Openmax/syslink error in RDK 00.07.00.01 of 816x DVR reference.
We try run rdk tstEncoder on 816x DVR reference board. It came to error in syslink.
And our process is like this:
(1) insmod syslink.ko and ti81xx_hdmi.ko;
(2) we make sure app_m3video.xem3 and app_m3vpss.xem3  are exist;
(3) /opt/netra/tstEncoder
Is the process or something wrong? How to fix this?
log:
start application
tstEncoder 18:12:04
err: Error create uinput device -1.
OsalDrv driver open: /dev/syslinkipc/Osal: No such device or address
OsalDrv driver close: /dev/syslinkipc/Osal: Bad file descriptor
/dev/syslinkipc/MultiProc: No such device or address
MultiProc driver close: : Bad file descriptor
SharedRegion driver open: : No such device or address
SharedRegion driver close: : Bad file descriptor
/dev/syslinkipc/GateMP: No such device or address
/dev/syslinkipc/MessageQ: No such device or address
MessageQ driver close: : Bad file descriptor
Notify driver open: /dev/syslinkipc/Notify: No such device or address
Notify driver close: /dev/syslinkipc/Notify: Bad file descriptor
/dev/syslinkipc/HeapBufMP: No such device or address
/dev/syslinkipc/HeapMemMP: No such device or address
/dev/syslinkipc/ListMP: No such device or address
/dev/syslinkipc/RingIO: No such device or address
RingIO driver close: : Bad file descriptor
/dev/syslinkipc/ClientNotifyMgr: No such device or address
ClientNotifyMgr driver close: : Bad file descriptor
/dev/syslinkipc/FrameQBufMgr: No such device or address
FrameQBufMgr driver close: : Bad file descriptor
/dev/syslinkipc/FrameQ: No such device or address
FrameQ driver close: : Bad file descriptor
/dev/syslinkipc/Ipc: No such device or address
Assertion at Line no: 231 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/procMgr/hlos/usr/Linux/ProcMgrDrvUsr.c: (ProcMgrDrvUsr_refCount > 0) : failed
[t=0x00000003] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
xdc.runtime.Main: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
[t=0x00000111] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
xdc.runtime.Main: "IpcSupport.c", line 313: ipc_initialize() failed
Assertion at Line no: 1080 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/ipc/hlos/usr/SharedRegion.c: (id < SharedRegion_module->cfg.numEntries) : failed
Assertion at Line no: 1064 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/ipc/hlos/usr/MessageQ.c: (heap != NULL) : failed
[t=0x00000206] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
[t=0x0000026c] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
app: dvr_init() ... done
enc: bitrate ... 1200000
app: dvr_startsystem ... start
Assertion at Line no: 217 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/ipc/hlos/usr/Linux/GateMPDrv.c: (GateMPDrv_refCount > 0) : failed
Assertion at Line no: 222 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/ipc/hlos/usr/Linux/HeapBufMPDrv.c: (HeapBufMPDrv_refCount > 0) : failed
Assertion at Line no: 221 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/ipc/hlos/usr/Linux/HeapMemMPDrv.c: (HeapMemMPDrv_refCount > 0) : failed
Assertion at Line no: 225 in /home/idaroa/proj/src/20110527/00.07.00.01/dvr/../ti_tools/syslink_02_00_00_67/ti/syslink/ipc/hlos/usr/Linux/ListMPDrv.c: (ListMPDrv_refCount > 0) : failed
[t=0x0001a824] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
[t=0x0001a8a7] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
[t=0x0001a950] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
[t=0x0001a9b4] [tid=0x400742d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
err: Line number: 201
app: lib816x_statsystem ... done
<  h> : help.
<  q> : quit.
<  1> : encoder            test.
input cmd:
  • Maybe you are using the wrong version of syslink. As I can only see syslinkipc_ device files in /dev. (Version 2.00.02.80 or .00.78) on DM8148.
    If you are using the current Beta EZSDK for Netra you'll have to use a syslink version like .00.68 or so, I think. Since the newer versions are not compatible anymore.
    Markus
  • Thanks Markus.
    I used rdk version00.07.00.01 and the syslink_02_00_00_67. All those are provided by ti.
    You mean my version of  syslink is older? The problem cause by syslink.ko?
    I try the default syslink.ko  and  app_m3video.xem3, app_m3vpss.xem3 in RDK( udworks), it is still error. The tstEncoder can work in ti offical image.  But it can no work in the rootfs that i built. So there maybe something wrong in syslink.ko or app_m3video.xem3, app_m3vpss.xem3.
    Maybe I think:
    (1)  The *.ko or *.xm3 are wrong. That  maybe the versions are not   compatible anymore;
    (2)  I do not use udev.  I insmod syslink.ko and ti81xx_hdmi.ko directly. Did it need other kernel modules?
    Besides the version, is my process is ok?
  • Ok should be fine, which root system do you use. Because if your's doesn't support udev, it can be that the device files won't get created automatically. In this cases you'll have
    to create them by hand using mknod. I think this is mentioned in the SDK User Guide or ROOTFS Creation Guide in the wiki.
    But as you see those devices files are not available or not where your applications needs them to be. Pls have look into /dev and look for the syslink device files.
    If there are syslink_... files or some subdirectory containing those files then  the application is not compatible with the current version (would need an older one then).
    EDIT: Oh I see you don't use udev. That can be the reason. Ok, use mknod.
    Markus
  • Yes, Markus you are right. The function call like this:
    LIB816x_StartSystem()
      \___ DVR_Init()
              \___ DVR_start_front_if() ==> It depend on /dev/input/uinput.
    The kernel has built in the uinput driver. Becase I use mdev, the /dev/input/uinput was not created auto.
    I tar the normal nodes in /dev of offical image, and tar xf it under /dev in my rootfs.  But this only fix "err: Error create uinput device -1.". The syslink error is still.
    Maybe it seems 2 things.
    (1) The kernel driver of syslink is error, Maybe the version problem;
    (2) The major and minor I created using the load_moules are wrong.
    Anything else you think? Thanks.
    Yaming
    Log like this:
    /opt- # ./load_module.sh
    SysLink version : 02.00.00.67_alpha2
    SysLink module created on Date:May  9 2011 Time:07:39:43
    Entered KnlUtilsDrv_initializeModule
    Trace enabled
    Trace SetFailureReason enabled
    Trace class 3
    traceMask value: 0x30101
    DM8168DUCATIPWR Module already initialized!
    Leaving KnlUtilsDrv_initializeModule 0x0
    [module] ti81xx_hdmi init done
    load module completed
    /opt- # lsmod
    TI81xx_hdmi 11306 0 - Live 0xbf181000
    syslink 1074625 0 - Live 0xbf049000
    ipv6 209879 10 - Live 0xbf000000
    /opt- # ./start_app.sh
    start application
    tstEncoder 18:12:04
    input: dvr-keypad as /devices/virtual/input/input0
    front_interface start
    [t=0x00000002] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
    [t=0x00000103] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
    [t=0x000001ee] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
    [t=0x00000251] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
    [t=0x0001a03d] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
    [t=0x0001a113] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
    [t=0x0001a1bf] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 222: ipc_initialize(), error in ProcMgr_open()
    [t=0x0001a223] [tid=0x400692d0] xdc.runtime.Main: ERROR: "IpcSupport.c", line 313: ipc_initialize() failed
    <  h> : help.
    <  q> : quit.
    input cmd:
  • Hi Yaming,
    Looks like the syslink module insertion has not succeeded for you. We can check it by looking at the log. Can you share the log of insmod syslink.ko also? You have not shared in last post.
    BTW, to confirm if it is syslink.ko problem, can you use the syslink.ko and the uImage from the TI DVR RDK release and only replace your .xem3 binaries and test.
    Also, can you confirm if you are using the right paths for the syslink that you have used in the Rules.make to build the .xem3 binaries.
    Anshuman
    PS: Please mark this post as verified, if you think it has answered your question. Thanks.
  • Hi guys,
    I'm sure the driver of syslink for linux kernel is ok now. Now  I traced that tstEncoder came to DVR_StartSystem().
    I use mdev for manage the node under /dev, the device node for uinput and  syslinkipc could not be created very for DVR lib.
    I was cheated by "/opt/load_modules.sh", it create the wrong major. I check every major, minor and path of every node and recreated them manually. Now we can see "Starting Streaming Server...DONE".
    But tstEncoder hung at this stage. I'm sure tstEncoder hung in DVR_StartSystem(). And  I put the tstEncoder in offical DVR image it act likely. So the .xem3 maybe are right.
    This moment, I just depend on trace the DVR_StartSystem(). Any ideas? The run log like this:
    [root@/opt-]# ./start_app.sh
    start application
    [root@/opt-]# tstEncoder 03:50:39
    Wait for VM3 to to create the server first
    Entering: OMX_TI_CMUX_ComponentInit
    Entering: OMX_TI_DMUX_ComponentInit
     AVSERVER UI: Starting Streaming Server...
    Entering: _OMX_TI_DMUX_DataProcPrdTaskFcn
    Entering: _OMX_CMUXDataProcPrdTaskFcn
    NetraDrvInit: 6
    queue id:0
    Initializing...
    ...done initializing
    NetraDrvInit: 2
    queue id:0
    Initializing...
    Play this stream using the URL:
            rtsp://10.51.252.125:8557/h264_ch7
    NetraDrvInit: 2
    queue id:0
    Initializing...
            rtsp://10.51.252.125:8556/h264_ch6
    NetraDrvInit: 10
    queue id:0
    Initializing...
            rtsp://10.51.252.125:8555/h264_ch5
    NetraDrvInit: 9
    queue id:0
    Initializing...
            rtsp://10.51.252.125:8554/h264_ch4
    NetraDrvInit: 8
    queue id:0
    Initializing...
            rtsp://10.51.252.125:8553/h264_ch3
    NetraDrvInit: 6
    NetraDrvInit: 2
    queue id:0
    Initializing...
            rtsp://10.51.252.125:8551/h264_ch1
            rtsp://10.51.252.125:8558/h264_ch8
    queue id:0
    Initializing...
            rtsp://10.51.252.125:8552/h264_ch2
     AVSERVER UI: Starting Streaming Server...DONE
    I use the "insmod ./$moudle_dir/syslink.ko TRACE=1 TRACEFAILURE=1" for debug. And the log as following. Is the tstEncoder depend on record enable?
    *** DM8168VIDEOM3PROC_translate: srcAddr not found in slave address space
            Error [0x86a85001] at Line no: 1471 in file /home/phoong/work/netra/dvr/sdk_5011/syslink_02_00_00_67/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/family/hlos/knl/ti81xx/ti81xxducati/ti81xxvideom3/Dm8168M3VideoProc.c
    *** Processor_translateAddr: Processor address translation failed!
            Error [0x86a85001] at Line no: 600 in file /home/phoong/work/netra/dvr/sdk_5011/syslink_02_00_00_67/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/procMgr/hlos/knl/Processor.c
    *** ElfLoaderTrgWrite_copy: Processor_translateAddr failed!
            Error [0x86a85001] at Line no: 521 in file /home/phoong/work/netra/dvr/sdk_5011/syslink_02_00_00_67/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/procMgr/hlos/knl/loaders/Elf/ElfLoader.c
    *** DM8168VPSSM3PROC_translate: srcAddr not found in slave address space
            Error [0x86a85001] at Line no: 1475 in file /home/phoong/work/netra/dvr/sdk_5011/syslink_02_00_00_67/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/family/hlos/knl/ti81xx/ti81xxducati/ti81xxvpssm3/Dm8168M3DssProc.c
    I just put tstEncoder on the TI DVR RDK release and  it hung at " AVSERVER UI: Starting Streaming Server...DONE", the seem as in my rootfs.
    The rtsp server can run now, but tstEncoder is hunged.
     According the trace tstEncoder was hung in 00.07.00.01/dvr/app/src/omx_il_tunnel.c function: omx_ilclient_connect_VFPCSC_VFDC() @ line 974;
    eError = OMX_SendCommand ( pContext->hVFDC[H_VFDC_PB_OFFSET], OMX_CommandPortEnable, nVFDCPortIndex, NULL );
     The function call maybe like this:
              DVR_StartSystem()
                 \___ omx_ilclient_connect_VFPCSC_VFDC()
                            \___ OMX_SendCommand () ==>hunged here.
    Maybe the normal following  prcoss will proble kernel module ti8x6x_fb.ko and vpss.ko. But it is hunged here. Any idiea?
    Did you check the standard DVR RDK application? Was that also giving the same problem? If yes, then we can debug from that direction.
    Anshuman
    I check the standard DVR RDK application using nfs ../target/rfs. When I run tstEncoder under it, tstEncoder is still hunged at "AVSERVER UI: Starting Streaming Server...DONE". But "dvrmain"  can come to "app: lib816x_statsystem ... done".
    We just want to check RTSP and Encoder in DVR reference. Is my test method using tstEncoder is wrong? Can you give some advice for this? Log and /opt/netra/start.sh as following.
    Log:
    root@dvr:~# cat /opt/netra/start.sh
    #! /bin/sh
    export LD_LIBRARY_PATH=/usr/lib
    export QT_QWS_FONTDIR=/usr/lib/fonts
    if [ ! -e ./app_m3video.xem3 ]; then
            echo "not found app_m3video.xem3"
            exit 0
    fi
    if [ ! -e ./app_m3vpss.xem3 ]; then
            echo "not found app_m3vpss.xem3"
            exit 0
    fi
    ./tstEncoder&
    if [ -x ./dvrmain ]; then
    #       ./dvrmain -qws hdmi ntsc &
    #       ./dvrmain -qws hdmi pal &
    #       ./dvrmain -qws vga ntsc &
    #       ./dvrmain -qws vga pal &
    else
            echo "not found dvrmain"
    fi
    INIT: version 2.86 booting
    Error opening /dev/fb0: No such file or directory
    Please wait: booting...
    Starting udev
    udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead.
    udev: starting version 141
    udev: renamed network interface eth1 to eth3
    udevd-event[122]: error changing netif name eth0 to eth2: Device or resource busy
    Root filesystem already rw, not remounting
    Caching udev devnodes
    Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
    ALSA: Restoring mixer settings...
    NOT configuring network interfaces: / is an NFS mount
    No state is present for card DVR
    Found hardware: "" "" "" "" ""
    Hardware is initialized using a generic method
    INIT: Entering runlevel: 5
    Starting system message bus: dbus.
    Starting telnet daemon.
    Starting syslogd/klogd: NET: Registered protocol family 10
    done
    Starting thttpd.
    traceMask value: 0x0
    start application
    ./start.sh: line 22: syntax error: "else" unexpected
    tstEncoder 00:23:54
     _   _ ___  _   _         _
    | | | |    | ||| |___ ___| | _ ___
    | |_| | |) |  ~  | . |  _| |/_|  -|
    |_____|___ /____/ ___|_| |_| _|-__|
    DVR_Netra Board (2011.04)
    dvr login: Entering: OMX_TI_CMUX_ComponentInit
    NetraDrvInit: 2
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8556/h264_ch6
    NetraDrvInit: 10
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8555/h264_ch5
    NetraDrvInit: 9
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8554/h264_ch4
    NetraDrvInit: 8
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8553/h264_ch3
    NetraDrvInit: 6
    queue id:0
    Initializing...
    NetraDrvInit: 2
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8551/h264_ch1
    NetraDrvInit: 2
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8557/h264_ch7
    NetraDrvInit: 6
    queue id:0
    Initializing...
            rtsp://10.51.252.76:8558/h264_ch8
            rtsp://10.51.252.76:8552/h264_ch2
     _   _ ___  _   _         _
    dvr login: root
    /opt/netra/app_m3video.xem3  /opt/netra/skin/
    /opt/netra/app_m3vpss.xem3   /opt/netra/start.sh
    /opt/netra/dvrmain           /opt/netra/tstEncoder
    /opt/netra/prep-sdd.sh       /opt/netra/wis-streamer
    root@dvr:~#
  • The root cause of tstEncoder hunged at "AVSERVER UI: Starting Streaming Server...DONE" maybe the code of tstEncoder.c line 292 of 00.07.00.01.
       288  int main(void)
       289  {
       290          printf("tstEncoder %s\n",__TIME__);
       291
       292          LIB816x_startSystem(0, 2);   --> The wrong val.
       293          testThread();
       294
       295          return 0;
       296  }
    According the video source(PAL) we use,  modify LIB816x_startSystem(2, 0). tstEncoder runs ok now.
    Good catch. Yes, the PAL input mode is supported as input selection only on the dvrmain application. For the test applications, it was assumed to have NTSC input.
    But did you mention that your dvrmain application was also not working. That is strange, if you selected PAL input in start.sh script.
    Anshuman
