Automated executable load and run in C6713
I am trying to do some automated tests on C6713 DSP. I have a lot of projects and will try to process following for each projects:
- Build Project
- Load and Run Executable
- Retrieve Results
As far i can do building automatically from MS command line. I use DSK6713HPI daughtercard RS232 interface to retrieve test results. However i cannot load executable file on target.
I think there is no command in the Code Composer related with uploading and running "out" files. So I have tried win6DSK (http://www.educationaldsp.com/stockproduct_dsk6xxxhpi.htm#downloads) with DSK6713HPI daughtercard on the DSK also i have tried to update and run  C6X_CONTROL application. With the daughtercard applications i could manage to run any "out" files. However this time problems occur related my RS232 connection.
If you have any experience related with my problem, i would be glad for your helps.
Omer
