Here is a shell script with menu for executing gfx tests to make life easier.. GraphicsSDK.
#!/bin/bash
# A menu driven Shell script which has following options
while :
do
 clear
 echo "1.gles1test1"
 echo "2.gles1_texture_stream"
 echo "3.gles2test1"
 echo "4.gles2_texture_stream"
 echo "5.ovg_unit_test"
 echo "6.pvr2d_test"
 echo "7.services_test"
 echo "8.sgx_blit_test"
 echo "9.sgx_clipblit_test"
 echo "10.sgx_flip_test"
 echo "11.sgx_init_test"
 echo "12.sgx_render_flip_test"
 echo "13.xgles1test1"
 echo "14.xgles1_texture_stream"
 echo "15.xgles2test1"
 echo "16.xgles2_texture_stream"
 echo "17.xmultiegltest"
 echo "18.xovg_unit_test"
 echo "19.Refresh Display :0 and exit"
 echo "20.exit"
 echo -n "Please enter option [1 - 20]"
 read opt
 case $opt in
  1) echo "************ 1.gles1test1 *************";
     gles1test1;;
  2) echo "*********** 2.gles1_texture_stream*****";
     gles1_texture_stream;;
  3) echo "***********3.gles2test1****************";
     gles2test1;;
  4) echo "***********4.gles2_texture_stream******";
     gles2_texture_stream;;
  5) echo "***********5.ovg_unit_test*************";
     ovg_unit_test;;
  6) echo "***********6.pvr2d_test****************";
     pvr2d_test;;
  7) echo "***********7.services_test*************";
     services_test;;
  8) echo "***********8.sgx_blit_test*************";
     sgx_blit_test;;
  9) echo "***********9.sgx_clipblit_test*********";
     sgx_clipblit_test;;
  10) echo "**********10.sgx_flip_test************";
     sgx_flip_test;;
  11) echo "**********11.sgx_init_test************";
     sgx_init_test;;
  12) echo "**********12.sgx_render_flip_test*****";
     sgx_render_flip_test;;
  13) echo "**********13.xgles1test1**************";
     xgles1test1;;
  14) echo "**********14.xgles1_texture_stream****";
     xgles1_texture_stream;;
  15) echo "**********15.xgles2test1**************";
     xgles2test1;;
  16) echo "**********16.xgles2_texture_stream****";
     xgles2_texture_stream;;
  17) echo "**********17.xmultiegltest************";
     xmultiegltest;;
  18) echo "**********18.xovg_unit_test***********";
     xovg_unit_test;;
  19) echo "*****19.Refresh Display :0 and exit***";
    xrefresh -d :0
     exit 1;;
  20) echo "Bye $USER";
     exit 1;;
  *) echo "$opt is an invaild option. Please select option between 1-4 only";
     echo "Press [enter] key to continue. . .";
     read enterKey;;
esac
done
