PROCESSOR-SDK-AM62X: Reboot is not working on AM62X board.
Part Number: PROCESSOR-SDK-AM62X
Other Parts Discussed in Thread: AM625
Hi Ti,
working on AM62X customised board with SDK version 09_00_00_03.
Observed that reboot is not working .
Could you please help me on this.
Naresh.
  • Hi Naresh,
    What is the AM62x part number on your board?
    reboot with Linux 'reboot' command? What is "not working"? What is the console log after the "reboot" command?
  • Hi Bin Liu,
    reboot command is not working in  the linux shell.
    please find the consol logs after reboot .
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# reboot
    root@am62xx-evm:~#          Stopping Session c1 of User root...
    [  OK  ] Removed slice Slice /system/modprobe.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target System Time Set.
    [  OK  ] Stopped target Timer Units.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Closed Process Core Dump Socket.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping containerd container runtime...
             Stopping Getty on tty1...
             Stopping Netperf Benchmark Server...
             Stopping NFS status monitor for NFSv2/3 locking....
             Stopping Serial Getty on ttyS2...
             Stopping Load/Save Random Seed...
             Starting Record Runlevel Change in UTMP...
             Stopping TEE Supplicant...
             Stopping LSB: Expand Rootfs of boot device...
    [  OK  ] Stopped TEE Supplicant.
    [  OK  ] Stopped Wait for Network to be Configured.
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped Netperf Benchmark Server.
    [  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
    [  OK  ] Stopped containerd container runtime.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Load/Save Random Seed.
    [  OK  ] Stopped LSB: Expand Rootfs of boot device.
    [  OK  ] Stopped Session c1 of User root.
    [  OK  ] Finished Record Runlevel Change in UTMP.
    [  OK  ] Removed slice Slice /system/getty.
    [  OK  ] Removed slice Slice /system/serial-getty.
    [  OK  ] Stopped target Host and Network Name Lookups.
             Stopping User Login Management...
             Stopping telnetd.service...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped User Login Management.
    [  OK  ] Stopped User Manager for UID 0.
    [  OK  ] Stopped telnetd.service.
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Removed slice User Slice of UID 0.
             Stopping Permit User Sessions...
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Remote File Systems.
             Stopping Network Name Resolution...
    [  OK  ] Stopped Network Name Resolution.
             Stopping Network Configuration...
    [  OK  ] Stopped Network Configuration.
    [  OK  ] Stopped target Preparation for Network.
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Path Units.
    [  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
    [  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
    [  OK  ] Stopped target Slice Units.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Socket Units.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Closed GPS (Global Positioning System) Daemon Sockets.
    [  OK  ] Closed Network Service Netlink Socket.
             Stopping D-Bus System Message Bus...
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Stopped target System Initialization.
    [  OK  ] Stopped Apply Kernel Variables.
             Stopping Network Time Synchronization...
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /media/ram...
             Unmounting Temporary Directory /tmp...
             Unmounting /var/volatile...
    [  OK  ] Unmounted /media/ram.
    [  OK  ] Unmounted Temporary Directory /tmp.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Preparation for Local File Systems.
    [  OK  ] Stopped target Swaps.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Reached target System Shutdown.
    [  OK  ] Reached target Late Shutdown Services.
    [  OK  ] Finished System Reboot.
    [  OK  ] Reached target System Reboot.
    [   43.737077] kauditd_printk_skb: 3 callbacks suppressed
    [   43.737106] audit: type=1334 audit(1651169475.664:13): prog-id=8 op=UNLOAD
    [   43.766681] audit: type=1334 audit(1651169475.684:14): prog-id=7 op=UNLOAD
    [   43.782598] audit: type=1334 audit(1651169475.688:15): prog-id=10 op=UNLOAD
    [   43.796365] audit: type=1334 audit(1651169475.688:16): prog-id=9 op=UNLOAD
    [   43.809704] audit: type=1334 audit(1651169475.720:17): prog-id=6 op=UNLOAD
    [   43.817246] audit: type=1334 audit(1651169475.720:18): prog-id=5 op=UNLOAD
    [   43.827085] audit: type=1334 audit(1651169475.720:19): prog-id=4 op=UNLOAD
    [   43.838384] audit: type=1334 audit(1651169475.720:20): prog-id=3 op=UNLOAD
    [   43.877723] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   43.972394] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   44.008877] systemd-journald[172]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   44.036076] audit: type=1335 audit(1651169475.964:21): pid=172 uid=0 auid=4294967295 tty=(none) ses=4294967295 comm="systemd-journal" exe="/lib/systemd/systemd-journald" nl-mcgrp=1 op=disconnect res=1
    [   44.092438] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   44.116498] systemd-shutdown[1]: Unmounting file systems.
    [   44.126961] [469]: Remounting '/' read-only with options 'n/a'.
    [   44.156961] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
    [   44.169182] systemd-shutdown[1]: All filesystems unmounted.
    [   44.174921] systemd-shutdown[1]: Deactivating swaps.
    [   44.180310] systemd-shutdown[1]: All swaps deactivated.
    [   44.185576] systemd-shutdown[1]: Detaching loop devices.
    [   44.195088] systemd-shutdown[1]: All loop devices detached.
    [   44.200757] systemd-shutdown[1]: Stopping MD devices.
    [   44.206289] systemd-shutdown[1]: All MD devices stopped.
    [   44.211743] systemd-shutdown[1]: Detaching DM devices.
    [   44.217194] systemd-shutdown[1]: All DM devices detached.
    [   44.222624] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [   44.241280] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   44.249581] systemd-shutdown[1]: Rebooting.
    [   44.253880] kvm: exiting hardware virtualization
    [   44.300639] reboot: Restarting system
    CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB0
    Naresh
  • Hi Naresh,
    Can command 'reset' at the U-Boot prompt reboot the board?
  • What is the boot media of the board, SD card, eMMC or something else?
  • Hi Bin Liu,
    Thanks for your Quick Response,
    • Boot media is eMMC
    • Reset command also not working in uboot prompt , please find below logs
    Logs snippet:
    U-Boot 2023.04-00001-gf5b119738d (Nov 08 2023 - 15:51:26 +0530)
    SoC: AM62X SR1.0 GP
    Model: Texas Instruments AM625 SK
    EEPROM not available at 80, trying to read at 81
    Reading on-board EEPROM at 0x51 failed -121
    DRAM: 2 GiB
    Core: 71 devices, 31 uclasses, devicetree: separate
    MMC: mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In: serial
    Out: serial
    Err: serial
    Net: eth0: ethernet@8000000port@1
    Hit any key to stop autoboot: 0
    => reset
    resetting ...
    Naresh
  • Hi Maresh,
    Can you please try the following u-boot command, then try Linux reboot or u-boot reset?
    => mmc rst-function 0 1
  • Hi Bin Liu,
    Thanks  Bin Liu for your support , reset and reboot wokring fine after that issuing "mmc rst-function 0 1" command.
    but in uboot even i eabled saveenv command in menuconfig , i didnt observed that saveenv command in uboot shell . so on everytime i will issue below commands in uboot in order to boot entire linux kernel through emmc .
    uboot# setenv mmcdev 0
    uboot#bootpart 0
    uboot#boot.
    observtions on my board:
    => saveenv
    Unknown command 'saveenv' - try 'help'
    => env save
    env - environment handling commands
    Usage:
    env default [-f] -a - [forcibly] reset default environment
    env default [-f] var [...] - [forcibly] reset variable(s) to their default values
    env delete [-f] var [...] - [forcibly] delete variable(s)
    env edit name - edit environment variable
    env exists name - tests for existence of variable
    env export [-t | -b | -c] [-s size] addr [var ...] - export environment
    env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] - import environment
    env print [-a | name ...] - print environment
    env run var [...] - run commands in an environment variable
    env set [-f] name [arg ...]
    Could you please help me how to enable saveenv in uboot ?
    Naresh
  • Hi Naresh,
    Glad the reboot issue is resolved.
    Please create a new E2E post for the U-Boot ENV issue so that it will be routed to our U-Boot expert for comments.
  • at it will be
    sure thanks Bin Liu for your support.
