TDA4VM: The secure boot stress test may encounter a freeze issue.
Part Number: TDA4VM
Hi Ti,
    I have encountered a freezing issue during the testing of the secure boot process. Upon multiple power cycles, the system freezes at a certain point.
   Device Type: HS-SE SR1.1
   SDK Version: 08_06_00_12
Test Procedure:
  1. Compile SBL
    Target compilation is sbl_cust_img_hs.
  2. Compile and obtain can boot app
    The path for obtaining can boot app is mcusw/binary/can_boot_app_mcu_rtos/bin/j721e_evm.
  3. Obtain the image for A72 core.
    The path for obtaining the image is pdk_jacinto_08_06_00_31/packages/ti/boot/sbl/tools/BootApp_binaries/linux/j721e_evm_hs.
  4. Invoke the script to generate lateapp1/lateapp2.
    The path for generating images is pdk_jacinto_08_06_00_31/packages/ti/boot/sbl/example/boot_app/multicore_images/j721e_evm.
  5. Obtain TIFS.
    The path for obtaining TIFS is pdk_jacinto_08_06_00_31/packages/ti/drv/sciclient/soc/V1.
  6. Obtain nor_spi_patterns.bin.
    The path for obtaining nor_spi_patterns.bin is packages/ti/board/src/flash/nor/ospi/nor_spi_patterns.bin.
  7. Flash the above images into the memory.
  8. Switch the boot mode to ospi flash boot; conduct multiple power cycles. It is observed that sporadically, the SBL freezes with no LOG output, and after a period of freeze, it automatically resets.
Notes:
    No modifications have been made to the code; native TI images are used.
Issues:
  1. Why does the freezing phenomenon occur, and have you conducted stress tests for secure boot on your end? Please assist in resolving this issue.
  2. Please help replicate and resolve the issue through the same testing.
  3. Have you conducted stress testing for secure boot on your end? Can you provide a stress test report for secure boot?
This issue is relatively urgent, so please provide assistance as soon as possible.
