How to build the SBL image of am62a7 in SDK9.1?
Please refer to the following generic guides
For reference, following is the build of SBL_NULL
~/ti/mcu_plus_sdk/am62a 09.01.00.39 ❯ make -s -C examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang all Generating SysConfig files ... Running script... Validating... Generating Code (example.syscfg)... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_dpl_config.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_dpl_config.h... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_config.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_config.h... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_open_close.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_open_close.h... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_pinmux_config.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_power_clock_config.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_config.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_config.h... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_open_close.c... Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_open_close.h... Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: ../main.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_drivers_config.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_drivers_open_close.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_board_config.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_board_open_close.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_dpl_config.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_pinmux_config.c Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_power_clock_config.c . Linking: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out ... Linking: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out Done !!! . Boot image: am62ax:r5fss0-0:nortos:ti-arm-clang /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/sbl_null.release.tiimage ... Boot image: am62ax:r5fss0-0:nortos:ti-arm-clang /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/sbl_null.release.tiimage Done !!! Boot image: am62ax:r5fss0-0:nortos:ti-arm-clang /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/sbl_null.release.hs_fs.tiimage Done !!! .
Prashant
