TDA4VM: Possible ways to Keep TDA4VM keep alive when the Key Switch is OFF
Part Number: TDA4VM
As per one of the Client Requirements to wakeup the ECU,
  • The Real Time Clock asserts an output that starts the main supply  --> Is this possible to keep MCU energized when Key Switch is Off , If suppose the RTC have the capability to have an alarm function to wake up the ECU. The ECU shall awaken based on this alarm when key switch is off.
    • If yes how this will be routed to TDA4VM ? Please provide Pin/Port map
  • Buss activity on the RS-232 port determined by the DCD line  -->  How this would be possible, is there be a Pin mapping when ECU is wakeup by ( I2c/CAN signal ?)
  • Jyoti,
    I think this is a system-level question. The SoC does not directly respond to the Key Switch.
    In a real system, I assume that this Key Switch is a signal with which you power down the system...
    TDA4VM is NOT optimized for low power modes, and so it could make sense to delay the turn-off of the SoC, but it is probably not likely that you would want to keep the SoC power indefinitely.
    Kevin
