AM6421: AM6421 sbl_qspi code or prebuild binary not present in SDK.
Part Number: AM6421
We have designed custom board with QSPI flash. We need sbl_qspi image for running firmware.
  • Hi Nikhil,
    There is no SBL_QSPI bootloader in the MCU+ SDK. Instead, the already present SBL_OSPI can be modified to work for your custom QSPI flash. You will need to only change the flash configuration in the Sysconfig file according to your flash datasheet. Then, the SBL_OSPI should be able to boot an application from the custom QSPI flash.
    Prashant
