Hi, I'm WOONG HEE KO.
I have a problem with IPC of MCU+SDK 09.01.00.
In this version, the enviorment recommend that the user installs and uses sysconfig 1.18 and ccs 12.5. So I have installed those utils.
problem: auto-generated file('ti_drivers_config') by IPC has a problem as below.
The example ($SDK_ROOT\examples\drivers\ipc\ipc_rpmsg_echo\am64x-evm\r5fss0-0_freertos) has a same problem.
My questions:
1) I can't modify auto-generated file by using ipc driver, so how to fix it?
2) The problem is a bug or Should I change the settings of sysconfig?
3) I used ind_comms_sdk_am64x_09_00_00_03 and mcu_plus_sdk_am64x_09_01_00_41 both. It's ok to I used them?
