I've spent the better part of 2 weeks trying to build the latest version of gstreamer for a DM355. I needed some features in the latest gstreamer that wasn't present in the TI gstreamer port. Also I had trouble building the TI gstreamer port to begin with.
Here are the command options I used. Note that all I needed as the following plugins: app, coreelements, isomp4, wavenv, and waveparse, so my command line options are very restrictive:
Get the glib-2.22.2 source
Build
the glib source:
./configure
--build=i686-linux --host=arm-none-linux-gnueabi --prefix=/home/user/product1/dependencies
NM=nm RANLIB=ranlib CPPFLAGS="-DPlatform_dm355 -I/home/user/temp/opt/gstreamer/include
-I/include" CFLAGS="-O2 -march=armv5te -mtune=arm926ej-s"
LDFLAGS="-L/home/user/temp/opt/gstreamer/lib -L/lib"
glib_cv_stack_grows=no glib_cv_uscore=no ac_cv_func_posix_getpwuid_r=yes
ac_cv_func_posix_getgrgid_r=yes
CC=/opt/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc
Configure
and build gstreamer-0.10.35
export
PKG_CONFIG_PATH=/home/user/product1/dependencies/lib/pkgconfig
Note
the “ don’t paste well, copy this and paste it into notepad, then copy and
paste it into a terminal
./configure
CC=/opt/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc --build=i686-linux
CFLAGS=-I/home/user/product1/dependencies/include/ LDFLAGS=-L/home/nlbuts/product1/dependencies/lib/
--disable-loadsave GLIB_CFLAGS="-I/home/user/product1/dependencies/include
-I/home/user/product1/dependencies/include/glib-2.0 -I/home/user/product1/dependencies/include/glib-2.0/glib
-I/home/user/product1/dependencies/lib/glib-2.0/include"
Configure
and build gst-plugins-base-0.10.34 (0.10.34 doesn’t build something with a
unittest)
./configure
GLIB_CFLAGS="-I/home/user/product1/dependencies/include -I/home/user/product1/dependencies/include/glib-2.0
-I/home/user/product1/dependencies/include/glib-2.0/glib -I/home/user/product1/dependencies/lib/glib-2.0/include"
--disable-examples
--disable-external
--disable-adder
--disable-audioconvert
--disable-audiorate
--disable-audiotestsrc
--disable-encoding
--disable-ffmpegcolorspace
--disable-gdp
--disable-playback
--disable-audioresample
--disable-subparse
--disable-tcp
--disable-typefind
--disable-videotestsrc
--disable-videorate
--disable-videoscale
--disable-volume
--disable-x
--disable-xvideo
--disable-xshm
--disable-gst_v4l
--disable-alsa
--disable-cdparanoia
--disable-gnome_vfs
--disable-ivorbis
--disable-gio
--disable-libvisual
--disable-ogg
--disable-oggtest
--disable-pango
--disable-theora
--disable-vorbis
--disable-vorbistest
--disable-freetypetest
Configure
and build gst-plugins-good-0.10.30
./configure
--disable-examples
--disable-external
--disable-gconftool
--disable-videofilter
--disable-alpha
--disable-apetag
--disable-audiofx
--disable-audioparsers
--disable-auparse
--disable-autodetect
--disable-avi
--disable-cutter
--disable-debugutils
--disable-deinterlace
--disable-effectv
--disable-equalizer
--disable-flv
--disable-id3demux
--disable-icydemux
--disable-interleave
--disable-flx
--disable-goom
--disable-goom2k1
--disable-imagefreeze
--disable-law
--disable-level
--disable-matroska
--disable-monoscope
--disable-multifile
--disable-multipart
--disable-replaygain
--disable-rtp
--disable-rtpmanager
--disable-rtsp
--disable-shapewipe
--disable-smpte
--disable-spectrum
--disable-udp
--disable-videobox
--disable-videocrop
--disable-videomixer
--disable-y4m
--disable-directsound
--disable-oss
--disable-oss4
--disable-sunaudio
--disable-osx_audio
--disable-osx_video
--disable-gst_v4l2
--disable-x
--disable-xshm
--disable-xvideo
--disable-aalib
--disable-aalibtest
--disable-annodex
--disable-cairo
--disable-cairo_gobject
--disable-esd
--disable-esdtest
--disable-flac
--disable-gconf
--disable-gdk_pixbuf
--disable-hal
--disable-jack
--disable-jpeg
--disable-libcaca
--disable-libdv
--disable-libpng
--disable-pulse
--disable-dv1394
--disable-shout2
--disable-shout2test
--disable-soup
--disable-speex
--disable-taglib
--disable-bz2
Then you can modify the helloworld app to use this subset for testing. Another way to test is to run gst-inspect to verify the plugins are present. You will need to define the GST_PLUGIN_PATH to the location to the gstreamer plug-ins. Also, the tool, gst-plugin-scanner, needs to be at the harded code defined by PREFIX. I can't figure out a way to redirect this. So I had to create a path on my target called:
/home/user/produce1/dependencies/libexec/gstreamer-0.10
and put the gst-plugin-scanner in this directory. According to the docs, you should be able to override this with GST_PLUGIN_SCANNER environment variable, but that doesn't appear to work. If you know a way to build this and redefine the location of this loader, let me know.
Hopefully this helps other people out.
