AM3352: Develop U-boot using SDK-08.02.00.24
Part Number: AM3352
Hi Team,
AM3352 is currently being developed using SDK8.02.
1) U-boot is slow to write and read nand, writing is about 360KB/S and reading is about 960KB/S. Config_NAND_OMAP_GPMC_prefetch and config_CMD_cache are turned on but the speed does not increase much. The speed is fast in kernel and the start log is as follows:
CCC
U-Boot SPL 2021.01-00001-gc59bf25a38-dirty (Nov 29 2023 - 13:54:05 +0800)
Trying to boot from NAND
nand: using OMAP_ECC_BCH16_CODE_HW
use GPMC prefetch read.
Loading element from 0x00080000 (size 0x00000040) to 0x80800000
(持续打印:uncorrectable ECC errors)
U-Boot 2021.01-00001-gc59bf25a38-dirty (Nov 29 2023 - 13:54:05 +0800)
CPU : AM335X-GP rev 2.1
Model: TI AM335x EVM
DRAM: 512 MiB
Setting QCA7000 and wifi&ble power
WDT: Started with servicing (60s timeout)
NAND: nand: using OMAP_ECC_BCH16_CODE_HW
nand_base: device found, Manufacturer ID: 0x2c, Chip ID: 0x48
nand_base: Micron MT29F16G08ABACAWP
nand_base: 2048 MiB, SLC, erase size: 512 KiB, page size: 4096, OOB size: 224
2048 MiB
2) Using TFTP download under U-boot is slow, approximately 1MB/S. The network download speed is fast after entering the kernel.
link up on port 0, speed 100, full duplex
Using ethernet@4a100000 device
TFTP from server 192.168.0.8; our IP address is 192.168.0.10
Filename 'zImage.bin'.
Load address: 0x82000000
Loading: #################################################################
1 MiB/s
done
Bytes transferred = 5239296 (4ff200 hex)
3) Download rootfs to nand under u-boot, nand write fails if the file system is greater than 256M or if you write large files (not more than 450M) with the following error: “nand: error: invalid bit-flip location”
nand info:
=> nand info
Device 0: nand0, sector size 512 KiB
Page size 4096 b
OOB size 224 b
Erase size 524288 b
subpagesize 1024 b
options 0x4000400c
bbt options 0x00000000
nand config:
/* NAND: device related configs */
#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_PAGE_COUNT  (CONFIG_SYS_NAND_BLOCK_SIZE / \
                     CONFIG_SYS_NAND_PAGE_SIZE)
#define CONFIG_SYS_NAND_PAGE_SIZE   4096
#define CONFIG_SYS_NAND_OOBSIZE     224
#define CONFIG_SYS_NAND_BLOCK_SIZE  (512*1024)
/* NAND: driver related configs */
#define CONFIG_SYS_NAND_BAD_BLOCK_POS   NAND_LARGE_BADBLOCK_POS
#define CONFIG_SYS_NAND_ECCPOS      {   \
             2,   3,   4,   5,   6,   7,   8,   9, \
             10,  11,  12,  13,  14,  15,  16,  17,  18,  19, \
             20,  21,  22,  23,  24,  25,  26,  27,  28,  29, \
             30,  31,  32,  33,  34,  35,  36,  37,  38,  39, \
             40,  41,  42,  43,  44,  45,  46,  47,  48,  49, \
             50,  51,  52,  53,  54,  55,  56,  57,  58,  59, \
             60,  61,  62,  63,  64,  65,  66,  67,  68,  69, \
             70,  71,  72,  73,  74,  75,  76,  77,  78,  79, \
             80,  81,  82,  83,  84,  85,  86,  87,  88,  89, \
             90,  91,  92,  93,  94,  95,  96,  97,  98,  99, \
            100, 101, 102, 103, 104, 105, 106, 107, 108, 109, \
            110, 111, 112, 113, 114, 115, 116, 117, 118, 119, \
            120, 121, 122, 123, 124, 125, 126, 127, 128, 129, \
            130, 131, 132, 133, 134, 135, 136, 137, 138, 139, \
            140, 141, 142, 143, 144, 145, 146, 147, 148, 149, \
            150, 151, 152, 153, 154, 155, 156, 157, 158, 159, \
            160, 161, 162, 163, 164, 165, 166, 167, 168, 169, \
            170, 171, 172, 173, 174, 175, 176, 177, 178, 179, \
            180, 181, 182, 183, 184, 185, 186, 187, 188, 189, \
            190, 191, 192, 193, 194, 195, 196, 197, 198, 199, \
            200, 201, 202, 203, 204, 205, 206, 207, 208, 209, \
#define CONFIG_SYS_NAND_ECCSIZE     512
#define CONFIG_SYS_NAND_ECCBYTES    26
#define CONFIG_SYS_NAND_ONFI_DETECTION
#define CONFIG_NAND_OMAP_ECCSCHEME  OMAP_ECC_BCH16_CODE_HW
Could you help check this case? Thanks.
Cherry
  • Hi Cherry,
    I think the speed delta on GPMC-NAND RD/WR access between @u-boot vs @kernel is due to DMA is used @kernel, but not @u-boot.
    -Hong
  • Hi Hong,
    Thank you for the support.
    Thanks for the information, but on u-boot, it should not be that slow.  At the same time, SPL jumps to U-boot and always reports ECC errors which is not expected.
    The customer has referenced the link here to change NAND_GPMC_CONFIG from
    // #define M_NAND_GPMC_CONFIG1  0x00000800
    // #define M_NAND_GPMC_CONFIG2  0x001e1e00
    // #define M_NAND_GPMC_CONFIG3  0x001e1e00
    // #define M_NAND_GPMC_CONFIG4  0x16051807
    // #define M_NAND_GPMC_CONFIG5  0x00151e1e
    // #define M_NAND_GPMC_CONFIG6  0x16000f80
    // #define M_NAND_GPMC_CONFIG7  0x00000008
    #define M_NAND_GPMC_CONFIG1 ( GPMCFCLKDIVIDER(0) | 0 /* TIMEPARAGRANULARITY */ | 0 /* MUXADDDATA */ | \
                                  DEVICETYPE_NAND | DEVICESIZE_8BIT | WAITPINSELECT(0) | WAITMONITORINGTIME(0) | \
                                  0 /* WAITWRITEMONITORING */ | 0 /* WAITREADMONITORING */ | ATTACHEDDEVICEPAGELENGTH(0) | \
                                  CLKACTIVATIONTIME(0) | 0 /* WRITETYPE */ | 0 /* WRITEMULTIPLE */ | 0 /* READTYPE */ | \
                                  0 /* READMULTIPLE */ | 0 /* WRAPBURST */ )
    /* CONFIG2: Chip Select */
    #define M_NAND_GPMC_CONFIG2 (CSWROFFTIME(_CSWOFF) | CSRDOFFTIME(_CSROFF) | CSONTIME(0) | 0 /* CSEXTRADELAY */ )
    /* CONFIG3: ADV/ALE */
    #define M_NAND_GPMC_CONFIG3 ( ADVWROFFTIME(_ADWOFF) | ADVRDOFFTIME(_ADROFF) | 0 /* ADVEXTRADELAY */ | ADVONTIME(_ADON) )
    /* CONFIG4: WE/OE */
    #define M_NAND_GPMC_CONFIG4 ( WEOFFTIME(_WEOFF) | 0 /* WEEXTRADELAY */ | WEONTIME(_WEON) | \
        OEOFFTIME(_OEOFF) | 0 /* OEEXTRADELAY */ | OEONTIME(_OEON) )
    /* CONFIG5: Cycle Timing */
    #define M_NAND_GPMC_CONFIG5 ( PAGEBURSTACCESSTIME(0) | RDACCESSTIME(_RDACC) | WRCYCLETIME(_WRCY) | RDCYCLETIME(_RDCY) )
    /* CONFIG6: Rest of the Pack */
    #define M_NAND_GPMC_CONFIG6 ( WRACCESSTIME(_WRACC) | (((_WBURST) &  0xf) << 16) | CYCLE2CYCLEDELAY(_CSHIGH) | \
                                 (1 << 7) | 0 /* CYCLE2CYCLEDIFFCSEN */ | BUSTURNAROUND(_BTURN) )
    /* CONFIG7: Address Mapping */
    #define M_NAND_GPMC_CONFIG7 MASKADDRESS(0x00) | (1 << 6) | BASEADDRESS(0x0)
    NAND read and write speeds can be improved to:
    Read: 2.7MB/S; Write: 600KB/S;
    It does not seem to load GPMC related configuration parameters from the device tree.
    Thanks and regards,
    Cherry
  • Hi Cherry,
    In addition to DMA, NAND device AC parameter tune-up, and GPMC-NAND "Prefetch and Write-Posting Engine" are some options to optimize GPMC-NAND performance.
    -Hong
  • Hi Hong,
    Could you help look into the ECC error issue?
    Also, may I know is there an example of NAND using DMA under U-boot available?
    Thanks and regards,
    Cherry
  • Could you help look into the ECC error issue?
    Will you upload the full boot log as attachment?
    -Hong
  • Hi Hong,
    Please see the log here:
    CCCCCCCC
    U-Boot SPL 2021.01-00004-g221b7b9eda-dirty (Dec 07 2023 - 15:18:30 +0800)
    omap-elm: uncorrectable ECC errors
    U-Boot 2021.01-00004-g221b7b9eda-dirty (Dec 07 2023 - 15:18:30 +0800)
    DRAM: 512 MiB
    2048 MiB
    Loading Environment from NAND... Scanning device for bad blocks
    Bad eraseblock 90 at 0x000002d00000
    Bad eraseblock 91 at 0x000002d80000
    [854]NAND read process: offset: 0x00280000, size: 0x00080000
    [1043]Nand read size: 524288, use time:189ms, read speed: 2705kB/s
    *** Warning - bad CRC, using default environment
    <ethaddr> not set. Validating first E-fuse MAC
    Net: DEBUG: modename: ti,am3352-cpsw-phy-sel, mode: 6
    DEBUG: cpsw_gmii_sel_am3352, mode: 6
    DEBUG: cpsw_gmii_sel_am3352, extern clk
    eth2: ethernet@4a100000, eth3: usb_ether
    Hit any key to stop autoboot: 0
    nand Write exception log:
    NAND write: device 0 offset 0xd80000, size 0x14680000
    [4023370]NAND write process: offset: 0x00d80000, size: 0x14680000
    Skip bad block 0x02d00000
    Skip bad block 0x02d80000
    [4344265]NAND write to offset 0x12d80000 failed -5
    300417024 bytes written: ERROR
    Thanks and regards,
    Cherry
  • Hi Cherry,
    Thanks for sharing the boot log.
    Let me have a closer look at the log, and get back to you.
    -Hong
  • Hi Cherry,
    There was issue observed on NAND boot with SDK 8.2.
    Is it possible to upgrade to the latest SDK 9.1?
    www.ti.com/.../09.01.00.001
    The following two patchs needs to be applied on top of SDK 9.1
    1. mtd: nand: omap_gpmc: Fix NAND in SPL for AM335x
    git.ti.com/.../
    2. mtd: rawnand: omap_elm: Fix elm_init definition
    git.ti.com/.../
    -Hong
  • Hi Hong,
    The customer have tried the version of SDK9.1, but SPL cannot jump to u-boot, while using SPL of SDK8.2 can jump to u-boot of SDK9.1, and u-boot of SDK9.1 will also fail to write large files. A large file write will trigger a chip crash restart, and there are no improvements for NAND write speed.
    Thanks and regards,
    Cherry
  • Hi Cherry,
    As noted in my last reply.
    git.ti.com/.../
    git.ti.com/.../
    -Hong
  • Hello Hong,
    Thank you and as per your last reply the ECC error has been resolved, but we still face the NAND write issue.
    Please see the log below:
    => run uprootfs
    Filename 'am335xubiaa'.
    Loading: ################################################# 256 MiB
    1.5 MiB/s
    done
    Bytes transferred = 268435456 (10000000 hex)
    NAND erase.part: device 0 offset 0xd80000, size 0x7f280000
    Skipping bad block at 0x02d00000
    Skipping bad block at 0x02d80000
    Erasing at 0x7ff80000 -- 100% complete.
    OK
    NAND write: device 0 offset 0xd80000, size 0x10000000
    [642544]NAND write process: offset: 0x00d80000, size: 0x10000000
    [942579]NAND write to offset 0x10e80000 finish
    [942591]Nand write size: 0, use time:300046ms, write speed: 874kB/s
    268435456 bytes written: OK
    Filename 'am335xubiab'.
    Loading: ################################################## 70.5 MiB
    1.5 MiB/s
    done
    Bytes transferred = 73924608 (4680000 hex)
    NAND write: device 0 offset 0x10e80000, size 0x4680000
    [1080334]NAND write process: offset: 0x10e80000, size: 0x04680000
    data abort
    pc : [<9ff91094>] lr : [<9ff90a57>]
    reloc pc : [<8082f094>] lr : [<8082ea57>]
    sp : 9decd3a8 ip : 00000002 fp : 9def0500
    r10: 00000002 r9 : 9dee1ea0 r8 : 9dee79e8
    r7 : 9ffeb554 r6 : 9ffeaff0 r5 : 9dee8068 r4 : 9def0500
    r3 : 00000000 r2 : 9ffeb5d4 r1 : 9dee79f5 r0 : 07ff0002
    Flags: nZCv IRQs off FIQs on Mode SVC_32 (T)
    Code: f3bf 8f5f 4a0c 6813 (6218) 69db
    Resetting CPU ...
    CCCCCCCCg ...
    U-Boot SPL 2023.04-dirty (Dec 13 2023 - 17:41:11 +0800)
    GPMC use prefetch
    U-Boot 2023.04-dirty (Dec 13 2023 - 17:41:11 +0800)
    DRAM: 512 MiB
    Core: 152 devices, 16 uclasses, devicetree: separate
    Thanks and regards,
    Cherry
  • Hi Cherry,
    It is good to know u-boot booting from NAND works on the customer board.
    I'm attaching a reference NAND flashing log on AM335x GP EVM using SDK 9.1 + two latest patches as listed in my last reply.
    - where "nand write..." @u-boot works when flashing u-boot binaries to NAND.
    -Hong
    U-Boot SPL 2023.04-00001-ga6b09c3a4c-dirty (Dec 07 2023 - 14:29:54 -0600)
    Trying to boot from MMC1
    U-Boot 2023.04-00001-ga6b09c3a4c-dirty (Dec 07 2023 - 14:29:54 -0600)
    DRAM:  1 GiB
    Core:  156 devices, 17 uclasses, devicetree: separate
    WDT:   Started wdt@44e35000 with servicing every 1000ms (60s timeout)
    NAND:  256 MiB
    MMC:   OMAP SD/MMC: 0
    Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
    Net:   eth2: ethernet@4a100000, eth3: usb_ether
    Hit any key to stop autoboot:  2  0
    => mtdparts
    device nand0 <nand.0>, # parts = 10
     #: name		size		offset		mask_flags
     0: NAND.SPL            0x00020000	0x00000000	0
     1: NAND.SPL.backup1    0x00020000	0x00020000	0
     2: NAND.SPL.backup2    0x00020000	0x00040000	0
     3: NAND.SPL.backup3    0x00020000	0x00060000	0
     4: NAND.u-boot-spl-os  0x00040000	0x00080000	0
     5: NAND.u-boot         0x00100000	0x000c0000	0
     6: NAND.u-boot-env     0x00020000	0x001c0000	0
     7: NAND.u-boot-env.backup10x00020000	0x001e0000	0
     8: NAND.kernel         0x00800000	0x00200000	0
     9: NAND.file-system    0x0f600000	0x00a00000	0
    active partition: nand0,0 - (NAND.SPL) 0x00020000 @ 0x00000000
    defaults:
    mtdids  : nand0=nand.0
    mtdparts: mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)
    => nand info
    Device 0: nand0, sector size 128 KiB
      Page size         2048 b
      OOB size            64 b
      Erase size      131072 b
      ecc strength         8 bits
      ecc step size      512 b
      subpagesize        512 b
      options       0x0000400c
      bbt options   0x00008000
    => nand erase.chip
    NAND erase.chip: device 0 whole chip
    Erasing at 0x0 --   0% complete.
    Erasing at 0x280000 --   1% complete.
    Erasing at 0x500000 --   2% complete.
    Erasing at 0x7a0000 --   3% complete.
    Erasing at 0xa20000 --   4% complete.
    Erasing at 0xcc0000 --   5% complete.
    Erasing at 0xf40000 --   6% complete.
    Erasing at 0x11e0000 --   7% complete.
    Erasing at 0x1460000 --   8% complete.
    Erasing at 0x1700000 --   9% complete.
    Erasing at 0x1980000 --  10% complete.
    Erasing at 0x1c20000 --  11% complete.
    Erasing at 0x1ea0000 --  12% complete.
    Erasing at 0x2140000 --  13% complete.
    Erasing at 0x23c0000 --  14% complete.
    Erasing at 0x2660000 --  15% complete.
    Erasing at 0x28e0000 --  16% complete.
    Erasing at 0x2b80000 --  17% complete.
    Erasing at 0x2e00000 --  18% complete.
    Erasing at 0x30a0000 --  19% complete.
    Erasing at 0x3320000 --  20% complete.
    Erasing at 0x35c0000 --  21% complete.
    Erasing at 0x3840000 --  22% complete.
    Erasing at 0x3ae0000 --  23% complete.
    Erasing at 0x3d60000 --  24% complete.
    Erasing at 0x3fe0000 --  25% complete.
    Erasing at 0x4280000 --  26% complete.
    Erasing at 0x4500000 --  27% complete.
    Erasing at 0x47a0000 --  28% complete.
    Erasing at 0x4a20000 --  29% complete.
    Erasing at 0x4cc0000 --  30% complete.
    Erasing at 0x4f40000 --  31% complete.
    Erasing at 0x51e0000 --  32% complete.
    Erasing at 0x5460000 --  33% complete.
    Erasing at 0x5700000 --  34% complete.
    Erasing at 0x5980000 --  35% complete.
    Erasing at 0x5c20000 --  36% complete.
    Erasing at 0x5ea0000 --  37% complete.
    Erasing at 0x6140000 --  38% complete.
    Erasing at 0x63c0000 --  39% complete.
    Erasing at 0x6660000 --  40% complete.
    Erasing at 0x68e0000 --  41% complete.
    Erasing at 0x6b80000 --  42% complete.
    Erasing at 0x6e00000 --  43% complete.
    Erasing at 0x70a0000 --  44% complete.
    Erasing at 0x7320000 --  45% complete.
    Erasing at 0x75c0000 --  46% complete.
    Erasing at 0x7840000 --  47% complete.
    Erasing at 0x7ae0000 --  48% complete.
    Erasing at 0x7d60000 --  49% complete.
    Erasing at 0x7fe0000 --  50% complete.
    Erasing at 0x8280000 --  51% complete.
    Erasing at 0x8500000 --  52% complete.
    Erasing at 0x87a0000 --  53% complete.
    Erasing at 0x8a20000 --  54% complete.
    Erasing at 0x8cc0000 --  55% complete.
    Erasing at 0x8f40000 --  56% complete.
    Erasing at 0x91e0000 --  57% complete.
    Erasing at 0x9460000 --  58% complete.
    Erasing at 0x9700000 --  59% complete.
    Erasing at 0x9980000 --  60% complete.
    Erasing at 0x9c20000 --  61% complete.
    Erasing at 0x9ea0000 --  62% complete.
    Erasing at 0xa140000 --  63% complete.
    Erasing at 0xa3c0000 --  64% complete.
    Erasing at 0xa660000 --  65% complete.
    Erasing at 0xa8e0000 --  66% complete.
    Erasing at 0xab80000 --  67% complete.
    Erasing at 0xae00000 --  68% complete.
    Erasing at 0xb0a0000 --  69% complete.
    Erasing at 0xb320000 --  70% complete.
    Erasing at 0xb5c0000 --  71% complete.
    Erasing at 0xb840000 --  72% complete.
    Erasing at 0xbae0000 --  73% complete.
    Erasing at 0xbd60000 --  74% complete.
    Erasing at 0xbfe0000 --  75% complete.
    Erasing at 0xc280000 --  76% complete.
    Erasing at 0xc500000 --  77% complete.
    Erasing at 0xc7a0000 --  78% complete.
    Erasing at 0xca20000 --  79% complete.
    Erasing at 0xccc0000 --  80% complete.
    Erasing at 0xcf40000 --  81% complete.
    Erasing at 0xd1e0000 --  82% complete.
    Erasing at 0xd460000 --  83% complete.
    Erasing at 0xd700000 --  84% complete.
    Erasing at 0xd980000 --  85% complete.
    Erasing at 0xdc20000 --  86% complete.
    Erasing at 0xdea0000 --  87% complete.
    Erasing at 0xe140000 --  88% complete.
    Erasing at 0xe3c0000 --  89% complete.
    Erasing at 0xe660000 --  90% complete.
    Erasing at 0xe8e0000 --  91% complete.
    Erasing at 0xeb80000 --  92% complete.
    Erasing at 0xee00000 --  93% complete.
    Erasing at 0xf0a0000 --  94% complete.
    Erasing at 0xf320000 --  95% complete.
    Erasing at 0xf5c0000 --  96% complete.
    Erasing at 0xf840000 --  97% complete.
    Erasing at 0xfae0000 --  98% complete.
    Erasing at 0xfd60000 --  99% complete.
    Erasing at 0xffe0000 -- 100% complete.
    OK
    => load mmc 0:1 ${loadaddr} MLO
    110364 bytes read in 13 ms (8.1 MiB/s)
    => nand write ${loadaddr} NAND.SPL ${filesize}
    NAND write: device 0 offset 0x0, size 0x1af1c
     110364 bytes written: OK
    => load mmc 0:1 ${loadaddr} u-boot.img
    1453536 bytes read in 101 ms (13.7 MiB/s)
    => nand write ${loadaddr} 0xC0000 ${filesize}
    NAND write: device 0 offset 0xc0000, size 0x162de0
     1453536 bytes written: OK
    => md.l 0x44e10040 1
    44e10040: 00400397                             ..@.
  • Hi Hong,
    The customer used SDK8.2 in previous tests, writing large files over 256M to NAND triggers ECC error. But if using subcontracts, which means you write 256M at a time, that's no problem.
    With SDK9.1, files can be written normally if they do not exceed 256M and after this writing if trying to continue write about 70M of data, reset is triggered. Would it be possible that this issue is due to the GPMC does not support NAND bulk writes?
    => run uprootfs
    1.5 MiB/s
    done
    OK
    268435456 bytes written: OK (There is no problem writing 256M )
    1.5 MiB/s
    done
    data abort(Continue writing 70M data will trigger an exception )
    Resetting CPU ...
    Thanks and Regards,
    Cherry
  • Hi Cherry,
    1/. Will you help elaborate "But if using subcontracts, which means you write 256M at a time, that's no problem."?
    2/. Any code modifications on top of "SDK 9.1 + the two u-boot patches"?
    3/. Is it possible to test NAND write in kernel to get some additional data points?
    -Hong
  • Hi Hong,
    That means, subcontracts the file system to a maximum of 256M, for example, the file system size in use now is 326M, dividing it into two packages, one is 256M and the other is 70M, which is then downloaded and written to nand via tftp.
    First write:
    1.5 MiB/s
    done
    Second write:
    1.5 MiB/s
    done
    Modified pin mux, board, etc. related functions. The custom board does not have eeprom.
    Customers have tested write and read speed, writing or reading 500M data is good and speeds can be around 30M/S.
    Thanks and Regards,
    Cherry
  • Hi Cherry,
    I was out of office last two weeks, and I'm trying to catch up the e2e backlogs.
    Do we have any status update from the customer?
    -Hong
  • Hi Hong
      I fixed nand write issue, it's code issue i think, need include asm/arch/hardware.h before include omap_elm.h in omap_gpmc.c file, otherwise will call template  inline void elm_init(void) function, define in omap_elm.h:
    #ifdef ELM_BASE   -> this define in asm/arch/hardware.h
    void elm_init(void);
    #else
    static inline void elm_init(void)
    #endif
    so I add include asm/arch/hardware.h code in omap_gpmc.c file, nand write big file succeed. thanks
  • for improve tftp download speed, I change config follow, it can speed up to 6MB/S form 1MB/S:
    CONFIG_IP_DEFRAG=y
    CONFIG_NET_MAXDEFRAG=16384
    # CONFIG_SYS_FAULT_ECHO_LINK_DOWN is not set
    CONFIG_TFTP_BLOCKSIZE=16352
  • Hi mengsheng,
    Thanka for status update, and sharting the code changes on
    1/. bulk nand write issue;
    2/. tftp/nand write speedup
    -Hong
