Champs:
How to fix this?
BR Rio
Building ti-img-rogue-driver
make -C /opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver* ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- KERNELDIR=/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/ti-linux-kernel RGX_BVNC="33.15.11.3" BUILD=release PVR_BUILD_DIR=am62_linux WINDOW_SYSTEM=wayland
make[1]: Entering directory '/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501'
******* Multiarch build: no
******* Primary arch: target_aarch64
******* Secondary arch: none
******* PVR top-level arch: rogue
******* PVR DEFS arch: rogue
******* PVR USC arch: rogue
******* PVR TPU arch: rogue
******* HWDefs Root: /opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501/hwdefs/rogue
******* Host OS: linux
******* Target OS: linux
make[2]: aarch64-none-linux-gnu-/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-gcc: Command not found
WARNING: You are not specifying how to find dependent libraries, e.g., by specifying SYSROOT.
The build may fail.
build/linux/tools/cc-check.sh: line 53: aarch64-none-linux-gnu-gcc: command not found
warning: the compiler differs from the one used to build the kernel
The kernel was built by: aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712
You are using:
CC [M] /opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501/binary_am62_linux_wayland_release/target_aarch64/kbuild/services/server/env/linux/pvr_drm.o
/bin/sh: aarch64-none-linux-gnu-gcc: command not found
scripts/Makefile.build:250: recipe for target '/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501/binary_am62_linux_wayland_release/target_aarch64/kbuild/services/server/env/linux/pvr_drm.o' failed
make[5]: *** [/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501/binary_am62_linux_wayland_release/target_aarch64/kbuild/services/server/env/linux/pvr_drm.o] Error 127
Makefile:2012: recipe for target '/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501/binary_am62_linux_wayland_release/target_aarch64/kbuild' failed
make[4]: *** [/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501/binary_am62_linux_wayland_release/target_aarch64/kbuild] Error 2
build/linux/kbuild/kbuild.mk:86: recipe for target 'kbuild' failed
make[3]: *** [kbuild] Error 2
../config/core.mk:2534: recipe for target 'build' failed
make[2]: *** [build] Error 2
Makefile:54: recipe for target 'build' failed
make[1]: *** [build] Error 2
make[1]: Leaving directory '/opt/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/board-support/extra-drivers/ti-img-rogue-driver-23.1.6404501'
makerules/Makefile_ti-img-rogue-driver:4: recipe for target 'ti-img-rogue-driver' failed
make: *** [ti-img-rogue-driver] Error 2
