TDA4VE-Q1: tda4ve a72 failed to be started
Part Number: TDA4VE-Q1
TI Engineer:
Hello!
I have a startup question about tda4ve:
The board is powered on repeatedly. Sometimes, no logs are printed for A72.Sometimes A72 runs normally, that is, linux logs print normally.This phenomenon is very easy to happen, and there is no pattern to follow.
The log is as follows:
TIFS  ver: 8.6.3--v08.06.03 (Chill Capybar
SBL_SocLateInit.
Board_init.
Initlialzing PLLs ...done.
InitlialzingClocks ...Board_getInitParams ...Board_setInitParams ...done.
Initlialzing DDR ...done.
Initializing GTC ...Begin parsing user application
SBL_BootImage
SBL_RequestAllCores
If you don't get the logs of the application while booting     from boot0 partition then you might need to pass the MAX_APP_SIZE_EMMC (=<size of you application>)     while building your appimage
==xiex=> SBL_MulticoreImageParse:Ok
SBL_ReleaseAllCores
SBL_SlaveCoreBoot core_id=10
Sciclient_procBootSetProcessorCfg, ProcId 0x6, EntryPoint 0x0...
SBL_SlaveCoreBoot core_id=11
Sciclient_procBootSetProcessorCfg, ProcId 0x7, EntryPoint 0x0...
Skipping Sciclient_procBootSetProcessorCfg for ProcId 0x8, EntryPoint 0xfffffffe...
Skipping Sciclient_procBootSetProcessorCfg for ProcId 0x9, EntryPoint 0xfffffffe...
Skipping Sciclient_procBootSetProcessorCfg for ProcId 0x0, EntryPoint 0xfffffffe...
SBL_SlaveCoreBoot core_id=18
Sciclient_procBootSetProcessorCfg, ProcId 0x30, EntryPoint 0xb0200000...
SBL_SlaveCoreBoot core_id=19
Sciclient_procBootSetProcessorCfg, ProcId 0x31, EntryPoint 0xb6200000...
Skipping Sciclient_procBootSetProcessorCfg for ProcId 0x80, EntryPoint 0xfffffffe...
Board_releaseResource
SBL_SlaveCoreBoot core_id=0
Sciclient_procBootSetProcessorCfg, ProcId 0x20, EntryPoint 0x70000000...
SBL_SlaveCoreBoot core_id=2
SBL_SlaveCoreBoot core_id=3
SBL_SlaveCoreBoot core_id=4
SBL_SlaveCoreBoot core_id=5
SBL_SlaveCoreBoot core_id=6
SBL_SlaveCoreBoot core_id=7
Boot the core running SBL in the end
Sciclient_procBootSetProcessorCfg, ProcId 0x1, EntryPoint 0x41010000...
Sciclient_procBootSetProcessorCfg, ProcId 0x2, EntryPoint 0x41010000...
The SBL logs show that the SBL code is executed successfully.However, no log was printed on the A72 side.
At first glance, the A72 may not be running.
It is difficult to determine the cause of the problem.Please help to analyze the possible reasons.We will gradually verify and confirm the problem, thank you!
    A few more details will help us analyse the issue better:
    1. Is this happening on the TI TDA4VE EVM board?
    2. What is the frequency of the issue occurance?
    3. Which SDK version are you using?
    Keerthy
  • 1、TDA4VE board
    2、most are startup failures, the frequency is very high
    3、SDK version 08_06
    thanks !
    Can you share the successful boot logs?
    Also can you try this with 9.0 SDK which is the latest SDK.
    Keerthy
    Mass production is coming soon, there are no plans to use the 9.0 SDK at the moment.
    fail log:
    [13-45-51-873]==xiex=> current emmc partition: 1
    [13-45-52-238]0x4F8A00FF
    [13-45-52-238]0x4F8B0001
    [13-45-52-238]0x4F800079
    [13-45-52-238]0x4F80007A
    [13-45-52-238]0x4F8B0002
    [13-45-52-238]0x4F80007C
    [13-45-52-238]0x4F80007D
    [13-45-52-238]0x4F800094
    [13-45-52-238]0x4F800096
    [13-45-52-240]0x4F8000E3
    [13-45-52-240]0x4F8A00FF
    [13-45-52-240]0x4F8B0002
    [13-45-52-240]0x4D4000E3
    [13-45-52-240]0x4D4A0000
    [13-45-52-240]0x4D4B0000
    [13-45-52-240]0x4D4A0001
    [13-45-52-240]0x4D4B0001
    [13-45-52-240]0x4D4A0002
    [13-45-52-240]0x4D4B0002
    [13-45-52-241]0x4D4A0003
    [13-45-52-241]0x4D4B0003
    [13-45-52-241]0x4F8A00FF
    [13-45-52-241]0x4F8B0002
    [13-45-52-241]0x4F8000E3
    [13-45-52-241]0x4D4000E3
    [13-45-52-241]0x4D4A0004
    [13-45-52-241]0x4D4B0004
    [13-45-52-241]0x4D4A0005
    [13-45-52-241]0x4D4B0005
    [13-45-52-243]0x4F8B0002
    [13-45-52-243]0x4F8000E3
    [13-45-52-243]0x4D4000E3
    [13-45-52-243]0x4D4A0006
    [13-45-52-243]0x4D4B0006
    [13-45-52-243]0x4F8A00FF
    [13-45-52-243]0x4D4A0007
    [13-45-52-243]0x4D4B0007
    [13-45-52-243]0x4D4A0008
    [13-45-52-243]0x4D4B0008
    [13-45-52-243]0x4D4A0009
    [13-45-52-243]0x4D4B0009
    [13-45-52-243]0x4D4A000A
    [13-45-52-243]0x4D4B00B8
    [13-45-52-243]0x4D4A000B
    [13-45-52-243]0x4D4B00B9
    [13-45-52-243]0x4D4A000C
    [13-45-52-243]0x4D4B00BA
    [13-45-52-243]0x4D4A000D
    [13-45-52-243]0x4D4B00BB
    [13-45-52-243]0x4D4A000E
    [13-45-52-243]0x4D4B00BC
    [13-45-52-243]0x4D4A000F
    [13-45-52-243]0x4D4B00BD
    [13-45-52-244]0x4F8A00FF
    [13-45-52-244]0x4F8B0002
    [13-45-52-244]0x4F8000E3
    [13-45-52-244]0x4D4000E3
    [13-45-52-244]0x4D4A0010
    [13-45-52-244]0x4D4B00BE
    [13-45-52-244]0x4D4A0011
    [13-45-52-244]0x4D4B00BF
    [13-45-52-245]0x4D4000E3
    [13-45-52-245]0x4D4A0012
    [13-45-52-245]0x4D4B00C0
    [13-45-52-245]0x4F8A00FF
    [13-45-52-245]0x4F8B0002
    [13-45-52-245]0x4F8000E3
    [13-45-52-245]0x4D4A0013
    [13-45-52-245]0x4D4B00C1
    [13-45-52-245]0x4D4A0014
    [13-45-52-245]0x4D4B00C2
    [13-45-52-245]0x4D4A0015
    [13-45-52-245]0x4D4B00C3
    [13-45-52-245]0x4D4A0016
    [13-45-52-245]0x4D4B00E0
    [13-45-52-245]0x4D4A0017
    [13-45-52-245]0x4D4B00E1
    [13-45-52-245]0x4D4A0018
    [13-45-52-245]0x4D4B00E2
    [13-45-52-245]0x4D4A0019
    [13-45-52-251]0x4D4B00E3
    [13-45-52-251]0x4F8A00FF
    [13-45-52-251]0x4F8B0002
    [13-45-52-251]0x4F8000E3
    [13-45-52-251]0x4D4000E3
    [13-45-52-252]0x4D4A001A
    [13-45-52-252]0x4D4B0100
    [13-45-52-252]0x4F8A00FF
    [13-45-52-252]0x4F8B0002
    [13-45-52-252]0x4F8000E3
    [13-45-52-252]0x4D4000E3
    [13-45-52-252]0x4D4A001B
    [13-45-52-252]0x4D4B0101
    [13-45-52-252]0x4D4A001C
    [13-45-52-252]0x4D4B0102
    [13-45-52-252]0x4D4A001D
    [13-45-52-252]0x4D4B0103
    [13-45-52-252]0x4D4A001E
    [13-45-52-252]0x4D4B0120
    [13-45-52-252]0x4D4A001F
    [13-45-52-252]0x4D4B0121
    [13-45-52-252]0x4D4A0020
    [13-45-52-252]0x4D4B0122
    [13-45-52-252]0x4D4A0021
    [13-45-52-252]0x4D4B0123
    [13-45-52-252]0x4F8B0001
    [13-45-52-252]0x4F80010C
    [13-45-52-252]0x4D40010C
    [13-45-52-252]0x4D4A0000
    [13-45-52-252]0x4D4B0000
    [13-45-52-253]0x4F8B0001
    [13-45-52-253]0x4F80010C
    [13-45-52-253]0x4D40010C
    [13-45-52-253]0x4D4A0001
    [13-45-52-253]0x4D4B0001
    [13-45-52-253]0x4F8A00FF
    [13-45-52-254]0x4D4A0002
    [13-45-52-254]0x4D4B0002
    [13-45-52-254]0x4F8A00FF
    [13-45-52-254]0x4F8B0001
    [13-45-52-254]0x4F80010C
    [13-45-52-254]0x4D40010C
    [13-45-52-254]0x4D4A0003
    [13-45-52-254]0x4D4B0003
    [13-45-52-254]0x4D4A0004
    [13-45-52-254]0x4D4B0020
    [13-45-52-254]0x4D4A0005
    [13-45-52-254]0x4D4B0021
    [13-45-52-254]0x4D4A0006
    [13-45-52-254]0x4D4B0022
    [13-45-52-255]0x4F8B0001
    [13-45-52-255]0x4F80010C
    [13-45-52-255]0x4D40010C
    [13-45-52-255]0x4D4A0007
    [13-45-52-255]0x4D4B0023
    [13-45-52-255]0x4F8A00FF
    [13-45-52-255]0x4D4A0010
    [13-45-52-255]0x4D4B0005
    [13-45-52-255]0x4D4A0011
    [13-45-52-255]0x4D4B0006
    [13-45-52-255]0x4D4A0012
    [13-45-52-255]0x4D4B0007
    [13-45-52-257]0x4F8A00FF
    [13-45-52-257]0x4F8B0001
    [13-45-52-257]0x4F80010C
    [13-45-52-257]0x4D40010C
    [13-45-52-257]0x4D4A0013
    [13-45-52-257]0x4D4B0008
    [13-45-52-259]0x4D4A0014
    [13-45-52-573]0x4D4B0009
    [13-45-52-573]0x4F8A00FF
    [13-45-52-573]0x4F8B0001
    [13-45-52-573]0x4F80010C
    [13-45-52-573]0x4D40010C
    [13-45-52-573]0x4D4A0015
    [13-45-52-573]0x4D4B000A
    [13-45-52-573]0x4D4A0016
    [13-45-52-573]0x4D4B000B
    [13-45-52-573]0x4F8B0002
    [13-45-52-573]0x4F8000FE
    [13-45-52-573]0x4F8000FF
    [13-45-52-573]0x4F800109
    [13-45-52-574]0x4F8B0002
    [13-45-52-574]0x4F800109
    [13-45-52-574]0x4F8A00FF
    [13-45-52-576]0x4F8B0002
    [13-45-52-576]0x4F800109
    [13-45-52-576]0x4F8A00FF
    [13-45-52-577]0x4F8A00FF
    [13-45-52-577]0x4F8B0002
    [13-45-52-577]0x4F800109
    [13-45-52-578]0x4F8B0002
    [13-45-52-578]0x4F800109
    [13-45-52-578]0x4F8A00FF
    [13-45-52-578]0x4F8B0001
    [13-45-52-578]0x4F800113
    [13-45-52-578]0x4F8000E1
    [13-45-52-585]0x4F800103
    [13-45-52-585]0x4F8A00FF
    [13-45-52-585]0x4F8B0081
    [13-45-52-585]0x4F800110
    [13-45-52-585]0x4F8B0002
    [13-45-52-585]0x4F8000E1
    [13-45-52-585]0x4F800107
    [13-45-52-585]0x4F8B0001
    [13-45-52-585]0x4F800111
    [13-45-52-585]0x4F800100
    [13-45-52-585]0x4F80010F
    [13-45-52-585]TIFS  ver: 8.6.3--v08.06.03 (Chill Capybar
    [13-45-52-585]SCISERVER Board Configuration header population... PASSED
    [13-45-52-585]Sciclient_setBoardConfigHeader... PASSED
    [13-45-52-585]0x61800200
    [13-45-52-585]0x61C00127
    [13-45-52-585]0x62000000
    [13-45-52-585]0x60000006
    [13-45-52-585]0x63960000
    [13-45-52-585]0x62D00001
    [13-45-52-585]0x639A0000
    [13-45-52-585]0x62D04001
    [13-45-52-585]0x62D00002
    [13-45-52-585]0x64160000
    [13-45-52-585]0x62D04002
    [13-45-52-585]0x641A0000
    [13-45-52-585]0x60000009
    [13-45-52-585]0x6000000A
    [13-45-52-585]0x6000000C
    [13-45-52-585]0x6000000D
    [13-45-52-585]0x608001E0
    [13-45-52-585]0x608001F2
    [13-45-52-585]0x608001F3
    [13-45-52-585]0x6000000E
    [13-45-52-585]0x608001D2
    [13-45-52-586]0x6000000F
    [13-45-52-586]0x63900000
    [13-45-52-586]0x62D00003
    [13-45-52-586]0x62D00004
    [13-45-52-586]0x64100000
    [13-45-52-586]0x60000010
    [13-45-52-586]0x60000011
    [13-45-52-586]0x60000012
    [13-45-52-586]0x60000013
    [13-45-52-586]0x60000014
    [13-45-52-586]0x60000015
    [13-45-52-586]0x60000016
    [13-45-52-586]0x63804000
    [13-45-52-586]0x62C00001
    [13-45-52-586]0x63844000
    [13-45-52-586]0x62C00002
    [13-45-52-587]0x62C00003
    [13-45-52-587]0x64004000
    [13-45-52-587]0x62C00004
    [13-45-52-587]0x64044000
    [13-45-52-587]0x60000017
    [13-45-52-587]0x60000018
    [13-45-52-587]0x60000019
    [13-45-52-587]0x6000001A
    [13-45-52-587]0x60800022
    [13-45-52-588]0x60800021
    [13-45-52-588]0x60800005
    [13-45-52-588]0x60800006
    [13-45-52-588]0x60800007
    [13-45-52-588]0x6080004D
    [13-45-52-588]0x60800046
    [13-45-52-588]0x6080001C
    [13-45-52-588]0x6080001D
    [13-45-52-588]0x60800023
    [13-45-52-588]0x6000001D
    [13-45-52-588]0x63800000
    [13-45-52-588]0x62C00005
    [13-45-52-588]0x62C00006
    [13-45-52-588]0x64000000
    [13-45-52-588]0x6000001E
    [13-45-52-588]0x63900001
    [13-45-52-588]0x62D00005
    [13-45-52-588]0x64100001
    [13-45-52-588]0x6000001F
    [13-45-52-588]0x63900002
    [13-45-52-588]0x62D00006
    [13-45-52-588]0x64100002
    [13-45-52-588]0x60000020
    [13-45-52-588]0x63900003
    [13-45-52-588]0x62D00007
    [13-45-52-588]0x64100003
    [13-45-52-588]0x60000021
    [13-45-52-589]0x63900004
    [13-45-52-589]0x62D00008
    [13-45-52-589]0x64100004
    [13-45-52-589]0x60000022
    [13-45-52-589]0x63900005
    [13-45-52-589]0x62D00009
    [13-45-52-589]0x64100005
    [13-45-52-589]0x60800024
    [13-45-52-589]0x60800052
    [13-45-52-589]0x60000023
    [13-45-52-589]0x63800001
    [13-45-52-589]0x62C00007
    [13-45-52-589]0x64000001
    [13-45-52-589]0x60000024
    [13-45-52-589]0x63900006
    [13-45-52-589]0x62D0000A
    [13-45-52-589]0x64100006
    [13-45-52-589]0x60000025
    [13-45-52-589]0x63800002
    [13-45-52-589]0x62C00008
    [13-45-52-589]0x64000002
    [13-45-52-589]0x6000002A
    [13-45-52-589]0x63934000
    [13-45-52-591]0x62D0000B
    [13-45-52-593]0x62D0000C
    [13-45-52-917]0x64134000
    [13-45-52-917]0x60800128
    [13-45-52-917]0x6080013E
    [13-45-52-917]0x608001E2
    [13-45-52-917]0x608001E3
    [13-45-52-917]0x608001E4
    [13-45-52-917]0x6080000D
    [13-45-52-917]0x608000E3
    [13-45-52-918]0x6000002B
    [13-45-52-918]0x63900007
    [13-45-52-918]0x62D0000D
    [13-45-52-918]0x64100007
    [13-45-52-918]0x6080013B
    [13-45-52-918]0x6080013C
    [13-45-52-918]0x6080013D
    [13-45-52-918]0x608001E5
    [13-45-52-918]0x608001E6
    [13-45-52-918]0x608001E7
    [13-45-52-918]0x608001E8
    [13-45-52-918]0x6080012A
    [13-45-52-918]0x60800140
    [13-45-52-918]0x6000002C
    [13-45-52-918]0x63900008
    [13-45-52-918]0x62D0000E
    [13-45-52-918]0x64100008
    [13-45-52-918]0x60800141
    [13-45-52-918]0x60800142
    [13-45-52-918]0x608001EC
    [13-45-52-918]0x60800131
    [13-45-52-918]0x60800139
    [13-45-52-918]0x608001E9
    [13-45-52-918]0x608001EA
    [13-45-52-918]0x608001ED
    [13-45-52-918]0x6000002D
    [13-45-52-918]0x63900009
    [13-45-52-918]0x62D0000F
    [13-45-52-918]0x64100009
    [13-45-52-918]0x60800220
    [13-45-52-918]0x608001DB
    [13-45-52-918]0x608001DC
    [13-45-52-918]0x608001D1
    [13-45-52-918]0x608001D3
    [13-45-52-918]0x6000002E
    [13-45-52-918]0x6390000A
    [13-45-52-918]0x62D00010
    [13-45-52-918]0x6410000A
    [13-45-52-918]0x608001E1
    [13-45-52-918]0x608001CF
    [13-45-52-918]0x608001D0
    [13-45-52-918]0x608001DD
    [13-45-52-918]0x608001DE
    [13-45-52-918]0x608001D4
    [13-45-52-918]0x6000002F
    [13-45-52-918]0x6390000B
    [13-45-52-918]0x62D00011
    [13-45-52-918]0x6410000B
    [13-45-52-918]0x608001D8
    [13-45-52-918]0x608001D6
    [13-45-52-918]0x608001D9
    [13-45-52-919]0x608001DA
    [13-45-52-919]0x6080008F
    [13-45-52-919]0x60800115
    [13-45-52-919]0x60000030
    [13-45-52-919]0x6390000C
    [13-45-52-919]0x62D00012
    [13-45-52-919]0x6410000C
    [13-45-52-919]0x608000AF
    [13-45-52-919]0x608000AE
    [13-45-52-919]0x608000B3
    [13-45-52-919]0x608000B2
    [13-45-52-919]0x608000B7
    [13-45-52-919]0x608000B6
    [13-45-52-919]0x608000BB
    [13-45-52-919]0x608000BA
    [13-45-52-919]0x60000031
    [13-45-52-919]0x6390000D
    [13-45-52-919]0x62D00013
    [13-45-52-920]0x6410000D
    [13-45-52-920]0x60800089
    [13-45-52-920]0x6080008A
    [13-45-52-920]0x608001DF
    [13-45-52-920]0x608000D0
    [13-45-52-920]0x6080013A
    [13-45-52-920]0x6080000E
    [13-45-52-920]0x60000032
    [13-45-52-920]0x6390000E
    [13-45-52-920]0x62D00014
    [13-45-52-920]0x6410000E
    [13-45-52-920]0x60800011
    [13-45-52-920]0x60800066
    [13-45-52-920]0x60800068
    [13-45-52-920]0x608001EE
    [13-45-52-920]0x608001EF
    [13-45-52-920]0x60000033
    [13-45-52-920]0x6390000F
    [13-45-52-920]0x62D00015
    [13-45-52-920]0x6410000F
    [13-45-52-920]0x608001F0
    [13-45-52-920]0x608001F1
    [13-45-52-920]0x608000C5
    [13-45-52-920]0x60800114
    [13-45-52-920]0x608000C4
    [13-45-52-920]0x60800221
    [13-45-52-920]0x60800222
    [13-45-52-920]0x60000034
    [13-45-52-920]0x63900010
    [13-45-52-920]0x62D00016
    [13-45-52-920]0x64100010
    [13-45-52-920]0x60800041
    [13-45-52-920]0x60800042
    [13-45-52-920]0x60800043
    [13-45-52-920]0x60800044
    [13-45-52-920]0x60800045
    [13-45-52-920]0x60000035
    [13-45-52-920]0x63800003
    [13-45-52-920]0x62C00009
    [13-45-52-920]0x64000003
    [13-45-52-920]0x60800047
    [13-45-52-921]0x60800048
    [13-45-52-921]0x60800049
    [13-45-52-921]0x6080004A
    [13-45-52-921]0x6080002D
    [13-45-52-921]0x60800019
    [13-45-52-921]0x60000036
    [13-45-52-921]0x63800004
    [13-45-52-921]0x62C0000A
    [13-45-52-921]0x64000004
    [13-45-52-921]0x6080013F
    [13-45-52-921]0x6080001B
    [13-45-52-921]0x60000037
    [13-45-52-921]0x63800005
    [13-45-52-921]0x62C0000B
    [13-45-52-921]0x64000005
    [13-45-52-921]0x608000D6
    [13-45-52-921]0x608001EB
    [13-45-52-921]0x608000CF
    [13-45-52-921]0x60000039
    [13-45-52-921]0x63934001
    [13-45-52-921]0x62D00017
    [13-45-52-921]0x64134001
    [13-45-52-921]0x608001FD
    [13-45-52-921]0x6000003D
    [13-45-52-921]0x63924000
    [13-45-52-921]0x63928000
    [13-45-52-921]0x64128000
    [13-45-52-921]0x62D00018
    [13-45-52-922]0x62D00019
    [13-45-52-922]0x62D0001A
    [13-45-52-922]0x64124000
    [13-45-52-922]0x608000D7
    [13-45-52-922]0x60800226
    [13-45-52-922]0x6000003F
    [13-45-52-922]0x63918000
    [13-45-52-922]0x63958000
    [13-45-52-922]0x64158000
    [13-45-52-922]0x62D0001B
    [13-45-52-922]0x62D2C001
    [13-45-52-922]0x62D2C002
    [13-45-52-922]0x64118000
    [13-45-52-922]0x60800227
    [13-45-52-922]0x60800244
    [13-45-52-922]0x60000040
    [13-45-52-922]0x6391C000
    [13-45-52-922]0x63958001
    [13-45-52-922]0x64158001
    [13-45-52-922]0x62D2C003
    [13-45-52-922]0x62D2C004
    [13-45-52-922]0x6411C000
    [13-45-52-922]0x608000DD
    [13-45-52-922]0x60800232
    [13-45-52-922]0x60000041
    [13-45-52-922]0x63920000
    [13-45-52-922]0x63958002
    [13-45-52-922]0x64158002
    [13-45-52-922]0x62D2C005
    [13-45-52-922]0x62D2C006
    [13-45-52-922]0x64120000
    [13-45-52-923]0x60800233
    [13-45-52-923]0x60800245
    [13-45-52-923]0x60000042
    [13-45-52-923]0x63924000
    [13-45-52-923]0x63958003
    [13-45-52-923]0x64158003
    [13-45-52-923]0x62D2C007
    [13-45-52-923]0x62D2C008
    [13-45-52-923]0x64124000
    [13-45-52-923]0x608000DE
    [13-45-52-923]0x60800234
    [13-45-52-923]0x60000043
    [13-45-52-923]0x63900011
    [13-45-52-923]0x62D0001C
    [13-45-52-923]0x64100011
    [13-45-52-923]0x60800235
    [13-45-52-923]0x60800246
    [13-45-52-923]0x60000044
    [13-45-52-923]0x63900012
    [13-45-52-923]0x62D0001D
    [13-45-52-923]0x64100012
    [13-45-52-923]0x608000DF
    [13-45-52-923]0x60800236
    [13-45-52-923]0x60000045
    [13-45-52-923]0x63900013
    [13-45-52-923]0x62D0001E
    [13-45-52-923]0x64100013
    [13-45-52-923]0x60800237
    [13-45-52-923]0x60800247
    [13-45-52-923]0x60000046
    [13-45-52-923]0x63900014
    [13-45-52-923]0x62D0001F
    [13-45-52-923]0x64100014
    [13-45-52-923]0x60800053
    [13-45-52-923]0x60800060
    [13-45-52-923]0x60000053
    [13-45-52-923]0x63800006
    [13-45-52-923]0x62C0000C
    [13-45-52-923]0x64000006
    [13-45-52-923]0x60800025
    [13-45-52-923]0x60800054
    [13-45-52-923]0x60000054
    [13-45-52-923]0x63800007
    [13-45-52-923]0x62C0000D
    [13-45-52-923]0x64000007
    [13-45-52-923]0x60800055
    [13-45-52-923]0x60800061
    [13-45-52-923]0x60000055
    [13-45-52-923]0x63800008
    [13-45-52-923]0x62C0000E
    [13-45-52-923]0x64000008
    [13-45-52-923]0x60800026
    [13-45-52-923]0x60800056
    [13-45-52-923]0x60000056
    [13-45-52-924]0x63800009
    [13-45-52-924]0x62C0000F
    [13-45-52-924]0x64000009
    [13-45-52-924]0x60800057
    [13-45-52-924]0x60800062
    [13-45-52-925]0x60000057
    [13-45-52-925]0x6380000A
    [13-45-52-925]0x62C00010
    [13-45-52-925]0x6400000A
    [13-45-52-925]0x60800027
    [13-45-52-925]0x60800058
    [13-45-52-925]0x60000058
    [13-45-52-925]0x6380000B
    [13-45-52-925]0x62C00011
    [13-45-52-925]0x6400000B
    [13-45-52-925]0x60800059
    [13-45-52-925]0x60800063
    [13-45-52-925]0x60000059
    [13-45-52-925]0x6380000C
    [13-45-52-925]0x62C00012
    [13-45-52-925]0x6400000C
    [13-45-52-925]0x60800028
    [13-45-52-925]0x6080005A
    [13-45-52-925]0x6000005A
    [13-45-52-925]0x6380000D
    [13-45-52-925]0x62C00013
    [13-45-52-925]0x6400000D
    [13-45-52-925]0x6080005B
    [13-45-52-925]0x60800064
    [13-45-52-926]0x6000005B
    [13-45-52-926]0x6380000E
    [13-45-52-926]0x62C00014
    [13-45-52-926]0x6400000E
    [13-45-52-926]0x608001FB
    [13-45-52-926]0x60000062
    [13-45-52-926]0x63964000
    [13-45-52-926]0x63930000
    [13-45-52-926]0x64130000
    [13-45-52-926]0x62D00020
    [13-45-52-926]0x62D00021
    [13-45-52-927]0x62D00022
    [13-45-52-927]0x64164000
    [13-45-52-927]0x60000067
    [13-45-52-927]0x63900015
    [13-45-52-927]0x62D00023
    [13-45-52-927]0x64100015
    [13-45-52-927]0x60000068
    [13-45-52-927]0x6380000F
    [13-45-52-933]0x62C00015
    [13-45-52-933]0x6400000F
    [13-45-52-933]0x60000069
    [13-45-52-933]0x63800010
    [13-45-52-937]0x62C00016
    [13-45-52-937]0x64000010
    [13-45-52-937]0x6000006A
    [13-45-52-937]0x6000006B
    [13-45-52-937]0x63800011
    [13-45-52-937]0x62C00017
    [13-45-52-937]0x64000011
    [13-45-52-937]0x60800029
    [13-45-52-937]0x6080002A
    [13-45-52-937]0x6000006C
    [13-45-52-937]0x63830000
    [13-45-52-937]0x62C00018
    [13-45-52-939]0x62C00019
    [13-45-52-939]0x64030000
    [13-45-52-939]0x60800018
    [13-45-52-939]0x60800031
    [13-45-52-939]0x6080002B
    [13-45-52-939]0x6080004B
    [13-45-52-939]0x6000006D
    [13-45-52-939]0x63828000
    [13-45-52-939]0x62C0001A
    [13-45-52-940]0x62C0001B
    [13-45-53-261]0x64028000
    [13-45-53-261]0x6080001A
    [13-45-53-261]0x60800032
    [13-45-53-262]0x6080002C
    [13-45-53-262]0x6080004C
    [13-45-53-262]0x6000006E
    [13-45-53-262]0x6382C000
    [13-45-53-262]0x62C0001C
    [13-45-53-262]0x62C0001D
    [13-45-53-262]0x6402C000
    [13-45-53-262]0x6000006F
    [13-45-53-262]0x63900016
    [13-45-53-262]0x62D00024
    [13-45-53-262]0x64100016
    [13-45-53-262]0x60000070
    [13-45-53-262]0x63924001
    [13-45-53-262]0x62D00025
    [13-45-53-262]0x64124001
    [13-45-53-262]0x60000071
    [13-45-53-262]0x63924002
    [13-45-53-262]0x62D00026
    [13-45-53-262]0x64124002
    [13-45-53-262]0x60000072
    [13-45-53-262]0x63924003
    [13-45-53-262]0x62D00027
    [13-45-53-262]0x64124003
    [13-45-53-262]0x6080003B
    [13-45-53-262]0x60000073
    [13-45-53-262]0x6380C000
    [13-45-53-262]0x62C0001E
    [13-45-53-262]0x62C0001F
    [13-45-53-262]0x6400C000
    [13-45-53-262]0x60000074
    [13-45-53-262]0x6380C001
    [13-45-53-262]0x62C00020
    [13-45-53-262]0x6400C001
    [13-45-53-262]0x6080009B
    [13-45-53-262]0x60000078
    [13-45-53-262]0x60000079
    [13-45-53-262]0x63924004
    [13-45-53-262]0x62D00028
    [13-45-53-262]0x64124004
    [13-45-53-262]0x6000007A
    [13-45-53-262]0x63924005
    [13-45-53-262]0x62D00029
    [13-45-53-262]0x64124005
    [13-45-53-262]0x6000007B
    [13-45-53-262]0x6000007C
    [13-45-53-262]0x63924006
    [13-45-53-262]0x62D0002A
    [13-45-53-262]0x64124006
    [13-45-53-262]0x6000007D
    [13-45-53-262]0x63800012
    [13-45-53-262]0x62C00021
    [13-45-53-262]0x64000012
    [13-45-53-262]0x6000007E
    [13-45-53-262]0x63800013
    [13-45-53-262]0x64000013
    [13-45-53-262]0x63804001
    [13-45-53-272]0x64004001
    [13-45-53-272]0x63808000
    [13-45-53-272]0x64008000
    [13-45-53-272]0x62C00022
    [13-45-53-272]0x6380C002
    [13-45-53-272]0x6400C002
    [13-45-53-272]0x63810000
    [13-45-53-272]0x64010000
    [13-45-53-272]0x62C00023
    [13-45-53-272]0x63814000
    [13-45-53-272]0x64014000
    [13-45-53-272]0x62C00024
    [13-45-53-272]0x63818000
    [13-45-53-272]0x64018000
    [13-45-53-272]0x62C00025
    [13-45-53-272]0x6381C000
    [13-45-53-272]0x6401C000
    [13-45-53-272]0x62C00026
    [13-45-53-272]0x63820000
    [13-45-53-272]0x64020000
    [13-45-53-272]0x62C00027
    [13-45-53-272]0x63824000
    [13-45-53-272]0x64024000
    [13-45-53-272]0x62C00028
    [13-45-53-272]0x63828001
    [13-45-53-272]0x64028001
    [13-45-53-272]0x6382C001
    [13-45-53-272]0x6402C001
    [13-45-53-272]0x63830001
    [13-45-53-273]0x64030001
    [13-45-53-273]0x6384C000
    [13-45-53-273]0x6404C000
    [13-45-53-273]0x62C04001
    [13-45-53-273]0x63850000
    [13-45-53-273]0x64050000
    [13-45-53-273]0x62C04002
    [13-45-53-273]0x63854000
    [13-45-53-273]0x64054000
    [13-45-53-273]0x63850001
    [13-45-53-273]0x64050001
    [13-45-53-273]0x62C04003
    [13-45-53-273]0x63000029
    [13-45-53-273]0x63004004
    [13-45-53-273]0x6000007F
    [13-45-53-273]0x60000083
    [13-45-53-273]0x60000084
    [13-45-53-273]0x60000085
    [13-45-53-273]0x60000086
    [13-45-53-273]0x60000087
    [13-45-53-273]0x60000088
    [13-45-53-273]0x60000089
    [13-45-53-273]0x63934002
    [13-45-53-273]0x62D0002B
    [13-45-53-273]0x64134002
    [13-45-53-273]0x6000008C
    [13-45-53-273]0x6000008D
    [13-45-53-273]0x6000008E
    [13-45-53-273]0x6000008F
    [13-45-53-273]0x63900017
    [13-45-53-274]0x64100017
    [13-45-53-274]0x63904000
    [13-45-53-274]0x64104000
    [13-45-53-274]0x63928001
    [13-45-53-274]0x64128001
    [13-45-53-274]0x62D0002C
    [13-45-53-274]0x63908000
    [13-45-53-274]0x64108000
    [13-45-53-274]0x62D0002D
    [13-45-53-274]0x6390C000
    [13-45-53-274]0x6410C000
    [13-45-53-274]0x63958004
    [13-45-53-274]0x64158004
    [13-45-53-274]0x62D0002E
    [13-45-53-274]0x63914000
    [13-45-53-274]0x64114000
    [13-45-53-274]0x62D0002F
    [13-45-53-274]0x63924007
    [13-45-53-274]0x64124007
    [13-45-53-274]0x63928002
    [13-45-53-274]0x64128002
    [13-45-53-274]0x63930001
    [13-45-53-274]0x64130001
    [13-45-53-274]0x63934003
    [13-45-53-274]0x64134003
    [13-45-53-274]0x63948000
    [13-45-53-274]0x64148000
    [13-45-53-274]0x62D00030
    [13-45-53-274]0x63958005
    [13-45-53-274]0x64158005
    [13-45-53-274]0x63960001
    [13-45-53-274]0x64160001
    [13-45-53-274]0x63964001
    [13-45-53-274]0x64164001
    [13-45-53-274]0x6396C000
    [13-45-53-274]0x6416C000
    [13-45-53-274]0x62D00031
    [13-45-53-274]0x63984000
    [13-45-53-274]0x64184000
    [13-45-53-274]0x62D00032
    [13-45-53-274]0x639A0001
    [13-45-53-274]0x641A0001
    [13-45-53-274]0x63918001
    [13-45-53-274]0x64118001
    [13-45-53-274]0x6391C001
    [13-45-53-274]0x6411C001
    [13-45-53-274]0x63920001
    [13-45-53-274]0x64120001
    [13-45-53-274]0x63924001
    [13-45-53-274]0x64124001
    [13-45-53-274]0x63100033
    [13-45-53-274]0x63104003
    [13-45-53-274]0x63108001
    [13-45-53-274]0x6310C001
    [13-45-53-274]0x63110001
    [13-45-53-274]0x63114001
    [13-45-53-274]0x63118001
    [13-45-53-274]0x6311C001
    [13-45-53-274]0x63120001
    [13-45-53-275]0x63124001
    [13-45-53-275]0x63128001
    [13-45-53-275]0x6312C009
    [13-45-53-275]0x63190001
    [13-45-53-275]0x63194001
    [13-45-53-275]0x63198001
    [13-45-53-275]0x60000090
    [13-45-53-275]0x60000091
    [13-45-53-275]0x60800030
    [13-45-53-275]0x60000093
    [13-45-53-275]0x60000094
    [13-45-53-275]0x63924008
    [13-45-53-275]0x62D00032
    [13-45-53-275]0x64124008
    [13-45-53-275]0x6080005C
    [13-45-53-275]0x60000095
    [13-45-53-275]0x63800014
    [13-45-53-275]0x62C00028
    [13-45-53-275]0x64000014
    [13-45-53-275]0x60000096
    [13-45-53-275]0x63924009
    [13-45-53-275]0x62D00033
    [13-45-53-275]0x64124009
    [13-45-53-275]0x60000097
    [13-45-53-275]0x63800015
    [13-45-53-275]0x62C00029
    [13-45-53-275]0x64000015
    [13-45-53-275]0x60800154
    [13-45-53-275]0x60800098
    [13-45-53-275]0x6080008C
    [13-45-53-275]0x6080014D
    [13-45-53-275]0x608000A5
    [13-45-53-275]0x608000A4
    [13-45-53-275]0x608000E1
    [13-45-53-275]0x60800083
    [13-45-53-275]0x60800116
    [13-45-53-275]0x608001B5
    [13-45-53-275]0x60800117
    [13-45-53-275]0x608000CE
    [13-45-53-275]0x60800010
    [13-45-53-275]0x6080010A
    [13-45-53-275]0x60800091
    [13-45-53-275]0x6080010B
    [13-45-53-275]0x60800090
    [13-45-53-275]0x608000FF
    [13-45-53-275]0x60800039
    [13-45-53-275]0x608000AD
    [13-45-53-275]0x6080009A
    [13-45-53-275]0x6080001E
    [13-45-53-275]0x60800223
    [13-45-53-276]0x60800249
    [13-45-53-276]0x608000B8
    [13-45-53-276]0x6080008D
    [13-45-53-276]0x6080021F
    [13-45-53-276]0x60800038
    [13-45-53-276]0x608000B0
    [13-45-53-276]0x6080008E
    [13-45-53-276]0x608000CC
    [13-45-53-276]0x608000C8
    [13-45-53-276]0x608000CD
    [13-45-53-277]0x60800118
    [13-45-53-277]0x6080015A
    [13-45-53-277]0x6080009C
    [13-45-53-277]0x608000A1
    [13-45-53-277]0x60800012
    [13-45-53-277]0x60800149
    [13-45-53-277]0x608000BD
    [13-45-53-277]0x6080001F
    [13-45-53-277]0x6080015F
    [13-45-53-277]0x608000C7
    [13-45-53-277]0x608000FE
    [13-45-53-277]0x608000B5
    [13-45-53-277]0x608000C9
    [13-45-53-277]0x6080011A
    [13-45-53-277]0x60800033
    [13-45-53-277]0x6080014F
    [13-45-53-277]0x6080023A
    [13-45-53-277]0x608000C2
    [13-45-53-277]0x60800020
    [13-45-53-277]0x60800095
    [13-45-53-277]0x60800146
    [13-45-53-277]0x608000A0
    [13-45-53-277]0x60800035
    [13-45-53-277]0x60800159
    [13-45-53-277]0x60800013
    [13-45-53-277]0x608000F8
    [13-45-53-277]0x608000B1
    [13-45-53-277]0x60800015
    [13-45-53-277]0x608000F9
    [13-45-53-277]0x608000A7
    [13-45-53-277]0x608000A8
    [13-45-53-277]0x608000BF
    [13-45-53-277]0x608000BC
    [13-45-53-277]0x608000AB
    [13-45-53-277]0x60800110
    [13-45-53-277]0x60800119
    [13-45-53-277]0x60800144
    [13-45-53-277]0x60800092
    [13-45-53-277]0x608000B9
    [13-45-53-277]0x608000A2
    [13-45-53-277]0x60800143
    [13-45-53-277]0x6080009F
    [13-45-53-277]0x60800104
    [13-45-53-277]0x60800082
    [13-45-53-277]0x6080008B
    [13-45-53-277]0x60800016
    [13-45-53-277]0x608000C0
    [13-45-53-277]0x608000BE
    [13-45-53-277]0x6080009E
    [13-45-53-277]0x6080011C
    [13-45-53-277]0x60800034
    [13-45-53-277]0x60800094
    [13-45-53-277]0x608000AA
    [13-45-53-277]0x6080002E
    [13-45-53-277]0x608000C3
    [13-45-53-277]0x6080000F
    [13-45-53-277]0x60800099
    [13-45-53-277]0x608000A3
    [13-45-53-279]0x60800111
    [13-45-53-279]0x608000E2
    [13-45-53-279]0x6080011D
    [13-45-53-279]0x6080011B
    [13-45-53-279]0x6080015E
    [13-45-53-279]0x608000A6
    [13-45-53-279]0x60800105
    [13-45-53-279]0x608000CA
    [13-45-53-279]0x6080014C
    [13-45-53-282]0x608000CB
    [13-45-53-612]0x608000B4
    [13-45-53-612]0x60800096
    [13-45-53-612]0x6080009D
    [13-45-53-612]0x608000A9
    [13-45-53-612]0x60800014
    [13-45-53-612]0x60800017
    [13-45-53-612]0x6080023B
    [13-45-53-612]0x60800093
    [13-45-53-612]0x60800148
    [13-45-53-612]0x60800097
    [13-45-53-612]0x608000AC
    [13-45-53-612]0x608000C6
    [13-45-53-612]0x60800155
    [13-45-53-612]0x6080014A
    [13-45-53-612]0x608000D5
    [13-45-53-612]0x6080014E
    [13-45-53-612]0x608000D4
    [13-45-53-612]0x60800145
    [13-45-53-612]0x608000C1
    [13-45-53-612]0x608001F7
    [13-45-53-612]0x6000009D
    [13-45-53-612]0x600000AA
    [13-45-53-612]0x63908001
    [13-45-53-612]0x62D00034
    [13-45-53-612]0x64108001
    [13-45-53-612]0x600000AB
    [13-45-53-612]0x63908002
    [13-45-53-612]0x62D00035
    [13-45-53-612]0x64108002
    [13-45-53-612]0x600000AC
    [13-45-53-612]0x63908003
    [13-45-53-612]0x62D00036
    [13-45-53-612]0x64108003
    [13-45-53-612]0x600000AD
    [13-45-53-612]0x63908004
    [13-45-53-612]0x62D00037
    [13-45-53-612]0x64108004
    [13-45-53-612]0x600000B0
    [13-45-53-612]0x63818001
    [13-45-53-612]0x62C0002A
    [13-45-53-612]0x64018001
    [13-45-53-612]0x600000B1
    [13-45-53-612]0x63818002
    [13-45-53-612]0x62C0002B
    [13-45-53-612]0x64018002
    [13-45-53-612]0x600000B2
    [13-45-53-612]0x63854001
    [13-45-53-612]0x62C04003
    [13-45-53-612]0x64054001
    [13-45-53-612]0x600000B4
    [13-45-53-612]0x63800016
    [13-45-53-612]0x62C0002C
    [13-45-53-612]0x64000016
    [13-45-53-612]0x600000B5
    [13-45-53-612]0x63814001
    [13-45-53-612]0x62C0002D
    [13-45-53-612]0x64014001
    [13-45-53-612]0x60800050
    [13-45-53-612]0x600000CF
    [13-45-53-614]0x63820001
    [13-45-53-614]0x62C0002E
    [13-45-53-614]0x64020001
    [13-45-53-614]0x60800051
    [13-45-53-614]0x600000D0
    [13-45-53-614]0x63824001
    [13-45-53-614]0x62C0002F
    [13-45-53-614]0x64024001
    [13-45-53-614]0x6080023C
    [13-45-53-614]0x608000FB
    [13-45-53-614]0x608000FC
    [13-45-53-614]0x608000EE
    [13-45-53-614]0x608000FA
    [13-45-53-614]0x608000FD
    [13-45-53-614]0x608000F3
    [13-45-53-614]0x600000D1
    [13-45-53-614]0x6390C001
    [13-45-53-614]0x62D00038
    [13-45-53-614]0x6410C001
    [13-45-53-614]0x6080023D
    [13-45-53-614]0x60800101
    [13-45-53-614]0x60800102
    [13-45-53-614]0x608000EF
    [13-45-53-614]0x60800100
    [13-45-53-614]0x60800103
    [13-45-53-614]0x608000F4
    [13-45-53-614]0x600000D2
    [13-45-53-614]0x6390C002
    [13-45-53-614]0x62D00039
    [13-45-53-614]0x6410C002
    [13-45-53-614]0x6080023E
    [13-45-53-614]0x60800107
    [13-45-53-614]0x60800108
    [13-45-53-614]0x608000F0
    [13-45-53-614]0x60800106
    [13-45-53-614]0x60800109
    [13-45-53-614]0x608000F5
    [13-45-53-614]0x600000D3
    [13-45-53-614]0x6390C003
    [13-45-53-614]0x62D0003A
    [13-45-53-614]0x6410C003
    [13-45-53-614]0x6080023F
    [13-45-53-614]0x6080010D
    [13-45-53-614]0x6080010E
    [13-45-53-614]0x608000F1
    [13-45-53-614]0x6080010C
    [13-45-53-614]0x6080010F
    [13-45-53-614]0x608000F6
    [13-45-53-614]0x600000D4
    [13-45-53-614]0x6390C004
    [13-45-53-614]0x62D0003B
    [13-45-53-614]0x6410C004
    [13-45-53-614]0x60800240
    [13-45-53-614]0x60800113
    [13-45-53-614]0x608000F2
    [13-45-53-614]0x60800112
    [13-45-53-614]0x608000F7
    [13-45-53-614]0x600000D5
    [13-45-53-614]0x6390C005
    [13-45-53-615]0x62D0003C
    [13-45-53-615]0x6410C005
    [13-45-53-615]0x600000DD
    [13-45-53-615]0x63800017
    [13-45-53-615]0x62C00030
    [13-45-53-615]0x64000017
    [13-45-53-615]0x600000DE
    [13-45-53-615]0x63800018
    [13-45-53-615]0x62C00031
    [13-45-53-615]0x64000018
    [13-45-53-616]0x6080005D
    [13-45-53-616]0x600000DF
    [13-45-53-616]0x6380C003
    [13-45-53-616]0x62C00032
    [13-45-53-616]0x6400C003
    [13-45-53-616]0x6080011E
    [13-45-53-616]0x6080011F
    [13-45-53-616]0x600000E0
    [13-45-53-616]0x63914001
    [13-45-53-616]0x62D0003D
    [13-45-53-616]0x64114001
    [13-45-53-616]0x600000E1
    [13-45-53-616]0x63900018
    [13-45-53-616]0x62D0003E
    [13-45-53-616]0x64100018
    [13-45-53-616]0x60800120
    [13-45-53-616]0x60800121
    [13-45-53-616]0x60800211
    [13-45-53-616]0x600000E2
    [13-45-53-616]0x63900019
    [13-45-53-616]0x62D0003F
    [13-45-53-616]0x64100019
    [13-45-53-616]0x600000E3
    [13-45-53-616]0x6390001A
    [13-45-53-616]0x62D00040
    [13-45-53-616]0x6410001A
    [13-45-53-616]0x600000E4
    [13-45-53-616]0x6390001B
    [13-45-53-616]0x62D00041
    [13-45-53-616]0x6410001B
    [13-45-53-616]0x600000E5
    [13-45-53-616]0x6390001C
    [13-45-53-616]0x62D00042
    [13-45-53-616]0x6410001C
    [13-45-53-616]0x600000E6
    [13-45-53-616]0x6390001D
    [13-45-53-616]0x62D00043
    [13-45-53-616]0x6410001D
    [13-45-53-616]0x600000E7
    [13-45-53-616]0x6390001E
    [13-45-53-616]0x62D00044
    [13-45-53-616]0x6410001E
    [13-45-53-616]0x600000E8
    [13-45-53-616]0x6390001F
    [13-45-53-616]0x62D00045
    [13-45-53-616]0x6410001F
    [13-45-53-616]0x600000E9
    [13-45-53-616]0x63900020
    [13-45-53-616]0x62D00046
    [13-45-53-617]0x64100020
    [13-45-53-617]0x600000EA
    [13-45-53-617]0x63900021
    [13-45-53-617]0x62D00047
    [13-45-53-617]0x64100021
    [13-45-53-617]0x600000EB
    [13-45-53-617]0x63900022
    [13-45-53-618]0x62D00048
    [13-45-53-618]0x64100022
    [13-45-53-618]0x600000EC
    [13-45-53-618]0x63900023
    [13-45-53-618]0x62D00049
    [13-45-53-618]0x64100023
    [13-45-53-618]0x600000ED
    [13-45-53-618]0x63900024
    [13-45-53-618]0x62D0004A
    [13-45-53-618]0x64100024
    [13-45-53-618]0x600000EE
    [13-45-53-618]0x63900025
    [13-45-53-618]0x62D0004B
    [13-45-53-618]0x64100025
    [13-45-53-618]0x600000EF
    [13-45-53-618]0x63900026
    [13-45-53-618]0x62D0004C
    [13-45-53-618]0x64100026
    [13-45-53-618]0x600000F0
    [13-45-53-618]0x63900027
    [13-45-53-618]0x62D0004D
    [13-45-53-618]0x64100027
    [13-45-53-618]0x600000F1
    [13-45-53-618]0x63900028
    [13-45-53-618]0x62D0004E
    [13-45-53-618]0x64100028
    [13-45-53-618]0x600000F2
    [13-45-53-618]0x63900029
    [13-45-53-618]0x62D0004F
    [13-45-53-618]0x64100029
    [13-45-53-618]0x600000F3
    [13-45-53-618]0x6390002A
    [13-45-53-618]0x62D00050
    [13-45-53-618]0x6410002A
    [13-45-53-618]0x600000F4
    [13-45-53-618]0x6390002B
    [13-45-53-618]0x62D00051
    [13-45-53-618]0x6410002B
    [13-45-53-618]0x600000F5
    [13-45-53-618]0x6390002C
    [13-45-53-618]0x62D00052
    [13-45-53-618]0x6410002C
    [13-45-53-618]0x600000F6
    [13-45-53-618]0x6390002D
    [13-45-53-618]0x62D00053
    [13-45-53-618]0x6410002D
    [13-45-53-618]0x600000F7
    [13-45-53-618]0x6390002E
    [13-45-53-618]0x62D00054
    [13-45-53-618]0x6410002E
    [13-45-53-618]0x600000F8
    [13-45-53-618]0x6390002F
    [13-45-53-619]0x62D00055
    [13-45-53-619]0x6410002F
    [13-45-53-619]0x600000F9
    [13-45-53-619]0x63900030
    [13-45-53-619]0x62D00056
    [13-45-53-619]0x64100030
    [13-45-53-619]0x600000FA
    [13-45-53-619]0x63900031
    [13-45-53-619]0x62D00057
    [13-45-53-619]0x64100031
    [13-45-53-620]0x600000FB
    [13-45-53-620]0x63900032
    [13-45-53-620]0x62D00058
    [13-45-53-620]0x64100032
    [13-45-53-620]0x600000FC
    [13-45-53-620]0x63900033
    [13-45-53-620]0x62D00059
    [13-45-53-620]0x64100033
    [13-45-53-620]0x600000FD
    [13-45-53-620]0x63900034
    [13-45-53-620]0x62D0005A
    [13-45-53-620]0x64100034
    [13-45-53-620]0x600000FE
    [13-45-53-620]0x63900035
    [13-45-53-620]0x62D0005B
    [13-45-53-620]0x64100035
    [13-45-53-620]0x600000FF
    [13-45-53-620]0x63900036
    [13-45-53-620]0x62D0005C
    [13-45-53-620]0x64100036
    [13-45-53-620]0x60000100
    [13-45-53-620]0x63900037
    [13-45-53-620]0x62D0005D
    [13-45-53-620]0x64100037
    [13-45-53-620]0x60000101
    [13-45-53-620]0x63900038
    [13-45-53-620]0x62D0005E
    [13-45-53-621]0x64100038
    [13-45-53-621]0x60000102
    [13-45-53-621]0x63900039
    [13-45-53-621]0x62D0005F
    [13-45-53-621]0x64100039
    [13-45-53-621]0x60000103
    [13-45-53-621]0x6390003A
    [13-45-53-621]0x62D00060
    [13-45-53-621]0x6410003A
    [13-45-53-621]0x60000104
    [13-45-53-621]0x6390003B
    [13-45-53-621]0x62D00061
    [13-45-53-621]0x6410003B
    [13-45-53-621]0x60000105
    [13-45-53-621]0x6390003C
    [13-45-53-621]0x62D00062
    [13-45-53-621]0x6410003C
    [13-45-53-621]0x60000106
    [13-45-53-621]0x6390003D
    [13-45-53-621]0x62D00063
    [13-45-53-621]0x6410003D
    [13-45-53-621]0x60000107
    [13-45-53-623]0x6390003E
    [13-45-53-623]0x62D00064
    [13-45-53-623]0x6410003E
    [13-45-53-623]0x60000108
    [13-45-53-623]0x6390003F
    [13-45-53-623]0x62D00065
    [13-45-53-624]0x6410003F
    [13-45-53-624]0x60000109
    [13-45-53-624]0x63900040
    [13-45-53-625]0x62D00066
    [13-45-53-951]0x64100040
    [13-45-53-951]0x6000010A
    [13-45-53-951]0x63900041
    [13-45-53-951]0x62D00067
    [13-45-53-951]0x64100041
    [13-45-53-951]0x6000010B
    [13-45-53-951]0x6000010C
    [13-45-53-951]0x63800019
    [13-45-53-951]0x62C00033
    [13-45-53-951]0x64000019
    [13-45-53-951]0x6000010D
    [13-45-53-951]0x6380001A
    [13-45-53-951]0x62C00034
    [13-45-53-951]0x6400001A
    [13-45-53-951]0x6000010E
    [13-45-53-951]0x6380001B
    [13-45-53-951]0x62C00035
    [13-45-53-951]0x6400001B
    [13-45-53-951]0x6000010F
    [13-45-53-951]0x6380001C
    [13-45-53-951]0x62C00036
    [13-45-53-951]0x6400001C
    [13-45-53-951]0x60000110
    [13-45-53-951]0x6380001D
    [13-45-53-951]0x62C00037
    [13-45-53-951]0x6400001D
    [13-45-53-951]0x60000111
    [13-45-53-951]0x6380001E
    [13-45-53-951]0x62C00038
    [13-45-53-951]0x6400001E
    [13-45-53-951]0x60000112
    [13-45-53-951]0x6380001F
    [13-45-53-951]0x62C00039
    [13-45-53-951]0x6400001F
    [13-45-53-951]0x60000113
    [13-45-53-951]0x63800020
    [13-45-53-951]0x62C0003A
    [13-45-53-951]0x64000020
    [13-45-53-951]0x60000115
    [13-45-53-951]0x60000116
    [13-45-53-951]0x6000011B
    [13-45-53-951]0x60800009
    [13-45-53-951]0x6080000B
    [13-45-53-951]0x6000011C
    [13-45-53-951]0x6384C001
    [13-45-53-951]0x62C04004
    [13-45-53-951]0x6404C001
    [13-45-53-951]0x6080000A
    [13-45-53-951]0x6080000C
    [13-45-53-951]0x6000011D
    [13-45-53-951]0x63850002
    [13-45-53-951]0x62C04005
    [13-45-53-951]0x64050002
    [13-45-53-951]0x6080003F
    [13-45-53-951]0x60000127
    [13-45-53-951]0x6384C002
    [13-45-53-951]0x62C04006
    [13-45-53-951]0x6404C002
    [13-45-53-951]0x60800040
    [13-45-53-953]0x60000128
    [13-45-53-953]0x63850003
    [13-45-53-953]0x62C04007
    [13-45-53-953]0x64050003
    [13-45-53-953]0x60000130
    [13-45-53-953]0x6080003C
    [13-45-53-953]0x6000015B
    [13-45-53-953]0x63800021
    [13-45-53-953]0x62C0003B
    [13-45-53-953]0x64000021
    [13-45-53-953]0x6000015C
    [13-45-53-953]0x63800022
    [13-45-53-953]0x62C0003C
    [13-45-53-953]0x64000022
    [13-45-53-953]0x6080003A
    [13-45-53-953]0x6000015D
    [13-45-53-953]0x63800023
    [13-45-53-953]0x62C0003D
    [13-45-53-953]0x64000023
    [13-45-53-953]0x6080005E
    [13-45-53-953]0x6080005F
    [13-45-53-953]0x60000167
    [13-45-53-953]0x6380C004
    [13-45-53-953]0x62C0003E
    [13-45-53-953]0x6400C004
    [13-45-53-953]0x6000016E
    [13-45-53-953]0x63810001
    [13-45-53-953]0x62C0003F
    [13-45-53-953]0x64010001
    [13-45-53-953]0x6000016F
    [13-45-53-953]0x63948001
    [13-45-53-953]0x62D00068
    [13-45-53-953]0x64148001
    [13-45-53-953]0x60000170
    [13-45-53-953]0x63984001
    [13-45-53-953]0x62D00069
    [13-45-53-953]0x64184001
    [13-45-53-953]0x60000171
    [13-45-53-953]0x63930002
    [13-45-53-953]0x62D0006A
    [13-45-53-953]0x64130002
    [13-45-53-953]0x60000172
    [13-45-53-953]0x63928003
    [13-45-53-953]0x62D0006B
    [13-45-53-953]0x64128003
    [13-45-53-953]0x60000173
    [13-45-53-953]0x63958006
    [13-45-53-953]0x62D0006C
    [13-45-53-953]0x64158006
    [13-45-53-953]0x60000174
    [13-45-53-953]0x6396C001
    [13-45-53-953]0x62D0006D
    [13-45-53-953]0x6416C001
    [13-45-53-953]0x60000176
    [13-45-53-953]0x63D00042
    [13-45-53-953]0x64500042
    [13-45-53-953]0x63D04001
    [13-45-53-953]0x63D28004
    [13-45-53-953]0x64504001
    [13-45-53-954]0x6310006E
    [13-45-53-954]0x64528004
    [13-45-53-954]0x63D08005
    [13-45-53-954]0x64508005
    [13-45-53-954]0x63D0C006
    [13-45-53-954]0x6450C006
    [13-45-53-954]0x63D14002
    [13-45-53-954]0x64514002
    [13-45-53-954]0x63D2400A
    [13-45-53-954]0x6452400A
    [13-45-53-955]0x63D28003
    [13-45-53-955]0x64528003
    [13-45-53-955]0x63D30003
    [13-45-53-955]0x64530003
    [13-45-53-955]0x63D34004
    [13-45-53-955]0x64534004
    [13-45-53-955]0x63D48002
    [13-45-53-955]0x64548002
    [13-45-53-955]0x63D58007
    [13-45-53-955]0x64558007
    [13-45-53-955]0x63D60002
    [13-45-53-955]0x64560002
    [13-45-53-955]0x63D64002
    [13-45-53-955]0x64564002
    [13-45-53-955]0x63D6C002
    [13-45-53-955]0x6456C002
    [13-45-53-955]0x63D84002
    [13-45-53-955]0x64584002
    [13-45-53-955]0x63DA0002
    [13-45-53-955]0x645A0002
    [13-45-53-955]0x63D18002
    [13-45-53-955]0x64518002
    [13-45-53-955]0x63D1C002
    [13-45-53-955]0x6451C002
    [13-45-53-955]0x63D20002
    [13-45-53-955]0x64520002
    [13-45-53-955]0x63D24002
    [13-45-53-955]0x64524002
    [13-45-53-955]0x63C00024
    [13-45-53-955]0x64400024
    [13-45-53-955]0x63C04002
    [13-45-53-955]0x64404002
    [13-45-53-955]0x63C08001
    [13-45-53-955]0x64408001
    [13-45-53-955]0x63C0C005
    [13-45-53-955]0x6440C005
    [13-45-53-955]0x63C10002
    [13-45-53-955]0x64410002
    [13-45-53-955]0x63C14002
    [13-45-53-955]0x64414002
    [13-45-53-955]0x63C18003
    [13-45-53-955]0x64418003
    [13-45-53-955]0x63C1C001
    [13-45-53-955]0x6441C001
    [13-45-53-955]0x63C20002
    [13-45-53-955]0x64420002
    [13-45-53-955]0x63C24002
    [13-45-53-955]0x64424002
    [13-45-53-955]0x63C28002
    [13-45-53-956]0x64428002
    [13-45-53-956]0x63C2C002
    [13-45-53-956]0x6442C002
    [13-45-53-956]0x63C30002
    [13-45-53-956]0x64430002
    [13-45-53-956]0x63C4C003
    [13-45-53-956]0x6444C003
    [13-45-53-956]0x63C50004
    [13-45-53-956]0x64450004
    [13-45-53-956]0x63C54002
    [13-45-53-956]0x64454002
    [13-45-53-956]0x68400000
    [13-45-53-956]0x60400127
    [13-45-53-956]0x63C4C002
    [13-45-53-956]0x60C0003F
    [13-45-53-956]0x6444C002
    [13-45-53-956]0x63004008
    [13-45-53-956]0x61800200
    [13-45-53-956]0x61C00128
    [13-45-53-956]0x62000000
    [13-45-53-956]0x60400128
    [13-45-53-956]0x63C50003
    [13-45-53-956]0x60C00040
    [13-45-53-956]0x64450003
    [13-45-53-956]0x63004007
    [13-45-53-956]Initlialzing PLLs ...0x61800101
    [13-45-53-956]0x61C010CF
    [13-45-53-956]0x61800104
    [13-45-53-956]0x61800100
    [13-45-53-956]0x6180010D
    [13-45-53-956]0x61293043
    [13-45-53-956]0x6180010C
    [13-45-53-957]0x61293043
    [13-45-53-957]0x61800101
    [13-45-53-957]0x61C01095
    [13-45-53-957]0x61800104
    [13-45-53-957]0x61800100
    [13-45-53-957]0x62000000
    [13-45-53-957]0x6180010D
    [13-45-53-957]0x61296C44
    [13-45-53-957]0x6180010C
    [13-45-53-957]0x61C0146D
    [13-45-53-957]0x61800103
    [13-45-53-958]0x61800100
    [13-45-53-958]0x61C0146D
    [13-45-53-958]0x62000000
    [13-45-53-958]0x60C0004B
    [13-45-53-958]0x61800102
    [13-45-53-958]0x62000006
    [13-45-53-958]0x6180010D
    [13-45-53-958]0x6129FC45
    [13-45-53-958]0x6180010C
    [13-45-53-959]0x61C0146D
    [13-45-53-959]0x6129FC45
    [13-45-53-959]0x61800101
    [13-45-53-959]0x61C0146E
    [13-45-53-959]0x61800104
    [13-45-53-959]0x61800103
    [13-45-53-959]0x61800100
    [13-45-53-959]0x62000000
    [13-45-53-960]0x60C0004C
    [13-45-53-960]0x61800102
    [13-45-53-960]0x61C0146E
    [13-45-53-960]0x62000006
    [13-45-53-960]0x6180010D
    [13-45-53-960]0x6129FC45
    [13-45-53-960]0x6180010C
    [13-45-53-960]0x61800101
    [13-45-53-960]0x61C0841D
    [13-45-53-960]0x61800104
    [13-45-53-960]0x61800100
    [13-45-53-960]0x62000000
    [13-45-53-960]0x612BDC46
    [13-45-53-960]0x61C0481D
    [13-45-53-960]0x612B7C47
    [13-45-53-968]0x61C0481D
    [13-45-53-968]0x612B7C47
    [13-45-53-968]0x61800101
    [13-45-53-968]0x61C008CF
    [13-45-53-968]0x61800104
    [13-45-53-968]0x61800100
    [13-45-53-969]0x61C008CF
    [13-45-54-298]0x62000000
    [13-45-54-298]0x6180010D
    [13-45-54-298]0x61C008CF
    [13-45-54-298]0x61293049
    [13-45-54-298]0x6180010C
    [13-45-54-298]0x61800101
    [13-45-54-298]0x61C00862
    [13-45-54-298]0x61800104
    [13-45-54-298]0x61800100
    [13-45-54-298]0x612B7DE2
    [13-45-54-298]0x61C008B6
    [13-45-54-298]0x612931E4
    [13-45-54-298]0x61C00953
    [13-45-54-298]0x61277D3B
    [13-45-54-298]0x61C00C63
    [13-45-54-300]0x612B6DE7
    [13-45-54-300]0x6180010C
    [13-45-54-300]0x61C00C63
    [13-45-54-300]0x61800101
    [13-45-54-300]0x61C01495
    [13-45-54-300]0x61800104
    [13-45-54-300]0x61800100
    [13-45-54-300]0x62000000
    [13-45-54-300]0x6180010D
    [13-45-54-300]0x612B6D3F
    [13-45-54-300]0x61C01462
    [13-45-54-300]0x612B7DEF
    [13-45-54-300]0x61C004D1
    [13-45-54-300]0x612B7620
    [13-45-54-300]0x61C0841C
    [13-45-54-301]0x612BDDED
    [13-45-54-301]0x6180010C
    [13-45-54-301]0x61C0841C
    [13-45-54-314]0x612BDDED
    [13-45-54-314]0x61800101
    [13-45-54-314]0x61C00C1C
    [13-45-54-314]0x61800104
    [13-45-54-314]0x61800103
    [13-45-54-314]0x61800100
    [13-45-54-314]0x62000000
    [13-45-54-314]0x61800102
    [13-45-54-314]0x62000004
    [13-45-54-314]0x6180010D
    [13-45-54-314]0x612B7DEE
    [13-45-54-314]0x6180010C
    [13-45-54-314]0x61C0701C
    [13-45-54-314]0x612D31E6
    [13-45-54-314]done.
    [13-45-54-314]InitlialzingClocks ...0x61800201
    [13-45-54-314]0x61C00023
    [13-45-54-314]0x61800201
    [13-45-54-314]0x61C0006D
    [13-45-54-314]0x61C0006E
    [13-45-54-314]0x61C0006B
    [13-45-54-314]0x61C0006C
    [13-45-54-314]0x61C0006A
    [13-45-54-314]0x61C00095
    [13-45-54-314]0x61C000DF
    [13-45-54-314]0x61C00167
    [13-45-54-314]0x61C0008A
    [13-45-54-314]0x61800200
    [13-45-54-314]0x62000002
    [13-45-54-319]0x62D0006D
    [13-45-54-319]0x6413C000
    [13-45-54-319]0x62D0006E
    [13-45-54-319]0x6000008A
    [13-45-54-319]0x6393C000
    [13-45-54-319]0x61800202
    [13-45-54-319]0x61C0008A
    [13-45-54-319]0x62000000
    [13-45-54-319]0x61800201
    [13-45-54-319]0x61C0008B
    [13-45-54-319]0x61800200
    [13-45-54-319]0x62000002
    [13-45-54-319]0x62D0006F
    [13-45-54-319]0x64144000
    [13-45-54-319]0x62D00070
    [13-45-54-319]0x6000008B
    [13-45-54-319]0x63944000
    [13-45-54-319]0x61C00060
    [13-45-54-319]0x62D00071
    [13-45-54-319]0x64138000
    [13-45-54-319]0x6413C001
    [13-45-54-319]0x62D00072
    [13-45-54-319]0x60000060
    [13-45-54-319]0x63938000
    [13-45-54-319]0x6393C001
    [13-45-54-319]0x61C00061
    [13-45-54-320]0x61800200
    [13-45-54-320]0x61C00061
    [13-45-54-320]0x62000002
    [13-45-54-320]0x62D00073
    [13-45-54-320]0x64140000
    [13-45-54-320]0x64144001
    [13-45-54-320]0x62D00074
    [13-45-54-320]0x60000061
    [13-45-54-320]0x63940000
    [13-45-54-320]0x63944001
    [13-45-54-320]0x61800202
    [13-45-54-320]0x62000000
    [13-45-54-320]0x61800201
    [13-45-54-320]0x61C00062
    [13-45-54-320]0x61C00063
    [13-45-54-320]0x62D00075
    [13-45-54-321]0x6415C000
    [13-45-54-321]0x6416C001
    [13-45-54-321]0x62D00076
    [13-45-54-321]0x608001FC
    [13-45-54-321]0x608001AF
    [13-45-54-321]0x60000063
    [13-45-54-321]0x6395C000
    [13-45-54-321]0x6396C001
    [13-45-54-321]0x61800202
    [13-45-54-321]0x61C00063
    [13-45-54-321]0x62000000
    [13-45-54-321]0x61800201
    [13-45-54-321]0x61C00071
    [13-45-54-321]0x61C00165
    [13-45-54-321]0x61800200
    [13-45-54-321]0x62000002
    [13-45-54-321]0x62D04002
    [13-45-54-322]0x641B4000
    [13-45-54-322]0x62D04003
    [13-45-54-322]0x6080021C
    [13-45-54-322]0x60000165
    [13-45-54-322]0x639B4000
    [13-45-54-322]0x61800202
    [13-45-54-322]0x61C00165
    [13-45-54-322]0x62000000
    [13-45-54-322]0x61800201
    [13-45-54-322]0x61C0003D
    [13-45-54-322]done.
    [13-45-54-322]Initlialzing DDR ...0x61800101
    [13-45-54-322]0x61C0008A
    [13-45-54-322]0x61800104
    [13-45-54-322]0x61800100
    [13-45-54-322]0x6180010D
    [13-45-54-322]0x61257DCF
    [13-45-54-322]0x6180010C
    [13-45-54-322]0x61800101
    [13-45-54-323]0x61800104
    [13-45-54-323]0x61C0008A
    [13-45-54-323]0x61800100
    [13-45-54-323]0x62000000
    [13-45-54-323]0x6180010D
    [13-45-54-323]0x612FFDCF
    [13-45-54-323]0x6180010C
    [13-45-54-324]0x612FFDCF
    [13-45-54-324]0x61800101
    [13-45-54-325]0x61C0008A
    [13-45-54-325]0x61800104
    [13-45-54-325]0x61800100
    [13-45-54-325]0x62000000
    [13-45-54-325]0x6180010D
    [13-45-54-326]0x61C0008A
    [13-45-54-443]0x61257DCF
    [13-45-54-444]0x6180010C
    [13-45-54-444]0x61C0008A
    [13-45-54-444]0x61257DCF
    [13-45-54-444]0x61800101
    [13-45-54-444]0x61800104
    [13-45-54-444]0x61800100
    [13-45-54-444]0x62000000
    [13-45-54-444]0x6180010D
    [13-45-54-444]0x612FFDCF
    [13-45-54-445]0x61C0008A
    [13-45-54-445]0x62000000
    [13-45-54-445]0x6180010D
    [13-45-54-445]0x61257DCF
    [13-45-54-445]0x6180010C
    [13-45-54-445]0x61800101
    [13-45-54-445]0x61800104
    [13-45-54-445]0x61800100
    [13-45-54-445]0x612FFDCF
    [13-45-54-445]done.
    [13-45-54-445]Initializing GTC ...Begin parsing user application
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x20...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x21...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x2...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x6...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x7...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x8...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x9...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x30...
    [13-45-54-446]Calling Sciclient_procBootRequestProcessor, ProcId 0x31...
    [13-45-54-452]Calling Sciclient_procBootRequestProcessor, ProcId 0x80...
    [13-45-54-453]
    [13-45-54-454] If you don't get the logs of the application while booting     from boot0 partition then you might need to pass the MAX_APP_SIZE_EMMC (=<size of you application>)     while building your appimage
    [13-45-54-939]Searching for X509 certificate ...not found
    [13-45-54-939]Switching core id 8, proc_id 0x1 to split mode...
    [13-45-54-939]Calling Sciclient_procBootGetProcessorState, ProcId 0x1...
    [13-45-54-939]Sciclient_procBootSetProcessorCfg, ProcId 0x1, enabling split mode...
    [13-45-54-939]Enabling MCU TCMs after reset for core 8
    [13-45-54-939]Disabling HW-based memory init of MCU TCMs for core 8
    [13-45-54-939]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-45-54-939]Copying 0x40 bytes to 0x41010000
    [13-45-54-939]Copying 0x490 bytes to 0x41010040
    [13-45-54-939]Copying 0x448 bytes to 0x410104d0
    [13-45-54-939]Copying 0x318 bytes to 0x41010918
    [13-45-54-939]Copying 0x118 bytes to 0x41010c30
    [13-45-54-939]Copying 0x8c bytes to 0xa0100000
    [13-45-54-939]Copying 0x1184 bytes to 0xa056c300
    [13-45-54-939]Copying 0x2218 bytes to 0xa056d488
    [13-45-54-939]Copying 0x23260 bytes to 0xa05b5ee0
    [13-45-54-939]Copying 0xa1b0 bytes to 0xa05d9140
    [13-45-54-939]Copying 0x41b8 bytes to 0xa05f5380
    [13-45-54-939]Setting entry point for core 8 @0x41010000
    [13-45-54-940]Calling Sciclient_procBootGetProcessorState, ProcId 0x1...
    [13-45-54-940]Sciclient_procBootSetProcessorCfg, ProcId 0x1, enabling split mode...
    [13-45-54-940]Sciclient_pmSetModuleState Off, DevId 0x11d...
    [13-45-54-940]Calling Sciclient_procBootGetProcessorState, ProcId 0x2...
    [13-45-54-940]Enabling MCU TCMs after reset for core 9
    [13-45-54-940]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-45-54-940]Setting HALT for ProcId 0x2...
    [13-45-54-940]Sciclient_pmSetModuleState On, DevId 0x11d...
    [13-45-54-940]Clearing core_id 9 (lock-step) ATCM @ 0x41400000
    [13-45-54-940]Clearing core_id 9 (lock-step) BTCM @ 0x41410000
    [13-45-54-940]Translating coreid 9 local BTCM addr 0x41010000 to SoC MCU BTCM addr 0x41410000
    [13-45-54-940]Copying 0x40 bytes to 0x41410000
    [13-45-54-940]Translating coreid 9 local BTCM addr 0x41010040 to SoC MCU BTCM addr 0x41410040
    [13-45-54-940]Copying 0x490 bytes to 0x41410040
    [13-45-54-940]Translating coreid 9 local BTCM addr 0x410104d0 to SoC MCU BTCM addr 0x414104d0
    [13-45-54-940]Copying 0x448 bytes to 0x414104d0
    [13-45-54-940]Translating coreid 9 local BTCM addr 0x41010918 to SoC MCU BTCM addr 0x41410918
    [13-45-54-941]Copying 0x318 bytes to 0x41410918
    [13-45-54-941]Translating coreid 9 local BTCM addr 0x41010c30 to SoC MCU BTCM addr 0x41410c30
    [13-45-54-941]Copying 0x118 bytes to 0x41410c30
    [13-45-54-941]Copying 0x8c bytes to 0xa1100000
    [13-45-54-941]Copying 0x290 bytes to 0xa156c300
    [13-45-54-941]Copying 0xf1f0 bytes to 0xa159e240
    [13-45-54-941]Copying 0x36e0 bytes to 0xa15b9d00
    [13-45-54-941]Setting entry point for core 9 @0x41010000
    [13-45-54-941]Switching core id 10, proc_id 0x6 to split mode...
    [13-45-54-941]Calling Sciclient_procBootGetProcessorState, ProcId 0x6...
    [13-45-54-941]Sciclient_procBootSetProcessorCfg, ProcId 0x6, enabling split mode...
    [13-45-54-941]Sciclient_pmSetModuleState Off, DevId 0x117...
    [13-45-54-941]0x61800200
    [13-45-54-941]0x61C00117
    [13-45-54-941]0x62000000
    [13-45-54-941]Enabling MCU TCMs after reset for core 10
    [13-45-54-941]Disabling HW-based memory init of MCU TCMs for core 10
    [13-45-54-941]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-45-54-942]Setting HALT for ProcId 0x6...
    [13-45-54-942]Sciclient_pmSetModuleState On, DevId 0x117...
    [13-45-54-944]0x61800200
    [13-45-54-944]0x61C00117
    [13-45-54-944]0x62000002
    [13-45-54-944]0x62D60000
    [13-45-54-944]0x64174000
    [13-45-54-944]0x62D60001
    [13-45-54-944]0x60000117
    [13-45-54-944]0x63974000
    [13-45-54-944]Clearing core_id 10 (lock-step) ATCM @ 0x5c00000
    [13-45-54-944]Clearing core_id 10 (lock-step) BTCM @ 0x5c10000
    [13-45-54-944]Translating coreid 10 local ATCM addr 0x0 to SoC MCU ATCM addr 0x5c00000
    [13-45-54-944]Copying 0x40 bytes to 0x5c00000
    [13-45-54-944]Translating coreid 10 local ATCM addr 0x40 to SoC MCU ATCM addr 0x5c00040
    [13-45-54-944]Copying 0x490 bytes to 0x5c00040
    [13-45-54-944]Translating coreid 10 local ATCM addr 0x4d0 to SoC MCU ATCM addr 0x5c004d0
    [13-45-54-945]Copying 0x448 bytes to 0x5c004d0
    [13-45-54-945]Translating coreid 10 local ATCM addr 0x918 to SoC MCU ATCM addr 0x5c00918
    [13-45-54-945]Copying 0x318 bytes to 0x5c00918
    [13-45-54-945]Translating coreid 10 local ATCM addr 0xc30 to SoC MCU ATCM addr 0x5c00c30
    [13-45-54-945]Copying 0x118 bytes to 0x5c00c30
    [13-45-54-945]Copying 0x8c bytes to 0xa2100000
    [13-45-54-945]Copying 0x2c0 bytes to 0xa2f9a0cc
    [13-45-54-945]Copying 0x84400 bytes to 0xa30d8000
    [13-45-54-945]Copying 0x42b40 bytes to 0xa3232a00
    [13-45-54-945]Copying 0x12d98 bytes to 0xa328d540
    [13-45-54-945]Setting entry point for core 10 @0x0
    [13-45-54-950]Switching core id 10, proc_id 0x6 to split mode...
    [13-45-55-086]Calling Sciclient_procBootGetProcessorState, ProcId 0x6...
    [13-45-55-086]Sciclient_procBootSetProcessorCfg, ProcId 0x6, enabling split mode...
    [13-45-55-086]Sciclient_pmSetModuleState Off, DevId 0x118...
    [13-45-55-086]0x61800200
    [13-45-55-086]0x61C00118
    [13-45-55-086]0x62000000
    [13-45-55-087]Calling Sciclient_procBootGetProcessorState, ProcId 0x7...
    [13-45-55-087]Enabling MCU TCMs after reset for core 11
    [13-45-55-087]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-45-55-087]Setting HALT for ProcId 0x7...
    [13-45-55-087]Sciclient_pmSetModuleState On, DevId 0x118...
    [13-45-55-087]0x61800200
    [13-45-55-087]0x61C00118
    [13-45-55-087]0x62000002
    [13-45-55-087]0x62D60002
    [13-45-55-087]0x64178000
    [13-45-55-087]0x62D60003
    [13-45-55-087]0x60000118
    [13-45-55-087]0x63978000
    [13-45-55-087]Clearing core_id 11 (lock-step) ATCM @ 0x5d00000
    [13-45-55-087]Clearing core_id 11 (lock-step) BTCM @ 0x5d10000
    [13-45-55-087]Translating coreid 11 local ATCM addr 0x0 to SoC MCU ATCM addr 0x5d00000
    [13-45-55-087]Copying 0x40 bytes to 0x5d00000
    [13-45-55-087]Translating coreid 11 local ATCM addr 0x40 to SoC MCU ATCM addr 0x5d00040
    [13-45-55-087]Copying 0x490 bytes to 0x5d00040
    [13-45-55-088]Translating coreid 11 local ATCM addr 0x4d0 to SoC MCU ATCM addr 0x5d004d0
    [13-45-55-088]Copying 0x448 bytes to 0x5d004d0
    [13-45-55-088]Translating coreid 11 local ATCM addr 0x918 to SoC MCU ATCM addr 0x5d00918
    [13-45-55-088]Copying 0x318 bytes to 0x5d00918
    [13-45-55-088]Translating coreid 11 local ATCM addr 0xc30 to SoC MCU ATCM addr 0x5d00c30
    [13-45-55-088]Copying 0x118 bytes to 0x5d00c30
    [13-45-55-088]Copying 0x8c bytes to 0xa4100000
    [13-45-55-088]Copying 0x2c0 bytes to 0xa49d0b10
    [13-45-55-088]Copying 0xa40 bytes to 0xa49d0dd0
    [13-45-55-088]Copying 0x32e70 bytes to 0xa4b8e000
    [13-45-55-088]Copying 0x13060 bytes to 0xa4bc0e70
    [13-45-55-088]Setting entry point for core 11 @0x0
    [13-45-55-088]Copying 0x98 bytes to 0xb0100000
    [13-45-55-088]Copying 0x40 bytes to 0xb0200000
    [13-45-55-088]Copying 0x880 bytes to 0xb0400000
    [13-45-55-088]Copying 0x880 bytes to 0xb0600000
    [13-45-55-088]Copying 0x20 bytes to 0xb1367d50
    [13-45-55-090]Copying 0x1000 bytes to 0xb13e8000
    [13-45-55-106]Copying 0x5b5100 bytes to 0xb1400000
    [13-45-55-209]Copying 0x31150 bytes to 0xb1b24000
    [13-45-55-209]Copying 0x29468 bytes to 0xb1b55150
    [13-45-55-209]Setting entry point for core 18 @0xb0200000
    [13-45-55-209]Copying 0x98 bytes to 0xb6100000
    [13-45-55-209]Copying 0x40 bytes to 0xb6200000
    [13-45-55-209]Copying 0x840 bytes to 0xb6400000
    [13-45-55-209]Copying 0x840 bytes to 0xb6600000
    [13-45-55-209]Copying 0x1000 bytes to 0xb73660c0
    [13-45-55-209]Copying 0x2c630 bytes to 0xb7556000
    [13-45-55-211]Copying 0x7c0c bytes to 0xb75a6008
    [13-45-55-221]Copying 0x151ac0 bytes to 0xb7600000
    [13-45-55-243]Setting entry point for core 19 @0xb6200000
    [13-45-55-243]Copying 0x68880 bytes to 0x9e800000
    [13-45-55-244]Only load (not execute) image @0x9e800000
    [13-45-55-255]Copying 0x12b5200 bytes to 0x80080000
    [13-45-55-831]Only load (not execute) image @0x80080000
    [13-45-55-831]Copying 0x13e8c bytes to 0x82000000
    [13-45-55-831]Only load (not execute) image @0x82000000
    [13-45-55-831]Sciclient_pmSetModuleState On, DevId 0x4...
    [13-45-55-831]0x61800200
    [13-45-55-831]0x61C00004
    [13-45-55-831]0x62000002
    [13-45-55-831]0x62D38000
    [13-45-55-831]0x64138000
    [13-45-55-831]0x62D38001
    [13-45-55-831]0x608000D1
    [13-45-55-831]0x60000004
    [13-45-55-831]0x63938000
    [13-45-55-831]Copying 0xabc0 bytes to 0x70000000
    [13-45-55-831]Setting entry point for core 0 @0x70000000
    [13-45-55-831]==xiex=> SBL_MulticoreImageParse:Ok
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x20...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x21...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x1...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x2...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x6...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x7...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x8...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x9...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x30...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x31...
    [13-45-55-831]Sciclient_procBootReleaseProcessor, ProcId 0x80...
    [13-45-55-831]Calling Sciclient_procBootRequestProcessor, ProcId 0x6...
    [13-45-55-831]Sciclient_procBootSetProcessorCfg, ProcId 0x6, EntryPoint 0x0...
    [13-45-55-831]Sciclient_pmSetModuleClkFreq, DevId 0x117 @ 1000000000Hz...
    [13-45-55-831]0x6180010C
    [13-45-55-831]0x61C00117
    [13-45-55-831]0x612FDDDD
    [13-45-55-831]Clearing HALT for ProcId 0x6...
    [13-45-55-831]Calling Sciclient_procBootRequestProcessor, ProcId 0x7...
    [13-45-55-831]Sciclient_procBootSetProcessorCfg, ProcId 0x7, EntryPoint 0x0...
    [13-45-55-831]Sciclient_pmSetModuleClkFreq, DevId 0x118 @ 1000000000Hz...
    [13-45-55-831]0x61C00118
    [13-45-55-831]Clearing HALT for ProcId 0x7...
    [13-45-55-831]Calling Sciclient_procBootRequestProcessor, ProcId 0x30...
    [13-45-55-831]Sciclient_procBootSetProcessorCfg, ProcId 0x30, EntryPoint 0xb0200000...
    [13-45-55-831]Sciclient_pmSetModuleClkFreq, DevId 0x8 @ 1000000000Hz...
    [13-45-55-831]0x61C00008
    [13-45-55-832]0x612FDDD2
    [13-45-55-832]Sciclient_pmSetModuleState Off, DevId 0x8...
    [13-45-55-832]0x61800200
    [13-45-55-832]0x61C00008
    [13-45-55-832]0x62000000
    [13-45-55-832]Sciclient_pmSetModuleState On, DevId 0x8...
    [13-45-55-833]0x62000002
    [13-45-55-833]0x62D30000
    [13-45-55-833]0x64128000
    [13-45-55-833]0x62D30001
    [13-45-55-833]0x608000D2
    [13-45-55-833]0x60000008
    [13-45-55-833]0x63928000
    [13-45-55-833]Sciclient_procBootReleaseProcessor, ProcId 0x30...
    [13-45-55-833]Calling Sciclient_procBootRequestProcessor, ProcId 0x31...
    [13-45-55-833]Sciclient_procBootSetProcessorCfg, ProcId 0x31, EntryPoint 0xb6200000...
    [13-45-55-833]Sciclient_pmSetModuleClkFreq, DevId 0xb @ 1000000000Hz...
    [13-45-55-833]0x6180010C
    [13-45-55-833]0x61C0000B
    [13-45-55-833]0x612FDDD2
    [13-45-55-833]Sciclient_pmSetModuleState Off, DevId 0xb...
    [13-45-55-833]0x61800200
    [13-45-55-833]0x62000000
    [13-45-55-833]Sciclient_pmSetModuleState On, DevId 0xb...
    [13-45-55-833]0x62D34000
    [13-45-55-833]0x64130000
    [13-45-55-833]0x62D34001
    [13-45-55-833]0x6000000B
    [13-45-55-833]0x63930000
    [13-45-55-833]Sciclient_procBootReleaseProcessor, ProcId 0x31...
    [13-45-55-833]0x61800201
    [13-45-55-833]0x61C0006D
    [13-45-55-833]0x6040006D
    [13-45-55-833]0x63C28001
    [13-45-55-833]0x60C00031
    [13-45-55-833]0x64428001
    [13-45-55-833]0x63000040
    [13-45-55-833]0x6300003F
    [13-45-55-833]0x61800202
    [13-45-55-833]0x62000001
    [13-45-55-833]0x61C0006E
    [13-45-55-833]0x6040006E
    [13-45-55-833]0x63C2C001
    [13-45-55-833]0x60C00032
    [13-45-55-833]0x6442C001
    [13-45-55-833]0x6300003E
    [13-45-55-833]0x6300003D
    [13-45-55-833]0x61C0006B
    [13-45-55-835]0x61800200
    [13-45-55-835]0x61C0006B
    [13-45-55-835]0x62000000
    [13-45-55-835]0x6040006B
    [13-45-55-835]0x63C00023
    [13-45-55-835]0x64400023
    [13-45-55-835]0x6300003C
    [13-45-55-835]0x61800202
    [13-45-55-835]0x62000001
    [13-45-55-835]0x61800201
    [13-45-55-835]0x61C0006C
    [13-45-55-835]0x6040006C
    [13-45-55-835]0x63C30001
    [13-45-55-835]0x64430001
    [13-45-55-835]0x6300003B
    [13-45-55-835]0x6300003A
    [13-45-55-836]0x61C0006C
    [13-45-55-836]0x62000001
    [13-45-55-836]0x61800201
    [13-45-55-836]0x61C0006A
    [13-45-55-836]0x61800200
    [13-45-55-836]0x62000000
    [13-45-55-836]0x6040006A
    [13-45-55-836]0x61800202
    [13-45-55-836]0x61C000DF
    [13-45-55-836]0x604000DF
    [13-45-55-836]0x63C0C004
    [13-45-55-836]0x60C0005D
    [13-45-55-836]0x6440C004
    [13-45-55-836]0x63000039
    [13-45-55-836]0x61C00062
    [13-45-55-837]0x61C00062
    [13-45-55-837]0x62000000
    [13-45-55-837]0x60400062
    [13-45-55-837]0x63D64001
    [13-45-55-837]0x63D30002
    [13-45-55-837]0x60C001FB
    [13-45-55-837]0x64564001
    [13-45-55-837]0x63100077
    [13-45-55-837]0x64530002
    [13-45-55-837]0x63100076
    [13-45-55-837]0x61800202
    [13-45-55-840]0x61C00062
    [13-45-55-840]0x62000001
    [13-45-55-840]0x61800201
    [13-45-55-840]0x61C00063
    [13-45-55-841]0x61800200
    [13-45-56-114]0x61C00063
    [13-45-56-114]0x62000000
    [13-45-56-114]0x60400063
    [13-45-56-114]0x63D5C001
    [13-45-56-114]0x63D6C002
    [13-45-56-114]0x60C001AF
    [13-45-56-114]0x60C001FC
    [13-45-56-114]0x6455C001
    [13-45-56-114]0x63100075
    [13-45-56-114]0x6456C002
    [13-45-56-114]0x63100074
    [13-45-56-114]0x61800202
    [13-45-56-114]0x62000001
    [13-45-56-114]0x61800201
    [13-45-56-114]0x61C0003D
    [13-45-56-114]0x61800200
    [13-45-56-114]0x6040003D
    [13-45-56-114]0x63D24009
    [13-45-56-114]0x60C001FD
    [13-45-56-114]0x64524009
    [13-45-56-114]0x63100073
    [13-45-56-114]Calling Sciclient_procBootRequestProcessor, ProcId 0x20...
    [13-45-56-114]Sciclient_procBootSetProcessorCfg, ProcId 0x20, EntryPoint 0x70000000...
    [13-45-56-114]Sciclient_pmSetModuleClkFreq, DevId 0xca @ 2000000000Hz...
    [13-45-56-114]0x6180010C
    [13-45-56-114]0x61C000CA
    [13-45-56-114]0x6131DDD3
    [13-45-56-114]Sciclient_pmSetModuleState Off, DevId 0xca...
    [13-45-56-114]Sciclient_pmSetModuleState On, DevId 0xca...
    [13-45-56-114]0x62000002
    [13-45-56-114]0x62D3C000
    [13-45-56-114]0x62D38002
    [13-45-56-114]0x64140000
    [13-45-56-114]0x63938001
    [13-45-56-114]0x64138001
    [13-45-56-114]0x62D3C001
    [13-45-56-114]0x600000CA
    [13-45-56-114]0x63940000
    [13-45-56-114]Sciclient_procBootReleaseProcessor, ProcId 0x20...
    [13-45-56-114]Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
    [13-45-56-114]Sciclient_procBootSetProcessorCfg, ProcId 0x1, EntryPoint 0x41010000...
    [13-45-56-114]Sciclient_pmSetModuleClkFreq, DevId 0x11c @ 1000000000Hz...
    [13-45-56-115]0x61C0011C
    [13-45-56-115]0x612FDC07
    [13-45-56-115]Copying first 128 bytes from app to MCU ATCM @ 0x0 for core 8
    [13-45-56-117]Calling Sciclient_procBootRequestProcessor, ProcId 0x2...
    [13-45-56-117]Sciclient_procBootSetProcessorCfg, ProcId 0x2, EntryPoint 0x41010000...
    [13-45-56-117]Sciclient_pmSetModuleClkFreq, DevId 0x11d @ 1000000000Hz...
    [13-45-56-117]0x6180010C
    [13-45-56-117]0x61C0011D
    [13-45-56-117]0x612FDC07
    [13-45-56-117]0x6180010E
    [13-45-56-117]0x61C0011C
    [13-45-56-117]MCU @ 1000000000Hz.
    [13-45-56-118]cycles per usec  = 1000
    [13-45-56-118]  fxn:main                              line:14764479   cycle:    489800        timestamp:       489us
    [13-45-56-118]  fxn:main                              line: 261       cycle:    489951        timestamp:       489us
    [13-45-56-118]  fxn:SBL_SciClientInit                 line: 256       cycle:   4963693        timestamp:      4963us
    [13-45-56-118]  fxn:SBL_SciClientInit                 line: 279       cycle: 530683862        timestamp:    530683us
    [13-45-56-119]  fxn:SBL_SciClientInit                 line: 291       cycle: 532679649        timestamp:    532679us
    [13-45-56-119]  fxn:SBL_SciClientInit                 line: 306       cycle: 535832292        timestamp:    535832us
    [13-45-56-119]  fxn:SBL_SciClientInit                 line: 324       cycle: 542846219        timestamp:    542846us
    [13-45-56-119]**fxn:SBL_SciClientInit                 line: 326       cycle:        95        timestamp:         0us
    [13-45-56-123]  fxn:SBL_SciClientInit                 line: 358       cycle:   1426122        timestamp:      1426us
    [13-45-56-125]  fxn:SBL_SciClientInit                 line: 407       cycle:   2297071        timestamp:      2297us
    [13-45-56-128]  fxn:main                              line: 349       cycle:1949227248        timestamp:   1949227us
    [13-45-56-129]  fxn:main                              line: 366       cycle:-2054060699       timestamp:   2240906us
    [13-45-56-138]  fxn:main                              line: 405       cycle:-605063339        timestamp:   3689903us
    [13-45-56-151]  fxn:main                              line: 432       cycle:-266282832        timestamp:   4028684us
    [13-45-56-157]Copying first 128 bytes from app to MCU ATCM @ 0x41400000 for core 9
    [13-45-56-169]Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
    normal log :
    [13-55-19-157]iex=> current emmc partition: 1
    [13-55-19-505]0x4F8A00FF
    [13-55-19-505]0x4F8B0001
    [13-55-19-505]0x4F800079
    [13-55-19-505]0x4F80007A
    [13-55-19-505]0x4F8B0002
    [13-55-19-505]0x4F80007C
    [13-55-19-505]0x4F80007D
    [13-55-19-505]0x4F800094
    [13-55-19-505]0x4F800096
    [13-55-19-506]0x4F8B0002
    [13-55-19-506]0x4F8000E3
    [13-55-19-506]0x4F8A00FF
    [13-55-19-506]0x4D4000E3
    [13-55-19-506]0x4D4A0000
    [13-55-19-506]0x4D4B0000
    [13-55-19-506]0x4D4A0001
    [13-55-19-506]0x4D4B0001
    [13-55-19-506]0x4D4A0002
    [13-55-19-506]0x4D4B0002
    [13-55-19-506]0x4D4A0003
    [13-55-19-506]0x4D4B0003
    [13-55-19-507]0x4F8B0002
    [13-55-19-507]0x4F8000E3
    [13-55-19-507]0x4D4000E3
    [13-55-19-507]0x4D4A0004
    [13-55-19-507]0x4D4B0004
    [13-55-19-507]0x4F8A00FF
    [13-55-19-507]0x4D4A0005
    [13-55-19-507]0x4D4B0005
    [13-55-19-509]0x4F8B0002
    [13-55-19-509]0x4F8000E3
    [13-55-19-509]0x4D4000E3
    [13-55-19-509]0x4D4A0006
    [13-55-19-509]0x4D4B0006
    [13-55-19-509]0x4F8A00FF
    [13-55-19-509]0x4D4A0007
    [13-55-19-509]0x4D4B0007
    [13-55-19-509]0x4D4A0008
    [13-55-19-509]0x4D4B0008
    [13-55-19-509]0x4D4A0009
    [13-55-19-509]0x4D4B0009
    [13-55-19-510]0x4F8B0002
    [13-55-19-510]0x4F8000E3
    [13-55-19-510]0x4D4000E3
    [13-55-19-510]0x4D4A000A
    [13-55-19-510]0x4D4B00B8
    [13-55-19-510]0x4F8A00FF
    [13-55-19-510]0x4D4A000B
    [13-55-19-510]0x4D4B00B9
    [13-55-19-510]0x4D4A000C
    [13-55-19-510]0x4D4B00BA
    [13-55-19-510]0x4D4A000D
    [13-55-19-510]0x4D4B00BB
    [13-55-19-510]0x4D4A000E
    [13-55-19-510]0x4D4B00BC
    [13-55-19-510]0x4D4A000F
    [13-55-19-510]0x4D4B00BD
    [13-55-19-511]0x4F8A00FF
    [13-55-19-511]0x4F8B0002
    [13-55-19-511]0x4F8000E3
    [13-55-19-511]0x4D4000E3
    [13-55-19-511]0x4D4A0010
    [13-55-19-511]0x4D4B00BE
    [13-55-19-511]0x4D4A0011
    [13-55-19-511]0x4D4B00BF
    [13-55-19-511]0x4D4A0012
    [13-55-19-511]0x4D4B00C0
    [13-55-19-511]0x4D4A0013
    [13-55-19-511]0x4D4B00C1
    [13-55-19-511]0x4D4A0014
    [13-55-19-511]0x4D4B00C2
    [13-55-19-511]0x4D4A0015
    [13-55-19-511]0x4D4B00C3
    [13-55-19-511]0x4D4A0016
    [13-55-19-511]0x4D4B00E0
    [13-55-19-511]0x4D4A0017
    [13-55-19-511]0x4D4B00E1
    [13-55-19-512]0x4F8A00FF
    [13-55-19-512]0x4F8B0002
    [13-55-19-512]0x4F8000E3
    [13-55-19-512]0x4D4000E3
    [13-55-19-512]0x4D4A0018
    [13-55-19-512]0x4D4B00E2
    [13-55-19-512]0x4D4A0019
    [13-55-19-513]0x4D4B00E3
    [13-55-19-513]0x4F8A00FF
    [13-55-19-513]0x4F8B0002
    [13-55-19-513]0x4F8000E3
    [13-55-19-513]0x4D4000E3
    [13-55-19-513]0x4D4A001A
    [13-55-19-513]0x4D4B0100
    [13-55-19-513]0x4D4A001B
    [13-55-19-513]0x4D4B0101
    [13-55-19-513]0x4D4A001C
    [13-55-19-513]0x4D4B0102
    [13-55-19-513]0x4D4A001D
    [13-55-19-513]0x4D4B0103
    [13-55-19-513]0x4D4A001E
    [13-55-19-513]0x4D4B0120
    [13-55-19-513]0x4D4A001F
    [13-55-19-513]0x4D4B0121
    [13-55-19-513]0x4D4A0020
    [13-55-19-513]0x4D4B0122
    [13-55-19-513]0x4D4A0021
    [13-55-19-513]0x4D4B0123
    [13-55-19-513]0x4F8B0001
    [13-55-19-513]0x4F80010C
    [13-55-19-513]0x4D40010C
    [13-55-19-513]0x4D4A0000
    [13-55-19-513]0x4D4B0000
    [13-55-19-515]0x4F8B0001
    [13-55-19-515]0x4F80010C
    [13-55-19-515]0x4D40010C
    [13-55-19-515]0x4D4A0001
    [13-55-19-515]0x4D4B0001
    [13-55-19-515]0x4F8A00FF
    [13-55-19-515]0x4D4A0002
    [13-55-19-515]0x4D4B0002
    [13-55-19-515]0x4D4A0003
    [13-55-19-515]0x4D4B0003
    [13-55-19-515]0x4D4A0004
    [13-55-19-515]0x4D4B0020
    [13-55-19-515]0x4D4A0005
    [13-55-19-515]0x4D4B0021
    [13-55-19-516]0x4F8B0001
    [13-55-19-516]0x4F80010C
    [13-55-19-516]0x4D40010C
    [13-55-19-516]0x4D4A0006
    [13-55-19-516]0x4D4B0022
    [13-55-19-516]0x4F8A00FF
    [13-55-19-516]0x4D4A0007
    [13-55-19-516]0x4D4B0023
    [13-55-19-516]0x4D4A0010
    [13-55-19-516]0x4D4B0005
    [13-55-19-516]0x4D4A0011
    [13-55-19-516]0x4D4B0006
    [13-55-19-517]0x4D4A0012
    [13-55-19-517]0x4D4B0007
    [13-55-19-524]0x4F8A00FF
    [13-55-19-528]0x4F8B0001
    [13-55-19-528]0x4F80010C
    [13-55-19-528]0x4D40010C
    [13-55-19-528]0x4D4A0013
    [13-55-19-528]0x4D4B0008
    [13-55-19-528]0x4F8A00FF
    [13-55-19-529]0x4F8B0001
    [13-55-19-529]0x4F80010C
    [13-55-19-529]0x4D40010C
    [13-55-19-529]0x4D4A0014
    [13-55-19-531]0x4D4B0009
    [13-55-19-850]0x4F8A00FF
    [13-55-19-850]0x4F8B0001
    [13-55-19-850]0x4F80010C
    [13-55-19-850]0x4D40010C
    [13-55-19-850]0x4D4A0015
    [13-55-19-850]0x4D4B000A
    [13-55-19-850]0x4D4A0016
    [13-55-19-850]0x4D4B000B
    [13-55-19-850]0x4F8B0002
    [13-55-19-850]0x4F8000FE
    [13-55-19-850]0x4F8000FF
    [13-55-19-850]0x4F800109
    [13-55-19-852]0x4F800109
    [13-55-19-852]0x4F8A00FF
    [13-55-19-852]0x4F8B0002
    [13-55-19-854]0x4F8B0002
    [13-55-19-854]0x4F800109
    [13-55-19-854]0x4F8A00FF
    [13-55-19-854]0x4F8B0001
    [13-55-19-854]0x4F800113
    [13-55-19-854]0x4F8000E1
    [13-55-19-854]0x4F800103
    [13-55-19-856]0x4F8A00FF
    [13-55-19-856]0x4F8B0081
    [13-55-19-856]0x4F800110
    [13-55-19-856]0x4F8B0002
    [13-55-19-856]0x4F8000E1
    [13-55-19-856]0x4F800107
    [13-55-19-856]0x4F8B0001
    [13-55-19-856]0x4F800111
    [13-55-19-856]0x4F800100
    [13-55-19-856]0x4F80010F
    [13-55-19-856]TIFS  ver: 8.6.3--v08.06.03 (Chill Capybar
    [13-55-19-856]SCISERVER Board Configuration header population... PASSED
    [13-55-19-856]Sciclient_setBoardConfigHeader... PASSED
    [13-55-19-856]0x61800200
    [13-55-19-856]0x61C00127
    [13-55-19-856]0x62000000
    [13-55-19-856]0x60000006
    [13-55-19-856]0x63960000
    [13-55-19-856]0x62D00001
    [13-55-19-856]0x639A0000
    [13-55-19-856]0x62D04001
    [13-55-19-856]0x62D00002
    [13-55-19-856]0x64160000
    [13-55-19-856]0x62D04002
    [13-55-19-856]0x641A0000
    [13-55-19-856]0x60000009
    [13-55-19-856]0x6000000A
    [13-55-19-856]0x6000000C
    [13-55-19-856]0x6000000D
    [13-55-19-856]0x608001E0
    [13-55-19-856]0x608001F2
    [13-55-19-856]0x608001F3
    [13-55-19-856]0x6000000E
    [13-55-19-856]0x608001D2
    [13-55-19-856]0x6000000F
    [13-55-19-856]0x63900000
    [13-55-19-856]0x62D00003
    [13-55-19-856]0x62D00004
    [13-55-19-856]0x64100000
    [13-55-19-856]0x60000010
    [13-55-19-856]0x60000011
    [13-55-19-856]0x60000012
    [13-55-19-856]0x60000013
    [13-55-19-856]0x60000014
    [13-55-19-856]0x60000015
    [13-55-19-856]0x60000016
    [13-55-19-856]0x63804000
    [13-55-19-856]0x62C00001
    [13-55-19-856]0x63844000
    [13-55-19-856]0x62C00002
    [13-55-19-856]0x62C00003
    [13-55-19-867]0x64004000
    [13-55-19-867]0x62C00004
    [13-55-19-867]0x64044000
    [13-55-19-867]0x60000017
    [13-55-19-867]0x60000018
    [13-55-19-867]0x60000019
    [13-55-19-867]0x6000001A
    [13-55-19-867]0x60800022
    [13-55-19-867]0x60800021
    [13-55-19-867]0x60800005
    [13-55-19-867]0x60800006
    [13-55-19-867]0x60800007
    [13-55-19-868]0x6080004D
    [13-55-19-868]0x60800046
    [13-55-19-868]0x6080001C
    [13-55-19-868]0x6080001D
    [13-55-19-868]0x60800023
    [13-55-19-868]0x6000001D
    [13-55-19-868]0x63800000
    [13-55-19-868]0x62C00005
    [13-55-19-868]0x62C00006
    [13-55-19-868]0x64000000
    [13-55-19-868]0x6000001E
    [13-55-19-868]0x63900001
    [13-55-19-868]0x62D00005
    [13-55-19-868]0x64100001
    [13-55-19-868]0x6000001F
    [13-55-19-868]0x63900002
    [13-55-19-868]0x62D00006
    [13-55-19-868]0x64100002
    [13-55-19-868]0x60000020
    [13-55-19-868]0x63900003
    [13-55-19-868]0x62D00007
    [13-55-19-868]0x64100003
    [13-55-19-868]0x60000021
    [13-55-19-868]0x63900004
    [13-55-19-868]0x62D00008
    [13-55-19-869]0x64100004
    [13-55-19-869]0x60000022
    [13-55-19-869]0x63900005
    [13-55-19-869]0x62D00009
    [13-55-19-869]0x64100005
    [13-55-19-869]0x60800024
    [13-55-19-869]0x60800052
    [13-55-19-869]0x60000023
    [13-55-19-869]0x63800001
    [13-55-19-869]0x62C00007
    [13-55-19-869]0x64000001
    [13-55-19-869]0x60000024
    [13-55-19-869]0x63900006
    [13-55-19-869]0x62D0000A
    [13-55-19-869]0x64100006
    [13-55-19-869]0x60000025
    [13-55-19-869]0x63800002
    [13-55-19-869]0x62C00008
    [13-55-19-869]0x64000002
    [13-55-19-869]0x6000002A
    [13-55-19-869]0x63934000
    [13-55-19-869]0x62D0000B
    [13-55-19-874]0x62D0000C
    [13-55-19-874]0x64134000
    [13-55-20-198]0x60800128
    [13-55-20-198]0x6080013E
    [13-55-20-198]0x608001E2
    [13-55-20-198]0x608001E3
    [13-55-20-198]0x608001E4
    [13-55-20-198]0x6080000D
    [13-55-20-198]0x608000E3
    [13-55-20-198]0x6000002B
    [13-55-20-198]0x63900007
    [13-55-20-198]0x62D0000D
    [13-55-20-198]0x64100007
    [13-55-20-198]0x6080013B
    [13-55-20-198]0x6080013C
    [13-55-20-198]0x6080013D
    [13-55-20-198]0x608001E5
    [13-55-20-198]0x608001E6
    [13-55-20-198]0x608001E7
    [13-55-20-198]0x608001E8
    [13-55-20-198]0x6080012A
    [13-55-20-198]0x60800140
    [13-55-20-198]0x6000002C
    [13-55-20-198]0x63900008
    [13-55-20-198]0x62D0000E
    [13-55-20-198]0x64100008
    [13-55-20-198]0x60800141
    [13-55-20-198]0x60800142
    [13-55-20-198]0x608001EC
    [13-55-20-198]0x60800131
    [13-55-20-198]0x60800139
    [13-55-20-198]0x608001E9
    [13-55-20-198]0x608001EA
    [13-55-20-198]0x608001ED
    [13-55-20-198]0x6000002D
    [13-55-20-198]0x63900009
    [13-55-20-198]0x62D0000F
    [13-55-20-198]0x64100009
    [13-55-20-198]0x60800220
    [13-55-20-198]0x608001DB
    [13-55-20-198]0x608001DC
    [13-55-20-198]0x608001D1
    [13-55-20-198]0x608001D3
    [13-55-20-198]0x6000002E
    [13-55-20-198]0x6390000A
    [13-55-20-198]0x62D00010
    [13-55-20-198]0x6410000A
    [13-55-20-198]0x608001E1
    [13-55-20-198]0x608001CF
    [13-55-20-198]0x608001D0
    [13-55-20-198]0x608001DD
    [13-55-20-199]0x608001DE
    [13-55-20-199]0x608001D4
    [13-55-20-199]0x6000002F
    [13-55-20-199]0x6390000B
    [13-55-20-199]0x62D00011
    [13-55-20-199]0x6410000B
    [13-55-20-199]0x608001D8
    [13-55-20-199]0x608001D6
    [13-55-20-199]0x608001D9
    [13-55-20-199]0x608001DA
    [13-55-20-200]0x6080008F
    [13-55-20-200]0x60800115
    [13-55-20-200]0x60000030
    [13-55-20-200]0x6390000C
    [13-55-20-200]0x62D00012
    [13-55-20-200]0x6410000C
    [13-55-20-200]0x608000AF
    [13-55-20-200]0x608000AE
    [13-55-20-200]0x608000B3
    [13-55-20-200]0x608000B2
    [13-55-20-200]0x608000B7
    [13-55-20-200]0x608000B6
    [13-55-20-200]0x608000BB
    [13-55-20-200]0x608000BA
    [13-55-20-200]0x60000031
    [13-55-20-200]0x6390000D
    [13-55-20-200]0x62D00013
    [13-55-20-200]0x6410000D
    [13-55-20-200]0x60800089
    [13-55-20-200]0x6080008A
    [13-55-20-200]0x608001DF
    [13-55-20-200]0x608000D0
    [13-55-20-200]0x6080013A
    [13-55-20-200]0x6080000E
    [13-55-20-200]0x60000032
    [13-55-20-200]0x6390000E
    [13-55-20-200]0x62D00014
    [13-55-20-200]0x6410000E
    [13-55-20-200]0x60800011
    [13-55-20-200]0x60800066
    [13-55-20-200]0x60800068
    [13-55-20-200]0x608001EE
    [13-55-20-200]0x608001EF
    [13-55-20-200]0x60000033
    [13-55-20-200]0x6390000F
    [13-55-20-200]0x62D00015
    [13-55-20-200]0x6410000F
    [13-55-20-200]0x608001F0
    [13-55-20-200]0x608001F1
    [13-55-20-200]0x608000C5
    [13-55-20-200]0x60800114
    [13-55-20-200]0x608000C4
    [13-55-20-200]0x60800221
    [13-55-20-200]0x60800222
    [13-55-20-200]0x60000034
    [13-55-20-200]0x63900010
    [13-55-20-200]0x62D00016
    [13-55-20-200]0x64100010
    [13-55-20-200]0x60800041
    [13-55-20-200]0x60800042
    [13-55-20-200]0x60800043
    [13-55-20-200]0x60800044
    [13-55-20-200]0x60800045
    [13-55-20-200]0x60000035
    [13-55-20-201]0x63800003
    [13-55-20-201]0x62C00009
    [13-55-20-201]0x64000003
    [13-55-20-201]0x60800047
    [13-55-20-201]0x60800048
    [13-55-20-202]0x60800049
    [13-55-20-202]0x6080004A
    [13-55-20-202]0x6080002D
    [13-55-20-202]0x60800019
    [13-55-20-202]0x60000036
    [13-55-20-202]0x63800004
    [13-55-20-202]0x62C0000A
    [13-55-20-202]0x64000004
    [13-55-20-202]0x6080013F
    [13-55-20-202]0x6080001B
    [13-55-20-202]0x60000037
    [13-55-20-202]0x63800005
    [13-55-20-202]0x62C0000B
    [13-55-20-202]0x64000005
    [13-55-20-202]0x608000D6
    [13-55-20-202]0x608001EB
    [13-55-20-202]0x608000CF
    [13-55-20-202]0x60000039
    [13-55-20-202]0x63934001
    [13-55-20-202]0x62D00017
    [13-55-20-202]0x64134001
    [13-55-20-202]0x608001FD
    [13-55-20-202]0x6000003D
    [13-55-20-202]0x63924000
    [13-55-20-202]0x63928000
    [13-55-20-202]0x64128000
    [13-55-20-202]0x62D00018
    [13-55-20-202]0x62D00019
    [13-55-20-202]0x62D0001A
    [13-55-20-202]0x64124000
    [13-55-20-202]0x608000D7
    [13-55-20-202]0x60800226
    [13-55-20-202]0x6000003F
    [13-55-20-202]0x63918000
    [13-55-20-202]0x63958000
    [13-55-20-202]0x64158000
    [13-55-20-202]0x62D0001B
    [13-55-20-202]0x62D2C001
    [13-55-20-202]0x62D2C002
    [13-55-20-202]0x64118000
    [13-55-20-202]0x60800227
    [13-55-20-202]0x60800244
    [13-55-20-202]0x60000040
    [13-55-20-202]0x6391C000
    [13-55-20-202]0x63958001
    [13-55-20-202]0x64158001
    [13-55-20-202]0x62D2C003
    [13-55-20-202]0x62D2C004
    [13-55-20-202]0x6411C000
    [13-55-20-202]0x608000DD
    [13-55-20-202]0x60800232
    [13-55-20-202]0x60000041
    [13-55-20-202]0x63920000
    [13-55-20-202]0x63958002
    [13-55-20-202]0x64158002
    [13-55-20-202]0x62D2C005
    [13-55-20-202]0x62D2C006
    [13-55-20-202]0x64120000
    [13-55-20-202]0x60800233
    [13-55-20-204]0x60800245
    [13-55-20-204]0x60000042
    [13-55-20-204]0x63924000
    [13-55-20-204]0x63958003
    [13-55-20-204]0x64158003
    [13-55-20-204]0x62D2C007
    [13-55-20-204]0x62D2C008
    [13-55-20-204]0x64124000
    [13-55-20-204]0x608000DE
    [13-55-20-204]0x60800234
    [13-55-20-204]0x60000043
    [13-55-20-204]0x63900011
    [13-55-20-204]0x62D0001C
    [13-55-20-204]0x64100011
    [13-55-20-204]0x60800235
    [13-55-20-204]0x60800246
    [13-55-20-204]0x60000044
    [13-55-20-204]0x63900012
    [13-55-20-204]0x62D0001D
    [13-55-20-204]0x64100012
    [13-55-20-204]0x608000DF
    [13-55-20-204]0x60800236
    [13-55-20-204]0x60000045
    [13-55-20-204]0x63900013
    [13-55-20-204]0x62D0001E
    [13-55-20-204]0x64100013
    [13-55-20-204]0x60800237
    [13-55-20-204]0x60800247
    [13-55-20-204]0x60000046
    [13-55-20-204]0x63900014
    [13-55-20-204]0x62D0001F
    [13-55-20-204]0x64100014
    [13-55-20-204]0x60800053
    [13-55-20-204]0x60800060
    [13-55-20-204]0x60000053
    [13-55-20-204]0x63800006
    [13-55-20-204]0x62C0000C
    [13-55-20-204]0x64000006
    [13-55-20-204]0x60800025
    [13-55-20-204]0x60800054
    [13-55-20-204]0x60000054
    [13-55-20-204]0x63800007
    [13-55-20-204]0x62C0000D
    [13-55-20-204]0x64000007
    [13-55-20-204]0x60800055
    [13-55-20-204]0x60800061
    [13-55-20-204]0x60000055
    [13-55-20-204]0x63800008
    [13-55-20-204]0x62C0000E
    [13-55-20-204]0x64000008
    [13-55-20-204]0x60800026
    [13-55-20-204]0x60800056
    [13-55-20-204]0x60000056
    [13-55-20-204]0x63800009
    [13-55-20-204]0x62C0000F
    [13-55-20-204]0x64000009
    [13-55-20-204]0x60800057
    [13-55-20-204]0x60800062
    [13-55-20-204]0x60000057
    [13-55-20-205]0x6380000A
    [13-55-20-205]0x62C00010
    [13-55-20-205]0x6400000A
    [13-55-20-205]0x60800027
    [13-55-20-205]0x60800058
    [13-55-20-205]0x60000058
    [13-55-20-205]0x6380000B
    [13-55-20-205]0x62C00011
    [13-55-20-206]0x6400000B
    [13-55-20-206]0x60800059
    [13-55-20-206]0x60800063
    [13-55-20-206]0x60000059
    [13-55-20-206]0x6380000C
    [13-55-20-206]0x62C00012
    [13-55-20-206]0x6400000C
    [13-55-20-206]0x60800028
    [13-55-20-207]0x6080005A
    [13-55-20-207]0x6000005A
    [13-55-20-207]0x6380000D
    [13-55-20-207]0x62C00013
    [13-55-20-207]0x6400000D
    [13-55-20-207]0x6080005B
    [13-55-20-207]0x60800064
    [13-55-20-207]0x6000005B
    [13-55-20-207]0x6380000E
    [13-55-20-207]0x62C00014
    [13-55-20-207]0x6400000E
    [13-55-20-207]0x608001FB
    [13-55-20-207]0x60000062
    [13-55-20-207]0x63964000
    [13-55-20-207]0x63930000
    [13-55-20-207]0x64130000
    [13-55-20-207]0x62D00020
    [13-55-20-207]0x62D00021
    [13-55-20-207]0x62D00022
    [13-55-20-207]0x64164000
    [13-55-20-207]0x60000067
    [13-55-20-207]0x63900015
    [13-55-20-207]0x62D00023
    [13-55-20-208]0x64100015
    [13-55-20-208]0x60000068
    [13-55-20-208]0x6380000F
    [13-55-20-208]0x62C00015
    [13-55-20-208]0x6400000F
    [13-55-20-208]0x60000069
    [13-55-20-208]0x63800010
    [13-55-20-208]0x62C00016
    [13-55-20-208]0x64000010
    [13-55-20-208]0x6000006A
    [13-55-20-208]0x6000006B
    [13-55-20-208]0x63800011
    [13-55-20-208]0x62C00017
    [13-55-20-208]0x64000011
    [13-55-20-208]0x60800029
    [13-55-20-208]0x6080002A
    [13-55-20-208]0x6000006C
    [13-55-20-208]0x63830000
    [13-55-20-208]0x62C00018
    [13-55-20-208]0x62C00019
    [13-55-20-210]0x64030000
    [13-55-20-210]0x60800018
    [13-55-20-210]0x60800031
    [13-55-20-210]0x6080002B
    [13-55-20-210]0x6080004B
    [13-55-20-210]0x6000006D
    [13-55-20-210]0x63828000
    [13-55-20-210]0x62C0001A
    [13-55-20-210]0x62C0001B
    [13-55-20-212]0x64028000
    [13-55-20-539]0x6080001A
    [13-55-20-539]0x60800032
    [13-55-20-539]0x6080002C
    [13-55-20-539]0x6080004C
    [13-55-20-539]0x6000006E
    [13-55-20-539]0x6382C000
    [13-55-20-539]0x62C0001C
    [13-55-20-539]0x62C0001D
    [13-55-20-539]0x6402C000
    [13-55-20-539]0x6000006F
    [13-55-20-539]0x63900016
    [13-55-20-539]0x62D00024
    [13-55-20-539]0x64100016
    [13-55-20-539]0x60000070
    [13-55-20-539]0x63924001
    [13-55-20-539]0x62D00025
    [13-55-20-539]0x64124001
    [13-55-20-539]0x60000071
    [13-55-20-539]0x63924002
    [13-55-20-539]0x62D00026
    [13-55-20-539]0x64124002
    [13-55-20-539]0x60000072
    [13-55-20-539]0x63924003
    [13-55-20-539]0x62D00027
    [13-55-20-539]0x64124003
    [13-55-20-539]0x6080003B
    [13-55-20-539]0x60000073
    [13-55-20-539]0x6380C000
    [13-55-20-539]0x62C0001E
    [13-55-20-539]0x62C0001F
    [13-55-20-539]0x6400C000
    [13-55-20-539]0x60000074
    [13-55-20-539]0x6380C001
    [13-55-20-539]0x62C00020
    [13-55-20-539]0x6400C001
    [13-55-20-539]0x6080009B
    [13-55-20-539]0x60000078
    [13-55-20-539]0x60000079
    [13-55-20-539]0x63924004
    [13-55-20-539]0x62D00028
    [13-55-20-539]0x64124004
    [13-55-20-539]0x6000007A
    [13-55-20-539]0x63924005
    [13-55-20-539]0x62D00029
    [13-55-20-539]0x64124005
    [13-55-20-539]0x6000007B
    [13-55-20-539]0x6000007C
    [13-55-20-539]0x63924006
    [13-55-20-539]0x62D0002A
    [13-55-20-539]0x64124006
    [13-55-20-539]0x6000007D
    [13-55-20-540]0x63800012
    [13-55-20-540]0x62C00021
    [13-55-20-540]0x64000012
    [13-55-20-540]0x6000007E
    [13-55-20-540]0x63800013
    [13-55-20-540]0x64000013
    [13-55-20-540]0x63804001
    [13-55-20-540]0x64004001
    [13-55-20-541]0x63808000
    [13-55-20-541]0x64008000
    [13-55-20-541]0x62C00022
    [13-55-20-541]0x6380C002
    [13-55-20-541]0x6400C002
    [13-55-20-541]0x63810000
    [13-55-20-541]0x64010000
    [13-55-20-541]0x62C00023
    [13-55-20-541]0x63814000
    [13-55-20-541]0x64014000
    [13-55-20-541]0x62C00024
    [13-55-20-541]0x63818000
    [13-55-20-541]0x64018000
    [13-55-20-541]0x62C00025
    [13-55-20-541]0x6381C000
    [13-55-20-541]0x6401C000
    [13-55-20-541]0x62C00026
    [13-55-20-541]0x63820000
    [13-55-20-541]0x64020000
    [13-55-20-541]0x62C00027
    [13-55-20-541]0x63824000
    [13-55-20-541]0x64024000
    [13-55-20-541]0x62C00028
    [13-55-20-541]0x63828001
    [13-55-20-541]0x64028001
    [13-55-20-541]0x6382C001
    [13-55-20-541]0x6402C001
    [13-55-20-541]0x63830001
    [13-55-20-541]0x64030001
    [13-55-20-541]0x6384C000
    [13-55-20-541]0x6404C000
    [13-55-20-541]0x62C04001
    [13-55-20-541]0x63850000
    [13-55-20-541]0x64050000
    [13-55-20-541]0x62C04002
    [13-55-20-541]0x63854000
    [13-55-20-541]0x64054000
    [13-55-20-541]0x63850001
    [13-55-20-541]0x64050001
    [13-55-20-541]0x62C04003
    [13-55-20-541]0x63000029
    [13-55-20-541]0x63004004
    [13-55-20-541]0x6000007F
    [13-55-20-541]0x60000083
    [13-55-20-541]0x60000084
    [13-55-20-541]0x60000085
    [13-55-20-541]0x60000086
    [13-55-20-541]0x60000087
    [13-55-20-541]0x60000088
    [13-55-20-541]0x60000089
    [13-55-20-541]0x63934002
    [13-55-20-541]0x62D0002B
    [13-55-20-541]0x64134002
    [13-55-20-541]0x6000008C
    [13-55-20-541]0x6000008D
    [13-55-20-541]0x6000008E
    [13-55-20-541]0x6000008F
    [13-55-20-541]0x63900017
    [13-55-20-541]0x64100017
    [13-55-20-542]0x63904000
    [13-55-20-542]0x64104000
    [13-55-20-542]0x63928001
    [13-55-20-542]0x64128001
    [13-55-20-542]0x62D0002C
    [13-55-20-542]0x63908000
    [13-55-20-542]0x64108000
    [13-55-20-542]0x62D0002D
    [13-55-20-542]0x6390C000
    [13-55-20-542]0x6410C000
    [13-55-20-542]0x63958004
    [13-55-20-542]0x64158004
    [13-55-20-542]0x62D0002E
    [13-55-20-542]0x63914000
    [13-55-20-542]0x64114000
    [13-55-20-542]0x62D0002F
    [13-55-20-542]0x63924007
    [13-55-20-542]0x64124007
    [13-55-20-542]0x63928002
    [13-55-20-542]0x64128002
    [13-55-20-542]0x63930001
    [13-55-20-542]0x64130001
    [13-55-20-542]0x63934003
    [13-55-20-542]0x64134003
    [13-55-20-542]0x63948000
    [13-55-20-542]0x64148000
    [13-55-20-542]0x62D00030
    [13-55-20-542]0x63958005
    [13-55-20-542]0x64158005
    [13-55-20-542]0x63960001
    [13-55-20-542]0x64160001
    [13-55-20-542]0x63964001
    [13-55-20-542]0x64164001
    [13-55-20-542]0x6396C000
    [13-55-20-542]0x6416C000
    [13-55-20-542]0x62D00031
    [13-55-20-542]0x63984000
    [13-55-20-542]0x64184000
    [13-55-20-542]0x62D00032
    [13-55-20-542]0x639A0001
    [13-55-20-542]0x641A0001
    [13-55-20-542]0x63918001
    [13-55-20-542]0x64118001
    [13-55-20-542]0x6391C001
    [13-55-20-542]0x6411C001
    [13-55-20-542]0x63920001
    [13-55-20-542]0x64120001
    [13-55-20-542]0x63924001
    [13-55-20-542]0x64124001
    [13-55-20-542]0x63100033
    [13-55-20-542]0x63104003
    [13-55-20-542]0x63108001
    [13-55-20-542]0x6310C001
    [13-55-20-542]0x63110001
    [13-55-20-542]0x63114001
    [13-55-20-542]0x63118001
    [13-55-20-542]0x6311C001
    [13-55-20-542]0x63120001
    [13-55-20-542]0x63124001
    [13-55-20-543]0x63128001
    [13-55-20-543]0x6312C009
    [13-55-20-543]0x63190001
    [13-55-20-543]0x63194001
    [13-55-20-543]0x63198001
    [13-55-20-543]0x60000090
    [13-55-20-543]0x60000091
    [13-55-20-544]0x60800030
    [13-55-20-544]0x60000093
    [13-55-20-544]0x60000094
    [13-55-20-544]0x63924008
    [13-55-20-544]0x62D00032
    [13-55-20-544]0x64124008
    [13-55-20-544]0x6080005C
    [13-55-20-544]0x60000095
    [13-55-20-544]0x63800014
    [13-55-20-544]0x62C00028
    [13-55-20-544]0x64000014
    [13-55-20-544]0x60000096
    [13-55-20-544]0x63924009
    [13-55-20-544]0x62D00033
    [13-55-20-544]0x64124009
    [13-55-20-544]0x60000097
    [13-55-20-544]0x63800015
    [13-55-20-544]0x62C00029
    [13-55-20-544]0x64000015
    [13-55-20-544]0x60800154
    [13-55-20-544]0x60800098
    [13-55-20-544]0x6080008C
    [13-55-20-544]0x6080014D
    [13-55-20-544]0x608000A5
    [13-55-20-544]0x608000A4
    [13-55-20-544]0x608000E1
    [13-55-20-544]0x60800083
    [13-55-20-544]0x60800116
    [13-55-20-544]0x608001B5
    [13-55-20-544]0x60800117
    [13-55-20-544]0x608000CE
    [13-55-20-544]0x60800010
    [13-55-20-544]0x6080010A
    [13-55-20-544]0x60800091
    [13-55-20-544]0x6080010B
    [13-55-20-544]0x60800090
    [13-55-20-544]0x608000FF
    [13-55-20-544]0x60800039
    [13-55-20-544]0x608000AD
    [13-55-20-544]0x6080009A
    [13-55-20-544]0x6080001E
    [13-55-20-544]0x60800223
    [13-55-20-544]0x60800249
    [13-55-20-544]0x608000B8
    [13-55-20-544]0x6080008D
    [13-55-20-544]0x6080021F
    [13-55-20-544]0x60800038
    [13-55-20-544]0x608000B0
    [13-55-20-544]0x6080008E
    [13-55-20-544]0x608000CC
    [13-55-20-544]0x608000C8
    [13-55-20-544]0x608000CD
    [13-55-20-546]0x60800118
    [13-55-20-546]0x6080015A
    [13-55-20-546]0x6080009C
    [13-55-20-546]0x608000A1
    [13-55-20-546]0x60800012
    [13-55-20-546]0x60800149
    [13-55-20-546]0x608000BD
    [13-55-20-546]0x6080001F
    [13-55-20-546]0x6080015F
    [13-55-20-546]0x608000C7
    [13-55-20-546]0x608000FE
    [13-55-20-546]0x608000B5
    [13-55-20-546]0x608000C9
    [13-55-20-546]0x6080011A
    [13-55-20-546]0x60800033
    [13-55-20-546]0x6080014F
    [13-55-20-546]0x6080023A
    [13-55-20-546]0x608000C2
    [13-55-20-546]0x60800020
    [13-55-20-546]0x60800095
    [13-55-20-546]0x60800146
    [13-55-20-546]0x608000A0
    [13-55-20-546]0x60800035
    [13-55-20-546]0x60800159
    [13-55-20-547]0x60800013
    [13-55-20-547]0x608000F8
    [13-55-20-547]0x608000B1
    [13-55-20-547]0x60800015
    [13-55-20-547]0x608000F9
    [13-55-20-547]0x608000A7
    [13-55-20-547]0x608000A8
    [13-55-20-547]0x608000BF
    [13-55-20-547]0x608000BC
    [13-55-20-547]0x608000AB
    [13-55-20-547]0x60800110
    [13-55-20-547]0x60800119
    [13-55-20-547]0x60800144
    [13-55-20-547]0x60800092
    [13-55-20-547]0x608000B9
    [13-55-20-547]0x608000A2
    [13-55-20-547]0x60800143
    [13-55-20-547]0x6080009F
    [13-55-20-547]0x60800104
    [13-55-20-547]0x60800082
    [13-55-20-547]0x6080008B
    [13-55-20-548]0x60800016
    [13-55-20-548]0x608000C0
    [13-55-20-548]0x608000BE
    [13-55-20-548]0x6080009E
    [13-55-20-548]0x6080011C
    [13-55-20-548]0x60800034
    [13-55-20-548]0x60800094
    [13-55-20-548]0x608000AA
    [13-55-20-548]0x6080002E
    [13-55-20-548]0x608000C3
    [13-55-20-548]0x6080000F
    [13-55-20-548]0x60800099
    [13-55-20-548]0x608000A3
    [13-55-20-548]0x60800111
    [13-55-20-551]0x608000E2
    [13-55-20-551]0x6080011D
    [13-55-20-551]0x6080011B
    [13-55-20-551]0x6080015E
    [13-55-20-551]0x608000A6
    [13-55-20-551]0x60800105
    [13-55-20-551]0x608000CA
    [13-55-20-551]0x6080014C
    [13-55-20-551]0x608000CB
    [13-55-20-552]0x608000B4
    [13-55-20-882]0x60800096
    [13-55-20-882]0x6080009D
    [13-55-20-882]0x608000A9
    [13-55-20-882]0x60800014
    [13-55-20-882]0x60800017
    [13-55-20-882]0x6080023B
    [13-55-20-882]0x60800093
    [13-55-20-882]0x60800148
    [13-55-20-882]0x60800097
    [13-55-20-882]0x608000AC
    [13-55-20-882]0x608000C6
    [13-55-20-882]0x60800155
    [13-55-20-882]0x6080014A
    [13-55-20-882]0x608000D5
    [13-55-20-882]0x6080014E
    [13-55-20-882]0x608000D4
    [13-55-20-882]0x60800145
    [13-55-20-882]0x608000C1
    [13-55-20-882]0x608001F7
    [13-55-20-882]0x6000009D
    [13-55-20-883]0x600000AA
    [13-55-20-883]0x63908001
    [13-55-20-883]0x62D00034
    [13-55-20-883]0x64108001
    [13-55-20-883]0x600000AB
    [13-55-20-883]0x63908002
    [13-55-20-883]0x62D00035
    [13-55-20-883]0x64108002
    [13-55-20-883]0x600000AC
    [13-55-20-883]0x63908003
    [13-55-20-883]0x62D00036
    [13-55-20-883]0x64108003
    [13-55-20-883]0x600000AD
    [13-55-20-883]0x63908004
    [13-55-20-883]0x62D00037
    [13-55-20-883]0x64108004
    [13-55-20-883]0x600000B0
    [13-55-20-883]0x63818001
    [13-55-20-883]0x62C0002A
    [13-55-20-883]0x64018001
    [13-55-20-883]0x600000B1
    [13-55-20-883]0x63818002
    [13-55-20-883]0x62C0002B
    [13-55-20-883]0x64018002
    [13-55-20-883]0x600000B2
    [13-55-20-883]0x63854001
    [13-55-20-883]0x62C04003
    [13-55-20-883]0x64054001
    [13-55-20-883]0x600000B4
    [13-55-20-883]0x63800016
    [13-55-20-883]0x62C0002C
    [13-55-20-883]0x64000016
    [13-55-20-883]0x600000B5
    [13-55-20-883]0x63814001
    [13-55-20-883]0x62C0002D
    [13-55-20-883]0x64014001
    [13-55-20-883]0x60800050
    [13-55-20-883]0x600000CF
    [13-55-20-883]0x63820001
    [13-55-20-884]0x62C0002E
    [13-55-20-884]0x64020001
    [13-55-20-884]0x60800051
    [13-55-20-884]0x600000D0
    [13-55-20-884]0x63824001
    [13-55-20-884]0x62C0002F
    [13-55-20-884]0x64024001
    [13-55-20-884]0x6080023C
    [13-55-20-884]0x608000FB
    [13-55-20-884]0x608000FC
    [13-55-20-884]0x608000EE
    [13-55-20-884]0x608000FA
    [13-55-20-884]0x608000FD
    [13-55-20-884]0x608000F3
    [13-55-20-884]0x600000D1
    [13-55-20-884]0x6390C001
    [13-55-20-884]0x62D00038
    [13-55-20-884]0x6410C001
    [13-55-20-884]0x6080023D
    [13-55-20-884]0x60800101
    [13-55-20-884]0x60800102
    [13-55-20-884]0x608000EF
    [13-55-20-884]0x60800100
    [13-55-20-884]0x60800103
    [13-55-20-884]0x608000F4
    [13-55-20-884]0x600000D2
    [13-55-20-884]0x6390C002
    [13-55-20-884]0x62D00039
    [13-55-20-885]0x6410C002
    [13-55-20-885]0x6080023E
    [13-55-20-885]0x60800107
    [13-55-20-885]0x60800108
    [13-55-20-885]0x608000F0
    [13-55-20-885]0x60800106
    [13-55-20-885]0x60800109
    [13-55-20-885]0x608000F5
    [13-55-20-885]0x600000D3
    [13-55-20-885]0x6390C003
    [13-55-20-885]0x62D0003A
    [13-55-20-885]0x6410C003
    [13-55-20-885]0x6080023F
    [13-55-20-885]0x6080010D
    [13-55-20-885]0x6080010E
    [13-55-20-885]0x608000F1
    [13-55-20-885]0x6080010C
    [13-55-20-885]0x6080010F
    [13-55-20-885]0x608000F6
    [13-55-20-885]0x600000D4
    [13-55-20-885]0x6390C004
    [13-55-20-885]0x62D0003B
    [13-55-20-885]0x6410C004
    [13-55-20-885]0x60800240
    [13-55-20-885]0x60800113
    [13-55-20-885]0x608000F2
    [13-55-20-885]0x60800112
    [13-55-20-885]0x608000F7
    [13-55-20-885]0x600000D5
    [13-55-20-885]0x6390C005
    [13-55-20-885]0x62D0003C
    [13-55-20-886]0x6410C005
    [13-55-20-886]0x600000DD
    [13-55-20-886]0x63800017
    [13-55-20-886]0x62C00030
    [13-55-20-886]0x64000017
    [13-55-20-886]0x600000DE
    [13-55-20-886]0x63800018
    [13-55-20-886]0x62C00031
    [13-55-20-886]0x64000018
    [13-55-20-886]0x6080005D
    [13-55-20-886]0x600000DF
    [13-55-20-886]0x6380C003
    [13-55-20-886]0x62C00032
    [13-55-20-886]0x6400C003
    [13-55-20-886]0x6080011E
    [13-55-20-886]0x6080011F
    [13-55-20-886]0x600000E0
    [13-55-20-886]0x63914001
    [13-55-20-886]0x62D0003D
    [13-55-20-886]0x64114001
    [13-55-20-886]0x600000E1
    [13-55-20-886]0x63900018
    [13-55-20-886]0x62D0003E
    [13-55-20-886]0x64100018
    [13-55-20-886]0x60800120
    [13-55-20-886]0x60800121
    [13-55-20-886]0x60800211
    [13-55-20-886]0x600000E2
    [13-55-20-886]0x63900019
    [13-55-20-886]0x62D0003F
    [13-55-20-886]0x64100019
    [13-55-20-886]0x600000E3
    [13-55-20-886]0x6390001A
    [13-55-20-886]0x62D00040
    [13-55-20-886]0x6410001A
    [13-55-20-886]0x600000E4
    [13-55-20-886]0x6390001B
    [13-55-20-886]0x62D00041
    [13-55-20-886]0x6410001B
    [13-55-20-886]0x600000E5
    [13-55-20-887]0x6390001C
    [13-55-20-887]0x62D00042
    [13-55-20-887]0x6410001C
    [13-55-20-887]0x600000E6
    [13-55-20-887]0x6390001D
    [13-55-20-887]0x62D00043
    [13-55-20-887]0x6410001D
    [13-55-20-887]0x600000E7
    [13-55-20-887]0x6390001E
    [13-55-20-887]0x62D00044
    [13-55-20-887]0x6410001E
    [13-55-20-887]0x600000E8
    [13-55-20-887]0x6390001F
    [13-55-20-887]0x62D00045
    [13-55-20-887]0x6410001F
    [13-55-20-887]0x600000E9
    [13-55-20-887]0x63900020
    [13-55-20-887]0x62D00046
    [13-55-20-887]0x64100020
    [13-55-20-888]0x600000EA
    [13-55-20-888]0x63900021
    [13-55-20-888]0x62D00047
    [13-55-20-888]0x64100021
    [13-55-20-888]0x600000EB
    [13-55-20-888]0x63900022
    [13-55-20-888]0x62D00048
    [13-55-20-888]0x64100022
    [13-55-20-888]0x600000EC
    [13-55-20-888]0x63900023
    [13-55-20-888]0x62D00049
    [13-55-20-888]0x64100023
    [13-55-20-888]0x600000ED
    [13-55-20-888]0x63900024
    [13-55-20-888]0x62D0004A
    [13-55-20-888]0x64100024
    [13-55-20-888]0x600000EE
    [13-55-20-888]0x63900025
    [13-55-20-888]0x62D0004B
    [13-55-20-888]0x64100025
    [13-55-20-888]0x600000EF
    [13-55-20-888]0x63900026
    [13-55-20-888]0x62D0004C
    [13-55-20-888]0x64100026
    [13-55-20-888]0x600000F0
    [13-55-20-888]0x63900027
    [13-55-20-888]0x62D0004D
    [13-55-20-888]0x64100027
    [13-55-20-888]0x600000F1
    [13-55-20-888]0x63900028
    [13-55-20-888]0x62D0004E
    [13-55-20-888]0x64100028
    [13-55-20-888]0x600000F2
    [13-55-20-888]0x63900029
    [13-55-20-888]0x62D0004F
    [13-55-20-888]0x64100029
    [13-55-20-888]0x600000F3
    [13-55-20-888]0x6390002A
    [13-55-20-888]0x62D00050
    [13-55-20-888]0x6410002A
    [13-55-20-888]0x600000F4
    [13-55-20-888]0x6390002B
    [13-55-20-888]0x62D00051
    [13-55-20-888]0x6410002B
    [13-55-20-888]0x600000F5
    [13-55-20-888]0x6390002C
    [13-55-20-888]0x62D00052
    [13-55-20-888]0x6410002C
    [13-55-20-888]0x600000F6
    [13-55-20-888]0x6390002D
    [13-55-20-888]0x62D00053
    [13-55-20-888]0x6410002D
    [13-55-20-888]0x600000F7
    [13-55-20-888]0x6390002E
    [13-55-20-888]0x62D00054
    [13-55-20-888]0x6410002E
    [13-55-20-888]0x600000F8
    [13-55-20-888]0x6390002F
    [13-55-20-888]0x62D00055
    [13-55-20-890]0x6410002F
    [13-55-20-890]0x600000F9
    [13-55-20-890]0x63900030
    [13-55-20-890]0x62D00056
    [13-55-20-890]0x64100030
    [13-55-20-890]0x600000FA
    [13-55-20-890]0x63900031
    [13-55-20-890]0x62D00057
    [13-55-20-890]0x64100031
    [13-55-20-890]0x600000FB
    [13-55-20-890]0x63900032
    [13-55-20-890]0x62D00058
    [13-55-20-890]0x64100032
    [13-55-20-890]0x600000FC
    [13-55-20-890]0x63900033
    [13-55-20-890]0x62D00059
    [13-55-20-890]0x64100033
    [13-55-20-890]0x600000FD
    [13-55-20-890]0x63900034
    [13-55-20-890]0x62D0005A
    [13-55-20-890]0x64100034
    [13-55-20-890]0x600000FE
    [13-55-20-890]0x63900035
    [13-55-20-890]0x62D0005B
    [13-55-20-890]0x64100035
    [13-55-20-891]0x600000FF
    [13-55-20-891]0x63900036
    [13-55-20-891]0x62D0005C
    [13-55-20-891]0x64100036
    [13-55-20-891]0x60000100
    [13-55-20-891]0x63900037
    [13-55-20-891]0x62D0005D
    [13-55-20-891]0x64100037
    [13-55-20-891]0x60000101
    [13-55-20-891]0x63900038
    [13-55-20-891]0x62D0005E
    [13-55-20-891]0x64100038
    [13-55-20-891]0x60000102
    [13-55-20-891]0x63900039
    [13-55-20-891]0x62D0005F
    [13-55-20-891]0x64100039
    [13-55-20-891]0x60000103
    [13-55-20-891]0x6390003A
    [13-55-20-891]0x62D00060
    [13-55-20-891]0x6410003A
    [13-55-20-891]0x60000104
    [13-55-20-891]0x6390003B
    [13-55-20-891]0x62D00061
    [13-55-20-891]0x6410003B
    [13-55-20-891]0x60000105
    [13-55-20-891]0x6390003C
    [13-55-20-891]0x62D00062
    [13-55-20-892]0x6410003C
    [13-55-20-892]0x60000106
    [13-55-20-892]0x6390003D
    [13-55-20-892]0x62D00063
    [13-55-20-892]0x6410003D
    [13-55-20-892]0x60000107
    [13-55-20-892]0x6390003E
    [13-55-20-894]0x62D00064
    [13-55-20-894]0x6410003E
    [13-55-20-894]0x60000108
    [13-55-20-894]0x6390003F
    [13-55-20-894]0x62D00065
    [13-55-20-894]0x6410003F
    [13-55-20-894]0x60000109
    [13-55-20-894]0x63900040
    [13-55-20-894]0x62D00066
    [13-55-20-906]0x64100040
    [13-55-21-226]0x6000010A
    [13-55-21-226]0x63900041
    [13-55-21-226]0x62D00067
    [13-55-21-226]0x64100041
    [13-55-21-226]0x6000010B
    [13-55-21-226]0x6000010C
    [13-55-21-226]0x63800019
    [13-55-21-226]0x62C00033
    [13-55-21-226]0x64000019
    [13-55-21-226]0x6000010D
    [13-55-21-226]0x6380001A
    [13-55-21-226]0x62C00034
    [13-55-21-226]0x6400001A
    [13-55-21-226]0x6000010E
    [13-55-21-226]0x6380001B
    [13-55-21-226]0x62C00035
    [13-55-21-226]0x6400001B
    [13-55-21-226]0x6000010F
    [13-55-21-226]0x6380001C
    [13-55-21-226]0x62C00036
    [13-55-21-226]0x6400001C
    [13-55-21-226]0x60000110
    [13-55-21-226]0x6380001D
    [13-55-21-226]0x62C00037
    [13-55-21-226]0x6400001D
    [13-55-21-226]0x60000111
    [13-55-21-226]0x6380001E
    [13-55-21-226]0x62C00038
    [13-55-21-226]0x6400001E
    [13-55-21-226]0x60000112
    [13-55-21-226]0x6380001F
    [13-55-21-226]0x62C00039
    [13-55-21-226]0x6400001F
    [13-55-21-226]0x60000113
    [13-55-21-226]0x63800020
    [13-55-21-226]0x62C0003A
    [13-55-21-226]0x64000020
    [13-55-21-226]0x60000115
    [13-55-21-226]0x60000116
    [13-55-21-226]0x6000011B
    [13-55-21-226]0x60800009
    [13-55-21-226]0x6080000B
    [13-55-21-226]0x6000011C
    [13-55-21-226]0x6384C001
    [13-55-21-226]0x62C04004
    [13-55-21-226]0x6404C001
    [13-55-21-226]0x6080000A
    [13-55-21-226]0x6080000C
    [13-55-21-226]0x6000011D
    [13-55-21-226]0x63850002
    [13-55-21-226]0x62C04005
    [13-55-21-226]0x64050002
    [13-55-21-226]0x6080003F
    [13-55-21-226]0x60000127
    [13-55-21-226]0x6384C002
    [13-55-21-226]0x62C04006
    [13-55-21-226]0x6404C002
    [13-55-21-226]0x60800040
    [13-55-21-226]0x60000128
    [13-55-21-228]0x63850003
    [13-55-21-228]0x62C04007
    [13-55-21-228]0x64050003
    [13-55-21-228]0x60000130
    [13-55-21-228]0x6080003C
    [13-55-21-228]0x6000015B
    [13-55-21-228]0x63800021
    [13-55-21-228]0x62C0003B
    [13-55-21-228]0x64000021
    [13-55-21-228]0x6000015C
    [13-55-21-228]0x63800022
    [13-55-21-228]0x62C0003C
    [13-55-21-228]0x64000022
    [13-55-21-228]0x6080003A
    [13-55-21-228]0x6000015D
    [13-55-21-228]0x63800023
    [13-55-21-228]0x62C0003D
    [13-55-21-228]0x64000023
    [13-55-21-228]0x6080005E
    [13-55-21-228]0x6080005F
    [13-55-21-228]0x60000167
    [13-55-21-228]0x6380C004
    [13-55-21-228]0x62C0003E
    [13-55-21-228]0x6400C004
    [13-55-21-228]0x6000016E
    [13-55-21-228]0x63810001
    [13-55-21-228]0x62C0003F
    [13-55-21-228]0x64010001
    [13-55-21-228]0x6000016F
    [13-55-21-228]0x63948001
    [13-55-21-228]0x62D00068
    [13-55-21-228]0x64148001
    [13-55-21-228]0x60000170
    [13-55-21-228]0x63984001
    [13-55-21-228]0x62D00069
    [13-55-21-228]0x64184001
    [13-55-21-228]0x60000171
    [13-55-21-228]0x63930002
    [13-55-21-228]0x62D0006A
    [13-55-21-228]0x64130002
    [13-55-21-228]0x60000172
    [13-55-21-228]0x63928003
    [13-55-21-228]0x62D0006B
    [13-55-21-228]0x64128003
    [13-55-21-228]0x60000173
    [13-55-21-228]0x63958006
    [13-55-21-228]0x62D0006C
    [13-55-21-228]0x64158006
    [13-55-21-228]0x60000174
    [13-55-21-228]0x6396C001
    [13-55-21-228]0x62D0006D
    [13-55-21-228]0x6416C001
    [13-55-21-228]0x60000176
    [13-55-21-228]0x63D00042
    [13-55-21-228]0x64500042
    [13-55-21-228]0x63D04001
    [13-55-21-228]0x63D28004
    [13-55-21-228]0x64504001
    [13-55-21-228]0x6310006E
    [13-55-21-230]0x64528004
    [13-55-21-230]0x63D08005
    [13-55-21-230]0x64508005
    [13-55-21-230]0x63D0C006
    [13-55-21-230]0x6450C006
    [13-55-21-230]0x63D14002
    [13-55-21-230]0x64514002
    [13-55-21-230]0x63D2400A
    [13-55-21-230]0x6452400A
    [13-55-21-230]0x63D28003
    [13-55-21-230]0x64528003
    [13-55-21-230]0x63D30003
    [13-55-21-230]0x64530003
    [13-55-21-230]0x63D34004
    [13-55-21-230]0x64534004
    [13-55-21-230]0x63D48002
    [13-55-21-230]0x64548002
    [13-55-21-230]0x63D58007
    [13-55-21-230]0x64558007
    [13-55-21-230]0x63D60002
    [13-55-21-230]0x64560002
    [13-55-21-230]0x63D64002
    [13-55-21-230]0x64564002
    [13-55-21-230]0x63D6C002
    [13-55-21-230]0x6456C002
    [13-55-21-230]0x63D84002
    [13-55-21-230]0x64584002
    [13-55-21-230]0x63DA0002
    [13-55-21-230]0x645A0002
    [13-55-21-230]0x63D18002
    [13-55-21-230]0x64518002
    [13-55-21-230]0x63D1C002
    [13-55-21-230]0x6451C002
    [13-55-21-230]0x63D20002
    [13-55-21-230]0x64520002
    [13-55-21-230]0x63D24002
    [13-55-21-230]0x64524002
    [13-55-21-230]0x63C00024
    [13-55-21-230]0x64400024
    [13-55-21-230]0x63C04002
    [13-55-21-230]0x64404002
    [13-55-21-230]0x63C08001
    [13-55-21-230]0x64408001
    [13-55-21-230]0x63C0C005
    [13-55-21-230]0x6440C005
    [13-55-21-230]0x63C10002
    [13-55-21-230]0x64410002
    [13-55-21-230]0x63C14002
    [13-55-21-230]0x64414002
    [13-55-21-230]0x63C18003
    [13-55-21-230]0x64418003
    [13-55-21-230]0x63C1C001
    [13-55-21-230]0x6441C001
    [13-55-21-230]0x63C20002
    [13-55-21-230]0x64420002
    [13-55-21-230]0x63C24002
    [13-55-21-230]0x64424002
    [13-55-21-230]0x63C28002
    [13-55-21-230]0x64428002
    [13-55-21-237]0x63C2C002
    [13-55-21-237]0x6442C002
    [13-55-21-237]0x63C30002
    [13-55-21-237]0x64430002
    [13-55-21-237]0x63C4C003
    [13-55-21-237]0x6444C003
    [13-55-21-237]0x63C50004
    [13-55-21-237]0x64450004
    [13-55-21-237]0x63C54002
    [13-55-21-237]0x64454002
    [13-55-21-237]0x68400000
    [13-55-21-237]0x60400127
    [13-55-21-237]0x63C4C002
    [13-55-21-237]0x60C0003F
    [13-55-21-237]0x6444C002
    [13-55-21-237]0x63004008
    [13-55-21-237]0x61800200
    [13-55-21-237]0x61C00128
    [13-55-21-237]0x62000000
    [13-55-21-237]0x60400128
    [13-55-21-237]0x63C50003
    [13-55-21-237]0x60C00040
    [13-55-21-237]0x64450003
    [13-55-21-237]0x63004007
    [13-55-21-237]Initlialzing PLLs ...0x61800101
    [13-55-21-237]0x61C010CF
    [13-55-21-237]0x61800104
    [13-55-21-237]0x61800100
    [13-55-21-237]0x6180010D
    [13-55-21-237]0x61293043
    [13-55-21-237]0x6180010C
    [13-55-21-237]0x61800101
    [13-55-21-237]0x61C01095
    [13-55-21-237]0x61296C44
    [13-55-21-237]0x61C0146D
    [13-55-21-237]0x61800103
    [13-55-21-243]0x61C0146D
    [13-55-21-243]0x62000000
    [13-55-21-243]0x60C0004B
    [13-55-21-243]0x61800102
    [13-55-21-243]0x62000006
    [13-55-21-243]0x6180010D
    [13-55-21-243]0x6129FC45
    [13-55-21-243]0x6180010C
    [13-55-21-243]0x61800101
    [13-55-21-243]0x61C0146E
    [13-55-21-243]0x61800104
    [13-55-21-243]0x61800103
    [13-55-21-243]0x61800100
    [13-55-21-243]0x60C0004C
    [13-55-21-244]0x61C0146E
    [13-55-21-244]0x62000006
    [13-55-21-244]0x6180010D
    [13-55-21-244]0x6129FC45
    [13-55-21-244]0x6180010C
    [13-55-21-244]0x61800101
    [13-55-21-244]0x61C0841D
    [13-55-21-244]0x61800104
    [13-55-21-244]0x61800100
    [13-55-21-244]0x62000000
    [13-55-21-244]0x612BDC46
    [13-55-21-244]0x61C0481D
    [13-55-21-245]0x61C0481D
    [13-55-21-245]0x62000000
    [13-55-21-245]0x6180010D
    [13-55-21-245]0x612B7C47
    [13-55-21-245]0x6180010C
    [13-55-21-247]0x612B7C47
    [13-55-21-247]0x61800101
    [13-55-21-247]0x61C008CF
    [13-55-21-247]0x61800104
    [13-55-21-248]0x61800100
    [13-55-21-248]0x61C008CF
    [13-55-21-253]0x62000000
    [13-55-21-574]0x6180010D
    [13-55-21-574]0x61C008CF
    [13-55-21-574]0x61293049
    [13-55-21-574]0x6180010C
    [13-55-21-574]0x61800101
    [13-55-21-574]0x61C00862
    [13-55-21-574]0x61800104
    [13-55-21-574]0x61800100
    [13-55-21-574]0x62000000
    [13-55-21-574]0x612B7DE2
    [13-55-21-574]0x61C008B6
    [13-55-21-574]0x612931E4
    [13-55-21-574]0x61C00953
    [13-55-21-574]0x61277D3B
    [13-55-21-575]0x61800101
    [13-55-21-575]0x61C00C63
    [13-55-21-575]0x61800104
    [13-55-21-575]0x61800100
    [13-55-21-575]0x62000000
    [13-55-21-575]0x6180010D
    [13-55-21-575]0x612B6DE7
    [13-55-21-576]0x6180010C
    [13-55-21-576]0x61C00C63
    [13-55-21-576]0x612B6DE7
    [13-55-21-576]0x61800101
    [13-55-21-576]0x61C01495
    [13-55-21-576]0x61800104
    [13-55-21-576]0x61800100
    [13-55-21-576]0x62000000
    [13-55-21-576]0x6180010D
    [13-55-21-576]0x612B6D3F
    [13-55-21-576]0x61C01462
    [13-55-21-576]0x612B7DEF
    [13-55-21-576]0x61C004D1
    [13-55-21-576]0x612B7620
    [13-55-21-576]0x61C0841C
    [13-55-21-576]0x612BDDED
    [13-55-21-578]0x612BDDED
    [13-55-21-578]0x61800101
    [13-55-21-578]0x61C00C1C
    [13-55-21-578]0x61800104
    [13-55-21-578]0x61800103
    [13-55-21-578]0x61800100
    [13-55-21-578]0x62000000
    [13-55-21-578]0x61800102
    [13-55-21-578]0x62000004
    [13-55-21-578]0x6180010D
    [13-55-21-578]0x612B7DEE
    [13-55-21-578]0x6180010C
    [13-55-21-578]0x61C0701C
    [13-55-21-578]0x612D31E6
    [13-55-21-578]done.
    [13-55-21-578]InitlialzingClocks ...0x61800201
    [13-55-21-578]0x61C00023
    [13-55-21-578]0x61800201
    [13-55-21-578]0x61C0006D
    [13-55-21-578]0x61C0006E
    [13-55-21-578]0x61C0006B
    [13-55-21-578]0x61C0006C
    [13-55-21-578]0x61C0006A
    [13-55-21-578]0x61C00095
    [13-55-21-578]0x61C000DF
    [13-55-21-578]0x61C00167
    [13-55-21-578]0x61C0008A
    [13-55-21-578]0x61800200
    [13-55-21-578]0x62000002
    [13-55-21-578]0x62D0006D
    [13-55-21-579]0x6413C000
    [13-55-21-580]0x62D0006E
    [13-55-21-580]0x6000008A
    [13-55-21-580]0x6393C000
    [13-55-21-580]0x61800202
    [13-55-21-580]0x61C0008A
    [13-55-21-580]0x62000000
    [13-55-21-580]0x61800201
    [13-55-21-580]0x61C0008B
    [13-55-21-580]0x61800200
    [13-55-21-580]0x62000002
    [13-55-21-580]0x62D0006F
    [13-55-21-580]0x64144000
    [13-55-21-580]0x62D00070
    [13-55-21-580]0x6000008B
    [13-55-21-580]0x63944000
    [13-55-21-580]0x61C00060
    [13-55-21-580]0x62D00071
    [13-55-21-580]0x64138000
    [13-55-21-580]0x6413C001
    [13-55-21-580]0x62D00072
    [13-55-21-580]0x60000060
    [13-55-21-580]0x63938000
    [13-55-21-580]0x6393C001
    [13-55-21-580]0x61C00061
    [13-55-21-580]0x62D00073
    [13-55-21-580]0x64140000
    [13-55-21-580]0x64144001
    [13-55-21-580]0x62D00074
    [13-55-21-580]0x60000061
    [13-55-21-580]0x63940000
    [13-55-21-580]0x63944001
    [13-55-21-580]0x61C00062
    [13-55-21-580]0x61C00063
    [13-55-21-580]0x62D00075
    [13-55-21-580]0x6415C000
    [13-55-21-587]0x6416C001
    [13-55-21-587]0x62D00076
    [13-55-21-587]0x608001FC
    [13-55-21-587]0x608001AF
    [13-55-21-587]0x60000063
    [13-55-21-587]0x6395C000
    [13-55-21-588]0x6396C001
    [13-55-21-588]0x61800202
    [13-55-21-588]0x61C00063
    [13-55-21-588]0x62000000
    [13-55-21-588]0x61800201
    [13-55-21-588]0x61C00071
    [13-55-21-588]0x61C00165
    [13-55-21-588]0x61800200
    [13-55-21-588]0x62000002
    [13-55-21-588]0x62D04002
    [13-55-21-588]0x641B4000
    [13-55-21-588]0x62D04003
    [13-55-21-588]0x6080021C
    [13-55-21-588]0x60000165
    [13-55-21-588]0x639B4000
    [13-55-21-588]0x61C0003D
    [13-55-21-588]done.
    [13-55-21-589]Initlialzing DDR ...0x61800101
    [13-55-21-589]0x61C0008A
    [13-55-21-589]0x61800104
    [13-55-21-589]0x61800100
    [13-55-21-589]0x62000000
    [13-55-21-589]0x6180010D
    [13-55-21-589]0x61257DCF
    [13-55-21-589]0x6180010C
    [13-55-21-589]0x61800101
    [13-55-21-589]0x612FFDCF
    [13-55-21-590]0x612FFDCF
    [13-55-21-590]0x61800101
    [13-55-21-590]0x61C0008A
    [13-55-21-592]0x61800104
    [13-55-21-592]0x61C0008A
    [13-55-21-592]0x61800100
    [13-55-21-592]0x62000000
    [13-55-21-592]0x6180010D
    [13-55-21-594]0x61257DCF
    [13-55-21-721]0x6180010C
    [13-55-21-721]0x61C0008A
    [13-55-21-721]0x61257DCF
    [13-55-21-721]0x61800101
    [13-55-21-721]0x61800104
    [13-55-21-721]0x61800100
    [13-55-21-721]0x62000000
    [13-55-21-721]0x6180010D
    [13-55-21-722]0x61C0008A
    [13-55-21-722]0x612FFDCF
    [13-55-21-722]0x6180010C
    [13-55-21-722]0x61800101
    [13-55-21-722]0x61800104
    [13-55-21-722]0x61800100
    [13-55-21-722]0x62000000
    [13-55-21-722]0x6180010D
    [13-55-21-722]0x61257DCF
    [13-55-21-723]0x61C0008A
    [13-55-21-723]0x62000000
    [13-55-21-723]0x6180010D
    [13-55-21-723]0x612FFDCF
    [13-55-21-723]0x6180010C
    [13-55-21-723]done.
    [13-55-21-723]Initializing GTC ...Begin parsing user application
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x20...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x21...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x2...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x6...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x7...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x8...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x9...
    [13-55-21-723]Calling Sciclient_procBootRequestProcessor, ProcId 0x30...
    [13-55-21-724]Calling Sciclient_procBootRequestProcessor, ProcId 0x31...
    [13-55-21-724]Calling Sciclient_procBootRequestProcessor, ProcId 0x80...
    [13-55-21-726]
    [13-55-21-727] If you don't get the logs of the application while booting     from boot0 partition then you might need to pass the MAX_APP_SIZE_EMMC (=<size of you application>)     while building your appimage
    [13-55-22-206]Searching for X509 certificate ...not found
    [13-55-22-206]Switching core id 8, proc_id 0x1 to split mode...
    [13-55-22-206]Calling Sciclient_procBootGetProcessorState, ProcId 0x1...
    [13-55-22-206]Sciclient_procBootSetProcessorCfg, ProcId 0x1, enabling split mode...
    [13-55-22-206]Enabling MCU TCMs after reset for core 8
    [13-55-22-206]Disabling HW-based memory init of MCU TCMs for core 8
    [13-55-22-206]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-55-22-206]Copying 0x40 bytes to 0x41010000
    [13-55-22-206]Copying 0x490 bytes to 0x41010040
    [13-55-22-206]Copying 0x448 bytes to 0x410104d0
    [13-55-22-206]Copying 0x318 bytes to 0x41010918
    [13-55-22-206]Copying 0x118 bytes to 0x41010c30
    [13-55-22-206]Copying 0x8c bytes to 0xa0100000
    [13-55-22-206]Copying 0x1184 bytes to 0xa056c300
    [13-55-22-206]Copying 0x2218 bytes to 0xa056d488
    [13-55-22-206]Copying 0x23260 bytes to 0xa05b5ee0
    [13-55-22-206]Copying 0xa1b0 bytes to 0xa05d9140
    [13-55-22-206]Copying 0x41b8 bytes to 0xa05f5380
    [13-55-22-206]Setting entry point for core 8 @0x41010000
    [13-55-22-206]Sciclient_pmSetModuleState Off, DevId 0x11d...
    [13-55-22-206]Calling Sciclient_procBootGetProcessorState, ProcId 0x2...
    [13-55-22-206]Enabling MCU TCMs after reset for core 9
    [13-55-22-206]Setting HALT for ProcId 0x2...
    [13-55-22-207]Sciclient_pmSetModuleState On, DevId 0x11d...
    [13-55-22-207]Clearing core_id 9 (lock-step) ATCM @ 0x41400000
    [13-55-22-207]Clearing core_id 9 (lock-step) BTCM @ 0x41410000
    [13-55-22-207]Translating coreid 9 local BTCM addr 0x41010000 to SoC MCU BTCM addr 0x41410000
    [13-55-22-207]Copying 0x40 bytes to 0x41410000
    [13-55-22-207]Translating coreid 9 local BTCM addr 0x41010040 to SoC MCU BTCM addr 0x41410040
    [13-55-22-207]Copying 0x490 bytes to 0x41410040
    [13-55-22-207]Translating coreid 9 local BTCM addr 0x410104d0 to SoC MCU BTCM addr 0x414104d0
    [13-55-22-207]Copying 0x448 bytes to 0x414104d0
    [13-55-22-207]Translating coreid 9 local BTCM addr 0x41010918 to SoC MCU BTCM addr 0x41410918
    [13-55-22-207]Copying 0x318 bytes to 0x41410918
    [13-55-22-207]Translating coreid 9 local BTCM addr 0x41010c30 to SoC MCU BTCM addr 0x41410c30
    [13-55-22-207]Copying 0x118 bytes to 0x41410c30
    [13-55-22-207]Copying 0x8c bytes to 0xa1100000
    [13-55-22-208]Copying 0x290 bytes to 0xa156c300
    [13-55-22-208]Copying 0xf1f0 bytes to 0xa159e240
    [13-55-22-208]Copying 0x36e0 bytes to 0xa15b9d00
    [13-55-22-208]Setting entry point for core 9 @0x41010000
    [13-55-22-208]Switching core id 10, proc_id 0x6 to split mode...
    [13-55-22-208]Calling Sciclient_procBootGetProcessorState, ProcId 0x6...
    [13-55-22-208]Sciclient_procBootSetProcessorCfg, ProcId 0x6, enabling split mode...
    [13-55-22-208]Sciclient_pmSetModuleState Off, DevId 0x117...
    [13-55-22-208]0x61800200
    [13-55-22-208]0x61C00117
    [13-55-22-208]0x62000000
    [13-55-22-208]Enabling MCU TCMs after reset for core 10
    [13-55-22-208]Disabling HW-based memory init of MCU TCMs for core 10
    [13-55-22-208]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-55-22-208]Setting HALT for ProcId 0x6...
    [13-55-22-208]Sciclient_pmSetModuleState On, DevId 0x117...
    [13-55-22-210]0x61800200
    [13-55-22-211]0x61C00117
    [13-55-22-211]0x62000002
    [13-55-22-211]0x62D60000
    [13-55-22-211]0x64174000
    [13-55-22-211]0x62D60001
    [13-55-22-211]0x60000117
    [13-55-22-211]0x63974000
    [13-55-22-211]Clearing core_id 10 (lock-step) ATCM @ 0x5c00000
    [13-55-22-211]Clearing core_id 10 (lock-step) BTCM @ 0x5c10000
    [13-55-22-211]Translating coreid 10 local ATCM addr 0x0 to SoC MCU ATCM addr 0x5c00000
    [13-55-22-211]Copying 0x40 bytes to 0x5c00000
    [13-55-22-211]Translating coreid 10 local ATCM addr 0x40 to SoC MCU ATCM addr 0x5c00040
    [13-55-22-211]Copying 0x490 bytes to 0x5c00040
    [13-55-22-211]Translating coreid 10 local ATCM addr 0x4d0 to SoC MCU ATCM addr 0x5c004d0
    [13-55-22-211]Copying 0x448 bytes to 0x5c004d0
    [13-55-22-211]Translating coreid 10 local ATCM addr 0x918 to SoC MCU ATCM addr 0x5c00918
    [13-55-22-211]Copying 0x318 bytes to 0x5c00918
    [13-55-22-211]Translating coreid 10 local ATCM addr 0xc30 to SoC MCU ATCM addr 0x5c00c30
    [13-55-22-212]Copying 0x118 bytes to 0x5c00c30
    [13-55-22-212]Copying 0x8c bytes to 0xa2100000
    [13-55-22-212]Copying 0x2c0 bytes to 0xa2f9a0cc
    [13-55-22-212]Copying 0x84400 bytes to 0xa30d8000
    [13-55-22-212]Copying 0x42b40 bytes to 0xa3232a00
    [13-55-22-212]Copying 0x12d98 bytes to 0xa328d540
    [13-55-22-212]Setting entry point for core 10 @0x0
    [13-55-22-212]Switching core id 10, proc_id 0x6 to split mode...
    [13-55-22-214]Calling Sciclient_procBootGetProcessorState, ProcId 0x6...
    [13-55-22-367]Sciclient_procBootSetProcessorCfg, ProcId 0x6, enabling split mode...
    [13-55-22-367]Sciclient_pmSetModuleState Off, DevId 0x118...
    [13-55-22-367]0x61800200
    [13-55-22-367]0x61C00118
    [13-55-22-367]0x62000000
    [13-55-22-367]Calling Sciclient_procBootGetProcessorState, ProcId 0x7...
    [13-55-22-367]Enabling MCU TCMs after reset for core 11
    [13-55-22-367]Sciclient_procBootSetProcessorCfg update TCM enable/disable settings...
    [13-55-22-367]Setting HALT for ProcId 0x7...
    [13-55-22-367]Sciclient_pmSetModuleState On, DevId 0x118...
    [13-55-22-367]0x62000002
    [13-55-22-367]0x62D60002
    [13-55-22-367]0x64178000
    [13-55-22-367]0x62D60003
    [13-55-22-367]0x60000118
    [13-55-22-367]0x63978000
    [13-55-22-367]Clearing core_id 11 (lock-step) ATCM @ 0x5d00000
    [13-55-22-367]Clearing core_id 11 (lock-step) BTCM @ 0x5d10000
    [13-55-22-367]Translating coreid 11 local ATCM addr 0x0 to SoC MCU ATCM addr 0x5d00000
    [13-55-22-367]Copying 0x40 bytes to 0x5d00000
    [13-55-22-367]Translating coreid 11 local ATCM addr 0x40 to SoC MCU ATCM addr 0x5d00040
    [13-55-22-367]Copying 0x490 bytes to 0x5d00040
    [13-55-22-367]Translating coreid 11 local ATCM addr 0x4d0 to SoC MCU ATCM addr 0x5d004d0
    [13-55-22-367]Copying 0x448 bytes to 0x5d004d0
    [13-55-22-367]Translating coreid 11 local ATCM addr 0x918 to SoC MCU ATCM addr 0x5d00918
    [13-55-22-367]Copying 0x318 bytes to 0x5d00918
    [13-55-22-367]Translating coreid 11 local ATCM addr 0xc30 to SoC MCU ATCM addr 0x5d00c30
    [13-55-22-367]Copying 0x118 bytes to 0x5d00c30
    [13-55-22-367]Copying 0x8c bytes to 0xa4100000
    [13-55-22-367]Copying 0x2c0 bytes to 0xa49d0b10
    [13-55-22-367]Copying 0xa40 bytes to 0xa49d0dd0
    [13-55-22-367]Copying 0x32e70 bytes to 0xa4b8e000
    [13-55-22-367]Copying 0x13060 bytes to 0xa4bc0e70
    [13-55-22-367]Setting entry point for core 11 @0x0
    [13-55-22-368]Copying 0x98 bytes to 0xb0100000
    [13-55-22-368]Copying 0x40 bytes to 0xb0200000
    [13-55-22-368]Copying 0x880 bytes to 0xb0400000
    [13-55-22-368]Copying 0x880 bytes to 0xb0600000
    [13-55-22-368]Copying 0x20 bytes to 0xb1367d50
    [13-55-22-368]Copying 0x1000 bytes to 0xb13e8000
    [13-55-22-369]Copying 0x5b5100 bytes to 0xb1400000
    [13-55-22-499]Copying 0x31150 bytes to 0xb1b24000
    [13-55-22-499]Copying 0x29468 bytes to 0xb1b55150
    [13-55-22-499]Setting entry point for core 18 @0xb0200000
    [13-55-22-499]Copying 0x98 bytes to 0xb6100000
    [13-55-22-499]Copying 0x40 bytes to 0xb6200000
    [13-55-22-500]Copying 0x840 bytes to 0xb6400000
    [13-55-22-500]Copying 0x840 bytes to 0xb6600000
    [13-55-22-500]Copying 0x1000 bytes to 0xb73660c0
    [13-55-22-500]Copying 0x2c630 bytes to 0xb7556000
    [13-55-22-500]Copying 0x7c0c bytes to 0xb75a6008
    [13-55-22-501]Copying 0x151ac0 bytes to 0xb7600000
    [13-55-22-524]Setting entry point for core 19 @0xb6200000
    [13-55-22-524]Copying 0x68880 bytes to 0x9e800000
    [13-55-22-530]Only load (not execute) image @0x9e800000
    [13-55-22-541]Copying 0x12b5200 bytes to 0x80080000
    [13-55-23-107]Only load (not execute) image @0x80080000
    [13-55-23-107]Copying 0x13e8c bytes to 0x82000000
    [13-55-23-107]Only load (not execute) image @0x82000000
    [13-55-23-107]Sciclient_pmSetModuleState On, DevId 0x4...
    [13-55-23-107]0x61800200
    [13-55-23-107]0x61C00004
    [13-55-23-107]0x62000002
    [13-55-23-107]0x62D38000
    [13-55-23-107]0x64138000
    [13-55-23-107]0x62D38001
    [13-55-23-107]0x608000D1
    [13-55-23-107]0x60000004
    [13-55-23-107]0x63938000
    [13-55-23-107]Copying 0xabc0 bytes to 0x70000000
    [13-55-23-107]Setting entry point for core 0 @0x70000000
    [13-55-23-107]==xiex=> SBL_MulticoreImageParse:Ok
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x20...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x21...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x1...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x2...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x6...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x7...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x8...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x9...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x30...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x31...
    [13-55-23-107]Sciclient_procBootReleaseProcessor, ProcId 0x80...
    [13-55-23-107]Calling Sciclient_procBootRequestProcessor, ProcId 0x6...
    [13-55-23-107]Sciclient_procBootSetProcessorCfg, ProcId 0x6, EntryPoint 0x0...
    [13-55-23-107]Sciclient_pmSetModuleClkFreq, DevId 0x117 @ 1000000000Hz...
    [13-55-23-107]0x6180010C
    [13-55-23-107]0x61C00117
    [13-55-23-107]0x612FDDDD
    [13-55-23-107]Clearing HALT for ProcId 0x6...
    [13-55-23-107]Calling Sciclient_procBootRequestProcessor, ProcId 0x7...
    [13-55-23-107]Sciclient_procBootSetProcessorCfg, ProcId 0x7, EntryPoint 0x0...
    [13-55-23-107]Sciclient_pmSetModuleClkFreq, DevId 0x118 @ 1000000000Hz...
    [13-55-23-107]0x61C00118
    [13-55-23-107]Clearing HALT for ProcId 0x7...
    [13-55-23-107]Calling Sciclient_procBootRequestProcessor, ProcId 0x30...
    [13-55-23-108]Sciclient_procBootSetProcessorCfg, ProcId 0x30, EntryPoint 0xb0200000...
    [13-55-23-108]Sciclient_pmSetModuleClkFreq, DevId 0x8 @ 1000000000Hz...
    [13-55-23-108]0x6180010C
    [13-55-23-108]0x61C00008
    [13-55-23-108]0x612FDDD2
    [13-55-23-108]Sciclient_pmSetModuleState Off, DevId 0x8...
    [13-55-23-108]0x61800200
    [13-55-23-108]0x62000000
    [13-55-23-108]Sciclient_pmSetModuleState On, DevId 0x8...
    [13-55-23-118]0x62000002
    [13-55-23-118]0x62D30000
    [13-55-23-118]0x64128000
    [13-55-23-118]0x62D30001
    [13-55-23-118]0x608000D2
    [13-55-23-118]0x60000008
    [13-55-23-118]0x63928000
    [13-55-23-118]Sciclient_procBootReleaseProcessor, ProcId 0x30...
    [13-55-23-118]Calling Sciclient_procBootRequestProcessor, ProcId 0x31...
    [13-55-23-118]Sciclient_procBootSetProcessorCfg, ProcId 0x31, EntryPoint 0xb6200000...
    [13-55-23-118]Sciclient_pmSetModuleClkFreq, DevId 0xb @ 1000000000Hz...
    [13-55-23-118]0x6180010C
    [13-55-23-118]0x61C0000B
    [13-55-23-118]0x612FDDD2
    [13-55-23-118]Sciclient_pmSetModuleState Off, DevId 0xb...
    [13-55-23-118]0x61800200
    [13-55-23-118]0x62000000
    [13-55-23-118]Sciclient_pmSetModuleState On, DevId 0xb...
    [13-55-23-119]0x62D34000
    [13-55-23-119]0x64130000
    [13-55-23-119]0x62D34001
    [13-55-23-119]0x6000000B
    [13-55-23-119]0x63930000
    [13-55-23-119]Sciclient_procBootReleaseProcessor, ProcId 0x31...
    [13-55-23-119]0x61800201
    [13-55-23-119]0x61C0006D
    [13-55-23-119]0x61800200
    [13-55-23-119]0x62000000
    [13-55-23-119]0x6040006D
    [13-55-23-119]0x63C28001
    [13-55-23-119]0x60C00031
    [13-55-23-119]0x64428001
    [13-55-23-119]0x63000040
    [13-55-23-119]0x6300003F
    [13-55-23-119]0x61800202
    [13-55-23-119]0x62000001
    [13-55-23-119]0x61C0006E
    [13-55-23-119]0x6040006E
    [13-55-23-119]0x63C2C001
    [13-55-23-119]0x60C00032
    [13-55-23-119]0x6442C001
    [13-55-23-119]0x6300003E
    [13-55-23-119]0x6300003D
    [13-55-23-119]0x61C0006B
    [13-55-23-122]0x61800200
    [13-55-23-122]0x61C0006B
    [13-55-23-122]0x62000000
    [13-55-23-122]0x6040006B
    [13-55-23-122]0x63C00023
    [13-55-23-122]0x64400023
    [13-55-23-122]0x6300003C
    [13-55-23-122]0x61800202
    [13-55-23-122]0x62000001
    [13-55-23-122]0x61800201
    [13-55-23-122]0x61C0006C
    [13-55-23-122]0x6040006C
    [13-55-23-122]0x63C30001
    [13-55-23-122]0x64430001
    [13-55-23-122]0x6300003B
    [13-55-23-122]0x6300003A
    [13-55-23-123]0x61800201
    [13-55-23-123]0x61C0006A
    [13-55-23-123]0x61800200
    [13-55-23-123]0x62000000
    [13-55-23-123]0x6040006A
    [13-55-23-123]0x61800202
    [13-55-23-123]0x62000001
    [13-55-23-124]0x61800201
    [13-55-23-124]0x61C000DF
    [13-55-23-124]0x61800200
    [13-55-23-124]0x62000000
    [13-55-23-124]0x604000DF
    [13-55-23-124]0x63C0C004
    [13-55-23-124]0x60C0005D
    [13-55-23-125]0x6440C004
    [13-55-23-125]0x63000039
    [13-55-23-125]0x61800202
    [13-55-23-125]0x61C000DF
    [13-55-23-125]0x62000001
    [13-55-23-125]0x61800201
    [13-55-23-125]0x61C00062
    [13-55-23-125]0x61800200
    [13-55-23-125]0x62000000
    [13-55-23-125]0x60400062
    [13-55-23-125]0x63D64001
    [13-55-23-125]0x63D30002
    [13-55-23-125]0x60C001FB
    [13-55-23-125]0x64564001
    [13-55-23-125]0x63100077
    [13-55-23-125]0x64530002
    [13-55-23-125]0x63100076
    [13-55-23-128]0x61C00062
    [13-55-23-128]0x62000001
    [13-55-23-128]0x61800201
    [13-55-23-128]0x61C00063
    [13-55-23-129]0x61800200
    [13-55-23-380]0x61C00063
    [13-55-23-380]0x62000000
    [13-55-23-380]0x60400063
    [13-55-23-380]0x63D5C001
    [13-55-23-380]0x63D6C002
    [13-55-23-380]0x60C001AF
    [13-55-23-380]0x60C001FC
    [13-55-23-380]0x6455C001
    [13-55-23-380]0x63100075
    [13-55-23-380]0x6456C002
    [13-55-23-380]0x63100074
    [13-55-23-380]0x61800202
    [13-55-23-380]0x62000001
    [13-55-23-380]0x61800201
    [13-55-23-380]0x61C0003D
    [13-55-23-380]0x61800200
    [13-55-23-381]0x6040003D
    [13-55-23-381]0x63D24009
    [13-55-23-381]0x60C001FD
    [13-55-23-381]0x64524009
    [13-55-23-381]0x63100073
    [13-55-23-381]0x61800202
    [13-55-23-381]0x61C0003D
    [13-55-23-381]0x62000001
    [13-55-23-381]Calling Sciclient_procBootRequestProcessor, ProcId 0x20...
    [13-55-23-381]Sciclient_procBootSetProcessorCfg, ProcId 0x20, EntryPoint 0x70000000...
    [13-55-23-381]Sciclient_pmSetModuleClkFreq, DevId 0xca @ 2000000000Hz...
    [13-55-23-381]0x6180010C
    [13-55-23-381]0x61C000CA
    [13-55-23-381]0x6131DDD3
    [13-55-23-381]Sciclient_pmSetModuleState Off, DevId 0xca...
    [13-55-23-381]0x61800200
    [13-55-23-381]0x62000000
    [13-55-23-381]Sciclient_pmSetModuleState On, DevId 0xca...
    [13-55-23-382]0x61800200
    [13-55-23-382]0x61C000CA
    [13-55-23-382]0x62000002
    [13-55-23-382]0x62D3C000
    [13-55-23-382]0x62D38002
    [13-55-23-382]0x64140000
    [13-55-23-382]0x63938001
    [13-55-23-382]0x64138001
    [13-55-23-382]0x62D3C001
    [13-55-23-382]0x600000CA
    [13-55-23-382]0x63940000
    [13-55-23-382]Sciclient_procBootReleaseProcessor, ProcId 0x20...
    [13-55-23-382]Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
    [13-55-23-382]Sciclient_procBootSetProcessorCfg, ProcId 0x1, EntryPoint 0x41010000...
    [13-55-23-382]Sciclient_pmSetModuleClkFreq, DevId 0x11c @ 1000000000Hz...
    [13-55-23-382]0x6180010C
    [13-55-23-382]0x61C0011C
    [13-55-23-382]0x612FDC07
    [13-55-23-383]Copying first 128 bytes from app to MCU ATCM @ 0x0 for core 8
    [13-55-23-388]Calling Sciclient_procBootRequestProcessor, ProcId 0x2...
    [13-55-23-388]Sciclient_procBootSetProcessorCfg, ProcId 0x2, EntryPoint 0x41010000...
    [13-55-23-389]Sciclient_pmSetModuleClkFreq, DevId 0x11d @ 1000000000Hz...
    [13-55-23-389]0x6180010C
    [13-55-23-389]0x61C0011D
    [13-55-23-389]0x612FDC07
    [13-55-23-389]0x6180010E
    [13-55-23-389]0x61C0011C
    [13-55-23-389]MCU @ 1000000000Hz.
    [13-55-23-389]cycles per usec  = 1000
    [13-55-23-389]  fxn:main                              line:14743363   cycle:    489800        timestamp:       489us
    [13-55-23-389]  fxn:main                              line: 261       cycle:    489951        timestamp:       489us
    [13-55-23-389]  fxn:SBL_SciClientInit                 line: 256       cycle:   4963933        timestamp:      4963us
    [13-55-23-389]  fxn:SBL_SciClientInit                 line: 279       cycle: 530686286        timestamp:    530686us
    [13-55-23-389]  fxn:SBL_SciClientInit                 line: 291       cycle: 532681845        timestamp:    532681us
    [13-55-23-389]  fxn:SBL_SciClientInit                 line: 306       cycle: 535834488        timestamp:    535834us
    [13-55-23-389]  fxn:SBL_SciClientInit                 line: 324       cycle: 542848127        timestamp:    542848us
    [13-55-23-389]**fxn:SBL_SciClientInit                 line: 326       cycle:        95        timestamp:         0us
    [13-55-23-394]  fxn:SBL_SciClientInit                 line: 358       cycle:   1426110        timestamp:      1426us
    [13-55-23-407]  fxn:SBL_SciClientInit                 line: 407       cycle:   2297062        timestamp:      2297us
    [13-55-23-409]  fxn:main                              line: 349       cycle:1949227077        timestamp:   1949227us
    [13-55-23-410]  fxn:main                              line: 366       cycle:-2054060645       timestamp:   2240906us
    [13-55-23-415]  fxn:main                              line: 405       cycle:-604902998        timestamp:   3690064us
    [13-55-23-422]  fxn:main                              line: 432       cycle:-266121814        timestamp:   4028845us
    [13-55-23-425]Copying first 128 bytes from app to MCU ATCM @ 0x41400000 for core 9
    [13-55-23-436]Calling Sciclient_procBootRequestProcessor, ProcId 0x1...
    [13-55-23-728]type = 0x10e, host = 37
    [13-55-23-728]type = 0x2, host = 5
    [13-55-23-728]type = 0x10e, host = 21
    [13-55-23-728]type = 0x10e, host = 35
    [13-55-23-728]type = 0x10e, host = 23
    [13-55-23-728]type = 0x2, host = 37
    [13-55-23-728]type = 0x2, host = 21
    [13-55-23-728]type = 0x2, host = 35
    [13-55-23-728]type = 0x2, host = 23
    [13-55-23-728]type = 0x1500, host = 37
    [13-55-23-728]type = 0x1500, host = 21
    [13-55-23-728]type = 0x1500, host = 35
    [13-55-23-728]type = 0x1500, host = 23
    [13-55-23-728]type = 0x200, host = 251
    [13-55-23-729]type = 0x1500, host = 35
    [13-55-23-729]type = 0x1500, host = 23
    [13-55-23-729]type = 0x1500, host = 37
    [13-55-23-729]type = 0x1500, host = 21
    [13-55-23-730]type = 0x1500, host = 21
    [13-55-23-730]type = 0x1500, host = 35
    [13-55-23-730]type = 0x1500, host = 23
    [13-55-23-730]type = 0x1500, host = 37
    [13-55-23-730]type = 0x1300, host = 35
    [13-55-23-730]type = 0x1000, host = 35
    [13-55-23-730]type = 0x1300, host = 37
    [13-55-23-730]type = 0x1300, host = 21
    [13-55-23-731]type = 0x1300, host = 23
    [13-55-23-731]type = 0x1500, host = 37
    [13-55-23-731]type = 0x1500, host = 21
    [13-55-23-731]type = 0x1500, host = 35
    [13-55-23-731]type = 0x1500, host = 23
    [13-55-23-732]type = 0x1500, host = 23
    [13-55-23-732]type = 0x1000, host = 37
    [13-55-23-732]type = 0x1000, host = 21
    [13-55-23-732]type = 0x1500, host = 35
    [13-55-23-732]type = 0x1000, host = 23
    [13-55-23-732]type = 0x2, host = 12
    [13-55-23-738]type = 0x1500, host = 35
    [13-55-23-742]type = 0x1500, host = 35
    [13-55-23-742]type = 0x22, host = 12
    [13-55-23-743]type = 0x1000, host = 35
    [13-55-23-743]type = 0x104, host = 12
    [13-55-23-745]type = 0x104, host = 12
    [13-55-23-746]type = 0x104, host = 12
    [13-55-23-748]type = 0x104, host = 12
    [13-55-24-072]type = 0x104, host = 12
    [13-55-24-072]type = 0x103, host = 12
    [13-55-24-072]type = 0x10e, host = 12
    [13-55-24-073]type = 0x10e, host = 12
    [13-55-24-074]type = 0x10e, host = 12
    [13-55-24-074]type = 0x103, host = 12
    [13-55-24-075]type = 0x10e, host = 12
    [13-55-24-075]type = 0x103, host = 12
    [13-55-24-077]type = 0x10e, host = 12
    [13-55-24-077]type = 0x103, host = 12
    [13-55-24-078]type = 0x10e, host = 12
    [13-55-24-078]type = 0x103, host = 12
    [13-55-24-079]type = 0x10e, host = 12
    [13-55-24-080]type = 0x103, host = 12
    [13-55-24-372]type = 0x10e, host = 12
    [13-55-24-372]type = 0x103, host = 12
    [13-55-24-373]type = 0x10e, host = 12
    [13-55-24-373]type = 0x103, host = 12
    [13-55-24-374]type = 0x103, host = 12
    [13-55-24-374]type = 0x10e, host = 12
    [13-55-24-374]type = 0x200, host = 12
    [13-55-24-375]type = 0x200, host = 12
    [13-55-24-375]type = 0x1500, host = 12
    [13-55-24-376]type = 0x1500, host = 12
    [13-55-24-376]type = 0x200, host = 12
    [13-55-24-376]type = 0x10e, host = 12
    [13-55-24-376]type = 0x102, host = 12
    [13-55-24-376]type = 0x10d, host = 12
    [13-55-24-376]type = 0x10c, host = 12
    [13-55-24-376]type = 0x100, host = 12
    [13-55-24-379]type = 0x200, host = 12
    [13-55-24-391]type = 0x200, host = 12
    [13-55-24-392]type = 0x200, host = 12
    [13-55-24-410]type = 0x100, host = 12
    [13-55-24-411]type = 0x100, host = 12
    [13-55-24-426]type = 0x100, host = 12
    [13-55-24-426]type = 0x1000, host = 12
    [13-55-24-427]type = 0x200, host = 12
    [13-55-24-446]type = 0x100, host = 12
    [13-55-24-447]type = 0x200, host = 12
    [13-55-24-536]type = 0x200, host = 12
    [13-55-24-537]type = 0x200, host = 12
    [13-55-24-621]type = 0x100, host = 12
    [13-55-24-621]type = 0x1000, host = 12
    [13-55-24-621]type = 0x200, host = 12
    [13-55-24-622]type = 0x1000, host = 12
    [13-55-24-622]type = 0x100, host = 12
    [13-55-24-622]type = 0x1500, host = 12
    [13-55-24-623]type = 0x1500, host = 12
    [13-55-24-624]type = 0x200, host = 12
    [13-55-24-638]type = 0x200, host = 12
    [13-55-24-639]type = 0x200, host = 12
    [13-55-24-660]type = 0x100, host = 12
    [13-55-24-969]type = 0x100, host = 12
    [13-55-24-969]type = 0x1110, host = 12
    [13-55-24-969]type = 0x1205, host = 12
    [13-55-24-969]type = 0x1000, host = 12
    [13-55-24-969]type = 0x1215, host = 12
    [13-55-24-969]type = 0x1230, host = 12
    [13-55-24-969]type = 0x200, host = 12
    [13-55-24-969]type = 0x101, host = 12
    [13-55-24-970]type = 0x101, host = 12
    [13-55-24-971]type = 0x101, host = 12
    [13-55-24-972]type = 0x101, host = 12
    [13-55-24-973]type = 0x101, host = 12
    [13-55-24-975]type = 0x101, host = 12
    [13-55-24-976]type = 0x101, host = 12
    [13-55-24-978]type = 0x101, host = 12
    [13-55-24-993]type = 0x101, host = 12
    The difference is, under normal circumstances,/packages/ti/drv/sciclient/src/sciserver/server.c in static int32_t Sciserver_UserProcessMsg(uint32_t *msg_recv,int32_t *pRespMsgSize,uint8_t hw_host_id) function will be called and will not be called when startup fails.
    Enable debugging:
    /packages/ti/drv/sciclient/src/rm_pm_hal_build.mk
    CONFIG_TRACE=y
    CONFIG_TRACE_BUFFER=y
    CONFIG_TRACE_UART=y
    packages/ti/boot/sbl/sbl_component.mk
    SBL_CFLAGS += -DSBL_DISPLAY_PROFILE_INFO
    We tried on 9.0 and works as expected for at least 10-11 reboots. We will need time to switch to 8.6 SDK.
    Can you comment on how many times you tried and how frequently it failed?
    - Keerthy
    If the first cold start is successful and multiple startup failures occur, the longer the power-off wait time, the higher the startup probability.
    thanks!
    So after cold boot you use reboot command from Linux or how do you restart? You use the power switch?
    - Keerthy
    Note If the linux OS is successfully started, the reboot command also fails.If the startup fails, only the switching power supply can be used
