 1632.665359] flags: 0x8000000000000000(zone=2)
[ 1632.669713] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1632.677445] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1632.685175] page dumped because: nonzero _refcount
[ 1632.689957] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1632.761650] CPU: 2 PID: 3392 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1632.770847] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1632.776488] Call trace:
[ 1632.778922] dump_backtrace.part.0+0xdc/0xf0
[ 1632.783181] show_stack+0x18/0x30
[ 1632.786484] dump_stack_lvl+0x68/0x84
[ 1632.790135] dump_stack+0x18/0x34
[ 1632.793438] bad_page+0xe8/0x110
[ 1632.796654] check_new_pages+0xe0/0x110
[ 1632.800475] get_page_from_freelist+0x574/0xf10
[ 1632.804991] __alloc_pages+0x134/0xcec
[ 1632.808727] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1632.814458] dma_direct_alloc+0xd8/0x304
[ 1632.818366] dma_alloc_attrs+0x7c/0xe4
[ 1632.822101] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1632.827751] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1632.834005] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1632.840345] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1632.845820] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1632.851469] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1632.856337] v4l2_m21632.947234] page dumped because: nonzero _refcount
[ 1632.952015] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1633.023713] CPU: 2 PID: 3392 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1633.032911] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1633.038551] Call trace:
[ 1633.040984] dump_backtrace.part.0+0xdc/0xf0
[ 1633.045241] show_stack+0x18/0x30
[ 1633.048544] dump_stack_lvl+0x68/0x84
[ 1633.052194] dump_stack+0x18/0x34
[ 1633.055497] bad_page+0xe8/0x110
[ 1633.058712] check_new_pages+0xe0/0x110
[ 1633.062535] get_page_from_freelist+0x574/0xf10
[ 1633.067051] __alloc_pages+0x134/0xcec
[ 1633.070787] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1633.076516] dma_direct_alloc+0xd8/0x304
[ 1633.080425] dma_alloc_attrs+0x7c/0xe4
[ 1633.084160] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1633.089810] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1633.096065] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1633.102406] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1633.107880] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1633.113529] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1633.118396] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1633.124045] v4l_reqbufs+0x50/0x64 [videodev]
[ 1633.128410] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1633.133380] video_usercopy+0x214/0x6c4 [videodev]
[ 1633.138175] video_ioctl2+0x18/0x0516] dump_stack_lvl+0x68/0x84
[ 1633.314166] dump_stack+0x18/0x34
[ 1633.317470] bad_page+0xe8/0x110
[ 1633.320686] check_new_pages+0xe0/0x110
[ 1633.324508] get_page_from_freelist+0x574/0xf10
[ 1633.329025] __alloc_pages+0x134/0xcec
[ 1633.332760] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1633.338490] dma_direct_alloc+0xd8/0x304
[ 1633.342399] dma_alloc_attrs+0x7c/0xe4
[ 1633.346133] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1633.351783] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1633.358038] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1633.364379] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1633.369853] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1633.375501] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1633.380369] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1633.386018] v4l_reqbufs+0x50/0x64 [videodev]
[ 1633.390382] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1633.395351] video_usercopy+0x214/0x6c4 [videodev]
[ 1633.400147] video_ioctl2+0x18/0x2c [videodev]
[ 1633.404596] v4l2_ioctl+0x40/0x60 [videodev]
[ 1633.408872] __arm64_sys_ioctl+0xa8/0xf0
[ 1633.412779] invoke_syscall+0x48/0x114
[ 1633.416516] el0_svc_common.constprop.0+0xd4/0xfc
[ 1633.421206] do_el0_svc+0x30/0xd0
[ 1633.424509] el0_svc+0x2c/0x84
[ 1633.427551] el0t_64_sync_handler+0xbc/0x140
[ 1633.431806] el0t_64_sync+0x18c/0x190
[ 1633.439883] ------------[ cut here ]------------
[ 1633.444504] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1633.450864] WARNING: CPU: 0 PID: 3391 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1633.458074] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa0 x6 : 000000000000a680
[ 1633.618826] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1633.625944] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1633.633062] Call trace:
[ 1633.635495] __vunmap+0x78/0x30c
[ 1633.638710] vunmap+0x40/0x5c
[ 1633.641666] dma_direct_free+0x10c/0x110
[ 1633.645575] dma_free_attrs+0x98/0xe0
[ 1633.649225] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1633.654531] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1633.659485] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1633.664786] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1633.669739] v4l2_release+0xbc/0xf0 [videodev]
[ 1633.674192] __fput+0x70/0x250
[ 1633.677237] ____fput+0x10/0x20
[ 1633.680366] task_work_run+0x80/0xe0
[ 1633.683929] do_notify_resume+0x208/0x1280
[ 1633.688014] el0_svc+0x74/0x84
[ 1633.691057] el0t_64_sync_handler+0xbc/0x140
[ 1633.695312] el0t_64_sync+0x18c/0x190
[ 1633.698961] ---[ end trace 0000000000000000 ]---
[ 1633.703604] ------------[ cut here ]------------
[ 1633.708212] Trying to vfree() nonexistent vm area (00000000e0c066f9)
[ 1633.714559] WARNING: CPU: 0 PID: 3391 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1633.721763] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1633.793440] CPU: 0 PID: 3391 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1633.802549] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1633.808190] pstate: 647] WARNING: CPU: 0 PID: 3391 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1633.985453] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1634.057130] CPU: 0 PID: 3391 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1634.066238] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1634.071878] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1634.078820] pc : __vunmap+0x78/0x30c
[ 1634.082382] lr : __vunmap+0x78/0x30c
[ 1634.085943] sp : ffff80000c0ebad0
[ 1634.089243] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1634.096362] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1634.103479] x23: 0000000939800000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1634.110598] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1634.117716] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1634.124832] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000015b4
[ 1634.131950] x11: 000000000000073c x10: ffff8000092e42f0 x9 : ffff800009281550
[ 1634.139068] x8 : 000000010000173c x7 : ffff8000092d9550 x6 : 000000000000ada0
[ 1634.146186] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1634.153302] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1634.160420] Call trace:
[ 1634.162852] __vunmap+0x78/0x30c
[ 1634.166068] vunmap+0x40/0x5c
[ 1634.169023] dma_direct_free+0x10c/0x110
[x videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1634.320787] CPU: 0 PID: 3391 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1634.329896] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1634.335536] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1634.342479] pc : __vunmap+0x78/0x30c
[ 1634.346041] lr : __vunmap+0x78/0x30c
[ 1634.349602] sp : ffff80000c0ebad0
[ 1634.352902] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1634.360020] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1634.367138] x23: 00000009396e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1634.374256] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1634.381374] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1634.388491] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001626
[ 1634.395610] x11: 0000000000000762 x10: ffff8000092e4680 x9 : ffff800009281550
[ 1634.402727] x8 : 0000000100001762 x7 : ffff8000092d9550 x6 : 000000000000b130
[ 1634.409845] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1634.416961] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1634.424079] Call trace:
[ 1634.426513] __vunmap+0x78/0x30c
[ 1634.429727] vunmap+0x40/0x5c
[ 1634.432682] dma_direct_free+0x10c/0x110
[ 1634.436591] dma_free_attrs+0x98/0xe0
[ 1634.440239] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1634.445541] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1634.450408] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1634.455709] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1634.460663] use: nonzero _refcount
[ 1634.620261] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1634.691981] CPU: 0 PID: 3395 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1634.701178] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1634.706820] Call trace:
[ 1634.709254] dump_backtrace.part.0+0xdc/0xf0
[ 1634.713522] show_stack+0x18/0x30
[ 1634.716826] dump_stack_lvl+0x68/0x84
[ 1634.720479] dump_stack+0x18/0x34
[ 1634.723783] bad_page+0xe8/0x110
[ 1634.727001] check_new_pages+0xe0/0x110
[ 1634.730822] get_page_from_freelist+0x574/0xf10
[ 1634.735337] __alloc_pages+0x134/0xcec
[ 1634.739073] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1634.744804] dma_direct_alloc+0xd8/0x304
[ 1634.748712] dma_alloc_attrs+0x7c/0xe4
[ 1634.752447] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1634.758106] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1634.764360] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1634.770702] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1634.776176] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1634.781827] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1634.786697] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1634.792349] v4l_reqbufs+0x50/0x64 [videodev]
[ 1634.796719] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1634.801690] video_usercopy+0x214/0x6c4 [videodev]
[ 1634.806487] video_ioctl2+0x18/0x2c [videodev]
[ 1_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1634.954112] CPU: 0 PID: 3395 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1634.963310] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1634.968951] Call trace:
[ 1634.971384] dump_backtrace.part.0+0xdc/0xf0
[ 1634.975643] show_stack+0x18/0x30
[ 1634.978946] dump_stack_lvl+0x68/0x84
[ 1634.982596] dump_stack+0x18/0x34
[ 1634.985899] bad_page+0xe8/0x110
[ 1634.989115] check_new_pages+0xe0/0x110
[ 1634.992938] get_page_from_freelist+0x574/0xf10
[ 1634.997455] __alloc_pages+0x134/0xcec
[ 1635.001190] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1635.006920] dma_direct_alloc+0xd8/0x304
[ 1635.010828] dma_alloc_attrs+0x7c/0xe4
[ 1635.014563] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1635.020213] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1635.026467] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1635.032807] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1635.038281] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1635.043931] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1635.048800] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1635.054449] v4l_reqbufs+0x50/0x64 [videodev]
[ 1635.058815] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1635.063786] video_usercopy+0x214/0x6c4 [videodev]
[ 1635.068582] video_ioctl2+0x18/0x2c [videodev]
[ 1635.073031] v4l2_ioctl+0x40/0x60 [videodev]
[ 1635.077308] __arm64_sys_ioctl+0xa8/0xf0
[ 1635.081217] invoke_syscall+0x48/0x114
[ 1635.084954] el0_svc_common.constprop.0+0xd4/0xfc
[ 1635.089644] do_el0_svc+0x30/0xd0
[ 1635.092947] el0_svc+0x2c/0x84
[ 1635.095989] el0t_64_sync_handler+0xbc/0x140
[ 1635.100245] el0t_64_sync+0x18c/0x190
[ 1635.106499] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1635.116118] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1635.125153] BUG: Bad page state in process videotestsrc0:s pfn:939880ame_buffer+0x110/0x170 [wave5]
[ 1635.316131] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1635.321605] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1635.327253] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1635.332123] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1635.337773] v4l_reqbufs+0x50/0x64 [videodev]
[ 1635.342140] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1635.347110] video_usercopy+0x214/0x6c4 [videodev]
[ 1635.351907] video_ioctl2+0x18/0x2c [videodev]
[ 1635.356357] v4l2_ioctl+0x40/0x60 [videodev]
[ 1635.360633] __arm64_sys_ioctl+0xa8/0xf0
[ 1635.364541] invoke_syscall+0x48/0x114
[ 1635.368277] el0_svc_common.constprop.0+0xd4/0xfc
[ 1635.372967] do_el0_svc+0x30/0xd0
[ 1635.376270] el0_svc+0x2c/0x84
[ 1635.379310] el0t_64_sync_handler+0xbc/0x140
[ 1635.383565] el0t_64_sync+0x18c/0x190
[ 1635.387436] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1635.397849] ------------[ cut here ]------------
[ 1635.402468] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1635.408826] WARNING: CPU: 6 PID: 3394 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1635.416037] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1635.487732] CPU: 6 PID: 3394 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1635.496842] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1635.502483] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTPID: 3394 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1635.679733] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1635.751411] CPU: 6 PID: 3394 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1635.760520] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1635.766161] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1635.773104] pc : __vunmap+0x78/0x30c
[ 1635.776666] lr : __vunmap+0x78/0x30c
[ 1635.780227] sp : ffff80000beabad0
[ 1635.783528] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1635.790646] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1635.797764] x23: 00000009398c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1635.804882] x20: 0000000000000000 x19: ffff80000c5dd000 x18: ffffffffffffffff
[ 1635.812000] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1635.819118] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001884
[ 1635.826236] x11: 000000000000082c x10: ffff8000092e5970 x9 : ffff800009281550
[ 1635.833354] x8 : 000000010000182c x7 : ffff8000092d9550 x6 : 000000000000c420
[ 1635.840473] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1635.847591] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1635.854708] Call trace:
[ 1635.857142] __vunmap+0x78/0x30c
[ 1635.860356] vunmap+0x40/0x5c
[ 1635.863311] dma_direct_free+0x10c/0x110
[ 1635.867220] dma
[ 1636.040328] lr : __vunmap+0x78/0x30c
[ 1636.043890] sp : ffff80000beabad0
[ 1636.047194] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1636.054313] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1636.061429] x23: 0000000939840000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1636.068547] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1636.075666] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1636.082783] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000018f6
[ 1636.089901] x11: 0000000000000852 x10: ffff8000092e5d00 x9 : ffff800009281550
[ 1636.097019] x8 : 0000000100001852 x7 : ffff8000092d9550 x6 : 000000000000c7b0
[ 1636.104138] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1636.111255] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1636.118373] Call trace:
[ 1636.120806] __vunmap+0x78/0x30c
[ 1636.124021] vunmap+0x40/0x5c
[ 1636.126976] dma_direct_free+0x10c/0x110
[ 1636.130885] dma_free_attrs+0x98/0xe0
[ 1636.134534] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1636.139836] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1636.144791] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1636.150092] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1636.155046] v4l2_release+0xbc/0xf0 [videodev]
[ 1636.159497] __fput+0x70/0x250
[ 1636.162541] ____fput+0x10/0x20
[ 1636.165670] task_work_run+0x80/0xe0
[ 1636.169232] do_notify_resume+0x208/0x1280
[ 1636.173316] el0_svc+0x74/0x84
[ 1636.176357] el0t_64_sync_handler+0xbc/0x140
[ 1636.180612] el0t_64_sync+0x18c/0x190
[ 1636.184259] ---[ end trace 0000000000000000 ]---
[ 1636.188899] ------------[ cut here ]------------
[ 1636.193507] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1636.199855] WARNING: CPU: 6 PID: 3394 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1636.207059] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 v[ 1636.408362] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1636.413663] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1636.418618] v4l2_release+0xbc/0xf0 [videodev]
[ 1636.423070] __fput+0x70/0x250
[ 1636.426113] ____fput+0x10/0x20
[ 1636.429242] task_work_run+0x80/0xe0
[ 1636.432804] do_notify_resume+0x208/0x1280
[ 1636.436888] el0_svc+0x74/0x84
[ 1636.439929] el0t_64_sync_handler+0xbc/0x140
[ 1636.444185] el0t_64_sync+0x18c/0x190
[ 1636.447834] ---[ end trace 0000000000000000 ]---
[ 1636.513923] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1636.524007] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1636.533045] BUG: Bad page state in process videotestsrc0:s pfn:9398c0
[ 1636.539572] page:000000006215a7f8 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x9398c0
[ 1636.549039] flags: 0x8000000000000000(zone=2)
[ 1636.553398] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1636.561129] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1636.568859] page dumped because: nonzero _refcount
[ 1636.573641] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1636.645364] CPU: 0 PID: 3398 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1636.654563] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1636.660205] Call trace:
[ 1636.662640] dump_backtrace.part.0+0xdc/0xf0
[ 1636.666906] show_stack+0x18/0x30
[ 1636.670211] dump_stack_lvl+0x68/0x84
[ 1636.673866] dump_stack+0x18/0x34
[ 1636.677168] bad_page+0xe8/0x110
[ 1636.680385] check_new_pages+0xe0/0x110
[ 1636.684207] get_page_from_freelist+0x574/0xf10
[ 1636.688724] __alloc_pages+0x134/0xcec
[ 1636.692460] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1636.698191] dma_direct_alloc+0xd8/0x304
[ 1636.702100] dma_alloc_attrs+0x7c/0xe4
[ 1636.705836] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1636.711494] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1636.717749] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1636.724091] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1636.729565] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1636.735216] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1636.740087] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1636.745738] v4l_reqbufs+0x50/0x64 [videodev]
[ 1636.750107] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1636.755076] video_usercopy+0x214/0x6c4 [videodev]
[ 1636.759873] video_ioctl2+0x18/0x2c [videodev]
[ 1636.764322] v4l2_ioctl+0x40/0x60 [videodev]
[ 1636.768599] __arm64_sys_ioctl+0xa8/0xf0
[ 1636.772509] invoke_syscall+0x48/0x114
[ 1636.776248] el0_svc_common.constprop.0+0xd4/0xfc
[ 1636.780937] do_el0_svc+0x30/0xd0
[ 1636.784238] el0_svc+0x2c/0x84
[ 1636.787280] el0t_64_sync_handler+0xbc/0x140
[ 1636.791535] el0t_64_sync+0x18c/0x190
[ 1636.795202] BUG: Bad page state in process videotestsrc0:s pfn:939840
[ 1636.801718] page:00000000399d1f00 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939840
[ 1636.811184] flags: 0x8000000000000000(zone=2)
[ 1636.815535] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1636.823264] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1636.830993] page dumped because: nonzero _refcount
[ 1636.835773] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1636.907471] CPU: 0 PID: 3398 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1636.916667] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1636.922309] Call trace:
[ 1636.924742] dump_backtrace.part.0+0xdc/0xf0
[ 1636.929001] show_stack+0x18/0x30
[ 1636.932306] dump_stack_lvl+0x68/0x84
[ 1636.935957] dump_stack+0x18/0x34
[ 1636.939260] bad_page+0xe8/0x110
[ 1636.942475] check_new_pages+0xe0/0x110
[ 1636.946297] get_page_from_freelist+0x5c/0x42c [wave5]
[ 1636.991642] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1636.997293] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1637.002161] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1637.007812] v4l_reqbufs+0x50/0x64 [videodev]
[ 1637.012177] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1637.017146] video_usercopy+0x214/0x6c4 [videodev]
[ 1637.021942] video_ioctl2+0x18/0x2c [videodev]
[ 1637.026392] v4l2_ioctl+0x40/0x60 [videodev]
[ 1637.030668] __arm64_sys_ioctl+0xa8/0xf0
[ 1637.034576] invoke_syscall+0x48/0x114
[ 1637.038312] el0_svc_common.constprop.0+0xd4/0xfc
[ 1637.043002] do_el0_svc+0x30/0xd0
[ 1637.046305] el0_svc+0x2c/0x84
[ 1637.049346] el0t_64_sync_handler+0xbc/0x140
[ 1637.053601] el0t_64_sync+0x18c/0x190
[ 1637.057278] BUG: Bad page state in process videotestsrc0:s pfn:939900
[ 1637.063793] page:00000000548d1f90 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939900
[ 1637.073258] flags: 0x8000000000000000(zone=2)
[ 1637.077608] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1637.085338] raw: 0000000000000000 0000000000000000 ffffffffffffffff 0000000000000000
[ 1637.093065] page dumped because: nonzero _refcount
[ 1637.097846] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1637.169542] CPU: 0 PID: 3398 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1637.178739] Hardware name: Texas Instruments J784S4 EVM (Dtprop.0+0xd4/0xfc
[ 1637.305071] do_el0_svc+0x30/0xd0
[ 1637.308375] el0_svc+0x2c/0x84
[ 1637.311416] el0t_64_sync_handler+0xbc/0x140
[ 1637.315671] el0t_64_sync+0x18c/0x190
[ 1637.319342] BUG: Bad page state in process videotestsrc0:s pfn:939940
[ 1637.325857] page:000000003ff59283 refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x939940
[ 1637.335234] flags: 0x8000000000000000(zone=2)
[ 1637.339584] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1637.347314] raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
[ 1637.355041] page dumped because: nonzero _refcount
[ 1637.359822] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1637.431518] CPU: 0 PID: 3398 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1637.440714] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1637.446355] Call trace:
[ 1637.448789] dump_backtrace.part.0+0xdc/0xf0
[ 1637.453046] show_stack+0x18/0x30
[ 1637.456350] dump_stack_lvl+0x68/0x84
[ 1637.460000] dump_stack+0x18/0x34
[ 1637.463303] bad_page+0xe8/0x110
[ 1637.466517] check_new_pages+0xe0/0x110
[ 1637.470338] get_page_from_freelist+0x574/0xf10
[ 1637.474855] __alloc_pages+0x134/0xcec
[ 1637.478591] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1637.484320] dma_direct_alloc+0xd8/0x304
[ 1637.488229] dma_alloc_attrs+0x7c/0xe4
[ 1637.491964] wave5_vdi_allocate_dma_memory+0x40/0xb0 [
[ 1637.583873] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1637.593447] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1637.602659] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1637.613087] ------------[ cut here ]------------
[ 1637.617706] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1637.624066] WARNING: CPU: 7 PID: 3397 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1637.631279] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1637.702975] CPU: 7 PID: 3397 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1637.712086] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1637.717727] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1637.724669] pc : __vunmap+0x78/0x30c
[ 1637.728232] lr : __vunmap+0x78/0x30c
[ 1637.731793] sp : ffff80000c0b3ad0
[ 1637.735094] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1637.742212] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1637.749331] x23: 0000000939a00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1637.756449] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1637.763566] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1637.770684] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001bc9
[ 1637.838008] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1637.842963] v4l2_release+0xbc/0xf0 [videodev]
[ 1637.847418] __fput+0x70/0x250
[ 1637.850463] ____fput+0x10/0x20
[ 1637.853592] task_work_run+0x80/0xe0
[ 1637.857157] do_notify_resume+0x208/0x1280
[ 1637.861242] el0_svc+0x74/0x84
[ 1637.864285] el0t_64_sync_handler+0xbc/0x140
[ 1637.868540] el0t_64_sync+0x18c/0x190
[ 1637.872189] ---[ end trace 0000000000000000 ]---
[ 1637.876818] ------------[ cut here ]------------
[ 1637.881425] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1637.887773] WARNING: CPU: 7 PID: 3397 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1637.894978] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1637.966656] CPU: 7 PID: 3397 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1637.975766] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1637.981406] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1637.988349] pc : __vunmap+0x78/0x30c
[ 1637.991910] lr : __vunmap+0x78/0x30c
[ 1637.995472] sp : ffff80000c0b3ad0
[ 1637.998772] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1638.005890] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1638.013007] x23: 0000000939940000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1638.020125] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1638.027243] x17: 0000000000000000 x16: 00000000000area (00000000953119ba)
[ 1638.151438] WARNING: CPU: 7 PID: 3397 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1638.158643] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1638.230322] CPU: 7 PID: 3397 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1638.239432] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1638.245073] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1638.252015] pc : __vunmap+0x78/0x30c
[ 1638.255579] lr : __vunmap+0x78/0x30c
[ 1638.259140] sp : ffff80000c0b3ad0
[ 1638.262440] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1638.269558] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1638.276675] x23: 0000000939980000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1638.283792] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1638.290909] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1638.298027] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001cad
[ 1638.305144] x11: 000000000000098f x10: ffff8000092e7ab8 x9 : ffff800009281550
[ 1638.312261] x8 : 000000010000198f x7 : ffff8000092d9550 x6 : 000000000000e568
[ 1638.319379] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1638.326497] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1638.333615] Call trace:
[ 1638.336049] __vunmap+0x78/0x30c
[ 1638.339263] vunmap+0x40/0x5c
[ 163a pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1638.493983] CPU: 7 PID: 3397 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1638.503094] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1638.508734] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1638.515676] pc : __vunmap+0x78/0x30c
[ 1638.519238] lr : __vunmap+0x78/0x30c
[ 1638.522800] sp : ffff80000c0b3ad0
[ 1638.526100] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1638.533218] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1638.540336] x23: 0000000939860000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1638.547453] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1638.554571] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1638.561688] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001d1f
[ 1638.568806] x11: 00000000000009b5 x10: ffff8000092e7e48 x9 : ffff800009281550
[ 1638.575925] x8 : 00000001000019b5 x7 : ffff8000092d9550 x6 : 000000000000e8f8
[ 1638.583043] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1638.590160] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1638.597277] Call trace:
[ 1638.599710] __vunmap+0x78/0x30c
[ 1638.602924] vunmap+0x40/0x5c
[ 1638.605880] dma_direct_free+0x10c/0x110
[ 1638.609789] dma_free_attrs+0x98/0xe0
[ 1638.613438] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1638.618739] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1638.623607] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1638.628909] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1638.633864] v4l2_release+0xbc/0xf0 [videodev]
[ 1638.638317] __fput+0x70/0x250
[ 1638.641360] ____fput+0x10/0x20
[ 1638.644489] task_work_run+0x80/0xe0
[ 1638.648052] do_notify_resume+0x208/0x1280
[ 1638.652135] el0_svc+0x74/0x84
[ 1638.655176] el0t_64_sync_handler+0xbc/0x140
[ 1638.659431] el0t_64_sync+0x18c/0x190
[ 1638.663078] ---[ end trace 0000000000000000 ]---
[ 1638.733205] ------------[ cut here ]------------
[ 1638.737892] Trying to vfreat mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1638.751542] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1638.823244] CPU: 6 PID: 3400 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1638.832354] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1638.837995] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1638.844938] pc : __vunmap+0x78/0x30c
[ 1638.848500] lr : __vunmap+0x78/0x30c
[ 1638.852062] sp : ffff80000c37bad0
[ 1638.855363] x29: ffff80000c37bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1638.862482] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1638.869600] x23: 0000000939a80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1638.876717] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1638.883835] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1638.890952] x14: 0000000000000343 x13: 0000000000000000 x12: 0000000000000000
[ 1638.898070] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c37b980
[ 1638.905187] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1638.912304] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d8e48
[ 1638.919422] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1638.926540] Call trace:
[ 1638.928974] __vunmap+0x78/0x30c
[ 1638.932189] vunmap+0x40/0x5c
[ 1638.935145] dma_direct_free+0x10c/0x110
[ 1638.939055] dma_free_attrs ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1639.086942] CPU: 6 PID: 3400 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1639.096053] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1639.101695] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1639.108637] pc : __vunmap+0x78/0x30c
[ 1639.112199] lr : __vunmap+0x78/0x30c
[ 1639.115761] sp : ffff80000c37bad0
[ 1639.119061] x29: ffff80000c37bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1639.126180] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1639.133298] x23: 0000000939a40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1639.140417] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1639.147534] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c37b7b7
[ 1639.154651] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001e03
[ 1639.161768] x11: 0000000000000a01 x10: ffff8000092e8568 x9 : ffff800009281550
[ 1639.168885] x8 : 0000000100001a01 x7 : ffff8000092d9550 x6 : 000000000000f018
[ 1639.176003] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1639.183120] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1639.190237] Call trace:
[ 1639.192669] __vunmap+0x78/0x30c
[ 1639.195884] vunmap+0x40/0x5c
[ 1639.198839] dma_direct_free+0x10c/0x110
[ 1639.202750] dma_free_attrs+0x98/0xe0
[ 1639.206400] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1639.211707] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1639.216661] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1639.221962] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1639.226916] v4l2_release+0xbc/0xf0 [videodev]
[ 1639.231371] __fput+0x70/0x250
[ 1639.234415] ____fput+0x10/0x20
[ 1639.237544] task_work_run+0x80/0xe0
[ 1639.241106] do_notify_resume+0x208/0x1280
[ 1639.245191] el0_svc+0x74/0x84
[ 1639ipv6
[ 1639.350693] CPU: 6 PID: 3400 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1639.359802] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1639.365444] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1639.372386] pc : __vunmap+0x78/0x30c
[ 1639.375948] lr : __vunmap+0x78/0x30c
[ 1639.379510] sp : ffff80000c37bad0
[ 1639.382810] x29: ffff80000c37bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1639.389928] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1639.397045] x23: 00000009399c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1639.404162] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1639.411279] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1639.418396] x14: 0000000000000323 x13: 0000000000000000 x12: 0000000000000000
[ 1639.425514] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c37b980
[ 1639.432631] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1639.439747] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d8e48
[ 1639.446865] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1639.453982] Call trace:
[ 1639.456415] __vunmap+0x78/0x30c
[ 1639.459631] vunmap+0x40/0x5c
[ 1639.462586] dma_direct_free+0x10c/0x110
[ 1639.466495] dma_free_attrs+0x98/0xe0
[ 1639.470143] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1639.475446] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1639.480399] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1639.485701] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1639.490656] v4l2_release+0xbc/0xf0 [videodev]
[ 1639.495109] __fput+0x70/0x250
[ 1639.498153] ____fput+0x10/0x20
[ 1639.501282] task_work_run+0x80/0xe0
[ 1639.504844] do_notify_resume+0x208/0x1280
[ 1639.508928] el0_svc+0x74/0x84
[ 1639.511969] el0t_64_sync_handler+0xbc/0x140
[ 1639.516225] el0t_64_sync+0x18c/0x190
[ 1639.519874] ---[ end trace 0000000000000000 ]---
[ 1639.524503] ------------[ cut here ]------------
[ 1639.529111] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1639.535457] WARNING: CPU: 6 PID: 3400 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1639.542663: G B W O 6.1.33-g8f7f371be2 #1
[ 1639.623448] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1639.629092] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1639.636034] pc : __vunmap+0x78/0x30c
[ 1639.639596] lr : __vunmap+0x78/0x30c
[ 1639.643158] sp : ffff80000c37bad0
[ 1639.646458] x29: ffff80000c37bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1639.653577] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1639.660694] x23: 00000009399a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1639.667812] x20: 0000000000000000 x19: ffff80000bded000 x18: ffffffffffffffff
[ 1639.674930] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c37b7b7
[ 1639.682048] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001ee7
[ 1639.689166] x11: 0000000000000a4d x10: ffff8000092e8c88 x9 : ffff800009281550
[ 1639.696284] x8 : 0000000100001a4d x7 : ffff8000092d9550 x6 : 000000000000f738
[ 1639.703402] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1639.710520] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1639.717637] Call trace:
[ 1639.720070] __vunmap+0x78/0x30c
[ 1639.723286] vunmap+0x40/0x5c
[ 1639.726241] dma_direct_free+0x10c/0x110
[ 1639.730150] dma_free_attrs+0x98/0xe0
[ 1639.733798] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1639.739101] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1639.743968] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1639.749270] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1639.754224] v4l2_release+0xbc/0xf0 [videodev]
[ 1639.758675] __fput+0x70/0x250
[ 1639.761719] ____fput+0x10/0x20
[ 1639.764848] task_work_run+0x80/0xe0
[ 1639.768410] do_notify_resume+0x208/0x1280
[ 1639.772494] el0_svc+0x74/0x84
[ 1639.775536] el0t_64_sync_handler+0xbc/0x140
[ 1639.779790] el0t_64_sync+0x18c/0x190
[ 1639.783438] ---[ end trace 0000000000000000 ]---
[ 1639.856823] cma_alloc: 5 callbacks suppressed
[ 1639.856834] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1639.871269] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1639.882274] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1639.891853] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1639.901072] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1639.911593] ------------[ cut here ]------------
[ 1639.916225] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1639.922633] WARNING: CPU: 7 PID: 3403 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1639.929848] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1640.001551] CPU: 7 PID: 3403 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1640.010661] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1640.016302] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1640.023245] pc : __vunmap+0x78/0x30c
[ 1640.026807] lr : __vunmap+0x78/0x30c
[ 1640.030369] sp : ffff80000bdf3ad0
[ 1640.033669] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1640.040788] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1640.047906] x23: 0000000939b80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1640.055023] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1640.062141] x17: 0000000000000000 x16: 0000000000000000 x15: 00000000e0ccdeeb
[ 1640.069258] x14: 0000000000000169 x13: 0000000000000000 x12: 0000000000000000
[ 1640.076375] x11: 0000000000000 el0_svc+0x74/0x84
[ 1640.162865] el0t_64_sync_handler+0xbc/0x140
[ 1640.167120] el0t_64_sync+0x18c/0x190
[ 1640.170771] ---[ end trace 0000000000000000 ]---
[ 1640.175422] ------------[ cut here ]------------
[ 1640.180032] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1640.186382] WARNING: CPU: 7 PID: 3403 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1640.193588] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1640.265270] CPU: 7 PID: 3403 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1640.274380] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1640.280020] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1640.286963] pc : __vunmap+0x78/0x30c
[ 1640.290524] lr : __vunmap+0x78/0x30c
[ 1640.294086] sp : ffff80000bdf3ad0
[ 1640.297387] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1640.304505] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1640.311623] x23: 0000000939ac0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1640.318740] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1640.325857] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bdf37b7
[ 1640.332975] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001fdd
[ 1640.340091] x11: 0000000000000a9f x10: ffff8000092e9438 x9 : ffff800009281550
[ 1640.347208] x8 : 0000000100001a9f x7 : ffff8000092d9550 x6 : 000000000000fee8
[ 1j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1640.528934] CPU: 7 PID: 3403 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1640.538046] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1640.543686] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1640.550629] pc : __vunmap+0x78/0x30c
[ 1640.554190] lr : __vunmap+0x78/0x30c
[ 1640.557751] sp : ffff80000bdf3ad0
[ 1640.561051] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1640.568169] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1640.575287] x23: 0000000939b00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1640.582404] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1640.589521] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bdf37b7
[ 1640.596638] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000204f
[ 1640.603756] x11: 0000000000000ac5 x10: ffff8000092e97c8 x9 : ffff800009281550
[ 1640.610873] x8 : 0000000100001ac5 x7 : ffff8000092d9550 x6 : 0000000000010278
[ 1640.617991] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1640.625108] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1640.632225] Call trace:
[ 1640.634658] __vunmap+0x78/0x30c
[ 1640.637874] vunmap+0x40/0x5c
[ 1640.640830] dma_direct_free+0x10c/0x110
[ 1640.644738] dma_free_attrs+0x98/0xe0
[ 1640.648387] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1640.653690] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1640.658646] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1640.663947] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1640.drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1640.792578] CPU: 7 PID: 3403 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1640.801691] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1640.807332] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1640.814273] pc : __vunmap+0x78/0x30c
[ 1640.817834] lr : __vunmap+0x78/0x30c
[ 1640.821395] sp : ffff80000bdf3ad0
[ 1640.824694] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1640.831812] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1640.838929] x23: 00000009399e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1640.846047] x20: 0000000000000000 x19: ffff80000c37d000 x18: ffffffffffffffff
[ 1640.853166] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bdf37b7
[ 1640.860282] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000020c1
[ 1640.867400] x11: 0000000000000aeb x10: ffff8000092e9b58 x9 : ffff800009281550
[ 1640.874519] x8 : 0000000100001aeb x7 : ffff8000092d9550 x6 : 0000000000010608
[ 1640.881636] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1640.888754] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1640.895872] Call trace:
[ 1640.898307] __vunmap+0x78/0x30c
[ 1640.901521] vunmap+0x40/0x5c
[ 1640.904476] dma_direct_free+0x10c/0x110
[ 1640.908384] dma_free_attrs+0x98/0xe0
[ 1640.912034] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1640.917337] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1640.922205] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1640.927506] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1640.932460] v4l2_release+0xbc/0xf0 [videodev]
[ 1640.936912] __fput+0x70/0x250
[ 1640.939956] ____fput+0x10/0x20
41.027134] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1641.037219] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1641.048424] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1641.057995] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1641.067225] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1641.077539] ------------[ cut here ]------------
[ 1641.082160] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1641.088562] WARNING: CPU: 6 PID: 3406 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1641.095775] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1641.167480] CPU: 6 PID: 3406 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1641.176591] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1641.182232] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1641.189176] pc : __vunmap+0x78/0x30c
[ 1641.192738] lr : __vunmap+0x78/0x30c
[ 1641.196300] sp : ffff80000baebad0
[ 1641.199601] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1641.206720] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1641.213837] x23: 0000000939c00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1641.220955] x20: 0000000000000000 x19: [ 1641.345936] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1641.352283] WARNING: CPU: 6 PID: 3406 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1641.359488] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1641.431168] CPU: 6 PID: 3406 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1641.440277] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1641.445918] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1641.452860] pc : __vunmap+0x78/0x30c
[ 1641.456422] lr : __vunmap+0x78/0x30c
[ 1641.459984] sp : ffff80000baebad0
[ 1641.463284] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1641.470403] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1641.477520] x23: 0000000939bc0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1641.484637] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1641.491755] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1641.498872] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000021b4
[ 1641.505990] x11: 0000000000000b3c x10: ffff8000092ea2f0 x9 : ffff800009281550
[ 1641.513107] x8 : 0000000100001b3c x7 : ffff8000092d9550 x6 : 0000000000010da0
[ 1641.520226] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1641.527343] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1641.534461] Call trace:
[ 1641.536894] __vunmap+0x7aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1641.694834] CPU: 6 PID: 3406 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1641.703944] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1641.709585] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1641.716527] pc : __vunmap+0x78/0x30c
[ 1641.720088] lr : __vunmap+0x78/0x30c
[ 1641.723650] sp : ffff80000baebad0
[ 1641.726950] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1641.734068] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1641.741185] x23: 0000000939b40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1641.748303] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1641.755420] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1641.762537] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002226
[ 1641.769655] x11: 0000000000000b62 x10: ffff8000092ea680 x9 : ffff800009281550
[ 1641.776772] x8 : 0000000100001b62 x7 : ffff8000092d9550 x6 : 0000000000011130
[ 1641.783889] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1641.791006] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1641.798123] Call trace:
[ 1641.800556] __vunmap+0x78/0x30c
[ 1641.803771] vunmap+0x40/0x5c
[ 1641.806726] dma_direct_free+0x10c/0x110
[ 1641.810635] dma_free_attrs+0x98/0xe0
[ 1641.814284] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1641.819588] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1641.824543] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1641.829844] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1641.834799] v4l2_release+0xbc/0xf0 [videodev]
[ 1641.839251] __fput+0x70/0x250
[ 1641.842294] ____fput+0x10/0x20
[ 1641.84542ee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1641.958468] CPU: 6 PID: 3406 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1641.967577] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1641.973219] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1641.980161] pc : __vunmap+0x78/0x30c
[ 1641.983722] lr : __vunmap+0x78/0x30c
[ 1641.987284] sp : ffff80000baebad0
[ 1641.990583] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1641.997702] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1642.004819] x23: 0000000939b20000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1642.011936] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1642.019054] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1642.026171] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002298
[ 1642.033288] x11: 0000000000000b88 x10: ffff8000092eaa10 x9 : ffff800009281550
[ 1642.040406] x8 : 0000000100001b88 x7 : ffff8000092d9550 x6 : 00000000000114c0
[ 1642.047523] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1642.054640] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1642.061758] Call trace:
[ 1642.064191] __vunmap+0x78/0x30c
[ 1642.067406] vunmap+0x40/0x5c
[ 1642.070361] dma_direct_free+0x10c/0x110
[ 1642.074270] dma_free_attrs+0x98/0xe0
[ 1642.077919] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1642.083221] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1642.088088] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1642.093390] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1642.098345] v4l2_release+0xbc/0xf0 [videodev]
[ 1642.102795] __fput+0x70/0x250
[ 1642.105839] ____fput+0x10/0x20
[ 1642.108968] task_work_run+0x80/0xe0
[ 1642.112529] do_notify_resume+0x208/0x1280
[ 1642.116613] el0_svc+0x74/0x84
[ 1642.119654] el0t_64_sync_handler+0xbc/0x140
[ 1642.123910] el0t_64_sync+0x18c/0x190
[ 1642.127558] ---[ end trace 0000000000000000 ]---
[ 1642.205143] ------------[ cut here ]------------
[ 1642.209770] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1642.216133] Wc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1642.295054] CPU: 7 PID: 3409 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1642.304166] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1642.309807] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1642.316750] pc : __vunmap+0x78/0x30c
[ 1642.320313] lr : __vunmap+0x78/0x30c
[ 1642.323874] sp : ffff80000c0b3ad0
[ 1642.327174] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1642.334293] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1642.341411] x23: 0000000939d00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1642.348529] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1642.355647] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1642.362764] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000230a
[ 1642.369882] x11: 0000000000000bae x10: ffff8000092eada0 x9 : ffff800009281550
[ 1642.377000] x8 : 0000000100001bae x7 : ffff8000092d9550 x6 : 0000000000011850
[ 1642.384117] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1642.391235] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1642.398353] Call trace:
[ 1642.400787] __vunmap+0x78/0x30c
[ 1642.404004] vunmap+0x40/0x5c
[ 1642.406958] dma_direct_free+0x10c/0x110
[ 1642.410872] dma_free_attrs+0x98/0xe0
[ 1642.414520] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1642.419832] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1642.424786] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1642.430088] wave5_vpu_eeobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1642.558888] CPU: 7 PID: 3409 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1642.567999] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1642.573639] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1642.580581] pc : __vunmap+0x78/0x30c
[ 1642.584143] lr : __vunmap+0x78/0x30c
[ 1642.587704] sp : ffff80000c0b3ad0
[ 1642.591004] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1642.598123] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1642.605240] x23: 0000000939c40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1642.612359] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1642.619475] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1642.626593] x14: 00000000000003e1 x13: 0000000000000000 x12: 0000000000000000
[ 1642.633712] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0b3980
[ 1642.640830] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1642.647948] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a02a48
[ 1642.655067] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1642.662184] Call trace:
[ 1642.664618] __vunmap+0x78/0x30c
[ 1642.667832] vunmap+0x40/0x5c
[ 1642.670787] dma_direct_free+0x10c/0x110
[ 1642.674696] dma_free_attrs+0x98/0xe0
[ 1642.678344] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1642.683648] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1642.688603] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1642.693904] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1642.698858] v4l2_release+0xbc/0xf0 [videodev]
[ 1642.703312] __fput+0x70/0x250
[ 1642.70635ect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1642.822549] CPU: 7 PID: 3409 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1642.831662] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1642.837304] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1642.844246] pc : __vunmap+0x78/0x30c
[ 1642.847808] lr : __vunmap+0x78/0x30c
[ 1642.851370] sp : ffff80000c0b3ad0
[ 1642.854670] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1642.861787] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1642.868905] x23: 0000000939c80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1642.876023] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1642.883141] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0b37b7
[ 1642.890258] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000023ee
[ 1642.897376] x11: 0000000000000bfa x10: ffff8000092eb4c0 x9 : ffff800009281550
[ 1642.904494] x8 : 0000000100001bfa x7 : ffff8000092d9550 x6 : 0000000000011f70
[ 1642.911612] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1642.918729] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1642.925847] Call trace:
[ 1642.928280] __vunmap+0x78/0x30c
[ 1642.931497] vunmap+0x40/0x5c
[ 1642.934452] dma_direct_free+0x10c/0x110
[ 1642.938361] dma_free_attrs+0x98/0xe0
[ 1642.942009] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1642.947311] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1642.952266] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1642.957567] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1642.962521] v4l2_release+0xbc/0xf0 [videodev]
[ 1642.966973] __fput+0x70/0x250
[ 1642.970016] ____fput+0x10/0x20
[ 1642.973146] task_work_run+0x80/0xe0
[ 1642.976707] do_notify_resume+0x208/0x1280
[ 1642.980792] el0_svc+0x74/0x84
[ 1642.983833] el0t_64_sync_handler+0xbc/0x140
[ 1642.988088] el0t_64_sync+0x18c/0x190
[ 1642.991736] ---[ end trace 0gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1643.095376] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1643.101022] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1643.107965] pc : __vunmap+0x78/0x30c
[ 1643.111527] lr : __vunmap+0x78/0x30c
[ 1643.115089] sp : ffff80000c0b3ad0
[ 1643.118389] x29: ffff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1643.125507] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1643.132625] x23: 0000000939b60000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1643.139742] x20: 0000000000000000 x19: ffff80000c37d000 x18: ffffffffffffffff
[ 1643.146860] x17: 0000000000000000 x16: 0000000000000000 x15: 00000002a2669cc1
[ 1643.153978] x14: 0000000000000364 x13: 0000000000000000 x12: 0000000000000000
[ 1643.161095] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0b3980
[ 1643.168211] x8 : ffff0008aae15f90 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1643.175328] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a02a48
[ 1643.182447] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1643.189565] Call trace:
[ 1643.191997] __vunmap+0x78/0x30c
[ 1643.195212] vunmap+0x40/0x5c
[ 1643.198167] dma_direct_free+0x10c/0x110
[ 1643.202076] dma_free_attrs+0x98/0xe0
[ 1643.205724] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1643.211027] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1643.215894] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1643.221195] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1643.226150] v4l2_release+0xbc/0xf0 [videodev]
[ 1643.230601] __fput+0x70/0x250
[ 1643.233644] ____fput+0x10/0x20
[ 1643.236774] task_work_run+0x80/0xe0
[ 1643.240336] do_notify_resume+0x208/0x1280
[ 1643.244419] el0_svc+0x74/0x84
[ 1643.247461] el0t_64_sync_handler+0xbc/0x140
[ 1643.251716] el0t_64_sync+0x18c/0x190
[ 1643.255364] ---[ end trace 0000000000000000 ]---
[ 1643.326856] ------------[ cut here ]------------
[ 1643.331535] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1643.338012] WARNING: CPU: 6 PID: 3412 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1643.345227] Modules linked in: overlay cfg80211 pci_endpoiPU: 6 PID: 3412 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1643.426040] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1643.431683] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1643.438626] pc : __vunmap+0x78/0x30c
[ 1643.442190] lr : __vunmap+0x78/0x30c
[ 1643.445752] sp : ffff80000beabad0
[ 1643.449051] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1643.456171] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1643.463289] x23: 0000000939d80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1643.470407] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1643.477525] x17: 0000000000000000 x16: 0000000000000000 x15: 00009c5b82f92050
[ 1643.484642] x14: 000000000000003a x13: 000000000000003a x12: 0000000000000000
[ 1643.491760] x11: 0000000000000001 x10: 00000000000009b0 x9 : ffff80000beab980
[ 1643.498878] x8 : ffff0008aae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1643.505995] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dcd48
[ 1643.513113] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1643.520230] Call trace:
[ 1643.522664] __vunmap+0x78/0x30c
[ 1643.525879] vunmap+0x40/0x5c
[ 1643.528835] dma_direct_free+0x10c/0x110
[ 1643.532746] dma_free_attrs+0x98/0xe0
[ 1643.536396] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1643.541707] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1643.546662] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1643.551963] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1643.556918] v4l2_release+0xbc/0xf0 [videodev]
[ 1643.561373] __fput+0x70/0x250
[ 1643.564419] ____fput+0x10/0x20
[ 1643.567548] task_work_run+0x80/0xe0
[ 1643.571112] do_notify_resume+0x208/0x1280
[ 1643.575197] el0_svc+0x74/0x84
[ 1643.578240] el0t_64_sync_handler+0xbc/0x140
[ 1643.582496] el0t_64_sync+0x18c/0x190
[ 1643.586146] ---[ end trace 0000000000000000 ]---
[ 1643.590804] ------------[ cut here ]------------
[ 1643.595413] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1643.601762] WARNING: CPU: 6 PID: 3412 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1643.608968] Modules linked00000000000000
[ 1643.719882] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1643.727000] x23: 0000000939d40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1643.734118] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1643.741235] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1643.748352] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002544
[ 1643.755469] x11: 0000000000000c6c x10: ffff8000092ebf70 x9 : ffff800009281550
[ 1643.762587] x8 : 0000000100001c6c x7 : ffff8000092d9550 x6 : 0000000000012a20
[ 1643.769704] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1643.776822] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1643.783939] Call trace:
[ 1643.786372] __vunmap+0x78/0x30c
[ 1643.789588] vunmap+0x40/0x5c
[ 1643.792543] dma_direct_free+0x10c/0x110
[ 1643.796453] dma_free_attrs+0x98/0xe0
[ 1643.800102] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1643.805405] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1643.810361] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1643.815662] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1643.820617] v4l2_release+0xbc/0xf0 [videodev]
[ 1643.825070] __fput+0x70/0x250
[ 1643.828112] ____fput+0x10/0x20
[ 1643.831242] task_work_run+0x80/0xe0
[ 1643.834805] do_notify_resume+0x208/0x1280
[ 1643.838889] el0_svc+0x74/0x84
[ 1643.841930] el0t_64_sync_handler+0xbc/0x140
[ 1643.846186] el0t_64_sync+0x18c/0x190
[ 1643.849835] ---[ end trace 0000000000000000 ]---
[ 1643.854459] ------------[ cut here ]------------
[ 1643.859072] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1643.865467] WARNING: CPU: 6 PID: 3412 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1643.872675] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_hae15150 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1644.033413] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33dcd48
[ 1644.040532] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1644.047650] Call trace:
[ 1644.050085] __vunmap+0x78/0x30c
[ 1644.053299] vunmap+0x40/0x5c
[ 1644.056254] dma_direct_free+0x10c/0x110
[ 1644.060163] dma_free_attrs+0x98/0xe0
[ 1644.063811] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1644.069114] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1644.074069] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1644.079370] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1644.084324] v4l2_release+0xbc/0xf0 [videodev]
[ 1644.088775] __fput+0x70/0x250
[ 1644.091818] ____fput+0x10/0x20
[ 1644.094947] task_work_run+0x80/0xe0
[ 1644.098509] do_notify_resume+0x208/0x1280
[ 1644.102594] el0_svc+0x74/0x84
[ 1644.105635] el0t_64_sync_handler+0xbc/0x140
[ 1644.109890] el0t_64_sync+0x18c/0x190
[ 1644.113539] ---[ end trace 0000000000000000 ]---
[ 1644.118166] ------------[ cut here ]------------
[ 1644.122772] Trying to vfree() nonexistent vm area (00000000c07001e8)
[ 1644.129115] WARNING: CPU: 6 PID: 3412 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1644.136318] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1644.207996] CPU: 6 PID: 3412 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1644.217104] Hardware name: Texas Instruments J784S4 EVM (31] vunmap+0x40/0x5c
[ 1644.319886] dma_direct_free+0x10c/0x110
[ 1644.323797] dma_free_attrs+0x98/0xe0
[ 1644.327445] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1644.332748] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1644.337616] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1644.342918] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1644.347872] v4l2_release+0xbc/0xf0 [videodev]
[ 1644.352324] __fput+0x70/0x250
[ 1644.355367] ____fput+0x10/0x20
[ 1644.358496] task_work_run+0x80/0xe0
[ 1644.362058] do_notify_resume+0x208/0x1280
[ 1644.366142] el0_svc+0x74/0x84
[ 1644.369183] el0t_64_sync_handler+0xbc/0x140
[ 1644.373438] el0t_64_sync+0x18c/0x190
[ 1644.377087] ---[ end trace 0000000000000000 ]---
[ 1644.447795] ------------[ cut here ]------------
[ 1644.452470] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1644.458850] WARNING: CPU: 2 PID: 3415 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1644.466066] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1644.537769] CPU: 2 PID: 3415 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1644.546880] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1644.552522] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1644.559465] pc : __vunmap+0x78/0x30c
[ 1644.563027] lr : __vunmap+0x78/0x30c
[ 1644.566589] sp : ffff80000bdf3ad0
[ 1644.569889] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1644
[ 1644.584129] x23: 0000000939e80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1644.591247] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1644.598365] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1644.605483] x14: 000000000000021b x13: 0000000000000000 x12: 0000000000000000
[ 1644.612600] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000bdf3980
[ 1644.619717] x8 : ffff0008aae15f90 x7 : ffff000f5c396340 x6 : 0000000000000000
[ 1644.626833] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a269a6c8
[ 1644.633952] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1644.641069] Call trace:
[ 1644.643505] __vunmap+0x78/0x30c
[ 1644.646721] vunmap+0x40/0x5c
[ 1644.649676] dma_direct_free+0x10c/0x110
[ 1644.653587] dma_free_attrs+0x98/0xe0
[ 1644.657236] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1644.662547] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1644.667502] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1644.672803] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1644.677757] v4l2_release+0xbc/0xf0 [videodev]
[ 1644.682212] __fput+0x70/0x250
[ 1644.685256] ____fput+0x10/0x20
[ 1644.688386] task_work_run+0x80/0xe0
[ 1644.691951] do_notify_resume+0x208/0x1280
[ 1644.696038] el0_svc+0x74/0x84
[ 1644.699080] el0t_64_sync_handler+0xbc/0x140
[ 1644.703335] el0t_64_sync+0x18c/0x190
[ 1644.706984] ---[ end trace 0000000000000000 ]---
[ 1644.711727] ------------[ cut here ]------------
[ 1644.716342] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1644.722737] WARNING: CPU: 2 PID: 3415 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1644.729944] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtf000f5c396340 x6 : 0000000000000000
[ 1644.890679] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a269a6c8
[ 1644.897796] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1644.904913] Call trace:
[ 1644.907347] __vunmap+0x78/0x30c
[ 1644.910562] vunmap+0x40/0x5c
[ 1644.913517] dma_direct_free+0x10c/0x110
[ 1644.917426] dma_free_attrs+0x98/0xe0
[ 1644.921076] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1644.926380] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1644.931334] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1644.936635] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1644.941588] v4l2_release+0xbc/0xf0 [videodev]
[ 1644.946042] __fput+0x70/0x250
[ 1644.949084] ____fput+0x10/0x20
[ 1644.952214] task_work_run+0x80/0xe0
[ 1644.955776] do_notify_resume+0x208/0x1280
[ 1644.959859] el0_svc+0x74/0x84
[ 1644.962901] el0t_64_sync_handler+0xbc/0x140
[ 1644.967156] el0t_64_sync+0x18c/0x190
[ 1644.970805] ---[ end trace 0000000000000000 ]---
[ 1644.975431] ------------[ cut here ]------------
[ 1644.980038] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1644.986384] WARNING: CPU: 2 PID: 3415 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1644.993588] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1645.065262] CPU: 2 PID: 3415 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1645.074371] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1645.080011]_free+0x10c/0x110
[ 1645.181070] dma_free_attrs+0x98/0xe0
[ 1645.184719] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1645.190023] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1645.194977] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1645.200278] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1645.205231] v4l2_release+0xbc/0xf0 [videodev]
[ 1645.209685] __fput+0x70/0x250
[ 1645.212728] ____fput+0x10/0x20
[ 1645.215857] task_work_run+0x80/0xe0
[ 1645.219419] do_notify_resume+0x208/0x1280
[ 1645.223503] el0_svc+0x74/0x84
[ 1645.226543] el0t_64_sync_handler+0xbc/0x140
[ 1645.230798] el0t_64_sync+0x18c/0x190
[ 1645.234447] ---[ end trace 0000000000000000 ]---
[ 1645.239079] ------------[ cut here ]------------
[ 1645.243686] Trying to vfree() nonexistent vm area (00000000203b84ee)
[ 1645.250034] WARNING: CPU: 2 PID: 3415 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1645.257240] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1645.328916] CPU: 2 PID: 3415 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1645.338026] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1645.343666] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1645.350608] pc : __vunmap+0x78/0x30c
[ 1645.354170] lr : __vunmap+0x78/0x30c
[ 1645.357731] sp : ffff80000bdf3ad0
[ 1645.361031] x29: ffff80000bdf3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1645.368149] x26: 0000000000000000 x25: 000000000000000094355] el0t_64_sync+0x18c/0x190
[ 1645.498002] ---[ end trace 0000000000000000 ]---
[ 1645.570669] cma_alloc: 15 callbacks suppressed
[ 1645.570680] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1645.585220] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1645.596268] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1645.605830] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1645.615052] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1645.625472] ------------[ cut here ]------------
[ 1645.630092] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1645.636451] WARNING: CPU: 6 PID: 3418 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1645.643665] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1645.715367] CPU: 6 PID: 3418 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1645.724478] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1645.730120] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1645.737063] pc : __vunmap+0x78/0x30c
[ 1645.740626] lr : __vunmap+0x78/0x30c
[ 1645.744188] sp : ffff80000c353ad0
[ 1645.747488] x29: ffff80000c353ad0 x28: 0000000000000204 x27: 00000000093d6a28 x21: 0000000000000000
[ 1645.768849] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1645.775967] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3537b7
[ 1645.783084] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002874
[ 1645.790202] x11: 0000000000000d7c x10: ffff8000092ed8f0 x9 : ffff800009281550
[ 1645.797320] x8 : 0000000100001d7c x7 : ffff8000092d9550 x6 : 00000000000143a0
[ 1645.804437] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1645.811554] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1645.818672] Call trace:
[ 1645.821107] __vunmap+0x78/0x30c
[ 1645.824323] vunmap+0x40/0x5c
[ 1645.827278] dma_direct_free+0x10c/0x110
[ 1645.831189] dma_free_attrs+0x98/0xe0
[ 1645.834838] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1645.840149] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1645.845104] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1645.850405] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1645.855359] v4l2_release+0xbc/0xf0 [videodev]
[ 1645.859815] __fput+0x70/0x250
[ 1645.862859] ____fput+0x10/0x20
[ 1645.865989] task_work_run+0x80/0xe0
[ 1645.869553] do_notify_resume+0x208/0x1280
[ 1645.873638] el0_svc+0x74/0x84
[ 1645.876681] el0t_64_sync_handler+0xbc/0x140
[ 1645.880936] el0t_64_sync+0x18c/0x190
[ 1645.884584] ---[ end trace 0000000000000000 ]---
[ 1645.889212] ------------[ cut here ]------------
[ 1645.893835] Trying to vfree() nonexistent vm area (00000000e0c066f9)
[ 1645.900184] WARNING: CPU: 6 PID: 3418 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1645.907389] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x00028e6
[ 1646.053893] x11: 0000000000000da2 x10: ffff8000092edc80 x9 : ffff800009281550
[ 1646.061011] x8 : 0000000100001da2 x7 : ffff8000092d9550 x6 : 0000000000014730
[ 1646.068129] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1646.075246] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1646.082363] Call trace:
[ 1646.084795] __vunmap+0x78/0x30c
[ 1646.088009] vunmap+0x40/0x5c
[ 1646.090965] dma_direct_free+0x10c/0x110
[ 1646.094874] dma_free_attrs+0x98/0xe0
[ 1646.098522] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1646.103825] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1646.108779] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1646.114080] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1646.119035] v4l2_release+0xbc/0xf0 [videodev]
[ 1646.123489] __fput+0x70/0x250
[ 1646.126534] ____fput+0x10/0x20
[ 1646.129663] task_work_run+0x80/0xe0
[ 1646.133225] do_notify_resume+0x208/0x1280
[ 1646.137309] el0_svc+0x74/0x84
[ 1646.140350] el0t_64_sync_handler+0xbc/0x140
[ 1646.144605] el0t_64_sync+0x18c/0x190
[ 1646.148253] ---[ end trace 0000000000000000 ]---
[ 1646.152902] ------------[ cut here ]------------
[ 1646.157517] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1646.163869] WARNING: CPU: 4 PID: 3418 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1646.171075] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1646.242754] CPU: 4 PID: 3418 Comm: gs5c
[ 1646.354655] dma_direct_free+0x10c/0x110
[ 1646.358564] dma_free_attrs+0x98/0xe0
[ 1646.362216] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1646.367521] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1646.372476] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1646.377777] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1646.382731] v4l2_release+0xbc/0xf0 [videodev]
[ 1646.387183] __fput+0x70/0x250
[ 1646.390228] ____fput+0x10/0x20
[ 1646.393357] task_work_run+0x80/0xe0
[ 1646.396920] do_notify_resume+0x208/0x1280
[ 1646.401003] el0_svc+0x74/0x84
[ 1646.404044] el0t_64_sync_handler+0xbc/0x140
[ 1646.408299] el0t_64_sync+0x18c/0x190
[ 1646.411946] ---[ end trace 0000000000000000 ]---
[ 1646.416576] ------------[ cut here ]------------
[ 1646.421202] Trying to vfree() nonexistent vm area (000000000268fc23)
[ 1646.427547] WARNING: CPU: 4 PID: 3418 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1646.434752] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1646.506430] CPU: 4 PID: 3418 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1646.515539] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1646.521179] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1646.528121] pc : __vunmap+0x78/0x30c
[ 1646.531683] lr : __vunmap+0x78/0x30c
[ 1646.535244] sp : ffff80000c353ad0
[ 1646.538544] x29: ffff80000c353ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1646.545663] x26: 00000000free+0x10c/0x110
[ 1646.622239] dma_free_attrs+0x98/0xe0
[ 1646.625888] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1646.631193] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1646.636060] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1646.641362] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1646.646316] v4l2_release+0xbc/0xf0 [videodev]
[ 1646.650769] __fput+0x70/0x250
[ 1646.653813] ____fput+0x10/0x20
[ 1646.656942] task_work_run+0x80/0xe0
[ 1646.660505] do_notify_resume+0x208/0x1280
[ 1646.664589] el0_svc+0x74/0x84
[ 1646.667630] el0t_64_sync_handler+0xbc/0x140
[ 1646.671886] el0t_64_sync+0x18c/0x190
[ 1646.675534] ---[ end trace 0000000000000000 ]---
[ 1646.741813] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1646.751883] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1646.762964] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1646.772546] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1646.781761] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1646.792167] ------------[ cut here ]------------
[ 1646.796792] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1646.803198] WARNING: CPU: 6 PID: 3421 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1646.810413] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1646.882117] CPU: 6 PID: 3421 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1646.891229] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1646.896871] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1646.903815] pc : __vunmap+0x78/0x30c
[ 1646.907377] lr : __vunmap+0x78/0x30c
[ 1646.910938] sp : ffff8000094d3ad0
[ 1646.914238] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1646.921357] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1646.928475] x23: 000000093a000000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1646.935593] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1646.942711] x17: 0000000000000000 x16: 0000000000000000 x15: 000000036feede58
[ 1646.949828] x14: 0000000000000022 x13: 0000000000000000 x12: 0000000000000000
[ 1646.956945] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000094d3980
[ 1646.964063] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1646.971180] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33daa48
[ 1646.978298] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1646.985416] Call trace:
[ 1646.987850] __vunmap+0x78/0x30c
[ 1646.991066] vunmap+0x40/0x5c
[ 1646.994021] dma_direct_free+0x10c/0x110
[ 1646.997932] dma_free_attrs+0x98/0xe0
[ 1647.001581] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1647.006893] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1647.011848] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1647.017149] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1647.022105] v4l2_release+0xbc/0xf0 [videodev]
[ 1647.026560] __fput+0x70/0x250
[ 1647.029604] ____fput+0x10/0x20
[ 1647.032734] task_work_run+0x80/0xe0
[ 1647.036297] do_notify_resume+0x208/0x1280
[ 1647.040381] el0_svc+0x74/0x84
[ 1647.043424] el0t_64_sync_handler+0xbc/0x140
[ 1647.047680] el0t_64_sync+0x18c/0x190
[ 1647.051330] ---[ end trace 0000000000000000 ]---
[ 1647.055972] ------------[ cut here ]------------
[ 1647.060581] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1647.066931] WARNING: CPU: 6 PID: 3421 at mm/vmalloc.c:2693 __vunmap+0m(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1647.145817] CPU: 6 PID: 3421 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1647.154930] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1647.160572] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1647.167515] pc : __vunmap+0x78/0x30c
[ 1647.171077] lr : __vunmap+0x78/0x30c
[ 1647.174639] sp : ffff8000094d3ad0
[ 1647.177939] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1647.185057] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1647.192175] x23: 0000000939f40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1647.199294] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1647.206412] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1647.213530] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002abd
[ 1647.220648] x11: 0000000000000e3f x10: ffff8000092eeb38 x9 : ffff800009281550
[ 1647.227764] x8 : 0000000100001e3f x7 : ffff8000092d9550 x6 : 00000000000155e8
[ 1647.234882] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1647.241999] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1647.249118] Call trace:
[ 1647.251551] __vunmap+0x78/0x30c
[ 1647.254766] vunmap+0x40/0x5c
[ 1647.257722] dma_direct_free+0x10c/0x110
[ 1647.261631] dma_free_attrs+0x98/0xe0
[ 1647.265279] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1647.270583] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1647.275537] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1647.280838] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1647.285793] v4l2_release+0xbc/0xf0 [videodev]
[ 1647.290246] __fput+0x70/0x250
[ 1647.293290] ____fput+0x10/0x20
[ 1647.296419] task_work_run+0x80/0xe0
[ 1647.299981] do_notify_resume+0x208/0x1280
[ 1647.304066] el0_svc+0x74/0x84
[ 1647.307107] el0t_64_sync_handler+0xbc/0x140
[ 1647.311363] el0ect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1647.409501] CPU: 6 PID: 3421 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1647.418613] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1647.424254] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1647.431196] pc : __vunmap+0x78/0x30c
[ 1647.434758] lr : __vunmap+0x78/0x30c
[ 1647.438319] sp : ffff8000094d3ad0
[ 1647.441620] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1647.448737] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1647.455855] x23: 0000000939f80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1647.462972] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1647.470089] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1647.477207] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002b2f
[ 1647.484324] x11: 0000000000000e65 x10: ffff8000092eeec8 x9 : ffff800009281550
[ 1647.491441] x8 : 0000000100001e65 x7 : ffff8000092d9550 x6 : 0000000000015978
[ 1647.498558] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1647.505675] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1647.512793] Call trace:
[ 1647.515226] __vunmap+0x78/0x30c
[ 1647.518440] vunmap+0x40/0x5c
[ 1647.521395] dma_direct_free+0x10c/0x110
[ 1647.525304] dma_free_attrs+0x98/0xe0
[ 1647.528951] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1647.534254] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1647.539209] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1647.544510] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1647.549465] v4l2_release+0xbc/0xf0 [videodev]
[ 1647.553921] __fput+0x70/0x250
[ 1647.556964] ____fput+0x10/0x20
[ 1647.560093] task_work_run+0x80/0xe0
[ 1647.563656] do_notify_resume+0x208/0x1280
[ 1647.567739] el0_svc+0x74/0x84
[ 1647.570780] el0t_64_sync_handler+0xbc/0x140
[ 1647.575036] el0t_64_sync+0x18c/0x190
[ 1647.578683] ---[ end trace 00000000adence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1647.673144] CPU: 6 PID: 3421 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1647.682257] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1647.687898] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1647.694840] pc : __vunmap+0x78/0x30c
[ 1647.698401] lr : __vunmap+0x78/0x30c
[ 1647.701963] sp : ffff8000094d3ad0
[ 1647.705263] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1647.712382] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1647.719499] x23: 0000000939e60000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1647.726617] x20: 0000000000000000 x19: ffff80000c376000 x18: ffffffffffffffff
[ 1647.733735] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1647.740852] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002ba1
[ 1647.747969] x11: 0000000000000e8b x10: ffff8000092ef258 x9 : ffff800009281550
[ 1647.755088] x8 : 0000000100001e8b x7 : ffff8000092d9550 x6 : 0000000000015d08
[ 1647.762204] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1647.769321] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1647.776439] Call trace:
[ 1647.778873] __vunmap+0x78/0x30c
[ 1647.782087] vunmap+0x40/0x5c
[ 1647.785041] dma_direct_free+0x10c/0x110
[ 1647.788951] dma_free_attrs+0x98/0xe0
[ 1647.792599] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1647.797901] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1647.802769] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1647.808070] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1647.813023] v4l2_release+0xbc/0xf0 [videodev]
[ 1647.817476] __fput+0x70/0x250
[ 1647.820519] ____fput+0x10/0x20
[ 1647.823648] task_work_run+0x80/0xe0
[ 1647.827210] do_notify_resume+0x208/0x1280
[ 1647.831294] el0_svc+0x74/0x84
[ 1647.834335] el0t_64_sync_handler+0xbc/0x140
[ 1647.838590] el0t_64_sync+0x18c/0x190
[ 1647.842237] ---[ end trace 0000000000000000 ]---
[ 1647.914364] ------------[ cut here ]------------
[ 1647.919049] Trying to vfree() nonexistent vm area (000000005ap8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1648.004418] CPU: 7 PID: 3424 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1648.013530] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1648.019171] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1648.026114] pc : __vunmap+0x78/0x30c
[ 1648.029675] lr : __vunmap+0x78/0x30c
[ 1648.033237] sp : ffff80000c35bad0
[ 1648.036537] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1648.043657] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1648.050775] x23: 000000093a080000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1648.057893] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1648.065010] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1648.072128] x14: 0000000000000069 x13: 0000000000000000 x12: 0000000000000000
[ 1648.079245] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c35b980
[ 1648.086363] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1648.093481] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a05b48
[ 1648.100600] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1648.107717] Call trace:
[ 1648.110150] __vunmap+0x78/0x30c
[ 1648.113365] vunmap+0x40/0x5c
[ 1648.116320] dma_direct_free+0x10c/0x110
[ 1648.120232] dma_free_attrs+0x98/0xe0
[ 1648.123881] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1648.129193] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1648.134147] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1648.139449] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1648.144403] v4l2_release+0xbc/0xf0 [videodev]
[ 1648.148860] __fput+0x70/0x250
[ 1648.268168] CPU: 7 PID: 3424 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1648.277281] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1648.282922] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1648.289865] pc : __vunmap+0x78/0x30c
[ 1648.293429] lr : __vunmap+0x78/0x30c
[ 1648.296990] sp : ffff80000c35bad0
[ 1648.300290] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1648.307409] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1648.314526] x23: 000000093a040000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1648.321644] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1648.328762] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1648.335880] x14: 0000000000000288 x13: 0000000000000000 x12: 0000000000000000
[ 1648.342997] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c35b980
[ 1648.350114] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1648.357232] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a05b48
[ 1648.364349] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1648.371467] Call trace:
[ 1648.373900] __vunmap+0x78/0x30c
[ 1648.377116] vunmap+0x40/0x5c
[ 1648.380071] dma_direct_free+0x10c/0x110
[ 1648.383981] dma_free_attrs+0x98/0xe0
[ 1648.387628] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1648.392934] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1648.397888] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1648.403189] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1648.408145] v4l2_release+0xbc/0xf0 [videodev]
[ 1648.412600] __fput+0x70/0x250
[ 1648.415644] ____fput+0x10/0x20
[ 1648.418773] task_work_run+0x80/0xe0
[ 1648.422336] do_notify_resume+0x208/0x1280
[ 1648.426420] el0_svc+0x74/0x84
[ 1648.429462] el0t_64_sync_handler+0xbtodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1648.531864] CPU: 7 PID: 3424 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1648.540976] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1648.546616] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1648.553558] pc : __vunmap+0x78/0x30c
[ 1648.557120] lr : __vunmap+0x78/0x30c
[ 1648.560681] sp : ffff80000c35bad0
[ 1648.563982] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1648.571100] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1648.578217] x23: 0000000939fc0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1648.585335] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1648.592452] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c35b7b7
[ 1648.599569] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002cf7
[ 1648.606687] x11: 0000000000000efd x10: ffff8000092efd08 x9 : ffff800009281550
[ 1648.613805] x8 : 0000000100001efd x7 : ffff8000092d9550 x6 : 00000000000167b8
[ 1648.620924] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1648.628042] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1648.635159] Call trace:
[ 1648.637592] __vunmap+0x78/0x30c
[ 1648.640806] vunmap+0x40/0x5c
[ 1648.643761] dma_direct_free+0x10c/0x110
[ 1648.647670] dma_free_attrs+0x98/0xe0
[ 1648.651318] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1648.656620] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1648.661574] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1648.666875] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1648.671829] v4l2_release+0xbc/0xf0 [videodev]
[ 1648.676285] __fput+0x70/0x250
[ 1648.679329] ____fput+0x10/0x20
[ 1648.682458] task_work_run+0x80/0xe0
[ 1648.686020] do_notify_resume+0x208/0x1280
[ 1648.690104] el0_svc+0x74/0x84
[ 1648.693146] el0t_64_sync_handler+0xbc/0x140
[ 1648.697401] el0t_64_sync+0x18c/0x190
[ 1648.701048] ---[ end trace 0000000000000000 ]---
[ 1648.705671] ------------[ cut here ]------------
[ 1648.710280] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1648.716628] WARNING: CPU: 7 PID: 3424 at mm/vma 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1648.817204] pc : __vunmap+0x78/0x30c
[ 1648.820769] lr : __vunmap+0x78/0x30c
[ 1648.824331] sp : ffff80000c35bad0
[ 1648.827631] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1648.834748] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1648.841866] x23: 0000000939fa0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1648.848982] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1648.856100] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c35b7b7
[ 1648.863217] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002d69
[ 1648.870334] x11: 0000000000000f23 x10: ffff8000092f0098 x9 : ffff800009281550
[ 1648.877451] x8 : 0000000100001f23 x7 : ffff8000092d9550 x6 : 0000000000016b48
[ 1648.884569] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1648.891687] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1648.898805] Call trace:
[ 1648.901237] __vunmap+0x78/0x30c
[ 1648.904452] vunmap+0x40/0x5c
[ 1648.907407] dma_direct_free+0x10c/0x110
[ 1648.911316] dma_free_attrs+0x98/0xe0
[ 1648.914964] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1648.920266] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1648.925134] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1648.930435] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1648.935389] v4l2_release+0xbc/0xf0 [videodev]
[ 1648.939842] __fput+0x70/0x250
[ 1648.942885] ____fput+0x10/0x20
[ 1648.946014] task_work_run+0x80/0xe0
[ 1648.949575] do_notify_resume+0x208/0x1280
[ 1648.953659] el0_svc+0x74/0x84
[ 1648.956701] el0t_64_sync_handler+0xbc/0x140
[ 1648.960955] el0t_64_sync+0x18c/0x190
[ 1648.964604] ---[ end trace 0000000000000000 ]---
[ 1649.034106] ------------[ cut here ]------------
[ 1649.038732] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1649.045260] WARNING: CPU: 6 PID: 3427 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1649.052476] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common r ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1649.124181] CPU: 6 PID: 3427 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1649.133297] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1649.138939] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1649.145883] pc : __vunmap+0x78/0x30c
[ 1649.149445] lr : __vunmap+0x78/0x30c
[ 1649.153007] sp : ffff80000beabad0
[ 1649.156307] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1649.163427] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1649.170545] x23: 000000093a180000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1649.177664] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1649.184781] x17: 0000000000000000 x16: 0000000000000000 x15: 00009cabc1286a24
[ 1649.191899] x14: 0000000000000031 x13: 0000000000000031 x12: 0000000000000000
[ 1649.199016] x11: 0000000000000001 x10: 00000000000009b0 x9 : ffff80000beab980
[ 1649.206133] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1649.213251] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d8ac8
[ 1649.220369] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1649.227486] Call trace:
[ 1649.229920] __vunmap+0x78/0x30c
[ 1649.233137] vunmap+0x40/0x5c
[ 1649.236092] dma_direct_free+0x10c/0x110
[ 1649.240003] dma_free_attrs+0x98/0xe0
[ 1649.243651] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1649.248963] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1649.253918] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1649.259219] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1649.264173] v4l2_release+0xbc/0xf0 [videodev]
[ 1649.268629] __fput+0x70/0x250
[ 1649.271673] ____fput+0x10/0x20
[ 1649.274803] task_work_run+0x80/0xe0
[ 1649.278366] do_notify_resume+0x208/0x1280
[ 1649.282452] el0_svc+0x74/0x84
[ 16 6.1.33-g8f7f371be2 #1
[ 1649.397041] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1649.402682] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1649.409624] pc : __vunmap+0x78/0x30c
[ 1649.413185] lr : __vunmap+0x78/0x30c
[ 1649.416747] sp : ffff80000beabad0
[ 1649.420047] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1649.427164] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1649.434281] x23: 000000093a0c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1649.441399] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1649.448516] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1649.455633] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002e4d
[ 1649.462750] x11: 0000000000000f6f x10: ffff8000092f07b8 x9 : 0000000000000017
[ 1649.469868] x8 : 0000000000000000 x7 : 00000000000002aa x6 : 0000000000006175
[ 1649.476985] x5 : 000000000000001b x4 : 0000000000007175 x3 : ffff000f5c3e2d30
[ 1649.484102] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1649.491219] Call trace:
[ 1649.493652] __vunmap+0x78/0x30c
[ 1649.496868] vunmap+0x40/0x5c
[ 1649.499823] dma_direct_free+0x10c/0x110
[ 1649.503732] dma_free_attrs+0x98/0xe0
[ 1649.507380] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1649.512685] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1649.517640] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1649.522941] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1649.527896] v4l2_release+0xbc/0xf0 [videodev]
[ 1649.532350] __fput+0x70/0x250
[ 1649.535394] ____fput+0x10/0x20
[ 1649.538523] task_work_run+0x80/0xe0
[ 1649.542085] do_notify_resume+0x208/0x1280
[ 1649.546168] el0_svc+0x74/0x84
[ 1649.549210] el0t_64_sync_handler+0xbc/0x140
[ 1649.553464] el0t_64_sync+0x18c/0x190
[ 1649.557113] ---[ end trace 0000000000000000 ]---
[ 1649.561736] ------------[ cut here ]------------
[ 1649.566346] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1649.572695] WARNING: CPU: 6 PID: 3427 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1649.579900] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic 0000000000000
[ 1649.697932] x23: 000000093a100000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1649.705049] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1649.712167] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1649.719286] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002ebf
[ 1649.726403] x11: 0000000000000f95 x10: ffff8000092f0b48 x9 : ffff800009281550
[ 1649.733521] x8 : 0000000100001f95 x7 : ffff8000092d9550 x6 : 00000000000175f8
[ 1649.740640] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1649.747757] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1649.754875] Call trace:
[ 1649.757308] __vunmap+0x78/0x30c
[ 1649.760521] vunmap+0x40/0x5c
[ 1649.763477] dma_direct_free+0x10c/0x110
[ 1649.767385] dma_free_attrs+0x98/0xe0
[ 1649.771034] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1649.776337] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1649.781292] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1649.786593] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1649.791548] v4l2_release+0xbc/0xf0 [videodev]
[ 1649.796002] __fput+0x70/0x250
[ 1649.799046] ____fput+0x10/0x20
[ 1649.802175] task_work_run+0x80/0xe0
[ 1649.805737] do_notify_resume+0x208/0x1280
[ 1649.809820] el0_svc+0x74/0x84
[ 1649.812862] el0t_64_sync_handler+0xbc/0x140
[ 1649.817116] el0t_64_sync+0x18c/0x190
[ 1649.820764] ---[ end trace 0000000000000000 ]---
[ 1649.825386] ------------[ cut here ]------------
[ 1649.829995] Trying to vfree() nonexistent vm area (000000008a4148f5)
[ 1649.836343] WARNING: CPU: 6 PID: 3427 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1649.843548] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) sy79] x23: 0000000939fe0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1649.968697] x20: 0000000000000000 x19: ffff80000c0ad000 x18: ffffffffffffffff
[ 1649.975815] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1649.982933] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000002f31
[ 1649.990051] x11: 0000000000000fbb x10: ffff8000092f0ed8 x9 : ffff800009281550
[ 1649.997168] x8 : 0000000100001fbb x7 : ffff8000092d9550 x6 : 0000000000017988
[ 1650.004285] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1650.011403] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1650.018520] Call trace:
[ 1650.020952] __vunmap+0x78/0x30c
[ 1650.024166] vunmap+0x40/0x5c
[ 1650.027121] dma_direct_free+0x10c/0x110
[ 1650.031031] dma_free_attrs+0x98/0xe0
[ 1650.034680] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1650.039983] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1650.044850] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1650.050151] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1650.055106] v4l2_release+0xbc/0xf0 [videodev]
[ 1650.059556] __fput+0x70/0x250
[ 1650.062599] ____fput+0x10/0x20
[ 1650.065728] task_work_run+0x80/0xe0
[ 1650.069290] do_notify_resume+0x208/0x1280
[ 1650.073373] el0_svc+0x74/0x84
[ 1650.076415] el0t_64_sync_handler+0xbc/0x140
[ 1650.080669] el0t_64_sync+0x18c/0x190
[ 1650.084317] ---[ end trace 0000000000000000 ]---
[ 1650.154301] ------------[ cut here ]------------
[ 1650.158971] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1650.165416] WARNING: CPU: 1 PID: 3430 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1650.172632] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus ff80000c0b3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1650.283582] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1650.290701] x23: 000000093a200000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1650.297819] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1650.304938] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1650.312056] x14: 000000000000026d x13: 0000000000000000 x12: 0000000000000000
[ 1650.319174] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0b3980
[ 1650.326291] x8 : ffff0008aae15150 x7 : ffff000f5c383340 x6 : 0000000000000000
[ 1650.333407] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1b47748
[ 1650.340525] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1650.347643] Call trace:
[ 1650.350079] __vunmap+0x78/0x30c
[ 1650.353295] vunmap+0x40/0x5c
[ 1650.356251] dma_direct_free+0x10c/0x110
[ 1650.360162] dma_free_attrs+0x98/0xe0
[ 1650.363811] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1650.369122] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1650.374077] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1650.379378] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1650.384333] v4l2_release+0xbc/0xf0 [videodev]
[ 1650.388791] __fput+0x70/0x250
[ 1650.391836] ____fput+0x10/0x20
[ 1650.394965] task_work_run+0x80/0xe0
[ 1650.398529] do_notify_resume+0x208/0x1280
[ 1650.402614] el0_svc+0x74/0x84
[ 1650.405658] el0t_64_sync_handler+0xbc/0x140
[ 1650.409913] el0t_64_sync+0x18c/0x190
[ 1650.413561] ---[ end trace 0000000000000000 ]---
[ 1650.418272] ------------[ cut here ]------------
[ 1650.422880] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1650.429277] WARNING: CPU: 1 PID: 3430 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1650.436484] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common di x15: ffff80008c0b37b7
[ 1650.575878] x14: 00000000000000d0 x13: 0000000000000000 x12: 0000000000000000
[ 1650.582996] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0b3980
[ 1650.590114] x8 : ffff0008aae15150 x7 : ffff000f5c383340 x6 : 0000000000000000
[ 1650.597231] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1b47748
[ 1650.604349] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1650.611467] Call trace:
[ 1650.613900] __vunmap+0x78/0x30c
[ 1650.617115] vunmap+0x40/0x5c
[ 1650.620068] dma_direct_free+0x10c/0x110
[ 1650.623979] dma_free_attrs+0x98/0xe0
[ 1650.627628] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1650.632932] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1650.637888] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1650.643189] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1650.648145] v4l2_release+0xbc/0xf0 [videodev]
[ 1650.652599] __fput+0x70/0x250
[ 1650.655642] ____fput+0x10/0x20
[ 1650.658772] task_work_run+0x80/0xe0
[ 1650.662335] do_notify_resume+0x208/0x1280
[ 1650.666419] el0_svc+0x74/0x84
[ 1650.669462] el0t_64_sync_handler+0xbc/0x140
[ 1650.673716] el0t_64_sync+0x18c/0x190
[ 1650.677365] ---[ end trace 0000000000000000 ]---
[ 1650.681994] ------------[ cut here ]------------
[ 1650.686601] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1650.692947] WARNING: CPU: 1 PID: 3430 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1650.700152] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(race:
[ 1650.877560] __vunmap+0x78/0x30c
[ 1650.880775] vunmap+0x40/0x5c
[ 1650.883734] dma_direct_free+0x10c/0x110
[ 1650.887644] dma_free_attrs+0x98/0xe0
[ 1650.891292] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1650.896594] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1650.901548] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1650.906850] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1650.911804] v4l2_release+0xbc/0xf0 [videodev]
[ 1650.916257] __fput+0x70/0x250
[ 1650.919301] ____fput+0x10/0x20
[ 1650.922430] task_work_run+0x80/0xe0
[ 1650.925991] do_notify_resume+0x208/0x1280
[ 1650.930075] el0_svc+0x74/0x84
[ 1650.933117] el0t_64_sync_handler+0xbc/0x140
[ 1650.937372] el0t_64_sync+0x18c/0x190
[ 1650.941019] ---[ end trace 0000000000000000 ]---
[ 1650.945640] ------------[ cut here ]------------
[ 1650.950245] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1650.956589] WARNING: CPU: 1 PID: 3430 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1650.963794] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1651.035470] CPU: 1 PID: 3430 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1651.044578] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1651.050219] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1651.057161] pc : __vunmap+0x78/0x30c
[ 1651.060722] lr : __vunmap+0x78/0x30c
[ 1651.064284] sp : ffff80000c0b3ad0
[ 1651.067584] x29: ffff80000c0b3ad0 [wave5]
[ 1651.160219] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1651.165089] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1651.170391] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1651.175345] v4l2_release+0xbc/0xf0 [videodev]
[ 1651.179796] __fput+0x70/0x250
[ 1651.182840] ____fput+0x10/0x20
[ 1651.185969] task_work_run+0x80/0xe0
[ 1651.189531] do_notify_resume+0x208/0x1280
[ 1651.193614] el0_svc+0x74/0x84
[ 1651.196656] el0t_64_sync_handler+0xbc/0x140
[ 1651.200910] el0t_64_sync+0x18c/0x190
[ 1651.204559] ---[ end trace 0000000000000000 ]---
[ 1651.270286] cma_alloc: 15 callbacks suppressed
[ 1651.270297] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1651.284854] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1651.295864] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1651.305460] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1651.314680] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1651.325070] ------------[ cut here ]------------
[ 1651.329692] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1651.336055] WARNING: CPU: 6 PID: 3433 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1651.343271] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1651.414974] CPU: 6 PID: 3433 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1651.424085] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1651.429727] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1651.436670] pc : __vunmap+0x78/0x30c
[ 1651.440232] lr : __vunmap+0x78/0x30c
[ 1651.443793] sp : ffff80000baebad0
[ 1651.447093] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1651.454212] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1651.461330] x23: 000000093a300000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1651.468448] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1651.475565] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1651.482682] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000017d
[ 1651.489799] x11: 000000000000007f x10: ffff8000092da138 x9 : ffff800009281550
[ 1651.496917] x8 : 000000010000207f x7 : ffff8000092d9550 x6 : 0000000000000be8
[ 1651.504034] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1651.511150] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1651.518268] Call trace:
[ 1651.520702] __vunmap+0x78/0x30c
[ 1651.523918] vunmap+0x40/0x5c
[ 1651.526874] dma_direct_free+0x10c/0x110
[ 1651.530784] dma_free_attrs+0x98/0xe0
[ 1651.534433] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1651.539744] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1651.544698] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1651.550000] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1651.554955] v4l2_release+0xbc/0xf0 [videodev]
[ 1651.559411] __fput+0x70/0x250
[ 1651.562455] ____fput+0x10/0x20
[ 1651.565585] task_work_run+0x80/0xe0
[ 1651.569148] do_notify_resume+0x208/0x1280
[ 1651.573234] el0_svc+0x74/0x84
[ 1651.576278] el0t_64_sync_handler+0xbc/0x140
[ 1651.580534] el0t_64_sync+0x18c/0x190
[ 1651.584184] ---[ end trace 0000000000000000 ]---
[ 1651.588819] ------------[ cut here ]------------
[ 1651.593444] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1651.599854] WARNING: CPU: 6 PID: 3433 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1651.607061] Modules linked in: overlay cfg80211 pci_ : ffff80000baebad0
[ 1651.710867] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1651.717988] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1651.725106] x23: 000000093a240000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1651.732224] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1651.739342] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1651.746460] x14: 00000000000001d7 x13: 0000000000000000 x12: 0000000000000000
[ 1651.753578] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000baeb980
[ 1651.760696] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1651.767812] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d8748
[ 1651.774930] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1651.782046] Call trace:
[ 1651.784479] __vunmap+0x78/0x30c
[ 1651.787693] vunmap+0x40/0x5c
[ 1651.790649] dma_direct_free+0x10c/0x110
[ 1651.794558] dma_free_attrs+0x98/0xe0
[ 1651.798206] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1651.803509] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1651.808464] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1651.813764] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1651.818719] v4l2_release+0xbc/0xf0 [videodev]
[ 1651.823175] __fput+0x70/0x250
[ 1651.826219] ____fput+0x10/0x20
[ 1651.829348] task_work_run+0x80/0xe0
[ 1651.832911] do_notify_resume+0x208/0x1280
[ 1651.836995] el0_svc+0x74/0x84
[ 1651.840036] el0t_64_sync_handler+0xbc/0x140
[ 1651.844290] el0t_64_sync+0x18c/0x190
[ 1651.847938] ---[ end trace 0000000000000000 ]---
[ 1651.852565] ------------[ cut here ]------------
[ 1651.857172] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1651.863518] WARNING: CPU: 6 PID: 3433 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1651.870723] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_asy00 x25: 0000000000000000 x24: 0000000000000000
[ 1651.988751] x23: 000000093a280000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1651.995870] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1652.002988] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1652.010106] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000261
[ 1652.017224] x11: 00000000000000cb x10: ffff8000092da858 x9 : 0000000000000013
[ 1652.024342] x8 : 0000000000000000 x7 : 000000000000033a x6 : 0000000000004e7c
[ 1652.031460] x5 : 0000000000000016 x4 : 0000000000005a7c x3 : ffff000f5c3e2d30
[ 1652.038578] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1652.045696] Call trace:
[ 1652.048128] __vunmap+0x78/0x30c
[ 1652.051342] vunmap+0x40/0x5c
[ 1652.054297] dma_direct_free+0x10c/0x110
[ 1652.058206] dma_free_attrs+0x98/0xe0
[ 1652.061854] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1652.067156] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1652.072111] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1652.077412] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1652.082366] v4l2_release+0xbc/0xf0 [videodev]
[ 1652.086818] __fput+0x70/0x250
[ 1652.089860] ____fput+0x10/0x20
[ 1652.092989] task_work_run+0x80/0xe0
[ 1652.096551] do_notify_resume+0x208/0x1280
[ 1652.100634] el0_svc+0x74/0x84
[ 1652.103675] el0t_64_sync_handler+0xbc/0x140
[ 1652.107930] el0t_64_sync+0x18c/0x190
[ 1652.111579] ---[ end trace 0000000000000000 ]---
[ 1652.116206] ------------[ cut here ]------------
[ 1652.120816] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1652.127161] WARNING: CPU: 6 PID: 3433 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1652.134365] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remo9: ffff80000c3b5000 x18: ffffffffffffffff
[ 1652.266627] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1652.273749] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000002d3
[ 1652.280867] x11: 00000000000000f1 x10: ffff8000092dabe8 x9 : ffff800009281550
[ 1652.287985] x8 : 00000001000020f1 x7 : ffff8000092d9550 x6 : 0000000000001698
[ 1652.295103] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1652.302221] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1652.309339] Call trace:
[ 1652.311772] __vunmap+0x78/0x30c
[ 1652.314986] vunmap+0x40/0x5c
[ 1652.317941] dma_direct_free+0x10c/0x110
[ 1652.321850] dma_free_attrs+0x98/0xe0
[ 1652.325498] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1652.330800] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1652.335667] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1652.340968] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1652.345922] v4l2_release+0xbc/0xf0 [videodev]
[ 1652.350373] __fput+0x70/0x250
[ 1652.353416] ____fput+0x10/0x20
[ 1652.356545] task_work_run+0x80/0xe0
[ 1652.360108] do_notify_resume+0x208/0x1280
[ 1652.364191] el0_svc+0x74/0x84
[ 1652.367232] el0t_64_sync_handler+0xbc/0x140
[ 1652.371487] el0t_64_sync+0x18c/0x190
[ 1652.375134] ---[ end trace 0000000000000000 ]---
[ 1652.440860] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1652.450933] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1652.462039] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1652.471600] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1652.480816] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1652.491203] ------------[ cut here ]------------
[ 1652.495826] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1652.502186] WARNING: CPU: 7 PID: 3436 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1652.509402] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1652.581103] CPU: 7 PID: 3436 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1652.590215] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1652.595856] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1652.602800] pc : __vunmap+0x78/0x30c
[ 1652.606362] lr : __vunmap+0x78/0x30c
[ 1652.609924] sp : ffff80000bf8bad0
[ 1652.613224] x29: ffff80000bf8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1652.620344] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1652.627462] x23: 000000093a380000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1652.634580] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1652.641697] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bf8b7b7
[ 1652.648816] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000354
[ 1652.655933] x11: 000000000000011c x10: ffff8000092daff0 x9 : ffff800009281550
[ 1652.663051] x8 : 000000010000211c x7 : ffff8000092d9550 x6 : 0000000000001aa0
[ 1652.670169] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1652.677287] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1652.684405] Call trace:
[ 1652.686839] __vunmap+0x78/0x30c
[ 1652.690055] vunmap+0x40/0x5c
[ 1652.693011] dma_direct_free+0x10c/0x110
[ 1652.696922] dma_free_attrs+0x98/0xe0
[ 1652.700570] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1652.705882] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1652.710837] wave5_vpu_release_device+0x64/0x18c [ns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1652.844791] CPU: 7 PID: 3436 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1652.853903] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1652.859544] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1652.866486] pc : __vunmap+0x78/0x30c
[ 1652.870048] lr : __vunmap+0x78/0x30c
[ 1652.873609] sp : ffff80000bf8bad0
[ 1652.876909] x29: ffff80000bf8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1652.884027] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1652.891145] x23: 000000093a340000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1652.898262] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1652.905380] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bf8b7b7
[ 1652.912498] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000003c6
[ 1652.919615] x11: 0000000000000142 x10: ffff8000092db380 x9 : ffff800009281550
[ 1652.926733] x8 : 0000000100002142 x7 : ffff8000092d9550 x6 : 0000000000001e30
[ 1652.933851] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1652.940968] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1652.948085] Call trace:
[ 1652.950518] __vunmap+0x78/0x30c
[ 1652.953731] vunmap+0x40/0x5c
[ 1652.956687] dma_direct_free+0x10c/0x110
[ 1652.960596] dma_free_attrs+0x98/0xe0
[ 1652.964245] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1652.969548] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1652.974503] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1652.979804] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1652.984759] v4l2_release+0xbc/0xf0 [videodev]
[ 1652.989212] __fput+0x70/0x250
[ 1652.992254] ____fput+0 pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1653.108464] CPU: 7 PID: 3436 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1653.117577] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1653.123218] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1653.130160] pc : __vunmap+0x78/0x30c
[ 1653.133722] lr : __vunmap+0x78/0x30c
[ 1653.137283] sp : ffff80000bf8bad0
[ 1653.140583] x29: ffff80000bf8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1653.147701] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1653.154819] x23: 000000093a2c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1653.161936] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1653.169053] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bf8b7b7
[ 1653.176171] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000438
[ 1653.183288] x11: 0000000000000168 x10: ffff8000092db710 x9 : ffff800009281550
[ 1653.190406] x8 : 0000000100002168 x7 : ffff8000092d9550 x6 : 00000000000021c0
[ 1653.197523] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1653.204640] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1653.211757] Call trace:
[ 1653.214190] __vunmap+0x78/0x30c
[ 1653.217404] vunmap+0x40/0x5c
[ 1653.220359] dma_direct_free+0x10c/0x110
[ 1653.224268] dma_free_attrs+0x98/0xe0
[ 1653.227917] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1653.233220] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1653.238175] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1653.243476] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1653.248430] v4l2_release+0xbc/0xf0 [videodev]
[ 1653.252881] __fput+0x70/0x250
[ 1653.255924] ____fput+0x10/0x20
[ 1653.259054] task_work_run+0x80/0xe0
[ 1653.262615] do_notify_resume+0x208/0x1280
[ 1653.266699] el0_svc+0x74/0x84
[ 1653.269741] el0t_64_sync_handler+0xbc/0x140
[ 1653.273996] el0t_64_sync+0x18c/0x190
[ 1653.277645] ---[ end trace 0000000000000000 ]---
[ 1653.282283] ------------[ cut here ]------------
[ 1653.286893] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 16(DT)
[ 1653.386874] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1653.393816] pc : __vunmap+0x78/0x30c
[ 1653.397380] lr : __vunmap+0x78/0x30c
[ 1653.400941] sp : ffff80000bf8bad0
[ 1653.404241] x29: ffff80000bf8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1653.411359] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1653.418477] x23: 000000093a2a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1653.425595] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1653.432713] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008bf8b7b7
[ 1653.439830] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000004aa
[ 1653.446947] x11: 000000000000018e x10: ffff8000092dbaa0 x9 : ffff800009281550
[ 1653.454065] x8 : 000000010000218e x7 : ffff8000092d9550 x6 : 0000000000002550
[ 1653.461182] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1653.468299] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1653.475416] Call trace:
[ 1653.477849] __vunmap+0x78/0x30c
[ 1653.481065] vunmap+0x40/0x5c
[ 1653.484021] dma_direct_free+0x10c/0x110
[ 1653.487929] dma_free_attrs+0x98/0xe0
[ 1653.491578] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1653.496882] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1653.501750] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1653.507051] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1653.512005] v4l2_release+0xbc/0xf0 [videodev]
[ 1653.516458] __fput+0x70/0x250
[ 1653.519501] ____fput+0x10/0x20
[ 1653.522630] task_work_run+0x80/0xe0
[ 1653.526192] do_notify_resume+0x208/0x1280
[ 1653.530275] el0_svc+0x74/0x84
[ 1653.533317] el0t_64_sync_handler+0xbc/0x140
[ 1653.537572] el0t_64_sync+0x18c/0x190
[ 1653.541220] ---[ end trace 0000000000000000 ]---
[ 1653.611144] ------------[ cut here ]------------
[ 1653.615766] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1653.622158] WARNING: CPU: 6 PID: 3439 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1653.629371] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc y ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1653.701073] CPU: 6 PID: 3439 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1653.710188] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1653.715830] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1653.722773] pc : __vunmap+0x78/0x30c
[ 1653.726335] lr : __vunmap+0x78/0x30c
[ 1653.729897] sp : ffff80000beabad0
[ 1653.733196] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1653.740315] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1653.747433] x23: 000000093a480000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1653.754550] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1653.761668] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1653.768785] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000051c
[ 1653.775902] x11: 00000000000001b4 x10: ffff8000092dbe30 x9 : ffff800009281550
[ 1653.783020] x8 : 00000001000021b4 x7 : ffff8000092d9550 x6 : 00000000000028e0
[ 1653.790137] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1653.797254] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1653.804372] Call trace:
[ 1653.806806] __vunmap+0x78/0x30c
[ 1653.810021] vunmap+0x40/0x5c
[ 1653.812976] dma_direct_free+0x10c/0x110
[ 1653.816891] dma_free_attrs+0x98/0xe0
[ 1653.820541] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1653.825853] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1653.830807] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1653.836109] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1653.841064] v4l2_release+0xbc/0xf0 [videodev]
[ 1653.845520] __fput+0x70/0x250
[ 1653.848564] ____fput+0x10/0x20
[ 1653.851693] task_work_run+0x80/0xe0
[ 1653.855258] do_notify_resume+0x208/0x1280
[ 1653.859343] el0_svc+0x74/0x84
[ 1653.862386] el0t_64_sync_handler+0xbc/0x140
[ 1653.866641] el0t_64_sync+0x18c/0x190
[ 1653.870290] ---[ end trace 0000000000000000 ]---
[ 1653.874922] ------------[ clt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1653.964914] CPU: 6 PID: 3439 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1653.974024] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1653.979665] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1653.986608] pc : __vunmap+0x78/0x30c
[ 1653.990170] lr : __vunmap+0x78/0x30c
[ 1653.993732] sp : ffff80000beabad0
[ 1653.997032] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1654.004151] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1654.011269] x23: 000000093a3c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1654.018387] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1654.025505] x17: 0000000000000000 x16: 0000000000000000 x15: 0000b625eff3d7ce
[ 1654.032623] x14: 0000000000000015 x13: 0000000000000015 x12: 0000000000000000
[ 1654.039741] x11: 0000000000000001 x10: 00000000000009b0 x9 : ffff80000beab980
[ 1654.046859] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1654.053977] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d98c8
[ 1654.061095] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1654.068214] Call trace:
[ 1654.070647] __vunmap+0x78/0x30c
[ 1654.073861] vunmap+0x40/0x5c
[ 1654.076816] dma_direct_free+0x10c/0x110
[ 1654.080726] dma_free_attrs+0x98/0xe0
[ 1654.084374] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1654.089677] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1654.094631] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1654.099932] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1654.104886] v4l2_release+0xbc/0xf0 [videodev]
[ 1654.109340] __fput+0x70/0x250
[ 1654.112384] ____fput+0x10/0x20
[ 1654.115513] task_work_run+0x80/0xe0
[ 1654.119075] do_notify_resume+0x208/0x1280
[ 1654.123159] el0_svc+0x74/0x84
[ 1654.126201] el0t_64_sync_handler+0xbc/0x140
[ 1654.130456] el0t_64_sync+0x18c/0x190
[ 1654.134104] ---[ end trace 0000000000000000 ]---
[ 1654.131654.260684] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1654.267803] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1654.274924] x23: 000000093a400000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1654.282041] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1654.289159] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1654.296276] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000600
[ 1654.303393] x11: 0000000000000200 x10: ffff8000092dc550 x9 : 0000000000000013
[ 1654.310510] x8 : 0000000000000000 x7 : 0000000000000045 x6 : 00000000000051e1
[ 1654.317627] x5 : 0000000000000017 x4 : 00000000000061e1 x3 : ffff000f5c3e2d30
[ 1654.324744] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1654.331862] Call trace:
[ 1654.334295] __vunmap+0x78/0x30c
[ 1654.337509] vunmap+0x40/0x5c
[ 1654.340464] dma_direct_free+0x10c/0x110
[ 1654.344373] dma_free_attrs+0x98/0xe0
[ 1654.348020] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1654.353323] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1654.358279] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1654.363580] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1654.368535] v4l2_release+0xbc/0xf0 [videodev]
[ 1654.372987] __fput+0x70/0x250
[ 1654.376031] ____fput+0x10/0x20
[ 1654.379160] task_work_run+0x80/0xe0
[ 1654.382723] do_notify_resume+0x208/0x1280
[ 1654.386807] el0_svc+0x74/0x84
[ 1654.389848] el0t_64_sync_handler+0xbc/0x140
[ 1654.394104] el0t_64_sync+0x18c/0x190
[ 1654.397752] ---[ end trace 0000000000000000 ]---
[ 1654.402375] ------------[ cut here ]------------
[ 1654.406991] Trying to vfree() nonexistent vm area (000000004d29041c)
[ 1654.413385] WARNING: CPU: 6 PID: 3439 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1654.420592] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper v000000000000
[ 1654.559981] x14: 000000000000038b x13: 0000000000000000 x12: 0000000000000000
[ 1654.567101] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000beab980
[ 1654.574220] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1654.581338] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d98c8
[ 1654.588456] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1654.595574] Call trace:
[ 1654.598007] __vunmap+0x78/0x30c
[ 1654.601223] vunmap+0x40/0x5c
[ 1654.604178] dma_direct_free+0x10c/0x110
[ 1654.608088] dma_free_attrs+0x98/0xe0
[ 1654.611736] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1654.617038] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1654.621906] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1654.627207] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1654.632162] v4l2_release+0xbc/0xf0 [videodev]
[ 1654.636614] __fput+0x70/0x250
[ 1654.639657] ____fput+0x10/0x20
[ 1654.642786] task_work_run+0x80/0xe0
[ 1654.646348] do_notify_resume+0x208/0x1280
[ 1654.650431] el0_svc+0x74/0x84
[ 1654.653473] el0t_64_sync_handler+0xbc/0x140
[ 1654.657728] el0t_64_sync+0x18c/0x190
[ 1654.661377] ---[ end trace 0000000000000000 ]---
[ 1654.731901] ------------[ cut here ]------------
[ 1654.736527] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1654.742886] WARNING: CPU: 5 PID: 3442 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1654.750100] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse0000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1654.843503] pc : __vunmap+0x78/0x30c
[ 1654.847069] lr : __vunmap+0x78/0x30c
[ 1654.850631] sp : ffff80000c35bad0
[ 1654.853932] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1654.861051] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1654.868168] x23: 000000093a500000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1654.875286] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1654.882403] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c35b7b7
[ 1654.889520] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000006e4
[ 1654.896637] x11: 000000000000024c x10: ffff8000092dcc70 x9 : ffff800009281550
[ 1654.903754] x8 : 000000010000224c x7 : ffff8000092d9550 x6 : 0000000000003720
[ 1654.910871] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1654.917988] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1654.925106] Call trace:
[ 1654.927540] __vunmap+0x78/0x30c
[ 1654.930754] vunmap+0x40/0x5c
[ 1654.933710] dma_direct_free+0x10c/0x110
[ 1654.937622] dma_free_attrs+0x98/0xe0
[ 1654.941270] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1654.946582] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1654.951537] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1654.956839] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1654.961794] v4l2_release+0xbc/0xf0 [videodev]
[ 1654.966248] __fput+0x70/0x250
[ 1654.969293] ____fput+0x10/0x20
[ 1654.972423] task_work_run+0x80/0xe0
[ 1654.975986] do_notify_resume+0x208/0x1280
[ 1654.980072] el0_svc+0x74/0x84
[ 1654.983115] el0t_64_sync_handler+0xbc/0x140
[ 1654.987370] el0t_64_sync+0x18c/0x190
[ 1654.991018] ---[ end trace 0000000000000000 ]---
[ 1654.995697] ------------[ cut here ]------------
[ 1655.000309] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1655.006661] WARNING: CPU: 5 PID: 3442 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1655.013868] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common e name: Texas Instruments J784S4 EVM (DT)
[ 1655.100300] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1655.107245] pc : __vunmap+0x78/0x30c
[ 1655.110808] lr : __vunmap+0x78/0x30c
[ 1655.114369] sp : ffff80000c35bad0
[ 1655.117670] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1655.124787] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1655.131904] x23: 000000093a4c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1655.139024] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1655.146141] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c35b7b7
[ 1655.153258] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000756
[ 1655.160375] x11: 0000000000000272 x10: ffff8000092dd000 x9 : ffff800009281550
[ 1655.167492] x8 : 0000000100002272 x7 : ffff8000092d9550 x6 : 0000000000003ab0
[ 1655.174609] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1655.181726] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1655.188843] Call trace:
[ 1655.191276] __vunmap+0x78/0x30c
[ 1655.194491] vunmap+0x40/0x5c
[ 1655.197447] dma_direct_free+0x10c/0x110
[ 1655.201356] dma_free_attrs+0x98/0xe0
[ 1655.205004] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1655.210309] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1655.215264] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1655.220565] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1655.225519] v4l2_release+0xbc/0xf0 [videodev]
[ 1655.229972] __fput+0x70/0x250
[ 1655.233015] ____fput+0x10/0x20
[ 1655.236144] task_work_run+0x80/0xe0
[ 1655.239707] do_notify_resume+0x208/0x1280
[ 1655.243792] el0_svc+0x74/0x84
[ 1655.246833] el0t_64_sync_handler+0xbc/0x140
[ 1655.251088] el0t_64_sync+0x18c/0x190
[ 1655.254737] ---[ end trace 0000000000000000 ]---
[ 1655.259391] ------------[ cut here ]------------
[ 1655.264007] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1655.270365] WARNING: CPU: 0 PID: 3442 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1655.277575] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl 5.370976] pc : __vunmap+0x78/0x30c
[ 1655.374538] lr : __vunmap+0x78/0x30c
[ 1655.378100] sp : ffff80000c35bad0
[ 1655.381400] x29: ffff80000c35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1655.388520] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1655.395638] x23: 000000093a440000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1655.402755] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1655.409873] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c35b7b7
[ 1655.416991] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000007c8
[ 1655.424109] x11: 0000000000000298 x10: ffff8000092dd390 x9 : ffff800009281550
[ 1655.431226] x8 : 0000000100002298 x7 : ffff8000092d9550 x6 : 0000000000003e40
[ 1655.438345] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1655.445463] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1655.452581] Call trace:
[ 1655.455016] __vunmap+0x78/0x30c
[ 1655.458231] vunmap+0x40/0x5c
[ 1655.461186] dma_direct_free+0x10c/0x110
[ 1655.465097] dma_free_attrs+0x98/0xe0
[ 1655.468745] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1655.474053] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1655.479007] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1655.484309] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1655.489263] v4l2_release+0xbc/0xf0 [videodev]
[ 1655.493714] __fput+0x70/0x250
[ 1655.496758] ____fput+0x10/0x20
[ 1655.499887] task_work_run+0x80/0xe0
[ 1655.503450] do_notify_resume+0x208/0x1280
[ 1655.507535] el0_svc+0x74/0x84
[ 1655.510578] el0t_64_sync_handler+0xbc/0x140
[ 1655.514833] el0t_64_sync+0x18c/0x190
[ 1655.518483] ---[ end trace 0000000000000000 ]---
[ 1655.523127] ------------[ cut here ]------------
[ 1655.527739] Trying to vfree() nonexistent vm area (0000000080603a40)
[ 1655.534086] WARNING: CPU: 0 PID: 3442 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1655.541291] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_m35bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1655.652203] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1655.659322] x23: 000000093a420000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1655.666439] x20: 0000000000000000 x19: ffff80000c3b5000 x18: ffffffffffffffff
[ 1655.673556] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c35b7b7
[ 1655.680673] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000083a
[ 1655.687791] x11: 00000000000002be x10: ffff8000092dd720 x9 : ffff800009281550
[ 1655.694910] x8 : 00000001000022be x7 : ffff8000092d9550 x6 : 00000000000041d0
[ 1655.702027] x5 : ffff000f5c369b60 x4 : ffff000f5c369b60 x3 : ffff000f5c36cda0
[ 1655.709145] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1655.716263] Call trace:
[ 1655.718696] __vunmap+0x78/0x30c
[ 1655.721910] vunmap+0x40/0x5c
[ 1655.724866] dma_direct_free+0x10c/0x110
[ 1655.728775] dma_free_attrs+0x98/0xe0
[ 1655.732423] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1655.737725] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1655.742594] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1655.747894] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1655.752848] v4l2_release+0xbc/0xf0 [videodev]
[ 1655.757302] __fput+0x70/0x250
[ 1655.760345] ____fput+0x10/0x20
[ 1655.763474] task_work_run+0x80/0xe0
[ 1655.767037] do_notify_resume+0x208/0x1280
[ 1655.771120] el0_svc+0x74/0x84
[ 1655.774162] el0t_64_sync_handler+0xbc/0x140
[ 1655.778417] el0t_64_sync+0x18c/0x190
[ 1655.782064] ---[ end trace 0000000000000000 ]---
[ 1655.852319] ------------[ cut here ]------------
[ 1655.856942] Trying to vfree() nonexistent vm area (000000005a7bd19a)
[ 1655.863369] WARNING: CPU: 6 PID: 3445 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1655.870585] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_conne optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1655.942289] CPU: 6 PID: 3445 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1655.951406] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1655.957047] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1655.963990] pc : __vunmap+0x78/0x30c
[ 1655.967553] lr : __vunmap+0x78/0x30c
[ 1655.971115] sp : ffff8000094d3ad0
[ 1655.974415] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1655.981534] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1655.988651] x23: 000000093a600000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1655.995769] x20: 0000000000000000 x19: ffff80000c739000 x18: ffffffffffffffff
[ 1656.002887] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1656.010004] x14: 00000000000003c5 x13: 0000000000000001 x12: 0000000000000001
[ 1656.017122] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000094d3980
[ 1656.024239] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1656.031357] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d98c8
[ 1656.038474] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1656.045592] Call trace:
[ 1656.048027] __vunmap+0x78/0x30c
[ 1656.051241] vunmap+0x40/0x5c
[ 1656.054197] dma_direct_free+0x10c/0x110
[ 1656.058108] dma_free_attrs+0x98/0xe0
[ 1656.061756] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1656.067068] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1656.072023] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1656.077325] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1656.082280] v4l2_release+0xbc/0xf0 [videodev]
[ 1656.086736] __fput+0x70/0x250
[ 1656.089781] ____fput+0x10/0x20
[ 1656.092911] task_work_run+0x80/0xe0
[ 1656.096473] do_notify_resume+0x208/0x1280
[ 1656.100559] el0_svc+0x74/0x84
[ 1656.103603] el0t_64_sync_handler+0xbc/0x140
[ 1656.107859] el0t_64_sync+0x18c/0x190
[ 1656.111508] ---[ end trace 0000000000000000 ]---
[ 1656.116257] ------------[ cut here ]------------
[ 1656.120866] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1656.127260]60] sp : ffff8000094d3ad0
[ 1656.238260] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1656.245378] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1656.252496] x23: 000000093a540000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1656.259614] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1656.266731] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1656.273848] x14: 0000000000000224 x13: 0000000000000000 x12: 0000000000000000
[ 1656.280965] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000094d3980
[ 1656.288082] x8 : ffff0008aae15f90 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1656.295200] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d98c8
[ 1656.302317] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1656.309434] Call trace:
[ 1656.311867] __vunmap+0x78/0x30c
[ 1656.315083] vunmap+0x40/0x5c
[ 1656.318038] dma_direct_free+0x10c/0x110
[ 1656.321947] dma_free_attrs+0x98/0xe0
[ 1656.325596] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1656.330900] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1656.335856] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1656.341157] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1656.346112] v4l2_release+0xbc/0xf0 [videodev]
[ 1656.350568] __fput+0x70/0x250
[ 1656.353611] ____fput+0x10/0x20
[ 1656.356740] task_work_run+0x80/0xe0
[ 1656.360302] do_notify_resume+0x208/0x1280
[ 1656.364387] el0_svc+0x74/0x84
[ 1656.367429] el0t_64_sync_handler+0xbc/0x140
[ 1656.371685] el0t_64_sync+0x18c/0x190
[ 1656.375334] ---[ end trace 0000000000000000 ]---
[ 1656.379960] ------------[ cut here ]------------
[ 1656.384566] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1656.390911] WARNING: CPU: 6 PID: 3445 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1656.398116] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss_vunmap+0x78/0x30c
[ 1656.495049] lr : __vunmap+0x78/0x30c
[ 1656.498613] sp : ffff8000094d3ad0
[ 1656.501913] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1656.509032] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1656.516150] x23: 000000093a580000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1656.523267] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1656.530384] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1656.537501] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000990
[ 1656.544618] x11: 0000000000000330 x10: ffff8000092de1d0 x9 : ffff800009281550
[ 1656.551736] x8 : 0000000100002330 x7 : ffff8000092d9550 x6 : 0000000000004c80
[ 1656.558853] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1656.565970] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1656.573087] Call trace:
[ 1656.575521] __vunmap+0x78/0x30c
[ 1656.578735] vunmap+0x40/0x5c
[ 1656.581690] dma_direct_free+0x10c/0x110
[ 1656.585599] dma_free_attrs+0x98/0xe0
[ 1656.589246] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1656.594549] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1656.599503] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1656.604804] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1656.609758] v4l2_release+0xbc/0xf0 [videodev]
[ 1656.614210] __fput+0x70/0x250
[ 1656.617254] ____fput+0x10/0x20
[ 1656.620383] task_work_run+0x80/0xe0
[ 1656.623945] do_notify_resume+0x208/0x1280
[ 1656.628029] el0_svc+0x74/0x84
[ 1656.631070] el0t_64_sync_handler+0xbc/0x140
[ 1656.635325] el0t_64_sync+0x18c/0x190
[ 1656.638972] ---[ end trace 0000000000000000 ]---
[ 1656.643593] ------------[ cut here ]------------
[ 1656.644053] systemd-journald[211]: Data hash table of /run/log/journal/f08f228c5e744fcc8c6b15a383956c6e/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation.
[ 1656.648199] Trying to vfree() nonexistent vm area (0000000008b3bc44)
[ 1656.669281] systemd-journald[211]: /run/log/journal/f08f228c5e744fcc8c6b15a383956c6e/system.journal: Journal header limits reachedcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1656.769061] CPU: 6 PID: 3445 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1656.778173] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1656.783815] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1656.790758] pc : __vunmap+0x78/0x30c
[ 1656.794322] lr : __vunmap+0x78/0x30c
[ 1656.797883] sp : ffff8000094d3ad0
[ 1656.801183] x29: ffff8000094d3ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1656.808301] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1656.815419] x23: 000000093a460000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1656.822536] x20: 0000000000000000 x19: ffff80000c0e1000 x18: ffffffffffffffff
[ 1656.829653] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000894d37b7
[ 1656.836770] x14: 0000000000000000 x13: 2934346362336238 x12: 3030303030303030
[ 1656.843887] x11: 3028206165726120 x10: 6d7620746e657473 x9 : 6d7620746e657473
[ 1656.851004] x8 : 6978656e6f6e2029 x7 : 205d393931383436 x6 : 362e36353631205b
[ 1656.858121] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1656.865237] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1656.872355] Call trace:
[ 1656.874789] __vunmap+0x78/0x30c
[ 1656.878005] vunmap+0x40/0x5c
[ 1656.880960] dma_direct_free+0x10c/0x110
[ 1656.884870] dma_free_attrs+0x98/0xe0
[ 1656.888520] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1656.893829] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1656.898697] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1656.903998] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1656.908953] v4l2_release+0xbc/0xf0 [videodev]
[ 1656.913408] __fput+0x70/0x250
[ 1656.916452] ____fput+0x10/0x20
[ 1656.919581] task_work_run+0x80/0xe0
[ 1656.923144] do_notify_resume+0x208/0x1280
[ 1656.927230] el0_svc+0x74/0x84
[ 1656.930273] el0t_64_sync_handler+0xbc/0x140
[ 1656.934528] el0t_64_sync+0x18c/0x190
[ 1656.938176] ---[ end trace 0000000000000000 ]---
[ 1657.011243] cma_alloc: 15 callbacks suppressed
[ 1657.011254] cma: cma_alloc: linux-cma-buffers@980000000et: -16
[ 1657.036849] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1657.046419] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1657.055635] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1657.066168] ------------[ cut here ]------------
[ 1657.070791] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1657.077152] WARNING: CPU: 7 PID: 3449 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1657.084367] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1657.156070] CPU: 7 PID: 3449 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1657.165181] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1657.170823] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1657.177767] pc : __vunmap+0x78/0x30c
[ 1657.181329] lr : __vunmap+0x78/0x30c
[ 1657.184891] sp : ffff80000c0ebad0
[ 1657.188192] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1657.195311] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1657.202428] x23: 000000093a680000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1657.209546] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1657.216663] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1657.223782] x14: 0000000000000000 x13: ffff80000928151657.340930] WARNING: CPU: 7 PID: 3449 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1657.348138] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1657.419820] CPU: 7 PID: 3449 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1657.428930] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1657.434570] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1657.441511] pc : __vunmap+0x78/0x30c
[ 1657.445073] lr : __vunmap+0x78/0x30c
[ 1657.448635] sp : ffff80000c0ebad0
[ 1657.451935] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1657.459054] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1657.466171] x23: 000000093a640000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1657.473289] x20: 0000000000000000 x19: ffff80000c3ad000 x18: ffffffffffffffff
[ 1657.480406] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 1657.487523] x14: 0000000000000229 x13: 0000000000000000 x12: 0000000000000000
[ 1657.494640] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000c0eb980
[ 1657.501757] x8 : ffff0008aae15150 x7 : ffff000f5c3f5340 x6 : 0000000000000000
[ 1657.508875] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a1a073c8
[ 1657.515993] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1657.523111] Call trace:
[ 1657.525543] __vunmap+0x78/0x30c
[ 1657.528758] vunmap+0x40/0x5c
[ 1657.531713] dma_direct0x30c
[ 1657.611813] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1657.683491] CPU: 7 PID: 3449 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1657.692600] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1657.698240] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1657.705183] pc : __vunmap+0x78/0x30c
[ 1657.708744] lr : __vunmap+0x78/0x30c
[ 1657.712306] sp : ffff80000c0ebad0
[ 1657.715606] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1657.722725] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1657.729843] x23: 000000093a5c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1657.736961] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1657.744079] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1657.751197] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000b70
[ 1657.758315] x11: 00000000000003d0 x10: ffff8000092df0d0 x9 : ffff800009281550
[ 1657.765432] x8 : 00000001000023d0 x7 : ffff8000092d9550 x6 : 0000000000005b80
[ 1657.772549] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1657.779667] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1657.786785] Call trace:
[ 1657.789217] __vunmap+0x78/0x30c
[ 1657.792432] vunmap+0x40/0x5c
[ 1657.795387] dma_direct_free+0x10c/0x110
[ 1657.799296] dma_free_attrs+0x98/0xe0
[ 1657.802944] wave5_vrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1657.947125] CPU: 7 PID: 3449 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1657.956236] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1657.961877] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1657.968820] pc : __vunmap+0x78/0x30c
[ 1657.972382] lr : __vunmap+0x78/0x30c
[ 1657.975943] sp : ffff80000c0ebad0
[ 1657.979243] x29: ffff80000c0ebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1657.986362] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1657.993481] x23: 000000093a5a0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1658.000598] x20: 0000000000000000 x19: ffff80000c501000 x18: ffffffffffffffff
[ 1658.007717] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0eb7b7
[ 1658.014834] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000be2
[ 1658.021953] x11: 00000000000003f6 x10: ffff8000092df460 x9 : ffff800009281550
[ 1658.029070] x8 : 00000001000023f6 x7 : ffff8000092d9550 x6 : 0000000000005f10
[ 1658.036187] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1658.043305] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1658.050421] Call trace:
[ 1658.052855] __vunmap+0x78/0x30c
[ 1658.056070] vunmap+0x40/0x5c
[ 1658.059025] dma_direct_free+0x10c/0x110
[ 1658.062934] dma_free_attrs+0x98/0xe0
[ 1658.066582] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1658.071885] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1658.076752] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1658.182682] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1658.192878] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1658.203889] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1658.213671] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1658.222926] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1658.233287] ------------[ cut here ]------------
[ 1658.237960] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1658.244396] WARNING: CPU: 6 PID: 3452 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1658.251611] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1658.323312] CPU: 6 PID: 3452 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1658.332422] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1658.338063] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1658.345006] pc : __vunmap+0x78/0x30c
[ 1658.348568] lr : __vunmap+0x78/0x30c
[ 1658.352130] sp : ffff80000beabad0
[ 1658.355430] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1658.362548] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1658.369667] x23: 000000093a780000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1658.473927] task_work_run+0x80/0xe0
[ 1658.477490] do_notify_resume+0x208/0x1280
[ 1658.481576] el0_svc+0x74/0x84
[ 1658.484620] el0t_64_sync_handler+0xbc/0x140
[ 1658.488876] el0t_64_sync+0x18c/0x190
[ 1658.492525] ---[ end trace 0000000000000000 ]---
[ 1658.497181] ------------[ cut here ]------------
[ 1658.501790] Trying to vfree() nonexistent vm area (000000003fd1b520)
[ 1658.508137] WARNING: CPU: 6 PID: 3452 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1658.515342] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1658.587021] CPU: 6 PID: 3452 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1658.596130] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1658.601771] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1658.608713] pc : __vunmap+0x78/0x30c
[ 1658.612274] lr : __vunmap+0x78/0x30c
[ 1658.615835] sp : ffff80000beabad0
[ 1658.619134] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1658.626252] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1658.633369] x23: 000000093a6c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1658.640487] x20: 0000000000000000 x19: ffff80000c3ad000 x18: ffffffffffffffff
[ 1658.647604] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1658.654721] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000cd5
[ 1658.661838] x11: 0000000000000447 x10: ffff8000092dfbf8 x9 : ffff800enc_release+0x20/0x2c [wave5]
[ 1658.726983] v4l2_release+0xbc/0xf0 [videodev]
[ 1658.731438] __fput+0x70/0x250
[ 1658.734480] ____fput+0x10/0x20
[ 1658.737610] task_work_run+0x80/0xe0
[ 1658.741173] do_notify_resume+0x208/0x1280
[ 1658.745257] el0_svc+0x74/0x84
[ 1658.748299] el0t_64_sync_handler+0xbc/0x140
[ 1658.752555] el0t_64_sync+0x18c/0x190
[ 1658.756204] ---[ end trace 0000000000000000 ]---
[ 1658.760826] ------------[ cut here ]------------
[ 1658.765432] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1658.771778] WARNING: CPU: 6 PID: 3452 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1658.778984] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1658.850661] CPU: 6 PID: 3452 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1658.859771] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1658.865411] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1658.872353] pc : __vunmap+0x78/0x30c
[ 1658.875915] lr : __vunmap+0x78/0x30c
[ 1658.879477] sp : ffff80000beabad0
[ 1658.882777] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1658.889894] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1658.897011] x23: 000000093a700000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1658.904128] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1658.911246] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab98120] ____fput+0x10/0x20
[ 1659.001250] task_work_run+0x80/0xe0
[ 1659.004816] do_notify_resume+0x208/0x1280
[ 1659.008899] el0_svc+0x74/0x84
[ 1659.011942] el0t_64_sync_handler+0xbc/0x140
[ 1659.016198] el0t_64_sync+0x18c/0x190
[ 1659.019845] ---[ end trace 0000000000000000 ]---
[ 1659.024478] ------------[ cut here ]------------
[ 1659.029087] Trying to vfree() nonexistent vm area (00000000551396cf)
[ 1659.035431] WARNING: CPU: 6 PID: 3452 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1659.042637] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1659.114313] CPU: 6 PID: 3452 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1659.123423] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1659.129063] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1659.136005] pc : __vunmap+0x78/0x30c
[ 1659.139566] lr : __vunmap+0x78/0x30c
[ 1659.143128] sp : ffff80000beabad0
[ 1659.146428] x29: ffff80000beabad0 x28: 0000000000000204 x27: 0000000000000000
[ 1659.153547] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1659.160664] x23: 000000093a5e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1659.167782] x20: 0000000000000000 x19: ffff80000c501000 x18: ffffffffffffffff
[ 1659.174899] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008beab7b7
[ 1659.182017] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000db9
[ 1659.189134] x11: 0000000000009.268377] do_notify_resume+0x208/0x1280
[ 1659.272461] el0_svc+0x74/0x84
[ 1659.275505] el0t_64_sync_handler+0xbc/0x140
[ 1659.279760] el0t_64_sync+0x18c/0x190
[ 1659.283408] ---[ end trace 0000000000000000 ]---
[ 1659.360520] ------------[ cut here ]------------
[ 1659.365145] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1659.371512] WARNING: CPU: 7 PID: 3455 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1659.378728] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1659.450434] CPU: 7 PID: 3455 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1659.459545] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1659.465187] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1659.472131] pc : __vunmap+0x78/0x30c
[ 1659.475694] lr : __vunmap+0x78/0x30c
[ 1659.479254] sp : ffff80000c363ad0
[ 1659.482554] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1659.489675] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1659.496792] x23: 000000093a800000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1659.503910] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1659.511027] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3637b7
[ 1659.518146] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000e2b
[ 1659.525265] x11: 00000000000004b9 x10: ffff8000092e06a8 x9 : ffff800009281550
[ 1659.532382] x8 : 0000e_device+0x64/0x18c [wave5]
[ 1659.585472] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1659.590426] v4l2_release+0xbc/0xf0 [videodev]
[ 1659.594884] __fput+0x70/0x250
[ 1659.597928] ____fput+0x10/0x20
[ 1659.601057] task_work_run+0x80/0xe0
[ 1659.604621] do_notify_resume+0x208/0x1280
[ 1659.608707] el0_svc+0x74/0x84
[ 1659.611752] el0t_64_sync_handler+0xbc/0x140
[ 1659.616007] el0t_64_sync+0x18c/0x190
[ 1659.619657] ---[ end trace 0000000000000000 ]---
[ 1659.624286] ------------[ cut here ]------------
[ 1659.628899] Trying to vfree() nonexistent vm area (000000003fd1b520)
[ 1659.635329] WARNING: CPU: 7 PID: 3455 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1659.642536] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1659.714218] CPU: 7 PID: 3455 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1659.723328] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1659.728969] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1659.735911] pc : __vunmap+0x78/0x30c
[ 1659.739473] lr : __vunmap+0x78/0x30c
[ 1659.743035] sp : ffff80000c363ad0
[ 1659.746335] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1659.753452] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1659.760570] x23: 000000093a7c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1659.767688] x20: 0000000000000000 x19: ffff80000c3ad000 x18: ffffffffffffffff
[ 1659.774805] x17: 00000---
[ 1659.892646] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1659.898994] WARNING: CPU: 7 PID: 3455 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1659.906199] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1659.977877] CPU: 7 PID: 3455 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1659.986986] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1659.992625] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1659.999567] pc : __vunmap+0x78/0x30c
[ 1660.003129] lr : __vunmap+0x78/0x30c
[ 1660.006690] sp : ffff80000c363ad0
[ 1660.009990] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1660.017107] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1660.024225] x23: 000000093a740000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1660.031343] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1660.038460] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3637b7
[ 1660.045578] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000f0f
[ 1660.052695] x11: 0000000000000505 x10: ffff8000092e0dc8 x9 : 0000000000000016
[ 1660.059812] x8 : 0000000000000000 x7 : 0000000000000022 x6 : 0000000000005aa4
[ 1660.066928] x5 : 0000000000000019 x4 : 00000000000066a4 x3 : ffff000f5c3f5d30
[ 1660.074047] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1660.081164] Call trace:
[ 1660.083596] __vunmapp+0x78/0x30c
[ 1660.169839] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1660.241517] CPU: 7 PID: 3455 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1660.250626] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1660.256266] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1660.263207] pc : __vunmap+0x78/0x30c
[ 1660.266769] lr : __vunmap+0x78/0x30c
[ 1660.270330] sp : ffff80000c363ad0
[ 1660.273630] x29: ffff80000c363ad0 x28: 0000000000000204 x27: 0000000000000000
[ 1660.280748] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1660.287865] x23: 000000093a720000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1660.294982] x20: 0000000000000000 x19: ffff80000c501000 x18: ffffffffffffffff
[ 1660.302099] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c3637b7
[ 1660.309217] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000f81
[ 1660.316335] x11: 000000000000052b x10: ffff8000092e1158 x9 : ffff800009281550
[ 1660.323454] x8 : 000000010000252b x7 : ffff8000092d9550 x6 : 0000000000007c08
[ 1660.330571] x5 : ffff000f5c3eeb60 x4 : ffff000f5c3eeb60 x3 : ffff000f5c3f1da0
[ 1660.337688] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae14740
[ 1660.344806] Call trace:
[ 1660.347239] __vunmap+0x78/0x30c
[ 1660.350452] vunmap+0x40/0x5c
[ 1660.353408] dma_direct_free+0x10c/0x110
[ 1660.357316] dma_free_attrs+0x98/0xe0
[ 1660.36
[ 1660.481156] ------------[ cut here ]------------
[ 1660.485816] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1660.492178] WARNING: CPU: 6 PID: 3458 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1660.499392] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1660.571094] CPU: 6 PID: 3458 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1660.580206] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1660.585846] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1660.592789] pc : __vunmap+0x78/0x30c
[ 1660.596352] lr : __vunmap+0x78/0x30c
[ 1660.599914] sp : ffff80000baebad0
[ 1660.603214] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1660.610334] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1660.617452] x23: 000000093a900000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1660.624571] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1660.631689] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1660.638807] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000000ff3
[ 1660.645925] x11: 0000000000000551 x10: ffff8000092e14e8 x9 : ffff800009281550
[ 1660.653043] x8 : 0000000100002551 x7 : ffff8000092d9550 x6 : 00000/0x18c [wave5]
[ 1660.700831] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1660.706132] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1660.711085] v4l2_release+0xbc/0xf0 [videodev]
[ 1660.715541] __fput+0x70/0x250
[ 1660.718589] ____fput+0x10/0x20
[ 1660.721718] task_work_run+0x80/0xe0
[ 1660.725282] do_notify_resume+0x208/0x1280
[ 1660.729366] el0_svc+0x74/0x84
[ 1660.732409] el0t_64_sync_handler+0xbc/0x140
[ 1660.736664] el0t_64_sync+0x18c/0x190
[ 1660.740314] ---[ end trace 0000000000000000 ]---
[ 1660.744943] ------------[ cut here ]------------
[ 1660.749615] Trying to vfree() nonexistent vm area (000000003fd1b520)
[ 1660.756034] WARNING: CPU: 6 PID: 3458 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1660.763241] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1660.834919] CPU: 6 PID: 3458 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1660.844028] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1660.849669] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1660.856613] pc : __vunmap+0x78/0x30c
[ 1660.860175] lr : __vunmap+0x78/0x30c
[ 1660.863736] sp : ffff80000baebad0
[ 1660.867036] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1660.874155] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1660.881273] x23: 000000093a840000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1660.888392] x20: 0000000000000000 x19: ffff80000ce 0000000000000000 ]---
[ 1661.008750] ------------[ cut here ]------------
[ 1661.013360] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1661.019705] WARNING: CPU: 6 PID: 3458 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1661.026910] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1661.098587] CPU: 6 PID: 3458 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1661.107696] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1661.113337] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1661.120278] pc : __vunmap+0x78/0x30c
[ 1661.123840] lr : __vunmap+0x78/0x30c
[ 1661.127402] sp : ffff80000baebad0
[ 1661.130702] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1661.137819] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1661.144938] x23: 000000093a880000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1661.152056] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1661.159173] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1661.166291] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000010d7
[ 1661.173409] x11: 000000000000059d x10: ffff8000092e1c08 x9 : ffff800009281550
[ 1661.180527] x8 : 000000010000259d x7 : ffff8000092d9550 x6 : 00000000000086b8
[ 1661.187645] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1661.194763] x2 : 0000000000000000 x1 : 000000000000000c rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1661.362266] CPU: 5 PID: 3458 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1661.371376] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1661.377018] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1661.383960] pc : __vunmap+0x78/0x30c
[ 1661.387523] lr : __vunmap+0x78/0x30c
[ 1661.391084] sp : ffff80000baebad0
[ 1661.394384] x29: ffff80000baebad0 x28: 0000000000000204 x27: 0000000000000000
[ 1661.401503] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1661.408621] x23: 000000093a760000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1661.415738] x20: 0000000000000000 x19: ffff80000c0e1000 x18: ffffffffffffffff
[ 1661.422855] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008baeb7b7
[ 1661.429973] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001149
[ 1661.437090] x11: 00000000000005c3 x10: ffff8000092e1f98 x9 : ffff800009281550
[ 1661.444207] x8 : 00000001000025c3 x7 : ffff8000092d9550 x6 : 0000000000008a48
[ 1661.451324] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1661.458441] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aae15580
[ 1661.465558] Call trace:
[ 1661.467991] __vunmap+0x78/0x30c
[ 1661.471205] vunmap+0x40/0x5c
[ 1661.474161] dma_direct_free+0x10c/0x110
[ 1661.478070] dma_free_attrs+0x98/0xe0
[ 1661.481719] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1661.487024] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1661.49
[ 1661.601842] ------------[ cut here ]------------
[ 1661.606473] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1661.612835] WARNING: CPU: 6 PID: 3461 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1661.620049] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1661.691751] CPU: 6 PID: 3461 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1661.700862] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1661.706503] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1661.713447] pc : __vunmap+0x78/0x30c
[ 1661.717010] lr : __vunmap+0x78/0x30c
[ 1661.720571] sp : ffff80000c39bad0
[ 1661.723871] x29: ffff80000c39bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1661.730991] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1661.738110] x23: 000000093a980000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1661.745227] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1661.752345] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c39b7b7
[ 1661.759463] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000011bb
[ 1661.766581] x11: 00000000000005e9 x10: ffff8000092e2328 x9 : ffff800009281550
[ 1661.773699] x8 : 00000001000025e9 x7 : ffff8000092d9550 x6 : 0000000000008dd8
[ 1661.780816] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1661.787933] x2 : 0000000000000000 x1 : 00 x0 : ffff0008aa582ac0
[ 1661.795050] Call trace:
[ 1661.797490] __vunmap+0x78/0x30c
[ 1661.800705] vunmap+0x40/0x5c
[ 1661.803661] dma_direct_free+0x10c/0x110
[ 1661.807572] dma_free_attrs+0x98/0xe0
[ 1661.811222] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1661.816533] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1661.821488] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1661.826790] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1661.831744] v4l2_release+0xbc/0xf0 [videodev]
[ 1661.836199] __fput+0x70/0x250
[ 1661.839248] ____fput+0x10/0x20
[ 1661.842377] task_work_run+0x80/0xe0
[ 1661.845941] do_notify_resume+0x208/0x1280
[ 1661.850026] el0_svc+0x74/0x84
[ 1661.853070] el0t_64_sync_handler+0xbc/0x140
[ 1661.857325] el0t_64_sync+0x18c/0x190
[ 1661.860973] ---[ end trace 0000000000000000 ]---
[ 1661.865600] ------------[ cut here ]------------
[ 1661.870256] Trying to vfree() nonexistent vm area (000000003fd1b520)
[ 1661.876722] WARNING: CPU: 6 PID: 3461 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1661.883928] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1661.955607] CPU: 6 PID: 3461 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1661.964717] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1661.970357] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1661.977298] pc : __vunmap+0x78/0x30c
[ 1661.980860] lr : __vunmap+0x78/0x30c
[ 1661.984422] sp : ffff800000
[ 1662.044664] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d8ac8
[ 1662.051781] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa582ac0
[ 1662.058901] Call trace:
[ 1662.061335] __vunmap+0x78/0x30c
[ 1662.064549] vunmap+0x40/0x5c
[ 1662.067505] dma_direct_free+0x10c/0x110
[ 1662.071413] dma_free_attrs+0x98/0xe0
[ 1662.075062] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1662.080367] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1662.085322] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1662.090624] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1662.095579] v4l2_release+0xbc/0xf0 [videodev]
[ 1662.100033] __fput+0x70/0x250
[ 1662.103076] ____fput+0x10/0x20
[ 1662.106206] task_work_run+0x80/0xe0
[ 1662.109767] do_notify_resume+0x208/0x1280
[ 1662.113852] el0_svc+0x74/0x84
[ 1662.116893] el0t_64_sync_handler+0xbc/0x140
[ 1662.121148] el0t_64_sync+0x18c/0x190
[ 1662.124795] ---[ end trace 0000000000000000 ]---
[ 1662.129421] ------------[ cut here ]------------
[ 1662.134030] Trying to vfree() nonexistent vm area (0000000095989a9f)
[ 1662.140378] WARNING: CPU: 6 PID: 3461 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1662.147583] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1662.219261] CPU: 6 PID: 3461 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1662.228370] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1662.234011] pstate: 60000005 (nZCv daif 662.335066] dma_free_attrs+0x98/0xe0
[ 1662.338713] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1662.344016] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1662.348971] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1662.354272] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1662.359227] v4l2_release+0xbc/0xf0 [videodev]
[ 1662.363678] __fput+0x70/0x250
[ 1662.366720] ____fput+0x10/0x20
[ 1662.369850] task_work_run+0x80/0xe0
[ 1662.373412] do_notify_resume+0x208/0x1280
[ 1662.377495] el0_svc+0x74/0x84
[ 1662.380537] el0t_64_sync_handler+0xbc/0x140
[ 1662.384793] el0t_64_sync+0x18c/0x190
[ 1662.388441] ---[ end trace 0000000000000000 ]---
[ 1662.393065] ------------[ cut here ]------------
[ 1662.397679] Trying to vfree() nonexistent vm area (0000000008b3bc44)
[ 1662.404078] WARNING: CPU: 6 PID: 3461 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1662.411285] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1662.482964] CPU: 6 PID: 3461 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1662.492073] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1662.497713] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1662.504655] pc : __vunmap+0x78/0x30c
[ 1662.508217] lr : __vunmap+0x78/0x30c
[ 1662.511779] sp : ffff80000c39bad0
[ 1662.515078] x29: ffff80000c39bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1662.522196] x26: 0000000000000000 x25: 0000000000000000 x24: 00000000000000000000000 x10: 00000000000009b0 x9 : ffff80000c39b980
[ 1662.564901] x8 : ffff0008aa5834d0 x7 : ffff000f5c3e2340 x6 : 0000000000000000
[ 1662.572020] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a33d8ac8
[ 1662.579140] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa582ac0
[ 1662.586258] Call trace:
[ 1662.588691] __vunmap+0x78/0x30c
[ 1662.591905] vunmap+0x40/0x5c
[ 1662.594860] dma_direct_free+0x10c/0x110
[ 1662.598769] dma_free_attrs+0x98/0xe0
[ 1662.602418] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1662.607721] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1662.612588] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1662.617890] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1662.622844] v4l2_release+0xbc/0xf0 [videodev]
[ 1662.627298] __fput+0x70/0x250
[ 1662.630341] ____fput+0x10/0x20
[ 1662.633470] task_work_run+0x80/0xe0
[ 1662.637033] do_notify_resume+0x208/0x1280
[ 1662.641116] el0_svc+0x74/0x84
[ 1662.644158] el0t_64_sync_handler+0xbc/0x140
[ 1662.648414] el0t_64_sync+0x18c/0x190
[ 1662.652062] ---[ end trace 0000000000000000 ]---
[ 1662.716434] cma_alloc: 15 callbacks suppressed
[ 1662.716444] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1662.730963] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1662.741977] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1662.751540] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 65 pages, ret: -16
[ 1662.760764] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 2693 pages, ret: -16
[ 1662.771072] ------------[ cut here ]------------
[ 1662.775691] Trying to vfree() nonexistent vm area (00000000953119ba)
[ 1662.782098] WARNING: CPU: 5 PID: 3464 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1662.789314] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1662.861017] CPU: 5 PID: 3464 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1662.870127] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1662.875768] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1662.882712] pc : __vunmap+0x78/0x30c
[ 1662.886274] lr : __vunmap+0x78/0x30c
[ 1662.889836] sp : ffff80000ba8bad0
[ 1662.893136] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1662.900263] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1662.907381] x23: 000000093aa80000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1662.914500] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1662.921617] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1662.928735] x14: 00000000000003ae x13: 0000000000000000 x12: 0000000000000000
[ 1662.935852] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff80000ba8b980
[ 1662.942969] x8 : ffff0008aa581850 x7 : ffff000f5c3cf340 x6 : 0000000000000000
[ 1662.950086] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : ffff0008a41c8748
[ 1662.957203] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa580e40
[ 1662.964320] Call trace:
[ 1662.966754] __vunmap+0x78/0x30c
[ 1662.969969] vunmap+0x40/0x5c
[ 1662.972925] dma_direct_free+0x10c/0x110
[ 1662.976836] dma_free_attrs+0x98/0xe0
[ 1662.980484] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1662.985796] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1662.990751] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1662.996052] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1663.001007] v4l2_release+0xbc/0xf0 [videodev]
[ 1663.005463] __fput+0x70/0x250
[ 1663.008507] ____fput+0x10/0x20
[ 1663.124759] CPU: 5 PID: 3464 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1663.133872] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1663.139513] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1663.146455] pc : __vunmap+0x78/0x30c
[ 1663.150017] lr : __vunmap+0x78/0x30c
[ 1663.153579] sp : ffff80000ba8bad0
[ 1663.156879] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1663.163996] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1663.171113] x23: 000000093a9c0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1663.178230] x20: 0000000000000000 x19: ffff80000c3ad000 x18: ffffffffffffffff
[ 1663.185347] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1663.192464] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001407
[ 1663.199581] x11: 00000000000006ad x10: ffff8000092e3588 x9 : ffff800009281550
[ 1663.206698] x8 : 00000001000026ad x7 : ffff8000092d9550 x6 : 000000000000a038
[ 1663.213815] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1663.220932] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa580e40
[ 1663.228049] Call trace:
[ 1663.230481] __vunmap+0x78/0x30c
[ 1663.233696] vunmap+0x40/0x5c
[ 1663.236651] dma_direct_free+0x10c/0x110
[ 1663.240560] dma_free_attrs+0x98/0xe0
[ 1663.244208] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1663.249512] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1663.254466] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1663.259767] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1663.264721] v4l2_release+0xbc/0xf0 [videodev]
[ 1663.269174] __fput+0x70/0x250
[ 1663.272216] ____fput+0x10/0x20
[ 1663.275346] task_work_run+0x80/0xe0
[ 1663.278908] do_notify_resume+0x208/0x1280
[ 1663.282992] el0_svc+0x74/0x84
[ 1663.286033] el0t_64_sync_handler+0xbc/0x140
[ 1663.290287] el0t_64_sync+0x18c/0x190
[ 1663.293936] ---[ end trace 0000000000000000 ]---
[ 1663.298584] ------------[ cut here ]------------
[ 1663.303207] Trying to vfree() nonexistent vm areaO 6.1.33-g8f7f371be2 #1
[ 1663.397544] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1663.403185] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1663.410128] pc : __vunmap+0x78/0x30c
[ 1663.413690] lr : __vunmap+0x78/0x30c
[ 1663.417252] sp : ffff80000ba8bad0
[ 1663.420552] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1663.427670] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1663.434788] x23: 000000093aa00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1663.441906] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1663.449023] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1663.456140] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001479
[ 1663.463257] x11: 00000000000006d3 x10: ffff8000092e3918 x9 : ffff800009281550
[ 1663.470375] x8 : 00000001000026d3 x7 : ffff8000092d9550 x6 : 000000000000a3c8
[ 1663.477491] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1663.484609] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa580e40
[ 1663.491726] Call trace:
[ 1663.494158] __vunmap+0x78/0x30c
[ 1663.497372] vunmap+0x40/0x5c
[ 1663.500328] dma_direct_free+0x10c/0x110
[ 1663.504237] dma_free_attrs+0x98/0xe0
[ 1663.507885] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1663.513187] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1663.518142] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1663.523443] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1663.528398] v4l2_release+0xbc/0xf0 [videodev]
[ 1663.532849] __fput+0x70/0x250
[ 1663.535892] ____fput+0x10/0x20
[ 1663.539022] task_work_run+0x80/0xe0
[ 1663.542585] do_notify_resume+0x208/0x1280
[ 1663.546668] el0_svc+0x74/0x84
[ 1663.549709] el0t_64_sync_handler+0xbc/0x140
[ 1663.553964] el0t_64_sync+0x18c/0x190
[ 1663.557611] ---[ end trace 0000000000000000 ]---
[ 1663.562233] ------------[ cut here ]------------
[ 1663.566842] Trying to vfree() nonexistent vm area (0000000008b3bc44)
[ 1663.573189] WARNING: CPU: 5 PID: 3464 at mm/vmalloc.c:2693 __vunmap+0x78/0x30c
[ 1663.580394] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc.684192] x29: ffff80000ba8bad0 x28: 0000000000000204 x27: 0000000000000000
[ 1663.691310] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1663.698429] x23: 000000093a8e0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1663.705547] x20: 0000000000000000 x19: ffff80000c0e1000 x18: ffffffffffffffff
[ 1663.712664] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008ba8b7b7
[ 1663.719780] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000014eb
[ 1663.726897] x11: 00000000000006f9 x10: ffff8000092e3ca8 x9 : ffff800009281550
[ 1663.734014] x8 : 00000001000026f9 x7 : ffff8000092d9550 x6 : 000000000000a758
[ 1663.741131] x5 : ffff000f5c3c8b60 x4 : ffff000f5c3c8b60 x3 : ffff000f5c3cbda0
[ 1663.748248] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa580e40
[ 1663.755365] Call trace:
[ 1663.757797] __vunmap+0x78/0x30c
[ 1663.761012] vunmap+0x40/0x5c
[ 1663.763967] dma_direct_free+0x10c/0x110
[ 1663.767876] dma_free_attrs+0x98/0xe0
[ 1663.771524] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1663.776826] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1663.781693] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1663.786994] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1663.791948] v4l2_release+0xbc/0xf0 [videodev]
[ 1663.796399] __fput+0x70/0x250
[ 1663.799442] ____fput+0x10/0x20
[ 1663.802571] task_work_run+0x80/0xe0
[ 1663.806134] do_notify_resume+0x208/0x1280
[ 1663.810218] el0_svc+0x74/0x84
[ 1663.813259] el0t_64_sync_handler+0xbc/0x140
[ 1663.817513] el0t_64_sync+0x18c/0x190
[ 1663.821161] ---[ end trace 0000000000000000 ]---
[ 1663.893529] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 33 pages, ret: -16
[ 1663.903620] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 35 pages, ret: -16
[ 1663.912662] BUG: Bad page state: 77 messages suppressed
[ 1663.917879] BUG: Bad page state in process videotestsrc0:s pfn:93a9c0
[ 1663.924397] page:0000000069a9eafd refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x93a9c0
[ 1663.933865] flags: 0x8000000000000000(zone=2)
[ 1663.938219] raw: 8000000000000000 dead000000000100 dead000000000122 0000000000000000
[ 1663.945951] rama_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1664.030181] CPU: 7 PID: 3468 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1664.039379] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1664.045021] Call trace:
[ 1664.047455] dump_backtrace.part.0+0xdc/0xf0
[ 1664.051723] show_stack+0x18/0x30
[ 1664.055026] dump_stack_lvl+0x68/0x84
[ 1664.058680] dump_stack+0x18/0x34
[ 1664.061983] bad_page+0xe8/0x110
[ 1664.065199] check_new_pages+0xe0/0x110
[ 1664.069021] get_page_from_freelist+0x574/0xf10
[ 1664.073538] __alloc_pages+0x134/0xcec
[ 1664.077275] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1664.083006] dma_direct_alloc+0xd8/0x304
[ 1664.086914] dma_alloc_attrs+0x7c/0xe4
[ 1664.090650] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1664.096306] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1664.102562] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1664.108903] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1664.114377] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1664.120029] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1664.124899] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1664.130551] v4l_reqbufs+0x50/0x64 [videodev]
[ 1664.134919] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1664.139889] video_usercopy+0x214/0x6c4 [videodev]
[ 1664.144688] video_ioctl2+0x18/0x2c [videodev]
[ 1664.149138] v4l2_ioctl+0x40/0x60 [videodev]
[ 1664.153414] __arm64_sys_ioctl+0xa8/0xf0
[ 1664.157325] invoke_syscall+0x48/0x114
[ 1664.161064] el0_svc_common.constprop.0+0xd4/0xfc
[ 1664.165753] do_el0_svc+0x30/0xd0
[ 1664.169056] el0_svc+0x2c/0x84
[ 1664.172098] elr5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1664.292306] CPU: 7 PID: 3468 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1664.301505] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1664.307145] Call trace:
[ 1664.309579] dump_backtrace.part.0+0xdc/0xf0
[ 1664.313837] show_stack+0x18/0x30
[ 1664.317140] dump_stack_lvl+0x68/0x84
[ 1664.320791] dump_stack+0x18/0x34
[ 1664.324093] bad_page+0xe8/0x110
[ 1664.327310] check_new_pages+0xe0/0x110
[ 1664.331132] get_page_from_freelist+0x574/0xf10
[ 1664.335647] __alloc_pages+0x134/0xcec
[ 1664.339382] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1664.345113] dma_direct_alloc+0xd8/0x304
[ 1664.349021] dma_alloc_attrs+0x7c/0xe4
[ 1664.352756] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1664.358405] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1664.364660] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1664.371000] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1664.376475] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1664.382125] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1664.386994] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1664.392644] v4l_reqbufs+0x50/0x64 [videodev]
[ 1664.397012] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1664.401980] video_usercopy+0x214/0x6c4 [videodev]
[ 1664.406776] video_ioctl2+0x18/0x2c [videodev]
[ 1664.411225] v4l2_ioctl+0x40/0x60 [videodev]
[ 1664.415502] __arm64_sys_ioctl+0xa8/0xf0
[ 1664.419410] invoke_syscall+0x48/0x114
[ 1664.423146] el0_svc_common.constprop.0+0xd4/0xfc
[ 1664.427836] do_el0_svc+0x30/0xd0
[ 1664.431138] el0_svc+0x2c/0x84
[ 1664.434179] el0t_64_sync_handler+0xbc/0x140
[ 1664.438433] el0t_64_sync+0x18c/0x190
[ 1664.444712] cma: cma_alloc: linux-cma-buffers@980000000: alloc failed, req-size: 18 pages, ret: -16
[ 1664.454276] cma: cma_alloc: linux-cma-async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1664.575590] CPU: 7 PID: 3468 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1664.584788] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1664.590429] Call trace:
[ 1664.592861] dump_backtrace.part.0+0xdc/0xf0
[ 1664.597120] show_stack+0x18/0x30
[ 1664.600423] dump_stack_lvl+0x68/0x84
[ 1664.604075] dump_stack+0x18/0x34
[ 1664.607379] bad_page+0xe8/0x110
[ 1664.610595] check_new_pages+0xe0/0x110
[ 1664.614417] get_page_from_freelist+0x574/0xf10
[ 1664.618934] __alloc_pages+0x134/0xcec
[ 1664.622670] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1664.628400] dma_direct_alloc+0xd8/0x304
[ 1664.632308] dma_alloc_attrs+0x7c/0xe4
[ 1664.636044] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1664.641693] wave5_vpu_enc_register_framebuffer+0x274/0x6f0 [wave5]
[ 1664.647948] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1664.654288] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1664.659762] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1664.665412] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1664.670281] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1664.675930] v4l_reqbufs+0x50/0x64 [videodev]
[ 1664.680298] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1664.685268] video_usercopy+0x214/0x6c4 [videodev]
[ 1664.690064] video_ioctl2+0x18/0x2c [videodev]
[ 1664.694515] v4l2_ioctl+0x40/0x60 [videodev]
[ 1664.698790] __arm64_sys_ioctl+0xa8/0xf0
[ 1664.702698] invoke_syscall+0x48/0x114
[ 1664.706436] el0_svc_common.constprop.0+0xd4/0xfc
[ 1664.711124] do_el0_svc+0x30/0xd0
[ 1664.714427] el0_svc+0x2c/0x84
[ 1664.717469] el0t_64_sync_handler+0xbc/0x140
[ 1664.721724] el0t_64_sync+0x18c/0x190
[ 1664.725606] cma: cma_alloc: linux-cma-buffers@ms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1664.825850] CPU: 6 PID: 3467 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1664.834961] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1664.840602] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1664.847546] pc : __vunmap+0x78/0x30c
[ 1664.851108] lr : __vunmap+0x78/0x30c
[ 1664.854670] sp : ffff80000c0cbad0
[ 1664.857970] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1664.865088] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1664.872207] x23: 000000093ab00000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1664.879325] x20: 0000000000000000 x19: ffff80000c715000 x18: ffffffffffffffff
[ 1664.886443] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1664.893561] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000016d7
[ 1664.900679] x11: 000000000000079d x10: ffff8000092e4c08 x9 : ffff800009281550
[ 1664.907797] x8 : 000000010000279d x7 : ffff8000092d9550 x6 : 000000000000b6b8
[ 1664.914915] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1664.922033] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa582ac0
[ 1664.929151] Call trace:
[ 1664.931586] __vunmap+0x78/0x30c
[ 1664.934801] vunmap+0x40/0x5c
[ 1664.937757] dma_direct_free+0x10c/0x110
[ 1664.941667] dma_free_attrs+0x98/0xe0
[ 1664.945315] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1664.950622] wave5_vpu_enc_close+0x124/0x18c [wave5]
[ 1664.955576] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1664.960877] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1664.965831] v4l2_release+0xbc/0xf0 [videodev]
[ 1664.970285] __fput+0x70/0x250
[ 1664.973330] ____fput+0x10/0x20
[ 1664.976459] task_work_run+0x80/0xe0
[ 1664.980022] do_notify_resume+0x208/0x1280
[ 1664.984107] el0_svc+0x74/0x84
[ 16dns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1665.089525] CPU: 6 PID: 3467 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1665.098634] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1665.104275] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1665.111218] pc : __vunmap+0x78/0x30c
[ 1665.114780] lr : __vunmap+0x78/0x30c
[ 1665.118341] sp : ffff80000c0cbad0
[ 1665.121641] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1665.128760] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1665.135878] x23: 000000093aac0000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1665.142996] x20: 0000000000000000 x19: ffff80000c3ad000 x18: ffffffffffffffff
[ 1665.150114] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1665.157232] x14: 0000000000000000 x13: ffff800009281550 x12: 0000000000001749
[ 1665.164350] x11: 00000000000007c3 x10: ffff8000092e4f98 x9 : ffff800009281550
[ 1665.171468] x8 : 00000001000027c3 x7 : ffff8000092d9550 x6 : 000000000000ba48
[ 1665.178586] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1665.185704] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa582ac0
[ 1665.192821] Call trace:
[ 1665.195254] __vunmap+0x78/0x30c
[ 1665.198468] vunmap+0x40/0x5c
[ 1665.201424] dma_direct_free+0x10c/0x110
[ 1665.205332] dma_free_attrs+0x98/0xe0
[ 1665.208980] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1665.214283] wave5_vpu_enc_close+0x114/0x18c [wave5]
[ 1665.219237] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1665.224538] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1665.229492] v4l2_release+0xbc/0xf0 [videodev]
[ 1665.233946] __fput+0x70/0x250
[ 1665.236988] ____fput+0x10/0x20
[ 1665.240118] task_work_run+0x80/0xe0
[ 1665.243680] do_notify_resume+0x208/0x1280
[ 1665.247764] el0_svc+0x74/0x84
[ 1665.250804] el0t_64_sync_handler+0xbc/0x140
[ 1665.255059] el0t_64_sync+0x18c/0x190
[ 1665.258706] ---[ end trace 0000000000000000 ]---
[ 1665.263328] ------------[ cut here ]--------ore cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1665.353174] CPU: 6 PID: 3467 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1665.362285] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1665.367925] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1665.374867] pc : __vunmap+0x78/0x30c
[ 1665.378429] lr : __vunmap+0x78/0x30c
[ 1665.381990] sp : ffff80000c0cbad0
[ 1665.385290] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1665.392409] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1665.399526] x23: 000000093aa40000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1665.406645] x20: 0000000000000000 x19: ffff80000c3d5000 x18: ffffffffffffffff
[ 1665.413763] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1665.420881] x14: 0000000000000000 x13: ffff800009281550 x12: 00000000000017bb
[ 1665.427999] x11: 00000000000007e9 x10: ffff8000092e5328 x9 : ffff800009281550
[ 1665.435118] x8 : 00000001000027e9 x7 : ffff8000092d9550 x6 : 000000000000bdd8
[ 1665.442236] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1665.449354] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa582ac0
[ 1665.456472] Call trace:
[ 1665.458905] __vunmap+0x78/0x30c
[ 1665.462119] vunmap+0x40/0x5c
[ 1665.465074] dma_direct_free+0x10c/0x110
[ 1665.468984] dma_free_attrs+0x98/0xe0
[ 1665.472632] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1665.477935] wave5_vpu_enc_close+0x104/0x18c [wave5]
[ 1665.482889] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1665.488190] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1665.493144] v4l2_release+0xbc/0xf0 [videodev]
[ 1665.497595] __fput+0x70/0x250
[ 1665.500638] ____fput+0x10/0x20
[ 1665.503768] task_work_run+0x80/0xe0
[ 1665.507329] do_notify_resume+0x208/0x1280
[ 1665.511413] el0_svc+0x74/0x84
[ 1665.514455] el0t_64_sync_handler+0xbc/0x140
[ 1665.518709] el0t_64_sync+0x18c/0x190
[ 1665.522356] ---[ end trace 0000000000000000 ]---
[ 1665.526978] ------------[ cut here ]------------
[ 1665.531583] Trying to vfree() nonexistent vm area (0000000008b3bc44)
[ 1665.537928] WARNING: CPU: 6 PID: 3467 core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1665.616810] CPU: 6 PID: 3467 Comm: gst-launch-1.0 Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1665.625919] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1665.631560] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1665.638502] pc : __vunmap+0x78/0x30c
[ 1665.642063] lr : __vunmap+0x78/0x30c
[ 1665.645625] sp : ffff80000c0cbad0
[ 1665.648925] x29: ffff80000c0cbad0 x28: 0000000000000204 x27: 0000000000000000
[ 1665.656042] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1665.663160] x23: 000000093aa20000 x22: ffff8000093d6a28 x21: 0000000000000000
[ 1665.670279] x20: 0000000000000000 x19: ffff80000c0e1000 x18: ffffffffffffffff
[ 1665.677397] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80008c0cb7b7
[ 1665.684515] x14: 0000000000000000 x13: ffff800009281550 x12: 000000000000182d
[ 1665.691634] x11: 000000000000080f x10: ffff8000092e56b8 x9 : ffff800009281550
[ 1665.698752] x8 : 000000010000280f x7 : ffff8000092d9550 x6 : 000000000000c168
[ 1665.705869] x5 : ffff000f5c3dbb60 x4 : ffff000f5c3dbb60 x3 : ffff000f5c3deda0
[ 1665.712987] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008aa582ac0
[ 1665.720105] Call trace:
[ 1665.722538] __vunmap+0x78/0x30c
[ 1665.725752] vunmap+0x40/0x5c
[ 1665.728707] dma_direct_free+0x10c/0x110
[ 1665.732616] dma_free_attrs+0x98/0xe0
[ 1665.736264] wave5_vdi_free_dma_memory+0x34/0x64 [wave5]
[ 1665.741566] wave5_vpu_enc_close+0xf4/0x18c [wave5]
[ 1665.746434] wave5_vpu_release_device+0x64/0x18c [wave5]
[ 1665.751735] wave5_vpu_enc_release+0x20/0x2c [wave5]
[ 1665.756689] v4l2_release+0xbc/0xf0 [videodev]
[ 1665.761142] __fput+0x70/0x250
[ 1665.764185] ____fput+0x10/0x20
[ 1665.767315] task_work_run+0x80/0xe0
[ 1665.770876] do_notify_resume+0x208/0x1280
[ 1665.774960] el0_svc+0x74/0x84
[ 1665.778002] el0t_64_sync_handler+0xbc/0x140
[ 1665.782256] el0t_64_sync+0x18c/0x190
[ 1665.785904] ---[ end trace 0000000000000000 ]---
[ 1665.852331] BUG: Bad page state in process videotestsrc0:s pfn:93aac0
[ 1665.858861] page:0000000027f37959 refcount:-1 mapcount:0 mapping:0000000000000000 00000000000000
[ 1665.888149] page dumped because: nonzero _refcount
[ 1665.892931] Modules linked in: overlay cfg80211 pci_endpoint_test bluetooth ecdh_generic ecc rfkill cdns_csi2rx panel_edp v4l2_fwnode rpmsg_ctrl rpmsg_char cdns3 ti_am335x_adc kfifo_buf omap_rng cdns_usb_common wave5 j721e_csi2rx videobuf2_dma_contig v4l2_mem2mem videobuf2_memops crct10dif_ce ti_sn65dsi86 videobuf2_v4l2 cdns_mhdp8546 drm_dp_aux_bus tidss v4l2_async drm_display_helper videobuf2_common display_connector drm_dma_helper videodev drm_kms_helper ti_k3_r5_remoteproc cfbfillrect ti_k3_dsp_remoteproc mc pvrsrvkm(O) syscopyarea virtio_rpmsg_bus cfbimgblt sysfillrect sa2ul ti_am335x_tscadc sysimgblt rpmsg_ns cdns_dphy ti_k3_common cdns_dphy_rx fb_sys_fops cfbcopyarea pci_j721e_host pci_j721e pcie_cadence_host pcie_cadence optee_rng cdns3_ti rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 1665.964656] CPU: 7 PID: 3471 Comm: videotestsrc0:s Tainted: G B W O 6.1.33-g8f7f371be2 #1
[ 1665.973855] Hardware name: Texas Instruments J784S4 EVM (DT)
[ 1665.979496] Call trace:
[ 1665.981931] dump_backtrace.part.0+0xdc/0xf0
[ 1665.986199] show_stack+0x18/0x30
[ 1665.989503] dump_stack_lvl+0x68/0x84
[ 1665.993156] dump_stack+0x18/0x34
[ 1665.996459] bad_page+0xe8/0x110
[ 1665.999677] check_new_pages+0xe0/0x110
[ 1666.003499] get_page_from_freelist+0x574/0xf10
[ 1666.008015] __alloc_pages+0x134/0xcec
[ 1666.011751] __dma_direct_alloc_pages.constprop.0+0x164/0x1c4
[ 1666.017483] dma_direct_alloc+0xd8/0x304
[ 1666.021391] dma_alloc_attrs+0x7c/0xe4
[ 1666.025126] wave5_vdi_allocate_dma_memory+0x40/0xb0 [wave5]
[ 1666.030783] wave5_vpu_enc_register_framebuffer+0x1a4/0x6f0 [wave5]
[ 1666.037038] wave5_vpu_enc_register_frame_buffer+0x110/0x170 [wave5]
[ 1666.043379] wave5_vpu_enc_queue_setup+0x3dc/0x42c [wave5]
[ 1666.048853] vb2_core_reqbufs+0x138/0x460 [videobuf2_common]
[ 1666.054506] vb2_reqbufs+0x80/0xa0 [videobuf2_v4l2]
[ 1666.059376] v4l2_m2m_ioctl_reqbufs+0x4c/0x84 [v4l2_mem2mem]
[ 1666.065028] v4l_reqbufs+0x50/0x64 [videodev]
[ 1666.069395] __video_do_ioctl+0x184/0x3d0 [videodev]
[ 1666.074364] video_usercopy+0x214/0x6c4 [videodev]
[ 1666.079161]
