PROCESSOR-SDK-J721E: CPSW9G integration with QNX 7.1
Part Number: PROCESSOR-SDK-J721E
Other Parts Discussed in Thread: TDA4VM
I am trying to integrate CPSW9G in QNX (7.1) for SK board.
When I run the command to install the driver, below is the error message I am getting.
# io-pkt-v6-hc -d cpsw9g
# Jan 01 00:08:44.183 iopkt.233499 0 -----ONLINE-----
Jan 01 00:08:44.184 iopkt.233499 main_buffer* 0 tcpip starting
Jan 01 00:08:44.184 iopkt.233499 main_buffer 0 smmu support is disabled
Jan 01 00:08:44.185 iopkt.233499 main_buffer 0 initializing IPsec...
Jan 01 00:08:44.185 iopkt.233499 main_buffer 0 done
Jan 01 00:08:44.185 iopkt.233499 main_buffer 0 IPsec: Initialized Security Association Processing.
Jan 01 00:08:44.193 io_pkt_v6_hc.233499 0 -----ONLINE-----
Jan 01 00:08:44.193 iopkt.233499 main_buffer 0 devnp-cpsw9g.so (null)
Jan 01 00:08:44.194 iopkt.233499 main_buffer 0 an0
Jan 01 00:08:44.194 io_pkt_v6_hc.233499 slog* 0 cpsw_entry:546 Entry -->
Jan 01 00:08:44.194 io_pkt_v6_hc.233499 slog 0 cpsw_attach:720 Entry -->
Jan 01 00:08:44.194 io_pkt_v6_hc.233499 slog 0 CPSW9G Client (core : mpu1_0) .....
Jan 01 00:08:44.195 io_pkt_v6_hc.233499 slog 0 appRemoteDeviceInitFn(5) has started!
Jan 01 00:08:44.197 io_pkt_v6_hc.233499 slog 0 Remote device (core : mpu1_0) .....
Jan 01 00:08:44.198 iopkt.233499 main_buffer 0 Unable to init devnp-cpsw9g.so: No such device
Jan 01 00:08:44.198 io_pkt_v6_hc.233499 slog 0 Remote Device Framework Endpoint locate failed. Retrying !!!
Jan 01 00:08:44.198 io_pkt_v6_hc.233499 slog 0 EnetIf_RemoteAttach:392 Error: CpswProxy_connect failed
Jan 01 00:08:44.198 io_pkt_v6_hc.233499 slog 0 cpsw_attach:929 Error: EnetIf_RemoteAttach failed
But by following the same process I am able to install the cpsw2g driver without any issue.
Please let me know if I am missing anything.
Note: I can see the devnp-cpsw9g.so file in /proc/boot/devnp-cpsw9g.so
