Other Parts Discussed in Thread: SN65DSI86, BQ25890, CSD, TPS51632, TAS2764, TPS65090, DP83869, TPS65912, BQ24190, TPS65910, ADS7950, CDCE925, LM95241, TVP7002, ADC161S626, SN65DSI83, LM95245, ADS7846, ADC108S102, PCM5102A, TMP117, LP8727, INA238, TMP006, LM63, LMP91000, PCM1681, AMC6821, TLC4541, LM93, LM3639, TUSB320, TLV320AIC23B, TAS5805M, TPD12S015, LM8333, ADS8688, DAC5571, HDC2010, TMP401, TAS2552, PCM3168A, TMP464, TPS65219, TPS65218, DAC7612, AFE4404, TPS65217, ADS131E08, DRV2665, DRV2667, TMP513, DAC082S085, ADS7828, TUSB1210, TPS65010, LP3972, LP3971, LM8323, ADC128S052, BQ24257, LM3642, TPS23861, CDCE706, ADS1015, TAS2562, TCA6507, INA3221, LM83, TAS6424, TPS62360, LM80, LM87, THS7303, TLV320AIC23, DAC7311, TPS65086, LM3630A, DP83TC811, THS8200, TAS2770, TPS65023, LP3943, LM95234, HD3SS3220, TFP410, TVP5150, TSC2004, TSC2005, OPT3001, TSC2007, LM77, LM70, LP3944, LM73, LM3530, INA209, ADS8344, TAS2780, PCF8574, ADC084S021, ADS7871, PCM3060, TSC2046, LMK04832, LM3532, LM3533, BQ24735, TCA8418, PMP, TPA6130A2, DLPC3433, TWL6040, TAS5086, AFE4403, TMP102, TMP103, ADC128D818, TS3A227E, DAC124S085, TMP421, ADS124S08, TMP108, TPIC2810, LM3560, PCM1789, TMP007, BQ25980, TPS65132, LM92, TCA6416, LM90, AM68
I've just built u-boot and linux using the top level make file as described in section 1.3 of the getting started guide here: 1.3. Simplified SDK Build using Top-Level Makefile — Processor SDK Linux for J721s2 Documentation
I'm able to install u-boot and linux to the sdcard and it boots/loads linux. However, when I connected a usb device to any of the usb ports, nothing happens. Also, the output of lsusb is blank:
root@am68a-sk:/opt/edgeai-gst-apps# lsusb root@am68a-sk:/opt/edgeai-gst-apps#
Here is the full boot log from the uart console:
U-Boot SPL 2023.04-dirty (Dec 06 2023 - 20:55:40 -0500) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)') EEPROM not available at 0x50, trying to read at 0x51 SPL initial stack usage: 13424 bytes Trying to boot from MMC2 Authentication passed Authentication passed Authentication passed Authentication passed Authentication passed Loading Environment from nowhere... OK Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb-dirty NOTICE: BL31: Built : 00:42:57, Jan 13 2023 I/TC: I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2023.04-dirty (Dec 06 2023 - 20:55:32 -0500) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)') Trying to boot from MMC2 Authentication passed Authentication passed U-Boot 2023.04-dirty (Dec 06 2023 - 20:55:32 -0500) SoC: J721S2 SR1.0 HS-FS Model: Texas Instruments AM68 SK Board: AM68-SK-SOM rev E2 DRAM: 16 GiB Core: 73 devices, 31 uclasses, devicetree: separate Flash: 0 Bytes MMC: mmc@4fb0000: 1 Loading Environment from nowhere... OK In: serial@2880000 Out: serial@2880000 Err: serial@2880000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 1319 bytes read in 2 ms (643.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... ## Error: "main_cpsw0_qsgmii_phyinit" not defined k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 539832 bytes read in 31 ms (16.6 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 2 with data@addr=0x82000000 539832 bytes: Success! 400444 bytes read in 22 ms (17.4 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 3 with data@addr=0x82000000 400444 bytes: Success! Failed to load '/lib/firmware/j721s2-main-r5f1_0-fw' Failed to load '/lib/firmware/j721s2-main-r5f1_1-fw' 14381032 bytes read in 601 ms (22.8 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 6 with data@addr=0x82000000 14381032 bytes: Success! 9777224 bytes read in 409 ms (22.8 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 7 with data@addr=0x82000000 9777224 bytes: Success! 20593152 bytes read in 854 ms (23 MiB/s) 76203 bytes read in 9 ms (8.1 MiB/s) Working FDT set to 88000000 10448 bytes read in 5 ms (2 MiB/s) 10182 bytes read in 6 ms (1.6 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 ERROR: reserving fdt memory region failed (addr=880000000 size=2c000000 flags=4) Loading Device Tree to 000000008feea000, end 000000008fffffff ... OK Working FDT set to 8feea000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.1.33-dirty (amandio@DESKTOP-UJC140B) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Fri Dec 1 11:20:14 EST 2023 [ 0.000000] Machine model: Texas Instruments AM68 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b0100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 704 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000bbffffff] [ 0.000000] node 0: [mem 0x00000000bc000000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008abffffff] [ 0.000000] node 0: [mem 0x00000008ac000000-0x0000000bffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff] [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128766 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) systemd.hostname=am68a-sk root=PARTUUID=38358c03-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 13726380K/16777208K available (12480K kernel code, 1294K rwdata, 4048K rodata, 2176K init, 498K bss, 2133324K reserved, 917504K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8ac800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008ac030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008ac040000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008422] Console: colour dummy device 80x25 [ 0.012991] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023663] pid_max: default: 32768 minimum: 301 [ 0.028403] LSM: Security Framework initializing [ 0.033207] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.040986] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.050081] cblist_init_generic: Setting adjustable number of callback queues. [ 0.057491] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.063755] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.070070] rcu: Hierarchical SRCU implementation. [ 0.074969] rcu: Max phase no-delay instances is 1000. [ 0.080485] Platform MSI: msi-controller@1820000 domain created [ 0.086698] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.096518] EFI services will not be available. [ 0.101261] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.114329] Detected PIPT I-cache on CPU1 [ 0.114394] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.114408] GICv3: CPU1: using allocated LPI pending table @0x00000008ac050000 [ 0.114443] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.114499] smp: Brought up 1 node, 2 CPUs [ 0.143851] SMP: Total of 2 processors activated. [ 0.148655] CPU features: detected: 32-bit EL0 Support [ 0.153910] CPU features: detected: CRC32 instructions [ 0.159194] CPU: All CPU(s) started at EL2 [ 0.163377] alternatives: applying system-wide alternatives [ 0.170018] devtmpfs: initialized [ 0.180240] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.190227] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.210237] pinctrl core: initialized pinctrl subsystem [ 0.215940] DMI not present or invalid. [ 0.220203] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.227080] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.234752] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.243088] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.251316] audit: initializing netlink subsys (disabled) [ 0.256966] audit: type=2000 audit(0.168:1): state=initialized audit_enabled=0 res=1 [ 0.257208] thermal_sys: Registered thermal governor 'step_wise' [ 0.264891] thermal_sys: Registered thermal governor 'power_allocator' [ 0.271124] cpuidle: using governor menu [ 0.281884] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.288853] ASID allocator initialised with 65536 entries [ 0.302887] platform hdmi-connector: Fixed dependency cycle(s) with /dvi-bridge [ 0.310565] KASLR disabled due to lack of seed [ 0.318221] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.325167] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.331569] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.338503] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.344904] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.351837] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.358238] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.365171] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.372561] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected [ 0.382031] iommu: Default domain type: Translated [ 0.387021] iommu: DMA domain TLB invalidation policy: strict mode [ 0.393553] SCSI subsystem initialized [ 0.397594] usbcore: registered new interface driver usbfs [ 0.403223] usbcore: registered new interface driver hub [ 0.408660] usbcore: registered new device driver usb [ 0.414098] pps_core: LinuxPPS API ver. 1 registered [ 0.419171] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.428510] PTP clock support registered [ 0.432587] EDAC MC: Ver: 3.0.0 [ 0.436404] FPGA manager framework [ 0.439921] Advanced Linux Sound Architecture Driver Initialized. [ 0.446588] clocksource: Switched to clocksource arch_sys_counter [ 0.452944] VFS: Disk quotas dquot_6.6.0 [ 0.456981] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.467065] Carveout Heap: Exported 512 MiB at 0x0000000900000000 [ 0.473367] NET: Registered PF_INET protocol family [ 0.478767] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.491623] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.500536] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.508482] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.517166] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.525803] TCP: Hash tables configured (established 131072 bind 65536) [ 0.532703] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.539832] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.547511] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.553649] RPC: Registered named UNIX socket transport module. [ 0.559717] RPC: Registered udp transport module. [ 0.564521] RPC: Registered tcp transport module. [ 0.569324] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.575919] NET: Registered PF_XDP protocol family [ 0.580824] PCI: CLS 0 bytes, default 64 [ 0.585254] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.594507] Initialise system trusted keyrings [ 0.599214] workingset: timestamp_bits=46 max_order=22 bucket_order=0 [ 0.608414] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.614735] NFS: Registering the id_resolver key type [ 0.619916] Key type id_resolver registered [ 0.624187] Key type id_legacy registered [ 0.628312] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.635162] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.642821] 9p: Installing v9fs 9p2000 file system support [ 0.667671] Key type asymmetric registered [ 0.671856] Asymmetric key parser 'x509' registered [ 0.676868] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.684531] io scheduler mq-deadline registered [ 0.689173] io scheduler kyber registered [ 0.695224] pinctrl-single 4301c000.pinctrl: 13 pins, size 52 [ 0.701279] pinctrl-single 4301c038.pinctrl: 11 pins, size 44 [ 0.707288] pinctrl-single 4301c068.pinctrl: 72 pins, size 288 [ 0.713336] pinctrl-single 4301c190.pinctrl: 1 pins, size 4 [ 0.719173] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.729287] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.739618] loop: module loaded [ 0.743705] megasas: 07.719.03.00-rc1 [ 0.749547] tun: Universal TUN/TAP device driver, 1.6 [ 0.755119] thunder_xcv, ver 1.0 [ 0.758425] thunder_bgx, ver 1.0 [ 0.761743] nicpf, ver 1.0 [ 0.764750] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 0.772131] hns3: Copyright (c) 2017 Huawei Corporation. [ 0.777585] hclge is initializing [ 0.780976] e1000: Intel(R) PRO/1000 Network Driver [ 0.785957] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.791843] e1000e: Intel(R) PRO/1000 Network Driver [ 0.796912] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 0.802971] igb: Intel(R) Gigabit Ethernet Network Driver [ 0.808485] igb: Copyright (c) 2007-2014 Intel Corporation. [ 0.814188] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.820590] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.826719] sky2: driver version 1.30 [ 0.830867] VFIO - User Level meta-driver version: 0.3 [ 0.836578] usbcore: registered new interface driver usb-storage [ 0.843189] i2c_dev: i2c /dev entries driver [ 0.848574] sdhci: Secure Digital Host Controller Interface driver [ 0.854899] sdhci: Copyright(c) Pierre Ossman [ 0.859623] Synopsys Designware Multimedia Card Interface Driver [ 0.866017] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.872298] ledtrig-cpu: registered to indicate activity on CPUs [ 0.878540] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.885274] usbcore: registered new interface driver usbhid [ 0.890969] usbhid: USB HID core driver [ 0.895642] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.900208] optee: revision 3.20 (8e74d476) [ 0.916665] optee: dynamic shared memory is enabled [ 0.926153] optee: initialized driver [ 0.931061] Initializing XFRM netlink socket [ 0.935455] NET: Registered PF_PACKET protocol family [ 0.940696] 9pnet: Installing 9P2000 support [ 0.945094] Key type dns_resolver registered [ 0.949678] registered taskstats version 1 [ 0.953883] Loading compiled-in X.509 certificates [ 0.963896] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)') [ 0.990334] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 0.996661] pca953x 1-0020: supply vcc not found, using dummy regulator [ 1.003523] pca953x 1-0020: using no AI [ 1.031654] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 1.038109] pca953x 2-0021: supply vcc not found, using dummy regulator [ 1.044942] pca953x 2-0021: using no AI [ 1.071167] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.076969] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created [ 1.085523] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created [ 1.094866] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created [ 1.103527] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created [ 1.112330] ti-udma 311a0000.dma-controller: Number of rings: 48 [ 1.119074] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16) [ 1.128347] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272 [ 1.138242] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.145002] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.153870] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259 [ 1.164034] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.170793] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.178802] printk: console [ttyS2] disabled [ 1.183201] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 215, base_baud = 3000000) is a 8250 [ 1.192056] printk: console [ttyS2] enabled [ 1.192056] printk: console [ttyS2] enabled [ 1.200504] printk: bootconsole [ns16550a0] disabled [ 1.200504] printk: bootconsole [ns16550a0] disabled [ 1.212131] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.258597] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.267233] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.275513] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.288380] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.295590] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.301907] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 1.312398] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0 [ 1.427425] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 1.434244] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 1.441032] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 1.447818] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 1.454944] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.464976] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16) [ 1.477215] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.482226] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 1.488833] Creating 7 MTD partitions on "47040000.spi.0": [ 1.494304] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.500453] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.506343] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.512252] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.517875] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.524148] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.530052] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.540373] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.586596] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.595233] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.603514] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.616371] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.623579] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.629858] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 1.639980] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.647855] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present! [ 1.648372] mmc1: CQHCI version 5.10 [ 1.655161] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present! [ 1.666953] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present! [ 1.678371] ALSA device list: [ 1.681354] No soundcards found. [ 1.697197] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 1.704800] Waiting for root device PARTUUID=38358c03-02... [ 1.759613] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 1.766683] mmcblk1: mmc1:aaaa SL32G 29.7 GiB [ 1.775815] mmcblk1: p1 p2 [ 1.861756] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 1.870314] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.892611] devtmpfs: mounted [ 1.896621] Freeing unused kernel memory: 2176K [ 1.901366] Run /sbin/init as init process [ 2.090762] systemd[1]: System time before build time, advancing clock. [ 2.126033] NET: Registered PF_INET6 protocol family [ 2.131645] Segment Routing with IPv6 [ 2.135335] In-situ OAM (IOAM) with IPv6 [ 2.180587] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 2.211984] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.04! [ 2.290752] systemd[1]: Hostname set to <am68a-sk>. [ 2.382174] systemd-sysv-generator[134]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.411256] systemd-sysv-generator[134]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.435254] systemd-sysv-generator[134]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.459524] systemd-sysv-generator[134]: SysV service '/etc/init.d/autolaunch-demo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.484710] systemd-sysv-generator[134]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.509401] systemd-sysv-generator[134]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.532999] systemd-sysv-generator[134]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.557744] systemd-sysv-generator[134]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.582790] systemd-sysv-generator[134]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.606482] systemd-sysv-generator[134]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.630351] systemd-sysv-generator[134]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.655985] systemd-sysv-generator[134]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.680196] systemd-sysv-generator[134]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.704871] systemd-sysv-generator[134]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.728738] systemd-sysv-generator[134]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.753248] systemd-sysv-generator[134]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.778850] systemd-sysv-generator[134]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.802655] systemd-sysv-generator[134]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 2.972888] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.020025] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.072058] systemd[1]: Queued start job for default target Graphical Interface. [ 3.115521] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 3.140170] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 3.164039] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 3.187709] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 3.210837] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 3.234752] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 3.258812] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 3.278663] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 3.298643] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 3.318659] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 3.373795] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 3.394762] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 3.420006] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.442869] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.467049] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 3.486928] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.506933] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 3.527005] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 3.551012] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 3.570885] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.590888] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 3.634953] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 3.657471] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 3.698923] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 3.718901] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 3.737140] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 3.762160] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 3.785521] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 3.809589] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 3.833990] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 3.845532] fuse: init (API version 7.37) [ 3.883158] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 3.912869] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 3.930883] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 3.979133] systemd[1]: Starting Journal Service... Starting Journal Service... [ 4.010941] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 4.048671] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network …ts from Kernel command line... [ 4.077929] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 4.092560] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. [ 4.106059] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 4.127972] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 4.147230] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 4.478981] systemd-journald[149]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Finished Coldplug All udev Devices. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 4.709310] audit: type=1334 audit(1651167747.616:2): prog-id=5 op=LOAD [ 4.716412] audit: type=1334 audit(1651167747.624:3): prog-id=6 op=LOAD Starting Rule-based Manage…for Device Events and Files... [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Finished Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ 5.224090] random: crng init done [ OK ] Reached target Timer Units. [ 5.241913] CAN device driver interface [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ 5.280072] mc: Linux media interface: v0.10 Starting Docker Socket for the API... [ 5.300149] videodev: Linux video capture interface: v2.00 [ 5.328346] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b0000000 [ OK ] Listening on dropbear.socket.[ 5.341928] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 5.350700] remoteproc remoteproc0: 64800000.dsp is available [ 5.357595] remoteproc remoteproc0: attaching to 64800000.dsp Starting Weston socket... [ 5.378136] remoteproc remoteproc0: unsupported resource 65538 Starting Console System Startup Logging... [ 5.405155] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 5.417869] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c71-dma-memory@b0000000 [ 5.427549] at24 0-0051: supply vcc not found, using dummy regulator Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ 5.513514] virtio_rpmsg_bus virtio0: rpmsg host is online [ 5.519152] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 5.526570] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write [ OK ] Finished Load/Save Random Seed. [ 5.541960] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7) [ 5.548943] remoteproc remoteproc0: remote processor 64800000.dsp is now attached [ OK ] Listening on Docker Socket for the [ 5.557934] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000 API. [ 5.578746] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode [ OK ] Listening on Weston socket. [ 5.591590] remoteproc remoteproc1: 65800000.dsp is available [ OK ] Finished Console System Startup Logging. [ 5.606308] remoteproc remoteproc1: attaching to 65800000.dsp [ OK ] Finished Reboot and dump vmcore via kexec. [ 5.622192] remoteproc remoteproc1: unsupported resource 65538 [ OK ] Found device /dev/ttyS2. [ OK ] Started D-Bus System Message Bus. [ OK ] Reached target Socket Units. [ 5.678221] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode [ OK ] Reached target Basic System. [ 5.713409] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 5.722157] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000 [ 5.738882] virtio_rpmsg_bus virtio1: rpmsg host is online [ 5.740694] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 5.744990] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7) [ OK ] Started Job spooling tools.[ 5.763157] remoteproc remoteproc1: remote processor 65800000.dsp is now attached [ 5.776451] platform 41000000.r5f: configured R5F for IPC-only mode [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting Expand the rootfs…ll size of the boot device.... [ OK ] Started startwlanap. [ OK ] Started startwlansta. [ 5.897773] audit: type=1334 audit(1651169986.440:4): prog-id=7 op=LOAD [ 5.906033] audit: type=1334 audit(1651169986.452:5): prog-id=8 op=LOAD Starting User Login Management... [ OK ] Started TEE Supplicant. Starting telnetd.service... [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Reached target Preparation for Network. Starting Network Configuration... [ OK ] Started Telephony service. [ OK ] Started telnetd.service. [ 6.014460] m_can_platform 2761000.can: m_can device registered (irq=483, version=32) [ 6.028584] m_can_platform 2771000.can: m_can device registered (irq=484, version=32) [ 6.050946] Bluetooth: Core ver 2.22 [ 6.055880] m_can_platform 40528000.can: m_can device registered (irq=485, version=32) [ 6.063996] NET: Registered PF_BLUETOOTH protocol family [ 6.075940] Bluetooth: HCI device and connection manager initialized [ 6.082824] Bluetooth: HCI socket layer initialized [ 6.088152] m_can_platform 40568000.can: m_can device registered (irq=486, version=32) [ 6.096430] Bluetooth: L2CAP socket layer initialized [ 6.101664] Bluetooth: SCO socket layer initialized [ 6.128657] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 6.154286] remoteproc remoteproc2: 41000000.r5f is available [ 6.218678] remoteproc remoteproc2: attaching to 41000000.r5f [ OK ] Finished Expand the rootfs…full size of the boot device.. [ 6.364771] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 6.377352] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ OK ] Started User Login Management. [ 6.405852] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.441115] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.484363] virtio_rpmsg_bus virtio2: rpmsg host is online [ 6.494459] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7) [ 6.501366] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 6.509204] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 6.514314] remoteproc remoteproc2: remote processor 41000000.r5f is now attached [ OK ] Started Network Configuration. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 6.620820] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 6.630608] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 6.673091] platform 5c00000.r5f: configured R5F for IPC-only mode [ 6.682391] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 6.695551] remoteproc remoteproc3: 5c00000.r5f is available [ 6.759124] remoteproc remoteproc3: attaching to 5c00000.r5f [ 6.769237] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 6.780445] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 6.791355] virtio_rpmsg_bus virtio3: rpmsg host is online [ 6.797006] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 6.804526] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7) [ 6.812008] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached [ 6.823122] platform 5d00000.r5f: configured R5F for IPC-only mode [ 6.832609] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 6.873715] remoteproc remoteproc4: 5d00000.r5f is available [ 6.922639] remoteproc remoteproc4: attaching to 5d00000.r5f [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name L[ 6.960821] platform 5d00000.r5f: R5F core initialized in IPC-only mode ookups. Starting Avahi mDNS/DNS-SD Stack... [ 6.977369] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 Starting Enable and configure wl18xx bluetooth[ 6.994914] virtio_rpmsg_bus virtio4: rpmsg host is online stack... [ 7.002606] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 7.012098] rproc-virtio rproc-virtio.4.auto: registered virtio4 (type 7) Starting containerd container runtime...[ 7.019144] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 7.031528] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 7.033265] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached [ 7.038861] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 7.053740] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 7.063659] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 7.073447] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 7.081674] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 7.089383] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ OK ] Started Netperf Benchmark Server. [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Permit User Sessions... [ 7.130023] platform 5e00000.r5f: configured R5F for remoteproc mode [ 7.145406] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 7.155462] remoteproc remoteproc5: 5e00000.r5f is available [ 7.163718] platform 5f00000.r5f: configured R5F for remoteproc mode [ OK ] Finished Enable and configure wl18x[ 7.174221] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 x bluetooth stack. [ 7.186117] remoteproc remoteproc6: 5f00000.r5f is available [ 7.195992] remoteproc remoteproc5: loading /lib/firmware/j721s2-main-r5f1_0-fw failed with error -22 [ 7.207878] remoteproc remoteproc6: loading /lib/firmware/j721s2-main-r5f1_1-fw failed with error -22 [ OK ] Started Getty on tty1. [ 7.217544] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -22 [ 7.231955] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -22 [ 7.241655] remoteproc remoteproc5: powering up 5e00000.r5f [ 7.247381] remoteproc remoteproc5: loading /lib/firmware/j721s2-main-r5f1_0-fw failed with error -22 [ 7.256661] remoteproc remoteproc6: powering up 5f00000.r5f [ 7.262348] remoteproc remoteproc6: loading /lib/firmware/j721s2-main-r5f1_1-fw failed with error -22 [ 7.271644] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -22 [ 7.271657] remoteproc remoteproc5: request_firmware failed: -22 [ 7.271669] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -22 [ 7.271673] remoteproc remoteproc6: request_firmware failed: -22 [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Wayland…ositor, as a system service... [ 7.374062] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. [ 7.503261] [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* remote dsi host node not found [ 7.515618] audit: type=1334 audit(1651169988.060:6): prog-id=9 op=LOAD [ 7.525911] audit: type=1334 audit(1651169988.068:7): prog-id=10 op=LOAD Starting User Database Manager... [ OK ] Started User Database Manager. [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished User Runtime Directory /run/user/1000. Starting User Manager for UID 1000... [ 7.884276] audit: type=1006 audit(1651169988.428:8): pid=501 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 7.905836] audit: type=1300 audit(1651169988.428:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe692e828 a2=4 a3=ffffb79bc020 items=0 ppid=1 pid=501 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 7.941636] audit: type=1327 audit(1651169988.428:8): proctitle="(systemd)" [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston. [ 8.305205] audit: type=1006 audit(1651169988.848:9): pid=443 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 8.317639] audit: type=1300 audit(1651169988.848:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe692e828 a2=4 a3=ffffb79bc020 items=0 ppid=1 pid=443 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null) [ 8.344363] audit: type=1327 audit(1651169988.848:9): proctitle="(weston)" [FAILED] Failed to start Weston, a …mpositor, as a system service. See 'systemctl status weston.service' for details. [DEPEND] Dependency failed for DEMO. [ OK ] Created slice Slice /system/systemd-fsck. Starting EdgeAI OOB demos... [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/boot-mmcblk1p1... [ OK ] Started containerd container runtime. [ OK ] Mounted /run/media/boot-mmcblk1p1. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk-dev gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grub-common grub-editenv grub-efi gzip less libasm1 libatomic-dev libatomic1 libbfd libdebuginfod1 libdw1 libeigen-dev libelf1 libgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmpc3 libmpfr6 libopcodes libqt5charts-examples libqt5charts-plugins libqt5charts-qmlplugins libqt5charts5 libqt5sensors-plugins libqt5sensors-qmlplugins libqt5sensors5 libqt5serialport-examples libqt5serialport-plugins libqt5serialport-qmlplugins libqt5serialport5 libqt5svg-examples libqt5svg-plugins libqt5svg-qmlplugins libqt5svg5 libqt5virtualkeyboard-plugins libqt5virtualkeyboard-qmlplugins libqt5virtualkeyboard5 libqt5webchannel-plugins libqt5webchannel-qmlplugins libqt5webchannel5 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libunistring2 m4-dev m4 make nettle parted piglit qt3d-plugins qt3d-qmlplugins qt3d qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase qtconnectivity-plugins qtconnectivity-qmlplugins qtconnectivity qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-tools qtdeclarative qtgraphicaleffects-qmlplugins qtlocation-examples qtlocation-plugins qtlocation-qmlplugins qtlocation qtmultimedia-examples qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquics-qmlplugins.control qtquics2-plugins.control qtquics2-qmlplugins.control qtquics2.control qtscript-examples qtscript-plugins qtscript-qmlplugins qtscript qtwayland-examples qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Finished Print notice about GPLv3 packages. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am68a-sk - Arago 2023.04 am68a-sk - am68a-sk login: [ 14.976173] audit: type=1701 audit(1651169995.520:10): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1093 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1 [ 14.998131] audit: type=1334 audit(1651169995.540:11): prog-id=11 op=LOAD [ 15.005159] audit: type=1334 audit(1651169995.540:12): prog-id=12 op=LOAD [ 15.466662] audit: type=1334 audit(1651169996.012:13): prog-id=12 op=UNLOAD [ 15.473636] audit: type=1334 audit(1651169996.012:14): prog-id=11 op=UNLOAD [ 17.763097] platform 2910000.pcie: deferred probe pending [ 17.768509] platform 6000000.usb: deferred probe pending root [ 379.251376] audit: type=1006 audit(1651170359.796:15): pid=1268 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 379.264335] audit: type=1300 audit(1651170359.796:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe692e828 a2=1 a3=0 items=0 ppid=1 pid=1268 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 379.289815] audit: type=1327 audit(1651170359.796:15): proctitle="(systemd)" [ 379.307549] audit: type=1334 audit(1651170359.852:16): prog-id=13 op=LOAD [ 379.314611] audit: type=1300 audit(1651170359.852:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe591bff0 a2=78 a3=0 items=0 ppid=1 pid=1268 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 379.340117] audit: type=1327 audit(1651170359.852:16): proctitle="(systemd)" [ 379.347209] audit: type=1334 audit(1651170359.852:17): prog-id=13 op=UNLOAD [ 379.354219] audit: type=1334 audit(1651170359.852:18): prog-id=14 op=LOAD [ 379.361014] audit: type=1300 audit(1651170359.852:18): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe591c090 a2=78 a3=0 items=0 ppid=1 pid=1268 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 379.386461] audit: type=1327 audit(1651170359.852:18): proctitle="(systemd)" root@am68a-sk:/opt/edgeai-gst-apps#
I had shared a similar log like this in my previous post, which you can find here: SK-AM68: Unable to create bootable sdcard - Processors forum - Processors - TI E2E support forums
I was told in response that the "deferred probe pending" messages for pice and usb might cause issues.
Here is the config it was built with, taken from /proc/config.gz:
# # Automatically generated file; DO NOT EDIT. # Linux/arm64 6.1.33 Kernel Configuration # CONFIG_CC_VERSION_TEXT="aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712" CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=110301 CONFIG_CLANG_VERSION=0 CONFIG_AS_IS_GNU=y CONFIG_AS_VERSION=20244508 CONFIG_LD_IS_BFD=y CONFIG_LD_VERSION=20244508 CONFIG_LLD_VERSION=0 CONFIG_CC_CAN_LINK=y CONFIG_CC_CAN_LINK_STATIC=y CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y CONFIG_CC_HAS_ASM_INLINE=y CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y CONFIG_PAHOLE_VERSION=125 CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_TABLE_SORT=y CONFIG_THREAD_INFO_IN_TASK=y # # General setup # CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set # CONFIG_WERROR is not set CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_BUILD_SALT="" CONFIG_DEFAULT_INIT="" CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_SYSVIPC_COMPAT=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_WATCH_QUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set CONFIG_AUDIT=y CONFIG_HAVE_ARCH_AUDITSYSCALL=y CONFIG_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y CONFIG_GENERIC_IRQ_MIGRATION=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_GENERIC_IRQ_IPI=y CONFIG_GENERIC_MSI_IRQ=y CONFIG_GENERIC_MSI_IRQ_DOMAIN=y CONFIG_IRQ_MSI_IOMMU=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set # end of IRQ subsystem CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y CONFIG_HAVE_POSIX_CPU_TIMERS_TASK_WORK=y CONFIG_POSIX_CPU_TIMERS_TASK_WORK=y CONFIG_CONTEXT_TRACKING=y CONFIG_CONTEXT_TRACKING_IDLE=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set # CONFIG_NO_HZ is not set CONFIG_HIGH_RES_TIMERS=y # end of Timers subsystem CONFIG_BPF=y CONFIG_HAVE_EBPF_JIT=y CONFIG_ARCH_WANT_DEFAULT_BPF_JIT=y # # BPF subsystem # CONFIG_BPF_SYSCALL=y CONFIG_BPF_JIT=y # CONFIG_BPF_JIT_ALWAYS_ON is not set CONFIG_BPF_JIT_DEFAULT_ON=y CONFIG_BPF_UNPRIV_DEFAULT_OFF=y # CONFIG_BPF_PRELOAD is not set # end of BPF subsystem CONFIG_PREEMPT_BUILD=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y # CONFIG_PREEMPT_DYNAMIC is not set # CONFIG_SCHED_CORE is not set # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set CONFIG_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_SCHED_AVG_IRQ=y CONFIG_SCHED_THERMAL_PRESSURE=y CONFIG_BSD_PROCESS_ACCT=y CONFIG_BSD_PROCESS_ACCT_V3=y CONFIG_TASKSTATS=y # CONFIG_TASK_DELAY_ACCT is not set CONFIG_TASK_XACCT=y CONFIG_TASK_IO_ACCOUNTING=y # CONFIG_PSI is not set # end of CPU/Task time and stats accounting CONFIG_CPU_ISOLATION=y # # RCU Subsystem # CONFIG_TREE_RCU=y CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_TASKS_RCU_GENERIC=y CONFIG_TASKS_RCU=y CONFIG_TASKS_TRACE_RCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y # end of RCU Subsystem CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_IKHEADERS is not set CONFIG_LOG_BUF_SHIFT=17 CONFIG_LOG_CPU_MAX_BUF_SHIFT=12 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 # CONFIG_PRINTK_INDEX is not set CONFIG_GENERIC_SCHED_CLOCK=y # # Scheduler features # # CONFIG_UCLAMP_TASK is not set # end of Scheduler features CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y CONFIG_CC_HAS_INT128=y CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5" CONFIG_GCC11_NO_ARRAY_BOUNDS=y CONFIG_CC_NO_ARRAY_BOUNDS=y CONFIG_ARCH_SUPPORTS_INT128=y CONFIG_CGROUPS=y CONFIG_PAGE_COUNTER=y # CONFIG_CGROUP_FAVOR_DYNMODS is not set CONFIG_MEMCG=y CONFIG_MEMCG_KMEM=y CONFIG_BLK_CGROUP=y CONFIG_CGROUP_WRITEBACK=y CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y CONFIG_CFS_BANDWIDTH=y # CONFIG_RT_GROUP_SCHED is not set CONFIG_CGROUP_PIDS=y # CONFIG_CGROUP_RDMA is not set CONFIG_CGROUP_FREEZER=y CONFIG_CGROUP_HUGETLB=y CONFIG_CPUSETS=y CONFIG_PROC_PID_CPUSET=y CONFIG_CGROUP_DEVICE=y CONFIG_CGROUP_CPUACCT=y CONFIG_CGROUP_PERF=y CONFIG_CGROUP_BPF=y # CONFIG_CGROUP_MISC is not set # CONFIG_CGROUP_DEBUG is not set CONFIG_SOCK_CGROUP_DATA=y CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_TIME_NS=y CONFIG_IPC_NS=y CONFIG_USER_NS=y CONFIG_PID_NS=y CONFIG_NET_NS=y # CONFIG_CHECKPOINT_RESTORE is not set CONFIG_SCHED_AUTOGROUP=y # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_RD_ZSTD=y # CONFIG_BOOT_CONFIG is not set CONFIG_INITRAMFS_PRESERVE_MTIME=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_LD_ORPHAN_WARN=y CONFIG_SYSCTL=y CONFIG_HAVE_UID16=y CONFIG_SYSCTL_EXCEPTION_TRACE=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y CONFIG_FHANDLE=y CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y CONFIG_KCMP=y CONFIG_RSEQ=y # CONFIG_DEBUG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set # end of Kernel Performance Events And Counters CONFIG_SYSTEM_DATA_VERIFICATION=y CONFIG_PROFILING=y # end of General setup CONFIG_ARM64=y CONFIG_GCC_SUPPORTS_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_64BIT=y CONFIG_MMU=y CONFIG_ARM64_PAGE_SHIFT=12 CONFIG_ARM64_CONT_PTE_SHIFT=4 CONFIG_ARM64_CONT_PMD_SHIFT=4 CONFIG_ARCH_MMAP_RND_BITS_MIN=18 CONFIG_ARCH_MMAP_RND_BITS_MAX=33 CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11 CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16 CONFIG_STACKTRACE_SUPPORT=y CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000 CONFIG_LOCKDEP_SUPPORT=y CONFIG_GENERIC_BUG=y CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CSUM=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_MHP_MEMMAP_ON_MEMORY_ENABLE=y CONFIG_SMP=y CONFIG_KERNEL_MODE_NEON=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_PGTABLE_LEVELS=4 CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_ARCH_PROC_KCORE_TEXT=y # # Platform selection # # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_APPLE is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_BITMAIN is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_SPARX5 is not set CONFIG_ARCH_K3=y # CONFIG_ARCH_LG1K is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_KEEMBAY is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_NXP is not set # CONFIG_ARCH_NPCM is not set # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_REALTEK is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_SEATTLE is not set # CONFIG_ARCH_INTEL_SOCFPGA is not set # CONFIG_ARCH_SYNQUACER is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_SPRD is not set # CONFIG_ARCH_THUNDER is not set # CONFIG_ARCH_THUNDER2 is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_VISCONTI is not set # CONFIG_ARCH_XGENE is not set # CONFIG_ARCH_ZYNQMP is not set # end of Platform selection # # Kernel Features # # # ARM errata workarounds via the alternatives framework # CONFIG_ARM64_WORKAROUND_CLEAN_CACHE=y CONFIG_ARM64_ERRATUM_826319=y CONFIG_ARM64_ERRATUM_827319=y CONFIG_ARM64_ERRATUM_824069=y CONFIG_ARM64_ERRATUM_819472=y CONFIG_ARM64_ERRATUM_832075=y CONFIG_ARM64_ERRATUM_1742098=y CONFIG_ARM64_ERRATUM_845719=y CONFIG_ARM64_ERRATUM_843419=y CONFIG_ARM64_LD_HAS_FIX_ERRATUM_843419=y CONFIG_ARM64_ERRATUM_1024718=y CONFIG_ARM64_ERRATUM_1418040=y CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT=y CONFIG_ARM64_ERRATUM_1165522=y CONFIG_ARM64_ERRATUM_1319367=y CONFIG_ARM64_ERRATUM_1530923=y CONFIG_ARM64_WORKAROUND_REPEAT_TLBI=y CONFIG_ARM64_ERRATUM_2441007=y CONFIG_ARM64_ERRATUM_1286807=y CONFIG_ARM64_ERRATUM_1463225=y CONFIG_ARM64_ERRATUM_1542419=y CONFIG_ARM64_ERRATUM_1508412=y CONFIG_ARM64_ERRATUM_2051678=y CONFIG_ARM64_ERRATUM_2077057=y CONFIG_ARM64_ERRATUM_2658417=y CONFIG_ARM64_WORKAROUND_TSB_FLUSH_FAILURE=y CONFIG_ARM64_ERRATUM_2054223=y CONFIG_ARM64_ERRATUM_2067961=y CONFIG_ARM64_ERRATUM_2441009=y CONFIG_ARM64_ERRATUM_2457168=y # CONFIG_CAVIUM_ERRATUM_22375 is not set # CONFIG_CAVIUM_ERRATUM_23154 is not set # CONFIG_CAVIUM_ERRATUM_27456 is not set # CONFIG_CAVIUM_ERRATUM_30115 is not set CONFIG_CAVIUM_TX2_ERRATUM_219=y CONFIG_FUJITSU_ERRATUM_010001=y # CONFIG_HISILICON_ERRATUM_161600802 is not set # CONFIG_QCOM_FALKOR_ERRATUM_1003 is not set # CONFIG_QCOM_FALKOR_ERRATUM_1009 is not set # CONFIG_QCOM_QDF2400_ERRATUM_0065 is not set # CONFIG_QCOM_FALKOR_ERRATUM_E1041 is not set CONFIG_NVIDIA_CARMEL_CNP_ERRATUM=y CONFIG_SOCIONEXT_SYNQUACER_PREITS=y # end of ARM errata workarounds via the alternatives framework CONFIG_ARM64_4K_PAGES=y # CONFIG_ARM64_16K_PAGES is not set # CONFIG_ARM64_64K_PAGES is not set # CONFIG_ARM64_VA_BITS_39 is not set CONFIG_ARM64_VA_BITS_48=y CONFIG_ARM64_VA_BITS=48 CONFIG_ARM64_PA_BITS_48=y CONFIG_ARM64_PA_BITS=48 # CONFIG_CPU_BIG_ENDIAN is not set CONFIG_CPU_LITTLE_ENDIAN=y CONFIG_SCHED_MC=y # CONFIG_SCHED_CLUSTER is not set CONFIG_SCHED_SMT=y CONFIG_NR_CPUS=256 CONFIG_HOTPLUG_CPU=y # CONFIG_NUMA is not set # CONFIG_HZ_100 is not set CONFIG_HZ_250=y # CONFIG_HZ_300 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=250 CONFIG_SCHED_HRTICK=y CONFIG_ARCH_SPARSEMEM_ENABLE=y CONFIG_HW_PERF_EVENTS=y CONFIG_PARAVIRT=y # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set CONFIG_KEXEC=y CONFIG_KEXEC_FILE=y # CONFIG_KEXEC_SIG is not set CONFIG_CRASH_DUMP=y CONFIG_TRANS_TABLE=y # CONFIG_XEN is not set CONFIG_ARCH_FORCE_MAX_ORDER=11 CONFIG_UNMAP_KERNEL_AT_EL0=y CONFIG_MITIGATE_SPECTRE_BRANCH_HISTORY=y CONFIG_RODATA_FULL_DEFAULT_ENABLED=y # CONFIG_ARM64_SW_TTBR0_PAN is not set CONFIG_ARM64_TAGGED_ADDR_ABI=y CONFIG_COMPAT=y CONFIG_KUSER_HELPERS=y # CONFIG_COMPAT_ALIGNMENT_FIXUPS is not set # CONFIG_ARMV8_DEPRECATED is not set # # ARMv8.1 architectural features # CONFIG_ARM64_HW_AFDBM=y CONFIG_ARM64_PAN=y CONFIG_AS_HAS_LDAPR=y CONFIG_AS_HAS_LSE_ATOMICS=y CONFIG_ARM64_LSE_ATOMICS=y CONFIG_ARM64_USE_LSE_ATOMICS=y # end of ARMv8.1 architectural features # # ARMv8.2 architectural features # CONFIG_AS_HAS_ARMV8_2=y CONFIG_AS_HAS_SHA3=y # CONFIG_ARM64_PMEM is not set CONFIG_ARM64_RAS_EXTN=y CONFIG_ARM64_CNP=y # end of ARMv8.2 architectural features # # ARMv8.3 architectural features # CONFIG_ARM64_PTR_AUTH=y CONFIG_ARM64_PTR_AUTH_KERNEL=y CONFIG_CC_HAS_BRANCH_PROT_PAC_RET=y CONFIG_CC_HAS_SIGN_RETURN_ADDRESS=y CONFIG_AS_HAS_PAC=y CONFIG_AS_HAS_CFI_NEGATE_RA_STATE=y # end of ARMv8.3 architectural features # # ARMv8.4 architectural features # CONFIG_ARM64_AMU_EXTN=y CONFIG_AS_HAS_ARMV8_4=y CONFIG_ARM64_TLB_RANGE=y # end of ARMv8.4 architectural features # # ARMv8.5 architectural features # CONFIG_AS_HAS_ARMV8_5=y CONFIG_ARM64_BTI=y CONFIG_CC_HAS_BRANCH_PROT_PAC_RET_BTI=y CONFIG_ARM64_E0PD=y CONFIG_ARM64_AS_HAS_MTE=y CONFIG_ARM64_MTE=y # end of ARMv8.5 architectural features # # ARMv8.7 architectural features # CONFIG_ARM64_EPAN=y # end of ARMv8.7 architectural features CONFIG_ARM64_SVE=y CONFIG_ARM64_SME=y CONFIG_ARM64_MODULE_PLTS=y # CONFIG_ARM64_PSEUDO_NMI is not set CONFIG_RELOCATABLE=y CONFIG_RANDOMIZE_BASE=y CONFIG_RANDOMIZE_MODULE_REGION_FULL=y CONFIG_CC_HAVE_STACKPROTECTOR_SYSREG=y CONFIG_STACKPROTECTOR_PER_TASK=y CONFIG_ARCH_NR_GPIO=0 # end of Kernel Features # # Boot options # CONFIG_CMDLINE="" CONFIG_EFI_STUB=y CONFIG_EFI=y CONFIG_DMI=y # end of Boot options # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set CONFIG_HIBERNATE_CALLBACKS=y CONFIG_HIBERNATION=y CONFIG_HIBERNATION_SNAPSHOT_DEV=y CONFIG_PM_STD_PARTITION="" CONFIG_PM_SLEEP=y CONFIG_PM_SLEEP_SMP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_USERSPACE_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y # CONFIG_PM_DEBUG is not set CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y CONFIG_ENERGY_MODEL=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y CONFIG_ARCH_HIBERNATION_HEADER=y CONFIG_ARCH_SUSPEND_POSSIBLE=y # end of Power management options # # CPU Power Management # # # CPU Idle # CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y # CONFIG_CPU_IDLE_GOV_LADDER is not set CONFIG_CPU_IDLE_GOV_MENU=y # CONFIG_CPU_IDLE_GOV_TEO is not set CONFIG_DT_IDLE_STATES=y CONFIG_DT_IDLE_GENPD=y # # ARM CPU Idle Drivers # CONFIG_ARM_PSCI_CPUIDLE=y CONFIG_ARM_PSCI_CPUIDLE_DOMAIN=y # end of ARM CPU Idle Drivers # end of CPU Idle # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_ATTR_SET=y CONFIG_CPU_FREQ_GOV_COMMON=y CONFIG_CPU_FREQ_STAT=y # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=m CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y CONFIG_ARM_SCMI_CPUFREQ=y CONFIG_ARM_TI_CPUFREQ=y # end of CPU Frequency scaling # end of CPU Power Management CONFIG_ARCH_SUPPORTS_ACPI=y # CONFIG_ACPI is not set CONFIG_IRQ_BYPASS_MANAGER=y CONFIG_HAVE_KVM=y CONFIG_VIRTUALIZATION=y # CONFIG_KVM is not set # # General architecture-dependent options # CONFIG_CRASH_CORE=y CONFIG_KEXEC_CORE=y CONFIG_ARCH_HAS_SUBPAGE_FAULTS=y # CONFIG_KPROBES is not set CONFIG_JUMP_LABEL=y # CONFIG_STATIC_KEYS_SELFTEST is not set CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_HAVE_IOREMAP_PROT=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_ARCH_CORRECT_STACKTRACE_ON_KRETPROBE=y CONFIG_HAVE_FUNCTION_ERROR_INJECTION=y CONFIG_HAVE_NMI=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_TRACE_IRQFLAGS_NMI_SUPPORT=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_KEEPINITRD=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_ARCH_HAS_SET_DIRECT_MAP=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_WANTS_NO_INSTR=y CONFIG_HAVE_ASM_MODVERSIONS=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_FUNCTION_ARG_ACCESS_API=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_HAVE_ARCH_JUMP_LABEL_RELATIVE=y CONFIG_MMU_GATHER_TABLE_FREE=y CONFIG_MMU_GATHER_RCU_TABLE_FREE=y CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y CONFIG_HAVE_ALIGNED_STRUCT_PAGE=y CONFIG_HAVE_CMPXCHG_LOCAL=y CONFIG_HAVE_CMPXCHG_DOUBLE=y CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP=y CONFIG_SECCOMP_FILTER=y # CONFIG_SECCOMP_CACHE_DEBUG is not set CONFIG_HAVE_ARCH_STACKLEAK=y CONFIG_HAVE_STACKPROTECTOR=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_ARCH_SUPPORTS_LTO_CLANG=y CONFIG_ARCH_SUPPORTS_LTO_CLANG_THIN=y CONFIG_LTO_NONE=y CONFIG_ARCH_SUPPORTS_CFI_CLANG=y CONFIG_HAVE_CONTEXT_TRACKING_USER=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOVE_PUD=y CONFIG_HAVE_MOVE_PMD=y CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y CONFIG_HAVE_ARCH_HUGE_VMAP=y CONFIG_HAVE_ARCH_HUGE_VMALLOC=y CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_RELA=y CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y CONFIG_SOFTIRQ_ON_OWN_STACK=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_ARCH_MMAP_RND_BITS=18 CONFIG_HAVE_ARCH_MMAP_RND_COMPAT_BITS=y CONFIG_ARCH_MMAP_RND_COMPAT_BITS=11 CONFIG_PAGE_SIZE_LESS_THAN_64KB=y CONFIG_PAGE_SIZE_LESS_THAN_256KB=y CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_COMPAT_OLD_SIGACTION=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_HAVE_ARCH_VMAP_STACK=y CONFIG_VMAP_STACK=y CONFIG_HAVE_ARCH_RANDOMIZE_KSTACK_OFFSET=y CONFIG_RANDOMIZE_KSTACK_OFFSET=y # CONFIG_RANDOMIZE_KSTACK_OFFSET_DEFAULT is not set CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y CONFIG_HAVE_ARCH_COMPILER_H=y CONFIG_HAVE_ARCH_PREL32_RELOCATIONS=y CONFIG_ARCH_USE_MEMREMAP_PROT=y # CONFIG_LOCK_EVENT_COUNTS is not set CONFIG_ARCH_HAS_RELR=y CONFIG_HAVE_PREEMPT_DYNAMIC=y CONFIG_HAVE_PREEMPT_DYNAMIC_KEY=y CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y CONFIG_ARCH_SUPPORTS_PAGE_TABLE_CHECK=y CONFIG_ARCH_HAVE_TRACE_MMIO_ACCESS=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y # end of GCOV-based kernel profiling CONFIG_HAVE_GCC_PLUGINS=y CONFIG_GCC_PLUGINS=y # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set # end of General architecture-dependent options CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set CONFIG_MODULE_COMPRESS_NONE=y # CONFIG_MODULE_COMPRESS_GZIP is not set # CONFIG_MODULE_COMPRESS_XZ is not set # CONFIG_MODULE_COMPRESS_ZSTD is not set # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set CONFIG_MODPROBE_PATH="/sbin/modprobe" # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_BLOCK_LEGACY_AUTOLOAD=y CONFIG_BLK_CGROUP_RWSTAT=y CONFIG_BLK_DEV_BSG_COMMON=y CONFIG_BLK_DEV_BSGLIB=y CONFIG_BLK_DEV_INTEGRITY=y CONFIG_BLK_DEV_INTEGRITY_T10=y # CONFIG_BLK_DEV_ZONED is not set CONFIG_BLK_DEV_THROTTLING=y # CONFIG_BLK_DEV_THROTTLING_LOW is not set # CONFIG_BLK_WBT is not set # CONFIG_BLK_CGROUP_IOLATENCY is not set # CONFIG_BLK_CGROUP_IOCOST is not set # CONFIG_BLK_CGROUP_IOPRIO is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # CONFIG_BLK_INLINE_ENCRYPTION is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_EFI_PARTITION=y # end of Partition Types CONFIG_BLOCK_COMPAT=y CONFIG_BLK_MQ_PCI=y CONFIG_BLK_MQ_VIRTIO=y CONFIG_BLK_PM=y CONFIG_BLOCK_HOLDER_DEPRECATED=y CONFIG_BLK_MQ_STACKING=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set # end of IO Schedulers CONFIG_ASN1=y CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_MUTEX_SPIN_ON_OWNER=y CONFIG_RWSEM_SPIN_ON_OWNER=y CONFIG_LOCK_SPIN_ON_OWNER=y CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y CONFIG_QUEUED_SPINLOCKS=y CONFIG_ARCH_USE_QUEUED_RWLOCKS=y CONFIG_QUEUED_RWLOCKS=y CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y CONFIG_ARCH_HAS_SYSCALL_WRAPPER=y CONFIG_FREEZER=y # # Executable file formats # CONFIG_BINFMT_ELF=y CONFIG_COMPAT_BINFMT_ELF=y CONFIG_ARCH_BINFMT_ELF_STATE=y CONFIG_ARCH_BINFMT_ELF_EXTRA_PHDRS=y CONFIG_ARCH_HAVE_ELF_PROT=y CONFIG_ARCH_USE_GNU_PROPERTY=y CONFIG_ELFCORE=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_BINFMT_SCRIPT=y # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # end of Executable file formats # # Memory Management options # CONFIG_SWAP=y # CONFIG_ZSWAP is not set # # SLAB allocator options # # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set # CONFIG_SLUB_STATS is not set CONFIG_SLUB_CPU_PARTIAL=y # end of SLAB allocator options # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set # CONFIG_COMPAT_BRK is not set CONFIG_SPARSEMEM=y CONFIG_SPARSEMEM_EXTREME=y CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y CONFIG_SPARSEMEM_VMEMMAP=y CONFIG_HAVE_FAST_GUP=y CONFIG_ARCH_KEEP_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y CONFIG_EXCLUSIVE_SYSTEM_RAM=y CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y CONFIG_MEMORY_HOTPLUG=y # CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE is not set CONFIG_MEMORY_HOTREMOVE=y CONFIG_MHP_MEMMAP_ON_MEMORY=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_ARCH_ENABLE_SPLIT_PMD_PTLOCK=y CONFIG_MEMORY_BALLOON=y CONFIG_BALLOON_COMPACTION=y CONFIG_COMPACTION=y CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1 CONFIG_PAGE_REPORTING=y CONFIG_MIGRATION=y CONFIG_ARCH_ENABLE_HUGEPAGE_MIGRATION=y CONFIG_ARCH_ENABLE_THP_MIGRATION=y CONFIG_CONTIG_ALLOC=y CONFIG_PHYS_ADDR_T_64BIT=y CONFIG_KSM=y CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_ARCH_SUPPORTS_MEMORY_FAILURE=y CONFIG_MEMORY_FAILURE=y # CONFIG_HWPOISON_INJECT is not set CONFIG_ARCH_WANTS_THP_SWAP=y CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y # CONFIG_TRANSPARENT_HUGEPAGE_MADVISE is not set CONFIG_THP_SWAP=y # CONFIG_READ_ONLY_THP_FOR_FS is not set CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set # CONFIG_CMA_SYSFS is not set CONFIG_CMA_AREAS=19 CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_DEFERRED_STRUCT_PAGE_INIT is not set # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y CONFIG_ARCH_HAS_PTE_DEVMAP=y CONFIG_ARCH_HAS_ZONE_DMA_SET=y CONFIG_ZONE_DMA=y CONFIG_ZONE_DMA32=y # CONFIG_ZONE_DEVICE is not set CONFIG_ARCH_USES_HIGH_VMA_FLAGS=y CONFIG_VM_EVENT_COUNTERS=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_TEST is not set CONFIG_ARCH_HAS_PTE_SPECIAL=y # CONFIG_ANON_VMA_NAME is not set # CONFIG_USERFAULTFD is not set # CONFIG_LRU_GEN is not set # # Data Access Monitoring # # CONFIG_DAMON is not set # end of Data Access Monitoring # end of Memory Management options CONFIG_NET=y CONFIG_NET_INGRESS=y CONFIG_NET_EGRESS=y CONFIG_SKB_EXTENSIONS=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y CONFIG_UNIX_SCM=y CONFIG_AF_UNIX_OOB=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set CONFIG_XFRM=y CONFIG_XFRM_ALGO=y CONFIG_XFRM_USER=y # CONFIG_XFRM_INTERFACE is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_XFRM_ESP=y # CONFIG_NET_KEY is not set CONFIG_XDP_SOCKETS=y # CONFIG_XDP_SOCKETS_DIAG is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_ROUTE_CLASSID=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y # CONFIG_IP_PNP_RARP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_NET_IP_TUNNEL=m # CONFIG_IP_MROUTE is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set CONFIG_NET_UDP_TUNNEL=m # CONFIG_NET_FOU is not set # CONFIG_NET_FOU_IP_TUNNELS is not set # CONFIG_INET_AH is not set CONFIG_INET_ESP=y # CONFIG_INET_ESP_OFFLOAD is not set # CONFIG_INET_ESPINTCP is not set # CONFIG_INET_IPCOMP is not set CONFIG_INET_TABLE_PERTURB_ORDER=16 CONFIG_INET_TUNNEL=m CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=m # CONFIG_IPV6_ROUTER_PREF is not set # CONFIG_IPV6_OPTIMISTIC_DAD is not set # CONFIG_INET6_AH is not set # CONFIG_INET6_ESP is not set # CONFIG_INET6_IPCOMP is not set # CONFIG_IPV6_MIP6 is not set # CONFIG_IPV6_ILA is not set # CONFIG_IPV6_VTI is not set CONFIG_IPV6_SIT=m # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y # CONFIG_IPV6_TUNNEL is not set # CONFIG_IPV6_MULTIPLE_TABLES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_IPV6_RPL_LWTUNNEL is not set # CONFIG_IPV6_IOAM6_LWTUNNEL is not set # CONFIG_NETLABEL is not set # CONFIG_MPTCP is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set CONFIG_NETFILTER=y CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=m # # Core Netfilter Configuration # CONFIG_NETFILTER_INGRESS=y CONFIG_NETFILTER_EGRESS=y CONFIG_NETFILTER_SKIP_EGRESS=y CONFIG_NETFILTER_FAMILY_BRIDGE=y # CONFIG_NETFILTER_NETLINK_ACCT is not set # CONFIG_NETFILTER_NETLINK_QUEUE is not set # CONFIG_NETFILTER_NETLINK_LOG is not set # CONFIG_NETFILTER_NETLINK_OSF is not set CONFIG_NF_CONNTRACK=m CONFIG_NF_LOG_SYSLOG=m # CONFIG_NF_CONNTRACK_MARK is not set # CONFIG_NF_CONNTRACK_ZONES is not set # CONFIG_NF_CONNTRACK_PROCFS is not set CONFIG_NF_CONNTRACK_EVENTS=y # CONFIG_NF_CONNTRACK_TIMEOUT is not set # CONFIG_NF_CONNTRACK_TIMESTAMP is not set # CONFIG_NF_CONNTRACK_LABELS is not set CONFIG_NF_CT_PROTO_DCCP=y CONFIG_NF_CT_PROTO_SCTP=y CONFIG_NF_CT_PROTO_UDPLITE=y # CONFIG_NF_CONNTRACK_AMANDA is not set CONFIG_NF_CONNTRACK_FTP=m # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set # CONFIG_NF_CONNTRACK_SIP is not set CONFIG_NF_CONNTRACK_TFTP=m # CONFIG_NF_CT_NETLINK is not set CONFIG_NF_NAT=m CONFIG_NF_NAT_FTP=m CONFIG_NF_NAT_TFTP=m CONFIG_NF_NAT_REDIRECT=y CONFIG_NF_NAT_MASQUERADE=y # CONFIG_NF_TABLES is not set CONFIG_NETFILTER_XTABLES=m CONFIG_NETFILTER_XTABLES_COMPAT=y # # Xtables combined modules # CONFIG_NETFILTER_XT_MARK=m # CONFIG_NETFILTER_XT_CONNMARK is not set # # Xtables targets # # CONFIG_NETFILTER_XT_TARGET_AUDIT is not set CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set # CONFIG_NETFILTER_XT_TARGET_DSCP is not set # CONFIG_NETFILTER_XT_TARGET_HL is not set # CONFIG_NETFILTER_XT_TARGET_HMARK is not set # CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set # CONFIG_NETFILTER_XT_TARGET_LED is not set CONFIG_NETFILTER_XT_TARGET_LOG=m # CONFIG_NETFILTER_XT_TARGET_MARK is not set CONFIG_NETFILTER_XT_NAT=m # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set CONFIG_NETFILTER_XT_TARGET_REDIRECT=m CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m # CONFIG_NETFILTER_XT_TARGET_TEE is not set # CONFIG_NETFILTER_XT_TARGET_TPROXY is not set # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set # # Xtables matches # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m # CONFIG_NETFILTER_XT_MATCH_BPF is not set # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m # CONFIG_NETFILTER_XT_MATCH_CPU is not set # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set # CONFIG_NETFILTER_XT_MATCH_DSCP is not set # CONFIG_NETFILTER_XT_MATCH_ECN is not set # CONFIG_NETFILTER_XT_MATCH_ESP is not set # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_HELPER is not set # CONFIG_NETFILTER_XT_MATCH_HL is not set # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set # CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set CONFIG_NETFILTER_XT_MATCH_IPVS=m # CONFIG_NETFILTER_XT_MATCH_L2TP is not set # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set # CONFIG_NETFILTER_XT_MATCH_LIMIT is not set # CONFIG_NETFILTER_XT_MATCH_MAC is not set # CONFIG_NETFILTER_XT_MATCH_MARK is not set # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set # CONFIG_NETFILTER_XT_MATCH_OSF is not set # CONFIG_NETFILTER_XT_MATCH_OWNER is not set # CONFIG_NETFILTER_XT_MATCH_POLICY is not set # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set # CONFIG_NETFILTER_XT_MATCH_REALM is not set # CONFIG_NETFILTER_XT_MATCH_RECENT is not set # CONFIG_NETFILTER_XT_MATCH_SCTP is not set # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set # CONFIG_NETFILTER_XT_MATCH_STATE is not set # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set # CONFIG_NETFILTER_XT_MATCH_STRING is not set # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set # CONFIG_NETFILTER_XT_MATCH_TIME is not set # CONFIG_NETFILTER_XT_MATCH_U32 is not set # end of Core Netfilter Configuration # CONFIG_IP_SET is not set CONFIG_IP_VS=m # CONFIG_IP_VS_IPV6 is not set # CONFIG_IP_VS_DEBUG is not set CONFIG_IP_VS_TAB_BITS=12 # # IPVS transport protocol load balancing support # CONFIG_IP_VS_PROTO_TCP=y CONFIG_IP_VS_PROTO_UDP=y # CONFIG_IP_VS_PROTO_ESP is not set # CONFIG_IP_VS_PROTO_AH is not set # CONFIG_IP_VS_PROTO_SCTP is not set # # IPVS scheduler # CONFIG_IP_VS_RR=m # CONFIG_IP_VS_WRR is not set # CONFIG_IP_VS_LC is not set # CONFIG_IP_VS_WLC is not set # CONFIG_IP_VS_FO is not set # CONFIG_IP_VS_OVF is not set # CONFIG_IP_VS_LBLC is not set # CONFIG_IP_VS_LBLCR is not set # CONFIG_IP_VS_DH is not set # CONFIG_IP_VS_SH is not set # CONFIG_IP_VS_MH is not set # CONFIG_IP_VS_SED is not set # CONFIG_IP_VS_NQ is not set # CONFIG_IP_VS_TWOS is not set # # IPVS SH scheduler # CONFIG_IP_VS_SH_TAB_BITS=8 # # IPVS MH scheduler # CONFIG_IP_VS_MH_TAB_INDEX=12 # # IPVS application helper # # CONFIG_IP_VS_FTP is not set CONFIG_IP_VS_NFCT=y # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m # CONFIG_NF_SOCKET_IPV4 is not set # CONFIG_NF_TPROXY_IPV4 is not set # CONFIG_NF_DUP_IPV4 is not set # CONFIG_NF_LOG_ARP is not set # CONFIG_NF_LOG_IPV4 is not set CONFIG_NF_REJECT_IPV4=m CONFIG_IP_NF_IPTABLES=m # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_RPFILTER is not set # CONFIG_IP_NF_MATCH_TTL is not set CONFIG_IP_NF_FILTER=m CONFIG_IP_NF_TARGET_REJECT=m # CONFIG_IP_NF_TARGET_SYNPROXY is not set CONFIG_IP_NF_NAT=m CONFIG_IP_NF_TARGET_MASQUERADE=m # CONFIG_IP_NF_TARGET_NETMAP is not set CONFIG_IP_NF_TARGET_REDIRECT=m CONFIG_IP_NF_MANGLE=m # CONFIG_IP_NF_TARGET_CLUSTERIP is not set # CONFIG_IP_NF_TARGET_ECN is not set # CONFIG_IP_NF_TARGET_TTL is not set # CONFIG_IP_NF_RAW is not set # CONFIG_IP_NF_SECURITY is not set # CONFIG_IP_NF_ARPTABLES is not set # end of IP: Netfilter Configuration # # IPv6: Netfilter Configuration # # CONFIG_NF_SOCKET_IPV6 is not set # CONFIG_NF_TPROXY_IPV6 is not set # CONFIG_NF_DUP_IPV6 is not set CONFIG_NF_REJECT_IPV6=m CONFIG_NF_LOG_IPV6=m CONFIG_IP6_NF_IPTABLES=m # CONFIG_IP6_NF_MATCH_AH is not set # CONFIG_IP6_NF_MATCH_EUI64 is not set # CONFIG_IP6_NF_MATCH_FRAG is not set # CONFIG_IP6_NF_MATCH_OPTS is not set # CONFIG_IP6_NF_MATCH_HL is not set # CONFIG_IP6_NF_MATCH_IPV6HEADER is not set # CONFIG_IP6_NF_MATCH_MH is not set # CONFIG_IP6_NF_MATCH_RPFILTER is not set # CONFIG_IP6_NF_MATCH_RT is not set # CONFIG_IP6_NF_MATCH_SRH is not set # CONFIG_IP6_NF_TARGET_HL is not set CONFIG_IP6_NF_FILTER=m CONFIG_IP6_NF_TARGET_REJECT=m # CONFIG_IP6_NF_TARGET_SYNPROXY is not set CONFIG_IP6_NF_MANGLE=m # CONFIG_IP6_NF_RAW is not set # CONFIG_IP6_NF_SECURITY is not set CONFIG_IP6_NF_NAT=m CONFIG_IP6_NF_TARGET_MASQUERADE=m # CONFIG_IP6_NF_TARGET_NPT is not set # end of IPv6: Netfilter Configuration CONFIG_NF_DEFRAG_IPV6=m # CONFIG_NF_CONNTRACK_BRIDGE is not set # CONFIG_BRIDGE_NF_EBTABLES is not set # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set CONFIG_STP=m CONFIG_GARP=m CONFIG_MRP=m CONFIG_BRIDGE=m CONFIG_BRIDGE_IGMP_SNOOPING=y CONFIG_BRIDGE_VLAN_FILTERING=y # CONFIG_BRIDGE_MRP is not set # CONFIG_BRIDGE_CFM is not set CONFIG_NET_DSA=m # CONFIG_NET_DSA_TAG_AR9331 is not set CONFIG_NET_DSA_TAG_BRCM_COMMON=m CONFIG_NET_DSA_TAG_BRCM=m CONFIG_NET_DSA_TAG_BRCM_LEGACY=m CONFIG_NET_DSA_TAG_BRCM_PREPEND=m # CONFIG_NET_DSA_TAG_HELLCREEK is not set # CONFIG_NET_DSA_TAG_GSWIP is not set # CONFIG_NET_DSA_TAG_DSA is not set # CONFIG_NET_DSA_TAG_EDSA is not set # CONFIG_NET_DSA_TAG_MTK is not set # CONFIG_NET_DSA_TAG_KSZ is not set CONFIG_NET_DSA_TAG_OCELOT=m CONFIG_NET_DSA_TAG_OCELOT_8021Q=m # CONFIG_NET_DSA_TAG_QCA is not set # CONFIG_NET_DSA_TAG_RTL4_A is not set # CONFIG_NET_DSA_TAG_RTL8_4 is not set # CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set # CONFIG_NET_DSA_TAG_LAN9303 is not set # CONFIG_NET_DSA_TAG_SJA1105 is not set # CONFIG_NET_DSA_TAG_TRAILER is not set # CONFIG_NET_DSA_TAG_XRS700X is not set CONFIG_VLAN_8021Q=m CONFIG_VLAN_8021Q_GVRP=y CONFIG_VLAN_8021Q_MVRP=y CONFIG_LLC=m # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set CONFIG_NET_SCHED=y # # Queueing/Scheduling # # CONFIG_NET_SCH_CBQ is not set # CONFIG_NET_SCH_HTB is not set # CONFIG_NET_SCH_HFSC is not set # CONFIG_NET_SCH_PRIO is not set # CONFIG_NET_SCH_MULTIQ is not set # CONFIG_NET_SCH_RED is not set # CONFIG_NET_SCH_SFB is not set # CONFIG_NET_SCH_SFQ is not set # CONFIG_NET_SCH_TEQL is not set # CONFIG_NET_SCH_TBF is not set CONFIG_NET_SCH_CBS=m CONFIG_NET_SCH_ETF=m CONFIG_NET_SCH_TAPRIO=m # CONFIG_NET_SCH_GRED is not set # CONFIG_NET_SCH_DSMARK is not set # CONFIG_NET_SCH_NETEM is not set # CONFIG_NET_SCH_DRR is not set CONFIG_NET_SCH_MQPRIO=m # CONFIG_NET_SCH_SKBPRIO is not set # CONFIG_NET_SCH_CHOKE is not set # CONFIG_NET_SCH_QFQ is not set # CONFIG_NET_SCH_CODEL is not set # CONFIG_NET_SCH_FQ_CODEL is not set # CONFIG_NET_SCH_CAKE is not set # CONFIG_NET_SCH_FQ is not set # CONFIG_NET_SCH_HHF is not set # CONFIG_NET_SCH_PIE is not set CONFIG_NET_SCH_INGRESS=m # CONFIG_NET_SCH_PLUG is not set # CONFIG_NET_SCH_ETS is not set # CONFIG_NET_SCH_DEFAULT is not set # # Classification # CONFIG_NET_CLS=y CONFIG_NET_CLS_BASIC=m CONFIG_NET_CLS_ROUTE4=m CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m # CONFIG_CLS_U32_PERF is not set CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_RSVP=m CONFIG_NET_CLS_RSVP6=m CONFIG_NET_CLS_FLOW=m CONFIG_NET_CLS_CGROUP=m # CONFIG_NET_CLS_BPF is not set CONFIG_NET_CLS_FLOWER=m # CONFIG_NET_CLS_MATCHALL is not set CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_STACK=32 CONFIG_NET_EMATCH_CMP=m CONFIG_NET_EMATCH_NBYTE=m CONFIG_NET_EMATCH_U32=m CONFIG_NET_EMATCH_META=m CONFIG_NET_EMATCH_TEXT=m # CONFIG_NET_EMATCH_CANID is not set # CONFIG_NET_EMATCH_IPT is not set CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=m CONFIG_NET_ACT_GACT=m CONFIG_GACT_PROB=y CONFIG_NET_ACT_MIRRED=m # CONFIG_NET_ACT_SAMPLE is not set CONFIG_NET_ACT_IPT=m CONFIG_NET_ACT_NAT=m CONFIG_NET_ACT_PEDIT=m CONFIG_NET_ACT_SIMP=m CONFIG_NET_ACT_SKBEDIT=m CONFIG_NET_ACT_CSUM=m # CONFIG_NET_ACT_MPLS is not set # CONFIG_NET_ACT_VLAN is not set # CONFIG_NET_ACT_BPF is not set # CONFIG_NET_ACT_SKBMOD is not set # CONFIG_NET_ACT_IFE is not set # CONFIG_NET_ACT_TUNNEL_KEY is not set CONFIG_NET_ACT_GATE=m # CONFIG_NET_TC_SKB_EXT is not set CONFIG_NET_SCH_FIFO=y # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set CONFIG_HSR=m CONFIG_NET_SWITCHDEV=y CONFIG_NET_L3_MASTER_DEV=y CONFIG_QRTR=m CONFIG_QRTR_SMD=m CONFIG_QRTR_TUN=m CONFIG_QRTR_MHI=m # CONFIG_NET_NCSI is not set CONFIG_PCPU_DEV_REFCNT=y CONFIG_RPS=y CONFIG_RFS_ACCEL=y CONFIG_SOCK_RX_QUEUE_MAPPING=y CONFIG_XPS=y CONFIG_CGROUP_NET_PRIO=y CONFIG_CGROUP_NET_CLASSID=y CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_STREAM_PARSER is not set CONFIG_NET_FLOW_LIMIT=y # # Network testing # # CONFIG_NET_PKTGEN is not set # end of Network testing # end of Networking options # CONFIG_HAMRADIO is not set CONFIG_CAN=m CONFIG_CAN_RAW=m CONFIG_CAN_BCM=m CONFIG_CAN_GW=m # CONFIG_CAN_J1939 is not set # CONFIG_CAN_ISOTP is not set CONFIG_BT=m CONFIG_BT_BREDR=y # CONFIG_BT_RFCOMM is not set # CONFIG_BT_BNEP is not set CONFIG_BT_HIDP=m # CONFIG_BT_HS is not set # CONFIG_BT_LE is not set CONFIG_BT_LEDS=y # CONFIG_BT_MSFTEXT is not set # CONFIG_BT_AOSPEXT is not set # CONFIG_BT_DEBUGFS is not set # CONFIG_BT_SELFTEST is not set # CONFIG_BT_FEATURE_DEBUG is not set # # Bluetooth device drivers # CONFIG_BT_INTEL=m CONFIG_BT_BCM=m CONFIG_BT_RTL=m CONFIG_BT_QCA=m CONFIG_BT_HCIBTUSB=m # CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set CONFIG_BT_HCIBTUSB_BCM=y # CONFIG_BT_HCIBTUSB_MTK is not set CONFIG_BT_HCIBTUSB_RTL=y # CONFIG_BT_HCIBTSDIO is not set CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_SERDEV=y CONFIG_BT_HCIUART_H4=y # CONFIG_BT_HCIUART_NOKIA is not set # CONFIG_BT_HCIUART_BCSP is not set # CONFIG_BT_HCIUART_ATH3K is not set CONFIG_BT_HCIUART_LL=y # CONFIG_BT_HCIUART_3WIRE is not set # CONFIG_BT_HCIUART_INTEL is not set CONFIG_BT_HCIUART_BCM=y # CONFIG_BT_HCIUART_RTL is not set CONFIG_BT_HCIUART_QCA=y # CONFIG_BT_HCIUART_AG6XX is not set CONFIG_BT_HCIUART_MRVL=y # CONFIG_BT_HCIBCM203X is not set # CONFIG_BT_HCIBPA10X is not set # CONFIG_BT_HCIBFUSB is not set # CONFIG_BT_HCIVHCI is not set CONFIG_BT_MRVL=m CONFIG_BT_MRVL_SDIO=m # CONFIG_BT_ATH3K is not set # CONFIG_BT_MTKSDIO is not set # CONFIG_BT_MTKUART is not set # CONFIG_BT_VIRTIO is not set # end of Bluetooth device drivers # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set # CONFIG_MCTP is not set CONFIG_WIRELESS=y CONFIG_CFG80211=m # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set # CONFIG_CFG80211_CERTIFICATION_ONUS is not set CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set CONFIG_MAC80211=m CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" # CONFIG_MAC80211_MESH is not set CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 CONFIG_RFKILL=m CONFIG_RFKILL_LEDS=y # CONFIG_RFKILL_INPUT is not set # CONFIG_RFKILL_GPIO is not set CONFIG_NET_9P=y CONFIG_NET_9P_FD=y CONFIG_NET_9P_VIRTIO=y # CONFIG_NET_9P_DEBUG is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set CONFIG_NFC=m # CONFIG_NFC_DIGITAL is not set CONFIG_NFC_NCI=m # CONFIG_NFC_NCI_SPI is not set # CONFIG_NFC_NCI_UART is not set # CONFIG_NFC_HCI is not set # # Near Field Communication (NFC) devices # # CONFIG_NFC_VIRTUAL_NCI is not set # CONFIG_NFC_FDP is not set # CONFIG_NFC_PN533_USB is not set # CONFIG_NFC_PN533_I2C is not set # CONFIG_NFC_PN532_UART is not set # CONFIG_NFC_MRVL_USB is not set # CONFIG_NFC_ST_NCI_I2C is not set # CONFIG_NFC_ST_NCI_SPI is not set # CONFIG_NFC_NXP_NCI is not set CONFIG_NFC_S3FWRN5=m CONFIG_NFC_S3FWRN5_I2C=m # CONFIG_NFC_S3FWRN82_UART is not set # end of Near Field Communication (NFC) devices # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y CONFIG_NET_SELFTESTS=y CONFIG_NET_SOCK_MSG=y CONFIG_NET_DEVLINK=y CONFIG_PAGE_POOL=y CONFIG_PAGE_POOL_STATS=y CONFIG_FAILOVER=y CONFIG_ETHTOOL_NETLINK=y # # Device Drivers # CONFIG_ARM_AMBA=y CONFIG_HAVE_PCI=y CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_DOMAINS_GENERIC=y CONFIG_PCI_SYSCALL=y CONFIG_PCIEPORTBUS=y # CONFIG_HOTPLUG_PCI_PCIE is not set CONFIG_PCIEAER=y # CONFIG_PCIEAER_INJECT is not set # CONFIG_PCIE_ECRC is not set CONFIG_PCIEASPM=y CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_POWER_SUPERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCIE_DPC is not set # CONFIG_PCIE_PTM is not set CONFIG_PCI_MSI=y CONFIG_PCI_MSI_IRQ_DOMAIN=y CONFIG_PCI_QUIRKS=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set # CONFIG_PCI_STUB is not set # CONFIG_PCI_PF_STUB is not set CONFIG_PCI_ATS=y CONFIG_PCI_ECAM=y CONFIG_PCI_IOV=y # CONFIG_PCI_PRI is not set CONFIG_PCI_PASID=y CONFIG_PCI_LABEL=y # CONFIG_PCIE_BUS_TUNE_OFF is not set CONFIG_PCIE_BUS_DEFAULT=y # CONFIG_PCIE_BUS_SAFE is not set # CONFIG_PCIE_BUS_PERFORMANCE is not set # CONFIG_PCIE_BUS_PEER2PEER is not set # CONFIG_VGA_ARB is not set CONFIG_HOTPLUG_PCI=y # CONFIG_HOTPLUG_PCI_CPCI is not set # CONFIG_HOTPLUG_PCI_SHPC is not set # # PCI controller drivers # # CONFIG_PCI_FTPCI100 is not set CONFIG_PCI_HOST_COMMON=y CONFIG_PCI_HOST_GENERIC=y # CONFIG_PCIE_XILINX is not set # CONFIG_PCI_XGENE is not set CONFIG_PCIE_ALTERA=y CONFIG_PCIE_ALTERA_MSI=y CONFIG_PCI_HOST_THUNDER_PEM=y CONFIG_PCI_HOST_THUNDER_ECAM=y # CONFIG_PCIE_MICROCHIP_HOST is not set # # DesignWare PCI Core Support # CONFIG_PCIE_DW=y CONFIG_PCIE_DW_HOST=y CONFIG_PCIE_DW_EP=y # CONFIG_PCIE_DW_PLAT_HOST is not set # CONFIG_PCIE_DW_PLAT_EP is not set CONFIG_PCI_KEYSTONE=y CONFIG_PCI_KEYSTONE_HOST=y CONFIG_PCI_KEYSTONE_EP=y # CONFIG_PCI_HISI is not set # CONFIG_PCIE_KIRIN is not set CONFIG_PCI_MESON=m # CONFIG_PCIE_AL is not set # end of DesignWare PCI Core Support # # Mobiveil PCIe Core Support # # end of Mobiveil PCIe Core Support # # Cadence PCIe controllers support # CONFIG_PCIE_CADENCE=m CONFIG_PCIE_CADENCE_HOST=m CONFIG_PCIE_CADENCE_EP=m # CONFIG_PCIE_CADENCE_PLAT_HOST is not set # CONFIG_PCIE_CADENCE_PLAT_EP is not set CONFIG_PCI_J721E=m CONFIG_PCI_J721E_HOST=m CONFIG_PCI_J721E_EP=m # end of Cadence PCIe controllers support # end of PCI controller drivers # # PCI Endpoint # CONFIG_PCI_ENDPOINT=y CONFIG_PCI_ENDPOINT_CONFIGFS=y CONFIG_PCI_EPF_TEST=y CONFIG_PCI_EPF_NTB=y # end of PCI Endpoint # # PCI switch controller drivers # # CONFIG_PCI_SW_SWITCHTEC is not set # end of PCI switch controller drivers # CONFIG_CXL_BUS is not set # CONFIG_PCCARD is not set # CONFIG_RAPIDIO is not set # # Generic Driver Options # CONFIG_AUXILIARY_BUS=y # CONFIG_UEVENT_HELPER is not set CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y # CONFIG_DEVTMPFS_SAFE is not set CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_FW_LOADER_PAGED_BUF=y CONFIG_FW_LOADER_SYSFS=y CONFIG_EXTRA_FIRMWARE="" CONFIG_FW_LOADER_USER_HELPER=y # CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set # CONFIG_FW_LOADER_COMPRESS is not set CONFIG_FW_CACHE=y # CONFIG_FW_UPLOAD is not set # end of Firmware loader CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_GENERIC_CPU_VULNERABILITIES=y CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SLIMBUS=m CONFIG_REGMAP_SPI=y CONFIG_REGMAP_SPMI=m CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_REGMAP_SOUNDWIRE=m CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set CONFIG_GENERIC_ARCH_TOPOLOGY=y # end of Generic Driver Options # # Bus devices # CONFIG_ARM_CCI=y CONFIG_ARM_CCI400_COMMON=y CONFIG_BRCMSTB_GISB_ARB=y # CONFIG_MOXTET is not set CONFIG_VEXPRESS_CONFIG=y CONFIG_MHI_BUS=m # CONFIG_MHI_BUS_DEBUG is not set # CONFIG_MHI_BUS_PCI_GENERIC is not set # CONFIG_MHI_BUS_EP is not set # end of Bus devices # CONFIG_CONNECTOR is not set # # Firmware Drivers # # # ARM System Control and Management Interface Protocol # CONFIG_ARM_SCMI_PROTOCOL=y CONFIG_ARM_SCMI_HAVE_TRANSPORT=y CONFIG_ARM_SCMI_HAVE_SHMEM=y CONFIG_ARM_SCMI_HAVE_MSG=y CONFIG_ARM_SCMI_TRANSPORT_MAILBOX=y CONFIG_ARM_SCMI_TRANSPORT_OPTEE=y CONFIG_ARM_SCMI_TRANSPORT_SMC=y # CONFIG_ARM_SCMI_TRANSPORT_SMC_ATOMIC_ENABLE is not set # CONFIG_ARM_SCMI_TRANSPORT_VIRTIO is not set CONFIG_ARM_SCMI_POWER_DOMAIN=y # CONFIG_ARM_SCMI_POWER_CONTROL is not set # end of ARM System Control and Management Interface Protocol # CONFIG_ARM_SCPI_PROTOCOL is not set # CONFIG_FIRMWARE_MEMMAP is not set CONFIG_DMIID=y # CONFIG_DMI_SYSFS is not set # CONFIG_FW_CFG_SYSFS is not set # CONFIG_SYSFB_SIMPLEFB is not set CONFIG_TI_SCI_PROTOCOL=y # CONFIG_ARM_FFA_TRANSPORT is not set # CONFIG_GOOGLE_FIRMWARE is not set # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_ESRT=y CONFIG_EFI_VARS_PSTORE=y # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_GENERIC_STUB=y # CONFIG_EFI_ZBOOT is not set CONFIG_EFI_ARMSTUB_DTB_LOADER=y # CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set # CONFIG_EFI_BOOTLOADER_CONTROL is not set CONFIG_EFI_CAPSULE_LOADER=y # CONFIG_EFI_TEST is not set # CONFIG_RESET_ATTACK_MITIGATION is not set # CONFIG_EFI_DISABLE_PCI_DMA is not set CONFIG_EFI_EARLYCON=y # CONFIG_EFI_DISABLE_RUNTIME is not set # CONFIG_EFI_COCO_SECRET is not set # end of EFI (Extensible Firmware Interface) Support CONFIG_ARM_PSCI_FW=y # CONFIG_ARM_PSCI_CHECKER is not set CONFIG_HAVE_ARM_SMCCC=y CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y CONFIG_ARM_SMCCC_SOC_ID=y # # Tegra firmware driver # # end of Tegra firmware driver # end of Firmware Drivers CONFIG_GNSS=m CONFIG_GNSS_SERIAL=m CONFIG_GNSS_MTK_SERIAL=m # CONFIG_GNSS_SIRF_SERIAL is not set # CONFIG_GNSS_UBX_SERIAL is not set # CONFIG_GNSS_USB is not set CONFIG_MTD=y CONFIG_MTD_TESTS=m # # Partition parsers # # CONFIG_MTD_AR7_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set # end of Partition parsers # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # # Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK. # # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # CONFIG_MTD_CFI=y # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_GEN_PROBE=y CONFIG_MTD_CFI_ADV_OPTIONS=y CONFIG_MTD_CFI_NOSWAP=y # CONFIG_MTD_CFI_BE_BYTE_SWAP is not set # CONFIG_MTD_CFI_LE_BYTE_SWAP is not set # CONFIG_MTD_CFI_GEOMETRY is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_OTP is not set CONFIG_MTD_CFI_INTELEXT=y CONFIG_MTD_CFI_AMDSTD=y CONFIG_MTD_CFI_STAA=y CONFIG_MTD_CFI_UTIL=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # end of RAM/ROM/Flash chip drivers # # Mapping drivers for chip access # CONFIG_MTD_COMPLEX_MAPPINGS=y CONFIG_MTD_PHYSMAP=y # CONFIG_MTD_PHYSMAP_COMPAT is not set CONFIG_MTD_PHYSMAP_OF=y # CONFIG_MTD_PHYSMAP_VERSATILE is not set # CONFIG_MTD_PHYSMAP_GEMINI is not set # CONFIG_MTD_PHYSMAP_GPIO_ADDR is not set # CONFIG_MTD_PCI is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # end of Mapping drivers for chip access # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set CONFIG_MTD_DATAFLASH=y # CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set # CONFIG_MTD_DATAFLASH_OTP is not set # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_MCHP48L640 is not set CONFIG_MTD_SST25L=y # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # end of Self-contained MTD device drivers # # NAND # CONFIG_MTD_NAND_CORE=y # CONFIG_MTD_ONENAND is not set CONFIG_MTD_RAW_NAND=y # # Raw/parallel NAND flash controllers # CONFIG_MTD_NAND_DENALI=y # CONFIG_MTD_NAND_DENALI_PCI is not set CONFIG_MTD_NAND_DENALI_DT=y CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_OMAP_BCH=y CONFIG_MTD_NAND_OMAP_BCH_BUILD=y # CONFIG_MTD_NAND_CAFE is not set CONFIG_MTD_NAND_BRCMNAND=m # CONFIG_MTD_NAND_BRCMNAND_BCM63XX is not set CONFIG_MTD_NAND_BRCMNAND_BCMBCA=m CONFIG_MTD_NAND_BRCMNAND_BRCMSTB=m CONFIG_MTD_NAND_BRCMNAND_IPROC=m # CONFIG_MTD_NAND_MXIC is not set # CONFIG_MTD_NAND_GPIO is not set # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_NAND_CADENCE is not set # CONFIG_MTD_NAND_ARASAN is not set # CONFIG_MTD_NAND_INTEL_LGM is not set # # Misc # # CONFIG_MTD_NAND_NANDSIM is not set # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set CONFIG_MTD_SPI_NAND=y # # ECC engine support # CONFIG_MTD_NAND_ECC=y CONFIG_MTD_NAND_ECC_SW_HAMMING=y # CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set # CONFIG_MTD_NAND_ECC_SW_BCH is not set # CONFIG_MTD_NAND_ECC_MXIC is not set # end of ECC engine support # end of NAND # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # end of LPDDR & LPDDR2 PCM memory drivers CONFIG_MTD_SPI_NOR=y CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y # CONFIG_MTD_SPI_NOR_SWP_DISABLE is not set CONFIG_MTD_SPI_NOR_SWP_DISABLE_ON_VOLATILE=y # CONFIG_MTD_SPI_NOR_SWP_KEEP is not set CONFIG_MTD_UBI=m CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set # CONFIG_MTD_UBI_BLOCK is not set CONFIG_MTD_HYPERBUS=m CONFIG_HBMC_AM654=m CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set # CONFIG_ZRAM is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_DRBD is not set CONFIG_BLK_DEV_NBD=m # CONFIG_BLK_DEV_RAM is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set CONFIG_VIRTIO_BLK=y # CONFIG_BLK_DEV_RBD is not set # CONFIG_BLK_DEV_UBLK is not set # # NVME Support # CONFIG_NVME_CORE=m CONFIG_BLK_DEV_NVME=m # CONFIG_NVME_MULTIPATH is not set # CONFIG_NVME_VERBOSE_ERRORS is not set # CONFIG_NVME_HWMON is not set # CONFIG_NVME_FC is not set # CONFIG_NVME_TCP is not set # CONFIG_NVME_AUTH is not set # CONFIG_NVME_TARGET is not set # end of NVME Support # # Misc devices # # CONFIG_AD525X_DPOT is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_PHANTOM is not set # CONFIG_TIFM_CORE is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HI6421V600_IRQ is not set # CONFIG_HP_ILO is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set CONFIG_SRAM=y CONFIG_SRAM_DMA_HEAP=y # CONFIG_DW_XDATA_PCIE is not set CONFIG_PCI_ENDPOINT_TEST=m # CONFIG_XILINX_SDFEC is not set # CONFIG_HISI_HIKEY_USB is not set # CONFIG_OPEN_DICE is not set # CONFIG_VCPU_STALL_DETECTOR is not set CONFIG_DMA_BUF_PHYS=y CONFIG_TPS6594_ESM=y CONFIG_TPS6594_PFSM=y # CONFIG_C2PORT is not set # # EEPROM support # CONFIG_EEPROM_AT24=m CONFIG_EEPROM_AT25=m # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # end of EEPROM support # CONFIG_CB710_CORE is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # end of Texas Instruments shared transport line discipline # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # CONFIG_VMWARE_VMCI is not set # CONFIG_GENWQE is not set # CONFIG_ECHO is not set # CONFIG_BCM_VK is not set # CONFIG_MISC_ALCOR_PCI is not set # CONFIG_MISC_RTSX_PCI is not set # CONFIG_MISC_RTSX_USB is not set # CONFIG_HABANA_AI is not set CONFIG_UACCE=m # CONFIG_PVPANIC is not set # CONFIG_GP_PCI1XXXX is not set # end of Misc devices # # SCSI device support # CONFIG_SCSI_MOD=y CONFIG_RAID_ATTRS=m CONFIG_SCSI_COMMON=y CONFIG_SCSI=y CONFIG_SCSI_DMA=y # CONFIG_SCSI_PROC_FS is not set # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_BLK_DEV_SR is not set # CONFIG_CHR_DEV_SG is not set CONFIG_BLK_DEV_BSG=y # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set CONFIG_SCSI_SAS_ATTRS=y CONFIG_SCSI_SAS_LIBSAS=y CONFIG_SCSI_SAS_ATA=y CONFIG_SCSI_SAS_HOST_SMP=y # CONFIG_SCSI_SRP_ATTRS is not set # end of SCSI Transports CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_CXGB3_ISCSI is not set # CONFIG_SCSI_CXGB4_ISCSI is not set # CONFIG_SCSI_BNX2_ISCSI is not set # CONFIG_BE2ISCSI is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_HPSA is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_3W_SAS is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_AIC94XX is not set CONFIG_SCSI_HISI_SAS=y # CONFIG_SCSI_HISI_SAS_DEBUGFS_DEFAULT_ENABLE is not set # CONFIG_SCSI_MVSAS is not set # CONFIG_SCSI_MVUMI is not set # CONFIG_SCSI_ADVANSYS is not set # CONFIG_SCSI_ARCMSR is not set # CONFIG_SCSI_ESAS2R is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set CONFIG_MEGARAID_SAS=y CONFIG_SCSI_MPT3SAS=m CONFIG_SCSI_MPT2SAS_MAX_SGE=128 CONFIG_SCSI_MPT3SAS_MAX_SGE=128 # CONFIG_SCSI_MPT2SAS is not set # CONFIG_SCSI_MPI3MR is not set # CONFIG_SCSI_SMARTPQI is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_SCSI_BUSLOGIC is not set # CONFIG_SCSI_MYRB is not set # CONFIG_SCSI_MYRS is not set # CONFIG_SCSI_SNIC is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_FDOMAIN_PCI is not set # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_STEX is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_ISCSI is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_AM53C974 is not set # CONFIG_SCSI_WD719X is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_PMCRAID is not set # CONFIG_SCSI_PM8001 is not set # CONFIG_SCSI_VIRTIO is not set # CONFIG_SCSI_DH is not set # end of SCSI device support CONFIG_ATA=y CONFIG_SATA_HOST=y CONFIG_ATA_VERBOSE_ERROR=y CONFIG_ATA_FORCE=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # CONFIG_SATA_AHCI=y CONFIG_SATA_MOBILE_LPM_POLICY=0 CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_AHCI_DWC is not set CONFIG_AHCI_CEVA=y CONFIG_AHCI_XGENE=y CONFIG_AHCI_QORIQ=y # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set CONFIG_SATA_SIL24=y CONFIG_ATA_SFF=y # # SFF controllers with custom DMA interface # # CONFIG_PDC_ADMA is not set # CONFIG_SATA_QSTOR is not set # CONFIG_SATA_SX4 is not set CONFIG_ATA_BMDMA=y # # SATA SFF controllers with BMDMA # # CONFIG_ATA_PIIX is not set # CONFIG_SATA_DWC is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_NV is not set # CONFIG_SATA_PROMISE is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIS is not set # CONFIG_SATA_SVW is not set # CONFIG_SATA_ULI is not set # CONFIG_SATA_VIA is not set # CONFIG_SATA_VITESSE is not set # # PATA SFF controllers with BMDMA # # CONFIG_PATA_ALI is not set # CONFIG_PATA_AMD is not set # CONFIG_PATA_ARTOP is not set # CONFIG_PATA_ATIIXP is not set # CONFIG_PATA_ATP867X is not set # CONFIG_PATA_CMD64X is not set # CONFIG_PATA_CYPRESS is not set # CONFIG_PATA_EFAR is not set # CONFIG_PATA_HPT366 is not set # CONFIG_PATA_HPT37X is not set # CONFIG_PATA_HPT3X2N is not set # CONFIG_PATA_HPT3X3 is not set # CONFIG_PATA_IT8213 is not set # CONFIG_PATA_IT821X is not set # CONFIG_PATA_JMICRON is not set # CONFIG_PATA_MARVELL is not set # CONFIG_PATA_NETCELL is not set # CONFIG_PATA_NINJA32 is not set # CONFIG_PATA_NS87415 is not set # CONFIG_PATA_OLDPIIX is not set # CONFIG_PATA_OPTIDMA is not set # CONFIG_PATA_PDC2027X is not set # CONFIG_PATA_PDC_OLD is not set # CONFIG_PATA_RADISYS is not set # CONFIG_PATA_RDC is not set # CONFIG_PATA_SCH is not set # CONFIG_PATA_SERVERWORKS is not set # CONFIG_PATA_SIL680 is not set # CONFIG_PATA_SIS is not set # CONFIG_PATA_TOSHIBA is not set # CONFIG_PATA_TRIFLEX is not set # CONFIG_PATA_VIA is not set # CONFIG_PATA_WINBOND is not set # # PIO-only SFF controllers # # CONFIG_PATA_CMD640_PCI is not set # CONFIG_PATA_MPIIX is not set # CONFIG_PATA_NS87410 is not set # CONFIG_PATA_OPTI is not set CONFIG_PATA_PLATFORM=y CONFIG_PATA_OF_PLATFORM=y # CONFIG_PATA_RZ1000 is not set # # Generic fallback / legacy drivers # # CONFIG_ATA_GENERIC is not set # CONFIG_PATA_LEGACY is not set CONFIG_MD=y CONFIG_BLK_DEV_MD=m # CONFIG_MD_LINEAR is not set # CONFIG_MD_RAID0 is not set # CONFIG_MD_RAID1 is not set # CONFIG_MD_RAID10 is not set # CONFIG_MD_RAID456 is not set # CONFIG_MD_MULTIPATH is not set # CONFIG_MD_FAULTY is not set # CONFIG_BCACHE is not set CONFIG_BLK_DEV_DM_BUILTIN=y CONFIG_BLK_DEV_DM=m # CONFIG_DM_DEBUG is not set CONFIG_DM_BUFIO=m # CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set CONFIG_DM_BIO_PRISON=m CONFIG_DM_PERSISTENT_DATA=m # CONFIG_DM_UNSTRIPED is not set # CONFIG_DM_CRYPT is not set # CONFIG_DM_SNAPSHOT is not set CONFIG_DM_THIN_PROVISIONING=m # CONFIG_DM_CACHE is not set # CONFIG_DM_WRITECACHE is not set # CONFIG_DM_EBS is not set # CONFIG_DM_ERA is not set # CONFIG_DM_CLONE is not set CONFIG_DM_MIRROR=m # CONFIG_DM_LOG_USERSPACE is not set # CONFIG_DM_RAID is not set CONFIG_DM_ZERO=m # CONFIG_DM_MULTIPATH is not set # CONFIG_DM_DELAY is not set # CONFIG_DM_DUST is not set # CONFIG_DM_UEVENT is not set # CONFIG_DM_FLAKEY is not set # CONFIG_DM_VERITY is not set # CONFIG_DM_SWITCH is not set # CONFIG_DM_LOG_WRITES is not set # CONFIG_DM_INTEGRITY is not set # CONFIG_DM_AUDIT is not set # CONFIG_TARGET_CORE is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set # end of IEEE 1394 (FireWire) support CONFIG_NETDEVICES=y CONFIG_MII=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set CONFIG_DUMMY=m # CONFIG_WIREGUARD is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_FC is not set # CONFIG_IFB is not set # CONFIG_NET_TEAM is not set CONFIG_MACVLAN=m CONFIG_MACVTAP=m CONFIG_IPVLAN_L3S=y CONFIG_IPVLAN=m # CONFIG_IPVTAP is not set CONFIG_VXLAN=m # CONFIG_GENEVE is not set # CONFIG_BAREUDP is not set # CONFIG_GTP is not set # CONFIG_AMT is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set CONFIG_TUN=y CONFIG_TAP=m # CONFIG_TUN_VNET_CROSS_LE is not set CONFIG_VETH=m CONFIG_VIRTIO_NET=y # CONFIG_NLMON is not set # CONFIG_MHI_NET is not set # CONFIG_ARCNET is not set # # Distributed Switch Architecture drivers # CONFIG_B53=m # CONFIG_B53_SPI_DRIVER is not set # CONFIG_B53_MDIO_DRIVER is not set # CONFIG_B53_MMAP_DRIVER is not set CONFIG_B53_SRAB_DRIVER=m # CONFIG_B53_SERDES is not set CONFIG_NET_DSA_BCM_SF2=m # CONFIG_NET_DSA_LOOP is not set # CONFIG_NET_DSA_HIRSCHMANN_HELLCREEK is not set # CONFIG_NET_DSA_LANTIQ_GSWIP is not set # CONFIG_NET_DSA_MT7530 is not set # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON is not set # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_MSCC_SEVILLE is not set # CONFIG_NET_DSA_AR9331 is not set # CONFIG_NET_DSA_QCA8K is not set # CONFIG_NET_DSA_SJA1105 is not set # CONFIG_NET_DSA_XRS700X_I2C is not set # CONFIG_NET_DSA_XRS700X_MDIO is not set # CONFIG_NET_DSA_REALTEK is not set # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set # end of Distributed Switch Architecture drivers CONFIG_ETHERNET=y CONFIG_MDIO=m CONFIG_NET_VENDOR_3COM=y # CONFIG_VORTEX is not set # CONFIG_TYPHOON is not set CONFIG_NET_VENDOR_ADAPTEC=y # CONFIG_ADAPTEC_STARFIRE is not set CONFIG_NET_VENDOR_AGERE=y # CONFIG_ET131X is not set CONFIG_NET_VENDOR_ALACRITECH=y # CONFIG_SLICOSS is not set CONFIG_NET_VENDOR_ALTEON=y # CONFIG_ACENIC is not set # CONFIG_ALTERA_TSE is not set CONFIG_NET_VENDOR_AMAZON=y # CONFIG_ENA_ETHERNET is not set CONFIG_NET_VENDOR_AMD=y # CONFIG_AMD8111_ETH is not set # CONFIG_PCNET32 is not set CONFIG_AMD_XGBE=y CONFIG_NET_VENDOR_AQUANTIA=y # CONFIG_AQTION is not set CONFIG_NET_VENDOR_ARC=y CONFIG_NET_VENDOR_ASIX=y # CONFIG_SPI_AX88796C is not set CONFIG_NET_VENDOR_ATHEROS=y # CONFIG_ATL2 is not set # CONFIG_ATL1 is not set # CONFIG_ATL1E is not set CONFIG_ATL1C=m # CONFIG_ALX is not set CONFIG_NET_VENDOR_BROADCOM=y # CONFIG_B44 is not set CONFIG_BCMGENET=m # CONFIG_BNX2 is not set # CONFIG_CNIC is not set # CONFIG_TIGON3 is not set CONFIG_BNX2X=m CONFIG_BNX2X_SRIOV=y CONFIG_SYSTEMPORT=m # CONFIG_BNXT is not set CONFIG_NET_VENDOR_CADENCE=y CONFIG_MACB=y CONFIG_MACB_USE_HWSTAMP=y # CONFIG_MACB_PCI is not set CONFIG_NET_VENDOR_CAVIUM=y CONFIG_THUNDER_NIC_PF=y # CONFIG_THUNDER_NIC_VF is not set CONFIG_THUNDER_NIC_BGX=y CONFIG_THUNDER_NIC_RGX=y # CONFIG_CAVIUM_PTP is not set # CONFIG_LIQUIDIO is not set # CONFIG_LIQUIDIO_VF is not set CONFIG_NET_VENDOR_CHELSIO=y # CONFIG_CHELSIO_T1 is not set # CONFIG_CHELSIO_T3 is not set # CONFIG_CHELSIO_T4 is not set # CONFIG_CHELSIO_T4VF is not set CONFIG_NET_VENDOR_CISCO=y # CONFIG_ENIC is not set CONFIG_NET_VENDOR_CORTINA=y # CONFIG_GEMINI_ETHERNET is not set CONFIG_NET_VENDOR_DAVICOM=y # CONFIG_DM9051 is not set # CONFIG_DNET is not set CONFIG_NET_VENDOR_DEC=y # CONFIG_NET_TULIP is not set CONFIG_NET_VENDOR_DLINK=y # CONFIG_DL2K is not set # CONFIG_SUNDANCE is not set CONFIG_NET_VENDOR_EMULEX=y # CONFIG_BE2NET is not set CONFIG_NET_VENDOR_ENGLEDER=y # CONFIG_TSNEP is not set CONFIG_NET_VENDOR_EZCHIP=y # CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set CONFIG_NET_VENDOR_FUNGIBLE=y # CONFIG_FUN_ETH is not set CONFIG_NET_VENDOR_GOOGLE=y # CONFIG_GVE is not set CONFIG_NET_VENDOR_HISILICON=y CONFIG_HIX5HD2_GMAC=y # CONFIG_HISI_FEMAC is not set # CONFIG_HIP04_ETH is not set CONFIG_HNS_MDIO=y CONFIG_HNS=y CONFIG_HNS_DSAF=y CONFIG_HNS_ENET=y CONFIG_HNS3=y CONFIG_HNS3_HCLGE=y # CONFIG_HNS3_HCLGEVF is not set CONFIG_HNS3_ENET=y CONFIG_NET_VENDOR_HUAWEI=y # CONFIG_HINIC is not set CONFIG_NET_VENDOR_I825XX=y CONFIG_NET_VENDOR_INTEL=y # CONFIG_E100 is not set CONFIG_E1000=y CONFIG_E1000E=y CONFIG_IGB=y CONFIG_IGB_HWMON=y CONFIG_IGBVF=y # CONFIG_IXGB is not set # CONFIG_IXGBE is not set # CONFIG_IXGBEVF is not set # CONFIG_I40E is not set # CONFIG_I40EVF is not set # CONFIG_ICE is not set # CONFIG_FM10K is not set # CONFIG_IGC is not set CONFIG_NET_VENDOR_WANGXUN=y # CONFIG_NGBE is not set # CONFIG_TXGBE is not set # CONFIG_JME is not set CONFIG_NET_VENDOR_ADI=y # CONFIG_ADIN1110 is not set CONFIG_NET_VENDOR_LITEX=y # CONFIG_LITEX_LITEETH is not set CONFIG_NET_VENDOR_MARVELL=y CONFIG_MVMDIO=y # CONFIG_SKGE is not set CONFIG_SKY2=y # CONFIG_SKY2_DEBUG is not set # CONFIG_OCTEONTX2_AF is not set # CONFIG_OCTEONTX2_PF is not set # CONFIG_OCTEON_EP is not set # CONFIG_PRESTERA is not set CONFIG_NET_VENDOR_MELLANOX=y CONFIG_MLX4_EN=m CONFIG_MLX4_CORE=m CONFIG_MLX4_DEBUG=y CONFIG_MLX4_CORE_GEN2=y CONFIG_MLX5_CORE=m # CONFIG_MLX5_FPGA is not set CONFIG_MLX5_CORE_EN=y CONFIG_MLX5_EN_ARFS=y CONFIG_MLX5_EN_RXNFC=y CONFIG_MLX5_MPFS=y CONFIG_MLX5_ESWITCH=y CONFIG_MLX5_BRIDGE=y CONFIG_MLX5_CLS_ACT=y CONFIG_MLX5_TC_SAMPLE=y # CONFIG_MLX5_CORE_IPOIB is not set CONFIG_MLX5_SW_STEERING=y # CONFIG_MLX5_SF is not set # CONFIG_MLXSW_CORE is not set # CONFIG_MLXFW is not set CONFIG_NET_VENDOR_MICREL=y # CONFIG_KS8842 is not set # CONFIG_KS8851 is not set # CONFIG_KS8851_MLL is not set # CONFIG_KSZ884X_PCI is not set CONFIG_NET_VENDOR_MICROCHIP=y # CONFIG_ENC28J60 is not set # CONFIG_ENCX24J600 is not set # CONFIG_LAN743X is not set # CONFIG_LAN966X_SWITCH is not set CONFIG_NET_VENDOR_MICROSEMI=y # CONFIG_MSCC_OCELOT_SWITCH is not set CONFIG_NET_VENDOR_MICROSOFT=y CONFIG_NET_VENDOR_MYRI=y # CONFIG_MYRI10GE is not set # CONFIG_FEALNX is not set CONFIG_NET_VENDOR_NI=y # CONFIG_NI_XGE_MANAGEMENT_ENET is not set CONFIG_NET_VENDOR_NATSEMI=y # CONFIG_NATSEMI is not set # CONFIG_NS83820 is not set CONFIG_NET_VENDOR_NETERION=y # CONFIG_S2IO is not set CONFIG_NET_VENDOR_NETRONOME=y # CONFIG_NFP is not set CONFIG_NET_VENDOR_8390=y # CONFIG_NE2K_PCI is not set CONFIG_NET_VENDOR_NVIDIA=y # CONFIG_FORCEDETH is not set CONFIG_NET_VENDOR_OKI=y # CONFIG_ETHOC is not set CONFIG_NET_VENDOR_PACKET_ENGINES=y # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set CONFIG_NET_VENDOR_PENSANDO=y # CONFIG_IONIC is not set CONFIG_NET_VENDOR_QLOGIC=y # CONFIG_QLA3XXX is not set # CONFIG_QLCNIC is not set # CONFIG_NETXEN_NIC is not set # CONFIG_QED is not set CONFIG_NET_VENDOR_BROCADE=y # CONFIG_BNA is not set CONFIG_NET_VENDOR_QUALCOMM=y # CONFIG_QCA7000_SPI is not set # CONFIG_QCA7000_UART is not set CONFIG_QCOM_EMAC=m CONFIG_RMNET=m CONFIG_NET_VENDOR_RDC=y # CONFIG_R6040 is not set CONFIG_NET_VENDOR_REALTEK=y # CONFIG_8139CP is not set # CONFIG_8139TOO is not set CONFIG_R8169=m CONFIG_NET_VENDOR_RENESAS=y CONFIG_NET_VENDOR_ROCKER=y # CONFIG_ROCKER is not set CONFIG_NET_VENDOR_SAMSUNG=y # CONFIG_SXGBE_ETH is not set CONFIG_NET_VENDOR_SEEQ=y CONFIG_NET_VENDOR_SILAN=y # CONFIG_SC92031 is not set CONFIG_NET_VENDOR_SIS=y # CONFIG_SIS900 is not set # CONFIG_SIS190 is not set CONFIG_NET_VENDOR_SOLARFLARE=y # CONFIG_SFC is not set # CONFIG_SFC_FALCON is not set # CONFIG_SFC_SIENA is not set CONFIG_NET_VENDOR_SMSC=y CONFIG_SMC91X=y # CONFIG_EPIC100 is not set CONFIG_SMSC911X=y # CONFIG_SMSC9420 is not set CONFIG_NET_VENDOR_SOCIONEXT=y CONFIG_NET_VENDOR_STMICRO=y CONFIG_STMMAC_ETH=m # CONFIG_STMMAC_SELFTESTS is not set CONFIG_STMMAC_PLATFORM=m # CONFIG_DWMAC_DWC_QOS_ETH is not set CONFIG_DWMAC_GENERIC=m # CONFIG_DWMAC_INTEL_PLAT is not set # CONFIG_DWMAC_LOONGSON is not set # CONFIG_STMMAC_PCI is not set CONFIG_NET_VENDOR_SUN=y # CONFIG_HAPPYMEAL is not set # CONFIG_SUNGEM is not set # CONFIG_CASSINI is not set # CONFIG_NIU is not set CONFIG_NET_VENDOR_SYNOPSYS=y # CONFIG_DWC_XLGMAC is not set CONFIG_NET_VENDOR_TEHUTI=y # CONFIG_TEHUTI is not set CONFIG_NET_VENDOR_TI=y CONFIG_TI_DAVINCI_MDIO=y # CONFIG_TI_CPSW_PHY_SEL is not set CONFIG_TI_K3_AM65_CPSW_NUSS=y CONFIG_TI_K3_AM65_CPSW_SWITCHDEV=y CONFIG_TI_K3_AM65_CPTS=y CONFIG_TI_AM65_CPSW_TAS=y # CONFIG_TLAN is not set CONFIG_TI_RDEV_ETH_SWITCH_VIRT_EMAC=m CONFIG_TI_ICSSG_PRUETH=m CONFIG_TI_ICSS_IEP=m CONFIG_NET_VENDOR_VERTEXCOM=y # CONFIG_MSE102X is not set CONFIG_NET_VENDOR_VIA=y # CONFIG_VIA_RHINE is not set # CONFIG_VIA_VELOCITY is not set CONFIG_NET_VENDOR_WIZNET=y # CONFIG_WIZNET_W5100 is not set # CONFIG_WIZNET_W5300 is not set CONFIG_NET_VENDOR_XILINX=y # CONFIG_XILINX_EMACLITE is not set # CONFIG_XILINX_AXI_EMAC is not set # CONFIG_XILINX_LL_TEMAC is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set CONFIG_PHYLINK=y CONFIG_PHYLIB=y CONFIG_SWPHY=y # CONFIG_LED_TRIGGER_PHY is not set CONFIG_FIXED_PHY=y # CONFIG_SFP is not set # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_ADIN_PHY is not set # CONFIG_ADIN1100_PHY is not set CONFIG_AQUANTIA_PHY=y CONFIG_AX88796B_PHY=m CONFIG_BROADCOM_PHY=m CONFIG_BCM54140_PHY=m CONFIG_BCM7XXX_PHY=m # CONFIG_BCM84881_PHY is not set # CONFIG_BCM87XX_PHY is not set CONFIG_BCM_NET_PHYLIB=m # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set CONFIG_MARVELL_PHY=m CONFIG_MARVELL_10G_PHY=m # CONFIG_MARVELL_88X2222_PHY is not set # CONFIG_MAXLINEAR_GPHY is not set # CONFIG_MEDIATEK_GE_PHY is not set CONFIG_MICREL_PHY=y CONFIG_MICROCHIP_PHY=m # CONFIG_MICROCHIP_T1_PHY is not set CONFIG_MICROSEMI_PHY=y # CONFIG_MOTORCOMM_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_NXP_C45_TJA11XX_PHY is not set # CONFIG_NXP_TJA11XX_PHY is not set CONFIG_AT803X_PHY=y # CONFIG_QSEMI_PHY is not set CONFIG_REALTEK_PHY=y # CONFIG_RENESAS_PHY is not set CONFIG_ROCKCHIP_PHY=y CONFIG_SMSC_PHY=m # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_DP83822_PHY is not set # CONFIG_DP83TC811_PHY is not set # CONFIG_DP83848_PHY is not set CONFIG_DP83867_PHY=y CONFIG_DP83869_PHY=y CONFIG_DP83TD510_PHY=y CONFIG_VITESSE_PHY=y # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PSE_CONTROLLER is not set CONFIG_CAN_DEV=m # CONFIG_CAN_VCAN is not set # CONFIG_CAN_VXCAN is not set CONFIG_CAN_NETLINK=y CONFIG_CAN_CALC_BITTIMING=y CONFIG_CAN_RX_OFFLOAD=y # CONFIG_CAN_CAN327 is not set CONFIG_CAN_FLEXCAN=m # CONFIG_CAN_GRCAN is not set # CONFIG_CAN_KVASER_PCIEFD is not set # CONFIG_CAN_SLCAN is not set # CONFIG_CAN_XILINXCAN is not set # CONFIG_CAN_C_CAN is not set # CONFIG_CAN_CC770 is not set # CONFIG_CAN_CTUCANFD_PCI is not set # CONFIG_CAN_CTUCANFD_PLATFORM is not set # CONFIG_CAN_IFI_CANFD is not set CONFIG_CAN_M_CAN=m # CONFIG_CAN_M_CAN_PCI is not set CONFIG_CAN_M_CAN_PLATFORM=m # CONFIG_CAN_M_CAN_TCAN4X5X is not set # CONFIG_CAN_PEAK_PCIEFD is not set # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_SOFTING is not set # # CAN SPI interfaces # # CONFIG_CAN_HI311X is not set # CONFIG_CAN_MCP251X is not set CONFIG_CAN_MCP251XFD=m # CONFIG_CAN_MCP251XFD_SANITY is not set # end of CAN SPI interfaces # # CAN USB interfaces # # CONFIG_CAN_8DEV_USB is not set # CONFIG_CAN_EMS_USB is not set # CONFIG_CAN_ESD_USB is not set # CONFIG_CAN_ETAS_ES58X is not set # CONFIG_CAN_GS_USB is not set # CONFIG_CAN_KVASER_USB is not set # CONFIG_CAN_MCBA_USB is not set # CONFIG_CAN_PEAK_USB is not set # CONFIG_CAN_UCAN is not set # end of CAN USB interfaces # CONFIG_CAN_DEBUG_DEVICES is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y CONFIG_FWNODE_MDIO=y CONFIG_OF_MDIO=y CONFIG_MDIO_DEVRES=y CONFIG_MDIO_BITBANG=y CONFIG_MDIO_BCM_UNIMAC=m CONFIG_MDIO_CAVIUM=y CONFIG_MDIO_GPIO=y # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_MVUSB is not set # CONFIG_MDIO_MSCC_MIIM is not set # CONFIG_MDIO_OCTEON is not set # CONFIG_MDIO_IPQ4019 is not set # CONFIG_MDIO_IPQ8064 is not set CONFIG_MDIO_THUNDER=y # # MDIO Multiplexers # CONFIG_MDIO_BUS_MUX=y # CONFIG_MDIO_BUS_MUX_GPIO is not set CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y CONFIG_MDIO_BUS_MUX_MMIOREG=y # # PCS device drivers # CONFIG_PCS_XPCS=m # end of PCS device drivers # CONFIG_PPP is not set # CONFIG_SLIP is not set CONFIG_USB_NET_DRIVERS=y # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set CONFIG_USB_PEGASUS=m CONFIG_USB_RTL8150=m CONFIG_USB_RTL8152=m CONFIG_USB_LAN78XX=m CONFIG_USB_USBNET=m CONFIG_USB_NET_AX8817X=m CONFIG_USB_NET_AX88179_178A=m CONFIG_USB_NET_CDCETHER=m # CONFIG_USB_NET_CDC_EEM is not set CONFIG_USB_NET_CDC_NCM=m # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set # CONFIG_USB_NET_CDC_MBIM is not set CONFIG_USB_NET_DM9601=m # CONFIG_USB_NET_SR9700 is not set CONFIG_USB_NET_SR9800=m CONFIG_USB_NET_SMSC75XX=m CONFIG_USB_NET_SMSC95XX=m # CONFIG_USB_NET_GL620A is not set CONFIG_USB_NET_NET1080=m CONFIG_USB_NET_PLUSB=m CONFIG_USB_NET_MCS7830=m # CONFIG_USB_NET_RNDIS_HOST is not set CONFIG_USB_NET_CDC_SUBSET_ENABLE=m CONFIG_USB_NET_CDC_SUBSET=m # CONFIG_USB_ALI_M5632 is not set # CONFIG_USB_AN2720 is not set CONFIG_USB_BELKIN=y CONFIG_USB_ARMLINUX=y # CONFIG_USB_EPSON2888 is not set # CONFIG_USB_KC2190 is not set CONFIG_USB_NET_ZAURUS=m # CONFIG_USB_NET_CX82310_ETH is not set # CONFIG_USB_NET_KALMIA is not set # CONFIG_USB_NET_QMI_WWAN is not set # CONFIG_USB_HSO is not set # CONFIG_USB_NET_INT51X1 is not set # CONFIG_USB_IPHETH is not set # CONFIG_USB_SIERRA_NET is not set # CONFIG_USB_VL600 is not set # CONFIG_USB_NET_CH9200 is not set # CONFIG_USB_NET_AQC111 is not set CONFIG_USB_RTL8153_ECM=m CONFIG_WLAN=y CONFIG_WLAN_VENDOR_ADMTEK=y # CONFIG_ADM8211 is not set CONFIG_ATH_COMMON=m CONFIG_WLAN_VENDOR_ATH=y # CONFIG_ATH_DEBUG is not set # CONFIG_ATH5K is not set # CONFIG_ATH5K_PCI is not set # CONFIG_ATH9K is not set # CONFIG_ATH9K_HTC is not set # CONFIG_CARL9170 is not set # CONFIG_ATH6KL is not set # CONFIG_AR5523 is not set # CONFIG_WIL6210 is not set CONFIG_ATH10K=m CONFIG_ATH10K_CE=y CONFIG_ATH10K_PCI=m # CONFIG_ATH10K_AHB is not set # CONFIG_ATH10K_SDIO is not set # CONFIG_ATH10K_USB is not set # CONFIG_ATH10K_DEBUG is not set # CONFIG_ATH10K_DEBUGFS is not set CONFIG_WCN36XX=m # CONFIG_WCN36XX_DEBUGFS is not set CONFIG_ATH11K=m CONFIG_ATH11K_AHB=m CONFIG_ATH11K_PCI=m # CONFIG_ATH11K_DEBUG is not set CONFIG_WLAN_VENDOR_ATMEL=y # CONFIG_ATMEL is not set # CONFIG_AT76C50X_USB is not set CONFIG_WLAN_VENDOR_BROADCOM=y # CONFIG_B43 is not set # CONFIG_B43LEGACY is not set CONFIG_BRCMUTIL=m # CONFIG_BRCMSMAC is not set CONFIG_BRCMFMAC=m CONFIG_BRCMFMAC_PROTO_BCDC=y CONFIG_BRCMFMAC_SDIO=y # CONFIG_BRCMFMAC_USB is not set # CONFIG_BRCMFMAC_PCIE is not set # CONFIG_BRCM_TRACING is not set # CONFIG_BRCMDBG is not set CONFIG_WLAN_VENDOR_CISCO=y CONFIG_WLAN_VENDOR_INTEL=y # CONFIG_IPW2100 is not set # CONFIG_IPW2200 is not set # CONFIG_IWL4965 is not set # CONFIG_IWL3945 is not set CONFIG_IWLWIFI=m CONFIG_IWLWIFI_LEDS=y CONFIG_IWLDVM=m CONFIG_IWLMVM=m CONFIG_IWLWIFI_OPMODE_MODULAR=y # # Debugging Options # # CONFIG_IWLWIFI_DEBUG is not set # end of Debugging Options CONFIG_WLAN_VENDOR_INTERSIL=y # CONFIG_HOSTAP is not set # CONFIG_HERMES is not set # CONFIG_P54_COMMON is not set CONFIG_WLAN_VENDOR_MARVELL=y # CONFIG_LIBERTAS is not set # CONFIG_LIBERTAS_THINFIRM is not set CONFIG_MWIFIEX=m CONFIG_MWIFIEX_SDIO=m CONFIG_MWIFIEX_PCIE=m # CONFIG_MWIFIEX_USB is not set # CONFIG_MWL8K is not set CONFIG_WLAN_VENDOR_MEDIATEK=y # CONFIG_MT7601U is not set # CONFIG_MT76x0U is not set # CONFIG_MT76x0E is not set # CONFIG_MT76x2E is not set # CONFIG_MT76x2U is not set # CONFIG_MT7603E is not set # CONFIG_MT7615E is not set # CONFIG_MT7663U is not set # CONFIG_MT7663S is not set # CONFIG_MT7915E is not set # CONFIG_MT7921E is not set # CONFIG_MT7921S is not set # CONFIG_MT7921U is not set CONFIG_WLAN_VENDOR_MICROCHIP=y # CONFIG_WILC1000_SDIO is not set # CONFIG_WILC1000_SPI is not set CONFIG_WLAN_VENDOR_PURELIFI=y # CONFIG_PLFXLC is not set CONFIG_WLAN_VENDOR_RALINK=y # CONFIG_RT2X00 is not set CONFIG_WLAN_VENDOR_REALTEK=y # CONFIG_RTL8180 is not set # CONFIG_RTL8187 is not set CONFIG_RTL_CARDS=m # CONFIG_RTL8192CE is not set # CONFIG_RTL8192SE is not set # CONFIG_RTL8192DE is not set # CONFIG_RTL8723AE is not set # CONFIG_RTL8723BE is not set # CONFIG_RTL8188EE is not set # CONFIG_RTL8192EE is not set # CONFIG_RTL8821AE is not set # CONFIG_RTL8192CU is not set # CONFIG_RTL8XXXU is not set # CONFIG_RTW88 is not set # CONFIG_RTW89 is not set CONFIG_WLAN_VENDOR_RSI=y # CONFIG_RSI_91X is not set CONFIG_WLAN_VENDOR_SILABS=y # CONFIG_WFX is not set CONFIG_WLAN_VENDOR_ST=y # CONFIG_CW1200 is not set CONFIG_WLAN_VENDOR_TI=y # CONFIG_WL1251 is not set # CONFIG_WL12XX is not set CONFIG_WL18XX=m CONFIG_WLCORE=m # CONFIG_WLCORE_SPI is not set CONFIG_WLCORE_SDIO=m CONFIG_WILINK_PLATFORM_DATA=y CONFIG_WLAN_VENDOR_ZYDAS=y # CONFIG_USB_ZD1201 is not set # CONFIG_ZD1211RW is not set CONFIG_WLAN_VENDOR_QUANTENNA=y # CONFIG_QTNFMAC_PCIE is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # CONFIG_VIRT_WIFI is not set # CONFIG_WAN is not set # # Wireless WAN # # CONFIG_WWAN is not set # end of Wireless WAN # CONFIG_VMXNET3 is not set # CONFIG_NETDEVSIM is not set CONFIG_NET_FAILOVER=y # CONFIG_ISDN is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y CONFIG_INPUT_FF_MEMLESS=m # CONFIG_INPUT_SPARSEKMAP is not set CONFIG_INPUT_MATRIXKMAP=y CONFIG_INPUT_VIVALDIFMAP=y # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y CONFIG_KEYBOARD_ADC=m # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_QT1050 is not set # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=y # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_PINEPHONE is not set # CONFIG_KEYBOARD_SAMSUNG is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set # CONFIG_KEYBOARD_XTKBD is not set CONFIG_KEYBOARD_CROS_EC=y # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_KEYBOARD_MTK_PMIC is not set # CONFIG_KEYBOARD_CYPRESS_SF is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_BYD=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y CONFIG_MOUSE_PS2_CYPRESS=y CONFIG_MOUSE_PS2_TRACKPOINT=y # CONFIG_MOUSE_PS2_ELANTECH is not set # CONFIG_MOUSE_PS2_SENTELIC is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set CONFIG_MOUSE_PS2_FOCALTECH=y CONFIG_MOUSE_PS2_SMBUS=y # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set # CONFIG_MOUSE_CYAPA is not set # CONFIG_MOUSE_ELAN_I2C is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_MOUSE_GPIO is not set # CONFIG_MOUSE_SYNAPTICS_I2C is not set # CONFIG_MOUSE_SYNAPTICS_USB is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_ADC is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set CONFIG_TOUCHSCREEN_ATMEL_MXT=m # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_BU21029 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_EXC3000 is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set CONFIG_TOUCHSCREEN_GOODIX=m # CONFIG_TOUCHSCREEN_HIDEEP is not set # CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set CONFIG_TOUCHSCREEN_ILI210X=m # CONFIG_TOUCHSCREEN_ILITEK is not set # CONFIG_TOUCHSCREEN_S6SY761 is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MMS114 is not set # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MSG2638 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMAGIS is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set CONFIG_TOUCHSCREEN_EDT_FT5X06=m # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set # CONFIG_TOUCHSCREEN_TI_AM335X_TSC is not set # CONFIG_TOUCHSCREEN_PIXCIR is not set # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_STMFTS is not set # CONFIG_TOUCHSCREEN_SUR40 is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZET6223 is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set # CONFIG_TOUCHSCREEN_IQS5XX is not set # CONFIG_TOUCHSCREEN_ZINITIX is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_GPIO_BEEPER is not set # CONFIG_INPUT_GPIO_DECODER is not set # CONFIG_INPUT_GPIO_VIBRA is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set CONFIG_INPUT_TPS65219_PWRBUTTON=m # CONFIG_INPUT_AXP20X_PEK is not set # CONFIG_INPUT_UINPUT is not set # CONFIG_INPUT_PCF8574 is not set CONFIG_INPUT_PWM_BEEPER=m CONFIG_INPUT_PWM_VIBRA=m # CONFIG_INPUT_RK805_PWRKEY is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_DA7280_HAPTICS is not set # CONFIG_INPUT_ADXL34X is not set # CONFIG_INPUT_IBM_PANEL is not set # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_IQS269A is not set # CONFIG_INPUT_IQS626A is not set # CONFIG_INPUT_IQS7222 is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y # CONFIG_SERIO_SERPORT is not set CONFIG_SERIO_AMBAKMI=y # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_GPIO_PS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # end of Hardware I/O ports # end of Input device support # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=16 CONFIG_LDISC_AUTOLOAD=y # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y CONFIG_SERIAL_8250_16550A_VARIANTS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_EXAR=y CONFIG_SERIAL_8250_NR_UARTS=4 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 CONFIG_SERIAL_8250_EXTENDED=y # CONFIG_SERIAL_8250_MANY_PORTS is not set CONFIG_SERIAL_8250_SHARE_IRQ=y # CONFIG_SERIAL_8250_DETECT_IRQ is not set # CONFIG_SERIAL_8250_RSA is not set CONFIG_SERIAL_8250_FSL=y # CONFIG_SERIAL_8250_DW is not set # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_8250_OMAP=y CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y CONFIG_SERIAL_8250_PERICOM=y CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_AMBA_PL010 is not set # CONFIG_SERIAL_AMBA_PL011 is not set # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set # CONFIG_SERIAL_SIFIVE is not set # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_RP2 is not set CONFIG_SERIAL_FSL_LPUART=y CONFIG_SERIAL_FSL_LPUART_CONSOLE=y CONFIG_SERIAL_FSL_LINFLEXUART=y CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_SPRD is not set # end of Serial drivers CONFIG_SERIAL_MCTRL_GPIO=y # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_NOZOMI is not set # CONFIG_NULL_TTY is not set CONFIG_HVC_DRIVER=y # CONFIG_HVC_DCC is not set # CONFIG_RPMSG_TTY is not set CONFIG_SERIAL_DEV_BUS=y CONFIG_SERIAL_DEV_CTRL_TTYPORT=y # CONFIG_TTY_PRINTK is not set CONFIG_VIRTIO_CONSOLE=y CONFIG_IPMI_HANDLER=m CONFIG_IPMI_DMI_DECODE=y CONFIG_IPMI_PLAT_DATA=y # CONFIG_IPMI_PANIC_EVENT is not set CONFIG_IPMI_DEVICE_INTERFACE=m CONFIG_IPMI_SI=m # CONFIG_IPMI_SSIF is not set # CONFIG_IPMI_IPMB is not set # CONFIG_IPMI_WATCHDOG is not set # CONFIG_IPMI_POWEROFF is not set # CONFIG_IPMB_DEVICE_INTERFACE is not set CONFIG_HW_RANDOM=m # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_BA431 is not set CONFIG_HW_RANDOM_OMAP=m # CONFIG_HW_RANDOM_VIRTIO is not set CONFIG_HW_RANDOM_OPTEE=m # CONFIG_HW_RANDOM_CCTRNG is not set # CONFIG_HW_RANDOM_XIPHERA is not set CONFIG_HW_RANDOM_ARM_SMCCC_TRNG=m CONFIG_HW_RANDOM_CN10K=m # CONFIG_APPLICOM is not set CONFIG_DEVMEM=y CONFIG_DEVPORT=y CONFIG_TCG_TPM=y # CONFIG_TCG_TIS is not set # CONFIG_TCG_TIS_SPI is not set # CONFIG_TCG_TIS_I2C is not set # CONFIG_TCG_TIS_I2C_CR50 is not set # CONFIG_TCG_TIS_I2C_ATMEL is not set CONFIG_TCG_TIS_I2C_INFINEON=y # CONFIG_TCG_TIS_I2C_NUVOTON is not set # CONFIG_TCG_ATMEL is not set # CONFIG_TCG_VTPM_PROXY is not set # CONFIG_TCG_FTPM_TEE is not set # CONFIG_TCG_TIS_ST33ZP24_I2C is not set # CONFIG_TCG_TIS_ST33ZP24_SPI is not set # CONFIG_XILLYBUS is not set # CONFIG_XILLYUSB is not set CONFIG_RANDOM_TRUST_CPU=y CONFIG_RANDOM_TRUST_BOOTLOADER=y # end of Character devices # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_MUX=y # # Multiplexer I2C Chip support # # CONFIG_I2C_ARB_GPIO_CHALLENGE is not set # CONFIG_I2C_MUX_GPIO is not set # CONFIG_I2C_MUX_GPMUX is not set # CONFIG_I2C_MUX_LTC4306 is not set # CONFIG_I2C_MUX_PCA9541 is not set CONFIG_I2C_MUX_PCA954x=y # CONFIG_I2C_MUX_PINCTRL is not set # CONFIG_I2C_MUX_REG is not set # CONFIG_I2C_DEMUX_PINCTRL is not set # CONFIG_I2C_MUX_MLXCPLD is not set # end of Multiplexer I2C Chip support CONFIG_I2C_ATR=m CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_NVIDIA_GPU is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # CONFIG_I2C_CADENCE=m # CONFIG_I2C_CBUS_GPIO is not set CONFIG_I2C_DESIGNWARE_CORE=y # CONFIG_I2C_DESIGNWARE_SLAVE is not set CONFIG_I2C_DESIGNWARE_PLATFORM=y # CONFIG_I2C_DESIGNWARE_PCI is not set # CONFIG_I2C_EMEV2 is not set CONFIG_I2C_GPIO=m # CONFIG_I2C_GPIO_FAULT_INJECTOR is not set # CONFIG_I2C_NOMADIK is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set CONFIG_I2C_RK3X=y # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_THUNDERX is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_CP2615 is not set # CONFIG_I2C_PCI1XXXX is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # CONFIG_I2C_CROS_EC_TUNNEL=y # CONFIG_I2C_VIRTIO is not set # end of I2C Hardware Bus support # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y # CONFIG_I2C_SLAVE_EEPROM is not set # CONFIG_I2C_SLAVE_TESTUNIT is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # end of I2C support # CONFIG_I3C is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y CONFIG_SPI_MEM=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set # CONFIG_SPI_BITBANG is not set # CONFIG_SPI_CADENCE is not set CONFIG_SPI_CADENCE_QUADSPI=y # CONFIG_SPI_CADENCE_XSPI is not set CONFIG_SPI_DESIGNWARE=m CONFIG_SPI_DW_DMA=y # CONFIG_SPI_DW_PCI is not set CONFIG_SPI_DW_MMIO=m CONFIG_SPI_NXP_FLEXSPI=y # CONFIG_SPI_GPIO is not set # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_MICROCHIP_CORE is not set # CONFIG_SPI_MICROCHIP_CORE_QSPI is not set # CONFIG_SPI_OC_TINY is not set CONFIG_SPI_OMAP24XX=m CONFIG_SPI_PL022=y # CONFIG_SPI_PXA2XX is not set CONFIG_SPI_ROCKCHIP=y # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SPI_MXIC is not set # CONFIG_SPI_THUNDERX is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # CONFIG_SPI_AMD is not set # # SPI Multiplexer support # # CONFIG_SPI_MUX is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=m # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set CONFIG_SPI_SLAVE=y # CONFIG_SPI_SLAVE_TIME is not set # CONFIG_SPI_SLAVE_SYSTEM_CONTROL is not set CONFIG_SPI_DYNAMIC=y CONFIG_SPMI=y # CONFIG_SPMI_HISI3670 is not set # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y CONFIG_PTP_1588_CLOCK_OPTIONAL=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # CONFIG_PTP_1588_CLOCK_KVM=y # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set # CONFIG_PTP_1588_CLOCK_IDTCM is not set # CONFIG_PTP_1588_CLOCK_OCP is not set # end of PTP clock support CONFIG_PINCTRL=y CONFIG_GENERIC_PINCTRL_GROUPS=y CONFIG_PINMUX=y CONFIG_GENERIC_PINMUX_FUNCTIONS=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_AXP209 is not set # CONFIG_PINCTRL_CY8C95X0 is not set CONFIG_PINCTRL_MAX77620=y # CONFIG_PINCTRL_MCP23S08 is not set # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set # CONFIG_PINCTRL_OCELOT is not set # CONFIG_PINCTRL_RK805 is not set CONFIG_PINCTRL_SINGLE=y # CONFIG_PINCTRL_STMFX is not set # CONFIG_PINCTRL_SX150X is not set CONFIG_PINCTRL_TPS6594=y # # Renesas pinctrl drivers # # end of Renesas pinctrl drivers CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y CONFIG_GPIO_CDEV=y CONFIG_GPIO_CDEV_V1=y CONFIG_GPIO_GENERIC=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set CONFIG_GPIO_ALTERA=m # CONFIG_GPIO_CADENCE is not set CONFIG_GPIO_DAVINCI=y CONFIG_GPIO_DWAPB=y # CONFIG_GPIO_EXAR is not set # CONFIG_GPIO_FTGPIO010 is not set CONFIG_GPIO_GENERIC_PLATFORM=y # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_LOGICVC is not set CONFIG_GPIO_MB86S7X=y CONFIG_GPIO_PL061=y # CONFIG_GPIO_SIFIVE is not set # CONFIG_GPIO_SYSCON is not set CONFIG_GPIO_WCD934X=m CONFIG_GPIO_XGENE=y # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_AMD_FCH is not set # end of Memory mapped GPIO drivers # # I2C GPIO expanders # # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set CONFIG_GPIO_MAX732X=y # CONFIG_GPIO_MAX732X_IRQ is not set CONFIG_GPIO_PCA953X=y CONFIG_GPIO_PCA953X_IRQ=y # CONFIG_GPIO_PCA9570 is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_TPIC2810 is not set # end of I2C GPIO expanders # # MFD GPIO expanders # CONFIG_GPIO_BD9571MWV=m CONFIG_GPIO_MAX77620=y # CONFIG_GPIO_WM8994 is not set # end of MFD GPIO expanders # # PCI GPIO expanders # # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_PCI_IDIO_16 is not set # CONFIG_GPIO_PCIE_IDIO_24 is not set # CONFIG_GPIO_RDC321X is not set # end of PCI GPIO expanders # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX3191X is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_PISOSR is not set # CONFIG_GPIO_XRA1403 is not set # end of SPI GPIO expanders # # USB GPIO expanders # # end of USB GPIO expanders # # Virtual GPIO drivers # # CONFIG_GPIO_AGGREGATOR is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_VIRTIO is not set # CONFIG_GPIO_SIM is not set # end of Virtual GPIO drivers # CONFIG_W1 is not set CONFIG_POWER_RESET=y CONFIG_POWER_RESET_BRCMSTB=y # CONFIG_POWER_RESET_GPIO is not set # CONFIG_POWER_RESET_GPIO_RESTART is not set # CONFIG_POWER_RESET_LTC2952 is not set # CONFIG_POWER_RESET_MT6323 is not set # CONFIG_POWER_RESET_REGULATOR is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_RESET_VEXPRESS is not set CONFIG_POWER_RESET_XGENE=y CONFIG_POWER_RESET_SYSCON=y # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set CONFIG_REBOOT_MODE=y CONFIG_SYSCON_REBOOT_MODE=y # CONFIG_NVMEM_REBOOT_MODE is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set CONFIG_POWER_SUPPLY_HWMON=y # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_IP5XXX_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_CHARGER_ADP5061 is not set # CONFIG_BATTERY_CW2015 is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SAMSUNG_SDI is not set CONFIG_BATTERY_SBS=m # CONFIG_CHARGER_SBS is not set # CONFIG_MANAGER_SBS is not set CONFIG_BATTERY_BQ27XXX=y CONFIG_BATTERY_BQ27XXX_I2C=y # CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set # CONFIG_AXP20X_POWER is not set # CONFIG_BATTERY_MAX17040 is not set CONFIG_BATTERY_MAX17042=m # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LT3651 is not set # CONFIG_CHARGER_LTC4162L is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_MAX77976 is not set CONFIG_CHARGER_MT6360=m # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ2515X is not set CONFIG_CHARGER_BQ25890=m CONFIG_CHARGER_BQ25980=m # CONFIG_CHARGER_BQ256XX is not set # CONFIG_CHARGER_RK817 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_BATTERY_GOLDFISH is not set # CONFIG_BATTERY_RT5033 is not set # CONFIG_CHARGER_RT9455 is not set # CONFIG_CHARGER_CROS_USBPD is not set CONFIG_CHARGER_CROS_PCHG=y # CONFIG_CHARGER_UCS1002 is not set # CONFIG_CHARGER_BD99954 is not set # CONFIG_BATTERY_UG3105 is not set CONFIG_HWMON=y # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM1177 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_AHT10 is not set # CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set # CONFIG_SENSORS_AS370 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_AXI_FAN_CONTROL is not set CONFIG_SENSORS_ARM_SCMI=y # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_CORSAIR_CPRO is not set # CONFIG_SENSORS_CORSAIR_PSU is not set # CONFIG_SENSORS_DRIVETEMP is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_I5K_AMB is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_FTSTEUTATES is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set CONFIG_SENSORS_GPIO_FAN=m # CONFIG_SENSORS_HIH6130 is not set # CONFIG_SENSORS_IBMAEM is not set # CONFIG_SENSORS_IBMPEX is not set # CONFIG_SENSORS_IIO_HWMON is not set # CONFIG_SENSORS_IT87 is not set CONFIG_SENSORS_JC42=m # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2947_I2C is not set # CONFIG_SENSORS_LTC2947_SPI is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC2992 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX127 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31722 is not set # CONFIG_SENSORS_MAX31730 is not set # CONFIG_SENSORS_MAX31760 is not set # CONFIG_SENSORS_MAX6620 is not set # CONFIG_SENSORS_MAX6621 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_TC654 is not set # CONFIG_SENSORS_TPS23861 is not set # CONFIG_SENSORS_MR75203 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set CONFIG_SENSORS_LM75=m # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set CONFIG_SENSORS_LM90=m # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set # CONFIG_SENSORS_LM95245 is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set # CONFIG_SENSORS_NTC_THERMISTOR is not set # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NCT6775_I2C is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_NPCM7XX is not set # CONFIG_SENSORS_NZXT_KRAKEN2 is not set # CONFIG_SENSORS_NZXT_SMART2 is not set # CONFIG_SENSORS_OCC_P8_I2C is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set CONFIG_SENSORS_PWM_FAN=m # CONFIG_SENSORS_SBTSI is not set # CONFIG_SENSORS_SBRMI is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHT4x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_SIS5595 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC2305 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_STTS751 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set CONFIG_SENSORS_INA2XX=m # CONFIG_SENSORS_INA238 is not set CONFIG_SENSORS_INA3221=m # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set # CONFIG_SENSORS_TMP102 is not set # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP108 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_TMP464 is not set # CONFIG_SENSORS_TMP513 is not set # CONFIG_SENSORS_VEXPRESS is not set # CONFIG_SENSORS_VIA686A is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_VT8231 is not set # CONFIG_SENSORS_W83773G is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set CONFIG_THERMAL=y # CONFIG_THERMAL_NETLINK is not set # CONFIG_THERMAL_STATISTICS is not set CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_OF=y # CONFIG_THERMAL_WRITABLE_TRIPS is not set CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set # CONFIG_THERMAL_GOV_FAIR_SHARE is not set CONFIG_THERMAL_GOV_STEP_WISE=y # CONFIG_THERMAL_GOV_BANG_BANG is not set # CONFIG_THERMAL_GOV_USER_SPACE is not set CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y CONFIG_CPU_FREQ_THERMAL=y CONFIG_DEVFREQ_THERMAL=y CONFIG_THERMAL_EMULATION=y # CONFIG_THERMAL_MMIO is not set CONFIG_K3_THERMAL=y # CONFIG_MAX77620_THERMAL is not set # CONFIG_GENERIC_ADC_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y CONFIG_WATCHDOG_OPEN_TIMEOUT=0 # CONFIG_WATCHDOG_SYSFS is not set # CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set CONFIG_ARM_SP805_WATCHDOG=y CONFIG_ARM_SBSA_WATCHDOG=y # CONFIG_CADENCE_WATCHDOG is not set CONFIG_DW_WATCHDOG=y # CONFIG_K3_RTI_WATCHDOG is not set # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_MAX77620_WATCHDOG is not set CONFIG_ARM_SMC_WATCHDOG=y # CONFIG_ALIM7101_WDT is not set # CONFIG_I6300ESB_WDT is not set # CONFIG_HP_WATCHDOG is not set # CONFIG_MEN_A21_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # CONFIG_BCMA is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set CONFIG_MFD_BD9571MWV=y CONFIG_MFD_AXP20X=y CONFIG_MFD_AXP20X_I2C=y CONFIG_MFD_CROS_EC_DEV=y # CONFIG_MFD_MADERA is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_GATEWORKS_GSC is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_MP2629 is not set CONFIG_MFD_HI6421_PMIC=y # CONFIG_MFD_HI6421_SPMI is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_LPC_ICH is not set # CONFIG_LPC_SCH is not set # CONFIG_MFD_IQS62X is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set CONFIG_MFD_MAX77620=y # CONFIG_MFD_MAX77650 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77714 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set CONFIG_MFD_MT6360=y # CONFIG_MFD_MT6370 is not set CONFIG_MFD_MT6397=y # CONFIG_MFD_MENF21BMC is not set # CONFIG_MFD_OCELOT is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_CPCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_NTXEC is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_SY7636A is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_RT4831 is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RT5120 is not set # CONFIG_MFD_RC5T583 is not set CONFIG_MFD_RK808=y # CONFIG_MFD_RN5T618 is not set CONFIG_MFD_SEC_CORE=y # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y CONFIG_MFD_TI_AM335X_TSCADC=m # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set # CONFIG_MFD_TPS65218 is not set CONFIG_MFD_TPS65219=y # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set CONFIG_MFD_TPS6594=y CONFIG_MFD_TPS6594_I2C=y # CONFIG_MFD_TPS6594_SPI is not set # CONFIG_TWL4030_CORE is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set CONFIG_MFD_WM8994=m CONFIG_MFD_ROHM_BD718XX=y # CONFIG_MFD_ROHM_BD71828 is not set # CONFIG_MFD_ROHM_BD957XMUF is not set # CONFIG_MFD_STPMIC1 is not set # CONFIG_MFD_STMFX is not set CONFIG_MFD_WCD934X=m # CONFIG_MFD_ATC260X_I2C is not set # CONFIG_MFD_QCOM_PM8008 is not set CONFIG_MFD_VEXPRESS_SYSREG=y # CONFIG_RAVE_SP_CORE is not set # CONFIG_MFD_INTEL_M10_BMC is not set # CONFIG_MFD_RSMU_I2C is not set # CONFIG_MFD_RSMU_SPI is not set # end of Multifunction device drivers CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_88PG86X is not set # CONFIG_REGULATOR_ACT8865 is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ARM_SCMI is not set CONFIG_REGULATOR_AXP20X=y CONFIG_REGULATOR_BD718XX=y CONFIG_REGULATOR_BD9571MWV=y # CONFIG_REGULATOR_CROS_EC is not set # CONFIG_REGULATOR_DA9121 is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set CONFIG_REGULATOR_FAN53555=y # CONFIG_REGULATOR_FAN53880 is not set CONFIG_REGULATOR_GPIO=y # CONFIG_REGULATOR_HI6421 is not set CONFIG_REGULATOR_HI6421V530=y # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set CONFIG_REGULATOR_MAX77620=y # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8893 is not set # CONFIG_REGULATOR_MAX8952 is not set CONFIG_REGULATOR_MAX8973=y # CONFIG_REGULATOR_MAX20086 is not set # CONFIG_REGULATOR_MAX77826 is not set # CONFIG_REGULATOR_MCP16502 is not set # CONFIG_REGULATOR_MP5416 is not set CONFIG_REGULATOR_MP8859=y # CONFIG_REGULATOR_MP886X is not set # CONFIG_REGULATOR_MPQ7920 is not set # CONFIG_REGULATOR_MT6311 is not set # CONFIG_REGULATOR_MT6315 is not set # CONFIG_REGULATOR_MT6323 is not set # CONFIG_REGULATOR_MT6331 is not set # CONFIG_REGULATOR_MT6332 is not set CONFIG_REGULATOR_MT6358=y CONFIG_REGULATOR_MT6359=y CONFIG_REGULATOR_MT6360=y CONFIG_REGULATOR_MT6397=y CONFIG_REGULATOR_PCA9450=y CONFIG_REGULATOR_PF8X00=y CONFIG_REGULATOR_PFUZE100=y # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_QCOM_SPMI=y # CONFIG_REGULATOR_QCOM_USB_VBUS is not set # CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set CONFIG_REGULATOR_RK808=y CONFIG_REGULATOR_ROHM=y # CONFIG_REGULATOR_RT4801 is not set # CONFIG_REGULATOR_RT5190A is not set # CONFIG_REGULATOR_RT5759 is not set # CONFIG_REGULATOR_RT6160 is not set # CONFIG_REGULATOR_RT6245 is not set # CONFIG_REGULATOR_RTQ2134 is not set # CONFIG_REGULATOR_RTMV20 is not set # CONFIG_REGULATOR_RTQ6752 is not set # CONFIG_REGULATOR_S2MPA01 is not set CONFIG_REGULATOR_S2MPS11=y # CONFIG_REGULATOR_S5M8767 is not set # CONFIG_REGULATOR_SLG51000 is not set # CONFIG_REGULATOR_SY8106A is not set # CONFIG_REGULATOR_SY8824X is not set # CONFIG_REGULATOR_SY8827N is not set # CONFIG_REGULATOR_TPS51632 is not set # CONFIG_REGULATOR_TPS62360 is not set # CONFIG_REGULATOR_TPS6286X is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS6507X is not set CONFIG_REGULATOR_TPS65132=m CONFIG_REGULATOR_TPS65219=y CONFIG_REGULATOR_TPS6594=y # CONFIG_REGULATOR_TPS6524X is not set CONFIG_REGULATOR_VCTRL=m # CONFIG_REGULATOR_VEXPRESS is not set # CONFIG_REGULATOR_WM8994 is not set # CONFIG_REGULATOR_QCOM_LABIBB is not set # CONFIG_RC_CORE is not set CONFIG_CEC_CORE=m CONFIG_CEC_NOTIFIER=y # # CEC support # CONFIG_MEDIA_CEC_SUPPORT=y # CONFIG_CEC_CH7322 is not set # CONFIG_CEC_CROS_EC is not set # CONFIG_CEC_GPIO is not set # CONFIG_USB_PULSE8_CEC is not set # CONFIG_USB_RAINSHADOW_CEC is not set # end of CEC support CONFIG_MEDIA_SUPPORT=m # CONFIG_MEDIA_SUPPORT_FILTER is not set # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # # Media device types # CONFIG_MEDIA_CAMERA_SUPPORT=y CONFIG_MEDIA_ANALOG_TV_SUPPORT=y CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y CONFIG_MEDIA_RADIO_SUPPORT=y CONFIG_MEDIA_SDR_SUPPORT=y CONFIG_MEDIA_PLATFORM_SUPPORT=y CONFIG_MEDIA_TEST_SUPPORT=y # end of Media device types # # Media core support # CONFIG_VIDEO_DEV=m CONFIG_MEDIA_CONTROLLER=y CONFIG_DVB_CORE=m # end of Media core support # # Video4Linux options # CONFIG_VIDEO_V4L2_I2C=y CONFIG_VIDEO_V4L2_SUBDEV_API=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_V4L2_MEM2MEM_DEV=m CONFIG_V4L2_FWNODE=m CONFIG_V4L2_ASYNC=m # end of Video4Linux options # # Media controller options # # CONFIG_MEDIA_CONTROLLER_DVB is not set # end of Media controller options # # Digital TV options # # CONFIG_DVB_MMAP is not set # CONFIG_DVB_NET is not set CONFIG_DVB_MAX_ADAPTERS=16 CONFIG_DVB_DYNAMIC_MINORS=y # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set # CONFIG_DVB_ULE_DEBUG is not set # end of Digital TV options # # Media drivers # # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # # CONFIG_USB_GSPCA is not set # CONFIG_USB_PWC is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set CONFIG_USB_VIDEO_CLASS=m CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # # Analog TV USB devices # # CONFIG_VIDEO_GO7007 is not set # CONFIG_VIDEO_HDPVR is not set # CONFIG_VIDEO_PVRUSB2 is not set # CONFIG_VIDEO_STK1160_COMMON is not set # # Analog/digital TV USB devices # # CONFIG_VIDEO_AU0828 is not set # CONFIG_VIDEO_CX231XX is not set # # Digital TV USB devices # # CONFIG_DVB_AS102 is not set # CONFIG_DVB_B2C2_FLEXCOP_USB is not set # CONFIG_DVB_USB_V2 is not set # CONFIG_SMS_USB_DRV is not set # CONFIG_DVB_TTUSB_BUDGET is not set # CONFIG_DVB_TTUSB_DEC is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set # # Software defined radio USB devices # # CONFIG_USB_AIRSPY is not set # CONFIG_USB_HACKRF is not set # CONFIG_USB_MSI2500 is not set # CONFIG_MEDIA_PCI_SUPPORT is not set CONFIG_RADIO_ADAPTERS=m # CONFIG_RADIO_MAXIRADIO is not set # CONFIG_RADIO_SAA7706H is not set # CONFIG_RADIO_SHARK is not set # CONFIG_RADIO_SHARK2 is not set # CONFIG_RADIO_SI4713 is not set # CONFIG_RADIO_TEA5764 is not set # CONFIG_RADIO_TEF6862 is not set # CONFIG_RADIO_WL1273 is not set # CONFIG_USB_DSBR is not set # CONFIG_USB_KEENE is not set # CONFIG_USB_MA901 is not set # CONFIG_USB_MR800 is not set # CONFIG_USB_RAREMONO is not set # CONFIG_RADIO_SI470X is not set CONFIG_MEDIA_PLATFORM_DRIVERS=y CONFIG_V4L_PLATFORM_DRIVERS=y CONFIG_SDR_PLATFORM_DRIVERS=y # CONFIG_DVB_PLATFORM_DRIVERS is not set CONFIG_V4L_MEM2MEM_DRIVERS=y # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set # CONFIG_VIDEO_MUX is not set # # Allegro DVT media platform drivers # # # Amlogic media platform drivers # # # Amphion drivers # # # Aspeed media platform drivers # # CONFIG_VIDEO_ASPEED is not set # # Atmel media platform drivers # # # Cadence media platform drivers # CONFIG_VIDEO_CADENCE_CSI2RX=m # CONFIG_VIDEO_CADENCE_CSI2TX is not set # # Chips&Media media platform drivers # CONFIG_VIDEO_WAVE_VPU=m # # IMG media platform drivers # CONFIG_VIDEO_IMG_VXD_DEC=m CONFIG_VIDEO_IMG_VXE_ENC=m CONFIG_VIDEO_E5010_JPEG_ENC=m # # Intel media platform drivers # # # Marvell media platform drivers # # CONFIG_VIDEO_CAFE_CCIC is not set # # Mediatek media platform drivers # # # NVidia media platform drivers # # # NXP media platform drivers # # # Qualcomm media platform drivers # # # Renesas media platform drivers # # # Rockchip media platform drivers # # # Samsung media platform drivers # # # STMicroelectronics media platform drivers # # # Sunxi media platform drivers # # # Texas Instruments drivers # # CONFIG_VIDEO_TI_CAL is not set CONFIG_VIDEO_TI_J721E_CSI2RX=m # # Verisilicon media platform drivers # # # VIA media platform drivers # # # Xilinx media platform drivers # # CONFIG_VIDEO_XILINX is not set # # MMC/SDIO DVB adapters # # CONFIG_SMS_SDIO_DRV is not set # CONFIG_V4L_TEST_DRIVERS is not set # CONFIG_DVB_TEST_DRIVERS is not set CONFIG_VIDEOBUF2_CORE=m CONFIG_VIDEOBUF2_V4L2=m CONFIG_VIDEOBUF2_MEMOPS=m CONFIG_VIDEOBUF2_DMA_CONTIG=m CONFIG_VIDEOBUF2_VMALLOC=m CONFIG_VIDEOBUF2_DMA_SG=m # end of Media drivers # # Media ancillary drivers # CONFIG_MEDIA_ATTACH=y # # Camera sensor devices # # CONFIG_VIDEO_AR0521 is not set # CONFIG_VIDEO_HI556 is not set # CONFIG_VIDEO_HI846 is not set # CONFIG_VIDEO_HI847 is not set # CONFIG_VIDEO_IMX208 is not set # CONFIG_VIDEO_IMX214 is not set CONFIG_VIDEO_IMX219=m # CONFIG_VIDEO_IMX258 is not set # CONFIG_VIDEO_IMX274 is not set # CONFIG_VIDEO_IMX290 is not set # CONFIG_VIDEO_IMX319 is not set # CONFIG_VIDEO_IMX334 is not set # CONFIG_VIDEO_IMX335 is not set # CONFIG_VIDEO_IMX355 is not set CONFIG_VIDEO_IMX390=m # CONFIG_VIDEO_IMX412 is not set # CONFIG_VIDEO_MT9M001 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9T112 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set # CONFIG_VIDEO_MT9V111 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_OG01A1B is not set # CONFIG_VIDEO_OV02A10 is not set # CONFIG_VIDEO_OV08D10 is not set # CONFIG_VIDEO_OV13858 is not set # CONFIG_VIDEO_OV13B10 is not set CONFIG_VIDEO_OV2312=m # CONFIG_VIDEO_OV2640 is not set # CONFIG_VIDEO_OV2659 is not set # CONFIG_VIDEO_OV2680 is not set # CONFIG_VIDEO_OV2685 is not set CONFIG_VIDEO_OV5640=m CONFIG_VIDEO_OV5645=m # CONFIG_VIDEO_OV5647 is not set # CONFIG_VIDEO_OV5648 is not set # CONFIG_VIDEO_OV5670 is not set # CONFIG_VIDEO_OV5675 is not set # CONFIG_VIDEO_OV5693 is not set # CONFIG_VIDEO_OV5695 is not set # CONFIG_VIDEO_OV6650 is not set # CONFIG_VIDEO_OV7251 is not set # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV772X is not set # CONFIG_VIDEO_OV7740 is not set # CONFIG_VIDEO_OV8856 is not set # CONFIG_VIDEO_OV8865 is not set # CONFIG_VIDEO_OV9282 is not set # CONFIG_VIDEO_OV9640 is not set # CONFIG_VIDEO_OV9650 is not set # CONFIG_VIDEO_RDACM20 is not set # CONFIG_VIDEO_RDACM21 is not set # CONFIG_VIDEO_RJ54N1 is not set # CONFIG_VIDEO_S5C73M3 is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_S5K5BAF is not set # CONFIG_VIDEO_S5K6A3 is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_CCS is not set # CONFIG_VIDEO_ET8EK8 is not set # CONFIG_VIDEO_M5MOLS is not set # end of Camera sensor devices # # Lens drivers # # CONFIG_VIDEO_AD5820 is not set # CONFIG_VIDEO_AK7375 is not set # CONFIG_VIDEO_DW9714 is not set # CONFIG_VIDEO_DW9768 is not set # CONFIG_VIDEO_DW9807_VCM is not set # end of Lens drivers # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_LM3560 is not set # CONFIG_VIDEO_LM3646 is not set # end of Flash devices # # Audio decoders, processors and mixers # # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # CONFIG_VIDEO_TDA1997X is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_WM8775 is not set # end of Audio decoders, processors and mixers # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # end of RDS decoders # # Video decoders # # CONFIG_VIDEO_ADV7180 is not set # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV748X is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_ISL7998X is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_MAX9286 is not set # CONFIG_VIDEO_ML86V7667 is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TC358743 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_TW9910 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # end of Video decoders # # Video encoders # # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_THS8200 is not set # end of Video encoders # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # end of Video improvement chips # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # end of Audio/Video compression chips # # SDR tuner chips # # CONFIG_SDR_MAX2175 is not set # end of SDR tuner chips # # Miscellaneous helper chips # # CONFIG_VIDEO_I2C is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_ST_MIPID02 is not set # CONFIG_VIDEO_THS7303 is not set # end of Miscellaneous helper chips # # Video serializers and deserializers # # CONFIG_VIDEO_DS90UB913 is not set CONFIG_VIDEO_DS90UB953=m CONFIG_VIDEO_DS90UB960=m # end of Video serializers and deserializers # # Media SPI Adapters # CONFIG_CXD2880_SPI_DRV=m # CONFIG_VIDEO_GS1662 is not set # end of Media SPI Adapters CONFIG_MEDIA_TUNER=m # # Customize TV tuners # CONFIG_MEDIA_TUNER_E4000=m CONFIG_MEDIA_TUNER_FC0011=m CONFIG_MEDIA_TUNER_FC0012=m CONFIG_MEDIA_TUNER_FC0013=m CONFIG_MEDIA_TUNER_FC2580=m CONFIG_MEDIA_TUNER_IT913X=m CONFIG_MEDIA_TUNER_M88RS6000T=m CONFIG_MEDIA_TUNER_MAX2165=m CONFIG_MEDIA_TUNER_MC44S803=m CONFIG_MEDIA_TUNER_MSI001=m CONFIG_MEDIA_TUNER_MT2060=m CONFIG_MEDIA_TUNER_MT2063=m CONFIG_MEDIA_TUNER_MT20XX=m CONFIG_MEDIA_TUNER_MT2131=m CONFIG_MEDIA_TUNER_MT2266=m CONFIG_MEDIA_TUNER_MXL301RF=m CONFIG_MEDIA_TUNER_MXL5005S=m CONFIG_MEDIA_TUNER_MXL5007T=m CONFIG_MEDIA_TUNER_QM1D1B0004=m CONFIG_MEDIA_TUNER_QM1D1C0042=m CONFIG_MEDIA_TUNER_QT1010=m CONFIG_MEDIA_TUNER_R820T=m CONFIG_MEDIA_TUNER_SI2157=m CONFIG_MEDIA_TUNER_SIMPLE=m CONFIG_MEDIA_TUNER_TDA18212=m CONFIG_MEDIA_TUNER_TDA18218=m CONFIG_MEDIA_TUNER_TDA18250=m CONFIG_MEDIA_TUNER_TDA18271=m CONFIG_MEDIA_TUNER_TDA827X=m CONFIG_MEDIA_TUNER_TDA8290=m CONFIG_MEDIA_TUNER_TDA9887=m CONFIG_MEDIA_TUNER_TEA5761=m CONFIG_MEDIA_TUNER_TEA5767=m CONFIG_MEDIA_TUNER_TUA9001=m CONFIG_MEDIA_TUNER_XC2028=m CONFIG_MEDIA_TUNER_XC4000=m CONFIG_MEDIA_TUNER_XC5000=m # end of Customize TV tuners # # Customise DVB Frontends # # # Multistandard (satellite) frontends # CONFIG_DVB_M88DS3103=m CONFIG_DVB_MXL5XX=m CONFIG_DVB_STB0899=m CONFIG_DVB_STB6100=m CONFIG_DVB_STV090x=m CONFIG_DVB_STV0910=m CONFIG_DVB_STV6110x=m CONFIG_DVB_STV6111=m # # Multistandard (cable + terrestrial) frontends # CONFIG_DVB_DRXK=m CONFIG_DVB_MN88472=m CONFIG_DVB_MN88473=m CONFIG_DVB_SI2165=m CONFIG_DVB_TDA18271C2DD=m # # DVB-S (satellite) frontends # CONFIG_DVB_CX24110=m CONFIG_DVB_CX24116=m CONFIG_DVB_CX24117=m CONFIG_DVB_CX24120=m CONFIG_DVB_CX24123=m CONFIG_DVB_DS3000=m CONFIG_DVB_MB86A16=m CONFIG_DVB_MT312=m CONFIG_DVB_S5H1420=m CONFIG_DVB_SI21XX=m CONFIG_DVB_STB6000=m CONFIG_DVB_STV0288=m CONFIG_DVB_STV0299=m CONFIG_DVB_STV0900=m CONFIG_DVB_STV6110=m CONFIG_DVB_TDA10071=m CONFIG_DVB_TDA10086=m CONFIG_DVB_TDA8083=m CONFIG_DVB_TDA8261=m CONFIG_DVB_TDA826X=m CONFIG_DVB_TS2020=m CONFIG_DVB_TUA6100=m CONFIG_DVB_TUNER_CX24113=m CONFIG_DVB_TUNER_ITD1000=m CONFIG_DVB_VES1X93=m CONFIG_DVB_ZL10036=m CONFIG_DVB_ZL10039=m # # DVB-T (terrestrial) frontends # CONFIG_DVB_AF9013=m CONFIG_DVB_CX22700=m CONFIG_DVB_CX22702=m CONFIG_DVB_CXD2820R=m CONFIG_DVB_CXD2841ER=m CONFIG_DVB_DIB3000MB=m CONFIG_DVB_DIB3000MC=m CONFIG_DVB_DIB7000M=m CONFIG_DVB_DIB7000P=m CONFIG_DVB_DIB9000=m CONFIG_DVB_DRXD=m CONFIG_DVB_EC100=m CONFIG_DVB_L64781=m CONFIG_DVB_MT352=m CONFIG_DVB_NXT6000=m CONFIG_DVB_RTL2830=m CONFIG_DVB_RTL2832=m CONFIG_DVB_RTL2832_SDR=m CONFIG_DVB_S5H1432=m CONFIG_DVB_SI2168=m CONFIG_DVB_SP887X=m CONFIG_DVB_STV0367=m CONFIG_DVB_TDA10048=m CONFIG_DVB_TDA1004X=m CONFIG_DVB_ZD1301_DEMOD=m CONFIG_DVB_ZL10353=m CONFIG_DVB_CXD2880=m # # DVB-C (cable) frontends # CONFIG_DVB_STV0297=m CONFIG_DVB_TDA10021=m CONFIG_DVB_TDA10023=m CONFIG_DVB_VES1820=m # # ATSC (North American/Korean Terrestrial/Cable DTV) frontends # CONFIG_DVB_AU8522=m CONFIG_DVB_AU8522_DTV=m CONFIG_DVB_AU8522_V4L=m CONFIG_DVB_BCM3510=m CONFIG_DVB_LG2160=m CONFIG_DVB_LGDT3305=m CONFIG_DVB_LGDT3306A=m CONFIG_DVB_LGDT330X=m CONFIG_DVB_MXL692=m CONFIG_DVB_NXT200X=m CONFIG_DVB_OR51132=m CONFIG_DVB_OR51211=m CONFIG_DVB_S5H1409=m CONFIG_DVB_S5H1411=m # # ISDB-T (terrestrial) frontends # CONFIG_DVB_DIB8000=m CONFIG_DVB_MB86A20S=m CONFIG_DVB_S921=m # # ISDB-S (satellite) & ISDB-T (terrestrial) frontends # CONFIG_DVB_MN88443X=m CONFIG_DVB_TC90522=m # # Digital terrestrial only tuners/PLL # CONFIG_DVB_PLL=m CONFIG_DVB_TUNER_DIB0070=m CONFIG_DVB_TUNER_DIB0090=m # # SEC control devices for DVB-S # CONFIG_DVB_A8293=m CONFIG_DVB_AF9033=m CONFIG_DVB_ASCOT2E=m CONFIG_DVB_ATBM8830=m CONFIG_DVB_HELENE=m CONFIG_DVB_HORUS3A=m CONFIG_DVB_ISL6405=m CONFIG_DVB_ISL6421=m CONFIG_DVB_ISL6423=m CONFIG_DVB_IX2505V=m CONFIG_DVB_LGS8GL5=m CONFIG_DVB_LGS8GXX=m CONFIG_DVB_LNBH25=m CONFIG_DVB_LNBH29=m CONFIG_DVB_LNBP21=m CONFIG_DVB_LNBP22=m CONFIG_DVB_M88RS2000=m CONFIG_DVB_TDA665x=m CONFIG_DVB_DRX39XYJ=m # # Common Interface (EN50221) controller drivers # CONFIG_DVB_CXD2099=m CONFIG_DVB_SP2=m # end of Customise DVB Frontends # # Tools to develop new frontends # # CONFIG_DVB_DUMMY_FE is not set # end of Media ancillary drivers # # Graphics support # CONFIG_DRM=m CONFIG_DRM_MIPI_DSI=y CONFIG_DRM_KMS_HELPER=m # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set # CONFIG_DRM_DEBUG_MODESET_LOCK is not set CONFIG_DRM_FBDEV_EMULATION=y CONFIG_DRM_FBDEV_OVERALLOC=100 # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set CONFIG_DRM_DP_AUX_BUS=m CONFIG_DRM_DISPLAY_HELPER=m CONFIG_DRM_DISPLAY_DP_HELPER=y CONFIG_DRM_DISPLAY_HDCP_HELPER=y CONFIG_DRM_DISPLAY_HDMI_HELPER=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DP_CEC is not set CONFIG_DRM_GEM_DMA_HELPER=m # # I2C encoder or helper chips # CONFIG_DRM_I2C_CH7006=m CONFIG_DRM_I2C_SIL164=m CONFIG_DRM_I2C_NXP_TDA998X=m # CONFIG_DRM_I2C_NXP_TDA9950 is not set # end of I2C encoder or helper chips # # ARM devices # CONFIG_DRM_HDLCD=m # CONFIG_DRM_HDLCD_SHOW_UNDERRUN is not set CONFIG_DRM_MALI_DISPLAY=m CONFIG_DRM_KOMEDA=m # end of ARM devices # CONFIG_DRM_RADEON is not set # CONFIG_DRM_AMDGPU is not set # CONFIG_DRM_NOUVEAU is not set # CONFIG_DRM_VGEM is not set # CONFIG_DRM_VKMS is not set # CONFIG_DRM_VMWGFX is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_AST is not set # CONFIG_DRM_MGAG200 is not set CONFIG_DRM_RCAR_DW_HDMI=m CONFIG_DRM_RCAR_USE_LVDS=y CONFIG_DRM_RCAR_USE_MIPI_DSI=y # CONFIG_DRM_QXL is not set # CONFIG_DRM_VIRTIO_GPU is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_ABT_Y030XX067A is not set # CONFIG_DRM_PANEL_ARM_VERSATILE is not set # CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set # CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set # CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m # CONFIG_DRM_PANEL_DSI_CM is not set CONFIG_DRM_PANEL_LVDS=m CONFIG_DRM_PANEL_SIMPLE=m CONFIG_DRM_PANEL_EDP=m # CONFIG_DRM_PANEL_EBBG_FT8719 is not set # CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set # CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set # CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set # CONFIG_DRM_PANEL_JDI_R63452 is not set # CONFIG_DRM_PANEL_KHADAS_TS050 is not set # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set # CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set # CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set # CONFIG_DRM_PANEL_LG_LB035Q02 is not set # CONFIG_DRM_PANEL_LG_LG4573 is not set # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set # CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set # CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set # CONFIG_DRM_PANEL_NOVATEK_NT35560 is not set # CONFIG_DRM_PANEL_NOVATEK_NT35950 is not set # CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set CONFIG_DRM_PANEL_MANTIX_MLAF057WE51=m # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set # CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set CONFIG_DRM_PANEL_RAYDIUM_RM67191=m # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set # CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set # CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set # CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set CONFIG_DRM_PANEL_SITRONIX_ST7703=m # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set # CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set # CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set # CONFIG_DRM_PANEL_TPO_TPG110 is not set CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m # CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set # CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set # CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set # end of Display Panels CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_CHIPONE_ICN6211 is not set # CONFIG_DRM_CHRONTEL_CH7033 is not set # CONFIG_DRM_CROS_EC_ANX7688 is not set CONFIG_DRM_DISPLAY_CONNECTOR=m # CONFIG_DRM_ITE_IT6505 is not set CONFIG_DRM_LONTIUM_LT8912B=m # CONFIG_DRM_LONTIUM_LT9211 is not set CONFIG_DRM_LONTIUM_LT9611=m CONFIG_DRM_LONTIUM_LT9611UXC=m CONFIG_DRM_ITE_IT66121=m # CONFIG_DRM_LVDS_CODEC is not set # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set CONFIG_DRM_NWL_MIPI_DSI=m # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set CONFIG_DRM_PARADE_PS8640=m # CONFIG_DRM_SIL_SII8620 is not set CONFIG_DRM_SII902X=m # CONFIG_DRM_SII9234 is not set CONFIG_DRM_SIMPLE_BRIDGE=m CONFIG_DRM_THINE_THC63LVD1024=m # CONFIG_DRM_TOSHIBA_TC358762 is not set # CONFIG_DRM_TOSHIBA_TC358764 is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TOSHIBA_TC358768 is not set # CONFIG_DRM_TOSHIBA_TC358775 is not set # CONFIG_DRM_TI_DLPC3433 is not set CONFIG_DRM_TI_TFP410=m # CONFIG_DRM_TI_SN65DSI83 is not set CONFIG_DRM_TI_SN65DSI86=m # CONFIG_DRM_TI_TPD12S015 is not set # CONFIG_DRM_ANALOGIX_ANX6345 is not set # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_ANALOGIX_ANX7625 is not set # CONFIG_DRM_I2C_ADV7511 is not set CONFIG_DRM_CDNS_DSI=m CONFIG_DRM_CDNS_DSI_J721E=y CONFIG_DRM_CDNS_MHDP8546=m CONFIG_DRM_CDNS_MHDP8546_J721E=y CONFIG_DRM_DW_HDMI=m CONFIG_DRM_DW_HDMI_AHB_AUDIO=m CONFIG_DRM_DW_HDMI_I2S_AUDIO=m # CONFIG_DRM_DW_HDMI_GP_AUDIO is not set CONFIG_DRM_DW_HDMI_CEC=m # end of Display Interface Bridges # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_HISI_HIBMC is not set # CONFIG_DRM_HISI_KIRIN is not set # CONFIG_DRM_LOGICVC is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_BOCHS is not set # CONFIG_DRM_CIRRUS_QEMU is not set # CONFIG_DRM_GM12U320 is not set # CONFIG_DRM_PANEL_MIPI_DBI is not set # CONFIG_DRM_SIMPLEDRM is not set # CONFIG_TINYDRM_HX8357D is not set # CONFIG_TINYDRM_ILI9163 is not set # CONFIG_TINYDRM_ILI9225 is not set # CONFIG_TINYDRM_ILI9341 is not set # CONFIG_TINYDRM_ILI9486 is not set # CONFIG_TINYDRM_MI0283QT is not set # CONFIG_TINYDRM_REPAPER is not set # CONFIG_TINYDRM_ST7586 is not set # CONFIG_TINYDRM_ST7735R is not set # CONFIG_DRM_PL111 is not set # CONFIG_DRM_LIMA is not set # CONFIG_DRM_PANFROST is not set CONFIG_DRM_TIDSS=m # CONFIG_DRM_GUD is not set # CONFIG_DRM_SSD130X is not set CONFIG_DRM_LEGACY=y # CONFIG_DRM_TDFX is not set # CONFIG_DRM_R128 is not set # CONFIG_DRM_MGA is not set # CONFIG_DRM_VIA is not set # CONFIG_DRM_SAVAGE is not set CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m CONFIG_DRM_NOMODESET=y # # Frame buffer Devices # CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set CONFIG_FB_CFB_FILLRECT=m CONFIG_FB_CFB_COPYAREA=m CONFIG_FB_CFB_IMAGEBLIT=m CONFIG_FB_SYS_FILLRECT=m CONFIG_FB_SYS_COPYAREA=m CONFIG_FB_SYS_IMAGEBLIT=m # CONFIG_FB_FOREIGN_ENDIAN is not set CONFIG_FB_SYS_FOPS=m CONFIG_FB_DEFERRED_IO=y CONFIG_FB_MODE_HELPERS=y # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_ARMCLCD is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set # CONFIG_FB_EFI is not set # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_I740 is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set # CONFIG_FB_SIMPLE is not set # CONFIG_FB_SSD1307 is not set # CONFIG_FB_SM712 is not set # end of Frame buffer Devices # # Backlight & LCD device support # # CONFIG_LCD_CLASS_DEVICE is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y # CONFIG_BACKLIGHT_KTD253 is not set CONFIG_BACKLIGHT_PWM=m # CONFIG_BACKLIGHT_QCOM_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3630A is not set # CONFIG_BACKLIGHT_LM3639 is not set CONFIG_BACKLIGHT_LP855X=m # CONFIG_BACKLIGHT_GPIO is not set # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set # CONFIG_BACKLIGHT_ARCXCNN is not set # CONFIG_BACKLIGHT_LED is not set # end of Backlight & LCD device support CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_DUMMY_CONSOLE_COLUMNS=80 CONFIG_DUMMY_CONSOLE_ROWS=25 CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set # end of Console display driver support CONFIG_LOGO=y # CONFIG_LOGO_LINUX_MONO is not set # CONFIG_LOGO_LINUX_VGA16 is not set CONFIG_LOGO_LINUX_CLUT224=y # end of Graphics support CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_PCM_ELD=y CONFIG_SND_PCM_IEC958=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_MAX_CARDS=32 CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set CONFIG_SND_CTL_FAST_LOOKUP=y # CONFIG_SND_DEBUG is not set # CONFIG_SND_CTL_INPUT_VALIDATION is not set # CONFIG_SND_SEQUENCER is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_SERIAL_GENERIC is not set # CONFIG_SND_MPU401 is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ALS300 is not set # CONFIG_SND_ALI5451 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_AZT3328 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_EMU10K1 is not set # CONFIG_SND_EMU10K1X is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_ES1938 is not set # CONFIG_SND_ES1968 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_ICE1712 is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LOLA is not set # CONFIG_SND_LX6464ES is not set # CONFIG_SND_MAESTRO3 is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SE6X is not set # CONFIG_SND_SONICVIBES is not set # CONFIG_SND_TRIDENT is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # # HD-Audio # # CONFIG_SND_HDA_INTEL is not set # end of HD-Audio CONFIG_SND_HDA_PREALLOC_SIZE=64 # CONFIG_SND_SPI is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=m CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_ADI is not set # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_AMD_ACP_CONFIG is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # CONFIG_SND_SOC_FSL_ASRC=m # CONFIG_SND_SOC_FSL_SAI is not set CONFIG_SND_SOC_FSL_AUDMIX=m CONFIG_SND_SOC_FSL_SSI=m CONFIG_SND_SOC_FSL_SPDIF=m CONFIG_SND_SOC_FSL_ESAI=m CONFIG_SND_SOC_FSL_MICFIL=m CONFIG_SND_SOC_FSL_EASRC=m # CONFIG_SND_SOC_FSL_XCVR is not set CONFIG_SND_SOC_FSL_UTILS=m # CONFIG_SND_SOC_FSL_RPMSG is not set CONFIG_SND_SOC_IMX_AUDMUX=m # end of SoC Audio for Freescale CPUs # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set # CONFIG_SND_SOC_SOF_TOPLEVEL is not set # # STMicroelectronics STM32 SOC audio support # # end of STMicroelectronics STM32 SOC audio support # # Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_TI_EDMA_PCM=m CONFIG_SND_SOC_TI_SDMA_PCM=m CONFIG_SND_SOC_TI_UDMA_PCM=m # # Texas Instruments DAI support for: # CONFIG_SND_SOC_DAVINCI_MCASP=m # # Audio support for boards with Texas Instruments SoCs # CONFIG_SND_SOC_J721E_EVM=m # end of Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1372_I2C is not set # CONFIG_SND_SOC_ADAU1372_SPI is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set CONFIG_SND_SOC_ADAU7002=m # CONFIG_SND_SOC_ADAU7118_HW is not set # CONFIG_SND_SOC_ADAU7118_I2C is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4375 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_AW8738 is not set # CONFIG_SND_SOC_BD28623 is not set # CONFIG_SND_SOC_BT_SCO is not set CONFIG_SND_SOC_CROS_EC_CODEC=m # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS35L41_SPI is not set # CONFIG_SND_SOC_CS35L41_I2C is not set # CONFIG_SND_SOC_CS35L45_SPI is not set # CONFIG_SND_SOC_CS35L45_I2C is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS42L83 is not set # CONFIG_SND_SOC_CS4234 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_CX2072X is not set # CONFIG_SND_SOC_DA7213 is not set CONFIG_SND_SOC_DMIC=m CONFIG_SND_SOC_HDMI_CODEC=m # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8326 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set CONFIG_SND_SOC_GTM601=m # CONFIG_SND_SOC_HDA is not set # CONFIG_SND_SOC_ICS43432 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set CONFIG_SND_SOC_MAX98357A=m # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set CONFIG_SND_SOC_MAX98927=m # CONFIG_SND_SOC_MAX98520 is not set # CONFIG_SND_SOC_MAX98373_I2C is not set # CONFIG_SND_SOC_MAX98373_SDW is not set # CONFIG_SND_SOC_MAX98390 is not set # CONFIG_SND_SOC_MAX98396 is not set # CONFIG_SND_SOC_MAX9860 is not set CONFIG_SND_SOC_MSM8916_WCD_ANALOG=m CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM186X_SPI is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3060_SPI is not set CONFIG_SND_SOC_PCM3168A=m CONFIG_SND_SOC_PCM3168A_I2C=m # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM5102A is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RK817 is not set CONFIG_SND_SOC_RL6231=m # CONFIG_SND_SOC_RT1308_SDW is not set # CONFIG_SND_SOC_RT1316_SDW is not set # CONFIG_SND_SOC_RT1318_SDW is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_RT5640 is not set CONFIG_SND_SOC_RT5659=m # CONFIG_SND_SOC_RT5682_SDW is not set # CONFIG_SND_SOC_RT700_SDW is not set # CONFIG_SND_SOC_RT711_SDW is not set # CONFIG_SND_SOC_RT711_SDCA_SDW is not set # CONFIG_SND_SOC_RT715_SDW is not set # CONFIG_SND_SOC_RT715_SDCA_SDW is not set # CONFIG_SND_SOC_RT9120 is not set # CONFIG_SND_SOC_SDW_MOCKUP is not set CONFIG_SND_SOC_SGTL5000=m CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m CONFIG_SND_SOC_SIMPLE_MUX=m CONFIG_SND_SOC_SPDIF=m # CONFIG_SND_SOC_SRC4XXX_I2C is not set # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2518 is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS2562 is not set # CONFIG_SND_SOC_TAS2764 is not set # CONFIG_SND_SOC_TAS2770 is not set # CONFIG_SND_SOC_TAS2780 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS5805M is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TFA989X is not set # CONFIG_SND_SOC_TLV320ADC3XXX is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set CONFIG_SND_SOC_TLV320AIC31XX=m CONFIG_SND_SOC_TLV320AIC32X4=m CONFIG_SND_SOC_TLV320AIC32X4_I2C=m # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set CONFIG_SND_SOC_TLV320AIC3X=m CONFIG_SND_SOC_TLV320AIC3X_I2C=m # CONFIG_SND_SOC_TLV320AIC3X_SPI is not set # CONFIG_SND_SOC_TLV320ADCX140 is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_UDA1334 is not set CONFIG_SND_SOC_WCD9335=m CONFIG_SND_SOC_WCD_MBHC=m CONFIG_SND_SOC_WCD934X=m CONFIG_SND_SOC_WCD938X=m CONFIG_SND_SOC_WCD938X_SDW=m # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set CONFIG_SND_SOC_WM8524=m # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731_I2C is not set # CONFIG_SND_SOC_WM8731_SPI is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set CONFIG_SND_SOC_WM8904=m # CONFIG_SND_SOC_WM8940 is not set CONFIG_SND_SOC_WM8960=m CONFIG_SND_SOC_WM8962=m # CONFIG_SND_SOC_WM8974 is not set CONFIG_SND_SOC_WM8978=m # CONFIG_SND_SOC_WM8985 is not set CONFIG_SND_SOC_WSA881X=m # CONFIG_SND_SOC_WSA883X is not set # CONFIG_SND_SOC_ZL38060 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_MT6660 is not set # CONFIG_SND_SOC_NAU8315 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8821 is not set CONFIG_SND_SOC_NAU8822=m # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set CONFIG_SND_SOC_LPASS_MACRO_COMMON=m CONFIG_SND_SOC_LPASS_WSA_MACRO=m CONFIG_SND_SOC_LPASS_VA_MACRO=m CONFIG_SND_SOC_LPASS_RX_MACRO=m CONFIG_SND_SOC_LPASS_TX_MACRO=m # end of CODEC drivers CONFIG_SND_SIMPLE_CARD_UTILS=m CONFIG_SND_SIMPLE_CARD=m CONFIG_SND_AUDIO_GRAPH_CARD=m CONFIG_SND_AUDIO_GRAPH_CARD2=m # CONFIG_SND_AUDIO_GRAPH_CARD2_CUSTOM_SAMPLE is not set # CONFIG_SND_TEST_COMPONENT is not set # CONFIG_SND_VIRTIO is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACCUTOUCH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_ASUS is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_BETOP_FF is not set # CONFIG_HID_BIGBEN_FF is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CORSAIR is not set # CONFIG_HID_COUGAR is not set # CONFIG_HID_MACALLY is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set # CONFIG_HID_CREATIVE_SB0540 is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELAN is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_GLORIOUS is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_GOOGLE_HAMMER is not set # CONFIG_HID_VIVALDI is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_VIEWSONIC is not set # CONFIG_HID_VRC2 is not set # CONFIG_HID_XIAOMI is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_ITE is not set # CONFIG_HID_JABRA is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_LETSKETCH is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MALTRON is not set # CONFIG_HID_MAYFLASH is not set # CONFIG_HID_MEGAWORLD_FF is not set # CONFIG_HID_REDRAGON is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set CONFIG_HID_MULTITOUCH=m # CONFIG_HID_NINTENDO is not set # CONFIG_HID_NTI is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PLAYSTATION is not set # CONFIG_HID_PXRC is not set # CONFIG_HID_RAZER is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_RETRODE is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SEMITEK is not set # CONFIG_HID_SIGMAMICRO is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEAM is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_TOPRE is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_U2FZERO is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # CONFIG_HID_MCP2221 is not set # end of Special HID drivers # # USB HID support # CONFIG_USB_HID=y # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # end of USB HID support # # I2C HID support # CONFIG_I2C_HID_OF=m # CONFIG_I2C_HID_OF_ELAN is not set # CONFIG_I2C_HID_OF_GOODIX is not set # end of I2C HID support CONFIG_I2C_HID_CORE=m # end of HID support CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y # CONFIG_USB_LED_TRIG is not set CONFIG_USB_ULPI_BUS=y CONFIG_USB_CONN_GPIO=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y CONFIG_USB_PCI=y # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_FEW_INIT_RETRIES is not set # CONFIG_USB_DYNAMIC_MINORS is not set CONFIG_USB_OTG=y # CONFIG_USB_OTG_PRODUCTLIST is not set # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set # CONFIG_USB_OTG_FSM is not set # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set CONFIG_USB_AUTOSUSPEND_DELAY=2 # CONFIG_USB_MON is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set CONFIG_USB_XHCI_HCD=y # CONFIG_USB_XHCI_DBGCAP is not set CONFIG_USB_XHCI_PCI=m CONFIG_USB_XHCI_PCI_RENESAS=m CONFIG_USB_XHCI_PLATFORM=m CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_ROOT_HUB_TT=y CONFIG_USB_EHCI_TT_NEWSCHED=y CONFIG_USB_EHCI_PCI=y # CONFIG_USB_EHCI_FSL is not set CONFIG_USB_EHCI_HCD_PLATFORM=y # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_HCD_PCI=y CONFIG_USB_OHCI_HCD_PLATFORM=y # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=m # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set # CONFIG_USB_UAS is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set CONFIG_USB_CDNS_SUPPORT=m CONFIG_USB_CDNS_HOST=y CONFIG_USB_CDNS3=m CONFIG_USB_CDNS3_GADGET=y CONFIG_USB_CDNS3_HOST=y CONFIG_USB_CDNS3_TI=m # CONFIG_USB_MUSB_HDRC is not set CONFIG_USB_DWC3=m # CONFIG_USB_DWC3_ULPI is not set # CONFIG_USB_DWC3_HOST is not set # CONFIG_USB_DWC3_GADGET is not set CONFIG_USB_DWC3_DUAL_ROLE=y # # Platform Glue Driver Support # CONFIG_USB_DWC3_HAPS=m CONFIG_USB_DWC3_KEYSTONE=m CONFIG_USB_DWC3_OF_SIMPLE=m CONFIG_USB_DWC3_AM62=m # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set # CONFIG_USB_ISP1760 is not set # # USB port drivers # CONFIG_USB_SERIAL=m # CONFIG_USB_SERIAL_GENERIC is not set # CONFIG_USB_SERIAL_SIMPLE is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set CONFIG_USB_SERIAL_CP210X=m # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set CONFIG_USB_SERIAL_FTDI_SIO=m # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_F8153X is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set CONFIG_USB_SERIAL_WWAN=m CONFIG_USB_SERIAL_OPTION=m # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_UPD78F0730 is not set # CONFIG_USB_SERIAL_XR is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_APPLE_MFI_FASTCHARGE is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HUB_USB251XB is not set # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # CONFIG_USB_CHAOSKEY is not set # CONFIG_USB_ONBOARD_HUB is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=y # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ISP1301 is not set CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT=y # end of USB Physical Layer drivers CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32 # CONFIG_U_SERIAL_CONSOLE is not set # # USB Peripheral Controller # # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set CONFIG_USB_SNP_CORE=y CONFIG_USB_SNP_UDC_PLAT=y # CONFIG_USB_M66592 is not set CONFIG_USB_BDC_UDC=y # CONFIG_USB_AMD5536UDC is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_NET2280 is not set # CONFIG_USB_GOKU is not set # CONFIG_USB_EG20T is not set # CONFIG_USB_GADGET_XILINX is not set # CONFIG_USB_MAX3420_UDC is not set # CONFIG_USB_DUMMY_HCD is not set # end of USB Peripheral Controller CONFIG_USB_LIBCOMPOSITE=m CONFIG_USB_F_ACM=m CONFIG_USB_F_SS_LB=m CONFIG_USB_U_SERIAL=m CONFIG_USB_U_ETHER=m CONFIG_USB_F_SERIAL=m CONFIG_USB_F_OBEX=m CONFIG_USB_F_NCM=m CONFIG_USB_F_ECM=m CONFIG_USB_F_EEM=m CONFIG_USB_F_SUBSET=m CONFIG_USB_F_RNDIS=m CONFIG_USB_F_MASS_STORAGE=m CONFIG_USB_F_FS=m CONFIG_USB_CONFIGFS=m CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_OBEX=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_ECM_SUBSET=y CONFIG_USB_CONFIGFS_RNDIS=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y # CONFIG_USB_CONFIGFS_F_LB_SS is not set CONFIG_USB_CONFIGFS_F_FS=y # CONFIG_USB_CONFIGFS_F_UAC1 is not set # CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set # CONFIG_USB_CONFIGFS_F_UAC2 is not set # CONFIG_USB_CONFIGFS_F_MIDI is not set # CONFIG_USB_CONFIGFS_F_HID is not set # CONFIG_USB_CONFIGFS_F_UVC is not set # CONFIG_USB_CONFIGFS_F_PRINTER is not set # # USB Gadget precomposed configurations # CONFIG_USB_ZERO=m # CONFIG_USB_ZERO_HNPTEST is not set # CONFIG_USB_AUDIO is not set CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set CONFIG_USB_G_NCM=m # CONFIG_USB_GADGETFS is not set # CONFIG_USB_FUNCTIONFS is not set CONFIG_USB_MASS_STORAGE=m CONFIG_USB_G_SERIAL=m # CONFIG_USB_MIDI_GADGET is not set # CONFIG_USB_G_PRINTER is not set CONFIG_USB_CDC_COMPOSITE=m # CONFIG_USB_G_ACM_MS is not set CONFIG_USB_G_MULTI=m CONFIG_USB_G_MULTI_RNDIS=y CONFIG_USB_G_MULTI_CDC=y # CONFIG_USB_G_HID is not set # CONFIG_USB_G_DBGP is not set # CONFIG_USB_G_WEBCAM is not set # CONFIG_USB_RAW_GADGET is not set # end of USB Gadget precomposed configurations CONFIG_TYPEC=m CONFIG_TYPEC_TCPM=m CONFIG_TYPEC_TCPCI=m # CONFIG_TYPEC_RT1711H is not set # CONFIG_TYPEC_MT6360 is not set # CONFIG_TYPEC_TCPCI_MAXIM is not set CONFIG_TYPEC_FUSB302=m # CONFIG_TYPEC_UCSI is not set CONFIG_TYPEC_TPS6598X=m # CONFIG_TYPEC_ANX7411 is not set # CONFIG_TYPEC_RT1719 is not set CONFIG_TYPEC_HD3SS3220=m # CONFIG_TYPEC_STUSB160X is not set # CONFIG_TYPEC_WUSB3801 is not set # # USB Type-C Multiplexer/DeMultiplexer Switch support # # CONFIG_TYPEC_MUX_FSA4480 is not set # CONFIG_TYPEC_MUX_PI3USB30532 is not set # end of USB Type-C Multiplexer/DeMultiplexer Switch support # # USB Type-C Alternate Mode drivers # # CONFIG_TYPEC_DP_ALTMODE is not set # end of USB Type-C Alternate Mode drivers CONFIG_USB_ROLE_SWITCH=y CONFIG_MMC=y CONFIG_PWRSEQ_EMMC=y # CONFIG_PWRSEQ_SD8787 is not set CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=32 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_DEBUG is not set CONFIG_MMC_ARMMMCI=y CONFIG_MMC_STM32_SDMMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_IO_ACCESSORS=y # CONFIG_MMC_SDHCI_PCI is not set CONFIG_MMC_SDHCI_PLTFM=y CONFIG_MMC_SDHCI_OF_ARASAN=y # CONFIG_MMC_SDHCI_OF_AT91 is not set CONFIG_MMC_SDHCI_OF_DWCMSHC=y CONFIG_MMC_SDHCI_CADENCE=y CONFIG_MMC_SDHCI_F_SDH30=y # CONFIG_MMC_SDHCI_MILBEAUT is not set # CONFIG_MMC_TIFM_SD is not set CONFIG_MMC_SPI=y # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set CONFIG_MMC_DW=y CONFIG_MMC_DW_PLTFM=y # CONFIG_MMC_DW_BLUEFIELD is not set CONFIG_MMC_DW_EXYNOS=y CONFIG_MMC_DW_HI3798CV200=y CONFIG_MMC_DW_K3=y # CONFIG_MMC_DW_PCI is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set CONFIG_MMC_CQHCI=y # CONFIG_MMC_HSQ is not set # CONFIG_MMC_TOSHIBA_PCI is not set CONFIG_MMC_MTK=y CONFIG_MMC_SDHCI_XENON=y # CONFIG_MMC_SDHCI_OMAP is not set CONFIG_MMC_SDHCI_AM654=y CONFIG_SCSI_UFSHCD=y CONFIG_SCSI_UFS_BSG=y # CONFIG_SCSI_UFS_HPB is not set # CONFIG_SCSI_UFS_HWMON is not set # CONFIG_SCSI_UFSHCD_PCI is not set CONFIG_SCSI_UFSHCD_PLATFORM=y CONFIG_SCSI_UFS_CDNS_PLATFORM=m # CONFIG_SCSI_UFS_DWC_TC_PLATFORM is not set CONFIG_SCSI_UFS_TI_J721E=m # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # CONFIG_LEDS_CLASS_FLASH is not set CONFIG_LEDS_CLASS_MULTICOLOR=m # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_AN30259A is not set # CONFIG_LEDS_AW2013 is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_CR0014114 is not set # CONFIG_LEDS_EL15203000 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3532 is not set # CONFIG_LEDS_LM3642 is not set CONFIG_LEDS_LM3692X=m # CONFIG_LEDS_MT6323 is not set CONFIG_LEDS_PCA9532=m # CONFIG_LEDS_PCA9532_GPIO is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP50XX is not set # CONFIG_LEDS_LP55XX_COMMON is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set CONFIG_LEDS_PWM=y # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_TLC591XX is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set CONFIG_LEDS_SYSCON=y # CONFIG_LEDS_MLXREG is not set # CONFIG_LEDS_USER is not set # CONFIG_LEDS_SPI_BYTE is not set # CONFIG_LEDS_TI_LMU_COMMON is not set # # Flash and Torch LED drivers # # # RGB LED drivers # # CONFIG_LEDS_PWM_MULTICOLOR is not set CONFIG_LEDS_QCOM_LPG=m # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y # CONFIG_LEDS_TRIGGER_ONESHOT is not set CONFIG_LEDS_TRIGGER_DISK=y # CONFIG_LEDS_TRIGGER_MTD is not set CONFIG_LEDS_TRIGGER_HEARTBEAT=y # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set CONFIG_LEDS_TRIGGER_CPU=y # CONFIG_LEDS_TRIGGER_ACTIVITY is not set # CONFIG_LEDS_TRIGGER_GPIO is not set CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_LEDS_TRIGGER_TRANSIENT is not set # CONFIG_LEDS_TRIGGER_CAMERA is not set CONFIG_LEDS_TRIGGER_PANIC=y # CONFIG_LEDS_TRIGGER_NETDEV is not set # CONFIG_LEDS_TRIGGER_PATTERN is not set # CONFIG_LEDS_TRIGGER_AUDIO is not set # CONFIG_LEDS_TRIGGER_TTY is not set # # Simple LED drivers # # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_SUPPORT=y CONFIG_EDAC=y CONFIG_EDAC_LEGACY_SYSFS=y # CONFIG_EDAC_DEBUG is not set # CONFIG_EDAC_THUNDERX is not set # CONFIG_EDAC_XGENE is not set # CONFIG_EDAC_DMC520 is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set CONFIG_RTC_DRV_DS1307=m # CONFIG_RTC_DRV_DS1307_CENTURY is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set CONFIG_RTC_DRV_HYM8563=m # CONFIG_RTC_DRV_MAX6900 is not set CONFIG_RTC_DRV_MAX77686=y # CONFIG_RTC_DRV_NCT3018Y is not set CONFIG_RTC_DRV_RK808=m # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_ISL12026 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set CONFIG_RTC_DRV_PCF85063=m CONFIG_RTC_DRV_PCF85363=m # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set CONFIG_RTC_DRV_M41T80=m # CONFIG_RTC_DRV_M41T80_WDT is not set CONFIG_RTC_DRV_BQ32K=m CONFIG_RTC_DRV_TPS6594=y # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set CONFIG_RTC_DRV_RX8581=m # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set CONFIG_RTC_DRV_RV3028=m # CONFIG_RTC_DRV_RV3032 is not set CONFIG_RTC_DRV_RV8803=m CONFIG_RTC_DRV_S5M=y # CONFIG_RTC_DRV_SD3078 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # CONFIG_RTC_DRV_DS3232=y CONFIG_RTC_DRV_DS3232_HWMON=y CONFIG_RTC_DRV_PCF2127=m # CONFIG_RTC_DRV_RV3029C2 is not set # CONFIG_RTC_DRV_RX6110 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set CONFIG_RTC_DRV_EFI=y # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_OPTEE is not set # CONFIG_RTC_DRV_ZYNQMP is not set CONFIG_RTC_DRV_CROS_EC=y # # on-CPU RTC drivers # # CONFIG_RTC_DRV_PL030 is not set CONFIG_RTC_DRV_PL031=y # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set CONFIG_RTC_DRV_MT6397=m # CONFIG_RTC_DRV_R7301 is not set CONFIG_RTC_DRV_TI_K3=m # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_GOLDFISH is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_ASYNC_TX_ENABLE_CHANNEL_SWITCH=y CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set # CONFIG_AMBA_PL08X is not set CONFIG_BCM_SBA_RAID=m # CONFIG_DW_AXI_DMAC is not set CONFIG_FSL_EDMA=y # CONFIG_FSL_QDMA is not set # CONFIG_INTEL_IDMA64 is not set CONFIG_MV_XOR_V2=y CONFIG_PL330_DMA=y # CONFIG_PLX_DMA is not set # CONFIG_XILINX_DMA is not set # CONFIG_XILINX_ZYNQMP_DMA is not set # CONFIG_XILINX_ZYNQMP_DPDMA is not set CONFIG_QCOM_HIDMA_MGMT=y CONFIG_QCOM_HIDMA=y # CONFIG_DW_DMAC is not set # CONFIG_DW_DMAC_PCI is not set # CONFIG_DW_EDMA is not set # CONFIG_DW_EDMA_PCIE is not set # CONFIG_SF_PDMA is not set CONFIG_TI_K3_UDMA=y CONFIG_TI_K3_UDMA_GLUE_LAYER=y CONFIG_TI_K3_PSIL=y # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set CONFIG_DMA_ENGINE_RAID=y # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_UDMABUF is not set # CONFIG_DMABUF_MOVE_NOTIFY is not set # CONFIG_DMABUF_DEBUG is not set # CONFIG_DMABUF_SELFTESTS is not set CONFIG_DMABUF_HEAPS=y # CONFIG_DMABUF_SYSFS_STATS is not set CONFIG_DMABUF_HEAPS_SYSTEM=y CONFIG_DMABUF_HEAPS_CMA=y CONFIG_DMABUF_HEAPS_CARVEOUT=y # end of DMABUF options # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set CONFIG_VFIO=y CONFIG_VFIO_IOMMU_TYPE1=y CONFIG_VFIO_VIRQFD=y # CONFIG_VFIO_NOIOMMU is not set CONFIG_VFIO_PCI_CORE=y CONFIG_VFIO_PCI_MMAP=y CONFIG_VFIO_PCI_INTX=y CONFIG_VFIO_PCI=y # CONFIG_MLX5_VFIO_PCI is not set # CONFIG_VFIO_PLATFORM is not set # CONFIG_VFIO_MDEV is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO_ANCHOR=y CONFIG_VIRTIO=y CONFIG_VIRTIO_PCI_LIB=y CONFIG_VIRTIO_PCI_LIB_LEGACY=y CONFIG_VIRTIO_MENU=y CONFIG_VIRTIO_PCI=y CONFIG_VIRTIO_PCI_LEGACY=y CONFIG_VIRTIO_BALLOON=y # CONFIG_VIRTIO_MEM is not set # CONFIG_VIRTIO_INPUT is not set CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # CONFIG_VDPA is not set CONFIG_VHOST_MENU=y # CONFIG_VHOST_NET is not set # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set # # Microsoft Hyper-V guest support # # end of Microsoft Hyper-V guest support # CONFIG_GREYBUS is not set # CONFIG_COMEDI is not set CONFIG_STAGING=y # CONFIG_PRISM2_USB is not set # CONFIG_RTL8192U is not set # CONFIG_RTLLIB is not set # CONFIG_RTL8723BS is not set # CONFIG_R8712U is not set # CONFIG_R8188EU is not set # CONFIG_RTS5208 is not set # CONFIG_VT6655 is not set # CONFIG_VT6656 is not set # # IIO staging drivers # # # Accelerometers # # CONFIG_ADIS16203 is not set # CONFIG_ADIS16240 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7816 is not set # end of Analog to digital converters # # Analog digital bi-direction converters # # CONFIG_ADT7316 is not set # end of Analog digital bi-direction converters # # Direct Digital Synthesis # # CONFIG_AD9832 is not set # CONFIG_AD9834 is not set # end of Direct Digital Synthesis # # Network Analyzer, Impedance Converters # # CONFIG_AD5933 is not set # end of Network Analyzer, Impedance Converters # # Active energy metering IC # # CONFIG_ADE7854 is not set # end of Active energy metering IC # # Resolver to digital converters # # CONFIG_AD2S1210 is not set # end of Resolver to digital converters # end of IIO staging drivers # CONFIG_FB_SM750 is not set CONFIG_STAGING_MEDIA=y CONFIG_VIDEO_MAX96712=m # CONFIG_STAGING_MEDIA_DEPRECATED is not set # CONFIG_STAGING_BOARD is not set # CONFIG_LTE_GDM724X is not set # CONFIG_FB_TFT is not set # CONFIG_KS7010 is not set # CONFIG_PI433 is not set # CONFIG_XIL_AXIS_FIFO is not set # CONFIG_FIELDBUS_DEV is not set # CONFIG_QLGE is not set # CONFIG_VME_BUS is not set # CONFIG_GOLDFISH is not set CONFIG_CHROME_PLATFORMS=y CONFIG_CROS_EC=y CONFIG_CROS_EC_I2C=y # CONFIG_CROS_EC_RPMSG is not set CONFIG_CROS_EC_SPI=y CONFIG_CROS_EC_PROTO=y # CONFIG_CROS_KBD_LED_BACKLIGHT is not set CONFIG_CROS_EC_CHARDEV=m CONFIG_CROS_EC_LIGHTBAR=y CONFIG_CROS_EC_VBC=y CONFIG_CROS_EC_DEBUGFS=y CONFIG_CROS_EC_SENSORHUB=y CONFIG_CROS_EC_SYSFS=y CONFIG_CROS_EC_TYPEC=m CONFIG_CROS_USBPD_NOTIFY=y # CONFIG_MELLANOX_PLATFORM is not set CONFIG_SURFACE_PLATFORMS=y CONFIG_HAVE_CLK=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Clock driver for ARM Reference designs # # CONFIG_CLK_ICST is not set # CONFIG_CLK_SP810 is not set CONFIG_CLK_VEXPRESS_OSC=y # end of Clock driver for ARM Reference designs # CONFIG_LMK04832 is not set # CONFIG_COMMON_CLK_MAX77686 is not set # CONFIG_COMMON_CLK_MAX9485 is not set CONFIG_COMMON_CLK_RK808=y CONFIG_COMMON_CLK_SCMI=y # CONFIG_COMMON_CLK_SI5341 is not set # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set CONFIG_COMMON_CLK_CS2000_CP=y CONFIG_COMMON_CLK_S2MPS11=y # CONFIG_COMMON_CLK_AXI_CLKGEN is not set CONFIG_COMMON_CLK_XGENE=y CONFIG_COMMON_CLK_PWM=y # CONFIG_COMMON_CLK_RS9_PCIE is not set CONFIG_COMMON_CLK_VC5=y # CONFIG_COMMON_CLK_VC7 is not set CONFIG_COMMON_CLK_BD718XX=m # CONFIG_COMMON_CLK_FIXED_MMIO is not set CONFIG_TI_SCI_CLK=y # CONFIG_TI_SCI_CLK_PROBE_FROM_FW is not set CONFIG_TI_SYSCON_CLK=y # CONFIG_XILINX_VCU is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set CONFIG_HWSPINLOCK=y # CONFIG_HWSPINLOCK_OMAP is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_OMAP_DM_TIMER=y CONFIG_ARM_ARCH_TIMER=y CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y CONFIG_ARM_ARCH_TIMER_OOL_WORKAROUND=y CONFIG_FSL_ERRATUM_A008585=y CONFIG_HISILICON_ERRATUM_161010101=y CONFIG_ARM64_ERRATUM_858921=y # CONFIG_MICROCHIP_PIT64B is not set # end of Clock Source drivers CONFIG_MAILBOX=y # CONFIG_ARM_MHU is not set # CONFIG_ARM_MHU_V2 is not set # CONFIG_PLATFORM_MHU is not set # CONFIG_PL320_MBOX is not set CONFIG_OMAP2PLUS_MBOX=y CONFIG_OMAP_MBOX_KFIFO_SIZE=256 # CONFIG_ALTERA_MBOX is not set CONFIG_TI_MESSAGE_MANAGER=y # CONFIG_MAILBOX_TEST is not set CONFIG_IOMMU_IOVA=y CONFIG_IOMMU_API=y CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # CONFIG_IOMMU_IO_PGTABLE=y CONFIG_IOMMU_IO_PGTABLE_LPAE=y # CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y # CONFIG_IOMMU_IO_PGTABLE_ARMV7S_SELFTEST is not set CONFIG_IOMMU_IO_PGTABLE_DART=y # end of Generic IOMMU Pagetable Support # CONFIG_IOMMU_DEBUGFS is not set CONFIG_IOMMU_DEFAULT_DMA_STRICT=y # CONFIG_IOMMU_DEFAULT_DMA_LAZY is not set # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set CONFIG_OF_IOMMU=y CONFIG_IOMMU_DMA=y CONFIG_ARM_SMMU=y # CONFIG_ARM_SMMU_LEGACY_DT_BINDINGS is not set CONFIG_ARM_SMMU_DISABLE_BYPASS_BY_DEFAULT=y CONFIG_ARM_SMMU_V3=y # CONFIG_ARM_SMMU_V3_SVA is not set # CONFIG_VIRTIO_IOMMU is not set # # Remoteproc drivers # CONFIG_REMOTEPROC=y # CONFIG_REMOTEPROC_CDEV is not set CONFIG_PRU_REMOTEPROC=m CONFIG_TI_K3_DSP_REMOTEPROC=m CONFIG_TI_K3_M4_REMOTEPROC=m CONFIG_TI_K3_R5_REMOTEPROC=m # end of Remoteproc drivers # # Rpmsg drivers # CONFIG_RPMSG=y CONFIG_RPMSG_CHAR=m CONFIG_RPMSG_CTRL=m CONFIG_RPMSG_NS=m CONFIG_RPMSG_QCOM_GLINK=y CONFIG_RPMSG_QCOM_GLINK_RPM=y CONFIG_RPMSG_VIRTIO=m CONFIG_RPMSG_PRU=m # end of Rpmsg drivers # # Rpmsg virtual device drivers # CONFIG_RPMSG_KDRV=y # CONFIG_RPMSG_KDRV_DEMO is not set # CONFIG_RPMSG_KDRV_DISPLAY is not set CONFIG_RPMSG_KDRV_ETH_SWITCH=y # end of Rpmsg virtual device drivers CONFIG_SOUNDWIRE=m # # SoundWire Devices # CONFIG_SOUNDWIRE_QCOM=m # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # end of Amlogic SoC drivers # # Broadcom SoC drivers # CONFIG_SOC_BRCMSTB=y # end of Broadcom SoC drivers # # NXP/Freescale QorIQ SoC drivers # # CONFIG_QUICC_ENGINE is not set CONFIG_FSL_RCPM=y # end of NXP/Freescale QorIQ SoC drivers # # fujitsu SoC drivers # # end of fujitsu SoC drivers # # i.MX SoC drivers # # end of i.MX SoC drivers # # Enable LiteX SoC Builder specific drivers # # CONFIG_LITEX_SOC_CONTROLLER is not set # end of Enable LiteX SoC Builder specific drivers # # Qualcomm SoC drivers # CONFIG_QCOM_QMI_HELPERS=m # end of Qualcomm SoC drivers CONFIG_SOC_TI=y CONFIG_TI_SCI_PM_DOMAINS=y CONFIG_TI_K3_RINGACC=y CONFIG_TI_K3_SOCINFO=y CONFIG_TI_PRUSS=m CONFIG_TI_SCI_INTA_MSI_DOMAIN=y # # Xilinx SoC drivers # # end of Xilinx SoC drivers # end of SOC (System On Chip) specific Drivers CONFIG_PM_DEVFREQ=y # # DEVFREQ Governors # CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set # CONFIG_DEVFREQ_GOV_POWERSAVE is not set CONFIG_DEVFREQ_GOV_USERSPACE=m # CONFIG_DEVFREQ_GOV_PASSIVE is not set # # DEVFREQ Drivers # # CONFIG_PM_DEVFREQ_EVENT is not set CONFIG_EXTCON=y # # Extcon Device Drivers # # CONFIG_EXTCON_ADC_JACK is not set # CONFIG_EXTCON_FSA9480 is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set CONFIG_EXTCON_PTN5150=m # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set CONFIG_EXTCON_USB_GPIO=y CONFIG_EXTCON_USBC_CROS_EC=y # CONFIG_EXTCON_USBC_TUSB320 is not set CONFIG_MEMORY=y # CONFIG_ARM_PL172_MPMC is not set CONFIG_OMAP_GPMC=y # CONFIG_OMAP_GPMC_DEBUG is not set CONFIG_IIO=y CONFIG_IIO_BUFFER=y # CONFIG_IIO_BUFFER_CB is not set # CONFIG_IIO_BUFFER_DMA is not set # CONFIG_IIO_BUFFER_DMAENGINE is not set # CONFIG_IIO_BUFFER_HW_CONSUMER is not set CONFIG_IIO_KFIFO_BUF=m CONFIG_IIO_TRIGGERED_BUFFER=m # CONFIG_IIO_CONFIGFS is not set CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 # CONFIG_IIO_SW_DEVICE is not set # CONFIG_IIO_SW_TRIGGER is not set # CONFIG_IIO_TRIGGERED_EVENT is not set # # Accelerometers # # CONFIG_ADIS16201 is not set # CONFIG_ADIS16209 is not set # CONFIG_ADXL313_I2C is not set # CONFIG_ADXL313_SPI is not set # CONFIG_ADXL345_I2C is not set # CONFIG_ADXL345_SPI is not set # CONFIG_ADXL355_I2C is not set # CONFIG_ADXL355_SPI is not set # CONFIG_ADXL367_SPI is not set # CONFIG_ADXL367_I2C is not set # CONFIG_ADXL372_SPI is not set # CONFIG_ADXL372_I2C is not set # CONFIG_BMA180 is not set # CONFIG_BMA220 is not set # CONFIG_BMA400 is not set # CONFIG_BMC150_ACCEL is not set # CONFIG_BMI088_ACCEL is not set # CONFIG_DA280 is not set # CONFIG_DA311 is not set # CONFIG_DMARD06 is not set # CONFIG_DMARD09 is not set # CONFIG_DMARD10 is not set # CONFIG_FXLS8962AF_I2C is not set # CONFIG_FXLS8962AF_SPI is not set # CONFIG_IIO_CROS_EC_ACCEL_LEGACY is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # CONFIG_KXCJK1013 is not set # CONFIG_MC3230 is not set # CONFIG_MMA7455_I2C is not set # CONFIG_MMA7455_SPI is not set # CONFIG_MMA7660 is not set # CONFIG_MMA8452 is not set # CONFIG_MMA9551 is not set # CONFIG_MMA9553 is not set # CONFIG_MSA311 is not set # CONFIG_MXC4005 is not set # CONFIG_MXC6255 is not set # CONFIG_SCA3000 is not set # CONFIG_SCA3300 is not set # CONFIG_STK8312 is not set # CONFIG_STK8BA50 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7091R5 is not set # CONFIG_AD7124 is not set # CONFIG_AD7192 is not set # CONFIG_AD7266 is not set # CONFIG_AD7280 is not set # CONFIG_AD7291 is not set # CONFIG_AD7292 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7606_IFACE_PARALLEL is not set # CONFIG_AD7606_IFACE_SPI is not set # CONFIG_AD7766 is not set # CONFIG_AD7768_1 is not set # CONFIG_AD7780 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_AD7949 is not set # CONFIG_AD799X is not set # CONFIG_ADI_AXI_ADC is not set # CONFIG_AXP20X_ADC is not set # CONFIG_AXP288_ADC is not set # CONFIG_CC10001_ADC is not set # CONFIG_ENVELOPE_DETECTOR is not set # CONFIG_HI8435 is not set # CONFIG_HX711 is not set # CONFIG_INA2XX_ADC is not set # CONFIG_LTC2471 is not set # CONFIG_LTC2485 is not set # CONFIG_LTC2496 is not set # CONFIG_LTC2497 is not set # CONFIG_MAX1027 is not set # CONFIG_MAX11100 is not set # CONFIG_MAX1118 is not set # CONFIG_MAX11205 is not set # CONFIG_MAX1241 is not set # CONFIG_MAX1363 is not set CONFIG_MAX9611=m # CONFIG_MCP320X is not set # CONFIG_MCP3422 is not set # CONFIG_MCP3911 is not set # CONFIG_MEDIATEK_MT6360_ADC is not set # CONFIG_NAU7802 is not set CONFIG_QCOM_VADC_COMMON=m # CONFIG_QCOM_SPMI_IADC is not set CONFIG_QCOM_SPMI_VADC=m CONFIG_QCOM_SPMI_ADC5=m # CONFIG_RICHTEK_RTQ6056 is not set # CONFIG_SD_ADC_MODULATOR is not set # CONFIG_TI_ADC081C is not set # CONFIG_TI_ADC0832 is not set # CONFIG_TI_ADC084S021 is not set # CONFIG_TI_ADC12138 is not set # CONFIG_TI_ADC108S102 is not set # CONFIG_TI_ADC128S052 is not set # CONFIG_TI_ADC161S626 is not set CONFIG_TI_ADS1015=m # CONFIG_TI_ADS7950 is not set # CONFIG_TI_ADS8344 is not set # CONFIG_TI_ADS8688 is not set # CONFIG_TI_ADS124S08 is not set # CONFIG_TI_ADS131E08 is not set CONFIG_TI_AM335X_ADC=m # CONFIG_TI_TLC4541 is not set # CONFIG_TI_TSC2046 is not set # CONFIG_VF610_ADC is not set # CONFIG_XILINX_XADC is not set # end of Analog to digital converters # # Analog to digital and digital to analog converters # # CONFIG_AD74413R is not set # end of Analog to digital and digital to analog converters # # Analog Front Ends # # CONFIG_IIO_RESCALE is not set # end of Analog Front Ends # # Amplifiers # # CONFIG_AD8366 is not set # CONFIG_ADA4250 is not set # CONFIG_HMC425 is not set # end of Amplifiers # # Capacitance to digital converters # # CONFIG_AD7150 is not set # CONFIG_AD7746 is not set # end of Capacitance to digital converters # # Chemical Sensors # # CONFIG_ATLAS_PH_SENSOR is not set # CONFIG_ATLAS_EZO_SENSOR is not set # CONFIG_BME680 is not set # CONFIG_CCS811 is not set # CONFIG_IAQCORE is not set # CONFIG_PMS7003 is not set # CONFIG_SCD30_CORE is not set # CONFIG_SCD4X is not set # CONFIG_SENSIRION_SGP30 is not set # CONFIG_SENSIRION_SGP40 is not set # CONFIG_SPS30_I2C is not set # CONFIG_SPS30_SERIAL is not set # CONFIG_SENSEAIR_SUNRISE_CO2 is not set # CONFIG_VZ89X is not set # end of Chemical Sensors CONFIG_IIO_CROS_EC_SENSORS_CORE=m CONFIG_IIO_CROS_EC_SENSORS=m # CONFIG_IIO_CROS_EC_SENSORS_LID_ANGLE is not set # # Hid Sensor IIO Common # # end of Hid Sensor IIO Common # # IIO SCMI Sensors # # CONFIG_IIO_SCMI is not set # end of IIO SCMI Sensors # # SSP Sensor Common # # CONFIG_IIO_SSP_SENSORHUB is not set # end of SSP Sensor Common CONFIG_IIO_ST_SENSORS_I2C=m CONFIG_IIO_ST_SENSORS_SPI=m CONFIG_IIO_ST_SENSORS_CORE=m # # Digital to analog converters # # CONFIG_AD3552R is not set # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5592R is not set # CONFIG_AD5593R is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_LTC2688 is not set # CONFIG_AD5686_SPI is not set # CONFIG_AD5696_I2C is not set # CONFIG_AD5755 is not set # CONFIG_AD5758 is not set # CONFIG_AD5761 is not set # CONFIG_AD5764 is not set # CONFIG_AD5766 is not set # CONFIG_AD5770R is not set # CONFIG_AD5791 is not set # CONFIG_AD7293 is not set # CONFIG_AD7303 is not set # CONFIG_AD8801 is not set # CONFIG_DPOT_DAC is not set # CONFIG_DS4424 is not set # CONFIG_LTC1660 is not set # CONFIG_LTC2632 is not set # CONFIG_M62332 is not set # CONFIG_MAX517 is not set # CONFIG_MAX5821 is not set # CONFIG_MCP4725 is not set # CONFIG_MCP4922 is not set # CONFIG_TI_DAC082S085 is not set # CONFIG_TI_DAC5571 is not set # CONFIG_TI_DAC7311 is not set # CONFIG_TI_DAC7612 is not set # CONFIG_VF610_DAC is not set # end of Digital to analog converters # # IIO dummy driver # # end of IIO dummy driver # # Filters # # CONFIG_ADMV8818 is not set # end of Filters # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # end of Clock Generator/Distribution # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # CONFIG_ADF4371 is not set # CONFIG_ADMV1013 is not set # CONFIG_ADMV1014 is not set # CONFIG_ADMV4420 is not set # CONFIG_ADRF6780 is not set # end of Phase-Locked Loop (PLL) frequency synthesizers # end of Frequency Synthesizers DDS/PLL # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS290 is not set # CONFIG_ADXRS450 is not set # CONFIG_BMG160 is not set # CONFIG_FXAS21002C is not set # CONFIG_MPU3050_I2C is not set # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # end of Digital gyroscope sensors # # Health Sensors # # # Heart Rate Monitors # # CONFIG_AFE4403 is not set # CONFIG_AFE4404 is not set # CONFIG_MAX30100 is not set # CONFIG_MAX30102 is not set # end of Heart Rate Monitors # end of Health Sensors # # Humidity sensors # # CONFIG_AM2315 is not set # CONFIG_DHT11 is not set # CONFIG_HDC100X is not set # CONFIG_HDC2010 is not set # CONFIG_HTS221 is not set # CONFIG_HTU21 is not set # CONFIG_SI7005 is not set # CONFIG_SI7020 is not set # end of Humidity sensors # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16460 is not set # CONFIG_ADIS16475 is not set # CONFIG_ADIS16480 is not set # CONFIG_BMI160_I2C is not set # CONFIG_BMI160_SPI is not set # CONFIG_BOSCH_BNO055_SERIAL is not set # CONFIG_BOSCH_BNO055_I2C is not set # CONFIG_FXOS8700_I2C is not set # CONFIG_FXOS8700_SPI is not set # CONFIG_KMX61 is not set # CONFIG_INV_ICM42600_I2C is not set # CONFIG_INV_ICM42600_SPI is not set # CONFIG_INV_MPU6050_I2C is not set # CONFIG_INV_MPU6050_SPI is not set CONFIG_IIO_ST_LSM6DSX=m CONFIG_IIO_ST_LSM6DSX_I2C=m CONFIG_IIO_ST_LSM6DSX_SPI=m # CONFIG_IIO_ST_LSM9DS0 is not set # end of Inertial measurement units # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_ADUX1020 is not set # CONFIG_AL3010 is not set # CONFIG_AL3320A is not set # CONFIG_APDS9300 is not set # CONFIG_APDS9960 is not set # CONFIG_AS73211 is not set # CONFIG_BH1750 is not set # CONFIG_BH1780 is not set # CONFIG_CM32181 is not set # CONFIG_CM3232 is not set # CONFIG_CM3323 is not set # CONFIG_CM3605 is not set # CONFIG_CM36651 is not set CONFIG_IIO_CROS_EC_LIGHT_PROX=m # CONFIG_GP2AP002 is not set # CONFIG_GP2AP020A00F is not set CONFIG_SENSORS_ISL29018=m # CONFIG_SENSORS_ISL29028 is not set # CONFIG_ISL29125 is not set # CONFIG_JSA1212 is not set # CONFIG_RPR0521 is not set # CONFIG_LTR501 is not set # CONFIG_LTRF216A is not set # CONFIG_LV0104CS is not set # CONFIG_MAX44000 is not set # CONFIG_MAX44009 is not set # CONFIG_NOA1305 is not set # CONFIG_OPT3001 is not set # CONFIG_PA12203001 is not set # CONFIG_SI1133 is not set # CONFIG_SI1145 is not set # CONFIG_STK3310 is not set # CONFIG_ST_UVIS25 is not set # CONFIG_TCS3414 is not set # CONFIG_TCS3472 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_TSL2583 is not set # CONFIG_TSL2591 is not set # CONFIG_TSL2772 is not set # CONFIG_TSL4531 is not set # CONFIG_US5182D is not set CONFIG_VCNL4000=m # CONFIG_VCNL4035 is not set # CONFIG_VEML6030 is not set # CONFIG_VEML6070 is not set # CONFIG_VL6180 is not set # CONFIG_ZOPT2201 is not set # end of Light sensors # # Magnetometer sensors # # CONFIG_AK8974 is not set # CONFIG_AK8975 is not set # CONFIG_AK09911 is not set # CONFIG_BMC150_MAGN_I2C is not set # CONFIG_BMC150_MAGN_SPI is not set # CONFIG_MAG3110 is not set # CONFIG_MMC35240 is not set CONFIG_IIO_ST_MAGN_3AXIS=m CONFIG_IIO_ST_MAGN_I2C_3AXIS=m CONFIG_IIO_ST_MAGN_SPI_3AXIS=m # CONFIG_SENSORS_HMC5843_I2C is not set # CONFIG_SENSORS_HMC5843_SPI is not set # CONFIG_SENSORS_RM3100_I2C is not set # CONFIG_SENSORS_RM3100_SPI is not set # CONFIG_YAMAHA_YAS530 is not set # end of Magnetometer sensors # # Multiplexers # # CONFIG_IIO_MUX is not set # end of Multiplexers # # Inclinometer sensors # # end of Inclinometer sensors # # Triggers - standalone # # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # end of Triggers - standalone # # Linear and angular position sensors # # end of Linear and angular position sensors # # Digital potentiometers # # CONFIG_AD5110 is not set # CONFIG_AD5272 is not set # CONFIG_DS1803 is not set # CONFIG_MAX5432 is not set # CONFIG_MAX5481 is not set # CONFIG_MAX5487 is not set # CONFIG_MCP4018 is not set # CONFIG_MCP4131 is not set # CONFIG_MCP4531 is not set # CONFIG_MCP41010 is not set # CONFIG_TPL0102 is not set # end of Digital potentiometers # # Digital potentiostats # # CONFIG_LMP91000 is not set # end of Digital potentiostats # # Pressure sensors # # CONFIG_ABP060MG is not set # CONFIG_BMP280 is not set CONFIG_IIO_CROS_EC_BARO=m # CONFIG_DLHL60D is not set # CONFIG_DPS310 is not set # CONFIG_HP03 is not set # CONFIG_ICP10100 is not set # CONFIG_MPL115_I2C is not set # CONFIG_MPL115_SPI is not set CONFIG_MPL3115=m # CONFIG_MS5611 is not set # CONFIG_MS5637 is not set # CONFIG_IIO_ST_PRESS is not set # CONFIG_T5403 is not set # CONFIG_HP206C is not set # CONFIG_ZPA2326 is not set # end of Pressure sensors # # Lightning sensors # # CONFIG_AS3935 is not set # end of Lightning sensors # # Proximity and distance sensors # # CONFIG_CROS_EC_MKBP_PROXIMITY is not set # CONFIG_ISL29501 is not set # CONFIG_LIDAR_LITE_V2 is not set # CONFIG_MB1232 is not set # CONFIG_PING is not set # CONFIG_RFD77402 is not set # CONFIG_SRF04 is not set # CONFIG_SX9310 is not set # CONFIG_SX9324 is not set # CONFIG_SX9360 is not set # CONFIG_SX9500 is not set # CONFIG_SRF08 is not set # CONFIG_VCNL3020 is not set # CONFIG_VL53L0X_I2C is not set # end of Proximity and distance sensors # # Resolver to digital converters # # CONFIG_AD2S90 is not set # CONFIG_AD2S1200 is not set # end of Resolver to digital converters # # Temperature sensors # # CONFIG_LTC2983 is not set # CONFIG_MAXIM_THERMOCOUPLE is not set # CONFIG_MLX90614 is not set # CONFIG_MLX90632 is not set # CONFIG_TMP006 is not set # CONFIG_TMP007 is not set # CONFIG_TMP117 is not set # CONFIG_TSYS01 is not set # CONFIG_TSYS02D is not set # CONFIG_MAX31856 is not set # CONFIG_MAX31865 is not set # end of Temperature sensors # CONFIG_NTB is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_DEBUG is not set # CONFIG_PWM_ATMEL_TCB is not set # CONFIG_PWM_CLK is not set CONFIG_PWM_CROS_EC=m # CONFIG_PWM_DWC is not set # CONFIG_PWM_FSL_FTM is not set CONFIG_PWM_OMAP_DMTIMER=m # CONFIG_PWM_PCA9685 is not set CONFIG_PWM_TIECAP=m CONFIG_PWM_TIEHRPWM=m # CONFIG_PWM_XILINX is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 CONFIG_ARM_GIC_V2M=y CONFIG_ARM_GIC_V3=y CONFIG_ARM_GIC_V3_ITS=y CONFIG_ARM_GIC_V3_ITS_PCI=y # CONFIG_AL_FIC is not set # CONFIG_XILINX_INTC is not set CONFIG_PARTITION_PERCPU=y CONFIG_TI_SCI_INTR_IRQCHIP=y CONFIG_TI_SCI_INTA_IRQCHIP=y CONFIG_TI_PRUSS_INTC=m # end of IRQ chip support # CONFIG_IPACK_BUS is not set CONFIG_RESET_CONTROLLER=y CONFIG_RESET_SCMI=y CONFIG_RESET_SIMPLE=y CONFIG_RESET_TI_SCI=y # CONFIG_RESET_TI_SYSCON is not set # CONFIG_RESET_TI_TPS380X is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y CONFIG_GENERIC_PHY_MIPI_DPHY=y CONFIG_PHY_XGENE=y CONFIG_PHY_CAN_TRANSCEIVER=m # # PHY drivers for Broadcom platforms # # CONFIG_BCM_KONA_USB2_PHY is not set # end of PHY drivers for Broadcom platforms CONFIG_PHY_CADENCE_TORRENT=y CONFIG_PHY_CADENCE_DPHY=m CONFIG_PHY_CADENCE_DPHY_RX=m CONFIG_PHY_CADENCE_SIERRA=y # CONFIG_PHY_CADENCE_SALVO is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_LAN966X_SERDES is not set # CONFIG_PHY_CPCAP_USB is not set # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_PHY_OCELOT_SERDES is not set CONFIG_PHY_QCOM_USB_HS=m # CONFIG_PHY_QCOM_USB_HSIC is not set CONFIG_PHY_AM654_SERDES=y CONFIG_PHY_J721E_WIZ=y # CONFIG_OMAP_USB2 is not set # CONFIG_PHY_TUSB1210 is not set CONFIG_PHY_TI_GMII_SEL=y # end of PHY Subsystem # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # CONFIG_ARM_CCI_PMU=m CONFIG_ARM_CCI400_PMU=y CONFIG_ARM_CCI5xx_PMU=y CONFIG_ARM_CCN=m CONFIG_ARM_CMN=m CONFIG_ARM_PMU=y CONFIG_ARM_DSU_PMU=m CONFIG_ARM_SPE_PMU=m # CONFIG_HISI_PCIE_PMU is not set # CONFIG_HNS3_PMU is not set # end of Performance monitor support CONFIG_RAS=y # CONFIG_USB4 is not set # # Android # # CONFIG_ANDROID_BINDER_IPC is not set # end of Android # CONFIG_LIBNVDIMM is not set # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_NVMEM_SYSFS=y CONFIG_NVMEM_RMEM=m # CONFIG_NVMEM_SPMI_SDAM is not set # CONFIG_NVMEM_U_BOOT_ENV is not set # # HW tracing support # CONFIG_STM=m # CONFIG_STM_PROTO_BASIC is not set # CONFIG_STM_PROTO_SYS_T is not set # CONFIG_STM_DUMMY is not set # CONFIG_STM_SOURCE_CONSOLE is not set # CONFIG_STM_SOURCE_HEARTBEAT is not set # CONFIG_INTEL_TH is not set # CONFIG_HISI_PTT is not set # end of HW tracing support CONFIG_FPGA=y # CONFIG_ALTERA_PR_IP_CORE is not set # CONFIG_FPGA_MGR_ALTERA_PS_SPI is not set CONFIG_FPGA_MGR_ALTERA_CVP=m # CONFIG_FPGA_MGR_XILINX_SPI is not set # CONFIG_FPGA_MGR_ICE40_SPI is not set # CONFIG_FPGA_MGR_MACHXO2_SPI is not set CONFIG_FPGA_BRIDGE=m CONFIG_ALTERA_FREEZE_BRIDGE=m # CONFIG_XILINX_PR_DECOUPLER is not set CONFIG_FPGA_REGION=m CONFIG_OF_FPGA_REGION=m # CONFIG_FPGA_DFL is not set # CONFIG_FPGA_MGR_MICROCHIP_SPI is not set # CONFIG_FSI is not set CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_MULTIPLEXER=y # # Multiplexer drivers # # CONFIG_MUX_ADG792A is not set # CONFIG_MUX_ADGS1408 is not set CONFIG_MUX_GPIO=y CONFIG_MUX_MMIO=y # end of Multiplexer drivers CONFIG_PM_OPP=y # CONFIG_SIOX is not set CONFIG_SLIMBUS=m CONFIG_SLIM_QCOM_CTRL=m CONFIG_INTERCONNECT=y CONFIG_COUNTER=m # CONFIG_INTERRUPT_CNT is not set # CONFIG_FTM_QUADDEC is not set # CONFIG_MICROCHIP_TCB_CAPTURE is not set # CONFIG_INTEL_QEP is not set CONFIG_TI_ECAP_CAPTURE=m # CONFIG_MOST is not set # CONFIG_PECI is not set # CONFIG_HTE is not set # end of Device Drivers # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_VALIDATE_FS_PARSER is not set CONFIG_FS_IOMAP=y CONFIG_EXT2_FS=y # CONFIG_EXT2_FS_XATTR is not set CONFIG_EXT3_FS=y CONFIG_EXT3_FS_POSIX_ACL=y CONFIG_EXT3_FS_SECURITY=y CONFIG_EXT4_FS=y CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set CONFIG_BTRFS_FS=m CONFIG_BTRFS_FS_POSIX_ACL=y # CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set # CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set # CONFIG_BTRFS_DEBUG is not set # CONFIG_BTRFS_ASSERT is not set # CONFIG_BTRFS_FS_REF_VERIFY is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set # CONFIG_FS_VERITY is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y CONFIG_FANOTIFY=y CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y CONFIG_QUOTA=y # CONFIG_QUOTA_NETLINK_INTERFACE is not set CONFIG_PRINT_QUOTA_WARNING=y # CONFIG_QUOTA_DEBUG is not set # CONFIG_QFMT_V1 is not set # CONFIG_QFMT_V2 is not set CONFIG_QUOTACTL=y CONFIG_AUTOFS4_FS=y CONFIG_AUTOFS_FS=y CONFIG_FUSE_FS=m CONFIG_CUSE=m # CONFIG_VIRTIO_FS is not set CONFIG_OVERLAY_FS=m # CONFIG_OVERLAY_FS_REDIRECT_DIR is not set CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y # CONFIG_OVERLAY_FS_INDEX is not set # CONFIG_OVERLAY_FS_XINO_AUTO is not set # CONFIG_OVERLAY_FS_METACOPY is not set # # Caches # CONFIG_NETFS_SUPPORT=y # CONFIG_NETFS_STATS is not set # CONFIG_FSCACHE is not set # end of Caches # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # end of CD-ROM/DVD Filesystems # # DOS/FAT/EXFAT/NT Filesystems # CONFIG_FAT_FS=y # CONFIG_MSDOS_FS is not set CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set # CONFIG_EXFAT_FS is not set # CONFIG_NTFS_FS is not set # CONFIG_NTFS3_FS is not set # end of DOS/FAT/EXFAT/NT Filesystems # # Pseudo filesystems # CONFIG_PROC_FS=y # CONFIG_PROC_KCORE is not set CONFIG_PROC_VMCORE=y # CONFIG_PROC_VMCORE_DEVICE_DUMP is not set CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y # CONFIG_PROC_CHILDREN is not set CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y # CONFIG_TMPFS_INODE64 is not set CONFIG_ARCH_SUPPORTS_HUGETLBFS=y CONFIG_HUGETLBFS=y CONFIG_HUGETLB_PAGE=y CONFIG_MEMFD_CREATE=y CONFIG_ARCH_HAS_GIGANTIC_PAGE=y CONFIG_CONFIGFS_FS=y CONFIG_EFIVAR_FS=y # end of Pseudo filesystems CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set CONFIG_UBIFS_FS=m # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y CONFIG_UBIFS_FS_ZSTD=y # CONFIG_UBIFS_ATIME_SUPPORT is not set CONFIG_UBIFS_FS_XATTR=y CONFIG_UBIFS_FS_SECURITY=y # CONFIG_UBIFS_FS_AUTHENTICATION is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y CONFIG_SQUASHFS_FILE_CACHE=y # CONFIG_SQUASHFS_FILE_DIRECT is not set CONFIG_SQUASHFS_DECOMP_SINGLE=y # CONFIG_SQUASHFS_DECOMP_MULTI is not set # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set # CONFIG_SQUASHFS_LZO is not set # CONFIG_SQUASHFS_XZ is not set # CONFIG_SQUASHFS_ZSTD is not set # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set CONFIG_PSTORE=y CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240 CONFIG_PSTORE_DEFLATE_COMPRESS=y # CONFIG_PSTORE_LZO_COMPRESS is not set # CONFIG_PSTORE_LZ4_COMPRESS is not set # CONFIG_PSTORE_LZ4HC_COMPRESS is not set # CONFIG_PSTORE_842_COMPRESS is not set # CONFIG_PSTORE_ZSTD_COMPRESS is not set CONFIG_PSTORE_COMPRESS=y CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y CONFIG_PSTORE_COMPRESS_DEFAULT="deflate" # CONFIG_PSTORE_CONSOLE is not set # CONFIG_PSTORE_PMSG is not set # CONFIG_PSTORE_RAM is not set # CONFIG_PSTORE_BLK is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_EROFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y # CONFIG_NFS_V3_ACL is not set CONFIG_NFS_V4=y # CONFIG_NFS_SWAP is not set CONFIG_NFS_V4_1=y CONFIG_NFS_V4_2=y CONFIG_PNFS_FILE_LAYOUT=y CONFIG_PNFS_BLOCK=m CONFIG_PNFS_FLEXFILE_LAYOUT=y CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org" # CONFIG_NFS_V4_1_MIGRATION is not set CONFIG_NFS_V4_SECURITY_LABEL=y CONFIG_ROOT_NFS=y # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y CONFIG_NFS_DISABLE_UDP_SUPPORT=y # CONFIG_NFS_V4_2_READ_PLUS is not set # CONFIG_NFSD is not set CONFIG_GRACE_PERIOD=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_COMMON=y CONFIG_NFS_V4_2_SSC_HELPER=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_SUNRPC_BACKCHANNEL=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_SMB_SERVER is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_9P_FS=y # CONFIG_9P_FS_POSIX_ACL is not set # CONFIG_9P_FS_SECURITY is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set # CONFIG_NLS_UTF8 is not set # CONFIG_DLM is not set # CONFIG_UNICODE is not set CONFIG_IO_WQ=y # end of File systems # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_REQUEST_CACHE is not set # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_TRUSTED_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set CONFIG_SECURITY=y CONFIG_SECURITYFS=y # CONFIG_SECURITY_NETWORK is not set # CONFIG_SECURITY_PATH is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set # CONFIG_SECURITY_SMACK is not set # CONFIG_SECURITY_TOMOYO is not set # CONFIG_SECURITY_APPARMOR is not set # CONFIG_SECURITY_LOADPIN is not set # CONFIG_SECURITY_YAMA is not set # CONFIG_SECURITY_SAFESETID is not set # CONFIG_SECURITY_LOCKDOWN_LSM is not set # CONFIG_SECURITY_LANDLOCK is not set CONFIG_INTEGRITY=y # CONFIG_INTEGRITY_SIGNATURE is not set CONFIG_INTEGRITY_AUDIT=y # CONFIG_IMA is not set # CONFIG_IMA_SECURE_AND_OR_TRUSTED_BOOT is not set # CONFIG_EVM is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf" # # Kernel hardening options # # # Memory initialization # CONFIG_INIT_STACK_NONE=y # CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set # CONFIG_GCC_PLUGIN_STACKLEAK is not set # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y # CONFIG_ZERO_CALL_USED_REGS is not set # end of Memory initialization CONFIG_RANDSTRUCT_NONE=y # CONFIG_RANDSTRUCT_FULL is not set # CONFIG_RANDSTRUCT_PERFORMANCE is not set # end of Kernel hardening options # end of Security options CONFIG_XOR_BLOCKS=m CONFIG_ASYNC_TX_DISABLE_PQ_VAL_DMA=y CONFIG_ASYNC_TX_DISABLE_XOR_VAL_DMA=y CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_SKCIPHER=y CONFIG_CRYPTO_SKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=y CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=m CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=y CONFIG_CRYPTO_NULL=y CONFIG_CRYPTO_NULL2=y # CONFIG_CRYPTO_PCRYPT is not set # CONFIG_CRYPTO_CRYPTD is not set CONFIG_CRYPTO_AUTHENC=y CONFIG_CRYPTO_TEST=m CONFIG_CRYPTO_ENGINE=m # end of Crypto core or helper # # Public-key cryptography # CONFIG_CRYPTO_RSA=y CONFIG_CRYPTO_DH=m # CONFIG_CRYPTO_DH_RFC7919_GROUPS is not set CONFIG_CRYPTO_ECC=m CONFIG_CRYPTO_ECDH=m # CONFIG_CRYPTO_ECDSA is not set # CONFIG_CRYPTO_ECRDSA is not set # CONFIG_CRYPTO_SM2 is not set CONFIG_CRYPTO_CURVE25519=m # end of Public-key cryptography # # Block ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARIA is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=m # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set CONFIG_CRYPTO_SM4=m CONFIG_CRYPTO_SM4_GENERIC=m # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # end of Block ciphers # # Length-preserving ciphers and modes # # CONFIG_CRYPTO_ADIANTUM is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_CHACHA20 is not set CONFIG_CRYPTO_CBC=y # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=y # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=m # CONFIG_CRYPTO_HCTR2 is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set CONFIG_CRYPTO_XTS=m # end of Length-preserving ciphers and modes # # AEAD (authenticated encryption with associated data) ciphers # # CONFIG_CRYPTO_AEGIS128 is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_CCM=m CONFIG_CRYPTO_GCM=y CONFIG_CRYPTO_SEQIV=y CONFIG_CRYPTO_ECHAINIV=y # CONFIG_CRYPTO_ESSIV is not set # end of AEAD (authenticated encryption with associated data) ciphers # # Hashes, digests, and MACs # CONFIG_CRYPTO_BLAKE2B=m CONFIG_CRYPTO_CMAC=m CONFIG_CRYPTO_GHASH=y CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_MD4 is not set CONFIG_CRYPTO_MD5=m CONFIG_CRYPTO_MICHAEL_MIC=m # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_RMD160 is not set CONFIG_CRYPTO_SHA1=y CONFIG_CRYPTO_SHA256=y CONFIG_CRYPTO_SHA512=y CONFIG_CRYPTO_SHA3=m CONFIG_CRYPTO_SM3=m CONFIG_CRYPTO_SM3_GENERIC=m # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_VMAC is not set # CONFIG_CRYPTO_WP512 is not set # CONFIG_CRYPTO_XCBC is not set CONFIG_CRYPTO_XXHASH=m # end of Hashes, digests, and MACs # # CRCs (cyclic redundancy checks) # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set CONFIG_CRYPTO_CRCT10DIF=y CONFIG_CRYPTO_CRC64_ROCKSOFT=y # end of CRCs (cyclic redundancy checks) # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=m # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set CONFIG_CRYPTO_ZSTD=m # end of Compression # # Random number generation # CONFIG_CRYPTO_ANSI_CPRNG=y CONFIG_CRYPTO_DRBG_MENU=y CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=y CONFIG_CRYPTO_JITTERENTROPY=y # end of Random number generation # # Userspace interface # CONFIG_CRYPTO_USER_API=m CONFIG_CRYPTO_USER_API_HASH=m # CONFIG_CRYPTO_USER_API_SKCIPHER is not set CONFIG_CRYPTO_USER_API_RNG=m # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y # end of Userspace interface CONFIG_CRYPTO_HASH_INFO=y # CONFIG_CRYPTO_NHPOLY1305_NEON is not set CONFIG_CRYPTO_CHACHA20_NEON=m # # Accelerated Cryptographic Algorithms for CPU (arm64) # CONFIG_CRYPTO_GHASH_ARM64_CE=y # CONFIG_CRYPTO_POLY1305_NEON is not set CONFIG_CRYPTO_SHA1_ARM64_CE=y CONFIG_CRYPTO_SHA256_ARM64=y CONFIG_CRYPTO_SHA2_ARM64_CE=y CONFIG_CRYPTO_SHA512_ARM64=m CONFIG_CRYPTO_SHA512_ARM64_CE=m CONFIG_CRYPTO_SHA3_ARM64=m # CONFIG_CRYPTO_SM3_NEON is not set CONFIG_CRYPTO_SM3_ARM64_CE=m # CONFIG_CRYPTO_POLYVAL_ARM64_CE is not set # CONFIG_CRYPTO_AES_ARM64 is not set CONFIG_CRYPTO_AES_ARM64_CE=y CONFIG_CRYPTO_AES_ARM64_CE_BLK=y CONFIG_CRYPTO_AES_ARM64_NEON_BLK=m CONFIG_CRYPTO_AES_ARM64_BS=m # CONFIG_CRYPTO_SM4_ARM64_CE is not set # CONFIG_CRYPTO_SM4_ARM64_CE_BLK is not set # CONFIG_CRYPTO_SM4_ARM64_NEON_BLK is not set CONFIG_CRYPTO_AES_ARM64_CE_CCM=y CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m # end of Accelerated Cryptographic Algorithms for CPU (arm64) CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set # CONFIG_CRYPTO_DEV_CCP is not set # CONFIG_CRYPTO_DEV_QAT_DH895xCC is not set # CONFIG_CRYPTO_DEV_QAT_C3XXX is not set # CONFIG_CRYPTO_DEV_QAT_C62X is not set # CONFIG_CRYPTO_DEV_QAT_4XXX is not set # CONFIG_CRYPTO_DEV_QAT_DH895xCCVF is not set # CONFIG_CRYPTO_DEV_QAT_C3XXXVF is not set # CONFIG_CRYPTO_DEV_QAT_C62XVF is not set # CONFIG_CRYPTO_DEV_NITROX_CNN55XX is not set # CONFIG_CRYPTO_DEV_CAVIUM_ZIP is not set # CONFIG_CRYPTO_DEV_VIRTIO is not set # CONFIG_CRYPTO_DEV_SAFEXCEL is not set CONFIG_CRYPTO_DEV_CCREE=m # CONFIG_CRYPTO_DEV_HISI_SEC is not set CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m # CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set CONFIG_CRYPTO_DEV_SA2UL=m CONFIG_CRYPTO_DEV_TI_MCRC64=m CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # CONFIG_PKCS7_TEST_KEY is not set # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set # CONFIG_FIPS_SIGNATURE_SELFTEST is not set # # Certificates for signature checking # CONFIG_SYSTEM_TRUSTED_KEYRING=y CONFIG_SYSTEM_TRUSTED_KEYS="" # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set # CONFIG_SECONDARY_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # end of Certificates for signature checking CONFIG_BINARY_PRINTF=y # # Library routines # CONFIG_RAID6_PQ=m CONFIG_RAID6_PQ_BENCHMARK=y CONFIG_LINEAR_RANGES=y CONFIG_PACKING=y CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y # CONFIG_CORDIC is not set # CONFIG_PRIME_NUMBERS is not set CONFIG_RATIONAL=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y CONFIG_ARCH_HAS_FAST_MULTIPLIER=y CONFIG_ARCH_USE_SYM_ANNOTATIONS=y CONFIG_INDIRECT_PIO=y # # Crypto library routines # CONFIG_CRYPTO_LIB_UTILS=y CONFIG_CRYPTO_LIB_AES=y CONFIG_CRYPTO_LIB_ARC4=m CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m CONFIG_CRYPTO_LIB_CHACHA_GENERIC=m # CONFIG_CRYPTO_LIB_CHACHA is not set CONFIG_CRYPTO_LIB_CURVE25519_GENERIC=m # CONFIG_CRYPTO_LIB_CURVE25519 is not set CONFIG_CRYPTO_LIB_DES=m CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9 # CONFIG_CRYPTO_LIB_POLY1305 is not set # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set CONFIG_CRYPTO_LIB_SHA1=y CONFIG_CRYPTO_LIB_SHA256=y # end of Crypto library routines CONFIG_CRC_CCITT=m CONFIG_CRC16=y CONFIG_CRC_T10DIF=y CONFIG_CRC64_ROCKSOFT=y CONFIG_CRC_ITU_T=y CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set CONFIG_CRC64=y # CONFIG_CRC4 is not set CONFIG_CRC7=y CONFIG_LIBCRC32C=m CONFIG_CRC8=y CONFIG_XXHASH=y CONFIG_AUDIT_GENERIC=y CONFIG_AUDIT_ARCH_COMPAT_GENERIC=y CONFIG_AUDIT_COMPAT_GENERIC=y # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_ZSTD_COMMON=y CONFIG_ZSTD_COMPRESS=m CONFIG_ZSTD_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y # CONFIG_XZ_DEC_MICROLZMA is not set CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_DECOMPRESS_ZSTD=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_BCH=y CONFIG_TEXTSEARCH=y CONFIG_TEXTSEARCH_KMP=m CONFIG_TEXTSEARCH_BM=m CONFIG_TEXTSEARCH_FSM=m CONFIG_INTERVAL_TREE=y CONFIG_XARRAY_MULTI=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_DMA_OPS=y CONFIG_NEED_SG_DMA_LENGTH=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_ARCH_DMA_ADDR_T_64BIT=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y CONFIG_ARCH_HAS_DMA_PREP_COHERENT=y CONFIG_SWIOTLB=y # CONFIG_DMA_RESTRICTED_POOL is not set CONFIG_DMA_NONCOHERENT_MMAP=y CONFIG_DMA_COHERENT_POOL=y CONFIG_DMA_DIRECT_REMAP=y CONFIG_DMA_CMA=y CONFIG_DMA_PERNUMA_CMA=y # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=32 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # CONFIG_DMA_API_DEBUG is not set # CONFIG_DMA_MAP_BENCHMARK is not set CONFIG_SGL_ALLOC=y # CONFIG_FORCE_NR_CPUS is not set CONFIG_CPU_RMAP=y CONFIG_DQL=y CONFIG_GLOB=y # CONFIG_GLOB_SELFTEST is not set CONFIG_NLATTR=y CONFIG_CLZ_TAB=y CONFIG_IRQ_POLL=y CONFIG_MPILIB=y CONFIG_DIMLIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_HAVE_GENERIC_VDSO=y CONFIG_GENERIC_GETTIMEOFDAY=y CONFIG_GENERIC_VDSO_TIME_NS=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y CONFIG_SG_SPLIT=y CONFIG_SG_POOL=y CONFIG_ARCH_STACKWALK=y CONFIG_STACKDEPOT=y CONFIG_SBITMAP=y # end of Library routines CONFIG_GENERIC_IOREMAP=y CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set # CONFIG_STACKTRACE_BUILD_ID is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_DYNAMIC_DEBUG_CORE is not set CONFIG_SYMBOLIC_ERRNAME=y CONFIG_DEBUG_BUGVERBOSE=y # end of printk and dmesg options CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y # # Compile-time checks and compiler options # CONFIG_DEBUG_INFO=y CONFIG_AS_HAS_NON_CONST_LEB128=y # CONFIG_DEBUG_INFO_NONE is not set CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT=y # CONFIG_DEBUG_INFO_DWARF4 is not set # CONFIG_DEBUG_INFO_DWARF5 is not set CONFIG_DEBUG_INFO_REDUCED=y # CONFIG_DEBUG_INFO_COMPRESSED is not set # CONFIG_DEBUG_INFO_SPLIT is not set CONFIG_PAHOLE_HAS_SPLIT_BTF=y # CONFIG_GDB_SCRIPTS is not set CONFIG_FRAME_WARN=2048 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_HEADERS_INSTALL is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_64B is not set CONFIG_ARCH_WANT_FRAME_POINTERS=y CONFIG_FRAME_POINTER=y # CONFIG_VMLINUX_MAP is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # end of Compile-time checks and compiler options # # Generic Kernel Debugging Instruments # CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_MAGIC_SYSRQ_SERIAL=y CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE="" CONFIG_DEBUG_FS=y CONFIG_DEBUG_FS_ALLOW_ALL=y # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set # CONFIG_DEBUG_FS_ALLOW_NONE is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set CONFIG_ARCH_HAS_UBSAN_SANITIZE_ALL=y # CONFIG_UBSAN is not set CONFIG_HAVE_ARCH_KCSAN=y CONFIG_HAVE_KCSAN_COMPILER=y # CONFIG_KCSAN is not set # end of Generic Kernel Debugging Instruments # # Networking Debugging # # CONFIG_NET_DEV_REFCNT_TRACKER is not set # CONFIG_NET_NS_REFCNT_TRACKER is not set # CONFIG_DEBUG_NET is not set # end of Networking Debugging # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set CONFIG_SLUB_DEBUG=y # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_TABLE_CHECK is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_RODATA_TEST is not set CONFIG_ARCH_HAS_DEBUG_WX=y # CONFIG_DEBUG_WX is not set CONFIG_GENERIC_PTDUMP=y # CONFIG_PTDUMP_DEBUGFS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SHRINKER_DEBUG is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_SCHED_STACK_END_CHECK is not set CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_VM_PGTABLE is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_PER_CPU_MAPS is not set CONFIG_HAVE_ARCH_KASAN=y CONFIG_HAVE_ARCH_KASAN_SW_TAGS=y CONFIG_HAVE_ARCH_KASAN_HW_TAGS=y CONFIG_HAVE_ARCH_KASAN_VMALLOC=y CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_CC_HAS_KASAN_SW_TAGS=y CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y # CONFIG_KASAN is not set CONFIG_HAVE_ARCH_KFENCE=y # CONFIG_KFENCE is not set # end of Memory Debugging # CONFIG_DEBUG_SHIRQ is not set # # Debug Oops, Lockups and Hangs # # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_TEST_LOCKUP is not set # end of Debug Oops, Lockups and Hangs # # Scheduler Debugging # # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # end of Scheduler Debugging # CONFIG_DEBUG_TIMEKEEPING is not set # CONFIG_DEBUG_PREEMPT is not set # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # CONFIG_SCF_TORTURE_TEST is not set # CONFIG_CSD_LOCK_WAIT_DEBUG is not set # end of Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_DEBUG_IRQFLAGS is not set CONFIG_STACKTRACE=y # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set # # Debug kernel data structures # # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PLIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_DEBUG_MAPLE_TREE is not set # end of Debug kernel data structures # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_SCALE_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_RCU_REF_SCALE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0 CONFIG_RCU_TRACE=y # CONFIG_RCU_EQS_DEBUG is not set # end of RCU Debugging # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACE_CLOCK=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set CONFIG_SAMPLES=y # CONFIG_SAMPLE_AUXDISPLAY is not set # CONFIG_SAMPLE_KOBJECT is not set # CONFIG_SAMPLE_HW_BREAKPOINT is not set # CONFIG_SAMPLE_KFIFO is not set CONFIG_SAMPLE_RPMSG_CLIENT=m # CONFIG_SAMPLE_CONFIGFS is not set # CONFIG_SAMPLE_VFIO_MDEV_MDPY_FB is not set # CONFIG_SAMPLE_WATCHDOG is not set # CONFIG_SAMPLE_CORESIGHT_SYSCFG is not set CONFIG_STRICT_DEVMEM=y # CONFIG_IO_STRICT_DEVMEM is not set # # arm64 Debugging # # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_DEBUG_EFI is not set # CONFIG_ARM64_RELOC_TEST is not set CONFIG_CORESIGHT=m CONFIG_CORESIGHT_LINKS_AND_SINKS=m CONFIG_CORESIGHT_LINK_AND_SINK_TMC=m CONFIG_CORESIGHT_CATU=m CONFIG_CORESIGHT_SINK_TPIU=m CONFIG_CORESIGHT_SINK_ETBV10=m # CONFIG_CORESIGHT_SOURCE_ETM4X is not set CONFIG_CORESIGHT_STM=m CONFIG_CORESIGHT_CPU_DEBUG=m # CONFIG_CORESIGHT_CPU_DEBUG_DEFAULT_ON is not set CONFIG_CORESIGHT_CTI=m # CONFIG_CORESIGHT_CTI_INTEGRATION_REGS is not set # end of arm64 Debugging # # Kernel Testing and Coverage # # CONFIG_KUNIT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y CONFIG_RUNTIME_TESTING_MENU=y # CONFIG_LKDTM is not set # CONFIG_TEST_MIN_HEAP is not set # CONFIG_TEST_DIV64 is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_TEST_REF_TRACKER is not set # CONFIG_RBTREE_TEST is not set # CONFIG_REED_SOLOMON_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_STRING_SELFTEST is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_STRSCPY is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_SCANF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_XARRAY is not set # CONFIG_TEST_MAPLE_TREE is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_SIPHASH is not set # CONFIG_TEST_IDA is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_BITOPS is not set # CONFIG_TEST_VMALLOC is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_TEST_BLACKHOLE_DEV is not set # CONFIG_FIND_BIT_BENCHMARK is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_SYSCTL is not set # CONFIG_TEST_UDELAY is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_TEST_KMOD is not set # CONFIG_TEST_MEMCAT_P is not set # CONFIG_TEST_MEMINIT is not set # CONFIG_TEST_FREE_PAGES is not set CONFIG_ARCH_USE_MEMTEST=y CONFIG_MEMTEST=y # end of Kernel Testing and Coverage # # Rust hacking # # end of Rust hacking # end of Kernel hacking
Could someone help me get usb devices working on this evm?
Thanks!
