Part Number: TMS320C6657
Hello ,
I need some assistance to configure MSI interruption between RC and EPP (evm : tms320c6657).
Thank you
Hello ,
Thank you
Once you install, PROCESSOR-SDK-RTOS-C665x 06_03_00_106
http://software-dl.ti.com/processor-sdk-rtos/esd/C665x/latest/index_FDS.html
in PDK package, in the file pcie.c, the configuration of MSI interrupts and other MSI functions are given.
File location : C:\ti\pdk_c665x_2_0_16\packages\ti\csl\src\ip\pcie\V1\priv
void PCIEMsiMailboxConfig(uint32_t baseAddr,
const pcieLocationParams_t *locationParams,
const pcieMsiMailboxParams_t *msiMailboxParams)
uint32_t cfgAddr;
if (PCIE_DEVICE_TYPE_RC == PCIEGetDeviceType(baseAddr))
if (PCIE_LOCATION_LOCAL == locationParams->location)
/* Configure local MSI mail box lower address. */
cfgAddr = baseAddr + PCIECTRL_PL_OFFSET +
PCIECTRL_PL_MSI_CTRL_ADDRESS;
HW_WR_REG32(cfgAddr, msiMailboxParams->lowerAddr);
/* Configure local MSI mail box upper address. */
PCIECTRL_PL_MSI_CTRL_UPPER_ADDRESS;
HW_WR_REG32(cfgAddr, msiMailboxParams->upperAddr);
else
/* Get outbound remote configuration space. */
if ((uint32_t) SOC_PCIE_SS1_CONF_BASE == baseAddr)
cfgAddr = (uint32_t) SOC_PCIE_SS1_DAT_BASE +
locationParams->outboundCfgOffset +
PCIECTRL_EP_PCIEWIRE_OFFSET;
else
cfgAddr = (uint32_t) SOC_PCIE_SS2_DAT_BASE +
/* Configure Remote MSI descriptor lower address. */
HW_WR_REG32(
cfgAddr + PCIECTRL_EP_PCIEWIRE_MSI_ADDR_L32,
/* Configure Remote MSI descriptor upper address. */
HW_WR_REG32(
cfgAddr + PCIECTRL_EP_PCIEWIRE_MSI_ADDR_U32,
/* Configure Remote MSI descriptor data. */
HW_WR_REG32(
cfgAddr + PCIECTRL_EP_PCIEWIRE_MSI_DATA,
msiMailboxParams->data);
else
cfgAddr = baseAddr + PCIECTRL_EP_DBICS_OFFSET +
PCIECTRL_EP_DBICS_MSI_ADDR_L32;
PCIECTRL_EP_DBICS_MSI_ADDR_U32;
/* Configure local MSI mail box Data. */
PCIECTRL_EP_DBICS_MSI_DATA;
HW_WR_REG32(cfgAddr, msiMailboxParams->data);
void PCIEMsiCtrl(uint32_t baseAddr,
const pcieMsiCtrlParams_t *msiCtrlParams)
uint32_t regVal;
uint32_t cfgAddr;
/* Configure local MSI capabilities. */
cfgAddr = baseAddr + PCIECTRL_RC_DBICS_OFFSET +
PCIECTRL_RC_DBICS_MSI_CAP;
regVal = HW_RD_REG32(cfgAddr);
/* Enable or disable 64 bit MSI generation. */
HW_SET_FIELD32(
regVal,
PCIECTRL_RC_DBICS_MSI_CAP_MSI_64_EN,
msiCtrlParams->enable64Bit);
/* Enable or disable multiple msg capability. */
HW_SET_FIELD32(
regVal,
PCIECTRL_RC_DBICS_MSI_CAP_MME,
msiCtrlParams->enableMultiMsg);
/* Enable or disable MSI generation. */
HW_SET_FIELD32(
regVal,
PCIECTRL_RC_DBICS_MSI_CAP_MSI_EN,
msiCtrlParams->enableMsi);
HW_WR_REG32(cfgAddr, regVal);
else
PCIECTRL_EP_PCIEWIRE_OFFSET +
PCIECTRL_EP_PCIEWIRE_MSI_CAP;
else
HW_SET_FIELD32(
regVal,
PCIECTRL_EP_PCIEWIRE_MSI_CAP_MSI_64_EN,
HW_SET_FIELD32(
regVal,
PCIECTRL_EP_PCIEWIRE_MSI_CAP_MME,
HW_SET_FIELD32(
regVal,
PCIECTRL_EP_PCIEWIRE_MSI_CAP_MSI_EN,
else
PCIECTRL_EP_DBICS_MSI_CAP;
HW_SET_FIELD32(
regVal,
PCIECTRL_EP_DBICS_MSI_CAP_MSI_64_EN,
HW_SET_FIELD32(
regVal,
PCIECTRL_EP_DBICS_MSI_CAP_MME,
HW_SET_FIELD32(
regVal,
PCIECTRL_EP_DBICS_MSI_CAP_MSI_EN,
void PCIEMsiIntrCtrl(uint32_t baseAddr,
uint32_t msiIntrNum,
uint32_t msiIntrGroup,
uint32_t enableMsiIntr)
uint32_t regVal;
uint32_t cfgAddr;
/* Enable or disable MSI interrupt. */
PCIECTRL_PL_MSI_CTRL_INT_ENABLE(msiIntrGroup);
if (TRUE == enableMsiIntr)
regVal |= ((uint32_t) 1U << msiIntrNum);
else
regVal &= (~((uint32_t) 1U << msiIntrNum));
uint32_t PCIEMsiActiveIntrStatus(uint32_t baseAddr, uint32_t msiIntrGroup)
return HW_RD_REG32(
PCIECTRL_PL_MSI_CTRL_INT_STATUS(msiIntrGroup));
void PCIEMsiActiveIntrClear(uint32_t baseAddr,
uint32_t intrMask)
HW_WR_REG32(
PCIECTRL_PL_MSI_CTRL_INT_STATUS(msiIntrGroup),
intrMask);
void PCIEMsiTransmit(uint32_t baseAddr,
pcieMsiIntrType_t msiType,
uint32_t msiOutboundCfgSpace)
uint32_t regVal;
uint32_t msiData;
uint32_t cfgAddr;
/* Get MSI data. */
msiData = HW_RD_REG32(
PCIECTRL_EP_DBICS_MSI_DATA);
if (PCIE_MSI_INTR_TYPE_HW == msiType)
/* Configure MSI data to be written into XMT register. */
regVal =
((msiData <<
PCIECTRL_TI_CONF_MSI_XMT_VECTOR_SHIFT) &
PCIECTRL_TI_CONF_MSI_XMT_VECTOR_MASK);
regVal |=
((uint32_t) PCIECTRL_TI_CONF_MSI_XMT_REQ_GRANT <<
PCIECTRL_TI_CONF_MSI_XMT_REQ_GRANT_SHIFT);
/* Grant MSI request. */
HW_WR_REG32(
baseAddr + PCIECTRL_TI_CONF_OFFSET + PCIECTRL_TI_CONF_MSI_XMT,
regVal);
/* Wait till MSI request is granted. */
do
PCIECTRL_TI_CONF_MSI_XMT) &
PCIECTRL_TI_CONF_MSI_XMT_REQ_GRANT_MASK;
} while (PCIECTRL_TI_CONF_MSI_XMT_REQ_GRANT_PENDING == regVal);
else
cfgAddr = (uint32_t) SOC_PCIE_SS1_DAT_BASE + msiOutboundCfgSpace;
else
cfgAddr = (uint32_t) SOC_PCIE_SS2_DAT_BASE + msiOutboundCfgSpace;
HW_WR_REG32(cfgAddr, msiData);
Shankari G
