Part Number: AM625
My customer wants to change u-boot serial output from UART0(SDK default) to UART6.
They changed device tree as below, but it does not work properly. File names (*.dtsi) are changed to *.txt.
// SPDX-License-Identifier: GPL-2.0
* Common AM62x SK dts file for SPLs
* Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
chosen {
stdout-path = "serial2:115200n8";
tick-timer = &timer1;
aliases {
mmc0 = &sdhci0;
mmc1 = &sdhci1;
memory@80000000 {
u-boot,dm-spl;
&cbass_main{
u-boot,dm-spl;
timer1: timer@2400000 {
compatible = "ti,omap5430-timer";
reg = <0x00 0x2400000 0x00 0x80>;
ti,timer-alwon;
clock-frequency = <25000000>;
u-boot,dm-spl;
&dmss {
u-boot,dm-spl;
&secure_proxy_main {
u-boot,dm-spl;
&dmsc {
u-boot,dm-spl;
&k3_pds {
u-boot,dm-spl;
&k3_clks {
u-boot,dm-spl;
&k3_reset {
u-boot,dm-spl;
&wkup_conf {
u-boot,dm-spl;
&chipid {
u-boot,dm-spl;
&main_pmx0 {
u-boot,dm-spl;
&main_uart6 {
u-boot,dm-spl;
&main_uart6_pins_default {
u-boot,dm-spl;
&main_uart1 {
u-boot,dm-spl;
&cbass_mcu {
u-boot,dm-spl;
&cbass_wakeup {
u-boot,dm-spl;
&mcu_pmx0 {
u-boot,dm-spl;
&wkup_uart0 {
u-boot,dm-spl;
&main_i2c0 {
u-boot,dm-spl;
&main_i2c0_pins_default {
u-boot,dm-spl;
&sdhci0 {
u-boot,dm-spl;
&sdhci1 {
u-boot,dm-spl;
&main_mmc1_pins_default {
u-boot,dm-spl;
&usbss0 {
u-boot,dm-spl;
&usb0 {
dr_mode = "peripheral";
/* Since role switching is not supported in U-Boot */
/delete-property/ extcon;
u-boot,dm-spl;
&usbss1 {
u-boot,dm-spl;
&usb1 {
u-boot,dm-spl;
&main_usb1_pins_default {
u-boot,dm-spl;
&cpsw3g {
reg = <0x0 0x8000000 0x0 0x200000>,
<0x0 0x43000200 0x0 0x8>;
reg-names = "cpsw_nuss", "mac_efuse";
/delete-property/ ranges;
u-boot,dm-spl;
cpsw-phy-sel@04044 {
compatible = "ti,am64-phy-gmii-sel";
reg = <0x0 0x00104044 0x0 0x8>;
u-boot,dm-spl;
&cpsw_port2 {
status = "disabled";
&main_bcdma {
u-boot,dm-spl;
&main_pktdma {
u-boot,dm-spl;
&fss {
u-boot,dm-spl;
&ospi0_pins_default {
u-boot,dm-spl;
&cpsw_port1 {
u-boot,dm-spl;
&main_rgmii1_pins_default {
u-boot,dm-spl;
&main_mdio1_pins_default {
u-boot,dm-spl;
&cpsw3g_phy0 {
u-boot,dm-spl;
&dmsc {
u-boot,dm-spl;
k3_sysreset: sysreset-controller {
compatible = "ti,sci-sysreset";
u-boot,dm-spl;
* Common dtsi for AM62x SK and derivatives
/dts-v1/;
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include "k3-am625.dtsi"
aliases {
serial2 = &main_uart6;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
usb0 = &usb0;
usb1 = &usb1;
spi0 = &ospi0;
remoteproc0 = &mcu_m4fss;
chosen {
bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
memory@80000000 {
device_type = "memory";
/* 2G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
compatible = "shared-dma-pool";
reg = <0x00 0x9cb00000 0x00 0x100000>;
no-map;
mcu_m4fss_memory_region: m4f-memory@9cc00000 {
reg = <0x00 0x9cc00000 0x00 0xe00000>;
no-map;
secure_tfa_ddr: tfa@9e780000 {
reg = <0x00 0x9e780000 0x00 0x80000>;
alignment = <0x1000>;
no-map;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
no-map;
wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 {
reg = <0x00 0x9db00000 0x00 0xc00000>;
no-map;
vmain_pd: regulator-0 {
/* TPS65988 PD CONTROLLER OUTPUT */
compatible = "regulator-fixed";
regulator-name = "vmain_pd";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-always-on;
regulator-boot-on;
vcc_5v0: regulator-1 {
/* Output of LM34936 */
regulator-name = "vcc_5v0";
vin-supply = <&vmain_pd>;
regulator-boot-on;
vcc_3v3_sys: regulator-2 {
/* output of LM61460-Q1 */
regulator-name = "vcc_3v3_sys";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vdd_mmc1: fixed-regulator-sd {
/* TPS22918DBVR */
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vcc_3v3_sys>;
gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
vdd_sd_dv: gpio-regulator-TLV71033 {
/* Output of TLV71033 */
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-names = "default";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vcc_5v0>;
gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
leds {
compatible = "gpio-leds";
pinctrl-0 = <&usr_led_pins_default>;
led-0 {
label = "am62-sk:green:heartbeat";
gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
function = LED_FUNCTION_HEARTBEAT;
default-state = "off";
extcon_usb0: extcon-usb0 {
compatible = "linux,extcon-usb-gpio";
id-gpios = <&main_gpio1 50 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&extcon_usb0_gpio_id_pins_default>;
&main_pmx0 {
main_uart0_pins_default: main-uart0-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
main_uart6_pins_default: main-uart6-pins-default {
AM62X_IOPAD(0x01c, PIN_INPUT, 3)
AM62X_IOPAD(0x020, PIN_OUTPUT, 3)
main_i2c0_pins_default: main-i2c0-pins-default {
AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */
AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */
main_i2c1_pins_default: main-i2c1-pins-default {
AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */
AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */
main_i2c2_pins_default: main-i2c2-pins-default {
AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */
AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */
main_mmc0_pins_default: main-mmc0-pins-default {
AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */
AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */
AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */
AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */
AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */
AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */
AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */
AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */
AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */
AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */
main_mmc1_pins_default: main-mmc1-pins-default {
AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */
AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */
AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */
AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */
AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */
AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */
AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */
usr_led_pins_default: usr-led-pins-default {
AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */
main_mdio1_pins_default: main-mdio1-pins-default {
AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */
AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */
main_rgmii1_pins_default: main-rgmii1-pins-default {
AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */
AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */
AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */
AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */
AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */
AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */
AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */
AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */
AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */
AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */
AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */
AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */
main_rgmii2_pins_default: main-rgmii2-pins-default {
AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */
AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */
AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */
AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */
AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */
AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */
AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */
AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */
AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */
AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */
AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */
AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */
vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
AM62X_IOPAD(0x07c, PIN_OUTPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */
extcon_usb0_gpio_id_pins_default: extcon-usb0-gpio-id-pins-default {
AM62X_IOPAD(0x254, PIN_INPUT_PULLUP, 7) /* (C20) USB0_DRVVBUS.GPIO1_50 */
main_usb1_pins_default: main-usb1-pins-default {
AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */
ospi0_pins_default: ospi0-pins-default {
AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */
AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */
AM62X_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */
AM62X_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */
AM62X_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */
AM62X_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */
AM62X_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */
AM62X_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */
AM62X_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */
AM62X_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */
AM62X_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */
&wkup_uart0 {
/* WKUP UART0 is used by DM firmware */
status = "reserved";
&mcu_uart0 {
&main_uart0 {
pinctrl-0 = <&main_uart0_pins_default>;
&main_uart1 {
/* Main UART1 is used by TIFS firmware */
&main_uart2 {
&main_uart3 {
&main_uart4 {
&main_uart5 {
&main_uart6 {
pinctrl-0 = <&main_uart6_pins_default>;
&mcu_i2c0 {
&wkup_i2c0 {
&main_i2c0 {
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
&main_i2c1 {
pinctrl-0 = <&main_i2c1_pins_default>;
exp1: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "GPIO_CPSW2_RST", "GPIO_CPSW1_RST",
"PRU_DETECT", "MMC1_SD_EN",
"VPP_LDO_EN", "EXP_PS_3V3_En",
"EXP_PS_5V0_En", "EXP_HAT_DETECT",
"GPIO_AUD_RSTn", "GPIO_eMMC_RSTn",
"UART1_FET_BUF_EN", "WL_LT_EN",
"GPIO_HDMI_RSTn", "CSI_GPIO1",
"CSI_GPIO2", "PRU_3V3_EN",
"HDMI_INTn", "TEST_GPIO2",
"MCASP1_FET_EN", "MCASP1_BUF_BT_EN",
"MCASP1_FET_SEL", "UART1_FET_SEL",
"TSINT#", "IO_EXP_TEST_LED";
&main_i2c2 {
&main_i2c3 {
&sdhci0 {
pinctrl-0 = <&main_mmc0_pins_default>;
ti,driver-strength-ohm = <50>;
disable-wp;
&sdhci1 {
/* SD/MMC */
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
&usbss0 {
ti,vbus-divider;
&usb0 {
extcon = <&extcon_usb0>;
&usb1 {
dr_mode = "host";
pinctrl-0 = <&main_usb1_pins_default>;
&cpsw3g {
pinctrl-0 = <&main_mdio1_pins_default
&main_rgmii2_pins_default>;
&cpsw_port1 {
phy-mode = "rgmii-rxid";
phy-handle = <&cpsw3g_phy0>;
&cpsw3g_mdio {
cpsw3g_phy0: ethernet-phy@0 {
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
&mailbox0_cluster0 {
mbox_m4_0: mbox-m4-0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
&ospi0 {
pinctrl-0 = <&ospi0_pins_default>;
Are there anything missed?
Thanks and regards,
Koichiro Tashiro
